[petsc-users] conflict between petsc.h90 and MPI_INT, MPI_SUM etc...
Timothée Nicolas timothee.nicolas at gmail.com
Tue Jan 31 10:08:06 CST 2017
Dear all,
I am a bit confused as to how to link PETSc correctly in a code that
already uses MPI natively. I wish to define a DMDA for my problem, but when
I try to include petsc.h90, the compiler complains that MPI_XXXXX variables
are already defined:
/cm/shared/apps/mpich/ge/intel/3.2/include/mpif.h(9): error #6401: The
attributes of this name conflict with those made accessible by a USE
statement.   [MPI_SOURCE]
       INTEGER MPI_SOURCE, MPI_TAG, MPI_ERROR
statement.   [MPI_TAG]
statement.   [MPI_ERROR]
/cm/shared/apps/mpich/ge/intel/3.2/include/mpif.h(11): error #6401: The
statement.   [MPI_STATUS_SIZE]
       INTEGER MPI_STATUS_SIZE
/cm/shared/apps/mpich/ge/intel/3.2/include/mpif.h(13): error #6401: The
statement.   [MPI_STATUS_IGNORE]
       INTEGER MPI_STATUS_IGNORE(MPI_STATUS_SIZE)
/cm/shared/apps/mpich/ge/intel/3.2/include/mpif.h(14): error #6401: The
statement.   [MPI_STATUSES_IGNORE]
       INTEGER MPI_STATUSES_IGNORE(MPI_STATUS_SIZE,1)
/cm/shared/apps/mpich/ge/intel/3.2/include/mpif.h(15): error #6401: The
statement.   [MPI_ERRCODES_IGNORE]
       INTEGER MPI_ERRCODES_IGNORE(1)
/cm/shared/apps/mpich/ge/intel/3.2/include/mpif.h(16): error #6401: The
statement.   [MPI_ARGVS_NULL]
       CHARACTER*1 MPI_ARGVS_NULL(1,1)
/cm/shared/apps/mpich/ge/intel/3.2/include/mpif.h(17): error #6401: The
statement.   [MPI_ARGV_NULL]
       CHARACTER*1 MPI_ARGV_NULL(1)
/cm/shared/apps/mpich/ge/intel/3.2/include/mpif.h(18): error #6401: The
statement.   [MPI_SUCCESS]
       INTEGER MPI_SUCCESS
/cm/shared/apps/mpich/ge/intel/3.2/include/mpif.h(20): error #6401: The
statement.   [MPI_ERR_SIZE]
       INTEGER MPI_ERR_SIZE
/cm/shared/apps/mpich/ge/intel/3.2/include/mpif.h(22): error #6401: The
statement.   [MPI_ERR_INFO_KEY]
       INTEGER MPI_ERR_INFO_KEY
/cm/shared/apps/mpich/ge/intel/3.2/include/mpif.h(24): error #6401: The
statement.   [MPI_ERR_FILE]
       INTEGER MPI_ERR_FILE
/cm/shared/apps/mpich/ge/intel/3.2/include/mpif.h(26): error #6401: The
statement.   [MPI_ERR_AMODE]
       INTEGER MPI_ERR_AMODE
/cm/shared/apps/mpich/ge/intel/3.2/include/mpif.h(28): error #6401: The
statement.   [MPI_ERR_TRUNCATE]
       INTEGER MPI_ERR_TRUNCATE
/cm/shared/apps/mpich/ge/intel/3.2/include/mpif.h(30): error #6401: The
statement.   [MPI_ERR_BASE]
       INTEGER MPI_ERR_BASE
/cm/shared/apps/mpich/ge/intel/3.2/include/mpif.h(32): error #6401: The
statement.   [MPI_ERR_OP]
       INTEGER MPI_ERR_OP
/cm/shared/apps/mpich/ge/intel/3.2/include/mpif.h(34): error #6401: The
statement.   [MPI_ERR_ASSERT]
       INTEGER MPI_ERR_ASSERT
/cm/shared/apps/mpich/ge/intel/3.2/include/mpif.h(36): error #6401: The
statement.   [MPI_ERR_NAME]
       INTEGER MPI_ERR_NAME
/cm/shared/apps/mpich/ge/intel/3.2/include/mpif.h(38): error #6401: The
statement.   [MPI_ERR_NO_MEM]
       INTEGER MPI_ERR_NO_MEM
/cm/shared/apps/mpich/ge/intel/3.2/include/mpif.h(40): error #6401: The
statement.   [MPI_ERR_INFO]
/cm/shared/apps/mpich/ge/intel/3.2/include/mpif.h(42): error #6401: The
statement.   [MPI_ERR_COUNT]
       INTEGER MPI_ERR_COUNT
/cm/shared/apps/mpich/ge/intel/3.2/include/mpif.h(44): error #6401: The
statement.   [MPI_ERR_SPAWN]
       INTEGER MPI_ERR_SPAWN
/cm/shared/apps/mpich/ge/intel/3.2/include/mpif.h(46): error #6401: The
statement.   [MPI_ERR_CONVERSION]
       INTEGER MPI_ERR_CONVERSION
/cm/shared/apps/mpich/ge/intel/3.2/include/mpif.h(48): error #6401: The
statement.   [MPI_ERR_GROUP]
       INTEGER MPI_ERR_GROUP
/cm/shared/apps/mpich/ge/intel/3.2/include/mpif.h(50): error #6401: The
statement.   [MPI_ERR_RMA_SYNC]
       INTEGER MPI_ERR_RMA_SYNC
/cm/shared/apps/mpich/ge/intel/3.2/include/mpif.h(52): error #6401: The
statement.   [MPI_ERR_NOT_SAME]
       INTEGER MPI_ERR_NOT_SAME
/cm/shared/apps/mpich/ge/intel/3.2/include/mpif.h(54): error #6401: The
statement.   [MPI_ERR_KEYVAL]
       INTEGER MPI_ERR_KEYVAL
/cm/shared/apps/mpich/ge/intel/3.2/include/mpif.h(56): error #6401: The
statement.   [MPI_ERR_ACCESS]
       INTEGER MPI_ERR_ACCESS
/cm/shared/apps/mpich/ge/intel/3.2/include/mpif.h(58): error #6401: The
statement.   [MPI_ERR_DIMS]
       INTEGER MPI_ERR_DIMS
I usually write everything consistently within PETSc, but for the first
time, I have to use some PETSc routines in a code that is mostly standard
FORTRAN 90.
Is including PETSc via #include <petsc/finclude/petscdef.h> the wrong
method?
Best
Timothee
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20170131/3d4ce611/attachment-0001.html>
