[petsc-users] malconfigured gamg
Wed Jan 11 19:39:49 CST 2017
> On Jan 11, 2017, at 3:51 PM, Jed Brown <jed at jedbrown.org> wrote:
> Arne Morten Kvarving <arne.morten.kvarving at sintef.no> writes:
>> hi,
>> first, this was an user error and i totally acknowledge this, but i
>> wonder if this might be an oversight in your error checking: if you
>> configure gamg with ilu/asm smoothing, and are stupid enough to have set
>> the number of smoother cycles to 0, your program churns along and
>> apparently converges just fine (towards garbage, but apparently 'sane'
>> garbage (not 0, not nan, not inf))
> My concern here is that skipping smoothing actually makes sense, e.g.,
> for Kaskade cycles (no pre-smoothing).  I would suggest checking the
> unpreconditioned (or true) residual in order to notice when a singular
> preconditioner causes stagnation (instead of misdiagnosing it as
> convergence due to the preconditioned residual dropping).
  Jed,
  Yeah but what about checking that the sum of the number of pre and post smooths >=1 ?
>> once i set sor as smoother, i got the error message
>> 'PETSC ERROR: Relaxation requires global its 0 positive' which pointed
>> me to my stupid.
>> fixing this made both asm and sor work fine.
>> it's all wrapped up in a schur/fieldsplit (it's P2/P1 navier-stokes),
>> constructed by hand due to "surrounding" reasons. but i don't think
>> that's relevant as such. i've used 3.6.4 as the oldest and 3.7.4 as the
>> newest version and behavior was the same. if you want logs et al don't
>> hesitate to ask for them, but i do not think they would add much.
>> cheers
>> arnem
