[petsc-users] malconfigured gamg
Jed Brown jed at jedbrown.org
Wed Jan 11 15:51:24 CST 2017
Arne Morten Kvarving <arne.morten.kvarving at sintef.no> writes:
> hi,
> first, this was an user error and i totally acknowledge this, but i
> wonder if this might be an oversight in your error checking: if you
> configure gamg with ilu/asm smoothing, and are stupid enough to have set
> the number of smoother cycles to 0, your program churns along and
> apparently converges just fine (towards garbage, but apparently 'sane'
> garbage (not 0, not nan, not inf))
My concern here is that skipping smoothing actually makes sense, e.g.,
for Kaskade cycles (no pre-smoothing).  I would suggest checking the
unpreconditioned (or true) residual in order to notice when a singular
preconditioner causes stagnation (instead of misdiagnosing it as
convergence due to the preconditioned residual dropping).
> once i set sor as smoother, i got the error message
> 'PETSC ERROR: Relaxation requires global its 0 positive' which pointed
> me to my stupid.
> fixing this made both asm and sor work fine.
> it's all wrapped up in a schur/fieldsplit (it's P2/P1 navier-stokes),
> constructed by hand due to "surrounding" reasons. but i don't think
> that's relevant as such. i've used 3.6.4 as the oldest and 3.7.4 as the
> newest version and behavior was the same. if you want logs et al don't
> hesitate to ask for them, but i do not think they would add much.
> cheers
> arnem
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20170111/8044aa04/attachment.pgp>
