[petsc-users] Using PCFIELDSPLIT with -pc_fieldsplit_type schur
Wed Jan 11 19:32:22 CST 2017
   Can you please run with all the monitoring on? So we can see the convergence of all the inner solvers
-fieldsplit_FE_split_ksp_monitor
Then run again with
-fieldsplit_FE_split_ksp_monitor  -fieldsplit_FE_split_pc_type cholesky
and send both sets of results
Barry
> On Jan 11, 2017, at 6:32 PM, David Knezevic <david.knezevic at akselos.com> wrote:
> On Wed, Jan 11, 2017 at 5:52 PM, Dave May <dave.mayhem23 at gmail.com> wrote:
> so I gather that I'll have to look into a user-defined approximation to S.
> Where does the 2x2 block system come from?
> Maybe someone on the list knows the right approximation to use for S.
> The model is 3D linear elasticity using a finite element discretization. I applied substructuring to part of the system to "condense" it, and that results in the small A00 block. The A11 block is just standard 3D elasticity; no substructuring was applied there. There are constraints to connect the degrees of freedom on the interface of the substructured and non-substructured regions.
> If anyone has suggestions for a good way to precondition this type of system, I'd be most appreciative!
> Thanks,
> David
>   0 KSP Residual norm 5.405528187695e+04
>   1 KSP Residual norm 2.187814910803e+02
>   2 KSP Residual norm 1.019051577515e-01
>   3 KSP Residual norm 4.370464012859e-04
> KSP Object: 1 MPI processes
>   type: cg
>   maximum iterations=1000
>   tolerances:  relative=1e-06, absolute=1e-50, divergence=10000.
>   left preconditioning
>   using nonzero initial guess
>   using PRECONDITIONED norm type for convergence test
> PC Object: 1 MPI processes
>   type: fieldsplit
>     FieldSplit with Schur preconditioner, factorization FULL
>     Preconditioner for the Schur complement formed from Sp, an assembled approximation to S, which uses (lumped, if requested) A00's diagonal's inverse
>     Split info:
>     Split number 0 Defined by IS
>     Split number 1 Defined by IS
>     KSP solver for A00 block
>       KSP Object:      (fieldsplit_RB_split_)       1 MPI processes
>         type: preonly
>         maximum iterations=10000, initial guess is zero
>         tolerances:  relative=1e-05, absolute=1e-50, divergence=10000.
>         using NONE norm type for convergence test
>       PC Object:      (fieldsplit_RB_split_)       1 MPI processes
>         type: cholesky
>           Cholesky: out-of-place factorization
>           tolerance for zero pivot 2.22045e-14
>           matrix ordering: natural
>           factor fill ratio given 0., needed 0.
>             Factored matrix follows:
>               Mat Object:               1 MPI processes
>                 type: seqaij
>                 rows=324, cols=324
>                 package used to perform factorization: mumps
>                 total: nonzeros=3042, allocated nonzeros=3042
>                 total number of mallocs used during MatSetValues calls =0
>                   MUMPS run parameters:
>                     SYM (matrix type):                   2
>                     PAR (host participation):            1
>                     ICNTL(1) (output for error):         6
>                     ICNTL(2) (output of diagnostic msg): 0
>                     ICNTL(3) (output for global info):   0
>                     ICNTL(4) (level of printing):        0
>                     ICNTL(5) (input mat struct):         0
>                     ICNTL(6) (matrix prescaling):        7
>                     ICNTL(7) (sequentia matrix ordering):7
>                     ICNTL(8) (scalling strategy):        77
>                     ICNTL(10) (max num of refinements):  0
>                     ICNTL(11) (error analysis):          0
>                     ICNTL(12) (efficiency control):                         0
>                     ICNTL(13) (efficiency control):                         0
>                     ICNTL(14) (percentage of estimated workspace increase): 20
>                     ICNTL(18) (input mat struct):                           0
>                     ICNTL(19) (Shur complement info):                       0
>                     ICNTL(20) (rhs sparse pattern):                         0
>                     ICNTL(21) (solution struct):                            0
>                     ICNTL(22) (in-core/out-of-core facility):               0
>                     ICNTL(23) (max size of memory can be allocated locally):0
>                     ICNTL(24) (detection of null pivot rows):               0
>                     ICNTL(25) (computation of a null space basis):          0
>                     ICNTL(26) (Schur options for rhs or solution):          0
>                     ICNTL(27) (experimental parameter):                     -24
>                     ICNTL(28) (use parallel or sequential ordering):        1
>                     ICNTL(29) (parallel ordering):                          0
>                     ICNTL(30) (user-specified set of entries in inv(A)):    0
>                     ICNTL(31) (factors is discarded in the solve phase):    0
>                     ICNTL(33) (compute determinant):                        0
>                     CNTL(1) (relative pivoting threshold):      0.01
>                     CNTL(2) (stopping criterion of refinement): 1.49012e-08
>                     CNTL(3) (absolute pivoting threshold):      0.
>                     CNTL(4) (value of static pivoting):         -1.
>                     CNTL(5) (fixation for null pivots):         0.
>                     RINFO(1) (local estimated flops for the elimination after analysis):
>                       [0] 29394.
>                     RINFO(2) (local estimated flops for the assembly after factorization):
>                       [0]  1092.
>                     RINFO(3) (local estimated flops for the elimination after factorization):
>                       [0]  29394.
>                     INFO(15) (estimated size of (in MB) MUMPS internal data for running numerical factorization):
>                     [0] 1
>                     INFO(16) (size of (in MB) MUMPS internal data used during numerical factorization):
>                       [0] 1
>                     INFO(23) (num of pivots eliminated on this processor after factorization):
>                       [0] 324
>                     RINFOG(1) (global estimated flops for the elimination after analysis): 29394.
>                     RINFOG(2) (global estimated flops for the assembly after factorization): 1092.
>                     RINFOG(3) (global estimated flops for the elimination after factorization): 29394.
>                     (RINFOG(12) RINFOG(13))*2^INFOG(34) (determinant): (0.,0.)*(2^0)
>                     INFOG(3) (estimated real workspace for factors on all processors after analysis): 3888
>                     INFOG(4) (estimated integer workspace for factors on all processors after analysis): 2067
>                     INFOG(5) (estimated maximum front size in the complete tree): 12
>                     INFOG(6) (number of nodes in the complete tree): 53
>                     INFOG(7) (ordering option effectively use after analysis): 2
>                     INFOG(8) (structural symmetry in percent of the permuted matrix after analysis): 100
>                     INFOG(9) (total real/complex workspace to store the matrix factors after factorization): 3888
>                     INFOG(10) (total integer space store the matrix factors after factorization): 2067
>                     INFOG(11) (order of largest frontal matrix after factorization): 12
>                     INFOG(12) (number of off-diagonal pivots): 0
>                     INFOG(13) (number of delayed pivots after factorization): 0
>                     INFOG(14) (number of memory compress after factorization): 0
>                     INFOG(15) (number of steps of iterative refinement after solution): 0
>                     INFOG(16) (estimated size (in MB) of all MUMPS internal data for factorization after analysis: value on the most memory consuming processor): 1
>                     INFOG(17) (estimated size of all MUMPS internal data for factorization after analysis: sum over all processors): 1
>                     INFOG(18) (size of all MUMPS internal data allocated during factorization: value on the most memory consuming processor): 1
>                     INFOG(19) (size of all MUMPS internal data allocated during factorization: sum over all processors): 1
>                     INFOG(20) (estimated number of entries in the factors): 3042
>                     INFOG(21) (size in MB of memory effectively used during factorization - value on the most memory consuming processor): 1
>                     INFOG(22) (size in MB of memory effectively used during factorization - sum over all processors): 1
>                     INFOG(23) (after analysis: value of ICNTL(6) effectively used): 5
>                     INFOG(24) (after analysis: value of ICNTL(12) effectively used): 1
>                     INFOG(25) (after factorization: number of pivots modified by static pivoting): 0
>                     INFOG(28) (after factorization: number of null pivots encountered): 0
>                     INFOG(29) (after factorization: effective number of entries in the factors (sum over all processors)): 3042
>                     INFOG(30, 31) (after solution: size in Mbytes of memory used during solution phase): 0, 0
>                     INFOG(32) (after analysis: type of analysis done): 1
>                     INFOG(33) (value used for ICNTL(8)): -2
>                     INFOG(34) (exponent of the determinant if determinant is requested): 0
>         linear system matrix = precond matrix:
>         Mat Object:        (fieldsplit_RB_split_)         1 MPI processes
>           type: seqaij
>           rows=324, cols=324
>           total: nonzeros=5760, allocated nonzeros=5760
>             using I-node routines: found 108 nodes, limit used is 5
>     KSP solver for S = A11 - A10 inv(A00) A01
>       KSP Object:      (fieldsplit_FE_split_)       1 MPI processes
>         type: cg
>       PC Object:      (fieldsplit_FE_split_)       1 MPI processes
>         type: bjacobi
>           block Jacobi: number of blocks = 1
>           Local solve is same for all blocks, in the following KSP and PC objects:
>           KSP Object:          (fieldsplit_FE_split_sub_)           1 MPI processes
>             type: preonly
>           PC Object:          (fieldsplit_FE_split_sub_)           1 MPI processes
>             type: ilu
>               ILU: out-of-place factorization
>               0 levels of fill
>               factor fill ratio given 1., needed 1.
>                     type: seqaij
>                     rows=28476, cols=28476
>                     package used to perform factorization: petsc
>                     total: nonzeros=1037052, allocated nonzeros=1037052
>                       using I-node routines: found 9489 nodes, limit used is 5
>               type: seqaij
>         linear system matrix followed by preconditioner matrix:
>         Mat Object:        (fieldsplit_FE_split_)         1 MPI processes
>           type: schurcomplement
>             Schur complement A11 - A10 inv(A00) A01
>             A11
>                 type: seqaij
>                 total: nonzeros=1017054, allocated nonzeros=1017054
>                   using I-node routines: found 9492 nodes, limit used is 5
>             A10
>                 type: seqaij
>                 rows=28476, cols=324
>                 total: nonzeros=936, allocated nonzeros=936
>                   using I-node routines: found 5717 nodes, limit used is 5
>             KSP of A00
>                 type: preonly
>                 type: cholesky
>                         type: seqaij
>                         rows=324, cols=324
>                               [0] 29394.
>                               [0]  1092.
>                               [0]  29394.
>                             [0] 1
>                               [0] 1
>                               [0] 324
>                   type: seqaij
>                   rows=324, cols=324
>             A01
>                 type: seqaij
>                 rows=324, cols=28476
>                   using I-node routines: found 67 nodes, limit used is 5
>           type: seqaij
>   Mat Object:  ()   1 MPI processes
>     type: seqaij
>     rows=28800, cols=28800
>     total: nonzeros=1024686, allocated nonzeros=1024794
>       using I-node routines: found 9600 nodes, limit used is 5
> ---------------------------------------------- PETSc Performance Summary: ----------------------------------------------
> /home/dknez/akselos-dev/scrbe/build/bin/fe_solver-opt_real on a arch-linux2-c-opt named david-Lenovo with 1 processor, by dknez Wed Jan 11 17:22:10 2017
> Using Petsc Release Version 3.7.3, unknown
>                          Max       Max/Min        Avg      Total
> Time (sec):           9.638e+01      1.00000   9.638e+01
> Objects:              2.030e+02      1.00000   2.030e+02
> Flops:                1.732e+11      1.00000   1.732e+11  1.732e+11
> Flops/sec:            1.797e+09      1.00000   1.797e+09  1.797e+09
> MPI Messages:         0.000e+00      0.00000   0.000e+00  0.000e+00
> MPI Message Lengths:  0.000e+00      0.00000   0.000e+00  0.000e+00
> MPI Reductions:       0.000e+00      0.00000
> Flop counting convention: 1 flop = 1 real number operation of type (multiply/divide/add/subtract)
>                             e.g., VecAXPY() for real vectors of length N --> 2N flops
>                             and VecAXPY() for complex vectors of length N --> 8N flops
> Summary of Stages:   ----- Time ------  ----- Flops -----  --- Messages ---  -- Message Lengths --  -- Reductions --
>                         Avg     %Total     Avg     %Total   counts   %Total     Avg         %Total   counts   %Total
>  0:      Main Stage: 9.6379e+01 100.0%  1.7318e+11 100.0%  0.000e+00   0.0%  0.000e+00        0.0%  0.000e+00   0.0%
> See the 'Profiling' chapter of the users' manual for details on interpreting output.
> Phase summary info:
>    Count: number of times phase was executed
>    Time and Flops: Max - maximum over all processors
>                    Ratio - ratio of maximum to minimum over all processors
>    Mess: number of messages sent
>    Avg. len: average message length (bytes)
>    Reduct: number of global reductions
>    Global: entire computation
>    Stage: stages of a computation. Set stages with PetscLogStagePush() and PetscLogStagePop().
>       %T - percent time in this phase         %F - percent flops in this phase
>       %M - percent messages in this phase     %L - percent message lengths in this phase
>       %R - percent reductions in this phase
>    Total Mflop/s: 10e-6 * (sum of flops over all processors)/(max time over all processors)
> Event                Count      Time (sec)     Flops                             --- Global ---  --- Stage ---   Total
>                    Max Ratio  Max     Ratio   Max  Ratio  Mess   Avg len Reduct  %T %F %M %L %R  %T %F %M %L %R Mflop/s
> --- Event Stage 0: Main Stage
> VecDot                42 1.0 2.2411e-05 1.0 8.53e+03 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0   380
> VecTDot            77761 1.0 1.4294e+00 1.0 4.43e+09 1.0 0.0e+00 0.0e+00 0.0e+00  1  3  0  0  0   1  3  0  0  0  3098
> VecNorm            38894 1.0 9.1002e-01 1.0 2.22e+09 1.0 0.0e+00 0.0e+00 0.0e+00  1  1  0  0  0   1  1  0  0  0  2434
> VecScale           38882 1.0 3.7314e-01 1.0 1.11e+09 1.0 0.0e+00 0.0e+00 0.0e+00  0  1  0  0  0   0  1  0  0  0  2967
> VecCopy            38908 1.0 2.1655e-02 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
> VecSet             77887 1.0 3.2034e-01 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
> VecAXPY            77777 1.0 1.8382e+00 1.0 4.43e+09 1.0 0.0e+00 0.0e+00 0.0e+00  2  3  0  0  0   2  3  0  0  0  2409
> VecAYPX            38875 1.0 1.2884e+00 1.0 2.21e+09 1.0 0.0e+00 0.0e+00 0.0e+00  1  1  0  0  0   1  1  0  0  0  1718
> VecAssemblyBegin      68 1.0 1.9407e-04 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
> VecAssemblyEnd        68 1.0 2.6941e-05 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
> VecScatterBegin       48 1.0 4.6349e-04 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
> MatMult            38891 1.0 4.3045e+01 1.0 8.03e+10 1.0 0.0e+00 0.0e+00 0.0e+00 45 46  0  0  0  45 46  0  0  0  1866
> MatMultAdd         38889 1.0 3.5360e+01 1.0 7.91e+10 1.0 0.0e+00 0.0e+00 0.0e+00 37 46  0  0  0  37 46  0  0  0  2236
> MatSolve           77769 1.0 4.8780e+01 1.0 7.95e+10 1.0 0.0e+00 0.0e+00 0.0e+00 51 46  0  0  0  51 46  0  0  0  1631
> MatLUFactorNum         1 1.0 1.9575e-02 1.0 2.49e+07 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0  1274
> MatCholFctrSym         1 1.0 9.4891e-04 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
> MatCholFctrNum         1 1.0 3.7885e-04 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
> MatILUFactorSym        1 1.0 4.1780e-03 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
> MatConvert             1 1.0 3.0041e-05 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
> MatScale               2 1.0 2.7180e-05 1.0 2.53e+04 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0   930
> MatAssemblyBegin      32 1.0 4.0531e-06 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
> MatAssemblyEnd        32 1.0 1.2032e-02 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
> MatGetRow         114978 1.0 5.9254e-03 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
> MatGetRowIJ            2 1.0 2.1458e-06 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
> MatGetSubMatrice       6 1.0 1.5707e-02 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
> MatGetOrdering         2 1.0 3.2425e-04 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
> MatZeroEntries         6 1.0 3.0580e-03 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
> MatView                7 1.0 3.5119e-03 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
> MatAXPY                1 1.0 1.9384e-02 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
> MatMatMult             1 1.0 2.7120e-03 1.0 3.16e+05 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0   117
> MatMatMultSym          1 1.0 1.8010e-03 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
> MatMatMultNum          1 1.0 6.1703e-04 1.0 3.16e+05 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0   513
> KSPSetUp               4 1.0 9.8944e-05 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
> KSPSolve               1 1.0 9.3380e+01 1.0 1.73e+11 1.0 0.0e+00 0.0e+00 0.0e+00 97100  0  0  0  97100  0  0  0  1855
> PCSetUp                4 1.0 6.6326e-02 1.0 2.53e+07 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0   381
> PCSetUpOnBlocks        5 1.0 2.4082e-02 1.0 2.49e+07 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0  1036
> PCApply                5 1.0 9.3376e+01 1.0 1.73e+11 1.0 0.0e+00 0.0e+00 0.0e+00 97100  0  0  0  97100  0  0  0  1855
> KSPSolve_FS_0          5 1.0 7.0214e-04 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
> KSPSolve_FS_Schu       5 1.0 9.3372e+01 1.0 1.73e+11 1.0 0.0e+00 0.0e+00 0.0e+00 97100  0  0  0  97100  0  0  0  1855
> KSPSolve_FS_Low        5 1.0 2.1377e-03 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
> Memory usage is given in bytes:
> Object Type          Creations   Destructions     Memory  Descendants' Mem.
> Reports information only for process 0.
>               Vector    92             92      9698040     0.
>       Vector Scatter    24             24        15936     0.
>            Index Set    51             51       537876     0.
>    IS L to G Mapping     3              3       240408     0.
>               Matrix    16             16     77377776     0.
>        Krylov Solver     6              6         7888     0.
>       Preconditioner     6              6         6288     0.
>               Viewer     1              0            0     0.
>     Distributed Mesh     1              1         4624     0.
> Star Forest Bipartite Graph     2              2         1616     0.
>      Discrete System     1              1          872     0.
> Average time to get PetscTime(): 0.
> #PETSc Option Table entries:
> -ksp_monitor
> -ksp_view
> -log_view
> #End of PETSc Option Table entries
> Compiled without FORTRAN kernels
> Compiled with full precision matrices (default)
> sizeof(short) 2 sizeof(int) 4 sizeof(long) 8 sizeof(void*) 8 sizeof(PetscScalar) 8 sizeof(PetscInt) 4
> Configure options: --with-shared-libraries=1 --with-debugging=0 --download-suitesparse --download-blacs --download-ptscotch=yes --with-blas-lapack-dir=/opt/intel/system_studio_2015.2.050/mkl --CXXFLAGS=-Wl,--no-as-needed --download-scalapack --download-mumps --download-metis --prefix=/home/dknez/software/libmesh_install/opt_real/petsc --download-hypre --download-ml
> Libraries compiled on Wed Sep 21 17:38:52 2016 on david-Lenovo
> Machine characteristics: Linux-4.4.0-38-generic-x86_64-with-Ubuntu-16.04-xenial
> Using PETSc directory: /home/dknez/software/petsc-src
> Using PETSc arch: arch-linux2-c-opt
> Using C compiler: mpicc  -fPIC  -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -fvisibility=hidden -g -O  ${COPTFLAGS} ${CFLAGS}
> Using Fortran compiler: mpif90  -fPIC -Wall -ffree-line-length-0 -Wno-unused-dummy-argument -g -O   ${FOPTFLAGS} ${FFLAGS}
> Using include paths: -I/home/dknez/software/petsc-src/arch-linux2-c-opt/include -I/home/dknez/software/petsc-src/include -I/home/dknez/software/petsc-src/include -I/home/dknez/software/petsc-src/arch-linux2-c-opt/include -I/home/dknez/software/libmesh_install/opt_real/petsc/include -I/usr/lib/openmpi/include/openmpi/opal/mca/event/libevent2021/libevent -I/usr/lib/openmpi/include/openmpi/opal/mca/event/libevent2021/libevent/include -I/usr/lib/openmpi/include -I/usr/lib/openmpi/include/openmpi
> Using C linker: mpicc
> Using Fortran linker: mpif90
> Using libraries: -Wl,-rpath,/home/dknez/software/petsc-src/arch-linux2-c-opt/lib -L/home/dknez/software/petsc-src/arch-linux2-c-opt/lib -lpetsc -Wl,-rpath,/home/dknez/software/libmesh_install/opt_real/petsc/lib -L/home/dknez/software/libmesh_install/opt_real/petsc/lib -lcmumps -ldmumps -lsmumps -lzmumps -lmumps_common -lpord -lmetis -lHYPRE -Wl,-rpath,/usr/lib/openmpi/lib -L/usr/lib/openmpi/lib -Wl,-rpath,/usr/lib/gcc/x86_64-linux-gnu/5 -L/usr/lib/gcc/x86_64-linux-gnu/5 -Wl,-rpath,/usr/lib/x86_64-linux-gnu -L/usr/lib/x86_64-linux-gnu -Wl,-rpath,/lib/x86_64-linux-gnu -L/lib/x86_64-linux-gnu -lmpi_cxx -lstdc++ -lscalapack -lml -lmpi_cxx -lstdc++ -lumfpack -lklu -lcholmod -lbtf -lccolamd -lcolamd -lcamd -lamd -lsuitesparseconfig -Wl,-rpath,/opt/intel/system_studio_2015.2.050/mkl/lib/intel64 -L/opt/intel/system_studio_2015.2.050/mkl/lib/intel64 -lmkl_intel_lp64 -lmkl_sequential -lmkl_core -lpthread -lm -lhwloc -lptesmumps -lptscotch -lptscotcherr -lscotch -lscotcherr -lX11 -lm -lmpi_usempif08 -lmpi_usempi_ignore_tkr -lmpi_mpifh -lgfortran -lm -lgfortran -lm -lquadmath -lm -lmpi_cxx -lstdc++ -lrt -lm -lpthread -lz -Wl,-rpath,/usr/lib/openmpi/lib -L/usr/lib/openmpi/lib -Wl,-rpath,/usr/lib/gcc/x86_64-linux-gnu/5 -L/usr/lib/gcc/x86_64-linux-gnu/5 -Wl,-rpath,/usr/lib/x86_64-linux-gnu -L/usr/lib/x86_64-linux-gnu -Wl,-rpath,/lib/x86_64-linux-gnu -L/lib/x86_64-linux-gnu -Wl,-rpath,/usr/lib/x86_64-linux-gnu -L/usr/lib/x86_64-linux-gnu -ldl -Wl,-rpath,/usr/lib/openmpi/lib -lmpi -lgcc_s -lpthread -ldl
> On Wed, Jan 11, 2017 at 4:49 PM, Dave May <dave.mayhem23 at gmail.com> wrote:
> It looks like the Schur solve is requiring a huge number of iterates to converge (based on the instances of MatMult).
> This is killing the performance.
> Are you sure that A11 is a good approximation to S? You might consider trying the selfp option
> http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/PC/PCFieldSplitSetSchurPre.html#PCFieldSplitSetSchurPre
> Note that the best approx to S is likely both problem and discretisation dependent so if selfp is also terrible, you might want to consider coding up your own approx to S for your specific system.
> Thanks,
>   Dave
> On Wed, 11 Jan 2017 at 22:34, David Knezevic <david.knezevic at akselos.com> wrote:
> I have a definite block 2x2 system and I figured it'd be good to apply the PCFIELDSPLIT functionality with Schur complement, as described in Section 4.5 of the manual.
> The A00 block of my matrix is very small so I figured I'd specify a direct solver (i.e. MUMPS) for that block.
> So I did the following:
> - PCFieldSplitSetIS to specify the indices of the two splits
> - PCFieldSplitGetSubKSP to get the two KSP objects, and to set the solver and PC types for each (MUMPS for A00, ILU+CG for A11)
> - I set -pc_fieldsplit_schur_fact_type full
> Below I have pasted the output of "-ksp_view -ksp_monitor -log_view" for a test case. It seems to converge well, but I'm concerned about the speed (about 90 seconds, vs. about 1 second if I use a direct solver for the entire system). I just wanted to check if I'm setting this up in a good way?
> Many thanks,
> David
>   0 KSP Residual norm 5.405774214400e+04
>   1 KSP Residual norm 1.849649014371e+02
>   2 KSP Residual norm 7.462775074989e-02
>   3 KSP Residual norm 2.680497175260e-04
>   type: cg
>   type: fieldsplit
>     Preconditioner for the Schur complement formed from A11
>     Split info:
>         type: preonly
>         type: cholesky
>                 type: seqaij
>                 rows=324, cols=324
>                       [0] 29394.
>                       [0]  1092.
>                       [0]  29394.
>                     [0] 1
>                       [0] 1
>                       [0] 324
>           type: seqaij
>           rows=324, cols=324
>         type: cg
>         type: bjacobi
>             type: preonly
>             type: ilu
>               0 levels of fill
>                     type: seqaij
>               type: seqaij
>             A11
>                 type: seqaij
>             A10
>                 type: seqaij
>             KSP of A00
>                 type: preonly
>                 type: cholesky
>                         type: seqaij
>                         rows=324, cols=324
>                               [0] 29394.
>                               [0]  1092.
>                               [0]  29394.
>                             [0] 1
>                               [0] 1
>                               [0] 324
>                   type: seqaij
>                   rows=324, cols=324
>             A01
>                 type: seqaij
>           type: seqaij
>     type: seqaij
> /home/dknez/akselos-dev/scrbe/build/bin/fe_solver-opt_real on a arch-linux2-c-opt named david-Lenovo with 1 processor, by dknez Wed Jan 11 16:16:47 2017
> Time (sec):           9.179e+01      1.00000   9.179e+01
> Objects:              1.990e+02      1.00000   1.990e+02
> Flops:                1.634e+11      1.00000   1.634e+11  1.634e+11
> Flops/sec:            1.780e+09      1.00000   1.780e+09  1.780e+09
>  0:      Main Stage: 9.1787e+01 100.0%  1.6336e+11 100.0%  0.000e+00   0.0%  0.000e+00        0.0%  0.000e+00   0.0%
> Phase summary info:
> VecDot                42 1.0 2.4080e-05 1.0 8.53e+03 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0   354
> VecTDot            74012 1.0 1.2440e+00 1.0 4.22e+09 1.0 0.0e+00 0.0e+00 0.0e+00  1  3  0  0  0   1  3  0  0  0  3388
> VecNorm            37020 1.0 8.3580e-01 1.0 2.11e+09 1.0 0.0e+00 0.0e+00 0.0e+00  1  1  0  0  0   1  1  0  0  0  2523
> VecScale           37008 1.0 3.5800e-01 1.0 1.05e+09 1.0 0.0e+00 0.0e+00 0.0e+00  0  1  0  0  0   0  1  0  0  0  2944
> VecCopy            37034 1.0 2.5754e-02 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
> VecSet             74137 1.0 3.0537e-01 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
> VecAXPY            74029 1.0 1.7233e+00 1.0 4.22e+09 1.0 0.0e+00 0.0e+00 0.0e+00  2  3  0  0  0   2  3  0  0  0  2446
> VecAYPX            37001 1.0 1.2214e+00 1.0 2.11e+09 1.0 0.0e+00 0.0e+00 0.0e+00  1  1  0  0  0   1  1  0  0  0  1725
> VecAssemblyBegin      68 1.0 2.0432e-04 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
> VecAssemblyEnd        68 1.0 2.5988e-05 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
> VecScatterBegin       48 1.0 4.6921e-04 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
> MatMult            37017 1.0 4.1269e+01 1.0 7.65e+10 1.0 0.0e+00 0.0e+00 0.0e+00 45 47  0  0  0  45 47  0  0  0  1853
> MatMultAdd         37015 1.0 3.3638e+01 1.0 7.53e+10 1.0 0.0e+00 0.0e+00 0.0e+00 37 46  0  0  0  37 46  0  0  0  2238
> MatSolve           74021 1.0 4.6602e+01 1.0 7.42e+10 1.0 0.0e+00 0.0e+00 0.0e+00 51 45  0  0  0  51 45  0  0  0  1593
> MatLUFactorNum         1 1.0 1.7209e-02 1.0 2.44e+07 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0  1420
> MatCholFctrSym         1 1.0 8.8310e-04 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
> MatCholFctrNum         1 1.0 3.6907e-04 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
> MatILUFactorSym        1 1.0 3.7372e-03 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
> MatAssemblyBegin      29 1.0 2.1458e-06 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
> MatAssemblyEnd        29 1.0 9.9473e-03 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
> MatGetRow          58026 1.0 2.8155e-03 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
> MatGetRowIJ            2 1.0 0.0000e+00 0.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
> MatGetSubMatrice       6 1.0 1.5399e-02 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
> MatGetOrdering         2 1.0 3.0112e-04 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
> MatZeroEntries         6 1.0 2.9490e-03 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
> MatView                7 1.0 3.4356e-03 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
> KSPSetUp               4 1.0 9.4891e-05 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
> KSPSolve               1 1.0 8.8793e+01 1.0 1.63e+11 1.0 0.0e+00 0.0e+00 0.0e+00 97100  0  0  0  97100  0  0  0  1840
> PCSetUp                4 1.0 3.8375e-02 1.0 2.44e+07 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0   637
> PCSetUpOnBlocks        5 1.0 2.1250e-02 1.0 2.44e+07 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0  1150
> PCApply                5 1.0 8.8789e+01 1.0 1.63e+11 1.0 0.0e+00 0.0e+00 0.0e+00 97100  0  0  0  97100  0  0  0  1840
> KSPSolve_FS_0          5 1.0 7.5364e-04 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
> KSPSolve_FS_Schu       5 1.0 8.8785e+01 1.0 1.63e+11 1.0 0.0e+00 0.0e+00 0.0e+00 97100  0  0  0  97100  0  0  0  1840
> KSPSolve_FS_Low        5 1.0 2.1019e-03 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
>               Vector    91             91      9693912     0.
>            Index Set    51             51       537888     0.
>               Matrix    13             13     64097868     0.
>               Viewer     1              0            0     0.
> -ksp_monitor
> -ksp_view
> -log_view
