[petsc-users] Using PCFIELDSPLIT with -pc_fieldsplit_type schur
David Knezevic david.knezevic at akselos.com
Wed Jan 11 19:47:05 CST 2017
I've attached the two log files. Using cholesky for "FE_split" seems to
have helped a lot!
David
David J. Knezevic | CTO
Akselos | 210 Broadway, #201 | Cambridge, MA | 02139
Phone: +1-617-599-4755
[image: akselos.com] <http://akselos.com/>    [image: @AkselosCAE]
<http://www.twitter.com/akselosCAE>    [image:
linkedin.com/company/akselos]
<https://www.linkedin.com/company/akselos>
This e-mail and any attachments may contain confidential material for
the sole use of the intended recipient(s). Any review or distribution
by others is strictly prohibited. If you are not the intended
recipient, please contact the sender and delete all copies.
On Wed, Jan 11, 2017 at 8:32 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>    Can you please run with all the monitoring on? So we can see the
> convergence of all the inner solvers
> -fieldsplit_FE_split_ksp_monitor
> Then run again with
> -fieldsplit_FE_split_ksp_monitor  -fieldsplit_FE_split_pc_type cholesky
> and send both sets of results
> Barry
> > On Jan 11, 2017, at 6:32 PM, David Knezevic <david.knezevic at akselos.com>
> wrote:
> > On Wed, Jan 11, 2017 at 5:52 PM, Dave May <dave.mayhem23 at gmail.com>
> wrote:
> > so I gather that I'll have to look into a user-defined approximation to
> S.
> > Where does the 2x2 block system come from?
> > Maybe someone on the list knows the right approximation to use for S.
> > The model is 3D linear elasticity using a finite element discretization.
> I applied substructuring to part of the system to "condense" it, and that
> results in the small A00 block. The A11 block is just standard 3D
> elasticity; no substructuring was applied there. There are constraints to
> connect the degrees of freedom on the interface of the substructured and
> non-substructured regions.
> > If anyone has suggestions for a good way to precondition this type of
> system, I'd be most appreciative!
> > Thanks,
> > David
> >   0 KSP Residual norm 5.405528187695e+04
> >   1 KSP Residual norm 2.187814910803e+02
> >   2 KSP Residual norm 1.019051577515e-01
> >   3 KSP Residual norm 4.370464012859e-04
> > KSP Object: 1 MPI processes
> >   type: cg
> >   maximum iterations=1000
> >   tolerances:  relative=1e-06, absolute=1e-50, divergence=10000.
> >   left preconditioning
> >   using nonzero initial guess
> >   using PRECONDITIONED norm type for convergence test
> > PC Object: 1 MPI processes
> >   type: fieldsplit
> >     FieldSplit with Schur preconditioner, factorization FULL
> >     Preconditioner for the Schur complement formed from Sp, an assembled
> approximation to S, which uses (lumped, if requested) A00's diagonal's
> inverse
> >     Split info:
> >     Split number 0 Defined by IS
> >     Split number 1 Defined by IS
> >     KSP solver for A00 block
> >       KSP Object:      (fieldsplit_RB_split_)       1 MPI processes
> >         type: preonly
> >         maximum iterations=10000, initial guess is zero
> >         tolerances:  relative=1e-05, absolute=1e-50, divergence=10000.
> >         using NONE norm type for convergence test
> >       PC Object:      (fieldsplit_RB_split_)       1 MPI processes
> >         type: cholesky
> >           Cholesky: out-of-place factorization
> >           tolerance for zero pivot 2.22045e-14
> >           matrix ordering: natural
> >           factor fill ratio given 0., needed 0.
> >             Factored matrix follows:
> >               Mat Object:               1 MPI processes
> >                 type: seqaij
> >                 rows=324, cols=324
> >                 package used to perform factorization: mumps
> >                 total: nonzeros=3042, allocated nonzeros=3042
> >                 total number of mallocs used during MatSetValues calls =0
> >                   MUMPS run parameters:
> >                     SYM (matrix type):                   2
> >                     PAR (host participation):            1
> >                     ICNTL(1) (output for error):         6
> >                     ICNTL(2) (output of diagnostic msg): 0
> >                     ICNTL(3) (output for global info):   0
> >                     ICNTL(4) (level of printing):        0
> >                     ICNTL(5) (input mat struct):         0
> >                     ICNTL(6) (matrix prescaling):        7
> >                     ICNTL(7) (sequentia matrix ordering):7
> >                     ICNTL(8) (scalling strategy):        77
> >                     ICNTL(10) (max num of refinements):  0
> >                     ICNTL(11) (error analysis):          0
> >                     ICNTL(12) (efficiency control):
>    0
> >                     ICNTL(13) (efficiency control):
>    0
> >                     ICNTL(14) (percentage of estimated workspace
> increase): 20
> >                     ICNTL(18) (input mat struct):
>    0
> >                     ICNTL(19) (Shur complement info):
>    0
> >                     ICNTL(20) (rhs sparse pattern):
>    0
> >                     ICNTL(21) (solution struct):
>     0
> >                     ICNTL(22) (in-core/out-of-core facility):
>    0
> >                     ICNTL(23) (max size of memory can be allocated
> locally):0
> >                     ICNTL(24) (detection of null pivot rows):
>    0
> >                     ICNTL(25) (computation of a null space basis):
>     0
> >                     ICNTL(26) (Schur options for rhs or solution):
>     0
> >                     ICNTL(27) (experimental parameter):
>    -24
> >                     ICNTL(28) (use parallel or sequential ordering):
>     1
> >                     ICNTL(29) (parallel ordering):
>     0
> >                     ICNTL(30) (user-specified set of entries in
> inv(A)):    0
> >                     ICNTL(31) (factors is discarded in the solve
> phase):    0
> >                     ICNTL(33) (compute determinant):
>     0
> >                     CNTL(1) (relative pivoting threshold):      0.01
> >                     CNTL(2) (stopping criterion of refinement):
> 1.49012e-08
> >                     CNTL(3) (absolute pivoting threshold):      0.
> >                     CNTL(4) (value of static pivoting):         -1.
> >                     CNTL(5) (fixation for null pivots):         0.
> >                     RINFO(1) (local estimated flops for the elimination
> after analysis):
> >                       [0] 29394.
> >                     RINFO(2) (local estimated flops for the assembly
> after factorization):
> >                       [0]  1092.
> >                     RINFO(3) (local estimated flops for the elimination
> >                       [0]  29394.
> >                     INFO(15) (estimated size of (in MB) MUMPS internal
> data for running numerical factorization):
> >                     [0] 1
> >                     INFO(16) (size of (in MB) MUMPS internal data used
> during numerical factorization):
> >                       [0] 1
> >                     INFO(23) (num of pivots eliminated on this processor
> >                       [0] 324
> >                     RINFOG(1) (global estimated flops for the
> elimination after analysis): 29394.
> >                     RINFOG(2) (global estimated flops for the assembly
> after factorization): 1092.
> >                     RINFOG(3) (global estimated flops for the
> elimination after factorization): 29394.
> >                     (RINFOG(12) RINFOG(13))*2^INFOG(34) (determinant):
> (0.,0.)*(2^0)
> >                     INFOG(3) (estimated real workspace for factors on
> all processors after analysis): 3888
> >                     INFOG(4) (estimated integer workspace for factors on
> all processors after analysis): 2067
> >                     INFOG(5) (estimated maximum front size in the
> complete tree): 12
> >                     INFOG(6) (number of nodes in the complete tree): 53
> >                     INFOG(7) (ordering option effectively use after
> analysis): 2
> >                     INFOG(8) (structural symmetry in percent of the
> permuted matrix after analysis): 100
> >                     INFOG(9) (total real/complex workspace to store the
> matrix factors after factorization): 3888
> >                     INFOG(10) (total integer space store the matrix
> factors after factorization): 2067
> >                     INFOG(11) (order of largest frontal matrix after
> factorization): 12
> >                     INFOG(12) (number of off-diagonal pivots): 0
> >                     INFOG(13) (number of delayed pivots after
> factorization): 0
> >                     INFOG(14) (number of memory compress after
> factorization): 0
> >                     INFOG(15) (number of steps of iterative refinement
> after solution): 0
> >                     INFOG(16) (estimated size (in MB) of all MUMPS
> internal data for factorization after analysis: value on the most memory
> consuming processor): 1
> >                     INFOG(17) (estimated size of all MUMPS internal data
> for factorization after analysis: sum over all processors): 1
> >                     INFOG(18) (size of all MUMPS internal data allocated
> during factorization: value on the most memory consuming processor): 1
> >                     INFOG(19) (size of all MUMPS internal data allocated
> during factorization: sum over all processors): 1
> >                     INFOG(20) (estimated number of entries in the
> factors): 3042
> >                     INFOG(21) (size in MB of memory effectively used
> during factorization - value on the most memory consuming processor): 1
> >                     INFOG(22) (size in MB of memory effectively used
> during factorization - sum over all processors): 1
> >                     INFOG(23) (after analysis: value of ICNTL(6)
> effectively used): 5
> >                     INFOG(24) (after analysis: value of ICNTL(12)
> effectively used): 1
> >                     INFOG(25) (after factorization: number of pivots
> modified by static pivoting): 0
> >                     INFOG(28) (after factorization: number of null
> pivots encountered): 0
> >                     INFOG(29) (after factorization: effective number of
> entries in the factors (sum over all processors)): 3042
> >                     INFOG(30, 31) (after solution: size in Mbytes of
> memory used during solution phase): 0, 0
> >                     INFOG(32) (after analysis: type of analysis done): 1
> >                     INFOG(33) (value used for ICNTL(8)): -2
> >                     INFOG(34) (exponent of the determinant if
> determinant is requested): 0
> >         linear system matrix = precond matrix:
> >         Mat Object:        (fieldsplit_RB_split_)         1 MPI processes
> >           type: seqaij
> >           rows=324, cols=324
> >           total: nonzeros=5760, allocated nonzeros=5760
> >             using I-node routines: found 108 nodes, limit used is 5
> >     KSP solver for S = A11 - A10 inv(A00) A01
> >       KSP Object:      (fieldsplit_FE_split_)       1 MPI processes
> >         type: cg
> >       PC Object:      (fieldsplit_FE_split_)       1 MPI processes
> >         type: bjacobi
> >           block Jacobi: number of blocks = 1
> >           Local solve is same for all blocks, in the following KSP and
> PC objects:
> >           KSP Object:          (fieldsplit_FE_split_sub_)           1
> MPI processes
> >             type: preonly
> divergence=10000.
> >           PC Object:          (fieldsplit_FE_split_sub_)           1 MPI
> processes
> >             type: ilu
> >               ILU: out-of-place factorization
> >               0 levels of fill
> >               factor fill ratio given 1., needed 1.
> >                     type: seqaij
> >                     rows=28476, cols=28476
> >                     package used to perform factorization: petsc
> >                     total: nonzeros=1037052, allocated nonzeros=1037052
> calls =0
> >                       using I-node routines: found 9489 nodes, limit
> used is 5
> >               type: seqaij
> >                 using I-node routines: found 9489 nodes, limit used is 5
> >         linear system matrix followed by preconditioner matrix:
> >         Mat Object:        (fieldsplit_FE_split_)         1 MPI processes
> >           type: schurcomplement
> >             Schur complement A11 - A10 inv(A00) A01
> >             A11
>    1 MPI processes
> >                 type: seqaij
> >                 total: nonzeros=1017054, allocated nonzeros=1017054
> >                   using I-node routines: found 9492 nodes, limit used is
> 5
> >             A10
> >                 type: seqaij
> >                 rows=28476, cols=324
> >                 total: nonzeros=936, allocated nonzeros=936
> >                   using I-node routines: found 5717 nodes, limit used is
> 5
> >             KSP of A00
>    1 MPI processes
> >                 type: preonly
> divergence=10000.
>    1 MPI processes
> >                 type: cholesky
> >                         type: seqaij
> >                         rows=324, cols=324
> calls =0
>            0
>            0
> increase): 20
>            0
>            0
>            0
>             0
>            0
> allocated locally):0
>            0
> basis):          0
> solution):          0
>            -24
> ordering):        1
>             0
> inv(A)):    0
> phase):    0
>             0
> 0.01
> 1.49012e-08
> 0.
>  -1.
>  0.
> >                               [0] 29394.
> assembly after factorization):
> >                               [0]  1092.
> >                               [0]  29394.
> internal data for running numerical factorization):
> >                             [0] 1
> data used during numerical factorization):
> >                               [0] 1
> processor after factorization):
> >                               [0] 324
> assembly after factorization): 1092.
> (determinant): (0.,0.)*(2^0)
> factors on all processors after analysis): 3888
> factors on all processors after analysis): 2067
> the complete tree): 12
> tree): 53
> after analysis): 2
> the permuted matrix after analysis): 100
> store the matrix factors after factorization): 3888
> matrix factors after factorization): 2067
> after factorization): 12
> factorization): 0
> factorization): 0
> refinement after solution): 0
> MUMPS internal data for factorization after analysis: value on the most
> internal data for factorization after analysis: sum over all processors): 1
> allocated during factorization: value on the most memory consuming
> processor): 1
> allocated during factorization: sum over all processors): 1
> the factors): 3042
> used during factorization - value on the most memory consuming processor): 1
> used during factorization - sum over all processors): 1
> ICNTL(12) effectively used): 1
> pivots modified by static pivoting): 0
> null pivots encountered): 0
> number of entries in the factors (sum over all processors)): 3042
> Mbytes of memory used during solution phase): 0, 0
> done): 1
>          1 MPI processes
> >                   type: seqaij
> >                   rows=324, cols=324
> =0
> is 5
> >             A01
> >                 type: seqaij
> >                 rows=324, cols=28476
> >                   using I-node routines: found 67 nodes, limit used is 5
> >           type: seqaij
> >   Mat Object:  ()   1 MPI processes
> >     type: seqaij
> >     rows=28800, cols=28800
> >     total: nonzeros=1024686, allocated nonzeros=1024794
> >       using I-node routines: found 9600 nodes, limit used is 5
> > ---------------------------------------------- PETSc Performance
> Summary: ----------------------------------------------
> > /home/dknez/akselos-dev/scrbe/build/bin/fe_solver-opt_real on a
> arch-linux2-c-opt named david-Lenovo with 1 processor, by dknez Wed Jan 11
> 17:22:10 2017
> > Using Petsc Release Version 3.7.3, unknown
> >                          Max       Max/Min        Avg      Total
> > Time (sec):           9.638e+01      1.00000   9.638e+01
> > Objects:              2.030e+02      1.00000   2.030e+02
> > Flops:                1.732e+11      1.00000   1.732e+11  1.732e+11
> > Flops/sec:            1.797e+09      1.00000   1.797e+09  1.797e+09
> > MPI Messages:         0.000e+00      0.00000   0.000e+00  0.000e+00
> > MPI Message Lengths:  0.000e+00      0.00000   0.000e+00  0.000e+00
> > MPI Reductions:       0.000e+00      0.00000
> > Flop counting convention: 1 flop = 1 real number operation of type
> (multiply/divide/add/subtract)
> >                             e.g., VecAXPY() for real vectors of length N
> --> 2N flops
> >                             and VecAXPY() for complex vectors of length
> N --> 8N flops
> > Summary of Stages:   ----- Time ------  ----- Flops -----  --- Messages
> ---  -- Message Lengths --  -- Reductions --
> >                         Avg     %Total     Avg     %Total   counts
>  %Total     Avg         %Total   counts   %Total
> >  0:      Main Stage: 9.6379e+01 100.0%  1.7318e+11 100.0%  0.000e+00
>  0.0%  0.000e+00        0.0%  0.000e+00   0.0%
> > See the 'Profiling' chapter of the users' manual for details on
> interpreting output.
> > Phase summary info:
> >    Count: number of times phase was executed
> >    Time and Flops: Max - maximum over all processors
> >                    Ratio - ratio of maximum to minimum over all
> processors
> >    Mess: number of messages sent
> >    Avg. len: average message length (bytes)
> >    Reduct: number of global reductions
> >    Global: entire computation
> >    Stage: stages of a computation. Set stages with PetscLogStagePush()
> and PetscLogStagePop().
> >       %T - percent time in this phase         %F - percent flops in this
> phase
> >       %M - percent messages in this phase     %L - percent message
> lengths in this phase
> >       %R - percent reductions in this phase
> >    Total Mflop/s: 10e-6 * (sum of flops over all processors)/(max time
> > Event                Count      Time (sec)     Flops
>          --- Global ---  --- Stage ---   Total
> >                    Max Ratio  Max     Ratio   Max  Ratio  Mess   Avg len
> Reduct  %T %F %M %L %R  %T %F %M %L %R Mflop/s
> > --- Event Stage 0: Main Stage
> > VecDot                42 1.0 2.2411e-05 1.0 8.53e+03 1.0 0.0e+00 0.0e+00
> 0.0e+00  0  0  0  0  0   0  0  0  0  0   380
> > VecTDot            77761 1.0 1.4294e+00 1.0 4.43e+09 1.0 0.0e+00 0.0e+00
> 0.0e+00  1  3  0  0  0   1  3  0  0  0  3098
> > VecNorm            38894 1.0 9.1002e-01 1.0 2.22e+09 1.0 0.0e+00 0.0e+00
> 0.0e+00  1  1  0  0  0   1  1  0  0  0  2434
> > VecScale           38882 1.0 3.7314e-01 1.0 1.11e+09 1.0 0.0e+00 0.0e+00
> 0.0e+00  0  1  0  0  0   0  1  0  0  0  2967
> > VecCopy            38908 1.0 2.1655e-02 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
> 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
> > VecSet             77887 1.0 3.2034e-01 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
> > VecAXPY            77777 1.0 1.8382e+00 1.0 4.43e+09 1.0 0.0e+00 0.0e+00
> 0.0e+00  2  3  0  0  0   2  3  0  0  0  2409
> > VecAYPX            38875 1.0 1.2884e+00 1.0 2.21e+09 1.0 0.0e+00 0.0e+00
> 0.0e+00  1  1  0  0  0   1  1  0  0  0  1718
> > VecAssemblyBegin      68 1.0 1.9407e-04 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
> > VecAssemblyEnd        68 1.0 2.6941e-05 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
> > VecScatterBegin       48 1.0 4.6349e-04 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
> > MatMult            38891 1.0 4.3045e+01 1.0 8.03e+10 1.0 0.0e+00 0.0e+00
> 0.0e+00 45 46  0  0  0  45 46  0  0  0  1866
> > MatMultAdd         38889 1.0 3.5360e+01 1.0 7.91e+10 1.0 0.0e+00 0.0e+00
> 0.0e+00 37 46  0  0  0  37 46  0  0  0  2236
> > MatSolve           77769 1.0 4.8780e+01 1.0 7.95e+10 1.0 0.0e+00 0.0e+00
> 0.0e+00 51 46  0  0  0  51 46  0  0  0  1631
> > MatLUFactorNum         1 1.0 1.9575e-02 1.0 2.49e+07 1.0 0.0e+00 0.0e+00
> 0.0e+00  0  0  0  0  0   0  0  0  0  0  1274
> > MatCholFctrSym         1 1.0 9.4891e-04 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
> > MatCholFctrNum         1 1.0 3.7885e-04 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
> > MatILUFactorSym        1 1.0 4.1780e-03 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
> > MatConvert             1 1.0 3.0041e-05 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
> > MatScale               2 1.0 2.7180e-05 1.0 2.53e+04 1.0 0.0e+00 0.0e+00
> 0.0e+00  0  0  0  0  0   0  0  0  0  0   930
> > MatAssemblyBegin      32 1.0 4.0531e-06 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
> > MatAssemblyEnd        32 1.0 1.2032e-02 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
> > MatGetRow         114978 1.0 5.9254e-03 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
> > MatGetRowIJ            2 1.0 2.1458e-06 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
> > MatGetSubMatrice       6 1.0 1.5707e-02 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
> > MatGetOrdering         2 1.0 3.2425e-04 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
> > MatZeroEntries         6 1.0 3.0580e-03 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
> > MatView                7 1.0 3.5119e-03 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
> > MatAXPY                1 1.0 1.9384e-02 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
> > MatMatMult             1 1.0 2.7120e-03 1.0 3.16e+05 1.0 0.0e+00 0.0e+00
> 0.0e+00  0  0  0  0  0   0  0  0  0  0   117
> > MatMatMultSym          1 1.0 1.8010e-03 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
> > MatMatMultNum          1 1.0 6.1703e-04 1.0 3.16e+05 1.0 0.0e+00 0.0e+00
> 0.0e+00  0  0  0  0  0   0  0  0  0  0   513
> > KSPSetUp               4 1.0 9.8944e-05 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
> > KSPSolve               1 1.0 9.3380e+01 1.0 1.73e+11 1.0 0.0e+00 0.0e+00
> 0.0e+00 97100  0  0  0  97100  0  0  0  1855
> > PCSetUp                4 1.0 6.6326e-02 1.0 2.53e+07 1.0 0.0e+00 0.0e+00
> 0.0e+00  0  0  0  0  0   0  0  0  0  0   381
> > PCSetUpOnBlocks        5 1.0 2.4082e-02 1.0 2.49e+07 1.0 0.0e+00 0.0e+00
> 0.0e+00  0  0  0  0  0   0  0  0  0  0  1036
> > PCApply                5 1.0 9.3376e+01 1.0 1.73e+11 1.0 0.0e+00 0.0e+00
> > KSPSolve_FS_0          5 1.0 7.0214e-04 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
> > KSPSolve_FS_Schu       5 1.0 9.3372e+01 1.0 1.73e+11 1.0 0.0e+00 0.0e+00
> > KSPSolve_FS_Low        5 1.0 2.1377e-03 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
> > Memory usage is given in bytes:
> > Object Type          Creations   Destructions     Memory  Descendants'
> Mem.
> > Reports information only for process 0.
> >               Vector    92             92      9698040     0.
> >       Vector Scatter    24             24        15936     0.
> >            Index Set    51             51       537876     0.
> >    IS L to G Mapping     3              3       240408     0.
> >               Matrix    16             16     77377776     0.
> >        Krylov Solver     6              6         7888     0.
> >       Preconditioner     6              6         6288     0.
> >               Viewer     1              0            0     0.
> >     Distributed Mesh     1              1         4624     0.
> > Star Forest Bipartite Graph     2              2         1616     0.
> >      Discrete System     1              1          872     0.
> > Average time to get PetscTime(): 0.
> > #PETSc Option Table entries:
> > -ksp_monitor
> > -ksp_view
> > -log_view
> > #End of PETSc Option Table entries
> > Compiled without FORTRAN kernels
> > Compiled with full precision matrices (default)
> > sizeof(short) 2 sizeof(int) 4 sizeof(long) 8 sizeof(void*) 8
> sizeof(PetscScalar) 8 sizeof(PetscInt) 4
> > Configure options: --with-shared-libraries=1 --with-debugging=0
> --download-suitesparse --download-blacs --download-ptscotch=yes
> --with-blas-lapack-dir=/opt/intel/system_studio_2015.2.050/mkl
> --CXXFLAGS=-Wl,--no-as-needed --download-scalapack --download-mumps
> --download-metis --prefix=/home/dknez/software/libmesh_install/opt_real/petsc
> --download-hypre --download-ml
> > Libraries compiled on Wed Sep 21 17:38:52 2016 on david-Lenovo
> > Machine characteristics: Linux-4.4.0-38-generic-x86_64-
> with-Ubuntu-16.04-xenial
> > Using PETSc directory: /home/dknez/software/petsc-src
> > Using PETSc arch: arch-linux2-c-opt
> > Using C compiler: mpicc  -fPIC  -Wall -Wwrite-strings
> -Wno-strict-aliasing -Wno-unknown-pragmas -fvisibility=hidden -g -O
> ${COPTFLAGS} ${CFLAGS}
> > Using Fortran compiler: mpif90  -fPIC -Wall -ffree-line-length-0
> -Wno-unused-dummy-argument -g -O   ${FOPTFLAGS} ${FFLAGS}
> > Using include paths: -I/home/dknez/software/petsc-src/arch-linux2-c-opt/include
> -I/home/dknez/software/petsc-src/include -I/home/dknez/software/petsc-src/include
> -I/home/dknez/software/libmesh_install/opt_real/petsc/include
> -I/usr/lib/openmpi/include/openmpi/opal/mca/event/libevent2021/libevent
> -I/usr/lib/openmpi/include/openmpi/opal/mca/event/libevent2021/libevent/include
> -I/usr/lib/openmpi/include -I/usr/lib/openmpi/include/openmpi
> > Using C linker: mpicc
> > Using Fortran linker: mpif90
> > Using libraries: -Wl,-rpath,/home/dknez/software/petsc-src/arch-linux2-c-opt/lib
> -L/home/dknez/software/petsc-src/arch-linux2-c-opt/lib -lpetsc
> -Wl,-rpath,/home/dknez/software/libmesh_install/opt_real/petsc/lib
> -L/home/dknez/software/libmesh_install/opt_real/petsc/lib -lcmumps
> -ldmumps -lsmumps -lzmumps -lmumps_common -lpord -lmetis -lHYPRE
> -Wl,-rpath,/usr/lib/openmpi/lib -L/usr/lib/openmpi/lib
> -Wl,-rpath,/usr/lib/gcc/x86_64-linux-gnu/5 -L/usr/lib/gcc/x86_64-linux-gnu/5
> -Wl,-rpath,/usr/lib/x86_64-linux-gnu -L/usr/lib/x86_64-linux-gnu
> -Wl,-rpath,/lib/x86_64-linux-gnu -L/lib/x86_64-linux-gnu -lmpi_cxx
> -lstdc++ -lscalapack -lml -lmpi_cxx -lstdc++ -lumfpack -lklu -lcholmod
> -lbtf -lccolamd -lcolamd -lcamd -lamd -lsuitesparseconfig
> -Wl,-rpath,/opt/intel/system_studio_2015.2.050/mkl/lib/intel64
> -L/opt/intel/system_studio_2015.2.050/mkl/lib/intel64 -lmkl_intel_lp64
> -lmkl_sequential -lmkl_core -lpthread -lm -lhwloc -lptesmumps -lptscotch
> -lptscotcherr -lscotch -lscotcherr -lX11 -lm -lmpi_usempif08
> -lmpi_usempi_ignore_tkr -lmpi_mpifh -lgfortran -lm -lgfortran -lm
> -lquadmath -lm -lmpi_cxx -lstdc++ -lrt -lm -lpthread -lz
> -Wl,-rpath,/usr/lib/x86_64-linux-gnu -L/usr/lib/x86_64-linux-gnu -ldl
> -Wl,-rpath,/usr/lib/openmpi/lib -lmpi -lgcc_s -lpthread -ldl
> > On Wed, Jan 11, 2017 at 4:49 PM, Dave May <dave.mayhem23 at gmail.com>
> wrote:
> > It looks like the Schur solve is requiring a huge number of iterates to
> converge (based on the instances of MatMult).
> > This is killing the performance.
> > Are you sure that A11 is a good approximation to S? You might consider
> trying the selfp option
> > http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/PC/
> PCFieldSplitSetSchurPre.html#PCFieldSplitSetSchurPre
> > Note that the best approx to S is likely both problem and discretisation
> dependent so if selfp is also terrible, you might want to consider coding
> up your own approx to S for your specific system.
> > Thanks,
> >   Dave
> > On Wed, 11 Jan 2017 at 22:34, David Knezevic <david.knezevic at akselos.com>
> wrote:
> > I have a definite block 2x2 system and I figured it'd be good to apply
> the PCFIELDSPLIT functionality with Schur complement, as described in
> Section 4.5 of the manual.
> > The A00 block of my matrix is very small so I figured I'd specify a
> direct solver (i.e. MUMPS) for that block.
> > So I did the following:
> > - PCFieldSplitSetIS to specify the indices of the two splits
> > - PCFieldSplitGetSubKSP to get the two KSP objects, and to set the
> solver and PC types for each (MUMPS for A00, ILU+CG for A11)
> > - I set -pc_fieldsplit_schur_fact_type full
> > Below I have pasted the output of "-ksp_view -ksp_monitor -log_view" for
> a test case. It seems to converge well, but I'm concerned about the speed
> (about 90 seconds, vs. about 1 second if I use a direct solver for the
> entire system). I just wanted to check if I'm setting this up in a good way?
> > Many thanks,
> > David
> >   0 KSP Residual norm 5.405774214400e+04
> >   1 KSP Residual norm 1.849649014371e+02
> >   2 KSP Residual norm 7.462775074989e-02
> >   3 KSP Residual norm 2.680497175260e-04
> >   type: cg
> >   type: fieldsplit
> >     Preconditioner for the Schur complement formed from A11
> >     Split info:
> >         type: preonly
> >         type: cholesky
> >                 type: seqaij
> >                 rows=324, cols=324
>    0
>    0
> increase): 20
>    0
>    0
>    0
>     0
>    0
> locally):0
>    0
>     0
>     0
>    -24
>     1
>     0
> inv(A)):    0
> phase):    0
>     0
> 1.49012e-08
> after analysis):
> >                       [0] 29394.
> >                       [0]  1092.
> >                       [0]  29394.
> >                     [0] 1
> >                       [0] 1
> >                       [0] 324
> (0.,0.)*(2^0)
> complete tree): 12
> analysis): 2
> factorization): 12
> factorization): 0
> factorization): 0
> after solution): 0
> factors): 3042
> >           type: seqaij
> >           rows=324, cols=324
> >         type: cg
> >         type: bjacobi
> PC objects:
> MPI processes
> >             type: preonly
> divergence=10000.
> processes
> >             type: ilu
> >               0 levels of fill
> >                     type: seqaij
> calls =0
> used is 5
> MPI processes
> >               type: seqaij
> >                 using I-node routines: found 9492 nodes, limit used is 5
> >             A11
>    1 MPI processes
> >                 type: seqaij
> 5
> >             A10
> >                 type: seqaij
> 5
> >             KSP of A00
>    1 MPI processes
> >                 type: preonly
> divergence=10000.
>    1 MPI processes
> >                 type: cholesky
> >                         type: seqaij
> >                         rows=324, cols=324
> calls =0
>            0
>            0
> increase): 20
>            0
>            0
>            0
>             0
>            0
>            0
> basis):          0
> solution):          0
>            -24
> ordering):        1
>             0
> inv(A)):    0
> phase):    0
>             0
> 0.01
> 1.49012e-08
> 0.
>  -1.
>  0.
> >                               [0] 29394.
> >                               [0]  1092.
> >                               [0]  29394.
> >                             [0] 1
> >                               [0] 1
> >                               [0] 324
> tree): 53
> after analysis): 2
> factorization): 0
> factorization): 0
> processor): 1
> the factors): 3042
> done): 1
>          1 MPI processes
> >                   type: seqaij
> >                   rows=324, cols=324
> =0
> is 5
> >             A01
> >                 type: seqaij
> >           type: seqaij
> >     type: seqaij
> 16:16:47 2017
> > Time (sec):           9.179e+01      1.00000   9.179e+01
> > Objects:              1.990e+02      1.00000   1.990e+02
> > Flops:                1.634e+11      1.00000   1.634e+11  1.634e+11
> > Flops/sec:            1.780e+09      1.00000   1.780e+09  1.780e+09
> --> 2N flops
> N --> 8N flops
> >  0:      Main Stage: 9.1787e+01 100.0%  1.6336e+11 100.0%  0.000e+00
> > Phase summary info:
> processors
> phase
> > VecDot                42 1.0 2.4080e-05 1.0 8.53e+03 1.0 0.0e+00 0.0e+00
> 0.0e+00  0  0  0  0  0   0  0  0  0  0   354
> > VecTDot            74012 1.0 1.2440e+00 1.0 4.22e+09 1.0 0.0e+00 0.0e+00
> 0.0e+00  1  3  0  0  0   1  3  0  0  0  3388
> > VecNorm            37020 1.0 8.3580e-01 1.0 2.11e+09 1.0 0.0e+00 0.0e+00
> 0.0e+00  1  1  0  0  0   1  1  0  0  0  2523
> > VecScale           37008 1.0 3.5800e-01 1.0 1.05e+09 1.0 0.0e+00 0.0e+00
> 0.0e+00  0  1  0  0  0   0  1  0  0  0  2944
> > VecCopy            37034 1.0 2.5754e-02 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
> > VecSet             74137 1.0 3.0537e-01 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
> > VecAXPY            74029 1.0 1.7233e+00 1.0 4.22e+09 1.0 0.0e+00 0.0e+00
> 0.0e+00  2  3  0  0  0   2  3  0  0  0  2446
> > VecAYPX            37001 1.0 1.2214e+00 1.0 2.11e+09 1.0 0.0e+00 0.0e+00
> 0.0e+00  1  1  0  0  0   1  1  0  0  0  1725
> > VecAssemblyBegin      68 1.0 2.0432e-04 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
> > VecAssemblyEnd        68 1.0 2.5988e-05 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
> > VecScatterBegin       48 1.0 4.6921e-04 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
> > MatMult            37017 1.0 4.1269e+01 1.0 7.65e+10 1.0 0.0e+00 0.0e+00
> 0.0e+00 45 47  0  0  0  45 47  0  0  0  1853
> > MatMultAdd         37015 1.0 3.3638e+01 1.0 7.53e+10 1.0 0.0e+00 0.0e+00
> 0.0e+00 37 46  0  0  0  37 46  0  0  0  2238
> > MatSolve           74021 1.0 4.6602e+01 1.0 7.42e+10 1.0 0.0e+00 0.0e+00
> 0.0e+00 51 45  0  0  0  51 45  0  0  0  1593
> > MatLUFactorNum         1 1.0 1.7209e-02 1.0 2.44e+07 1.0 0.0e+00 0.0e+00
> 0.0e+00  0  0  0  0  0   0  0  0  0  0  1420
> > MatCholFctrSym         1 1.0 8.8310e-04 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
> > MatCholFctrNum         1 1.0 3.6907e-04 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
> > MatILUFactorSym        1 1.0 3.7372e-03 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
> > MatAssemblyBegin      29 1.0 2.1458e-06 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
> > MatAssemblyEnd        29 1.0 9.9473e-03 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
> > MatGetRow          58026 1.0 2.8155e-03 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
> > MatGetRowIJ            2 1.0 0.0000e+00 0.0 0.00e+00 0.0 0.0e+00 0.0e+00
> > MatGetSubMatrice       6 1.0 1.5399e-02 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
> > MatGetOrdering         2 1.0 3.0112e-04 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
> > MatZeroEntries         6 1.0 2.9490e-03 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
> > MatView                7 1.0 3.4356e-03 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
> > KSPSetUp               4 1.0 9.4891e-05 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
> > KSPSolve               1 1.0 8.8793e+01 1.0 1.63e+11 1.0 0.0e+00 0.0e+00
> 0.0e+00 97100  0  0  0  97100  0  0  0  1840
> > PCSetUp                4 1.0 3.8375e-02 1.0 2.44e+07 1.0 0.0e+00 0.0e+00
> 0.0e+00  0  0  0  0  0   0  0  0  0  0   637
> > PCSetUpOnBlocks        5 1.0 2.1250e-02 1.0 2.44e+07 1.0 0.0e+00 0.0e+00
> 0.0e+00  0  0  0  0  0   0  0  0  0  0  1150
> > PCApply                5 1.0 8.8789e+01 1.0 1.63e+11 1.0 0.0e+00 0.0e+00
> > KSPSolve_FS_0          5 1.0 7.5364e-04 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
> > KSPSolve_FS_Schu       5 1.0 8.8785e+01 1.0 1.63e+11 1.0 0.0e+00 0.0e+00
> > KSPSolve_FS_Low        5 1.0 2.1019e-03 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
> Mem.
> >               Vector    91             91      9693912     0.
> >            Index Set    51             51       537888     0.
> >               Matrix    13             13     64097868     0.
> >               Viewer     1              0            0     0.
> > -ksp_monitor
> > -ksp_view
> > -log_view
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20170111/14cb5c88/attachment-0001.html>
    Residual norms for fieldsplit_FE_split_ solve.
    0 KSP Residual norm 7.439873800415e+00
    1 KSP Residual norm 2.271092312202e+00
    2 KSP Residual norm 1.579282324756e+00
    3 KSP Residual norm 1.107108552974e+00
    4 KSP Residual norm 8.906995999187e-01
    5 KSP Residual norm 7.119535581527e-01
    6 KSP Residual norm 6.292448465808e-01
    7 KSP Residual norm 5.574190632829e-01
    8 KSP Residual norm 4.914453903768e-01
    9 KSP Residual norm 4.169590427313e-01
   10 KSP Residual norm 3.833759307828e-01
   11 KSP Residual norm 3.525084900775e-01
   12 KSP Residual norm 3.090712658867e-01
   13 KSP Residual norm 3.072058092791e-01
   14 KSP Residual norm 2.791154478844e-01
   15 KSP Residual norm 2.596487823324e-01
   16 KSP Residual norm 2.454855113839e-01
   17 KSP Residual norm 2.323657304086e-01
   18 KSP Residual norm 2.180987080607e-01
   19 KSP Residual norm 2.071787317658e-01
   20 KSP Residual norm 1.892488656995e-01
   21 KSP Residual norm 1.812493522062e-01
   22 KSP Residual norm 1.876453055369e-01
   23 KSP Residual norm 1.683189793079e-01
   24 KSP Residual norm 1.543469424065e-01
   25 KSP Residual norm 1.496069368476e-01
   26 KSP Residual norm 1.493645624754e-01
   27 KSP Residual norm 1.525727733866e-01
   28 KSP Residual norm 1.504760809841e-01
   29 KSP Residual norm 1.398787428655e-01
   30 KSP Residual norm 1.377742552240e-01
   31 KSP Residual norm 1.350150247010e-01
   32 KSP Residual norm 1.275144910850e-01
   33 KSP Residual norm 1.273327004584e-01
   34 KSP Residual norm 1.216415065625e-01
   35 KSP Residual norm 1.109570051668e-01
   36 KSP Residual norm 1.074358443291e-01
   37 KSP Residual norm 1.061971546557e-01
   38 KSP Residual norm 1.067809057557e-01
   39 KSP Residual norm 1.063479786887e-01
   40 KSP Residual norm 1.034518470284e-01
   41 KSP Residual norm 9.721337391778e-02
   42 KSP Residual norm 9.699203830334e-02
   43 KSP Residual norm 9.481065986826e-02
   44 KSP Residual norm 9.136671340793e-02
   45 KSP Residual norm 8.851274329317e-02
   46 KSP Residual norm 8.467762039012e-02
   47 KSP Residual norm 8.471801429555e-02
   48 KSP Residual norm 8.278633364455e-02
   49 KSP Residual norm 7.838491006512e-02
   50 KSP Residual norm 7.670240644506e-02
   51 KSP Residual norm 8.043224588019e-02
   52 KSP Residual norm 8.363745629948e-02
   53 KSP Residual norm 7.940546973611e-02
   54 KSP Residual norm 7.456475032696e-02
   55 KSP Residual norm 7.700637275547e-02
   56 KSP Residual norm 7.543373247528e-02
   57 KSP Residual norm 7.094501517914e-02
   58 KSP Residual norm 7.075418803924e-02
   59 KSP Residual norm 6.974463189188e-02
   60 KSP Residual norm 6.564358161289e-02
   61 KSP Residual norm 6.777118961072e-02
   62 KSP Residual norm 6.572645071229e-02
   63 KSP Residual norm 6.592491054825e-02
   64 KSP Residual norm 6.361704393145e-02
   65 KSP Residual norm 6.091631661495e-02
   66 KSP Residual norm 6.045947178947e-02
   67 KSP Residual norm 5.960456641459e-02
   68 KSP Residual norm 5.849383480514e-02
   69 KSP Residual norm 5.706157714189e-02
   70 KSP Residual norm 5.785957008296e-02
   71 KSP Residual norm 5.598254854109e-02
   72 KSP Residual norm 5.456921702305e-02
   73 KSP Residual norm 5.612718298077e-02
   74 KSP Residual norm 5.404331315421e-02
   75 KSP Residual norm 5.445184161126e-02
   76 KSP Residual norm 5.513790692539e-02
   77 KSP Residual norm 5.603152577219e-02
   78 KSP Residual norm 5.594578881463e-02
   79 KSP Residual norm 5.270506297482e-02
   80 KSP Residual norm 4.969434451616e-02
   81 KSP Residual norm 5.066917256846e-02
   82 KSP Residual norm 5.145815352597e-02
   83 KSP Residual norm 4.855115729361e-02
   84 KSP Residual norm 4.872335394452e-02
   85 KSP Residual norm 4.674867276039e-02
   86 KSP Residual norm 4.754130141657e-02
   87 KSP Residual norm 4.833727177651e-02
   88 KSP Residual norm 4.753752603403e-02
   89 KSP Residual norm 4.711922842054e-02
   90 KSP Residual norm 4.405539388922e-02
   91 KSP Residual norm 4.296516931381e-02
   92 KSP Residual norm 4.339330987856e-02
   93 KSP Residual norm 4.309048328104e-02
   94 KSP Residual norm 4.249286390589e-02
   95 KSP Residual norm 4.279072317861e-02
   96 KSP Residual norm 4.138481489705e-02
   97 KSP Residual norm 4.075783749198e-02
   98 KSP Residual norm 4.150832258048e-02
   99 KSP Residual norm 4.196726309881e-02
  100 KSP Residual norm 4.511508557881e-02
  101 KSP Residual norm 4.353430099295e-02
  102 KSP Residual norm 4.110659276090e-02
  103 KSP Residual norm 4.216362776668e-02
  104 KSP Residual norm 4.132142431466e-02
  105 KSP Residual norm 3.937463571948e-02
  106 KSP Residual norm 3.847820147612e-02
  107 KSP Residual norm 3.903461144864e-02
  108 KSP Residual norm 3.873827003588e-02
  109 KSP Residual norm 3.757181226921e-02
  110 KSP Residual norm 3.713370747089e-02
  111 KSP Residual norm 3.797595762562e-02
  112 KSP Residual norm 3.904892207809e-02
  113 KSP Residual norm 3.832213482446e-02
  114 KSP Residual norm 3.673918137725e-02
  115 KSP Residual norm 3.568169366392e-02
  116 KSP Residual norm 3.463483623212e-02
  117 KSP Residual norm 3.474865380315e-02
  118 KSP Residual norm 3.369100450734e-02
  119 KSP Residual norm 3.429462851161e-02
  120 KSP Residual norm 3.356928597959e-02
  121 KSP Residual norm 3.388831153274e-02
  122 KSP Residual norm 3.403530170365e-02
  123 KSP Residual norm 3.432423924461e-02
  124 KSP Residual norm 3.480510081872e-02
  125 KSP Residual norm 3.501270104127e-02
  126 KSP Residual norm 3.436014578560e-02
  127 KSP Residual norm 3.313137022795e-02
  128 KSP Residual norm 3.224202549572e-02
  129 KSP Residual norm 3.282496094068e-02
  130 KSP Residual norm 3.179581680589e-02
  131 KSP Residual norm 3.126804650993e-02
  132 KSP Residual norm 3.164061472181e-02
  133 KSP Residual norm 3.064596217610e-02
  134 KSP Residual norm 3.123484050542e-02
  135 KSP Residual norm 3.098163173034e-02
  136 KSP Residual norm 3.021371993367e-02
  137 KSP Residual norm 2.997438018349e-02
  138 KSP Residual norm 2.996861618503e-02
  139 KSP Residual norm 2.952174027773e-02
  140 KSP Residual norm 2.781275108201e-02
  141 KSP Residual norm 2.831949666222e-02
  142 KSP Residual norm 2.943315787910e-02
  143 KSP Residual norm 2.861351453584e-02
  144 KSP Residual norm 2.857243223511e-02
  145 KSP Residual norm 2.776445330757e-02
  146 KSP Residual norm 2.815377297347e-02
  147 KSP Residual norm 2.833952777968e-02
  148 KSP Residual norm 2.820315095721e-02
  149 KSP Residual norm 2.887229075208e-02
  150 KSP Residual norm 2.979067721535e-02
  151 KSP Residual norm 2.815700116316e-02
  152 KSP Residual norm 2.680023054442e-02
  153 KSP Residual norm 2.639722486097e-02
  154 KSP Residual norm 2.662100285008e-02
  155 KSP Residual norm 2.675384875846e-02
  156 KSP Residual norm 2.701241246267e-02
  157 KSP Residual norm 2.643754530991e-02
  158 KSP Residual norm 2.592855185871e-02
  159 KSP Residual norm 2.618977338412e-02
  160 KSP Residual norm 2.586809270174e-02
  161 KSP Residual norm 2.576998073277e-02
  162 KSP Residual norm 2.540380238842e-02
  163 KSP Residual norm 2.495114311948e-02
  164 KSP Residual norm 2.455716236236e-02
  165 KSP Residual norm 2.428454731484e-02
  166 KSP Residual norm 2.464342635564e-02
  167 KSP Residual norm 2.452483143323e-02
  168 KSP Residual norm 2.481544666658e-02
  169 KSP Residual norm 2.477918836230e-02
  170 KSP Residual norm 2.359566978599e-02
  171 KSP Residual norm 2.418262225393e-02
  172 KSP Residual norm 2.564699145458e-02
  173 KSP Residual norm 2.500981972636e-02
  174 KSP Residual norm 2.471425418109e-02
  175 KSP Residual norm 2.445163739021e-02
  176 KSP Residual norm 2.385452288757e-02
  177 KSP Residual norm 2.428112914859e-02
  178 KSP Residual norm 2.291705127975e-02
  179 KSP Residual norm 2.271629416191e-02
  180 KSP Residual norm 2.345648624740e-02
  181 KSP Residual norm 2.411307961322e-02
  182 KSP Residual norm 2.305778032055e-02
  183 KSP Residual norm 2.363029408956e-02
  184 KSP Residual norm 2.334430183050e-02
  185 KSP Residual norm 2.288119542251e-02
  186 KSP Residual norm 2.268194883960e-02
  187 KSP Residual norm 2.194114600599e-02
  188 KSP Residual norm 2.138125374716e-02
  189 KSP Residual norm 2.122308178911e-02
  190 KSP Residual norm 2.167011211336e-02
  191 KSP Residual norm 2.124093196590e-02
  192 KSP Residual norm 2.254672827834e-02
  193 KSP Residual norm 2.259893744483e-02
  194 KSP Residual norm 2.124131449373e-02
  195 KSP Residual norm 2.128570772460e-02
  196 KSP Residual norm 2.272443514094e-02
  197 KSP Residual norm 2.248357368551e-02
  198 KSP Residual norm 2.186082830509e-02
  199 KSP Residual norm 2.193211823715e-02
  200 KSP Residual norm 2.092614010486e-02
  201 KSP Residual norm 2.058552529496e-02
  202 KSP Residual norm 2.093249615703e-02
  203 KSP Residual norm 2.045325798910e-02
  204 KSP Residual norm 2.043511462793e-02
  205 KSP Residual norm 2.037030539329e-02
  206 KSP Residual norm 2.103460538310e-02
  207 KSP Residual norm 2.069703021464e-02
  208 KSP Residual norm 1.978197990018e-02
  209 KSP Residual norm 1.997727225256e-02
  210 KSP Residual norm 2.014133842310e-02
  211 KSP Residual norm 1.909869680533e-02
  212 KSP Residual norm 1.898652371759e-02
  213 KSP Residual norm 1.917618301995e-02
  214 KSP Residual norm 1.903312625797e-02
  215 KSP Residual norm 1.935123404273e-02
  216 KSP Residual norm 1.876736458793e-02
  217 KSP Residual norm 1.907165437333e-02
  218 KSP Residual norm 1.931891473034e-02
  219 KSP Residual norm 1.947700505686e-02
  220 KSP Residual norm 1.946867709414e-02
  221 KSP Residual norm 1.975097371142e-02
  222 KSP Residual norm 1.936728796435e-02
  223 KSP Residual norm 1.861169070605e-02
  224 KSP Residual norm 1.821669203618e-02
  225 KSP Residual norm 1.830030189024e-02
  226 KSP Residual norm 1.847574748920e-02
  227 KSP Residual norm 1.821934647650e-02
  228 KSP Residual norm 1.858550789703e-02
  229 KSP Residual norm 1.790620122765e-02
  230 KSP Residual norm 1.736046756570e-02
  231 KSP Residual norm 1.808056503558e-02
  232 KSP Residual norm 1.831571970355e-02
  233 KSP Residual norm 1.782550071852e-02
  234 KSP Residual norm 1.704250503644e-02
  235 KSP Residual norm 1.775557915607e-02
  236 KSP Residual norm 1.749168705311e-02
  237 KSP Residual norm 1.716635016316e-02
  238 KSP Residual norm 1.697804812505e-02
  239 KSP Residual norm 1.719949296811e-02
  240 KSP Residual norm 1.798197854926e-02
  241 KSP Residual norm 1.773491134572e-02
  242 KSP Residual norm 1.724256440113e-02
  243 KSP Residual norm 1.777189498102e-02
  244 KSP Residual norm 1.819945790203e-02
  245 KSP Residual norm 1.762431996374e-02
  246 KSP Residual norm 1.711668380042e-02
  247 KSP Residual norm 1.717847950917e-02
  248 KSP Residual norm 1.675314264329e-02
  249 KSP Residual norm 1.672527101557e-02
  250 KSP Residual norm 1.652103275422e-02
  251 KSP Residual norm 1.696676153706e-02
  252 KSP Residual norm 1.715357344334e-02
  253 KSP Residual norm 1.706981861601e-02
  254 KSP Residual norm 1.696030869204e-02
  255 KSP Residual norm 1.763423572015e-02
  256 KSP Residual norm 1.829751997263e-02
  257 KSP Residual norm 1.972223165522e-02
  258 KSP Residual norm 2.130118969187e-02
  259 KSP Residual norm 2.315722127923e-02
  260 KSP Residual norm 2.684768883739e-02
  261 KSP Residual norm 3.348163940639e-02
  262 KSP Residual norm 4.199127730378e-02
  263 KSP Residual norm 5.398653105045e-02
  264 KSP Residual norm 6.821839369420e-02
  265 KSP Residual norm 8.029032178293e-02
  266 KSP Residual norm 8.815811508553e-02
  267 KSP Residual norm 8.962694266764e-02
  268 KSP Residual norm 8.065993997821e-02
  269 KSP Residual norm 6.648938465331e-02
  270 KSP Residual norm 5.345676431768e-02
  271 KSP Residual norm 3.972291572909e-02
  272 KSP Residual norm 2.946517479139e-02
  273 KSP Residual norm 2.384222409654e-02
  274 KSP Residual norm 2.191852135161e-02
  275 KSP Residual norm 2.190584659264e-02
  276 KSP Residual norm 2.207283053774e-02
  277 KSP Residual norm 2.285429680636e-02
  278 KSP Residual norm 2.042181640152e-02
  279 KSP Residual norm 1.666191118634e-02
  280 KSP Residual norm 1.233344503183e-02
  281 KSP Residual norm 9.732943526464e-03
  282 KSP Residual norm 8.231148322685e-03
  283 KSP Residual norm 7.658532417128e-03
  284 KSP Residual norm 7.159090758549e-03
  285 KSP Residual norm 6.837740854101e-03
  286 KSP Residual norm 6.771864567159e-03
  287 KSP Residual norm 6.506633131436e-03
  288 KSP Residual norm 6.552854756680e-03
  289 KSP Residual norm 6.465354304817e-03
  290 KSP Residual norm 6.348201270809e-03
  291 KSP Residual norm 6.054566113069e-03
  292 KSP Residual norm 5.368641816405e-03
  293 KSP Residual norm 4.740328570452e-03
  294 KSP Residual norm 4.455220605625e-03
  295 KSP Residual norm 4.414378942258e-03
  296 KSP Residual norm 4.365393288580e-03
  297 KSP Residual norm 4.112409955106e-03
  298 KSP Residual norm 3.683251112994e-03
  299 KSP Residual norm 3.338614520090e-03
  300 KSP Residual norm 3.099327570392e-03
  301 KSP Residual norm 3.109917829137e-03
  302 KSP Residual norm 3.004996253210e-03
  303 KSP Residual norm 2.830520603323e-03
  304 KSP Residual norm 2.748235291994e-03
  305 KSP Residual norm 2.914293446395e-03
  306 KSP Residual norm 2.780149150920e-03
  307 KSP Residual norm 2.608542174674e-03
  308 KSP Residual norm 2.404201656147e-03
  309 KSP Residual norm 2.247889289592e-03
  310 KSP Residual norm 2.359008329300e-03
  311 KSP Residual norm 2.662652962160e-03
  312 KSP Residual norm 2.917896860107e-03
  313 KSP Residual norm 2.781060424836e-03
  314 KSP Residual norm 2.499901538412e-03
  315 KSP Residual norm 2.318409392919e-03
  316 KSP Residual norm 2.237948977105e-03
  317 KSP Residual norm 2.275842789015e-03
  318 KSP Residual norm 2.095361798572e-03
  319 KSP Residual norm 1.939363510796e-03
  320 KSP Residual norm 1.824756647376e-03
  321 KSP Residual norm 1.855785739942e-03
  322 KSP Residual norm 1.876266124266e-03
  323 KSP Residual norm 1.706083418355e-03
  324 KSP Residual norm 1.504223272392e-03
  325 KSP Residual norm 1.367003023878e-03
  326 KSP Residual norm 1.325025357987e-03
  327 KSP Residual norm 1.217685553397e-03
  328 KSP Residual norm 1.147595137980e-03
  329 KSP Residual norm 1.140757899810e-03
  330 KSP Residual norm 1.161337539671e-03
  331 KSP Residual norm 1.189634577655e-03
  332 KSP Residual norm 1.156853032944e-03
  333 KSP Residual norm 1.168543981069e-03
  334 KSP Residual norm 1.255758863060e-03
  335 KSP Residual norm 1.329900079847e-03
  336 KSP Residual norm 1.277788599679e-03
  337 KSP Residual norm 1.156283394140e-03
  338 KSP Residual norm 1.170787202744e-03
  339 KSP Residual norm 1.165756028629e-03
  340 KSP Residual norm 1.149594359750e-03
  341 KSP Residual norm 1.035743087984e-03
  342 KSP Residual norm 9.055748010466e-04
  343 KSP Residual norm 8.729284667762e-04
  344 KSP Residual norm 9.123661560199e-04
  345 KSP Residual norm 9.403865973752e-04
  346 KSP Residual norm 9.397482648680e-04
  347 KSP Residual norm 9.781230092460e-04
  348 KSP Residual norm 1.028764754662e-03
  349 KSP Residual norm 1.098227372587e-03
  350 KSP Residual norm 1.131938817545e-03
  351 KSP Residual norm 1.178183837363e-03
  352 KSP Residual norm 1.219263604270e-03
  353 KSP Residual norm 1.285550443119e-03
  354 KSP Residual norm 1.314390656564e-03
  355 KSP Residual norm 1.280155123264e-03
  356 KSP Residual norm 1.337317413181e-03
  357 KSP Residual norm 1.375269807467e-03
  358 KSP Residual norm 1.339949505912e-03
  359 KSP Residual norm 1.312858194973e-03
  360 KSP Residual norm 1.302230401883e-03
  361 KSP Residual norm 1.296953236606e-03
  362 KSP Residual norm 1.241958131296e-03
  363 KSP Residual norm 1.317399611984e-03
  364 KSP Residual norm 1.404700632013e-03
  365 KSP Residual norm 1.465377387279e-03
  366 KSP Residual norm 1.449387099771e-03
  367 KSP Residual norm 1.340755308031e-03
  368 KSP Residual norm 1.276373010248e-03
  369 KSP Residual norm 1.300492007224e-03
  370 KSP Residual norm 1.305680420594e-03
  371 KSP Residual norm 1.247563315763e-03
  372 KSP Residual norm 1.215067995838e-03
  373 KSP Residual norm 1.245842567847e-03
  374 KSP Residual norm 1.248065264454e-03
  375 KSP Residual norm 1.279964483758e-03
  376 KSP Residual norm 1.296017171744e-03
  377 KSP Residual norm 1.322475758719e-03
  378 KSP Residual norm 1.346553928101e-03
  379 KSP Residual norm 1.409217159475e-03
  380 KSP Residual norm 1.427387037000e-03
  381 KSP Residual norm 1.385982705722e-03
  382 KSP Residual norm 1.326140475173e-03
  383 KSP Residual norm 1.363313832696e-03
  384 KSP Residual norm 1.399869841773e-03
  385 KSP Residual norm 1.382389217698e-03
  386 KSP Residual norm 1.354178848227e-03
  387 KSP Residual norm 1.352742312886e-03
  388 KSP Residual norm 1.353096597807e-03
  389 KSP Residual norm 1.334145707497e-03
  390 KSP Residual norm 1.244976876447e-03
  391 KSP Residual norm 1.206076100038e-03
  392 KSP Residual norm 1.261782193894e-03
  393 KSP Residual norm 1.300016335362e-03
  394 KSP Residual norm 1.220254929690e-03
  395 KSP Residual norm 1.106128865061e-03
  396 KSP Residual norm 1.046642239943e-03
  397 KSP Residual norm 1.064825863444e-03
  398 KSP Residual norm 1.076071139351e-03
  399 KSP Residual norm 1.072418592011e-03
  400 KSP Residual norm 1.054699683117e-03
  401 KSP Residual norm 1.044433124340e-03
  402 KSP Residual norm 1.067396312320e-03
  403 KSP Residual norm 1.152053727618e-03
  404 KSP Residual norm 1.214731081875e-03
  405 KSP Residual norm 1.200559675103e-03
  406 KSP Residual norm 1.118454110419e-03
  407 KSP Residual norm 1.065613359694e-03
  408 KSP Residual norm 1.059780664889e-03
  409 KSP Residual norm 1.147890672875e-03
  410 KSP Residual norm 1.160152942280e-03
  411 KSP Residual norm 1.155457644175e-03
  412 KSP Residual norm 1.218328095414e-03
  413 KSP Residual norm 1.282417285128e-03
  414 KSP Residual norm 1.290107982445e-03
  415 KSP Residual norm 1.276638656415e-03
  416 KSP Residual norm 1.278858623101e-03
  417 KSP Residual norm 1.363772235297e-03
  418 KSP Residual norm 1.419371458797e-03
  419 KSP Residual norm 1.412832072037e-03
  420 KSP Residual norm 1.365748169574e-03
  421 KSP Residual norm 1.405720923862e-03
  422 KSP Residual norm 1.453177134976e-03
  423 KSP Residual norm 1.520454157083e-03
  424 KSP Residual norm 1.446299931363e-03
  425 KSP Residual norm 1.351877459723e-03
  426 KSP Residual norm 1.327808945913e-03
  427 KSP Residual norm 1.350351799488e-03
  428 KSP Residual norm 1.385479038188e-03
  429 KSP Residual norm 1.387796324528e-03
  430 KSP Residual norm 1.384647149458e-03
  431 KSP Residual norm 1.460355026546e-03
  432 KSP Residual norm 1.480065918295e-03
  433 KSP Residual norm 1.456790034607e-03
  434 KSP Residual norm 1.429909079454e-03
  435 KSP Residual norm 1.451310070774e-03
  436 KSP Residual norm 1.406727345937e-03
  437 KSP Residual norm 1.325991263019e-03
  438 KSP Residual norm 1.246160382525e-03
  439 KSP Residual norm 1.255009836241e-03
  440 KSP Residual norm 1.303332052273e-03
  441 KSP Residual norm 1.286598917010e-03
  442 KSP Residual norm 1.239425544177e-03
  443 KSP Residual norm 1.252515845760e-03
  444 KSP Residual norm 1.294422403484e-03
  445 KSP Residual norm 1.276765289333e-03
  446 KSP Residual norm 1.244824813612e-03
  447 KSP Residual norm 1.183245770405e-03
  448 KSP Residual norm 1.153565086222e-03
  449 KSP Residual norm 1.119489362997e-03
  450 KSP Residual norm 1.117623170827e-03
  451 KSP Residual norm 1.096029604095e-03
  452 KSP Residual norm 1.055193076106e-03
  453 KSP Residual norm 1.005504863389e-03
  454 KSP Residual norm 9.941050424498e-04
  455 KSP Residual norm 9.770049958018e-04
  456 KSP Residual norm 9.092852704615e-04
  457 KSP Residual norm 8.974990456384e-04
  458 KSP Residual norm 9.012999264230e-04
  459 KSP Residual norm 9.147555348631e-04
  460 KSP Residual norm 9.349542493543e-04
  461 KSP Residual norm 9.631165447434e-04
  462 KSP Residual norm 9.927856223692e-04
  463 KSP Residual norm 9.783830479125e-04
  464 KSP Residual norm 9.818168561440e-04
  465 KSP Residual norm 9.896615948644e-04
  466 KSP Residual norm 1.006369854207e-03
  467 KSP Residual norm 9.939846132237e-04
  468 KSP Residual norm 9.767849618419e-04
  469 KSP Residual norm 9.502666517985e-04
  470 KSP Residual norm 9.627158476888e-04
  471 KSP Residual norm 9.696220358260e-04
  472 KSP Residual norm 9.555925574913e-04
  473 KSP Residual norm 9.596753073191e-04
  474 KSP Residual norm 9.778312668318e-04
  475 KSP Residual norm 9.886046752730e-04
  476 KSP Residual norm 9.764004519850e-04
  477 KSP Residual norm 9.018124220522e-04
  478 KSP Residual norm 8.857320067402e-04
  479 KSP Residual norm 8.713510421022e-04
  480 KSP Residual norm 8.969565417031e-04
  481 KSP Residual norm 9.336233261242e-04
  482 KSP Residual norm 9.433172095001e-04
  483 KSP Residual norm 9.161931619946e-04
  484 KSP Residual norm 9.038656681831e-04
  485 KSP Residual norm 9.181623563365e-04
  486 KSP Residual norm 9.069719514158e-04
  487 KSP Residual norm 9.191716357195e-04
  488 KSP Residual norm 9.206538113900e-04
  489 KSP Residual norm 9.309524213734e-04
  490 KSP Residual norm 9.715978975188e-04
  491 KSP Residual norm 1.013562676274e-03
  492 KSP Residual norm 1.009919531281e-03
  493 KSP Residual norm 1.059499239989e-03
  494 KSP Residual norm 1.076813253306e-03
  495 KSP Residual norm 1.074668719575e-03
  496 KSP Residual norm 1.133223873975e-03
  497 KSP Residual norm 1.147944277888e-03
  498 KSP Residual norm 1.192672858255e-03
  499 KSP Residual norm 1.304195086532e-03
  500 KSP Residual norm 1.302173161555e-03
  501 KSP Residual norm 1.270177225081e-03
  502 KSP Residual norm 1.216566257579e-03
  503 KSP Residual norm 1.165110642117e-03
  504 KSP Residual norm 1.195550821372e-03
  505 KSP Residual norm 1.192631583738e-03
  506 KSP Residual norm 1.237066709884e-03
  507 KSP Residual norm 1.210893265197e-03
  508 KSP Residual norm 1.078432807806e-03
  509 KSP Residual norm 1.008083683026e-03
  510 KSP Residual norm 1.056488978524e-03
  511 KSP Residual norm 1.126142245496e-03
  512 KSP Residual norm 1.128376995711e-03
  513 KSP Residual norm 1.096525953864e-03
  514 KSP Residual norm 1.095326824687e-03
  515 KSP Residual norm 1.142282392403e-03
  516 KSP Residual norm 1.139660427298e-03
  517 KSP Residual norm 1.094055452431e-03
  518 KSP Residual norm 1.063409470212e-03
  519 KSP Residual norm 1.110273349622e-03
  520 KSP Residual norm 1.202600760469e-03
  521 KSP Residual norm 1.268411358991e-03
  522 KSP Residual norm 1.277862861022e-03
  523 KSP Residual norm 1.305649608547e-03
  524 KSP Residual norm 1.340498031515e-03
  525 KSP Residual norm 1.325384291903e-03
  526 KSP Residual norm 1.304614031779e-03
  527 KSP Residual norm 1.287973763995e-03
  528 KSP Residual norm 1.267718986109e-03
  529 KSP Residual norm 1.241471871921e-03
  530 KSP Residual norm 1.269218895099e-03
  531 KSP Residual norm 1.252827011848e-03
  532 KSP Residual norm 1.206084773674e-03
  533 KSP Residual norm 1.191593136725e-03
  534 KSP Residual norm 1.164464769735e-03
  535 KSP Residual norm 1.192334038324e-03
  536 KSP Residual norm 1.219492933410e-03
  537 KSP Residual norm 1.199743127274e-03
  538 KSP Residual norm 1.248335920228e-03
  539 KSP Residual norm 1.252673398232e-03
  540 KSP Residual norm 1.246751345189e-03
  541 KSP Residual norm 1.205530499378e-03
  542 KSP Residual norm 1.195070824271e-03
  543 KSP Residual norm 1.223501263517e-03
  544 KSP Residual norm 1.262089895506e-03
  545 KSP Residual norm 1.323061159399e-03
  546 KSP Residual norm 1.349425603612e-03
  547 KSP Residual norm 1.309128586794e-03
  548 KSP Residual norm 1.302075761304e-03
  549 KSP Residual norm 1.331125648600e-03
  550 KSP Residual norm 1.353544159260e-03
  551 KSP Residual norm 1.377107006558e-03
  552 KSP Residual norm 1.349377941781e-03
  553 KSP Residual norm 1.358605387046e-03
  554 KSP Residual norm 1.436355572419e-03
  555 KSP Residual norm 1.502607291761e-03
  556 KSP Residual norm 1.449345666679e-03
  557 KSP Residual norm 1.424783995975e-03
  558 KSP Residual norm 1.427960551265e-03
  559 KSP Residual norm 1.427466632801e-03
  560 KSP Residual norm 1.481062651578e-03
  561 KSP Residual norm 1.562158551958e-03
  562 KSP Residual norm 1.598554803542e-03
  563 KSP Residual norm 1.597557725759e-03
  564 KSP Residual norm 1.659863389266e-03
  565 KSP Residual norm 1.695117214430e-03
  566 KSP Residual norm 1.751026900278e-03
  567 KSP Residual norm 1.739353545363e-03
  568 KSP Residual norm 1.817037903174e-03
  569 KSP Residual norm 1.857665704497e-03
  570 KSP Residual norm 1.782656590883e-03
  571 KSP Residual norm 1.821065237934e-03
  572 KSP Residual norm 1.812838460391e-03
  573 KSP Residual norm 1.922829241083e-03
  574 KSP Residual norm 1.960159350212e-03
  575 KSP Residual norm 2.020917548665e-03
  576 KSP Residual norm 2.001600983891e-03
  577 KSP Residual norm 1.941586650750e-03
  578 KSP Residual norm 2.010907353233e-03
  579 KSP Residual norm 2.231140523179e-03
  580 KSP Residual norm 2.374708165863e-03
  581 KSP Residual norm 2.445724331607e-03
  582 KSP Residual norm 2.451548247846e-03
  583 KSP Residual norm 2.471622812581e-03
  584 KSP Residual norm 2.546071482432e-03
  585 KSP Residual norm 2.576192819880e-03
  586 KSP Residual norm 2.684760642875e-03
  587 KSP Residual norm 2.844454005347e-03
  588 KSP Residual norm 2.891295774829e-03
  589 KSP Residual norm 2.827164491452e-03
  590 KSP Residual norm 2.978210284874e-03
  591 KSP Residual norm 3.118874246324e-03
  592 KSP Residual norm 3.226927540750e-03
  593 KSP Residual norm 3.297702822485e-03
  594 KSP Residual norm 3.269635997402e-03
  595 KSP Residual norm 3.272395692426e-03
  596 KSP Residual norm 3.127220033345e-03
  597 KSP Residual norm 3.002089958033e-03
  598 KSP Residual norm 2.887952193552e-03
  599 KSP Residual norm 2.789545707468e-03
  600 KSP Residual norm 2.728822784045e-03
  601 KSP Residual norm 2.586721450953e-03
  602 KSP Residual norm 2.456861877398e-03
  603 KSP Residual norm 2.270195608825e-03
  604 KSP Residual norm 2.234015372155e-03
  605 KSP Residual norm 2.271006954022e-03
  606 KSP Residual norm 2.274709919172e-03
  607 KSP Residual norm 2.319140505599e-03
  608 KSP Residual norm 2.371304192676e-03
  609 KSP Residual norm 2.381183182868e-03
  610 KSP Residual norm 2.473342013503e-03
  611 KSP Residual norm 2.668702366905e-03
  612 KSP Residual norm 2.840263324868e-03
  613 KSP Residual norm 2.887342238157e-03
  614 KSP Residual norm 2.945717643492e-03
  615 KSP Residual norm 2.954708258451e-03
  616 KSP Residual norm 2.782576372141e-03
  617 KSP Residual norm 2.604890421262e-03
  618 KSP Residual norm 2.554034090005e-03
  619 KSP Residual norm 2.623418706237e-03
  620 KSP Residual norm 2.561484842595e-03
  621 KSP Residual norm 2.393195287692e-03
  622 KSP Residual norm 2.160609863780e-03
  623 KSP Residual norm 1.979602551998e-03
  624 KSP Residual norm 1.963931478777e-03
  625 KSP Residual norm 1.948555791659e-03
  626 KSP Residual norm 2.017840029712e-03
  627 KSP Residual norm 2.046199056507e-03
  628 KSP Residual norm 1.993108418353e-03
  629 KSP Residual norm 1.974961947376e-03
  630 KSP Residual norm 2.061584360663e-03
  631 KSP Residual norm 2.054957286204e-03
  632 KSP Residual norm 1.990859027025e-03
  633 KSP Residual norm 2.041368256010e-03
  634 KSP Residual norm 2.058655836834e-03
  635 KSP Residual norm 2.099752038269e-03
  636 KSP Residual norm 2.131260502055e-03
  637 KSP Residual norm 2.152145468088e-03
  638 KSP Residual norm 2.186736970547e-03
  639 KSP Residual norm 2.226068625504e-03
  640 KSP Residual norm 2.414508229979e-03
  641 KSP Residual norm 2.641630675320e-03
  642 KSP Residual norm 2.875761700403e-03
  643 KSP Residual norm 3.128751719400e-03
  644 KSP Residual norm 3.218863877361e-03
  645 KSP Residual norm 3.286440896976e-03
  646 KSP Residual norm 3.573443161029e-03
  647 KSP Residual norm 3.886465854832e-03
  648 KSP Residual norm 3.996486091627e-03
  649 KSP Residual norm 3.952223090674e-03
  650 KSP Residual norm 4.148696249293e-03
  651 KSP Residual norm 4.079176608710e-03
  652 KSP Residual norm 3.918952724596e-03
  653 KSP Residual norm 3.923035202176e-03
  654 KSP Residual norm 3.944710633091e-03
  655 KSP Residual norm 3.857676629281e-03
  656 KSP Residual norm 3.736280082312e-03
  657 KSP Residual norm 3.793661571477e-03
  658 KSP Residual norm 3.873896125551e-03
  659 KSP Residual norm 3.877810193883e-03
  660 KSP Residual norm 4.169433784065e-03
  661 KSP Residual norm 4.323131896838e-03
  662 KSP Residual norm 4.296835496769e-03
  663 KSP Residual norm 4.207135380912e-03
  664 KSP Residual norm 4.031582293437e-03
  665 KSP Residual norm 4.218523456173e-03
  666 KSP Residual norm 4.529317974038e-03
  667 KSP Residual norm 4.934835798003e-03
  668 KSP Residual norm 5.301936631949e-03
  669 KSP Residual norm 5.277983685620e-03
  670 KSP Residual norm 5.019195591950e-03
  671 KSP Residual norm 4.851201693366e-03
  672 KSP Residual norm 4.734902022510e-03
  673 KSP Residual norm 4.976852212368e-03
  674 KSP Residual norm 5.193092769362e-03
  675 KSP Residual norm 5.074930831870e-03
  676 KSP Residual norm 5.032785592826e-03
  677 KSP Residual norm 5.158280095896e-03
  678 KSP Residual norm 5.322468916220e-03
  679 KSP Residual norm 5.634887770503e-03
  680 KSP Residual norm 5.909765459769e-03
  681 KSP Residual norm 6.020179701853e-03
  682 KSP Residual norm 5.783216033479e-03
  683 KSP Residual norm 5.624748149217e-03
  684 KSP Residual norm 5.501514634248e-03
  685 KSP Residual norm 5.696721575211e-03
  686 KSP Residual norm 5.715606984051e-03
  687 KSP Residual norm 5.562257632383e-03
  688 KSP Residual norm 5.544174264842e-03
  689 KSP Residual norm 5.485930659494e-03
  690 KSP Residual norm 4.956546863206e-03
  691 KSP Residual norm 4.632123369208e-03
  692 KSP Residual norm 4.604542140537e-03
  693 KSP Residual norm 4.866250739707e-03
  694 KSP Residual norm 4.773117405448e-03
  695 KSP Residual norm 4.708889265211e-03
  696 KSP Residual norm 4.918986654095e-03
  697 KSP Residual norm 5.108781269711e-03
  698 KSP Residual norm 4.924217059739e-03
  699 KSP Residual norm 4.618712978303e-03
  700 KSP Residual norm 4.540370025483e-03
  701 KSP Residual norm 4.648699130247e-03
  702 KSP Residual norm 4.530699767673e-03
  703 KSP Residual norm 4.208925421903e-03
  704 KSP Residual norm 4.188225308855e-03
  705 KSP Residual norm 4.422248684790e-03
  706 KSP Residual norm 4.568392073765e-03
  707 KSP Residual norm 4.616808828879e-03
  708 KSP Residual norm 4.588543206558e-03
  709 KSP Residual norm 4.639488790088e-03
  710 KSP Residual norm 4.444272664026e-03
  711 KSP Residual norm 4.234628347681e-03
  712 KSP Residual norm 4.127758383775e-03
  713 KSP Residual norm 4.226146707318e-03
  714 KSP Residual norm 4.315745072182e-03
  715 KSP Residual norm 4.414551383475e-03
  716 KSP Residual norm 4.526361096101e-03
  717 KSP Residual norm 4.821404255311e-03
  718 KSP Residual norm 5.048407023781e-03
  719 KSP Residual norm 4.865432067942e-03
  720 KSP Residual norm 4.736673154911e-03
  721 KSP Residual norm 4.844045662115e-03
  722 KSP Residual norm 5.025216696831e-03
  723 KSP Residual norm 5.063807199625e-03
  724 KSP Residual norm 5.199316362538e-03
  725 KSP Residual norm 5.073180119090e-03
  726 KSP Residual norm 4.867937378468e-03
  727 KSP Residual norm 4.622519181293e-03
  728 KSP Residual norm 4.301126032899e-03
  729 KSP Residual norm 4.102680159217e-03
  730 KSP Residual norm 4.182928190220e-03
  731 KSP Residual norm 4.286367784157e-03
  732 KSP Residual norm 4.391122318785e-03
  733 KSP Residual norm 4.595538944216e-03
  734 KSP Residual norm 4.706566736553e-03
  735 KSP Residual norm 4.503865315399e-03
  736 KSP Residual norm 4.316431285229e-03
  737 KSP Residual norm 4.430407108087e-03
  738 KSP Residual norm 4.506848843703e-03
  739 KSP Residual norm 4.433850111061e-03
  740 KSP Residual norm 4.380771081996e-03
  741 KSP Residual norm 4.222631885474e-03
  742 KSP Residual norm 4.147771849579e-03
  743 KSP Residual norm 4.365639718295e-03
  744 KSP Residual norm 4.717559413792e-03
  745 KSP Residual norm 4.814102031643e-03
  746 KSP Residual norm 4.664000257623e-03
  747 KSP Residual norm 4.828979911030e-03
  748 KSP Residual norm 4.936597793490e-03
  749 KSP Residual norm 4.861591122631e-03
  750 KSP Residual norm 4.672726595736e-03
  751 KSP Residual norm 4.922548149667e-03
  752 KSP Residual norm 5.229361787727e-03
  753 KSP Residual norm 5.249145190642e-03
  754 KSP Residual norm 4.948681226659e-03
  755 KSP Residual norm 4.630066570005e-03
  756 KSP Residual norm 4.599738801059e-03
  757 KSP Residual norm 4.929083792314e-03
  758 KSP Residual norm 5.566633954187e-03
  759 KSP Residual norm 5.769661533521e-03
  760 KSP Residual norm 5.644415061329e-03
  761 KSP Residual norm 5.704979658186e-03
  762 KSP Residual norm 5.491941722453e-03
  763 KSP Residual norm 5.126667613508e-03
  764 KSP Residual norm 4.851766976706e-03
  765 KSP Residual norm 4.811919456483e-03
  766 KSP Residual norm 4.907107900783e-03
  767 KSP Residual norm 5.248085780992e-03
  768 KSP Residual norm 5.489611963591e-03
  769 KSP Residual norm 5.983835818817e-03
  770 KSP Residual norm 6.525916643132e-03
  771 KSP Residual norm 6.778487524504e-03
  772 KSP Residual norm 6.669372553854e-03
  773 KSP Residual norm 6.135866213372e-03
  774 KSP Residual norm 5.783129247859e-03
  775 KSP Residual norm 5.784201879151e-03
  776 KSP Residual norm 5.741559179621e-03
  777 KSP Residual norm 5.703354544397e-03
  778 KSP Residual norm 5.482250606638e-03
  779 KSP Residual norm 5.310252890419e-03
  780 KSP Residual norm 5.335711864097e-03
  781 KSP Residual norm 5.313727521953e-03
  782 KSP Residual norm 5.298550285404e-03
  783 KSP Residual norm 5.277860914991e-03
  784 KSP Residual norm 5.562270366961e-03
  785 KSP Residual norm 5.773676284701e-03
  786 KSP Residual norm 5.937828098629e-03
  787 KSP Residual norm 5.933205595583e-03
  788 KSP Residual norm 5.706620882406e-03
  789 KSP Residual norm 5.746541406510e-03
  790 KSP Residual norm 5.682632330616e-03
  791 KSP Residual norm 5.718373329312e-03
  792 KSP Residual norm 5.858127842517e-03
  793 KSP Residual norm 6.036029033969e-03
  794 KSP Residual norm 5.937362017402e-03
  795 KSP Residual norm 5.662821329724e-03
  796 KSP Residual norm 5.570868424837e-03
  797 KSP Residual norm 5.736255872605e-03
  798 KSP Residual norm 5.718267824764e-03
  799 KSP Residual norm 5.523708236915e-03
  800 KSP Residual norm 5.260143665610e-03
  801 KSP Residual norm 5.273276972924e-03
  802 KSP Residual norm 5.326177610156e-03
  803 KSP Residual norm 5.470489474939e-03
  804 KSP Residual norm 5.563660821212e-03
  805 KSP Residual norm 5.450467821544e-03
  806 KSP Residual norm 5.257754749895e-03
  807 KSP Residual norm 5.173273041024e-03
  808 KSP Residual norm 5.173399710786e-03
  809 KSP Residual norm 5.129745167935e-03
  810 KSP Residual norm 4.990486065819e-03
  811 KSP Residual norm 4.752904983010e-03
  812 KSP Residual norm 4.620248446524e-03
  813 KSP Residual norm 4.643793500577e-03
  814 KSP Residual norm 4.670321867182e-03
  815 KSP Residual norm 4.617087182743e-03
  816 KSP Residual norm 4.700188292896e-03
  817 KSP Residual norm 4.605612711004e-03
  818 KSP Residual norm 4.383306226908e-03
  819 KSP Residual norm 4.491049783797e-03
  820 KSP Residual norm 4.641695104821e-03
  821 KSP Residual norm 4.728778395632e-03
  822 KSP Residual norm 4.726685398043e-03
  823 KSP Residual norm 4.719323445919e-03
  824 KSP Residual norm 4.397459455653e-03
  825 KSP Residual norm 4.202202803142e-03
  826 KSP Residual norm 4.187108103326e-03
  827 KSP Residual norm 4.413636897633e-03
  828 KSP Residual norm 4.294243790417e-03
  829 KSP Residual norm 4.237713512230e-03
  830 KSP Residual norm 4.230817171428e-03
  831 KSP Residual norm 4.361317085853e-03
  832 KSP Residual norm 4.322420049048e-03
  833 KSP Residual norm 4.333158250701e-03
  834 KSP Residual norm 4.272257205512e-03
  835 KSP Residual norm 4.166208845377e-03
  836 KSP Residual norm 4.276427624622e-03
  837 KSP Residual norm 4.262789381603e-03
  838 KSP Residual norm 4.390849186044e-03
  839 KSP Residual norm 4.392670055004e-03
  840 KSP Residual norm 4.197153591994e-03
  841 KSP Residual norm 3.985740589991e-03
  842 KSP Residual norm 3.751916382322e-03
  843 KSP Residual norm 3.744476290366e-03
  844 KSP Residual norm 3.703285656437e-03
  845 KSP Residual norm 3.681674911257e-03
  846 KSP Residual norm 3.665749856416e-03
  847 KSP Residual norm 3.795682207139e-03
  848 KSP Residual norm 3.879211906228e-03
  849 KSP Residual norm 3.904866739752e-03
  850 KSP Residual norm 4.053463668093e-03
  851 KSP Residual norm 4.310206873307e-03
  852 KSP Residual norm 4.398468828346e-03
  853 KSP Residual norm 4.303875562632e-03
  854 KSP Residual norm 4.281086768268e-03
  855 KSP Residual norm 4.381377636333e-03
  856 KSP Residual norm 4.408508579163e-03
  857 KSP Residual norm 4.261455674502e-03
  858 KSP Residual norm 4.085046370784e-03
  859 KSP Residual norm 3.962246614559e-03
  860 KSP Residual norm 4.017324998468e-03
  861 KSP Residual norm 4.080511395918e-03
  862 KSP Residual norm 4.036490084737e-03
  863 KSP Residual norm 3.937069305169e-03
  864 KSP Residual norm 3.707986416453e-03
  865 KSP Residual norm 3.777951030973e-03
  866 KSP Residual norm 3.974784104611e-03
  867 KSP Residual norm 4.188430303811e-03
  868 KSP Residual norm 4.219085975362e-03
  869 KSP Residual norm 4.145977225117e-03
  870 KSP Residual norm 4.181287665007e-03
  871 KSP Residual norm 4.195306731661e-03
  872 KSP Residual norm 4.174729054987e-03
  873 KSP Residual norm 4.178829217510e-03
  874 KSP Residual norm 4.152426882362e-03
  875 KSP Residual norm 4.337268072075e-03
  876 KSP Residual norm 4.575096886853e-03
  877 KSP Residual norm 4.540538034903e-03
  878 KSP Residual norm 4.689722606122e-03
  879 KSP Residual norm 5.092002143298e-03
  880 KSP Residual norm 5.426101401836e-03
  881 KSP Residual norm 5.319771478453e-03
  882 KSP Residual norm 5.065400101422e-03
  883 KSP Residual norm 4.987627471669e-03
  884 KSP Residual norm 5.231010313901e-03
  885 KSP Residual norm 5.697968184051e-03
  886 KSP Residual norm 5.984576951654e-03
  887 KSP Residual norm 5.890014849194e-03
  888 KSP Residual norm 5.765833588141e-03
  889 KSP Residual norm 5.831964254872e-03
  890 KSP Residual norm 5.804212026051e-03
  891 KSP Residual norm 5.453299776526e-03
  892 KSP Residual norm 5.581785894480e-03
  893 KSP Residual norm 5.914960551582e-03
  894 KSP Residual norm 6.215274237221e-03
  895 KSP Residual norm 6.380147448218e-03
  896 KSP Residual norm 6.434006988794e-03
  897 KSP Residual norm 6.956152793164e-03
  898 KSP Residual norm 7.569943236908e-03
  899 KSP Residual norm 7.196213063372e-03
  900 KSP Residual norm 6.669265142295e-03
  901 KSP Residual norm 6.291602518634e-03
  902 KSP Residual norm 6.219791968697e-03
  903 KSP Residual norm 6.338503625427e-03
  904 KSP Residual norm 6.424207519846e-03
  905 KSP Residual norm 6.358795522748e-03
  906 KSP Residual norm 6.065467535689e-03
  907 KSP Residual norm 5.900664281144e-03
  908 KSP Residual norm 5.842698544577e-03
  909 KSP Residual norm 5.930779381444e-03
  910 KSP Residual norm 5.701726896468e-03
  911 KSP Residual norm 5.451726110990e-03
  912 KSP Residual norm 5.358715189907e-03
  913 KSP Residual norm 5.074947630587e-03
  914 KSP Residual norm 4.879003170423e-03
  915 KSP Residual norm 4.508233945089e-03
  916 KSP Residual norm 4.443694702769e-03
  917 KSP Residual norm 4.613572364187e-03
  918 KSP Residual norm 4.738259183511e-03
  919 KSP Residual norm 4.791155625810e-03
  920 KSP Residual norm 4.974137880502e-03
  921 KSP Residual norm 5.104963370756e-03
  922 KSP Residual norm 5.161325592815e-03
  923 KSP Residual norm 5.066610625764e-03
  924 KSP Residual norm 4.859808367323e-03
  925 KSP Residual norm 4.759496591612e-03
  926 KSP Residual norm 4.877206386720e-03
  927 KSP Residual norm 5.057897513934e-03
  928 KSP Residual norm 5.111313050571e-03
  929 KSP Residual norm 5.389458752792e-03
  930 KSP Residual norm 5.737138995252e-03
  931 KSP Residual norm 5.998194270249e-03
  932 KSP Residual norm 6.146434423575e-03
  933 KSP Residual norm 6.569709275569e-03
  934 KSP Residual norm 6.962879787477e-03
  935 KSP Residual norm 7.372751593413e-03
  936 KSP Residual norm 7.516081815966e-03
  937 KSP Residual norm 7.345681334036e-03
  938 KSP Residual norm 7.387023502760e-03
  939 KSP Residual norm 7.751916785347e-03
  940 KSP Residual norm 8.124853985422e-03
  941 KSP Residual norm 8.161143065742e-03
  942 KSP Residual norm 8.067366672832e-03
  943 KSP Residual norm 8.229867127952e-03
  944 KSP Residual norm 8.853793072529e-03
  945 KSP Residual norm 9.269567121478e-03
  946 KSP Residual norm 8.751506073752e-03
  947 KSP Residual norm 7.938945593248e-03
  948 KSP Residual norm 7.797694446958e-03
  949 KSP Residual norm 7.929228242394e-03
  950 KSP Residual norm 7.719452507282e-03
  951 KSP Residual norm 6.832883878296e-03
  952 KSP Residual norm 6.443643850214e-03
  953 KSP Residual norm 6.295045856499e-03
  954 KSP Residual norm 6.150883178803e-03
  955 KSP Residual norm 6.074214553054e-03
  956 KSP Residual norm 6.034663057893e-03
  957 KSP Residual norm 6.236959412573e-03
  958 KSP Residual norm 6.307983143271e-03
  959 KSP Residual norm 6.337338786166e-03
  960 KSP Residual norm 6.424917217463e-03
  961 KSP Residual norm 6.797528340310e-03
  962 KSP Residual norm 6.747058303445e-03
  963 KSP Residual norm 6.474594117430e-03
  964 KSP Residual norm 5.993114301998e-03
  965 KSP Residual norm 5.624010238615e-03
  966 KSP Residual norm 5.593720784244e-03
  967 KSP Residual norm 5.589581870468e-03
  968 KSP Residual norm 5.603005508742e-03
  969 KSP Residual norm 5.810391484899e-03
  970 KSP Residual norm 6.194263875096e-03
  971 KSP Residual norm 6.136652736529e-03
  972 KSP Residual norm 6.283690392221e-03
  973 KSP Residual norm 6.519842963053e-03
  974 KSP Residual norm 6.895802471345e-03
  975 KSP Residual norm 6.992540210060e-03
  976 KSP Residual norm 6.948142695474e-03
  977 KSP Residual norm 6.902910092755e-03
  978 KSP Residual norm 6.810624040762e-03
  979 KSP Residual norm 6.933177851430e-03
  980 KSP Residual norm 7.308598793955e-03
  981 KSP Residual norm 7.517714501679e-03
  982 KSP Residual norm 7.832519795887e-03
  983 KSP Residual norm 7.864611364591e-03
  984 KSP Residual norm 7.684466785193e-03
  985 KSP Residual norm 7.640868812113e-03
  986 KSP Residual norm 7.935507353152e-03
  987 KSP Residual norm 8.163967874078e-03
  988 KSP Residual norm 8.055085011071e-03
  989 KSP Residual norm 7.676106656276e-03
  990 KSP Residual norm 7.230936801529e-03
  991 KSP Residual norm 6.951908145572e-03
  992 KSP Residual norm 6.802094733110e-03
  993 KSP Residual norm 6.683949692399e-03
  994 KSP Residual norm 6.336700308828e-03
  995 KSP Residual norm 6.244222851116e-03
  996 KSP Residual norm 6.304898269266e-03
  997 KSP Residual norm 6.330769690003e-03
  998 KSP Residual norm 6.228526816184e-03
  999 KSP Residual norm 6.236334612293e-03
  1000 KSP Residual norm 6.082543349162e-03
  1001 KSP Residual norm 5.951192334012e-03
  1002 KSP Residual norm 5.896320518952e-03
  1003 KSP Residual norm 5.893906943159e-03
  1004 KSP Residual norm 6.189911727147e-03
  1005 KSP Residual norm 6.298401986625e-03
  1006 KSP Residual norm 6.394011235232e-03
  1007 KSP Residual norm 6.515404444493e-03
  1008 KSP Residual norm 6.720948446026e-03
  1009 KSP Residual norm 6.589878288593e-03
  1010 KSP Residual norm 6.152351062045e-03
  1011 KSP Residual norm 5.969266592480e-03
  1012 KSP Residual norm 6.170609409981e-03
  1013 KSP Residual norm 6.469621506901e-03
  1014 KSP Residual norm 6.459914206986e-03
  1015 KSP Residual norm 6.593668533056e-03
  1016 KSP Residual norm 6.622514784875e-03
  1017 KSP Residual norm 6.656735647554e-03
  1018 KSP Residual norm 6.751257601391e-03
  1019 KSP Residual norm 6.988646562368e-03
  1020 KSP Residual norm 6.905687803374e-03
  1021 KSP Residual norm 6.655272945212e-03
  1022 KSP Residual norm 6.777996924187e-03
  1023 KSP Residual norm 6.947630339348e-03
  1024 KSP Residual norm 6.950024896731e-03
  1025 KSP Residual norm 6.581465729748e-03
  1026 KSP Residual norm 6.623424889169e-03
  1027 KSP Residual norm 6.544497469118e-03
  1028 KSP Residual norm 6.765260623953e-03
  1029 KSP Residual norm 6.915449248189e-03
  1030 KSP Residual norm 6.372236580133e-03
  1031 KSP Residual norm 5.953128974582e-03
  1032 KSP Residual norm 6.015530242281e-03
  1033 KSP Residual norm 5.943168745891e-03
  1034 KSP Residual norm 5.596915041857e-03
  1035 KSP Residual norm 5.408257600816e-03
  1036 KSP Residual norm 5.462516314601e-03
  1037 KSP Residual norm 5.452288052399e-03
  1038 KSP Residual norm 5.531964783471e-03
  1039 KSP Residual norm 5.396516226761e-03
  1040 KSP Residual norm 4.956288530837e-03
  1041 KSP Residual norm 4.675443151148e-03
  1042 KSP Residual norm 4.634914726898e-03
  1043 KSP Residual norm 4.719420543451e-03
  1044 KSP Residual norm 4.878425027179e-03
  1045 KSP Residual norm 4.992200285686e-03
  1046 KSP Residual norm 4.883623561089e-03
  1047 KSP Residual norm 4.902805121842e-03
  1048 KSP Residual norm 5.038729498491e-03
  1049 KSP Residual norm 5.137707181042e-03
  1050 KSP Residual norm 4.830803807506e-03
  1051 KSP Residual norm 4.320867223425e-03
  1052 KSP Residual norm 4.142120709162e-03
  1053 KSP Residual norm 4.298950610032e-03
  1054 KSP Residual norm 4.467252788161e-03
  1055 KSP Residual norm 4.522559064521e-03
  1056 KSP Residual norm 4.761306312461e-03
  1057 KSP Residual norm 5.150319637346e-03
  1058 KSP Residual norm 5.322174446922e-03
  1059 KSP Residual norm 5.238802254595e-03
  1060 KSP Residual norm 5.061485394297e-03
  1061 KSP Residual norm 4.909992936371e-03
  1062 KSP Residual norm 4.685635154322e-03
  1063 KSP Residual norm 4.549642150475e-03
  1064 KSP Residual norm 4.315222756062e-03
  1065 KSP Residual norm 4.281712726966e-03
  1066 KSP Residual norm 4.628655632869e-03
  1067 KSP Residual norm 5.104523083976e-03
  1068 KSP Residual norm 5.189322907695e-03
  1069 KSP Residual norm 5.221327773111e-03
  1070 KSP Residual norm 5.319418446647e-03
  1071 KSP Residual norm 5.285463126603e-03
  1072 KSP Residual norm 5.180630969047e-03
  1073 KSP Residual norm 5.214370896858e-03
  1074 KSP Residual norm 5.560363588384e-03
  1075 KSP Residual norm 5.820058047521e-03
  1076 KSP Residual norm 6.161044287324e-03
  1077 KSP Residual norm 6.134595772506e-03
  1078 KSP Residual norm 6.162806832956e-03
  1079 KSP Residual norm 6.015504687689e-03
  1080 KSP Residual norm 5.965365763166e-03
  1081 KSP Residual norm 5.925516590688e-03
  1082 KSP Residual norm 6.050030721362e-03
  1083 KSP Residual norm 6.035467347951e-03
  1084 KSP Residual norm 5.840636688796e-03
  1085 KSP Residual norm 5.974492387850e-03
  1086 KSP Residual norm 6.306378068772e-03
  1087 KSP Residual norm 6.223532094991e-03
  1088 KSP Residual norm 5.978102326085e-03
  1089 KSP Residual norm 6.032699383338e-03
  1090 KSP Residual norm 5.963182048539e-03
  1091 KSP Residual norm 5.845853825071e-03
  1092 KSP Residual norm 5.703606769746e-03
  1093 KSP Residual norm 5.589634794580e-03
  1094 KSP Residual norm 5.945482515465e-03
  1095 KSP Residual norm 6.096712270725e-03
  1096 KSP Residual norm 5.727527640483e-03
  1097 KSP Residual norm 5.463535057390e-03
  1098 KSP Residual norm 5.621914974956e-03
  1099 KSP Residual norm 5.892077814275e-03
  1100 KSP Residual norm 6.139083451418e-03
  1101 KSP Residual norm 5.740656746572e-03
  1102 KSP Residual norm 5.328292130255e-03
  1103 KSP Residual norm 5.258243410082e-03
  1104 KSP Residual norm 5.294375311027e-03
  1105 KSP Residual norm 5.457460865136e-03
  1106 KSP Residual norm 5.774135867417e-03
  1107 KSP Residual norm 6.231248846901e-03
  1108 KSP Residual norm 6.634947482888e-03
  1109 KSP Residual norm 6.915589060378e-03
  1110 KSP Residual norm 6.842662490898e-03
  1111 KSP Residual norm 6.653520411095e-03
  1112 KSP Residual norm 6.507144896527e-03
  1113 KSP Residual norm 6.203930956071e-03
  1114 KSP Residual norm 6.190651197615e-03
  1115 KSP Residual norm 6.443233750548e-03
  1116 KSP Residual norm 6.846407285740e-03
  1117 KSP Residual norm 6.813516923484e-03
  1118 KSP Residual norm 6.586346121190e-03
  1119 KSP Residual norm 6.716516964440e-03
  1120 KSP Residual norm 6.750677507897e-03
  1121 KSP Residual norm 6.650235124616e-03
  1122 KSP Residual norm 6.340073963061e-03
  1123 KSP Residual norm 6.442977105372e-03
  1124 KSP Residual norm 6.607485326192e-03
  1125 KSP Residual norm 6.654648159593e-03
  1126 KSP Residual norm 6.390913213498e-03
  1127 KSP Residual norm 6.139694331253e-03
  1128 KSP Residual norm 5.975839996696e-03
  1129 KSP Residual norm 6.181452135028e-03
  1130 KSP Residual norm 6.483924116115e-03
  1131 KSP Residual norm 6.244388643648e-03
  1132 KSP Residual norm 5.726665913960e-03
  1133 KSP Residual norm 5.548101276250e-03
  1134 KSP Residual norm 5.670483843427e-03
  1135 KSP Residual norm 5.815484357897e-03
  1136 KSP Residual norm 5.836656679452e-03
  1137 KSP Residual norm 6.126786438304e-03
  1138 KSP Residual norm 6.131637697385e-03
  1139 KSP Residual norm 5.939461551154e-03
  1140 KSP Residual norm 5.899863029397e-03
  1141 KSP Residual norm 5.879249371999e-03
  1142 KSP Residual norm 5.733033436179e-03
  1143 KSP Residual norm 5.810084705179e-03
  1144 KSP Residual norm 6.192124782418e-03
  1145 KSP Residual norm 6.198880886066e-03
  1146 KSP Residual norm 6.126373924098e-03
  1147 KSP Residual norm 6.202550295473e-03
  1148 KSP Residual norm 6.619257825958e-03
  1149 KSP Residual norm 6.958254861449e-03
  1150 KSP Residual norm 6.903498120753e-03
  1151 KSP Residual norm 6.853397498305e-03
  1152 KSP Residual norm 6.783288123518e-03
  1153 KSP Residual norm 6.684459902594e-03
  1154 KSP Residual norm 7.000778316486e-03
  1155 KSP Residual norm 6.912436408032e-03
  1156 KSP Residual norm 6.819457534321e-03
  1157 KSP Residual norm 6.677222508219e-03
  1158 KSP Residual norm 6.455952608254e-03
  1159 KSP Residual norm 6.346410790821e-03
  1160 KSP Residual norm 6.331219961493e-03
  1161 KSP Residual norm 6.640611156020e-03
  1162 KSP Residual norm 6.790349677284e-03
  1163 KSP Residual norm 6.332263850028e-03
  1164 KSP Residual norm 5.816647448194e-03
  1165 KSP Residual norm 5.697215514246e-03
  1166 KSP Residual norm 6.016051161797e-03
  1167 KSP Residual norm 6.340316880162e-03
  1168 KSP Residual norm 6.101820359558e-03
  1169 KSP Residual norm 5.802519263927e-03
  1170 KSP Residual norm 5.442038846680e-03
  1171 KSP Residual norm 4.842404703879e-03
  1172 KSP Residual norm 4.307367171043e-03
  1173 KSP Residual norm 4.312710721844e-03
  1174 KSP Residual norm 4.615300758975e-03
  1175 KSP Residual norm 4.835514304094e-03
  1176 KSP Residual norm 4.971895126694e-03
  1177 KSP Residual norm 4.922519270854e-03
  1178 KSP Residual norm 5.027507820926e-03
  1179 KSP Residual norm 5.381926369022e-03
  1180 KSP Residual norm 5.924644512727e-03
  1181 KSP Residual norm 5.891518828823e-03
  1182 KSP Residual norm 5.675322830638e-03
  1183 KSP Residual norm 5.488681315201e-03
  1184 KSP Residual norm 5.464539823754e-03
  1185 KSP Residual norm 5.191120797280e-03
  1186 KSP Residual norm 5.036484482861e-03
  1187 KSP Residual norm 5.514703417422e-03
  1188 KSP Residual norm 6.021271127233e-03
  1189 KSP Residual norm 6.102166452512e-03
  1190 KSP Residual norm 5.759277572695e-03
  1191 KSP Residual norm 5.365159664280e-03
  1192 KSP Residual norm 4.831505966819e-03
  1193 KSP Residual norm 4.669862169270e-03
  1194 KSP Residual norm 4.619647530157e-03
  1195 KSP Residual norm 4.692323156185e-03
  1196 KSP Residual norm 4.827179343472e-03
  1197 KSP Residual norm 4.722460358927e-03
  1198 KSP Residual norm 4.457709639624e-03
  1199 KSP Residual norm 4.232960701882e-03
  1200 KSP Residual norm 3.913306868682e-03
  1201 KSP Residual norm 3.938209539604e-03
  1202 KSP Residual norm 4.209949450264e-03
  1203 KSP Residual norm 4.348061906313e-03
  1204 KSP Residual norm 4.309578170217e-03
  1205 KSP Residual norm 4.215557309157e-03
  1206 KSP Residual norm 4.328624858550e-03
  1207 KSP Residual norm 4.679769902461e-03
  1208 KSP Residual norm 4.772875673194e-03
  1209 KSP Residual norm 4.840061492543e-03
  1210 KSP Residual norm 4.894836284673e-03
  1211 KSP Residual norm 5.106793066553e-03
  1212 KSP Residual norm 5.419370252828e-03
  1213 KSP Residual norm 5.602897497417e-03
  1214 KSP Residual norm 5.620211820518e-03
  1215 KSP Residual norm 5.541580410610e-03
  1216 KSP Residual norm 5.377318358986e-03
  1217 KSP Residual norm 5.355932724490e-03
  1218 KSP Residual norm 5.172556245287e-03
  1219 KSP Residual norm 5.195067873454e-03
  1220 KSP Residual norm 5.411953098667e-03
  1221 KSP Residual norm 5.542498186585e-03
  1222 KSP Residual norm 5.699400248498e-03
  1223 KSP Residual norm 6.083526194246e-03
  1224 KSP Residual norm 6.776632040042e-03
  1225 KSP Residual norm 6.591245482881e-03
  1226 KSP Residual norm 6.056789615984e-03
  1227 KSP Residual norm 5.620002002496e-03
  1228 KSP Residual norm 5.511076945362e-03
  1229 KSP Residual norm 5.403195902175e-03
  1230 KSP Residual norm 4.979935000628e-03
  1231 KSP Residual norm 4.573086112890e-03
  1232 KSP Residual norm 4.459743381228e-03
  1233 KSP Residual norm 4.372845880899e-03
  1234 KSP Residual norm 4.302849623364e-03
  1235 KSP Residual norm 4.111474668947e-03
  1236 KSP Residual norm 3.979685522244e-03
  1237 KSP Residual norm 4.065333685994e-03
  1238 KSP Residual norm 4.212503344253e-03
  1239 KSP Residual norm 4.255606705877e-03
  1240 KSP Residual norm 4.410395450204e-03
  1241 KSP Residual norm 4.645881211501e-03
  1242 KSP Residual norm 4.396305934514e-03
  1243 KSP Residual norm 3.795604675090e-03
  1244 KSP Residual norm 3.382639010574e-03
  1245 KSP Residual norm 3.263719609938e-03
  1246 KSP Residual norm 3.292309527915e-03
  1247 KSP Residual norm 3.454794521972e-03
  1248 KSP Residual norm 3.756456407396e-03
  1249 KSP Residual norm 4.129318294708e-03
  1250 KSP Residual norm 4.188513748578e-03
  1251 KSP Residual norm 4.333470426178e-03
  1252 KSP Residual norm 4.534784618524e-03
  1253 KSP Residual norm 4.662683091238e-03
  1254 KSP Residual norm 4.745039771543e-03
  1255 KSP Residual norm 5.036284709742e-03
  1256 KSP Residual norm 5.140546926157e-03
  1257 KSP Residual norm 5.026826636179e-03
  1258 KSP Residual norm 5.010636800537e-03
  1259 KSP Residual norm 5.316707900383e-03
  1260 KSP Residual norm 5.326368822382e-03
  1261 KSP Residual norm 5.266328100617e-03
  1262 KSP Residual norm 5.234593905012e-03
  1263 KSP Residual norm 5.186181958411e-03
  1264 KSP Residual norm 4.808342735265e-03
  1265 KSP Residual norm 4.556387656805e-03
  1266 KSP Residual norm 4.549331733816e-03
  1267 KSP Residual norm 4.669412804075e-03
  1268 KSP Residual norm 4.574004829108e-03
  1269 KSP Residual norm 4.340970646999e-03
  1270 KSP Residual norm 4.319369679024e-03
  1271 KSP Residual norm 4.578968060174e-03
  1272 KSP Residual norm 4.846032166389e-03
  1273 KSP Residual norm 4.746368789336e-03
  1274 KSP Residual norm 4.609013741009e-03
  1275 KSP Residual norm 4.708151412562e-03
  1276 KSP Residual norm 4.995241581273e-03
  1277 KSP Residual norm 5.332579238943e-03
  1278 KSP Residual norm 5.204965860375e-03
  1279 KSP Residual norm 4.945698544804e-03
  1280 KSP Residual norm 4.804631013042e-03
  1281 KSP Residual norm 4.917148464483e-03
  1282 KSP Residual norm 5.240730514973e-03
  1283 KSP Residual norm 5.576608925829e-03
  1284 KSP Residual norm 5.371381327328e-03
  1285 KSP Residual norm 5.011314190904e-03
  1286 KSP Residual norm 4.866107074784e-03
  1287 KSP Residual norm 4.787906287522e-03
  1288 KSP Residual norm 4.864775553534e-03
  1289 KSP Residual norm 4.916785832573e-03
  1290 KSP Residual norm 4.657463941679e-03
  1291 KSP Residual norm 4.530399732902e-03
  1292 KSP Residual norm 4.567561150432e-03
  1293 KSP Residual norm 4.623376308790e-03
  1294 KSP Residual norm 4.386296319403e-03
  1295 KSP Residual norm 4.224960644615e-03
  1296 KSP Residual norm 4.124504209937e-03
  1297 KSP Residual norm 4.113756726773e-03
  1298 KSP Residual norm 4.219404272017e-03
  1299 KSP Residual norm 4.319074017788e-03
  1300 KSP Residual norm 4.338363708766e-03
  1301 KSP Residual norm 4.087293049445e-03
  1302 KSP Residual norm 3.828187057594e-03
  1303 KSP Residual norm 3.615664295881e-03
  1304 KSP Residual norm 3.720737447464e-03
  1305 KSP Residual norm 3.995361756972e-03
  1306 KSP Residual norm 4.202771155210e-03
  1307 KSP Residual norm 4.412679881259e-03
  1308 KSP Residual norm 4.559842389085e-03
  1309 KSP Residual norm 4.771511782515e-03
  1310 KSP Residual norm 4.804998789986e-03
  1311 KSP Residual norm 5.021417214261e-03
  1312 KSP Residual norm 5.325459583935e-03
  1313 KSP Residual norm 5.448092377851e-03
  1314 KSP Residual norm 5.357339275060e-03
  1315 KSP Residual norm 5.172504557519e-03
  1316 KSP Residual norm 4.864858663382e-03
  1317 KSP Residual norm 4.573250060157e-03
  1318 KSP Residual norm 4.497697556282e-03
  1319 KSP Residual norm 4.611563966140e-03
  1320 KSP Residual norm 4.608284094663e-03
  1321 KSP Residual norm 4.378159837225e-03
  1322 KSP Residual norm 4.486083715508e-03
  1323 KSP Residual norm 5.006618659923e-03
  1324 KSP Residual norm 5.400365411200e-03
  1325 KSP Residual norm 5.307026679105e-03
  1326 KSP Residual norm 5.293514731677e-03
  1327 KSP Residual norm 5.306975541628e-03
  1328 KSP Residual norm 5.368792860268e-03
  1329 KSP Residual norm 4.919812160700e-03
  1330 KSP Residual norm 4.471669316051e-03
  1331 KSP Residual norm 4.515952541262e-03
  1332 KSP Residual norm 4.917163287239e-03
  1333 KSP Residual norm 5.245851058222e-03
  1334 KSP Residual norm 5.621468067928e-03
  1335 KSP Residual norm 5.652217685842e-03
  1336 KSP Residual norm 5.708425105195e-03
  1337 KSP Residual norm 5.824373614395e-03
  1338 KSP Residual norm 6.009562993019e-03
  1339 KSP Residual norm 6.144142720600e-03
  1340 KSP Residual norm 6.599285586716e-03
  1341 KSP Residual norm 7.344808253598e-03
  1342 KSP Residual norm 7.688040205459e-03
  1343 KSP Residual norm 7.586092654733e-03
  1344 KSP Residual norm 7.173564259039e-03
  1345 KSP Residual norm 6.598240988005e-03
  1346 KSP Residual norm 5.892587099044e-03
  1347 KSP Residual norm 5.613682437077e-03
  1348 KSP Residual norm 5.460696099903e-03
  1349 KSP Residual norm 5.462517746714e-03
  1350 KSP Residual norm 5.600953475630e-03
  1351 KSP Residual norm 5.387775229912e-03
  1352 KSP Residual norm 5.181412421696e-03
  1353 KSP Residual norm 4.931952401920e-03
  1354 KSP Residual norm 4.570619979257e-03
  1355 KSP Residual norm 4.377392593060e-03
  1356 KSP Residual norm 4.134943800022e-03
  1357 KSP Residual norm 4.050101621145e-03
  1358 KSP Residual norm 3.927170173902e-03
  1359 KSP Residual norm 4.002863746419e-03
  1360 KSP Residual norm 4.133904576647e-03
  1361 KSP Residual norm 4.093282465061e-03
  1362 KSP Residual norm 3.857297451022e-03
  1363 KSP Residual norm 3.620285409349e-03
  1364 KSP Residual norm 3.382937730415e-03
  1365 KSP Residual norm 3.338970913338e-03
  1366 KSP Residual norm 3.621615143604e-03
  1367 KSP Residual norm 4.004203600945e-03
  1368 KSP Residual norm 4.313641226175e-03
  1369 KSP Residual norm 4.381419457289e-03
  1370 KSP Residual norm 4.062557649672e-03
  1371 KSP Residual norm 3.804951568249e-03
  1372 KSP Residual norm 3.824966688333e-03
  1373 KSP Residual norm 4.170571410610e-03
  1374 KSP Residual norm 4.359063888330e-03
  1375 KSP Residual norm 4.369708161276e-03
  1376 KSP Residual norm 4.616366604858e-03
  1377 KSP Residual norm 4.813132711751e-03
  1378 KSP Residual norm 4.841581890431e-03
  1379 KSP Residual norm 4.615457216910e-03
  1380 KSP Residual norm 4.364865174047e-03
  1381 KSP Residual norm 4.402076551154e-03
  1382 KSP Residual norm 4.550847289956e-03
  1383 KSP Residual norm 4.653118821445e-03
  1384 KSP Residual norm 4.848951209101e-03
  1385 KSP Residual norm 5.335005979295e-03
  1386 KSP Residual norm 5.990831239637e-03
  1387 KSP Residual norm 6.390408526740e-03
  1388 KSP Residual norm 6.238132730307e-03
  1389 KSP Residual norm 5.777213476124e-03
  1390 KSP Residual norm 5.745474019357e-03
  1391 KSP Residual norm 6.171919713719e-03
  1392 KSP Residual norm 6.814628576131e-03
  1393 KSP Residual norm 7.092930622436e-03
  1394 KSP Residual norm 7.202829647083e-03
  1395 KSP Residual norm 7.263068243672e-03
  1396 KSP Residual norm 7.991866027692e-03
  1397 KSP Residual norm 8.076857344675e-03
  1398 KSP Residual norm 7.416722959321e-03
  1399 KSP Residual norm 7.256745039815e-03
  1400 KSP Residual norm 7.817460645521e-03
  1401 KSP Residual norm 7.888386414770e-03
  1402 KSP Residual norm 7.778721146485e-03
  1403 KSP Residual norm 7.633145130674e-03
  1404 KSP Residual norm 7.080884138097e-03
  1405 KSP Residual norm 6.392244539346e-03
  1406 KSP Residual norm 5.964969378442e-03
  1407 KSP Residual norm 5.759052737011e-03
  1408 KSP Residual norm 5.509325648131e-03
  1409 KSP Residual norm 4.965502665671e-03
  1410 KSP Residual norm 4.553387456256e-03
  1411 KSP Residual norm 4.350348933840e-03
  1412 KSP Residual norm 4.450579817108e-03
  1413 KSP Residual norm 4.462209314224e-03
  1414 KSP Residual norm 4.759025680116e-03
  1415 KSP Residual norm 4.843115994220e-03
  1416 KSP Residual norm 4.883781434826e-03
  1417 KSP Residual norm 4.855960636670e-03
  1418 KSP Residual norm 4.909991832520e-03
  1419 KSP Residual norm 5.167335712909e-03
  1420 KSP Residual norm 5.062535842783e-03
  1421 KSP Residual norm 4.861047026837e-03
  1422 KSP Residual norm 4.614075594659e-03
  1423 KSP Residual norm 4.448845132952e-03
  1424 KSP Residual norm 4.341318580693e-03
  1425 KSP Residual norm 4.446510898985e-03
  1426 KSP Residual norm 4.663442738450e-03
  1427 KSP Residual norm 4.765644861878e-03
  1428 KSP Residual norm 4.659291336051e-03
  1429 KSP Residual norm 4.359520779209e-03
  1430 KSP Residual norm 4.223229345176e-03
  1431 KSP Residual norm 4.418285143963e-03
  1432 KSP Residual norm 4.619124062440e-03
  1433 KSP Residual norm 4.553885494409e-03
  1434 KSP Residual norm 4.280900988546e-03
  1435 KSP Residual norm 4.085018266935e-03
  1436 KSP Residual norm 4.004797334160e-03
  1437 KSP Residual norm 4.007557730599e-03
  1438 KSP Residual norm 3.818920853936e-03
  1439 KSP Residual norm 3.735385033394e-03
  1440 KSP Residual norm 3.797665363864e-03
  1441 KSP Residual norm 3.647434711828e-03
  1442 KSP Residual norm 3.434667605772e-03
  1443 KSP Residual norm 3.579061679853e-03
  1444 KSP Residual norm 3.929397396732e-03
  1445 KSP Residual norm 4.161246364486e-03
  1446 KSP Residual norm 4.247942879325e-03
  1447 KSP Residual norm 4.214530157465e-03
  1448 KSP Residual norm 4.349880370678e-03
  1449 KSP Residual norm 4.382618450311e-03
  1450 KSP Residual norm 4.317896908899e-03
  1451 KSP Residual norm 4.318923942325e-03
  1452 KSP Residual norm 4.597371089027e-03
  1453 KSP Residual norm 4.734297417514e-03
  1454 KSP Residual norm 4.723529661083e-03
  1455 KSP Residual norm 4.535019309761e-03
  1456 KSP Residual norm 4.557228968325e-03
  1457 KSP Residual norm 4.675657336082e-03
  1458 KSP Residual norm 4.678101252096e-03
  1459 KSP Residual norm 4.440029523124e-03
  1460 KSP Residual norm 4.443447061774e-03
  1461 KSP Residual norm 4.675489876803e-03
  1462 KSP Residual norm 4.697316439515e-03
  1463 KSP Residual norm 4.347006366960e-03
  1464 KSP Residual norm 4.116358055477e-03
  1465 KSP Residual norm 3.909385741593e-03
  1466 KSP Residual norm 3.427271155185e-03
  1467 KSP Residual norm 3.148050704572e-03
  1468 KSP Residual norm 3.146758567557e-03
  1469 KSP Residual norm 3.326439000327e-03
  1470 KSP Residual norm 3.528227381870e-03
  1471 KSP Residual norm 3.734636049772e-03
  1472 KSP Residual norm 3.801175141192e-03
  1473 KSP Residual norm 3.682733054341e-03
  1474 KSP Residual norm 3.869391327748e-03
  1475 KSP Residual norm 4.124262041395e-03
  1476 KSP Residual norm 4.301928175170e-03
  1477 KSP Residual norm 4.360539607347e-03
  1478 KSP Residual norm 4.695576840578e-03
  1479 KSP Residual norm 5.338862907112e-03
  1480 KSP Residual norm 5.857255626224e-03
  1481 KSP Residual norm 5.758243446024e-03
  1482 KSP Residual norm 5.429528389948e-03
  1483 KSP Residual norm 5.332596773347e-03
  1484 KSP Residual norm 5.317884347570e-03
  1485 KSP Residual norm 5.251252274662e-03
  1486 KSP Residual norm 4.970344100120e-03
  1487 KSP Residual norm 4.679405455370e-03
  1488 KSP Residual norm 4.257698337737e-03
  1489 KSP Residual norm 3.922890835350e-03
  1490 KSP Residual norm 3.740125726498e-03
  1491 KSP Residual norm 3.739714064191e-03
  1492 KSP Residual norm 3.966049899764e-03
  1493 KSP Residual norm 4.027427417459e-03
  1494 KSP Residual norm 3.958089315333e-03
  1495 KSP Residual norm 3.911692723710e-03
  1496 KSP Residual norm 4.016878615819e-03
  1497 KSP Residual norm 4.250091344628e-03
  1498 KSP Residual norm 4.518796865137e-03
  1499 KSP Residual norm 5.010301973299e-03
  1500 KSP Residual norm 5.578390370620e-03
  1501 KSP Residual norm 5.614031960271e-03
  1502 KSP Residual norm 5.487587594523e-03
  1503 KSP Residual norm 5.490917249746e-03
  1504 KSP Residual norm 5.410518625817e-03
  1505 KSP Residual norm 4.795851091615e-03
  1506 KSP Residual norm 3.971918432854e-03
  1507 KSP Residual norm 3.703618718688e-03
  1508 KSP Residual norm 3.914709198679e-03
  1509 KSP Residual norm 4.020164070164e-03
  1510 KSP Residual norm 4.140657598389e-03
  1511 KSP Residual norm 4.045678848300e-03
  1512 KSP Residual norm 3.877274234083e-03
  1513 KSP Residual norm 3.773905053915e-03
  1514 KSP Residual norm 3.777227522832e-03
  1515 KSP Residual norm 3.615497735700e-03
  1516 KSP Residual norm 3.329500584338e-03
  1517 KSP Residual norm 3.211498061362e-03
  1518 KSP Residual norm 3.401609027037e-03
  1519 KSP Residual norm 3.792488962233e-03
  1520 KSP Residual norm 3.770037286683e-03
  1521 KSP Residual norm 3.396567762266e-03
  1522 KSP Residual norm 3.019110598211e-03
  1523 KSP Residual norm 3.152200151492e-03
  1524 KSP Residual norm 3.557575669406e-03
  1525 KSP Residual norm 3.872615871153e-03
  1526 KSP Residual norm 4.159628700692e-03
  1527 KSP Residual norm 4.183185965547e-03
  1528 KSP Residual norm 4.076722224240e-03
  1529 KSP Residual norm 3.792985283323e-03
  1530 KSP Residual norm 3.455971465179e-03
  1531 KSP Residual norm 3.346246982667e-03
  1532 KSP Residual norm 3.461595065848e-03
  1533 KSP Residual norm 3.719177306018e-03
  1534 KSP Residual norm 3.738392400040e-03
  1535 KSP Residual norm 3.321691072143e-03
  1536 KSP Residual norm 3.081074856988e-03
  1537 KSP Residual norm 3.326777042453e-03
  1538 KSP Residual norm 3.959519687464e-03
  1539 KSP Residual norm 4.448615395345e-03
  1540 KSP Residual norm 4.638141453377e-03
  1541 KSP Residual norm 4.626773464162e-03
  1542 KSP Residual norm 4.483684621375e-03
  1543 KSP Residual norm 4.342412403729e-03
  1544 KSP Residual norm 4.205782505569e-03
  1545 KSP Residual norm 4.106900721390e-03
  1546 KSP Residual norm 4.095639807755e-03
  1547 KSP Residual norm 4.162839274005e-03
  1548 KSP Residual norm 4.317606778375e-03
  1549 KSP Residual norm 4.299305149905e-03
  1550 KSP Residual norm 4.148649072744e-03
  1551 KSP Residual norm 4.073325903721e-03
  1552 KSP Residual norm 4.011903492316e-03
  1553 KSP Residual norm 3.927519683330e-03
  1554 KSP Residual norm 3.728278189639e-03
  1555 KSP Residual norm 3.524235386843e-03
  1556 KSP Residual norm 3.605233908790e-03
  1557 KSP Residual norm 3.997424334329e-03
  1558 KSP Residual norm 4.697881418515e-03
  1559 KSP Residual norm 4.893748047315e-03
  1560 KSP Residual norm 4.745987021851e-03
  1561 KSP Residual norm 4.450249967684e-03
  1562 KSP Residual norm 4.357138704257e-03
  1563 KSP Residual norm 4.367710481440e-03
  1564 KSP Residual norm 4.484935772773e-03
  1565 KSP Residual norm 4.499326997528e-03
  1566 KSP Residual norm 4.146770349785e-03
  1567 KSP Residual norm 3.712414470514e-03
  1568 KSP Residual norm 3.548515634102e-03
  1569 KSP Residual norm 3.660986761216e-03
  1570 KSP Residual norm 3.799659058599e-03
  1571 KSP Residual norm 3.814251344302e-03
  1572 KSP Residual norm 3.782927834391e-03
  1573 KSP Residual norm 3.856112517795e-03
  1574 KSP Residual norm 4.053264140504e-03
  1575 KSP Residual norm 4.098474476568e-03
  1576 KSP Residual norm 3.687961478176e-03
  1577 KSP Residual norm 3.334331419984e-03
  1578 KSP Residual norm 3.340775962920e-03
  1579 KSP Residual norm 3.647538053510e-03
  1580 KSP Residual norm 3.732505656428e-03
  1581 KSP Residual norm 3.569907419767e-03
  1582 KSP Residual norm 3.284915346407e-03
  1583 KSP Residual norm 2.867992050476e-03
  1584 KSP Residual norm 2.609457809758e-03
  1585 KSP Residual norm 2.548729593534e-03
  1586 KSP Residual norm 2.703303121263e-03
  1587 KSP Residual norm 2.991301617554e-03
  1588 KSP Residual norm 3.181960046360e-03
  1589 KSP Residual norm 2.812457127578e-03
  1590 KSP Residual norm 2.357118285072e-03
  1591 KSP Residual norm 2.331637798308e-03
  1592 KSP Residual norm 2.767640590317e-03
  1593 KSP Residual norm 3.120168921408e-03
  1594 KSP Residual norm 3.071446073340e-03
  1595 KSP Residual norm 2.901376408602e-03
  1596 KSP Residual norm 2.736985639322e-03
  1597 KSP Residual norm 2.685199238895e-03
  1598 KSP Residual norm 2.662069200765e-03
  1599 KSP Residual norm 2.723556510636e-03
  1600 KSP Residual norm 2.865503849469e-03
  1601 KSP Residual norm 3.124754319916e-03
  1602 KSP Residual norm 3.501928923907e-03
  1603 KSP Residual norm 3.710686527071e-03
  1604 KSP Residual norm 3.698074422762e-03
  1605 KSP Residual norm 3.433141741764e-03
  1606 KSP Residual norm 3.119678872135e-03
  1607 KSP Residual norm 2.928591276034e-03
  1608 KSP Residual norm 2.740490664497e-03
  1609 KSP Residual norm 2.700187040953e-03
  1610 KSP Residual norm 3.058181422370e-03
  1611 KSP Residual norm 3.631169145322e-03
  1612 KSP Residual norm 3.865620502931e-03
  1613 KSP Residual norm 3.410310938254e-03
  1614 KSP Residual norm 2.778380603588e-03
  1615 KSP Residual norm 2.519935144611e-03
  1616 KSP Residual norm 2.536730914580e-03
  1617 KSP Residual norm 2.722169589183e-03
  1618 KSP Residual norm 2.981607527716e-03
  1619 KSP Residual norm 3.074443842388e-03
  1620 KSP Residual norm 3.102897043425e-03
  1621 KSP Residual norm 3.334968227213e-03
  1622 KSP Residual norm 3.765759167624e-03
  1623 KSP Residual norm 4.260428606374e-03
  1624 KSP Residual norm 4.692079458287e-03
  1625 KSP Residual norm 5.031307315013e-03
  1626 KSP Residual norm 4.421918845491e-03
  1627 KSP Residual norm 3.287483165129e-03
  1628 KSP Residual norm 2.369767919189e-03
  1629 KSP Residual norm 1.932654903757e-03
  1630 KSP Residual norm 1.962317074491e-03
  1631 KSP Residual norm 2.434378646182e-03
  1632 KSP Residual norm 3.165878044867e-03
  1633 KSP Residual norm 4.008110394569e-03
  1634 KSP Residual norm 4.243942144954e-03
  1635 KSP Residual norm 3.502225516401e-03
  1636 KSP Residual norm 2.676679314493e-03
  1637 KSP Residual norm 2.113255870404e-03
  1638 KSP Residual norm 1.943585178476e-03
  1639 KSP Residual norm 2.182514404814e-03
  1640 KSP Residual norm 2.842236509915e-03
  1641 KSP Residual norm 3.797676250207e-03
  1642 KSP Residual norm 4.796159154955e-03
  1643 KSP Residual norm 4.855718878594e-03
  1644 KSP Residual norm 3.805743905144e-03
  1645 KSP Residual norm 2.836189035614e-03
  1646 KSP Residual norm 2.311683718706e-03
  1647 KSP Residual norm 2.304059112016e-03
  1648 KSP Residual norm 3.001923838056e-03
  1649 KSP Residual norm 4.465398931268e-03
  1650 KSP Residual norm 6.316248645066e-03
  1651 KSP Residual norm 7.460452089176e-03
  1652 KSP Residual norm 6.157762247948e-03
  1653 KSP Residual norm 4.028858910124e-03
  1654 KSP Residual norm 2.607315308302e-03
  1655 KSP Residual norm 2.135887579079e-03
  1656 KSP Residual norm 2.214752212489e-03
  1657 KSP Residual norm 2.889084953386e-03
  1658 KSP Residual norm 4.448359025874e-03
  1659 KSP Residual norm 6.312792290081e-03
  1660 KSP Residual norm 6.454085180289e-03
  1661 KSP Residual norm 4.821242484495e-03
  1662 KSP Residual norm 3.136267667322e-03
  1663 KSP Residual norm 2.048069925869e-03
  1664 KSP Residual norm 1.642042732627e-03
  1665 KSP Residual norm 1.776685047647e-03
  1666 KSP Residual norm 2.623757732771e-03
  1667 KSP Residual norm 4.458232614128e-03
  1668 KSP Residual norm 6.978633797115e-03
  1669 KSP Residual norm 7.237631617823e-03
  1670 KSP Residual norm 4.985964037370e-03
  1671 KSP Residual norm 2.915990817911e-03
  1672 KSP Residual norm 2.034845647516e-03
  1673 KSP Residual norm 1.913779478677e-03
  1674 KSP Residual norm 2.437839848479e-03
  1675 KSP Residual norm 3.816997921800e-03
  1676 KSP Residual norm 5.453049433777e-03
  1677 KSP Residual norm 5.652942559526e-03
  1678 KSP Residual norm 4.474314780586e-03
  1679 KSP Residual norm 2.979968710938e-03
  1680 KSP Residual norm 1.962384551434e-03
  1681 KSP Residual norm 1.629787231112e-03
  1682 KSP Residual norm 1.775963421001e-03
  1683 KSP Residual norm 2.570855608573e-03
  1684 KSP Residual norm 4.218418470023e-03
  1685 KSP Residual norm 6.808798194916e-03
  1686 KSP Residual norm 8.665640165091e-03
  1687 KSP Residual norm 6.816417271790e-03
  1688 KSP Residual norm 4.077925925808e-03
  1689 KSP Residual norm 2.529468344520e-03
  1690 KSP Residual norm 2.079852452529e-03
  1691 KSP Residual norm 2.169906661041e-03
  1692 KSP Residual norm 2.748732070558e-03
  1693 KSP Residual norm 4.293496737558e-03
  1694 KSP Residual norm 7.106427579240e-03
  1695 KSP Residual norm 1.039582615490e-02
  1696 KSP Residual norm 1.066412513256e-02
  1697 KSP Residual norm 7.363116007261e-03
  1698 KSP Residual norm 4.484806027494e-03
  1699 KSP Residual norm 3.194517941305e-03
  1700 KSP Residual norm 2.997403024709e-03
  1701 KSP Residual norm 3.715245506908e-03
  1702 KSP Residual norm 5.667183771566e-03
  1703 KSP Residual norm 9.895874135020e-03
  1704 KSP Residual norm 1.713628494096e-02
  1705 KSP Residual norm 2.253742675078e-02
  1706 KSP Residual norm 1.815633226840e-02
  1707 KSP Residual norm 1.027253732195e-02
  1708 KSP Residual norm 5.585731982869e-03
  1709 KSP Residual norm 3.560817037432e-03
  1710 KSP Residual norm 3.174754585629e-03
  1711 KSP Residual norm 4.087044780875e-03
  1712 KSP Residual norm 6.310730407470e-03
  1713 KSP Residual norm 8.889169687391e-03
  1714 KSP Residual norm 1.010227705484e-02
  1715 KSP Residual norm 9.757653183414e-03
  1716 KSP Residual norm 1.042924992465e-02
  1717 KSP Residual norm 1.236414617044e-02
  1718 KSP Residual norm 1.344340520603e-02
  1719 KSP Residual norm 9.861580508839e-03
  1720 KSP Residual norm 5.760429650522e-03
  1721 KSP Residual norm 3.968634397526e-03
  1722 KSP Residual norm 3.860048899695e-03
  1723 KSP Residual norm 4.885282153439e-03
  1724 KSP Residual norm 6.411846189810e-03
  1725 KSP Residual norm 7.528899153385e-03
  1726 KSP Residual norm 8.282565560188e-03
  1727 KSP Residual norm 1.028477470185e-02
  1728 KSP Residual norm 1.406352667328e-02
  1729 KSP Residual norm 1.613317508911e-02
  1730 KSP Residual norm 1.265179056408e-02
  1731 KSP Residual norm 8.433894035220e-03
  1732 KSP Residual norm 7.024467576599e-03
  1733 KSP Residual norm 7.522036580324e-03
  1734 KSP Residual norm 8.086010468802e-03
  1735 KSP Residual norm 6.775999043073e-03
  1736 KSP Residual norm 4.982660999927e-03
  1737 KSP Residual norm 4.153635535655e-03
  1738 KSP Residual norm 4.498743086892e-03
  1739 KSP Residual norm 6.376384796902e-03
  1740 KSP Residual norm 9.019305036726e-03
  1741 KSP Residual norm 1.008571307583e-02
  1742 KSP Residual norm 9.867622730951e-03
  1743 KSP Residual norm 1.130154844008e-02
  1744 KSP Residual norm 1.487352700809e-02
  1745 KSP Residual norm 1.674566260071e-02
  1746 KSP Residual norm 1.295908724076e-02
  1747 KSP Residual norm 9.270210719206e-03
  1748 KSP Residual norm 7.608571110303e-03
  1749 KSP Residual norm 6.682015809861e-03
  1750 KSP Residual norm 5.806877257439e-03
  1751 KSP Residual norm 4.662759516076e-03
  1752 KSP Residual norm 3.842666916488e-03
  1753 KSP Residual norm 3.669687472434e-03
  1754 KSP Residual norm 4.150693018521e-03
  1755 KSP Residual norm 5.197551156139e-03
  1756 KSP Residual norm 5.944114827337e-03
  1757 KSP Residual norm 6.456393033999e-03
  1758 KSP Residual norm 7.760231053459e-03
  1759 KSP Residual norm 1.037947368702e-02
  1760 KSP Residual norm 1.496028745626e-02
  1761 KSP Residual norm 1.618786763382e-02
  1762 KSP Residual norm 1.370970144802e-02
  1763 KSP Residual norm 1.180123064819e-02
  1764 KSP Residual norm 1.206538297991e-02
  1765 KSP Residual norm 1.128858176079e-02
  1766 KSP Residual norm 8.433779869320e-03
  1767 KSP Residual norm 5.728690607563e-03
  1768 KSP Residual norm 4.715870157427e-03
  1769 KSP Residual norm 4.903849994668e-03
  1770 KSP Residual norm 5.860927693618e-03
  1771 KSP Residual norm 5.955039528640e-03
  1772 KSP Residual norm 5.623262887997e-03
  1773 KSP Residual norm 6.396771032506e-03
  1774 KSP Residual norm 9.031367977476e-03
  1775 KSP Residual norm 1.299959176062e-02
  1776 KSP Residual norm 1.473141113096e-02
  1777 KSP Residual norm 1.301728743945e-02
  1778 KSP Residual norm 1.186704670476e-02
  1779 KSP Residual norm 1.271037519749e-02
  1780 KSP Residual norm 1.390386482594e-02
  1781 KSP Residual norm 1.203407490800e-02
  1782 KSP Residual norm 9.695334509794e-03
  1783 KSP Residual norm 8.568230932420e-03
  1784 KSP Residual norm 8.648198914198e-03
  1785 KSP Residual norm 8.377636695143e-03
  1786 KSP Residual norm 7.007933502942e-03
  1787 KSP Residual norm 5.982063968369e-03
  1788 KSP Residual norm 6.296043628802e-03
  1789 KSP Residual norm 7.651552723818e-03
  1790 KSP Residual norm 8.561237485700e-03
  1791 KSP Residual norm 8.559295288210e-03
  1792 KSP Residual norm 8.819457619708e-03
  1793 KSP Residual norm 1.100979421964e-02
  1794 KSP Residual norm 1.512814836318e-02
  1795 KSP Residual norm 1.747930112508e-02
  1796 KSP Residual norm 1.503911210909e-02
  1797 KSP Residual norm 1.333828397169e-02
  1798 KSP Residual norm 1.503110014031e-02
  1799 KSP Residual norm 1.858874048740e-02
  1800 KSP Residual norm 1.754785446477e-02
  1801 KSP Residual norm 1.265005935329e-02
  1802 KSP Residual norm 9.644563862227e-03
  1803 KSP Residual norm 8.339675321860e-03
  1804 KSP Residual norm 8.328279073357e-03
  1805 KSP Residual norm 7.687861874409e-03
  1806 KSP Residual norm 5.869926944451e-03
  1807 KSP Residual norm 4.854194518142e-03
  1808 KSP Residual norm 4.751080118652e-03
  1809 KSP Residual norm 5.304959976306e-03
  1810 KSP Residual norm 5.582226363115e-03
  1811 KSP Residual norm 5.301484986900e-03
  1812 KSP Residual norm 5.622322252902e-03
  1813 KSP Residual norm 7.282562214031e-03
  1814 KSP Residual norm 9.685663358062e-03
  1815 KSP Residual norm 1.110743276654e-02
  1816 KSP Residual norm 1.089423023046e-02
  1817 KSP Residual norm 1.200160432866e-02
  1818 KSP Residual norm 1.600239670961e-02
  1819 KSP Residual norm 2.114175274990e-02
  1820 KSP Residual norm 2.168298795445e-02
  1821 KSP Residual norm 1.924855736963e-02
  1822 KSP Residual norm 1.925728569694e-02
  1823 KSP Residual norm 2.156804080003e-02
  1824 KSP Residual norm 2.174795961672e-02
  1825 KSP Residual norm 1.857980960454e-02
  1826 KSP Residual norm 1.580064745947e-02
  1827 KSP Residual norm 1.464780188666e-02
  1828 KSP Residual norm 1.419629565106e-02
  1829 KSP Residual norm 1.199934486506e-02
  1830 KSP Residual norm 9.297607562041e-03
  1831 KSP Residual norm 7.973058376218e-03
  1832 KSP Residual norm 8.071779389779e-03
  1833 KSP Residual norm 7.655424487629e-03
  1834 KSP Residual norm 6.147071787004e-03
  1835 KSP Residual norm 5.092429298832e-03
  1836 KSP Residual norm 5.236830339569e-03
  1837 KSP Residual norm 5.903585382046e-03
  1838 KSP Residual norm 6.270704482619e-03
  1839 KSP Residual norm 6.429789049653e-03
  1840 KSP Residual norm 7.336468878096e-03
  1841 KSP Residual norm 9.369292088197e-03
  1842 KSP Residual norm 1.139526872507e-02
  1843 KSP Residual norm 1.185995814746e-02
  1844 KSP Residual norm 1.241981684210e-02
  1845 KSP Residual norm 1.554131717488e-02
  1846 KSP Residual norm 1.982680913327e-02
  1847 KSP Residual norm 2.082327701056e-02
  1848 KSP Residual norm 1.847297822087e-02
  1849 KSP Residual norm 1.726200472182e-02
  1850 KSP Residual norm 1.819892023894e-02
  1851 KSP Residual norm 1.812721678711e-02
  1852 KSP Residual norm 1.545821640092e-02
  1853 KSP Residual norm 1.351946708467e-02
  1854 KSP Residual norm 1.321421672781e-02
  1855 KSP Residual norm 1.203583764597e-02
  1856 KSP Residual norm 9.275182152481e-03
  1857 KSP Residual norm 7.166020487625e-03
  1858 KSP Residual norm 6.667041846874e-03
  1859 KSP Residual norm 6.979920613231e-03
  1860 KSP Residual norm 6.228819166919e-03
  1861 KSP Residual norm 5.296069511341e-03
  1862 KSP Residual norm 5.395934083308e-03
  1863 KSP Residual norm 6.589992548511e-03
  1864 KSP Residual norm 7.994790437338e-03
  1865 KSP Residual norm 8.198103360516e-03
  1866 KSP Residual norm 8.356807517315e-03
  1867 KSP Residual norm 9.552692725974e-03
  1868 KSP Residual norm 1.180930871093e-02
  1869 KSP Residual norm 1.369013031159e-02
  1870 KSP Residual norm 1.405625655625e-02
  1871 KSP Residual norm 1.499059973109e-02
  1872 KSP Residual norm 1.749830190835e-02
  1873 KSP Residual norm 1.923240732681e-02
  1874 KSP Residual norm 1.792581177987e-02
  1875 KSP Residual norm 1.595420253315e-02
  1876 KSP Residual norm 1.592437927271e-02
  1877 KSP Residual norm 1.571061792241e-02
  1878 KSP Residual norm 1.330409361058e-02
  1879 KSP Residual norm 1.011402845723e-02
  1880 KSP Residual norm 8.385714312478e-03
  1881 KSP Residual norm 7.619838379779e-03
  1882 KSP Residual norm 7.079068831244e-03
  1883 KSP Residual norm 6.263483895898e-03
  1884 KSP Residual norm 5.416913551314e-03
  1885 KSP Residual norm 5.248740770795e-03
  1886 KSP Residual norm 5.823178578214e-03
  1887 KSP Residual norm 5.856710332746e-03
  1888 KSP Residual norm 5.340607713094e-03
  1889 KSP Residual norm 5.372666907277e-03
  1890 KSP Residual norm 6.254021658222e-03
  1891 KSP Residual norm 7.002555893646e-03
  1892 KSP Residual norm 7.119015191351e-03
  1893 KSP Residual norm 7.398487660308e-03
  1894 KSP Residual norm 8.598149935475e-03
  1895 KSP Residual norm 9.082542888550e-03
  1896 KSP Residual norm 8.823606871381e-03
  1897 KSP Residual norm 8.351271646168e-03
  1898 KSP Residual norm 8.792697059084e-03
  1899 KSP Residual norm 9.434861567697e-03
  1900 KSP Residual norm 8.739188946527e-03
  1901 KSP Residual norm 7.439345048644e-03
  1902 KSP Residual norm 6.988512905492e-03
  1903 KSP Residual norm 7.266598646058e-03
  1904 KSP Residual norm 6.860594789317e-03
  1905 KSP Residual norm 5.869662347953e-03
  1906 KSP Residual norm 5.189292046807e-03
  1907 KSP Residual norm 4.698378415098e-03
  1908 KSP Residual norm 4.125932694582e-03
  1909 KSP Residual norm 3.623733579068e-03
  1910 KSP Residual norm 3.397717857275e-03
  1911 KSP Residual norm 3.450602416975e-03
  1912 KSP Residual norm 3.371679742809e-03
  1913 KSP Residual norm 3.211538717453e-03
  1914 KSP Residual norm 3.381570484386e-03
  1915 KSP Residual norm 3.752374891032e-03
  1916 KSP Residual norm 4.180224899146e-03
  1917 KSP Residual norm 4.425439107566e-03
  1918 KSP Residual norm 4.789578199346e-03
  1919 KSP Residual norm 5.284732777086e-03
  1920 KSP Residual norm 5.612706090822e-03
  1921 KSP Residual norm 5.861795033631e-03
  1922 KSP Residual norm 6.262650523811e-03
  1923 KSP Residual norm 7.405189723965e-03
  1924 KSP Residual norm 8.588777389142e-03
  1925 KSP Residual norm 9.036165294655e-03
  1926 KSP Residual norm 9.216393583533e-03
  1927 KSP Residual norm 1.015521724006e-02
  1928 KSP Residual norm 1.063074433343e-02
  1929 KSP Residual norm 9.895151313230e-03
  1930 KSP Residual norm 9.097228298051e-03
  1931 KSP Residual norm 8.685730919586e-03
  1932 KSP Residual norm 8.534987793340e-03
  1933 KSP Residual norm 7.863482725812e-03
  1934 KSP Residual norm 6.232590539545e-03
  1935 KSP Residual norm 5.209143529906e-03
  1936 KSP Residual norm 4.983723053720e-03
  1937 KSP Residual norm 4.813332251178e-03
  1938 KSP Residual norm 4.284521837285e-03
  1939 KSP Residual norm 3.984519392867e-03
  1940 KSP Residual norm 4.077399442331e-03
  1941 KSP Residual norm 4.352043481077e-03
  1942 KSP Residual norm 4.461858984941e-03
  1943 KSP Residual norm 4.380420741836e-03
  1944 KSP Residual norm 4.734130093898e-03
  1945 KSP Residual norm 5.852860035227e-03
  1946 KSP Residual norm 6.975950093485e-03
  1947 KSP Residual norm 7.052942525567e-03
  1948 KSP Residual norm 6.928412056660e-03
  1949 KSP Residual norm 7.888872516775e-03
  1950 KSP Residual norm 9.111899173159e-03
  1951 KSP Residual norm 9.278983874453e-03
  1952 KSP Residual norm 9.858700588481e-03
  1953 KSP Residual norm 1.179287626505e-02
  1954 KSP Residual norm 1.282807255394e-02
  1955 KSP Residual norm 1.262679691404e-02
  1956 KSP Residual norm 1.255775353882e-02
  1957 KSP Residual norm 1.370183873868e-02
  1958 KSP Residual norm 1.400213065512e-02
  1959 KSP Residual norm 1.283815157619e-02
  1960 KSP Residual norm 1.235915610084e-02
  1961 KSP Residual norm 1.266753849066e-02
  1962 KSP Residual norm 1.244201832218e-02
  1963 KSP Residual norm 1.041024275825e-02
  1964 KSP Residual norm 8.842758841380e-03
  1965 KSP Residual norm 8.240799359774e-03
  1966 KSP Residual norm 7.948646573032e-03
  1967 KSP Residual norm 6.445879239365e-03
  1968 KSP Residual norm 5.559004256048e-03
  1969 KSP Residual norm 5.066960361645e-03
  1970 KSP Residual norm 4.673923122700e-03
  1971 KSP Residual norm 4.072119570099e-03
  1972 KSP Residual norm 3.530170413031e-03
  1973 KSP Residual norm 3.445412172218e-03
  1974 KSP Residual norm 3.692808674938e-03
  1975 KSP Residual norm 3.509296213417e-03
  1976 KSP Residual norm 3.194284614736e-03
  1977 KSP Residual norm 3.214085704621e-03
  1978 KSP Residual norm 3.312784983574e-03
  1979 KSP Residual norm 3.376878732161e-03
  1980 KSP Residual norm 3.517881561328e-03
  1981 KSP Residual norm 3.693201640814e-03
  1982 KSP Residual norm 4.035821718953e-03
  1983 KSP Residual norm 4.303835709655e-03
  1984 KSP Residual norm 4.552984049764e-03
  1985 KSP Residual norm 5.220254958434e-03
  1986 KSP Residual norm 6.551890355271e-03
  1987 KSP Residual norm 8.381415823956e-03
  1988 KSP Residual norm 9.738560576716e-03
  1989 KSP Residual norm 1.100926661348e-02
  1990 KSP Residual norm 1.246532004316e-02
  1991 KSP Residual norm 1.407235479874e-02
  1992 KSP Residual norm 1.461033789890e-02
  1993 KSP Residual norm 1.466527654767e-02
  1994 KSP Residual norm 1.608542024596e-02
  1995 KSP Residual norm 1.723354282800e-02
  1996 KSP Residual norm 1.654429130126e-02
  1997 KSP Residual norm 1.497588013766e-02
  1998 KSP Residual norm 1.422318323008e-02
  1999 KSP Residual norm 1.372816158785e-02
  2000 KSP Residual norm 1.187907197624e-02
  2001 KSP Residual norm 9.530673313997e-03
  2002 KSP Residual norm 8.350842995280e-03
  2003 KSP Residual norm 8.040856946159e-03
  2004 KSP Residual norm 7.300758382425e-03
  2005 KSP Residual norm 6.351812200229e-03
  2006 KSP Residual norm 5.449815802557e-03
  2007 KSP Residual norm 5.410388539106e-03
  2008 KSP Residual norm 5.497381835543e-03
  2009 KSP Residual norm 4.766470175888e-03
  2010 KSP Residual norm 3.920445921370e-03
  2011 KSP Residual norm 3.635909540975e-03
  2012 KSP Residual norm 3.578050027117e-03
  2013 KSP Residual norm 3.281862671151e-03
  2014 KSP Residual norm 3.147248560594e-03
  2015 KSP Residual norm 3.257930715380e-03
  2016 KSP Residual norm 3.528434561439e-03
  2017 KSP Residual norm 3.704069547408e-03
  2018 KSP Residual norm 3.666226252482e-03
  2019 KSP Residual norm 3.748786599519e-03
  2020 KSP Residual norm 4.224789132151e-03
  2021 KSP Residual norm 4.713188915244e-03
  2022 KSP Residual norm 4.914611177949e-03
  2023 KSP Residual norm 5.100616440787e-03
  2024 KSP Residual norm 5.619478115716e-03
  2025 KSP Residual norm 6.242762113305e-03
  2026 KSP Residual norm 6.657735104471e-03
  2027 KSP Residual norm 7.401660853611e-03
  2028 KSP Residual norm 8.182706351312e-03
  2029 KSP Residual norm 8.293373495531e-03
  2030 KSP Residual norm 7.720806516677e-03
  2031 KSP Residual norm 7.731863907682e-03
  2032 KSP Residual norm 8.085902710517e-03
  2033 KSP Residual norm 7.932570278344e-03
  2034 KSP Residual norm 7.332322255068e-03
  2035 KSP Residual norm 6.981249891929e-03
  2036 KSP Residual norm 7.071360310580e-03
  2037 KSP Residual norm 6.607769945073e-03
  2038 KSP Residual norm 5.661103487318e-03
  2039 KSP Residual norm 5.113391338547e-03
  2040 KSP Residual norm 4.829759783025e-03
  2041 KSP Residual norm 4.583432553280e-03
  2042 KSP Residual norm 4.072399257332e-03
  2043 KSP Residual norm 3.457746678394e-03
  2044 KSP Residual norm 3.103218976754e-03
  2045 KSP Residual norm 2.986630897216e-03
  2046 KSP Residual norm 2.752096872884e-03
  2047 KSP Residual norm 2.601932301287e-03
  2048 KSP Residual norm 2.720727886614e-03
  2049 KSP Residual norm 2.887925956684e-03
  2050 KSP Residual norm 3.018447606692e-03
  2051 KSP Residual norm 3.082987476405e-03
  2052 KSP Residual norm 3.366759308843e-03
  2053 KSP Residual norm 3.759993248183e-03
  2054 KSP Residual norm 4.037275861301e-03
  2055 KSP Residual norm 4.049762465846e-03
  2056 KSP Residual norm 4.291473542844e-03
  2057 KSP Residual norm 4.793912122751e-03
  2058 KSP Residual norm 5.429296355667e-03
  2059 KSP Residual norm 5.999137088175e-03
  2060 KSP Residual norm 6.714532180763e-03
  2061 KSP Residual norm 7.157076086637e-03
  2062 KSP Residual norm 7.305423541139e-03
  2063 KSP Residual norm 7.840616914368e-03
  2064 KSP Residual norm 8.621338555374e-03
  2065 KSP Residual norm 9.179826914789e-03
  2066 KSP Residual norm 9.219040982171e-03
  2067 KSP Residual norm 9.081038905495e-03
  2068 KSP Residual norm 9.145498306064e-03
  2069 KSP Residual norm 9.219909480688e-03
  2070 KSP Residual norm 9.266003675083e-03
  2071 KSP Residual norm 8.549392921627e-03
  2072 KSP Residual norm 7.813939776317e-03
  2073 KSP Residual norm 7.511934879918e-03
  2074 KSP Residual norm 6.987487537767e-03
  2075 KSP Residual norm 6.181082525053e-03
  2076 KSP Residual norm 5.501067850667e-03
  2077 KSP Residual norm 5.316939535299e-03
  2078 KSP Residual norm 5.376044849232e-03
  2079 KSP Residual norm 4.812349537692e-03
  2080 KSP Residual norm 4.083001156083e-03
  2081 KSP Residual norm 3.984095588508e-03
  2082 KSP Residual norm 4.166602468433e-03
  2083 KSP Residual norm 3.736388905897e-03
  2084 KSP Residual norm 3.181344392970e-03
  2085 KSP Residual norm 3.087472465346e-03
  2086 KSP Residual norm 3.299309121667e-03
  2087 KSP Residual norm 3.122460123169e-03
  2088 KSP Residual norm 2.904036501409e-03
  2089 KSP Residual norm 2.916197279864e-03
  2090 KSP Residual norm 3.158694228775e-03
  2091 KSP Residual norm 3.299142972491e-03
  2092 KSP Residual norm 3.213974282697e-03
  2093 KSP Residual norm 3.321177716622e-03
  2094 KSP Residual norm 3.885809232016e-03
  2095 KSP Residual norm 4.328927945493e-03
  2096 KSP Residual norm 4.128316493644e-03
  2097 KSP Residual norm 4.061668994145e-03
  2098 KSP Residual norm 4.632615412637e-03
  2099 KSP Residual norm 5.419201729535e-03
  2100 KSP Residual norm 5.806306099173e-03
  2101 KSP Residual norm 6.499985237890e-03
  2102 KSP Residual norm 8.009977304793e-03
  2103 KSP Residual norm 9.143990958236e-03
  2104 KSP Residual norm 9.206698244420e-03
  2105 KSP Residual norm 9.294092252086e-03
  2106 KSP Residual norm 9.563695136136e-03
  2107 KSP Residual norm 8.860454764156e-03
  2108 KSP Residual norm 8.024764898450e-03
  2109 KSP Residual norm 7.718856528597e-03
  2110 KSP Residual norm 7.582562138927e-03
  2111 KSP Residual norm 7.114006432207e-03
  2112 KSP Residual norm 6.695573452676e-03
  2113 KSP Residual norm 6.318059725508e-03
  2114 KSP Residual norm 5.735068156662e-03
  2115 KSP Residual norm 5.486371917502e-03
  2116 KSP Residual norm 5.317941170076e-03
  2117 KSP Residual norm 5.153691910605e-03
  2118 KSP Residual norm 4.996322690960e-03
  2119 KSP Residual norm 4.639298979665e-03
  2120 KSP Residual norm 4.155770131347e-03
  2121 KSP Residual norm 3.875657105043e-03
  2122 KSP Residual norm 3.659569568406e-03
  2123 KSP Residual norm 3.574986658392e-03
  2124 KSP Residual norm 3.528766455188e-03
  2125 KSP Residual norm 3.301499565247e-03
  2126 KSP Residual norm 3.034514817403e-03
  2127 KSP Residual norm 2.762297206424e-03
  2128 KSP Residual norm 2.758080912531e-03
  2129 KSP Residual norm 3.004429701481e-03
  2130 KSP Residual norm 3.187509659594e-03
  2131 KSP Residual norm 3.320572410868e-03
  2132 KSP Residual norm 3.299541354205e-03
  2133 KSP Residual norm 3.223831194932e-03
  2134 KSP Residual norm 3.189967754497e-03
  2135 KSP Residual norm 3.403427921578e-03
  2136 KSP Residual norm 3.584610061763e-03
  2137 KSP Residual norm 3.711454211957e-03
  2138 KSP Residual norm 3.953840788285e-03
  2139 KSP Residual norm 4.105451876925e-03
  2140 KSP Residual norm 4.177676230502e-03
  2141 KSP Residual norm 4.308532456220e-03
  2142 KSP Residual norm 4.709470620439e-03
  2143 KSP Residual norm 5.773774414679e-03
  2144 KSP Residual norm 6.587720688920e-03
  2145 KSP Residual norm 6.770095137610e-03
  2146 KSP Residual norm 8.024962739428e-03
  2147 KSP Residual norm 9.979006460618e-03
  2148 KSP Residual norm 1.065598861617e-02
  2149 KSP Residual norm 1.028467092583e-02
  2150 KSP Residual norm 1.031263755519e-02
  2151 KSP Residual norm 1.018699324856e-02
  2152 KSP Residual norm 9.406281252560e-03
  2153 KSP Residual norm 8.920330262389e-03
  2154 KSP Residual norm 8.971791173694e-03
  2155 KSP Residual norm 9.516663684974e-03
  2156 KSP Residual norm 9.079106424707e-03
  2157 KSP Residual norm 7.963741724505e-03
  2158 KSP Residual norm 7.154186451308e-03
  2159 KSP Residual norm 6.775668514411e-03
  2160 KSP Residual norm 6.390988704684e-03
  2161 KSP Residual norm 5.772587283237e-03
  2162 KSP Residual norm 5.435320689840e-03
  2163 KSP Residual norm 5.465545999965e-03
  2164 KSP Residual norm 5.233001651176e-03
  2165 KSP Residual norm 4.652810907220e-03
  2166 KSP Residual norm 4.447632631418e-03
  2167 KSP Residual norm 4.448594208194e-03
  2168 KSP Residual norm 4.350817195271e-03
  2169 KSP Residual norm 4.205294412744e-03
  2170 KSP Residual norm 4.223189936177e-03
  2171 KSP Residual norm 4.288138588316e-03
  2172 KSP Residual norm 4.076768554048e-03
  2173 KSP Residual norm 3.949251053219e-03
  2174 KSP Residual norm 4.222998063808e-03
  2175 KSP Residual norm 4.394186001931e-03
  2176 KSP Residual norm 4.431744202567e-03
  2177 KSP Residual norm 4.714660974315e-03
  2178 KSP Residual norm 5.265011457330e-03
  2179 KSP Residual norm 5.550076240279e-03
  2180 KSP Residual norm 5.385488061286e-03
  2181 KSP Residual norm 5.170849664168e-03
  2182 KSP Residual norm 5.844721354479e-03
  2183 KSP Residual norm 7.297130276539e-03
  2184 KSP Residual norm 7.850736875997e-03
  2185 KSP Residual norm 7.698468024820e-03
  2186 KSP Residual norm 8.290259524435e-03
  2187 KSP Residual norm 9.384539453648e-03
  2188 KSP Residual norm 9.735129216493e-03
  2189 KSP Residual norm 9.868657977979e-03
  2190 KSP Residual norm 1.091551433912e-02
  2191 KSP Residual norm 1.245981706657e-02
  2192 KSP Residual norm 1.197197715594e-02
  2193 KSP Residual norm 1.164069198550e-02
  2194 KSP Residual norm 1.244648944014e-02
  2195 KSP Residual norm 1.350572985483e-02
  2196 KSP Residual norm 1.373395245921e-02
  2197 KSP Residual norm 1.328422543346e-02
  2198 KSP Residual norm 1.223399174464e-02
  2199 KSP Residual norm 1.162356128188e-02
  2200 KSP Residual norm 1.066884095926e-02
  2201 KSP Residual norm 9.112010736212e-03
  2202 KSP Residual norm 8.422796463594e-03
  2203 KSP Residual norm 8.383002149071e-03
  2204 KSP Residual norm 7.824083280895e-03
  2205 KSP Residual norm 7.034107064892e-03
  2206 KSP Residual norm 6.406017848159e-03
  2207 KSP Residual norm 5.924109479508e-03
  2208 KSP Residual norm 5.357465387764e-03
  2209 KSP Residual norm 4.984026665317e-03
  2210 KSP Residual norm 4.746244849070e-03
  2211 KSP Residual norm 4.376851720421e-03
  2212 KSP Residual norm 3.720427440057e-03
  2213 KSP Residual norm 3.146408949809e-03
  2214 KSP Residual norm 2.890006160957e-03
  2215 KSP Residual norm 2.756658730239e-03
  2216 KSP Residual norm 2.653215495302e-03
  2217 KSP Residual norm 2.650206256948e-03
  2218 KSP Residual norm 2.721887896256e-03
  2219 KSP Residual norm 2.684622175643e-03
  2220 KSP Residual norm 2.488504584793e-03
  2221 KSP Residual norm 2.386959412109e-03
  2222 KSP Residual norm 2.371450010664e-03
  2223 KSP Residual norm 2.499419977970e-03
  2224 KSP Residual norm 2.693033707163e-03
  2225 KSP Residual norm 2.860677622571e-03
  2226 KSP Residual norm 2.952863582608e-03
  2227 KSP Residual norm 2.988598797066e-03
  2228 KSP Residual norm 2.890748879091e-03
  2229 KSP Residual norm 2.868441200643e-03
  2230 KSP Residual norm 2.991111970293e-03
  2231 KSP Residual norm 3.172985514033e-03
  2232 KSP Residual norm 3.292606908435e-03
  2233 KSP Residual norm 3.392155811553e-03
  2234 KSP Residual norm 3.535230701617e-03
  2235 KSP Residual norm 3.959373637352e-03
  2236 KSP Residual norm 4.565212140205e-03
  2237 KSP Residual norm 4.821196987496e-03
  2238 KSP Residual norm 4.922415050281e-03
  2239 KSP Residual norm 5.072974539554e-03
  2240 KSP Residual norm 5.263813883195e-03
  2241 KSP Residual norm 5.426306929832e-03
  2242 KSP Residual norm 6.120664810580e-03
  2243 KSP Residual norm 7.159099015502e-03
  2244 KSP Residual norm 7.409615555114e-03
  2245 KSP Residual norm 7.513554331491e-03
  2246 KSP Residual norm 8.000313332997e-03
  2247 KSP Residual norm 8.774490252024e-03
  2248 KSP Residual norm 9.039336379211e-03
  2249 KSP Residual norm 9.416574883628e-03
  2250 KSP Residual norm 1.045552940291e-02
  2251 KSP Residual norm 1.095124765772e-02
  2252 KSP Residual norm 1.091067731545e-02
  2253 KSP Residual norm 1.072798400570e-02
  2254 KSP Residual norm 1.053330165208e-02
  2255 KSP Residual norm 1.087027560563e-02
  2256 KSP Residual norm 1.094340292209e-02
  2257 KSP Residual norm 9.944151818544e-03
  2258 KSP Residual norm 9.524326498058e-03
  2259 KSP Residual norm 9.857883498125e-03
  2260 KSP Residual norm 9.999241781813e-03
  2261 KSP Residual norm 8.917422673018e-03
  2262 KSP Residual norm 8.019990947943e-03
  2263 KSP Residual norm 7.923931148596e-03
  2264 KSP Residual norm 7.630228933650e-03
  2265 KSP Residual norm 6.890681148470e-03
  2266 KSP Residual norm 6.397314247109e-03
  2267 KSP Residual norm 6.076721021358e-03
  2268 KSP Residual norm 5.769028879956e-03
  2269 KSP Residual norm 5.336649542499e-03
  2270 KSP Residual norm 4.881407930542e-03
  2271 KSP Residual norm 4.577405831613e-03
  2272 KSP Residual norm 4.213415851037e-03
  2273 KSP Residual norm 3.775766616320e-03
  2274 KSP Residual norm 3.404244489367e-03
  2275 KSP Residual norm 3.261894222734e-03
  2276 KSP Residual norm 3.100577799789e-03
  2277 KSP Residual norm 2.763231017518e-03
  2278 KSP Residual norm 2.567503732718e-03
  2279 KSP Residual norm 2.629261305111e-03
  2280 KSP Residual norm 2.583372462179e-03
  2281 KSP Residual norm 2.257492720860e-03
  2282 KSP Residual norm 2.168975357396e-03
  2283 KSP Residual norm 2.355179931970e-03
  2284 KSP Residual norm 2.492067164151e-03
  2285 KSP Residual norm 2.456665907090e-03
  2286 KSP Residual norm 2.437810288837e-03
  2287 KSP Residual norm 2.740218703631e-03
  2288 KSP Residual norm 2.946953069909e-03
  2289 KSP Residual norm 2.787872921852e-03
  2290 KSP Residual norm 2.725536734613e-03
  2291 KSP Residual norm 3.033412099267e-03
  2292 KSP Residual norm 3.272583682207e-03
  2293 KSP Residual norm 3.204235568301e-03
  2294 KSP Residual norm 3.421108353676e-03
  2295 KSP Residual norm 3.971217627917e-03
  2296 KSP Residual norm 4.128587634961e-03
  2297 KSP Residual norm 4.298336760100e-03
  2298 KSP Residual norm 4.722062357837e-03
  2299 KSP Residual norm 5.697560142610e-03
  2300 KSP Residual norm 5.968990862527e-03
  2301 KSP Residual norm 5.826561794337e-03
  2302 KSP Residual norm 6.359427330795e-03
  2303 KSP Residual norm 7.376375276938e-03
  2304 KSP Residual norm 7.922245439289e-03
  2305 KSP Residual norm 8.028445372328e-03
  2306 KSP Residual norm 7.699912691885e-03
  2307 KSP Residual norm 7.587940128727e-03
  2308 KSP Residual norm 7.960298833559e-03
  2309 KSP Residual norm 8.461080082996e-03
  2310 KSP Residual norm 9.332967294487e-03
  2311 KSP Residual norm 1.057501275364e-02
  2312 KSP Residual norm 1.151537427737e-02
  2313 KSP Residual norm 1.208983731323e-02
  2314 KSP Residual norm 1.270610053976e-02
  2315 KSP Residual norm 1.401458135679e-02
  2316 KSP Residual norm 1.465214520382e-02
  2317 KSP Residual norm 1.486866786002e-02
  2318 KSP Residual norm 1.560342833672e-02
  2319 KSP Residual norm 1.699230182908e-02
  2320 KSP Residual norm 1.811264580263e-02
  2321 KSP Residual norm 1.771933729362e-02
  2322 KSP Residual norm 1.820507682733e-02
  2323 KSP Residual norm 1.790918445477e-02
  2324 KSP Residual norm 1.672804542537e-02
  2325 KSP Residual norm 1.552464898903e-02
  2326 KSP Residual norm 1.542876923443e-02
  2327 KSP Residual norm 1.452627185034e-02
  2328 KSP Residual norm 1.355062176346e-02
  2329 KSP Residual norm 1.260040776986e-02
  2330 KSP Residual norm 1.229162073681e-02
  2331 KSP Residual norm 1.228076319119e-02
  2332 KSP Residual norm 1.154472090508e-02
  2333 KSP Residual norm 1.048177215151e-02
  2334 KSP Residual norm 9.744028166372e-03
  2335 KSP Residual norm 9.596511059772e-03
  2336 KSP Residual norm 9.486410482497e-03
  2337 KSP Residual norm 8.745430932840e-03
  2338 KSP Residual norm 8.210290136575e-03
  2339 KSP Residual norm 7.839236326358e-03
  2340 KSP Residual norm 7.194744679873e-03
  2341 KSP Residual norm 6.571357371524e-03
  2342 KSP Residual norm 6.106849801378e-03
  2343 KSP Residual norm 6.022124082466e-03
  2344 KSP Residual norm 5.880372351873e-03
  2345 KSP Residual norm 5.944846889075e-03
  2346 KSP Residual norm 5.961756628698e-03
  2347 KSP Residual norm 5.826538667703e-03
  2348 KSP Residual norm 5.760630918210e-03
  2349 KSP Residual norm 5.492884703535e-03
  2350 KSP Residual norm 5.410281952695e-03
  2351 KSP Residual norm 5.494273029143e-03
  2352 KSP Residual norm 5.303777160006e-03
  2353 KSP Residual norm 5.299306677113e-03
  2354 KSP Residual norm 5.593943123853e-03
  2355 KSP Residual norm 5.947341230891e-03
  2356 KSP Residual norm 6.248050330786e-03
  2357 KSP Residual norm 6.672418445200e-03
  2358 KSP Residual norm 6.840759883722e-03
  2359 KSP Residual norm 7.311645521061e-03
  2360 KSP Residual norm 8.528165651140e-03
  2361 KSP Residual norm 9.359232085623e-03
  2362 KSP Residual norm 8.997214443045e-03
  2363 KSP Residual norm 9.151512001640e-03
  2364 KSP Residual norm 9.814919143160e-03
  2365 KSP Residual norm 9.473961467521e-03
  2366 KSP Residual norm 8.916794002765e-03
  2367 KSP Residual norm 9.580099819334e-03
  2368 KSP Residual norm 1.092803287468e-02
  2369 KSP Residual norm 1.177066696453e-02
  2370 KSP Residual norm 1.233610734730e-02
  2371 KSP Residual norm 1.349596697859e-02
  2372 KSP Residual norm 1.422597580577e-02
  2373 KSP Residual norm 1.394041333853e-02
  2374 KSP Residual norm 1.324928418055e-02
  2375 KSP Residual norm 1.396539289495e-02
  2376 KSP Residual norm 1.514717693073e-02
  2377 KSP Residual norm 1.451979579451e-02
  2378 KSP Residual norm 1.264633392368e-02
  2379 KSP Residual norm 1.110823036001e-02
  2380 KSP Residual norm 1.006475915249e-02
  2381 KSP Residual norm 9.365164277252e-03
  2382 KSP Residual norm 9.045684726161e-03
  2383 KSP Residual norm 8.579824342906e-03
  2384 KSP Residual norm 8.162256717764e-03
  2385 KSP Residual norm 7.491664866784e-03
  2386 KSP Residual norm 7.139888523418e-03
  2387 KSP Residual norm 7.212352332472e-03
  2388 KSP Residual norm 7.129900453900e-03
  2389 KSP Residual norm 6.429884715097e-03
  2390 KSP Residual norm 6.118678763045e-03
  2391 KSP Residual norm 6.653860543467e-03
  2392 KSP Residual norm 6.582069714587e-03
  2393 KSP Residual norm 5.762185306889e-03
  2394 KSP Residual norm 5.456077407301e-03
  2395 KSP Residual norm 5.436151997470e-03
  2396 KSP Residual norm 5.019341766606e-03
  2397 KSP Residual norm 4.700956991695e-03
  2398 KSP Residual norm 4.668023157564e-03
  2399 KSP Residual norm 4.501515700463e-03
  2400 KSP Residual norm 4.197022164665e-03
  2401 KSP Residual norm 3.817706011035e-03
  2402 KSP Residual norm 3.664318386502e-03
  2403 KSP Residual norm 3.767331470893e-03
  2404 KSP Residual norm 3.850171435180e-03
  2405 KSP Residual norm 3.890255062260e-03
  2406 KSP Residual norm 4.075339454006e-03
  2407 KSP Residual norm 4.343737239892e-03
  2408 KSP Residual norm 4.331519772355e-03
  2409 KSP Residual norm 4.268280541827e-03
  2410 KSP Residual norm 4.464476774624e-03
  2411 KSP Residual norm 4.943672287012e-03
  2412 KSP Residual norm 5.317709547685e-03
  2413 KSP Residual norm 5.459401763318e-03
  2414 KSP Residual norm 5.646754403152e-03
  2415 KSP Residual norm 5.774969211463e-03
  2416 KSP Residual norm 5.708560645311e-03
  2417 KSP Residual norm 5.674091351982e-03
  2418 KSP Residual norm 5.854876560222e-03
  2419 KSP Residual norm 6.260401374731e-03
  2420 KSP Residual norm 6.621278399721e-03
  2421 KSP Residual norm 7.282592497201e-03
  2422 KSP Residual norm 8.093100105437e-03
  2423 KSP Residual norm 8.303737134056e-03
  2424 KSP Residual norm 8.401936399922e-03
  2425 KSP Residual norm 8.811703568770e-03
  2426 KSP Residual norm 8.942527065268e-03
  2427 KSP Residual norm 9.454131455613e-03
  2428 KSP Residual norm 1.056739724498e-02
  2429 KSP Residual norm 1.131059497836e-02
  2430 KSP Residual norm 1.135639791659e-02
  2431 KSP Residual norm 1.205126873730e-02
  2432 KSP Residual norm 1.262495951635e-02
  2433 KSP Residual norm 1.303848674425e-02
  2434 KSP Residual norm 1.301252885924e-02
  2435 KSP Residual norm 1.377500347167e-02
  2436 KSP Residual norm 1.429601251787e-02
  2437 KSP Residual norm 1.392106005918e-02
  2438 KSP Residual norm 1.360317743723e-02
  2439 KSP Residual norm 1.426602654522e-02
  2440 KSP Residual norm 1.510382328407e-02
  2441 KSP Residual norm 1.473928783444e-02
  2442 KSP Residual norm 1.380171657314e-02
  2443 KSP Residual norm 1.268300260363e-02
  2444 KSP Residual norm 1.255281825396e-02
  2445 KSP Residual norm 1.268661415517e-02
  2446 KSP Residual norm 1.295737164497e-02
  2447 KSP Residual norm 1.355555123857e-02
  2448 KSP Residual norm 1.355735990527e-02
  2449 KSP Residual norm 1.336200081031e-02
  2450 KSP Residual norm 1.252572155735e-02
  2451 KSP Residual norm 1.131979365474e-02
  2452 KSP Residual norm 1.100821509650e-02
  2453 KSP Residual norm 1.087773496952e-02
  2454 KSP Residual norm 1.013125318378e-02
  2455 KSP Residual norm 9.805815814668e-03
  2456 KSP Residual norm 1.004451530965e-02
  2457 KSP Residual norm 9.575804427701e-03
  2458 KSP Residual norm 8.652734196563e-03
  2459 KSP Residual norm 8.163438150136e-03
  2460 KSP Residual norm 8.041074727141e-03
  2461 KSP Residual norm 7.346137486217e-03
  2462 KSP Residual norm 6.565328169772e-03
  2463 KSP Residual norm 6.495238995987e-03
  2464 KSP Residual norm 6.543818246286e-03
  2465 KSP Residual norm 5.844422743171e-03
  2466 KSP Residual norm 5.161768107683e-03
  2467 KSP Residual norm 4.998513002561e-03
  2468 KSP Residual norm 5.023178132147e-03
  2469 KSP Residual norm 4.955750454620e-03
  2470 KSP Residual norm 4.914149665942e-03
  2471 KSP Residual norm 5.082266464149e-03
  2472 KSP Residual norm 5.226795434602e-03
  2473 KSP Residual norm 5.083034164029e-03
  2474 KSP Residual norm 4.786180670349e-03
  2475 KSP Residual norm 4.723714363499e-03
  2476 KSP Residual norm 4.706592527681e-03
  2477 KSP Residual norm 4.400559829879e-03
  2478 KSP Residual norm 4.111435196105e-03
  2479 KSP Residual norm 4.337075346385e-03
  2480 KSP Residual norm 4.945178145864e-03
  2481 KSP Residual norm 5.092298303078e-03
  2482 KSP Residual norm 4.784661524695e-03
  2483 KSP Residual norm 4.919441824071e-03
  2484 KSP Residual norm 5.886707767174e-03
  2485 KSP Residual norm 6.150378407138e-03
  2486 KSP Residual norm 6.227021440015e-03
  2487 KSP Residual norm 6.745898636979e-03
  2488 KSP Residual norm 7.047764964447e-03
  2489 KSP Residual norm 6.892213427333e-03
  2490 KSP Residual norm 7.331046814200e-03
  2491 KSP Residual norm 8.227580999757e-03
  2492 KSP Residual norm 9.024133996447e-03
  2493 KSP Residual norm 9.058584392188e-03
  2494 KSP Residual norm 9.224694390954e-03
  2495 KSP Residual norm 9.945749770545e-03
  2496 KSP Residual norm 1.027578826375e-02
  2497 KSP Residual norm 1.025977864628e-02
  2498 KSP Residual norm 1.047135323925e-02
  2499 KSP Residual norm 1.128179504584e-02
  2500 KSP Residual norm 1.163186215290e-02
  2501 KSP Residual norm 1.180260491874e-02
  2502 KSP Residual norm 1.228759810586e-02
  2503 KSP Residual norm 1.261920600272e-02
  2504 KSP Residual norm 1.246019870243e-02
  2505 KSP Residual norm 1.259940043368e-02
  2506 KSP Residual norm 1.235165793218e-02
  2507 KSP Residual norm 1.155175172210e-02
  2508 KSP Residual norm 1.109419638823e-02
  2509 KSP Residual norm 1.112496659786e-02
  2510 KSP Residual norm 1.105540691914e-02
  2511 KSP Residual norm 1.118139652667e-02
  2512 KSP Residual norm 1.045814729055e-02
  2513 KSP Residual norm 9.565959357082e-03
  2514 KSP Residual norm 9.665109194128e-03
  2515 KSP Residual norm 1.033527019297e-02
  2516 KSP Residual norm 1.020689592293e-02
  2517 KSP Residual norm 9.411272897569e-03
  2518 KSP Residual norm 8.552625261265e-03
  2519 KSP Residual norm 8.020197971840e-03
  2520 KSP Residual norm 8.009439687359e-03
  2521 KSP Residual norm 8.357946587350e-03
  2522 KSP Residual norm 8.362529612484e-03
  2523 KSP Residual norm 8.114648870068e-03
  2524 KSP Residual norm 7.807525075191e-03
  2525 KSP Residual norm 7.818755683000e-03
  2526 KSP Residual norm 7.290236106522e-03
  2527 KSP Residual norm 6.766378491383e-03
  2528 KSP Residual norm 6.419448174050e-03
  2529 KSP Residual norm 6.016044262508e-03
  2530 KSP Residual norm 5.457758626948e-03
  2531 KSP Residual norm 5.225608365999e-03
  2532 KSP Residual norm 5.140382521091e-03
  2533 KSP Residual norm 4.847419115490e-03
  2534 KSP Residual norm 4.344336303964e-03
  2535 KSP Residual norm 3.953836922469e-03
  2536 KSP Residual norm 3.759166852375e-03
  2537 KSP Residual norm 3.465317723701e-03
  2538 KSP Residual norm 3.376037501877e-03
  2539 KSP Residual norm 3.465844879655e-03
  2540 KSP Residual norm 3.188246161516e-03
  2541 KSP Residual norm 2.806258819422e-03
  2542 KSP Residual norm 2.574138120822e-03
  2543 KSP Residual norm 2.400153103637e-03
  2544 KSP Residual norm 2.256897887269e-03
  2545 KSP Residual norm 2.172604881480e-03
  2546 KSP Residual norm 2.119275275677e-03
  2547 KSP Residual norm 1.934906777052e-03
  2548 KSP Residual norm 1.887190889666e-03
  2549 KSP Residual norm 2.005042240433e-03
  2550 KSP Residual norm 2.003622964132e-03
  2551 KSP Residual norm 2.017525563253e-03
  2552 KSP Residual norm 2.120766630389e-03
  2553 KSP Residual norm 2.030221752738e-03
  2554 KSP Residual norm 1.822857717387e-03
  2555 KSP Residual norm 1.858280486180e-03
  2556 KSP Residual norm 2.066510567964e-03
  2557 KSP Residual norm 2.082650460288e-03
  2558 KSP Residual norm 1.942917568133e-03
  2559 KSP Residual norm 1.939991779578e-03
  2560 KSP Residual norm 1.964283335486e-03
  2561 KSP Residual norm 1.952533731378e-03
  2562 KSP Residual norm 1.942083965188e-03
  2563 KSP Residual norm 2.056157903246e-03
  2564 KSP Residual norm 2.194497253377e-03
  2565 KSP Residual norm 2.371419632789e-03
  2566 KSP Residual norm 2.518347065455e-03
  2567 KSP Residual norm 2.701302247258e-03
  2568 KSP Residual norm 2.795331332162e-03
  2569 KSP Residual norm 2.670469528493e-03
  2570 KSP Residual norm 2.486617843393e-03
  2571 KSP Residual norm 2.490357246694e-03
  2572 KSP Residual norm 2.644629342573e-03
  2573 KSP Residual norm 2.717135486971e-03
  2574 KSP Residual norm 2.817669991730e-03
  2575 KSP Residual norm 3.134078794211e-03
  2576 KSP Residual norm 3.439559563310e-03
  2577 KSP Residual norm 3.525304337067e-03
  2578 KSP Residual norm 3.848407219676e-03
  2579 KSP Residual norm 4.172120908185e-03
  2580 KSP Residual norm 4.147151486596e-03
  2581 KSP Residual norm 4.244007764660e-03
  2582 KSP Residual norm 4.653581934327e-03
  2583 KSP Residual norm 5.337753974150e-03
  2584 KSP Residual norm 5.579099169522e-03
  2585 KSP Residual norm 5.293906845109e-03
  2586 KSP Residual norm 5.188560162742e-03
  2587 KSP Residual norm 5.434809181416e-03
  2588 KSP Residual norm 5.777278090177e-03
  2589 KSP Residual norm 5.798176790722e-03
  2590 KSP Residual norm 6.013124695274e-03
  2591 KSP Residual norm 6.449577667500e-03
  2592 KSP Residual norm 6.434569035132e-03
  2593 KSP Residual norm 6.647043507976e-03
  2594 KSP Residual norm 6.766497340129e-03
  2595 KSP Residual norm 6.586268634271e-03
  2596 KSP Residual norm 6.362863368277e-03
  2597 KSP Residual norm 6.972034378214e-03
  2598 KSP Residual norm 7.666433212361e-03
  2599 KSP Residual norm 7.030591364164e-03
  2600 KSP Residual norm 6.261952143498e-03
  2601 KSP Residual norm 6.334862749894e-03
  2602 KSP Residual norm 6.318795570805e-03
  2603 KSP Residual norm 6.172005139057e-03
  2604 KSP Residual norm 6.471332821120e-03
  2605 KSP Residual norm 6.783784346312e-03
  2606 KSP Residual norm 6.416069229820e-03
  2607 KSP Residual norm 6.007075002044e-03
  2608 KSP Residual norm 5.893058127475e-03
  2609 KSP Residual norm 5.683576052440e-03
  2610 KSP Residual norm 5.408949172070e-03
  2611 KSP Residual norm 5.115837579870e-03
  2612 KSP Residual norm 4.845334779024e-03
  2613 KSP Residual norm 4.544017248392e-03
  2614 KSP Residual norm 4.322561110461e-03
  2615 KSP Residual norm 4.051869859407e-03
  2616 KSP Residual norm 3.633203941098e-03
  2617 KSP Residual norm 3.730359285905e-03
  2618 KSP Residual norm 3.953531389059e-03
  2619 KSP Residual norm 3.546282614388e-03
  2620 KSP Residual norm 2.946557927049e-03
  2621 KSP Residual norm 2.744013009653e-03
  2622 KSP Residual norm 2.797304890528e-03
  2623 KSP Residual norm 2.776063401053e-03
  2624 KSP Residual norm 2.666853252490e-03
  2625 KSP Residual norm 2.570553908970e-03
  2626 KSP Residual norm 2.418137297250e-03
  2627 KSP Residual norm 2.342030722541e-03
  2628 KSP Residual norm 2.384143106336e-03
  2629 KSP Residual norm 2.331581495599e-03
  2630 KSP Residual norm 2.118101736682e-03
  2631 KSP Residual norm 1.966008740335e-03
  2632 KSP Residual norm 1.929165865116e-03
  2633 KSP Residual norm 1.858383094757e-03
  2634 KSP Residual norm 1.840139851182e-03
  2635 KSP Residual norm 1.730583423718e-03
  2636 KSP Residual norm 1.576364084886e-03
  2637 KSP Residual norm 1.582887351903e-03
  2638 KSP Residual norm 1.615390108123e-03
  2639 KSP Residual norm 1.430278769497e-03
  2640 KSP Residual norm 1.309774816050e-03
  2641 KSP Residual norm 1.307817759557e-03
  2642 KSP Residual norm 1.213478325933e-03
  2643 KSP Residual norm 1.083290090130e-03
  2644 KSP Residual norm 1.085094157745e-03
  2645 KSP Residual norm 1.149726040631e-03
  2646 KSP Residual norm 1.111283849541e-03
  2647 KSP Residual norm 9.855745611789e-04
  2648 KSP Residual norm 9.046436388309e-04
  2649 KSP Residual norm 8.680357480033e-04
  2650 KSP Residual norm 8.813872816119e-04
  2651 KSP Residual norm 9.193231486463e-04
  2652 KSP Residual norm 9.709608864798e-04
  2653 KSP Residual norm 9.548075389208e-04
  2654 KSP Residual norm 8.900324621046e-04
  2655 KSP Residual norm 8.725312938322e-04
  2656 KSP Residual norm 9.082437403545e-04
  2657 KSP Residual norm 9.385644497781e-04
  2658 KSP Residual norm 9.624593688495e-04
  2659 KSP Residual norm 1.012088976398e-03
  2660 KSP Residual norm 1.011955489881e-03
  2661 KSP Residual norm 9.749066420987e-04
  2662 KSP Residual norm 9.855223442161e-04
  2663 KSP Residual norm 1.059256654704e-03
  2664 KSP Residual norm 1.092440140365e-03
  2665 KSP Residual norm 1.090564467516e-03
  2666 KSP Residual norm 1.065117419279e-03
  2667 KSP Residual norm 1.108393848916e-03
  2668 KSP Residual norm 1.210653186918e-03
  2669 KSP Residual norm 1.256173308257e-03
  2670 KSP Residual norm 1.234334641031e-03
  2671 KSP Residual norm 1.310454239223e-03
  2672 KSP Residual norm 1.416780503419e-03
  2673 KSP Residual norm 1.422885149903e-03
  2674 KSP Residual norm 1.388075037904e-03
  2675 KSP Residual norm 1.366737962308e-03
  2676 KSP Residual norm 1.379201938358e-03
  2677 KSP Residual norm 1.351799042850e-03
  2678 KSP Residual norm 1.475734405630e-03
  2679 KSP Residual norm 1.713326884038e-03
  2680 KSP Residual norm 1.828599164666e-03
  2681 KSP Residual norm 1.857615319113e-03
  2682 KSP Residual norm 1.988256942276e-03
  2683 KSP Residual norm 2.095755035175e-03
  2684 KSP Residual norm 2.175776595377e-03
  2685 KSP Residual norm 2.437862726306e-03
  2686 KSP Residual norm 2.872368978122e-03
  2687 KSP Residual norm 2.930121135955e-03
  2688 KSP Residual norm 2.785150249971e-03
  2689 KSP Residual norm 2.926861935826e-03
  2690 KSP Residual norm 3.256586448558e-03
  2691 KSP Residual norm 3.394495732335e-03
  2692 KSP Residual norm 3.676170240234e-03
  2693 KSP Residual norm 4.464070401612e-03
  2694 KSP Residual norm 4.925003235818e-03
  2695 KSP Residual norm 4.657972593757e-03
  2696 KSP Residual norm 4.520776031390e-03
  2697 KSP Residual norm 4.826169301751e-03
  2698 KSP Residual norm 4.705226785431e-03
  2699 KSP Residual norm 4.845834495802e-03
  2700 KSP Residual norm 5.450568165750e-03
  2701 KSP Residual norm 5.405685886439e-03
  2702 KSP Residual norm 5.064404720592e-03
  2703 KSP Residual norm 5.159041773853e-03
  2704 KSP Residual norm 5.396253694145e-03
  2705 KSP Residual norm 5.087777378594e-03
  2706 KSP Residual norm 4.416701744863e-03
  2707 KSP Residual norm 4.283464780264e-03
  2708 KSP Residual norm 4.227776586809e-03
  2709 KSP Residual norm 3.816430510896e-03
  2710 KSP Residual norm 3.507188080857e-03
  2711 KSP Residual norm 3.664141787644e-03
  2712 KSP Residual norm 3.882078097164e-03
  2713 KSP Residual norm 3.558005800540e-03
  2714 KSP Residual norm 3.362556333894e-03
  2715 KSP Residual norm 3.381412266198e-03
  2716 KSP Residual norm 3.272343545117e-03
  2717 KSP Residual norm 3.098166203496e-03
  2718 KSP Residual norm 2.918170899895e-03
  2719 KSP Residual norm 2.805589012223e-03
  2720 KSP Residual norm 2.617461682809e-03
  2721 KSP Residual norm 2.498203821414e-03
  2722 KSP Residual norm 2.555703948928e-03
  2723 KSP Residual norm 2.704929910323e-03
  2724 KSP Residual norm 2.704804499672e-03
  2725 KSP Residual norm 2.422352305371e-03
  2726 KSP Residual norm 2.146010215001e-03
  2727 KSP Residual norm 2.157191475484e-03
  2728 KSP Residual norm 2.145336994135e-03
  2729 KSP Residual norm 2.086378289458e-03
  2730 KSP Residual norm 2.229778840444e-03
  2731 KSP Residual norm 2.535817164615e-03
  2732 KSP Residual norm 2.632680974580e-03
  2733 KSP Residual norm 2.488486653901e-03
  2734 KSP Residual norm 2.374380582123e-03
  2735 KSP Residual norm 2.430738511771e-03
  2736 KSP Residual norm 2.420248713523e-03
  2737 KSP Residual norm 2.302847190148e-03
  2738 KSP Residual norm 2.254438668835e-03
  2739 KSP Residual norm 2.206384051676e-03
  2740 KSP Residual norm 2.026611506674e-03
  2741 KSP Residual norm 1.863862978796e-03
  2742 KSP Residual norm 1.791918577784e-03
  2743 KSP Residual norm 1.589158171238e-03
  2744 KSP Residual norm 1.448351414910e-03
  2745 KSP Residual norm 1.462011618822e-03
  2746 KSP Residual norm 1.546262244036e-03
  2747 KSP Residual norm 1.457974955196e-03
  2748 KSP Residual norm 1.358665370080e-03
  2749 KSP Residual norm 1.485787041264e-03
  2750 KSP Residual norm 1.649416402076e-03
  2751 KSP Residual norm 1.520063285568e-03
  2752 KSP Residual norm 1.394521339503e-03
  2753 KSP Residual norm 1.542474992449e-03
  2754 KSP Residual norm 1.617270768548e-03
  2755 KSP Residual norm 1.484129864690e-03
  2756 KSP Residual norm 1.489982256038e-03
  2757 KSP Residual norm 1.634619136561e-03
  2758 KSP Residual norm 1.576841752283e-03
  2759 KSP Residual norm 1.484849375883e-03
  2760 KSP Residual norm 1.588611441559e-03
  2761 KSP Residual norm 1.788271668052e-03
  2762 KSP Residual norm 1.838564643069e-03
  2763 KSP Residual norm 1.956549529214e-03
  2764 KSP Residual norm 2.153577292642e-03
  2765 KSP Residual norm 2.158929997251e-03
  2766 KSP Residual norm 2.004385674663e-03
  2767 KSP Residual norm 2.025979711910e-03
  2768 KSP Residual norm 2.272282762743e-03
  2769 KSP Residual norm 2.482726499242e-03
  2770 KSP Residual norm 2.703743415817e-03
  2771 KSP Residual norm 3.014984680178e-03
  2772 KSP Residual norm 3.362472240067e-03
  2773 KSP Residual norm 3.569907893456e-03
  2774 KSP Residual norm 3.793544712662e-03
  2775 KSP Residual norm 3.971139276993e-03
  2776 KSP Residual norm 4.087569126960e-03
  2777 KSP Residual norm 4.363456089764e-03
  2778 KSP Residual norm 4.625571421248e-03
  2779 KSP Residual norm 4.624976548773e-03
  2780 KSP Residual norm 4.718849386844e-03
  2781 KSP Residual norm 4.786949244693e-03
  2782 KSP Residual norm 4.771666421559e-03
  2783 KSP Residual norm 5.104231978217e-03
  2784 KSP Residual norm 5.734907457343e-03
  2785 KSP Residual norm 5.764605173383e-03
  2786 KSP Residual norm 5.426953091590e-03
  2787 KSP Residual norm 5.580034553178e-03
  2788 KSP Residual norm 5.949693184172e-03
  2789 KSP Residual norm 5.996671739248e-03
  2790 KSP Residual norm 6.157706620644e-03
  2791 KSP Residual norm 6.848408423874e-03
  2792 KSP Residual norm 7.066338896982e-03
  2793 KSP Residual norm 6.587699824354e-03
  2794 KSP Residual norm 6.594254657823e-03
  2795 KSP Residual norm 7.284894664177e-03
  2796 KSP Residual norm 7.388794406292e-03
  2797 KSP Residual norm 6.742009621402e-03
  2798 KSP Residual norm 6.669693683210e-03
  2799 KSP Residual norm 6.280792363793e-03
  2800 KSP Residual norm 5.548612251379e-03
  2801 KSP Residual norm 5.358466425664e-03
  2802 KSP Residual norm 5.617501994186e-03
  2803 KSP Residual norm 5.319539313742e-03
  2804 KSP Residual norm 4.781893806291e-03
  2805 KSP Residual norm 4.741739705150e-03
  2806 KSP Residual norm 4.981281036051e-03
  2807 KSP Residual norm 4.723399945724e-03
  2808 KSP Residual norm 4.341339983627e-03
  2809 KSP Residual norm 4.651093018266e-03
  2810 KSP Residual norm 5.040994656518e-03
  2811 KSP Residual norm 4.479552064666e-03
  2812 KSP Residual norm 3.830957288486e-03
  2813 KSP Residual norm 3.533215940491e-03
  2814 KSP Residual norm 3.438896124903e-03
  2815 KSP Residual norm 3.205565080589e-03
  2816 KSP Residual norm 3.178743406165e-03
  2817 KSP Residual norm 3.240179887624e-03
  2818 KSP Residual norm 3.158195637160e-03
  2819 KSP Residual norm 2.892701103103e-03
  2820 KSP Residual norm 2.797142641246e-03
  2821 KSP Residual norm 2.779326882773e-03
  2822 KSP Residual norm 2.617507251360e-03
  2823 KSP Residual norm 2.350097638705e-03
  2824 KSP Residual norm 2.096293170896e-03
  2825 KSP Residual norm 1.948274586444e-03
  2826 KSP Residual norm 1.807042821225e-03
  2827 KSP Residual norm 1.738739744696e-03
  2828 KSP Residual norm 1.678668895603e-03
  2829 KSP Residual norm 1.773884200509e-03
  2830 KSP Residual norm 1.836552583922e-03
  2831 KSP Residual norm 1.737215267139e-03
  2832 KSP Residual norm 1.598291536644e-03
  2833 KSP Residual norm 1.562991290880e-03
  2834 KSP Residual norm 1.467456550119e-03
  2835 KSP Residual norm 1.294963690664e-03
  2836 KSP Residual norm 1.237019430877e-03
  2837 KSP Residual norm 1.312206291645e-03
  2838 KSP Residual norm 1.291349637627e-03
  2839 KSP Residual norm 1.160335094663e-03
  2840 KSP Residual norm 1.063879454608e-03
  2841 KSP Residual norm 1.034625807636e-03
  2842 KSP Residual norm 9.770485830404e-04
  2843 KSP Residual norm 9.374445013353e-04
  2844 KSP Residual norm 9.902724864709e-04
  2845 KSP Residual norm 1.036533344318e-03
  2846 KSP Residual norm 1.079569282831e-03
  2847 KSP Residual norm 1.226883463673e-03
  2848 KSP Residual norm 1.430574675211e-03
  2849 KSP Residual norm 1.354421865633e-03
  2850 KSP Residual norm 1.231373694932e-03
  2851 KSP Residual norm 1.175397745394e-03
  2852 KSP Residual norm 1.070148692108e-03
  2853 KSP Residual norm 1.015922741370e-03
  2854 KSP Residual norm 1.103931648087e-03
  2855 KSP Residual norm 1.171540606755e-03
  2856 KSP Residual norm 1.088958128808e-03
  2857 KSP Residual norm 1.083246789518e-03
  2858 KSP Residual norm 1.113855493690e-03
  2859 KSP Residual norm 1.110085190246e-03
  2860 KSP Residual norm 1.142143272029e-03
  2861 KSP Residual norm 1.193743390105e-03
  2862 KSP Residual norm 1.131546392426e-03
  2863 KSP Residual norm 1.127578239592e-03
  2864 KSP Residual norm 1.271221238619e-03
  2865 KSP Residual norm 1.359804747599e-03
  2866 KSP Residual norm 1.289379864152e-03
  2867 KSP Residual norm 1.321333706950e-03
  2868 KSP Residual norm 1.544458941025e-03
  2869 KSP Residual norm 1.563976433107e-03
  2870 KSP Residual norm 1.399474385920e-03
  2871 KSP Residual norm 1.356252805981e-03
  2872 KSP Residual norm 1.443852116959e-03
  2873 KSP Residual norm 1.356990907946e-03
  2874 KSP Residual norm 1.285187356557e-03
  2875 KSP Residual norm 1.430496822359e-03
  2876 KSP Residual norm 1.681358820304e-03
  2877 KSP Residual norm 1.749072634641e-03
  2878 KSP Residual norm 1.829374916805e-03
  2879 KSP Residual norm 2.117446004955e-03
  2880 KSP Residual norm 2.172038560867e-03
  2881 KSP Residual norm 1.990623694723e-03
  2882 KSP Residual norm 2.142729037698e-03
  2883 KSP Residual norm 2.459801592783e-03
  2884 KSP Residual norm 2.405512176252e-03
  2885 KSP Residual norm 2.407816699724e-03
  2886 KSP Residual norm 2.653979926691e-03
  2887 KSP Residual norm 2.735241253463e-03
  2888 KSP Residual norm 2.684942144314e-03
  2889 KSP Residual norm 3.107427807814e-03
  2890 KSP Residual norm 3.575515284824e-03
  2891 KSP Residual norm 3.376235460739e-03
  2892 KSP Residual norm 3.404884516786e-03
  2893 KSP Residual norm 3.929868756447e-03
  2894 KSP Residual norm 4.111687608396e-03
  2895 KSP Residual norm 3.788022365376e-03
  2896 KSP Residual norm 4.037486192237e-03
  2897 KSP Residual norm 4.582307985708e-03
  2898 KSP Residual norm 4.397018421487e-03
  2899 KSP Residual norm 4.184351178202e-03
  2900 KSP Residual norm 4.129499004219e-03
  2901 KSP Residual norm 4.193657012396e-03
  2902 KSP Residual norm 4.345469063901e-03
  2903 KSP Residual norm 4.722109775846e-03
  2904 KSP Residual norm 5.392810790430e-03
  2905 KSP Residual norm 5.386641629693e-03
  2906 KSP Residual norm 5.090454899875e-03
  2907 KSP Residual norm 5.202040851774e-03
  2908 KSP Residual norm 5.417690627987e-03
  2909 KSP Residual norm 5.076526303676e-03
  2910 KSP Residual norm 5.233764214625e-03
  2911 KSP Residual norm 6.362598247088e-03
  2912 KSP Residual norm 7.075721196366e-03
  2913 KSP Residual norm 6.983864367887e-03
  2914 KSP Residual norm 7.582708469288e-03
  2915 KSP Residual norm 7.969517990493e-03
  2916 KSP Residual norm 7.917432839086e-03
  2917 KSP Residual norm 8.326635825449e-03
  2918 KSP Residual norm 8.822095168357e-03
  2919 KSP Residual norm 8.668312680659e-03
  2920 KSP Residual norm 9.188392767430e-03
  2921 KSP Residual norm 1.019618131499e-02
  2922 KSP Residual norm 9.443758357690e-03
  2923 KSP Residual norm 7.912514701689e-03
  2924 KSP Residual norm 7.307896808691e-03
  2925 KSP Residual norm 7.190406002902e-03
  2926 KSP Residual norm 6.848901440889e-03
  2927 KSP Residual norm 7.007735645264e-03
  2928 KSP Residual norm 8.085929902110e-03
  2929 KSP Residual norm 9.055854895566e-03
  2930 KSP Residual norm 8.788443507417e-03
  2931 KSP Residual norm 8.892129795841e-03
  2932 KSP Residual norm 9.391775988154e-03
  2933 KSP Residual norm 8.778762453979e-03
  2934 KSP Residual norm 8.177475371371e-03
  2935 KSP Residual norm 8.296157796572e-03
  2936 KSP Residual norm 8.428951916742e-03
  2937 KSP Residual norm 7.253612634486e-03
  2938 KSP Residual norm 6.486381004139e-03
  2939 KSP Residual norm 6.653913849035e-03
  2940 KSP Residual norm 6.711623842603e-03
  2941 KSP Residual norm 6.561290672839e-03
  2942 KSP Residual norm 7.211875432346e-03
  2943 KSP Residual norm 7.516924345150e-03
  2944 KSP Residual norm 6.571239843022e-03
  2945 KSP Residual norm 6.308294812942e-03
  2946 KSP Residual norm 6.468447711975e-03
  2947 KSP Residual norm 5.456713710464e-03
  2948 KSP Residual norm 4.407074338385e-03
  2949 KSP Residual norm 4.541864464324e-03
  2950 KSP Residual norm 5.127110075465e-03
  2951 KSP Residual norm 4.475441723750e-03
  2952 KSP Residual norm 3.935090225693e-03
  2953 KSP Residual norm 3.986292185665e-03
  2954 KSP Residual norm 3.861524737337e-03
  2955 KSP Residual norm 3.525301600677e-03
  2956 KSP Residual norm 3.606986049901e-03
  2957 KSP Residual norm 3.741501646941e-03
  2958 KSP Residual norm 3.329653686436e-03
  2959 KSP Residual norm 3.202102690664e-03
  2960 KSP Residual norm 3.450486095169e-03
  2961 KSP Residual norm 3.252219165076e-03
  2962 KSP Residual norm 2.477276891406e-03
  2963 KSP Residual norm 2.049933056556e-03
  2964 KSP Residual norm 1.902709902863e-03
  2965 KSP Residual norm 1.752531162959e-03
  2966 KSP Residual norm 1.696427240540e-03
  2967 KSP Residual norm 1.946924154321e-03
  2968 KSP Residual norm 2.227951284603e-03
  2969 KSP Residual norm 2.009009158130e-03
  2970 KSP Residual norm 1.882226516836e-03
  2971 KSP Residual norm 2.086086727174e-03
  2972 KSP Residual norm 2.055611734290e-03
  2973 KSP Residual norm 1.741240774921e-03
  2974 KSP Residual norm 1.725175564643e-03
  2975 KSP Residual norm 1.755915800229e-03
  2976 KSP Residual norm 1.509528375407e-03
  2977 KSP Residual norm 1.357637627266e-03
  2978 KSP Residual norm 1.460549071024e-03
  2979 KSP Residual norm 1.553492067748e-03
  2980 KSP Residual norm 1.364009061525e-03
  2981 KSP Residual norm 1.272013168916e-03
  2982 KSP Residual norm 1.186072933342e-03
  2983 KSP Residual norm 9.951101622586e-04
  2984 KSP Residual norm 9.363652021728e-04
  2985 KSP Residual norm 1.004675852639e-03
  2986 KSP Residual norm 1.036029921093e-03
  2987 KSP Residual norm 1.064462437764e-03
  2988 KSP Residual norm 1.224997879950e-03
  2989 KSP Residual norm 1.388057630221e-03
  2990 KSP Residual norm 1.372660186962e-03
  2991 KSP Residual norm 1.424045125325e-03
  2992 KSP Residual norm 1.500297885504e-03
  2993 KSP Residual norm 1.473977518522e-03
  2994 KSP Residual norm 1.397325608450e-03
  2995 KSP Residual norm 1.446577138766e-03
  2996 KSP Residual norm 1.432956780215e-03
  2997 KSP Residual norm 1.368682613462e-03
  2998 KSP Residual norm 1.330389794315e-03
  2999 KSP Residual norm 1.354215374244e-03
  3000 KSP Residual norm 1.319668006136e-03
  3001 KSP Residual norm 1.273994985774e-03
  3002 KSP Residual norm 1.371379762475e-03
  3003 KSP Residual norm 1.430753016456e-03
  3004 KSP Residual norm 1.306663632696e-03
  3005 KSP Residual norm 1.286112809999e-03
  3006 KSP Residual norm 1.350415243744e-03
  3007 KSP Residual norm 1.372214677136e-03
  3008 KSP Residual norm 1.418110778472e-03
  3009 KSP Residual norm 1.736144243771e-03
  3010 KSP Residual norm 1.962396016012e-03
  3011 KSP Residual norm 1.875622461591e-03
  3012 KSP Residual norm 1.828878048051e-03
  3013 KSP Residual norm 1.968093592774e-03
  3014 KSP Residual norm 2.024599310890e-03
  3015 KSP Residual norm 1.914434050527e-03
  3016 KSP Residual norm 1.949234213420e-03
  3017 KSP Residual norm 2.059691091928e-03
  3018 KSP Residual norm 2.230823155566e-03
  3019 KSP Residual norm 2.452639340379e-03
  3020 KSP Residual norm 2.884304396912e-03
  3021 KSP Residual norm 3.358685292056e-03
  3022 KSP Residual norm 3.553951903749e-03
  3023 KSP Residual norm 3.449118175846e-03
  3024 KSP Residual norm 3.300312969099e-03
  3025 KSP Residual norm 3.141321863979e-03
  3026 KSP Residual norm 3.189177447526e-03
  3027 KSP Residual norm 3.586824420308e-03
  3028 KSP Residual norm 4.318036306854e-03
  3029 KSP Residual norm 4.643788568772e-03
  3030 KSP Residual norm 4.370505229741e-03
  3031 KSP Residual norm 4.161352510344e-03
  3032 KSP Residual norm 4.426873460573e-03
  3033 KSP Residual norm 4.727376409745e-03
  3034 KSP Residual norm 4.935447116989e-03
  3035 KSP Residual norm 5.195492858474e-03
  3036 KSP Residual norm 5.262987991305e-03
  3037 KSP Residual norm 4.988286243106e-03
  3038 KSP Residual norm 4.838626754328e-03
  3039 KSP Residual norm 5.135821517572e-03
  3040 KSP Residual norm 5.128463280593e-03
  3041 KSP Residual norm 4.894818274532e-03
  3042 KSP Residual norm 5.157080366224e-03
  3043 KSP Residual norm 5.899655632507e-03
  3044 KSP Residual norm 6.311604201119e-03
  3045 KSP Residual norm 6.503921463717e-03
  3046 KSP Residual norm 7.045433203190e-03
  3047 KSP Residual norm 7.822428362162e-03
  3048 KSP Residual norm 7.801763914628e-03
  3049 KSP Residual norm 7.803226763047e-03
  3050 KSP Residual norm 8.170601241380e-03
  3051 KSP Residual norm 7.843857344975e-03
  3052 KSP Residual norm 7.654351738200e-03
  3053 KSP Residual norm 8.644931839356e-03
  3054 KSP Residual norm 9.699516109829e-03
  3055 KSP Residual norm 9.647065952106e-03
  3056 KSP Residual norm 1.006655408950e-02
  3057 KSP Residual norm 1.023806234184e-02
  3058 KSP Residual norm 9.532513741776e-03
  3059 KSP Residual norm 9.513932902273e-03
  3060 KSP Residual norm 1.005696053542e-02
  3061 KSP Residual norm 9.512926491812e-03
  3062 KSP Residual norm 8.959904449497e-03
  3063 KSP Residual norm 9.498596804941e-03
  3064 KSP Residual norm 1.065376693957e-02
  3065 KSP Residual norm 1.010658942622e-02
  3066 KSP Residual norm 9.678241257087e-03
  3067 KSP Residual norm 1.021317781344e-02
  3068 KSP Residual norm 1.109162939418e-02
  3069 KSP Residual norm 1.158666376649e-02
  3070 KSP Residual norm 1.202557056106e-02
  3071 KSP Residual norm 1.211144817720e-02
  3072 KSP Residual norm 1.120304665676e-02
  3073 KSP Residual norm 1.083553887500e-02
  3074 KSP Residual norm 1.121522622165e-02
  3075 KSP Residual norm 1.121260214238e-02
  3076 KSP Residual norm 1.046440502336e-02
  3077 KSP Residual norm 1.004708331370e-02
  3078 KSP Residual norm 1.073391842848e-02
  3079 KSP Residual norm 1.156613829371e-02
  3080 KSP Residual norm 1.236452671945e-02
  3081 KSP Residual norm 1.309923551733e-02
  3082 KSP Residual norm 1.438114956817e-02
  3083 KSP Residual norm 1.426149827407e-02
  3084 KSP Residual norm 1.224280180376e-02
  3085 KSP Residual norm 1.096181143829e-02
  3086 KSP Residual norm 1.111920170108e-02
  3087 KSP Residual norm 1.118340676655e-02
  3088 KSP Residual norm 1.000130923922e-02
  3089 KSP Residual norm 9.754845073746e-03
  3090 KSP Residual norm 1.014216156263e-02
  3091 KSP Residual norm 9.540691283703e-03
  3092 KSP Residual norm 9.401965344054e-03
  3093 KSP Residual norm 9.624902854579e-03
  3094 KSP Residual norm 9.147961612330e-03
  3095 KSP Residual norm 7.906191690820e-03
  3096 KSP Residual norm 7.592020558342e-03
  3097 KSP Residual norm 7.524035202212e-03
  3098 KSP Residual norm 7.266627699893e-03
  3099 KSP Residual norm 6.751911787101e-03
  3100 KSP Residual norm 6.387038264013e-03
  3101 KSP Residual norm 5.486121905795e-03
  3102 KSP Residual norm 4.760691147831e-03
  3103 KSP Residual norm 4.980285403119e-03
  3104 KSP Residual norm 5.753887376636e-03
  3105 KSP Residual norm 6.060393070534e-03
  3106 KSP Residual norm 5.800149107397e-03
  3107 KSP Residual norm 5.712092792131e-03
  3108 KSP Residual norm 5.723257999910e-03
  3109 KSP Residual norm 5.585497985460e-03
  3110 KSP Residual norm 5.299240610802e-03
  3111 KSP Residual norm 5.185844312278e-03
  3112 KSP Residual norm 5.180691238305e-03
  3113 KSP Residual norm 5.170254632558e-03
  3114 KSP Residual norm 5.031353871658e-03
  3115 KSP Residual norm 4.516523814593e-03
  3116 KSP Residual norm 3.891943664907e-03
  3117 KSP Residual norm 3.527455407802e-03
  3118 KSP Residual norm 3.276607605164e-03
  3119 KSP Residual norm 3.137818567100e-03
  3120 KSP Residual norm 3.510031082913e-03
  3121 KSP Residual norm 4.090076535163e-03
  3122 KSP Residual norm 4.204439159335e-03
  3123 KSP Residual norm 4.519044874314e-03
  3124 KSP Residual norm 4.711943201661e-03
  3125 KSP Residual norm 4.108752640532e-03
  3126 KSP Residual norm 3.479065521297e-03
  3127 KSP Residual norm 3.495031577776e-03
  3128 KSP Residual norm 3.934896362242e-03
  3129 KSP Residual norm 4.070916898692e-03
  3130 KSP Residual norm 4.288349051719e-03
  3131 KSP Residual norm 4.317228547289e-03
  3132 KSP Residual norm 3.946454044654e-03
  3133 KSP Residual norm 3.779196047954e-03
  3134 KSP Residual norm 4.032446591841e-03
  3135 KSP Residual norm 4.018336837785e-03
  3136 KSP Residual norm 3.607753498867e-03
  3137 KSP Residual norm 3.481587781544e-03
  3138 KSP Residual norm 3.455709777074e-03
  3139 KSP Residual norm 3.363059582249e-03
  3140 KSP Residual norm 3.313987873533e-03
  3141 KSP Residual norm 3.237254013235e-03
  3142 KSP Residual norm 2.768398774635e-03
  3143 KSP Residual norm 2.468370301959e-03
  3144 KSP Residual norm 2.535141088666e-03
  3145 KSP Residual norm 2.928032024313e-03
  3146 KSP Residual norm 3.847497590560e-03
  3147 KSP Residual norm 4.242685138425e-03
  3148 KSP Residual norm 3.615538528394e-03
  3149 KSP Residual norm 3.113010251107e-03
  3150 KSP Residual norm 3.162645118937e-03
  3151 KSP Residual norm 3.317127403664e-03
  3152 KSP Residual norm 3.471925769185e-03
  3153 KSP Residual norm 3.828187151022e-03
  3154 KSP Residual norm 4.090509587600e-03
  3155 KSP Residual norm 3.897198613880e-03
  3156 KSP Residual norm 3.639927871554e-03
  3157 KSP Residual norm 3.528236759149e-03
  3158 KSP Residual norm 3.438661404826e-03
  3159 KSP Residual norm 3.636352107113e-03
  3160 KSP Residual norm 3.997719762216e-03
  3161 KSP Residual norm 4.112496172284e-03
  3162 KSP Residual norm 4.057648658384e-03
  3163 KSP Residual norm 4.270657152407e-03
  3164 KSP Residual norm 4.405984332441e-03
  3165 KSP Residual norm 3.807035656515e-03
  3166 KSP Residual norm 3.531658843093e-03
  3167 KSP Residual norm 3.943140142473e-03
  3168 KSP Residual norm 3.994005998218e-03
  3169 KSP Residual norm 3.925806568403e-03
  3170 KSP Residual norm 4.283447489515e-03
  3171 KSP Residual norm 4.995750857361e-03
  3172 KSP Residual norm 5.209611202407e-03
  3173 KSP Residual norm 5.080346313836e-03
  3174 KSP Residual norm 4.799734984449e-03
  3175 KSP Residual norm 4.163699720599e-03
  3176 KSP Residual norm 4.081417388337e-03
  3177 KSP Residual norm 4.614329415968e-03
  3178 KSP Residual norm 5.245797563056e-03
  3179 KSP Residual norm 5.297680341569e-03
  3180 KSP Residual norm 5.401341806411e-03
  3181 KSP Residual norm 6.006059778329e-03
  3182 KSP Residual norm 7.005651171496e-03
  3183 KSP Residual norm 8.532646190371e-03
  3184 KSP Residual norm 9.728916729099e-03
  3185 KSP Residual norm 9.381147206066e-03
  3186 KSP Residual norm 8.961874693029e-03
  3187 KSP Residual norm 9.086673303911e-03
  3188 KSP Residual norm 8.251175181581e-03
  3189 KSP Residual norm 6.911038858331e-03
  3190 KSP Residual norm 6.568919068833e-03
  3191 KSP Residual norm 6.805271037313e-03
  3192 KSP Residual norm 7.204067554180e-03
  3193 KSP Residual norm 8.129184294157e-03
  3194 KSP Residual norm 9.005369610526e-03
  3195 KSP Residual norm 9.442528385542e-03
  3196 KSP Residual norm 9.774101977640e-03
  3197 KSP Residual norm 1.033055682201e-02
  3198 KSP Residual norm 1.043221180782e-02
  3199 KSP Residual norm 1.078135156047e-02
  3200 KSP Residual norm 1.200591990423e-02
  3201 KSP Residual norm 1.305363207925e-02
  3202 KSP Residual norm 1.378489495984e-02
  3203 KSP Residual norm 1.356199718732e-02
  3204 KSP Residual norm 1.269109848995e-02
  3205 KSP Residual norm 1.269489526675e-02
  3206 KSP Residual norm 1.451094867081e-02
  3207 KSP Residual norm 1.567832583739e-02
  3208 KSP Residual norm 1.532058906301e-02
  3209 KSP Residual norm 1.576409641088e-02
  3210 KSP Residual norm 1.643058038446e-02
  3211 KSP Residual norm 1.557642354238e-02
  3212 KSP Residual norm 1.552121527862e-02
  3213 KSP Residual norm 1.628124738715e-02
  3214 KSP Residual norm 1.537868036131e-02
  3215 KSP Residual norm 1.411653453381e-02
  3216 KSP Residual norm 1.438663611149e-02
  3217 KSP Residual norm 1.586387854502e-02
  3218 KSP Residual norm 1.532058834136e-02
  3219 KSP Residual norm 1.381368567635e-02
  3220 KSP Residual norm 1.269730312762e-02
  3221 KSP Residual norm 1.185916433179e-02
  3222 KSP Residual norm 1.137845876087e-02
  3223 KSP Residual norm 1.122832688659e-02
  3224 KSP Residual norm 1.142049772445e-02
  3225 KSP Residual norm 1.150003013665e-02
  3226 KSP Residual norm 1.329890835724e-02
  3227 KSP Residual norm 1.690954609903e-02
  3228 KSP Residual norm 1.907361819568e-02
  3229 KSP Residual norm 1.836512146272e-02
  3230 KSP Residual norm 1.644260808452e-02
  3231 KSP Residual norm 1.429160276489e-02
  3232 KSP Residual norm 1.238839069472e-02
  3233 KSP Residual norm 1.206765651211e-02
  3234 KSP Residual norm 1.162683853596e-02
  3235 KSP Residual norm 1.080653244405e-02
  3236 KSP Residual norm 9.770249579341e-03
  3237 KSP Residual norm 9.143515025012e-03
  3238 KSP Residual norm 8.858832879797e-03
  3239 KSP Residual norm 9.023756798777e-03
  3240 KSP Residual norm 1.001068990928e-02
  3241 KSP Residual norm 1.069471425598e-02
  3242 KSP Residual norm 1.020298319345e-02
  3243 KSP Residual norm 8.865505274785e-03
  3244 KSP Residual norm 7.383176934210e-03
  3245 KSP Residual norm 7.414517430798e-03
  3246 KSP Residual norm 9.001557144410e-03
  3247 KSP Residual norm 1.022769544403e-02
  3248 KSP Residual norm 9.785680285920e-03
  3249 KSP Residual norm 9.142389815218e-03
  3250 KSP Residual norm 8.536210708611e-03
  3251 KSP Residual norm 6.867894613730e-03
  3252 KSP Residual norm 5.895947524297e-03
  3253 KSP Residual norm 5.818159631934e-03
  3254 KSP Residual norm 5.969135701545e-03
  3255 KSP Residual norm 6.268075658928e-03
  3256 KSP Residual norm 7.399276665667e-03
  3257 KSP Residual norm 7.661427943296e-03
  3258 KSP Residual norm 6.453249799503e-03
  3259 KSP Residual norm 5.921344561978e-03
  3260 KSP Residual norm 5.982986714829e-03
  3261 KSP Residual norm 5.199720903837e-03
  3262 KSP Residual norm 4.422412439531e-03
  3263 KSP Residual norm 4.694366066974e-03
  3264 KSP Residual norm 5.853588950046e-03
  3265 KSP Residual norm 6.551662871828e-03
  3266 KSP Residual norm 6.490056762985e-03
  3267 KSP Residual norm 5.951388959900e-03
  3268 KSP Residual norm 4.516412582620e-03
  3269 KSP Residual norm 2.983165029024e-03
  3270 KSP Residual norm 2.039595003348e-03
  3271 KSP Residual norm 1.794976143482e-03
  3272 KSP Residual norm 1.939361591023e-03
  3273 KSP Residual norm 2.531434460060e-03
  3274 KSP Residual norm 3.598802316831e-03
  3275 KSP Residual norm 4.674419793336e-03
  3276 KSP Residual norm 4.842539121028e-03
  3277 KSP Residual norm 3.996983218608e-03
  3278 KSP Residual norm 3.140164118259e-03
  3279 KSP Residual norm 2.515405621939e-03
  3280 KSP Residual norm 2.408966869639e-03
  3281 KSP Residual norm 2.720855275036e-03
  3282 KSP Residual norm 3.355954732026e-03
  3283 KSP Residual norm 4.167591031500e-03
  3284 KSP Residual norm 4.680635771816e-03
  3285 KSP Residual norm 3.889527774632e-03
  3286 KSP Residual norm 2.755805924728e-03
  3287 KSP Residual norm 2.315840756050e-03
  3288 KSP Residual norm 2.308845251531e-03
  3289 KSP Residual norm 2.636645978699e-03
  3290 KSP Residual norm 3.402433647969e-03
  3291 KSP Residual norm 4.251620632374e-03
  3292 KSP Residual norm 3.793730879779e-03
  3293 KSP Residual norm 2.832866760978e-03
  3294 KSP Residual norm 2.180505219503e-03
  3295 KSP Residual norm 1.697614738254e-03
  3296 KSP Residual norm 1.665784154063e-03
  3297 KSP Residual norm 2.161024671321e-03
  3298 KSP Residual norm 3.050830942266e-03
  3299 KSP Residual norm 3.509991938504e-03
  3300 KSP Residual norm 3.542214302572e-03
  3301 KSP Residual norm 3.106173541680e-03
  3302 KSP Residual norm 2.376905396518e-03
  3303 KSP Residual norm 2.173447876136e-03
  3304 KSP Residual norm 2.308632256805e-03
  3305 KSP Residual norm 2.176363396384e-03
  3306 KSP Residual norm 1.813052173020e-03
  3307 KSP Residual norm 1.624029390453e-03
  3308 KSP Residual norm 1.559582321585e-03
  3309 KSP Residual norm 1.519515691497e-03
  3310 KSP Residual norm 1.893851598042e-03
  3311 KSP Residual norm 2.836681978166e-03
  3312 KSP Residual norm 3.660679422597e-03
  3313 KSP Residual norm 3.559310041600e-03
  3314 KSP Residual norm 3.105166606565e-03
  3315 KSP Residual norm 2.343716525519e-03
  3316 KSP Residual norm 1.722636638757e-03
  3317 KSP Residual norm 1.443878171809e-03
  3318 KSP Residual norm 1.516598879532e-03
  3319 KSP Residual norm 1.954914482820e-03
  3320 KSP Residual norm 2.782514594175e-03
  3321 KSP Residual norm 3.700013789797e-03
  3322 KSP Residual norm 3.772175780929e-03
  3323 KSP Residual norm 2.935475918005e-03
  3324 KSP Residual norm 2.083878885861e-03
  3325 KSP Residual norm 1.703560777235e-03
  3326 KSP Residual norm 1.706262679731e-03
  3327 KSP Residual norm 2.224070904846e-03
  3328 KSP Residual norm 3.404123082333e-03
  3329 KSP Residual norm 5.017399865633e-03
  3330 KSP Residual norm 5.328545072862e-03
  3331 KSP Residual norm 4.110554961613e-03
  3332 KSP Residual norm 3.055932463793e-03
  3333 KSP Residual norm 2.434093665887e-03
  3334 KSP Residual norm 2.245025757791e-03
  3335 KSP Residual norm 2.597381919391e-03
  3336 KSP Residual norm 3.608560344999e-03
  3337 KSP Residual norm 5.024544092493e-03
  3338 KSP Residual norm 6.757773177279e-03
  3339 KSP Residual norm 7.236990599686e-03
  3340 KSP Residual norm 5.334018579363e-03
  3341 KSP Residual norm 3.670426817844e-03
  3342 KSP Residual norm 3.458658010460e-03
  3343 KSP Residual norm 4.177897662309e-03
  3344 KSP Residual norm 5.361834008504e-03
  3345 KSP Residual norm 7.448364528135e-03
  3346 KSP Residual norm 1.161156259565e-02
  3347 KSP Residual norm 1.466722425199e-02
  3348 KSP Residual norm 1.223571276010e-02
  3349 KSP Residual norm 8.515548591274e-03
  3350 KSP Residual norm 5.560222541152e-03
  3351 KSP Residual norm 3.737752004715e-03
  3352 KSP Residual norm 3.374691477137e-03
  3353 KSP Residual norm 4.248075403035e-03
  3354 KSP Residual norm 6.454549110546e-03
  3355 KSP Residual norm 9.253753441211e-03
  3356 KSP Residual norm 1.172261739627e-02
  3357 KSP Residual norm 1.293159358061e-02
  3358 KSP Residual norm 1.327533129647e-02
  3359 KSP Residual norm 1.421858697334e-02
  3360 KSP Residual norm 1.588189853110e-02
  3361 KSP Residual norm 1.468433443893e-02
  3362 KSP Residual norm 1.061499850396e-02
  3363 KSP Residual norm 7.238306118037e-03
  3364 KSP Residual norm 5.295484481415e-03
  3365 KSP Residual norm 5.030433624303e-03
  3366 KSP Residual norm 6.448894481015e-03
  3367 KSP Residual norm 1.005121245882e-02
  3368 KSP Residual norm 1.460014037975e-02
  3369 KSP Residual norm 1.624683604566e-02
  3370 KSP Residual norm 1.433959148724e-02
  3371 KSP Residual norm 1.160450343864e-02
  3372 KSP Residual norm 9.605938004674e-03
  3373 KSP Residual norm 8.899127743228e-03
  3374 KSP Residual norm 9.370299718388e-03
  3375 KSP Residual norm 9.380021626241e-03
  3376 KSP Residual norm 8.342611820587e-03
  3377 KSP Residual norm 6.985668548425e-03
  3378 KSP Residual norm 6.327982854763e-03
  3379 KSP Residual norm 6.591958145806e-03
  3380 KSP Residual norm 7.177543030292e-03
  3381 KSP Residual norm 7.853954858680e-03
  3382 KSP Residual norm 8.120645681643e-03
  3383 KSP Residual norm 9.053611504499e-03
  3384 KSP Residual norm 1.136035037033e-02
  3385 KSP Residual norm 1.304283230750e-02
  3386 KSP Residual norm 1.163407764338e-02
  3387 KSP Residual norm 8.409491414743e-03
  3388 KSP Residual norm 6.076571569911e-03
  3389 KSP Residual norm 5.063308200875e-03
  3390 KSP Residual norm 5.248174315404e-03
  3391 KSP Residual norm 6.560021912350e-03
  3392 KSP Residual norm 7.415905842330e-03
  3393 KSP Residual norm 7.258096522426e-03
  3394 KSP Residual norm 7.519030670535e-03
  3395 KSP Residual norm 7.947065118337e-03
  3396 KSP Residual norm 8.439483136767e-03
  3397 KSP Residual norm 9.153467368035e-03
  3398 KSP Residual norm 8.306626157337e-03
  3399 KSP Residual norm 5.999621700177e-03
  3400 KSP Residual norm 4.249803258353e-03
  3401 KSP Residual norm 3.266740729237e-03
  3402 KSP Residual norm 2.962905410642e-03
  3403 KSP Residual norm 3.294654846176e-03
  3404 KSP Residual norm 3.473894366545e-03
  3405 KSP Residual norm 3.310995992788e-03
  3406 KSP Residual norm 3.726455952379e-03
  3407 KSP Residual norm 4.885673388954e-03
  3408 KSP Residual norm 5.546168850270e-03
  3409 KSP Residual norm 5.740402294123e-03
  3410 KSP Residual norm 6.079770275235e-03
  3411 KSP Residual norm 6.014014871281e-03
  3412 KSP Residual norm 6.020096376792e-03
  3413 KSP Residual norm 5.968133126080e-03
  3414 KSP Residual norm 5.059945350920e-03
  3415 KSP Residual norm 3.587378586357e-03
  3416 KSP Residual norm 2.822033047601e-03
  3417 KSP Residual norm 2.513662279448e-03
  3418 KSP Residual norm 2.379184307503e-03
  3419 KSP Residual norm 2.329629264453e-03
  3420 KSP Residual norm 2.204936400537e-03
  3421 KSP Residual norm 2.085485526127e-03
  3422 KSP Residual norm 2.239133298867e-03
  3423 KSP Residual norm 2.781163346688e-03
  3424 KSP Residual norm 3.467984178772e-03
  3425 KSP Residual norm 3.766608644314e-03
  3426 KSP Residual norm 3.542590969970e-03
  3427 KSP Residual norm 3.021545797448e-03
  3428 KSP Residual norm 2.575151560536e-03
  3429 KSP Residual norm 2.360653493124e-03
  3430 KSP Residual norm 2.316791073053e-03
  3431 KSP Residual norm 2.217026763308e-03
  3432 KSP Residual norm 1.992379378075e-03
  3433 KSP Residual norm 1.753332197379e-03
  3434 KSP Residual norm 1.757412270373e-03
  3435 KSP Residual norm 2.202389081792e-03
  3436 KSP Residual norm 2.686035122139e-03
  3437 KSP Residual norm 2.499700048378e-03
  3438 KSP Residual norm 2.244939603433e-03
  3439 KSP Residual norm 2.330553771967e-03
  3440 KSP Residual norm 2.624392189817e-03
  3441 KSP Residual norm 2.623874272572e-03
  3442 KSP Residual norm 2.070401979000e-03
  3443 KSP Residual norm 1.444355694733e-03
  3444 KSP Residual norm 1.094870722720e-03
  3445 KSP Residual norm 9.607246377444e-04
  3446 KSP Residual norm 8.651114234745e-04
  3447 KSP Residual norm 7.499264278678e-04
  3448 KSP Residual norm 6.984004105417e-04
  3449 KSP Residual norm 7.806927786775e-04
  3450 KSP Residual norm 1.030933255808e-03
  3451 KSP Residual norm 1.398237545698e-03
  3452 KSP Residual norm 1.562644637794e-03
  3453 KSP Residual norm 1.511551810266e-03
  3454 KSP Residual norm 1.473179602700e-03
  3455 KSP Residual norm 1.517294639902e-03
  3456 KSP Residual norm 1.480657264659e-03
  3457 KSP Residual norm 1.201818362205e-03
  3458 KSP Residual norm 8.991204921500e-04
  3459 KSP Residual norm 8.256666138973e-04
  3460 KSP Residual norm 8.916031729385e-04
  3461 KSP Residual norm 9.093828933303e-04
  3462 KSP Residual norm 7.921076595761e-04
  3463 KSP Residual norm 6.812389654892e-04
  3464 KSP Residual norm 6.586554280163e-04
  3465 KSP Residual norm 7.291705292598e-04
  3466 KSP Residual norm 8.036112210929e-04
  3467 KSP Residual norm 8.366608045404e-04
  3468 KSP Residual norm 7.963892254702e-04
  3469 KSP Residual norm 7.877505216885e-04
  3470 KSP Residual norm 8.353415436455e-04
  3471 KSP Residual norm 9.277720257402e-04
  3472 KSP Residual norm 1.101942335291e-03
  3473 KSP Residual norm 1.067069499995e-03
  3474 KSP Residual norm 8.006057154162e-04
  3475 KSP Residual norm 6.566476734925e-04
  3476 KSP Residual norm 6.350126093126e-04
  3477 KSP Residual norm 6.742107335825e-04
  3478 KSP Residual norm 6.354443420061e-04
  3479 KSP Residual norm 5.179732380869e-04
  3480 KSP Residual norm 4.121368114192e-04
  3481 KSP Residual norm 3.787878580931e-04
  3482 KSP Residual norm 4.440028813957e-04
  3483 KSP Residual norm 5.114775212055e-04
  3484 KSP Residual norm 4.743065925748e-04
  3485 KSP Residual norm 4.294702343993e-04
  3486 KSP Residual norm 4.657060853571e-04
  3487 KSP Residual norm 5.852635504900e-04
  3488 KSP Residual norm 7.011058864148e-04
  3489 KSP Residual norm 7.195693799062e-04
  3490 KSP Residual norm 6.535302888204e-04
  3491 KSP Residual norm 5.841926553952e-04
  3492 KSP Residual norm 5.497100454829e-04
  3493 KSP Residual norm 5.255295851755e-04
  3494 KSP Residual norm 4.356822844171e-04
  3495 KSP Residual norm 3.685597805375e-04
  3496 KSP Residual norm 3.330568822722e-04
  3497 KSP Residual norm 3.421860146338e-04
  3498 KSP Residual norm 3.690993881108e-04
  3499 KSP Residual norm 3.532750971556e-04
  3500 KSP Residual norm 3.049433515967e-04
  3501 KSP Residual norm 2.931011824341e-04
  3502 KSP Residual norm 3.440663736710e-04
  3503 KSP Residual norm 4.632817903386e-04
  3504 KSP Residual norm 5.561854642997e-04
  3505 KSP Residual norm 5.630559169398e-04
  3506 KSP Residual norm 5.380430164398e-04
  3507 KSP Residual norm 6.104820630153e-04
  3508 KSP Residual norm 8.274878968856e-04
  3509 KSP Residual norm 9.875315649218e-04
  3510 KSP Residual norm 9.092201828164e-04
  3511 KSP Residual norm 7.757570077409e-04
  3512 KSP Residual norm 7.559988057923e-04
  3513 KSP Residual norm 8.803879684377e-04
  3514 KSP Residual norm 9.508967221048e-04
  3515 KSP Residual norm 7.389022793062e-04
  3516 KSP Residual norm 6.193006140846e-04
  3517 KSP Residual norm 6.570425920917e-04
  3518 KSP Residual norm 7.832796504841e-04
  3519 KSP Residual norm 8.532010926067e-04
  3520 KSP Residual norm 8.208984225632e-04
  3521 KSP Residual norm 7.932871011582e-04
  3522 KSP Residual norm 8.798936491137e-04
  3523 KSP Residual norm 1.070383262272e-03
  3524 KSP Residual norm 1.195189003322e-03
  3525 KSP Residual norm 1.205191158875e-03
  3526 KSP Residual norm 1.266488170870e-03
  3527 KSP Residual norm 1.554374548755e-03
  3528 KSP Residual norm 2.023641804266e-03
  3529 KSP Residual norm 2.045493343792e-03
  3530 KSP Residual norm 1.478040580461e-03
  3531 KSP Residual norm 1.075182917332e-03
  3532 KSP Residual norm 9.771798637772e-04
  3533 KSP Residual norm 1.067532871406e-03
  3534 KSP Residual norm 1.030407985674e-03
  3535 KSP Residual norm 8.620271812682e-04
  3536 KSP Residual norm 8.317543992205e-04
  3537 KSP Residual norm 1.015062917753e-03
  3538 KSP Residual norm 1.334676394032e-03
  3539 KSP Residual norm 1.496384546331e-03
  3540 KSP Residual norm 1.441118149914e-03
  3541 KSP Residual norm 1.525326786434e-03
  3542 KSP Residual norm 1.931801313192e-03
  3543 KSP Residual norm 2.280673015354e-03
  3544 KSP Residual norm 2.018253041515e-03
  3545 KSP Residual norm 1.678637829758e-03
  3546 KSP Residual norm 1.639551928886e-03
  3547 KSP Residual norm 1.806076301212e-03
  3548 KSP Residual norm 1.997638456010e-03
  3549 KSP Residual norm 1.877914332868e-03
  3550 KSP Residual norm 1.484076951522e-03
  3551 KSP Residual norm 1.330692024164e-03
  3552 KSP Residual norm 1.437317909713e-03
  3553 KSP Residual norm 1.613975703049e-03
  3554 KSP Residual norm 1.673509057881e-03
  3555 KSP Residual norm 1.613179476473e-03
  3556 KSP Residual norm 1.724258525116e-03
  3557 KSP Residual norm 2.249061196567e-03
  3558 KSP Residual norm 3.032330505208e-03
  3559 KSP Residual norm 3.311623721401e-03
  3560 KSP Residual norm 3.128816736141e-03
  3561 KSP Residual norm 3.171573670495e-03
  3562 KSP Residual norm 3.733094582663e-03
  3563 KSP Residual norm 4.097017261153e-03
  3564 KSP Residual norm 3.513162399956e-03
  3565 KSP Residual norm 2.948428313749e-03
  3566 KSP Residual norm 2.901393034600e-03
  3567 KSP Residual norm 2.984534470525e-03
  3568 KSP Residual norm 2.779805984533e-03
  3569 KSP Residual norm 2.432290259025e-03
  3570 KSP Residual norm 2.389515820843e-03
  3571 KSP Residual norm 2.593743319429e-03
  3572 KSP Residual norm 2.785783894119e-03
  3573 KSP Residual norm 2.501197636017e-03
  3574 KSP Residual norm 2.082103648580e-03
  3575 KSP Residual norm 2.041599248973e-03
  3576 KSP Residual norm 2.399253747622e-03
  3577 KSP Residual norm 2.732195497203e-03
  3578 KSP Residual norm 2.709450757970e-03
  3579 KSP Residual norm 2.626285332542e-03
  3580 KSP Residual norm 3.036264845884e-03
  3581 KSP Residual norm 4.021274289136e-03
  3582 KSP Residual norm 4.881630819856e-03
  3583 KSP Residual norm 4.877683385218e-03
  3584 KSP Residual norm 4.338828882271e-03
  3585 KSP Residual norm 4.245469786156e-03
  3586 KSP Residual norm 4.453349478537e-03
  3587 KSP Residual norm 4.187751638837e-03
  3588 KSP Residual norm 3.784529402750e-03
  3589 KSP Residual norm 3.561587575294e-03
  3590 KSP Residual norm 3.509756733965e-03
  3591 KSP Residual norm 3.549135223631e-03
  3592 KSP Residual norm 3.401174808818e-03
  3593 KSP Residual norm 3.240863107469e-03
  3594 KSP Residual norm 3.520559389878e-03
  3595 KSP Residual norm 4.082694692065e-03
  3596 KSP Residual norm 4.136352599546e-03
  3597 KSP Residual norm 4.166900620936e-03
  3598 KSP Residual norm 5.044139245858e-03
  3599 KSP Residual norm 6.561622484536e-03
  3600 KSP Residual norm 7.307164257339e-03
  3601 KSP Residual norm 7.443863158124e-03
  3602 KSP Residual norm 7.828314430839e-03
  3603 KSP Residual norm 8.166278844055e-03
  3604 KSP Residual norm 7.658887239474e-03
  3605 KSP Residual norm 6.207092964009e-03
  3606 KSP Residual norm 4.678215399264e-03
  3607 KSP Residual norm 4.331164823929e-03
  3608 KSP Residual norm 4.833612569223e-03
  3609 KSP Residual norm 4.850875438914e-03
  3610 KSP Residual norm 4.047203963261e-03
  3611 KSP Residual norm 3.592469971986e-03
  3612 KSP Residual norm 3.532370630108e-03
  3613 KSP Residual norm 3.553192131972e-03
  3614 KSP Residual norm 3.665485709967e-03
  3615 KSP Residual norm 3.676007855053e-03
  3616 KSP Residual norm 3.981008685067e-03
  3617 KSP Residual norm 5.034569569705e-03
  3618 KSP Residual norm 6.117479478495e-03
  3619 KSP Residual norm 6.033465754972e-03
  3620 KSP Residual norm 6.227823513094e-03
  3621 KSP Residual norm 7.423841165264e-03
  3622 KSP Residual norm 8.306450199043e-03
  3623 KSP Residual norm 8.151912053584e-03
  3624 KSP Residual norm 7.754934563164e-03
  3625 KSP Residual norm 6.914354816909e-03
  3626 KSP Residual norm 6.253304568856e-03
  3627 KSP Residual norm 5.509961410378e-03
  3628 KSP Residual norm 4.394914369350e-03
  3629 KSP Residual norm 3.843952478986e-03
  3630 KSP Residual norm 4.149416599223e-03
  3631 KSP Residual norm 4.231999601513e-03
  3632 KSP Residual norm 3.540120774239e-03
  3633 KSP Residual norm 3.313927565109e-03
  3634 KSP Residual norm 3.855125406389e-03
  3635 KSP Residual norm 4.200891466551e-03
  3636 KSP Residual norm 4.150891094791e-03
  3637 KSP Residual norm 3.814103303157e-03
  3638 KSP Residual norm 3.586413132211e-03
  3639 KSP Residual norm 3.863108676532e-03
  3640 KSP Residual norm 4.476251263711e-03
  3641 KSP Residual norm 4.712874915970e-03
  3642 KSP Residual norm 5.332327228744e-03
  3643 KSP Residual norm 6.941879291547e-03
  3644 KSP Residual norm 8.118919341655e-03
  3645 KSP Residual norm 7.298348207224e-03
  3646 KSP Residual norm 5.954375112478e-03
  3647 KSP Residual norm 4.984839833387e-03
  3648 KSP Residual norm 4.384941933256e-03
  3649 KSP Residual norm 4.133886164299e-03
  3650 KSP Residual norm 3.545905667035e-03
  3651 KSP Residual norm 2.994975000936e-03
  3652 KSP Residual norm 2.767849745248e-03
  3653 KSP Residual norm 2.769630219044e-03
  3654 KSP Residual norm 2.439119191702e-03
  3655 KSP Residual norm 2.185834742866e-03
  3656 KSP Residual norm 2.202221778376e-03
  3657 KSP Residual norm 2.271546394093e-03
  3658 KSP Residual norm 2.366900033367e-03
  3659 KSP Residual norm 2.659340650284e-03
  3660 KSP Residual norm 2.704229966839e-03
  3661 KSP Residual norm 2.692655430256e-03
  3662 KSP Residual norm 2.892313527326e-03
  3663 KSP Residual norm 3.288715276748e-03
  3664 KSP Residual norm 3.769148978695e-03
  3665 KSP Residual norm 4.412253772286e-03
  3666 KSP Residual norm 4.761415185989e-03
  3667 KSP Residual norm 4.615132664724e-03
  3668 KSP Residual norm 4.554537747807e-03
  3669 KSP Residual norm 4.331885400047e-03
  3670 KSP Residual norm 3.832073404816e-03
  3671 KSP Residual norm 3.661534364403e-03
  3672 KSP Residual norm 3.689620790663e-03
  3673 KSP Residual norm 3.429423924588e-03
  3674 KSP Residual norm 3.060374069393e-03
  3675 KSP Residual norm 2.864262662252e-03
  3676 KSP Residual norm 2.672317271465e-03
  3677 KSP Residual norm 2.587979518671e-03
  3678 KSP Residual norm 2.568162988685e-03
  3679 KSP Residual norm 2.186044796154e-03
  3680 KSP Residual norm 1.727412388961e-03
  3681 KSP Residual norm 1.682847424785e-03
  3682 KSP Residual norm 1.821662828664e-03
  3683 KSP Residual norm 1.855863327891e-03
  3684 KSP Residual norm 1.818325924442e-03
  3685 KSP Residual norm 1.901158812440e-03
  3686 KSP Residual norm 2.089844447169e-03
  3687 KSP Residual norm 2.602974999488e-03
  3688 KSP Residual norm 3.018596557282e-03
  3689 KSP Residual norm 2.884115491376e-03
  3690 KSP Residual norm 2.961167133682e-03
  3691 KSP Residual norm 3.602270471292e-03
  3692 KSP Residual norm 4.112099294529e-03
  3693 KSP Residual norm 3.931680371933e-03
  3694 KSP Residual norm 3.659312970152e-03
  3695 KSP Residual norm 3.471262559772e-03
  3696 KSP Residual norm 3.131867604394e-03
  3697 KSP Residual norm 2.647193407058e-03
  3698 KSP Residual norm 1.962630853265e-03
  3699 KSP Residual norm 1.438871758597e-03
  3700 KSP Residual norm 1.319042910112e-03
  3701 KSP Residual norm 1.392918112041e-03
  3702 KSP Residual norm 1.316320114879e-03
  3703 KSP Residual norm 1.255495628385e-03
  3704 KSP Residual norm 1.221276120255e-03
  3705 KSP Residual norm 1.199294005221e-03
  3706 KSP Residual norm 1.265677446081e-03
  3707 KSP Residual norm 1.376997309064e-03
  3708 KSP Residual norm 1.365480084884e-03
  3709 KSP Residual norm 1.278357561762e-03
  3710 KSP Residual norm 1.307647305705e-03
  3711 KSP Residual norm 1.271105239642e-03
  3712 KSP Residual norm 1.121904585817e-03
  3713 KSP Residual norm 1.105572981791e-03
  3714 KSP Residual norm 1.150658368807e-03
  3715 KSP Residual norm 1.133291576619e-03
  3716 KSP Residual norm 1.133521042662e-03
  3717 KSP Residual norm 1.172699492001e-03
  3718 KSP Residual norm 1.227452311584e-03
  3719 KSP Residual norm 1.375807043239e-03
  3720 KSP Residual norm 1.519214167410e-03
  3721 KSP Residual norm 1.496648336825e-03
  3722 KSP Residual norm 1.479128754948e-03
  3723 KSP Residual norm 1.386605556850e-03
  3724 KSP Residual norm 1.123984411991e-03
  3725 KSP Residual norm 1.019650926164e-03
  3726 KSP Residual norm 1.062686708325e-03
  3727 KSP Residual norm 9.688928695139e-04
  3728 KSP Residual norm 7.979894915360e-04
  3729 KSP Residual norm 7.999058710281e-04
  3730 KSP Residual norm 9.139786750030e-04
  3731 KSP Residual norm 1.040568590637e-03
  3732 KSP Residual norm 1.128567347413e-03
  3733 KSP Residual norm 1.204887771337e-03
  3734 KSP Residual norm 1.300372691905e-03
  3735 KSP Residual norm 1.508734119908e-03
  3736 KSP Residual norm 1.729315134442e-03
  3737 KSP Residual norm 1.846671078686e-03
  3738 KSP Residual norm 2.160761751184e-03
  3739 KSP Residual norm 2.430394745094e-03
  3740 KSP Residual norm 2.271433580421e-03
  3741 KSP Residual norm 1.895654453543e-03
  3742 KSP Residual norm 1.694876639236e-03
  3743 KSP Residual norm 1.664785611067e-03
  3744 KSP Residual norm 1.845714329804e-03
  3745 KSP Residual norm 1.928638202536e-03
  3746 KSP Residual norm 1.714802331203e-03
  3747 KSP Residual norm 1.625047760745e-03
  3748 KSP Residual norm 1.713473645431e-03
  3749 KSP Residual norm 1.829653885607e-03
  3750 KSP Residual norm 1.672760741911e-03
  3751 KSP Residual norm 1.474465283155e-03
  3752 KSP Residual norm 1.425192074654e-03
  3753 KSP Residual norm 1.467973336645e-03
  3754 KSP Residual norm 1.473926936692e-03
  3755 KSP Residual norm 1.350396371662e-03
  3756 KSP Residual norm 1.304074505142e-03
  3757 KSP Residual norm 1.494142474303e-03
  3758 KSP Residual norm 1.673990463401e-03
  3759 KSP Residual norm 1.722978244809e-03
  3760 KSP Residual norm 1.883893105765e-03
  3761 KSP Residual norm 2.252772410373e-03
  3762 KSP Residual norm 2.457645832058e-03
  3763 KSP Residual norm 2.591371644087e-03
  3764 KSP Residual norm 3.014127607147e-03
  3765 KSP Residual norm 3.658591732078e-03
  3766 KSP Residual norm 3.966524686175e-03
  3767 KSP Residual norm 3.862014072163e-03
  3768 KSP Residual norm 3.777509564235e-03
  3769 KSP Residual norm 4.056011536640e-03
  3770 KSP Residual norm 4.548859906303e-03
  3771 KSP Residual norm 4.544581773738e-03
  3772 KSP Residual norm 4.091599538555e-03
  3773 KSP Residual norm 4.306313663683e-03
  3774 KSP Residual norm 4.351657747698e-03
  3775 KSP Residual norm 3.824055216587e-03
  3776 KSP Residual norm 3.505714847880e-03
  3777 KSP Residual norm 3.537716266683e-03
  3778 KSP Residual norm 3.317663861356e-03
  3779 KSP Residual norm 2.850104340265e-03
  3780 KSP Residual norm 2.553317624037e-03
  3781 KSP Residual norm 2.325589585195e-03
  3782 KSP Residual norm 2.140112890449e-03
  3783 KSP Residual norm 2.184446675867e-03
  3784 KSP Residual norm 2.275638442386e-03
  3785 KSP Residual norm 2.437849826740e-03
  3786 KSP Residual norm 2.868317331370e-03
  3787 KSP Residual norm 3.312619326922e-03
  3788 KSP Residual norm 3.410376571653e-03
  3789 KSP Residual norm 3.786321830045e-03
  3790 KSP Residual norm 4.508358257941e-03
  3791 KSP Residual norm 4.892462517884e-03
  3792 KSP Residual norm 5.553242085047e-03
  3793 KSP Residual norm 6.601775799811e-03
  3794 KSP Residual norm 7.053367506202e-03
  3795 KSP Residual norm 7.333486350305e-03
  3796 KSP Residual norm 7.649033463018e-03
  3797 KSP Residual norm 7.876043153176e-03
  3798 KSP Residual norm 8.189345098556e-03
  3799 KSP Residual norm 8.555044954388e-03
  3800 KSP Residual norm 8.014667913915e-03
  3801 KSP Residual norm 7.248413672911e-03
  3802 KSP Residual norm 7.287397118484e-03
  3803 KSP Residual norm 7.637040534018e-03
  3804 KSP Residual norm 6.897714931498e-03
  3805 KSP Residual norm 5.944469575451e-03
  3806 KSP Residual norm 5.528459318034e-03
  3807 KSP Residual norm 5.120640390509e-03
  3808 KSP Residual norm 5.004626284979e-03
  3809 KSP Residual norm 4.807067376378e-03
  3810 KSP Residual norm 4.145125430127e-03
  3811 KSP Residual norm 4.048204614586e-03
  3812 KSP Residual norm 4.404451642166e-03
  3813 KSP Residual norm 4.421239620152e-03
  3814 KSP Residual norm 4.235949899498e-03
  3815 KSP Residual norm 4.318141981494e-03
  3816 KSP Residual norm 4.354335812443e-03
  3817 KSP Residual norm 4.546322496775e-03
  3818 KSP Residual norm 5.031750667498e-03
  3819 KSP Residual norm 5.678117818594e-03
  3820 KSP Residual norm 6.142015034997e-03
  3821 KSP Residual norm 6.888812809295e-03
  3822 KSP Residual norm 7.390367234017e-03
  3823 KSP Residual norm 7.242315061307e-03
  3824 KSP Residual norm 7.198365334206e-03
  3825 KSP Residual norm 7.905688770395e-03
  3826 KSP Residual norm 8.467086227498e-03
  3827 KSP Residual norm 8.994802372687e-03
  3828 KSP Residual norm 9.159103811113e-03
  3829 KSP Residual norm 9.321363538906e-03
  3830 KSP Residual norm 9.340719550397e-03
  3831 KSP Residual norm 8.794202141717e-03
  3832 KSP Residual norm 7.320236022828e-03
  3833 KSP Residual norm 6.202776925164e-03
  3834 KSP Residual norm 6.002133205176e-03
  3835 KSP Residual norm 5.774001141672e-03
  3836 KSP Residual norm 5.522115330165e-03
  3837 KSP Residual norm 5.750920916907e-03
  3838 KSP Residual norm 5.784424597201e-03
  3839 KSP Residual norm 5.504244278726e-03
  3840 KSP Residual norm 5.786508402931e-03
  3841 KSP Residual norm 6.258709456382e-03
  3842 KSP Residual norm 6.184804909771e-03
  3843 KSP Residual norm 6.356004268985e-03
  3844 KSP Residual norm 6.602123566606e-03
  3845 KSP Residual norm 6.629844664195e-03
  3846 KSP Residual norm 6.591228941087e-03
  3847 KSP Residual norm 6.622254373335e-03
  3848 KSP Residual norm 7.022275135718e-03
  3849 KSP Residual norm 7.837290866996e-03
  3850 KSP Residual norm 8.123428859581e-03
  3851 KSP Residual norm 7.749126144592e-03
  3852 KSP Residual norm 8.163895683028e-03
  3853 KSP Residual norm 9.515605767568e-03
  3854 KSP Residual norm 1.001839354636e-02
  3855 KSP Residual norm 9.104095295020e-03
  3856 KSP Residual norm 8.774792035458e-03
  3857 KSP Residual norm 9.217738089275e-03
  3858 KSP Residual norm 1.018684571783e-02
  3859 KSP Residual norm 9.748869663756e-03
  3860 KSP Residual norm 7.794010844671e-03
  3861 KSP Residual norm 6.623638961256e-03
  3862 KSP Residual norm 6.355345934030e-03
  3863 KSP Residual norm 5.763380439604e-03
  3864 KSP Residual norm 4.581589857017e-03
  3865 KSP Residual norm 4.204658458253e-03
  3866 KSP Residual norm 4.358757553644e-03
  3867 KSP Residual norm 4.372774461814e-03
  3868 KSP Residual norm 4.075135303573e-03
  3869 KSP Residual norm 3.988355680697e-03
  3870 KSP Residual norm 4.074966854814e-03
  3871 KSP Residual norm 4.428383285782e-03
  3872 KSP Residual norm 4.992694123191e-03
  3873 KSP Residual norm 5.345483223032e-03
  3874 KSP Residual norm 5.907896699672e-03
  3875 KSP Residual norm 6.791550695225e-03
  3876 KSP Residual norm 7.453043324368e-03
  3877 KSP Residual norm 7.316237666160e-03
  3878 KSP Residual norm 7.638203490970e-03
  3879 KSP Residual norm 8.189926544721e-03
  3880 KSP Residual norm 8.172873192297e-03
  3881 KSP Residual norm 8.202362329638e-03
  3882 KSP Residual norm 7.875925066871e-03
  3883 KSP Residual norm 7.302825340613e-03
  3884 KSP Residual norm 6.769260297802e-03
  3885 KSP Residual norm 5.824290141855e-03
  3886 KSP Residual norm 4.628515099291e-03
  3887 KSP Residual norm 4.344626413698e-03
  3888 KSP Residual norm 4.438663569125e-03
  3889 KSP Residual norm 3.802257686884e-03
  3890 KSP Residual norm 3.095255544821e-03
  3891 KSP Residual norm 2.848210691569e-03
  3892 KSP Residual norm 2.657250095577e-03
  3893 KSP Residual norm 2.276320456704e-03
  3894 KSP Residual norm 2.037450393309e-03
  3895 KSP Residual norm 1.915467200636e-03
  3896 KSP Residual norm 1.719587131875e-03
  3897 KSP Residual norm 1.524609344566e-03
  3898 KSP Residual norm 1.290825461981e-03
  3899 KSP Residual norm 1.168883320575e-03
  3900 KSP Residual norm 1.283331231701e-03
  3901 KSP Residual norm 1.436126987057e-03
  3902 KSP Residual norm 1.361955006227e-03
  3903 KSP Residual norm 1.338175783573e-03
  3904 KSP Residual norm 1.570638634894e-03
  3905 KSP Residual norm 1.713508983336e-03
  3906 KSP Residual norm 1.677892560676e-03
  3907 KSP Residual norm 1.813736764789e-03
  3908 KSP Residual norm 2.242120276841e-03
  3909 KSP Residual norm 2.698144730117e-03
  3910 KSP Residual norm 2.943518756740e-03
  3911 KSP Residual norm 2.811756037698e-03
  3912 KSP Residual norm 2.699136252558e-03
  3913 KSP Residual norm 2.913649753289e-03
  3914 KSP Residual norm 2.953715188845e-03
  3915 KSP Residual norm 2.652624157403e-03
  3916 KSP Residual norm 2.673256732648e-03
  3917 KSP Residual norm 2.724974376132e-03
  3918 KSP Residual norm 2.333190412935e-03
  3919 KSP Residual norm 1.956168059339e-03
  3920 KSP Residual norm 1.871657576280e-03
  3921 KSP Residual norm 1.899763659179e-03
  3922 KSP Residual norm 1.997132487780e-03
  3923 KSP Residual norm 2.058263607911e-03
  3924 KSP Residual norm 1.903797645321e-03
  3925 KSP Residual norm 1.710810284625e-03
  3926 KSP Residual norm 1.557951987260e-03
  3927 KSP Residual norm 1.380954604580e-03
  3928 KSP Residual norm 1.273116266406e-03
  3929 KSP Residual norm 1.281841353544e-03
  3930 KSP Residual norm 1.277594278924e-03
  3931 KSP Residual norm 1.277687865662e-03
  3932 KSP Residual norm 1.353717396913e-03
  3933 KSP Residual norm 1.402807119549e-03
  3934 KSP Residual norm 1.422277591573e-03
  3935 KSP Residual norm 1.625924173011e-03
  3936 KSP Residual norm 1.975493126500e-03
  3937 KSP Residual norm 2.196794890192e-03
  3938 KSP Residual norm 2.341207215937e-03
  3939 KSP Residual norm 2.430487228105e-03
  3940 KSP Residual norm 2.495149065372e-03
  3941 KSP Residual norm 2.778120305213e-03
  3942 KSP Residual norm 3.124408930176e-03
  3943 KSP Residual norm 3.190882529742e-03
  3944 KSP Residual norm 3.373692722048e-03
  3945 KSP Residual norm 3.709821475184e-03
  3946 KSP Residual norm 3.491173160141e-03
  3947 KSP Residual norm 3.063171306949e-03
  3948 KSP Residual norm 2.800498250288e-03
  3949 KSP Residual norm 2.768468359212e-03
  3950 KSP Residual norm 2.789753714034e-03
  3951 KSP Residual norm 2.738210884861e-03
  3952 KSP Residual norm 2.465213574489e-03
  3953 KSP Residual norm 2.265157643342e-03
  3954 KSP Residual norm 2.358747748701e-03
  3955 KSP Residual norm 2.411573013505e-03
  3956 KSP Residual norm 2.089312592337e-03
  3957 KSP Residual norm 1.933501287631e-03
  3958 KSP Residual norm 2.108368215422e-03
  3959 KSP Residual norm 2.219814652133e-03
  3960 KSP Residual norm 2.110738251193e-03
  3961 KSP Residual norm 2.234926751875e-03
  3962 KSP Residual norm 2.593577306467e-03
  3963 KSP Residual norm 2.983545200723e-03
  3964 KSP Residual norm 3.078357910477e-03
  3965 KSP Residual norm 2.966701504541e-03
  3966 KSP Residual norm 3.149638391658e-03
  3967 KSP Residual norm 3.445184167452e-03
  3968 KSP Residual norm 3.453035160513e-03
  3969 KSP Residual norm 3.502134926831e-03
  3970 KSP Residual norm 4.085379176779e-03
  3971 KSP Residual norm 4.590664868093e-03
  3972 KSP Residual norm 4.469800844813e-03
  3973 KSP Residual norm 4.237203899081e-03
  3974 KSP Residual norm 4.128879619177e-03
  3975 KSP Residual norm 4.125836613557e-03
  3976 KSP Residual norm 4.214714507964e-03
  3977 KSP Residual norm 4.105466834480e-03
  3978 KSP Residual norm 3.934598316084e-03
  3979 KSP Residual norm 3.912392761648e-03
  3980 KSP Residual norm 3.798478103772e-03
  3981 KSP Residual norm 3.562448082973e-03
  3982 KSP Residual norm 3.545680883614e-03
  3983 KSP Residual norm 3.645794420826e-03
  3984 KSP Residual norm 3.592630361608e-03
  3985 KSP Residual norm 3.553548998729e-03
  3986 KSP Residual norm 3.700141927027e-03
  3987 KSP Residual norm 3.567627859690e-03
  3988 KSP Residual norm 3.390844827108e-03
  3989 KSP Residual norm 3.281308568522e-03
  3990 KSP Residual norm 2.991696242542e-03
  3991 KSP Residual norm 2.792869991820e-03
  3992 KSP Residual norm 3.010884760411e-03
  3993 KSP Residual norm 3.227496452664e-03
  3994 KSP Residual norm 3.412383234711e-03
  3995 KSP Residual norm 3.795193937763e-03
  3996 KSP Residual norm 4.149179729550e-03
  3997 KSP Residual norm 4.539427431375e-03
  3998 KSP Residual norm 5.416436361368e-03
  3999 KSP Residual norm 6.300588368756e-03
  4000 KSP Residual norm 6.167787442207e-03
  4001 KSP Residual norm 6.292404625557e-03
  4002 KSP Residual norm 7.008852289372e-03
  4003 KSP Residual norm 7.565498299997e-03
  4004 KSP Residual norm 8.120854469308e-03
  4005 KSP Residual norm 8.713611599056e-03
  4006 KSP Residual norm 9.677399641609e-03
  4007 KSP Residual norm 1.054689757176e-02
  4008 KSP Residual norm 1.087582928849e-02
  4009 KSP Residual norm 1.007451883091e-02
  4010 KSP Residual norm 1.005418117457e-02
  4011 KSP Residual norm 1.124097769836e-02
  4012 KSP Residual norm 1.148649707407e-02
  4013 KSP Residual norm 9.941201966828e-03
  4014 KSP Residual norm 8.901971081700e-03
  4015 KSP Residual norm 8.696142532189e-03
  4016 KSP Residual norm 8.404181169403e-03
  4017 KSP Residual norm 7.741560127934e-03
  4018 KSP Residual norm 6.870162833530e-03
  4019 KSP Residual norm 6.409642477895e-03
  4020 KSP Residual norm 6.069328086156e-03
  4021 KSP Residual norm 5.776827413134e-03
  4022 KSP Residual norm 5.670138057287e-03
  4023 KSP Residual norm 6.239748496973e-03
  4024 KSP Residual norm 6.364078567745e-03
  4025 KSP Residual norm 5.480279527492e-03
  4026 KSP Residual norm 5.420611891364e-03
  4027 KSP Residual norm 6.693178523687e-03
  4028 KSP Residual norm 7.573505928781e-03
  4029 KSP Residual norm 7.355062725531e-03
  4030 KSP Residual norm 7.865815366378e-03
  4031 KSP Residual norm 8.913608852850e-03
  4032 KSP Residual norm 9.353830422719e-03
  4033 KSP Residual norm 9.445000231771e-03
  4034 KSP Residual norm 9.764659241521e-03
  4035 KSP Residual norm 1.100159122518e-02
  4036 KSP Residual norm 1.285288256792e-02
  4037 KSP Residual norm 1.335029056582e-02
  4038 KSP Residual norm 1.294587675911e-02
  4039 KSP Residual norm 1.422094898257e-02
  4040 KSP Residual norm 1.628215393699e-02
  4041 KSP Residual norm 1.696945076695e-02
  4042 KSP Residual norm 1.694930718735e-02
  4043 KSP Residual norm 1.843978945611e-02
  4044 KSP Residual norm 2.052299648808e-02
  4045 KSP Residual norm 2.211748841535e-02
  4046 KSP Residual norm 2.321705907275e-02
  4047 KSP Residual norm 2.341689257375e-02
  4048 KSP Residual norm 2.416178335527e-02
  4049 KSP Residual norm 2.599295943495e-02
  4050 KSP Residual norm 2.514273558437e-02
  4051 KSP Residual norm 2.373749571765e-02
  4052 KSP Residual norm 2.496239301966e-02
  4053 KSP Residual norm 2.384572486980e-02
  4054 KSP Residual norm 2.189786972011e-02
  4055 KSP Residual norm 2.172818225751e-02
  4056 KSP Residual norm 2.205485921263e-02
  4057 KSP Residual norm 2.086284956444e-02
  4058 KSP Residual norm 1.978949412410e-02
  4059 KSP Residual norm 1.903694302453e-02
  4060 KSP Residual norm 1.756156298591e-02
  4061 KSP Residual norm 1.650577386275e-02
  4062 KSP Residual norm 1.612937501544e-02
  4063 KSP Residual norm 1.558395950881e-02
  4064 KSP Residual norm 1.577750699603e-02
  4065 KSP Residual norm 1.655934045560e-02
  4066 KSP Residual norm 1.473611853106e-02
  4067 KSP Residual norm 1.377019185090e-02
  4068 KSP Residual norm 1.564529179969e-02
  4069 KSP Residual norm 1.774505414733e-02
  4070 KSP Residual norm 1.868732589035e-02
  4071 KSP Residual norm 1.991885818140e-02
  4072 KSP Residual norm 2.012862143662e-02
  4073 KSP Residual norm 1.988132788479e-02
  4074 KSP Residual norm 2.115103418971e-02
  4075 KSP Residual norm 2.358979444836e-02
  4076 KSP Residual norm 2.611719633359e-02
  4077 KSP Residual norm 3.035047492284e-02
  4078 KSP Residual norm 3.352971782032e-02
  4079 KSP Residual norm 3.578598417072e-02
  4080 KSP Residual norm 4.263841989420e-02
  4081 KSP Residual norm 5.165886197902e-02
  4082 KSP Residual norm 5.486201128347e-02
  4083 KSP Residual norm 5.049910298019e-02
  4084 KSP Residual norm 4.605553120815e-02
  4085 KSP Residual norm 4.490494642830e-02
  4086 KSP Residual norm 4.829641408881e-02
  4087 KSP Residual norm 5.501933354121e-02
  4088 KSP Residual norm 5.762181496335e-02
  4089 KSP Residual norm 6.184507763720e-02
  4090 KSP Residual norm 6.799001535709e-02
  4091 KSP Residual norm 6.699676586533e-02
  4092 KSP Residual norm 6.137143947571e-02
  4093 KSP Residual norm 6.145208768691e-02
  4094 KSP Residual norm 6.447849143416e-02
  4095 KSP Residual norm 6.677785223841e-02
  4096 KSP Residual norm 6.994893194717e-02
  4097 KSP Residual norm 7.259122470004e-02
  4098 KSP Residual norm 6.628765269480e-02
  4099 KSP Residual norm 5.769623044857e-02
  4100 KSP Residual norm 4.954700349837e-02
  4101 KSP Residual norm 4.471952485641e-02
  4102 KSP Residual norm 4.250378170916e-02
  4103 KSP Residual norm 4.024537134283e-02
  4104 KSP Residual norm 3.712590771737e-02
  4105 KSP Residual norm 3.736567911800e-02
  4106 KSP Residual norm 3.892325200756e-02
  4107 KSP Residual norm 3.618833648615e-02
  4108 KSP Residual norm 3.274608263635e-02
  4109 KSP Residual norm 3.302857805750e-02
  4110 KSP Residual norm 3.368772472420e-02
  4111 KSP Residual norm 3.084212384729e-02
  4112 KSP Residual norm 2.668617404434e-02
  4113 KSP Residual norm 2.604814110785e-02
  4114 KSP Residual norm 2.984441792959e-02
  4115 KSP Residual norm 3.794117643623e-02
  4116 KSP Residual norm 4.452640277485e-02
  4117 KSP Residual norm 4.683760157063e-02
  4118 KSP Residual norm 4.627721780100e-02
  4119 KSP Residual norm 4.750187095074e-02
  4120 KSP Residual norm 5.246150669565e-02
  4121 KSP Residual norm 6.162377530446e-02
  4122 KSP Residual norm 6.940348416890e-02
  4123 KSP Residual norm 6.691640581601e-02
  4124 KSP Residual norm 6.090565988371e-02
  4125 KSP Residual norm 5.826128057062e-02
  4126 KSP Residual norm 5.637134138895e-02
  4127 KSP Residual norm 5.479174409528e-02
  4128 KSP Residual norm 5.077100516913e-02
  4129 KSP Residual norm 4.710560934884e-02
  4130 KSP Residual norm 4.689111810416e-02
  4131 KSP Residual norm 4.582858436072e-02
  4132 KSP Residual norm 4.018768421611e-02
  4133 KSP Residual norm 3.983785178650e-02
  4134 KSP Residual norm 3.979030025495e-02
  4135 KSP Residual norm 3.514106000032e-02
  4136 KSP Residual norm 3.181214922977e-02
  4137 KSP Residual norm 3.383059959436e-02
  4138 KSP Residual norm 3.435143887120e-02
  4139 KSP Residual norm 3.201574560649e-02
  4140 KSP Residual norm 3.025203926137e-02
  4141 KSP Residual norm 2.955297935694e-02
  4142 KSP Residual norm 3.005511786720e-02
  4143 KSP Residual norm 3.134659999092e-02
  4144 KSP Residual norm 3.152611526486e-02
  4145 KSP Residual norm 3.378896641577e-02
  4146 KSP Residual norm 3.767631864871e-02
  4147 KSP Residual norm 3.872142644142e-02
  4148 KSP Residual norm 3.788041737293e-02
  4149 KSP Residual norm 4.003507550931e-02
  4150 KSP Residual norm 4.352619292239e-02
  4151 KSP Residual norm 4.722291075145e-02
  4152 KSP Residual norm 5.312430242758e-02
  4153 KSP Residual norm 6.384037240444e-02
  4154 KSP Residual norm 6.976262480136e-02
  4155 KSP Residual norm 6.727404192307e-02
  4156 KSP Residual norm 6.278491467126e-02
  4157 KSP Residual norm 5.903721072657e-02
  4158 KSP Residual norm 5.770156694826e-02
  4159 KSP Residual norm 5.719171927231e-02
  4160 KSP Residual norm 5.405639928914e-02
  4161 KSP Residual norm 5.104723515948e-02
  4162 KSP Residual norm 5.246997457170e-02
  4163 KSP Residual norm 5.085264261434e-02
  4164 KSP Residual norm 4.639547771841e-02
  4165 KSP Residual norm 4.424276902582e-02
  4166 KSP Residual norm 3.894890310919e-02
  4167 KSP Residual norm 3.188992989941e-02
  4168 KSP Residual norm 2.891759071865e-02
  4169 KSP Residual norm 2.911735950990e-02
  4170 KSP Residual norm 2.737932630824e-02
  4171 KSP Residual norm 2.513876186543e-02
  4172 KSP Residual norm 2.334986682740e-02
  4173 KSP Residual norm 2.168115377523e-02
  4174 KSP Residual norm 2.196663323481e-02
  4175 KSP Residual norm 2.301565649075e-02
  4176 KSP Residual norm 2.151719060006e-02
  4177 KSP Residual norm 2.006323971901e-02
  4178 KSP Residual norm 2.055958248099e-02
  4179 KSP Residual norm 2.085541329820e-02
  4180 KSP Residual norm 1.971004760518e-02
  4181 KSP Residual norm 1.928401803922e-02
  4182 KSP Residual norm 1.961270292296e-02
  4183 KSP Residual norm 2.032814605531e-02
  4184 KSP Residual norm 2.084056987718e-02
  4185 KSP Residual norm 1.921762997018e-02
  4186 KSP Residual norm 1.847233155789e-02
  4187 KSP Residual norm 2.049672581148e-02
  4188 KSP Residual norm 2.389381826180e-02
  4189 KSP Residual norm 2.589106108971e-02
  4190 KSP Residual norm 2.829041676912e-02
  4191 KSP Residual norm 3.107395419930e-02
  4192 KSP Residual norm 3.313222908529e-02
  4193 KSP Residual norm 3.574395005143e-02
  4194 KSP Residual norm 3.763611194066e-02
  4195 KSP Residual norm 3.783113059850e-02
  4196 KSP Residual norm 3.810303732131e-02
  4197 KSP Residual norm 3.910627755148e-02
  4198 KSP Residual norm 4.087449554290e-02
  4199 KSP Residual norm 4.133407095921e-02
  4200 KSP Residual norm 3.912211956128e-02
  4201 KSP Residual norm 3.584684092597e-02
  4202 KSP Residual norm 3.410416417466e-02
  4203 KSP Residual norm 3.089408696511e-02
  4204 KSP Residual norm 2.721438390337e-02
  4205 KSP Residual norm 2.542328046610e-02
  4206 KSP Residual norm 2.534751439496e-02
  4207 KSP Residual norm 2.201163504458e-02
  4208 KSP Residual norm 1.897173081031e-02
  4209 KSP Residual norm 1.778612566789e-02
  4210 KSP Residual norm 1.658467259507e-02
  4211 KSP Residual norm 1.463353687131e-02
  4212 KSP Residual norm 1.372266039403e-02
  4213 KSP Residual norm 1.386600833626e-02
  4214 KSP Residual norm 1.413474215759e-02
  4215 KSP Residual norm 1.364982865091e-02
  4216 KSP Residual norm 1.220735256835e-02
  4217 KSP Residual norm 1.056331911208e-02
  4218 KSP Residual norm 1.088532116905e-02
  4219 KSP Residual norm 1.122182851744e-02
  4220 KSP Residual norm 1.024576915002e-02
  4221 KSP Residual norm 9.685094919381e-03
  4222 KSP Residual norm 1.020841898353e-02
  4223 KSP Residual norm 1.026862157750e-02
  4224 KSP Residual norm 9.442588629808e-03
  4225 KSP Residual norm 8.810335436026e-03
  4226 KSP Residual norm 8.722293627830e-03
  4227 KSP Residual norm 9.293531504949e-03
  4228 KSP Residual norm 9.822152110870e-03
  4229 KSP Residual norm 9.889328955851e-03
  4230 KSP Residual norm 1.070451223944e-02
  4231 KSP Residual norm 1.238185370013e-02
  4232 KSP Residual norm 1.378262595931e-02
  4233 KSP Residual norm 1.535885577032e-02
  4234 KSP Residual norm 1.790240334794e-02
  4235 KSP Residual norm 1.878800842548e-02
  4236 KSP Residual norm 1.710013687941e-02
  4237 KSP Residual norm 1.594068750413e-02
  4238 KSP Residual norm 1.655386570933e-02
  4239 KSP Residual norm 1.749197146271e-02
  4240 KSP Residual norm 1.952041724866e-02
  4241 KSP Residual norm 2.144960774538e-02
  4242 KSP Residual norm 2.157263928537e-02
  4243 KSP Residual norm 2.121099531783e-02
  4244 KSP Residual norm 2.009938524786e-02
  4245 KSP Residual norm 1.813194249856e-02
  4246 KSP Residual norm 1.801936846260e-02
  4247 KSP Residual norm 1.971323604789e-02
  4248 KSP Residual norm 1.983009954623e-02
  4249 KSP Residual norm 1.892251611939e-02
  4250 KSP Residual norm 1.889829507085e-02
  4251 KSP Residual norm 1.867747261733e-02
  4252 KSP Residual norm 1.792211688059e-02
  4253 KSP Residual norm 1.674841349386e-02
  4254 KSP Residual norm 1.585124779596e-02
  4255 KSP Residual norm 1.599284123319e-02
  4256 KSP Residual norm 1.576600388785e-02
  4257 KSP Residual norm 1.491558449498e-02
  4258 KSP Residual norm 1.443848922019e-02
  4259 KSP Residual norm 1.393131558042e-02
  4260 KSP Residual norm 1.243906245472e-02
  4261 KSP Residual norm 1.001290372198e-02
  4262 KSP Residual norm 8.511398912990e-03
  4263 KSP Residual norm 8.066213770473e-03
  4264 KSP Residual norm 8.227340391243e-03
  4265 KSP Residual norm 8.500394900963e-03
  4266 KSP Residual norm 9.014187567342e-03
  4267 KSP Residual norm 9.462171200366e-03
  4268 KSP Residual norm 9.889216057286e-03
  4269 KSP Residual norm 8.953715920124e-03
  4270 KSP Residual norm 7.793467920104e-03
  4271 KSP Residual norm 7.605625436814e-03
  4272 KSP Residual norm 8.237896802035e-03
  4273 KSP Residual norm 8.962565770242e-03
  4274 KSP Residual norm 9.700766071067e-03
  4275 KSP Residual norm 1.057777171600e-02
  4276 KSP Residual norm 1.163363620762e-02
  4277 KSP Residual norm 1.208131610918e-02
  4278 KSP Residual norm 1.201757014741e-02
  4279 KSP Residual norm 1.250389070910e-02
  4280 KSP Residual norm 1.272933054374e-02
  4281 KSP Residual norm 1.216689327075e-02
  4282 KSP Residual norm 1.193828250704e-02
  4283 KSP Residual norm 1.246689184820e-02
  4284 KSP Residual norm 1.312474726255e-02
  4285 KSP Residual norm 1.263541419629e-02
  4286 KSP Residual norm 1.172921671573e-02
  4287 KSP Residual norm 1.248007088743e-02
  4288 KSP Residual norm 1.407592826539e-02
  4289 KSP Residual norm 1.413448717270e-02
  4290 KSP Residual norm 1.357751255638e-02
  4291 KSP Residual norm 1.452968722840e-02
  4292 KSP Residual norm 1.584177590728e-02
  4293 KSP Residual norm 1.465715531433e-02
  4294 KSP Residual norm 1.333612525778e-02
  4295 KSP Residual norm 1.384375993868e-02
  4296 KSP Residual norm 1.386915622517e-02
  4297 KSP Residual norm 1.261838066562e-02
  4298 KSP Residual norm 1.175311334406e-02
  4299 KSP Residual norm 1.215236500646e-02
  4300 KSP Residual norm 1.255994524421e-02
  4301 KSP Residual norm 1.124460072384e-02
  4302 KSP Residual norm 9.343985657655e-03
  4303 KSP Residual norm 8.335202935980e-03
  4304 KSP Residual norm 8.285002658333e-03
  4305 KSP Residual norm 8.067162735187e-03
  4306 KSP Residual norm 7.348408965037e-03
  4307 KSP Residual norm 7.251382815039e-03
  4308 KSP Residual norm 7.724153703956e-03
  4309 KSP Residual norm 8.165541009594e-03
  4310 KSP Residual norm 8.161988205972e-03
  4311 KSP Residual norm 8.837952909069e-03
  4312 KSP Residual norm 9.636726196004e-03
  4313 KSP Residual norm 1.063023191083e-02
  4314 KSP Residual norm 1.091507928602e-02
  4315 KSP Residual norm 1.148995199751e-02
  4316 KSP Residual norm 1.256403293086e-02
  4317 KSP Residual norm 1.295631262711e-02
  4318 KSP Residual norm 1.236584792169e-02
  4319 KSP Residual norm 1.206236777988e-02
  4320 KSP Residual norm 1.263655891020e-02
  4321 KSP Residual norm 1.304027979574e-02
  4322 KSP Residual norm 1.334171959374e-02
  4323 KSP Residual norm 1.373594325953e-02
  4324 KSP Residual norm 1.329683296616e-02
  4325 KSP Residual norm 1.372400313264e-02
  4326 KSP Residual norm 1.516615141962e-02
  4327 KSP Residual norm 1.673829022112e-02
  4328 KSP Residual norm 1.889700559647e-02
  4329 KSP Residual norm 2.206670894884e-02
  4330 KSP Residual norm 2.430567542455e-02
  4331 KSP Residual norm 2.599881652863e-02
  4332 KSP Residual norm 2.939128723687e-02
  4333 KSP Residual norm 3.303847575911e-02
  4334 KSP Residual norm 3.261819884770e-02
  4335 KSP Residual norm 3.227755508146e-02
  4336 KSP Residual norm 3.516514611817e-02
  4337 KSP Residual norm 3.714248843602e-02
  4338 KSP Residual norm 3.687957608601e-02
  4339 KSP Residual norm 3.547144948854e-02
  4340 KSP Residual norm 3.538730000684e-02
  4341 KSP Residual norm 3.747209848009e-02
  4342 KSP Residual norm 4.033719367847e-02
  4343 KSP Residual norm 4.188069048659e-02
  4344 KSP Residual norm 4.027148882804e-02
  4345 KSP Residual norm 3.822077958758e-02
  4346 KSP Residual norm 3.653243560561e-02
  4347 KSP Residual norm 3.511659944011e-02
  4348 KSP Residual norm 3.206975127852e-02
  4349 KSP Residual norm 3.086545559654e-02
  4350 KSP Residual norm 3.127029182767e-02
  4351 KSP Residual norm 3.044384193361e-02
  4352 KSP Residual norm 2.846068960966e-02
  4353 KSP Residual norm 2.777564701555e-02
  4354 KSP Residual norm 2.569979107924e-02
  4355 KSP Residual norm 2.331487808072e-02
  4356 KSP Residual norm 2.253010482072e-02
  4357 KSP Residual norm 2.216228329378e-02
  4358 KSP Residual norm 2.043967396656e-02
  4359 KSP Residual norm 2.023111342518e-02
  4360 KSP Residual norm 2.187629590988e-02
  4361 KSP Residual norm 2.184819232415e-02
  4362 KSP Residual norm 1.822781641288e-02
  4363 KSP Residual norm 1.558867590643e-02
  4364 KSP Residual norm 1.575311061178e-02
  4365 KSP Residual norm 1.809224181664e-02
  4366 KSP Residual norm 2.130859643515e-02
  4367 KSP Residual norm 2.376103624940e-02
  4368 KSP Residual norm 2.502147297115e-02
  4369 KSP Residual norm 2.623400155944e-02
  4370 KSP Residual norm 2.739120320655e-02
  4371 KSP Residual norm 2.942773841794e-02
  4372 KSP Residual norm 3.200238216774e-02
  4373 KSP Residual norm 3.338058966096e-02
  4374 KSP Residual norm 3.313429368699e-02
  4375 KSP Residual norm 3.461235426972e-02
  4376 KSP Residual norm 3.811517365282e-02
  4377 KSP Residual norm 4.046572050369e-02
  4378 KSP Residual norm 4.134439617517e-02
  4379 KSP Residual norm 4.562675841668e-02
  4380 KSP Residual norm 5.212114202472e-02
  4381 KSP Residual norm 5.456690035163e-02
  4382 KSP Residual norm 5.225156155629e-02
  4383 KSP Residual norm 5.154045850229e-02
  4384 KSP Residual norm 5.583443611844e-02
  4385 KSP Residual norm 6.290982861831e-02
  4386 KSP Residual norm 6.450934490892e-02
  4387 KSP Residual norm 6.225312631384e-02
  4388 KSP Residual norm 6.204275106502e-02
  4389 KSP Residual norm 6.709831924677e-02
  4390 KSP Residual norm 7.303918792821e-02
  4391 KSP Residual norm 7.607221642580e-02
  4392 KSP Residual norm 7.785470924369e-02
  4393 KSP Residual norm 7.826606828851e-02
  4394 KSP Residual norm 7.967619320243e-02
  4395 KSP Residual norm 7.984488955252e-02
  4396 KSP Residual norm 7.594015846163e-02
  4397 KSP Residual norm 7.448891051246e-02
  4398 KSP Residual norm 7.395679493806e-02
  4399 KSP Residual norm 7.079387810796e-02
  4400 KSP Residual norm 6.814797450049e-02
  4401 KSP Residual norm 6.878511005462e-02
  4402 KSP Residual norm 6.821471316216e-02
  4403 KSP Residual norm 6.129683459287e-02
  4404 KSP Residual norm 5.513161157759e-02
  4405 KSP Residual norm 5.400916771858e-02
  4406 KSP Residual norm 5.713751137240e-02
  4407 KSP Residual norm 5.508343444529e-02
  4408 KSP Residual norm 4.958965746627e-02
  4409 KSP Residual norm 4.482339821928e-02
  4410 KSP Residual norm 4.083577232812e-02
  4411 KSP Residual norm 3.957885546103e-02
  4412 KSP Residual norm 3.967240796630e-02
  4413 KSP Residual norm 3.728369645287e-02
  4414 KSP Residual norm 3.226500874638e-02
  4415 KSP Residual norm 2.658508602181e-02
  4416 KSP Residual norm 2.243037461516e-02
  4417 KSP Residual norm 2.118619526210e-02
  4418 KSP Residual norm 2.038447161234e-02
  4419 KSP Residual norm 1.902572524747e-02
  4420 KSP Residual norm 1.756000590113e-02
  4421 KSP Residual norm 1.694984169246e-02
  4422 KSP Residual norm 1.623223727461e-02
  4423 KSP Residual norm 1.484945348301e-02
  4424 KSP Residual norm 1.425405980546e-02
  4425 KSP Residual norm 1.470653094556e-02
  4426 KSP Residual norm 1.458935889012e-02
  4427 KSP Residual norm 1.293215686369e-02
  4428 KSP Residual norm 1.158375529529e-02
  4429 KSP Residual norm 1.145287243611e-02
  4430 KSP Residual norm 1.096277925257e-02
  4431 KSP Residual norm 1.022076337818e-02
  4432 KSP Residual norm 1.032267774439e-02
  4433 KSP Residual norm 1.236991410043e-02
  4434 KSP Residual norm 1.503856744922e-02
  4435 KSP Residual norm 1.615662952662e-02
  4436 KSP Residual norm 1.770620500533e-02
  4437 KSP Residual norm 1.956199501807e-02
  4438 KSP Residual norm 2.015816510449e-02
  4439 KSP Residual norm 1.951267658699e-02
  4440 KSP Residual norm 1.843100893997e-02
  4441 KSP Residual norm 1.851266566866e-02
  4442 KSP Residual norm 1.892542891790e-02
  4443 KSP Residual norm 1.796682590042e-02
  4444 KSP Residual norm 1.722464550182e-02
  4445 KSP Residual norm 1.868191386322e-02
  4446 KSP Residual norm 2.066282950335e-02
  4447 KSP Residual norm 2.020060391601e-02
  4448 KSP Residual norm 2.000627501822e-02
  4449 KSP Residual norm 2.033319998842e-02
  4450 KSP Residual norm 1.959216035400e-02
  4451 KSP Residual norm 1.808017765673e-02
  4452 KSP Residual norm 1.698079625997e-02
  4453 KSP Residual norm 1.626785390426e-02
  4454 KSP Residual norm 1.616999484548e-02
  4455 KSP Residual norm 1.606097315872e-02
  4456 KSP Residual norm 1.642414344635e-02
  4457 KSP Residual norm 1.682823461466e-02
  4458 KSP Residual norm 1.633484799356e-02
  4459 KSP Residual norm 1.588795131649e-02
  4460 KSP Residual norm 1.584363336047e-02
  4461 KSP Residual norm 1.538679118579e-02
  4462 KSP Residual norm 1.429521352663e-02
  4463 KSP Residual norm 1.289393515798e-02
  4464 KSP Residual norm 1.245768605385e-02
  4465 KSP Residual norm 1.272402080298e-02
  4466 KSP Residual norm 1.275535831287e-02
  4467 KSP Residual norm 1.219396475175e-02
  4468 KSP Residual norm 1.163351295872e-02
  4469 KSP Residual norm 1.175752166397e-02
  4470 KSP Residual norm 1.093596782102e-02
  4471 KSP Residual norm 9.663729370247e-03
  4472 KSP Residual norm 9.081115435288e-03
  4473 KSP Residual norm 9.339063465569e-03
  4474 KSP Residual norm 9.591448392416e-03
  4475 KSP Residual norm 9.599471359057e-03
  4476 KSP Residual norm 9.703447291851e-03
  4477 KSP Residual norm 1.001450604403e-02
  4478 KSP Residual norm 1.077962278287e-02
  4479 KSP Residual norm 1.150009077025e-02
  4480 KSP Residual norm 1.229345486357e-02
  4481 KSP Residual norm 1.287235228033e-02
  4482 KSP Residual norm 1.265535392658e-02
  4483 KSP Residual norm 1.156308035077e-02
  4484 KSP Residual norm 1.114011596853e-02
  4485 KSP Residual norm 1.147153421137e-02
  4486 KSP Residual norm 1.112594017387e-02
  4487 KSP Residual norm 1.021418512486e-02
  4488 KSP Residual norm 9.792645690396e-03
  4489 KSP Residual norm 9.245683125612e-03
  4490 KSP Residual norm 9.257146877628e-03
  4491 KSP Residual norm 9.392165152820e-03
  4492 KSP Residual norm 9.524362593064e-03
  4493 KSP Residual norm 1.023149277578e-02
  4494 KSP Residual norm 1.212519050172e-02
  4495 KSP Residual norm 1.373353270897e-02
  4496 KSP Residual norm 1.355322660452e-02
  4497 KSP Residual norm 1.319365688975e-02
  4498 KSP Residual norm 1.320598856272e-02
  4499 KSP Residual norm 1.303314579576e-02
  4500 KSP Residual norm 1.280999738416e-02
  4501 KSP Residual norm 1.286543335859e-02
  4502 KSP Residual norm 1.245117101716e-02
  4503 KSP Residual norm 1.166004328005e-02
  4504 KSP Residual norm 1.149385895545e-02
  4505 KSP Residual norm 1.198758776558e-02
  4506 KSP Residual norm 1.207378491676e-02
  4507 KSP Residual norm 1.084156987528e-02
  4508 KSP Residual norm 9.254195116218e-03
  4509 KSP Residual norm 8.870781250756e-03
  4510 KSP Residual norm 9.020231346209e-03
  4511 KSP Residual norm 8.569913824718e-03
  4512 KSP Residual norm 7.785538142756e-03
  4513 KSP Residual norm 7.305871557667e-03
  4514 KSP Residual norm 7.284265054015e-03
  4515 KSP Residual norm 7.221062818228e-03
  4516 KSP Residual norm 7.140567405317e-03
  4517 KSP Residual norm 7.415245136982e-03
  4518 KSP Residual norm 7.786163532958e-03
  4519 KSP Residual norm 7.493589885061e-03
  4520 KSP Residual norm 6.923520903935e-03
  4521 KSP Residual norm 6.488676059735e-03
  4522 KSP Residual norm 6.314385517513e-03
  4523 KSP Residual norm 5.771334330971e-03
  4524 KSP Residual norm 5.137059606800e-03
  4525 KSP Residual norm 5.190613076976e-03
  4526 KSP Residual norm 5.485144484875e-03
  4527 KSP Residual norm 4.987731218788e-03
  4528 KSP Residual norm 4.275484929414e-03
  4529 KSP Residual norm 4.273648435680e-03
  4530 KSP Residual norm 4.681552936585e-03
  4531 KSP Residual norm 4.961890292442e-03
  4532 KSP Residual norm 5.024460531338e-03
  4533 KSP Residual norm 5.094514678711e-03
  4534 KSP Residual norm 5.511628985233e-03
  4535 KSP Residual norm 5.772947393146e-03
  4536 KSP Residual norm 5.494456452308e-03
  4537 KSP Residual norm 5.430000883516e-03
  4538 KSP Residual norm 6.029664715855e-03
  4539 KSP Residual norm 7.202474564781e-03
  4540 KSP Residual norm 8.255026164732e-03
  4541 KSP Residual norm 8.663638679693e-03
  4542 KSP Residual norm 9.156804572598e-03
  4543 KSP Residual norm 9.528409971005e-03
  4544 KSP Residual norm 9.004011761565e-03
  4545 KSP Residual norm 8.265189619488e-03
  4546 KSP Residual norm 8.511100581038e-03
  4547 KSP Residual norm 8.848333678829e-03
  4548 KSP Residual norm 8.469172509830e-03
  4549 KSP Residual norm 8.183452675852e-03
  4550 KSP Residual norm 8.418835744943e-03
  4551 KSP Residual norm 8.349988468643e-03
  4552 KSP Residual norm 8.110743967592e-03
  4553 KSP Residual norm 7.868795202645e-03
  4554 KSP Residual norm 7.533548722006e-03
  4555 KSP Residual norm 7.503047814224e-03
  4556 KSP Residual norm 7.198527592347e-03
  4557 KSP Residual norm 6.602610859014e-03
  4558 KSP Residual norm 5.928200665097e-03
  4559 KSP Residual norm 5.753114308744e-03
  4560 KSP Residual norm 5.989274351955e-03
  4561 KSP Residual norm 5.846791526975e-03
  4562 KSP Residual norm 5.511767992415e-03
  4563 KSP Residual norm 5.382926278810e-03
  4564 KSP Residual norm 5.448343355683e-03
  4565 KSP Residual norm 5.105030191056e-03
  4566 KSP Residual norm 4.723043641197e-03
  4567 KSP Residual norm 4.469811098350e-03
  4568 KSP Residual norm 4.334992698130e-03
  4569 KSP Residual norm 3.928590823078e-03
  4570 KSP Residual norm 3.646305926684e-03
  4571 KSP Residual norm 3.586355737516e-03
  4572 KSP Residual norm 3.472674737293e-03
  4573 KSP Residual norm 3.220610295982e-03
  4574 KSP Residual norm 3.010126817340e-03
  4575 KSP Residual norm 2.929265323296e-03
  4576 KSP Residual norm 2.862266090784e-03
  4577 KSP Residual norm 2.760268484709e-03
  4578 KSP Residual norm 2.698525320928e-03
  4579 KSP Residual norm 2.821719281981e-03
  4580 KSP Residual norm 3.247349282734e-03
  4581 KSP Residual norm 3.852340658180e-03
  4582 KSP Residual norm 4.180526509750e-03
  4583 KSP Residual norm 4.384976716934e-03
  4584 KSP Residual norm 4.354906564723e-03
  4585 KSP Residual norm 4.314425355341e-03
  4586 KSP Residual norm 4.232315007032e-03
  4587 KSP Residual norm 4.262720403959e-03
  4588 KSP Residual norm 4.539999824623e-03
  4589 KSP Residual norm 4.867119743444e-03
  4590 KSP Residual norm 5.381570729403e-03
  4591 KSP Residual norm 6.450614716025e-03
  4592 KSP Residual norm 7.690289509690e-03
  4593 KSP Residual norm 8.000161345832e-03
  4594 KSP Residual norm 7.819448166282e-03
  4595 KSP Residual norm 8.008696594533e-03
  4596 KSP Residual norm 7.867188305389e-03
  4597 KSP Residual norm 7.625887126866e-03
  4598 KSP Residual norm 8.289235801512e-03
  4599 KSP Residual norm 9.568200090172e-03
  4600 KSP Residual norm 9.906722861646e-03
  4601 KSP Residual norm 9.959100563549e-03
  4602 KSP Residual norm 1.002358188073e-02
  4603 KSP Residual norm 9.892212356164e-03
  4604 KSP Residual norm 1.007772310809e-02
  4605 KSP Residual norm 1.094742253074e-02
  4606 KSP Residual norm 1.204157128724e-02
  4607 KSP Residual norm 1.281646958731e-02
  4608 KSP Residual norm 1.215726535352e-02
  4609 KSP Residual norm 1.093467492496e-02
  4610 KSP Residual norm 1.069801877084e-02
  4611 KSP Residual norm 1.077395405875e-02
  4612 KSP Residual norm 1.075960710753e-02
  4613 KSP Residual norm 1.013651319526e-02
  4614 KSP Residual norm 9.710897936448e-03
  4615 KSP Residual norm 9.182699053929e-03
  4616 KSP Residual norm 8.293399133489e-03
  4617 KSP Residual norm 7.723147755421e-03
  4618 KSP Residual norm 7.991858294129e-03
  4619 KSP Residual norm 8.938344640381e-03
  4620 KSP Residual norm 8.654439004309e-03
  4621 KSP Residual norm 7.181141301408e-03
  4622 KSP Residual norm 6.357230595613e-03
  4623 KSP Residual norm 6.422117995639e-03
  4624 KSP Residual norm 6.483063368787e-03
  4625 KSP Residual norm 6.865442041828e-03
  4626 KSP Residual norm 7.410354335749e-03
  4627 KSP Residual norm 7.197010267209e-03
  4628 KSP Residual norm 6.824861693545e-03
  4629 KSP Residual norm 6.897666276806e-03
  4630 KSP Residual norm 7.506296015931e-03
  4631 KSP Residual norm 7.905088162358e-03
  4632 KSP Residual norm 7.862757023938e-03
  4633 KSP Residual norm 8.544522738893e-03
  4634 KSP Residual norm 9.360255424249e-03
  4635 KSP Residual norm 9.179099451290e-03
  4636 KSP Residual norm 8.286752076018e-03
  4637 KSP Residual norm 7.746846310036e-03
  4638 KSP Residual norm 7.534871355381e-03
  4639 KSP Residual norm 7.282719682088e-03
  4640 KSP Residual norm 7.553492203465e-03
  4641 KSP Residual norm 9.295155557681e-03
  4642 KSP Residual norm 1.171992700109e-02
  4643 KSP Residual norm 1.286637312900e-02
  4644 KSP Residual norm 1.271570269138e-02
  4645 KSP Residual norm 1.298333595908e-02
  4646 KSP Residual norm 1.347439695833e-02
  4647 KSP Residual norm 1.305011359740e-02
  4648 KSP Residual norm 1.306731634648e-02
  4649 KSP Residual norm 1.289962866463e-02
  4650 KSP Residual norm 1.268087597179e-02
  4651 KSP Residual norm 1.181452450529e-02
  4652 KSP Residual norm 1.162013706209e-02
  4653 KSP Residual norm 1.227906872619e-02
  4654 KSP Residual norm 1.325070303771e-02
  4655 KSP Residual norm 1.337762070145e-02
  4656 KSP Residual norm 1.315158500085e-02
  4657 KSP Residual norm 1.280614725143e-02
  4658 KSP Residual norm 1.279197585693e-02
  4659 KSP Residual norm 1.297450067139e-02
  4660 KSP Residual norm 1.288594217896e-02
  4661 KSP Residual norm 1.324791314990e-02
  4662 KSP Residual norm 1.332737571601e-02
  4663 KSP Residual norm 1.377272971364e-02
  4664 KSP Residual norm 1.470093687998e-02
  4665 KSP Residual norm 1.521424957280e-02
  4666 KSP Residual norm 1.426627944548e-02
  4667 KSP Residual norm 1.334366572410e-02
  4668 KSP Residual norm 1.269344829471e-02
  4669 KSP Residual norm 1.157214060039e-02
  4670 KSP Residual norm 1.089210980287e-02
  4671 KSP Residual norm 1.138383261846e-02
  4672 KSP Residual norm 1.239333059775e-02
  4673 KSP Residual norm 1.238727732204e-02
  4674 KSP Residual norm 1.115915590468e-02
  4675 KSP Residual norm 9.818285958862e-03
  4676 KSP Residual norm 8.565492420102e-03
  4677 KSP Residual norm 8.386541780752e-03
  4678 KSP Residual norm 9.516688861134e-03
  4679 KSP Residual norm 1.055328475215e-02
  4680 KSP Residual norm 1.103554801045e-02
  4681 KSP Residual norm 1.214862504166e-02
  4682 KSP Residual norm 1.334068555972e-02
  4683 KSP Residual norm 1.261599459542e-02
  4684 KSP Residual norm 1.226182142533e-02
  4685 KSP Residual norm 1.213480550847e-02
  4686 KSP Residual norm 1.128132550377e-02
  4687 KSP Residual norm 1.061403127221e-02
  4688 KSP Residual norm 1.063349230992e-02
  4689 KSP Residual norm 1.100848987199e-02
  4690 KSP Residual norm 1.182402965199e-02
  4691 KSP Residual norm 1.241531199741e-02
  4692 KSP Residual norm 1.178730273607e-02
  4693 KSP Residual norm 1.118470952312e-02
  4694 KSP Residual norm 1.088443059126e-02
  4695 KSP Residual norm 1.124772832917e-02
  4696 KSP Residual norm 1.227516148048e-02
  4697 KSP Residual norm 1.361596978640e-02
  4698 KSP Residual norm 1.481280206513e-02
  4699 KSP Residual norm 1.503265598500e-02
  4700 KSP Residual norm 1.405032574327e-02
  4701 KSP Residual norm 1.349902341937e-02
  4702 KSP Residual norm 1.431737388001e-02
  4703 KSP Residual norm 1.510908150518e-02
  4704 KSP Residual norm 1.493536282337e-02
  4705 KSP Residual norm 1.551422531292e-02
  4706 KSP Residual norm 1.734336603421e-02
  4707 KSP Residual norm 2.002501626185e-02
  4708 KSP Residual norm 2.437462491444e-02
  4709 KSP Residual norm 2.787437687602e-02
  4710 KSP Residual norm 2.969851828531e-02
  4711 KSP Residual norm 3.218934254707e-02
  4712 KSP Residual norm 3.334929843073e-02
  4713 KSP Residual norm 3.362831222543e-02
  4714 KSP Residual norm 3.716477564943e-02
  4715 KSP Residual norm 3.912634467630e-02
  4716 KSP Residual norm 3.385720793202e-02
  4717 KSP Residual norm 3.148142322739e-02
  4718 KSP Residual norm 3.614145952465e-02
  4719 KSP Residual norm 4.372417586063e-02
  4720 KSP Residual norm 4.681159484674e-02
  4721 KSP Residual norm 4.927379738417e-02
  4722 KSP Residual norm 5.332342467052e-02
  4723 KSP Residual norm 5.711397446185e-02
  4724 KSP Residual norm 5.630133139287e-02
  4725 KSP Residual norm 5.150282811884e-02
  4726 KSP Residual norm 4.848854259112e-02
  4727 KSP Residual norm 4.839766712392e-02
  4728 KSP Residual norm 4.434141718208e-02
  4729 KSP Residual norm 3.899315766144e-02
  4730 KSP Residual norm 3.714692830255e-02
  4731 KSP Residual norm 3.808062959376e-02
  4732 KSP Residual norm 4.016749477394e-02
  4733 KSP Residual norm 4.266357705396e-02
  4734 KSP Residual norm 4.339169673220e-02
  4735 KSP Residual norm 4.319612095025e-02
  4736 KSP Residual norm 4.215492209268e-02
  4737 KSP Residual norm 4.114426642373e-02
  4738 KSP Residual norm 3.930242419604e-02
  4739 KSP Residual norm 3.635129552145e-02
  4740 KSP Residual norm 3.390812645207e-02
  4741 KSP Residual norm 3.148750122687e-02
  4742 KSP Residual norm 2.999444339151e-02
  4743 KSP Residual norm 2.840582120708e-02
  4744 KSP Residual norm 2.762142759199e-02
  4745 KSP Residual norm 2.756049086040e-02
  4746 KSP Residual norm 2.528557249255e-02
  4747 KSP Residual norm 1.985618261662e-02
  4748 KSP Residual norm 1.704874133330e-02
  4749 KSP Residual norm 1.702916365609e-02
  4750 KSP Residual norm 1.760842219336e-02
  4751 KSP Residual norm 1.789682033856e-02
  4752 KSP Residual norm 1.713223185387e-02
  4753 KSP Residual norm 1.569896355416e-02
  4754 KSP Residual norm 1.436561731637e-02
  4755 KSP Residual norm 1.359599960161e-02
  4756 KSP Residual norm 1.300462886490e-02
  4757 KSP Residual norm 1.245207510571e-02
  4758 KSP Residual norm 1.202992508680e-02
  4759 KSP Residual norm 1.253906473485e-02
  4760 KSP Residual norm 1.370882739476e-02
  4761 KSP Residual norm 1.427135535699e-02
  4762 KSP Residual norm 1.239537244118e-02
  4763 KSP Residual norm 1.231282471630e-02
  4764 KSP Residual norm 1.422684655278e-02
  4765 KSP Residual norm 1.553672450769e-02
  4766 KSP Residual norm 1.642684069468e-02
  4767 KSP Residual norm 1.800600010207e-02
  4768 KSP Residual norm 1.919540710086e-02
  4769 KSP Residual norm 1.740662476578e-02
  4770 KSP Residual norm 1.477995780205e-02
  4771 KSP Residual norm 1.399626756825e-02
  4772 KSP Residual norm 1.511396159601e-02
  4773 KSP Residual norm 1.688380847740e-02
  4774 KSP Residual norm 1.916919031668e-02
  4775 KSP Residual norm 2.244179738950e-02
  4776 KSP Residual norm 2.656126852966e-02
  4777 KSP Residual norm 2.897145629632e-02
  4778 KSP Residual norm 2.940996576390e-02
  4779 KSP Residual norm 2.825507853185e-02
  4780 KSP Residual norm 2.845705802397e-02
  4781 KSP Residual norm 2.886157826641e-02
  4782 KSP Residual norm 2.701527474462e-02
  4783 KSP Residual norm 2.642677855064e-02
  4784 KSP Residual norm 2.901462934352e-02
  4785 KSP Residual norm 3.402873026474e-02
  4786 KSP Residual norm 3.853720495238e-02
  4787 KSP Residual norm 3.850369558944e-02
  4788 KSP Residual norm 3.196678228647e-02
  4789 KSP Residual norm 2.634458486650e-02
  4790 KSP Residual norm 2.410137337534e-02
  4791 KSP Residual norm 2.516763698972e-02
  4792 KSP Residual norm 2.772430350738e-02
  4793 KSP Residual norm 2.689201040742e-02
  4794 KSP Residual norm 2.436219820416e-02
  4795 KSP Residual norm 2.261589709462e-02
  4796 KSP Residual norm 2.277671648243e-02
  4797 KSP Residual norm 2.562926450131e-02
  4798 KSP Residual norm 3.042263996726e-02
  4799 KSP Residual norm 3.251990926068e-02
  4800 KSP Residual norm 3.085956605997e-02
  4801 KSP Residual norm 2.646868399630e-02
  4802 KSP Residual norm 2.386192171524e-02
  4803 KSP Residual norm 2.261458721256e-02
  4804 KSP Residual norm 2.062660091819e-02
  4805 KSP Residual norm 1.869516568364e-02
  4806 KSP Residual norm 1.760108480192e-02
  4807 KSP Residual norm 1.754443504284e-02
  4808 KSP Residual norm 1.796042878408e-02
  4809 KSP Residual norm 1.788378531861e-02
  4810 KSP Residual norm 1.530127019498e-02
  4811 KSP Residual norm 1.215105364291e-02
  4812 KSP Residual norm 1.084502145397e-02
  4813 KSP Residual norm 1.040249650107e-02
  4814 KSP Residual norm 9.958002318289e-03
  4815 KSP Residual norm 9.097127761621e-03
  4816 KSP Residual norm 8.910933318721e-03
  4817 KSP Residual norm 9.315951713342e-03
  4818 KSP Residual norm 9.950766199381e-03
  4819 KSP Residual norm 9.998912624615e-03
  4820 KSP Residual norm 9.455630025168e-03
  4821 KSP Residual norm 8.270036764891e-03
  4822 KSP Residual norm 7.859719892972e-03
  4823 KSP Residual norm 8.155333463607e-03
  4824 KSP Residual norm 8.272047439841e-03
  4825 KSP Residual norm 8.085623764538e-03
  4826 KSP Residual norm 7.547949352706e-03
  4827 KSP Residual norm 6.644991843527e-03
  4828 KSP Residual norm 5.462484033838e-03
  4829 KSP Residual norm 4.988850411074e-03
  4830 KSP Residual norm 5.102907622420e-03
  4831 KSP Residual norm 5.449278214594e-03
  4832 KSP Residual norm 5.720242187523e-03
  4833 KSP Residual norm 6.082833267210e-03
  4834 KSP Residual norm 5.929903839415e-03
  4835 KSP Residual norm 4.995252054354e-03
  4836 KSP Residual norm 4.491057907517e-03
  4837 KSP Residual norm 4.837108278648e-03
  4838 KSP Residual norm 6.055193862859e-03
  4839 KSP Residual norm 6.920685278467e-03
  4840 KSP Residual norm 7.231459824192e-03
  4841 KSP Residual norm 8.107222146470e-03
  4842 KSP Residual norm 9.308239239686e-03
  4843 KSP Residual norm 9.871463989251e-03
  4844 KSP Residual norm 1.002484830643e-02
  4845 KSP Residual norm 1.026884090543e-02
  4846 KSP Residual norm 1.037122151751e-02
  4847 KSP Residual norm 9.770518532811e-03
  4848 KSP Residual norm 9.286292396229e-03
  4849 KSP Residual norm 9.804405914052e-03
  4850 KSP Residual norm 1.042391520388e-02
  4851 KSP Residual norm 1.065719222685e-02
  4852 KSP Residual norm 1.111461650311e-02
  4853 KSP Residual norm 1.172781563300e-02
  4854 KSP Residual norm 1.265211396877e-02
  4855 KSP Residual norm 1.306519731946e-02
  4856 KSP Residual norm 1.287582554304e-02
  4857 KSP Residual norm 1.232046664975e-02
  4858 KSP Residual norm 1.194964402615e-02
  4859 KSP Residual norm 1.148504283675e-02
  4860 KSP Residual norm 1.070334349280e-02
  4861 KSP Residual norm 1.065549411294e-02
  4862 KSP Residual norm 1.068936895043e-02
  4863 KSP Residual norm 1.001884044768e-02
  4864 KSP Residual norm 8.632443770420e-03
  4865 KSP Residual norm 6.928568699760e-03
  4866 KSP Residual norm 5.646926488273e-03
  4867 KSP Residual norm 4.978013413895e-03
  4868 KSP Residual norm 4.959400548923e-03
  4869 KSP Residual norm 5.160469696160e-03
  4870 KSP Residual norm 4.971745575577e-03
  4871 KSP Residual norm 4.928852565150e-03
  4872 KSP Residual norm 5.549808642864e-03
  4873 KSP Residual norm 6.227012788396e-03
  4874 KSP Residual norm 5.897499897790e-03
  4875 KSP Residual norm 4.857923099915e-03
  4876 KSP Residual norm 4.121677201552e-03
  4877 KSP Residual norm 4.073826787684e-03
  4878 KSP Residual norm 4.450419215251e-03
  4879 KSP Residual norm 5.263443308304e-03
  4880 KSP Residual norm 6.394327906829e-03
  4881 KSP Residual norm 6.381629515620e-03
  4882 KSP Residual norm 5.412036775608e-03
  4883 KSP Residual norm 4.694628047564e-03
  4884 KSP Residual norm 4.657643136149e-03
  4885 KSP Residual norm 5.266059715368e-03
  4886 KSP Residual norm 6.271757358305e-03
  4887 KSP Residual norm 6.796039189475e-03
  4888 KSP Residual norm 6.379619582637e-03
  4889 KSP Residual norm 6.246866960254e-03
  4890 KSP Residual norm 6.591449778191e-03
  4891 KSP Residual norm 6.257950698969e-03
  4892 KSP Residual norm 6.083635246191e-03
  4893 KSP Residual norm 6.257576495005e-03
  4894 KSP Residual norm 5.832728742303e-03
  4895 KSP Residual norm 4.989826804701e-03
  4896 KSP Residual norm 4.185729388971e-03
  4897 KSP Residual norm 3.749863191958e-03
  4898 KSP Residual norm 4.055073930552e-03
  4899 KSP Residual norm 5.203687735174e-03
  4900 KSP Residual norm 7.289298072190e-03
  4901 KSP Residual norm 9.765633568643e-03
  4902 KSP Residual norm 1.080706924468e-02
  4903 KSP Residual norm 1.002662072119e-02
  4904 KSP Residual norm 8.988931475513e-03
  4905 KSP Residual norm 8.453173556504e-03
  4906 KSP Residual norm 9.320737266791e-03
  4907 KSP Residual norm 1.047363050911e-02
  4908 KSP Residual norm 1.076803557135e-02
  4909 KSP Residual norm 1.039213410634e-02
  4910 KSP Residual norm 9.155568292591e-03
  4911 KSP Residual norm 7.626370109756e-03
  4912 KSP Residual norm 6.557297619764e-03
  4913 KSP Residual norm 5.688947686707e-03
  4914 KSP Residual norm 5.307608385522e-03
  4915 KSP Residual norm 5.402110500513e-03
  4916 KSP Residual norm 5.758432233635e-03
  4917 KSP Residual norm 6.434845501485e-03
  4918 KSP Residual norm 7.111541646617e-03
  4919 KSP Residual norm 7.488030948720e-03
  4920 KSP Residual norm 6.705354653259e-03
  4921 KSP Residual norm 4.790018037051e-03
  4922 KSP Residual norm 3.362452309240e-03
  4923 KSP Residual norm 2.946761601425e-03
  4924 KSP Residual norm 3.390387075941e-03
  4925 KSP Residual norm 4.241381450779e-03
  4926 KSP Residual norm 5.270902723724e-03
  4927 KSP Residual norm 6.059402611143e-03
  4928 KSP Residual norm 5.337757436964e-03
  4929 KSP Residual norm 3.833830493822e-03
  4930 KSP Residual norm 2.747645358915e-03
  4931 KSP Residual norm 2.150688673279e-03
  4932 KSP Residual norm 1.914781624795e-03
  4933 KSP Residual norm 2.077408449524e-03
  4934 KSP Residual norm 2.632585692938e-03
  4935 KSP Residual norm 3.300334592556e-03
  4936 KSP Residual norm 3.179171046809e-03
  4937 KSP Residual norm 2.228488962779e-03
  4938 KSP Residual norm 1.514179510410e-03
  4939 KSP Residual norm 1.178432803597e-03
  4940 KSP Residual norm 1.092308238180e-03
  4941 KSP Residual norm 1.194188530520e-03
  4942 KSP Residual norm 1.459530746680e-03
  4943 KSP Residual norm 1.974357583893e-03
  4944 KSP Residual norm 2.456511377489e-03
  4945 KSP Residual norm 2.363429800002e-03
  4946 KSP Residual norm 1.747724840607e-03
  4947 KSP Residual norm 1.238167988902e-03
  4948 KSP Residual norm 9.347618818802e-04
  4949 KSP Residual norm 7.846093234227e-04
  4950 KSP Residual norm 7.969019913978e-04
  4951 KSP Residual norm 1.018032594440e-03
  4952 KSP Residual norm 1.435193586315e-03
  4953 KSP Residual norm 1.763016426696e-03
  4954 KSP Residual norm 1.879673692883e-03
  4955 KSP Residual norm 1.648663413833e-03
  4956 KSP Residual norm 1.115507322067e-03
  4957 KSP Residual norm 6.986300219611e-04
  4958 KSP Residual norm 5.518190849376e-04
  4959 KSP Residual norm 5.930730453886e-04
  4960 KSP Residual norm 7.720168068322e-04
  4961 KSP Residual norm 9.852553178381e-04
  4962 KSP Residual norm 1.136653159694e-03
  4963 KSP Residual norm 1.180083614422e-03
  4964 KSP Residual norm 1.160501693820e-03
  4965 KSP Residual norm 1.130479996735e-03
  4966 KSP Residual norm 1.193048737706e-03
  4967 KSP Residual norm 1.337340833074e-03
  4968 KSP Residual norm 1.407270243137e-03
  4969 KSP Residual norm 1.332676891727e-03
  4970 KSP Residual norm 1.301055778962e-03
  4971 KSP Residual norm 1.361806020942e-03
  4972 KSP Residual norm 1.541484114909e-03
  4973 KSP Residual norm 1.818375177566e-03
  4974 KSP Residual norm 2.031378473856e-03
  4975 KSP Residual norm 1.853145278024e-03
  4976 KSP Residual norm 1.524647736242e-03
  4977 KSP Residual norm 1.342015063503e-03
  4978 KSP Residual norm 1.405340684928e-03
  4979 KSP Residual norm 1.737159120482e-03
  4980 KSP Residual norm 2.422470991332e-03
  4981 KSP Residual norm 3.063469428059e-03
  4982 KSP Residual norm 3.263232649914e-03
  4983 KSP Residual norm 3.286345157348e-03
  4984 KSP Residual norm 3.329342521906e-03
  4985 KSP Residual norm 3.326627977020e-03
  4986 KSP Residual norm 3.371354442555e-03
  4987 KSP Residual norm 3.421220349236e-03
  4988 KSP Residual norm 3.287196782563e-03
  4989 KSP Residual norm 2.715823964119e-03
  4990 KSP Residual norm 2.214979943780e-03
  4991 KSP Residual norm 2.114034858605e-03
  4992 KSP Residual norm 2.269898558350e-03
  4993 KSP Residual norm 2.499906013821e-03
  4994 KSP Residual norm 2.912036386996e-03
  4995 KSP Residual norm 3.387337502437e-03
  4996 KSP Residual norm 3.235464518676e-03
  4997 KSP Residual norm 2.880509673571e-03
  4998 KSP Residual norm 2.816461095183e-03
  4999 KSP Residual norm 3.022250534837e-03
  5000 KSP Residual norm 3.291150101357e-03
  5001 KSP Residual norm 3.389669223662e-03
  5002 KSP Residual norm 2.817208090928e-03
  5003 KSP Residual norm 1.978803521597e-03
  5004 KSP Residual norm 1.422343727108e-03
  5005 KSP Residual norm 1.144685926365e-03
  5006 KSP Residual norm 1.234667529448e-03
  5007 KSP Residual norm 1.819585014719e-03
  5008 KSP Residual norm 2.750600411515e-03
  5009 KSP Residual norm 3.165378437491e-03
  5010 KSP Residual norm 2.677495677307e-03
  5011 KSP Residual norm 2.163050280073e-03
  5012 KSP Residual norm 1.874207928539e-03
  5013 KSP Residual norm 1.535687724493e-03
  5014 KSP Residual norm 1.313885632045e-03
  5015 KSP Residual norm 1.408869915294e-03
  5016 KSP Residual norm 1.588029743271e-03
  5017 KSP Residual norm 1.588344572732e-03
  5018 KSP Residual norm 1.669796293906e-03
  5019 KSP Residual norm 1.944841238776e-03
  5020 KSP Residual norm 2.045359968243e-03
  5021 KSP Residual norm 1.656331145003e-03
  5022 KSP Residual norm 1.279755905280e-03
  5023 KSP Residual norm 1.079348218324e-03
  5024 KSP Residual norm 1.096175544553e-03
  5025 KSP Residual norm 1.288021654318e-03
  5026 KSP Residual norm 1.594553342392e-03
  5027 KSP Residual norm 1.888061940387e-03
  5028 KSP Residual norm 2.171248386832e-03
  5029 KSP Residual norm 2.454370553550e-03
  5030 KSP Residual norm 2.816579734572e-03
  5031 KSP Residual norm 3.084512066111e-03
  5032 KSP Residual norm 3.027622341693e-03
  5033 KSP Residual norm 2.978665746558e-03
  5034 KSP Residual norm 2.690866475698e-03
  5035 KSP Residual norm 2.110124306155e-03
  5036 KSP Residual norm 1.674828335178e-03
  5037 KSP Residual norm 1.566565908324e-03
  5038 KSP Residual norm 1.747937220098e-03
  5039 KSP Residual norm 2.248892010782e-03
  5040 KSP Residual norm 2.857705442715e-03
  5041 KSP Residual norm 3.085106545901e-03
  5042 KSP Residual norm 3.051309956733e-03
  5043 KSP Residual norm 3.033356990345e-03
  5044 KSP Residual norm 3.192142597189e-03
  5045 KSP Residual norm 3.375624152832e-03
  5046 KSP Residual norm 3.336374499905e-03
  5047 KSP Residual norm 3.050958470633e-03
  5048 KSP Residual norm 2.756607565141e-03
  5049 KSP Residual norm 2.515508106626e-03
  5050 KSP Residual norm 2.489483992298e-03
  5051 KSP Residual norm 2.849603288255e-03
  5052 KSP Residual norm 3.546447799366e-03
  5053 KSP Residual norm 4.151401419809e-03
  5054 KSP Residual norm 4.446572591243e-03
  5055 KSP Residual norm 4.856234194189e-03
  5056 KSP Residual norm 5.256038219276e-03
  5057 KSP Residual norm 5.845514047672e-03
  5058 KSP Residual norm 6.592947114170e-03
  5059 KSP Residual norm 6.076006162852e-03
  5060 KSP Residual norm 5.404819106328e-03
  5061 KSP Residual norm 5.269282759973e-03
  5062 KSP Residual norm 5.001933187235e-03
  5063 KSP Residual norm 4.622849954769e-03
  5064 KSP Residual norm 4.823257629216e-03
  5065 KSP Residual norm 5.573911968753e-03
  5066 KSP Residual norm 6.516973487883e-03
  5067 KSP Residual norm 7.820591843174e-03
  5068 KSP Residual norm 8.378533585387e-03
  5069 KSP Residual norm 7.809567523651e-03
  5070 KSP Residual norm 6.823901788272e-03
  5071 KSP Residual norm 6.260748730520e-03
  5072 KSP Residual norm 5.898450566380e-03
  5073 KSP Residual norm 5.687804058418e-03
  5074 KSP Residual norm 5.262967099664e-03
  5075 KSP Residual norm 4.844076719264e-03
  5076 KSP Residual norm 4.651855957704e-03
  5077 KSP Residual norm 4.479522372641e-03
  5078 KSP Residual norm 4.820802430663e-03
  5079 KSP Residual norm 5.157007390652e-03
  5080 KSP Residual norm 5.347094848023e-03
  5081 KSP Residual norm 5.480147694964e-03
  5082 KSP Residual norm 6.197823277763e-03
  5083 KSP Residual norm 6.953930398315e-03
  5084 KSP Residual norm 7.494722045878e-03
  5085 KSP Residual norm 7.122049835994e-03
  5086 KSP Residual norm 5.250897891001e-03
  5087 KSP Residual norm 3.733753304278e-03
  5088 KSP Residual norm 3.000130609437e-03
  5089 KSP Residual norm 2.730444865874e-03
  5090 KSP Residual norm 2.806777592697e-03
  5091 KSP Residual norm 3.534693244892e-03
  5092 KSP Residual norm 4.742855747346e-03
  5093 KSP Residual norm 5.618857680117e-03
  5094 KSP Residual norm 5.727560122837e-03
  5095 KSP Residual norm 5.665085254908e-03
  5096 KSP Residual norm 5.572251597088e-03
  5097 KSP Residual norm 5.392866905234e-03
  5098 KSP Residual norm 4.797175112142e-03
  5099 KSP Residual norm 4.115744724931e-03
  5100 KSP Residual norm 3.808753573586e-03
  5101 KSP Residual norm 3.911638581068e-03
  5102 KSP Residual norm 3.978371081644e-03
  5103 KSP Residual norm 4.160433694042e-03
  5104 KSP Residual norm 4.717609959807e-03
  5105 KSP Residual norm 5.529647619336e-03
  5106 KSP Residual norm 6.057214307890e-03
  5107 KSP Residual norm 6.661957144616e-03
  5108 KSP Residual norm 7.161526349291e-03
  5109 KSP Residual norm 7.570901013840e-03
  5110 KSP Residual norm 7.707589057577e-03
  5111 KSP Residual norm 7.683271579517e-03
  5112 KSP Residual norm 7.846003147522e-03
  5113 KSP Residual norm 8.308064350657e-03
  5114 KSP Residual norm 8.337705614986e-03
  5115 KSP Residual norm 7.612423043577e-03
  5116 KSP Residual norm 7.332948570313e-03
  5117 KSP Residual norm 7.268416620020e-03
  5118 KSP Residual norm 7.415675864539e-03
  5119 KSP Residual norm 8.621764085841e-03
  5120 KSP Residual norm 1.058892453647e-02
  5121 KSP Residual norm 1.178819456823e-02
  5122 KSP Residual norm 1.225711412480e-02
  5123 KSP Residual norm 1.273167378411e-02
  5124 KSP Residual norm 1.301503302738e-02
  5125 KSP Residual norm 1.221850412513e-02
  5126 KSP Residual norm 1.124446749456e-02
  5127 KSP Residual norm 1.023472666998e-02
  5128 KSP Residual norm 9.532791955133e-03
  5129 KSP Residual norm 9.174097741455e-03
  5130 KSP Residual norm 9.694037708432e-03
  5131 KSP Residual norm 1.055795212558e-02
  5132 KSP Residual norm 9.425549028743e-03
  5133 KSP Residual norm 8.619620720571e-03
  5134 KSP Residual norm 1.002930961693e-02
  5135 KSP Residual norm 1.278178777314e-02
  5136 KSP Residual norm 1.347910571283e-02
  5137 KSP Residual norm 1.170006737430e-02
  5138 KSP Residual norm 9.876322953708e-03
  5139 KSP Residual norm 9.995696068193e-03
  5140 KSP Residual norm 1.197374794613e-02
  5141 KSP Residual norm 1.180659063410e-02
  5142 KSP Residual norm 8.960345861898e-03
  5143 KSP Residual norm 6.670112656017e-03
  5144 KSP Residual norm 5.325361947471e-03
  5145 KSP Residual norm 4.736550206560e-03
  5146 KSP Residual norm 5.072528972719e-03
  5147 KSP Residual norm 5.757265321682e-03
  5148 KSP Residual norm 5.833410810155e-03
  5149 KSP Residual norm 5.502048773279e-03
  5150 KSP Residual norm 5.020828627945e-03
  5151 KSP Residual norm 4.879906807749e-03
  5152 KSP Residual norm 5.473968702837e-03
  5153 KSP Residual norm 6.806856885144e-03
  5154 KSP Residual norm 8.018509552909e-03
  5155 KSP Residual norm 8.304671294585e-03
  5156 KSP Residual norm 8.427119056107e-03
  5157 KSP Residual norm 9.083636959881e-03
  5158 KSP Residual norm 1.031694186913e-02
  5159 KSP Residual norm 1.026507915940e-02
  5160 KSP Residual norm 9.187457077705e-03
  5161 KSP Residual norm 8.958463131120e-03
  5162 KSP Residual norm 9.005353946366e-03
  5163 KSP Residual norm 7.998277276331e-03
  5164 KSP Residual norm 7.076361672102e-03
  5165 KSP Residual norm 6.012448325201e-03
  5166 KSP Residual norm 4.614796846782e-03
  5167 KSP Residual norm 4.092226890317e-03
  5168 KSP Residual norm 4.552101862680e-03
  5169 KSP Residual norm 5.165059680433e-03
  5170 KSP Residual norm 5.132031450739e-03
  5171 KSP Residual norm 5.228096972927e-03
  5172 KSP Residual norm 6.330401772911e-03
  5173 KSP Residual norm 9.020369001129e-03
  5174 KSP Residual norm 1.191885618250e-02
  5175 KSP Residual norm 1.155960131928e-02
  5176 KSP Residual norm 9.926623465561e-03
  5177 KSP Residual norm 9.926733624389e-03
  5178 KSP Residual norm 1.195694135051e-02
  5179 KSP Residual norm 1.338259629072e-02
  5180 KSP Residual norm 1.389102283443e-02
  5181 KSP Residual norm 1.267728231799e-02
  5182 KSP Residual norm 1.165462408308e-02
  5183 KSP Residual norm 1.221733246193e-02
  5184 KSP Residual norm 1.256365927293e-02
  5185 KSP Residual norm 1.147165485488e-02
  5186 KSP Residual norm 9.948083793328e-03
  5187 KSP Residual norm 8.952059063007e-03
  5188 KSP Residual norm 9.548145245048e-03
  5189 KSP Residual norm 1.198090008198e-02
  5190 KSP Residual norm 1.421032375516e-02
  5191 KSP Residual norm 1.455043651700e-02
  5192 KSP Residual norm 1.597607475038e-02
  5193 KSP Residual norm 1.731138927366e-02
  5194 KSP Residual norm 1.869657793075e-02
  5195 KSP Residual norm 2.056260700247e-02
  5196 KSP Residual norm 1.989650020402e-02
  5197 KSP Residual norm 1.644841553315e-02
  5198 KSP Residual norm 1.402123831286e-02
  5199 KSP Residual norm 1.393307731848e-02
  5200 KSP Residual norm 1.499889495236e-02
  5201 KSP Residual norm 1.512649830288e-02
  5202 KSP Residual norm 1.452302777099e-02
  5203 KSP Residual norm 1.400754830125e-02
  5204 KSP Residual norm 1.454268965046e-02
  5205 KSP Residual norm 1.605382740223e-02
  5206 KSP Residual norm 1.747113205190e-02
  5207 KSP Residual norm 1.826558199165e-02
  5208 KSP Residual norm 1.766043281495e-02
  5209 KSP Residual norm 1.624484941571e-02
  5210 KSP Residual norm 1.573189280158e-02
  5211 KSP Residual norm 1.590837291997e-02
  5212 KSP Residual norm 1.489017780109e-02
  5213 KSP Residual norm 1.299770002216e-02
  5214 KSP Residual norm 1.147567719050e-02
  5215 KSP Residual norm 1.042029489694e-02
  5216 KSP Residual norm 1.003509276822e-02
  5217 KSP Residual norm 9.768968368273e-03
  5218 KSP Residual norm 8.752247826823e-03
  5219 KSP Residual norm 7.601636512821e-03
  5220 KSP Residual norm 8.168160771245e-03
  5221 KSP Residual norm 1.080881386017e-02
  5222 KSP Residual norm 1.341820622108e-02
  5223 KSP Residual norm 1.304121223602e-02
  5224 KSP Residual norm 1.110327025048e-02
  5225 KSP Residual norm 9.743934920607e-03
  5226 KSP Residual norm 9.277908333168e-03
  5227 KSP Residual norm 8.558564414890e-03
  5228 KSP Residual norm 7.211650134836e-03
  5229 KSP Residual norm 5.988205291223e-03
  5230 KSP Residual norm 5.703158478056e-03
  5231 KSP Residual norm 5.551940465001e-03
  5232 KSP Residual norm 5.386992639716e-03
  5233 KSP Residual norm 5.019571930758e-03
  5234 KSP Residual norm 4.476459677889e-03
  5235 KSP Residual norm 3.781661865522e-03
  5236 KSP Residual norm 3.701038045348e-03
  5237 KSP Residual norm 4.429787412057e-03
  5238 KSP Residual norm 5.345586233516e-03
  5239 KSP Residual norm 5.605324989227e-03
  5240 KSP Residual norm 5.575771676464e-03
  5241 KSP Residual norm 5.831218616475e-03
  5242 KSP Residual norm 6.658094702125e-03
  5243 KSP Residual norm 7.821203358408e-03
  5244 KSP Residual norm 7.423070869094e-03
  5245 KSP Residual norm 5.436615846481e-03
  5246 KSP Residual norm 3.950016393308e-03
  5247 KSP Residual norm 3.315810664097e-03
  5248 KSP Residual norm 3.325728496516e-03
  5249 KSP Residual norm 3.126640604489e-03
  5250 KSP Residual norm 2.558728088265e-03
  5251 KSP Residual norm 2.262427999336e-03
  5252 KSP Residual norm 2.406402413605e-03
  5253 KSP Residual norm 2.997248114239e-03
  5254 KSP Residual norm 3.787470875264e-03
  5255 KSP Residual norm 4.270036535989e-03
  5256 KSP Residual norm 4.631049225251e-03
  5257 KSP Residual norm 5.218134405630e-03
  5258 KSP Residual norm 6.607068903890e-03
  5259 KSP Residual norm 7.960533351606e-03
  5260 KSP Residual norm 7.166807492011e-03
  5261 KSP Residual norm 5.997626686697e-03
  5262 KSP Residual norm 6.178378670894e-03
  5263 KSP Residual norm 7.438134165446e-03
  5264 KSP Residual norm 6.984649077495e-03
  5265 KSP Residual norm 5.136207872633e-03
  5266 KSP Residual norm 4.644114249803e-03
  5267 KSP Residual norm 5.507585266405e-03
  5268 KSP Residual norm 6.560606415636e-03
  5269 KSP Residual norm 6.299041827985e-03
  5270 KSP Residual norm 5.947565289050e-03
  5271 KSP Residual norm 6.052466081758e-03
  5272 KSP Residual norm 6.633452172370e-03
  5273 KSP Residual norm 7.343726482563e-03
  5274 KSP Residual norm 7.706364749192e-03
  5275 KSP Residual norm 7.498006751567e-03
  5276 KSP Residual norm 7.582417555133e-03
  5277 KSP Residual norm 8.575346699186e-03
  5278 KSP Residual norm 8.913395547110e-03
  5279 KSP Residual norm 7.819152327133e-03
  5280 KSP Residual norm 6.835399530654e-03
  5281 KSP Residual norm 6.616375226819e-03
  5282 KSP Residual norm 6.942442179146e-03
  5283 KSP Residual norm 6.701451226587e-03
  5284 KSP Residual norm 6.135577499091e-03
  5285 KSP Residual norm 5.841247466051e-03
  5286 KSP Residual norm 5.811567014070e-03
  5287 KSP Residual norm 6.153801526829e-03
  5288 KSP Residual norm 6.370917959567e-03
  5289 KSP Residual norm 5.974126718975e-03
  5290 KSP Residual norm 5.157197549608e-03
  5291 KSP Residual norm 4.506417439043e-03
  5292 KSP Residual norm 4.226676984224e-03
  5293 KSP Residual norm 4.476507758499e-03
  5294 KSP Residual norm 5.282982936160e-03
  5295 KSP Residual norm 5.736576221504e-03
  5296 KSP Residual norm 4.864534830334e-03
  5297 KSP Residual norm 4.218531524174e-03
  5298 KSP Residual norm 4.315266172564e-03
  5299 KSP Residual norm 4.359964728158e-03
  5300 KSP Residual norm 4.042754202727e-03
  5301 KSP Residual norm 3.587051339079e-03
  5302 KSP Residual norm 3.354907241891e-03
  5303 KSP Residual norm 3.598450594975e-03
  5304 KSP Residual norm 3.825154915405e-03
  5305 KSP Residual norm 3.696607710441e-03
  5306 KSP Residual norm 3.609045564149e-03
  5307 KSP Residual norm 3.785466801854e-03
  5308 KSP Residual norm 4.186759102805e-03
  5309 KSP Residual norm 4.485623763844e-03
  5310 KSP Residual norm 4.194450565602e-03
  5311 KSP Residual norm 3.792055641733e-03
  5312 KSP Residual norm 3.922425745534e-03
  5313 KSP Residual norm 4.447457413111e-03
  5314 KSP Residual norm 4.232897818345e-03
  5315 KSP Residual norm 3.658716643868e-03
  5316 KSP Residual norm 3.287345091224e-03
  5317 KSP Residual norm 2.969861678067e-03
  5318 KSP Residual norm 2.548695342826e-03
  5319 KSP Residual norm 2.186322831664e-03
  5320 KSP Residual norm 1.865956342423e-03
  5321 KSP Residual norm 1.639912204247e-03
  5322 KSP Residual norm 1.612372144684e-03
  5323 KSP Residual norm 1.548680511225e-03
  5324 KSP Residual norm 1.463191038880e-03
  5325 KSP Residual norm 1.485551702543e-03
  5326 KSP Residual norm 1.578625931248e-03
  5327 KSP Residual norm 1.678239612159e-03
  5328 KSP Residual norm 1.817246820426e-03
  5329 KSP Residual norm 2.093034605559e-03
  5330 KSP Residual norm 2.379539180216e-03
  5331 KSP Residual norm 2.281340139175e-03
  5332 KSP Residual norm 2.113771530724e-03
  5333 KSP Residual norm 1.953018997233e-03
  5334 KSP Residual norm 1.787146918122e-03
  5335 KSP Residual norm 1.673173151466e-03
  5336 KSP Residual norm 1.673879455218e-03
  5337 KSP Residual norm 1.610088340176e-03
  5338 KSP Residual norm 1.375386601546e-03
  5339 KSP Residual norm 1.204256628393e-03
  5340 KSP Residual norm 1.172068834485e-03
  5341 KSP Residual norm 1.167299749369e-03
  5342 KSP Residual norm 1.084987721925e-03
  5343 KSP Residual norm 1.048608500019e-03
  5344 KSP Residual norm 1.182894398543e-03
  5345 KSP Residual norm 1.453015709397e-03
  5346 KSP Residual norm 1.767447466914e-03
  5347 KSP Residual norm 2.047673873151e-03
  5348 KSP Residual norm 2.165888451651e-03
  5349 KSP Residual norm 2.345026100221e-03
  5350 KSP Residual norm 2.699483159671e-03
  5351 KSP Residual norm 3.029545334055e-03
  5352 KSP Residual norm 3.098176374562e-03
  5353 KSP Residual norm 2.863551593303e-03
  5354 KSP Residual norm 2.665654364024e-03
  5355 KSP Residual norm 2.591283133431e-03
  5356 KSP Residual norm 2.494178966467e-03
  5357 KSP Residual norm 2.197196779720e-03
  5358 KSP Residual norm 1.911928992764e-03
  5359 KSP Residual norm 1.870311203534e-03
  5360 KSP Residual norm 1.849589844497e-03
  5361 KSP Residual norm 1.742174612829e-03
  5362 KSP Residual norm 1.629652677123e-03
  5363 KSP Residual norm 1.711177703496e-03
  5364 KSP Residual norm 1.912003863409e-03
  5365 KSP Residual norm 1.960739899509e-03
  5366 KSP Residual norm 1.901441585670e-03
  5367 KSP Residual norm 1.925905953983e-03
  5368 KSP Residual norm 1.986371216477e-03
  5369 KSP Residual norm 1.957363818653e-03
  5370 KSP Residual norm 2.053645174170e-03
  5371 KSP Residual norm 2.330000687696e-03
  5372 KSP Residual norm 2.490599777998e-03
  5373 KSP Residual norm 2.764168582941e-03
  5374 KSP Residual norm 3.333090739671e-03
  5375 KSP Residual norm 3.299297499929e-03
  5376 KSP Residual norm 2.943633959223e-03
  5377 KSP Residual norm 3.020934084618e-03
  5378 KSP Residual norm 3.559496348939e-03
  5379 KSP Residual norm 3.750851249493e-03
  5380 KSP Residual norm 3.057948346840e-03
  5381 KSP Residual norm 2.483756421269e-03
  5382 KSP Residual norm 2.313690894628e-03
  5383 KSP Residual norm 2.284330872334e-03
  5384 KSP Residual norm 2.067498440454e-03
  5385 KSP Residual norm 1.900828101659e-03
  5386 KSP Residual norm 1.896266700462e-03
  5387 KSP Residual norm 2.053747040898e-03
  5388 KSP Residual norm 2.344842302619e-03
  5389 KSP Residual norm 2.448419012429e-03
  5390 KSP Residual norm 2.216759496229e-03
  5391 KSP Residual norm 2.143984695538e-03
  5392 KSP Residual norm 2.267819864387e-03
  5393 KSP Residual norm 2.100480202825e-03
  5394 KSP Residual norm 1.758421892352e-03
  5395 KSP Residual norm 1.624170996767e-03
  5396 KSP Residual norm 1.623729138292e-03
  5397 KSP Residual norm 1.715904587707e-03
  5398 KSP Residual norm 1.628547705282e-03
  5399 KSP Residual norm 1.369979652687e-03
  5400 KSP Residual norm 1.197552314130e-03
  5401 KSP Residual norm 1.235218715062e-03
  5402 KSP Residual norm 1.251795156399e-03
  5403 KSP Residual norm 1.055398984970e-03
  5404 KSP Residual norm 8.693521818439e-04
  5405 KSP Residual norm 7.765063210340e-04
  5406 KSP Residual norm 8.061923680833e-04
  5407 KSP Residual norm 8.149611894986e-04
  5408 KSP Residual norm 7.216353075345e-04
  5409 KSP Residual norm 6.957923218712e-04
  5410 KSP Residual norm 7.951162909202e-04
  5411 KSP Residual norm 8.469759210108e-04
  5412 KSP Residual norm 8.136838889844e-04
  5413 KSP Residual norm 8.467882306835e-04
  5414 KSP Residual norm 9.013272552227e-04
  5415 KSP Residual norm 9.403081361950e-04
  5416 KSP Residual norm 9.849734302925e-04
  5417 KSP Residual norm 9.031059445749e-04
  5418 KSP Residual norm 7.554833038730e-04
  5419 KSP Residual norm 6.641867816478e-04
  5420 KSP Residual norm 5.882686720478e-04
  5421 KSP Residual norm 5.146939792882e-04
  5422 KSP Residual norm 4.958902421118e-04
  5423 KSP Residual norm 4.933509916772e-04
  5424 KSP Residual norm 4.882247397423e-04
  5425 KSP Residual norm 4.747048969735e-04
  5426 KSP Residual norm 4.784796763508e-04
  5427 KSP Residual norm 4.999307350715e-04
  5428 KSP Residual norm 5.243624785548e-04
  5429 KSP Residual norm 5.483302830145e-04
  5430 KSP Residual norm 6.131506349290e-04
  5431 KSP Residual norm 6.352148222316e-04
  5432 KSP Residual norm 5.757184833653e-04
  5433 KSP Residual norm 5.968829149853e-04
  5434 KSP Residual norm 6.817250660139e-04
  5435 KSP Residual norm 6.874654095218e-04
  5436 KSP Residual norm 6.585349986495e-04
  5437 KSP Residual norm 6.565726686462e-04
  5438 KSP Residual norm 6.764294138953e-04
  5439 KSP Residual norm 7.278807566020e-04
  5440 KSP Residual norm 8.085586887535e-04
  5441 KSP Residual norm 7.630429361587e-04
  5442 KSP Residual norm 6.206752290149e-04
  5443 KSP Residual norm 5.819511475547e-04
  5444 KSP Residual norm 6.465257952358e-04
  5445 KSP Residual norm 6.454210708622e-04
  5446 KSP Residual norm 5.561588402338e-04
  5447 KSP Residual norm 4.881485648730e-04
  5448 KSP Residual norm 5.141944068032e-04
  5449 KSP Residual norm 5.888141774876e-04
  5450 KSP Residual norm 5.735795430384e-04
  5451 KSP Residual norm 5.252693912947e-04
  5452 KSP Residual norm 5.472216968971e-04
  5453 KSP Residual norm 6.429222011012e-04
  5454 KSP Residual norm 7.053246569235e-04
  5455 KSP Residual norm 7.429112339675e-04
  5456 KSP Residual norm 7.693895427094e-04
  5457 KSP Residual norm 8.491570316152e-04
  5458 KSP Residual norm 9.660910274535e-04
  5459 KSP Residual norm 9.911439508787e-04
  5460 KSP Residual norm 9.367592708760e-04
  5461 KSP Residual norm 9.912179534390e-04
  5462 KSP Residual norm 1.168263072062e-03
  5463 KSP Residual norm 1.256266202974e-03
  5464 KSP Residual norm 1.171014256605e-03
  5465 KSP Residual norm 1.132362106124e-03
  5466 KSP Residual norm 1.166902839267e-03
  5467 KSP Residual norm 1.182462127042e-03
  5468 KSP Residual norm 1.070222512522e-03
  5469 KSP Residual norm 9.206785642296e-04
  5470 KSP Residual norm 8.413939349152e-04
  5471 KSP Residual norm 8.537473414134e-04
  5472 KSP Residual norm 9.202916667921e-04
  5473 KSP Residual norm 8.716198936471e-04
  5474 KSP Residual norm 8.713846114770e-04
  5475 KSP Residual norm 9.529167027262e-04
  5476 KSP Residual norm 9.668177988798e-04
  5477 KSP Residual norm 8.555935437774e-04
  5478 KSP Residual norm 7.819021412871e-04
  5479 KSP Residual norm 8.279334404567e-04
  5480 KSP Residual norm 8.632508766114e-04
  5481 KSP Residual norm 7.624863590967e-04
  5482 KSP Residual norm 7.082102483952e-04
  5483 KSP Residual norm 6.948532033834e-04
  5484 KSP Residual norm 6.398521462701e-04
  5485 KSP Residual norm 5.842358819130e-04
  5486 KSP Residual norm 5.534344985165e-04
  5487 KSP Residual norm 5.157037674218e-04
  5488 KSP Residual norm 5.159158713989e-04
  5489 KSP Residual norm 5.823786140097e-04
  5490 KSP Residual norm 5.981525457366e-04
  5491 KSP Residual norm 5.570890062575e-04
  5492 KSP Residual norm 5.450117473878e-04
  5493 KSP Residual norm 5.295188269093e-04
  5494 KSP Residual norm 4.938334956021e-04
  5495 KSP Residual norm 4.886598351553e-04
  5496 KSP Residual norm 5.163247130083e-04
  5497 KSP Residual norm 4.899156276800e-04
  5498 KSP Residual norm 4.760163279581e-04
  5499 KSP Residual norm 5.104929275361e-04
  5500 KSP Residual norm 5.518958695104e-04
  5501 KSP Residual norm 5.204581735775e-04
  5502 KSP Residual norm 4.702311113589e-04
  5503 KSP Residual norm 4.631875978934e-04
  5504 KSP Residual norm 5.069550315656e-04
  5505 KSP Residual norm 5.428603301611e-04
  5506 KSP Residual norm 5.157784070885e-04
  5507 KSP Residual norm 4.556783214684e-04
  5508 KSP Residual norm 4.245485377656e-04
  5509 KSP Residual norm 4.268921172213e-04
  5510 KSP Residual norm 4.283720223248e-04
  5511 KSP Residual norm 3.867115304653e-04
  5512 KSP Residual norm 3.352428401407e-04
  5513 KSP Residual norm 3.174533887163e-04
  5514 KSP Residual norm 2.873558066900e-04
  5515 KSP Residual norm 2.543423152381e-04
  5516 KSP Residual norm 2.205920585448e-04
  5517 KSP Residual norm 1.904484367096e-04
  5518 KSP Residual norm 1.762030537920e-04
  5519 KSP Residual norm 1.713669432590e-04
  5520 KSP Residual norm 1.484616200034e-04
  5521 KSP Residual norm 1.291725557462e-04
  5522 KSP Residual norm 1.279656720388e-04
  5523 KSP Residual norm 1.339253399541e-04
  5524 KSP Residual norm 1.130742007400e-04
  5525 KSP Residual norm 9.226543504901e-05
  5526 KSP Residual norm 9.337781091670e-05
  5527 KSP Residual norm 1.033740271140e-04
  5528 KSP Residual norm 1.077084271398e-04
  5529 KSP Residual norm 1.078378465288e-04
  5530 KSP Residual norm 1.142127592458e-04
  5531 KSP Residual norm 1.296306433532e-04
  5532 KSP Residual norm 1.397546422793e-04
  5533 KSP Residual norm 1.360697136744e-04
  5534 KSP Residual norm 1.330607527380e-04
  5535 KSP Residual norm 1.282371457806e-04
  5536 KSP Residual norm 1.300163013936e-04
  5537 KSP Residual norm 1.403428137837e-04
  5538 KSP Residual norm 1.366756756029e-04
  5539 KSP Residual norm 1.142203581770e-04
  5540 KSP Residual norm 1.058979001250e-04
  5541 KSP Residual norm 1.061069452013e-04
  5542 KSP Residual norm 1.025637608431e-04
  5543 KSP Residual norm 9.764269999651e-05
  5544 KSP Residual norm 9.671340362633e-05
  5545 KSP Residual norm 1.025095953929e-04
  5546 KSP Residual norm 1.078139515394e-04
  5547 KSP Residual norm 1.150143576937e-04
  5548 KSP Residual norm 1.202196098788e-04
  5549 KSP Residual norm 1.276574943103e-04
  5550 KSP Residual norm 1.341955162129e-04
  5551 KSP Residual norm 1.496811108075e-04
  5552 KSP Residual norm 1.696865048115e-04
  5553 KSP Residual norm 1.805843626317e-04
  5554 KSP Residual norm 1.773557321230e-04
  5555 KSP Residual norm 1.740569548714e-04
  5556 KSP Residual norm 1.893071345861e-04
  5557 KSP Residual norm 2.000699092322e-04
  5558 KSP Residual norm 1.976560690861e-04
  5559 KSP Residual norm 1.968881124422e-04
  5560 KSP Residual norm 2.015241556695e-04
  5561 KSP Residual norm 2.136191320420e-04
  5562 KSP Residual norm 2.041253067977e-04
  5563 KSP Residual norm 1.817563216214e-04
  5564 KSP Residual norm 1.820620737751e-04
  5565 KSP Residual norm 2.040498486297e-04
  5566 KSP Residual norm 2.191985137190e-04
  5567 KSP Residual norm 2.110098065809e-04
  5568 KSP Residual norm 1.936365651161e-04
  5569 KSP Residual norm 1.950353541804e-04
  5570 KSP Residual norm 2.361640077098e-04
  5571 KSP Residual norm 2.909394547983e-04
  5572 KSP Residual norm 3.174936992635e-04
  5573 KSP Residual norm 3.128069202910e-04
  5574 KSP Residual norm 2.963798382496e-04
  5575 KSP Residual norm 2.977631698650e-04
  5576 KSP Residual norm 3.074171672751e-04
  5577 KSP Residual norm 3.124346464784e-04
  5578 KSP Residual norm 3.147092932601e-04
  5579 KSP Residual norm 3.289911755945e-04
  5580 KSP Residual norm 3.401372379534e-04
  5581 KSP Residual norm 3.459055044411e-04
  5582 KSP Residual norm 3.494742390363e-04
  5583 KSP Residual norm 3.241751533875e-04
  5584 KSP Residual norm 2.984716177779e-04
  5585 KSP Residual norm 2.841187218740e-04
  5586 KSP Residual norm 2.500963203614e-04
  5587 KSP Residual norm 1.985559588665e-04
  5588 KSP Residual norm 1.813063461890e-04
  5589 KSP Residual norm 1.884995846394e-04
  5590 KSP Residual norm 1.862124949968e-04
  5591 KSP Residual norm 1.576137634920e-04
  5592 KSP Residual norm 1.314333115333e-04
  5593 KSP Residual norm 1.233170540821e-04
  5594 KSP Residual norm 1.256715269944e-04
  5595 KSP Residual norm 1.274156428359e-04
  5596 KSP Residual norm 1.304975747973e-04
  5597 KSP Residual norm 1.403750917018e-04
  5598 KSP Residual norm 1.518813122260e-04
  5599 KSP Residual norm 1.594566833030e-04
  5600 KSP Residual norm 1.607368647173e-04
  5601 KSP Residual norm 1.512590127040e-04
  5602 KSP Residual norm 1.503473571558e-04
  5603 KSP Residual norm 1.593245697035e-04
  5604 KSP Residual norm 1.564282073915e-04
  5605 KSP Residual norm 1.528019132185e-04
  5606 KSP Residual norm 1.554991897247e-04
  5607 KSP Residual norm 1.505493314950e-04
  5608 KSP Residual norm 1.494931849597e-04
  5609 KSP Residual norm 1.543089634330e-04
  5610 KSP Residual norm 1.525547365678e-04
  5611 KSP Residual norm 1.443624500493e-04
  5612 KSP Residual norm 1.413876022153e-04
  5613 KSP Residual norm 1.340625797578e-04
  5614 KSP Residual norm 1.190953314077e-04
  5615 KSP Residual norm 1.092086393545e-04
  5616 KSP Residual norm 1.013878003574e-04
  5617 KSP Residual norm 8.985011747366e-05
  5618 KSP Residual norm 7.803686905695e-05
  5619 KSP Residual norm 6.968710138343e-05
  0 KSP Residual norm 5.405774214400e+04
    Residual norms for fieldsplit_FE_split_ solve.
    0 KSP Residual norm 7.439873800415e+00
    1 KSP Residual norm 2.271092312202e+00
    2 KSP Residual norm 1.579282324756e+00
    3 KSP Residual norm 1.107108552974e+00
    4 KSP Residual norm 8.906995999187e-01
    5 KSP Residual norm 7.119535581527e-01
    6 KSP Residual norm 6.292448465808e-01
    7 KSP Residual norm 5.574190632829e-01
    8 KSP Residual norm 4.914453903768e-01
    9 KSP Residual norm 4.169590427313e-01
   10 KSP Residual norm 3.833759307828e-01
   11 KSP Residual norm 3.525084900775e-01
   12 KSP Residual norm 3.090712658867e-01
   13 KSP Residual norm 3.072058092791e-01
   14 KSP Residual norm 2.791154478844e-01
   15 KSP Residual norm 2.596487823324e-01
   16 KSP Residual norm 2.454855113839e-01
   17 KSP Residual norm 2.323657304086e-01
   18 KSP Residual norm 2.180987080607e-01
   19 KSP Residual norm 2.071787317658e-01
   20 KSP Residual norm 1.892488656995e-01
   21 KSP Residual norm 1.812493522062e-01
   22 KSP Residual norm 1.876453055369e-01
   23 KSP Residual norm 1.683189793079e-01
   24 KSP Residual norm 1.543469424065e-01
   25 KSP Residual norm 1.496069368476e-01
   26 KSP Residual norm 1.493645624754e-01
   27 KSP Residual norm 1.525727733866e-01
   28 KSP Residual norm 1.504760809841e-01
   29 KSP Residual norm 1.398787428655e-01
   30 KSP Residual norm 1.377742552240e-01
   31 KSP Residual norm 1.350150247010e-01
   32 KSP Residual norm 1.275144910850e-01
   33 KSP Residual norm 1.273327004584e-01
   34 KSP Residual norm 1.216415065625e-01
   35 KSP Residual norm 1.109570051668e-01
   36 KSP Residual norm 1.074358443291e-01
   37 KSP Residual norm 1.061971546557e-01
   38 KSP Residual norm 1.067809057557e-01
   39 KSP Residual norm 1.063479786887e-01
   40 KSP Residual norm 1.034518470284e-01
   41 KSP Residual norm 9.721337391778e-02
   42 KSP Residual norm 9.699203830334e-02
   43 KSP Residual norm 9.481065986826e-02
   44 KSP Residual norm 9.136671340793e-02
   45 KSP Residual norm 8.851274329317e-02
   46 KSP Residual norm 8.467762039012e-02
   47 KSP Residual norm 8.471801429555e-02
   48 KSP Residual norm 8.278633364455e-02
   49 KSP Residual norm 7.838491006512e-02
   50 KSP Residual norm 7.670240644506e-02
   51 KSP Residual norm 8.043224588019e-02
   52 KSP Residual norm 8.363745629948e-02
   53 KSP Residual norm 7.940546973611e-02
   54 KSP Residual norm 7.456475032696e-02
   55 KSP Residual norm 7.700637275547e-02
   56 KSP Residual norm 7.543373247528e-02
   57 KSP Residual norm 7.094501517914e-02
   58 KSP Residual norm 7.075418803924e-02
   59 KSP Residual norm 6.974463189188e-02
   60 KSP Residual norm 6.564358161289e-02
   61 KSP Residual norm 6.777118961072e-02
   62 KSP Residual norm 6.572645071229e-02
   63 KSP Residual norm 6.592491054825e-02
   64 KSP Residual norm 6.361704393145e-02
   65 KSP Residual norm 6.091631661495e-02
   66 KSP Residual norm 6.045947178947e-02
   67 KSP Residual norm 5.960456641459e-02
   68 KSP Residual norm 5.849383480514e-02
   69 KSP Residual norm 5.706157714189e-02
   70 KSP Residual norm 5.785957008296e-02
   71 KSP Residual norm 5.598254854109e-02
   72 KSP Residual norm 5.456921702305e-02
   73 KSP Residual norm 5.612718298077e-02
   74 KSP Residual norm 5.404331315421e-02
   75 KSP Residual norm 5.445184161126e-02
   76 KSP Residual norm 5.513790692539e-02
   77 KSP Residual norm 5.603152577219e-02
   78 KSP Residual norm 5.594578881463e-02
   79 KSP Residual norm 5.270506297482e-02
   80 KSP Residual norm 4.969434451616e-02
   81 KSP Residual norm 5.066917256846e-02
   82 KSP Residual norm 5.145815352597e-02
   83 KSP Residual norm 4.855115729361e-02
   84 KSP Residual norm 4.872335394452e-02
   85 KSP Residual norm 4.674867276039e-02
   86 KSP Residual norm 4.754130141657e-02
   87 KSP Residual norm 4.833727177651e-02
   88 KSP Residual norm 4.753752603403e-02
   89 KSP Residual norm 4.711922842054e-02
   90 KSP Residual norm 4.405539388922e-02
   91 KSP Residual norm 4.296516931381e-02
   92 KSP Residual norm 4.339330987856e-02
   93 KSP Residual norm 4.309048328104e-02
   94 KSP Residual norm 4.249286390589e-02
   95 KSP Residual norm 4.279072317861e-02
   96 KSP Residual norm 4.138481489705e-02
   97 KSP Residual norm 4.075783749198e-02
   98 KSP Residual norm 4.150832258048e-02
   99 KSP Residual norm 4.196726309881e-02
  100 KSP Residual norm 4.511508557881e-02
  101 KSP Residual norm 4.353430099295e-02
  102 KSP Residual norm 4.110659276090e-02
  103 KSP Residual norm 4.216362776668e-02
  104 KSP Residual norm 4.132142431466e-02
  105 KSP Residual norm 3.937463571948e-02
  106 KSP Residual norm 3.847820147612e-02
  107 KSP Residual norm 3.903461144864e-02
  108 KSP Residual norm 3.873827003588e-02
  109 KSP Residual norm 3.757181226921e-02
  110 KSP Residual norm 3.713370747089e-02
  111 KSP Residual norm 3.797595762562e-02
  112 KSP Residual norm 3.904892207809e-02
  113 KSP Residual norm 3.832213482446e-02
  114 KSP Residual norm 3.673918137725e-02
  115 KSP Residual norm 3.568169366392e-02
  116 KSP Residual norm 3.463483623212e-02
  117 KSP Residual norm 3.474865380315e-02
  118 KSP Residual norm 3.369100450734e-02
  119 KSP Residual norm 3.429462851161e-02
  120 KSP Residual norm 3.356928597959e-02
  121 KSP Residual norm 3.388831153274e-02
  122 KSP Residual norm 3.403530170365e-02
  123 KSP Residual norm 3.432423924461e-02
  124 KSP Residual norm 3.480510081872e-02
  125 KSP Residual norm 3.501270104127e-02
  126 KSP Residual norm 3.436014578560e-02
  127 KSP Residual norm 3.313137022795e-02
  128 KSP Residual norm 3.224202549572e-02
  129 KSP Residual norm 3.282496094068e-02
  130 KSP Residual norm 3.179581680589e-02
  131 KSP Residual norm 3.126804650993e-02
  132 KSP Residual norm 3.164061472181e-02
  133 KSP Residual norm 3.064596217610e-02
  134 KSP Residual norm 3.123484050542e-02
  135 KSP Residual norm 3.098163173034e-02
  136 KSP Residual norm 3.021371993367e-02
  137 KSP Residual norm 2.997438018349e-02
  138 KSP Residual norm 2.996861618503e-02
  139 KSP Residual norm 2.952174027773e-02
  140 KSP Residual norm 2.781275108201e-02
  141 KSP Residual norm 2.831949666222e-02
  142 KSP Residual norm 2.943315787910e-02
  143 KSP Residual norm 2.861351453584e-02
  144 KSP Residual norm 2.857243223511e-02
  145 KSP Residual norm 2.776445330757e-02
  146 KSP Residual norm 2.815377297347e-02
  147 KSP Residual norm 2.833952777968e-02
  148 KSP Residual norm 2.820315095721e-02
  149 KSP Residual norm 2.887229075208e-02
  150 KSP Residual norm 2.979067721535e-02
  151 KSP Residual norm 2.815700116316e-02
  152 KSP Residual norm 2.680023054442e-02
  153 KSP Residual norm 2.639722486097e-02
  154 KSP Residual norm 2.662100285008e-02
  155 KSP Residual norm 2.675384875846e-02
  156 KSP Residual norm 2.701241246267e-02
  157 KSP Residual norm 2.643754530991e-02
  158 KSP Residual norm 2.592855185871e-02
  159 KSP Residual norm 2.618977338412e-02
  160 KSP Residual norm 2.586809270174e-02
  161 KSP Residual norm 2.576998073277e-02
  162 KSP Residual norm 2.540380238842e-02
  163 KSP Residual norm 2.495114311948e-02
  164 KSP Residual norm 2.455716236236e-02
  165 KSP Residual norm 2.428454731484e-02
  166 KSP Residual norm 2.464342635564e-02
  167 KSP Residual norm 2.452483143323e-02
  168 KSP Residual norm 2.481544666658e-02
  169 KSP Residual norm 2.477918836230e-02
  170 KSP Residual norm 2.359566978599e-02
  171 KSP Residual norm 2.418262225393e-02
  172 KSP Residual norm 2.564699145458e-02
  173 KSP Residual norm 2.500981972636e-02
  174 KSP Residual norm 2.471425418109e-02
  175 KSP Residual norm 2.445163739021e-02
  176 KSP Residual norm 2.385452288757e-02
  177 KSP Residual norm 2.428112914859e-02
  178 KSP Residual norm 2.291705127975e-02
  179 KSP Residual norm 2.271629416191e-02
  180 KSP Residual norm 2.345648624740e-02
  181 KSP Residual norm 2.411307961322e-02
  182 KSP Residual norm 2.305778032055e-02
  183 KSP Residual norm 2.363029408956e-02
  184 KSP Residual norm 2.334430183050e-02
  185 KSP Residual norm 2.288119542251e-02
  186 KSP Residual norm 2.268194883960e-02
  187 KSP Residual norm 2.194114600599e-02
  188 KSP Residual norm 2.138125374716e-02
  189 KSP Residual norm 2.122308178911e-02
  190 KSP Residual norm 2.167011211336e-02
  191 KSP Residual norm 2.124093196590e-02
  192 KSP Residual norm 2.254672827834e-02
  193 KSP Residual norm 2.259893744483e-02
  194 KSP Residual norm 2.124131449373e-02
  195 KSP Residual norm 2.128570772460e-02
  196 KSP Residual norm 2.272443514094e-02
  197 KSP Residual norm 2.248357368551e-02
  198 KSP Residual norm 2.186082830509e-02
  199 KSP Residual norm 2.193211823715e-02
  200 KSP Residual norm 2.092614010486e-02
  201 KSP Residual norm 2.058552529496e-02
  202 KSP Residual norm 2.093249615703e-02
  203 KSP Residual norm 2.045325798910e-02
  204 KSP Residual norm 2.043511462793e-02
  205 KSP Residual norm 2.037030539329e-02
  206 KSP Residual norm 2.103460538310e-02
  207 KSP Residual norm 2.069703021464e-02
  208 KSP Residual norm 1.978197990018e-02
  209 KSP Residual norm 1.997727225256e-02
  210 KSP Residual norm 2.014133842310e-02
  211 KSP Residual norm 1.909869680533e-02
  212 KSP Residual norm 1.898652371759e-02
  213 KSP Residual norm 1.917618301995e-02
  214 KSP Residual norm 1.903312625797e-02
  215 KSP Residual norm 1.935123404273e-02
  216 KSP Residual norm 1.876736458793e-02
  217 KSP Residual norm 1.907165437333e-02
  218 KSP Residual norm 1.931891473034e-02
  219 KSP Residual norm 1.947700505686e-02
  220 KSP Residual norm 1.946867709414e-02
  221 KSP Residual norm 1.975097371142e-02
  222 KSP Residual norm 1.936728796435e-02
  223 KSP Residual norm 1.861169070605e-02
  224 KSP Residual norm 1.821669203618e-02
  225 KSP Residual norm 1.830030189024e-02
  226 KSP Residual norm 1.847574748920e-02
  227 KSP Residual norm 1.821934647650e-02
  228 KSP Residual norm 1.858550789703e-02
  229 KSP Residual norm 1.790620122765e-02
  230 KSP Residual norm 1.736046756570e-02
  231 KSP Residual norm 1.808056503558e-02
  232 KSP Residual norm 1.831571970355e-02
  233 KSP Residual norm 1.782550071852e-02
  234 KSP Residual norm 1.704250503644e-02
  235 KSP Residual norm 1.775557915607e-02
  236 KSP Residual norm 1.749168705311e-02
  237 KSP Residual norm 1.716635016316e-02
  238 KSP Residual norm 1.697804812505e-02
  239 KSP Residual norm 1.719949296811e-02
  240 KSP Residual norm 1.798197854926e-02
  241 KSP Residual norm 1.773491134572e-02
  242 KSP Residual norm 1.724256440113e-02
  243 KSP Residual norm 1.777189498102e-02
  244 KSP Residual norm 1.819945790203e-02
  245 KSP Residual norm 1.762431996374e-02
  246 KSP Residual norm 1.711668380042e-02
  247 KSP Residual norm 1.717847950917e-02
  248 KSP Residual norm 1.675314264329e-02
  249 KSP Residual norm 1.672527101557e-02
  250 KSP Residual norm 1.652103275422e-02
  251 KSP Residual norm 1.696676153706e-02
  252 KSP Residual norm 1.715357344334e-02
  253 KSP Residual norm 1.706981861601e-02
  254 KSP Residual norm 1.696030869204e-02
  255 KSP Residual norm 1.763423572015e-02
  256 KSP Residual norm 1.829751997263e-02
  257 KSP Residual norm 1.972223165522e-02
  258 KSP Residual norm 2.130118969187e-02
  259 KSP Residual norm 2.315722127923e-02
  260 KSP Residual norm 2.684768883739e-02
  261 KSP Residual norm 3.348163940639e-02
  262 KSP Residual norm 4.199127730378e-02
  263 KSP Residual norm 5.398653105045e-02
  264 KSP Residual norm 6.821839369420e-02
  265 KSP Residual norm 8.029032178293e-02
  266 KSP Residual norm 8.815811508553e-02
  267 KSP Residual norm 8.962694266764e-02
  268 KSP Residual norm 8.065993997821e-02
  269 KSP Residual norm 6.648938465331e-02
  270 KSP Residual norm 5.345676431768e-02
  271 KSP Residual norm 3.972291572909e-02
  272 KSP Residual norm 2.946517479139e-02
  273 KSP Residual norm 2.384222409654e-02
  274 KSP Residual norm 2.191852135161e-02
  275 KSP Residual norm 2.190584659264e-02
  276 KSP Residual norm 2.207283053774e-02
  277 KSP Residual norm 2.285429680636e-02
  278 KSP Residual norm 2.042181640152e-02
  279 KSP Residual norm 1.666191118634e-02
  280 KSP Residual norm 1.233344503183e-02
  281 KSP Residual norm 9.732943526464e-03
  282 KSP Residual norm 8.231148322685e-03
  283 KSP Residual norm 7.658532417128e-03
  284 KSP Residual norm 7.159090758549e-03
  285 KSP Residual norm 6.837740854101e-03
  286 KSP Residual norm 6.771864567159e-03
  287 KSP Residual norm 6.506633131436e-03
  288 KSP Residual norm 6.552854756680e-03
  289 KSP Residual norm 6.465354304817e-03
  290 KSP Residual norm 6.348201270809e-03
  291 KSP Residual norm 6.054566113069e-03
  292 KSP Residual norm 5.368641816405e-03
  293 KSP Residual norm 4.740328570452e-03
  294 KSP Residual norm 4.455220605625e-03
  295 KSP Residual norm 4.414378942258e-03
  296 KSP Residual norm 4.365393288580e-03
  297 KSP Residual norm 4.112409955106e-03
  298 KSP Residual norm 3.683251112994e-03
  299 KSP Residual norm 3.338614520090e-03
  300 KSP Residual norm 3.099327570392e-03
  301 KSP Residual norm 3.109917829137e-03
  302 KSP Residual norm 3.004996253210e-03
  303 KSP Residual norm 2.830520603323e-03
  304 KSP Residual norm 2.748235291994e-03
  305 KSP Residual norm 2.914293446395e-03
  306 KSP Residual norm 2.780149150920e-03
  307 KSP Residual norm 2.608542174674e-03
  308 KSP Residual norm 2.404201656147e-03
  309 KSP Residual norm 2.247889289592e-03
  310 KSP Residual norm 2.359008329300e-03
  311 KSP Residual norm 2.662652962160e-03
  312 KSP Residual norm 2.917896860107e-03
  313 KSP Residual norm 2.781060424836e-03
  314 KSP Residual norm 2.499901538412e-03
  315 KSP Residual norm 2.318409392919e-03
  316 KSP Residual norm 2.237948977105e-03
  317 KSP Residual norm 2.275842789015e-03
  318 KSP Residual norm 2.095361798572e-03
  319 KSP Residual norm 1.939363510796e-03
  320 KSP Residual norm 1.824756647376e-03
  321 KSP Residual norm 1.855785739942e-03
  322 KSP Residual norm 1.876266124266e-03
  323 KSP Residual norm 1.706083418355e-03
  324 KSP Residual norm 1.504223272392e-03
  325 KSP Residual norm 1.367003023878e-03
  326 KSP Residual norm 1.325025357987e-03
  327 KSP Residual norm 1.217685553397e-03
  328 KSP Residual norm 1.147595137980e-03
  329 KSP Residual norm 1.140757899810e-03
  330 KSP Residual norm 1.161337539671e-03
  331 KSP Residual norm 1.189634577655e-03
  332 KSP Residual norm 1.156853032944e-03
  333 KSP Residual norm 1.168543981069e-03
  334 KSP Residual norm 1.255758863060e-03
  335 KSP Residual norm 1.329900079847e-03
  336 KSP Residual norm 1.277788599679e-03
  337 KSP Residual norm 1.156283394140e-03
  338 KSP Residual norm 1.170787202744e-03
  339 KSP Residual norm 1.165756028629e-03
  340 KSP Residual norm 1.149594359750e-03
  341 KSP Residual norm 1.035743087984e-03
  342 KSP Residual norm 9.055748010466e-04
  343 KSP Residual norm 8.729284667762e-04
  344 KSP Residual norm 9.123661560199e-04
  345 KSP Residual norm 9.403865973752e-04
  346 KSP Residual norm 9.397482648680e-04
  347 KSP Residual norm 9.781230092460e-04
  348 KSP Residual norm 1.028764754662e-03
  349 KSP Residual norm 1.098227372587e-03
  350 KSP Residual norm 1.131938817545e-03
  351 KSP Residual norm 1.178183837363e-03
  352 KSP Residual norm 1.219263604270e-03
  353 KSP Residual norm 1.285550443119e-03
  354 KSP Residual norm 1.314390656564e-03
  355 KSP Residual norm 1.280155123264e-03
  356 KSP Residual norm 1.337317413181e-03
  357 KSP Residual norm 1.375269807467e-03
  358 KSP Residual norm 1.339949505912e-03
  359 KSP Residual norm 1.312858194973e-03
  360 KSP Residual norm 1.302230401883e-03
  361 KSP Residual norm 1.296953236606e-03
  362 KSP Residual norm 1.241958131296e-03
  363 KSP Residual norm 1.317399611984e-03
  364 KSP Residual norm 1.404700632013e-03
  365 KSP Residual norm 1.465377387279e-03
  366 KSP Residual norm 1.449387099771e-03
  367 KSP Residual norm 1.340755308031e-03
  368 KSP Residual norm 1.276373010248e-03
  369 KSP Residual norm 1.300492007224e-03
  370 KSP Residual norm 1.305680420594e-03
  371 KSP Residual norm 1.247563315763e-03
  372 KSP Residual norm 1.215067995838e-03
  373 KSP Residual norm 1.245842567847e-03
  374 KSP Residual norm 1.248065264454e-03
  375 KSP Residual norm 1.279964483758e-03
  376 KSP Residual norm 1.296017171744e-03
  377 KSP Residual norm 1.322475758719e-03
  378 KSP Residual norm 1.346553928101e-03
  379 KSP Residual norm 1.409217159475e-03
  380 KSP Residual norm 1.427387037000e-03
  381 KSP Residual norm 1.385982705722e-03
  382 KSP Residual norm 1.326140475173e-03
  383 KSP Residual norm 1.363313832696e-03
  384 KSP Residual norm 1.399869841773e-03
  385 KSP Residual norm 1.382389217698e-03
  386 KSP Residual norm 1.354178848227e-03
  387 KSP Residual norm 1.352742312886e-03
  388 KSP Residual norm 1.353096597807e-03
  389 KSP Residual norm 1.334145707497e-03
  390 KSP Residual norm 1.244976876447e-03
  391 KSP Residual norm 1.206076100038e-03
  392 KSP Residual norm 1.261782193894e-03
  393 KSP Residual norm 1.300016335362e-03
  394 KSP Residual norm 1.220254929690e-03
  395 KSP Residual norm 1.106128865061e-03
  396 KSP Residual norm 1.046642239943e-03
  397 KSP Residual norm 1.064825863444e-03
  398 KSP Residual norm 1.076071139351e-03
  399 KSP Residual norm 1.072418592011e-03
  400 KSP Residual norm 1.054699683117e-03
  401 KSP Residual norm 1.044433124340e-03
  402 KSP Residual norm 1.067396312320e-03
  403 KSP Residual norm 1.152053727618e-03
  404 KSP Residual norm 1.214731081875e-03
  405 KSP Residual norm 1.200559675103e-03
  406 KSP Residual norm 1.118454110419e-03
  407 KSP Residual norm 1.065613359694e-03
  408 KSP Residual norm 1.059780664889e-03
  409 KSP Residual norm 1.147890672875e-03
  410 KSP Residual norm 1.160152942280e-03
  411 KSP Residual norm 1.155457644175e-03
  412 KSP Residual norm 1.218328095414e-03
  413 KSP Residual norm 1.282417285128e-03
  414 KSP Residual norm 1.290107982445e-03
  415 KSP Residual norm 1.276638656415e-03
  416 KSP Residual norm 1.278858623101e-03
  417 KSP Residual norm 1.363772235297e-03
  418 KSP Residual norm 1.419371458797e-03
  419 KSP Residual norm 1.412832072037e-03
  420 KSP Residual norm 1.365748169574e-03
  421 KSP Residual norm 1.405720923862e-03
  422 KSP Residual norm 1.453177134976e-03
  423 KSP Residual norm 1.520454157083e-03
  424 KSP Residual norm 1.446299931363e-03
  425 KSP Residual norm 1.351877459723e-03
  426 KSP Residual norm 1.327808945913e-03
  427 KSP Residual norm 1.350351799488e-03
  428 KSP Residual norm 1.385479038188e-03
  429 KSP Residual norm 1.387796324528e-03
  430 KSP Residual norm 1.384647149458e-03
  431 KSP Residual norm 1.460355026546e-03
  432 KSP Residual norm 1.480065918295e-03
  433 KSP Residual norm 1.456790034607e-03
  434 KSP Residual norm 1.429909079454e-03
  435 KSP Residual norm 1.451310070774e-03
  436 KSP Residual norm 1.406727345937e-03
  437 KSP Residual norm 1.325991263019e-03
  438 KSP Residual norm 1.246160382525e-03
  439 KSP Residual norm 1.255009836241e-03
  440 KSP Residual norm 1.303332052273e-03
  441 KSP Residual norm 1.286598917010e-03
  442 KSP Residual norm 1.239425544177e-03
  443 KSP Residual norm 1.252515845760e-03
  444 KSP Residual norm 1.294422403484e-03
  445 KSP Residual norm 1.276765289333e-03
  446 KSP Residual norm 1.244824813612e-03
  447 KSP Residual norm 1.183245770405e-03
  448 KSP Residual norm 1.153565086222e-03
  449 KSP Residual norm 1.119489362997e-03
  450 KSP Residual norm 1.117623170827e-03
  451 KSP Residual norm 1.096029604095e-03
  452 KSP Residual norm 1.055193076106e-03
  453 KSP Residual norm 1.005504863389e-03
  454 KSP Residual norm 9.941050424498e-04
  455 KSP Residual norm 9.770049958018e-04
  456 KSP Residual norm 9.092852704615e-04
  457 KSP Residual norm 8.974990456384e-04
  458 KSP Residual norm 9.012999264230e-04
  459 KSP Residual norm 9.147555348631e-04
  460 KSP Residual norm 9.349542493543e-04
  461 KSP Residual norm 9.631165447434e-04
  462 KSP Residual norm 9.927856223692e-04
  463 KSP Residual norm 9.783830479125e-04
  464 KSP Residual norm 9.818168561440e-04
  465 KSP Residual norm 9.896615948644e-04
  466 KSP Residual norm 1.006369854207e-03
  467 KSP Residual norm 9.939846132237e-04
  468 KSP Residual norm 9.767849618419e-04
  469 KSP Residual norm 9.502666517985e-04
  470 KSP Residual norm 9.627158476888e-04
  471 KSP Residual norm 9.696220358260e-04
  472 KSP Residual norm 9.555925574913e-04
  473 KSP Residual norm 9.596753073191e-04
  474 KSP Residual norm 9.778312668318e-04
  475 KSP Residual norm 9.886046752730e-04
  476 KSP Residual norm 9.764004519850e-04
  477 KSP Residual norm 9.018124220522e-04
  478 KSP Residual norm 8.857320067402e-04
  479 KSP Residual norm 8.713510421022e-04
  480 KSP Residual norm 8.969565417031e-04
  481 KSP Residual norm 9.336233261242e-04
  482 KSP Residual norm 9.433172095001e-04
  483 KSP Residual norm 9.161931619946e-04
  484 KSP Residual norm 9.038656681831e-04
  485 KSP Residual norm 9.181623563365e-04
  486 KSP Residual norm 9.069719514158e-04
  487 KSP Residual norm 9.191716357195e-04
  488 KSP Residual norm 9.206538113900e-04
  489 KSP Residual norm 9.309524213734e-04
  490 KSP Residual norm 9.715978975188e-04
  491 KSP Residual norm 1.013562676274e-03
  492 KSP Residual norm 1.009919531281e-03
  493 KSP Residual norm 1.059499239989e-03
  494 KSP Residual norm 1.076813253306e-03
  495 KSP Residual norm 1.074668719575e-03
  496 KSP Residual norm 1.133223873975e-03
  497 KSP Residual norm 1.147944277888e-03
  498 KSP Residual norm 1.192672858255e-03
  499 KSP Residual norm 1.304195086532e-03
  500 KSP Residual norm 1.302173161555e-03
  501 KSP Residual norm 1.270177225081e-03
  502 KSP Residual norm 1.216566257579e-03
  503 KSP Residual norm 1.165110642117e-03
  504 KSP Residual norm 1.195550821372e-03
  505 KSP Residual norm 1.192631583738e-03
  506 KSP Residual norm 1.237066709884e-03
  507 KSP Residual norm 1.210893265197e-03
  508 KSP Residual norm 1.078432807806e-03
  509 KSP Residual norm 1.008083683026e-03
  510 KSP Residual norm 1.056488978524e-03
  511 KSP Residual norm 1.126142245496e-03
  512 KSP Residual norm 1.128376995711e-03
  513 KSP Residual norm 1.096525953864e-03
  514 KSP Residual norm 1.095326824687e-03
  515 KSP Residual norm 1.142282392403e-03
  516 KSP Residual norm 1.139660427298e-03
  517 KSP Residual norm 1.094055452431e-03
  518 KSP Residual norm 1.063409470212e-03
  519 KSP Residual norm 1.110273349622e-03
  520 KSP Residual norm 1.202600760469e-03
  521 KSP Residual norm 1.268411358991e-03
  522 KSP Residual norm 1.277862861022e-03
  523 KSP Residual norm 1.305649608547e-03
  524 KSP Residual norm 1.340498031515e-03
  525 KSP Residual norm 1.325384291903e-03
  526 KSP Residual norm 1.304614031779e-03
  527 KSP Residual norm 1.287973763995e-03
  528 KSP Residual norm 1.267718986109e-03
  529 KSP Residual norm 1.241471871921e-03
  530 KSP Residual norm 1.269218895099e-03
  531 KSP Residual norm 1.252827011848e-03
  532 KSP Residual norm 1.206084773674e-03
  533 KSP Residual norm 1.191593136725e-03
  534 KSP Residual norm 1.164464769735e-03
  535 KSP Residual norm 1.192334038324e-03
  536 KSP Residual norm 1.219492933410e-03
  537 KSP Residual norm 1.199743127274e-03
  538 KSP Residual norm 1.248335920228e-03
  539 KSP Residual norm 1.252673398232e-03
  540 KSP Residual norm 1.246751345189e-03
  541 KSP Residual norm 1.205530499378e-03
  542 KSP Residual norm 1.195070824271e-03
  543 KSP Residual norm 1.223501263517e-03
  544 KSP Residual norm 1.262089895506e-03
  545 KSP Residual norm 1.323061159399e-03
  546 KSP Residual norm 1.349425603612e-03
  547 KSP Residual norm 1.309128586794e-03
  548 KSP Residual norm 1.302075761304e-03
  549 KSP Residual norm 1.331125648600e-03
  550 KSP Residual norm 1.353544159260e-03
  551 KSP Residual norm 1.377107006558e-03
  552 KSP Residual norm 1.349377941781e-03
  553 KSP Residual norm 1.358605387046e-03
  554 KSP Residual norm 1.436355572419e-03
  555 KSP Residual norm 1.502607291761e-03
  556 KSP Residual norm 1.449345666679e-03
  557 KSP Residual norm 1.424783995975e-03
  558 KSP Residual norm 1.427960551265e-03
  559 KSP Residual norm 1.427466632801e-03
  560 KSP Residual norm 1.481062651578e-03
  561 KSP Residual norm 1.562158551958e-03
  562 KSP Residual norm 1.598554803542e-03
  563 KSP Residual norm 1.597557725759e-03
  564 KSP Residual norm 1.659863389266e-03
  565 KSP Residual norm 1.695117214430e-03
  566 KSP Residual norm 1.751026900278e-03
  567 KSP Residual norm 1.739353545363e-03
  568 KSP Residual norm 1.817037903174e-03
  569 KSP Residual norm 1.857665704497e-03
  570 KSP Residual norm 1.782656590883e-03
  571 KSP Residual norm 1.821065237934e-03
  572 KSP Residual norm 1.812838460391e-03
  573 KSP Residual norm 1.922829241083e-03
  574 KSP Residual norm 1.960159350212e-03
  575 KSP Residual norm 2.020917548665e-03
  576 KSP Residual norm 2.001600983891e-03
  577 KSP Residual norm 1.941586650750e-03
  578 KSP Residual norm 2.010907353233e-03
  579 KSP Residual norm 2.231140523179e-03
  580 KSP Residual norm 2.374708165863e-03
  581 KSP Residual norm 2.445724331607e-03
  582 KSP Residual norm 2.451548247846e-03
  583 KSP Residual norm 2.471622812581e-03
  584 KSP Residual norm 2.546071482432e-03
  585 KSP Residual norm 2.576192819880e-03
  586 KSP Residual norm 2.684760642875e-03
  587 KSP Residual norm 2.844454005347e-03
  588 KSP Residual norm 2.891295774829e-03
  589 KSP Residual norm 2.827164491452e-03
  590 KSP Residual norm 2.978210284874e-03
  591 KSP Residual norm 3.118874246324e-03
  592 KSP Residual norm 3.226927540750e-03
  593 KSP Residual norm 3.297702822485e-03
  594 KSP Residual norm 3.269635997402e-03
  595 KSP Residual norm 3.272395692426e-03
  596 KSP Residual norm 3.127220033345e-03
  597 KSP Residual norm 3.002089958033e-03
  598 KSP Residual norm 2.887952193552e-03
  599 KSP Residual norm 2.789545707468e-03
  600 KSP Residual norm 2.728822784045e-03
  601 KSP Residual norm 2.586721450953e-03
  602 KSP Residual norm 2.456861877398e-03
  603 KSP Residual norm 2.270195608825e-03
  604 KSP Residual norm 2.234015372155e-03
  605 KSP Residual norm 2.271006954022e-03
  606 KSP Residual norm 2.274709919172e-03
  607 KSP Residual norm 2.319140505599e-03
  608 KSP Residual norm 2.371304192676e-03
  609 KSP Residual norm 2.381183182868e-03
  610 KSP Residual norm 2.473342013503e-03
  611 KSP Residual norm 2.668702366905e-03
  612 KSP Residual norm 2.840263324868e-03
  613 KSP Residual norm 2.887342238157e-03
  614 KSP Residual norm 2.945717643492e-03
  615 KSP Residual norm 2.954708258451e-03
  616 KSP Residual norm 2.782576372141e-03
  617 KSP Residual norm 2.604890421262e-03
  618 KSP Residual norm 2.554034090005e-03
  619 KSP Residual norm 2.623418706237e-03
  620 KSP Residual norm 2.561484842595e-03
  621 KSP Residual norm 2.393195287692e-03
  622 KSP Residual norm 2.160609863780e-03
  623 KSP Residual norm 1.979602551998e-03
  624 KSP Residual norm 1.963931478777e-03
  625 KSP Residual norm 1.948555791659e-03
  626 KSP Residual norm 2.017840029712e-03
  627 KSP Residual norm 2.046199056507e-03
  628 KSP Residual norm 1.993108418353e-03
  629 KSP Residual norm 1.974961947376e-03
  630 KSP Residual norm 2.061584360663e-03
  631 KSP Residual norm 2.054957286204e-03
  632 KSP Residual norm 1.990859027025e-03
  633 KSP Residual norm 2.041368256010e-03
  634 KSP Residual norm 2.058655836834e-03
  635 KSP Residual norm 2.099752038269e-03
  636 KSP Residual norm 2.131260502055e-03
  637 KSP Residual norm 2.152145468088e-03
  638 KSP Residual norm 2.186736970547e-03
  639 KSP Residual norm 2.226068625504e-03
  640 KSP Residual norm 2.414508229979e-03
  641 KSP Residual norm 2.641630675320e-03
  642 KSP Residual norm 2.875761700403e-03
  643 KSP Residual norm 3.128751719400e-03
  644 KSP Residual norm 3.218863877361e-03
  645 KSP Residual norm 3.286440896976e-03
  646 KSP Residual norm 3.573443161029e-03
  647 KSP Residual norm 3.886465854832e-03
  648 KSP Residual norm 3.996486091627e-03
  649 KSP Residual norm 3.952223090674e-03
  650 KSP Residual norm 4.148696249293e-03
  651 KSP Residual norm 4.079176608710e-03
  652 KSP Residual norm 3.918952724596e-03
  653 KSP Residual norm 3.923035202176e-03
  654 KSP Residual norm 3.944710633091e-03
  655 KSP Residual norm 3.857676629281e-03
  656 KSP Residual norm 3.736280082312e-03
  657 KSP Residual norm 3.793661571477e-03
  658 KSP Residual norm 3.873896125551e-03
  659 KSP Residual norm 3.877810193883e-03
  660 KSP Residual norm 4.169433784065e-03
  661 KSP Residual norm 4.323131896838e-03
  662 KSP Residual norm 4.296835496769e-03
  663 KSP Residual norm 4.207135380912e-03
  664 KSP Residual norm 4.031582293437e-03
  665 KSP Residual norm 4.218523456173e-03
  666 KSP Residual norm 4.529317974038e-03
  667 KSP Residual norm 4.934835798003e-03
  668 KSP Residual norm 5.301936631949e-03
  669 KSP Residual norm 5.277983685620e-03
  670 KSP Residual norm 5.019195591950e-03
  671 KSP Residual norm 4.851201693366e-03
  672 KSP Residual norm 4.734902022510e-03
  673 KSP Residual norm 4.976852212368e-03
  674 KSP Residual norm 5.193092769362e-03
  675 KSP Residual norm 5.074930831870e-03
  676 KSP Residual norm 5.032785592826e-03
  677 KSP Residual norm 5.158280095896e-03
  678 KSP Residual norm 5.322468916220e-03
  679 KSP Residual norm 5.634887770503e-03
  680 KSP Residual norm 5.909765459769e-03
  681 KSP Residual norm 6.020179701853e-03
  682 KSP Residual norm 5.783216033479e-03
  683 KSP Residual norm 5.624748149217e-03
  684 KSP Residual norm 5.501514634248e-03
  685 KSP Residual norm 5.696721575211e-03
  686 KSP Residual norm 5.715606984051e-03
  687 KSP Residual norm 5.562257632383e-03
  688 KSP Residual norm 5.544174264842e-03
  689 KSP Residual norm 5.485930659494e-03
  690 KSP Residual norm 4.956546863206e-03
  691 KSP Residual norm 4.632123369208e-03
  692 KSP Residual norm 4.604542140537e-03
  693 KSP Residual norm 4.866250739707e-03
  694 KSP Residual norm 4.773117405448e-03
  695 KSP Residual norm 4.708889265211e-03
  696 KSP Residual norm 4.918986654095e-03
  697 KSP Residual norm 5.108781269711e-03
  698 KSP Residual norm 4.924217059739e-03
  699 KSP Residual norm 4.618712978303e-03
  700 KSP Residual norm 4.540370025483e-03
  701 KSP Residual norm 4.648699130247e-03
  702 KSP Residual norm 4.530699767673e-03
  703 KSP Residual norm 4.208925421903e-03
  704 KSP Residual norm 4.188225308855e-03
  705 KSP Residual norm 4.422248684790e-03
  706 KSP Residual norm 4.568392073765e-03
  707 KSP Residual norm 4.616808828879e-03
  708 KSP Residual norm 4.588543206558e-03
  709 KSP Residual norm 4.639488790088e-03
  710 KSP Residual norm 4.444272664026e-03
  711 KSP Residual norm 4.234628347681e-03
  712 KSP Residual norm 4.127758383775e-03
  713 KSP Residual norm 4.226146707318e-03
  714 KSP Residual norm 4.315745072182e-03
  715 KSP Residual norm 4.414551383475e-03
  716 KSP Residual norm 4.526361096101e-03
  717 KSP Residual norm 4.821404255311e-03
  718 KSP Residual norm 5.048407023781e-03
  719 KSP Residual norm 4.865432067942e-03
  720 KSP Residual norm 4.736673154911e-03
  721 KSP Residual norm 4.844045662115e-03
  722 KSP Residual norm 5.025216696831e-03
  723 KSP Residual norm 5.063807199625e-03
  724 KSP Residual norm 5.199316362538e-03
  725 KSP Residual norm 5.073180119090e-03
  726 KSP Residual norm 4.867937378468e-03
  727 KSP Residual norm 4.622519181293e-03
  728 KSP Residual norm 4.301126032899e-03
  729 KSP Residual norm 4.102680159217e-03
  730 KSP Residual norm 4.182928190220e-03
  731 KSP Residual norm 4.286367784157e-03
  732 KSP Residual norm 4.391122318785e-03
  733 KSP Residual norm 4.595538944216e-03
  734 KSP Residual norm 4.706566736553e-03
  735 KSP Residual norm 4.503865315399e-03
  736 KSP Residual norm 4.316431285229e-03
  737 KSP Residual norm 4.430407108087e-03
  738 KSP Residual norm 4.506848843703e-03
  739 KSP Residual norm 4.433850111061e-03
  740 KSP Residual norm 4.380771081996e-03
  741 KSP Residual norm 4.222631885474e-03
  742 KSP Residual norm 4.147771849579e-03
  743 KSP Residual norm 4.365639718295e-03
  744 KSP Residual norm 4.717559413792e-03
  745 KSP Residual norm 4.814102031643e-03
  746 KSP Residual norm 4.664000257623e-03
  747 KSP Residual norm 4.828979911030e-03
  748 KSP Residual norm 4.936597793490e-03
  749 KSP Residual norm 4.861591122631e-03
  750 KSP Residual norm 4.672726595736e-03
  751 KSP Residual norm 4.922548149667e-03
  752 KSP Residual norm 5.229361787727e-03
  753 KSP Residual norm 5.249145190642e-03
  754 KSP Residual norm 4.948681226659e-03
  755 KSP Residual norm 4.630066570005e-03
  756 KSP Residual norm 4.599738801059e-03
  757 KSP Residual norm 4.929083792314e-03
  758 KSP Residual norm 5.566633954187e-03
  759 KSP Residual norm 5.769661533521e-03
  760 KSP Residual norm 5.644415061329e-03
  761 KSP Residual norm 5.704979658186e-03
  762 KSP Residual norm 5.491941722453e-03
  763 KSP Residual norm 5.126667613508e-03
  764 KSP Residual norm 4.851766976706e-03
  765 KSP Residual norm 4.811919456483e-03
  766 KSP Residual norm 4.907107900783e-03
  767 KSP Residual norm 5.248085780992e-03
  768 KSP Residual norm 5.489611963591e-03
  769 KSP Residual norm 5.983835818817e-03
  770 KSP Residual norm 6.525916643132e-03
  771 KSP Residual norm 6.778487524504e-03
  772 KSP Residual norm 6.669372553854e-03
  773 KSP Residual norm 6.135866213372e-03
  774 KSP Residual norm 5.783129247859e-03
  775 KSP Residual norm 5.784201879151e-03
  776 KSP Residual norm 5.741559179621e-03
  777 KSP Residual norm 5.703354544397e-03
  778 KSP Residual norm 5.482250606638e-03
  779 KSP Residual norm 5.310252890419e-03
  780 KSP Residual norm 5.335711864097e-03
  781 KSP Residual norm 5.313727521953e-03
  782 KSP Residual norm 5.298550285404e-03
  783 KSP Residual norm 5.277860914991e-03
  784 KSP Residual norm 5.562270366961e-03
  785 KSP Residual norm 5.773676284701e-03
  786 KSP Residual norm 5.937828098629e-03
  787 KSP Residual norm 5.933205595583e-03
  788 KSP Residual norm 5.706620882406e-03
  789 KSP Residual norm 5.746541406510e-03
  790 KSP Residual norm 5.682632330616e-03
  791 KSP Residual norm 5.718373329312e-03
  792 KSP Residual norm 5.858127842517e-03
  793 KSP Residual norm 6.036029033969e-03
  794 KSP Residual norm 5.937362017402e-03
  795 KSP Residual norm 5.662821329724e-03
  796 KSP Residual norm 5.570868424837e-03
  797 KSP Residual norm 5.736255872605e-03
  798 KSP Residual norm 5.718267824764e-03
  799 KSP Residual norm 5.523708236915e-03
  800 KSP Residual norm 5.260143665610e-03
  801 KSP Residual norm 5.273276972924e-03
  802 KSP Residual norm 5.326177610156e-03
  803 KSP Residual norm 5.470489474939e-03
  804 KSP Residual norm 5.563660821212e-03
  805 KSP Residual norm 5.450467821544e-03
  806 KSP Residual norm 5.257754749895e-03
  807 KSP Residual norm 5.173273041024e-03
  808 KSP Residual norm 5.173399710786e-03
  809 KSP Residual norm 5.129745167935e-03
  810 KSP Residual norm 4.990486065819e-03
  811 KSP Residual norm 4.752904983010e-03
  812 KSP Residual norm 4.620248446524e-03
  813 KSP Residual norm 4.643793500577e-03
  814 KSP Residual norm 4.670321867182e-03
  815 KSP Residual norm 4.617087182743e-03
  816 KSP Residual norm 4.700188292896e-03
  817 KSP Residual norm 4.605612711004e-03
  818 KSP Residual norm 4.383306226908e-03
  819 KSP Residual norm 4.491049783797e-03
  820 KSP Residual norm 4.641695104821e-03
  821 KSP Residual norm 4.728778395632e-03
  822 KSP Residual norm 4.726685398043e-03
  823 KSP Residual norm 4.719323445919e-03
  824 KSP Residual norm 4.397459455653e-03
  825 KSP Residual norm 4.202202803142e-03
  826 KSP Residual norm 4.187108103326e-03
  827 KSP Residual norm 4.413636897633e-03
  828 KSP Residual norm 4.294243790417e-03
  829 KSP Residual norm 4.237713512230e-03
  830 KSP Residual norm 4.230817171428e-03
  831 KSP Residual norm 4.361317085853e-03
  832 KSP Residual norm 4.322420049048e-03
  833 KSP Residual norm 4.333158250701e-03
  834 KSP Residual norm 4.272257205512e-03
  835 KSP Residual norm 4.166208845377e-03
  836 KSP Residual norm 4.276427624622e-03
  837 KSP Residual norm 4.262789381603e-03
  838 KSP Residual norm 4.390849186044e-03
  839 KSP Residual norm 4.392670055004e-03
  840 KSP Residual norm 4.197153591994e-03
  841 KSP Residual norm 3.985740589991e-03
  842 KSP Residual norm 3.751916382322e-03
  843 KSP Residual norm 3.744476290366e-03
  844 KSP Residual norm 3.703285656437e-03
  845 KSP Residual norm 3.681674911257e-03
  846 KSP Residual norm 3.665749856416e-03
  847 KSP Residual norm 3.795682207139e-03
  848 KSP Residual norm 3.879211906228e-03
  849 KSP Residual norm 3.904866739752e-03
  850 KSP Residual norm 4.053463668093e-03
  851 KSP Residual norm 4.310206873307e-03
  852 KSP Residual norm 4.398468828346e-03
  853 KSP Residual norm 4.303875562632e-03
  854 KSP Residual norm 4.281086768268e-03
  855 KSP Residual norm 4.381377636333e-03
  856 KSP Residual norm 4.408508579163e-03
  857 KSP Residual norm 4.261455674502e-03
  858 KSP Residual norm 4.085046370784e-03
  859 KSP Residual norm 3.962246614559e-03
  860 KSP Residual norm 4.017324998468e-03
  861 KSP Residual norm 4.080511395918e-03
  862 KSP Residual norm 4.036490084737e-03
  863 KSP Residual norm 3.937069305169e-03
  864 KSP Residual norm 3.707986416453e-03
  865 KSP Residual norm 3.777951030973e-03
  866 KSP Residual norm 3.974784104611e-03
  867 KSP Residual norm 4.188430303811e-03
  868 KSP Residual norm 4.219085975362e-03
  869 KSP Residual norm 4.145977225117e-03
  870 KSP Residual norm 4.181287665007e-03
  871 KSP Residual norm 4.195306731661e-03
  872 KSP Residual norm 4.174729054987e-03
  873 KSP Residual norm 4.178829217510e-03
  874 KSP Residual norm 4.152426882362e-03
  875 KSP Residual norm 4.337268072075e-03
  876 KSP Residual norm 4.575096886853e-03
  877 KSP Residual norm 4.540538034903e-03
  878 KSP Residual norm 4.689722606122e-03
  879 KSP Residual norm 5.092002143298e-03
  880 KSP Residual norm 5.426101401836e-03
  881 KSP Residual norm 5.319771478453e-03
  882 KSP Residual norm 5.065400101422e-03
  883 KSP Residual norm 4.987627471669e-03
  884 KSP Residual norm 5.231010313901e-03
  885 KSP Residual norm 5.697968184051e-03
  886 KSP Residual norm 5.984576951654e-03
  887 KSP Residual norm 5.890014849194e-03
  888 KSP Residual norm 5.765833588141e-03
  889 KSP Residual norm 5.831964254872e-03
  890 KSP Residual norm 5.804212026051e-03
  891 KSP Residual norm 5.453299776526e-03
  892 KSP Residual norm 5.581785894480e-03
  893 KSP Residual norm 5.914960551582e-03
  894 KSP Residual norm 6.215274237221e-03
  895 KSP Residual norm 6.380147448218e-03
  896 KSP Residual norm 6.434006988794e-03
  897 KSP Residual norm 6.956152793164e-03
  898 KSP Residual norm 7.569943236908e-03
  899 KSP Residual norm 7.196213063372e-03
  900 KSP Residual norm 6.669265142295e-03
  901 KSP Residual norm 6.291602518634e-03
  902 KSP Residual norm 6.219791968697e-03
  903 KSP Residual norm 6.338503625427e-03
  904 KSP Residual norm 6.424207519846e-03
  905 KSP Residual norm 6.358795522748e-03
  906 KSP Residual norm 6.065467535689e-03
  907 KSP Residual norm 5.900664281144e-03
  908 KSP Residual norm 5.842698544577e-03
  909 KSP Residual norm 5.930779381444e-03
  910 KSP Residual norm 5.701726896468e-03
  911 KSP Residual norm 5.451726110990e-03
  912 KSP Residual norm 5.358715189907e-03
  913 KSP Residual norm 5.074947630587e-03
  914 KSP Residual norm 4.879003170423e-03
  915 KSP Residual norm 4.508233945089e-03
  916 KSP Residual norm 4.443694702769e-03
  917 KSP Residual norm 4.613572364187e-03
  918 KSP Residual norm 4.738259183511e-03
  919 KSP Residual norm 4.791155625810e-03
  920 KSP Residual norm 4.974137880502e-03
  921 KSP Residual norm 5.104963370756e-03
  922 KSP Residual norm 5.161325592815e-03
  923 KSP Residual norm 5.066610625764e-03
  924 KSP Residual norm 4.859808367323e-03
  925 KSP Residual norm 4.759496591612e-03
  926 KSP Residual norm 4.877206386720e-03
  927 KSP Residual norm 5.057897513934e-03
  928 KSP Residual norm 5.111313050571e-03
  929 KSP Residual norm 5.389458752792e-03
  930 KSP Residual norm 5.737138995252e-03
  931 KSP Residual norm 5.998194270249e-03
  932 KSP Residual norm 6.146434423575e-03
  933 KSP Residual norm 6.569709275569e-03
  934 KSP Residual norm 6.962879787477e-03
  935 KSP Residual norm 7.372751593413e-03
  936 KSP Residual norm 7.516081815966e-03
  937 KSP Residual norm 7.345681334036e-03
  938 KSP Residual norm 7.387023502760e-03
  939 KSP Residual norm 7.751916785347e-03
  940 KSP Residual norm 8.124853985422e-03
  941 KSP Residual norm 8.161143065742e-03
  942 KSP Residual norm 8.067366672832e-03
  943 KSP Residual norm 8.229867127952e-03
  944 KSP Residual norm 8.853793072529e-03
  945 KSP Residual norm 9.269567121478e-03
  946 KSP Residual norm 8.751506073752e-03
  947 KSP Residual norm 7.938945593248e-03
  948 KSP Residual norm 7.797694446958e-03
  949 KSP Residual norm 7.929228242394e-03
  950 KSP Residual norm 7.719452507282e-03
  951 KSP Residual norm 6.832883878296e-03
  952 KSP Residual norm 6.443643850214e-03
  953 KSP Residual norm 6.295045856499e-03
  954 KSP Residual norm 6.150883178803e-03
  955 KSP Residual norm 6.074214553054e-03
  956 KSP Residual norm 6.034663057893e-03
  957 KSP Residual norm 6.236959412573e-03
  958 KSP Residual norm 6.307983143271e-03
  959 KSP Residual norm 6.337338786166e-03
  960 KSP Residual norm 6.424917217463e-03
  961 KSP Residual norm 6.797528340310e-03
  962 KSP Residual norm 6.747058303445e-03
  963 KSP Residual norm 6.474594117430e-03
  964 KSP Residual norm 5.993114301998e-03
  965 KSP Residual norm 5.624010238615e-03
  966 KSP Residual norm 5.593720784244e-03
  967 KSP Residual norm 5.589581870468e-03
  968 KSP Residual norm 5.603005508742e-03
  969 KSP Residual norm 5.810391484899e-03
  970 KSP Residual norm 6.194263875096e-03
  971 KSP Residual norm 6.136652736529e-03
  972 KSP Residual norm 6.283690392221e-03
  973 KSP Residual norm 6.519842963053e-03
  974 KSP Residual norm 6.895802471345e-03
  975 KSP Residual norm 6.992540210060e-03
  976 KSP Residual norm 6.948142695474e-03
  977 KSP Residual norm 6.902910092755e-03
  978 KSP Residual norm 6.810624040762e-03
  979 KSP Residual norm 6.933177851430e-03
  980 KSP Residual norm 7.308598793955e-03
  981 KSP Residual norm 7.517714501679e-03
  982 KSP Residual norm 7.832519795887e-03
  983 KSP Residual norm 7.864611364591e-03
  984 KSP Residual norm 7.684466785193e-03
  985 KSP Residual norm 7.640868812113e-03
  986 KSP Residual norm 7.935507353152e-03
  987 KSP Residual norm 8.163967874078e-03
  988 KSP Residual norm 8.055085011071e-03
  989 KSP Residual norm 7.676106656276e-03
  990 KSP Residual norm 7.230936801529e-03
  991 KSP Residual norm 6.951908145572e-03
  992 KSP Residual norm 6.802094733110e-03
  993 KSP Residual norm 6.683949692399e-03
  994 KSP Residual norm 6.336700308828e-03
  995 KSP Residual norm 6.244222851116e-03
  996 KSP Residual norm 6.304898269266e-03
  997 KSP Residual norm 6.330769690003e-03
  998 KSP Residual norm 6.228526816184e-03
  999 KSP Residual norm 6.236334612293e-03
  1000 KSP Residual norm 6.082543349162e-03
  1001 KSP Residual norm 5.951192334012e-03
  1002 KSP Residual norm 5.896320518952e-03
  1003 KSP Residual norm 5.893906943159e-03
  1004 KSP Residual norm 6.189911727147e-03
  1005 KSP Residual norm 6.298401986625e-03
  1006 KSP Residual norm 6.394011235232e-03
  1007 KSP Residual norm 6.515404444493e-03
  1008 KSP Residual norm 6.720948446026e-03
  1009 KSP Residual norm 6.589878288593e-03
  1010 KSP Residual norm 6.152351062045e-03
  1011 KSP Residual norm 5.969266592480e-03
  1012 KSP Residual norm 6.170609409981e-03
  1013 KSP Residual norm 6.469621506901e-03
  1014 KSP Residual norm 6.459914206986e-03
  1015 KSP Residual norm 6.593668533056e-03
  1016 KSP Residual norm 6.622514784875e-03
  1017 KSP Residual norm 6.656735647554e-03
  1018 KSP Residual norm 6.751257601391e-03
  1019 KSP Residual norm 6.988646562368e-03
  1020 KSP Residual norm 6.905687803374e-03
  1021 KSP Residual norm 6.655272945212e-03
  1022 KSP Residual norm 6.777996924187e-03
  1023 KSP Residual norm 6.947630339348e-03
  1024 KSP Residual norm 6.950024896731e-03
  1025 KSP Residual norm 6.581465729748e-03
  1026 KSP Residual norm 6.623424889169e-03
  1027 KSP Residual norm 6.544497469118e-03
  1028 KSP Residual norm 6.765260623953e-03
  1029 KSP Residual norm 6.915449248189e-03
  1030 KSP Residual norm 6.372236580133e-03
  1031 KSP Residual norm 5.953128974582e-03
  1032 KSP Residual norm 6.015530242281e-03
  1033 KSP Residual norm 5.943168745891e-03
  1034 KSP Residual norm 5.596915041857e-03
  1035 KSP Residual norm 5.408257600816e-03
  1036 KSP Residual norm 5.462516314601e-03
  1037 KSP Residual norm 5.452288052399e-03
  1038 KSP Residual norm 5.531964783471e-03
  1039 KSP Residual norm 5.396516226761e-03
  1040 KSP Residual norm 4.956288530837e-03
  1041 KSP Residual norm 4.675443151148e-03
  1042 KSP Residual norm 4.634914726898e-03
  1043 KSP Residual norm 4.719420543451e-03
  1044 KSP Residual norm 4.878425027179e-03
  1045 KSP Residual norm 4.992200285686e-03
  1046 KSP Residual norm 4.883623561089e-03
  1047 KSP Residual norm 4.902805121842e-03
  1048 KSP Residual norm 5.038729498491e-03
  1049 KSP Residual norm 5.137707181042e-03
  1050 KSP Residual norm 4.830803807506e-03
  1051 KSP Residual norm 4.320867223425e-03
  1052 KSP Residual norm 4.142120709162e-03
  1053 KSP Residual norm 4.298950610032e-03
  1054 KSP Residual norm 4.467252788161e-03
  1055 KSP Residual norm 4.522559064521e-03
  1056 KSP Residual norm 4.761306312461e-03
  1057 KSP Residual norm 5.150319637346e-03
  1058 KSP Residual norm 5.322174446922e-03
  1059 KSP Residual norm 5.238802254595e-03
  1060 KSP Residual norm 5.061485394297e-03
  1061 KSP Residual norm 4.909992936371e-03
  1062 KSP Residual norm 4.685635154322e-03
  1063 KSP Residual norm 4.549642150475e-03
  1064 KSP Residual norm 4.315222756062e-03
  1065 KSP Residual norm 4.281712726966e-03
  1066 KSP Residual norm 4.628655632869e-03
  1067 KSP Residual norm 5.104523083976e-03
  1068 KSP Residual norm 5.189322907695e-03
  1069 KSP Residual norm 5.221327773111e-03
  1070 KSP Residual norm 5.319418446647e-03
  1071 KSP Residual norm 5.285463126603e-03
  1072 KSP Residual norm 5.180630969047e-03
  1073 KSP Residual norm 5.214370896858e-03
  1074 KSP Residual norm 5.560363588384e-03
  1075 KSP Residual norm 5.820058047521e-03
  1076 KSP Residual norm 6.161044287324e-03
  1077 KSP Residual norm 6.134595772506e-03
  1078 KSP Residual norm 6.162806832956e-03
  1079 KSP Residual norm 6.015504687689e-03
  1080 KSP Residual norm 5.965365763166e-03
  1081 KSP Residual norm 5.925516590688e-03
  1082 KSP Residual norm 6.050030721362e-03
  1083 KSP Residual norm 6.035467347951e-03
  1084 KSP Residual norm 5.840636688796e-03
  1085 KSP Residual norm 5.974492387850e-03
  1086 KSP Residual norm 6.306378068772e-03
  1087 KSP Residual norm 6.223532094991e-03
  1088 KSP Residual norm 5.978102326085e-03
  1089 KSP Residual norm 6.032699383338e-03
  1090 KSP Residual norm 5.963182048539e-03
  1091 KSP Residual norm 5.845853825071e-03
  1092 KSP Residual norm 5.703606769746e-03
  1093 KSP Residual norm 5.589634794580e-03
  1094 KSP Residual norm 5.945482515465e-03
  1095 KSP Residual norm 6.096712270725e-03
  1096 KSP Residual norm 5.727527640483e-03
  1097 KSP Residual norm 5.463535057390e-03
  1098 KSP Residual norm 5.621914974956e-03
  1099 KSP Residual norm 5.892077814275e-03
  1100 KSP Residual norm 6.139083451418e-03
  1101 KSP Residual norm 5.740656746572e-03
  1102 KSP Residual norm 5.328292130255e-03
  1103 KSP Residual norm 5.258243410082e-03
  1104 KSP Residual norm 5.294375311027e-03
  1105 KSP Residual norm 5.457460865136e-03
  1106 KSP Residual norm 5.774135867417e-03
  1107 KSP Residual norm 6.231248846901e-03
  1108 KSP Residual norm 6.634947482888e-03
  1109 KSP Residual norm 6.915589060378e-03
  1110 KSP Residual norm 6.842662490898e-03
  1111 KSP Residual norm 6.653520411095e-03
  1112 KSP Residual norm 6.507144896527e-03
  1113 KSP Residual norm 6.203930956071e-03
  1114 KSP Residual norm 6.190651197615e-03
  1115 KSP Residual norm 6.443233750548e-03
  1116 KSP Residual norm 6.846407285740e-03
  1117 KSP Residual norm 6.813516923484e-03
  1118 KSP Residual norm 6.586346121190e-03
  1119 KSP Residual norm 6.716516964440e-03
  1120 KSP Residual norm 6.750677507897e-03
  1121 KSP Residual norm 6.650235124616e-03
  1122 KSP Residual norm 6.340073963061e-03
  1123 KSP Residual norm 6.442977105372e-03
  1124 KSP Residual norm 6.607485326192e-03
  1125 KSP Residual norm 6.654648159593e-03
  1126 KSP Residual norm 6.390913213498e-03
  1127 KSP Residual norm 6.139694331253e-03
  1128 KSP Residual norm 5.975839996696e-03
  1129 KSP Residual norm 6.181452135028e-03
  1130 KSP Residual norm 6.483924116115e-03
  1131 KSP Residual norm 6.244388643648e-03
  1132 KSP Residual norm 5.726665913960e-03
  1133 KSP Residual norm 5.548101276250e-03
  1134 KSP Residual norm 5.670483843427e-03
  1135 KSP Residual norm 5.815484357897e-03
  1136 KSP Residual norm 5.836656679452e-03
  1137 KSP Residual norm 6.126786438304e-03
  1138 KSP Residual norm 6.131637697385e-03
  1139 KSP Residual norm 5.939461551154e-03
  1140 KSP Residual norm 5.899863029397e-03
  1141 KSP Residual norm 5.879249371999e-03
  1142 KSP Residual norm 5.733033436179e-03
  1143 KSP Residual norm 5.810084705179e-03
  1144 KSP Residual norm 6.192124782418e-03
  1145 KSP Residual norm 6.198880886066e-03
  1146 KSP Residual norm 6.126373924098e-03
  1147 KSP Residual norm 6.202550295473e-03
  1148 KSP Residual norm 6.619257825958e-03
  1149 KSP Residual norm 6.958254861449e-03
  1150 KSP Residual norm 6.903498120753e-03
  1151 KSP Residual norm 6.853397498305e-03
  1152 KSP Residual norm 6.783288123518e-03
  1153 KSP Residual norm 6.684459902594e-03
  1154 KSP Residual norm 7.000778316486e-03
  1155 KSP Residual norm 6.912436408032e-03
  1156 KSP Residual norm 6.819457534321e-03
  1157 KSP Residual norm 6.677222508219e-03
  1158 KSP Residual norm 6.455952608254e-03
  1159 KSP Residual norm 6.346410790821e-03
  1160 KSP Residual norm 6.331219961493e-03
  1161 KSP Residual norm 6.640611156020e-03
  1162 KSP Residual norm 6.790349677284e-03
  1163 KSP Residual norm 6.332263850028e-03
  1164 KSP Residual norm 5.816647448194e-03
  1165 KSP Residual norm 5.697215514246e-03
  1166 KSP Residual norm 6.016051161797e-03
  1167 KSP Residual norm 6.340316880162e-03
  1168 KSP Residual norm 6.101820359558e-03
  1169 KSP Residual norm 5.802519263927e-03
  1170 KSP Residual norm 5.442038846680e-03
  1171 KSP Residual norm 4.842404703879e-03
  1172 KSP Residual norm 4.307367171043e-03
  1173 KSP Residual norm 4.312710721844e-03
  1174 KSP Residual norm 4.615300758975e-03
  1175 KSP Residual norm 4.835514304094e-03
  1176 KSP Residual norm 4.971895126694e-03
  1177 KSP Residual norm 4.922519270854e-03
  1178 KSP Residual norm 5.027507820926e-03
  1179 KSP Residual norm 5.381926369022e-03
  1180 KSP Residual norm 5.924644512727e-03
  1181 KSP Residual norm 5.891518828823e-03
  1182 KSP Residual norm 5.675322830638e-03
  1183 KSP Residual norm 5.488681315201e-03
  1184 KSP Residual norm 5.464539823754e-03
  1185 KSP Residual norm 5.191120797280e-03
  1186 KSP Residual norm 5.036484482861e-03
  1187 KSP Residual norm 5.514703417422e-03
  1188 KSP Residual norm 6.021271127233e-03
  1189 KSP Residual norm 6.102166452512e-03
  1190 KSP Residual norm 5.759277572695e-03
  1191 KSP Residual norm 5.365159664280e-03
  1192 KSP Residual norm 4.831505966819e-03
  1193 KSP Residual norm 4.669862169270e-03
  1194 KSP Residual norm 4.619647530157e-03
  1195 KSP Residual norm 4.692323156185e-03
  1196 KSP Residual norm 4.827179343472e-03
  1197 KSP Residual norm 4.722460358927e-03
  1198 KSP Residual norm 4.457709639624e-03
  1199 KSP Residual norm 4.232960701882e-03
  1200 KSP Residual norm 3.913306868682e-03
  1201 KSP Residual norm 3.938209539604e-03
  1202 KSP Residual norm 4.209949450264e-03
  1203 KSP Residual norm 4.348061906313e-03
  1204 KSP Residual norm 4.309578170217e-03
  1205 KSP Residual norm 4.215557309157e-03
  1206 KSP Residual norm 4.328624858550e-03
  1207 KSP Residual norm 4.679769902461e-03
  1208 KSP Residual norm 4.772875673194e-03
  1209 KSP Residual norm 4.840061492543e-03
  1210 KSP Residual norm 4.894836284673e-03
  1211 KSP Residual norm 5.106793066553e-03
  1212 KSP Residual norm 5.419370252828e-03
  1213 KSP Residual norm 5.602897497417e-03
  1214 KSP Residual norm 5.620211820518e-03
  1215 KSP Residual norm 5.541580410610e-03
  1216 KSP Residual norm 5.377318358986e-03
  1217 KSP Residual norm 5.355932724490e-03
  1218 KSP Residual norm 5.172556245287e-03
  1219 KSP Residual norm 5.195067873454e-03
  1220 KSP Residual norm 5.411953098667e-03
  1221 KSP Residual norm 5.542498186585e-03
  1222 KSP Residual norm 5.699400248498e-03
  1223 KSP Residual norm 6.083526194246e-03
  1224 KSP Residual norm 6.776632040042e-03
  1225 KSP Residual norm 6.591245482881e-03
  1226 KSP Residual norm 6.056789615984e-03
  1227 KSP Residual norm 5.620002002496e-03
  1228 KSP Residual norm 5.511076945362e-03
  1229 KSP Residual norm 5.403195902175e-03
  1230 KSP Residual norm 4.979935000628e-03
  1231 KSP Residual norm 4.573086112890e-03
  1232 KSP Residual norm 4.459743381228e-03
  1233 KSP Residual norm 4.372845880899e-03
  1234 KSP Residual norm 4.302849623364e-03
  1235 KSP Residual norm 4.111474668947e-03
  1236 KSP Residual norm 3.979685522244e-03
  1237 KSP Residual norm 4.065333685994e-03
  1238 KSP Residual norm 4.212503344253e-03
  1239 KSP Residual norm 4.255606705877e-03
  1240 KSP Residual norm 4.410395450204e-03
  1241 KSP Residual norm 4.645881211501e-03
  1242 KSP Residual norm 4.396305934514e-03
  1243 KSP Residual norm 3.795604675090e-03
  1244 KSP Residual norm 3.382639010574e-03
  1245 KSP Residual norm 3.263719609938e-03
  1246 KSP Residual norm 3.292309527915e-03
  1247 KSP Residual norm 3.454794521972e-03
  1248 KSP Residual norm 3.756456407396e-03
  1249 KSP Residual norm 4.129318294708e-03
  1250 KSP Residual norm 4.188513748578e-03
  1251 KSP Residual norm 4.333470426178e-03
  1252 KSP Residual norm 4.534784618524e-03
  1253 KSP Residual norm 4.662683091238e-03
  1254 KSP Residual norm 4.745039771543e-03
  1255 KSP Residual norm 5.036284709742e-03
  1256 KSP Residual norm 5.140546926157e-03
  1257 KSP Residual norm 5.026826636179e-03
  1258 KSP Residual norm 5.010636800537e-03
  1259 KSP Residual norm 5.316707900383e-03
  1260 KSP Residual norm 5.326368822382e-03
  1261 KSP Residual norm 5.266328100617e-03
  1262 KSP Residual norm 5.234593905012e-03
  1263 KSP Residual norm 5.186181958411e-03
  1264 KSP Residual norm 4.808342735265e-03
  1265 KSP Residual norm 4.556387656805e-03
  1266 KSP Residual norm 4.549331733816e-03
  1267 KSP Residual norm 4.669412804075e-03
  1268 KSP Residual norm 4.574004829108e-03
  1269 KSP Residual norm 4.340970646999e-03
  1270 KSP Residual norm 4.319369679024e-03
  1271 KSP Residual norm 4.578968060174e-03
  1272 KSP Residual norm 4.846032166389e-03
  1273 KSP Residual norm 4.746368789336e-03
  1274 KSP Residual norm 4.609013741009e-03
  1275 KSP Residual norm 4.708151412562e-03
  1276 KSP Residual norm 4.995241581273e-03
  1277 KSP Residual norm 5.332579238943e-03
  1278 KSP Residual norm 5.204965860375e-03
  1279 KSP Residual norm 4.945698544804e-03
  1280 KSP Residual norm 4.804631013042e-03
  1281 KSP Residual norm 4.917148464483e-03
  1282 KSP Residual norm 5.240730514973e-03
  1283 KSP Residual norm 5.576608925829e-03
  1284 KSP Residual norm 5.371381327328e-03
  1285 KSP Residual norm 5.011314190904e-03
  1286 KSP Residual norm 4.866107074784e-03
  1287 KSP Residual norm 4.787906287522e-03
  1288 KSP Residual norm 4.864775553534e-03
  1289 KSP Residual norm 4.916785832573e-03
  1290 KSP Residual norm 4.657463941679e-03
  1291 KSP Residual norm 4.530399732902e-03
  1292 KSP Residual norm 4.567561150432e-03
  1293 KSP Residual norm 4.623376308790e-03
  1294 KSP Residual norm 4.386296319403e-03
  1295 KSP Residual norm 4.224960644615e-03
  1296 KSP Residual norm 4.124504209937e-03
  1297 KSP Residual norm 4.113756726773e-03
  1298 KSP Residual norm 4.219404272017e-03
  1299 KSP Residual norm 4.319074017788e-03
  1300 KSP Residual norm 4.338363708766e-03
  1301 KSP Residual norm 4.087293049445e-03
  1302 KSP Residual norm 3.828187057594e-03
  1303 KSP Residual norm 3.615664295881e-03
  1304 KSP Residual norm 3.720737447464e-03
  1305 KSP Residual norm 3.995361756972e-03
  1306 KSP Residual norm 4.202771155210e-03
  1307 KSP Residual norm 4.412679881259e-03
  1308 KSP Residual norm 4.559842389085e-03
  1309 KSP Residual norm 4.771511782515e-03
  1310 KSP Residual norm 4.804998789986e-03
  1311 KSP Residual norm 5.021417214261e-03
  1312 KSP Residual norm 5.325459583935e-03
  1313 KSP Residual norm 5.448092377851e-03
  1314 KSP Residual norm 5.357339275060e-03
  1315 KSP Residual norm 5.172504557519e-03
  1316 KSP Residual norm 4.864858663382e-03
  1317 KSP Residual norm 4.573250060157e-03
  1318 KSP Residual norm 4.497697556282e-03
  1319 KSP Residual norm 4.611563966140e-03
  1320 KSP Residual norm 4.608284094663e-03
  1321 KSP Residual norm 4.378159837225e-03
  1322 KSP Residual norm 4.486083715508e-03
  1323 KSP Residual norm 5.006618659923e-03
  1324 KSP Residual norm 5.400365411200e-03
  1325 KSP Residual norm 5.307026679105e-03
  1326 KSP Residual norm 5.293514731677e-03
  1327 KSP Residual norm 5.306975541628e-03
  1328 KSP Residual norm 5.368792860268e-03
  1329 KSP Residual norm 4.919812160700e-03
  1330 KSP Residual norm 4.471669316051e-03
  1331 KSP Residual norm 4.515952541262e-03
  1332 KSP Residual norm 4.917163287239e-03
  1333 KSP Residual norm 5.245851058222e-03
  1334 KSP Residual norm 5.621468067928e-03
  1335 KSP Residual norm 5.652217685842e-03
  1336 KSP Residual norm 5.708425105195e-03
  1337 KSP Residual norm 5.824373614395e-03
  1338 KSP Residual norm 6.009562993019e-03
  1339 KSP Residual norm 6.144142720600e-03
  1340 KSP Residual norm 6.599285586716e-03
  1341 KSP Residual norm 7.344808253598e-03
  1342 KSP Residual norm 7.688040205459e-03
  1343 KSP Residual norm 7.586092654733e-03
  1344 KSP Residual norm 7.173564259039e-03
  1345 KSP Residual norm 6.598240988005e-03
  1346 KSP Residual norm 5.892587099044e-03
  1347 KSP Residual norm 5.613682437077e-03
  1348 KSP Residual norm 5.460696099903e-03
  1349 KSP Residual norm 5.462517746714e-03
  1350 KSP Residual norm 5.600953475630e-03
  1351 KSP Residual norm 5.387775229912e-03
  1352 KSP Residual norm 5.181412421696e-03
  1353 KSP Residual norm 4.931952401920e-03
  1354 KSP Residual norm 4.570619979257e-03
  1355 KSP Residual norm 4.377392593060e-03
  1356 KSP Residual norm 4.134943800022e-03
  1357 KSP Residual norm 4.050101621145e-03
  1358 KSP Residual norm 3.927170173902e-03
  1359 KSP Residual norm 4.002863746419e-03
  1360 KSP Residual norm 4.133904576647e-03
  1361 KSP Residual norm 4.093282465061e-03
  1362 KSP Residual norm 3.857297451022e-03
  1363 KSP Residual norm 3.620285409349e-03
  1364 KSP Residual norm 3.382937730415e-03
  1365 KSP Residual norm 3.338970913338e-03
  1366 KSP Residual norm 3.621615143604e-03
  1367 KSP Residual norm 4.004203600945e-03
  1368 KSP Residual norm 4.313641226175e-03
  1369 KSP Residual norm 4.381419457289e-03
  1370 KSP Residual norm 4.062557649672e-03
  1371 KSP Residual norm 3.804951568249e-03
  1372 KSP Residual norm 3.824966688333e-03
  1373 KSP Residual norm 4.170571410610e-03
  1374 KSP Residual norm 4.359063888330e-03
  1375 KSP Residual norm 4.369708161276e-03
  1376 KSP Residual norm 4.616366604858e-03
  1377 KSP Residual norm 4.813132711751e-03
  1378 KSP Residual norm 4.841581890431e-03
  1379 KSP Residual norm 4.615457216910e-03
  1380 KSP Residual norm 4.364865174047e-03
  1381 KSP Residual norm 4.402076551154e-03
  1382 KSP Residual norm 4.550847289956e-03
  1383 KSP Residual norm 4.653118821445e-03
  1384 KSP Residual norm 4.848951209101e-03
  1385 KSP Residual norm 5.335005979295e-03
  1386 KSP Residual norm 5.990831239637e-03
  1387 KSP Residual norm 6.390408526740e-03
  1388 KSP Residual norm 6.238132730307e-03
  1389 KSP Residual norm 5.777213476124e-03
  1390 KSP Residual norm 5.745474019357e-03
  1391 KSP Residual norm 6.171919713719e-03
  1392 KSP Residual norm 6.814628576131e-03
  1393 KSP Residual norm 7.092930622436e-03
  1394 KSP Residual norm 7.202829647083e-03
  1395 KSP Residual norm 7.263068243672e-03
  1396 KSP Residual norm 7.991866027692e-03
  1397 KSP Residual norm 8.076857344675e-03
  1398 KSP Residual norm 7.416722959321e-03
  1399 KSP Residual norm 7.256745039815e-03
  1400 KSP Residual norm 7.817460645521e-03
  1401 KSP Residual norm 7.888386414770e-03
  1402 KSP Residual norm 7.778721146485e-03
  1403 KSP Residual norm 7.633145130674e-03
  1404 KSP Residual norm 7.080884138097e-03
  1405 KSP Residual norm 6.392244539346e-03
  1406 KSP Residual norm 5.964969378442e-03
  1407 KSP Residual norm 5.759052737011e-03
  1408 KSP Residual norm 5.509325648131e-03
  1409 KSP Residual norm 4.965502665671e-03
  1410 KSP Residual norm 4.553387456256e-03
  1411 KSP Residual norm 4.350348933840e-03
  1412 KSP Residual norm 4.450579817108e-03
  1413 KSP Residual norm 4.462209314224e-03
  1414 KSP Residual norm 4.759025680116e-03
  1415 KSP Residual norm 4.843115994220e-03
  1416 KSP Residual norm 4.883781434826e-03
  1417 KSP Residual norm 4.855960636670e-03
  1418 KSP Residual norm 4.909991832520e-03
  1419 KSP Residual norm 5.167335712909e-03
  1420 KSP Residual norm 5.062535842783e-03
  1421 KSP Residual norm 4.861047026837e-03
  1422 KSP Residual norm 4.614075594659e-03
  1423 KSP Residual norm 4.448845132952e-03
  1424 KSP Residual norm 4.341318580693e-03
  1425 KSP Residual norm 4.446510898985e-03
  1426 KSP Residual norm 4.663442738450e-03
  1427 KSP Residual norm 4.765644861878e-03
  1428 KSP Residual norm 4.659291336051e-03
  1429 KSP Residual norm 4.359520779209e-03
  1430 KSP Residual norm 4.223229345176e-03
  1431 KSP Residual norm 4.418285143963e-03
  1432 KSP Residual norm 4.619124062440e-03
  1433 KSP Residual norm 4.553885494409e-03
  1434 KSP Residual norm 4.280900988546e-03
  1435 KSP Residual norm 4.085018266935e-03
  1436 KSP Residual norm 4.004797334160e-03
  1437 KSP Residual norm 4.007557730599e-03
  1438 KSP Residual norm 3.818920853936e-03
  1439 KSP Residual norm 3.735385033394e-03
  1440 KSP Residual norm 3.797665363864e-03
  1441 KSP Residual norm 3.647434711828e-03
  1442 KSP Residual norm 3.434667605772e-03
  1443 KSP Residual norm 3.579061679853e-03
  1444 KSP Residual norm 3.929397396732e-03
  1445 KSP Residual norm 4.161246364486e-03
  1446 KSP Residual norm 4.247942879325e-03
  1447 KSP Residual norm 4.214530157465e-03
  1448 KSP Residual norm 4.349880370678e-03
  1449 KSP Residual norm 4.382618450311e-03
  1450 KSP Residual norm 4.317896908899e-03
  1451 KSP Residual norm 4.318923942325e-03
  1452 KSP Residual norm 4.597371089027e-03
  1453 KSP Residual norm 4.734297417514e-03
  1454 KSP Residual norm 4.723529661083e-03
  1455 KSP Residual norm 4.535019309761e-03
  1456 KSP Residual norm 4.557228968325e-03
  1457 KSP Residual norm 4.675657336082e-03
  1458 KSP Residual norm 4.678101252096e-03
  1459 KSP Residual norm 4.440029523124e-03
  1460 KSP Residual norm 4.443447061774e-03
  1461 KSP Residual norm 4.675489876803e-03
  1462 KSP Residual norm 4.697316439515e-03
  1463 KSP Residual norm 4.347006366960e-03
  1464 KSP Residual norm 4.116358055477e-03
  1465 KSP Residual norm 3.909385741593e-03
  1466 KSP Residual norm 3.427271155185e-03
  1467 KSP Residual norm 3.148050704572e-03
  1468 KSP Residual norm 3.146758567557e-03
  1469 KSP Residual norm 3.326439000327e-03
  1470 KSP Residual norm 3.528227381870e-03
  1471 KSP Residual norm 3.734636049772e-03
  1472 KSP Residual norm 3.801175141192e-03
  1473 KSP Residual norm 3.682733054341e-03
  1474 KSP Residual norm 3.869391327748e-03
  1475 KSP Residual norm 4.124262041395e-03
  1476 KSP Residual norm 4.301928175170e-03
  1477 KSP Residual norm 4.360539607347e-03
  1478 KSP Residual norm 4.695576840578e-03
  1479 KSP Residual norm 5.338862907112e-03
  1480 KSP Residual norm 5.857255626224e-03
  1481 KSP Residual norm 5.758243446024e-03
  1482 KSP Residual norm 5.429528389948e-03
  1483 KSP Residual norm 5.332596773347e-03
  1484 KSP Residual norm 5.317884347570e-03
  1485 KSP Residual norm 5.251252274662e-03
  1486 KSP Residual norm 4.970344100120e-03
  1487 KSP Residual norm 4.679405455370e-03
  1488 KSP Residual norm 4.257698337737e-03
  1489 KSP Residual norm 3.922890835350e-03
  1490 KSP Residual norm 3.740125726498e-03
  1491 KSP Residual norm 3.739714064191e-03
  1492 KSP Residual norm 3.966049899764e-03
  1493 KSP Residual norm 4.027427417459e-03
  1494 KSP Residual norm 3.958089315333e-03
  1495 KSP Residual norm 3.911692723710e-03
  1496 KSP Residual norm 4.016878615819e-03
  1497 KSP Residual norm 4.250091344628e-03
  1498 KSP Residual norm 4.518796865137e-03
  1499 KSP Residual norm 5.010301973299e-03
  1500 KSP Residual norm 5.578390370620e-03
  1501 KSP Residual norm 5.614031960271e-03
  1502 KSP Residual norm 5.487587594523e-03
  1503 KSP Residual norm 5.490917249746e-03
  1504 KSP Residual norm 5.410518625817e-03
  1505 KSP Residual norm 4.795851091615e-03
  1506 KSP Residual norm 3.971918432854e-03
  1507 KSP Residual norm 3.703618718688e-03
  1508 KSP Residual norm 3.914709198679e-03
  1509 KSP Residual norm 4.020164070164e-03
  1510 KSP Residual norm 4.140657598389e-03
  1511 KSP Residual norm 4.045678848300e-03
  1512 KSP Residual norm 3.877274234083e-03
  1513 KSP Residual norm 3.773905053915e-03
  1514 KSP Residual norm 3.777227522832e-03
  1515 KSP Residual norm 3.615497735700e-03
  1516 KSP Residual norm 3.329500584338e-03
  1517 KSP Residual norm 3.211498061362e-03
  1518 KSP Residual norm 3.401609027037e-03
  1519 KSP Residual norm 3.792488962233e-03
  1520 KSP Residual norm 3.770037286683e-03
  1521 KSP Residual norm 3.396567762266e-03
  1522 KSP Residual norm 3.019110598211e-03
  1523 KSP Residual norm 3.152200151492e-03
  1524 KSP Residual norm 3.557575669406e-03
  1525 KSP Residual norm 3.872615871153e-03
  1526 KSP Residual norm 4.159628700692e-03
  1527 KSP Residual norm 4.183185965547e-03
  1528 KSP Residual norm 4.076722224240e-03
  1529 KSP Residual norm 3.792985283323e-03
  1530 KSP Residual norm 3.455971465179e-03
  1531 KSP Residual norm 3.346246982667e-03
  1532 KSP Residual norm 3.461595065848e-03
  1533 KSP Residual norm 3.719177306018e-03
  1534 KSP Residual norm 3.738392400040e-03
  1535 KSP Residual norm 3.321691072143e-03
  1536 KSP Residual norm 3.081074856988e-03
  1537 KSP Residual norm 3.326777042453e-03
  1538 KSP Residual norm 3.959519687464e-03
  1539 KSP Residual norm 4.448615395345e-03
  1540 KSP Residual norm 4.638141453377e-03
  1541 KSP Residual norm 4.626773464162e-03
  1542 KSP Residual norm 4.483684621375e-03
  1543 KSP Residual norm 4.342412403729e-03
  1544 KSP Residual norm 4.205782505569e-03
  1545 KSP Residual norm 4.106900721390e-03
  1546 KSP Residual norm 4.095639807755e-03
  1547 KSP Residual norm 4.162839274005e-03
  1548 KSP Residual norm 4.317606778375e-03
  1549 KSP Residual norm 4.299305149905e-03
  1550 KSP Residual norm 4.148649072744e-03
  1551 KSP Residual norm 4.073325903721e-03
  1552 KSP Residual norm 4.011903492316e-03
  1553 KSP Residual norm 3.927519683330e-03
  1554 KSP Residual norm 3.728278189639e-03
  1555 KSP Residual norm 3.524235386843e-03
  1556 KSP Residual norm 3.605233908790e-03
  1557 KSP Residual norm 3.997424334329e-03
  1558 KSP Residual norm 4.697881418515e-03
  1559 KSP Residual norm 4.893748047315e-03
  1560 KSP Residual norm 4.745987021851e-03
  1561 KSP Residual norm 4.450249967684e-03
  1562 KSP Residual norm 4.357138704257e-03
  1563 KSP Residual norm 4.367710481440e-03
  1564 KSP Residual norm 4.484935772773e-03
  1565 KSP Residual norm 4.499326997528e-03
  1566 KSP Residual norm 4.146770349785e-03
  1567 KSP Residual norm 3.712414470514e-03
  1568 KSP Residual norm 3.548515634102e-03
  1569 KSP Residual norm 3.660986761216e-03
  1570 KSP Residual norm 3.799659058599e-03
  1571 KSP Residual norm 3.814251344302e-03
  1572 KSP Residual norm 3.782927834391e-03
  1573 KSP Residual norm 3.856112517795e-03
  1574 KSP Residual norm 4.053264140504e-03
  1575 KSP Residual norm 4.098474476568e-03
  1576 KSP Residual norm 3.687961478176e-03
  1577 KSP Residual norm 3.334331419984e-03
  1578 KSP Residual norm 3.340775962920e-03
  1579 KSP Residual norm 3.647538053510e-03
  1580 KSP Residual norm 3.732505656428e-03
  1581 KSP Residual norm 3.569907419767e-03
  1582 KSP Residual norm 3.284915346407e-03
  1583 KSP Residual norm 2.867992050476e-03
  1584 KSP Residual norm 2.609457809758e-03
  1585 KSP Residual norm 2.548729593534e-03
  1586 KSP Residual norm 2.703303121263e-03
  1587 KSP Residual norm 2.991301617554e-03
  1588 KSP Residual norm 3.181960046360e-03
  1589 KSP Residual norm 2.812457127578e-03
  1590 KSP Residual norm 2.357118285072e-03
  1591 KSP Residual norm 2.331637798308e-03
  1592 KSP Residual norm 2.767640590317e-03
  1593 KSP Residual norm 3.120168921408e-03
  1594 KSP Residual norm 3.071446073340e-03
  1595 KSP Residual norm 2.901376408602e-03
  1596 KSP Residual norm 2.736985639322e-03
  1597 KSP Residual norm 2.685199238895e-03
  1598 KSP Residual norm 2.662069200765e-03
  1599 KSP Residual norm 2.723556510636e-03
  1600 KSP Residual norm 2.865503849469e-03
  1601 KSP Residual norm 3.124754319916e-03
  1602 KSP Residual norm 3.501928923907e-03
  1603 KSP Residual norm 3.710686527071e-03
  1604 KSP Residual norm 3.698074422762e-03
  1605 KSP Residual norm 3.433141741764e-03
  1606 KSP Residual norm 3.119678872135e-03
  1607 KSP Residual norm 2.928591276034e-03
  1608 KSP Residual norm 2.740490664497e-03
  1609 KSP Residual norm 2.700187040953e-03
  1610 KSP Residual norm 3.058181422370e-03
  1611 KSP Residual norm 3.631169145322e-03
  1612 KSP Residual norm 3.865620502931e-03
  1613 KSP Residual norm 3.410310938254e-03
  1614 KSP Residual norm 2.778380603588e-03
  1615 KSP Residual norm 2.519935144611e-03
  1616 KSP Residual norm 2.536730914580e-03
  1617 KSP Residual norm 2.722169589183e-03
  1618 KSP Residual norm 2.981607527716e-03
  1619 KSP Residual norm 3.074443842388e-03
  1620 KSP Residual norm 3.102897043425e-03
  1621 KSP Residual norm 3.334968227213e-03
  1622 KSP Residual norm 3.765759167624e-03
  1623 KSP Residual norm 4.260428606374e-03
  1624 KSP Residual norm 4.692079458287e-03
  1625 KSP Residual norm 5.031307315013e-03
  1626 KSP Residual norm 4.421918845491e-03
  1627 KSP Residual norm 3.287483165129e-03
  1628 KSP Residual norm 2.369767919189e-03
  1629 KSP Residual norm 1.932654903757e-03
  1630 KSP Residual norm 1.962317074491e-03
  1631 KSP Residual norm 2.434378646182e-03
  1632 KSP Residual norm 3.165878044867e-03
  1633 KSP Residual norm 4.008110394569e-03
  1634 KSP Residual norm 4.243942144954e-03
  1635 KSP Residual norm 3.502225516401e-03
  1636 KSP Residual norm 2.676679314493e-03
  1637 KSP Residual norm 2.113255870404e-03
  1638 KSP Residual norm 1.943585178476e-03
  1639 KSP Residual norm 2.182514404814e-03
  1640 KSP Residual norm 2.842236509915e-03
  1641 KSP Residual norm 3.797676250207e-03
  1642 KSP Residual norm 4.796159154955e-03
  1643 KSP Residual norm 4.855718878594e-03
  1644 KSP Residual norm 3.805743905144e-03
  1645 KSP Residual norm 2.836189035614e-03
  1646 KSP Residual norm 2.311683718706e-03
  1647 KSP Residual norm 2.304059112016e-03
  1648 KSP Residual norm 3.001923838056e-03
  1649 KSP Residual norm 4.465398931268e-03
  1650 KSP Residual norm 6.316248645066e-03
  1651 KSP Residual norm 7.460452089176e-03
  1652 KSP Residual norm 6.157762247948e-03
  1653 KSP Residual norm 4.028858910124e-03
  1654 KSP Residual norm 2.607315308302e-03
  1655 KSP Residual norm 2.135887579079e-03
  1656 KSP Residual norm 2.214752212489e-03
  1657 KSP Residual norm 2.889084953386e-03
  1658 KSP Residual norm 4.448359025874e-03
  1659 KSP Residual norm 6.312792290081e-03
  1660 KSP Residual norm 6.454085180289e-03
  1661 KSP Residual norm 4.821242484495e-03
  1662 KSP Residual norm 3.136267667322e-03
  1663 KSP Residual norm 2.048069925869e-03
  1664 KSP Residual norm 1.642042732627e-03
  1665 KSP Residual norm 1.776685047647e-03
  1666 KSP Residual norm 2.623757732771e-03
  1667 KSP Residual norm 4.458232614128e-03
  1668 KSP Residual norm 6.978633797115e-03
  1669 KSP Residual norm 7.237631617823e-03
  1670 KSP Residual norm 4.985964037370e-03
  1671 KSP Residual norm 2.915990817911e-03
  1672 KSP Residual norm 2.034845647516e-03
  1673 KSP Residual norm 1.913779478677e-03
  1674 KSP Residual norm 2.437839848479e-03
  1675 KSP Residual norm 3.816997921800e-03
  1676 KSP Residual norm 5.453049433777e-03
  1677 KSP Residual norm 5.652942559526e-03
  1678 KSP Residual norm 4.474314780586e-03
  1679 KSP Residual norm 2.979968710938e-03
  1680 KSP Residual norm 1.962384551434e-03
  1681 KSP Residual norm 1.629787231112e-03
  1682 KSP Residual norm 1.775963421001e-03
  1683 KSP Residual norm 2.570855608573e-03
  1684 KSP Residual norm 4.218418470023e-03
  1685 KSP Residual norm 6.808798194916e-03
  1686 KSP Residual norm 8.665640165091e-03
  1687 KSP Residual norm 6.816417271790e-03
  1688 KSP Residual norm 4.077925925808e-03
  1689 KSP Residual norm 2.529468344520e-03
  1690 KSP Residual norm 2.079852452529e-03
  1691 KSP Residual norm 2.169906661041e-03
  1692 KSP Residual norm 2.748732070558e-03
  1693 KSP Residual norm 4.293496737558e-03
  1694 KSP Residual norm 7.106427579240e-03
  1695 KSP Residual norm 1.039582615490e-02
  1696 KSP Residual norm 1.066412513256e-02
  1697 KSP Residual norm 7.363116007261e-03
  1698 KSP Residual norm 4.484806027494e-03
  1699 KSP Residual norm 3.194517941305e-03
  1700 KSP Residual norm 2.997403024709e-03
  1701 KSP Residual norm 3.715245506908e-03
  1702 KSP Residual norm 5.667183771566e-03
  1703 KSP Residual norm 9.895874135020e-03
  1704 KSP Residual norm 1.713628494096e-02
  1705 KSP Residual norm 2.253742675078e-02
  1706 KSP Residual norm 1.815633226840e-02
  1707 KSP Residual norm 1.027253732195e-02
  1708 KSP Residual norm 5.585731982869e-03
  1709 KSP Residual norm 3.560817037432e-03
  1710 KSP Residual norm 3.174754585629e-03
  1711 KSP Residual norm 4.087044780875e-03
  1712 KSP Residual norm 6.310730407470e-03
  1713 KSP Residual norm 8.889169687391e-03
  1714 KSP Residual norm 1.010227705484e-02
  1715 KSP Residual norm 9.757653183414e-03
  1716 KSP Residual norm 1.042924992465e-02
  1717 KSP Residual norm 1.236414617044e-02
  1718 KSP Residual norm 1.344340520603e-02
  1719 KSP Residual norm 9.861580508839e-03
  1720 KSP Residual norm 5.760429650522e-03
  1721 KSP Residual norm 3.968634397526e-03
  1722 KSP Residual norm 3.860048899695e-03
  1723 KSP Residual norm 4.885282153439e-03
  1724 KSP Residual norm 6.411846189810e-03
  1725 KSP Residual norm 7.528899153385e-03
  1726 KSP Residual norm 8.282565560188e-03
  1727 KSP Residual norm 1.028477470185e-02
  1728 KSP Residual norm 1.406352667328e-02
  1729 KSP Residual norm 1.613317508911e-02
  1730 KSP Residual norm 1.265179056408e-02
  1731 KSP Residual norm 8.433894035220e-03
  1732 KSP Residual norm 7.024467576599e-03
  1733 KSP Residual norm 7.522036580324e-03
  1734 KSP Residual norm 8.086010468802e-03
  1735 KSP Residual norm 6.775999043073e-03
  1736 KSP Residual norm 4.982660999927e-03
  1737 KSP Residual norm 4.153635535655e-03
  1738 KSP Residual norm 4.498743086892e-03
  1739 KSP Residual norm 6.376384796902e-03
  1740 KSP Residual norm 9.019305036726e-03
  1741 KSP Residual norm 1.008571307583e-02
  1742 KSP Residual norm 9.867622730951e-03
  1743 KSP Residual norm 1.130154844008e-02
  1744 KSP Residual norm 1.487352700809e-02
  1745 KSP Residual norm 1.674566260071e-02
  1746 KSP Residual norm 1.295908724076e-02
  1747 KSP Residual norm 9.270210719206e-03
  1748 KSP Residual norm 7.608571110303e-03
  1749 KSP Residual norm 6.682015809861e-03
  1750 KSP Residual norm 5.806877257439e-03
  1751 KSP Residual norm 4.662759516076e-03
  1752 KSP Residual norm 3.842666916488e-03
  1753 KSP Residual norm 3.669687472434e-03
  1754 KSP Residual norm 4.150693018521e-03
  1755 KSP Residual norm 5.197551156139e-03
  1756 KSP Residual norm 5.944114827337e-03
  1757 KSP Residual norm 6.456393033999e-03
  1758 KSP Residual norm 7.760231053459e-03
  1759 KSP Residual norm 1.037947368702e-02
  1760 KSP Residual norm 1.496028745626e-02
  1761 KSP Residual norm 1.618786763382e-02
  1762 KSP Residual norm 1.370970144802e-02
  1763 KSP Residual norm 1.180123064819e-02
  1764 KSP Residual norm 1.206538297991e-02
  1765 KSP Residual norm 1.128858176079e-02
  1766 KSP Residual norm 8.433779869320e-03
  1767 KSP Residual norm 5.728690607563e-03
  1768 KSP Residual norm 4.715870157427e-03
  1769 KSP Residual norm 4.903849994668e-03
  1770 KSP Residual norm 5.860927693618e-03
  1771 KSP Residual norm 5.955039528640e-03
  1772 KSP Residual norm 5.623262887997e-03
  1773 KSP Residual norm 6.396771032506e-03
  1774 KSP Residual norm 9.031367977476e-03
  1775 KSP Residual norm 1.299959176062e-02
  1776 KSP Residual norm 1.473141113096e-02
  1777 KSP Residual norm 1.301728743945e-02
  1778 KSP Residual norm 1.186704670476e-02
  1779 KSP Residual norm 1.271037519749e-02
  1780 KSP Residual norm 1.390386482594e-02
  1781 KSP Residual norm 1.203407490800e-02
  1782 KSP Residual norm 9.695334509794e-03
  1783 KSP Residual norm 8.568230932420e-03
  1784 KSP Residual norm 8.648198914198e-03
  1785 KSP Residual norm 8.377636695143e-03
  1786 KSP Residual norm 7.007933502942e-03
  1787 KSP Residual norm 5.982063968369e-03
  1788 KSP Residual norm 6.296043628802e-03
  1789 KSP Residual norm 7.651552723818e-03
  1790 KSP Residual norm 8.561237485700e-03
  1791 KSP Residual norm 8.559295288210e-03
  1792 KSP Residual norm 8.819457619708e-03
  1793 KSP Residual norm 1.100979421964e-02
  1794 KSP Residual norm 1.512814836318e-02
  1795 KSP Residual norm 1.747930112508e-02
  1796 KSP Residual norm 1.503911210909e-02
  1797 KSP Residual norm 1.333828397169e-02
  1798 KSP Residual norm 1.503110014031e-02
  1799 KSP Residual norm 1.858874048740e-02
  1800 KSP Residual norm 1.754785446477e-02
  1801 KSP Residual norm 1.265005935329e-02
  1802 KSP Residual norm 9.644563862227e-03
  1803 KSP Residual norm 8.339675321860e-03
  1804 KSP Residual norm 8.328279073357e-03
  1805 KSP Residual norm 7.687861874409e-03
  1806 KSP Residual norm 5.869926944451e-03
  1807 KSP Residual norm 4.854194518142e-03
  1808 KSP Residual norm 4.751080118652e-03
  1809 KSP Residual norm 5.304959976306e-03
  1810 KSP Residual norm 5.582226363115e-03
  1811 KSP Residual norm 5.301484986900e-03
  1812 KSP Residual norm 5.622322252902e-03
  1813 KSP Residual norm 7.282562214031e-03
  1814 KSP Residual norm 9.685663358062e-03
  1815 KSP Residual norm 1.110743276654e-02
  1816 KSP Residual norm 1.089423023046e-02
  1817 KSP Residual norm 1.200160432866e-02
  1818 KSP Residual norm 1.600239670961e-02
  1819 KSP Residual norm 2.114175274990e-02
  1820 KSP Residual norm 2.168298795445e-02
  1821 KSP Residual norm 1.924855736963e-02
  1822 KSP Residual norm 1.925728569694e-02
  1823 KSP Residual norm 2.156804080003e-02
  1824 KSP Residual norm 2.174795961672e-02
  1825 KSP Residual norm 1.857980960454e-02
  1826 KSP Residual norm 1.580064745947e-02
  1827 KSP Residual norm 1.464780188666e-02
  1828 KSP Residual norm 1.419629565106e-02
  1829 KSP Residual norm 1.199934486506e-02
  1830 KSP Residual norm 9.297607562041e-03
  1831 KSP Residual norm 7.973058376218e-03
  1832 KSP Residual norm 8.071779389779e-03
  1833 KSP Residual norm 7.655424487629e-03
  1834 KSP Residual norm 6.147071787004e-03
  1835 KSP Residual norm 5.092429298832e-03
  1836 KSP Residual norm 5.236830339569e-03
  1837 KSP Residual norm 5.903585382046e-03
  1838 KSP Residual norm 6.270704482619e-03
  1839 KSP Residual norm 6.429789049653e-03
  1840 KSP Residual norm 7.336468878096e-03
  1841 KSP Residual norm 9.369292088197e-03
  1842 KSP Residual norm 1.139526872507e-02
  1843 KSP Residual norm 1.185995814746e-02
  1844 KSP Residual norm 1.241981684210e-02
  1845 KSP Residual norm 1.554131717488e-02
  1846 KSP Residual norm 1.982680913327e-02
  1847 KSP Residual norm 2.082327701056e-02
  1848 KSP Residual norm 1.847297822087e-02
  1849 KSP Residual norm 1.726200472182e-02
  1850 KSP Residual norm 1.819892023894e-02
  1851 KSP Residual norm 1.812721678711e-02
  1852 KSP Residual norm 1.545821640092e-02
  1853 KSP Residual norm 1.351946708467e-02
  1854 KSP Residual norm 1.321421672781e-02
  1855 KSP Residual norm 1.203583764597e-02
  1856 KSP Residual norm 9.275182152481e-03
  1857 KSP Residual norm 7.166020487625e-03
  1858 KSP Residual norm 6.667041846874e-03
  1859 KSP Residual norm 6.979920613231e-03
  1860 KSP Residual norm 6.228819166919e-03
  1861 KSP Residual norm 5.296069511341e-03
  1862 KSP Residual norm 5.395934083308e-03
  1863 KSP Residual norm 6.589992548511e-03
  1864 KSP Residual norm 7.994790437338e-03
  1865 KSP Residual norm 8.198103360516e-03
  1866 KSP Residual norm 8.356807517315e-03
  1867 KSP Residual norm 9.552692725974e-03
  1868 KSP Residual norm 1.180930871093e-02
  1869 KSP Residual norm 1.369013031159e-02
  1870 KSP Residual norm 1.405625655625e-02
  1871 KSP Residual norm 1.499059973109e-02
  1872 KSP Residual norm 1.749830190835e-02
  1873 KSP Residual norm 1.923240732681e-02
  1874 KSP Residual norm 1.792581177987e-02
  1875 KSP Residual norm 1.595420253315e-02
  1876 KSP Residual norm 1.592437927271e-02
  1877 KSP Residual norm 1.571061792241e-02
  1878 KSP Residual norm 1.330409361058e-02
  1879 KSP Residual norm 1.011402845723e-02
  1880 KSP Residual norm 8.385714312478e-03
  1881 KSP Residual norm 7.619838379779e-03
  1882 KSP Residual norm 7.079068831244e-03
  1883 KSP Residual norm 6.263483895898e-03
  1884 KSP Residual norm 5.416913551314e-03
  1885 KSP Residual norm 5.248740770795e-03
  1886 KSP Residual norm 5.823178578214e-03
  1887 KSP Residual norm 5.856710332746e-03
  1888 KSP Residual norm 5.340607713094e-03
  1889 KSP Residual norm 5.372666907277e-03
  1890 KSP Residual norm 6.254021658222e-03
  1891 KSP Residual norm 7.002555893646e-03
  1892 KSP Residual norm 7.119015191351e-03
  1893 KSP Residual norm 7.398487660308e-03
  1894 KSP Residual norm 8.598149935475e-03
  1895 KSP Residual norm 9.082542888550e-03
  1896 KSP Residual norm 8.823606871381e-03
  1897 KSP Residual norm 8.351271646168e-03
  1898 KSP Residual norm 8.792697059084e-03
  1899 KSP Residual norm 9.434861567697e-03
  1900 KSP Residual norm 8.739188946527e-03
  1901 KSP Residual norm 7.439345048644e-03
  1902 KSP Residual norm 6.988512905492e-03
  1903 KSP Residual norm 7.266598646058e-03
  1904 KSP Residual norm 6.860594789317e-03
  1905 KSP Residual norm 5.869662347953e-03
  1906 KSP Residual norm 5.189292046807e-03
  1907 KSP Residual norm 4.698378415098e-03
  1908 KSP Residual norm 4.125932694582e-03
  1909 KSP Residual norm 3.623733579068e-03
  1910 KSP Residual norm 3.397717857275e-03
  1911 KSP Residual norm 3.450602416975e-03
  1912 KSP Residual norm 3.371679742809e-03
  1913 KSP Residual norm 3.211538717453e-03
  1914 KSP Residual norm 3.381570484386e-03
  1915 KSP Residual norm 3.752374891032e-03
  1916 KSP Residual norm 4.180224899146e-03
  1917 KSP Residual norm 4.425439107566e-03
  1918 KSP Residual norm 4.789578199346e-03
  1919 KSP Residual norm 5.284732777086e-03
  1920 KSP Residual norm 5.612706090822e-03
  1921 KSP Residual norm 5.861795033631e-03
  1922 KSP Residual norm 6.262650523811e-03
  1923 KSP Residual norm 7.405189723965e-03
  1924 KSP Residual norm 8.588777389142e-03
  1925 KSP Residual norm 9.036165294655e-03
  1926 KSP Residual norm 9.216393583533e-03
  1927 KSP Residual norm 1.015521724006e-02
  1928 KSP Residual norm 1.063074433343e-02
  1929 KSP Residual norm 9.895151313230e-03
  1930 KSP Residual norm 9.097228298051e-03
  1931 KSP Residual norm 8.685730919586e-03
  1932 KSP Residual norm 8.534987793340e-03
  1933 KSP Residual norm 7.863482725812e-03
  1934 KSP Residual norm 6.232590539545e-03
  1935 KSP Residual norm 5.209143529906e-03
  1936 KSP Residual norm 4.983723053720e-03
  1937 KSP Residual norm 4.813332251178e-03
  1938 KSP Residual norm 4.284521837285e-03
  1939 KSP Residual norm 3.984519392867e-03
  1940 KSP Residual norm 4.077399442331e-03
  1941 KSP Residual norm 4.352043481077e-03
  1942 KSP Residual norm 4.461858984941e-03
  1943 KSP Residual norm 4.380420741836e-03
  1944 KSP Residual norm 4.734130093898e-03
  1945 KSP Residual norm 5.852860035227e-03
  1946 KSP Residual norm 6.975950093485e-03
  1947 KSP Residual norm 7.052942525567e-03
  1948 KSP Residual norm 6.928412056660e-03
  1949 KSP Residual norm 7.888872516775e-03
  1950 KSP Residual norm 9.111899173159e-03
  1951 KSP Residual norm 9.278983874453e-03
  1952 KSP Residual norm 9.858700588481e-03
  1953 KSP Residual norm 1.179287626505e-02
  1954 KSP Residual norm 1.282807255394e-02
  1955 KSP Residual norm 1.262679691404e-02
  1956 KSP Residual norm 1.255775353882e-02
  1957 KSP Residual norm 1.370183873868e-02
  1958 KSP Residual norm 1.400213065512e-02
  1959 KSP Residual norm 1.283815157619e-02
  1960 KSP Residual norm 1.235915610084e-02
  1961 KSP Residual norm 1.266753849066e-02
  1962 KSP Residual norm 1.244201832218e-02
  1963 KSP Residual norm 1.041024275825e-02
  1964 KSP Residual norm 8.842758841380e-03
  1965 KSP Residual norm 8.240799359774e-03
  1966 KSP Residual norm 7.948646573032e-03
  1967 KSP Residual norm 6.445879239365e-03
  1968 KSP Residual norm 5.559004256048e-03
  1969 KSP Residual norm 5.066960361645e-03
  1970 KSP Residual norm 4.673923122700e-03
  1971 KSP Residual norm 4.072119570099e-03
  1972 KSP Residual norm 3.530170413031e-03
  1973 KSP Residual norm 3.445412172218e-03
  1974 KSP Residual norm 3.692808674938e-03
  1975 KSP Residual norm 3.509296213417e-03
  1976 KSP Residual norm 3.194284614736e-03
  1977 KSP Residual norm 3.214085704621e-03
  1978 KSP Residual norm 3.312784983574e-03
  1979 KSP Residual norm 3.376878732161e-03
  1980 KSP Residual norm 3.517881561328e-03
  1981 KSP Residual norm 3.693201640814e-03
  1982 KSP Residual norm 4.035821718953e-03
  1983 KSP Residual norm 4.303835709655e-03
  1984 KSP Residual norm 4.552984049764e-03
  1985 KSP Residual norm 5.220254958434e-03
  1986 KSP Residual norm 6.551890355271e-03
  1987 KSP Residual norm 8.381415823956e-03
  1988 KSP Residual norm 9.738560576716e-03
  1989 KSP Residual norm 1.100926661348e-02
  1990 KSP Residual norm 1.246532004316e-02
  1991 KSP Residual norm 1.407235479874e-02
  1992 KSP Residual norm 1.461033789890e-02
  1993 KSP Residual norm 1.466527654767e-02
  1994 KSP Residual norm 1.608542024596e-02
  1995 KSP Residual norm 1.723354282800e-02
  1996 KSP Residual norm 1.654429130126e-02
  1997 KSP Residual norm 1.497588013766e-02
  1998 KSP Residual norm 1.422318323008e-02
  1999 KSP Residual norm 1.372816158785e-02
  2000 KSP Residual norm 1.187907197624e-02
  2001 KSP Residual norm 9.530673313997e-03
  2002 KSP Residual norm 8.350842995280e-03
  2003 KSP Residual norm 8.040856946159e-03
  2004 KSP Residual norm 7.300758382425e-03
  2005 KSP Residual norm 6.351812200229e-03
  2006 KSP Residual norm 5.449815802557e-03
  2007 KSP Residual norm 5.410388539106e-03
  2008 KSP Residual norm 5.497381835543e-03
  2009 KSP Residual norm 4.766470175888e-03
  2010 KSP Residual norm 3.920445921370e-03
  2011 KSP Residual norm 3.635909540975e-03
  2012 KSP Residual norm 3.578050027117e-03
  2013 KSP Residual norm 3.281862671151e-03
  2014 KSP Residual norm 3.147248560594e-03
  2015 KSP Residual norm 3.257930715380e-03
  2016 KSP Residual norm 3.528434561439e-03
  2017 KSP Residual norm 3.704069547408e-03
  2018 KSP Residual norm 3.666226252482e-03
  2019 KSP Residual norm 3.748786599519e-03
  2020 KSP Residual norm 4.224789132151e-03
  2021 KSP Residual norm 4.713188915244e-03
  2022 KSP Residual norm 4.914611177949e-03
  2023 KSP Residual norm 5.100616440787e-03
  2024 KSP Residual norm 5.619478115716e-03
  2025 KSP Residual norm 6.242762113305e-03
  2026 KSP Residual norm 6.657735104471e-03
  2027 KSP Residual norm 7.401660853611e-03
  2028 KSP Residual norm 8.182706351312e-03
  2029 KSP Residual norm 8.293373495531e-03
  2030 KSP Residual norm 7.720806516677e-03
  2031 KSP Residual norm 7.731863907682e-03
  2032 KSP Residual norm 8.085902710517e-03
  2033 KSP Residual norm 7.932570278344e-03
  2034 KSP Residual norm 7.332322255068e-03
  2035 KSP Residual norm 6.981249891929e-03
  2036 KSP Residual norm 7.071360310580e-03
  2037 KSP Residual norm 6.607769945073e-03
  2038 KSP Residual norm 5.661103487318e-03
  2039 KSP Residual norm 5.113391338547e-03
  2040 KSP Residual norm 4.829759783025e-03
  2041 KSP Residual norm 4.583432553280e-03
  2042 KSP Residual norm 4.072399257332e-03
  2043 KSP Residual norm 3.457746678394e-03
  2044 KSP Residual norm 3.103218976754e-03
  2045 KSP Residual norm 2.986630897216e-03
  2046 KSP Residual norm 2.752096872884e-03
  2047 KSP Residual norm 2.601932301287e-03
  2048 KSP Residual norm 2.720727886614e-03
  2049 KSP Residual norm 2.887925956684e-03
  2050 KSP Residual norm 3.018447606692e-03
  2051 KSP Residual norm 3.082987476405e-03
  2052 KSP Residual norm 3.366759308843e-03
  2053 KSP Residual norm 3.759993248183e-03
  2054 KSP Residual norm 4.037275861301e-03
  2055 KSP Residual norm 4.049762465846e-03
  2056 KSP Residual norm 4.291473542844e-03
  2057 KSP Residual norm 4.793912122751e-03
  2058 KSP Residual norm 5.429296355667e-03
  2059 KSP Residual norm 5.999137088175e-03
  2060 KSP Residual norm 6.714532180763e-03
  2061 KSP Residual norm 7.157076086637e-03
  2062 KSP Residual norm 7.305423541139e-03
  2063 KSP Residual norm 7.840616914368e-03
  2064 KSP Residual norm 8.621338555374e-03
  2065 KSP Residual norm 9.179826914789e-03
  2066 KSP Residual norm 9.219040982171e-03
  2067 KSP Residual norm 9.081038905495e-03
  2068 KSP Residual norm 9.145498306064e-03
  2069 KSP Residual norm 9.219909480688e-03
  2070 KSP Residual norm 9.266003675083e-03
  2071 KSP Residual norm 8.549392921627e-03
  2072 KSP Residual norm 7.813939776317e-03
  2073 KSP Residual norm 7.511934879918e-03
  2074 KSP Residual norm 6.987487537767e-03
  2075 KSP Residual norm 6.181082525053e-03
  2076 KSP Residual norm 5.501067850667e-03
  2077 KSP Residual norm 5.316939535299e-03
  2078 KSP Residual norm 5.376044849232e-03
  2079 KSP Residual norm 4.812349537692e-03
  2080 KSP Residual norm 4.083001156083e-03
  2081 KSP Residual norm 3.984095588508e-03
  2082 KSP Residual norm 4.166602468433e-03
  2083 KSP Residual norm 3.736388905897e-03
  2084 KSP Residual norm 3.181344392970e-03
  2085 KSP Residual norm 3.087472465346e-03
  2086 KSP Residual norm 3.299309121667e-03
  2087 KSP Residual norm 3.122460123169e-03
  2088 KSP Residual norm 2.904036501409e-03
  2089 KSP Residual norm 2.916197279864e-03
  2090 KSP Residual norm 3.158694228775e-03
  2091 KSP Residual norm 3.299142972491e-03
  2092 KSP Residual norm 3.213974282697e-03
  2093 KSP Residual norm 3.321177716622e-03
  2094 KSP Residual norm 3.885809232016e-03
  2095 KSP Residual norm 4.328927945493e-03
  2096 KSP Residual norm 4.128316493644e-03
  2097 KSP Residual norm 4.061668994145e-03
  2098 KSP Residual norm 4.632615412637e-03
  2099 KSP Residual norm 5.419201729535e-03
  2100 KSP Residual norm 5.806306099173e-03
  2101 KSP Residual norm 6.499985237890e-03
  2102 KSP Residual norm 8.009977304793e-03
  2103 KSP Residual norm 9.143990958236e-03
  2104 KSP Residual norm 9.206698244420e-03
  2105 KSP Residual norm 9.294092252086e-03
  2106 KSP Residual norm 9.563695136136e-03
  2107 KSP Residual norm 8.860454764156e-03
  2108 KSP Residual norm 8.024764898450e-03
  2109 KSP Residual norm 7.718856528597e-03
  2110 KSP Residual norm 7.582562138927e-03
  2111 KSP Residual norm 7.114006432207e-03
  2112 KSP Residual norm 6.695573452676e-03
  2113 KSP Residual norm 6.318059725508e-03
  2114 KSP Residual norm 5.735068156662e-03
  2115 KSP Residual norm 5.486371917502e-03
  2116 KSP Residual norm 5.317941170076e-03
  2117 KSP Residual norm 5.153691910605e-03
  2118 KSP Residual norm 4.996322690960e-03
  2119 KSP Residual norm 4.639298979665e-03
  2120 KSP Residual norm 4.155770131347e-03
  2121 KSP Residual norm 3.875657105043e-03
  2122 KSP Residual norm 3.659569568406e-03
  2123 KSP Residual norm 3.574986658392e-03
  2124 KSP Residual norm 3.528766455188e-03
  2125 KSP Residual norm 3.301499565247e-03
  2126 KSP Residual norm 3.034514817403e-03
  2127 KSP Residual norm 2.762297206424e-03
  2128 KSP Residual norm 2.758080912531e-03
  2129 KSP Residual norm 3.004429701481e-03
  2130 KSP Residual norm 3.187509659594e-03
  2131 KSP Residual norm 3.320572410868e-03
  2132 KSP Residual norm 3.299541354205e-03
  2133 KSP Residual norm 3.223831194932e-03
  2134 KSP Residual norm 3.189967754497e-03
  2135 KSP Residual norm 3.403427921578e-03
  2136 KSP Residual norm 3.584610061763e-03
  2137 KSP Residual norm 3.711454211957e-03
  2138 KSP Residual norm 3.953840788285e-03
  2139 KSP Residual norm 4.105451876925e-03
  2140 KSP Residual norm 4.177676230502e-03
  2141 KSP Residual norm 4.308532456220e-03
  2142 KSP Residual norm 4.709470620439e-03
  2143 KSP Residual norm 5.773774414679e-03
  2144 KSP Residual norm 6.587720688920e-03
  2145 KSP Residual norm 6.770095137610e-03
  2146 KSP Residual norm 8.024962739428e-03
  2147 KSP Residual norm 9.979006460618e-03
  2148 KSP Residual norm 1.065598861617e-02
  2149 KSP Residual norm 1.028467092583e-02
  2150 KSP Residual norm 1.031263755519e-02
  2151 KSP Residual norm 1.018699324856e-02
  2152 KSP Residual norm 9.406281252560e-03
  2153 KSP Residual norm 8.920330262389e-03
  2154 KSP Residual norm 8.971791173694e-03
  2155 KSP Residual norm 9.516663684974e-03
  2156 KSP Residual norm 9.079106424707e-03
  2157 KSP Residual norm 7.963741724505e-03
  2158 KSP Residual norm 7.154186451308e-03
  2159 KSP Residual norm 6.775668514411e-03
  2160 KSP Residual norm 6.390988704684e-03
  2161 KSP Residual norm 5.772587283237e-03
  2162 KSP Residual norm 5.435320689840e-03
  2163 KSP Residual norm 5.465545999965e-03
  2164 KSP Residual norm 5.233001651176e-03
  2165 KSP Residual norm 4.652810907220e-03
  2166 KSP Residual norm 4.447632631418e-03
  2167 KSP Residual norm 4.448594208194e-03
  2168 KSP Residual norm 4.350817195271e-03
  2169 KSP Residual norm 4.205294412744e-03
  2170 KSP Residual norm 4.223189936177e-03
  2171 KSP Residual norm 4.288138588316e-03
  2172 KSP Residual norm 4.076768554048e-03
  2173 KSP Residual norm 3.949251053219e-03
  2174 KSP Residual norm 4.222998063808e-03
  2175 KSP Residual norm 4.394186001931e-03
  2176 KSP Residual norm 4.431744202567e-03
  2177 KSP Residual norm 4.714660974315e-03
  2178 KSP Residual norm 5.265011457330e-03
  2179 KSP Residual norm 5.550076240279e-03
  2180 KSP Residual norm 5.385488061286e-03
  2181 KSP Residual norm 5.170849664168e-03
  2182 KSP Residual norm 5.844721354479e-03
  2183 KSP Residual norm 7.297130276539e-03
  2184 KSP Residual norm 7.850736875997e-03
  2185 KSP Residual norm 7.698468024820e-03
  2186 KSP Residual norm 8.290259524435e-03
  2187 KSP Residual norm 9.384539453648e-03
  2188 KSP Residual norm 9.735129216493e-03
  2189 KSP Residual norm 9.868657977979e-03
  2190 KSP Residual norm 1.091551433912e-02
  2191 KSP Residual norm 1.245981706657e-02
  2192 KSP Residual norm 1.197197715594e-02
  2193 KSP Residual norm 1.164069198550e-02
  2194 KSP Residual norm 1.244648944014e-02
  2195 KSP Residual norm 1.350572985483e-02
  2196 KSP Residual norm 1.373395245921e-02
  2197 KSP Residual norm 1.328422543346e-02
  2198 KSP Residual norm 1.223399174464e-02
  2199 KSP Residual norm 1.162356128188e-02
  2200 KSP Residual norm 1.066884095926e-02
  2201 KSP Residual norm 9.112010736212e-03
  2202 KSP Residual norm 8.422796463594e-03
  2203 KSP Residual norm 8.383002149071e-03
  2204 KSP Residual norm 7.824083280895e-03
  2205 KSP Residual norm 7.034107064892e-03
  2206 KSP Residual norm 6.406017848159e-03
  2207 KSP Residual norm 5.924109479508e-03
  2208 KSP Residual norm 5.357465387764e-03
  2209 KSP Residual norm 4.984026665317e-03
  2210 KSP Residual norm 4.746244849070e-03
  2211 KSP Residual norm 4.376851720421e-03
  2212 KSP Residual norm 3.720427440057e-03
  2213 KSP Residual norm 3.146408949809e-03
  2214 KSP Residual norm 2.890006160957e-03
  2215 KSP Residual norm 2.756658730239e-03
  2216 KSP Residual norm 2.653215495302e-03
  2217 KSP Residual norm 2.650206256948e-03
  2218 KSP Residual norm 2.721887896256e-03
  2219 KSP Residual norm 2.684622175643e-03
  2220 KSP Residual norm 2.488504584793e-03
  2221 KSP Residual norm 2.386959412109e-03
  2222 KSP Residual norm 2.371450010664e-03
  2223 KSP Residual norm 2.499419977970e-03
  2224 KSP Residual norm 2.693033707163e-03
  2225 KSP Residual norm 2.860677622571e-03
  2226 KSP Residual norm 2.952863582608e-03
  2227 KSP Residual norm 2.988598797066e-03
  2228 KSP Residual norm 2.890748879091e-03
  2229 KSP Residual norm 2.868441200643e-03
  2230 KSP Residual norm 2.991111970293e-03
  2231 KSP Residual norm 3.172985514033e-03
  2232 KSP Residual norm 3.292606908435e-03
  2233 KSP Residual norm 3.392155811553e-03
  2234 KSP Residual norm 3.535230701617e-03
  2235 KSP Residual norm 3.959373637352e-03
  2236 KSP Residual norm 4.565212140205e-03
  2237 KSP Residual norm 4.821196987496e-03
  2238 KSP Residual norm 4.922415050281e-03
  2239 KSP Residual norm 5.072974539554e-03
  2240 KSP Residual norm 5.263813883195e-03
  2241 KSP Residual norm 5.426306929832e-03
  2242 KSP Residual norm 6.120664810580e-03
  2243 KSP Residual norm 7.159099015502e-03
  2244 KSP Residual norm 7.409615555114e-03
  2245 KSP Residual norm 7.513554331491e-03
  2246 KSP Residual norm 8.000313332997e-03
  2247 KSP Residual norm 8.774490252024e-03
  2248 KSP Residual norm 9.039336379211e-03
  2249 KSP Residual norm 9.416574883628e-03
  2250 KSP Residual norm 1.045552940291e-02
  2251 KSP Residual norm 1.095124765772e-02
  2252 KSP Residual norm 1.091067731545e-02
  2253 KSP Residual norm 1.072798400570e-02
  2254 KSP Residual norm 1.053330165208e-02
  2255 KSP Residual norm 1.087027560563e-02
  2256 KSP Residual norm 1.094340292209e-02
  2257 KSP Residual norm 9.944151818544e-03
  2258 KSP Residual norm 9.524326498058e-03
  2259 KSP Residual norm 9.857883498125e-03
  2260 KSP Residual norm 9.999241781813e-03
  2261 KSP Residual norm 8.917422673018e-03
  2262 KSP Residual norm 8.019990947943e-03
  2263 KSP Residual norm 7.923931148596e-03
  2264 KSP Residual norm 7.630228933650e-03
  2265 KSP Residual norm 6.890681148470e-03
  2266 KSP Residual norm 6.397314247109e-03
  2267 KSP Residual norm 6.076721021358e-03
  2268 KSP Residual norm 5.769028879956e-03
  2269 KSP Residual norm 5.336649542499e-03
  2270 KSP Residual norm 4.881407930542e-03
  2271 KSP Residual norm 4.577405831613e-03
  2272 KSP Residual norm 4.213415851037e-03
  2273 KSP Residual norm 3.775766616320e-03
  2274 KSP Residual norm 3.404244489367e-03
  2275 KSP Residual norm 3.261894222734e-03
  2276 KSP Residual norm 3.100577799789e-03
  2277 KSP Residual norm 2.763231017518e-03
  2278 KSP Residual norm 2.567503732718e-03
  2279 KSP Residual norm 2.629261305111e-03
  2280 KSP Residual norm 2.583372462179e-03
  2281 KSP Residual norm 2.257492720860e-03
  2282 KSP Residual norm 2.168975357396e-03
  2283 KSP Residual norm 2.355179931970e-03
  2284 KSP Residual norm 2.492067164151e-03
  2285 KSP Residual norm 2.456665907090e-03
  2286 KSP Residual norm 2.437810288837e-03
  2287 KSP Residual norm 2.740218703631e-03
  2288 KSP Residual norm 2.946953069909e-03
  2289 KSP Residual norm 2.787872921852e-03
  2290 KSP Residual norm 2.725536734613e-03
  2291 KSP Residual norm 3.033412099267e-03
  2292 KSP Residual norm 3.272583682207e-03
  2293 KSP Residual norm 3.204235568301e-03
  2294 KSP Residual norm 3.421108353676e-03
  2295 KSP Residual norm 3.971217627917e-03
  2296 KSP Residual norm 4.128587634961e-03
  2297 KSP Residual norm 4.298336760100e-03
  2298 KSP Residual norm 4.722062357837e-03
  2299 KSP Residual norm 5.697560142610e-03
  2300 KSP Residual norm 5.968990862527e-03
  2301 KSP Residual norm 5.826561794337e-03
  2302 KSP Residual norm 6.359427330795e-03
  2303 KSP Residual norm 7.376375276938e-03
  2304 KSP Residual norm 7.922245439289e-03
  2305 KSP Residual norm 8.028445372328e-03
  2306 KSP Residual norm 7.699912691885e-03
  2307 KSP Residual norm 7.587940128727e-03
  2308 KSP Residual norm 7.960298833559e-03
  2309 KSP Residual norm 8.461080082996e-03
  2310 KSP Residual norm 9.332967294487e-03
  2311 KSP Residual norm 1.057501275364e-02
  2312 KSP Residual norm 1.151537427737e-02
  2313 KSP Residual norm 1.208983731323e-02
  2314 KSP Residual norm 1.270610053976e-02
  2315 KSP Residual norm 1.401458135679e-02
  2316 KSP Residual norm 1.465214520382e-02
  2317 KSP Residual norm 1.486866786002e-02
  2318 KSP Residual norm 1.560342833672e-02
  2319 KSP Residual norm 1.699230182908e-02
  2320 KSP Residual norm 1.811264580263e-02
  2321 KSP Residual norm 1.771933729362e-02
  2322 KSP Residual norm 1.820507682733e-02
  2323 KSP Residual norm 1.790918445477e-02
  2324 KSP Residual norm 1.672804542537e-02
  2325 KSP Residual norm 1.552464898903e-02
  2326 KSP Residual norm 1.542876923443e-02
  2327 KSP Residual norm 1.452627185034e-02
  2328 KSP Residual norm 1.355062176346e-02
  2329 KSP Residual norm 1.260040776986e-02
  2330 KSP Residual norm 1.229162073681e-02
  2331 KSP Residual norm 1.228076319119e-02
  2332 KSP Residual norm 1.154472090508e-02
  2333 KSP Residual norm 1.048177215151e-02
  2334 KSP Residual norm 9.744028166372e-03
  2335 KSP Residual norm 9.596511059772e-03
  2336 KSP Residual norm 9.486410482497e-03
  2337 KSP Residual norm 8.745430932840e-03
  2338 KSP Residual norm 8.210290136575e-03
  2339 KSP Residual norm 7.839236326358e-03
  2340 KSP Residual norm 7.194744679873e-03
  2341 KSP Residual norm 6.571357371524e-03
  2342 KSP Residual norm 6.106849801378e-03
  2343 KSP Residual norm 6.022124082466e-03
  2344 KSP Residual norm 5.880372351873e-03
  2345 KSP Residual norm 5.944846889075e-03
  2346 KSP Residual norm 5.961756628698e-03
  2347 KSP Residual norm 5.826538667703e-03
  2348 KSP Residual norm 5.760630918210e-03
  2349 KSP Residual norm 5.492884703535e-03
  2350 KSP Residual norm 5.410281952695e-03
  2351 KSP Residual norm 5.494273029143e-03
  2352 KSP Residual norm 5.303777160006e-03
  2353 KSP Residual norm 5.299306677113e-03
  2354 KSP Residual norm 5.593943123853e-03
  2355 KSP Residual norm 5.947341230891e-03
  2356 KSP Residual norm 6.248050330786e-03
  2357 KSP Residual norm 6.672418445200e-03
  2358 KSP Residual norm 6.840759883722e-03
  2359 KSP Residual norm 7.311645521061e-03
  2360 KSP Residual norm 8.528165651140e-03
  2361 KSP Residual norm 9.359232085623e-03
  2362 KSP Residual norm 8.997214443045e-03
  2363 KSP Residual norm 9.151512001640e-03
  2364 KSP Residual norm 9.814919143160e-03
  2365 KSP Residual norm 9.473961467521e-03
  2366 KSP Residual norm 8.916794002765e-03
  2367 KSP Residual norm 9.580099819334e-03
  2368 KSP Residual norm 1.092803287468e-02
  2369 KSP Residual norm 1.177066696453e-02
  2370 KSP Residual norm 1.233610734730e-02
  2371 KSP Residual norm 1.349596697859e-02
  2372 KSP Residual norm 1.422597580577e-02
  2373 KSP Residual norm 1.394041333853e-02
  2374 KSP Residual norm 1.324928418055e-02
  2375 KSP Residual norm 1.396539289495e-02
  2376 KSP Residual norm 1.514717693073e-02
  2377 KSP Residual norm 1.451979579451e-02
  2378 KSP Residual norm 1.264633392368e-02
  2379 KSP Residual norm 1.110823036001e-02
  2380 KSP Residual norm 1.006475915249e-02
  2381 KSP Residual norm 9.365164277252e-03
  2382 KSP Residual norm 9.045684726161e-03
  2383 KSP Residual norm 8.579824342906e-03
  2384 KSP Residual norm 8.162256717764e-03
  2385 KSP Residual norm 7.491664866784e-03
  2386 KSP Residual norm 7.139888523418e-03
  2387 KSP Residual norm 7.212352332472e-03
  2388 KSP Residual norm 7.129900453900e-03
  2389 KSP Residual norm 6.429884715097e-03
  2390 KSP Residual norm 6.118678763045e-03
  2391 KSP Residual norm 6.653860543467e-03
  2392 KSP Residual norm 6.582069714587e-03
  2393 KSP Residual norm 5.762185306889e-03
  2394 KSP Residual norm 5.456077407301e-03
  2395 KSP Residual norm 5.436151997470e-03
  2396 KSP Residual norm 5.019341766606e-03
  2397 KSP Residual norm 4.700956991695e-03
  2398 KSP Residual norm 4.668023157564e-03
  2399 KSP Residual norm 4.501515700463e-03
  2400 KSP Residual norm 4.197022164665e-03
  2401 KSP Residual norm 3.817706011035e-03
  2402 KSP Residual norm 3.664318386502e-03
  2403 KSP Residual norm 3.767331470893e-03
  2404 KSP Residual norm 3.850171435180e-03
  2405 KSP Residual norm 3.890255062260e-03
  2406 KSP Residual norm 4.075339454006e-03
  2407 KSP Residual norm 4.343737239892e-03
  2408 KSP Residual norm 4.331519772355e-03
  2409 KSP Residual norm 4.268280541827e-03
  2410 KSP Residual norm 4.464476774624e-03
  2411 KSP Residual norm 4.943672287012e-03
  2412 KSP Residual norm 5.317709547685e-03
  2413 KSP Residual norm 5.459401763318e-03
  2414 KSP Residual norm 5.646754403152e-03
  2415 KSP Residual norm 5.774969211463e-03
  2416 KSP Residual norm 5.708560645311e-03
  2417 KSP Residual norm 5.674091351982e-03
  2418 KSP Residual norm 5.854876560222e-03
  2419 KSP Residual norm 6.260401374731e-03
  2420 KSP Residual norm 6.621278399721e-03
  2421 KSP Residual norm 7.282592497201e-03
  2422 KSP Residual norm 8.093100105437e-03
  2423 KSP Residual norm 8.303737134056e-03
  2424 KSP Residual norm 8.401936399922e-03
  2425 KSP Residual norm 8.811703568770e-03
  2426 KSP Residual norm 8.942527065268e-03
  2427 KSP Residual norm 9.454131455613e-03
  2428 KSP Residual norm 1.056739724498e-02
  2429 KSP Residual norm 1.131059497836e-02
  2430 KSP Residual norm 1.135639791659e-02
  2431 KSP Residual norm 1.205126873730e-02
  2432 KSP Residual norm 1.262495951635e-02
  2433 KSP Residual norm 1.303848674425e-02
  2434 KSP Residual norm 1.301252885924e-02
  2435 KSP Residual norm 1.377500347167e-02
  2436 KSP Residual norm 1.429601251787e-02
  2437 KSP Residual norm 1.392106005918e-02
  2438 KSP Residual norm 1.360317743723e-02
  2439 KSP Residual norm 1.426602654522e-02
  2440 KSP Residual norm 1.510382328407e-02
  2441 KSP Residual norm 1.473928783444e-02
  2442 KSP Residual norm 1.380171657314e-02
  2443 KSP Residual norm 1.268300260363e-02
  2444 KSP Residual norm 1.255281825396e-02
  2445 KSP Residual norm 1.268661415517e-02
  2446 KSP Residual norm 1.295737164497e-02
  2447 KSP Residual norm 1.355555123857e-02
  2448 KSP Residual norm 1.355735990527e-02
  2449 KSP Residual norm 1.336200081031e-02
  2450 KSP Residual norm 1.252572155735e-02
  2451 KSP Residual norm 1.131979365474e-02
  2452 KSP Residual norm 1.100821509650e-02
  2453 KSP Residual norm 1.087773496952e-02
  2454 KSP Residual norm 1.013125318378e-02
  2455 KSP Residual norm 9.805815814668e-03
  2456 KSP Residual norm 1.004451530965e-02
  2457 KSP Residual norm 9.575804427701e-03
  2458 KSP Residual norm 8.652734196563e-03
  2459 KSP Residual norm 8.163438150136e-03
  2460 KSP Residual norm 8.041074727141e-03
  2461 KSP Residual norm 7.346137486217e-03
  2462 KSP Residual norm 6.565328169772e-03
  2463 KSP Residual norm 6.495238995987e-03
  2464 KSP Residual norm 6.543818246286e-03
  2465 KSP Residual norm 5.844422743171e-03
  2466 KSP Residual norm 5.161768107683e-03
  2467 KSP Residual norm 4.998513002561e-03
  2468 KSP Residual norm 5.023178132147e-03
  2469 KSP Residual norm 4.955750454620e-03
  2470 KSP Residual norm 4.914149665942e-03
  2471 KSP Residual norm 5.082266464149e-03
  2472 KSP Residual norm 5.226795434602e-03
  2473 KSP Residual norm 5.083034164029e-03
  2474 KSP Residual norm 4.786180670349e-03
  2475 KSP Residual norm 4.723714363499e-03
  2476 KSP Residual norm 4.706592527681e-03
  2477 KSP Residual norm 4.400559829879e-03
  2478 KSP Residual norm 4.111435196105e-03
  2479 KSP Residual norm 4.337075346385e-03
  2480 KSP Residual norm 4.945178145864e-03
  2481 KSP Residual norm 5.092298303078e-03
  2482 KSP Residual norm 4.784661524695e-03
  2483 KSP Residual norm 4.919441824071e-03
  2484 KSP Residual norm 5.886707767174e-03
  2485 KSP Residual norm 6.150378407138e-03
  2486 KSP Residual norm 6.227021440015e-03
  2487 KSP Residual norm 6.745898636979e-03
  2488 KSP Residual norm 7.047764964447e-03
  2489 KSP Residual norm 6.892213427333e-03
  2490 KSP Residual norm 7.331046814200e-03
  2491 KSP Residual norm 8.227580999757e-03
  2492 KSP Residual norm 9.024133996447e-03
  2493 KSP Residual norm 9.058584392188e-03
  2494 KSP Residual norm 9.224694390954e-03
  2495 KSP Residual norm 9.945749770545e-03
  2496 KSP Residual norm 1.027578826375e-02
  2497 KSP Residual norm 1.025977864628e-02
  2498 KSP Residual norm 1.047135323925e-02
  2499 KSP Residual norm 1.128179504584e-02
  2500 KSP Residual norm 1.163186215290e-02
  2501 KSP Residual norm 1.180260491874e-02
  2502 KSP Residual norm 1.228759810586e-02
  2503 KSP Residual norm 1.261920600272e-02
  2504 KSP Residual norm 1.246019870243e-02
  2505 KSP Residual norm 1.259940043368e-02
  2506 KSP Residual norm 1.235165793218e-02
  2507 KSP Residual norm 1.155175172210e-02
  2508 KSP Residual norm 1.109419638823e-02
  2509 KSP Residual norm 1.112496659786e-02
  2510 KSP Residual norm 1.105540691914e-02
  2511 KSP Residual norm 1.118139652667e-02
  2512 KSP Residual norm 1.045814729055e-02
  2513 KSP Residual norm 9.565959357082e-03
  2514 KSP Residual norm 9.665109194128e-03
  2515 KSP Residual norm 1.033527019297e-02
  2516 KSP Residual norm 1.020689592293e-02
  2517 KSP Residual norm 9.411272897569e-03
  2518 KSP Residual norm 8.552625261265e-03
  2519 KSP Residual norm 8.020197971840e-03
  2520 KSP Residual norm 8.009439687359e-03
  2521 KSP Residual norm 8.357946587350e-03
  2522 KSP Residual norm 8.362529612484e-03
  2523 KSP Residual norm 8.114648870068e-03
  2524 KSP Residual norm 7.807525075191e-03
  2525 KSP Residual norm 7.818755683000e-03
  2526 KSP Residual norm 7.290236106522e-03
  2527 KSP Residual norm 6.766378491383e-03
  2528 KSP Residual norm 6.419448174050e-03
  2529 KSP Residual norm 6.016044262508e-03
  2530 KSP Residual norm 5.457758626948e-03
  2531 KSP Residual norm 5.225608365999e-03
  2532 KSP Residual norm 5.140382521091e-03
  2533 KSP Residual norm 4.847419115490e-03
  2534 KSP Residual norm 4.344336303964e-03
  2535 KSP Residual norm 3.953836922469e-03
  2536 KSP Residual norm 3.759166852375e-03
  2537 KSP Residual norm 3.465317723701e-03
  2538 KSP Residual norm 3.376037501877e-03
  2539 KSP Residual norm 3.465844879655e-03
  2540 KSP Residual norm 3.188246161516e-03
  2541 KSP Residual norm 2.806258819422e-03
  2542 KSP Residual norm 2.574138120822e-03
  2543 KSP Residual norm 2.400153103637e-03
  2544 KSP Residual norm 2.256897887269e-03
  2545 KSP Residual norm 2.172604881480e-03
  2546 KSP Residual norm 2.119275275677e-03
  2547 KSP Residual norm 1.934906777052e-03
  2548 KSP Residual norm 1.887190889666e-03
  2549 KSP Residual norm 2.005042240433e-03
  2550 KSP Residual norm 2.003622964132e-03
  2551 KSP Residual norm 2.017525563253e-03
  2552 KSP Residual norm 2.120766630389e-03
  2553 KSP Residual norm 2.030221752738e-03
  2554 KSP Residual norm 1.822857717387e-03
  2555 KSP Residual norm 1.858280486180e-03
  2556 KSP Residual norm 2.066510567964e-03
  2557 KSP Residual norm 2.082650460288e-03
  2558 KSP Residual norm 1.942917568133e-03
  2559 KSP Residual norm 1.939991779578e-03
  2560 KSP Residual norm 1.964283335486e-03
  2561 KSP Residual norm 1.952533731378e-03
  2562 KSP Residual norm 1.942083965188e-03
  2563 KSP Residual norm 2.056157903246e-03
  2564 KSP Residual norm 2.194497253377e-03
  2565 KSP Residual norm 2.371419632789e-03
  2566 KSP Residual norm 2.518347065455e-03
  2567 KSP Residual norm 2.701302247258e-03
  2568 KSP Residual norm 2.795331332162e-03
  2569 KSP Residual norm 2.670469528493e-03
  2570 KSP Residual norm 2.486617843393e-03
  2571 KSP Residual norm 2.490357246694e-03
  2572 KSP Residual norm 2.644629342573e-03
  2573 KSP Residual norm 2.717135486971e-03
  2574 KSP Residual norm 2.817669991730e-03
  2575 KSP Residual norm 3.134078794211e-03
  2576 KSP Residual norm 3.439559563310e-03
  2577 KSP Residual norm 3.525304337067e-03
  2578 KSP Residual norm 3.848407219676e-03
  2579 KSP Residual norm 4.172120908185e-03
  2580 KSP Residual norm 4.147151486596e-03
  2581 KSP Residual norm 4.244007764660e-03
  2582 KSP Residual norm 4.653581934327e-03
  2583 KSP Residual norm 5.337753974150e-03
  2584 KSP Residual norm 5.579099169522e-03
  2585 KSP Residual norm 5.293906845109e-03
  2586 KSP Residual norm 5.188560162742e-03
  2587 KSP Residual norm 5.434809181416e-03
  2588 KSP Residual norm 5.777278090177e-03
  2589 KSP Residual norm 5.798176790722e-03
  2590 KSP Residual norm 6.013124695274e-03
  2591 KSP Residual norm 6.449577667500e-03
  2592 KSP Residual norm 6.434569035132e-03
  2593 KSP Residual norm 6.647043507976e-03
  2594 KSP Residual norm 6.766497340129e-03
  2595 KSP Residual norm 6.586268634271e-03
  2596 KSP Residual norm 6.362863368277e-03
  2597 KSP Residual norm 6.972034378214e-03
  2598 KSP Residual norm 7.666433212361e-03
  2599 KSP Residual norm 7.030591364164e-03
  2600 KSP Residual norm 6.261952143498e-03
  2601 KSP Residual norm 6.334862749894e-03
  2602 KSP Residual norm 6.318795570805e-03
  2603 KSP Residual norm 6.172005139057e-03
  2604 KSP Residual norm 6.471332821120e-03
  2605 KSP Residual norm 6.783784346312e-03
  2606 KSP Residual norm 6.416069229820e-03
  2607 KSP Residual norm 6.007075002044e-03
  2608 KSP Residual norm 5.893058127475e-03
  2609 KSP Residual norm 5.683576052440e-03
  2610 KSP Residual norm 5.408949172070e-03
  2611 KSP Residual norm 5.115837579870e-03
  2612 KSP Residual norm 4.845334779024e-03
  2613 KSP Residual norm 4.544017248392e-03
  2614 KSP Residual norm 4.322561110461e-03
  2615 KSP Residual norm 4.051869859407e-03
  2616 KSP Residual norm 3.633203941098e-03
  2617 KSP Residual norm 3.730359285905e-03
  2618 KSP Residual norm 3.953531389059e-03
  2619 KSP Residual norm 3.546282614388e-03
  2620 KSP Residual norm 2.946557927049e-03
  2621 KSP Residual norm 2.744013009653e-03
  2622 KSP Residual norm 2.797304890528e-03
  2623 KSP Residual norm 2.776063401053e-03
  2624 KSP Residual norm 2.666853252490e-03
  2625 KSP Residual norm 2.570553908970e-03
  2626 KSP Residual norm 2.418137297250e-03
  2627 KSP Residual norm 2.342030722541e-03
  2628 KSP Residual norm 2.384143106336e-03
  2629 KSP Residual norm 2.331581495599e-03
  2630 KSP Residual norm 2.118101736682e-03
  2631 KSP Residual norm 1.966008740335e-03
  2632 KSP Residual norm 1.929165865116e-03
  2633 KSP Residual norm 1.858383094757e-03
  2634 KSP Residual norm 1.840139851182e-03
  2635 KSP Residual norm 1.730583423718e-03
  2636 KSP Residual norm 1.576364084886e-03
  2637 KSP Residual norm 1.582887351903e-03
  2638 KSP Residual norm 1.615390108123e-03
  2639 KSP Residual norm 1.430278769497e-03
  2640 KSP Residual norm 1.309774816050e-03
  2641 KSP Residual norm 1.307817759557e-03
  2642 KSP Residual norm 1.213478325933e-03
  2643 KSP Residual norm 1.083290090130e-03
  2644 KSP Residual norm 1.085094157745e-03
  2645 KSP Residual norm 1.149726040631e-03
  2646 KSP Residual norm 1.111283849541e-03
  2647 KSP Residual norm 9.855745611789e-04
  2648 KSP Residual norm 9.046436388309e-04
  2649 KSP Residual norm 8.680357480033e-04
  2650 KSP Residual norm 8.813872816119e-04
  2651 KSP Residual norm 9.193231486463e-04
  2652 KSP Residual norm 9.709608864798e-04
  2653 KSP Residual norm 9.548075389208e-04
  2654 KSP Residual norm 8.900324621046e-04
  2655 KSP Residual norm 8.725312938322e-04
  2656 KSP Residual norm 9.082437403545e-04
  2657 KSP Residual norm 9.385644497781e-04
  2658 KSP Residual norm 9.624593688495e-04
  2659 KSP Residual norm 1.012088976398e-03
  2660 KSP Residual norm 1.011955489881e-03
  2661 KSP Residual norm 9.749066420987e-04
  2662 KSP Residual norm 9.855223442161e-04
  2663 KSP Residual norm 1.059256654704e-03
  2664 KSP Residual norm 1.092440140365e-03
  2665 KSP Residual norm 1.090564467516e-03
  2666 KSP Residual norm 1.065117419279e-03
  2667 KSP Residual norm 1.108393848916e-03
  2668 KSP Residual norm 1.210653186918e-03
  2669 KSP Residual norm 1.256173308257e-03
  2670 KSP Residual norm 1.234334641031e-03
  2671 KSP Residual norm 1.310454239223e-03
  2672 KSP Residual norm 1.416780503419e-03
  2673 KSP Residual norm 1.422885149903e-03
  2674 KSP Residual norm 1.388075037904e-03
  2675 KSP Residual norm 1.366737962308e-03
  2676 KSP Residual norm 1.379201938358e-03
  2677 KSP Residual norm 1.351799042850e-03
  2678 KSP Residual norm 1.475734405630e-03
  2679 KSP Residual norm 1.713326884038e-03
  2680 KSP Residual norm 1.828599164666e-03
  2681 KSP Residual norm 1.857615319113e-03
  2682 KSP Residual norm 1.988256942276e-03
  2683 KSP Residual norm 2.095755035175e-03
  2684 KSP Residual norm 2.175776595377e-03
  2685 KSP Residual norm 2.437862726306e-03
  2686 KSP Residual norm 2.872368978122e-03
  2687 KSP Residual norm 2.930121135955e-03
  2688 KSP Residual norm 2.785150249971e-03
  2689 KSP Residual norm 2.926861935826e-03
  2690 KSP Residual norm 3.256586448558e-03
  2691 KSP Residual norm 3.394495732335e-03
  2692 KSP Residual norm 3.676170240234e-03
  2693 KSP Residual norm 4.464070401612e-03
  2694 KSP Residual norm 4.925003235818e-03
  2695 KSP Residual norm 4.657972593757e-03
  2696 KSP Residual norm 4.520776031390e-03
  2697 KSP Residual norm 4.826169301751e-03
  2698 KSP Residual norm 4.705226785431e-03
  2699 KSP Residual norm 4.845834495802e-03
  2700 KSP Residual norm 5.450568165750e-03
  2701 KSP Residual norm 5.405685886439e-03
  2702 KSP Residual norm 5.064404720592e-03
  2703 KSP Residual norm 5.159041773853e-03
  2704 KSP Residual norm 5.396253694145e-03
  2705 KSP Residual norm 5.087777378594e-03
  2706 KSP Residual norm 4.416701744863e-03
  2707 KSP Residual norm 4.283464780264e-03
  2708 KSP Residual norm 4.227776586809e-03
  2709 KSP Residual norm 3.816430510896e-03
  2710 KSP Residual norm 3.507188080857e-03
  2711 KSP Residual norm 3.664141787644e-03
  2712 KSP Residual norm 3.882078097164e-03
  2713 KSP Residual norm 3.558005800540e-03
  2714 KSP Residual norm 3.362556333894e-03
  2715 KSP Residual norm 3.381412266198e-03
  2716 KSP Residual norm 3.272343545117e-03
  2717 KSP Residual norm 3.098166203496e-03
  2718 KSP Residual norm 2.918170899895e-03
  2719 KSP Residual norm 2.805589012223e-03
  2720 KSP Residual norm 2.617461682809e-03
  2721 KSP Residual norm 2.498203821414e-03
  2722 KSP Residual norm 2.555703948928e-03
  2723 KSP Residual norm 2.704929910323e-03
  2724 KSP Residual norm 2.704804499672e-03
  2725 KSP Residual norm 2.422352305371e-03
  2726 KSP Residual norm 2.146010215001e-03
  2727 KSP Residual norm 2.157191475484e-03
  2728 KSP Residual norm 2.145336994135e-03
  2729 KSP Residual norm 2.086378289458e-03
  2730 KSP Residual norm 2.229778840444e-03
  2731 KSP Residual norm 2.535817164615e-03
  2732 KSP Residual norm 2.632680974580e-03
  2733 KSP Residual norm 2.488486653901e-03
  2734 KSP Residual norm 2.374380582123e-03
  2735 KSP Residual norm 2.430738511771e-03
  2736 KSP Residual norm 2.420248713523e-03
  2737 KSP Residual norm 2.302847190148e-03
  2738 KSP Residual norm 2.254438668835e-03
  2739 KSP Residual norm 2.206384051676e-03
  2740 KSP Residual norm 2.026611506674e-03
  2741 KSP Residual norm 1.863862978796e-03
  2742 KSP Residual norm 1.791918577784e-03
  2743 KSP Residual norm 1.589158171238e-03
  2744 KSP Residual norm 1.448351414910e-03
  2745 KSP Residual norm 1.462011618822e-03
  2746 KSP Residual norm 1.546262244036e-03
  2747 KSP Residual norm 1.457974955196e-03
  2748 KSP Residual norm 1.358665370080e-03
  2749 KSP Residual norm 1.485787041264e-03
  2750 KSP Residual norm 1.649416402076e-03
  2751 KSP Residual norm 1.520063285568e-03
  2752 KSP Residual norm 1.394521339503e-03
  2753 KSP Residual norm 1.542474992449e-03
  2754 KSP Residual norm 1.617270768548e-03
  2755 KSP Residual norm 1.484129864690e-03
  2756 KSP Residual norm 1.489982256038e-03
  2757 KSP Residual norm 1.634619136561e-03
  2758 KSP Residual norm 1.576841752283e-03
  2759 KSP Residual norm 1.484849375883e-03
  2760 KSP Residual norm 1.588611441559e-03
  2761 KSP Residual norm 1.788271668052e-03
  2762 KSP Residual norm 1.838564643069e-03
  2763 KSP Residual norm 1.956549529214e-03
  2764 KSP Residual norm 2.153577292642e-03
  2765 KSP Residual norm 2.158929997251e-03
  2766 KSP Residual norm 2.004385674663e-03
  2767 KSP Residual norm 2.025979711910e-03
  2768 KSP Residual norm 2.272282762743e-03
  2769 KSP Residual norm 2.482726499242e-03
  2770 KSP Residual norm 2.703743415817e-03
  2771 KSP Residual norm 3.014984680178e-03
  2772 KSP Residual norm 3.362472240067e-03
  2773 KSP Residual norm 3.569907893456e-03
  2774 KSP Residual norm 3.793544712662e-03
  2775 KSP Residual norm 3.971139276993e-03
  2776 KSP Residual norm 4.087569126960e-03
  2777 KSP Residual norm 4.363456089764e-03
  2778 KSP Residual norm 4.625571421248e-03
  2779 KSP Residual norm 4.624976548773e-03
  2780 KSP Residual norm 4.718849386844e-03
  2781 KSP Residual norm 4.786949244693e-03
  2782 KSP Residual norm 4.771666421559e-03
  2783 KSP Residual norm 5.104231978217e-03
  2784 KSP Residual norm 5.734907457343e-03
  2785 KSP Residual norm 5.764605173383e-03
  2786 KSP Residual norm 5.426953091590e-03
  2787 KSP Residual norm 5.580034553178e-03
  2788 KSP Residual norm 5.949693184172e-03
  2789 KSP Residual norm 5.996671739248e-03
  2790 KSP Residual norm 6.157706620644e-03
  2791 KSP Residual norm 6.848408423874e-03
  2792 KSP Residual norm 7.066338896982e-03
  2793 KSP Residual norm 6.587699824354e-03
  2794 KSP Residual norm 6.594254657823e-03
  2795 KSP Residual norm 7.284894664177e-03
  2796 KSP Residual norm 7.388794406292e-03
  2797 KSP Residual norm 6.742009621402e-03
  2798 KSP Residual norm 6.669693683210e-03
  2799 KSP Residual norm 6.280792363793e-03
  2800 KSP Residual norm 5.548612251379e-03
  2801 KSP Residual norm 5.358466425664e-03
  2802 KSP Residual norm 5.617501994186e-03
  2803 KSP Residual norm 5.319539313742e-03
  2804 KSP Residual norm 4.781893806291e-03
  2805 KSP Residual norm 4.741739705150e-03
  2806 KSP Residual norm 4.981281036051e-03
  2807 KSP Residual norm 4.723399945724e-03
  2808 KSP Residual norm 4.341339983627e-03
  2809 KSP Residual norm 4.651093018266e-03
  2810 KSP Residual norm 5.040994656518e-03
  2811 KSP Residual norm 4.479552064666e-03
  2812 KSP Residual norm 3.830957288486e-03
  2813 KSP Residual norm 3.533215940491e-03
  2814 KSP Residual norm 3.438896124903e-03
  2815 KSP Residual norm 3.205565080589e-03
  2816 KSP Residual norm 3.178743406165e-03
  2817 KSP Residual norm 3.240179887624e-03
  2818 KSP Residual norm 3.158195637160e-03
  2819 KSP Residual norm 2.892701103103e-03
  2820 KSP Residual norm 2.797142641246e-03
  2821 KSP Residual norm 2.779326882773e-03
  2822 KSP Residual norm 2.617507251360e-03
  2823 KSP Residual norm 2.350097638705e-03
  2824 KSP Residual norm 2.096293170896e-03
  2825 KSP Residual norm 1.948274586444e-03
  2826 KSP Residual norm 1.807042821225e-03
  2827 KSP Residual norm 1.738739744696e-03
  2828 KSP Residual norm 1.678668895603e-03
  2829 KSP Residual norm 1.773884200509e-03
  2830 KSP Residual norm 1.836552583922e-03
  2831 KSP Residual norm 1.737215267139e-03
  2832 KSP Residual norm 1.598291536644e-03
  2833 KSP Residual norm 1.562991290880e-03
  2834 KSP Residual norm 1.467456550119e-03
  2835 KSP Residual norm 1.294963690664e-03
  2836 KSP Residual norm 1.237019430877e-03
  2837 KSP Residual norm 1.312206291645e-03
  2838 KSP Residual norm 1.291349637627e-03
  2839 KSP Residual norm 1.160335094663e-03
  2840 KSP Residual norm 1.063879454608e-03
  2841 KSP Residual norm 1.034625807636e-03
  2842 KSP Residual norm 9.770485830404e-04
  2843 KSP Residual norm 9.374445013353e-04
  2844 KSP Residual norm 9.902724864709e-04
  2845 KSP Residual norm 1.036533344318e-03
  2846 KSP Residual norm 1.079569282831e-03
  2847 KSP Residual norm 1.226883463673e-03
  2848 KSP Residual norm 1.430574675211e-03
  2849 KSP Residual norm 1.354421865633e-03
  2850 KSP Residual norm 1.231373694932e-03
  2851 KSP Residual norm 1.175397745394e-03
  2852 KSP Residual norm 1.070148692108e-03
  2853 KSP Residual norm 1.015922741370e-03
  2854 KSP Residual norm 1.103931648087e-03
  2855 KSP Residual norm 1.171540606755e-03
  2856 KSP Residual norm 1.088958128808e-03
  2857 KSP Residual norm 1.083246789518e-03
  2858 KSP Residual norm 1.113855493690e-03
  2859 KSP Residual norm 1.110085190246e-03
  2860 KSP Residual norm 1.142143272029e-03
  2861 KSP Residual norm 1.193743390105e-03
  2862 KSP Residual norm 1.131546392426e-03
  2863 KSP Residual norm 1.127578239592e-03
  2864 KSP Residual norm 1.271221238619e-03
  2865 KSP Residual norm 1.359804747599e-03
  2866 KSP Residual norm 1.289379864152e-03
  2867 KSP Residual norm 1.321333706950e-03
  2868 KSP Residual norm 1.544458941025e-03
  2869 KSP Residual norm 1.563976433107e-03
  2870 KSP Residual norm 1.399474385920e-03
  2871 KSP Residual norm 1.356252805981e-03
  2872 KSP Residual norm 1.443852116959e-03
  2873 KSP Residual norm 1.356990907946e-03
  2874 KSP Residual norm 1.285187356557e-03
  2875 KSP Residual norm 1.430496822359e-03
  2876 KSP Residual norm 1.681358820304e-03
  2877 KSP Residual norm 1.749072634641e-03
  2878 KSP Residual norm 1.829374916805e-03
  2879 KSP Residual norm 2.117446004955e-03
  2880 KSP Residual norm 2.172038560867e-03
  2881 KSP Residual norm 1.990623694723e-03
  2882 KSP Residual norm 2.142729037698e-03
  2883 KSP Residual norm 2.459801592783e-03
  2884 KSP Residual norm 2.405512176252e-03
  2885 KSP Residual norm 2.407816699724e-03
  2886 KSP Residual norm 2.653979926691e-03
  2887 KSP Residual norm 2.735241253463e-03
  2888 KSP Residual norm 2.684942144314e-03
  2889 KSP Residual norm 3.107427807814e-03
  2890 KSP Residual norm 3.575515284824e-03
  2891 KSP Residual norm 3.376235460739e-03
  2892 KSP Residual norm 3.404884516786e-03
  2893 KSP Residual norm 3.929868756447e-03
  2894 KSP Residual norm 4.111687608396e-03
  2895 KSP Residual norm 3.788022365376e-03
  2896 KSP Residual norm 4.037486192237e-03
  2897 KSP Residual norm 4.582307985708e-03
  2898 KSP Residual norm 4.397018421487e-03
  2899 KSP Residual norm 4.184351178202e-03
  2900 KSP Residual norm 4.129499004219e-03
  2901 KSP Residual norm 4.193657012396e-03
  2902 KSP Residual norm 4.345469063901e-03
  2903 KSP Residual norm 4.722109775846e-03
  2904 KSP Residual norm 5.392810790430e-03
  2905 KSP Residual norm 5.386641629693e-03
  2906 KSP Residual norm 5.090454899875e-03
  2907 KSP Residual norm 5.202040851774e-03
  2908 KSP Residual norm 5.417690627987e-03
  2909 KSP Residual norm 5.076526303676e-03
  2910 KSP Residual norm 5.233764214625e-03
  2911 KSP Residual norm 6.362598247088e-03
  2912 KSP Residual norm 7.075721196366e-03
  2913 KSP Residual norm 6.983864367887e-03
  2914 KSP Residual norm 7.582708469288e-03
  2915 KSP Residual norm 7.969517990493e-03
  2916 KSP Residual norm 7.917432839086e-03
  2917 KSP Residual norm 8.326635825449e-03
  2918 KSP Residual norm 8.822095168357e-03
  2919 KSP Residual norm 8.668312680659e-03
  2920 KSP Residual norm 9.188392767430e-03
  2921 KSP Residual norm 1.019618131499e-02
  2922 KSP Residual norm 9.443758357690e-03
  2923 KSP Residual norm 7.912514701689e-03
  2924 KSP Residual norm 7.307896808691e-03
  2925 KSP Residual norm 7.190406002902e-03
  2926 KSP Residual norm 6.848901440889e-03
  2927 KSP Residual norm 7.007735645264e-03
  2928 KSP Residual norm 8.085929902110e-03
  2929 KSP Residual norm 9.055854895566e-03
  2930 KSP Residual norm 8.788443507417e-03
  2931 KSP Residual norm 8.892129795841e-03
  2932 KSP Residual norm 9.391775988154e-03
  2933 KSP Residual norm 8.778762453979e-03
  2934 KSP Residual norm 8.177475371371e-03
  2935 KSP Residual norm 8.296157796572e-03
  2936 KSP Residual norm 8.428951916742e-03
  2937 KSP Residual norm 7.253612634486e-03
  2938 KSP Residual norm 6.486381004139e-03
  2939 KSP Residual norm 6.653913849035e-03
  2940 KSP Residual norm 6.711623842603e-03
  2941 KSP Residual norm 6.561290672839e-03
  2942 KSP Residual norm 7.211875432346e-03
  2943 KSP Residual norm 7.516924345150e-03
  2944 KSP Residual norm 6.571239843022e-03
  2945 KSP Residual norm 6.308294812942e-03
  2946 KSP Residual norm 6.468447711975e-03
  2947 KSP Residual norm 5.456713710464e-03
  2948 KSP Residual norm 4.407074338385e-03
  2949 KSP Residual norm 4.541864464324e-03
  2950 KSP Residual norm 5.127110075465e-03
  2951 KSP Residual norm 4.475441723750e-03
  2952 KSP Residual norm 3.935090225693e-03
  2953 KSP Residual norm 3.986292185665e-03
  2954 KSP Residual norm 3.861524737337e-03
  2955 KSP Residual norm 3.525301600677e-03
  2956 KSP Residual norm 3.606986049901e-03
  2957 KSP Residual norm 3.741501646941e-03
  2958 KSP Residual norm 3.329653686436e-03
  2959 KSP Residual norm 3.202102690664e-03
  2960 KSP Residual norm 3.450486095169e-03
  2961 KSP Residual norm 3.252219165076e-03
  2962 KSP Residual norm 2.477276891406e-03
  2963 KSP Residual norm 2.049933056556e-03
  2964 KSP Residual norm 1.902709902863e-03
  2965 KSP Residual norm 1.752531162959e-03
  2966 KSP Residual norm 1.696427240540e-03
  2967 KSP Residual norm 1.946924154321e-03
  2968 KSP Residual norm 2.227951284603e-03
  2969 KSP Residual norm 2.009009158130e-03
  2970 KSP Residual norm 1.882226516836e-03
  2971 KSP Residual norm 2.086086727174e-03
  2972 KSP Residual norm 2.055611734290e-03
  2973 KSP Residual norm 1.741240774921e-03
  2974 KSP Residual norm 1.725175564643e-03
  2975 KSP Residual norm 1.755915800229e-03
  2976 KSP Residual norm 1.509528375407e-03
  2977 KSP Residual norm 1.357637627266e-03
  2978 KSP Residual norm 1.460549071024e-03
  2979 KSP Residual norm 1.553492067748e-03
  2980 KSP Residual norm 1.364009061525e-03
  2981 KSP Residual norm 1.272013168916e-03
  2982 KSP Residual norm 1.186072933342e-03
  2983 KSP Residual norm 9.951101622586e-04
  2984 KSP Residual norm 9.363652021728e-04
  2985 KSP Residual norm 1.004675852639e-03
  2986 KSP Residual norm 1.036029921093e-03
  2987 KSP Residual norm 1.064462437764e-03
  2988 KSP Residual norm 1.224997879950e-03
  2989 KSP Residual norm 1.388057630221e-03
  2990 KSP Residual norm 1.372660186962e-03
  2991 KSP Residual norm 1.424045125325e-03
  2992 KSP Residual norm 1.500297885504e-03
  2993 KSP Residual norm 1.473977518522e-03
  2994 KSP Residual norm 1.397325608450e-03
  2995 KSP Residual norm 1.446577138766e-03
  2996 KSP Residual norm 1.432956780215e-03
  2997 KSP Residual norm 1.368682613462e-03
  2998 KSP Residual norm 1.330389794315e-03
  2999 KSP Residual norm 1.354215374244e-03
  3000 KSP Residual norm 1.319668006136e-03
  3001 KSP Residual norm 1.273994985774e-03
  3002 KSP Residual norm 1.371379762475e-03
  3003 KSP Residual norm 1.430753016456e-03
  3004 KSP Residual norm 1.306663632696e-03
  3005 KSP Residual norm 1.286112809999e-03
  3006 KSP Residual norm 1.350415243744e-03
  3007 KSP Residual norm 1.372214677136e-03
  3008 KSP Residual norm 1.418110778472e-03
  3009 KSP Residual norm 1.736144243771e-03
  3010 KSP Residual norm 1.962396016012e-03
  3011 KSP Residual norm 1.875622461591e-03
  3012 KSP Residual norm 1.828878048051e-03
  3013 KSP Residual norm 1.968093592774e-03
  3014 KSP Residual norm 2.024599310890e-03
  3015 KSP Residual norm 1.914434050527e-03
  3016 KSP Residual norm 1.949234213420e-03
  3017 KSP Residual norm 2.059691091928e-03
  3018 KSP Residual norm 2.230823155566e-03
  3019 KSP Residual norm 2.452639340379e-03
  3020 KSP Residual norm 2.884304396912e-03
  3021 KSP Residual norm 3.358685292056e-03
  3022 KSP Residual norm 3.553951903749e-03
  3023 KSP Residual norm 3.449118175846e-03
  3024 KSP Residual norm 3.300312969099e-03
  3025 KSP Residual norm 3.141321863979e-03
  3026 KSP Residual norm 3.189177447526e-03
  3027 KSP Residual norm 3.586824420308e-03
  3028 KSP Residual norm 4.318036306854e-03
  3029 KSP Residual norm 4.643788568772e-03
  3030 KSP Residual norm 4.370505229741e-03
  3031 KSP Residual norm 4.161352510344e-03
  3032 KSP Residual norm 4.426873460573e-03
  3033 KSP Residual norm 4.727376409745e-03
  3034 KSP Residual norm 4.935447116989e-03
  3035 KSP Residual norm 5.195492858474e-03
  3036 KSP Residual norm 5.262987991305e-03
  3037 KSP Residual norm 4.988286243106e-03
  3038 KSP Residual norm 4.838626754328e-03
  3039 KSP Residual norm 5.135821517572e-03
  3040 KSP Residual norm 5.128463280593e-03
  3041 KSP Residual norm 4.894818274532e-03
  3042 KSP Residual norm 5.157080366224e-03
  3043 KSP Residual norm 5.899655632507e-03
  3044 KSP Residual norm 6.311604201119e-03
  3045 KSP Residual norm 6.503921463717e-03
  3046 KSP Residual norm 7.045433203190e-03
  3047 KSP Residual norm 7.822428362162e-03
  3048 KSP Residual norm 7.801763914628e-03
  3049 KSP Residual norm 7.803226763047e-03
  3050 KSP Residual norm 8.170601241380e-03
  3051 KSP Residual norm 7.843857344975e-03
  3052 KSP Residual norm 7.654351738200e-03
  3053 KSP Residual norm 8.644931839356e-03
  3054 KSP Residual norm 9.699516109829e-03
  3055 KSP Residual norm 9.647065952106e-03
  3056 KSP Residual norm 1.006655408950e-02
  3057 KSP Residual norm 1.023806234184e-02
  3058 KSP Residual norm 9.532513741776e-03
  3059 KSP Residual norm 9.513932902273e-03
  3060 KSP Residual norm 1.005696053542e-02
  3061 KSP Residual norm 9.512926491812e-03
  3062 KSP Residual norm 8.959904449497e-03
  3063 KSP Residual norm 9.498596804941e-03
  3064 KSP Residual norm 1.065376693957e-02
  3065 KSP Residual norm 1.010658942622e-02
  3066 KSP Residual norm 9.678241257087e-03
  3067 KSP Residual norm 1.021317781344e-02
  3068 KSP Residual norm 1.109162939418e-02
  3069 KSP Residual norm 1.158666376649e-02
  3070 KSP Residual norm 1.202557056106e-02
  3071 KSP Residual norm 1.211144817720e-02
  3072 KSP Residual norm 1.120304665676e-02
  3073 KSP Residual norm 1.083553887500e-02
  3074 KSP Residual norm 1.121522622165e-02
  3075 KSP Residual norm 1.121260214238e-02
  3076 KSP Residual norm 1.046440502336e-02
  3077 KSP Residual norm 1.004708331370e-02
  3078 KSP Residual norm 1.073391842848e-02
  3079 KSP Residual norm 1.156613829371e-02
  3080 KSP Residual norm 1.236452671945e-02
  3081 KSP Residual norm 1.309923551733e-02
  3082 KSP Residual norm 1.438114956817e-02
  3083 KSP Residual norm 1.426149827407e-02
  3084 KSP Residual norm 1.224280180376e-02
  3085 KSP Residual norm 1.096181143829e-02
  3086 KSP Residual norm 1.111920170108e-02
  3087 KSP Residual norm 1.118340676655e-02
  3088 KSP Residual norm 1.000130923922e-02
  3089 KSP Residual norm 9.754845073746e-03
  3090 KSP Residual norm 1.014216156263e-02
  3091 KSP Residual norm 9.540691283703e-03
  3092 KSP Residual norm 9.401965344054e-03
  3093 KSP Residual norm 9.624902854579e-03
  3094 KSP Residual norm 9.147961612330e-03
  3095 KSP Residual norm 7.906191690820e-03
  3096 KSP Residual norm 7.592020558342e-03
  3097 KSP Residual norm 7.524035202212e-03
  3098 KSP Residual norm 7.266627699893e-03
  3099 KSP Residual norm 6.751911787101e-03
  3100 KSP Residual norm 6.387038264013e-03
  3101 KSP Residual norm 5.486121905795e-03
  3102 KSP Residual norm 4.760691147831e-03
  3103 KSP Residual norm 4.980285403119e-03
  3104 KSP Residual norm 5.753887376636e-03
  3105 KSP Residual norm 6.060393070534e-03
  3106 KSP Residual norm 5.800149107397e-03
  3107 KSP Residual norm 5.712092792131e-03
  3108 KSP Residual norm 5.723257999910e-03
  3109 KSP Residual norm 5.585497985460e-03
  3110 KSP Residual norm 5.299240610802e-03
  3111 KSP Residual norm 5.185844312278e-03
  3112 KSP Residual norm 5.180691238305e-03
  3113 KSP Residual norm 5.170254632558e-03
  3114 KSP Residual norm 5.031353871658e-03
  3115 KSP Residual norm 4.516523814593e-03
  3116 KSP Residual norm 3.891943664907e-03
  3117 KSP Residual norm 3.527455407802e-03
  3118 KSP Residual norm 3.276607605164e-03
  3119 KSP Residual norm 3.137818567100e-03
  3120 KSP Residual norm 3.510031082913e-03
  3121 KSP Residual norm 4.090076535163e-03
  3122 KSP Residual norm 4.204439159335e-03
  3123 KSP Residual norm 4.519044874314e-03
  3124 KSP Residual norm 4.711943201661e-03
  3125 KSP Residual norm 4.108752640532e-03
  3126 KSP Residual norm 3.479065521297e-03
  3127 KSP Residual norm 3.495031577776e-03
  3128 KSP Residual norm 3.934896362242e-03
  3129 KSP Residual norm 4.070916898692e-03
  3130 KSP Residual norm 4.288349051719e-03
  3131 KSP Residual norm 4.317228547289e-03
  3132 KSP Residual norm 3.946454044654e-03
  3133 KSP Residual norm 3.779196047954e-03
  3134 KSP Residual norm 4.032446591841e-03
  3135 KSP Residual norm 4.018336837785e-03
  3136 KSP Residual norm 3.607753498867e-03
  3137 KSP Residual norm 3.481587781544e-03
  3138 KSP Residual norm 3.455709777074e-03
  3139 KSP Residual norm 3.363059582249e-03
  3140 KSP Residual norm 3.313987873533e-03
  3141 KSP Residual norm 3.237254013235e-03
  3142 KSP Residual norm 2.768398774635e-03
  3143 KSP Residual norm 2.468370301959e-03
  3144 KSP Residual norm 2.535141088666e-03
  3145 KSP Residual norm 2.928032024313e-03
  3146 KSP Residual norm 3.847497590560e-03
  3147 KSP Residual norm 4.242685138425e-03
  3148 KSP Residual norm 3.615538528394e-03
  3149 KSP Residual norm 3.113010251107e-03
  3150 KSP Residual norm 3.162645118937e-03
  3151 KSP Residual norm 3.317127403664e-03
  3152 KSP Residual norm 3.471925769185e-03
  3153 KSP Residual norm 3.828187151022e-03
  3154 KSP Residual norm 4.090509587600e-03
  3155 KSP Residual norm 3.897198613880e-03
  3156 KSP Residual norm 3.639927871554e-03
  3157 KSP Residual norm 3.528236759149e-03
  3158 KSP Residual norm 3.438661404826e-03
  3159 KSP Residual norm 3.636352107113e-03
  3160 KSP Residual norm 3.997719762216e-03
  3161 KSP Residual norm 4.112496172284e-03
  3162 KSP Residual norm 4.057648658384e-03
  3163 KSP Residual norm 4.270657152407e-03
  3164 KSP Residual norm 4.405984332441e-03
  3165 KSP Residual norm 3.807035656515e-03
  3166 KSP Residual norm 3.531658843093e-03
  3167 KSP Residual norm 3.943140142473e-03
  3168 KSP Residual norm 3.994005998218e-03
  3169 KSP Residual norm 3.925806568403e-03
  3170 KSP Residual norm 4.283447489515e-03
  3171 KSP Residual norm 4.995750857361e-03
  3172 KSP Residual norm 5.209611202407e-03
  3173 KSP Residual norm 5.080346313836e-03
  3174 KSP Residual norm 4.799734984449e-03
  3175 KSP Residual norm 4.163699720599e-03
  3176 KSP Residual norm 4.081417388337e-03
  3177 KSP Residual norm 4.614329415968e-03
  3178 KSP Residual norm 5.245797563056e-03
  3179 KSP Residual norm 5.297680341569e-03
  3180 KSP Residual norm 5.401341806411e-03
  3181 KSP Residual norm 6.006059778329e-03
  3182 KSP Residual norm 7.005651171496e-03
  3183 KSP Residual norm 8.532646190371e-03
  3184 KSP Residual norm 9.728916729099e-03
  3185 KSP Residual norm 9.381147206066e-03
  3186 KSP Residual norm 8.961874693029e-03
  3187 KSP Residual norm 9.086673303911e-03
  3188 KSP Residual norm 8.251175181581e-03
  3189 KSP Residual norm 6.911038858331e-03
  3190 KSP Residual norm 6.568919068833e-03
  3191 KSP Residual norm 6.805271037313e-03
  3192 KSP Residual norm 7.204067554180e-03
  3193 KSP Residual norm 8.129184294157e-03
  3194 KSP Residual norm 9.005369610526e-03
  3195 KSP Residual norm 9.442528385542e-03
  3196 KSP Residual norm 9.774101977640e-03
  3197 KSP Residual norm 1.033055682201e-02
  3198 KSP Residual norm 1.043221180782e-02
  3199 KSP Residual norm 1.078135156047e-02
  3200 KSP Residual norm 1.200591990423e-02
  3201 KSP Residual norm 1.305363207925e-02
  3202 KSP Residual norm 1.378489495984e-02
  3203 KSP Residual norm 1.356199718732e-02
  3204 KSP Residual norm 1.269109848995e-02
  3205 KSP Residual norm 1.269489526675e-02
  3206 KSP Residual norm 1.451094867081e-02
  3207 KSP Residual norm 1.567832583739e-02
  3208 KSP Residual norm 1.532058906301e-02
  3209 KSP Residual norm 1.576409641088e-02
  3210 KSP Residual norm 1.643058038446e-02
  3211 KSP Residual norm 1.557642354238e-02
  3212 KSP Residual norm 1.552121527862e-02
  3213 KSP Residual norm 1.628124738715e-02
  3214 KSP Residual norm 1.537868036131e-02
  3215 KSP Residual norm 1.411653453381e-02
  3216 KSP Residual norm 1.438663611149e-02
  3217 KSP Residual norm 1.586387854502e-02
  3218 KSP Residual norm 1.532058834136e-02
  3219 KSP Residual norm 1.381368567635e-02
  3220 KSP Residual norm 1.269730312762e-02
  3221 KSP Residual norm 1.185916433179e-02
  3222 KSP Residual norm 1.137845876087e-02
  3223 KSP Residual norm 1.122832688659e-02
  3224 KSP Residual norm 1.142049772445e-02
  3225 KSP Residual norm 1.150003013665e-02
  3226 KSP Residual norm 1.329890835724e-02
  3227 KSP Residual norm 1.690954609903e-02
  3228 KSP Residual norm 1.907361819568e-02
  3229 KSP Residual norm 1.836512146272e-02
  3230 KSP Residual norm 1.644260808452e-02
  3231 KSP Residual norm 1.429160276489e-02
  3232 KSP Residual norm 1.238839069472e-02
  3233 KSP Residual norm 1.206765651211e-02
  3234 KSP Residual norm 1.162683853596e-02
  3235 KSP Residual norm 1.080653244405e-02
  3236 KSP Residual norm 9.770249579341e-03
  3237 KSP Residual norm 9.143515025012e-03
  3238 KSP Residual norm 8.858832879797e-03
  3239 KSP Residual norm 9.023756798777e-03
  3240 KSP Residual norm 1.001068990928e-02
  3241 KSP Residual norm 1.069471425598e-02
  3242 KSP Residual norm 1.020298319345e-02
  3243 KSP Residual norm 8.865505274785e-03
  3244 KSP Residual norm 7.383176934210e-03
  3245 KSP Residual norm 7.414517430798e-03
  3246 KSP Residual norm 9.001557144410e-03
  3247 KSP Residual norm 1.022769544403e-02
  3248 KSP Residual norm 9.785680285920e-03
  3249 KSP Residual norm 9.142389815218e-03
  3250 KSP Residual norm 8.536210708611e-03
  3251 KSP Residual norm 6.867894613730e-03
  3252 KSP Residual norm 5.895947524297e-03
  3253 KSP Residual norm 5.818159631934e-03
  3254 KSP Residual norm 5.969135701545e-03
  3255 KSP Residual norm 6.268075658928e-03
  3256 KSP Residual norm 7.399276665667e-03
  3257 KSP Residual norm 7.661427943296e-03
  3258 KSP Residual norm 6.453249799503e-03
  3259 KSP Residual norm 5.921344561978e-03
  3260 KSP Residual norm 5.982986714829e-03
  3261 KSP Residual norm 5.199720903837e-03
  3262 KSP Residual norm 4.422412439531e-03
  3263 KSP Residual norm 4.694366066974e-03
  3264 KSP Residual norm 5.853588950046e-03
  3265 KSP Residual norm 6.551662871828e-03
  3266 KSP Residual norm 6.490056762985e-03
  3267 KSP Residual norm 5.951388959900e-03
  3268 KSP Residual norm 4.516412582620e-03
  3269 KSP Residual norm 2.983165029024e-03
  3270 KSP Residual norm 2.039595003348e-03
  3271 KSP Residual norm 1.794976143482e-03
  3272 KSP Residual norm 1.939361591023e-03
  3273 KSP Residual norm 2.531434460060e-03
  3274 KSP Residual norm 3.598802316831e-03
  3275 KSP Residual norm 4.674419793336e-03
  3276 KSP Residual norm 4.842539121028e-03
  3277 KSP Residual norm 3.996983218608e-03
  3278 KSP Residual norm 3.140164118259e-03
  3279 KSP Residual norm 2.515405621939e-03
  3280 KSP Residual norm 2.408966869639e-03
  3281 KSP Residual norm 2.720855275036e-03
  3282 KSP Residual norm 3.355954732026e-03
  3283 KSP Residual norm 4.167591031500e-03
  3284 KSP Residual norm 4.680635771816e-03
  3285 KSP Residual norm 3.889527774632e-03
  3286 KSP Residual norm 2.755805924728e-03
  3287 KSP Residual norm 2.315840756050e-03
  3288 KSP Residual norm 2.308845251531e-03
  3289 KSP Residual norm 2.636645978699e-03
  3290 KSP Residual norm 3.402433647969e-03
  3291 KSP Residual norm 4.251620632374e-03
  3292 KSP Residual norm 3.793730879779e-03
  3293 KSP Residual norm 2.832866760978e-03
  3294 KSP Residual norm 2.180505219503e-03
  3295 KSP Residual norm 1.697614738254e-03
  3296 KSP Residual norm 1.665784154063e-03
  3297 KSP Residual norm 2.161024671321e-03
  3298 KSP Residual norm 3.050830942266e-03
  3299 KSP Residual norm 3.509991938504e-03
  3300 KSP Residual norm 3.542214302572e-03
  3301 KSP Residual norm 3.106173541680e-03
  3302 KSP Residual norm 2.376905396518e-03
  3303 KSP Residual norm 2.173447876136e-03
  3304 KSP Residual norm 2.308632256805e-03
  3305 KSP Residual norm 2.176363396384e-03
  3306 KSP Residual norm 1.813052173020e-03
  3307 KSP Residual norm 1.624029390453e-03
  3308 KSP Residual norm 1.559582321585e-03
  3309 KSP Residual norm 1.519515691497e-03
  3310 KSP Residual norm 1.893851598042e-03
  3311 KSP Residual norm 2.836681978166e-03
  3312 KSP Residual norm 3.660679422597e-03
  3313 KSP Residual norm 3.559310041600e-03
  3314 KSP Residual norm 3.105166606565e-03
  3315 KSP Residual norm 2.343716525519e-03
  3316 KSP Residual norm 1.722636638757e-03
  3317 KSP Residual norm 1.443878171809e-03
  3318 KSP Residual norm 1.516598879532e-03
  3319 KSP Residual norm 1.954914482820e-03
  3320 KSP Residual norm 2.782514594175e-03
  3321 KSP Residual norm 3.700013789797e-03
  3322 KSP Residual norm 3.772175780929e-03
  3323 KSP Residual norm 2.935475918005e-03
  3324 KSP Residual norm 2.083878885861e-03
  3325 KSP Residual norm 1.703560777235e-03
  3326 KSP Residual norm 1.706262679731e-03
  3327 KSP Residual norm 2.224070904846e-03
  3328 KSP Residual norm 3.404123082333e-03
  3329 KSP Residual norm 5.017399865633e-03
  3330 KSP Residual norm 5.328545072862e-03
  3331 KSP Residual norm 4.110554961613e-03
  3332 KSP Residual norm 3.055932463793e-03
  3333 KSP Residual norm 2.434093665887e-03
  3334 KSP Residual norm 2.245025757791e-03
  3335 KSP Residual norm 2.597381919391e-03
  3336 KSP Residual norm 3.608560344999e-03
  3337 KSP Residual norm 5.024544092493e-03
  3338 KSP Residual norm 6.757773177279e-03
  3339 KSP Residual norm 7.236990599686e-03
  3340 KSP Residual norm 5.334018579363e-03
  3341 KSP Residual norm 3.670426817844e-03
  3342 KSP Residual norm 3.458658010460e-03
  3343 KSP Residual norm 4.177897662309e-03
  3344 KSP Residual norm 5.361834008504e-03
  3345 KSP Residual norm 7.448364528135e-03
  3346 KSP Residual norm 1.161156259565e-02
  3347 KSP Residual norm 1.466722425199e-02
  3348 KSP Residual norm 1.223571276010e-02
  3349 KSP Residual norm 8.515548591274e-03
  3350 KSP Residual norm 5.560222541152e-03
  3351 KSP Residual norm 3.737752004715e-03
  3352 KSP Residual norm 3.374691477137e-03
  3353 KSP Residual norm 4.248075403035e-03
  3354 KSP Residual norm 6.454549110546e-03
  3355 KSP Residual norm 9.253753441211e-03
  3356 KSP Residual norm 1.172261739627e-02
  3357 KSP Residual norm 1.293159358061e-02
  3358 KSP Residual norm 1.327533129647e-02
  3359 KSP Residual norm 1.421858697334e-02
  3360 KSP Residual norm 1.588189853110e-02
  3361 KSP Residual norm 1.468433443893e-02
  3362 KSP Residual norm 1.061499850396e-02
  3363 KSP Residual norm 7.238306118037e-03
  3364 KSP Residual norm 5.295484481415e-03
  3365 KSP Residual norm 5.030433624303e-03
  3366 KSP Residual norm 6.448894481015e-03
  3367 KSP Residual norm 1.005121245882e-02
  3368 KSP Residual norm 1.460014037975e-02
  3369 KSP Residual norm 1.624683604566e-02
  3370 KSP Residual norm 1.433959148724e-02
  3371 KSP Residual norm 1.160450343864e-02
  3372 KSP Residual norm 9.605938004674e-03
  3373 KSP Residual norm 8.899127743228e-03
  3374 KSP Residual norm 9.370299718388e-03
  3375 KSP Residual norm 9.380021626241e-03
  3376 KSP Residual norm 8.342611820587e-03
  3377 KSP Residual norm 6.985668548425e-03
  3378 KSP Residual norm 6.327982854763e-03
  3379 KSP Residual norm 6.591958145806e-03
  3380 KSP Residual norm 7.177543030292e-03
  3381 KSP Residual norm 7.853954858680e-03
  3382 KSP Residual norm 8.120645681643e-03
  3383 KSP Residual norm 9.053611504499e-03
  3384 KSP Residual norm 1.136035037033e-02
  3385 KSP Residual norm 1.304283230750e-02
  3386 KSP Residual norm 1.163407764338e-02
  3387 KSP Residual norm 8.409491414743e-03
  3388 KSP Residual norm 6.076571569911e-03
  3389 KSP Residual norm 5.063308200875e-03
  3390 KSP Residual norm 5.248174315404e-03
  3391 KSP Residual norm 6.560021912350e-03
  3392 KSP Residual norm 7.415905842330e-03
  3393 KSP Residual norm 7.258096522426e-03
  3394 KSP Residual norm 7.519030670535e-03
  3395 KSP Residual norm 7.947065118337e-03
  3396 KSP Residual norm 8.439483136767e-03
  3397 KSP Residual norm 9.153467368035e-03
  3398 KSP Residual norm 8.306626157337e-03
  3399 KSP Residual norm 5.999621700177e-03
  3400 KSP Residual norm 4.249803258353e-03
  3401 KSP Residual norm 3.266740729237e-03
  3402 KSP Residual norm 2.962905410642e-03
  3403 KSP Residual norm 3.294654846176e-03
  3404 KSP Residual norm 3.473894366545e-03
  3405 KSP Residual norm 3.310995992788e-03
  3406 KSP Residual norm 3.726455952379e-03
  3407 KSP Residual norm 4.885673388954e-03
  3408 KSP Residual norm 5.546168850270e-03
  3409 KSP Residual norm 5.740402294123e-03
  3410 KSP Residual norm 6.079770275235e-03
  3411 KSP Residual norm 6.014014871281e-03
  3412 KSP Residual norm 6.020096376792e-03
  3413 KSP Residual norm 5.968133126080e-03
  3414 KSP Residual norm 5.059945350920e-03
  3415 KSP Residual norm 3.587378586357e-03
  3416 KSP Residual norm 2.822033047601e-03
  3417 KSP Residual norm 2.513662279448e-03
  3418 KSP Residual norm 2.379184307503e-03
  3419 KSP Residual norm 2.329629264453e-03
  3420 KSP Residual norm 2.204936400537e-03
  3421 KSP Residual norm 2.085485526127e-03
  3422 KSP Residual norm 2.239133298867e-03
  3423 KSP Residual norm 2.781163346688e-03
  3424 KSP Residual norm 3.467984178772e-03
  3425 KSP Residual norm 3.766608644314e-03
  3426 KSP Residual norm 3.542590969970e-03
  3427 KSP Residual norm 3.021545797448e-03
  3428 KSP Residual norm 2.575151560536e-03
  3429 KSP Residual norm 2.360653493124e-03
  3430 KSP Residual norm 2.316791073053e-03
  3431 KSP Residual norm 2.217026763308e-03
  3432 KSP Residual norm 1.992379378075e-03
  3433 KSP Residual norm 1.753332197379e-03
  3434 KSP Residual norm 1.757412270373e-03
  3435 KSP Residual norm 2.202389081792e-03
  3436 KSP Residual norm 2.686035122139e-03
  3437 KSP Residual norm 2.499700048378e-03
  3438 KSP Residual norm 2.244939603433e-03
  3439 KSP Residual norm 2.330553771967e-03
  3440 KSP Residual norm 2.624392189817e-03
  3441 KSP Residual norm 2.623874272572e-03
  3442 KSP Residual norm 2.070401979000e-03
  3443 KSP Residual norm 1.444355694733e-03
  3444 KSP Residual norm 1.094870722720e-03
  3445 KSP Residual norm 9.607246377444e-04
  3446 KSP Residual norm 8.651114234745e-04
  3447 KSP Residual norm 7.499264278678e-04
  3448 KSP Residual norm 6.984004105417e-04
  3449 KSP Residual norm 7.806927786775e-04
  3450 KSP Residual norm 1.030933255808e-03
  3451 KSP Residual norm 1.398237545698e-03
  3452 KSP Residual norm 1.562644637794e-03
  3453 KSP Residual norm 1.511551810266e-03
  3454 KSP Residual norm 1.473179602700e-03
  3455 KSP Residual norm 1.517294639902e-03
  3456 KSP Residual norm 1.480657264659e-03
  3457 KSP Residual norm 1.201818362205e-03
  3458 KSP Residual norm 8.991204921500e-04
  3459 KSP Residual norm 8.256666138973e-04
  3460 KSP Residual norm 8.916031729385e-04
  3461 KSP Residual norm 9.093828933303e-04
  3462 KSP Residual norm 7.921076595761e-04
  3463 KSP Residual norm 6.812389654892e-04
  3464 KSP Residual norm 6.586554280163e-04
  3465 KSP Residual norm 7.291705292598e-04
  3466 KSP Residual norm 8.036112210929e-04
  3467 KSP Residual norm 8.366608045404e-04
  3468 KSP Residual norm 7.963892254702e-04
  3469 KSP Residual norm 7.877505216885e-04
  3470 KSP Residual norm 8.353415436455e-04
  3471 KSP Residual norm 9.277720257402e-04
  3472 KSP Residual norm 1.101942335291e-03
  3473 KSP Residual norm 1.067069499995e-03
  3474 KSP Residual norm 8.006057154162e-04
  3475 KSP Residual norm 6.566476734925e-04
  3476 KSP Residual norm 6.350126093126e-04
  3477 KSP Residual norm 6.742107335825e-04
  3478 KSP Residual norm 6.354443420061e-04
  3479 KSP Residual norm 5.179732380869e-04
  3480 KSP Residual norm 4.121368114192e-04
  3481 KSP Residual norm 3.787878580931e-04
  3482 KSP Residual norm 4.440028813957e-04
  3483 KSP Residual norm 5.114775212055e-04
  3484 KSP Residual norm 4.743065925748e-04
  3485 KSP Residual norm 4.294702343993e-04
  3486 KSP Residual norm 4.657060853571e-04
  3487 KSP Residual norm 5.852635504900e-04
  3488 KSP Residual norm 7.011058864148e-04
  3489 KSP Residual norm 7.195693799062e-04
  3490 KSP Residual norm 6.535302888204e-04
  3491 KSP Residual norm 5.841926553952e-04
  3492 KSP Residual norm 5.497100454829e-04
  3493 KSP Residual norm 5.255295851755e-04
  3494 KSP Residual norm 4.356822844171e-04
  3495 KSP Residual norm 3.685597805375e-04
  3496 KSP Residual norm 3.330568822722e-04
  3497 KSP Residual norm 3.421860146338e-04
  3498 KSP Residual norm 3.690993881108e-04
  3499 KSP Residual norm 3.532750971556e-04
  3500 KSP Residual norm 3.049433515967e-04
  3501 KSP Residual norm 2.931011824341e-04
  3502 KSP Residual norm 3.440663736710e-04
  3503 KSP Residual norm 4.632817903386e-04
  3504 KSP Residual norm 5.561854642997e-04
  3505 KSP Residual norm 5.630559169398e-04
  3506 KSP Residual norm 5.380430164398e-04
  3507 KSP Residual norm 6.104820630153e-04
  3508 KSP Residual norm 8.274878968856e-04
  3509 KSP Residual norm 9.875315649218e-04
  3510 KSP Residual norm 9.092201828164e-04
  3511 KSP Residual norm 7.757570077409e-04
  3512 KSP Residual norm 7.559988057923e-04
  3513 KSP Residual norm 8.803879684377e-04
  3514 KSP Residual norm 9.508967221048e-04
  3515 KSP Residual norm 7.389022793062e-04
  3516 KSP Residual norm 6.193006140846e-04
  3517 KSP Residual norm 6.570425920917e-04
  3518 KSP Residual norm 7.832796504841e-04
  3519 KSP Residual norm 8.532010926067e-04
  3520 KSP Residual norm 8.208984225632e-04
  3521 KSP Residual norm 7.932871011582e-04
  3522 KSP Residual norm 8.798936491137e-04
  3523 KSP Residual norm 1.070383262272e-03
  3524 KSP Residual norm 1.195189003322e-03
  3525 KSP Residual norm 1.205191158875e-03
  3526 KSP Residual norm 1.266488170870e-03
  3527 KSP Residual norm 1.554374548755e-03
  3528 KSP Residual norm 2.023641804266e-03
  3529 KSP Residual norm 2.045493343792e-03
  3530 KSP Residual norm 1.478040580461e-03
  3531 KSP Residual norm 1.075182917332e-03
  3532 KSP Residual norm 9.771798637772e-04
  3533 KSP Residual norm 1.067532871406e-03
  3534 KSP Residual norm 1.030407985674e-03
  3535 KSP Residual norm 8.620271812682e-04
  3536 KSP Residual norm 8.317543992205e-04
  3537 KSP Residual norm 1.015062917753e-03
  3538 KSP Residual norm 1.334676394032e-03
  3539 KSP Residual norm 1.496384546331e-03
  3540 KSP Residual norm 1.441118149914e-03
  3541 KSP Residual norm 1.525326786434e-03
  3542 KSP Residual norm 1.931801313192e-03
  3543 KSP Residual norm 2.280673015354e-03
  3544 KSP Residual norm 2.018253041515e-03
  3545 KSP Residual norm 1.678637829758e-03
  3546 KSP Residual norm 1.639551928886e-03
  3547 KSP Residual norm 1.806076301212e-03
  3548 KSP Residual norm 1.997638456010e-03
  3549 KSP Residual norm 1.877914332868e-03
  3550 KSP Residual norm 1.484076951522e-03
  3551 KSP Residual norm 1.330692024164e-03
  3552 KSP Residual norm 1.437317909713e-03
  3553 KSP Residual norm 1.613975703049e-03
  3554 KSP Residual norm 1.673509057881e-03
  3555 KSP Residual norm 1.613179476473e-03
  3556 KSP Residual norm 1.724258525116e-03
  3557 KSP Residual norm 2.249061196567e-03
  3558 KSP Residual norm 3.032330505208e-03
  3559 KSP Residual norm 3.311623721401e-03
  3560 KSP Residual norm 3.128816736141e-03
  3561 KSP Residual norm 3.171573670495e-03
  3562 KSP Residual norm 3.733094582663e-03
  3563 KSP Residual norm 4.097017261153e-03
  3564 KSP Residual norm 3.513162399956e-03
  3565 KSP Residual norm 2.948428313749e-03
  3566 KSP Residual norm 2.901393034600e-03
  3567 KSP Residual norm 2.984534470525e-03
  3568 KSP Residual norm 2.779805984533e-03
  3569 KSP Residual norm 2.432290259025e-03
  3570 KSP Residual norm 2.389515820843e-03
  3571 KSP Residual norm 2.593743319429e-03
  3572 KSP Residual norm 2.785783894119e-03
  3573 KSP Residual norm 2.501197636017e-03
  3574 KSP Residual norm 2.082103648580e-03
  3575 KSP Residual norm 2.041599248973e-03
  3576 KSP Residual norm 2.399253747622e-03
  3577 KSP Residual norm 2.732195497203e-03
  3578 KSP Residual norm 2.709450757970e-03
  3579 KSP Residual norm 2.626285332542e-03
  3580 KSP Residual norm 3.036264845884e-03
  3581 KSP Residual norm 4.021274289136e-03
  3582 KSP Residual norm 4.881630819856e-03
  3583 KSP Residual norm 4.877683385218e-03
  3584 KSP Residual norm 4.338828882271e-03
  3585 KSP Residual norm 4.245469786156e-03
  3586 KSP Residual norm 4.453349478537e-03
  3587 KSP Residual norm 4.187751638837e-03
  3588 KSP Residual norm 3.784529402750e-03
  3589 KSP Residual norm 3.561587575294e-03
  3590 KSP Residual norm 3.509756733965e-03
  3591 KSP Residual norm 3.549135223631e-03
  3592 KSP Residual norm 3.401174808818e-03
  3593 KSP Residual norm 3.240863107469e-03
  3594 KSP Residual norm 3.520559389878e-03
  3595 KSP Residual norm 4.082694692065e-03
  3596 KSP Residual norm 4.136352599546e-03
  3597 KSP Residual norm 4.166900620936e-03
  3598 KSP Residual norm 5.044139245858e-03
  3599 KSP Residual norm 6.561622484536e-03
  3600 KSP Residual norm 7.307164257339e-03
  3601 KSP Residual norm 7.443863158124e-03
  3602 KSP Residual norm 7.828314430839e-03
  3603 KSP Residual norm 8.166278844055e-03
  3604 KSP Residual norm 7.658887239474e-03
  3605 KSP Residual norm 6.207092964009e-03
  3606 KSP Residual norm 4.678215399264e-03
  3607 KSP Residual norm 4.331164823929e-03
  3608 KSP Residual norm 4.833612569223e-03
  3609 KSP Residual norm 4.850875438914e-03
  3610 KSP Residual norm 4.047203963261e-03
  3611 KSP Residual norm 3.592469971986e-03
  3612 KSP Residual norm 3.532370630108e-03
  3613 KSP Residual norm 3.553192131972e-03
  3614 KSP Residual norm 3.665485709967e-03
  3615 KSP Residual norm 3.676007855053e-03
  3616 KSP Residual norm 3.981008685067e-03
  3617 KSP Residual norm 5.034569569705e-03
  3618 KSP Residual norm 6.117479478495e-03
  3619 KSP Residual norm 6.033465754972e-03
  3620 KSP Residual norm 6.227823513094e-03
  3621 KSP Residual norm 7.423841165264e-03
  3622 KSP Residual norm 8.306450199043e-03
  3623 KSP Residual norm 8.151912053584e-03
  3624 KSP Residual norm 7.754934563164e-03
  3625 KSP Residual norm 6.914354816909e-03
  3626 KSP Residual norm 6.253304568856e-03
  3627 KSP Residual norm 5.509961410378e-03
  3628 KSP Residual norm 4.394914369350e-03
  3629 KSP Residual norm 3.843952478986e-03
  3630 KSP Residual norm 4.149416599223e-03
  3631 KSP Residual norm 4.231999601513e-03
  3632 KSP Residual norm 3.540120774239e-03
  3633 KSP Residual norm 3.313927565109e-03
  3634 KSP Residual norm 3.855125406389e-03
  3635 KSP Residual norm 4.200891466551e-03
  3636 KSP Residual norm 4.150891094791e-03
  3637 KSP Residual norm 3.814103303157e-03
  3638 KSP Residual norm 3.586413132211e-03
  3639 KSP Residual norm 3.863108676532e-03
  3640 KSP Residual norm 4.476251263711e-03
  3641 KSP Residual norm 4.712874915970e-03
  3642 KSP Residual norm 5.332327228744e-03
  3643 KSP Residual norm 6.941879291547e-03
  3644 KSP Residual norm 8.118919341655e-03
  3645 KSP Residual norm 7.298348207224e-03
  3646 KSP Residual norm 5.954375112478e-03
  3647 KSP Residual norm 4.984839833387e-03
  3648 KSP Residual norm 4.384941933256e-03
  3649 KSP Residual norm 4.133886164299e-03
  3650 KSP Residual norm 3.545905667035e-03
  3651 KSP Residual norm 2.994975000936e-03
  3652 KSP Residual norm 2.767849745248e-03
  3653 KSP Residual norm 2.769630219044e-03
  3654 KSP Residual norm 2.439119191702e-03
  3655 KSP Residual norm 2.185834742866e-03
  3656 KSP Residual norm 2.202221778376e-03
  3657 KSP Residual norm 2.271546394093e-03
  3658 KSP Residual norm 2.366900033367e-03
  3659 KSP Residual norm 2.659340650284e-03
  3660 KSP Residual norm 2.704229966839e-03
  3661 KSP Residual norm 2.692655430256e-03
  3662 KSP Residual norm 2.892313527326e-03
  3663 KSP Residual norm 3.288715276748e-03
  3664 KSP Residual norm 3.769148978695e-03
  3665 KSP Residual norm 4.412253772286e-03
  3666 KSP Residual norm 4.761415185989e-03
  3667 KSP Residual norm 4.615132664724e-03
  3668 KSP Residual norm 4.554537747807e-03
  3669 KSP Residual norm 4.331885400047e-03
  3670 KSP Residual norm 3.832073404816e-03
  3671 KSP Residual norm 3.661534364403e-03
  3672 KSP Residual norm 3.689620790663e-03
  3673 KSP Residual norm 3.429423924588e-03
  3674 KSP Residual norm 3.060374069393e-03
  3675 KSP Residual norm 2.864262662252e-03
  3676 KSP Residual norm 2.672317271465e-03
  3677 KSP Residual norm 2.587979518671e-03
  3678 KSP Residual norm 2.568162988685e-03
  3679 KSP Residual norm 2.186044796154e-03
  3680 KSP Residual norm 1.727412388961e-03
  3681 KSP Residual norm 1.682847424785e-03
  3682 KSP Residual norm 1.821662828664e-03
  3683 KSP Residual norm 1.855863327891e-03
  3684 KSP Residual norm 1.818325924442e-03
  3685 KSP Residual norm 1.901158812440e-03
  3686 KSP Residual norm 2.089844447169e-03
  3687 KSP Residual norm 2.602974999488e-03
  3688 KSP Residual norm 3.018596557282e-03
  3689 KSP Residual norm 2.884115491376e-03
  3690 KSP Residual norm 2.961167133682e-03
  3691 KSP Residual norm 3.602270471292e-03
  3692 KSP Residual norm 4.112099294529e-03
  3693 KSP Residual norm 3.931680371933e-03
  3694 KSP Residual norm 3.659312970152e-03
  3695 KSP Residual norm 3.471262559772e-03
  3696 KSP Residual norm 3.131867604394e-03
  3697 KSP Residual norm 2.647193407058e-03
  3698 KSP Residual norm 1.962630853265e-03
  3699 KSP Residual norm 1.438871758597e-03
  3700 KSP Residual norm 1.319042910112e-03
  3701 KSP Residual norm 1.392918112041e-03
  3702 KSP Residual norm 1.316320114879e-03
  3703 KSP Residual norm 1.255495628385e-03
  3704 KSP Residual norm 1.221276120255e-03
  3705 KSP Residual norm 1.199294005221e-03
  3706 KSP Residual norm 1.265677446081e-03
  3707 KSP Residual norm 1.376997309064e-03
  3708 KSP Residual norm 1.365480084884e-03
  3709 KSP Residual norm 1.278357561762e-03
  3710 KSP Residual norm 1.307647305705e-03
  3711 KSP Residual norm 1.271105239642e-03
  3712 KSP Residual norm 1.121904585817e-03
  3713 KSP Residual norm 1.105572981791e-03
  3714 KSP Residual norm 1.150658368807e-03
  3715 KSP Residual norm 1.133291576619e-03
  3716 KSP Residual norm 1.133521042662e-03
  3717 KSP Residual norm 1.172699492001e-03
  3718 KSP Residual norm 1.227452311584e-03
  3719 KSP Residual norm 1.375807043239e-03
  3720 KSP Residual norm 1.519214167410e-03
  3721 KSP Residual norm 1.496648336825e-03
  3722 KSP Residual norm 1.479128754948e-03
  3723 KSP Residual norm 1.386605556850e-03
  3724 KSP Residual norm 1.123984411991e-03
  3725 KSP Residual norm 1.019650926164e-03
  3726 KSP Residual norm 1.062686708325e-03
  3727 KSP Residual norm 9.688928695139e-04
  3728 KSP Residual norm 7.979894915360e-04
  3729 KSP Residual norm 7.999058710281e-04
  3730 KSP Residual norm 9.139786750030e-04
  3731 KSP Residual norm 1.040568590637e-03
  3732 KSP Residual norm 1.128567347413e-03
  3733 KSP Residual norm 1.204887771337e-03
  3734 KSP Residual norm 1.300372691905e-03
  3735 KSP Residual norm 1.508734119908e-03
  3736 KSP Residual norm 1.729315134442e-03
  3737 KSP Residual norm 1.846671078686e-03
  3738 KSP Residual norm 2.160761751184e-03
  3739 KSP Residual norm 2.430394745094e-03
  3740 KSP Residual norm 2.271433580421e-03
  3741 KSP Residual norm 1.895654453543e-03
  3742 KSP Residual norm 1.694876639236e-03
  3743 KSP Residual norm 1.664785611067e-03
  3744 KSP Residual norm 1.845714329804e-03
  3745 KSP Residual norm 1.928638202536e-03
  3746 KSP Residual norm 1.714802331203e-03
  3747 KSP Residual norm 1.625047760745e-03
  3748 KSP Residual norm 1.713473645431e-03
  3749 KSP Residual norm 1.829653885607e-03
  3750 KSP Residual norm 1.672760741911e-03
  3751 KSP Residual norm 1.474465283155e-03
  3752 KSP Residual norm 1.425192074654e-03
  3753 KSP Residual norm 1.467973336645e-03
  3754 KSP Residual norm 1.473926936692e-03
  3755 KSP Residual norm 1.350396371662e-03
  3756 KSP Residual norm 1.304074505142e-03
  3757 KSP Residual norm 1.494142474303e-03
  3758 KSP Residual norm 1.673990463401e-03
  3759 KSP Residual norm 1.722978244809e-03
  3760 KSP Residual norm 1.883893105765e-03
  3761 KSP Residual norm 2.252772410373e-03
  3762 KSP Residual norm 2.457645832058e-03
  3763 KSP Residual norm 2.591371644087e-03
  3764 KSP Residual norm 3.014127607147e-03
  3765 KSP Residual norm 3.658591732078e-03
  3766 KSP Residual norm 3.966524686175e-03
  3767 KSP Residual norm 3.862014072163e-03
  3768 KSP Residual norm 3.777509564235e-03
  3769 KSP Residual norm 4.056011536640e-03
  3770 KSP Residual norm 4.548859906303e-03
  3771 KSP Residual norm 4.544581773738e-03
  3772 KSP Residual norm 4.091599538555e-03
  3773 KSP Residual norm 4.306313663683e-03
  3774 KSP Residual norm 4.351657747698e-03
  3775 KSP Residual norm 3.824055216587e-03
  3776 KSP Residual norm 3.505714847880e-03
  3777 KSP Residual norm 3.537716266683e-03
  3778 KSP Residual norm 3.317663861356e-03
  3779 KSP Residual norm 2.850104340265e-03
  3780 KSP Residual norm 2.553317624037e-03
  3781 KSP Residual norm 2.325589585195e-03
  3782 KSP Residual norm 2.140112890449e-03
  3783 KSP Residual norm 2.184446675867e-03
  3784 KSP Residual norm 2.275638442386e-03
  3785 KSP Residual norm 2.437849826740e-03
  3786 KSP Residual norm 2.868317331370e-03
  3787 KSP Residual norm 3.312619326922e-03
  3788 KSP Residual norm 3.410376571653e-03
  3789 KSP Residual norm 3.786321830045e-03
  3790 KSP Residual norm 4.508358257941e-03
  3791 KSP Residual norm 4.892462517884e-03
  3792 KSP Residual norm 5.553242085047e-03
  3793 KSP Residual norm 6.601775799811e-03
  3794 KSP Residual norm 7.053367506202e-03
  3795 KSP Residual norm 7.333486350305e-03
  3796 KSP Residual norm 7.649033463018e-03
  3797 KSP Residual norm 7.876043153176e-03
  3798 KSP Residual norm 8.189345098556e-03
  3799 KSP Residual norm 8.555044954388e-03
  3800 KSP Residual norm 8.014667913915e-03
  3801 KSP Residual norm 7.248413672911e-03
  3802 KSP Residual norm 7.287397118484e-03
  3803 KSP Residual norm 7.637040534018e-03
  3804 KSP Residual norm 6.897714931498e-03
  3805 KSP Residual norm 5.944469575451e-03
  3806 KSP Residual norm 5.528459318034e-03
  3807 KSP Residual norm 5.120640390509e-03
  3808 KSP Residual norm 5.004626284979e-03
  3809 KSP Residual norm 4.807067376378e-03
  3810 KSP Residual norm 4.145125430127e-03
  3811 KSP Residual norm 4.048204614586e-03
  3812 KSP Residual norm 4.404451642166e-03
  3813 KSP Residual norm 4.421239620152e-03
  3814 KSP Residual norm 4.235949899498e-03
  3815 KSP Residual norm 4.318141981494e-03
  3816 KSP Residual norm 4.354335812443e-03
  3817 KSP Residual norm 4.546322496775e-03
  3818 KSP Residual norm 5.031750667498e-03
  3819 KSP Residual norm 5.678117818594e-03
  3820 KSP Residual norm 6.142015034997e-03
  3821 KSP Residual norm 6.888812809295e-03
  3822 KSP Residual norm 7.390367234017e-03
  3823 KSP Residual norm 7.242315061307e-03
  3824 KSP Residual norm 7.198365334206e-03
  3825 KSP Residual norm 7.905688770395e-03
  3826 KSP Residual norm 8.467086227498e-03
  3827 KSP Residual norm 8.994802372687e-03
  3828 KSP Residual norm 9.159103811113e-03
  3829 KSP Residual norm 9.321363538906e-03
  3830 KSP Residual norm 9.340719550397e-03
  3831 KSP Residual norm 8.794202141717e-03
  3832 KSP Residual norm 7.320236022828e-03
  3833 KSP Residual norm 6.202776925164e-03
  3834 KSP Residual norm 6.002133205176e-03
  3835 KSP Residual norm 5.774001141672e-03
  3836 KSP Residual norm 5.522115330165e-03
  3837 KSP Residual norm 5.750920916907e-03
  3838 KSP Residual norm 5.784424597201e-03
  3839 KSP Residual norm 5.504244278726e-03
  3840 KSP Residual norm 5.786508402931e-03
  3841 KSP Residual norm 6.258709456382e-03
  3842 KSP Residual norm 6.184804909771e-03
  3843 KSP Residual norm 6.356004268985e-03
  3844 KSP Residual norm 6.602123566606e-03
  3845 KSP Residual norm 6.629844664195e-03
  3846 KSP Residual norm 6.591228941087e-03
  3847 KSP Residual norm 6.622254373335e-03
  3848 KSP Residual norm 7.022275135718e-03
  3849 KSP Residual norm 7.837290866996e-03
  3850 KSP Residual norm 8.123428859581e-03
  3851 KSP Residual norm 7.749126144592e-03
  3852 KSP Residual norm 8.163895683028e-03
  3853 KSP Residual norm 9.515605767568e-03
  3854 KSP Residual norm 1.001839354636e-02
  3855 KSP Residual norm 9.104095295020e-03
  3856 KSP Residual norm 8.774792035458e-03
  3857 KSP Residual norm 9.217738089275e-03
  3858 KSP Residual norm 1.018684571783e-02
  3859 KSP Residual norm 9.748869663756e-03
  3860 KSP Residual norm 7.794010844671e-03
  3861 KSP Residual norm 6.623638961256e-03
  3862 KSP Residual norm 6.355345934030e-03
  3863 KSP Residual norm 5.763380439604e-03
  3864 KSP Residual norm 4.581589857017e-03
  3865 KSP Residual norm 4.204658458253e-03
  3866 KSP Residual norm 4.358757553644e-03
  3867 KSP Residual norm 4.372774461814e-03
  3868 KSP Residual norm 4.075135303573e-03
  3869 KSP Residual norm 3.988355680697e-03
  3870 KSP Residual norm 4.074966854814e-03
  3871 KSP Residual norm 4.428383285782e-03
  3872 KSP Residual norm 4.992694123191e-03
  3873 KSP Residual norm 5.345483223032e-03
  3874 KSP Residual norm 5.907896699672e-03
  3875 KSP Residual norm 6.791550695225e-03
  3876 KSP Residual norm 7.453043324368e-03
  3877 KSP Residual norm 7.316237666160e-03
  3878 KSP Residual norm 7.638203490970e-03
  3879 KSP Residual norm 8.189926544721e-03
  3880 KSP Residual norm 8.172873192297e-03
  3881 KSP Residual norm 8.202362329638e-03
  3882 KSP Residual norm 7.875925066871e-03
  3883 KSP Residual norm 7.302825340613e-03
  3884 KSP Residual norm 6.769260297802e-03
  3885 KSP Residual norm 5.824290141855e-03
  3886 KSP Residual norm 4.628515099291e-03
  3887 KSP Residual norm 4.344626413698e-03
  3888 KSP Residual norm 4.438663569125e-03
  3889 KSP Residual norm 3.802257686884e-03
  3890 KSP Residual norm 3.095255544821e-03
  3891 KSP Residual norm 2.848210691569e-03
  3892 KSP Residual norm 2.657250095577e-03
  3893 KSP Residual norm 2.276320456704e-03
  3894 KSP Residual norm 2.037450393309e-03
  3895 KSP Residual norm 1.915467200636e-03
  3896 KSP Residual norm 1.719587131875e-03
  3897 KSP Residual norm 1.524609344566e-03
  3898 KSP Residual norm 1.290825461981e-03
  3899 KSP Residual norm 1.168883320575e-03
  3900 KSP Residual norm 1.283331231701e-03
  3901 KSP Residual norm 1.436126987057e-03
  3902 KSP Residual norm 1.361955006227e-03
  3903 KSP Residual norm 1.338175783573e-03
  3904 KSP Residual norm 1.570638634894e-03
  3905 KSP Residual norm 1.713508983336e-03
  3906 KSP Residual norm 1.677892560676e-03
  3907 KSP Residual norm 1.813736764789e-03
  3908 KSP Residual norm 2.242120276841e-03
  3909 KSP Residual norm 2.698144730117e-03
  3910 KSP Residual norm 2.943518756740e-03
  3911 KSP Residual norm 2.811756037698e-03
  3912 KSP Residual norm 2.699136252558e-03
  3913 KSP Residual norm 2.913649753289e-03
  3914 KSP Residual norm 2.953715188845e-03
  3915 KSP Residual norm 2.652624157403e-03
  3916 KSP Residual norm 2.673256732648e-03
  3917 KSP Residual norm 2.724974376132e-03
  3918 KSP Residual norm 2.333190412935e-03
  3919 KSP Residual norm 1.956168059339e-03
  3920 KSP Residual norm 1.871657576280e-03
  3921 KSP Residual norm 1.899763659179e-03
  3922 KSP Residual norm 1.997132487780e-03
  3923 KSP Residual norm 2.058263607911e-03
  3924 KSP Residual norm 1.903797645321e-03
  3925 KSP Residual norm 1.710810284625e-03
  3926 KSP Residual norm 1.557951987260e-03
  3927 KSP Residual norm 1.380954604580e-03
  3928 KSP Residual norm 1.273116266406e-03
  3929 KSP Residual norm 1.281841353544e-03
  3930 KSP Residual norm 1.277594278924e-03
  3931 KSP Residual norm 1.277687865662e-03
  3932 KSP Residual norm 1.353717396913e-03
  3933 KSP Residual norm 1.402807119549e-03
  3934 KSP Residual norm 1.422277591573e-03
  3935 KSP Residual norm 1.625924173011e-03
  3936 KSP Residual norm 1.975493126500e-03
  3937 KSP Residual norm 2.196794890192e-03
  3938 KSP Residual norm 2.341207215937e-03
  3939 KSP Residual norm 2.430487228105e-03
  3940 KSP Residual norm 2.495149065372e-03
  3941 KSP Residual norm 2.778120305213e-03
  3942 KSP Residual norm 3.124408930176e-03
  3943 KSP Residual norm 3.190882529742e-03
  3944 KSP Residual norm 3.373692722048e-03
  3945 KSP Residual norm 3.709821475184e-03
  3946 KSP Residual norm 3.491173160141e-03
  3947 KSP Residual norm 3.063171306949e-03
  3948 KSP Residual norm 2.800498250288e-03
  3949 KSP Residual norm 2.768468359212e-03
  3950 KSP Residual norm 2.789753714034e-03
  3951 KSP Residual norm 2.738210884861e-03
  3952 KSP Residual norm 2.465213574489e-03
  3953 KSP Residual norm 2.265157643342e-03
  3954 KSP Residual norm 2.358747748701e-03
  3955 KSP Residual norm 2.411573013505e-03
  3956 KSP Residual norm 2.089312592337e-03
  3957 KSP Residual norm 1.933501287631e-03
  3958 KSP Residual norm 2.108368215422e-03
  3959 KSP Residual norm 2.219814652133e-03
  3960 KSP Residual norm 2.110738251193e-03
  3961 KSP Residual norm 2.234926751875e-03
  3962 KSP Residual norm 2.593577306467e-03
  3963 KSP Residual norm 2.983545200723e-03
  3964 KSP Residual norm 3.078357910477e-03
  3965 KSP Residual norm 2.966701504541e-03
  3966 KSP Residual norm 3.149638391658e-03
  3967 KSP Residual norm 3.445184167452e-03
  3968 KSP Residual norm 3.453035160513e-03
  3969 KSP Residual norm 3.502134926831e-03
  3970 KSP Residual norm 4.085379176779e-03
  3971 KSP Residual norm 4.590664868093e-03
  3972 KSP Residual norm 4.469800844813e-03
  3973 KSP Residual norm 4.237203899081e-03
  3974 KSP Residual norm 4.128879619177e-03
  3975 KSP Residual norm 4.125836613557e-03
  3976 KSP Residual norm 4.214714507964e-03
  3977 KSP Residual norm 4.105466834480e-03
  3978 KSP Residual norm 3.934598316084e-03
  3979 KSP Residual norm 3.912392761648e-03
  3980 KSP Residual norm 3.798478103772e-03
  3981 KSP Residual norm 3.562448082973e-03
  3982 KSP Residual norm 3.545680883614e-03
  3983 KSP Residual norm 3.645794420826e-03
  3984 KSP Residual norm 3.592630361608e-03
  3985 KSP Residual norm 3.553548998729e-03
  3986 KSP Residual norm 3.700141927027e-03
  3987 KSP Residual norm 3.567627859690e-03
  3988 KSP Residual norm 3.390844827108e-03
  3989 KSP Residual norm 3.281308568522e-03
  3990 KSP Residual norm 2.991696242542e-03
  3991 KSP Residual norm 2.792869991820e-03
  3992 KSP Residual norm 3.010884760411e-03
  3993 KSP Residual norm 3.227496452664e-03
  3994 KSP Residual norm 3.412383234711e-03
  3995 KSP Residual norm 3.795193937763e-03
  3996 KSP Residual norm 4.149179729550e-03
  3997 KSP Residual norm 4.539427431375e-03
  3998 KSP Residual norm 5.416436361368e-03
  3999 KSP Residual norm 6.300588368756e-03
  4000 KSP Residual norm 6.167787442207e-03
  4001 KSP Residual norm 6.292404625557e-03
  4002 KSP Residual norm 7.008852289372e-03
  4003 KSP Residual norm 7.565498299997e-03
  4004 KSP Residual norm 8.120854469308e-03
  4005 KSP Residual norm 8.713611599056e-03
  4006 KSP Residual norm 9.677399641609e-03
  4007 KSP Residual norm 1.054689757176e-02
  4008 KSP Residual norm 1.087582928849e-02
  4009 KSP Residual norm 1.007451883091e-02
  4010 KSP Residual norm 1.005418117457e-02
  4011 KSP Residual norm 1.124097769836e-02
  4012 KSP Residual norm 1.148649707407e-02
  4013 KSP Residual norm 9.941201966828e-03
  4014 KSP Residual norm 8.901971081700e-03
  4015 KSP Residual norm 8.696142532189e-03
  4016 KSP Residual norm 8.404181169403e-03
  4017 KSP Residual norm 7.741560127934e-03
  4018 KSP Residual norm 6.870162833530e-03
  4019 KSP Residual norm 6.409642477895e-03
  4020 KSP Residual norm 6.069328086156e-03
  4021 KSP Residual norm 5.776827413134e-03
  4022 KSP Residual norm 5.670138057287e-03
  4023 KSP Residual norm 6.239748496973e-03
  4024 KSP Residual norm 6.364078567745e-03
  4025 KSP Residual norm 5.480279527492e-03
  4026 KSP Residual norm 5.420611891364e-03
  4027 KSP Residual norm 6.693178523687e-03
  4028 KSP Residual norm 7.573505928781e-03
  4029 KSP Residual norm 7.355062725531e-03
  4030 KSP Residual norm 7.865815366378e-03
  4031 KSP Residual norm 8.913608852850e-03
  4032 KSP Residual norm 9.353830422719e-03
  4033 KSP Residual norm 9.445000231771e-03
  4034 KSP Residual norm 9.764659241521e-03
  4035 KSP Residual norm 1.100159122518e-02
  4036 KSP Residual norm 1.285288256792e-02
  4037 KSP Residual norm 1.335029056582e-02
  4038 KSP Residual norm 1.294587675911e-02
  4039 KSP Residual norm 1.422094898257e-02
  4040 KSP Residual norm 1.628215393699e-02
  4041 KSP Residual norm 1.696945076695e-02
  4042 KSP Residual norm 1.694930718735e-02
  4043 KSP Residual norm 1.843978945611e-02
  4044 KSP Residual norm 2.052299648808e-02
  4045 KSP Residual norm 2.211748841535e-02
  4046 KSP Residual norm 2.321705907275e-02
  4047 KSP Residual norm 2.341689257375e-02
  4048 KSP Residual norm 2.416178335527e-02
  4049 KSP Residual norm 2.599295943495e-02
  4050 KSP Residual norm 2.514273558437e-02
  4051 KSP Residual norm 2.373749571765e-02
  4052 KSP Residual norm 2.496239301966e-02
  4053 KSP Residual norm 2.384572486980e-02
  4054 KSP Residual norm 2.189786972011e-02
  4055 KSP Residual norm 2.172818225751e-02
  4056 KSP Residual norm 2.205485921263e-02
  4057 KSP Residual norm 2.086284956444e-02
  4058 KSP Residual norm 1.978949412410e-02
  4059 KSP Residual norm 1.903694302453e-02
  4060 KSP Residual norm 1.756156298591e-02
  4061 KSP Residual norm 1.650577386275e-02
  4062 KSP Residual norm 1.612937501544e-02
  4063 KSP Residual norm 1.558395950881e-02
  4064 KSP Residual norm 1.577750699603e-02
  4065 KSP Residual norm 1.655934045560e-02
  4066 KSP Residual norm 1.473611853106e-02
  4067 KSP Residual norm 1.377019185090e-02
  4068 KSP Residual norm 1.564529179969e-02
  4069 KSP Residual norm 1.774505414733e-02
  4070 KSP Residual norm 1.868732589035e-02
  4071 KSP Residual norm 1.991885818140e-02
  4072 KSP Residual norm 2.012862143662e-02
  4073 KSP Residual norm 1.988132788479e-02
  4074 KSP Residual norm 2.115103418971e-02
  4075 KSP Residual norm 2.358979444836e-02
  4076 KSP Residual norm 2.611719633359e-02
  4077 KSP Residual norm 3.035047492284e-02
  4078 KSP Residual norm 3.352971782032e-02
  4079 KSP Residual norm 3.578598417072e-02
  4080 KSP Residual norm 4.263841989420e-02
  4081 KSP Residual norm 5.165886197902e-02
  4082 KSP Residual norm 5.486201128347e-02
  4083 KSP Residual norm 5.049910298019e-02
  4084 KSP Residual norm 4.605553120815e-02
  4085 KSP Residual norm 4.490494642830e-02
  4086 KSP Residual norm 4.829641408881e-02
  4087 KSP Residual norm 5.501933354121e-02
  4088 KSP Residual norm 5.762181496335e-02
  4089 KSP Residual norm 6.184507763720e-02
  4090 KSP Residual norm 6.799001535709e-02
  4091 KSP Residual norm 6.699676586533e-02
  4092 KSP Residual norm 6.137143947571e-02
  4093 KSP Residual norm 6.145208768691e-02
  4094 KSP Residual norm 6.447849143416e-02
  4095 KSP Residual norm 6.677785223841e-02
  4096 KSP Residual norm 6.994893194717e-02
  4097 KSP Residual norm 7.259122470004e-02
  4098 KSP Residual norm 6.628765269480e-02
  4099 KSP Residual norm 5.769623044857e-02
  4100 KSP Residual norm 4.954700349837e-02
  4101 KSP Residual norm 4.471952485641e-02
  4102 KSP Residual norm 4.250378170916e-02
  4103 KSP Residual norm 4.024537134283e-02
  4104 KSP Residual norm 3.712590771737e-02
  4105 KSP Residual norm 3.736567911800e-02
  4106 KSP Residual norm 3.892325200756e-02
  4107 KSP Residual norm 3.618833648615e-02
  4108 KSP Residual norm 3.274608263635e-02
  4109 KSP Residual norm 3.302857805750e-02
  4110 KSP Residual norm 3.368772472420e-02
  4111 KSP Residual norm 3.084212384729e-02
  4112 KSP Residual norm 2.668617404434e-02
  4113 KSP Residual norm 2.604814110785e-02
  4114 KSP Residual norm 2.984441792959e-02
  4115 KSP Residual norm 3.794117643623e-02
  4116 KSP Residual norm 4.452640277485e-02
  4117 KSP Residual norm 4.683760157063e-02
  4118 KSP Residual norm 4.627721780100e-02
  4119 KSP Residual norm 4.750187095074e-02
  4120 KSP Residual norm 5.246150669565e-02
  4121 KSP Residual norm 6.162377530446e-02
  4122 KSP Residual norm 6.940348416890e-02
  4123 KSP Residual norm 6.691640581601e-02
  4124 KSP Residual norm 6.090565988371e-02
  4125 KSP Residual norm 5.826128057062e-02
  4126 KSP Residual norm 5.637134138895e-02
  4127 KSP Residual norm 5.479174409528e-02
  4128 KSP Residual norm 5.077100516913e-02
  4129 KSP Residual norm 4.710560934884e-02
  4130 KSP Residual norm 4.689111810416e-02
  4131 KSP Residual norm 4.582858436072e-02
  4132 KSP Residual norm 4.018768421611e-02
  4133 KSP Residual norm 3.983785178650e-02
  4134 KSP Residual norm 3.979030025495e-02
  4135 KSP Residual norm 3.514106000032e-02
  4136 KSP Residual norm 3.181214922977e-02
  4137 KSP Residual norm 3.383059959436e-02
  4138 KSP Residual norm 3.435143887120e-02
  4139 KSP Residual norm 3.201574560649e-02
  4140 KSP Residual norm 3.025203926137e-02
  4141 KSP Residual norm 2.955297935694e-02
  4142 KSP Residual norm 3.005511786720e-02
  4143 KSP Residual norm 3.134659999092e-02
  4144 KSP Residual norm 3.152611526486e-02
  4145 KSP Residual norm 3.378896641577e-02
  4146 KSP Residual norm 3.767631864871e-02
  4147 KSP Residual norm 3.872142644142e-02
  4148 KSP Residual norm 3.788041737293e-02
  4149 KSP Residual norm 4.003507550931e-02
  4150 KSP Residual norm 4.352619292239e-02
  4151 KSP Residual norm 4.722291075145e-02
  4152 KSP Residual norm 5.312430242758e-02
  4153 KSP Residual norm 6.384037240444e-02
  4154 KSP Residual norm 6.976262480136e-02
  4155 KSP Residual norm 6.727404192307e-02
  4156 KSP Residual norm 6.278491467126e-02
  4157 KSP Residual norm 5.903721072657e-02
  4158 KSP Residual norm 5.770156694826e-02
  4159 KSP Residual norm 5.719171927231e-02
  4160 KSP Residual norm 5.405639928914e-02
  4161 KSP Residual norm 5.104723515948e-02
  4162 KSP Residual norm 5.246997457170e-02
  4163 KSP Residual norm 5.085264261434e-02
  4164 KSP Residual norm 4.639547771841e-02
  4165 KSP Residual norm 4.424276902582e-02
  4166 KSP Residual norm 3.894890310919e-02
  4167 KSP Residual norm 3.188992989941e-02
  4168 KSP Residual norm 2.891759071865e-02
  4169 KSP Residual norm 2.911735950990e-02
  4170 KSP Residual norm 2.737932630824e-02
  4171 KSP Residual norm 2.513876186543e-02
  4172 KSP Residual norm 2.334986682740e-02
  4173 KSP Residual norm 2.168115377523e-02
  4174 KSP Residual norm 2.196663323481e-02
  4175 KSP Residual norm 2.301565649075e-02
  4176 KSP Residual norm 2.151719060006e-02
  4177 KSP Residual norm 2.006323971901e-02
  4178 KSP Residual norm 2.055958248099e-02
  4179 KSP Residual norm 2.085541329820e-02
  4180 KSP Residual norm 1.971004760518e-02
  4181 KSP Residual norm 1.928401803922e-02
  4182 KSP Residual norm 1.961270292296e-02
  4183 KSP Residual norm 2.032814605531e-02
  4184 KSP Residual norm 2.084056987718e-02
  4185 KSP Residual norm 1.921762997018e-02
  4186 KSP Residual norm 1.847233155789e-02
  4187 KSP Residual norm 2.049672581148e-02
  4188 KSP Residual norm 2.389381826180e-02
  4189 KSP Residual norm 2.589106108971e-02
  4190 KSP Residual norm 2.829041676912e-02
  4191 KSP Residual norm 3.107395419930e-02
  4192 KSP Residual norm 3.313222908529e-02
  4193 KSP Residual norm 3.574395005143e-02
  4194 KSP Residual norm 3.763611194066e-02
  4195 KSP Residual norm 3.783113059850e-02
  4196 KSP Residual norm 3.810303732131e-02
  4197 KSP Residual norm 3.910627755148e-02
  4198 KSP Residual norm 4.087449554290e-02
  4199 KSP Residual norm 4.133407095921e-02
  4200 KSP Residual norm 3.912211956128e-02
  4201 KSP Residual norm 3.584684092597e-02
  4202 KSP Residual norm 3.410416417466e-02
  4203 KSP Residual norm 3.089408696511e-02
  4204 KSP Residual norm 2.721438390337e-02
  4205 KSP Residual norm 2.542328046610e-02
  4206 KSP Residual norm 2.534751439496e-02
  4207 KSP Residual norm 2.201163504458e-02
  4208 KSP Residual norm 1.897173081031e-02
  4209 KSP Residual norm 1.778612566789e-02
  4210 KSP Residual norm 1.658467259507e-02
  4211 KSP Residual norm 1.463353687131e-02
  4212 KSP Residual norm 1.372266039403e-02
  4213 KSP Residual norm 1.386600833626e-02
  4214 KSP Residual norm 1.413474215759e-02
  4215 KSP Residual norm 1.364982865091e-02
  4216 KSP Residual norm 1.220735256835e-02
  4217 KSP Residual norm 1.056331911208e-02
  4218 KSP Residual norm 1.088532116905e-02
  4219 KSP Residual norm 1.122182851744e-02
  4220 KSP Residual norm 1.024576915002e-02
  4221 KSP Residual norm 9.685094919381e-03
  4222 KSP Residual norm 1.020841898353e-02
  4223 KSP Residual norm 1.026862157750e-02
  4224 KSP Residual norm 9.442588629808e-03
  4225 KSP Residual norm 8.810335436026e-03
  4226 KSP Residual norm 8.722293627830e-03
  4227 KSP Residual norm 9.293531504949e-03
  4228 KSP Residual norm 9.822152110870e-03
  4229 KSP Residual norm 9.889328955851e-03
  4230 KSP Residual norm 1.070451223944e-02
  4231 KSP Residual norm 1.238185370013e-02
  4232 KSP Residual norm 1.378262595931e-02
  4233 KSP Residual norm 1.535885577032e-02
  4234 KSP Residual norm 1.790240334794e-02
  4235 KSP Residual norm 1.878800842548e-02
  4236 KSP Residual norm 1.710013687941e-02
  4237 KSP Residual norm 1.594068750413e-02
  4238 KSP Residual norm 1.655386570933e-02
  4239 KSP Residual norm 1.749197146271e-02
  4240 KSP Residual norm 1.952041724866e-02
  4241 KSP Residual norm 2.144960774538e-02
  4242 KSP Residual norm 2.157263928537e-02
  4243 KSP Residual norm 2.121099531783e-02
  4244 KSP Residual norm 2.009938524786e-02
  4245 KSP Residual norm 1.813194249856e-02
  4246 KSP Residual norm 1.801936846260e-02
  4247 KSP Residual norm 1.971323604789e-02
  4248 KSP Residual norm 1.983009954623e-02
  4249 KSP Residual norm 1.892251611939e-02
  4250 KSP Residual norm 1.889829507085e-02
  4251 KSP Residual norm 1.867747261733e-02
  4252 KSP Residual norm 1.792211688059e-02
  4253 KSP Residual norm 1.674841349386e-02
  4254 KSP Residual norm 1.585124779596e-02
  4255 KSP Residual norm 1.599284123319e-02
  4256 KSP Residual norm 1.576600388785e-02
  4257 KSP Residual norm 1.491558449498e-02
  4258 KSP Residual norm 1.443848922019e-02
  4259 KSP Residual norm 1.393131558042e-02
  4260 KSP Residual norm 1.243906245472e-02
  4261 KSP Residual norm 1.001290372198e-02
  4262 KSP Residual norm 8.511398912990e-03
  4263 KSP Residual norm 8.066213770473e-03
  4264 KSP Residual norm 8.227340391243e-03
  4265 KSP Residual norm 8.500394900963e-03
  4266 KSP Residual norm 9.014187567342e-03
  4267 KSP Residual norm 9.462171200366e-03
  4268 KSP Residual norm 9.889216057286e-03
  4269 KSP Residual norm 8.953715920124e-03
  4270 KSP Residual norm 7.793467920104e-03
  4271 KSP Residual norm 7.605625436814e-03
  4272 KSP Residual norm 8.237896802035e-03
  4273 KSP Residual norm 8.962565770242e-03
  4274 KSP Residual norm 9.700766071067e-03
  4275 KSP Residual norm 1.057777171600e-02
  4276 KSP Residual norm 1.163363620762e-02
  4277 KSP Residual norm 1.208131610918e-02
  4278 KSP Residual norm 1.201757014741e-02
  4279 KSP Residual norm 1.250389070910e-02
  4280 KSP Residual norm 1.272933054374e-02
  4281 KSP Residual norm 1.216689327075e-02
  4282 KSP Residual norm 1.193828250704e-02
  4283 KSP Residual norm 1.246689184820e-02
  4284 KSP Residual norm 1.312474726255e-02
  4285 KSP Residual norm 1.263541419629e-02
  4286 KSP Residual norm 1.172921671573e-02
  4287 KSP Residual norm 1.248007088743e-02
  4288 KSP Residual norm 1.407592826539e-02
  4289 KSP Residual norm 1.413448717270e-02
  4290 KSP Residual norm 1.357751255638e-02
  4291 KSP Residual norm 1.452968722840e-02
  4292 KSP Residual norm 1.584177590728e-02
  4293 KSP Residual norm 1.465715531433e-02
  4294 KSP Residual norm 1.333612525778e-02
  4295 KSP Residual norm 1.384375993868e-02
  4296 KSP Residual norm 1.386915622517e-02
  4297 KSP Residual norm 1.261838066562e-02
  4298 KSP Residual norm 1.175311334406e-02
  4299 KSP Residual norm 1.215236500646e-02
  4300 KSP Residual norm 1.255994524421e-02
  4301 KSP Residual norm 1.124460072384e-02
  4302 KSP Residual norm 9.343985657655e-03
  4303 KSP Residual norm 8.335202935980e-03
  4304 KSP Residual norm 8.285002658333e-03
  4305 KSP Residual norm 8.067162735187e-03
  4306 KSP Residual norm 7.348408965037e-03
  4307 KSP Residual norm 7.251382815039e-03
  4308 KSP Residual norm 7.724153703956e-03
  4309 KSP Residual norm 8.165541009594e-03
  4310 KSP Residual norm 8.161988205972e-03
  4311 KSP Residual norm 8.837952909069e-03
  4312 KSP Residual norm 9.636726196004e-03
  4313 KSP Residual norm 1.063023191083e-02
  4314 KSP Residual norm 1.091507928602e-02
  4315 KSP Residual norm 1.148995199751e-02
  4316 KSP Residual norm 1.256403293086e-02
  4317 KSP Residual norm 1.295631262711e-02
  4318 KSP Residual norm 1.236584792169e-02
  4319 KSP Residual norm 1.206236777988e-02
  4320 KSP Residual norm 1.263655891020e-02
  4321 KSP Residual norm 1.304027979574e-02
  4322 KSP Residual norm 1.334171959374e-02
  4323 KSP Residual norm 1.373594325953e-02
  4324 KSP Residual norm 1.329683296616e-02
  4325 KSP Residual norm 1.372400313264e-02
  4326 KSP Residual norm 1.516615141962e-02
  4327 KSP Residual norm 1.673829022112e-02
  4328 KSP Residual norm 1.889700559647e-02
  4329 KSP Residual norm 2.206670894884e-02
  4330 KSP Residual norm 2.430567542455e-02
  4331 KSP Residual norm 2.599881652863e-02
  4332 KSP Residual norm 2.939128723687e-02
  4333 KSP Residual norm 3.303847575911e-02
  4334 KSP Residual norm 3.261819884770e-02
  4335 KSP Residual norm 3.227755508146e-02
  4336 KSP Residual norm 3.516514611817e-02
  4337 KSP Residual norm 3.714248843602e-02
  4338 KSP Residual norm 3.687957608601e-02
  4339 KSP Residual norm 3.547144948854e-02
  4340 KSP Residual norm 3.538730000684e-02
  4341 KSP Residual norm 3.747209848009e-02
  4342 KSP Residual norm 4.033719367847e-02
  4343 KSP Residual norm 4.188069048659e-02
  4344 KSP Residual norm 4.027148882804e-02
  4345 KSP Residual norm 3.822077958758e-02
  4346 KSP Residual norm 3.653243560561e-02
  4347 KSP Residual norm 3.511659944011e-02
  4348 KSP Residual norm 3.206975127852e-02
  4349 KSP Residual norm 3.086545559654e-02
  4350 KSP Residual norm 3.127029182767e-02
  4351 KSP Residual norm 3.044384193361e-02
  4352 KSP Residual norm 2.846068960966e-02
  4353 KSP Residual norm 2.777564701555e-02
  4354 KSP Residual norm 2.569979107924e-02
  4355 KSP Residual norm 2.331487808072e-02
  4356 KSP Residual norm 2.253010482072e-02
  4357 KSP Residual norm 2.216228329378e-02
  4358 KSP Residual norm 2.043967396656e-02
  4359 KSP Residual norm 2.023111342518e-02
  4360 KSP Residual norm 2.187629590988e-02
  4361 KSP Residual norm 2.184819232415e-02
  4362 KSP Residual norm 1.822781641288e-02
  4363 KSP Residual norm 1.558867590643e-02
  4364 KSP Residual norm 1.575311061178e-02
  4365 KSP Residual norm 1.809224181664e-02
  4366 KSP Residual norm 2.130859643515e-02
  4367 KSP Residual norm 2.376103624940e-02
  4368 KSP Residual norm 2.502147297115e-02
  4369 KSP Residual norm 2.623400155944e-02
  4370 KSP Residual norm 2.739120320655e-02
  4371 KSP Residual norm 2.942773841794e-02
  4372 KSP Residual norm 3.200238216774e-02
  4373 KSP Residual norm 3.338058966096e-02
  4374 KSP Residual norm 3.313429368699e-02
  4375 KSP Residual norm 3.461235426972e-02
  4376 KSP Residual norm 3.811517365282e-02
  4377 KSP Residual norm 4.046572050369e-02
  4378 KSP Residual norm 4.134439617517e-02
  4379 KSP Residual norm 4.562675841668e-02
  4380 KSP Residual norm 5.212114202472e-02
  4381 KSP Residual norm 5.456690035163e-02
  4382 KSP Residual norm 5.225156155629e-02
  4383 KSP Residual norm 5.154045850229e-02
  4384 KSP Residual norm 5.583443611844e-02
  4385 KSP Residual norm 6.290982861831e-02
  4386 KSP Residual norm 6.450934490892e-02
  4387 KSP Residual norm 6.225312631384e-02
  4388 KSP Residual norm 6.204275106502e-02
  4389 KSP Residual norm 6.709831924677e-02
  4390 KSP Residual norm 7.303918792821e-02
  4391 KSP Residual norm 7.607221642580e-02
  4392 KSP Residual norm 7.785470924369e-02
  4393 KSP Residual norm 7.826606828851e-02
  4394 KSP Residual norm 7.967619320243e-02
  4395 KSP Residual norm 7.984488955252e-02
  4396 KSP Residual norm 7.594015846163e-02
  4397 KSP Residual norm 7.448891051246e-02
  4398 KSP Residual norm 7.395679493806e-02
  4399 KSP Residual norm 7.079387810796e-02
  4400 KSP Residual norm 6.814797450049e-02
  4401 KSP Residual norm 6.878511005462e-02
  4402 KSP Residual norm 6.821471316216e-02
  4403 KSP Residual norm 6.129683459287e-02
  4404 KSP Residual norm 5.513161157759e-02
  4405 KSP Residual norm 5.400916771858e-02
  4406 KSP Residual norm 5.713751137240e-02
  4407 KSP Residual norm 5.508343444529e-02
  4408 KSP Residual norm 4.958965746627e-02
  4409 KSP Residual norm 4.482339821928e-02
  4410 KSP Residual norm 4.083577232812e-02
  4411 KSP Residual norm 3.957885546103e-02
  4412 KSP Residual norm 3.967240796630e-02
  4413 KSP Residual norm 3.728369645287e-02
  4414 KSP Residual norm 3.226500874638e-02
  4415 KSP Residual norm 2.658508602181e-02
  4416 KSP Residual norm 2.243037461516e-02
  4417 KSP Residual norm 2.118619526210e-02
  4418 KSP Residual norm 2.038447161234e-02
  4419 KSP Residual norm 1.902572524747e-02
  4420 KSP Residual norm 1.756000590113e-02
  4421 KSP Residual norm 1.694984169246e-02
  4422 KSP Residual norm 1.623223727461e-02
  4423 KSP Residual norm 1.484945348301e-02
  4424 KSP Residual norm 1.425405980546e-02
  4425 KSP Residual norm 1.470653094556e-02
  4426 KSP Residual norm 1.458935889012e-02
  4427 KSP Residual norm 1.293215686369e-02
  4428 KSP Residual norm 1.158375529529e-02
  4429 KSP Residual norm 1.145287243611e-02
  4430 KSP Residual norm 1.096277925257e-02
  4431 KSP Residual norm 1.022076337818e-02
  4432 KSP Residual norm 1.032267774439e-02
  4433 KSP Residual norm 1.236991410043e-02
  4434 KSP Residual norm 1.503856744922e-02
  4435 KSP Residual norm 1.615662952662e-02
  4436 KSP Residual norm 1.770620500533e-02
  4437 KSP Residual norm 1.956199501807e-02
  4438 KSP Residual norm 2.015816510449e-02
  4439 KSP Residual norm 1.951267658699e-02
  4440 KSP Residual norm 1.843100893997e-02
  4441 KSP Residual norm 1.851266566866e-02
  4442 KSP Residual norm 1.892542891790e-02
  4443 KSP Residual norm 1.796682590042e-02
  4444 KSP Residual norm 1.722464550182e-02
  4445 KSP Residual norm 1.868191386322e-02
  4446 KSP Residual norm 2.066282950335e-02
  4447 KSP Residual norm 2.020060391601e-02
  4448 KSP Residual norm 2.000627501822e-02
  4449 KSP Residual norm 2.033319998842e-02
  4450 KSP Residual norm 1.959216035400e-02
  4451 KSP Residual norm 1.808017765673e-02
  4452 KSP Residual norm 1.698079625997e-02
  4453 KSP Residual norm 1.626785390426e-02
  4454 KSP Residual norm 1.616999484548e-02
  4455 KSP Residual norm 1.606097315872e-02
  4456 KSP Residual norm 1.642414344635e-02
  4457 KSP Residual norm 1.682823461466e-02
  4458 KSP Residual norm 1.633484799356e-02
  4459 KSP Residual norm 1.588795131649e-02
  4460 KSP Residual norm 1.584363336047e-02
  4461 KSP Residual norm 1.538679118579e-02
  4462 KSP Residual norm 1.429521352663e-02
  4463 KSP Residual norm 1.289393515798e-02
  4464 KSP Residual norm 1.245768605385e-02
  4465 KSP Residual norm 1.272402080298e-02
  4466 KSP Residual norm 1.275535831287e-02
  4467 KSP Residual norm 1.219396475175e-02
  4468 KSP Residual norm 1.163351295872e-02
  4469 KSP Residual norm 1.175752166397e-02
  4470 KSP Residual norm 1.093596782102e-02
  4471 KSP Residual norm 9.663729370247e-03
  4472 KSP Residual norm 9.081115435288e-03
  4473 KSP Residual norm 9.339063465569e-03
  4474 KSP Residual norm 9.591448392416e-03
  4475 KSP Residual norm 9.599471359057e-03
  4476 KSP Residual norm 9.703447291851e-03
  4477 KSP Residual norm 1.001450604403e-02
  4478 KSP Residual norm 1.077962278287e-02
  4479 KSP Residual norm 1.150009077025e-02
  4480 KSP Residual norm 1.229345486357e-02
  4481 KSP Residual norm 1.287235228033e-02
  4482 KSP Residual norm 1.265535392658e-02
  4483 KSP Residual norm 1.156308035077e-02
  4484 KSP Residual norm 1.114011596853e-02
  4485 KSP Residual norm 1.147153421137e-02
  4486 KSP Residual norm 1.112594017387e-02
  4487 KSP Residual norm 1.021418512486e-02
  4488 KSP Residual norm 9.792645690396e-03
  4489 KSP Residual norm 9.245683125612e-03
  4490 KSP Residual norm 9.257146877628e-03
  4491 KSP Residual norm 9.392165152820e-03
  4492 KSP Residual norm 9.524362593064e-03
  4493 KSP Residual norm 1.023149277578e-02
  4494 KSP Residual norm 1.212519050172e-02
  4495 KSP Residual norm 1.373353270897e-02
  4496 KSP Residual norm 1.355322660452e-02
  4497 KSP Residual norm 1.319365688975e-02
  4498 KSP Residual norm 1.320598856272e-02
  4499 KSP Residual norm 1.303314579576e-02
  4500 KSP Residual norm 1.280999738416e-02
  4501 KSP Residual norm 1.286543335859e-02
  4502 KSP Residual norm 1.245117101716e-02
  4503 KSP Residual norm 1.166004328005e-02
  4504 KSP Residual norm 1.149385895545e-02
  4505 KSP Residual norm 1.198758776558e-02
  4506 KSP Residual norm 1.207378491676e-02
  4507 KSP Residual norm 1.084156987528e-02
  4508 KSP Residual norm 9.254195116218e-03
  4509 KSP Residual norm 8.870781250756e-03
  4510 KSP Residual norm 9.020231346209e-03
  4511 KSP Residual norm 8.569913824718e-03
  4512 KSP Residual norm 7.785538142756e-03
  4513 KSP Residual norm 7.305871557667e-03
  4514 KSP Residual norm 7.284265054015e-03
  4515 KSP Residual norm 7.221062818228e-03
  4516 KSP Residual norm 7.140567405317e-03
  4517 KSP Residual norm 7.415245136982e-03
  4518 KSP Residual norm 7.786163532958e-03
  4519 KSP Residual norm 7.493589885061e-03
  4520 KSP Residual norm 6.923520903935e-03
  4521 KSP Residual norm 6.488676059735e-03
  4522 KSP Residual norm 6.314385517513e-03
  4523 KSP Residual norm 5.771334330971e-03
  4524 KSP Residual norm 5.137059606800e-03
  4525 KSP Residual norm 5.190613076976e-03
  4526 KSP Residual norm 5.485144484875e-03
  4527 KSP Residual norm 4.987731218788e-03
  4528 KSP Residual norm 4.275484929414e-03
  4529 KSP Residual norm 4.273648435680e-03
  4530 KSP Residual norm 4.681552936585e-03
  4531 KSP Residual norm 4.961890292442e-03
  4532 KSP Residual norm 5.024460531338e-03
  4533 KSP Residual norm 5.094514678711e-03
  4534 KSP Residual norm 5.511628985233e-03
  4535 KSP Residual norm 5.772947393146e-03
  4536 KSP Residual norm 5.494456452308e-03
  4537 KSP Residual norm 5.430000883516e-03
  4538 KSP Residual norm 6.029664715855e-03
  4539 KSP Residual norm 7.202474564781e-03
  4540 KSP Residual norm 8.255026164732e-03
  4541 KSP Residual norm 8.663638679693e-03
  4542 KSP Residual norm 9.156804572598e-03
  4543 KSP Residual norm 9.528409971005e-03
  4544 KSP Residual norm 9.004011761565e-03
  4545 KSP Residual norm 8.265189619488e-03
  4546 KSP Residual norm 8.511100581038e-03
  4547 KSP Residual norm 8.848333678829e-03
  4548 KSP Residual norm 8.469172509830e-03
  4549 KSP Residual norm 8.183452675852e-03
  4550 KSP Residual norm 8.418835744943e-03
  4551 KSP Residual norm 8.349988468643e-03
  4552 KSP Residual norm 8.110743967592e-03
  4553 KSP Residual norm 7.868795202645e-03
  4554 KSP Residual norm 7.533548722006e-03
  4555 KSP Residual norm 7.503047814224e-03
  4556 KSP Residual norm 7.198527592347e-03
  4557 KSP Residual norm 6.602610859014e-03
  4558 KSP Residual norm 5.928200665097e-03
  4559 KSP Residual norm 5.753114308744e-03
  4560 KSP Residual norm 5.989274351955e-03
  4561 KSP Residual norm 5.846791526975e-03
  4562 KSP Residual norm 5.511767992415e-03
  4563 KSP Residual norm 5.382926278810e-03
  4564 KSP Residual norm 5.448343355683e-03
  4565 KSP Residual norm 5.105030191056e-03
  4566 KSP Residual norm 4.723043641197e-03
  4567 KSP Residual norm 4.469811098350e-03
  4568 KSP Residual norm 4.334992698130e-03
  4569 KSP Residual norm 3.928590823078e-03
  4570 KSP Residual norm 3.646305926684e-03
  4571 KSP Residual norm 3.586355737516e-03
  4572 KSP Residual norm 3.472674737293e-03
  4573 KSP Residual norm 3.220610295982e-03
  4574 KSP Residual norm 3.010126817340e-03
  4575 KSP Residual norm 2.929265323296e-03
  4576 KSP Residual norm 2.862266090784e-03
  4577 KSP Residual norm 2.760268484709e-03
  4578 KSP Residual norm 2.698525320928e-03
  4579 KSP Residual norm 2.821719281981e-03
  4580 KSP Residual norm 3.247349282734e-03
  4581 KSP Residual norm 3.852340658180e-03
  4582 KSP Residual norm 4.180526509750e-03
  4583 KSP Residual norm 4.384976716934e-03
  4584 KSP Residual norm 4.354906564723e-03
  4585 KSP Residual norm 4.314425355341e-03
  4586 KSP Residual norm 4.232315007032e-03
  4587 KSP Residual norm 4.262720403959e-03
  4588 KSP Residual norm 4.539999824623e-03
  4589 KSP Residual norm 4.867119743444e-03
  4590 KSP Residual norm 5.381570729403e-03
  4591 KSP Residual norm 6.450614716025e-03
  4592 KSP Residual norm 7.690289509690e-03
  4593 KSP Residual norm 8.000161345832e-03
  4594 KSP Residual norm 7.819448166282e-03
  4595 KSP Residual norm 8.008696594533e-03
  4596 KSP Residual norm 7.867188305389e-03
  4597 KSP Residual norm 7.625887126866e-03
  4598 KSP Residual norm 8.289235801512e-03
  4599 KSP Residual norm 9.568200090172e-03
  4600 KSP Residual norm 9.906722861646e-03
  4601 KSP Residual norm 9.959100563549e-03
  4602 KSP Residual norm 1.002358188073e-02
  4603 KSP Residual norm 9.892212356164e-03
  4604 KSP Residual norm 1.007772310809e-02
  4605 KSP Residual norm 1.094742253074e-02
  4606 KSP Residual norm 1.204157128724e-02
  4607 KSP Residual norm 1.281646958731e-02
  4608 KSP Residual norm 1.215726535352e-02
  4609 KSP Residual norm 1.093467492496e-02
  4610 KSP Residual norm 1.069801877084e-02
  4611 KSP Residual norm 1.077395405875e-02
  4612 KSP Residual norm 1.075960710753e-02
  4613 KSP Residual norm 1.013651319526e-02
  4614 KSP Residual norm 9.710897936448e-03
  4615 KSP Residual norm 9.182699053929e-03
  4616 KSP Residual norm 8.293399133489e-03
  4617 KSP Residual norm 7.723147755421e-03
  4618 KSP Residual norm 7.991858294129e-03
  4619 KSP Residual norm 8.938344640381e-03
  4620 KSP Residual norm 8.654439004309e-03
  4621 KSP Residual norm 7.181141301408e-03
  4622 KSP Residual norm 6.357230595613e-03
  4623 KSP Residual norm 6.422117995639e-03
  4624 KSP Residual norm 6.483063368787e-03
  4625 KSP Residual norm 6.865442041828e-03
  4626 KSP Residual norm 7.410354335749e-03
  4627 KSP Residual norm 7.197010267209e-03
  4628 KSP Residual norm 6.824861693545e-03
  4629 KSP Residual norm 6.897666276806e-03
  4630 KSP Residual norm 7.506296015931e-03
  4631 KSP Residual norm 7.905088162358e-03
  4632 KSP Residual norm 7.862757023938e-03
  4633 KSP Residual norm 8.544522738893e-03
  4634 KSP Residual norm 9.360255424249e-03
  4635 KSP Residual norm 9.179099451290e-03
  4636 KSP Residual norm 8.286752076018e-03
  4637 KSP Residual norm 7.746846310036e-03
  4638 KSP Residual norm 7.534871355381e-03
  4639 KSP Residual norm 7.282719682088e-03
  4640 KSP Residual norm 7.553492203465e-03
  4641 KSP Residual norm 9.295155557681e-03
  4642 KSP Residual norm 1.171992700109e-02
  4643 KSP Residual norm 1.286637312900e-02
  4644 KSP Residual norm 1.271570269138e-02
  4645 KSP Residual norm 1.298333595908e-02
  4646 KSP Residual norm 1.347439695833e-02
  4647 KSP Residual norm 1.305011359740e-02
  4648 KSP Residual norm 1.306731634648e-02
  4649 KSP Residual norm 1.289962866463e-02
  4650 KSP Residual norm 1.268087597179e-02
  4651 KSP Residual norm 1.181452450529e-02
  4652 KSP Residual norm 1.162013706209e-02
  4653 KSP Residual norm 1.227906872619e-02
  4654 KSP Residual norm 1.325070303771e-02
  4655 KSP Residual norm 1.337762070145e-02
  4656 KSP Residual norm 1.315158500085e-02
  4657 KSP Residual norm 1.280614725143e-02
  4658 KSP Residual norm 1.279197585693e-02
  4659 KSP Residual norm 1.297450067139e-02
  4660 KSP Residual norm 1.288594217896e-02
  4661 KSP Residual norm 1.324791314990e-02
  4662 KSP Residual norm 1.332737571601e-02
  4663 KSP Residual norm 1.377272971364e-02
  4664 KSP Residual norm 1.470093687998e-02
  4665 KSP Residual norm 1.521424957280e-02
  4666 KSP Residual norm 1.426627944548e-02
  4667 KSP Residual norm 1.334366572410e-02
  4668 KSP Residual norm 1.269344829471e-02
  4669 KSP Residual norm 1.157214060039e-02
  4670 KSP Residual norm 1.089210980287e-02
  4671 KSP Residual norm 1.138383261846e-02
  4672 KSP Residual norm 1.239333059775e-02
  4673 KSP Residual norm 1.238727732204e-02
  4674 KSP Residual norm 1.115915590468e-02
  4675 KSP Residual norm 9.818285958862e-03
  4676 KSP Residual norm 8.565492420102e-03
  4677 KSP Residual norm 8.386541780752e-03
  4678 KSP Residual norm 9.516688861134e-03
  4679 KSP Residual norm 1.055328475215e-02
  4680 KSP Residual norm 1.103554801045e-02
  4681 KSP Residual norm 1.214862504166e-02
  4682 KSP Residual norm 1.334068555972e-02
  4683 KSP Residual norm 1.261599459542e-02
  4684 KSP Residual norm 1.226182142533e-02
  4685 KSP Residual norm 1.213480550847e-02
  4686 KSP Residual norm 1.128132550377e-02
  4687 KSP Residual norm 1.061403127221e-02
  4688 KSP Residual norm 1.063349230992e-02
  4689 KSP Residual norm 1.100848987199e-02
  4690 KSP Residual norm 1.182402965199e-02
  4691 KSP Residual norm 1.241531199741e-02
  4692 KSP Residual norm 1.178730273607e-02
  4693 KSP Residual norm 1.118470952312e-02
  4694 KSP Residual norm 1.088443059126e-02
  4695 KSP Residual norm 1.124772832917e-02
  4696 KSP Residual norm 1.227516148048e-02
  4697 KSP Residual norm 1.361596978640e-02
  4698 KSP Residual norm 1.481280206513e-02
  4699 KSP Residual norm 1.503265598500e-02
  4700 KSP Residual norm 1.405032574327e-02
  4701 KSP Residual norm 1.349902341937e-02
  4702 KSP Residual norm 1.431737388001e-02
  4703 KSP Residual norm 1.510908150518e-02
  4704 KSP Residual norm 1.493536282337e-02
  4705 KSP Residual norm 1.551422531292e-02
  4706 KSP Residual norm 1.734336603421e-02
  4707 KSP Residual norm 2.002501626185e-02
  4708 KSP Residual norm 2.437462491444e-02
  4709 KSP Residual norm 2.787437687602e-02
  4710 KSP Residual norm 2.969851828531e-02
  4711 KSP Residual norm 3.218934254707e-02
  4712 KSP Residual norm 3.334929843073e-02
  4713 KSP Residual norm 3.362831222543e-02
  4714 KSP Residual norm 3.716477564943e-02
  4715 KSP Residual norm 3.912634467630e-02
  4716 KSP Residual norm 3.385720793202e-02
  4717 KSP Residual norm 3.148142322739e-02
  4718 KSP Residual norm 3.614145952465e-02
  4719 KSP Residual norm 4.372417586063e-02
  4720 KSP Residual norm 4.681159484674e-02
  4721 KSP Residual norm 4.927379738417e-02
  4722 KSP Residual norm 5.332342467052e-02
  4723 KSP Residual norm 5.711397446185e-02
  4724 KSP Residual norm 5.630133139287e-02
  4725 KSP Residual norm 5.150282811884e-02
  4726 KSP Residual norm 4.848854259112e-02
  4727 KSP Residual norm 4.839766712392e-02
  4728 KSP Residual norm 4.434141718208e-02
  4729 KSP Residual norm 3.899315766144e-02
  4730 KSP Residual norm 3.714692830255e-02
  4731 KSP Residual norm 3.808062959376e-02
  4732 KSP Residual norm 4.016749477394e-02
  4733 KSP Residual norm 4.266357705396e-02
  4734 KSP Residual norm 4.339169673220e-02
  4735 KSP Residual norm 4.319612095025e-02
  4736 KSP Residual norm 4.215492209268e-02
  4737 KSP Residual norm 4.114426642373e-02
  4738 KSP Residual norm 3.930242419604e-02
  4739 KSP Residual norm 3.635129552145e-02
  4740 KSP Residual norm 3.390812645207e-02
  4741 KSP Residual norm 3.148750122687e-02
  4742 KSP Residual norm 2.999444339151e-02
  4743 KSP Residual norm 2.840582120708e-02
  4744 KSP Residual norm 2.762142759199e-02
  4745 KSP Residual norm 2.756049086040e-02
  4746 KSP Residual norm 2.528557249255e-02
  4747 KSP Residual norm 1.985618261662e-02
  4748 KSP Residual norm 1.704874133330e-02
  4749 KSP Residual norm 1.702916365609e-02
  4750 KSP Residual norm 1.760842219336e-02
  4751 KSP Residual norm 1.789682033856e-02
  4752 KSP Residual norm 1.713223185387e-02
  4753 KSP Residual norm 1.569896355416e-02
  4754 KSP Residual norm 1.436561731637e-02
  4755 KSP Residual norm 1.359599960161e-02
  4756 KSP Residual norm 1.300462886490e-02
  4757 KSP Residual norm 1.245207510571e-02
  4758 KSP Residual norm 1.202992508680e-02
  4759 KSP Residual norm 1.253906473485e-02
  4760 KSP Residual norm 1.370882739476e-02
  4761 KSP Residual norm 1.427135535699e-02
  4762 KSP Residual norm 1.239537244118e-02
  4763 KSP Residual norm 1.231282471630e-02
  4764 KSP Residual norm 1.422684655278e-02
  4765 KSP Residual norm 1.553672450769e-02
  4766 KSP Residual norm 1.642684069468e-02
  4767 KSP Residual norm 1.800600010207e-02
  4768 KSP Residual norm 1.919540710086e-02
  4769 KSP Residual norm 1.740662476578e-02
  4770 KSP Residual norm 1.477995780205e-02
  4771 KSP Residual norm 1.399626756825e-02
  4772 KSP Residual norm 1.511396159601e-02
  4773 KSP Residual norm 1.688380847740e-02
  4774 KSP Residual norm 1.916919031668e-02
  4775 KSP Residual norm 2.244179738950e-02
  4776 KSP Residual norm 2.656126852966e-02
  4777 KSP Residual norm 2.897145629632e-02
  4778 KSP Residual norm 2.940996576390e-02
  4779 KSP Residual norm 2.825507853185e-02
  4780 KSP Residual norm 2.845705802397e-02
  4781 KSP Residual norm 2.886157826641e-02
  4782 KSP Residual norm 2.701527474462e-02
  4783 KSP Residual norm 2.642677855064e-02
  4784 KSP Residual norm 2.901462934352e-02
  4785 KSP Residual norm 3.402873026474e-02
  4786 KSP Residual norm 3.853720495238e-02
  4787 KSP Residual norm 3.850369558944e-02
  4788 KSP Residual norm 3.196678228647e-02
  4789 KSP Residual norm 2.634458486650e-02
  4790 KSP Residual norm 2.410137337534e-02
  4791 KSP Residual norm 2.516763698972e-02
  4792 KSP Residual norm 2.772430350738e-02
  4793 KSP Residual norm 2.689201040742e-02
  4794 KSP Residual norm 2.436219820416e-02
  4795 KSP Residual norm 2.261589709462e-02
  4796 KSP Residual norm 2.277671648243e-02
  4797 KSP Residual norm 2.562926450131e-02
  4798 KSP Residual norm 3.042263996726e-02
  4799 KSP Residual norm 3.251990926068e-02
  4800 KSP Residual norm 3.085956605997e-02
  4801 KSP Residual norm 2.646868399630e-02
  4802 KSP Residual norm 2.386192171524e-02
  4803 KSP Residual norm 2.261458721256e-02
  4804 KSP Residual norm 2.062660091819e-02
  4805 KSP Residual norm 1.869516568364e-02
  4806 KSP Residual norm 1.760108480192e-02
  4807 KSP Residual norm 1.754443504284e-02
  4808 KSP Residual norm 1.796042878408e-02
  4809 KSP Residual norm 1.788378531861e-02
  4810 KSP Residual norm 1.530127019498e-02
  4811 KSP Residual norm 1.215105364291e-02
  4812 KSP Residual norm 1.084502145397e-02
  4813 KSP Residual norm 1.040249650107e-02
  4814 KSP Residual norm 9.958002318289e-03
  4815 KSP Residual norm 9.097127761621e-03
  4816 KSP Residual norm 8.910933318721e-03
  4817 KSP Residual norm 9.315951713342e-03
  4818 KSP Residual norm 9.950766199381e-03
  4819 KSP Residual norm 9.998912624615e-03
  4820 KSP Residual norm 9.455630025168e-03
  4821 KSP Residual norm 8.270036764891e-03
  4822 KSP Residual norm 7.859719892972e-03
  4823 KSP Residual norm 8.155333463607e-03
  4824 KSP Residual norm 8.272047439841e-03
  4825 KSP Residual norm 8.085623764538e-03
  4826 KSP Residual norm 7.547949352706e-03
  4827 KSP Residual norm 6.644991843527e-03
  4828 KSP Residual norm 5.462484033838e-03
  4829 KSP Residual norm 4.988850411074e-03
  4830 KSP Residual norm 5.102907622420e-03
  4831 KSP Residual norm 5.449278214594e-03
  4832 KSP Residual norm 5.720242187523e-03
  4833 KSP Residual norm 6.082833267210e-03
  4834 KSP Residual norm 5.929903839415e-03
  4835 KSP Residual norm 4.995252054354e-03
  4836 KSP Residual norm 4.491057907517e-03
  4837 KSP Residual norm 4.837108278648e-03
  4838 KSP Residual norm 6.055193862859e-03
  4839 KSP Residual norm 6.920685278467e-03
  4840 KSP Residual norm 7.231459824192e-03
  4841 KSP Residual norm 8.107222146470e-03
  4842 KSP Residual norm 9.308239239686e-03
  4843 KSP Residual norm 9.871463989251e-03
  4844 KSP Residual norm 1.002484830643e-02
  4845 KSP Residual norm 1.026884090543e-02
  4846 KSP Residual norm 1.037122151751e-02
  4847 KSP Residual norm 9.770518532811e-03
  4848 KSP Residual norm 9.286292396229e-03
  4849 KSP Residual norm 9.804405914052e-03
  4850 KSP Residual norm 1.042391520388e-02
  4851 KSP Residual norm 1.065719222685e-02
  4852 KSP Residual norm 1.111461650311e-02
  4853 KSP Residual norm 1.172781563300e-02
  4854 KSP Residual norm 1.265211396877e-02
  4855 KSP Residual norm 1.306519731946e-02
  4856 KSP Residual norm 1.287582554304e-02
  4857 KSP Residual norm 1.232046664975e-02
  4858 KSP Residual norm 1.194964402615e-02
  4859 KSP Residual norm 1.148504283675e-02
  4860 KSP Residual norm 1.070334349280e-02
  4861 KSP Residual norm 1.065549411294e-02
  4862 KSP Residual norm 1.068936895043e-02
  4863 KSP Residual norm 1.001884044768e-02
  4864 KSP Residual norm 8.632443770420e-03
  4865 KSP Residual norm 6.928568699760e-03
  4866 KSP Residual norm 5.646926488273e-03
  4867 KSP Residual norm 4.978013413895e-03
  4868 KSP Residual norm 4.959400548923e-03
  4869 KSP Residual norm 5.160469696160e-03
  4870 KSP Residual norm 4.971745575577e-03
  4871 KSP Residual norm 4.928852565150e-03
  4872 KSP Residual norm 5.549808642864e-03
  4873 KSP Residual norm 6.227012788396e-03
  4874 KSP Residual norm 5.897499897790e-03
  4875 KSP Residual norm 4.857923099915e-03
  4876 KSP Residual norm 4.121677201552e-03
  4877 KSP Residual norm 4.073826787684e-03
  4878 KSP Residual norm 4.450419215251e-03
  4879 KSP Residual norm 5.263443308304e-03
  4880 KSP Residual norm 6.394327906829e-03
  4881 KSP Residual norm 6.381629515620e-03
  4882 KSP Residual norm 5.412036775608e-03
  4883 KSP Residual norm 4.694628047564e-03
  4884 KSP Residual norm 4.657643136149e-03
  4885 KSP Residual norm 5.266059715368e-03
  4886 KSP Residual norm 6.271757358305e-03
  4887 KSP Residual norm 6.796039189475e-03
  4888 KSP Residual norm 6.379619582637e-03
  4889 KSP Residual norm 6.246866960254e-03
  4890 KSP Residual norm 6.591449778191e-03
  4891 KSP Residual norm 6.257950698969e-03
  4892 KSP Residual norm 6.083635246191e-03
  4893 KSP Residual norm 6.257576495005e-03
  4894 KSP Residual norm 5.832728742303e-03
  4895 KSP Residual norm 4.989826804701e-03
  4896 KSP Residual norm 4.185729388971e-03
  4897 KSP Residual norm 3.749863191958e-03
  4898 KSP Residual norm 4.055073930552e-03
  4899 KSP Residual norm 5.203687735174e-03
  4900 KSP Residual norm 7.289298072190e-03
  4901 KSP Residual norm 9.765633568643e-03
  4902 KSP Residual norm 1.080706924468e-02
  4903 KSP Residual norm 1.002662072119e-02
  4904 KSP Residual norm 8.988931475513e-03
  4905 KSP Residual norm 8.453173556504e-03
  4906 KSP Residual norm 9.320737266791e-03
  4907 KSP Residual norm 1.047363050911e-02
  4908 KSP Residual norm 1.076803557135e-02
  4909 KSP Residual norm 1.039213410634e-02
  4910 KSP Residual norm 9.155568292591e-03
  4911 KSP Residual norm 7.626370109756e-03
  4912 KSP Residual norm 6.557297619764e-03
  4913 KSP Residual norm 5.688947686707e-03
  4914 KSP Residual norm 5.307608385522e-03
  4915 KSP Residual norm 5.402110500513e-03
  4916 KSP Residual norm 5.758432233635e-03
  4917 KSP Residual norm 6.434845501485e-03
  4918 KSP Residual norm 7.111541646617e-03
  4919 KSP Residual norm 7.488030948720e-03
  4920 KSP Residual norm 6.705354653259e-03
  4921 KSP Residual norm 4.790018037051e-03
  4922 KSP Residual norm 3.362452309240e-03
  4923 KSP Residual norm 2.946761601425e-03
  4924 KSP Residual norm 3.390387075941e-03
  4925 KSP Residual norm 4.241381450779e-03
  4926 KSP Residual norm 5.270902723724e-03
  4927 KSP Residual norm 6.059402611143e-03
  4928 KSP Residual norm 5.337757436964e-03
  4929 KSP Residual norm 3.833830493822e-03
  4930 KSP Residual norm 2.747645358915e-03
  4931 KSP Residual norm 2.150688673279e-03
  4932 KSP Residual norm 1.914781624795e-03
  4933 KSP Residual norm 2.077408449524e-03
  4934 KSP Residual norm 2.632585692938e-03
  4935 KSP Residual norm 3.300334592556e-03
  4936 KSP Residual norm 3.179171046809e-03
  4937 KSP Residual norm 2.228488962779e-03
  4938 KSP Residual norm 1.514179510410e-03
  4939 KSP Residual norm 1.178432803597e-03
  4940 KSP Residual norm 1.092308238180e-03
  4941 KSP Residual norm 1.194188530520e-03
  4942 KSP Residual norm 1.459530746680e-03
  4943 KSP Residual norm 1.974357583893e-03
  4944 KSP Residual norm 2.456511377489e-03
  4945 KSP Residual norm 2.363429800002e-03
  4946 KSP Residual norm 1.747724840607e-03
  4947 KSP Residual norm 1.238167988902e-03
  4948 KSP Residual norm 9.347618818802e-04
  4949 KSP Residual norm 7.846093234227e-04
  4950 KSP Residual norm 7.969019913978e-04
  4951 KSP Residual norm 1.018032594440e-03
  4952 KSP Residual norm 1.435193586315e-03
  4953 KSP Residual norm 1.763016426696e-03
  4954 KSP Residual norm 1.879673692883e-03
  4955 KSP Residual norm 1.648663413833e-03
  4956 KSP Residual norm 1.115507322067e-03
  4957 KSP Residual norm 6.986300219611e-04
  4958 KSP Residual norm 5.518190849376e-04
  4959 KSP Residual norm 5.930730453886e-04
  4960 KSP Residual norm 7.720168068322e-04
  4961 KSP Residual norm 9.852553178381e-04
  4962 KSP Residual norm 1.136653159694e-03
  4963 KSP Residual norm 1.180083614422e-03
  4964 KSP Residual norm 1.160501693820e-03
  4965 KSP Residual norm 1.130479996735e-03
  4966 KSP Residual norm 1.193048737706e-03
  4967 KSP Residual norm 1.337340833074e-03
  4968 KSP Residual norm 1.407270243137e-03
  4969 KSP Residual norm 1.332676891727e-03
  4970 KSP Residual norm 1.301055778962e-03
  4971 KSP Residual norm 1.361806020942e-03
  4972 KSP Residual norm 1.541484114909e-03
  4973 KSP Residual norm 1.818375177566e-03
  4974 KSP Residual norm 2.031378473856e-03
  4975 KSP Residual norm 1.853145278024e-03
  4976 KSP Residual norm 1.524647736242e-03
  4977 KSP Residual norm 1.342015063503e-03
  4978 KSP Residual norm 1.405340684928e-03
  4979 KSP Residual norm 1.737159120482e-03
  4980 KSP Residual norm 2.422470991332e-03
  4981 KSP Residual norm 3.063469428059e-03
  4982 KSP Residual norm 3.263232649914e-03
  4983 KSP Residual norm 3.286345157348e-03
  4984 KSP Residual norm 3.329342521906e-03
  4985 KSP Residual norm 3.326627977020e-03
  4986 KSP Residual norm 3.371354442555e-03
  4987 KSP Residual norm 3.421220349236e-03
  4988 KSP Residual norm 3.287196782563e-03
  4989 KSP Residual norm 2.715823964119e-03
  4990 KSP Residual norm 2.214979943780e-03
  4991 KSP Residual norm 2.114034858605e-03
  4992 KSP Residual norm 2.269898558350e-03
  4993 KSP Residual norm 2.499906013821e-03
  4994 KSP Residual norm 2.912036386996e-03
  4995 KSP Residual norm 3.387337502437e-03
  4996 KSP Residual norm 3.235464518676e-03
  4997 KSP Residual norm 2.880509673571e-03
  4998 KSP Residual norm 2.816461095183e-03
  4999 KSP Residual norm 3.022250534837e-03
  5000 KSP Residual norm 3.291150101357e-03
  5001 KSP Residual norm 3.389669223662e-03
  5002 KSP Residual norm 2.817208090928e-03
  5003 KSP Residual norm 1.978803521597e-03
  5004 KSP Residual norm 1.422343727108e-03
  5005 KSP Residual norm 1.144685926365e-03
  5006 KSP Residual norm 1.234667529448e-03
  5007 KSP Residual norm 1.819585014719e-03
  5008 KSP Residual norm 2.750600411515e-03
  5009 KSP Residual norm 3.165378437491e-03
  5010 KSP Residual norm 2.677495677307e-03
  5011 KSP Residual norm 2.163050280073e-03
  5012 KSP Residual norm 1.874207928539e-03
  5013 KSP Residual norm 1.535687724493e-03
  5014 KSP Residual norm 1.313885632045e-03
  5015 KSP Residual norm 1.408869915294e-03
  5016 KSP Residual norm 1.588029743271e-03
  5017 KSP Residual norm 1.588344572732e-03
  5018 KSP Residual norm 1.669796293906e-03
  5019 KSP Residual norm 1.944841238776e-03
  5020 KSP Residual norm 2.045359968243e-03
  5021 KSP Residual norm 1.656331145003e-03
  5022 KSP Residual norm 1.279755905280e-03
  5023 KSP Residual norm 1.079348218324e-03
  5024 KSP Residual norm 1.096175544553e-03
  5025 KSP Residual norm 1.288021654318e-03
  5026 KSP Residual norm 1.594553342392e-03
  5027 KSP Residual norm 1.888061940387e-03
  5028 KSP Residual norm 2.171248386832e-03
  5029 KSP Residual norm 2.454370553550e-03
  5030 KSP Residual norm 2.816579734572e-03
  5031 KSP Residual norm 3.084512066111e-03
  5032 KSP Residual norm 3.027622341693e-03
  5033 KSP Residual norm 2.978665746558e-03
  5034 KSP Residual norm 2.690866475698e-03
  5035 KSP Residual norm 2.110124306155e-03
  5036 KSP Residual norm 1.674828335178e-03
  5037 KSP Residual norm 1.566565908324e-03
  5038 KSP Residual norm 1.747937220098e-03
  5039 KSP Residual norm 2.248892010782e-03
  5040 KSP Residual norm 2.857705442715e-03
  5041 KSP Residual norm 3.085106545901e-03
  5042 KSP Residual norm 3.051309956733e-03
  5043 KSP Residual norm 3.033356990345e-03
  5044 KSP Residual norm 3.192142597189e-03
  5045 KSP Residual norm 3.375624152832e-03
  5046 KSP Residual norm 3.336374499905e-03
  5047 KSP Residual norm 3.050958470633e-03
  5048 KSP Residual norm 2.756607565141e-03
  5049 KSP Residual norm 2.515508106626e-03
  5050 KSP Residual norm 2.489483992298e-03
  5051 KSP Residual norm 2.849603288255e-03
  5052 KSP Residual norm 3.546447799366e-03
  5053 KSP Residual norm 4.151401419809e-03
  5054 KSP Residual norm 4.446572591243e-03
  5055 KSP Residual norm 4.856234194189e-03
  5056 KSP Residual norm 5.256038219276e-03
  5057 KSP Residual norm 5.845514047672e-03
  5058 KSP Residual norm 6.592947114170e-03
  5059 KSP Residual norm 6.076006162852e-03
  5060 KSP Residual norm 5.404819106328e-03
  5061 KSP Residual norm 5.269282759973e-03
  5062 KSP Residual norm 5.001933187235e-03
  5063 KSP Residual norm 4.622849954769e-03
  5064 KSP Residual norm 4.823257629216e-03
  5065 KSP Residual norm 5.573911968753e-03
  5066 KSP Residual norm 6.516973487883e-03
  5067 KSP Residual norm 7.820591843174e-03
  5068 KSP Residual norm 8.378533585387e-03
  5069 KSP Residual norm 7.809567523651e-03
  5070 KSP Residual norm 6.823901788272e-03
  5071 KSP Residual norm 6.260748730520e-03
  5072 KSP Residual norm 5.898450566380e-03
  5073 KSP Residual norm 5.687804058418e-03
  5074 KSP Residual norm 5.262967099664e-03
  5075 KSP Residual norm 4.844076719264e-03
  5076 KSP Residual norm 4.651855957704e-03
  5077 KSP Residual norm 4.479522372641e-03
  5078 KSP Residual norm 4.820802430663e-03
  5079 KSP Residual norm 5.157007390652e-03
  5080 KSP Residual norm 5.347094848023e-03
  5081 KSP Residual norm 5.480147694964e-03
  5082 KSP Residual norm 6.197823277763e-03
  5083 KSP Residual norm 6.953930398315e-03
  5084 KSP Residual norm 7.494722045878e-03
  5085 KSP Residual norm 7.122049835994e-03
  5086 KSP Residual norm 5.250897891001e-03
  5087 KSP Residual norm 3.733753304278e-03
  5088 KSP Residual norm 3.000130609437e-03
  5089 KSP Residual norm 2.730444865874e-03
  5090 KSP Residual norm 2.806777592697e-03
  5091 KSP Residual norm 3.534693244892e-03
  5092 KSP Residual norm 4.742855747346e-03
  5093 KSP Residual norm 5.618857680117e-03
  5094 KSP Residual norm 5.727560122837e-03
  5095 KSP Residual norm 5.665085254908e-03
  5096 KSP Residual norm 5.572251597088e-03
  5097 KSP Residual norm 5.392866905234e-03
  5098 KSP Residual norm 4.797175112142e-03
  5099 KSP Residual norm 4.115744724931e-03
  5100 KSP Residual norm 3.808753573586e-03
  5101 KSP Residual norm 3.911638581068e-03
  5102 KSP Residual norm 3.978371081644e-03
  5103 KSP Residual norm 4.160433694042e-03
  5104 KSP Residual norm 4.717609959807e-03
  5105 KSP Residual norm 5.529647619336e-03
  5106 KSP Residual norm 6.057214307890e-03
  5107 KSP Residual norm 6.661957144616e-03
  5108 KSP Residual norm 7.161526349291e-03
  5109 KSP Residual norm 7.570901013840e-03
  5110 KSP Residual norm 7.707589057577e-03
  5111 KSP Residual norm 7.683271579517e-03
  5112 KSP Residual norm 7.846003147522e-03
  5113 KSP Residual norm 8.308064350657e-03
  5114 KSP Residual norm 8.337705614986e-03
  5115 KSP Residual norm 7.612423043577e-03
  5116 KSP Residual norm 7.332948570313e-03
  5117 KSP Residual norm 7.268416620020e-03
  5118 KSP Residual norm 7.415675864539e-03
  5119 KSP Residual norm 8.621764085841e-03
  5120 KSP Residual norm 1.058892453647e-02
  5121 KSP Residual norm 1.178819456823e-02
  5122 KSP Residual norm 1.225711412480e-02
  5123 KSP Residual norm 1.273167378411e-02
  5124 KSP Residual norm 1.301503302738e-02
  5125 KSP Residual norm 1.221850412513e-02
  5126 KSP Residual norm 1.124446749456e-02
  5127 KSP Residual norm 1.023472666998e-02
  5128 KSP Residual norm 9.532791955133e-03
  5129 KSP Residual norm 9.174097741455e-03
  5130 KSP Residual norm 9.694037708432e-03
  5131 KSP Residual norm 1.055795212558e-02
  5132 KSP Residual norm 9.425549028743e-03
  5133 KSP Residual norm 8.619620720571e-03
  5134 KSP Residual norm 1.002930961693e-02
  5135 KSP Residual norm 1.278178777314e-02
  5136 KSP Residual norm 1.347910571283e-02
  5137 KSP Residual norm 1.170006737430e-02
  5138 KSP Residual norm 9.876322953708e-03
  5139 KSP Residual norm 9.995696068193e-03
  5140 KSP Residual norm 1.197374794613e-02
  5141 KSP Residual norm 1.180659063410e-02
  5142 KSP Residual norm 8.960345861898e-03
  5143 KSP Residual norm 6.670112656017e-03
  5144 KSP Residual norm 5.325361947471e-03
  5145 KSP Residual norm 4.736550206560e-03
  5146 KSP Residual norm 5.072528972719e-03
  5147 KSP Residual norm 5.757265321682e-03
  5148 KSP Residual norm 5.833410810155e-03
  5149 KSP Residual norm 5.502048773279e-03
  5150 KSP Residual norm 5.020828627945e-03
  5151 KSP Residual norm 4.879906807749e-03
  5152 KSP Residual norm 5.473968702837e-03
  5153 KSP Residual norm 6.806856885144e-03
  5154 KSP Residual norm 8.018509552909e-03
  5155 KSP Residual norm 8.304671294585e-03
  5156 KSP Residual norm 8.427119056107e-03
  5157 KSP Residual norm 9.083636959881e-03
  5158 KSP Residual norm 1.031694186913e-02
  5159 KSP Residual norm 1.026507915940e-02
  5160 KSP Residual norm 9.187457077705e-03
  5161 KSP Residual norm 8.958463131120e-03
  5162 KSP Residual norm 9.005353946366e-03
  5163 KSP Residual norm 7.998277276331e-03
  5164 KSP Residual norm 7.076361672102e-03
  5165 KSP Residual norm 6.012448325201e-03
  5166 KSP Residual norm 4.614796846782e-03
  5167 KSP Residual norm 4.092226890317e-03
  5168 KSP Residual norm 4.552101862680e-03
  5169 KSP Residual norm 5.165059680433e-03
  5170 KSP Residual norm 5.132031450739e-03
  5171 KSP Residual norm 5.228096972927e-03
  5172 KSP Residual norm 6.330401772911e-03
  5173 KSP Residual norm 9.020369001129e-03
  5174 KSP Residual norm 1.191885618250e-02
  5175 KSP Residual norm 1.155960131928e-02
  5176 KSP Residual norm 9.926623465561e-03
  5177 KSP Residual norm 9.926733624389e-03
  5178 KSP Residual norm 1.195694135051e-02
  5179 KSP Residual norm 1.338259629072e-02
  5180 KSP Residual norm 1.389102283443e-02
  5181 KSP Residual norm 1.267728231799e-02
  5182 KSP Residual norm 1.165462408308e-02
  5183 KSP Residual norm 1.221733246193e-02
  5184 KSP Residual norm 1.256365927293e-02
  5185 KSP Residual norm 1.147165485488e-02
  5186 KSP Residual norm 9.948083793328e-03
  5187 KSP Residual norm 8.952059063007e-03
  5188 KSP Residual norm 9.548145245048e-03
  5189 KSP Residual norm 1.198090008198e-02
  5190 KSP Residual norm 1.421032375516e-02
  5191 KSP Residual norm 1.455043651700e-02
  5192 KSP Residual norm 1.597607475038e-02
  5193 KSP Residual norm 1.731138927366e-02
  5194 KSP Residual norm 1.869657793075e-02
  5195 KSP Residual norm 2.056260700247e-02
  5196 KSP Residual norm 1.989650020402e-02
  5197 KSP Residual norm 1.644841553315e-02
  5198 KSP Residual norm 1.402123831286e-02
  5199 KSP Residual norm 1.393307731848e-02
  5200 KSP Residual norm 1.499889495236e-02
  5201 KSP Residual norm 1.512649830288e-02
  5202 KSP Residual norm 1.452302777099e-02
  5203 KSP Residual norm 1.400754830125e-02
  5204 KSP Residual norm 1.454268965046e-02
  5205 KSP Residual norm 1.605382740223e-02
  5206 KSP Residual norm 1.747113205190e-02
  5207 KSP Residual norm 1.826558199165e-02
  5208 KSP Residual norm 1.766043281495e-02
  5209 KSP Residual norm 1.624484941571e-02
  5210 KSP Residual norm 1.573189280158e-02
  5211 KSP Residual norm 1.590837291997e-02
  5212 KSP Residual norm 1.489017780109e-02
  5213 KSP Residual norm 1.299770002216e-02
  5214 KSP Residual norm 1.147567719050e-02
  5215 KSP Residual norm 1.042029489694e-02
  5216 KSP Residual norm 1.003509276822e-02
  5217 KSP Residual norm 9.768968368273e-03
  5218 KSP Residual norm 8.752247826823e-03
  5219 KSP Residual norm 7.601636512821e-03
  5220 KSP Residual norm 8.168160771245e-03
  5221 KSP Residual norm 1.080881386017e-02
  5222 KSP Residual norm 1.341820622108e-02
  5223 KSP Residual norm 1.304121223602e-02
  5224 KSP Residual norm 1.110327025048e-02
  5225 KSP Residual norm 9.743934920607e-03
  5226 KSP Residual norm 9.277908333168e-03
  5227 KSP Residual norm 8.558564414890e-03
  5228 KSP Residual norm 7.211650134836e-03
  5229 KSP Residual norm 5.988205291223e-03
  5230 KSP Residual norm 5.703158478056e-03
  5231 KSP Residual norm 5.551940465001e-03
  5232 KSP Residual norm 5.386992639716e-03
  5233 KSP Residual norm 5.019571930758e-03
  5234 KSP Residual norm 4.476459677889e-03
  5235 KSP Residual norm 3.781661865522e-03
  5236 KSP Residual norm 3.701038045348e-03
  5237 KSP Residual norm 4.429787412057e-03
  5238 KSP Residual norm 5.345586233516e-03
  5239 KSP Residual norm 5.605324989227e-03
  5240 KSP Residual norm 5.575771676464e-03
  5241 KSP Residual norm 5.831218616475e-03
  5242 KSP Residual norm 6.658094702125e-03
  5243 KSP Residual norm 7.821203358408e-03
  5244 KSP Residual norm 7.423070869094e-03
  5245 KSP Residual norm 5.436615846481e-03
  5246 KSP Residual norm 3.950016393308e-03
  5247 KSP Residual norm 3.315810664097e-03
  5248 KSP Residual norm 3.325728496516e-03
  5249 KSP Residual norm 3.126640604489e-03
  5250 KSP Residual norm 2.558728088265e-03
  5251 KSP Residual norm 2.262427999336e-03
  5252 KSP Residual norm 2.406402413605e-03
  5253 KSP Residual norm 2.997248114239e-03
  5254 KSP Residual norm 3.787470875264e-03
  5255 KSP Residual norm 4.270036535989e-03
  5256 KSP Residual norm 4.631049225251e-03
  5257 KSP Residual norm 5.218134405630e-03
  5258 KSP Residual norm 6.607068903890e-03
  5259 KSP Residual norm 7.960533351606e-03
  5260 KSP Residual norm 7.166807492011e-03
  5261 KSP Residual norm 5.997626686697e-03
  5262 KSP Residual norm 6.178378670894e-03
  5263 KSP Residual norm 7.438134165446e-03
  5264 KSP Residual norm 6.984649077495e-03
  5265 KSP Residual norm 5.136207872633e-03
  5266 KSP Residual norm 4.644114249803e-03
  5267 KSP Residual norm 5.507585266405e-03
  5268 KSP Residual norm 6.560606415636e-03
  5269 KSP Residual norm 6.299041827985e-03
  5270 KSP Residual norm 5.947565289050e-03
  5271 KSP Residual norm 6.052466081758e-03
  5272 KSP Residual norm 6.633452172370e-03
  5273 KSP Residual norm 7.343726482563e-03
  5274 KSP Residual norm 7.706364749192e-03
  5275 KSP Residual norm 7.498006751567e-03
  5276 KSP Residual norm 7.582417555133e-03
  5277 KSP Residual norm 8.575346699186e-03
  5278 KSP Residual norm 8.913395547110e-03
  5279 KSP Residual norm 7.819152327133e-03
  5280 KSP Residual norm 6.835399530654e-03
  5281 KSP Residual norm 6.616375226819e-03
  5282 KSP Residual norm 6.942442179146e-03
  5283 KSP Residual norm 6.701451226587e-03
  5284 KSP Residual norm 6.135577499091e-03
  5285 KSP Residual norm 5.841247466051e-03
  5286 KSP Residual norm 5.811567014070e-03
  5287 KSP Residual norm 6.153801526829e-03
  5288 KSP Residual norm 6.370917959567e-03
  5289 KSP Residual norm 5.974126718975e-03
  5290 KSP Residual norm 5.157197549608e-03
  5291 KSP Residual norm 4.506417439043e-03
  5292 KSP Residual norm 4.226676984224e-03
  5293 KSP Residual norm 4.476507758499e-03
  5294 KSP Residual norm 5.282982936160e-03
  5295 KSP Residual norm 5.736576221504e-03
  5296 KSP Residual norm 4.864534830334e-03
  5297 KSP Residual norm 4.218531524174e-03
  5298 KSP Residual norm 4.315266172564e-03
  5299 KSP Residual norm 4.359964728158e-03
  5300 KSP Residual norm 4.042754202727e-03
  5301 KSP Residual norm 3.587051339079e-03
  5302 KSP Residual norm 3.354907241891e-03
  5303 KSP Residual norm 3.598450594975e-03
  5304 KSP Residual norm 3.825154915405e-03
  5305 KSP Residual norm 3.696607710441e-03
  5306 KSP Residual norm 3.609045564149e-03
  5307 KSP Residual norm 3.785466801854e-03
  5308 KSP Residual norm 4.186759102805e-03
  5309 KSP Residual norm 4.485623763844e-03
  5310 KSP Residual norm 4.194450565602e-03
  5311 KSP Residual norm 3.792055641733e-03
  5312 KSP Residual norm 3.922425745534e-03
  5313 KSP Residual norm 4.447457413111e-03
  5314 KSP Residual norm 4.232897818345e-03
  5315 KSP Residual norm 3.658716643868e-03
  5316 KSP Residual norm 3.287345091224e-03
  5317 KSP Residual norm 2.969861678067e-03
  5318 KSP Residual norm 2.548695342826e-03
  5319 KSP Residual norm 2.186322831664e-03
  5320 KSP Residual norm 1.865956342423e-03
  5321 KSP Residual norm 1.639912204247e-03
  5322 KSP Residual norm 1.612372144684e-03
  5323 KSP Residual norm 1.548680511225e-03
  5324 KSP Residual norm 1.463191038880e-03
  5325 KSP Residual norm 1.485551702543e-03
  5326 KSP Residual norm 1.578625931248e-03
  5327 KSP Residual norm 1.678239612159e-03
  5328 KSP Residual norm 1.817246820426e-03
  5329 KSP Residual norm 2.093034605559e-03
  5330 KSP Residual norm 2.379539180216e-03
  5331 KSP Residual norm 2.281340139175e-03
  5332 KSP Residual norm 2.113771530724e-03
  5333 KSP Residual norm 1.953018997233e-03
  5334 KSP Residual norm 1.787146918122e-03
  5335 KSP Residual norm 1.673173151466e-03
  5336 KSP Residual norm 1.673879455218e-03
  5337 KSP Residual norm 1.610088340176e-03
  5338 KSP Residual norm 1.375386601546e-03
  5339 KSP Residual norm 1.204256628393e-03
  5340 KSP Residual norm 1.172068834485e-03
  5341 KSP Residual norm 1.167299749369e-03
  5342 KSP Residual norm 1.084987721925e-03
  5343 KSP Residual norm 1.048608500019e-03
  5344 KSP Residual norm 1.182894398543e-03
  5345 KSP Residual norm 1.453015709397e-03
  5346 KSP Residual norm 1.767447466914e-03
  5347 KSP Residual norm 2.047673873151e-03
  5348 KSP Residual norm 2.165888451651e-03
  5349 KSP Residual norm 2.345026100221e-03
  5350 KSP Residual norm 2.699483159671e-03
  5351 KSP Residual norm 3.029545334055e-03
  5352 KSP Residual norm 3.098176374562e-03
  5353 KSP Residual norm 2.863551593303e-03
  5354 KSP Residual norm 2.665654364024e-03
  5355 KSP Residual norm 2.591283133431e-03
  5356 KSP Residual norm 2.494178966467e-03
  5357 KSP Residual norm 2.197196779720e-03
  5358 KSP Residual norm 1.911928992764e-03
  5359 KSP Residual norm 1.870311203534e-03
  5360 KSP Residual norm 1.849589844497e-03
  5361 KSP Residual norm 1.742174612829e-03
  5362 KSP Residual norm 1.629652677123e-03
  5363 KSP Residual norm 1.711177703496e-03
  5364 KSP Residual norm 1.912003863409e-03
  5365 KSP Residual norm 1.960739899509e-03
  5366 KSP Residual norm 1.901441585670e-03
  5367 KSP Residual norm 1.925905953983e-03
  5368 KSP Residual norm 1.986371216477e-03
  5369 KSP Residual norm 1.957363818653e-03
  5370 KSP Residual norm 2.053645174170e-03
  5371 KSP Residual norm 2.330000687696e-03
  5372 KSP Residual norm 2.490599777998e-03
  5373 KSP Residual norm 2.764168582941e-03
  5374 KSP Residual norm 3.333090739671e-03
  5375 KSP Residual norm 3.299297499929e-03
  5376 KSP Residual norm 2.943633959223e-03
  5377 KSP Residual norm 3.020934084618e-03
  5378 KSP Residual norm 3.559496348939e-03
  5379 KSP Residual norm 3.750851249493e-03
  5380 KSP Residual norm 3.057948346840e-03
  5381 KSP Residual norm 2.483756421269e-03
  5382 KSP Residual norm 2.313690894628e-03
  5383 KSP Residual norm 2.284330872334e-03
  5384 KSP Residual norm 2.067498440454e-03
  5385 KSP Residual norm 1.900828101659e-03
  5386 KSP Residual norm 1.896266700462e-03
  5387 KSP Residual norm 2.053747040898e-03
  5388 KSP Residual norm 2.344842302619e-03
  5389 KSP Residual norm 2.448419012429e-03
  5390 KSP Residual norm 2.216759496229e-03
  5391 KSP Residual norm 2.143984695538e-03
  5392 KSP Residual norm 2.267819864387e-03
  5393 KSP Residual norm 2.100480202825e-03
  5394 KSP Residual norm 1.758421892352e-03
  5395 KSP Residual norm 1.624170996767e-03
  5396 KSP Residual norm 1.623729138292e-03
  5397 KSP Residual norm 1.715904587707e-03
  5398 KSP Residual norm 1.628547705282e-03
  5399 KSP Residual norm 1.369979652687e-03
  5400 KSP Residual norm 1.197552314130e-03
  5401 KSP Residual norm 1.235218715062e-03
  5402 KSP Residual norm 1.251795156399e-03
  5403 KSP Residual norm 1.055398984970e-03
  5404 KSP Residual norm 8.693521818439e-04
  5405 KSP Residual norm 7.765063210340e-04
  5406 KSP Residual norm 8.061923680833e-04
  5407 KSP Residual norm 8.149611894986e-04
  5408 KSP Residual norm 7.216353075345e-04
  5409 KSP Residual norm 6.957923218712e-04
  5410 KSP Residual norm 7.951162909202e-04
  5411 KSP Residual norm 8.469759210108e-04
  5412 KSP Residual norm 8.136838889844e-04
  5413 KSP Residual norm 8.467882306835e-04
  5414 KSP Residual norm 9.013272552227e-04
  5415 KSP Residual norm 9.403081361950e-04
  5416 KSP Residual norm 9.849734302925e-04
  5417 KSP Residual norm 9.031059445749e-04
  5418 KSP Residual norm 7.554833038730e-04
  5419 KSP Residual norm 6.641867816478e-04
  5420 KSP Residual norm 5.882686720478e-04
  5421 KSP Residual norm 5.146939792882e-04
  5422 KSP Residual norm 4.958902421118e-04
  5423 KSP Residual norm 4.933509916772e-04
  5424 KSP Residual norm 4.882247397423e-04
  5425 KSP Residual norm 4.747048969735e-04
  5426 KSP Residual norm 4.784796763508e-04
  5427 KSP Residual norm 4.999307350715e-04
  5428 KSP Residual norm 5.243624785548e-04
  5429 KSP Residual norm 5.483302830145e-04
  5430 KSP Residual norm 6.131506349290e-04
  5431 KSP Residual norm 6.352148222316e-04
  5432 KSP Residual norm 5.757184833653e-04
  5433 KSP Residual norm 5.968829149853e-04
  5434 KSP Residual norm 6.817250660139e-04
  5435 KSP Residual norm 6.874654095218e-04
  5436 KSP Residual norm 6.585349986495e-04
  5437 KSP Residual norm 6.565726686462e-04
  5438 KSP Residual norm 6.764294138953e-04
  5439 KSP Residual norm 7.278807566020e-04
  5440 KSP Residual norm 8.085586887535e-04
  5441 KSP Residual norm 7.630429361587e-04
  5442 KSP Residual norm 6.206752290149e-04
  5443 KSP Residual norm 5.819511475547e-04
  5444 KSP Residual norm 6.465257952358e-04
  5445 KSP Residual norm 6.454210708622e-04
  5446 KSP Residual norm 5.561588402338e-04
  5447 KSP Residual norm 4.881485648730e-04
  5448 KSP Residual norm 5.141944068032e-04
  5449 KSP Residual norm 5.888141774876e-04
  5450 KSP Residual norm 5.735795430384e-04
  5451 KSP Residual norm 5.252693912947e-04
  5452 KSP Residual norm 5.472216968971e-04
  5453 KSP Residual norm 6.429222011012e-04
  5454 KSP Residual norm 7.053246569235e-04
  5455 KSP Residual norm 7.429112339675e-04
  5456 KSP Residual norm 7.693895427094e-04
  5457 KSP Residual norm 8.491570316152e-04
  5458 KSP Residual norm 9.660910274535e-04
  5459 KSP Residual norm 9.911439508787e-04
  5460 KSP Residual norm 9.367592708760e-04
  5461 KSP Residual norm 9.912179534390e-04
  5462 KSP Residual norm 1.168263072062e-03
  5463 KSP Residual norm 1.256266202974e-03
  5464 KSP Residual norm 1.171014256605e-03
  5465 KSP Residual norm 1.132362106124e-03
  5466 KSP Residual norm 1.166902839267e-03
  5467 KSP Residual norm 1.182462127042e-03
  5468 KSP Residual norm 1.070222512522e-03
  5469 KSP Residual norm 9.206785642296e-04
  5470 KSP Residual norm 8.413939349152e-04
  5471 KSP Residual norm 8.537473414134e-04
  5472 KSP Residual norm 9.202916667921e-04
  5473 KSP Residual norm 8.716198936471e-04
  5474 KSP Residual norm 8.713846114770e-04
  5475 KSP Residual norm 9.529167027262e-04
  5476 KSP Residual norm 9.668177988798e-04
  5477 KSP Residual norm 8.555935437774e-04
  5478 KSP Residual norm 7.819021412871e-04
  5479 KSP Residual norm 8.279334404567e-04
  5480 KSP Residual norm 8.632508766114e-04
  5481 KSP Residual norm 7.624863590967e-04
  5482 KSP Residual norm 7.082102483952e-04
  5483 KSP Residual norm 6.948532033834e-04
  5484 KSP Residual norm 6.398521462701e-04
  5485 KSP Residual norm 5.842358819130e-04
  5486 KSP Residual norm 5.534344985165e-04
  5487 KSP Residual norm 5.157037674218e-04
  5488 KSP Residual norm 5.159158713989e-04
  5489 KSP Residual norm 5.823786140097e-04
  5490 KSP Residual norm 5.981525457366e-04
  5491 KSP Residual norm 5.570890062575e-04
  5492 KSP Residual norm 5.450117473878e-04
  5493 KSP Residual norm 5.295188269093e-04
  5494 KSP Residual norm 4.938334956021e-04
  5495 KSP Residual norm 4.886598351553e-04
  5496 KSP Residual norm 5.163247130083e-04
  5497 KSP Residual norm 4.899156276800e-04
  5498 KSP Residual norm 4.760163279581e-04
  5499 KSP Residual norm 5.104929275361e-04
  5500 KSP Residual norm 5.518958695104e-04
  5501 KSP Residual norm 5.204581735775e-04
  5502 KSP Residual norm 4.702311113589e-04
  5503 KSP Residual norm 4.631875978934e-04
  5504 KSP Residual norm 5.069550315656e-04
  5505 KSP Residual norm 5.428603301611e-04
  5506 KSP Residual norm 5.157784070885e-04
  5507 KSP Residual norm 4.556783214684e-04
  5508 KSP Residual norm 4.245485377656e-04
  5509 KSP Residual norm 4.268921172213e-04
  5510 KSP Residual norm 4.283720223248e-04
  5511 KSP Residual norm 3.867115304653e-04
  5512 KSP Residual norm 3.352428401407e-04
  5513 KSP Residual norm 3.174533887163e-04
  5514 KSP Residual norm 2.873558066900e-04
  5515 KSP Residual norm 2.543423152381e-04
  5516 KSP Residual norm 2.205920585448e-04
  5517 KSP Residual norm 1.904484367096e-04
  5518 KSP Residual norm 1.762030537920e-04
  5519 KSP Residual norm 1.713669432590e-04
  5520 KSP Residual norm 1.484616200034e-04
  5521 KSP Residual norm 1.291725557462e-04
  5522 KSP Residual norm 1.279656720388e-04
  5523 KSP Residual norm 1.339253399541e-04
  5524 KSP Residual norm 1.130742007400e-04
  5525 KSP Residual norm 9.226543504901e-05
  5526 KSP Residual norm 9.337781091670e-05
  5527 KSP Residual norm 1.033740271140e-04
  5528 KSP Residual norm 1.077084271398e-04
  5529 KSP Residual norm 1.078378465288e-04
  5530 KSP Residual norm 1.142127592458e-04
  5531 KSP Residual norm 1.296306433532e-04
  5532 KSP Residual norm 1.397546422793e-04
  5533 KSP Residual norm 1.360697136744e-04
  5534 KSP Residual norm 1.330607527380e-04
  5535 KSP Residual norm 1.282371457806e-04
  5536 KSP Residual norm 1.300163013936e-04
  5537 KSP Residual norm 1.403428137837e-04
  5538 KSP Residual norm 1.366756756029e-04
  5539 KSP Residual norm 1.142203581770e-04
  5540 KSP Residual norm 1.058979001250e-04
  5541 KSP Residual norm 1.061069452013e-04
  5542 KSP Residual norm 1.025637608431e-04
  5543 KSP Residual norm 9.764269999651e-05
  5544 KSP Residual norm 9.671340362633e-05
  5545 KSP Residual norm 1.025095953929e-04
  5546 KSP Residual norm 1.078139515394e-04
  5547 KSP Residual norm 1.150143576937e-04
  5548 KSP Residual norm 1.202196098788e-04
  5549 KSP Residual norm 1.276574943103e-04
  5550 KSP Residual norm 1.341955162129e-04
  5551 KSP Residual norm 1.496811108075e-04
  5552 KSP Residual norm 1.696865048115e-04
  5553 KSP Residual norm 1.805843626317e-04
  5554 KSP Residual norm 1.773557321230e-04
  5555 KSP Residual norm 1.740569548714e-04
  5556 KSP Residual norm 1.893071345861e-04
  5557 KSP Residual norm 2.000699092322e-04
  5558 KSP Residual norm 1.976560690861e-04
  5559 KSP Residual norm 1.968881124422e-04
  5560 KSP Residual norm 2.015241556695e-04
  5561 KSP Residual norm 2.136191320420e-04
  5562 KSP Residual norm 2.041253067977e-04
  5563 KSP Residual norm 1.817563216214e-04
  5564 KSP Residual norm 1.820620737751e-04
  5565 KSP Residual norm 2.040498486297e-04
  5566 KSP Residual norm 2.191985137190e-04
  5567 KSP Residual norm 2.110098065809e-04
  5568 KSP Residual norm 1.936365651161e-04
  5569 KSP Residual norm 1.950353541804e-04
  5570 KSP Residual norm 2.361640077098e-04
  5571 KSP Residual norm 2.909394547983e-04
  5572 KSP Residual norm 3.174936992635e-04
  5573 KSP Residual norm 3.128069202910e-04
  5574 KSP Residual norm 2.963798382496e-04
  5575 KSP Residual norm 2.977631698650e-04
  5576 KSP Residual norm 3.074171672751e-04
  5577 KSP Residual norm 3.124346464784e-04
  5578 KSP Residual norm 3.147092932601e-04
  5579 KSP Residual norm 3.289911755945e-04
  5580 KSP Residual norm 3.401372379534e-04
  5581 KSP Residual norm 3.459055044411e-04
  5582 KSP Residual norm 3.494742390363e-04
  5583 KSP Residual norm 3.241751533875e-04
  5584 KSP Residual norm 2.984716177779e-04
  5585 KSP Residual norm 2.841187218740e-04
  5586 KSP Residual norm 2.500963203614e-04
  5587 KSP Residual norm 1.985559588665e-04
  5588 KSP Residual norm 1.813063461890e-04
  5589 KSP Residual norm 1.884995846394e-04
  5590 KSP Residual norm 1.862124949968e-04
  5591 KSP Residual norm 1.576137634920e-04
  5592 KSP Residual norm 1.314333115333e-04
  5593 KSP Residual norm 1.233170540821e-04
  5594 KSP Residual norm 1.256715269944e-04
  5595 KSP Residual norm 1.274156428359e-04
  5596 KSP Residual norm 1.304975747973e-04
  5597 KSP Residual norm 1.403750917018e-04
  5598 KSP Residual norm 1.518813122260e-04
  5599 KSP Residual norm 1.594566833030e-04
  5600 KSP Residual norm 1.607368647173e-04
  5601 KSP Residual norm 1.512590127040e-04
  5602 KSP Residual norm 1.503473571558e-04
  5603 KSP Residual norm 1.593245697035e-04
  5604 KSP Residual norm 1.564282073915e-04
  5605 KSP Residual norm 1.528019132185e-04
  5606 KSP Residual norm 1.554991897247e-04
  5607 KSP Residual norm 1.505493314950e-04
  5608 KSP Residual norm 1.494931849597e-04
  5609 KSP Residual norm 1.543089634330e-04
  5610 KSP Residual norm 1.525547365678e-04
  5611 KSP Residual norm 1.443624500493e-04
  5612 KSP Residual norm 1.413876022153e-04
  5613 KSP Residual norm 1.340625797578e-04
  5614 KSP Residual norm 1.190953314077e-04
  5615 KSP Residual norm 1.092086393545e-04
  5616 KSP Residual norm 1.013878003574e-04
  5617 KSP Residual norm 8.985011747366e-05
  5618 KSP Residual norm 7.803686905695e-05
  5619 KSP Residual norm 6.968710138343e-05
    Residual norms for fieldsplit_FE_split_ solve.
    0 KSP Residual norm 6.981540039732e-05
    1 KSP Residual norm 5.486740819847e-05
    2 KSP Residual norm 4.859958377030e-05
    3 KSP Residual norm 4.830776818665e-05
    4 KSP Residual norm 4.680815415132e-05
    5 KSP Residual norm 4.931038847020e-05
    6 KSP Residual norm 5.311601221565e-05
    7 KSP Residual norm 5.445362946290e-05
    8 KSP Residual norm 5.501992703276e-05
    9 KSP Residual norm 5.614607086184e-05
   10 KSP Residual norm 5.818742397702e-05
   11 KSP Residual norm 6.076860407413e-05
   12 KSP Residual norm 6.209344716986e-05
   13 KSP Residual norm 6.276921190143e-05
   14 KSP Residual norm 6.575248070602e-05
   15 KSP Residual norm 7.027771801762e-05
   16 KSP Residual norm 6.876504852303e-05
   17 KSP Residual norm 6.235650944687e-05
   18 KSP Residual norm 5.823000331989e-05
   19 KSP Residual norm 5.720617267618e-05
   20 KSP Residual norm 5.333689341912e-05
   21 KSP Residual norm 4.633418134281e-05
   22 KSP Residual norm 4.179723268121e-05
   23 KSP Residual norm 3.985994954437e-05
   24 KSP Residual norm 3.768033487646e-05
   25 KSP Residual norm 3.470051378485e-05
   26 KSP Residual norm 3.325204563555e-05
   27 KSP Residual norm 3.180228468573e-05
   28 KSP Residual norm 3.169827245146e-05
   29 KSP Residual norm 3.222653194243e-05
   30 KSP Residual norm 3.103397420772e-05
   31 KSP Residual norm 2.872270528153e-05
   32 KSP Residual norm 2.979862025627e-05
   33 KSP Residual norm 3.346975052952e-05
   34 KSP Residual norm 3.501609175377e-05
   35 KSP Residual norm 3.641338990485e-05
   36 KSP Residual norm 4.039317497089e-05
   37 KSP Residual norm 4.295748454991e-05
   38 KSP Residual norm 4.373961253986e-05
   39 KSP Residual norm 4.319140632739e-05
   40 KSP Residual norm 4.380248212390e-05
   41 KSP Residual norm 4.532938293215e-05
   42 KSP Residual norm 4.559413519122e-05
   43 KSP Residual norm 4.731476781739e-05
   44 KSP Residual norm 4.775883847507e-05
   45 KSP Residual norm 4.545024483077e-05
   46 KSP Residual norm 4.373314157959e-05
   47 KSP Residual norm 4.137897107505e-05
   48 KSP Residual norm 3.546177537398e-05
   49 KSP Residual norm 3.052751623339e-05
   50 KSP Residual norm 2.864117038043e-05
   51 KSP Residual norm 2.702872123912e-05
   52 KSP Residual norm 2.628189014355e-05
   53 KSP Residual norm 2.670640399291e-05
   54 KSP Residual norm 2.499126125214e-05
   55 KSP Residual norm 2.266614064588e-05
   56 KSP Residual norm 2.252612290890e-05
   57 KSP Residual norm 2.380232527474e-05
   58 KSP Residual norm 2.479900394659e-05
   59 KSP Residual norm 2.594797782441e-05
   60 KSP Residual norm 2.794271226180e-05
   61 KSP Residual norm 3.102034979668e-05
   62 KSP Residual norm 3.509207964089e-05
   63 KSP Residual norm 3.604481329240e-05
   64 KSP Residual norm 3.592628672047e-05
   65 KSP Residual norm 3.757751616012e-05
   66 KSP Residual norm 3.921466117532e-05
   67 KSP Residual norm 4.089934520970e-05
   68 KSP Residual norm 4.300472982162e-05
   69 KSP Residual norm 4.373578651627e-05
   70 KSP Residual norm 4.367946591543e-05
   71 KSP Residual norm 4.412167599913e-05
   72 KSP Residual norm 4.534000742787e-05
   73 KSP Residual norm 4.462618450013e-05
   74 KSP Residual norm 4.441574051785e-05
   75 KSP Residual norm 4.395960448337e-05
   76 KSP Residual norm 4.409090830245e-05
   77 KSP Residual norm 4.420761732308e-05
   78 KSP Residual norm 4.371366661465e-05
   79 KSP Residual norm 4.322759109329e-05
   80 KSP Residual norm 4.352260878504e-05
   81 KSP Residual norm 4.368352336874e-05
   82 KSP Residual norm 4.258447314602e-05
   83 KSP Residual norm 4.056184545740e-05
   84 KSP Residual norm 4.056368411442e-05
   85 KSP Residual norm 4.275537722706e-05
   86 KSP Residual norm 4.878647073801e-05
   87 KSP Residual norm 5.714141406613e-05
   88 KSP Residual norm 6.315168874028e-05
   89 KSP Residual norm 6.417905869732e-05
   90 KSP Residual norm 6.430159427937e-05
   91 KSP Residual norm 7.101589182977e-05
   92 KSP Residual norm 7.515258571149e-05
   93 KSP Residual norm 7.381088175387e-05
   94 KSP Residual norm 8.006995216430e-05
   95 KSP Residual norm 9.105174606062e-05
   96 KSP Residual norm 8.795394773827e-05
   97 KSP Residual norm 8.160834868630e-05
   98 KSP Residual norm 8.716168381588e-05
   99 KSP Residual norm 9.314636077655e-05
  100 KSP Residual norm 9.034722539252e-05
  101 KSP Residual norm 8.560227248158e-05
  102 KSP Residual norm 8.736253425890e-05
  103 KSP Residual norm 9.078448680835e-05
  104 KSP Residual norm 9.446778199984e-05
  105 KSP Residual norm 9.803841442608e-05
  106 KSP Residual norm 1.019319395582e-04
  107 KSP Residual norm 1.025935703686e-04
  108 KSP Residual norm 1.064706043334e-04
  109 KSP Residual norm 1.141888451782e-04
  110 KSP Residual norm 1.171344768412e-04
  111 KSP Residual norm 1.191838088932e-04
  112 KSP Residual norm 1.299193798544e-04
  113 KSP Residual norm 1.402202562321e-04
  114 KSP Residual norm 1.292692066741e-04
  115 KSP Residual norm 1.178776502619e-04
  116 KSP Residual norm 1.237283041002e-04
  117 KSP Residual norm 1.376675931523e-04
  118 KSP Residual norm 1.421727334801e-04
  119 KSP Residual norm 1.307850143471e-04
  120 KSP Residual norm 1.170874317479e-04
  121 KSP Residual norm 1.131956759002e-04
  122 KSP Residual norm 1.088834413724e-04
  123 KSP Residual norm 9.868907877203e-05
  124 KSP Residual norm 8.904238360157e-05
  125 KSP Residual norm 8.658080221285e-05
  126 KSP Residual norm 8.423323391111e-05
  127 KSP Residual norm 7.785928265843e-05
  128 KSP Residual norm 7.144743125951e-05
  129 KSP Residual norm 6.853230521148e-05
  130 KSP Residual norm 6.878755852414e-05
  131 KSP Residual norm 6.549341206408e-05
  132 KSP Residual norm 6.536029796748e-05
  133 KSP Residual norm 6.941465520394e-05
  134 KSP Residual norm 7.441192350479e-05
  135 KSP Residual norm 8.054270903251e-05
  136 KSP Residual norm 9.257619604795e-05
  137 KSP Residual norm 9.972863209624e-05
  138 KSP Residual norm 1.025576511532e-04
  139 KSP Residual norm 1.073858880987e-04
  140 KSP Residual norm 1.069917174942e-04
  141 KSP Residual norm 9.905061128405e-05
  142 KSP Residual norm 9.712138881971e-05
  143 KSP Residual norm 9.896887251036e-05
  144 KSP Residual norm 9.180869356224e-05
  145 KSP Residual norm 8.412875895159e-05
  146 KSP Residual norm 8.080421028975e-05
  147 KSP Residual norm 7.547965549861e-05
  148 KSP Residual norm 6.898876902162e-05
  149 KSP Residual norm 6.365742257829e-05
  150 KSP Residual norm 6.364652228967e-05
  151 KSP Residual norm 6.535403973594e-05
  152 KSP Residual norm 6.200913940850e-05
  153 KSP Residual norm 5.564244648251e-05
  154 KSP Residual norm 5.518789581924e-05
  155 KSP Residual norm 5.750074436045e-05
  156 KSP Residual norm 5.661867421387e-05
  157 KSP Residual norm 5.339139172252e-05
  158 KSP Residual norm 5.030394807929e-05
  159 KSP Residual norm 4.937510171395e-05
  160 KSP Residual norm 5.226516349696e-05
  161 KSP Residual norm 5.404719112849e-05
  162 KSP Residual norm 5.304980719571e-05
  163 KSP Residual norm 5.574957126148e-05
  164 KSP Residual norm 6.312792655771e-05
  165 KSP Residual norm 6.654596382397e-05
  166 KSP Residual norm 6.297605018290e-05
  167 KSP Residual norm 5.723317277165e-05
  168 KSP Residual norm 5.516045984997e-05
  169 KSP Residual norm 5.392574351997e-05
  170 KSP Residual norm 5.072531195418e-05
  171 KSP Residual norm 5.074515168635e-05
  172 KSP Residual norm 5.592105315714e-05
  173 KSP Residual norm 5.789242817196e-05
  174 KSP Residual norm 5.564290007552e-05
  175 KSP Residual norm 5.438634017329e-05
  176 KSP Residual norm 5.616757442794e-05
  177 KSP Residual norm 5.755111896661e-05
  178 KSP Residual norm 5.923299575820e-05
  179 KSP Residual norm 6.014988172065e-05
  180 KSP Residual norm 6.272223927318e-05
  181 KSP Residual norm 6.651678381283e-05
  182 KSP Residual norm 6.472927027704e-05
  183 KSP Residual norm 6.134890024015e-05
  184 KSP Residual norm 6.470110659792e-05
  185 KSP Residual norm 6.976501966588e-05
  186 KSP Residual norm 6.969283534078e-05
  187 KSP Residual norm 7.425567388575e-05
  188 KSP Residual norm 7.864596253136e-05
  189 KSP Residual norm 7.567975844604e-05
  190 KSP Residual norm 7.557980116617e-05
  191 KSP Residual norm 7.877600682610e-05
  192 KSP Residual norm 7.576281015868e-05
  193 KSP Residual norm 7.417612264368e-05
  194 KSP Residual norm 7.386006862731e-05
  195 KSP Residual norm 7.440492828970e-05
  196 KSP Residual norm 7.777177324894e-05
  197 KSP Residual norm 8.103157109878e-05
  198 KSP Residual norm 8.795069003035e-05
  199 KSP Residual norm 1.001705442765e-04
  200 KSP Residual norm 1.070640980872e-04
  201 KSP Residual norm 1.091939217250e-04
  202 KSP Residual norm 1.191048783588e-04
  203 KSP Residual norm 1.362256171204e-04
  204 KSP Residual norm 1.467818182996e-04
  205 KSP Residual norm 1.521056078547e-04
  206 KSP Residual norm 1.487056681147e-04
  207 KSP Residual norm 1.464713212261e-04
  208 KSP Residual norm 1.446364144174e-04
  209 KSP Residual norm 1.453399521497e-04
  210 KSP Residual norm 1.457471847081e-04
  211 KSP Residual norm 1.467129700839e-04
  212 KSP Residual norm 1.415441306955e-04
  213 KSP Residual norm 1.396784650154e-04
  214 KSP Residual norm 1.429506359483e-04
  215 KSP Residual norm 1.428022622147e-04
  216 KSP Residual norm 1.365525434288e-04
  217 KSP Residual norm 1.337416897171e-04
  218 KSP Residual norm 1.295690094990e-04
  219 KSP Residual norm 1.205129995938e-04
  220 KSP Residual norm 1.128107184535e-04
  221 KSP Residual norm 1.128162828788e-04
  222 KSP Residual norm 1.156396769951e-04
  223 KSP Residual norm 1.128400982738e-04
  224 KSP Residual norm 1.137479574675e-04
  225 KSP Residual norm 1.089566876535e-04
  226 KSP Residual norm 1.050973423642e-04
  227 KSP Residual norm 1.086783600564e-04
  228 KSP Residual norm 1.129662218027e-04
  229 KSP Residual norm 1.130203710386e-04
  230 KSP Residual norm 1.090406054488e-04
  231 KSP Residual norm 1.103750635270e-04
  232 KSP Residual norm 1.136551399950e-04
  233 KSP Residual norm 1.189195823106e-04
  234 KSP Residual norm 1.215317691788e-04
  235 KSP Residual norm 1.193538311037e-04
  236 KSP Residual norm 1.201928148860e-04
  237 KSP Residual norm 1.240644246175e-04
  238 KSP Residual norm 1.282986527693e-04
  239 KSP Residual norm 1.303025128916e-04
  240 KSP Residual norm 1.227406426576e-04
  241 KSP Residual norm 1.185856347069e-04
  242 KSP Residual norm 1.228699755900e-04
  243 KSP Residual norm 1.200612617097e-04
  244 KSP Residual norm 1.179486758917e-04
  245 KSP Residual norm 1.245980860231e-04
  246 KSP Residual norm 1.325733764489e-04
  247 KSP Residual norm 1.250404886213e-04
  248 KSP Residual norm 1.194344593488e-04
  249 KSP Residual norm 1.170213487575e-04
  250 KSP Residual norm 1.134312347772e-04
  251 KSP Residual norm 1.124860971529e-04
  252 KSP Residual norm 1.137678303459e-04
  253 KSP Residual norm 1.089741563950e-04
  254 KSP Residual norm 1.111617773424e-04
  255 KSP Residual norm 1.189820969039e-04
  256 KSP Residual norm 1.171459703106e-04
  257 KSP Residual norm 1.134877679278e-04
  258 KSP Residual norm 1.174578677376e-04
  259 KSP Residual norm 1.253270758101e-04
  260 KSP Residual norm 1.295104635228e-04
  261 KSP Residual norm 1.279150133006e-04
  262 KSP Residual norm 1.240762848631e-04
  263 KSP Residual norm 1.208483296083e-04
  264 KSP Residual norm 1.166138220603e-04
  265 KSP Residual norm 1.217832261034e-04
  266 KSP Residual norm 1.336237809167e-04
  267 KSP Residual norm 1.390163179027e-04
  268 KSP Residual norm 1.421694296531e-04
  269 KSP Residual norm 1.518133902495e-04
  270 KSP Residual norm 1.529033806052e-04
  271 KSP Residual norm 1.487241957244e-04
  272 KSP Residual norm 1.526422933183e-04
  273 KSP Residual norm 1.516377833397e-04
  274 KSP Residual norm 1.460440099024e-04
  275 KSP Residual norm 1.521252242812e-04
  276 KSP Residual norm 1.562423693229e-04
  277 KSP Residual norm 1.431880642221e-04
  278 KSP Residual norm 1.385607213070e-04
  279 KSP Residual norm 1.498265566529e-04
  280 KSP Residual norm 1.596850217203e-04
  281 KSP Residual norm 1.565381776562e-04
  282 KSP Residual norm 1.519228874756e-04
  283 KSP Residual norm 1.521934344572e-04
  284 KSP Residual norm 1.522772565531e-04
  285 KSP Residual norm 1.460086868820e-04
  286 KSP Residual norm 1.495345138364e-04
  287 KSP Residual norm 1.561662095947e-04
  288 KSP Residual norm 1.639801631004e-04
  289 KSP Residual norm 1.836971875830e-04
  290 KSP Residual norm 1.941349179982e-04
  291 KSP Residual norm 1.954577705834e-04
  292 KSP Residual norm 2.007723397681e-04
  293 KSP Residual norm 2.192303732935e-04
  294 KSP Residual norm 2.408649813461e-04
  295 KSP Residual norm 2.509203477993e-04
  296 KSP Residual norm 2.728004395497e-04
  297 KSP Residual norm 3.123383574209e-04
  298 KSP Residual norm 3.231014687907e-04
  299 KSP Residual norm 3.038796238126e-04
  300 KSP Residual norm 2.805372286204e-04
  301 KSP Residual norm 2.699920560761e-04
  302 KSP Residual norm 2.611119685481e-04
  303 KSP Residual norm 2.504051786545e-04
  304 KSP Residual norm 2.438836142113e-04
  305 KSP Residual norm 2.512304350183e-04
  306 KSP Residual norm 2.720949286874e-04
  307 KSP Residual norm 2.870895322639e-04
  308 KSP Residual norm 2.938975084962e-04
  309 KSP Residual norm 3.017332467858e-04
  310 KSP Residual norm 3.082482922637e-04
  311 KSP Residual norm 3.130650847360e-04
  312 KSP Residual norm 3.257954879731e-04
  313 KSP Residual norm 3.307800922468e-04
  314 KSP Residual norm 3.252185256537e-04
  315 KSP Residual norm 3.447381487181e-04
  316 KSP Residual norm 3.691035511895e-04
  317 KSP Residual norm 3.592722434409e-04
  318 KSP Residual norm 3.461533727324e-04
  319 KSP Residual norm 3.496598609985e-04
  320 KSP Residual norm 3.422559497886e-04
  321 KSP Residual norm 3.513331786751e-04
  322 KSP Residual norm 3.678215591646e-04
  323 KSP Residual norm 3.837901176974e-04
  324 KSP Residual norm 4.049954785378e-04
  325 KSP Residual norm 4.267723759839e-04
  326 KSP Residual norm 4.357579054319e-04
  327 KSP Residual norm 4.206431529214e-04
  328 KSP Residual norm 3.960210422309e-04
  329 KSP Residual norm 3.896464535641e-04
  330 KSP Residual norm 3.956519812624e-04
  331 KSP Residual norm 4.048227578024e-04
  332 KSP Residual norm 4.049626060228e-04
  333 KSP Residual norm 3.931605132306e-04
  334 KSP Residual norm 3.755642935064e-04
  335 KSP Residual norm 3.661374572092e-04
  336 KSP Residual norm 3.765297357572e-04
  337 KSP Residual norm 3.877284874775e-04
  338 KSP Residual norm 4.066083243211e-04
  339 KSP Residual norm 4.307021980872e-04
  340 KSP Residual norm 4.194967482851e-04
  341 KSP Residual norm 3.703442337360e-04
  342 KSP Residual norm 3.479060139866e-04
  343 KSP Residual norm 3.259674347278e-04
  344 KSP Residual norm 3.175548728963e-04
  345 KSP Residual norm 3.213586928771e-04
  346 KSP Residual norm 3.250807460760e-04
  347 KSP Residual norm 3.251819131296e-04
  348 KSP Residual norm 3.313944592753e-04
  349 KSP Residual norm 3.441929583600e-04
  350 KSP Residual norm 3.472720691450e-04
  351 KSP Residual norm 3.498702948256e-04
  352 KSP Residual norm 3.537478107137e-04
  353 KSP Residual norm 3.568281368181e-04
  354 KSP Residual norm 3.695141812939e-04
  355 KSP Residual norm 3.792590697228e-04
  356 KSP Residual norm 3.752083064642e-04
  357 KSP Residual norm 3.679782681858e-04
  358 KSP Residual norm 3.805879751134e-04
  359 KSP Residual norm 3.903897745976e-04
  360 KSP Residual norm 3.867058955608e-04
  361 KSP Residual norm 3.743382017322e-04
  362 KSP Residual norm 3.610323721376e-04
  363 KSP Residual norm 3.305268164179e-04
  364 KSP Residual norm 3.098322171523e-04
  365 KSP Residual norm 3.171597509563e-04
  366 KSP Residual norm 3.296285788558e-04
  367 KSP Residual norm 3.259517986141e-04
  368 KSP Residual norm 3.208566354772e-04
  369 KSP Residual norm 3.092635598126e-04
  370 KSP Residual norm 2.963806886599e-04
  371 KSP Residual norm 2.930370626108e-04
  372 KSP Residual norm 2.801431006457e-04
  373 KSP Residual norm 2.599193126052e-04
  374 KSP Residual norm 2.485546338738e-04
  375 KSP Residual norm 2.564488862802e-04
  376 KSP Residual norm 2.561275758804e-04
  377 KSP Residual norm 2.475474939625e-04
  378 KSP Residual norm 2.400266434543e-04
  379 KSP Residual norm 2.476348723327e-04
  380 KSP Residual norm 2.694160138385e-04
  381 KSP Residual norm 2.857610375647e-04
  382 KSP Residual norm 2.922524550624e-04
  383 KSP Residual norm 2.848353280463e-04
  384 KSP Residual norm 2.673547985660e-04
  385 KSP Residual norm 2.701172032734e-04
  386 KSP Residual norm 2.695675447549e-04
  387 KSP Residual norm 2.625265920549e-04
  388 KSP Residual norm 2.581236031158e-04
  389 KSP Residual norm 2.558491000489e-04
  390 KSP Residual norm 2.556638787165e-04
  391 KSP Residual norm 2.709510403060e-04
  392 KSP Residual norm 2.878236899729e-04
  393 KSP Residual norm 2.782178148903e-04
  394 KSP Residual norm 2.528341448842e-04
  395 KSP Residual norm 2.397778461477e-04
  396 KSP Residual norm 2.354049002805e-04
  397 KSP Residual norm 2.306441416892e-04
  398 KSP Residual norm 2.288412364906e-04
  399 KSP Residual norm 2.317318059214e-04
  400 KSP Residual norm 2.400107978774e-04
  401 KSP Residual norm 2.259629392734e-04
  402 KSP Residual norm 2.077477682248e-04
  403 KSP Residual norm 2.005458393285e-04
  404 KSP Residual norm 1.977491471838e-04
  405 KSP Residual norm 1.905765654879e-04
  406 KSP Residual norm 1.884021912140e-04
  407 KSP Residual norm 1.988611879625e-04
  408 KSP Residual norm 2.076327027260e-04
  409 KSP Residual norm 2.140217100206e-04
  410 KSP Residual norm 2.127525474722e-04
  411 KSP Residual norm 2.203505907684e-04
  412 KSP Residual norm 2.170720887913e-04
  413 KSP Residual norm 2.069253730006e-04
  414 KSP Residual norm 2.147078693605e-04
  415 KSP Residual norm 2.327129291436e-04
  416 KSP Residual norm 2.519852947981e-04
  417 KSP Residual norm 2.636144153323e-04
  418 KSP Residual norm 2.746072723283e-04
  419 KSP Residual norm 2.818369827043e-04
  420 KSP Residual norm 2.909302251349e-04
  421 KSP Residual norm 3.073147904541e-04
  422 KSP Residual norm 3.095441312158e-04
  423 KSP Residual norm 2.977255900737e-04
  424 KSP Residual norm 2.799193331487e-04
  425 KSP Residual norm 2.749290483331e-04
  426 KSP Residual norm 2.874606134329e-04
  427 KSP Residual norm 2.902477130763e-04
  428 KSP Residual norm 2.757604890217e-04
  429 KSP Residual norm 2.792537966592e-04
  430 KSP Residual norm 3.103314820006e-04
  431 KSP Residual norm 3.385389022806e-04
  432 KSP Residual norm 3.626659268954e-04
  433 KSP Residual norm 3.818882153868e-04
  434 KSP Residual norm 4.048385232856e-04
  435 KSP Residual norm 4.197062525627e-04
  436 KSP Residual norm 4.228482750532e-04
  437 KSP Residual norm 4.111899475869e-04
  438 KSP Residual norm 4.086774546365e-04
  439 KSP Residual norm 4.132131036902e-04
  440 KSP Residual norm 4.304928509065e-04
  441 KSP Residual norm 4.567316942924e-04
  442 KSP Residual norm 5.098478062822e-04
  443 KSP Residual norm 5.417075445727e-04
  444 KSP Residual norm 5.371499781942e-04
  445 KSP Residual norm 5.338995247722e-04
  446 KSP Residual norm 5.255072001908e-04
  447 KSP Residual norm 5.110536827644e-04
  448 KSP Residual norm 5.020912890601e-04
  449 KSP Residual norm 5.116561237546e-04
  450 KSP Residual norm 5.226811206084e-04
  451 KSP Residual norm 5.048375434607e-04
  452 KSP Residual norm 4.711926174669e-04
  453 KSP Residual norm 4.639060730506e-04
  454 KSP Residual norm 4.937366762039e-04
  455 KSP Residual norm 5.325213172694e-04
  456 KSP Residual norm 5.369971722332e-04
  457 KSP Residual norm 5.369176373066e-04
  458 KSP Residual norm 5.442584174831e-04
  459 KSP Residual norm 5.537587086352e-04
  460 KSP Residual norm 5.647489638850e-04
  461 KSP Residual norm 5.964772267925e-04
  462 KSP Residual norm 6.223153191980e-04
  463 KSP Residual norm 6.584346636596e-04
  464 KSP Residual norm 7.206601354544e-04
  465 KSP Residual norm 7.661778987373e-04
  466 KSP Residual norm 7.616320358790e-04
  467 KSP Residual norm 7.409337567099e-04
  468 KSP Residual norm 7.398443583852e-04
  469 KSP Residual norm 7.616017560879e-04
  470 KSP Residual norm 7.615689005901e-04
  471 KSP Residual norm 7.465350910227e-04
  472 KSP Residual norm 7.157786316230e-04
  473 KSP Residual norm 6.813674934020e-04
  474 KSP Residual norm 7.038903810195e-04
  475 KSP Residual norm 7.411277825872e-04
  476 KSP Residual norm 7.751525138659e-04
  477 KSP Residual norm 7.612387324218e-04
  478 KSP Residual norm 7.331684292880e-04
  479 KSP Residual norm 7.443202028166e-04
  480 KSP Residual norm 7.357599705108e-04
  481 KSP Residual norm 7.070872272444e-04
  482 KSP Residual norm 6.900126599196e-04
  483 KSP Residual norm 6.342877796595e-04
  484 KSP Residual norm 5.847592870453e-04
  485 KSP Residual norm 5.834519419936e-04
  486 KSP Residual norm 5.964804845182e-04
  487 KSP Residual norm 5.662375700080e-04
  488 KSP Residual norm 5.383211884869e-04
  489 KSP Residual norm 5.548528167284e-04
  490 KSP Residual norm 5.767492190547e-04
  491 KSP Residual norm 5.837693802046e-04
  492 KSP Residual norm 5.993058075815e-04
  493 KSP Residual norm 6.093717460716e-04
  494 KSP Residual norm 5.943460626242e-04
  495 KSP Residual norm 5.649679913700e-04
  496 KSP Residual norm 5.363438797937e-04
  497 KSP Residual norm 5.177053380776e-04
  498 KSP Residual norm 4.972535862169e-04
  499 KSP Residual norm 4.985135280223e-04
  500 KSP Residual norm 5.316560947638e-04
  501 KSP Residual norm 5.308626408057e-04
  502 KSP Residual norm 5.168202514464e-04
  503 KSP Residual norm 5.011392896844e-04
  504 KSP Residual norm 4.922747083879e-04
  505 KSP Residual norm 4.881911680738e-04
  506 KSP Residual norm 4.910535459277e-04
  507 KSP Residual norm 4.738401466484e-04
  508 KSP Residual norm 4.509070504787e-04
  509 KSP Residual norm 4.417435773872e-04
  510 KSP Residual norm 4.490586510983e-04
  511 KSP Residual norm 4.373285709883e-04
  512 KSP Residual norm 4.210067546256e-04
  513 KSP Residual norm 4.149237852168e-04
  514 KSP Residual norm 4.126616380464e-04
  515 KSP Residual norm 4.400985650400e-04
  516 KSP Residual norm 4.668722840293e-04
  517 KSP Residual norm 4.487090538670e-04
  518 KSP Residual norm 4.108252906707e-04
  519 KSP Residual norm 3.893803650408e-04
  520 KSP Residual norm 3.690033563343e-04
  521 KSP Residual norm 3.372102448074e-04
  522 KSP Residual norm 3.124314668449e-04
  523 KSP Residual norm 3.063166939072e-04
  524 KSP Residual norm 3.009317612193e-04
  525 KSP Residual norm 2.890779231687e-04
  526 KSP Residual norm 2.755646645922e-04
  527 KSP Residual norm 2.771047017005e-04
  528 KSP Residual norm 2.772731520962e-04
  529 KSP Residual norm 2.569474876420e-04
  530 KSP Residual norm 2.371363859595e-04
  531 KSP Residual norm 2.320942381456e-04
  532 KSP Residual norm 2.319732315341e-04
  533 KSP Residual norm 2.280635097930e-04
  534 KSP Residual norm 2.213056603746e-04
  535 KSP Residual norm 2.213553030469e-04
  536 KSP Residual norm 2.088090657561e-04
  537 KSP Residual norm 1.874879273762e-04
  538 KSP Residual norm 1.809895898642e-04
  539 KSP Residual norm 1.865550273684e-04
  540 KSP Residual norm 1.895343280653e-04
  541 KSP Residual norm 1.827628870556e-04
  542 KSP Residual norm 1.813947650850e-04
  543 KSP Residual norm 1.928277510546e-04
  544 KSP Residual norm 2.189460446107e-04
  545 KSP Residual norm 2.389423192570e-04
  546 KSP Residual norm 2.593499176374e-04
  547 KSP Residual norm 2.784163893697e-04
  548 KSP Residual norm 2.825502209655e-04
  549 KSP Residual norm 2.817441266797e-04
  550 KSP Residual norm 2.764960244314e-04
  551 KSP Residual norm 2.734569762243e-04
  552 KSP Residual norm 2.710954464580e-04
  553 KSP Residual norm 2.755118209365e-04
  554 KSP Residual norm 2.705711734366e-04
  555 KSP Residual norm 2.657022405368e-04
  556 KSP Residual norm 2.655378434301e-04
  557 KSP Residual norm 2.647116778205e-04
  558 KSP Residual norm 2.673506255806e-04
  559 KSP Residual norm 2.649854663544e-04
  560 KSP Residual norm 2.728816892564e-04
  561 KSP Residual norm 2.776455434169e-04
  562 KSP Residual norm 2.574948366822e-04
  563 KSP Residual norm 2.316459149341e-04
  564 KSP Residual norm 2.128662992125e-04
  565 KSP Residual norm 2.021895944361e-04
  566 KSP Residual norm 1.993268678146e-04
  567 KSP Residual norm 2.080187296173e-04
  568 KSP Residual norm 2.160308678926e-04
  569 KSP Residual norm 2.131554348425e-04
  570 KSP Residual norm 2.000975062130e-04
  571 KSP Residual norm 1.910708626051e-04
  572 KSP Residual norm 1.899355968815e-04
  573 KSP Residual norm 2.024059819100e-04
  574 KSP Residual norm 2.090185387834e-04
  575 KSP Residual norm 2.104955694865e-04
  576 KSP Residual norm 2.068680324336e-04
  577 KSP Residual norm 2.063659888697e-04
  578 KSP Residual norm 2.109483827571e-04
  579 KSP Residual norm 2.247507464692e-04
  580 KSP Residual norm 2.536365279751e-04
  581 KSP Residual norm 2.995612119600e-04
  582 KSP Residual norm 3.286959491975e-04
  583 KSP Residual norm 3.458910058780e-04
  584 KSP Residual norm 3.600427435581e-04
  585 KSP Residual norm 3.700882017988e-04
  586 KSP Residual norm 3.665787171631e-04
  587 KSP Residual norm 3.770035539765e-04
  588 KSP Residual norm 3.857204574662e-04
  589 KSP Residual norm 3.735291635419e-04
  590 KSP Residual norm 3.606019788556e-04
  591 KSP Residual norm 3.510361884609e-04
  592 KSP Residual norm 3.484777324544e-04
  593 KSP Residual norm 3.709360132250e-04
  594 KSP Residual norm 3.894533771300e-04
  595 KSP Residual norm 4.105238338751e-04
  596 KSP Residual norm 4.060895026346e-04
  597 KSP Residual norm 3.836560995854e-04
  598 KSP Residual norm 3.772003634251e-04
  599 KSP Residual norm 3.966847293137e-04
  600 KSP Residual norm 4.229400992440e-04
  601 KSP Residual norm 4.096565923865e-04
  602 KSP Residual norm 3.859826494372e-04
  603 KSP Residual norm 3.770500142573e-04
  604 KSP Residual norm 3.880439493804e-04
  605 KSP Residual norm 4.191534630627e-04
  606 KSP Residual norm 4.414758926370e-04
  607 KSP Residual norm 4.321646514625e-04
  608 KSP Residual norm 4.138305649943e-04
  609 KSP Residual norm 3.958945970100e-04
  610 KSP Residual norm 3.827174321188e-04
  611 KSP Residual norm 3.733233914260e-04
  612 KSP Residual norm 3.561676971222e-04
  613 KSP Residual norm 3.521969896433e-04
  614 KSP Residual norm 3.652565699572e-04
  615 KSP Residual norm 3.621046057501e-04
  616 KSP Residual norm 3.459888780479e-04
  617 KSP Residual norm 3.331270592330e-04
  618 KSP Residual norm 3.289302440553e-04
  619 KSP Residual norm 3.350218092037e-04
  620 KSP Residual norm 3.482870144727e-04
  621 KSP Residual norm 3.475563403751e-04
  622 KSP Residual norm 3.342436536453e-04
  623 KSP Residual norm 3.330867058258e-04
  624 KSP Residual norm 3.380760842823e-04
  625 KSP Residual norm 3.292356888261e-04
  626 KSP Residual norm 3.050811981393e-04
  627 KSP Residual norm 2.852909413427e-04
  628 KSP Residual norm 2.748908805111e-04
  629 KSP Residual norm 2.713072346263e-04
  630 KSP Residual norm 2.686547215078e-04
  631 KSP Residual norm 2.604360223220e-04
  632 KSP Residual norm 2.553432595079e-04
  633 KSP Residual norm 2.632918151328e-04
  634 KSP Residual norm 2.767552525703e-04
  635 KSP Residual norm 2.732590709563e-04
  636 KSP Residual norm 2.552668340230e-04
  637 KSP Residual norm 2.426470704150e-04
  638 KSP Residual norm 2.504925811177e-04
  639 KSP Residual norm 2.664749837324e-04
  640 KSP Residual norm 2.663289494501e-04
  641 KSP Residual norm 2.587736071318e-04
  642 KSP Residual norm 2.610215060048e-04
  643 KSP Residual norm 2.665150886995e-04
  644 KSP Residual norm 2.666587947651e-04
  645 KSP Residual norm 2.606735807949e-04
  646 KSP Residual norm 2.494471368047e-04
  647 KSP Residual norm 2.463369537758e-04
  648 KSP Residual norm 2.465399359065e-04
  649 KSP Residual norm 2.366218981115e-04
  650 KSP Residual norm 2.211573924004e-04
  651 KSP Residual norm 2.018730340623e-04
  652 KSP Residual norm 1.888471481475e-04
  653 KSP Residual norm 1.818203529277e-04
  654 KSP Residual norm 1.815359699326e-04
  655 KSP Residual norm 1.889774417459e-04
  656 KSP Residual norm 1.901525887233e-04
  657 KSP Residual norm 1.938847383440e-04
  658 KSP Residual norm 1.915407299215e-04
  659 KSP Residual norm 1.850964001476e-04
  660 KSP Residual norm 1.841397297402e-04
  661 KSP Residual norm 1.866959987298e-04
  662 KSP Residual norm 1.770891695831e-04
  663 KSP Residual norm 1.662573137785e-04
  664 KSP Residual norm 1.591115887560e-04
  665 KSP Residual norm 1.512013373742e-04
  666 KSP Residual norm 1.518553517077e-04
  667 KSP Residual norm 1.513046488993e-04
  668 KSP Residual norm 1.440479352991e-04
  669 KSP Residual norm 1.403945594173e-04
  670 KSP Residual norm 1.365169959673e-04
  671 KSP Residual norm 1.393479125988e-04
  672 KSP Residual norm 1.511214294290e-04
  673 KSP Residual norm 1.587884613257e-04
  674 KSP Residual norm 1.575479668122e-04
  675 KSP Residual norm 1.566909340512e-04
  676 KSP Residual norm 1.522536705239e-04
  677 KSP Residual norm 1.390501033191e-04
  678 KSP Residual norm 1.340917935740e-04
  679 KSP Residual norm 1.360345295459e-04
  680 KSP Residual norm 1.379130227899e-04
  681 KSP Residual norm 1.386845452263e-04
  682 KSP Residual norm 1.463497011884e-04
  683 KSP Residual norm 1.489178479418e-04
  684 KSP Residual norm 1.418440621591e-04
  685 KSP Residual norm 1.356745528882e-04
  686 KSP Residual norm 1.341984731879e-04
  687 KSP Residual norm 1.343719618582e-04
  688 KSP Residual norm 1.273418777658e-04
  689 KSP Residual norm 1.118180679154e-04
  690 KSP Residual norm 1.045955198090e-04
  691 KSP Residual norm 1.039288383267e-04
  692 KSP Residual norm 1.011554506544e-04
  693 KSP Residual norm 9.368118667392e-05
  694 KSP Residual norm 8.778815047921e-05
  695 KSP Residual norm 8.242840443364e-05
  696 KSP Residual norm 8.284701377902e-05
  697 KSP Residual norm 8.771902822762e-05
  698 KSP Residual norm 9.158099488134e-05
  699 KSP Residual norm 9.045580911773e-05
  700 KSP Residual norm 8.720039417268e-05
  701 KSP Residual norm 8.061595510881e-05
  702 KSP Residual norm 7.564306265351e-05
  703 KSP Residual norm 7.029080695304e-05
  704 KSP Residual norm 6.505430184931e-05
  705 KSP Residual norm 6.359848182438e-05
  706 KSP Residual norm 6.945075160604e-05
  707 KSP Residual norm 7.964562428650e-05
  708 KSP Residual norm 8.464374068866e-05
  709 KSP Residual norm 8.605329694482e-05
  710 KSP Residual norm 8.784893347748e-05
  711 KSP Residual norm 9.077680593438e-05
  712 KSP Residual norm 9.211637659931e-05
  713 KSP Residual norm 9.287293305922e-05
  714 KSP Residual norm 8.955034606774e-05
  715 KSP Residual norm 9.350476179194e-05
  716 KSP Residual norm 1.020621804336e-04
  717 KSP Residual norm 1.099871187190e-04
  718 KSP Residual norm 1.097060015378e-04
  719 KSP Residual norm 1.005983055756e-04
  720 KSP Residual norm 9.136936752700e-05
  721 KSP Residual norm 8.904756140863e-05
  722 KSP Residual norm 9.324078480645e-05
  723 KSP Residual norm 9.478374721466e-05
  724 KSP Residual norm 9.303956716846e-05
  725 KSP Residual norm 9.379200182521e-05
  726 KSP Residual norm 9.789367347975e-05
  727 KSP Residual norm 1.014423597225e-04
  728 KSP Residual norm 1.001219584124e-04
  729 KSP Residual norm 9.483663061797e-05
  730 KSP Residual norm 9.075616607417e-05
  731 KSP Residual norm 9.179214431364e-05
  732 KSP Residual norm 9.621078333832e-05
  733 KSP Residual norm 9.903635553456e-05
  734 KSP Residual norm 9.960057375744e-05
  735 KSP Residual norm 9.832985171293e-05
  736 KSP Residual norm 9.961540001231e-05
  737 KSP Residual norm 1.074098614953e-04
  738 KSP Residual norm 1.129631023486e-04
  739 KSP Residual norm 1.211427118724e-04
  740 KSP Residual norm 1.182594319717e-04
  741 KSP Residual norm 1.073481015164e-04
  742 KSP Residual norm 1.070075767118e-04
  743 KSP Residual norm 1.128573325618e-04
  744 KSP Residual norm 1.129815739752e-04
  745 KSP Residual norm 1.084953547993e-04
  746 KSP Residual norm 1.077186897046e-04
  747 KSP Residual norm 1.152306412331e-04
  748 KSP Residual norm 1.264154432455e-04
  749 KSP Residual norm 1.262888960034e-04
  750 KSP Residual norm 1.219869790948e-04
  751 KSP Residual norm 1.188599982608e-04
  752 KSP Residual norm 1.128391206910e-04
  753 KSP Residual norm 1.056224946333e-04
  754 KSP Residual norm 1.042303676318e-04
  755 KSP Residual norm 1.112996020318e-04
  756 KSP Residual norm 1.230972573107e-04
  757 KSP Residual norm 1.287410376401e-04
  758 KSP Residual norm 1.283057084344e-04
  759 KSP Residual norm 1.302262556370e-04
  760 KSP Residual norm 1.338648157566e-04
  761 KSP Residual norm 1.390411979530e-04
  762 KSP Residual norm 1.345273231030e-04
  763 KSP Residual norm 1.230468725277e-04
  764 KSP Residual norm 1.127479391567e-04
  765 KSP Residual norm 1.093379906097e-04
  766 KSP Residual norm 1.104194925894e-04
  767 KSP Residual norm 1.070059525267e-04
  768 KSP Residual norm 9.816270285947e-05
  769 KSP Residual norm 8.972957065753e-05
  770 KSP Residual norm 8.433612921540e-05
  771 KSP Residual norm 7.783694295777e-05
  772 KSP Residual norm 7.238906231984e-05
  773 KSP Residual norm 7.114738254377e-05
  774 KSP Residual norm 7.135970448637e-05
  775 KSP Residual norm 6.865321420652e-05
  776 KSP Residual norm 6.590548987731e-05
  777 KSP Residual norm 6.492853979065e-05
  778 KSP Residual norm 6.564956719799e-05
  779 KSP Residual norm 6.488622156589e-05
  780 KSP Residual norm 6.230254109345e-05
  781 KSP Residual norm 6.075697104076e-05
  782 KSP Residual norm 6.163396656740e-05
  783 KSP Residual norm 6.604961640641e-05
  784 KSP Residual norm 6.865848550932e-05
  785 KSP Residual norm 6.867497355651e-05
  786 KSP Residual norm 6.692216674343e-05
  787 KSP Residual norm 6.509052474198e-05
  788 KSP Residual norm 6.780430251246e-05
  789 KSP Residual norm 7.226643294862e-05
  790 KSP Residual norm 7.467219628724e-05
  791 KSP Residual norm 7.607989415374e-05
  792 KSP Residual norm 7.400047152191e-05
  793 KSP Residual norm 6.945455914576e-05
  794 KSP Residual norm 6.743261338199e-05
  795 KSP Residual norm 6.591024804061e-05
  796 KSP Residual norm 6.290084823521e-05
  797 KSP Residual norm 5.842037130509e-05
  798 KSP Residual norm 5.596201688000e-05
  799 KSP Residual norm 5.602274355058e-05
  800 KSP Residual norm 5.892522654710e-05
  801 KSP Residual norm 6.177925173331e-05
  802 KSP Residual norm 6.545565104832e-05
  803 KSP Residual norm 7.008269249873e-05
  804 KSP Residual norm 6.981018823994e-05
  805 KSP Residual norm 6.381899885451e-05
  806 KSP Residual norm 6.016056007871e-05
  807 KSP Residual norm 6.107484493908e-05
  808 KSP Residual norm 6.474605984739e-05
  809 KSP Residual norm 6.613826694597e-05
  810 KSP Residual norm 6.349749633887e-05
  811 KSP Residual norm 5.804077916330e-05
  812 KSP Residual norm 5.587455640175e-05
  813 KSP Residual norm 5.666206285036e-05
  814 KSP Residual norm 5.483579564532e-05
  815 KSP Residual norm 4.989095365380e-05
  816 KSP Residual norm 4.714945287635e-05
  817 KSP Residual norm 5.012346093655e-05
  818 KSP Residual norm 5.680103112343e-05
  819 KSP Residual norm 5.878234244686e-05
  820 KSP Residual norm 5.530042722349e-05
  821 KSP Residual norm 5.067697236267e-05
  822 KSP Residual norm 4.709562325876e-05
  823 KSP Residual norm 4.307295018147e-05
  824 KSP Residual norm 4.059350372359e-05
  825 KSP Residual norm 4.090732338720e-05
  826 KSP Residual norm 4.182747107168e-05
  827 KSP Residual norm 4.128606856004e-05
  828 KSP Residual norm 4.167323965934e-05
  829 KSP Residual norm 4.083423822730e-05
  830 KSP Residual norm 4.009354493496e-05
  831 KSP Residual norm 4.133885600597e-05
  832 KSP Residual norm 4.197541767529e-05
  833 KSP Residual norm 4.240937926697e-05
  834 KSP Residual norm 4.873737639661e-05
  835 KSP Residual norm 5.696733311686e-05
  836 KSP Residual norm 6.255019564041e-05
  837 KSP Residual norm 6.258981459509e-05
  838 KSP Residual norm 5.799777851960e-05
  839 KSP Residual norm 5.684643664611e-05
  840 KSP Residual norm 5.932739216666e-05
  841 KSP Residual norm 5.953921917871e-05
  842 KSP Residual norm 5.672027683065e-05
  843 KSP Residual norm 5.636113048167e-05
  844 KSP Residual norm 6.045847179428e-05
  845 KSP Residual norm 6.485229209418e-05
  846 KSP Residual norm 6.369430030058e-05
  847 KSP Residual norm 6.300389895430e-05
  848 KSP Residual norm 6.544712222617e-05
  849 KSP Residual norm 7.000971984079e-05
  850 KSP Residual norm 7.133287306655e-05
  851 KSP Residual norm 7.087058130692e-05
  852 KSP Residual norm 7.337204849559e-05
  853 KSP Residual norm 7.711310420568e-05
  854 KSP Residual norm 7.785400856908e-05
  855 KSP Residual norm 7.881065966625e-05
  856 KSP Residual norm 7.896284636192e-05
  857 KSP Residual norm 8.010917447026e-05
  858 KSP Residual norm 8.460404292117e-05
  859 KSP Residual norm 8.901098830854e-05
  860 KSP Residual norm 8.494241143635e-05
  861 KSP Residual norm 7.914195701307e-05
  862 KSP Residual norm 7.588697085016e-05
  863 KSP Residual norm 7.264635006538e-05
  864 KSP Residual norm 6.564966440332e-05
  865 KSP Residual norm 5.851261779231e-05
  866 KSP Residual norm 5.294605912401e-05
  867 KSP Residual norm 4.968567211044e-05
  868 KSP Residual norm 4.960398891237e-05
  869 KSP Residual norm 4.922579626325e-05
  870 KSP Residual norm 5.013636474296e-05
  871 KSP Residual norm 5.279049511588e-05
  872 KSP Residual norm 5.572227844882e-05
  873 KSP Residual norm 5.674823503410e-05
  874 KSP Residual norm 6.011556345170e-05
  875 KSP Residual norm 6.513883896674e-05
  876 KSP Residual norm 7.072326382073e-05
  877 KSP Residual norm 7.659461421539e-05
  878 KSP Residual norm 7.971907062354e-05
  879 KSP Residual norm 7.385907552013e-05
  880 KSP Residual norm 6.590828765923e-05
  881 KSP Residual norm 5.962504329792e-05
  882 KSP Residual norm 5.670352987848e-05
  883 KSP Residual norm 5.571788468776e-05
  884 KSP Residual norm 5.515800176446e-05
  885 KSP Residual norm 5.002533023182e-05
  886 KSP Residual norm 4.419356033551e-05
  887 KSP Residual norm 3.993527786211e-05
  888 KSP Residual norm 3.816981615607e-05
  889 KSP Residual norm 3.919361614400e-05
  890 KSP Residual norm 4.129046356636e-05
  891 KSP Residual norm 4.286727239251e-05
  892 KSP Residual norm 4.516223594829e-05
  893 KSP Residual norm 4.638919513952e-05
  894 KSP Residual norm 4.521823965958e-05
  895 KSP Residual norm 4.265602312420e-05
  896 KSP Residual norm 4.076417985548e-05
  897 KSP Residual norm 3.924967806215e-05
  898 KSP Residual norm 3.735191718126e-05
  899 KSP Residual norm 3.691413685076e-05
  900 KSP Residual norm 3.627989323275e-05
  901 KSP Residual norm 3.400508490191e-05
  902 KSP Residual norm 3.155137917680e-05
  903 KSP Residual norm 3.192270938184e-05
  904 KSP Residual norm 3.493742114852e-05
  905 KSP Residual norm 3.877090447324e-05
  906 KSP Residual norm 3.940302474632e-05
  907 KSP Residual norm 3.702545272101e-05
  908 KSP Residual norm 3.450793462990e-05
  909 KSP Residual norm 3.399691751787e-05
  910 KSP Residual norm 3.358578323570e-05
  911 KSP Residual norm 3.502480119750e-05
  912 KSP Residual norm 3.649252011529e-05
  913 KSP Residual norm 3.588661365164e-05
  914 KSP Residual norm 3.621832847822e-05
  915 KSP Residual norm 3.786731251138e-05
  916 KSP Residual norm 3.864898340458e-05
  917 KSP Residual norm 3.769276717839e-05
  918 KSP Residual norm 3.732307007879e-05
  919 KSP Residual norm 3.756836896410e-05
  920 KSP Residual norm 3.811016365236e-05
  921 KSP Residual norm 3.960184242316e-05
  922 KSP Residual norm 3.754853856014e-05
  923 KSP Residual norm 3.502531618859e-05
  924 KSP Residual norm 3.546497303336e-05
  925 KSP Residual norm 3.828498211723e-05
  926 KSP Residual norm 3.841815082714e-05
  927 KSP Residual norm 3.539118184106e-05
  928 KSP Residual norm 3.161946113532e-05
  929 KSP Residual norm 3.138660505138e-05
  930 KSP Residual norm 3.357606197689e-05
  931 KSP Residual norm 3.717370565927e-05
  932 KSP Residual norm 3.968632605302e-05
  933 KSP Residual norm 4.044165822633e-05
  934 KSP Residual norm 4.131508740771e-05
  935 KSP Residual norm 4.136491939955e-05
  936 KSP Residual norm 4.126148013072e-05
  937 KSP Residual norm 4.041128025313e-05
  938 KSP Residual norm 3.961551627917e-05
  939 KSP Residual norm 3.856713286085e-05
  940 KSP Residual norm 3.769782531769e-05
  941 KSP Residual norm 3.616050833389e-05
  942 KSP Residual norm 3.471734940026e-05
  943 KSP Residual norm 3.468245629033e-05
  944 KSP Residual norm 3.453209177167e-05
  945 KSP Residual norm 3.534618388985e-05
  946 KSP Residual norm 3.487643302181e-05
  947 KSP Residual norm 3.495424884110e-05
  948 KSP Residual norm 3.559720584220e-05
  949 KSP Residual norm 3.541169440522e-05
  950 KSP Residual norm 3.405633898017e-05
  951 KSP Residual norm 3.415280558028e-05
  952 KSP Residual norm 3.415306079075e-05
  953 KSP Residual norm 3.307928211253e-05
  954 KSP Residual norm 3.394163735346e-05
  955 KSP Residual norm 3.534878641275e-05
  956 KSP Residual norm 3.714284133726e-05
  957 KSP Residual norm 3.771075874784e-05
  958 KSP Residual norm 3.569087402792e-05
  959 KSP Residual norm 3.404466048865e-05
  960 KSP Residual norm 3.514047102071e-05
  961 KSP Residual norm 3.692863480980e-05
  962 KSP Residual norm 3.739129967007e-05
  963 KSP Residual norm 3.609985665880e-05
  964 KSP Residual norm 3.510310414868e-05
  965 KSP Residual norm 3.469631543251e-05
  966 KSP Residual norm 3.380512839358e-05
  967 KSP Residual norm 3.333491012338e-05
  968 KSP Residual norm 3.183321577933e-05
  969 KSP Residual norm 3.072721814543e-05
  970 KSP Residual norm 2.929011342762e-05
  971 KSP Residual norm 2.792719450245e-05
  972 KSP Residual norm 2.819164627017e-05
  973 KSP Residual norm 2.911130705426e-05
  974 KSP Residual norm 2.961573082092e-05
  975 KSP Residual norm 2.787466833860e-05
  976 KSP Residual norm 2.514815034601e-05
  977 KSP Residual norm 2.517415015423e-05
  978 KSP Residual norm 2.676061088536e-05
  979 KSP Residual norm 2.725100983154e-05
  980 KSP Residual norm 2.761770527425e-05
  981 KSP Residual norm 2.921250108395e-05
  982 KSP Residual norm 3.098971688663e-05
  983 KSP Residual norm 3.139010283323e-05
  984 KSP Residual norm 3.226622522077e-05
  985 KSP Residual norm 3.501733989075e-05
  986 KSP Residual norm 4.087763626811e-05
  987 KSP Residual norm 4.360030797778e-05
  988 KSP Residual norm 4.141821873716e-05
  989 KSP Residual norm 3.967171439491e-05
  990 KSP Residual norm 4.110731618745e-05
  991 KSP Residual norm 4.479467375231e-05
  992 KSP Residual norm 4.446293766934e-05
  993 KSP Residual norm 4.339398266916e-05
  994 KSP Residual norm 4.253386550079e-05
  995 KSP Residual norm 3.998397695582e-05
  996 KSP Residual norm 3.558845767369e-05
  997 KSP Residual norm 3.168519622176e-05
  998 KSP Residual norm 2.899636669744e-05
  999 KSP Residual norm 2.800404914530e-05
  1000 KSP Residual norm 2.632930089158e-05
  1001 KSP Residual norm 2.432386037413e-05
  1002 KSP Residual norm 2.410110010576e-05
  1003 KSP Residual norm 2.678003895453e-05
  1004 KSP Residual norm 2.857706541637e-05
  1005 KSP Residual norm 2.896473694628e-05
  1006 KSP Residual norm 2.911200657526e-05
  1007 KSP Residual norm 3.064307874813e-05
  1008 KSP Residual norm 3.240707387696e-05
  1009 KSP Residual norm 3.282702607295e-05
  1010 KSP Residual norm 3.080647632135e-05
  1011 KSP Residual norm 3.002799060369e-05
  1012 KSP Residual norm 3.191194591343e-05
  1013 KSP Residual norm 3.307073954253e-05
  1014 KSP Residual norm 3.139573911125e-05
  1015 KSP Residual norm 2.994902790213e-05
  1016 KSP Residual norm 3.121351597704e-05
  1017 KSP Residual norm 3.516775342604e-05
  1018 KSP Residual norm 3.695495151602e-05
  1019 KSP Residual norm 3.603942107279e-05
  1020 KSP Residual norm 3.393762259557e-05
  1021 KSP Residual norm 3.238363596203e-05
  1022 KSP Residual norm 3.131187867504e-05
  1023 KSP Residual norm 2.953730496856e-05
  1024 KSP Residual norm 2.733207091346e-05
  1025 KSP Residual norm 2.535581658465e-05
  1026 KSP Residual norm 2.447094026325e-05
  1027 KSP Residual norm 2.352697197001e-05
  1028 KSP Residual norm 2.155594209180e-05
  1029 KSP Residual norm 1.965614719135e-05
  1030 KSP Residual norm 1.887552175669e-05
  1031 KSP Residual norm 2.029984807722e-05
  1032 KSP Residual norm 2.217189394586e-05
  1033 KSP Residual norm 2.188841397438e-05
  1034 KSP Residual norm 2.048334711720e-05
  1035 KSP Residual norm 1.999122277764e-05
  1036 KSP Residual norm 2.042632289208e-05
  1037 KSP Residual norm 2.189170277045e-05
  1038 KSP Residual norm 2.315714798040e-05
  1039 KSP Residual norm 2.324923891951e-05
  1040 KSP Residual norm 2.195190483420e-05
  1041 KSP Residual norm 2.152830707271e-05
  1042 KSP Residual norm 2.151685721855e-05
  1043 KSP Residual norm 2.039556159966e-05
  1044 KSP Residual norm 1.876175855317e-05
  1045 KSP Residual norm 1.752390057233e-05
  1046 KSP Residual norm 1.732328425934e-05
  1047 KSP Residual norm 1.827987447603e-05
  1048 KSP Residual norm 1.928677580358e-05
  1049 KSP Residual norm 1.892069919774e-05
  1050 KSP Residual norm 1.852045496008e-05
  1051 KSP Residual norm 1.909455420889e-05
  1052 KSP Residual norm 1.963197102343e-05
  1053 KSP Residual norm 1.878750381399e-05
  1054 KSP Residual norm 1.801423987327e-05
  1055 KSP Residual norm 1.794593205187e-05
  1056 KSP Residual norm 1.784578915985e-05
  1057 KSP Residual norm 1.824167830530e-05
  1058 KSP Residual norm 1.762008935708e-05
  1059 KSP Residual norm 1.725736868901e-05
  1060 KSP Residual norm 1.733529401393e-05
  1061 KSP Residual norm 1.675111428068e-05
  1062 KSP Residual norm 1.560285858569e-05
  1063 KSP Residual norm 1.503923284598e-05
  1064 KSP Residual norm 1.552705067186e-05
  1065 KSP Residual norm 1.666277765664e-05
  1066 KSP Residual norm 1.704086323254e-05
  1067 KSP Residual norm 1.647450535555e-05
  1068 KSP Residual norm 1.575953685271e-05
  1069 KSP Residual norm 1.458482805043e-05
  1070 KSP Residual norm 1.352251766894e-05
  1071 KSP Residual norm 1.312217340347e-05
  1072 KSP Residual norm 1.352632846867e-05
  1073 KSP Residual norm 1.413483063328e-05
  1074 KSP Residual norm 1.434560041448e-05
  1075 KSP Residual norm 1.475811454994e-05
  1076 KSP Residual norm 1.505897058670e-05
  1077 KSP Residual norm 1.546970593577e-05
  1078 KSP Residual norm 1.620499935072e-05
  1079 KSP Residual norm 1.736508480898e-05
  1080 KSP Residual norm 1.797065636785e-05
  1081 KSP Residual norm 1.794718371417e-05
  1082 KSP Residual norm 1.652737141517e-05
  1083 KSP Residual norm 1.529827929191e-05
  1084 KSP Residual norm 1.449423167720e-05
  1085 KSP Residual norm 1.376733087223e-05
  1086 KSP Residual norm 1.268819028001e-05
  1087 KSP Residual norm 1.186357337288e-05
  1088 KSP Residual norm 1.214148800488e-05
  1089 KSP Residual norm 1.329666986000e-05
  1090 KSP Residual norm 1.419553187845e-05
  1091 KSP Residual norm 1.458319413329e-05
  1092 KSP Residual norm 1.462430506569e-05
  1093 KSP Residual norm 1.425893945780e-05
  1094 KSP Residual norm 1.380815982992e-05
  1095 KSP Residual norm 1.371594388089e-05
  1096 KSP Residual norm 1.378047341795e-05
  1097 KSP Residual norm 1.392099279805e-05
  1098 KSP Residual norm 1.432358491796e-05
  1099 KSP Residual norm 1.512359341605e-05
  1100 KSP Residual norm 1.522604555772e-05
  1101 KSP Residual norm 1.501582067235e-05
  1102 KSP Residual norm 1.454323377181e-05
  1103 KSP Residual norm 1.351192087360e-05
  1104 KSP Residual norm 1.307031902499e-05
  1105 KSP Residual norm 1.249593230800e-05
  1106 KSP Residual norm 1.158914294459e-05
  1107 KSP Residual norm 1.085711596923e-05
  1108 KSP Residual norm 1.129323130221e-05
  1109 KSP Residual norm 1.203241273996e-05
  1110 KSP Residual norm 1.189488466156e-05
  1111 KSP Residual norm 1.179902996396e-05
  1112 KSP Residual norm 1.155449286810e-05
  1113 KSP Residual norm 1.119127942279e-05
  1114 KSP Residual norm 1.095314824700e-05
  1115 KSP Residual norm 1.113697658218e-05
  1116 KSP Residual norm 1.183016228919e-05
  1117 KSP Residual norm 1.235434182082e-05
  1118 KSP Residual norm 1.234300362882e-05
  1119 KSP Residual norm 1.207958155940e-05
  1120 KSP Residual norm 1.123744155387e-05
  1121 KSP Residual norm 1.041139367663e-05
  1122 KSP Residual norm 1.028332002076e-05
  1123 KSP Residual norm 1.036861254659e-05
  1124 KSP Residual norm 1.029357216562e-05
  1125 KSP Residual norm 1.056249546759e-05
  1126 KSP Residual norm 1.117827232537e-05
  1127 KSP Residual norm 1.191528768311e-05
  1128 KSP Residual norm 1.236699646248e-05
  1129 KSP Residual norm 1.265404831743e-05
  1130 KSP Residual norm 1.259697291451e-05
  1131 KSP Residual norm 1.252740788379e-05
  1132 KSP Residual norm 1.285626617730e-05
  1133 KSP Residual norm 1.300558343903e-05
  1134 KSP Residual norm 1.381016789594e-05
  1135 KSP Residual norm 1.431343942265e-05
  1136 KSP Residual norm 1.451950274356e-05
  1137 KSP Residual norm 1.532300867493e-05
  1138 KSP Residual norm 1.661444959755e-05
  1139 KSP Residual norm 1.719736506697e-05
  1140 KSP Residual norm 1.681549851108e-05
  1141 KSP Residual norm 1.653265064443e-05
  1142 KSP Residual norm 1.671917219582e-05
  1143 KSP Residual norm 1.782332039009e-05
  1144 KSP Residual norm 1.994601751655e-05
  1145 KSP Residual norm 2.077328982285e-05
  1146 KSP Residual norm 1.941233838159e-05
  1147 KSP Residual norm 1.721474036960e-05
  1148 KSP Residual norm 1.640331542375e-05
  1149 KSP Residual norm 1.673463384373e-05
  1150 KSP Residual norm 1.706161042198e-05
  1151 KSP Residual norm 1.750035673268e-05
  1152 KSP Residual norm 1.758683201480e-05
  1153 KSP Residual norm 1.807147151558e-05
  1154 KSP Residual norm 1.920330248147e-05
  1155 KSP Residual norm 1.990715240609e-05
  1156 KSP Residual norm 2.142921951081e-05
  1157 KSP Residual norm 2.363394653277e-05
  1158 KSP Residual norm 2.409679646693e-05
  1159 KSP Residual norm 2.252848922981e-05
  1160 KSP Residual norm 2.043574500195e-05
  1161 KSP Residual norm 1.980661156307e-05
  1162 KSP Residual norm 2.013229780946e-05
  1163 KSP Residual norm 2.114143261374e-05
  1164 KSP Residual norm 2.237477533649e-05
  1165 KSP Residual norm 2.193809826587e-05
  1166 KSP Residual norm 2.115476431617e-05
  1167 KSP Residual norm 2.057247242821e-05
  1168 KSP Residual norm 2.107587792497e-05
  1169 KSP Residual norm 2.127763683881e-05
  1170 KSP Residual norm 2.152671341555e-05
  1171 KSP Residual norm 2.133790325110e-05
  1172 KSP Residual norm 2.195190825592e-05
  1173 KSP Residual norm 2.181786865731e-05
  1174 KSP Residual norm 2.166847154574e-05
  1175 KSP Residual norm 2.198849117136e-05
  1176 KSP Residual norm 2.317094973172e-05
  1177 KSP Residual norm 2.466189411577e-05
  1178 KSP Residual norm 2.533260579389e-05
  1179 KSP Residual norm 2.496896232496e-05
  1180 KSP Residual norm 2.456039980620e-05
  1181 KSP Residual norm 2.388173873804e-05
  1182 KSP Residual norm 2.220204713040e-05
  1183 KSP Residual norm 2.155479071116e-05
  1184 KSP Residual norm 2.090194259046e-05
  1185 KSP Residual norm 1.975397097235e-05
  1186 KSP Residual norm 1.849788088781e-05
  1187 KSP Residual norm 1.759917041498e-05
  1188 KSP Residual norm 1.735589344613e-05
  1189 KSP Residual norm 1.838587390698e-05
  1190 KSP Residual norm 2.048981805969e-05
  1191 KSP Residual norm 2.223793868762e-05
  1192 KSP Residual norm 2.364503403067e-05
  1193 KSP Residual norm 2.631922877562e-05
  1194 KSP Residual norm 2.873945965252e-05
  1195 KSP Residual norm 2.872939709810e-05
  1196 KSP Residual norm 2.788731961436e-05
  1197 KSP Residual norm 2.868757234110e-05
  1198 KSP Residual norm 3.144223612869e-05
  1199 KSP Residual norm 3.432982852138e-05
  1200 KSP Residual norm 3.415188672221e-05
  1201 KSP Residual norm 3.201228456020e-05
  1202 KSP Residual norm 3.101834145042e-05
  1203 KSP Residual norm 3.230300590884e-05
  1204 KSP Residual norm 3.433512799804e-05
  1205 KSP Residual norm 3.528747492801e-05
  1206 KSP Residual norm 3.516125863969e-05
  1207 KSP Residual norm 3.561417037081e-05
  1208 KSP Residual norm 3.602552478765e-05
  1209 KSP Residual norm 3.616055397628e-05
  1210 KSP Residual norm 3.724544779553e-05
  1211 KSP Residual norm 3.751020115570e-05
  1212 KSP Residual norm 3.775147405145e-05
  1213 KSP Residual norm 3.846972462633e-05
  1214 KSP Residual norm 3.921777794086e-05
  1215 KSP Residual norm 4.045578824687e-05
  1216 KSP Residual norm 4.263883479369e-05
  1217 KSP Residual norm 4.442341519977e-05
  1218 KSP Residual norm 4.228423620976e-05
  1219 KSP Residual norm 3.997608202466e-05
  1220 KSP Residual norm 3.974303821045e-05
  1221 KSP Residual norm 4.166416907785e-05
  1222 KSP Residual norm 4.337337531367e-05
  1223 KSP Residual norm 4.304801730325e-05
  1224 KSP Residual norm 3.972456679578e-05
  1225 KSP Residual norm 3.674149351926e-05
  1226 KSP Residual norm 3.542568231494e-05
  1227 KSP Residual norm 3.559223370832e-05
  1228 KSP Residual norm 3.564620991575e-05
  1229 KSP Residual norm 3.624345317041e-05
  1230 KSP Residual norm 3.688180849276e-05
  1231 KSP Residual norm 3.747624167001e-05
  1232 KSP Residual norm 3.667702842277e-05
  1233 KSP Residual norm 3.521168601182e-05
  1234 KSP Residual norm 3.685882616824e-05
  1235 KSP Residual norm 4.045385557802e-05
  1236 KSP Residual norm 4.159322026787e-05
  1237 KSP Residual norm 3.990731576483e-05
  1238 KSP Residual norm 4.128498874312e-05
  1239 KSP Residual norm 4.380784910485e-05
  1240 KSP Residual norm 4.316924851041e-05
  1241 KSP Residual norm 3.912573008241e-05
  1242 KSP Residual norm 3.851391161173e-05
  1243 KSP Residual norm 4.129838956987e-05
  1244 KSP Residual norm 4.614278501035e-05
  1245 KSP Residual norm 5.008320879065e-05
  1246 KSP Residual norm 4.958150888960e-05
  1247 KSP Residual norm 4.627384151002e-05
  1248 KSP Residual norm 4.311350937799e-05
  1249 KSP Residual norm 4.062899886144e-05
  1250 KSP Residual norm 3.775718522903e-05
  1251 KSP Residual norm 3.698787628953e-05
  1252 KSP Residual norm 3.783599369550e-05
  1253 KSP Residual norm 3.676383028426e-05
  1254 KSP Residual norm 3.317555377620e-05
  1255 KSP Residual norm 3.107385108569e-05
  1256 KSP Residual norm 3.129533136678e-05
  1257 KSP Residual norm 3.289965152911e-05
  1258 KSP Residual norm 3.635528758498e-05
  1259 KSP Residual norm 3.994005559172e-05
  1260 KSP Residual norm 4.007643275249e-05
  1261 KSP Residual norm 3.740406633791e-05
  1262 KSP Residual norm 3.454688516715e-05
  1263 KSP Residual norm 3.373203661175e-05
  1264 KSP Residual norm 3.502872106137e-05
  1265 KSP Residual norm 3.689388016819e-05
  1266 KSP Residual norm 3.801244967261e-05
  1267 KSP Residual norm 3.751978305285e-05
  1268 KSP Residual norm 3.646629208410e-05
  1269 KSP Residual norm 3.660349614908e-05
  1270 KSP Residual norm 3.801554331752e-05
  1271 KSP Residual norm 3.920798039746e-05
  1272 KSP Residual norm 3.928361080415e-05
  1273 KSP Residual norm 3.726311168390e-05
  1274 KSP Residual norm 3.695969197323e-05
  1275 KSP Residual norm 3.834103547396e-05
  1276 KSP Residual norm 3.940585188190e-05
  1277 KSP Residual norm 3.981893995619e-05
  1278 KSP Residual norm 4.000054990565e-05
  1279 KSP Residual norm 3.886802488370e-05
  1280 KSP Residual norm 3.948519609008e-05
  1281 KSP Residual norm 4.258115972935e-05
  1282 KSP Residual norm 4.300800633516e-05
  1283 KSP Residual norm 4.348818985512e-05
  1284 KSP Residual norm 4.271386858815e-05
  1285 KSP Residual norm 4.174299748199e-05
  1286 KSP Residual norm 4.071149576460e-05
  1287 KSP Residual norm 4.197932276342e-05
  1288 KSP Residual norm 4.333901424858e-05
  1289 KSP Residual norm 4.247450953939e-05
  1290 KSP Residual norm 4.269959166605e-05
  1291 KSP Residual norm 4.266576981810e-05
  1292 KSP Residual norm 4.154941891414e-05
  1293 KSP Residual norm 4.003605631722e-05
  1294 KSP Residual norm 3.893957454975e-05
  1295 KSP Residual norm 3.689181013469e-05
  1296 KSP Residual norm 3.664121308226e-05
  1297 KSP Residual norm 4.045006194263e-05
  1298 KSP Residual norm 4.535591760325e-05
  1299 KSP Residual norm 4.593219719312e-05
  1300 KSP Residual norm 4.460326962986e-05
  1301 KSP Residual norm 4.527225284020e-05
  1302 KSP Residual norm 5.164373179724e-05
  1303 KSP Residual norm 5.987305457757e-05
  1304 KSP Residual norm 6.205531458447e-05
  1305 KSP Residual norm 5.954569824587e-05
  1306 KSP Residual norm 5.760371519062e-05
  1307 KSP Residual norm 5.936824587461e-05
  1308 KSP Residual norm 6.002654389829e-05
  1309 KSP Residual norm 6.036642176803e-05
  1310 KSP Residual norm 6.500378640290e-05
  1311 KSP Residual norm 7.019329103066e-05
  1312 KSP Residual norm 7.036316552840e-05
  1313 KSP Residual norm 6.619114297019e-05
  1314 KSP Residual norm 6.516574324979e-05
  1315 KSP Residual norm 6.876747422704e-05
  1316 KSP Residual norm 7.564762180329e-05
  1317 KSP Residual norm 8.037624907237e-05
  1318 KSP Residual norm 8.193683472970e-05
  1319 KSP Residual norm 8.683249399690e-05
  1320 KSP Residual norm 9.371357114987e-05
  1321 KSP Residual norm 9.343194241992e-05
  1322 KSP Residual norm 8.770997760191e-05
  1323 KSP Residual norm 8.062126863638e-05
  1324 KSP Residual norm 8.104231326508e-05
  1325 KSP Residual norm 8.709901267359e-05
  1326 KSP Residual norm 8.936865320833e-05
  1327 KSP Residual norm 8.671477464883e-05
  1328 KSP Residual norm 8.014939303772e-05
  1329 KSP Residual norm 7.596287547648e-05
  1330 KSP Residual norm 6.995401113159e-05
  1331 KSP Residual norm 6.668331522629e-05
  1332 KSP Residual norm 6.802303917520e-05
  1333 KSP Residual norm 7.177391216996e-05
  1334 KSP Residual norm 7.162905370631e-05
  1335 KSP Residual norm 6.833001334919e-05
  1336 KSP Residual norm 6.678695263480e-05
  1337 KSP Residual norm 6.904844304018e-05
  1338 KSP Residual norm 7.163346962269e-05
  1339 KSP Residual norm 7.111063634423e-05
  1340 KSP Residual norm 7.269599442416e-05
  1341 KSP Residual norm 7.943805397785e-05
  1342 KSP Residual norm 8.400114478840e-05
  1343 KSP Residual norm 8.241201438188e-05
  1344 KSP Residual norm 7.566513059460e-05
  1345 KSP Residual norm 6.889118087063e-05
  1346 KSP Residual norm 6.220672330154e-05
  1347 KSP Residual norm 5.931225235730e-05
  1348 KSP Residual norm 5.757243576606e-05
  1349 KSP Residual norm 5.572888549533e-05
  1350 KSP Residual norm 5.498457521379e-05
  1351 KSP Residual norm 5.518771074732e-05
  1352 KSP Residual norm 5.733427133201e-05
  1353 KSP Residual norm 6.062102910322e-05
  1354 KSP Residual norm 6.820407412865e-05
  1355 KSP Residual norm 7.476185844029e-05
  1356 KSP Residual norm 8.237097531704e-05
  1357 KSP Residual norm 9.054978929549e-05
  1358 KSP Residual norm 9.647495990443e-05
  1359 KSP Residual norm 1.015092736828e-04
  1360 KSP Residual norm 1.028225049059e-04
  1361 KSP Residual norm 9.798028846354e-05
  1362 KSP Residual norm 9.039556709578e-05
  1363 KSP Residual norm 8.389664302484e-05
  1364 KSP Residual norm 7.823822831689e-05
  1365 KSP Residual norm 7.419333670853e-05
  1366 KSP Residual norm 7.300370426151e-05
  1367 KSP Residual norm 7.234038070823e-05
  1368 KSP Residual norm 7.212059653405e-05
  1369 KSP Residual norm 7.125841363158e-05
  1370 KSP Residual norm 7.343721778706e-05
  1371 KSP Residual norm 7.882204533231e-05
  1372 KSP Residual norm 7.712987258872e-05
  1373 KSP Residual norm 7.660542421638e-05
  1374 KSP Residual norm 8.415792908016e-05
  1375 KSP Residual norm 9.632389504333e-05
  1376 KSP Residual norm 1.042950740652e-04
  1377 KSP Residual norm 1.007262163343e-04
  1378 KSP Residual norm 9.735193935163e-05
  1379 KSP Residual norm 9.998264987893e-05
  1380 KSP Residual norm 1.024789508215e-04
  1381 KSP Residual norm 1.081016407727e-04
  1382 KSP Residual norm 1.115667007694e-04
  1383 KSP Residual norm 1.135639221269e-04
  1384 KSP Residual norm 1.148991265655e-04
  1385 KSP Residual norm 1.153410018279e-04
  1386 KSP Residual norm 1.139862307524e-04
  1387 KSP Residual norm 1.045443410799e-04
  1388 KSP Residual norm 9.185367300655e-05
  1389 KSP Residual norm 8.329384258037e-05
  1390 KSP Residual norm 8.001140632603e-05
  1391 KSP Residual norm 7.493728611921e-05
  1392 KSP Residual norm 7.292835534873e-05
  1393 KSP Residual norm 7.509366618646e-05
  1394 KSP Residual norm 8.006868782785e-05
  1395 KSP Residual norm 8.764644940914e-05
  1396 KSP Residual norm 9.989504142827e-05
  1397 KSP Residual norm 1.070078296509e-04
  1398 KSP Residual norm 1.039924025447e-04
  1399 KSP Residual norm 1.027548454829e-04
  1400 KSP Residual norm 1.058811862576e-04
  1401 KSP Residual norm 1.089397698242e-04
  1402 KSP Residual norm 1.106481268775e-04
  1403 KSP Residual norm 1.089864894098e-04
  1404 KSP Residual norm 1.093765171370e-04
  1405 KSP Residual norm 1.086321145925e-04
  1406 KSP Residual norm 1.146602583241e-04
  1407 KSP Residual norm 1.225824540045e-04
  1408 KSP Residual norm 1.231980975968e-04
  1409 KSP Residual norm 1.284520816972e-04
  1410 KSP Residual norm 1.385983200873e-04
  1411 KSP Residual norm 1.405809859573e-04
  1412 KSP Residual norm 1.299828991748e-04
  1413 KSP Residual norm 1.110307584574e-04
  1414 KSP Residual norm 1.021153786946e-04
  1415 KSP Residual norm 1.029278954802e-04
  1416 KSP Residual norm 1.074367374081e-04
  1417 KSP Residual norm 1.124171588610e-04
  1418 KSP Residual norm 1.201247464327e-04
  1419 KSP Residual norm 1.317145155448e-04
  1420 KSP Residual norm 1.489862486301e-04
  1421 KSP Residual norm 1.595026769464e-04
  1422 KSP Residual norm 1.514012822946e-04
  1423 KSP Residual norm 1.310329445374e-04
  1424 KSP Residual norm 1.195800115250e-04
  1425 KSP Residual norm 1.178685991958e-04
  1426 KSP Residual norm 1.216694816007e-04
  1427 KSP Residual norm 1.313393293211e-04
  1428 KSP Residual norm 1.392408683093e-04
  1429 KSP Residual norm 1.440968800500e-04
  1430 KSP Residual norm 1.427586015202e-04
  1431 KSP Residual norm 1.438339844635e-04
  1432 KSP Residual norm 1.449906679223e-04
  1433 KSP Residual norm 1.277619836810e-04
  1434 KSP Residual norm 1.057032943485e-04
  1435 KSP Residual norm 9.267085559955e-05
  1436 KSP Residual norm 8.738522330196e-05
  1437 KSP Residual norm 8.824975655932e-05
  1438 KSP Residual norm 9.472655493848e-05
  1439 KSP Residual norm 1.059474486519e-04
  1440 KSP Residual norm 1.100064532365e-04
  1441 KSP Residual norm 1.114010848483e-04
  1442 KSP Residual norm 1.143666660417e-04
  1443 KSP Residual norm 1.163007695899e-04
  1444 KSP Residual norm 1.115201324767e-04
  1445 KSP Residual norm 1.009536173534e-04
  1446 KSP Residual norm 9.504400155876e-05
  1447 KSP Residual norm 9.835501584485e-05
  1448 KSP Residual norm 1.070136122688e-04
  1449 KSP Residual norm 1.082794841576e-04
  1450 KSP Residual norm 1.008186278689e-04
  1451 KSP Residual norm 9.378596340103e-05
  1452 KSP Residual norm 9.674802899286e-05
  1453 KSP Residual norm 1.123931447308e-04
  1454 KSP Residual norm 1.315393961540e-04
  1455 KSP Residual norm 1.402711342360e-04
  1456 KSP Residual norm 1.458315545479e-04
  1457 KSP Residual norm 1.552995703385e-04
  1458 KSP Residual norm 1.657152336409e-04
  1459 KSP Residual norm 1.593341671613e-04
  1460 KSP Residual norm 1.563471525558e-04
  1461 KSP Residual norm 1.588853876837e-04
  1462 KSP Residual norm 1.524736891738e-04
  1463 KSP Residual norm 1.353066547178e-04
  1464 KSP Residual norm 1.204972649653e-04
  1465 KSP Residual norm 1.260967620843e-04
  1466 KSP Residual norm 1.506863238403e-04
  1467 KSP Residual norm 1.666997387382e-04
  1468 KSP Residual norm 1.553635940061e-04
  1469 KSP Residual norm 1.338149034534e-04
  1470 KSP Residual norm 1.220913441558e-04
  1471 KSP Residual norm 1.360335358119e-04
  1472 KSP Residual norm 1.672880813558e-04
  1473 KSP Residual norm 1.949455011127e-04
  1474 KSP Residual norm 2.062393512148e-04
  1475 KSP Residual norm 1.959926439237e-04
  1476 KSP Residual norm 1.871835412853e-04
  1477 KSP Residual norm 1.981082422628e-04
  1478 KSP Residual norm 2.167921875555e-04
  1479 KSP Residual norm 2.304144613608e-04
  1480 KSP Residual norm 2.347299849131e-04
  1481 KSP Residual norm 2.106318475696e-04
  1482 KSP Residual norm 1.821753317710e-04
  1483 KSP Residual norm 1.681929636346e-04
  1484 KSP Residual norm 1.747095087648e-04
  1485 KSP Residual norm 1.889446093134e-04
  1486 KSP Residual norm 1.952797529263e-04
  1487 KSP Residual norm 1.918553147387e-04
  1488 KSP Residual norm 2.059418996607e-04
  1489 KSP Residual norm 2.404820817266e-04
  1490 KSP Residual norm 2.777832517328e-04
  1491 KSP Residual norm 3.050169049100e-04
  1492 KSP Residual norm 2.878531889854e-04
  1493 KSP Residual norm 2.517050364202e-04
  1494 KSP Residual norm 2.275447937233e-04
  1495 KSP Residual norm 2.156996084019e-04
  1496 KSP Residual norm 2.076764828401e-04
  1497 KSP Residual norm 1.976869922882e-04
  1498 KSP Residual norm 1.820992488223e-04
  1499 KSP Residual norm 1.614057800434e-04
  1500 KSP Residual norm 1.480127461511e-04
  1501 KSP Residual norm 1.469893306410e-04
  1502 KSP Residual norm 1.522980439938e-04
  1503 KSP Residual norm 1.636522251079e-04
  1504 KSP Residual norm 1.776184032761e-04
  1505 KSP Residual norm 2.083523362157e-04
  1506 KSP Residual norm 2.496504701915e-04
  1507 KSP Residual norm 2.812215206849e-04
  1508 KSP Residual norm 2.784790988798e-04
  1509 KSP Residual norm 2.402844999152e-04
  1510 KSP Residual norm 1.820074625126e-04
  1511 KSP Residual norm 1.490031511287e-04
  1512 KSP Residual norm 1.431029846309e-04
  1513 KSP Residual norm 1.500457008235e-04
  1514 KSP Residual norm 1.550159470974e-04
  1515 KSP Residual norm 1.583062812327e-04
  1516 KSP Residual norm 1.616413890558e-04
  1517 KSP Residual norm 1.563324738356e-04
  1518 KSP Residual norm 1.451139630464e-04
  1519 KSP Residual norm 1.392818441419e-04
  1520 KSP Residual norm 1.496392387252e-04
  1521 KSP Residual norm 1.593663216286e-04
  1522 KSP Residual norm 1.568803775052e-04
  1523 KSP Residual norm 1.523350116505e-04
  1524 KSP Residual norm 1.557883093996e-04
  1525 KSP Residual norm 1.510357333691e-04
  1526 KSP Residual norm 1.354069034118e-04
  1527 KSP Residual norm 1.222972372484e-04
  1528 KSP Residual norm 1.241395747719e-04
  1529 KSP Residual norm 1.343532970782e-04
  1530 KSP Residual norm 1.487204881163e-04
  1531 KSP Residual norm 1.519821471776e-04
  1532 KSP Residual norm 1.444061384137e-04
  1533 KSP Residual norm 1.430969233363e-04
  1534 KSP Residual norm 1.526761921572e-04
  1535 KSP Residual norm 1.669274030769e-04
  1536 KSP Residual norm 1.753079202012e-04
  1537 KSP Residual norm 1.704909620126e-04
  1538 KSP Residual norm 1.614814505517e-04
  1539 KSP Residual norm 1.588237564899e-04
  1540 KSP Residual norm 1.598958270834e-04
  1541 KSP Residual norm 1.632644581602e-04
  1542 KSP Residual norm 1.581711728837e-04
  1543 KSP Residual norm 1.487987729990e-04
  1544 KSP Residual norm 1.304004131744e-04
  1545 KSP Residual norm 1.132937840594e-04
  1546 KSP Residual norm 1.032210581236e-04
  1547 KSP Residual norm 1.044585401425e-04
  1548 KSP Residual norm 1.167320961009e-04
  1549 KSP Residual norm 1.293767937912e-04
  1550 KSP Residual norm 1.357861360011e-04
  1551 KSP Residual norm 1.392792584694e-04
  1552 KSP Residual norm 1.432964482430e-04
  1553 KSP Residual norm 1.552514086572e-04
  1554 KSP Residual norm 1.694185875703e-04
  1555 KSP Residual norm 1.636651967820e-04
  1556 KSP Residual norm 1.359970825612e-04
  1557 KSP Residual norm 1.123689241499e-04
  1558 KSP Residual norm 1.006181345949e-04
  1559 KSP Residual norm 1.069220379838e-04
  1560 KSP Residual norm 1.272952471881e-04
  1561 KSP Residual norm 1.736081543488e-04
  1562 KSP Residual norm 2.217745622057e-04
  1563 KSP Residual norm 2.278621758242e-04
  1564 KSP Residual norm 1.990014994625e-04
  1565 KSP Residual norm 1.689266518213e-04
  1566 KSP Residual norm 1.681749525813e-04
  1567 KSP Residual norm 1.902581122152e-04
  1568 KSP Residual norm 2.040611199586e-04
  1569 KSP Residual norm 2.073179254296e-04
  1570 KSP Residual norm 2.217986778912e-04
  1571 KSP Residual norm 2.416908640486e-04
  1572 KSP Residual norm 2.648648797321e-04
  1573 KSP Residual norm 2.584896671241e-04
  1574 KSP Residual norm 2.185625821977e-04
  1575 KSP Residual norm 1.786009216062e-04
  1576 KSP Residual norm 1.537224593758e-04
  1577 KSP Residual norm 1.365470057744e-04
  1578 KSP Residual norm 1.254963311650e-04
  1579 KSP Residual norm 1.190705830343e-04
  1580 KSP Residual norm 1.232265708413e-04
  1581 KSP Residual norm 1.405358292976e-04
  1582 KSP Residual norm 1.530863860904e-04
  1583 KSP Residual norm 1.589668759977e-04
  1584 KSP Residual norm 1.641396148775e-04
  1585 KSP Residual norm 1.833865995439e-04
  1586 KSP Residual norm 2.117121101827e-04
  1587 KSP Residual norm 2.140415485374e-04
  1588 KSP Residual norm 1.794579738421e-04
  1589 KSP Residual norm 1.406288970165e-04
  1590 KSP Residual norm 1.127013677563e-04
  1591 KSP Residual norm 1.044696342361e-04
  1592 KSP Residual norm 1.108871008629e-04
  1593 KSP Residual norm 1.231787173259e-04
  1594 KSP Residual norm 1.222547816366e-04
  1595 KSP Residual norm 9.991868931381e-05
  1596 KSP Residual norm 7.639041456275e-05
  1597 KSP Residual norm 6.937262226086e-05
  1598 KSP Residual norm 8.023027884463e-05
  1599 KSP Residual norm 1.078155202894e-04
  1600 KSP Residual norm 1.427796813838e-04
  1601 KSP Residual norm 1.658982453230e-04
  1602 KSP Residual norm 1.575573636873e-04
  1603 KSP Residual norm 1.266828454222e-04
  1604 KSP Residual norm 9.709971641665e-05
  1605 KSP Residual norm 8.256699101284e-05
  1606 KSP Residual norm 7.980579307520e-05
  1607 KSP Residual norm 8.855231505994e-05
  1608 KSP Residual norm 1.015907908585e-04
  1609 KSP Residual norm 1.179296948967e-04
  1610 KSP Residual norm 1.379364910157e-04
  1611 KSP Residual norm 1.420515360933e-04
  1612 KSP Residual norm 1.255570229919e-04
  1613 KSP Residual norm 1.117613901852e-04
  1614 KSP Residual norm 1.039501697027e-04
  1615 KSP Residual norm 9.364902609745e-05
  1616 KSP Residual norm 8.607081978396e-05
  1617 KSP Residual norm 8.909996006316e-05
  1618 KSP Residual norm 1.059468430216e-04
  1619 KSP Residual norm 1.350505931912e-04
  1620 KSP Residual norm 1.635870538549e-04
  1621 KSP Residual norm 1.763923518578e-04
  1622 KSP Residual norm 1.660306548737e-04
  1623 KSP Residual norm 1.510005028229e-04
  1624 KSP Residual norm 1.422726016876e-04
  1625 KSP Residual norm 1.457664446175e-04
  1626 KSP Residual norm 1.638357915378e-04
  1627 KSP Residual norm 1.845446520661e-04
  1628 KSP Residual norm 1.791976802638e-04
  1629 KSP Residual norm 1.623879267795e-04
  1630 KSP Residual norm 1.502923875717e-04
  1631 KSP Residual norm 1.418223077944e-04
  1632 KSP Residual norm 1.273254725453e-04
  1633 KSP Residual norm 1.184729548926e-04
  1634 KSP Residual norm 1.092059167818e-04
  1635 KSP Residual norm 9.048865879719e-05
  1636 KSP Residual norm 7.292817620989e-05
  1637 KSP Residual norm 6.099989036409e-05
  1638 KSP Residual norm 6.111855687351e-05
  1639 KSP Residual norm 7.591741259007e-05
  1640 KSP Residual norm 1.081490129047e-04
  1641 KSP Residual norm 1.357003835668e-04
  1642 KSP Residual norm 1.329226104717e-04
  1643 KSP Residual norm 1.014392111524e-04
  1644 KSP Residual norm 6.962606003180e-05
  1645 KSP Residual norm 5.186712928949e-05
  1646 KSP Residual norm 4.255776787865e-05
  1647 KSP Residual norm 4.344753395959e-05
  1648 KSP Residual norm 5.412434154219e-05
  1649 KSP Residual norm 7.552633147029e-05
  1650 KSP Residual norm 1.005940613207e-04
  1651 KSP Residual norm 1.144593357437e-04
  1652 KSP Residual norm 1.080392133403e-04
  1653 KSP Residual norm 8.518440784148e-05
  1654 KSP Residual norm 5.881334259044e-05
  1655 KSP Residual norm 4.817967366779e-05
  1656 KSP Residual norm 5.299823534953e-05
  1657 KSP Residual norm 7.136286729876e-05
  1658 KSP Residual norm 1.042100877155e-04
  1659 KSP Residual norm 1.313373841183e-04
  1660 KSP Residual norm 1.201537153493e-04
  1661 KSP Residual norm 9.018660112639e-05
  1662 KSP Residual norm 6.532562492553e-05
  1663 KSP Residual norm 5.649260300789e-05
  1664 KSP Residual norm 6.538773675498e-05
  1665 KSP Residual norm 9.596419339071e-05
  1666 KSP Residual norm 1.513165968446e-04
  1667 KSP Residual norm 1.951951397578e-04
  1668 KSP Residual norm 1.694458127844e-04
  1669 KSP Residual norm 1.133807508646e-04
  1670 KSP Residual norm 7.023736465041e-05
  1671 KSP Residual norm 4.806665406104e-05
  1672 KSP Residual norm 4.578182051396e-05
  1673 KSP Residual norm 6.055870487089e-05
  1674 KSP Residual norm 9.834221404856e-05
  1675 KSP Residual norm 1.550282956194e-04
  1676 KSP Residual norm 1.813010438116e-04
  1677 KSP Residual norm 1.335388506703e-04
  1678 KSP Residual norm 8.104089675768e-05
  1679 KSP Residual norm 6.041968601952e-05
  1680 KSP Residual norm 6.218671383638e-05
  1681 KSP Residual norm 8.430476290168e-05
  1682 KSP Residual norm 1.339875990970e-04
  1683 KSP Residual norm 2.050686414191e-04
  1684 KSP Residual norm 2.486792303236e-04
  1685 KSP Residual norm 2.158259204076e-04
  1686 KSP Residual norm 1.468145103665e-04
  1687 KSP Residual norm 9.535695331496e-05
  1688 KSP Residual norm 6.914309899951e-05
  1689 KSP Residual norm 5.874336791455e-05
  1690 KSP Residual norm 6.147096968782e-05
  1691 KSP Residual norm 8.132244892159e-05
  1692 KSP Residual norm 1.211144554351e-04
  1693 KSP Residual norm 1.598899522199e-04
  1694 KSP Residual norm 1.501443249046e-04
  1695 KSP Residual norm 9.928425049333e-05
  1696 KSP Residual norm 5.789109514265e-05
  1697 KSP Residual norm 3.735862717785e-05
  1698 KSP Residual norm 3.032327245044e-05
  1699 KSP Residual norm 3.112193254455e-05
  1700 KSP Residual norm 4.178863830514e-05
  1701 KSP Residual norm 6.309117034803e-05
  1702 KSP Residual norm 9.068646119005e-05
  1703 KSP Residual norm 1.000307139127e-04
  1704 KSP Residual norm 7.392841452253e-05
  1705 KSP Residual norm 4.501865928935e-05
  1706 KSP Residual norm 3.235679583790e-05
  1707 KSP Residual norm 2.978819542827e-05
  1708 KSP Residual norm 3.573129340262e-05
  1709 KSP Residual norm 4.951885946483e-05
  1710 KSP Residual norm 6.445601060555e-05
  1711 KSP Residual norm 6.957085192254e-05
  1712 KSP Residual norm 6.756587302994e-05
  1713 KSP Residual norm 7.056625677718e-05
  1714 KSP Residual norm 8.152279203535e-05
  1715 KSP Residual norm 8.710776724179e-05
  1716 KSP Residual norm 7.475694487381e-05
  1717 KSP Residual norm 5.502459078031e-05
  1718 KSP Residual norm 4.076192456932e-05
  1719 KSP Residual norm 3.675018119838e-05
  1720 KSP Residual norm 4.153785514217e-05
  1721 KSP Residual norm 5.335676678338e-05
  1722 KSP Residual norm 6.271637557330e-05
  1723 KSP Residual norm 6.465377859297e-05
  1724 KSP Residual norm 7.024060712657e-05
  1725 KSP Residual norm 8.547622571908e-05
  1726 KSP Residual norm 1.013047982263e-04
  1727 KSP Residual norm 8.958349464017e-05
  1728 KSP Residual norm 6.368058211490e-05
  1729 KSP Residual norm 4.879809280622e-05
  1730 KSP Residual norm 4.810344287796e-05
  1731 KSP Residual norm 5.200450512227e-05
  1732 KSP Residual norm 4.570440552338e-05
  1733 KSP Residual norm 3.434197560012e-05
  1734 KSP Residual norm 2.645040785699e-05
  1735 KSP Residual norm 2.654846690444e-05
  1736 KSP Residual norm 3.305476665633e-05
  1737 KSP Residual norm 4.028937077267e-05
  1738 KSP Residual norm 4.229884310405e-05
  1739 KSP Residual norm 4.057767977870e-05
  1740 KSP Residual norm 4.368169145254e-05
  1741 KSP Residual norm 5.806124660954e-05
  1742 KSP Residual norm 7.728286596288e-05
  1743 KSP Residual norm 7.466040085248e-05
  1744 KSP Residual norm 5.912087719640e-05
  1745 KSP Residual norm 4.979550758481e-05
  1746 KSP Residual norm 4.833362620949e-05
  1747 KSP Residual norm 4.897350052364e-05
  1748 KSP Residual norm 4.342477208681e-05
  1749 KSP Residual norm 3.587110145625e-05
  1750 KSP Residual norm 3.397927997564e-05
  1751 KSP Residual norm 3.933673634705e-05
  1752 KSP Residual norm 4.703086101383e-05
  1753 KSP Residual norm 4.639498957625e-05
  1754 KSP Residual norm 4.572118456320e-05
  1755 KSP Residual norm 5.489192113200e-05
  1756 KSP Residual norm 7.384741667165e-05
  1757 KSP Residual norm 8.733764008860e-05
  1758 KSP Residual norm 8.285208753563e-05
  1759 KSP Residual norm 7.455755746713e-05
  1760 KSP Residual norm 7.516681918448e-05
  1761 KSP Residual norm 8.345968991202e-05
  1762 KSP Residual norm 7.756991733274e-05
  1763 KSP Residual norm 5.657991132344e-05
  1764 KSP Residual norm 4.132539021751e-05
  1765 KSP Residual norm 3.858953252024e-05
  1766 KSP Residual norm 4.431505280786e-05
  1767 KSP Residual norm 4.545302359569e-05
  1768 KSP Residual norm 3.628828495200e-05
  1769 KSP Residual norm 2.845420725659e-05
  1770 KSP Residual norm 2.888470948136e-05
  1771 KSP Residual norm 3.660504080600e-05
  1772 KSP Residual norm 4.421476425188e-05
  1773 KSP Residual norm 4.420981539998e-05
  1774 KSP Residual norm 4.276369895633e-05
  1775 KSP Residual norm 4.826420755097e-05
  1776 KSP Residual norm 5.839814153108e-05
  1777 KSP Residual norm 5.663278126738e-05
  1778 KSP Residual norm 4.261978869464e-05
  1779 KSP Residual norm 3.752374746703e-05
  1780 KSP Residual norm 3.995229950895e-05
  1781 KSP Residual norm 4.159296217179e-05
  1782 KSP Residual norm 3.428943603040e-05
  1783 KSP Residual norm 2.536232949874e-05
  1784 KSP Residual norm 2.199648361586e-05
  1785 KSP Residual norm 2.267630924666e-05
  1786 KSP Residual norm 2.421920235551e-05
  1787 KSP Residual norm 2.339083498189e-05
  1788 KSP Residual norm 2.272224102939e-05
  1789 KSP Residual norm 2.660438795093e-05
  1790 KSP Residual norm 3.595247854564e-05
  1791 KSP Residual norm 4.758542959452e-05
  1792 KSP Residual norm 5.231398759863e-05
  1793 KSP Residual norm 5.271887525154e-05
  1794 KSP Residual norm 5.868998967500e-05
  1795 KSP Residual norm 7.422291394157e-05
  1796 KSP Residual norm 9.114275099629e-05
  1797 KSP Residual norm 8.692163969323e-05
  1798 KSP Residual norm 7.071703549949e-05
  1799 KSP Residual norm 6.541829758150e-05
  1800 KSP Residual norm 6.978241190142e-05
  1801 KSP Residual norm 6.906909186209e-05
  1802 KSP Residual norm 5.605318832255e-05
  1803 KSP Residual norm 4.480870705028e-05
  1804 KSP Residual norm 4.347940087147e-05
  1805 KSP Residual norm 4.736810910380e-05
  1806 KSP Residual norm 4.317126895758e-05
  1807 KSP Residual norm 3.526708138919e-05
  1808 KSP Residual norm 3.393518839314e-05
  1809 KSP Residual norm 4.120538523084e-05
  1810 KSP Residual norm 5.169442746598e-05
  1811 KSP Residual norm 5.879284948617e-05
  1812 KSP Residual norm 6.287013666618e-05
  1813 KSP Residual norm 7.713185133217e-05
  1814 KSP Residual norm 1.112265969136e-04
  1815 KSP Residual norm 1.550364230427e-04
  1816 KSP Residual norm 1.775803614424e-04
  1817 KSP Residual norm 1.689456419749e-04
  1818 KSP Residual norm 1.611915196464e-04
  1819 KSP Residual norm 1.667037248994e-04
  1820 KSP Residual norm 1.651580195153e-04
  1821 KSP Residual norm 1.365388912510e-04
  1822 KSP Residual norm 1.156999832836e-04
  1823 KSP Residual norm 1.124165045960e-04
  1824 KSP Residual norm 1.059263494255e-04
  1825 KSP Residual norm 8.274956283356e-05
  1826 KSP Residual norm 6.532002243282e-05
  1827 KSP Residual norm 6.311501169009e-05
  1828 KSP Residual norm 6.545118562832e-05
  1829 KSP Residual norm 5.703999539170e-05
  1830 KSP Residual norm 4.731194771401e-05
  1831 KSP Residual norm 4.686571231988e-05
  1832 KSP Residual norm 5.236015613828e-05
  1833 KSP Residual norm 5.533145806754e-05
  1834 KSP Residual norm 5.268374892611e-05
  1835 KSP Residual norm 5.017147725298e-05
  1836 KSP Residual norm 5.587819234823e-05
  1837 KSP Residual norm 7.184426848658e-05
  1838 KSP Residual norm 8.586911616072e-05
  1839 KSP Residual norm 8.662716532534e-05
  1840 KSP Residual norm 8.501490651984e-05
  1841 KSP Residual norm 9.771812233991e-05
  1842 KSP Residual norm 1.130250867607e-04
  1843 KSP Residual norm 1.085616268621e-04
  1844 KSP Residual norm 9.566848962302e-05
  1845 KSP Residual norm 9.311966192110e-05
  1846 KSP Residual norm 9.415670116004e-05
  1847 KSP Residual norm 8.804659977003e-05
  1848 KSP Residual norm 6.770294909616e-05
  1849 KSP Residual norm 5.221084181353e-05
  1850 KSP Residual norm 4.670579353667e-05
  1851 KSP Residual norm 4.819512615688e-05
  1852 KSP Residual norm 4.671396435292e-05
  1853 KSP Residual norm 4.177480955398e-05
  1854 KSP Residual norm 4.307178743888e-05
  1855 KSP Residual norm 5.238237414427e-05
  1856 KSP Residual norm 6.060702757200e-05
  1857 KSP Residual norm 6.080620170073e-05
  1858 KSP Residual norm 6.513203584982e-05
  1859 KSP Residual norm 7.888627391129e-05
  1860 KSP Residual norm 8.950704156141e-05
  1861 KSP Residual norm 8.657831426233e-05
  1862 KSP Residual norm 7.908055852432e-05
  1863 KSP Residual norm 8.635175305052e-05
  1864 KSP Residual norm 1.085206528166e-04
  1865 KSP Residual norm 1.162913065919e-04
  1866 KSP Residual norm 1.036266156916e-04
  1867 KSP Residual norm 9.665031486237e-05
  1868 KSP Residual norm 9.907376720976e-05
  1869 KSP Residual norm 9.835602457695e-05
  1870 KSP Residual norm 8.500364052670e-05
  1871 KSP Residual norm 7.199253004762e-05
  1872 KSP Residual norm 6.870825248643e-05
  1873 KSP Residual norm 6.981851502818e-05
  1874 KSP Residual norm 6.265131822843e-05
  1875 KSP Residual norm 5.030669315022e-05
  1876 KSP Residual norm 4.274925354472e-05
  1877 KSP Residual norm 3.858647977075e-05
  1878 KSP Residual norm 3.368296519471e-05
  1879 KSP Residual norm 2.742275165445e-05
  1880 KSP Residual norm 2.480060200444e-05
  1881 KSP Residual norm 2.621683999505e-05
  1882 KSP Residual norm 2.906286740443e-05
  1883 KSP Residual norm 3.045752112834e-05
  1884 KSP Residual norm 2.835651055679e-05
  1885 KSP Residual norm 2.897567110330e-05
  1886 KSP Residual norm 3.568567374638e-05
  1887 KSP Residual norm 4.561462244462e-05
  1888 KSP Residual norm 5.122453661449e-05
  1889 KSP Residual norm 5.267770286835e-05
  1890 KSP Residual norm 6.169881299403e-05
  1891 KSP Residual norm 8.057187791296e-05
  1892 KSP Residual norm 9.695035535993e-05
  1893 KSP Residual norm 9.659469095191e-05
  1894 KSP Residual norm 9.409280604400e-05
  1895 KSP Residual norm 9.530707040243e-05
  1896 KSP Residual norm 9.261842866598e-05
  1897 KSP Residual norm 8.347545296760e-05
  1898 KSP Residual norm 8.109444004373e-05
  1899 KSP Residual norm 8.520713265851e-05
  1900 KSP Residual norm 8.622939836032e-05
  1901 KSP Residual norm 7.780378310796e-05
  1902 KSP Residual norm 6.765595192081e-05
  1903 KSP Residual norm 6.376711525302e-05
  1904 KSP Residual norm 6.172628285816e-05
  1905 KSP Residual norm 5.517623474333e-05
  1906 KSP Residual norm 4.933415197155e-05
  1907 KSP Residual norm 4.757817972698e-05
  1908 KSP Residual norm 4.567076444637e-05
  1909 KSP Residual norm 3.968241143714e-05
  1910 KSP Residual norm 3.519611121404e-05
  1911 KSP Residual norm 3.656706326849e-05
  1912 KSP Residual norm 4.030027837565e-05
  1913 KSP Residual norm 3.932992145155e-05
  1914 KSP Residual norm 3.816054655325e-05
  1915 KSP Residual norm 4.298641288979e-05
  1916 KSP Residual norm 5.200898421600e-05
  1917 KSP Residual norm 6.127075880237e-05
  1918 KSP Residual norm 6.502246812138e-05
  1919 KSP Residual norm 7.107140710760e-05
  1920 KSP Residual norm 8.105909459055e-05
  1921 KSP Residual norm 8.772438805153e-05
  1922 KSP Residual norm 8.515018063269e-05
  1923 KSP Residual norm 8.374388275368e-05
  1924 KSP Residual norm 8.999425409334e-05
  1925 KSP Residual norm 8.848562701116e-05
  1926 KSP Residual norm 7.672014127488e-05
  1927 KSP Residual norm 6.882125930869e-05
  1928 KSP Residual norm 6.510731367965e-05
  1929 KSP Residual norm 5.853207715381e-05
  1930 KSP Residual norm 4.833575303195e-05
  1931 KSP Residual norm 4.079152330499e-05
  1932 KSP Residual norm 3.804418085596e-05
  1933 KSP Residual norm 3.671583238456e-05
  1934 KSP Residual norm 3.249094460221e-05
  1935 KSP Residual norm 2.818968930180e-05
  1936 KSP Residual norm 2.455600339593e-05
  1937 KSP Residual norm 2.268549583469e-05
  1938 KSP Residual norm 2.139072822561e-05
  1939 KSP Residual norm 2.119210349094e-05
  1940 KSP Residual norm 2.327074715160e-05
  1941 KSP Residual norm 2.744985516810e-05
  1942 KSP Residual norm 3.342901872368e-05
  1943 KSP Residual norm 3.833776466491e-05
  1944 KSP Residual norm 4.304442245814e-05
  1945 KSP Residual norm 5.041967301334e-05
  1946 KSP Residual norm 6.234009014930e-05
  1947 KSP Residual norm 7.080241494044e-05
  1948 KSP Residual norm 7.578848186134e-05
  1949 KSP Residual norm 8.136803806799e-05
  1950 KSP Residual norm 9.295436501126e-05
  1951 KSP Residual norm 9.545426905819e-05
  1952 KSP Residual norm 9.204960379493e-05
  1953 KSP Residual norm 9.703106775261e-05
  1954 KSP Residual norm 1.164813164361e-04
  1955 KSP Residual norm 1.254300731039e-04
  1956 KSP Residual norm 1.110164960759e-04
  1957 KSP Residual norm 1.021566459320e-04
  1958 KSP Residual norm 1.089447203592e-04
  1959 KSP Residual norm 1.139642834252e-04
  1960 KSP Residual norm 1.017424042626e-04
  1961 KSP Residual norm 8.504830286679e-05
  1962 KSP Residual norm 7.719094350895e-05
  1963 KSP Residual norm 7.000339913686e-05
  1964 KSP Residual norm 5.745591888795e-05
  1965 KSP Residual norm 5.054898401809e-05
  1966 KSP Residual norm 4.926736925454e-05
  1967 KSP Residual norm 4.775600314902e-05
  1968 KSP Residual norm 4.187795205101e-05
  1969 KSP Residual norm 3.637303144558e-05
  1970 KSP Residual norm 3.557163246377e-05
  1971 KSP Residual norm 3.601075010292e-05
  1972 KSP Residual norm 3.289158733166e-05
  1973 KSP Residual norm 3.013364732973e-05
  1974 KSP Residual norm 3.057845718720e-05
  1975 KSP Residual norm 3.159062772902e-05
  1976 KSP Residual norm 2.954281674491e-05
  1977 KSP Residual norm 2.970520393219e-05
  1978 KSP Residual norm 3.446007545808e-05
  1979 KSP Residual norm 4.154158078645e-05
  1980 KSP Residual norm 4.823108719157e-05
  1981 KSP Residual norm 5.514371122818e-05
  1982 KSP Residual norm 6.620848858541e-05
  1983 KSP Residual norm 7.361787614819e-05
  1984 KSP Residual norm 7.404957519912e-05
  1985 KSP Residual norm 7.587769129775e-05
  1986 KSP Residual norm 8.718819638297e-05
  1987 KSP Residual norm 1.045491937153e-04
  1988 KSP Residual norm 1.160223589894e-04
  1989 KSP Residual norm 1.153089114790e-04
  1990 KSP Residual norm 1.188733983327e-04
  1991 KSP Residual norm 1.345853673388e-04
  1992 KSP Residual norm 1.425507026857e-04
  1993 KSP Residual norm 1.339668054978e-04
  1994 KSP Residual norm 1.270642878899e-04
  1995 KSP Residual norm 1.253926551094e-04
  1996 KSP Residual norm 1.170403933972e-04
  1997 KSP Residual norm 1.015752348934e-04
  1998 KSP Residual norm 8.655967488148e-05
  1999 KSP Residual norm 7.728845790511e-05
  2000 KSP Residual norm 7.345547586614e-05
  2001 KSP Residual norm 7.084963534688e-05
  2002 KSP Residual norm 6.591356720823e-05
  2003 KSP Residual norm 6.330718105201e-05
  2004 KSP Residual norm 6.113178853395e-05
  2005 KSP Residual norm 5.778816266795e-05
  2006 KSP Residual norm 4.935234420663e-05
  2007 KSP Residual norm 4.468794671712e-05
  2008 KSP Residual norm 4.837779230756e-05
  2009 KSP Residual norm 5.527663814967e-05
  2010 KSP Residual norm 5.641785227988e-05
  2011 KSP Residual norm 5.675474362412e-05
  2012 KSP Residual norm 6.419625000284e-05
  2013 KSP Residual norm 7.582155513883e-05
  2014 KSP Residual norm 8.537570986489e-05
  2015 KSP Residual norm 9.482398182569e-05
  2016 KSP Residual norm 1.063625895562e-04
  2017 KSP Residual norm 1.154623872140e-04
  2018 KSP Residual norm 1.200249333478e-04
  2019 KSP Residual norm 1.294331926198e-04
  2020 KSP Residual norm 1.419912941039e-04
  2021 KSP Residual norm 1.540929176854e-04
  2022 KSP Residual norm 1.624175872529e-04
  2023 KSP Residual norm 1.690292092113e-04
  2024 KSP Residual norm 1.716680626458e-04
  2025 KSP Residual norm 1.730790655306e-04
  2026 KSP Residual norm 1.546063992232e-04
  2027 KSP Residual norm 1.300177384175e-04
  2028 KSP Residual norm 1.201083071643e-04
  2029 KSP Residual norm 1.108198331435e-04
  2030 KSP Residual norm 9.367379458212e-05
  2031 KSP Residual norm 7.728334801680e-05
  2032 KSP Residual norm 7.364801558827e-05
  2033 KSP Residual norm 7.191968224978e-05
  2034 KSP Residual norm 6.430768689345e-05
  2035 KSP Residual norm 5.584741309398e-05
  2036 KSP Residual norm 5.342822046168e-05
  2037 KSP Residual norm 5.351870488026e-05
  2038 KSP Residual norm 4.897636571757e-05
  2039 KSP Residual norm 4.348010597180e-05
  2040 KSP Residual norm 4.066036071986e-05
  2041 KSP Residual norm 3.978628058137e-05
  2042 KSP Residual norm 3.702065976097e-05
  2043 KSP Residual norm 3.384567728620e-05
  2044 KSP Residual norm 3.563232110428e-05
  2045 KSP Residual norm 4.013756038586e-05
  2046 KSP Residual norm 4.361737137094e-05
  2047 KSP Residual norm 4.617186659379e-05
  2048 KSP Residual norm 5.132887443457e-05
  2049 KSP Residual norm 6.034816287815e-05
  2050 KSP Residual norm 7.117012923850e-05
  2051 KSP Residual norm 8.045395778169e-05
  2052 KSP Residual norm 9.094204680949e-05
  2053 KSP Residual norm 1.033210559251e-04
  2054 KSP Residual norm 1.113550273736e-04
  2055 KSP Residual norm 1.125618312664e-04
  2056 KSP Residual norm 1.217997308288e-04
  2057 KSP Residual norm 1.406297800758e-04
  2058 KSP Residual norm 1.564996743460e-04
  2059 KSP Residual norm 1.641353733608e-04
  2060 KSP Residual norm 1.786071321103e-04
  2061 KSP Residual norm 2.020418732653e-04
  2062 KSP Residual norm 2.317258208946e-04
  2063 KSP Residual norm 2.325249005256e-04
  2064 KSP Residual norm 2.135091490829e-04
  2065 KSP Residual norm 2.099512160108e-04
  2066 KSP Residual norm 2.299120955404e-04
  2067 KSP Residual norm 2.382322596208e-04
  2068 KSP Residual norm 2.249036626476e-04
  2069 KSP Residual norm 2.089898703397e-04
  2070 KSP Residual norm 2.040948821142e-04
  2071 KSP Residual norm 1.991038337363e-04
  2072 KSP Residual norm 1.768302171210e-04
  2073 KSP Residual norm 1.654231832066e-04
  2074 KSP Residual norm 1.673060736667e-04
  2075 KSP Residual norm 1.664459628621e-04
  2076 KSP Residual norm 1.462984236462e-04
  2077 KSP Residual norm 1.274750009124e-04
  2078 KSP Residual norm 1.245294869258e-04
  2079 KSP Residual norm 1.225948215299e-04
  2080 KSP Residual norm 1.042575806097e-04
  2081 KSP Residual norm 8.659358725777e-05
  2082 KSP Residual norm 8.058411176778e-05
  2083 KSP Residual norm 7.985872804837e-05
  2084 KSP Residual norm 7.909978661000e-05
  2085 KSP Residual norm 7.588943927986e-05
  2086 KSP Residual norm 7.801546833461e-05
  2087 KSP Residual norm 8.939543427435e-05
  2088 KSP Residual norm 9.332935879162e-05
  2089 KSP Residual norm 8.566100239866e-05
  2090 KSP Residual norm 8.632606593098e-05
  2091 KSP Residual norm 9.529320421949e-05
  2092 KSP Residual norm 1.012068681805e-04
  2093 KSP Residual norm 1.040372561815e-04
  2094 KSP Residual norm 1.103677053549e-04
  2095 KSP Residual norm 1.262328403807e-04
  2096 KSP Residual norm 1.401253987967e-04
  2097 KSP Residual norm 1.411854651844e-04
  2098 KSP Residual norm 1.438812167555e-04
  2099 KSP Residual norm 1.669415193335e-04
  2100 KSP Residual norm 2.097690240300e-04
  2101 KSP Residual norm 2.525820169397e-04
  2102 KSP Residual norm 2.869166359697e-04
  2103 KSP Residual norm 3.162255665974e-04
  2104 KSP Residual norm 3.310550534410e-04
  2105 KSP Residual norm 3.330019192838e-04
  2106 KSP Residual norm 3.438565665013e-04
  2107 KSP Residual norm 3.813568723049e-04
  2108 KSP Residual norm 4.188917688844e-04
  2109 KSP Residual norm 4.105113172912e-04
  2110 KSP Residual norm 3.552540571811e-04
  2111 KSP Residual norm 3.240364341293e-04
  2112 KSP Residual norm 3.168536101792e-04
  2113 KSP Residual norm 2.893104558398e-04
  2114 KSP Residual norm 2.478065925695e-04
  2115 KSP Residual norm 2.364213100052e-04
  2116 KSP Residual norm 2.301758927433e-04
  2117 KSP Residual norm 2.063981171527e-04
  2118 KSP Residual norm 1.818653871418e-04
  2119 KSP Residual norm 1.654283425321e-04
  2120 KSP Residual norm 1.490059908107e-04
  2121 KSP Residual norm 1.361651655705e-04
  2122 KSP Residual norm 1.258183940148e-04
  2123 KSP Residual norm 1.193805626413e-04
  2124 KSP Residual norm 1.099165241967e-04
  2125 KSP Residual norm 9.312135566871e-05
  2126 KSP Residual norm 7.968481737556e-05
  2127 KSP Residual norm 7.587584577166e-05
  2128 KSP Residual norm 7.977341310049e-05
  2129 KSP Residual norm 8.105396819965e-05
  2130 KSP Residual norm 8.044541465144e-05
  2131 KSP Residual norm 8.147778748008e-05
  2132 KSP Residual norm 8.864454151897e-05
  2133 KSP Residual norm 1.018877902173e-04
  2134 KSP Residual norm 1.098819323142e-04
  2135 KSP Residual norm 1.154550972912e-04
  2136 KSP Residual norm 1.291584647482e-04
  2137 KSP Residual norm 1.407074968079e-04
  2138 KSP Residual norm 1.461764659046e-04
  2139 KSP Residual norm 1.566322973912e-04
  2140 KSP Residual norm 1.680249192688e-04
  2141 KSP Residual norm 1.759867228633e-04
  2142 KSP Residual norm 1.927274228507e-04
  2143 KSP Residual norm 2.242597801894e-04
  2144 KSP Residual norm 2.425292026805e-04
  2145 KSP Residual norm 2.365468989593e-04
  2146 KSP Residual norm 2.287712682275e-04
  2147 KSP Residual norm 2.333762373188e-04
  2148 KSP Residual norm 2.464175929646e-04
  2149 KSP Residual norm 2.667637391810e-04
  2150 KSP Residual norm 2.662563677010e-04
  2151 KSP Residual norm 2.710692693014e-04
  2152 KSP Residual norm 3.047950688204e-04
  2153 KSP Residual norm 3.370860129090e-04
  2154 KSP Residual norm 3.233847501232e-04
  2155 KSP Residual norm 2.947574675598e-04
  2156 KSP Residual norm 2.793183641549e-04
  2157 KSP Residual norm 2.764495790484e-04
  2158 KSP Residual norm 2.566056823036e-04
  2159 KSP Residual norm 2.298310237411e-04
  2160 KSP Residual norm 2.206766592004e-04
  2161 KSP Residual norm 2.222904102504e-04
  2162 KSP Residual norm 2.121782449003e-04
  2163 KSP Residual norm 1.859023789893e-04
  2164 KSP Residual norm 1.714570022773e-04
  2165 KSP Residual norm 1.693721300179e-04
  2166 KSP Residual norm 1.567970662707e-04
  2167 KSP Residual norm 1.322111644143e-04
  2168 KSP Residual norm 1.147823097816e-04
  2169 KSP Residual norm 1.151729209642e-04
  2170 KSP Residual norm 1.143783742795e-04
  2171 KSP Residual norm 1.084018743143e-04
  2172 KSP Residual norm 1.006674348966e-04
  2173 KSP Residual norm 9.555166362807e-05
  2174 KSP Residual norm 9.170606426874e-05
  2175 KSP Residual norm 8.741053296915e-05
  2176 KSP Residual norm 8.242224037062e-05
  2177 KSP Residual norm 7.758706499399e-05
  2178 KSP Residual norm 7.107154907316e-05
  2179 KSP Residual norm 6.237603053049e-05
  2180 KSP Residual norm 5.873850461650e-05
  2181 KSP Residual norm 6.001752003718e-05
  2182 KSP Residual norm 6.237670997216e-05
  2183 KSP Residual norm 6.139281168758e-05
  2184 KSP Residual norm 5.914545935942e-05
  2185 KSP Residual norm 5.884663578568e-05
  2186 KSP Residual norm 6.047997088460e-05
  2187 KSP Residual norm 6.329371095671e-05
  2188 KSP Residual norm 7.021001094637e-05
  2189 KSP Residual norm 7.647923644830e-05
  2190 KSP Residual norm 7.282653682265e-05
  2191 KSP Residual norm 6.770191546287e-05
  2192 KSP Residual norm 7.181143252398e-05
  2193 KSP Residual norm 8.653763153747e-05
  2194 KSP Residual norm 9.934720317205e-05
  2195 KSP Residual norm 1.073081103150e-04
  2196 KSP Residual norm 1.061802111238e-04
  2197 KSP Residual norm 1.002078910340e-04
  2198 KSP Residual norm 9.635891918043e-05
  2199 KSP Residual norm 9.408972393928e-05
  2200 KSP Residual norm 1.009790459012e-04
  2201 KSP Residual norm 1.271285889784e-04
  2202 KSP Residual norm 1.537354505821e-04
  2203 KSP Residual norm 1.621761350960e-04
  2204 KSP Residual norm 1.700066369504e-04
  2205 KSP Residual norm 1.931137847692e-04
  2206 KSP Residual norm 2.134282182864e-04
  2207 KSP Residual norm 2.060622005584e-04
  2208 KSP Residual norm 1.942445843235e-04
  2209 KSP Residual norm 1.973603245038e-04
  2210 KSP Residual norm 2.062111341542e-04
  2211 KSP Residual norm 2.075325224207e-04
  2212 KSP Residual norm 2.160064821904e-04
  2213 KSP Residual norm 2.216002587121e-04
  2214 KSP Residual norm 2.090511461745e-04
  2215 KSP Residual norm 1.905551068415e-04
  2216 KSP Residual norm 1.849120467096e-04
  2217 KSP Residual norm 1.901904717515e-04
  2218 KSP Residual norm 1.887477485445e-04
  2219 KSP Residual norm 1.798164701903e-04
  2220 KSP Residual norm 1.734671590589e-04
  2221 KSP Residual norm 1.761216756340e-04
  2222 KSP Residual norm 1.671351567175e-04
  2223 KSP Residual norm 1.440579394843e-04
  2224 KSP Residual norm 1.250176261648e-04
  2225 KSP Residual norm 1.253121671612e-04
  2226 KSP Residual norm 1.374449391930e-04
  2227 KSP Residual norm 1.349583805796e-04
  2228 KSP Residual norm 1.209413040716e-04
  2229 KSP Residual norm 1.054241693105e-04
  2230 KSP Residual norm 9.274364365914e-05
  2231 KSP Residual norm 8.446648193726e-05
  2232 KSP Residual norm 7.988946923577e-05
  2233 KSP Residual norm 7.894604000712e-05
  2234 KSP Residual norm 8.059494714037e-05
  2235 KSP Residual norm 8.045216042742e-05
  2236 KSP Residual norm 8.011383433813e-05
  2237 KSP Residual norm 7.820440461111e-05
  2238 KSP Residual norm 8.053146450935e-05
  2239 KSP Residual norm 8.541453266594e-05
  2240 KSP Residual norm 8.317519796360e-05
  2241 KSP Residual norm 8.571770294475e-05
  2242 KSP Residual norm 9.344884306611e-05
  2243 KSP Residual norm 9.295741529865e-05
  2244 KSP Residual norm 8.684465078566e-05
  2245 KSP Residual norm 8.297223536127e-05
  2246 KSP Residual norm 8.322466991227e-05
  2247 KSP Residual norm 8.831968445209e-05
  2248 KSP Residual norm 9.226380356608e-05
  2249 KSP Residual norm 9.422441463232e-05
  2250 KSP Residual norm 1.057150283414e-04
  2251 KSP Residual norm 1.224830901988e-04
  2252 KSP Residual norm 1.331522449159e-04
  2253 KSP Residual norm 1.413208919405e-04
  2254 KSP Residual norm 1.515161371470e-04
  2255 KSP Residual norm 1.588190268030e-04
  2256 KSP Residual norm 1.565600174728e-04
  2257 KSP Residual norm 1.519077760437e-04
  2258 KSP Residual norm 1.519165401249e-04
  2259 KSP Residual norm 1.596282141288e-04
  2260 KSP Residual norm 1.712875208077e-04
  2261 KSP Residual norm 1.821597065204e-04
  2262 KSP Residual norm 1.981337700490e-04
  2263 KSP Residual norm 2.135415021981e-04
  2264 KSP Residual norm 2.204781337423e-04
  2265 KSP Residual norm 2.313572316323e-04
  2266 KSP Residual norm 2.451684134992e-04
  2267 KSP Residual norm 2.537210836276e-04
  2268 KSP Residual norm 2.480140541450e-04
  2269 KSP Residual norm 2.397479743890e-04
  2270 KSP Residual norm 2.375829797543e-04
  2271 KSP Residual norm 2.364583912241e-04
  2272 KSP Residual norm 2.252184960572e-04
  2273 KSP Residual norm 2.163679820330e-04
  2274 KSP Residual norm 2.106219273481e-04
  2275 KSP Residual norm 2.109717253794e-04
  2276 KSP Residual norm 2.143508385264e-04
  2277 KSP Residual norm 2.323128971654e-04
  2278 KSP Residual norm 2.378017969407e-04
  2279 KSP Residual norm 2.086129966265e-04
  2280 KSP Residual norm 1.821378934959e-04
  2281 KSP Residual norm 1.702440452917e-04
  2282 KSP Residual norm 1.538326110841e-04
  2283 KSP Residual norm 1.268147348654e-04
  2284 KSP Residual norm 1.040025509461e-04
  2285 KSP Residual norm 9.238945573306e-05
  2286 KSP Residual norm 9.113541873480e-05
  2287 KSP Residual norm 9.545729227373e-05
  2288 KSP Residual norm 9.389686604025e-05
  2289 KSP Residual norm 8.471540910156e-05
  2290 KSP Residual norm 8.092324013286e-05
  2291 KSP Residual norm 7.845699197729e-05
  2292 KSP Residual norm 7.113673671055e-05
  2293 KSP Residual norm 6.902926216335e-05
  2294 KSP Residual norm 7.398435330542e-05
  2295 KSP Residual norm 7.959998642109e-05
  2296 KSP Residual norm 7.969150600137e-05
  2297 KSP Residual norm 7.895569322434e-05
  2298 KSP Residual norm 8.434355366307e-05
  2299 KSP Residual norm 8.870657968660e-05
  2300 KSP Residual norm 8.439351278067e-05
  2301 KSP Residual norm 7.974192115568e-05
  2302 KSP Residual norm 8.435944491590e-05
  2303 KSP Residual norm 9.601518862652e-05
  2304 KSP Residual norm 1.092146780410e-04
  2305 KSP Residual norm 1.236250564388e-04
  2306 KSP Residual norm 1.448453938802e-04
  2307 KSP Residual norm 1.577915570239e-04
  2308 KSP Residual norm 1.557729955066e-04
  2309 KSP Residual norm 1.520952317554e-04
  2310 KSP Residual norm 1.510661333301e-04
  2311 KSP Residual norm 1.474377883713e-04
  2312 KSP Residual norm 1.414668939765e-04
  2313 KSP Residual norm 1.459824453511e-04
  2314 KSP Residual norm 1.532624490929e-04
  2315 KSP Residual norm 1.604475659537e-04
  2316 KSP Residual norm 1.615454442294e-04
  2317 KSP Residual norm 1.549455162358e-04
  2318 KSP Residual norm 1.614312437080e-04
  2319 KSP Residual norm 1.669887941466e-04
  2320 KSP Residual norm 1.614862369333e-04
  2321 KSP Residual norm 1.596120456007e-04
  2322 KSP Residual norm 1.682527085484e-04
  2323 KSP Residual norm 1.779026743295e-04
  2324 KSP Residual norm 1.765883553665e-04
  2325 KSP Residual norm 1.739232156150e-04
  2326 KSP Residual norm 1.799974712687e-04
  2327 KSP Residual norm 1.806434166137e-04
  2328 KSP Residual norm 1.743831789899e-04
  2329 KSP Residual norm 1.848482569439e-04
  2330 KSP Residual norm 2.102617285496e-04
  2331 KSP Residual norm 2.320422473769e-04
  2332 KSP Residual norm 2.382570465323e-04
  2333 KSP Residual norm 2.228548849639e-04
  2334 KSP Residual norm 2.217500928061e-04
  2335 KSP Residual norm 2.382250555188e-04
  2336 KSP Residual norm 2.420957196517e-04
  2337 KSP Residual norm 2.126949869709e-04
  2338 KSP Residual norm 1.692738378553e-04
  2339 KSP Residual norm 1.391881623428e-04
  2340 KSP Residual norm 1.246871055055e-04
  2341 KSP Residual norm 1.088153104351e-04
  2342 KSP Residual norm 9.691636126096e-05
  2343 KSP Residual norm 9.269431005059e-05
  2344 KSP Residual norm 8.761136929050e-05
  2345 KSP Residual norm 8.161380227983e-05
  2346 KSP Residual norm 7.437369920325e-05
  2347 KSP Residual norm 6.596530758990e-05
  2348 KSP Residual norm 5.849581279183e-05
  2349 KSP Residual norm 5.206591498391e-05
  2350 KSP Residual norm 5.096197687523e-05
  2351 KSP Residual norm 5.235227840762e-05
  2352 KSP Residual norm 5.002094309548e-05
  2353 KSP Residual norm 4.554898084243e-05
  2354 KSP Residual norm 4.331779825569e-05
  2355 KSP Residual norm 4.502056915081e-05
  2356 KSP Residual norm 4.513351137936e-05
  2357 KSP Residual norm 4.325203162985e-05
  2358 KSP Residual norm 4.369756318174e-05
  2359 KSP Residual norm 4.791188982242e-05
  2360 KSP Residual norm 5.236506295731e-05
  2361 KSP Residual norm 5.315333650470e-05
  2362 KSP Residual norm 5.309020978406e-05
  2363 KSP Residual norm 5.287668714353e-05
  2364 KSP Residual norm 4.879893697589e-05
  2365 KSP Residual norm 4.648666077336e-05
  2366 KSP Residual norm 4.728255480296e-05
  2367 KSP Residual norm 5.199013622912e-05
  2368 KSP Residual norm 5.445981125523e-05
  2369 KSP Residual norm 5.290139914741e-05
  2370 KSP Residual norm 5.618379273285e-05
  2371 KSP Residual norm 6.564707091845e-05
  2372 KSP Residual norm 7.294412428352e-05
  2373 KSP Residual norm 7.234780715487e-05
  2374 KSP Residual norm 6.887877308614e-05
  2375 KSP Residual norm 6.997268480881e-05
  2376 KSP Residual norm 7.561965722597e-05
  2377 KSP Residual norm 7.975041669906e-05
  2378 KSP Residual norm 7.760923402662e-05
  2379 KSP Residual norm 7.540099741135e-05
  2380 KSP Residual norm 7.116307333408e-05
  2381 KSP Residual norm 6.295793347607e-05
  2382 KSP Residual norm 5.785234517360e-05
  2383 KSP Residual norm 6.164090770342e-05
  2384 KSP Residual norm 7.003850600494e-05
  2385 KSP Residual norm 7.016398282154e-05
  2386 KSP Residual norm 7.331113758847e-05
  2387 KSP Residual norm 8.416451523502e-05
  2388 KSP Residual norm 8.982226575026e-05
  2389 KSP Residual norm 8.422708847330e-05
  2390 KSP Residual norm 8.004700738578e-05
  2391 KSP Residual norm 8.188070554825e-05
  2392 KSP Residual norm 8.245606648174e-05
  2393 KSP Residual norm 7.628462732049e-05
  2394 KSP Residual norm 7.008224217210e-05
  2395 KSP Residual norm 7.149243912464e-05
  2396 KSP Residual norm 7.786040078026e-05
  2397 KSP Residual norm 7.610460375465e-05
  2398 KSP Residual norm 7.109183849232e-05
  2399 KSP Residual norm 7.298671454367e-05
  2400 KSP Residual norm 7.693265441345e-05
  2401 KSP Residual norm 7.747031334366e-05
  2402 KSP Residual norm 7.194228841576e-05
  2403 KSP Residual norm 6.455844112686e-05
  2404 KSP Residual norm 6.239162131136e-05
  2405 KSP Residual norm 6.477629121046e-05
  2406 KSP Residual norm 6.242596652556e-05
  2407 KSP Residual norm 5.690458858876e-05
  2408 KSP Residual norm 4.903651254711e-05
  2409 KSP Residual norm 4.632380778812e-05
  2410 KSP Residual norm 4.614481471399e-05
  2411 KSP Residual norm 4.395834763054e-05
  2412 KSP Residual norm 4.236379182631e-05
  2413 KSP Residual norm 4.172300138136e-05
  2414 KSP Residual norm 4.031772146354e-05
  2415 KSP Residual norm 3.885806126901e-05
  2416 KSP Residual norm 3.798958563083e-05
  2417 KSP Residual norm 3.899870630006e-05
  2418 KSP Residual norm 3.978878033293e-05
  2419 KSP Residual norm 3.930373437248e-05
  2420 KSP Residual norm 3.533035895158e-05
  2421 KSP Residual norm 3.170581040927e-05
  2422 KSP Residual norm 3.109979137307e-05
  2423 KSP Residual norm 3.171183823150e-05
  2424 KSP Residual norm 3.353712270729e-05
  2425 KSP Residual norm 3.527835345622e-05
  2426 KSP Residual norm 3.713164073648e-05
  2427 KSP Residual norm 3.938643667285e-05
  2428 KSP Residual norm 4.314562460621e-05
  2429 KSP Residual norm 4.715863259697e-05
  2430 KSP Residual norm 4.513847774689e-05
  2431 KSP Residual norm 4.192139718222e-05
  2432 KSP Residual norm 4.268601068874e-05
  2433 KSP Residual norm 4.584066869470e-05
  2434 KSP Residual norm 4.344823624398e-05
  2435 KSP Residual norm 4.020582364642e-05
  2436 KSP Residual norm 4.070899458197e-05
  2437 KSP Residual norm 4.079657052329e-05
  2438 KSP Residual norm 4.060020193671e-05
  2439 KSP Residual norm 4.149951388077e-05
  2440 KSP Residual norm 4.223947684109e-05
  2441 KSP Residual norm 4.068470056644e-05
  2442 KSP Residual norm 4.044946489518e-05
  2443 KSP Residual norm 4.441576752142e-05
  2444 KSP Residual norm 4.813554345106e-05
  2445 KSP Residual norm 4.613065465832e-05
  2446 KSP Residual norm 4.633778498457e-05
  2447 KSP Residual norm 4.922557369623e-05
  2448 KSP Residual norm 5.279731326841e-05
  2449 KSP Residual norm 5.333271097862e-05
  2450 KSP Residual norm 5.039034451608e-05
  2451 KSP Residual norm 5.031707537462e-05
  2452 KSP Residual norm 5.493019733143e-05
  2453 KSP Residual norm 6.009579304282e-05
  2454 KSP Residual norm 5.998128318259e-05
  2455 KSP Residual norm 5.698445291940e-05
  2456 KSP Residual norm 5.652085472890e-05
  2457 KSP Residual norm 5.867083347070e-05
  2458 KSP Residual norm 5.903295749641e-05
  2459 KSP Residual norm 5.749945166331e-05
  2460 KSP Residual norm 5.409293902355e-05
  2461 KSP Residual norm 5.145794400179e-05
  2462 KSP Residual norm 5.183431434930e-05
  2463 KSP Residual norm 5.552097948475e-05
  2464 KSP Residual norm 5.569415063709e-05
  2465 KSP Residual norm 5.278748773035e-05
  2466 KSP Residual norm 5.125155697592e-05
  2467 KSP Residual norm 5.165401423964e-05
  2468 KSP Residual norm 5.013502981398e-05
  2469 KSP Residual norm 4.773139835467e-05
  2470 KSP Residual norm 4.791700511513e-05
  2471 KSP Residual norm 5.186610235305e-05
  2472 KSP Residual norm 5.318428245094e-05
  2473 KSP Residual norm 5.037221519223e-05
  2474 KSP Residual norm 4.846358440628e-05
  2475 KSP Residual norm 4.612299590622e-05
  2476 KSP Residual norm 4.130114294874e-05
  2477 KSP Residual norm 3.920615706920e-05
  2478 KSP Residual norm 4.044433821042e-05
  2479 KSP Residual norm 4.168265290477e-05
  2480 KSP Residual norm 3.918934617509e-05
  2481 KSP Residual norm 3.560158891861e-05
  2482 KSP Residual norm 3.231012958670e-05
  2483 KSP Residual norm 3.012362596168e-05
  2484 KSP Residual norm 2.853936998222e-05
  2485 KSP Residual norm 2.714517259881e-05
  2486 KSP Residual norm 2.636931698152e-05
  2487 KSP Residual norm 2.655666223680e-05
  2488 KSP Residual norm 2.531509638015e-05
  2489 KSP Residual norm 2.391480497562e-05
  2490 KSP Residual norm 2.414261600730e-05
  2491 KSP Residual norm 2.492343846820e-05
  2492 KSP Residual norm 2.612092473969e-05
  2493 KSP Residual norm 2.743276476959e-05
  2494 KSP Residual norm 3.034763170454e-05
  2495 KSP Residual norm 3.355645010066e-05
  2496 KSP Residual norm 3.504307976450e-05
  2497 KSP Residual norm 3.466472503040e-05
  2498 KSP Residual norm 3.524867513446e-05
  2499 KSP Residual norm 3.559146154151e-05
  2500 KSP Residual norm 3.612356096905e-05
  2501 KSP Residual norm 3.821330396122e-05
  2502 KSP Residual norm 4.150087584732e-05
  2503 KSP Residual norm 4.453984926972e-05
  2504 KSP Residual norm 4.701954469269e-05
  2505 KSP Residual norm 4.939739046173e-05
  2506 KSP Residual norm 5.243477101231e-05
  2507 KSP Residual norm 5.405182387626e-05
  2508 KSP Residual norm 5.779870818750e-05
  2509 KSP Residual norm 5.949525340653e-05
  2510 KSP Residual norm 5.745600414122e-05
  2511 KSP Residual norm 5.661975069965e-05
  2512 KSP Residual norm 5.887912788223e-05
  2513 KSP Residual norm 6.404670001435e-05
  2514 KSP Residual norm 7.069108838276e-05
  2515 KSP Residual norm 7.447657498585e-05
  2516 KSP Residual norm 7.171217814892e-05
  2517 KSP Residual norm 7.343337460155e-05
  2518 KSP Residual norm 8.257184522413e-05
  2519 KSP Residual norm 9.555359162115e-05
  2520 KSP Residual norm 1.015905177955e-04
  2521 KSP Residual norm 1.044309990667e-04
  2522 KSP Residual norm 1.023232731569e-04
  2523 KSP Residual norm 1.052736829374e-04
  2524 KSP Residual norm 1.133910128202e-04
  2525 KSP Residual norm 1.117970704116e-04
  2526 KSP Residual norm 9.195571977788e-05
  2527 KSP Residual norm 7.803485646233e-05
  2528 KSP Residual norm 7.551883913084e-05
  2529 KSP Residual norm 8.014149241128e-05
  2530 KSP Residual norm 8.772237359993e-05
  2531 KSP Residual norm 9.654053431318e-05
  2532 KSP Residual norm 9.871974602925e-05
  2533 KSP Residual norm 9.629352029565e-05
  2534 KSP Residual norm 9.586266810218e-05
  2535 KSP Residual norm 9.486695460118e-05
  2536 KSP Residual norm 9.538956435908e-05
  2537 KSP Residual norm 9.146555591093e-05
  2538 KSP Residual norm 8.572118786136e-05
  2539 KSP Residual norm 8.472822366213e-05
  2540 KSP Residual norm 8.391800695387e-05
  2541 KSP Residual norm 7.589149454479e-05
  2542 KSP Residual norm 6.679926987889e-05
  2543 KSP Residual norm 6.521219621362e-05
  2544 KSP Residual norm 6.455569847371e-05
  2545 KSP Residual norm 6.018087781912e-05
  2546 KSP Residual norm 5.915751886636e-05
  2547 KSP Residual norm 6.282601426029e-05
  2548 KSP Residual norm 6.714651859608e-05
  2549 KSP Residual norm 6.921727934522e-05
  2550 KSP Residual norm 7.344940719043e-05
  2551 KSP Residual norm 7.643672962339e-05
  2552 KSP Residual norm 7.349435162064e-05
  2553 KSP Residual norm 6.469359367140e-05
  2554 KSP Residual norm 5.688865386305e-05
  2555 KSP Residual norm 5.165163613024e-05
  2556 KSP Residual norm 4.679373522340e-05
  2557 KSP Residual norm 4.156010991242e-05
  2558 KSP Residual norm 3.835016200548e-05
  2559 KSP Residual norm 3.959044633283e-05
  2560 KSP Residual norm 4.251873621926e-05
  2561 KSP Residual norm 4.586637817975e-05
  2562 KSP Residual norm 4.686586166984e-05
  2563 KSP Residual norm 4.616649880586e-05
  2564 KSP Residual norm 4.709771342781e-05
  2565 KSP Residual norm 5.107473263278e-05
  2566 KSP Residual norm 5.762345389441e-05
  2567 KSP Residual norm 6.386298021481e-05
  2568 KSP Residual norm 6.374755740589e-05
  2569 KSP Residual norm 6.087017263042e-05
  2570 KSP Residual norm 6.710487005912e-05
  2571 KSP Residual norm 7.473703054964e-05
  2572 KSP Residual norm 7.136408624995e-05
  2573 KSP Residual norm 7.004911577959e-05
  2574 KSP Residual norm 7.362417346435e-05
  2575 KSP Residual norm 7.471508940816e-05
  2576 KSP Residual norm 6.969544080515e-05
  2577 KSP Residual norm 7.015638923922e-05
  2578 KSP Residual norm 7.486123249157e-05
  2579 KSP Residual norm 8.052979467600e-05
  2580 KSP Residual norm 8.309119653837e-05
  2581 KSP Residual norm 8.562718701757e-05
  2582 KSP Residual norm 8.835416352618e-05
  2583 KSP Residual norm 9.548412350224e-05
  2584 KSP Residual norm 1.030844846703e-04
  2585 KSP Residual norm 1.025527704316e-04
  2586 KSP Residual norm 1.023548263858e-04
  2587 KSP Residual norm 1.084773089890e-04
  2588 KSP Residual norm 1.027637053914e-04
  2589 KSP Residual norm 9.155102881336e-05
  2590 KSP Residual norm 9.443580571784e-05
  2591 KSP Residual norm 1.015198220061e-04
  2592 KSP Residual norm 1.082932584637e-04
  2593 KSP Residual norm 1.251768351188e-04
  2594 KSP Residual norm 1.584642980311e-04
  2595 KSP Residual norm 1.821347375249e-04
  2596 KSP Residual norm 1.794793903667e-04
  2597 KSP Residual norm 1.680599530034e-04
  2598 KSP Residual norm 1.669609499900e-04
  2599 KSP Residual norm 1.697904825140e-04
  2600 KSP Residual norm 1.706470687561e-04
  2601 KSP Residual norm 1.822958202336e-04
  2602 KSP Residual norm 2.032115388570e-04
  2603 KSP Residual norm 2.204311401484e-04
  2604 KSP Residual norm 2.259096788278e-04
  2605 KSP Residual norm 2.263138857600e-04
  2606 KSP Residual norm 2.352395511741e-04
  2607 KSP Residual norm 2.619804829724e-04
  2608 KSP Residual norm 2.791487939479e-04
  2609 KSP Residual norm 2.554639620336e-04
  2610 KSP Residual norm 2.258304448226e-04
  2611 KSP Residual norm 1.954116159899e-04
  2612 KSP Residual norm 1.624904736551e-04
  2613 KSP Residual norm 1.483061533959e-04
  2614 KSP Residual norm 1.421014821911e-04
  2615 KSP Residual norm 1.357722291498e-04
  2616 KSP Residual norm 1.282565643948e-04
  2617 KSP Residual norm 1.350242123496e-04
  2618 KSP Residual norm 1.362714715781e-04
  2619 KSP Residual norm 1.317577505547e-04
  2620 KSP Residual norm 1.382400294903e-04
  2621 KSP Residual norm 1.541298608028e-04
  2622 KSP Residual norm 1.508475560096e-04
  2623 KSP Residual norm 1.388297372818e-04
  2624 KSP Residual norm 1.309199703765e-04
  2625 KSP Residual norm 1.220831127312e-04
  2626 KSP Residual norm 1.142585868239e-04
  2627 KSP Residual norm 1.074183298564e-04
  2628 KSP Residual norm 9.994146341025e-05
  2629 KSP Residual norm 9.420700711185e-05
  2630 KSP Residual norm 8.626940929019e-05
  2631 KSP Residual norm 7.814698881910e-05
  2632 KSP Residual norm 8.075274332567e-05
  2633 KSP Residual norm 8.388355963605e-05
  2634 KSP Residual norm 7.874315160859e-05
  2635 KSP Residual norm 7.322417136743e-05
  2636 KSP Residual norm 7.229262327786e-05
  2637 KSP Residual norm 7.289809252595e-05
  2638 KSP Residual norm 7.136869796543e-05
  2639 KSP Residual norm 7.017739740453e-05
  2640 KSP Residual norm 6.591215861970e-05
  2641 KSP Residual norm 6.205415308538e-05
  2642 KSP Residual norm 6.596125940918e-05
  2643 KSP Residual norm 7.204487972022e-05
  2644 KSP Residual norm 7.179895727567e-05
  2645 KSP Residual norm 7.400988283283e-05
  2646 KSP Residual norm 8.364965686139e-05
  2647 KSP Residual norm 9.133722382474e-05
  2648 KSP Residual norm 8.960741174111e-05
  2649 KSP Residual norm 8.273411012276e-05
  2650 KSP Residual norm 7.671087744838e-05
  2651 KSP Residual norm 7.414071346736e-05
  2652 KSP Residual norm 7.413064790601e-05
  2653 KSP Residual norm 6.892505947859e-05
  2654 KSP Residual norm 6.641426218853e-05
  2655 KSP Residual norm 6.609791763500e-05
  2656 KSP Residual norm 6.760661117874e-05
  2657 KSP Residual norm 7.015896003073e-05
  2658 KSP Residual norm 6.975538470772e-05
  2659 KSP Residual norm 6.987150676951e-05
  2660 KSP Residual norm 7.524436729959e-05
  2661 KSP Residual norm 8.570875033009e-05
  2662 KSP Residual norm 9.515659542009e-05
  2663 KSP Residual norm 9.871136274917e-05
  2664 KSP Residual norm 9.443535650484e-05
  2665 KSP Residual norm 9.893642188489e-05
  2666 KSP Residual norm 1.211865031452e-04
  2667 KSP Residual norm 1.423292115760e-04
  2668 KSP Residual norm 1.307180682489e-04
  2669 KSP Residual norm 1.161895156657e-04
  2670 KSP Residual norm 1.177705990722e-04
  2671 KSP Residual norm 1.135633707666e-04
  2672 KSP Residual norm 1.044983233552e-04
  2673 KSP Residual norm 1.015560115550e-04
  2674 KSP Residual norm 9.772443245858e-05
  2675 KSP Residual norm 8.177560282334e-05
  2676 KSP Residual norm 7.316984668395e-05
  2677 KSP Residual norm 7.141613893708e-05
  2678 KSP Residual norm 7.236059548106e-05
  2679 KSP Residual norm 7.761045836710e-05
  2680 KSP Residual norm 8.893394737327e-05
  2681 KSP Residual norm 1.016621101836e-04
  2682 KSP Residual norm 1.126991859164e-04
  2683 KSP Residual norm 1.221215701412e-04
  2684 KSP Residual norm 1.215257290112e-04
  2685 KSP Residual norm 1.237649424044e-04
  2686 KSP Residual norm 1.375574551202e-04
  2687 KSP Residual norm 1.515495972157e-04
  2688 KSP Residual norm 1.559268570488e-04
  2689 KSP Residual norm 1.552418022188e-04
  2690 KSP Residual norm 1.540889222373e-04
  2691 KSP Residual norm 1.509849659830e-04
  2692 KSP Residual norm 1.495491589717e-04
  2693 KSP Residual norm 1.543431955704e-04
  2694 KSP Residual norm 1.584033851904e-04
  2695 KSP Residual norm 1.537664657174e-04
  2696 KSP Residual norm 1.518588385328e-04
  2697 KSP Residual norm 1.600098928737e-04
  2698 KSP Residual norm 1.631100205522e-04
  2699 KSP Residual norm 1.499886239068e-04
  2700 KSP Residual norm 1.609924418033e-04
  2701 KSP Residual norm 1.869204672776e-04
  2702 KSP Residual norm 1.916923501378e-04
  2703 KSP Residual norm 1.856888397473e-04
  2704 KSP Residual norm 1.886637275069e-04
  2705 KSP Residual norm 1.963101071110e-04
  2706 KSP Residual norm 1.960623273820e-04
  2707 KSP Residual norm 1.920965948132e-04
  2708 KSP Residual norm 1.870570039036e-04
  2709 KSP Residual norm 1.750629562572e-04
  2710 KSP Residual norm 1.600281281492e-04
  2711 KSP Residual norm 1.484385966411e-04
  2712 KSP Residual norm 1.425987499806e-04
  2713 KSP Residual norm 1.389237184415e-04
  2714 KSP Residual norm 1.306168486614e-04
  2715 KSP Residual norm 1.259941692203e-04
  2716 KSP Residual norm 1.281349416352e-04
  2717 KSP Residual norm 1.275175406526e-04
  2718 KSP Residual norm 1.187058218368e-04
  2719 KSP Residual norm 1.136809289892e-04
  2720 KSP Residual norm 1.155378661584e-04
  2721 KSP Residual norm 1.140302391030e-04
  2722 KSP Residual norm 1.056481014678e-04
  2723 KSP Residual norm 9.734714173812e-05
  2724 KSP Residual norm 9.406541295757e-05
  2725 KSP Residual norm 9.246737342523e-05
  2726 KSP Residual norm 8.514437093883e-05
  2727 KSP Residual norm 7.957085140138e-05
  2728 KSP Residual norm 7.750589879035e-05
  2729 KSP Residual norm 7.109471481803e-05
  2730 KSP Residual norm 6.552027410612e-05
  2731 KSP Residual norm 7.027422877938e-05
  2732 KSP Residual norm 7.375756555500e-05
  2733 KSP Residual norm 6.240813324229e-05
  2734 KSP Residual norm 5.542005079353e-05
  2735 KSP Residual norm 5.449173170807e-05
  2736 KSP Residual norm 5.329068329687e-05
  2737 KSP Residual norm 5.090715521122e-05
  2738 KSP Residual norm 5.361935100142e-05
  2739 KSP Residual norm 5.911231888882e-05
  2740 KSP Residual norm 5.801782678697e-05
  2741 KSP Residual norm 5.725468793355e-05
  2742 KSP Residual norm 6.194756257456e-05
  2743 KSP Residual norm 6.336945835623e-05
  2744 KSP Residual norm 5.848579752400e-05
  2745 KSP Residual norm 5.506292643438e-05
  2746 KSP Residual norm 5.617843361705e-05
  2747 KSP Residual norm 5.834608899193e-05
  2748 KSP Residual norm 5.598276468575e-05
  2749 KSP Residual norm 5.648566133962e-05
  2750 KSP Residual norm 6.266956569096e-05
  2751 KSP Residual norm 6.835765907872e-05
  2752 KSP Residual norm 7.226829622211e-05
  2753 KSP Residual norm 7.476941020332e-05
  2754 KSP Residual norm 7.822119579677e-05
  2755 KSP Residual norm 7.748958195041e-05
  2756 KSP Residual norm 7.340275546659e-05
  2757 KSP Residual norm 6.879278550757e-05
  2758 KSP Residual norm 6.935629459116e-05
  2759 KSP Residual norm 6.974604375574e-05
  2760 KSP Residual norm 6.387768253729e-05
  2761 KSP Residual norm 5.916342789555e-05
  2762 KSP Residual norm 6.174478697807e-05
  2763 KSP Residual norm 6.191586477264e-05
  2764 KSP Residual norm 5.810330629357e-05
  2765 KSP Residual norm 5.807787159794e-05
  2766 KSP Residual norm 6.381314570978e-05
  2767 KSP Residual norm 6.919156009640e-05
  2768 KSP Residual norm 7.829993431968e-05
  2769 KSP Residual norm 9.774585973461e-05
  2770 KSP Residual norm 1.200003989363e-04
  2771 KSP Residual norm 1.297842880976e-04
  2772 KSP Residual norm 1.412740999062e-04
  2773 KSP Residual norm 1.630073757865e-04
  2774 KSP Residual norm 1.706536930462e-04
  2775 KSP Residual norm 1.589959261031e-04
  2776 KSP Residual norm 1.534621606252e-04
  2777 KSP Residual norm 1.577110995567e-04
  2778 KSP Residual norm 1.522459437676e-04
  2779 KSP Residual norm 1.475987398503e-04
  2780 KSP Residual norm 1.569009142527e-04
  2781 KSP Residual norm 1.690355428573e-04
  2782 KSP Residual norm 1.646535146735e-04
  2783 KSP Residual norm 1.549604287898e-04
  2784 KSP Residual norm 1.703719426804e-04
  2785 KSP Residual norm 1.805616248544e-04
  2786 KSP Residual norm 1.717352976056e-04
  2787 KSP Residual norm 1.798997042689e-04
  2788 KSP Residual norm 1.935919068536e-04
  2789 KSP Residual norm 1.872616230704e-04
  2790 KSP Residual norm 1.919112296791e-04
  2791 KSP Residual norm 2.286585243015e-04
  2792 KSP Residual norm 2.765361114183e-04
  2793 KSP Residual norm 2.758060604786e-04
  2794 KSP Residual norm 2.698227195502e-04
  2795 KSP Residual norm 2.688331357541e-04
  2796 KSP Residual norm 2.524275970659e-04
  2797 KSP Residual norm 2.345149556368e-04
  2798 KSP Residual norm 2.278747333198e-04
  2799 KSP Residual norm 2.225240719275e-04
  2800 KSP Residual norm 2.193101455626e-04
  2801 KSP Residual norm 2.178120306747e-04
  2802 KSP Residual norm 2.271716852184e-04
  2803 KSP Residual norm 2.371434920195e-04
  2804 KSP Residual norm 2.402546190469e-04
  2805 KSP Residual norm 2.414695269177e-04
  2806 KSP Residual norm 2.534853316148e-04
  2807 KSP Residual norm 2.786161944943e-04
  2808 KSP Residual norm 2.724617926424e-04
  2809 KSP Residual norm 2.470358407787e-04
  2810 KSP Residual norm 2.320861937884e-04
  2811 KSP Residual norm 2.370428873268e-04
  2812 KSP Residual norm 2.308138624931e-04
  2813 KSP Residual norm 2.083255898942e-04
  2814 KSP Residual norm 1.976585687891e-04
  2815 KSP Residual norm 2.090924374615e-04
  2816 KSP Residual norm 2.036391314802e-04
  2817 KSP Residual norm 1.820674727176e-04
  2818 KSP Residual norm 1.753073879342e-04
  2819 KSP Residual norm 1.847920091893e-04
  2820 KSP Residual norm 1.720619150346e-04
  2821 KSP Residual norm 1.502596374527e-04
  2822 KSP Residual norm 1.405689812458e-04
  2823 KSP Residual norm 1.436728871018e-04
  2824 KSP Residual norm 1.316710636961e-04
  2825 KSP Residual norm 1.186837289934e-04
  2826 KSP Residual norm 1.123751433744e-04
  2827 KSP Residual norm 1.039738176819e-04
  2828 KSP Residual norm 9.573492853490e-05
  2829 KSP Residual norm 9.766733552305e-05
  2830 KSP Residual norm 1.018264639792e-04
  2831 KSP Residual norm 8.789914897695e-05
  2832 KSP Residual norm 7.094369186012e-05
  2833 KSP Residual norm 6.401731397682e-05
  2834 KSP Residual norm 6.393255328270e-05
  2835 KSP Residual norm 5.907935211002e-05
  2836 KSP Residual norm 5.554259858867e-05
  2837 KSP Residual norm 5.670866366268e-05
  2838 KSP Residual norm 5.716920078025e-05
  2839 KSP Residual norm 4.889814106269e-05
  2840 KSP Residual norm 4.461754898926e-05
  2841 KSP Residual norm 4.845949008460e-05
  2842 KSP Residual norm 5.407130936100e-05
  2843 KSP Residual norm 5.394734821616e-05
  2844 KSP Residual norm 5.443854893379e-05
  2845 KSP Residual norm 5.880462546781e-05
  2846 KSP Residual norm 5.604589729507e-05
  2847 KSP Residual norm 5.058345932175e-05
  2848 KSP Residual norm 4.983721213943e-05
  2849 KSP Residual norm 5.063103450877e-05
  2850 KSP Residual norm 4.627337103439e-05
  2851 KSP Residual norm 4.150390459422e-05
  2852 KSP Residual norm 4.245217251116e-05
  2853 KSP Residual norm 4.046827461576e-05
  2854 KSP Residual norm 3.653114229107e-05
  2855 KSP Residual norm 3.784893196076e-05
  2856 KSP Residual norm 4.128175046279e-05
  2857 KSP Residual norm 3.820729684273e-05
  2858 KSP Residual norm 3.458811957403e-05
  2859 KSP Residual norm 3.719818425660e-05
  2860 KSP Residual norm 3.989375193757e-05
  2861 KSP Residual norm 3.648437390503e-05
  2862 KSP Residual norm 3.514787474582e-05
  2863 KSP Residual norm 3.672006198590e-05
  2864 KSP Residual norm 3.487635588729e-05
  2865 KSP Residual norm 3.439534231306e-05
  2866 KSP Residual norm 3.791355373752e-05
  2867 KSP Residual norm 3.726644907131e-05
  2868 KSP Residual norm 3.340412398662e-05
  2869 KSP Residual norm 3.433078500336e-05
  2870 KSP Residual norm 3.485951379642e-05
  2871 KSP Residual norm 3.028371556779e-05
  2872 KSP Residual norm 2.867789093390e-05
  2873 KSP Residual norm 3.082443839615e-05
  2874 KSP Residual norm 2.994326024623e-05
  2875 KSP Residual norm 3.002935247278e-05
  2876 KSP Residual norm 3.316997463862e-05
  2877 KSP Residual norm 3.276136460439e-05
  2878 KSP Residual norm 2.967328817999e-05
  2879 KSP Residual norm 2.934388389114e-05
  2880 KSP Residual norm 3.063513702837e-05
  2881 KSP Residual norm 3.083694518454e-05
  2882 KSP Residual norm 3.364540615194e-05
  2883 KSP Residual norm 3.851997271040e-05
  2884 KSP Residual norm 3.725365920289e-05
  2885 KSP Residual norm 3.665755212251e-05
  2886 KSP Residual norm 4.183135204928e-05
  2887 KSP Residual norm 4.752424156926e-05
  2888 KSP Residual norm 4.622243185009e-05
  2889 KSP Residual norm 4.604792000863e-05
  2890 KSP Residual norm 5.217109506257e-05
  2891 KSP Residual norm 5.309730188064e-05
  2892 KSP Residual norm 4.804961159999e-05
  2893 KSP Residual norm 4.798541843952e-05
  2894 KSP Residual norm 5.336060077889e-05
  2895 KSP Residual norm 4.864696884627e-05
  2896 KSP Residual norm 4.558004424790e-05
  2897 KSP Residual norm 5.512078751551e-05
  2898 KSP Residual norm 6.460516218688e-05
  2899 KSP Residual norm 5.832482466266e-05
  2900 KSP Residual norm 5.492796587533e-05
  2901 KSP Residual norm 5.567924095153e-05
  2902 KSP Residual norm 5.391480143795e-05
  2903 KSP Residual norm 5.443350144407e-05
  2904 KSP Residual norm 6.232902255946e-05
  2905 KSP Residual norm 6.914333705745e-05
  2906 KSP Residual norm 6.881440525459e-05
  2907 KSP Residual norm 7.453845917795e-05
  2908 KSP Residual norm 8.708017875334e-05
  2909 KSP Residual norm 8.344870605380e-05
  2910 KSP Residual norm 7.453624025433e-05
  2911 KSP Residual norm 7.973511242386e-05
  2912 KSP Residual norm 8.700347654139e-05
  2913 KSP Residual norm 7.812713737144e-05
  2914 KSP Residual norm 7.121321222264e-05
  2915 KSP Residual norm 7.796145466587e-05
  2916 KSP Residual norm 8.283051864607e-05
  2917 KSP Residual norm 8.406876087447e-05
  2918 KSP Residual norm 8.823189903795e-05
  2919 KSP Residual norm 9.438112448711e-05
  2920 KSP Residual norm 9.940585184990e-05
  2921 KSP Residual norm 1.111926719402e-04
  2922 KSP Residual norm 1.363866387670e-04
  2923 KSP Residual norm 1.548059122572e-04
  2924 KSP Residual norm 1.480819889549e-04
  2925 KSP Residual norm 1.480541835774e-04
  2926 KSP Residual norm 1.663039433726e-04
  2927 KSP Residual norm 1.725729245096e-04
  2928 KSP Residual norm 1.798584679799e-04
  2929 KSP Residual norm 2.029181786275e-04
  2930 KSP Residual norm 2.175519290702e-04
  2931 KSP Residual norm 2.138147497084e-04
  2932 KSP Residual norm 2.259883559807e-04
  2933 KSP Residual norm 2.547658575092e-04
  2934 KSP Residual norm 2.541819599950e-04
  2935 KSP Residual norm 2.589882768857e-04
  2936 KSP Residual norm 2.749082700495e-04
  2937 KSP Residual norm 2.453073162869e-04
  2938 KSP Residual norm 2.091106409589e-04
  2939 KSP Residual norm 2.056865778831e-04
  2940 KSP Residual norm 2.230577610617e-04
  2941 KSP Residual norm 2.284176507170e-04
  2942 KSP Residual norm 2.389221266366e-04
  2943 KSP Residual norm 2.572226436993e-04
  2944 KSP Residual norm 2.541934988709e-04
  2945 KSP Residual norm 2.436760315555e-04
  2946 KSP Residual norm 2.650269390277e-04
  2947 KSP Residual norm 3.069316363096e-04
  2948 KSP Residual norm 3.194951619918e-04
  2949 KSP Residual norm 3.266746126817e-04
  2950 KSP Residual norm 3.529403990272e-04
  2951 KSP Residual norm 3.302983837112e-04
  2952 KSP Residual norm 2.846674313965e-04
  2953 KSP Residual norm 2.925855845015e-04
  2954 KSP Residual norm 3.169611635151e-04
  2955 KSP Residual norm 2.751445295381e-04
  2956 KSP Residual norm 2.422294737745e-04
  2957 KSP Residual norm 2.488107560431e-04
  2958 KSP Residual norm 2.500047578650e-04
  2959 KSP Residual norm 2.163159993911e-04
  2960 KSP Residual norm 2.114109653086e-04
  2961 KSP Residual norm 2.336029640767e-04
  2962 KSP Residual norm 2.345752940936e-04
  2963 KSP Residual norm 2.130572910899e-04
  2964 KSP Residual norm 2.194030454563e-04
  2965 KSP Residual norm 2.242237215919e-04
  2966 KSP Residual norm 2.178423714781e-04
  2967 KSP Residual norm 2.388662628640e-04
  2968 KSP Residual norm 2.944931084366e-04
  2969 KSP Residual norm 2.947638674887e-04
  2970 KSP Residual norm 2.619179336545e-04
  2971 KSP Residual norm 2.607757840989e-04
  2972 KSP Residual norm 2.544625539137e-04
  2973 KSP Residual norm 2.111650403626e-04
  2974 KSP Residual norm 1.955033666107e-04
  2975 KSP Residual norm 2.224039186616e-04
  2976 KSP Residual norm 2.453220239181e-04
  2977 KSP Residual norm 2.150270783634e-04
  2978 KSP Residual norm 1.967434715007e-04
  2979 KSP Residual norm 2.172935661083e-04
  2980 KSP Residual norm 2.282110526316e-04
  2981 KSP Residual norm 2.141826474067e-04
  2982 KSP Residual norm 2.273050325666e-04
  2983 KSP Residual norm 2.511227568465e-04
  2984 KSP Residual norm 2.230076873065e-04
  2985 KSP Residual norm 1.864403880761e-04
  2986 KSP Residual norm 1.809232368430e-04
  2987 KSP Residual norm 1.809260031362e-04
  2988 KSP Residual norm 1.630379180076e-04
  2989 KSP Residual norm 1.550960753377e-04
  2990 KSP Residual norm 1.583229819832e-04
  2991 KSP Residual norm 1.362335808794e-04
  2992 KSP Residual norm 1.165174899278e-04
  2993 KSP Residual norm 1.130495787032e-04
  2994 KSP Residual norm 1.063821105932e-04
  2995 KSP Residual norm 9.769694701050e-05
  2996 KSP Residual norm 1.024099520605e-04
  2997 KSP Residual norm 1.058260267335e-04
  2998 KSP Residual norm 8.793836028414e-05
  2999 KSP Residual norm 7.674189584807e-05
  3000 KSP Residual norm 7.832545060640e-05
  3001 KSP Residual norm 8.123776701662e-05
  3002 KSP Residual norm 7.519430016332e-05
  3003 KSP Residual norm 7.257211117254e-05
  3004 KSP Residual norm 7.895642510913e-05
  3005 KSP Residual norm 8.232248232043e-05
  3006 KSP Residual norm 8.382921520721e-05
  3007 KSP Residual norm 8.917721889460e-05
  3008 KSP Residual norm 8.777029175351e-05
  3009 KSP Residual norm 7.508194797990e-05
  3010 KSP Residual norm 6.969711924552e-05
  3011 KSP Residual norm 7.027711878432e-05
  3012 KSP Residual norm 6.189916665181e-05
  3013 KSP Residual norm 5.558480955307e-05
  3014 KSP Residual norm 5.872701403394e-05
  3015 KSP Residual norm 5.764550801110e-05
  3016 KSP Residual norm 5.335476401032e-05
  3017 KSP Residual norm 5.555393605015e-05
  3018 KSP Residual norm 5.855374239394e-05
  3019 KSP Residual norm 5.118822365574e-05
  3020 KSP Residual norm 4.579096272686e-05
  3021 KSP Residual norm 4.806536921691e-05
  3022 KSP Residual norm 4.784650502488e-05
  3023 KSP Residual norm 4.538791804560e-05
  3024 KSP Residual norm 4.651987261180e-05
  3025 KSP Residual norm 4.586192224891e-05
  3026 KSP Residual norm 3.776080898557e-05
  3027 KSP Residual norm 3.290846065061e-05
  3028 KSP Residual norm 3.358071914431e-05
  3029 KSP Residual norm 3.485233425133e-05
  3030 KSP Residual norm 3.658801529886e-05
  3031 KSP Residual norm 3.823311977423e-05
  3032 KSP Residual norm 3.841317839957e-05
  3033 KSP Residual norm 3.700934014513e-05
  3034 KSP Residual norm 3.553613313720e-05
  3035 KSP Residual norm 3.526560664799e-05
  3036 KSP Residual norm 3.460412178838e-05
  3037 KSP Residual norm 2.980746909890e-05
  3038 KSP Residual norm 2.523321130510e-05
  3039 KSP Residual norm 2.374503422048e-05
  3040 KSP Residual norm 2.490537885031e-05
  3041 KSP Residual norm 2.524430625298e-05
  3042 KSP Residual norm 2.389176915935e-05
  3043 KSP Residual norm 2.140813586129e-05
  3044 KSP Residual norm 1.908501807033e-05
  3045 KSP Residual norm 1.765838887149e-05
  3046 KSP Residual norm 1.826501738451e-05
  3047 KSP Residual norm 2.090275003493e-05
  3048 KSP Residual norm 2.158035304582e-05
  3049 KSP Residual norm 1.948876881701e-05
  3050 KSP Residual norm 1.910639814256e-05
  3051 KSP Residual norm 2.068326874322e-05
  3052 KSP Residual norm 2.007916498953e-05
  3053 KSP Residual norm 1.815216331316e-05
  3054 KSP Residual norm 1.823220740622e-05
  3055 KSP Residual norm 1.878058485588e-05
  3056 KSP Residual norm 1.684918521901e-05
  3057 KSP Residual norm 1.630680279923e-05
  3058 KSP Residual norm 1.792380354438e-05
  3059 KSP Residual norm 1.823191875548e-05
  3060 KSP Residual norm 1.627326294890e-05
  3061 KSP Residual norm 1.501208439504e-05
  3062 KSP Residual norm 1.339173994152e-05
  3063 KSP Residual norm 1.080930988218e-05
  3064 KSP Residual norm 9.813573807538e-06
  3065 KSP Residual norm 9.883940737722e-06
  3066 KSP Residual norm 9.211893052572e-06
  3067 KSP Residual norm 8.590908346866e-06
  3068 KSP Residual norm 9.081093351400e-06
  3069 KSP Residual norm 9.791337341847e-06
  3070 KSP Residual norm 9.539758973048e-06
  3071 KSP Residual norm 9.861434959441e-06
  3072 KSP Residual norm 1.084083441213e-05
  3073 KSP Residual norm 1.112667554158e-05
  3074 KSP Residual norm 1.104646643839e-05
  3075 KSP Residual norm 1.081057403508e-05
  3076 KSP Residual norm 9.796739700224e-06
  3077 KSP Residual norm 8.585495211359e-06
  3078 KSP Residual norm 8.002938914736e-06
  3079 KSP Residual norm 7.697294313625e-06
  3080 KSP Residual norm 7.243160524573e-06
  3081 KSP Residual norm 7.183865939244e-06
  3082 KSP Residual norm 8.266783893935e-06
  3083 KSP Residual norm 8.975129795981e-06
  3084 KSP Residual norm 8.991923271717e-06
  3085 KSP Residual norm 1.047708169981e-05
  3086 KSP Residual norm 1.275011934179e-05
  3087 KSP Residual norm 1.277720469884e-05
  3088 KSP Residual norm 1.288553363823e-05
  3089 KSP Residual norm 1.418076540844e-05
  3090 KSP Residual norm 1.448583501389e-05
  3091 KSP Residual norm 1.351758169845e-05
  3092 KSP Residual norm 1.391327805145e-05
  3093 KSP Residual norm 1.529933903951e-05
  3094 KSP Residual norm 1.518593837087e-05
  3095 KSP Residual norm 1.492448860072e-05
  3096 KSP Residual norm 1.524907396152e-05
  3097 KSP Residual norm 1.499006363869e-05
  3098 KSP Residual norm 1.452586619339e-05
  3099 KSP Residual norm 1.525659444367e-05
  3100 KSP Residual norm 1.675232381260e-05
  3101 KSP Residual norm 1.669833884423e-05
  3102 KSP Residual norm 1.578215365756e-05
  3103 KSP Residual norm 1.579335071994e-05
  3104 KSP Residual norm 1.623841047098e-05
  3105 KSP Residual norm 1.716417691683e-05
  3106 KSP Residual norm 1.827476532089e-05
  3107 KSP Residual norm 2.040807457722e-05
  3108 KSP Residual norm 2.369192074687e-05
  3109 KSP Residual norm 2.437257458675e-05
  3110 KSP Residual norm 2.387742127635e-05
  3111 KSP Residual norm 2.579632231242e-05
  3112 KSP Residual norm 2.903855810130e-05
  3113 KSP Residual norm 2.745761500017e-05
  3114 KSP Residual norm 2.325259707086e-05
  3115 KSP Residual norm 2.261747764403e-05
  3116 KSP Residual norm 2.583994486062e-05
  3117 KSP Residual norm 2.867448580901e-05
  3118 KSP Residual norm 3.034871760602e-05
  3119 KSP Residual norm 3.261381535396e-05
  3120 KSP Residual norm 3.127784419734e-05
  3121 KSP Residual norm 2.868294135036e-05
  3122 KSP Residual norm 3.115919334022e-05
  3123 KSP Residual norm 3.943449309256e-05
  3124 KSP Residual norm 4.490933789997e-05
  3125 KSP Residual norm 4.894636167729e-05
  3126 KSP Residual norm 5.624776004675e-05
  3127 KSP Residual norm 5.912974540235e-05
  3128 KSP Residual norm 5.194683337825e-05
  3129 KSP Residual norm 5.216651363126e-05
  3130 KSP Residual norm 5.532558719964e-05
  3131 KSP Residual norm 5.208773563512e-05
  3132 KSP Residual norm 5.096883663527e-05
  3133 KSP Residual norm 5.459308472875e-05
  3134 KSP Residual norm 5.549600580888e-05
  3135 KSP Residual norm 5.442146066883e-05
  3136 KSP Residual norm 5.753276455022e-05
  3137 KSP Residual norm 6.122030735468e-05
  3138 KSP Residual norm 5.918485535130e-05
  3139 KSP Residual norm 5.903654630292e-05
  3140 KSP Residual norm 5.730854297744e-05
  3141 KSP Residual norm 5.225286365771e-05
  3142 KSP Residual norm 4.958983958548e-05
  3143 KSP Residual norm 4.827273652584e-05
  3144 KSP Residual norm 4.225511949034e-05
  3145 KSP Residual norm 3.530478041503e-05
  3146 KSP Residual norm 3.309154804151e-05
  3147 KSP Residual norm 3.276815863822e-05
  3148 KSP Residual norm 3.364697694738e-05
  3149 KSP Residual norm 3.780043499432e-05
  3150 KSP Residual norm 4.128172651046e-05
  3151 KSP Residual norm 3.941605247750e-05
  3152 KSP Residual norm 3.894883755593e-05
  3153 KSP Residual norm 3.869275314011e-05
  3154 KSP Residual norm 3.126337937533e-05
  3155 KSP Residual norm 2.334903861474e-05
  3156 KSP Residual norm 2.042505202755e-05
  3157 KSP Residual norm 2.148044813468e-05
  3158 KSP Residual norm 2.422204005642e-05
  3159 KSP Residual norm 2.610177872487e-05
  3160 KSP Residual norm 2.508883477346e-05
  3161 KSP Residual norm 2.187083388936e-05
  3162 KSP Residual norm 1.928064401712e-05
  3163 KSP Residual norm 1.926132293728e-05
  3164 KSP Residual norm 2.153059634358e-05
  3165 KSP Residual norm 2.414313715744e-05
  3166 KSP Residual norm 2.493579864012e-05
  3167 KSP Residual norm 2.439520861236e-05
  3168 KSP Residual norm 2.454965597216e-05
  3169 KSP Residual norm 2.496085820912e-05
  3170 KSP Residual norm 2.439405789278e-05
  3171 KSP Residual norm 2.392612885477e-05
  3172 KSP Residual norm 2.359211783333e-05
  3173 KSP Residual norm 2.264111993776e-05
  3174 KSP Residual norm 1.998509448380e-05
  3175 KSP Residual norm 1.884280353401e-05
  3176 KSP Residual norm 1.905853898637e-05
  3177 KSP Residual norm 1.765828869807e-05
  3178 KSP Residual norm 1.538484423549e-05
  3179 KSP Residual norm 1.434760139186e-05
  3180 KSP Residual norm 1.453820858146e-05
  3181 KSP Residual norm 1.494354641437e-05
  3182 KSP Residual norm 1.598534158227e-05
  3183 KSP Residual norm 1.670999027868e-05
  3184 KSP Residual norm 1.506112017854e-05
  3185 KSP Residual norm 1.397175695129e-05
  3186 KSP Residual norm 1.417044338567e-05
  3187 KSP Residual norm 1.341752509942e-05
  3188 KSP Residual norm 1.254078954016e-05
  3189 KSP Residual norm 1.288702429768e-05
  3190 KSP Residual norm 1.255092814294e-05
  3191 KSP Residual norm 1.112101093033e-05
  3192 KSP Residual norm 1.097985344038e-05
  3193 KSP Residual norm 1.272532997403e-05
  3194 KSP Residual norm 1.441222895620e-05
  3195 KSP Residual norm 1.525656540614e-05
  3196 KSP Residual norm 1.580556524554e-05
  3197 KSP Residual norm 1.592224549017e-05
  3198 KSP Residual norm 1.486261759542e-05
  3199 KSP Residual norm 1.395479839347e-05
  3200 KSP Residual norm 1.302747504831e-05
  3201 KSP Residual norm 1.097204366467e-05
  3202 KSP Residual norm 8.751434733207e-06
  3203 KSP Residual norm 7.915740592375e-06
  3204 KSP Residual norm 8.422449099951e-06
  3205 KSP Residual norm 9.666861226815e-06
  3206 KSP Residual norm 1.138276834129e-05
  3207 KSP Residual norm 1.260937701832e-05
  3208 KSP Residual norm 1.135573036472e-05
  3209 KSP Residual norm 8.784882730022e-06
  3210 KSP Residual norm 7.179270154009e-06
  3211 KSP Residual norm 7.052948792399e-06
  3212 KSP Residual norm 8.160581408284e-06
  3213 KSP Residual norm 9.491411441814e-06
  3214 KSP Residual norm 9.212056199399e-06
  3215 KSP Residual norm 8.035896772880e-06
  3216 KSP Residual norm 7.436754549615e-06
  3217 KSP Residual norm 7.147880590288e-06
  3218 KSP Residual norm 6.875806495411e-06
  3219 KSP Residual norm 6.728258016853e-06
  3220 KSP Residual norm 6.558028300309e-06
  3221 KSP Residual norm 5.596744166408e-06
  3222 KSP Residual norm 5.037074779112e-06
  3223 KSP Residual norm 5.502589648588e-06
  3224 KSP Residual norm 6.178138032325e-06
  3225 KSP Residual norm 6.436072389192e-06
  3226 KSP Residual norm 7.493447008679e-06
  3227 KSP Residual norm 8.680384493769e-06
  3228 KSP Residual norm 7.832977153327e-06
  3229 KSP Residual norm 6.119780465391e-06
  3230 KSP Residual norm 4.877503371345e-06
  3231 KSP Residual norm 4.263596073727e-06
  3232 KSP Residual norm 4.403648905265e-06
  3233 KSP Residual norm 4.942259066004e-06
  3234 KSP Residual norm 5.202680539426e-06
  3235 KSP Residual norm 5.376429931578e-06
  3236 KSP Residual norm 6.660289734611e-06
  3237 KSP Residual norm 8.549417156545e-06
  3238 KSP Residual norm 9.296715176002e-06
  3239 KSP Residual norm 9.110451043419e-06
  3240 KSP Residual norm 7.624156801182e-06
  3241 KSP Residual norm 5.381948612026e-06
  3242 KSP Residual norm 4.268577383838e-06
  3243 KSP Residual norm 4.720818114124e-06
  3244 KSP Residual norm 6.619795533018e-06
  3245 KSP Residual norm 9.088521429318e-06
  3246 KSP Residual norm 1.240980759084e-05
  3247 KSP Residual norm 1.493786363687e-05
  3248 KSP Residual norm 1.365507525432e-05
  3249 KSP Residual norm 1.101837794999e-05
  3250 KSP Residual norm 9.916952448789e-06
  3251 KSP Residual norm 9.555267853466e-06
  3252 KSP Residual norm 8.696571482657e-06
  3253 KSP Residual norm 8.719881297786e-06
  3254 KSP Residual norm 1.019029529513e-05
  3255 KSP Residual norm 1.240712557133e-05
  3256 KSP Residual norm 1.464078065964e-05
  3257 KSP Residual norm 1.625956236838e-05
  3258 KSP Residual norm 1.610353819909e-05
  3259 KSP Residual norm 1.547738080799e-05
  3260 KSP Residual norm 1.421341552492e-05
  3261 KSP Residual norm 1.188115606805e-05
  3262 KSP Residual norm 1.104307095892e-05
  3263 KSP Residual norm 1.285298530045e-05
  3264 KSP Residual norm 1.687043171361e-05
  3265 KSP Residual norm 2.166183060300e-05
  3266 KSP Residual norm 2.244302630276e-05
  3267 KSP Residual norm 2.011604266414e-05
  3268 KSP Residual norm 1.708896515367e-05
  3269 KSP Residual norm 1.501541074298e-05
  3270 KSP Residual norm 1.494924928148e-05
  3271 KSP Residual norm 1.459871621442e-05
  3272 KSP Residual norm 1.426206996600e-05
  3273 KSP Residual norm 1.472903432766e-05
  3274 KSP Residual norm 1.491289689752e-05
  3275 KSP Residual norm 1.467911953497e-05
  3276 KSP Residual norm 1.590957422828e-05
  3277 KSP Residual norm 2.106420504973e-05
  3278 KSP Residual norm 2.875038594849e-05
  3279 KSP Residual norm 3.441361421966e-05
  3280 KSP Residual norm 3.569826386577e-05
  3281 KSP Residual norm 3.037877045442e-05
  3282 KSP Residual norm 2.358718078041e-05
  3283 KSP Residual norm 2.188059602841e-05
  3284 KSP Residual norm 2.534623660961e-05
  3285 KSP Residual norm 2.876319439782e-05
  3286 KSP Residual norm 3.034671641283e-05
  3287 KSP Residual norm 3.074901201380e-05
  3288 KSP Residual norm 2.695282094531e-05
  3289 KSP Residual norm 2.122606938440e-05
  3290 KSP Residual norm 1.924344105616e-05
  3291 KSP Residual norm 2.288533317665e-05
  3292 KSP Residual norm 2.994098958874e-05
  3293 KSP Residual norm 3.741701031079e-05
  3294 KSP Residual norm 4.696887899960e-05
  3295 KSP Residual norm 5.233033704070e-05
  3296 KSP Residual norm 4.383546463489e-05
  3297 KSP Residual norm 3.442419415246e-05
  3298 KSP Residual norm 2.550768685969e-05
  3299 KSP Residual norm 1.993359380915e-05
  3300 KSP Residual norm 2.126529708047e-05
  3301 KSP Residual norm 2.842237069288e-05
  3302 KSP Residual norm 3.698428061978e-05
  3303 KSP Residual norm 4.205286673081e-05
  3304 KSP Residual norm 3.890628598452e-05
  3305 KSP Residual norm 2.851784591067e-05
  3306 KSP Residual norm 2.302999464729e-05
  3307 KSP Residual norm 2.453385600675e-05
  3308 KSP Residual norm 3.136492081822e-05
  3309 KSP Residual norm 4.222079531108e-05
  3310 KSP Residual norm 5.165795234999e-05
  3311 KSP Residual norm 5.131479034441e-05
  3312 KSP Residual norm 3.994790820639e-05
  3313 KSP Residual norm 2.747011898276e-05
  3314 KSP Residual norm 2.154710418857e-05
  3315 KSP Residual norm 2.126710001026e-05
  3316 KSP Residual norm 2.593124076821e-05
  3317 KSP Residual norm 3.332746393310e-05
  3318 KSP Residual norm 4.102663241242e-05
  3319 KSP Residual norm 4.141289324964e-05
  3320 KSP Residual norm 3.341756274927e-05
  3321 KSP Residual norm 2.510928691592e-05
  3322 KSP Residual norm 1.861623686504e-05
  3323 KSP Residual norm 1.573029943743e-05
  3324 KSP Residual norm 1.701207366240e-05
  3325 KSP Residual norm 2.219130301786e-05
  3326 KSP Residual norm 2.865259537642e-05
  3327 KSP Residual norm 3.277459980101e-05
  3328 KSP Residual norm 2.967207316529e-05
  3329 KSP Residual norm 2.012967446442e-05
  3330 KSP Residual norm 1.323779610640e-05
  3331 KSP Residual norm 1.170058764125e-05
  3332 KSP Residual norm 1.506874039563e-05
  3333 KSP Residual norm 2.187773957932e-05
  3334 KSP Residual norm 2.807532045097e-05
  3335 KSP Residual norm 3.476178423142e-05
  3336 KSP Residual norm 3.832318442393e-05
  3337 KSP Residual norm 3.105535569413e-05
  3338 KSP Residual norm 1.964748765249e-05
  3339 KSP Residual norm 1.183344877743e-05
  3340 KSP Residual norm 7.696038616628e-06
  3341 KSP Residual norm 6.285333628082e-06
  3342 KSP Residual norm 6.925560461326e-06
  3343 KSP Residual norm 9.918522521907e-06
  3344 KSP Residual norm 1.549464330447e-05
  3345 KSP Residual norm 2.131135161626e-05
  3346 KSP Residual norm 2.015989632038e-05
  3347 KSP Residual norm 1.290775905438e-05
  3348 KSP Residual norm 8.034820805598e-06
  3349 KSP Residual norm 5.705912965930e-06
  3350 KSP Residual norm 4.651391981281e-06
  3351 KSP Residual norm 4.547029847071e-06
  3352 KSP Residual norm 5.679968419010e-06
  3353 KSP Residual norm 8.448900024363e-06
  3354 KSP Residual norm 1.050633558129e-05
  3355 KSP Residual norm 9.679200792397e-06
  3356 KSP Residual norm 8.169027424337e-06
  3357 KSP Residual norm 6.648521428254e-06
  3358 KSP Residual norm 5.710510271592e-06
  3359 KSP Residual norm 5.175795269693e-06
  3360 KSP Residual norm 4.302373918401e-06
  3361 KSP Residual norm 3.629528180964e-06
  3362 KSP Residual norm 3.824357258986e-06
  3363 KSP Residual norm 4.945732969127e-06
  3364 KSP Residual norm 6.423387205401e-06
  3365 KSP Residual norm 6.920275517319e-06
  3366 KSP Residual norm 6.198857464093e-06
  3367 KSP Residual norm 4.626085229782e-06
  3368 KSP Residual norm 3.829072136821e-06
  3369 KSP Residual norm 3.809912689597e-06
  3370 KSP Residual norm 3.814821592034e-06
  3371 KSP Residual norm 3.202989443671e-06
  3372 KSP Residual norm 2.667076448618e-06
  3373 KSP Residual norm 2.468835979289e-06
  3374 KSP Residual norm 2.570826036892e-06
  3375 KSP Residual norm 3.173043705035e-06
  3376 KSP Residual norm 4.039890917904e-06
  3377 KSP Residual norm 4.068178823920e-06
  3378 KSP Residual norm 3.556608311169e-06
  3379 KSP Residual norm 3.028959222301e-06
  3380 KSP Residual norm 2.728996180852e-06
  3381 KSP Residual norm 2.893470883108e-06
  3382 KSP Residual norm 3.286525091617e-06
  3383 KSP Residual norm 3.156415463214e-06
  3384 KSP Residual norm 2.530071511509e-06
  3385 KSP Residual norm 2.128653649856e-06
  3386 KSP Residual norm 2.245452443505e-06
  3387 KSP Residual norm 2.916259437187e-06
  3388 KSP Residual norm 3.915548600624e-06
  3389 KSP Residual norm 5.046566855111e-06
  3390 KSP Residual norm 5.791378848346e-06
  3391 KSP Residual norm 6.258952687663e-06
  3392 KSP Residual norm 6.568897043088e-06
  3393 KSP Residual norm 6.726933143907e-06
  3394 KSP Residual norm 7.124626489960e-06
  3395 KSP Residual norm 6.910813941941e-06
  3396 KSP Residual norm 6.039878504467e-06
  3397 KSP Residual norm 5.002458912617e-06
  3398 KSP Residual norm 4.399671683077e-06
  3399 KSP Residual norm 4.213431829465e-06
  3400 KSP Residual norm 4.348157904986e-06
  3401 KSP Residual norm 4.300414991952e-06
  3402 KSP Residual norm 4.468360130142e-06
  3403 KSP Residual norm 5.244109098856e-06
  3404 KSP Residual norm 6.285041015688e-06
  3405 KSP Residual norm 7.421522913903e-06
  3406 KSP Residual norm 9.008240670641e-06
  3407 KSP Residual norm 9.923541717810e-06
  3408 KSP Residual norm 9.298882641464e-06
  3409 KSP Residual norm 8.883188000123e-06
  3410 KSP Residual norm 9.040650892792e-06
  3411 KSP Residual norm 8.743943345825e-06
  3412 KSP Residual norm 8.432430559586e-06
  3413 KSP Residual norm 7.726172984659e-06
  3414 KSP Residual norm 6.849683706682e-06
  3415 KSP Residual norm 6.774303701723e-06
  3416 KSP Residual norm 8.088012311917e-06
  3417 KSP Residual norm 9.432954227549e-06
  3418 KSP Residual norm 9.851059693386e-06
  3419 KSP Residual norm 1.046597391891e-05
  3420 KSP Residual norm 1.151646125394e-05
  3421 KSP Residual norm 1.296510878071e-05
  3422 KSP Residual norm 1.457289850243e-05
  3423 KSP Residual norm 1.531635524505e-05
  3424 KSP Residual norm 1.457343287216e-05
  3425 KSP Residual norm 1.565590880706e-05
  3426 KSP Residual norm 1.836349518612e-05
  3427 KSP Residual norm 1.883899065806e-05
  3428 KSP Residual norm 1.648177077744e-05
  3429 KSP Residual norm 1.454872874720e-05
  3430 KSP Residual norm 1.336455981563e-05
  3431 KSP Residual norm 1.369876216032e-05
  3432 KSP Residual norm 1.563155986076e-05
  3433 KSP Residual norm 1.773513146678e-05
  3434 KSP Residual norm 1.889918217112e-05
  3435 KSP Residual norm 1.920089108455e-05
  3436 KSP Residual norm 2.073556856208e-05
  3437 KSP Residual norm 2.401413776553e-05
  3438 KSP Residual norm 2.914853612921e-05
  3439 KSP Residual norm 2.980671549895e-05
  3440 KSP Residual norm 2.298654031174e-05
  3441 KSP Residual norm 1.781925990964e-05
  3442 KSP Residual norm 1.788686395393e-05
  3443 KSP Residual norm 2.124456605243e-05
  3444 KSP Residual norm 2.268130375391e-05
  3445 KSP Residual norm 2.015333115727e-05
  3446 KSP Residual norm 1.621876867064e-05
  3447 KSP Residual norm 1.467543589451e-05
  3448 KSP Residual norm 1.638064733787e-05
  3449 KSP Residual norm 1.950538486800e-05
  3450 KSP Residual norm 1.981411821023e-05
  3451 KSP Residual norm 1.746599466306e-05
  3452 KSP Residual norm 1.643555313935e-05
  3453 KSP Residual norm 1.734889796195e-05
  3454 KSP Residual norm 2.025451986627e-05
  3455 KSP Residual norm 2.246522395773e-05
  3456 KSP Residual norm 1.952559143006e-05
  3457 KSP Residual norm 1.535533671459e-05
  3458 KSP Residual norm 1.408359496695e-05
  3459 KSP Residual norm 1.434326783109e-05
  3460 KSP Residual norm 1.331776505808e-05
  3461 KSP Residual norm 1.041632225792e-05
  3462 KSP Residual norm 8.392585985888e-06
  3463 KSP Residual norm 7.557702263398e-06
  3464 KSP Residual norm 7.767591900393e-06
  3465 KSP Residual norm 8.657962758448e-06
  3466 KSP Residual norm 9.201941132156e-06
  3467 KSP Residual norm 9.661589386537e-06
  3468 KSP Residual norm 1.099193006597e-05
  3469 KSP Residual norm 1.296742697896e-05
  3470 KSP Residual norm 1.470399126726e-05
  3471 KSP Residual norm 1.515942185649e-05
  3472 KSP Residual norm 1.373776795099e-05
  3473 KSP Residual norm 1.143048495215e-05
  3474 KSP Residual norm 1.050086772088e-05
  3475 KSP Residual norm 1.115458501625e-05
  3476 KSP Residual norm 1.205072713730e-05
  3477 KSP Residual norm 1.058380332615e-05
  3478 KSP Residual norm 8.284614409351e-06
  3479 KSP Residual norm 6.481384082508e-06
  3480 KSP Residual norm 5.485943661615e-06
  3481 KSP Residual norm 5.580044440494e-06
  3482 KSP Residual norm 6.497775991127e-06
  3483 KSP Residual norm 6.439384241457e-06
  3484 KSP Residual norm 5.678117764058e-06
  3485 KSP Residual norm 5.961734635828e-06
  3486 KSP Residual norm 7.502834229859e-06
  3487 KSP Residual norm 8.761081406637e-06
  3488 KSP Residual norm 8.757232523749e-06
  3489 KSP Residual norm 8.415591899829e-06
  3490 KSP Residual norm 8.455132779463e-06
  3491 KSP Residual norm 8.779996404614e-06
  3492 KSP Residual norm 7.862788956484e-06
  3493 KSP Residual norm 5.782450410104e-06
  3494 KSP Residual norm 4.886546422831e-06
  3495 KSP Residual norm 4.890724197692e-06
  3496 KSP Residual norm 4.518768043227e-06
  3497 KSP Residual norm 3.731502415144e-06
  3498 KSP Residual norm 3.044744448705e-06
  3499 KSP Residual norm 2.723397336297e-06
  3500 KSP Residual norm 2.770578151290e-06
  3501 KSP Residual norm 3.159166450596e-06
  3502 KSP Residual norm 3.688241189002e-06
  3503 KSP Residual norm 3.704320985747e-06
  3504 KSP Residual norm 3.428489675987e-06
  3505 KSP Residual norm 3.664874349453e-06
  3506 KSP Residual norm 4.352063266174e-06
  3507 KSP Residual norm 5.095564988528e-06
  3508 KSP Residual norm 4.804007198632e-06
  3509 KSP Residual norm 3.944664147018e-06
  3510 KSP Residual norm 3.456089538284e-06
  3511 KSP Residual norm 3.353091755052e-06
  3512 KSP Residual norm 3.118295620289e-06
  3513 KSP Residual norm 2.634647287076e-06
  3514 KSP Residual norm 2.215318825704e-06
  3515 KSP Residual norm 2.107536549470e-06
  3516 KSP Residual norm 2.301761198864e-06
  3517 KSP Residual norm 2.634306633637e-06
  3518 KSP Residual norm 2.833486049921e-06
  3519 KSP Residual norm 2.819906321408e-06
  3520 KSP Residual norm 2.862448622959e-06
  3521 KSP Residual norm 3.103444214171e-06
  3522 KSP Residual norm 3.425086911027e-06
  3523 KSP Residual norm 3.052250060194e-06
  3524 KSP Residual norm 2.485378804797e-06
  3525 KSP Residual norm 2.329194879576e-06
  3526 KSP Residual norm 2.559072393455e-06
  3527 KSP Residual norm 2.691869934022e-06
  3528 KSP Residual norm 2.330669891274e-06
  3529 KSP Residual norm 1.849617027315e-06
  3530 KSP Residual norm 1.735085388705e-06
  3531 KSP Residual norm 1.898541178296e-06
  3532 KSP Residual norm 1.966065807046e-06
  3533 KSP Residual norm 1.754529346136e-06
  3534 KSP Residual norm 1.641007933640e-06
  3535 KSP Residual norm 1.888080792190e-06
  3536 KSP Residual norm 2.241713842927e-06
  3537 KSP Residual norm 2.129589016449e-06
  3538 KSP Residual norm 1.715606109555e-06
  3539 KSP Residual norm 1.441516077675e-06
  3540 KSP Residual norm 1.446329978727e-06
  3541 KSP Residual norm 1.579618228880e-06
  3542 KSP Residual norm 1.333454780343e-06
  3543 KSP Residual norm 9.645580401823e-07
  3544 KSP Residual norm 8.439710765374e-07
  3545 KSP Residual norm 9.192985179820e-07
  3546 KSP Residual norm 9.582221181273e-07
  3547 KSP Residual norm 7.676738408684e-07
  3548 KSP Residual norm 6.271246004834e-07
  3549 KSP Residual norm 6.349349447433e-07
  3550 KSP Residual norm 7.710621406193e-07
  3551 KSP Residual norm 9.320923312000e-07
  3552 KSP Residual norm 9.396954030959e-07
  3553 KSP Residual norm 9.271868753915e-07
  3554 KSP Residual norm 9.959760553364e-07
  3555 KSP Residual norm 1.102413847981e-06
  3556 KSP Residual norm 1.074699634744e-06
  3557 KSP Residual norm 9.528623251440e-07
  3558 KSP Residual norm 9.344857084589e-07
  3559 KSP Residual norm 9.156164586489e-07
  3560 KSP Residual norm 8.528582496735e-07
  3561 KSP Residual norm 7.610264110662e-07
  3562 KSP Residual norm 6.756343575947e-07
  3563 KSP Residual norm 6.388532147174e-07
  3564 KSP Residual norm 6.034252364984e-07
  3565 KSP Residual norm 5.062399809483e-07
  3566 KSP Residual norm 4.151200989298e-07
  3567 KSP Residual norm 4.032793815091e-07
  3568 KSP Residual norm 4.245988852464e-07
  3569 KSP Residual norm 3.825914344821e-07
  3570 KSP Residual norm 3.218384993194e-07
  3571 KSP Residual norm 3.109639768267e-07
  3572 KSP Residual norm 3.480219430295e-07
  3573 KSP Residual norm 4.223271752347e-07
  3574 KSP Residual norm 4.733245503122e-07
  3575 KSP Residual norm 4.443357596441e-07
  3576 KSP Residual norm 4.706528308369e-07
  3577 KSP Residual norm 5.868780622195e-07
  3578 KSP Residual norm 6.320335883680e-07
  3579 KSP Residual norm 5.410744182738e-07
  3580 KSP Residual norm 4.611244183073e-07
  3581 KSP Residual norm 4.562796351967e-07
  3582 KSP Residual norm 4.840517271442e-07
  3583 KSP Residual norm 4.846836465960e-07
  3584 KSP Residual norm 4.118916078670e-07
  3585 KSP Residual norm 3.385529841682e-07
  3586 KSP Residual norm 3.394438641770e-07
  3587 KSP Residual norm 3.878073162125e-07
  3588 KSP Residual norm 3.855427723957e-07
  3589 KSP Residual norm 3.763532974457e-07
  3590 KSP Residual norm 4.249176531873e-07
  3591 KSP Residual norm 4.951792588903e-07
  3592 KSP Residual norm 5.230653504428e-07
  3593 KSP Residual norm 5.166776135398e-07
  3594 KSP Residual norm 4.885661548536e-07
  3595 KSP Residual norm 5.089913209592e-07
  3596 KSP Residual norm 6.105817958582e-07
  3597 KSP Residual norm 6.744076293441e-07
  3598 KSP Residual norm 6.570618383792e-07
  3599 KSP Residual norm 6.803180224173e-07
  3600 KSP Residual norm 7.821022050445e-07
  3601 KSP Residual norm 8.480486496661e-07
  3602 KSP Residual norm 8.030118290118e-07
  3603 KSP Residual norm 7.183263359764e-07
  3604 KSP Residual norm 6.783240521457e-07
  3605 KSP Residual norm 6.976403169247e-07
  3606 KSP Residual norm 6.205059463396e-07
  3607 KSP Residual norm 4.719339261862e-07
  3608 KSP Residual norm 4.068526599426e-07
  3609 KSP Residual norm 4.272043268057e-07
  3610 KSP Residual norm 4.385974004489e-07
  3611 KSP Residual norm 4.057838074545e-07
  3612 KSP Residual norm 4.025013261647e-07
  3613 KSP Residual norm 4.284246321281e-07
  3614 KSP Residual norm 4.758598998461e-07
  3615 KSP Residual norm 5.371053557119e-07
  3616 KSP Residual norm 5.488740312323e-07
  3617 KSP Residual norm 5.891733783876e-07
  3618 KSP Residual norm 7.418999387560e-07
  3619 KSP Residual norm 8.853355059951e-07
  3620 KSP Residual norm 9.462025140680e-07
  3621 KSP Residual norm 1.054787551529e-06
  3622 KSP Residual norm 1.248844041606e-06
  3623 KSP Residual norm 1.531262547759e-06
  3624 KSP Residual norm 1.849772865716e-06
  3625 KSP Residual norm 2.033684609760e-06
  3626 KSP Residual norm 2.152610442800e-06
  3627 KSP Residual norm 2.464354850171e-06
  3628 KSP Residual norm 3.002453322179e-06
  3629 KSP Residual norm 3.083836558514e-06
  3630 KSP Residual norm 2.606788998609e-06
  3631 KSP Residual norm 2.387570103142e-06
  3632 KSP Residual norm 2.474155408846e-06
  3633 KSP Residual norm 2.695110143048e-06
  3634 KSP Residual norm 2.761896678164e-06
  3635 KSP Residual norm 2.638706373999e-06
  3636 KSP Residual norm 2.714194588856e-06
  3637 KSP Residual norm 3.172702504316e-06
  3638 KSP Residual norm 3.588080613719e-06
  3639 KSP Residual norm 3.351696232698e-06
  3640 KSP Residual norm 3.299169626506e-06
  3641 KSP Residual norm 3.826184395197e-06
  3642 KSP Residual norm 4.273069367044e-06
  3643 KSP Residual norm 4.441033436856e-06
  3644 KSP Residual norm 4.525507794219e-06
  3645 KSP Residual norm 4.622571681548e-06
  3646 KSP Residual norm 4.781589235052e-06
  3647 KSP Residual norm 4.913356228468e-06
  3648 KSP Residual norm 4.588498902656e-06
  3649 KSP Residual norm 4.444980124599e-06
  3650 KSP Residual norm 5.056860726362e-06
  3651 KSP Residual norm 5.686530029130e-06
  3652 KSP Residual norm 5.092280320456e-06
  3653 KSP Residual norm 4.837444826180e-06
  3654 KSP Residual norm 5.286485565352e-06
  3655 KSP Residual norm 5.154481267991e-06
  3656 KSP Residual norm 4.762643924650e-06
  3657 KSP Residual norm 4.585610017958e-06
  3658 KSP Residual norm 4.360509794952e-06
  3659 KSP Residual norm 4.264795850216e-06
  3660 KSP Residual norm 4.530978009758e-06
  3661 KSP Residual norm 4.443603117495e-06
  3662 KSP Residual norm 4.170560435769e-06
  3663 KSP Residual norm 4.225170560361e-06
  3664 KSP Residual norm 4.422941253743e-06
  3665 KSP Residual norm 4.392045373930e-06
  3666 KSP Residual norm 4.592818157570e-06
  3667 KSP Residual norm 4.780611599568e-06
  3668 KSP Residual norm 4.716905451106e-06
  3669 KSP Residual norm 4.937769765162e-06
  3670 KSP Residual norm 5.304756241094e-06
  3671 KSP Residual norm 5.191910998404e-06
  3672 KSP Residual norm 4.753438357897e-06
  3673 KSP Residual norm 4.269504706704e-06
  3674 KSP Residual norm 3.875836261946e-06
  3675 KSP Residual norm 3.758530621443e-06
  3676 KSP Residual norm 3.542483040917e-06
  3677 KSP Residual norm 2.917160506852e-06
  3678 KSP Residual norm 2.466230878100e-06
  3679 KSP Residual norm 2.401609746696e-06
  3680 KSP Residual norm 2.323964570817e-06
  3681 KSP Residual norm 2.077019978141e-06
  3682 KSP Residual norm 2.044328302573e-06
  3683 KSP Residual norm 2.303704496015e-06
  3684 KSP Residual norm 2.800020364772e-06
  3685 KSP Residual norm 3.132232747929e-06
  3686 KSP Residual norm 3.020493793944e-06
  3687 KSP Residual norm 2.759433828957e-06
  3688 KSP Residual norm 2.903929612669e-06
  3689 KSP Residual norm 3.028016108264e-06
  3690 KSP Residual norm 2.800120658122e-06
  3691 KSP Residual norm 2.746148229032e-06
  3692 KSP Residual norm 2.940429999851e-06
  3693 KSP Residual norm 3.063173237658e-06
  3694 KSP Residual norm 2.876877974440e-06
  3695 KSP Residual norm 2.415717454831e-06
  3696 KSP Residual norm 2.042197343663e-06
  3697 KSP Residual norm 1.821052134087e-06
  3698 KSP Residual norm 1.594767834728e-06
  3699 KSP Residual norm 1.291190117978e-06
  3700 KSP Residual norm 1.088918243555e-06
  3701 KSP Residual norm 1.044565588725e-06
  3702 KSP Residual norm 1.080917483961e-06
  3703 KSP Residual norm 1.016866562235e-06
  3704 KSP Residual norm 9.738967586824e-07
  3705 KSP Residual norm 1.030118717800e-06
  3706 KSP Residual norm 1.149573300664e-06
  3707 KSP Residual norm 1.280360872830e-06
  3708 KSP Residual norm 1.354074410667e-06
  3709 KSP Residual norm 1.318511366349e-06
  3710 KSP Residual norm 1.386781773062e-06
  3711 KSP Residual norm 1.525080313129e-06
  3712 KSP Residual norm 1.479698737472e-06
  3713 KSP Residual norm 1.432648061976e-06
  3714 KSP Residual norm 1.462875024770e-06
  3715 KSP Residual norm 1.383965558921e-06
  3716 KSP Residual norm 1.270742076136e-06
  3717 KSP Residual norm 1.171423655535e-06
  3718 KSP Residual norm 1.059754951912e-06
  3719 KSP Residual norm 9.422430271395e-07
  3720 KSP Residual norm 8.973334995884e-07
  3721 KSP Residual norm 8.383454102375e-07
  3722 KSP Residual norm 7.315684899432e-07
  3723 KSP Residual norm 7.081525117260e-07
  3724 KSP Residual norm 6.968663477808e-07
  3725 KSP Residual norm 6.952172806436e-07
  3726 KSP Residual norm 7.267344400176e-07
  3727 KSP Residual norm 8.107590605001e-07
  3728 KSP Residual norm 8.227224979989e-07
  3729 KSP Residual norm 8.294665474125e-07
  3730 KSP Residual norm 8.746843014578e-07
  3731 KSP Residual norm 9.445583595244e-07
  3732 KSP Residual norm 1.071064226952e-06
  3733 KSP Residual norm 1.262859292283e-06
  3734 KSP Residual norm 1.367596354232e-06
  3735 KSP Residual norm 1.388293351752e-06
  3736 KSP Residual norm 1.515373335978e-06
  3737 KSP Residual norm 1.630040652584e-06
  3738 KSP Residual norm 1.562416806984e-06
  3739 KSP Residual norm 1.529240057852e-06
  3740 KSP Residual norm 1.591940402724e-06
  3741 KSP Residual norm 1.660031391113e-06
  3742 KSP Residual norm 1.632973798744e-06
  3743 KSP Residual norm 1.552814259800e-06
  3744 KSP Residual norm 1.440819589805e-06
  3745 KSP Residual norm 1.430247065142e-06
  3746 KSP Residual norm 1.516318466711e-06
  3747 KSP Residual norm 1.469908935461e-06
  3748 KSP Residual norm 1.408366151022e-06
  3749 KSP Residual norm 1.303558869278e-06
  3750 KSP Residual norm 1.062321009734e-06
  3751 KSP Residual norm 8.702210268361e-07
  3752 KSP Residual norm 8.259925774839e-07
  3753 KSP Residual norm 8.058986009137e-07
  3754 KSP Residual norm 7.737775110823e-07
  3755 KSP Residual norm 8.103513608520e-07
  3756 KSP Residual norm 8.798638966731e-07
  3757 KSP Residual norm 8.841383635747e-07
  3758 KSP Residual norm 9.120599544767e-07
  3759 KSP Residual norm 9.851031676935e-07
  3760 KSP Residual norm 1.012672850688e-06
  3761 KSP Residual norm 1.073177107955e-06
  3762 KSP Residual norm 1.195683000042e-06
  3763 KSP Residual norm 1.166148943804e-06
  3764 KSP Residual norm 1.140841372740e-06
  3765 KSP Residual norm 1.211455307420e-06
  3766 KSP Residual norm 1.353990561219e-06
  3767 KSP Residual norm 1.522463109306e-06
  3768 KSP Residual norm 1.627904833774e-06
  3769 KSP Residual norm 1.608470525836e-06
  3770 KSP Residual norm 1.587587554794e-06
  3771 KSP Residual norm 1.615992846795e-06
  3772 KSP Residual norm 1.499939809079e-06
  3773 KSP Residual norm 1.359532500993e-06
  3774 KSP Residual norm 1.428909780163e-06
  3775 KSP Residual norm 1.445303386031e-06
  3776 KSP Residual norm 1.268380512460e-06
  3777 KSP Residual norm 1.226031745217e-06
  3778 KSP Residual norm 1.249574755914e-06
  3779 KSP Residual norm 1.234927751935e-06
  3780 KSP Residual norm 1.279231771040e-06
  3781 KSP Residual norm 1.420421339161e-06
  3782 KSP Residual norm 1.591164656229e-06
  3783 KSP Residual norm 1.755560572054e-06
  3784 KSP Residual norm 1.939712723472e-06
  3785 KSP Residual norm 2.158903182487e-06
  3786 KSP Residual norm 2.358977066217e-06
  3787 KSP Residual norm 2.318318510283e-06
  3788 KSP Residual norm 2.271296198857e-06
  3789 KSP Residual norm 2.567608144724e-06
  3790 KSP Residual norm 3.356690704413e-06
  3791 KSP Residual norm 3.840776912695e-06
  3792 KSP Residual norm 3.810442916231e-06
  3793 KSP Residual norm 4.272043675216e-06
  3794 KSP Residual norm 5.329524556348e-06
  3795 KSP Residual norm 5.852636762068e-06
  3796 KSP Residual norm 5.630433506794e-06
  3797 KSP Residual norm 5.244693500175e-06
  3798 KSP Residual norm 5.124463923441e-06
  3799 KSP Residual norm 5.444720518857e-06
  3800 KSP Residual norm 5.654689161350e-06
  3801 KSP Residual norm 5.019189014019e-06
  3802 KSP Residual norm 4.327008154834e-06
  3803 KSP Residual norm 3.795545965977e-06
  3804 KSP Residual norm 3.272145602977e-06
  3805 KSP Residual norm 2.882268172501e-06
  3806 KSP Residual norm 2.783864025375e-06
  3807 KSP Residual norm 2.869413910309e-06
  3808 KSP Residual norm 2.886645736391e-06
  3809 KSP Residual norm 2.978978804025e-06
  3810 KSP Residual norm 3.050697107902e-06
  3811 KSP Residual norm 3.152653521429e-06
  3812 KSP Residual norm 3.539045914679e-06
  3813 KSP Residual norm 4.080952973986e-06
  3814 KSP Residual norm 4.056366242479e-06
  3815 KSP Residual norm 4.128619597827e-06
  3816 KSP Residual norm 4.585346515874e-06
  3817 KSP Residual norm 5.395200941763e-06
  3818 KSP Residual norm 6.130422841083e-06
  3819 KSP Residual norm 6.746848625216e-06
  3820 KSP Residual norm 7.281251030174e-06
  3821 KSP Residual norm 8.363904703077e-06
  3822 KSP Residual norm 9.374561540588e-06
  3823 KSP Residual norm 8.703124786078e-06
  3824 KSP Residual norm 7.474884767157e-06
  3825 KSP Residual norm 7.103133456034e-06
  3826 KSP Residual norm 6.960668559380e-06
  3827 KSP Residual norm 6.672238211021e-06
  3828 KSP Residual norm 6.767395453705e-06
  3829 KSP Residual norm 7.363019083227e-06
  3830 KSP Residual norm 7.300953027647e-06
  3831 KSP Residual norm 6.651025999016e-06
  3832 KSP Residual norm 6.032274823082e-06
  3833 KSP Residual norm 5.368710672885e-06
  3834 KSP Residual norm 4.942438383253e-06
  3835 KSP Residual norm 4.552462089858e-06
  3836 KSP Residual norm 4.107684203262e-06
  3837 KSP Residual norm 4.290079933508e-06
  3838 KSP Residual norm 4.748851158122e-06
  3839 KSP Residual norm 4.777990905957e-06
  3840 KSP Residual norm 4.746523940651e-06
  3841 KSP Residual norm 5.431783114485e-06
  3842 KSP Residual norm 5.998721400670e-06
  3843 KSP Residual norm 5.994891506696e-06
  3844 KSP Residual norm 6.399145053679e-06
  3845 KSP Residual norm 7.159641088552e-06
  3846 KSP Residual norm 7.561793062474e-06
  3847 KSP Residual norm 7.479628299684e-06
  3848 KSP Residual norm 7.770825015306e-06
  3849 KSP Residual norm 8.562821038079e-06
  3850 KSP Residual norm 1.011488929149e-05
  3851 KSP Residual norm 1.094132392167e-05
  3852 KSP Residual norm 9.633134400814e-06
  3853 KSP Residual norm 8.544313293936e-06
  3854 KSP Residual norm 8.270855248278e-06
  3855 KSP Residual norm 7.820370290377e-06
  3856 KSP Residual norm 6.871965207121e-06
  3857 KSP Residual norm 5.951786552651e-06
  3858 KSP Residual norm 5.360502683583e-06
  3859 KSP Residual norm 5.414101965805e-06
  3860 KSP Residual norm 5.525984141113e-06
  3861 KSP Residual norm 5.208047400202e-06
  3862 KSP Residual norm 5.005375572901e-06
  3863 KSP Residual norm 5.307256257210e-06
  3864 KSP Residual norm 5.407369481090e-06
  3865 KSP Residual norm 5.227287184623e-06
  3866 KSP Residual norm 5.632868054008e-06
  3867 KSP Residual norm 6.936464699798e-06
  3868 KSP Residual norm 8.000146571746e-06
  3869 KSP Residual norm 8.593621213014e-06
  3870 KSP Residual norm 9.320002023306e-06
  3871 KSP Residual norm 9.768270304624e-06
  3872 KSP Residual norm 1.010525703557e-05
  3873 KSP Residual norm 1.036052578915e-05
  3874 KSP Residual norm 1.061429347273e-05
  3875 KSP Residual norm 1.166408852793e-05
  3876 KSP Residual norm 1.274939454818e-05
  3877 KSP Residual norm 1.223446056877e-05
  3878 KSP Residual norm 1.200067930319e-05
  3879 KSP Residual norm 1.236379270639e-05
  3880 KSP Residual norm 1.204555003139e-05
  3881 KSP Residual norm 1.097562163311e-05
  3882 KSP Residual norm 1.060829734514e-05
  3883 KSP Residual norm 1.049679185549e-05
  3884 KSP Residual norm 9.360125192350e-06
  3885 KSP Residual norm 8.876918486251e-06
  3886 KSP Residual norm 8.530351824767e-06
  3887 KSP Residual norm 8.009290019789e-06
  3888 KSP Residual norm 8.008801783341e-06
  3889 KSP Residual norm 7.590950111824e-06
  3890 KSP Residual norm 6.557974520820e-06
  3891 KSP Residual norm 6.099623183748e-06
  3892 KSP Residual norm 6.301827433178e-06
  3893 KSP Residual norm 6.338419462456e-06
  3894 KSP Residual norm 7.000523373679e-06
  3895 KSP Residual norm 8.963951528421e-06
  3896 KSP Residual norm 1.105496514305e-05
  3897 KSP Residual norm 1.131477202679e-05
  3898 KSP Residual norm 1.168041414311e-05
  3899 KSP Residual norm 1.261022864377e-05
  3900 KSP Residual norm 1.244473474677e-05
  3901 KSP Residual norm 1.248614919990e-05
  3902 KSP Residual norm 1.285753477646e-05
  3903 KSP Residual norm 1.299399636268e-05
  3904 KSP Residual norm 1.431623668462e-05
  3905 KSP Residual norm 1.584639889953e-05
  3906 KSP Residual norm 1.569555867591e-05
  3907 KSP Residual norm 1.549631167506e-05
  3908 KSP Residual norm 1.531167944840e-05
  3909 KSP Residual norm 1.323549949407e-05
  3910 KSP Residual norm 1.173037843572e-05
  3911 KSP Residual norm 1.124040223446e-05
  3912 KSP Residual norm 1.014137060834e-05
  3913 KSP Residual norm 8.267592648466e-06
  3914 KSP Residual norm 7.057529652661e-06
  3915 KSP Residual norm 6.342773202148e-06
  3916 KSP Residual norm 5.745664904008e-06
  3917 KSP Residual norm 5.361638071649e-06
  3918 KSP Residual norm 4.480233892138e-06
  3919 KSP Residual norm 3.803935908037e-06
  3920 KSP Residual norm 3.729284071624e-06
  3921 KSP Residual norm 3.664406335496e-06
  3922 KSP Residual norm 3.346082469532e-06
  3923 KSP Residual norm 3.277710122132e-06
  3924 KSP Residual norm 3.317248808822e-06
  3925 KSP Residual norm 3.101985570883e-06
  3926 KSP Residual norm 2.835559984315e-06
  3927 KSP Residual norm 2.806202255822e-06
  3928 KSP Residual norm 2.866816147590e-06
  3929 KSP Residual norm 3.046421172426e-06
  3930 KSP Residual norm 3.340653824567e-06
  3931 KSP Residual norm 3.481752448748e-06
  3932 KSP Residual norm 3.793235932999e-06
  3933 KSP Residual norm 4.589915951669e-06
  3934 KSP Residual norm 5.260319918914e-06
  3935 KSP Residual norm 5.068741225741e-06
  3936 KSP Residual norm 5.233519922258e-06
  3937 KSP Residual norm 5.608754644663e-06
  3938 KSP Residual norm 5.280688672832e-06
  3939 KSP Residual norm 4.688827804566e-06
  3940 KSP Residual norm 4.509159847625e-06
  3941 KSP Residual norm 4.524163865744e-06
  3942 KSP Residual norm 4.498420002468e-06
  3943 KSP Residual norm 4.042225112591e-06
  3944 KSP Residual norm 3.528011278487e-06
  3945 KSP Residual norm 3.676270594623e-06
  3946 KSP Residual norm 4.316137799525e-06
  3947 KSP Residual norm 4.265000129805e-06
  3948 KSP Residual norm 3.933686303661e-06
  3949 KSP Residual norm 4.045733582554e-06
  3950 KSP Residual norm 4.013671359101e-06
  3951 KSP Residual norm 3.509156177225e-06
  3952 KSP Residual norm 3.047449933389e-06
  3953 KSP Residual norm 2.945008087037e-06
  3954 KSP Residual norm 3.009269881032e-06
  3955 KSP Residual norm 3.066857051109e-06
  3956 KSP Residual norm 2.701925467700e-06
  3957 KSP Residual norm 2.354299306823e-06
  3958 KSP Residual norm 2.552126920559e-06
  3959 KSP Residual norm 3.169367356218e-06
  3960 KSP Residual norm 3.524024537499e-06
  3961 KSP Residual norm 3.596042564301e-06
  3962 KSP Residual norm 3.903056061934e-06
  3963 KSP Residual norm 4.090661779472e-06
  3964 KSP Residual norm 4.117562810927e-06
  3965 KSP Residual norm 4.164906567608e-06
  3966 KSP Residual norm 4.174242155959e-06
  3967 KSP Residual norm 4.397279913906e-06
  3968 KSP Residual norm 4.619749380131e-06
  3969 KSP Residual norm 4.319395139712e-06
  3970 KSP Residual norm 4.222769983938e-06
  3971 KSP Residual norm 4.695183902939e-06
  3972 KSP Residual norm 4.979577503148e-06
  3973 KSP Residual norm 4.546814703982e-06
  3974 KSP Residual norm 4.508707065855e-06
  3975 KSP Residual norm 4.868374733462e-06
  3976 KSP Residual norm 4.872509966033e-06
  3977 KSP Residual norm 4.541927740416e-06
  3978 KSP Residual norm 3.949368491098e-06
  3979 KSP Residual norm 3.364234175214e-06
  3980 KSP Residual norm 3.076584556032e-06
  3981 KSP Residual norm 2.877187798763e-06
  3982 KSP Residual norm 2.602491799925e-06
  3983 KSP Residual norm 2.547247921317e-06
  3984 KSP Residual norm 2.342735656875e-06
  3985 KSP Residual norm 1.810269522062e-06
  3986 KSP Residual norm 1.524509617965e-06
  3987 KSP Residual norm 1.473619204396e-06
  3988 KSP Residual norm 1.425998943179e-06
  3989 KSP Residual norm 1.365835136384e-06
  3990 KSP Residual norm 1.321311529931e-06
  3991 KSP Residual norm 1.239468999999e-06
  3992 KSP Residual norm 1.200630334762e-06
  3993 KSP Residual norm 1.177486702682e-06
  3994 KSP Residual norm 1.146270919585e-06
  3995 KSP Residual norm 1.203034759077e-06
  3996 KSP Residual norm 1.361136739204e-06
  3997 KSP Residual norm 1.394054599714e-06
  3998 KSP Residual norm 1.340223508940e-06
  3999 KSP Residual norm 1.529349104796e-06
  4000 KSP Residual norm 1.843794676089e-06
  4001 KSP Residual norm 2.011938517545e-06
  4002 KSP Residual norm 2.200087542422e-06
  4003 KSP Residual norm 2.664630149047e-06
  4004 KSP Residual norm 3.337513912444e-06
  4005 KSP Residual norm 3.791481240069e-06
  4006 KSP Residual norm 3.675329690418e-06
  4007 KSP Residual norm 3.344306223204e-06
  4008 KSP Residual norm 3.459187591552e-06
  4009 KSP Residual norm 4.008910872003e-06
  4010 KSP Residual norm 4.241212035824e-06
  4011 KSP Residual norm 4.117465405779e-06
  4012 KSP Residual norm 4.498301821306e-06
  4013 KSP Residual norm 5.067254086874e-06
  4014 KSP Residual norm 5.110000013286e-06
  4015 KSP Residual norm 4.834952253881e-06
  4016 KSP Residual norm 4.392434146129e-06
  4017 KSP Residual norm 4.203026242153e-06
  4018 KSP Residual norm 4.430658429098e-06
  4019 KSP Residual norm 4.400852175412e-06
  4020 KSP Residual norm 4.095238261669e-06
  4021 KSP Residual norm 3.689313397723e-06
  4022 KSP Residual norm 3.118165644290e-06
  4023 KSP Residual norm 2.416568615801e-06
  4024 KSP Residual norm 2.221954449922e-06
  4025 KSP Residual norm 2.282377786359e-06
  4026 KSP Residual norm 2.226676689853e-06
  4027 KSP Residual norm 2.255980249626e-06
  4028 KSP Residual norm 2.550292415727e-06
  4029 KSP Residual norm 2.863728156467e-06
  4030 KSP Residual norm 3.063258678214e-06
  4031 KSP Residual norm 3.199212696736e-06
  4032 KSP Residual norm 3.353509394471e-06
  4033 KSP Residual norm 3.696604520907e-06
  4034 KSP Residual norm 4.516201046009e-06
  4035 KSP Residual norm 5.234253087695e-06
  4036 KSP Residual norm 4.997151472966e-06
  4037 KSP Residual norm 5.018256341283e-06
  4038 KSP Residual norm 5.456310802496e-06
  4039 KSP Residual norm 5.480412341116e-06
  4040 KSP Residual norm 5.201160480214e-06
  4041 KSP Residual norm 5.570747285710e-06
  4042 KSP Residual norm 6.208550888128e-06
  4043 KSP Residual norm 6.979833294015e-06
  4044 KSP Residual norm 7.502132814159e-06
  4045 KSP Residual norm 7.106557773647e-06
  4046 KSP Residual norm 6.711742832633e-06
  4047 KSP Residual norm 6.173565996458e-06
  4048 KSP Residual norm 5.024413271093e-06
  4049 KSP Residual norm 4.158467148615e-06
  4050 KSP Residual norm 3.908694618079e-06
  4051 KSP Residual norm 3.827551925999e-06
  4052 KSP Residual norm 3.560695861823e-06
  4053 KSP Residual norm 3.457697050780e-06
  4054 KSP Residual norm 3.699141814143e-06
  4055 KSP Residual norm 3.897364526619e-06
  4056 KSP Residual norm 3.849794339861e-06
  4057 KSP Residual norm 3.805542853945e-06
  4058 KSP Residual norm 3.737819714822e-06
  4059 KSP Residual norm 3.856330607394e-06
  4060 KSP Residual norm 4.220779335093e-06
  4061 KSP Residual norm 4.602696295204e-06
  4062 KSP Residual norm 4.858600525129e-06
  4063 KSP Residual norm 5.165473240074e-06
  4064 KSP Residual norm 5.539455763645e-06
  4065 KSP Residual norm 5.787367508374e-06
  4066 KSP Residual norm 5.995999606028e-06
  4067 KSP Residual norm 5.976195633230e-06
  4068 KSP Residual norm 6.180948496748e-06
  4069 KSP Residual norm 7.460770120668e-06
  4070 KSP Residual norm 8.970797199034e-06
  4071 KSP Residual norm 9.287737191090e-06
  4072 KSP Residual norm 9.385475164838e-06
  4073 KSP Residual norm 1.053733436957e-05
  4074 KSP Residual norm 1.217077813649e-05
  4075 KSP Residual norm 1.289568087582e-05
  4076 KSP Residual norm 1.139917218444e-05
  4077 KSP Residual norm 1.055754089672e-05
  4078 KSP Residual norm 1.166916257122e-05
  4079 KSP Residual norm 1.274780549066e-05
  4080 KSP Residual norm 1.166800446754e-05
  4081 KSP Residual norm 9.875329156147e-06
  4082 KSP Residual norm 8.702883473273e-06
  4083 KSP Residual norm 8.345822535095e-06
  4084 KSP Residual norm 8.666013393134e-06
  4085 KSP Residual norm 8.655426618629e-06
  4086 KSP Residual norm 7.814370630228e-06
  4087 KSP Residual norm 7.106978803345e-06
  4088 KSP Residual norm 6.646471373602e-06
  4089 KSP Residual norm 5.814288829641e-06
  4090 KSP Residual norm 5.104821438660e-06
  4091 KSP Residual norm 4.835549919843e-06
  4092 KSP Residual norm 4.383854980778e-06
  4093 KSP Residual norm 4.132393430280e-06
  4094 KSP Residual norm 4.363886597331e-06
  4095 KSP Residual norm 4.621913466172e-06
  4096 KSP Residual norm 4.891155336691e-06
  4097 KSP Residual norm 5.377049794437e-06
  4098 KSP Residual norm 5.976734625296e-06
  4099 KSP Residual norm 6.594682366503e-06
  4100 KSP Residual norm 7.633527454703e-06
  4101 KSP Residual norm 8.557440255803e-06
  4102 KSP Residual norm 9.302727677549e-06
  4103 KSP Residual norm 1.047775248236e-05
  4104 KSP Residual norm 1.155736630998e-05
  4105 KSP Residual norm 1.196199470740e-05
  4106 KSP Residual norm 1.333258453809e-05
  4107 KSP Residual norm 1.517367040753e-05
  4108 KSP Residual norm 1.536897466647e-05
  4109 KSP Residual norm 1.565314958931e-05
  4110 KSP Residual norm 1.653095810263e-05
  4111 KSP Residual norm 1.657718872429e-05
  4112 KSP Residual norm 1.637679883608e-05
  4113 KSP Residual norm 1.712729905392e-05
  4114 KSP Residual norm 1.827012918296e-05
  4115 KSP Residual norm 2.001693351164e-05
  4116 KSP Residual norm 2.260199628011e-05
  4117 KSP Residual norm 2.275595044511e-05
  4118 KSP Residual norm 2.179091636973e-05
  4119 KSP Residual norm 2.241251751890e-05
  4120 KSP Residual norm 2.334921776753e-05
  4121 KSP Residual norm 2.170480640827e-05
  4122 KSP Residual norm 1.843602302234e-05
  4123 KSP Residual norm 1.645148916452e-05
  4124 KSP Residual norm 1.505553614366e-05
  4125 KSP Residual norm 1.314748398611e-05
  4126 KSP Residual norm 1.181953292705e-05
  4127 KSP Residual norm 1.052845508550e-05
  4128 KSP Residual norm 9.396535923326e-06
  4129 KSP Residual norm 8.202783677955e-06
  4130 KSP Residual norm 7.089183818425e-06
  4131 KSP Residual norm 6.500785833614e-06
  4132 KSP Residual norm 6.386832066749e-06
  4133 KSP Residual norm 6.243715143113e-06
  4134 KSP Residual norm 5.857783180655e-06
  4135 KSP Residual norm 5.501965527903e-06
  4136 KSP Residual norm 5.242630266802e-06
  4137 KSP Residual norm 4.907543913057e-06
  4138 KSP Residual norm 4.628566921256e-06
  4139 KSP Residual norm 4.611593892441e-06
  4140 KSP Residual norm 4.514538629071e-06
  4141 KSP Residual norm 4.107052713577e-06
  4142 KSP Residual norm 4.007340601790e-06
  4143 KSP Residual norm 4.144366122049e-06
  4144 KSP Residual norm 4.275942082769e-06
  4145 KSP Residual norm 4.488666524149e-06
  4146 KSP Residual norm 4.926035783454e-06
  4147 KSP Residual norm 5.682161572272e-06
  4148 KSP Residual norm 6.577037864479e-06
  4149 KSP Residual norm 6.845866035184e-06
  4150 KSP Residual norm 6.850846673560e-06
  4151 KSP Residual norm 7.131482459077e-06
  4152 KSP Residual norm 7.048261907960e-06
  4153 KSP Residual norm 6.478639044787e-06
  4154 KSP Residual norm 6.495468853249e-06
  4155 KSP Residual norm 7.006336672524e-06
  4156 KSP Residual norm 7.312898904866e-06
  4157 KSP Residual norm 6.935940741479e-06
  4158 KSP Residual norm 6.735395918752e-06
  4159 KSP Residual norm 6.973365129706e-06
  4160 KSP Residual norm 7.237348493477e-06
  4161 KSP Residual norm 7.181443764604e-06
  4162 KSP Residual norm 6.652732695176e-06
  4163 KSP Residual norm 6.456683700004e-06
  4164 KSP Residual norm 7.105718405442e-06
  4165 KSP Residual norm 7.696015030319e-06
  4166 KSP Residual norm 7.342599336740e-06
  4167 KSP Residual norm 7.001114677846e-06
  4168 KSP Residual norm 6.574312698020e-06
  4169 KSP Residual norm 6.094440598016e-06
  4170 KSP Residual norm 5.915977946512e-06
  4171 KSP Residual norm 5.599102971935e-06
  4172 KSP Residual norm 5.233525468123e-06
  4173 KSP Residual norm 4.921330882513e-06
  4174 KSP Residual norm 4.553649271811e-06
  4175 KSP Residual norm 4.244318384535e-06
  4176 KSP Residual norm 4.305646146491e-06
  4177 KSP Residual norm 3.945855349671e-06
  4178 KSP Residual norm 3.398451631528e-06
  4179 KSP Residual norm 3.257608985690e-06
  4180 KSP Residual norm 3.382528656754e-06
  4181 KSP Residual norm 3.361547141288e-06
  4182 KSP Residual norm 3.193208688971e-06
  4183 KSP Residual norm 2.967653373360e-06
  4184 KSP Residual norm 2.855727523872e-06
  4185 KSP Residual norm 2.965920373464e-06
  4186 KSP Residual norm 3.002917685308e-06
  4187 KSP Residual norm 2.803978484555e-06
  4188 KSP Residual norm 2.847121664869e-06
  4189 KSP Residual norm 3.166792711413e-06
  4190 KSP Residual norm 3.451108600626e-06
  4191 KSP Residual norm 3.723813792282e-06
  4192 KSP Residual norm 4.042502090498e-06
  4193 KSP Residual norm 4.228689771935e-06
  4194 KSP Residual norm 4.189246497762e-06
  4195 KSP Residual norm 4.269988106955e-06
  4196 KSP Residual norm 4.280805231644e-06
  4197 KSP Residual norm 4.248465731037e-06
  4198 KSP Residual norm 4.467084032637e-06
  4199 KSP Residual norm 4.632167947787e-06
  4200 KSP Residual norm 4.674867666761e-06
  4201 KSP Residual norm 4.605998722810e-06
  4202 KSP Residual norm 4.406649001944e-06
  4203 KSP Residual norm 4.057724046604e-06
  4204 KSP Residual norm 3.942681099657e-06
  4205 KSP Residual norm 3.943303815205e-06
  4206 KSP Residual norm 3.821869792395e-06
  4207 KSP Residual norm 3.934111893158e-06
  4208 KSP Residual norm 4.137367832785e-06
  4209 KSP Residual norm 4.287765846688e-06
  4210 KSP Residual norm 4.351902983190e-06
  4211 KSP Residual norm 4.382005655466e-06
  4212 KSP Residual norm 4.192428235014e-06
  4213 KSP Residual norm 4.006894746467e-06
  4214 KSP Residual norm 3.727023150471e-06
  4215 KSP Residual norm 3.415709359617e-06
  4216 KSP Residual norm 3.177829024506e-06
  4217 KSP Residual norm 2.953104272232e-06
  4218 KSP Residual norm 2.448728932112e-06
  4219 KSP Residual norm 2.127380426850e-06
  4220 KSP Residual norm 2.167212292649e-06
  4221 KSP Residual norm 2.121896081593e-06
  4222 KSP Residual norm 1.837010550971e-06
  4223 KSP Residual norm 1.607743892699e-06
  4224 KSP Residual norm 1.566440487234e-06
  4225 KSP Residual norm 1.632292557909e-06
  4226 KSP Residual norm 1.638334417496e-06
  4227 KSP Residual norm 1.480794250285e-06
  4228 KSP Residual norm 1.414953044023e-06
  4229 KSP Residual norm 1.534513263322e-06
  4230 KSP Residual norm 1.630558671848e-06
  4231 KSP Residual norm 1.468124533284e-06
  4232 KSP Residual norm 1.395477422569e-06
  4233 KSP Residual norm 1.555642834887e-06
  4234 KSP Residual norm 1.633758904011e-06
  4235 KSP Residual norm 1.549930657296e-06
  4236 KSP Residual norm 1.584122417914e-06
  4237 KSP Residual norm 1.682593737976e-06
  4238 KSP Residual norm 1.724214684835e-06
  4239 KSP Residual norm 1.772062759346e-06
  4240 KSP Residual norm 1.921401722302e-06
  4241 KSP Residual norm 2.081269471552e-06
  4242 KSP Residual norm 2.236763876521e-06
  4243 KSP Residual norm 2.477040469254e-06
  4244 KSP Residual norm 2.916802775968e-06
  4245 KSP Residual norm 3.333855715627e-06
  4246 KSP Residual norm 3.319341947077e-06
  4247 KSP Residual norm 2.731942171871e-06
  4248 KSP Residual norm 2.562847919669e-06
  4249 KSP Residual norm 2.959630763653e-06
  4250 KSP Residual norm 3.515310485493e-06
  4251 KSP Residual norm 3.622689106853e-06
  4252 KSP Residual norm 3.478491560088e-06
  4253 KSP Residual norm 3.358835631648e-06
  4254 KSP Residual norm 3.497170532034e-06
  4255 KSP Residual norm 3.491428057276e-06
  4256 KSP Residual norm 3.154074135817e-06
  4257 KSP Residual norm 2.882628689550e-06
  4258 KSP Residual norm 2.891798302277e-06
  4259 KSP Residual norm 2.909831715405e-06
  4260 KSP Residual norm 2.799883196286e-06
  4261 KSP Residual norm 2.725386020572e-06
  4262 KSP Residual norm 2.703398492820e-06
  4263 KSP Residual norm 2.682173355203e-06
  4264 KSP Residual norm 2.607176062333e-06
  4265 KSP Residual norm 2.461475066157e-06
  4266 KSP Residual norm 2.424246556766e-06
  4267 KSP Residual norm 2.669621244605e-06
  4268 KSP Residual norm 2.996777956464e-06
  4269 KSP Residual norm 2.967553561392e-06
  4270 KSP Residual norm 2.781821486019e-06
  4271 KSP Residual norm 2.633411867466e-06
  4272 KSP Residual norm 2.415358428900e-06
  4273 KSP Residual norm 2.067827469207e-06
  4274 KSP Residual norm 1.677127016659e-06
  4275 KSP Residual norm 1.355639858057e-06
  4276 KSP Residual norm 1.089178159621e-06
  4277 KSP Residual norm 9.654021069062e-07
  4278 KSP Residual norm 9.554188609288e-07
  4279 KSP Residual norm 9.589395567582e-07
  4280 KSP Residual norm 9.660220838651e-07
  4281 KSP Residual norm 1.036846196427e-06
  4282 KSP Residual norm 1.169906126471e-06
  4283 KSP Residual norm 1.270346181951e-06
  4284 KSP Residual norm 1.223851414313e-06
  4285 KSP Residual norm 1.240875331397e-06
  4286 KSP Residual norm 1.439635868316e-06
  4287 KSP Residual norm 1.617343148914e-06
  4288 KSP Residual norm 1.614055202169e-06
  4289 KSP Residual norm 1.631487945264e-06
  4290 KSP Residual norm 1.792174187594e-06
  4291 KSP Residual norm 1.998294068056e-06
  4292 KSP Residual norm 1.948884793372e-06
  4293 KSP Residual norm 1.834942802432e-06
  4294 KSP Residual norm 2.003001016979e-06
  4295 KSP Residual norm 2.395998818173e-06
  4296 KSP Residual norm 2.789322018390e-06
  4297 KSP Residual norm 2.910482086507e-06
  4298 KSP Residual norm 3.086246240411e-06
  4299 KSP Residual norm 3.318832561079e-06
  4300 KSP Residual norm 3.341385958344e-06
  4301 KSP Residual norm 3.201204157430e-06
  4302 KSP Residual norm 3.248139332964e-06
  4303 KSP Residual norm 3.438922278525e-06
  4304 KSP Residual norm 3.513516513813e-06
  4305 KSP Residual norm 3.646107831200e-06
  4306 KSP Residual norm 4.139114702900e-06
  4307 KSP Residual norm 4.471531992517e-06
  4308 KSP Residual norm 4.353716135277e-06
  4309 KSP Residual norm 4.225490123476e-06
  4310 KSP Residual norm 4.230082648201e-06
  4311 KSP Residual norm 4.183758217792e-06
  4312 KSP Residual norm 3.893599540989e-06
  4313 KSP Residual norm 3.452511837958e-06
  4314 KSP Residual norm 3.344634552027e-06
  4315 KSP Residual norm 3.432591511071e-06
  4316 KSP Residual norm 3.322104594250e-06
  4317 KSP Residual norm 2.813047682435e-06
  4318 KSP Residual norm 2.304809788223e-06
  4319 KSP Residual norm 1.994906105869e-06
  4320 KSP Residual norm 1.817887964899e-06
  4321 KSP Residual norm 1.622995571409e-06
  4322 KSP Residual norm 1.413132869975e-06
  4323 KSP Residual norm 1.267644010283e-06
  4324 KSP Residual norm 1.188085038779e-06
  4325 KSP Residual norm 1.133243672966e-06
  4326 KSP Residual norm 1.131879290789e-06
  4327 KSP Residual norm 1.255232951950e-06
  4328 KSP Residual norm 1.386376204335e-06
  4329 KSP Residual norm 1.431313603434e-06
  4330 KSP Residual norm 1.563338915860e-06
  4331 KSP Residual norm 1.771380685949e-06
  4332 KSP Residual norm 2.092735726560e-06
  4333 KSP Residual norm 2.307503796122e-06
  4334 KSP Residual norm 2.384177127872e-06
  4335 KSP Residual norm 2.298069130630e-06
  4336 KSP Residual norm 2.396112326167e-06
  4337 KSP Residual norm 2.597298094083e-06
  4338 KSP Residual norm 2.498746433333e-06
  4339 KSP Residual norm 2.418497130708e-06
  4340 KSP Residual norm 2.514109444758e-06
  4341 KSP Residual norm 2.563487711016e-06
  4342 KSP Residual norm 2.526385862442e-06
  4343 KSP Residual norm 2.591379084774e-06
  4344 KSP Residual norm 2.813137616320e-06
  4345 KSP Residual norm 3.110540830248e-06
  4346 KSP Residual norm 3.485807876087e-06
  4347 KSP Residual norm 3.743827377611e-06
  4348 KSP Residual norm 3.739646219966e-06
  4349 KSP Residual norm 3.612212867962e-06
  4350 KSP Residual norm 3.347285594573e-06
  4351 KSP Residual norm 3.378069573082e-06
  4352 KSP Residual norm 3.990921819713e-06
  4353 KSP Residual norm 4.694724497166e-06
  4354 KSP Residual norm 4.903688844549e-06
  4355 KSP Residual norm 4.822804565045e-06
  4356 KSP Residual norm 4.878511309625e-06
  4357 KSP Residual norm 5.425295586565e-06
  4358 KSP Residual norm 5.853320437057e-06
  4359 KSP Residual norm 5.403285175286e-06
  4360 KSP Residual norm 4.749194288277e-06
  4361 KSP Residual norm 4.335898759241e-06
  4362 KSP Residual norm 3.994356583634e-06
  4363 KSP Residual norm 3.650049186537e-06
  4364 KSP Residual norm 3.631398640575e-06
  4365 KSP Residual norm 3.933708524009e-06
  4366 KSP Residual norm 4.118526849987e-06
  4367 KSP Residual norm 4.415451212628e-06
  4368 KSP Residual norm 5.041851756737e-06
  4369 KSP Residual norm 5.307034722625e-06
  4370 KSP Residual norm 5.176011314779e-06
  4371 KSP Residual norm 4.915249601529e-06
  4372 KSP Residual norm 5.075262726313e-06
  4373 KSP Residual norm 4.983121889618e-06
  4374 KSP Residual norm 4.147099170085e-06
  4375 KSP Residual norm 3.374100530943e-06
  4376 KSP Residual norm 3.054932858654e-06
  4377 KSP Residual norm 2.837680552635e-06
  4378 KSP Residual norm 2.594987942371e-06
  4379 KSP Residual norm 2.436729276799e-06
  4380 KSP Residual norm 2.509332244263e-06
  4381 KSP Residual norm 2.669321750652e-06
  4382 KSP Residual norm 2.597587525864e-06
  4383 KSP Residual norm 2.492579133841e-06
  4384 KSP Residual norm 2.535687513017e-06
  4385 KSP Residual norm 2.707975205932e-06
  4386 KSP Residual norm 2.633742717142e-06
  4387 KSP Residual norm 2.373322874908e-06
  4388 KSP Residual norm 2.242950101315e-06
  4389 KSP Residual norm 2.394657835214e-06
  4390 KSP Residual norm 2.655465127535e-06
  4391 KSP Residual norm 2.829479683996e-06
  4392 KSP Residual norm 3.093722077234e-06
  4393 KSP Residual norm 3.230622554869e-06
  4394 KSP Residual norm 3.184359045103e-06
  4395 KSP Residual norm 3.168739761989e-06
  4396 KSP Residual norm 3.187274237746e-06
  4397 KSP Residual norm 3.207736753087e-06
  4398 KSP Residual norm 3.307641792369e-06
  4399 KSP Residual norm 3.479991195996e-06
  4400 KSP Residual norm 3.572773025726e-06
  4401 KSP Residual norm 3.677226408261e-06
  4402 KSP Residual norm 4.051770057382e-06
  4403 KSP Residual norm 4.608219130823e-06
  4404 KSP Residual norm 5.168494823681e-06
  4405 KSP Residual norm 5.687524764200e-06
  4406 KSP Residual norm 5.699117606999e-06
  4407 KSP Residual norm 5.387006610369e-06
  4408 KSP Residual norm 5.008564788924e-06
  4409 KSP Residual norm 5.104144350996e-06
  4410 KSP Residual norm 5.071999975338e-06
  4411 KSP Residual norm 4.716659315477e-06
  4412 KSP Residual norm 4.047400390550e-06
  4413 KSP Residual norm 3.524399409029e-06
  4414 KSP Residual norm 3.153073602726e-06
  4415 KSP Residual norm 2.771141697348e-06
  4416 KSP Residual norm 2.488156928148e-06
  4417 KSP Residual norm 2.501274152012e-06
  4418 KSP Residual norm 2.769063756245e-06
  4419 KSP Residual norm 2.938975386831e-06
  4420 KSP Residual norm 2.929243943111e-06
  4421 KSP Residual norm 2.866633398039e-06
  4422 KSP Residual norm 2.890806216267e-06
  4423 KSP Residual norm 2.805212436385e-06
  4424 KSP Residual norm 2.651751276045e-06
  4425 KSP Residual norm 2.666488569370e-06
  4426 KSP Residual norm 2.820671457985e-06
  4427 KSP Residual norm 2.752627651786e-06
  4428 KSP Residual norm 2.495361295055e-06
  4429 KSP Residual norm 2.564059122930e-06
  4430 KSP Residual norm 3.130947125063e-06
  4431 KSP Residual norm 3.621144862326e-06
  4432 KSP Residual norm 3.855315313124e-06
  4433 KSP Residual norm 4.396619428352e-06
  4434 KSP Residual norm 5.074272941338e-06
  4435 KSP Residual norm 5.250246048783e-06
  4436 KSP Residual norm 4.885706001022e-06
  4437 KSP Residual norm 4.559150824797e-06
  4438 KSP Residual norm 4.795783798655e-06
  4439 KSP Residual norm 5.435554062130e-06
  4440 KSP Residual norm 5.841644365006e-06
  4441 KSP Residual norm 6.371303195893e-06
  4442 KSP Residual norm 6.955297884843e-06
  4443 KSP Residual norm 7.490238121387e-06
  4444 KSP Residual norm 7.769888446280e-06
  4445 KSP Residual norm 8.114891731851e-06
  4446 KSP Residual norm 8.361760067799e-06
  4447 KSP Residual norm 8.102183991695e-06
  4448 KSP Residual norm 7.549749613660e-06
  4449 KSP Residual norm 7.214096925373e-06
  4450 KSP Residual norm 7.064276138927e-06
  4451 KSP Residual norm 6.854460904079e-06
  4452 KSP Residual norm 6.760366115516e-06
  4453 KSP Residual norm 7.309128393727e-06
  4454 KSP Residual norm 7.951264282768e-06
  4455 KSP Residual norm 7.773578769679e-06
  4456 KSP Residual norm 7.332955605206e-06
  4457 KSP Residual norm 7.342827094526e-06
  4458 KSP Residual norm 7.904867340596e-06
  4459 KSP Residual norm 8.401570840425e-06
  4460 KSP Residual norm 8.360004048710e-06
  4461 KSP Residual norm 8.311580295044e-06
  4462 KSP Residual norm 8.167812088042e-06
  4463 KSP Residual norm 7.444628037929e-06
  4464 KSP Residual norm 6.681253149968e-06
  4465 KSP Residual norm 6.671156951681e-06
  4466 KSP Residual norm 6.706863761832e-06
  4467 KSP Residual norm 5.892922219718e-06
  4468 KSP Residual norm 4.999490780900e-06
  4469 KSP Residual norm 4.565760519464e-06
  4470 KSP Residual norm 4.459653743128e-06
  4471 KSP Residual norm 4.775012438301e-06
  4472 KSP Residual norm 5.240229905226e-06
  4473 KSP Residual norm 5.616664893734e-06
  4474 KSP Residual norm 6.185344965312e-06
  4475 KSP Residual norm 6.803739092162e-06
  4476 KSP Residual norm 6.965123581004e-06
  4477 KSP Residual norm 6.439302038531e-06
  4478 KSP Residual norm 6.558283934702e-06
  4479 KSP Residual norm 7.540512363700e-06
  4480 KSP Residual norm 7.913329667216e-06
  4481 KSP Residual norm 7.342274049029e-06
  4482 KSP Residual norm 6.416642465014e-06
  4483 KSP Residual norm 5.923314890366e-06
  4484 KSP Residual norm 6.141487794981e-06
  4485 KSP Residual norm 6.459220139118e-06
  4486 KSP Residual norm 6.545254562034e-06
  4487 KSP Residual norm 6.600584986305e-06
  4488 KSP Residual norm 6.740721082371e-06
  4489 KSP Residual norm 7.139007115596e-06
  4490 KSP Residual norm 8.107526160043e-06
  4491 KSP Residual norm 9.081581939658e-06
  4492 KSP Residual norm 9.214070276925e-06
  4493 KSP Residual norm 9.116018302961e-06
  4494 KSP Residual norm 9.625206565481e-06
  4495 KSP Residual norm 1.061411598445e-05
  4496 KSP Residual norm 1.130551164552e-05
  4497 KSP Residual norm 1.116320246877e-05
  4498 KSP Residual norm 1.112396542288e-05
  4499 KSP Residual norm 1.173686805243e-05
  4500 KSP Residual norm 1.155355894180e-05
  4501 KSP Residual norm 1.016868896524e-05
  4502 KSP Residual norm 9.778276701099e-06
  4503 KSP Residual norm 1.056114391616e-05
  4504 KSP Residual norm 1.144800494972e-05
  4505 KSP Residual norm 1.210804883209e-05
  4506 KSP Residual norm 1.252087052071e-05
  4507 KSP Residual norm 1.252341619199e-05
  4508 KSP Residual norm 1.242902150396e-05
  4509 KSP Residual norm 1.222792924752e-05
  4510 KSP Residual norm 1.180686490712e-05
  4511 KSP Residual norm 1.155630615779e-05
  4512 KSP Residual norm 1.087258791359e-05
  4513 KSP Residual norm 1.034971408973e-05
  4514 KSP Residual norm 1.038218562463e-05
  4515 KSP Residual norm 1.103422117608e-05
  4516 KSP Residual norm 1.144834622760e-05
  4517 KSP Residual norm 1.172755837694e-05
  4518 KSP Residual norm 1.193605736013e-05
  4519 KSP Residual norm 1.170755220226e-05
  4520 KSP Residual norm 1.068672246546e-05
  4521 KSP Residual norm 1.002029540849e-05
  4522 KSP Residual norm 9.699503065243e-06
  4523 KSP Residual norm 9.162479341425e-06
  4524 KSP Residual norm 8.537419769763e-06
  4525 KSP Residual norm 7.791564441253e-06
  4526 KSP Residual norm 7.128015954438e-06
  4527 KSP Residual norm 7.247218491598e-06
  4528 KSP Residual norm 7.652775468190e-06
  4529 KSP Residual norm 7.653175202942e-06
  4530 KSP Residual norm 8.086025007614e-06
  4531 KSP Residual norm 8.093586854434e-06
  4532 KSP Residual norm 7.124222206751e-06
  4533 KSP Residual norm 6.659825944938e-06
  4534 KSP Residual norm 6.484545798744e-06
  4535 KSP Residual norm 6.031195600517e-06
  4536 KSP Residual norm 5.840510591402e-06
  4537 KSP Residual norm 5.982410869574e-06
  4538 KSP Residual norm 6.172897568264e-06
  4539 KSP Residual norm 6.209256490269e-06
  4540 KSP Residual norm 6.064944952514e-06
  4541 KSP Residual norm 6.072867499162e-06
  4542 KSP Residual norm 6.496617683122e-06
  4543 KSP Residual norm 7.158264554275e-06
  4544 KSP Residual norm 7.690710223765e-06
  4545 KSP Residual norm 8.202153087805e-06
  4546 KSP Residual norm 8.585621377010e-06
  4547 KSP Residual norm 7.771091841228e-06
  4548 KSP Residual norm 6.605450835758e-06
  4549 KSP Residual norm 6.576624972396e-06
  4550 KSP Residual norm 7.337735043230e-06
  4551 KSP Residual norm 7.771840789165e-06
  4552 KSP Residual norm 7.808874092485e-06
  4553 KSP Residual norm 8.145565959961e-06
  4554 KSP Residual norm 8.928032880868e-06
  4555 KSP Residual norm 9.322811356249e-06
  4556 KSP Residual norm 9.217783808124e-06
  4557 KSP Residual norm 9.944089465485e-06
  4558 KSP Residual norm 1.108833428478e-05
  4559 KSP Residual norm 1.092559756902e-05
  4560 KSP Residual norm 9.927248582039e-06
  4561 KSP Residual norm 9.731167520721e-06
  4562 KSP Residual norm 1.001294096719e-05
  4563 KSP Residual norm 9.994248050890e-06
  4564 KSP Residual norm 1.057288336630e-05
  4565 KSP Residual norm 1.055784070555e-05
  4566 KSP Residual norm 9.918863328643e-06
  4567 KSP Residual norm 9.476588810202e-06
  4568 KSP Residual norm 9.087952934058e-06
  4569 KSP Residual norm 7.914313226388e-06
  4570 KSP Residual norm 6.219620528958e-06
  4571 KSP Residual norm 4.970715208319e-06
  4572 KSP Residual norm 4.381074048155e-06
  4573 KSP Residual norm 4.257037374704e-06
  4574 KSP Residual norm 3.991327349578e-06
  4575 KSP Residual norm 3.470399412198e-06
  4576 KSP Residual norm 2.981084473327e-06
  4577 KSP Residual norm 2.870528967907e-06
  4578 KSP Residual norm 2.978460735544e-06
  4579 KSP Residual norm 3.123069793912e-06
  4580 KSP Residual norm 3.001584913147e-06
  4581 KSP Residual norm 2.665736254452e-06
  4582 KSP Residual norm 2.436231476897e-06
  4583 KSP Residual norm 2.488293743517e-06
  4584 KSP Residual norm 2.799996313113e-06
  4585 KSP Residual norm 3.325183599698e-06
  4586 KSP Residual norm 3.836168001089e-06
  4587 KSP Residual norm 3.944412074953e-06
  4588 KSP Residual norm 4.008941670035e-06
  4589 KSP Residual norm 4.105094695722e-06
  4590 KSP Residual norm 4.407243427201e-06
  4591 KSP Residual norm 4.560853594063e-06
  4592 KSP Residual norm 4.500019999570e-06
  4593 KSP Residual norm 4.294705056009e-06
  4594 KSP Residual norm 4.251641648236e-06
  4595 KSP Residual norm 4.548309316860e-06
  4596 KSP Residual norm 4.646855798998e-06
  4597 KSP Residual norm 4.265574712030e-06
  4598 KSP Residual norm 4.091813706284e-06
  4599 KSP Residual norm 4.471034963874e-06
  4600 KSP Residual norm 4.745870674793e-06
  4601 KSP Residual norm 4.624767327014e-06
  4602 KSP Residual norm 4.504061107083e-06
  4603 KSP Residual norm 4.738400384699e-06
  4604 KSP Residual norm 5.258082389614e-06
  4605 KSP Residual norm 5.757650554459e-06
  4606 KSP Residual norm 6.194370961563e-06
  4607 KSP Residual norm 6.422140043945e-06
  4608 KSP Residual norm 6.305982639737e-06
  4609 KSP Residual norm 6.206389104685e-06
  4610 KSP Residual norm 6.186224301597e-06
  4611 KSP Residual norm 5.961003499606e-06
  4612 KSP Residual norm 5.826489171045e-06
  4613 KSP Residual norm 5.885750344079e-06
  4614 KSP Residual norm 6.055924953065e-06
  4615 KSP Residual norm 6.063263036870e-06
  4616 KSP Residual norm 5.797351522394e-06
  4617 KSP Residual norm 5.823908894968e-06
  4618 KSP Residual norm 6.184456236982e-06
  4619 KSP Residual norm 6.507072729587e-06
  4620 KSP Residual norm 6.563135497577e-06
  4621 KSP Residual norm 6.712926715427e-06
  4622 KSP Residual norm 6.744411140431e-06
  4623 KSP Residual norm 6.085257888865e-06
  4624 KSP Residual norm 5.550313167580e-06
  4625 KSP Residual norm 5.501241507229e-06
  4626 KSP Residual norm 5.719243285453e-06
  4627 KSP Residual norm 4.890292468600e-06
  4628 KSP Residual norm 3.909271545199e-06
  4629 KSP Residual norm 3.479191085264e-06
  4630 KSP Residual norm 3.579382832217e-06
  4631 KSP Residual norm 3.957063119777e-06
  4632 KSP Residual norm 4.043510993896e-06
  4633 KSP Residual norm 3.952783800155e-06
  4634 KSP Residual norm 3.969581588256e-06
  4635 KSP Residual norm 3.696980230108e-06
  4636 KSP Residual norm 3.252765996725e-06
  4637 KSP Residual norm 3.217224598550e-06
  4638 KSP Residual norm 3.538805587260e-06
  4639 KSP Residual norm 3.724618415070e-06
  4640 KSP Residual norm 3.609490218028e-06
  4641 KSP Residual norm 3.417183591628e-06
  4642 KSP Residual norm 3.103798772522e-06
  4643 KSP Residual norm 2.940007371501e-06
  4644 KSP Residual norm 2.945616981145e-06
  4645 KSP Residual norm 3.033282901102e-06
  4646 KSP Residual norm 3.057095135696e-06
  4647 KSP Residual norm 3.002330709392e-06
  4648 KSP Residual norm 2.909910828571e-06
  4649 KSP Residual norm 2.730309350190e-06
  4650 KSP Residual norm 2.688065415040e-06
  4651 KSP Residual norm 2.762999991557e-06
  4652 KSP Residual norm 2.804632898940e-06
  4653 KSP Residual norm 3.123676759486e-06
  4654 KSP Residual norm 3.720672215481e-06
  4655 KSP Residual norm 4.051012435852e-06
  4656 KSP Residual norm 4.066929179458e-06
  4657 KSP Residual norm 4.124965839876e-06
  4658 KSP Residual norm 4.040746157444e-06
  4659 KSP Residual norm 3.900110946336e-06
  4660 KSP Residual norm 4.067435504438e-06
  4661 KSP Residual norm 4.543080931608e-06
  4662 KSP Residual norm 4.703700028288e-06
  4663 KSP Residual norm 4.320506599615e-06
  4664 KSP Residual norm 3.903941572165e-06
  4665 KSP Residual norm 3.739129539760e-06
  4666 KSP Residual norm 3.929078292892e-06
  4667 KSP Residual norm 4.613710501268e-06
  4668 KSP Residual norm 5.798389330501e-06
  4669 KSP Residual norm 6.283032097447e-06
  4670 KSP Residual norm 5.319465177879e-06
  4671 KSP Residual norm 4.449826258355e-06
  4672 KSP Residual norm 4.442277969338e-06
  4673 KSP Residual norm 5.035375482085e-06
  4674 KSP Residual norm 5.285849213512e-06
  4675 KSP Residual norm 4.959977263148e-06
  4676 KSP Residual norm 4.719895029588e-06
  4677 KSP Residual norm 4.898427968445e-06
  4678 KSP Residual norm 5.045105864954e-06
  4679 KSP Residual norm 4.728605193092e-06
  4680 KSP Residual norm 4.570097225955e-06
  4681 KSP Residual norm 4.626729948628e-06
  4682 KSP Residual norm 4.980426814831e-06
  4683 KSP Residual norm 5.124973281689e-06
  4684 KSP Residual norm 5.060773701544e-06
  4685 KSP Residual norm 5.250812546812e-06
  4686 KSP Residual norm 5.502027367380e-06
  4687 KSP Residual norm 5.276685793024e-06
  4688 KSP Residual norm 4.417570476167e-06
  4689 KSP Residual norm 3.633348973905e-06
  4690 KSP Residual norm 3.102810783248e-06
  4691 KSP Residual norm 3.128606860652e-06
  4692 KSP Residual norm 3.588772395799e-06
  4693 KSP Residual norm 4.017092734693e-06
  4694 KSP Residual norm 4.303003680295e-06
  4695 KSP Residual norm 4.365565950108e-06
  4696 KSP Residual norm 4.448694399364e-06
  4697 KSP Residual norm 4.015027136523e-06
  4698 KSP Residual norm 3.499674814751e-06
  4699 KSP Residual norm 3.212832178720e-06
  4700 KSP Residual norm 3.055100417737e-06
  4701 KSP Residual norm 3.119231869446e-06
  4702 KSP Residual norm 3.395893519119e-06
  4703 KSP Residual norm 3.480165727773e-06
  4704 KSP Residual norm 3.026151022904e-06
  4705 KSP Residual norm 2.554903848687e-06
  4706 KSP Residual norm 2.280303175951e-06
  4707 KSP Residual norm 2.240414324431e-06
  4708 KSP Residual norm 2.419206783838e-06
  4709 KSP Residual norm 2.404179086963e-06
  4710 KSP Residual norm 2.260143684334e-06
  4711 KSP Residual norm 2.125300499261e-06
  4712 KSP Residual norm 2.065449145861e-06
  4713 KSP Residual norm 2.152351013140e-06
  4714 KSP Residual norm 2.237572232798e-06
  4715 KSP Residual norm 2.196208032702e-06
  4716 KSP Residual norm 2.109189473815e-06
  4717 KSP Residual norm 2.149380585786e-06
  4718 KSP Residual norm 2.294435180638e-06
  4719 KSP Residual norm 2.465510537764e-06
  4720 KSP Residual norm 2.673931112141e-06
  4721 KSP Residual norm 2.842140270408e-06
  4722 KSP Residual norm 2.942547305071e-06
  4723 KSP Residual norm 2.945007316110e-06
  4724 KSP Residual norm 3.060425905198e-06
  4725 KSP Residual norm 2.928588700870e-06
  4726 KSP Residual norm 2.859712551335e-06
  4727 KSP Residual norm 2.919937782686e-06
  4728 KSP Residual norm 2.841410518816e-06
  4729 KSP Residual norm 2.704259932883e-06
  4730 KSP Residual norm 2.639921174211e-06
  4731 KSP Residual norm 2.683962521434e-06
  4732 KSP Residual norm 2.862650868540e-06
  4733 KSP Residual norm 3.156904312309e-06
  4734 KSP Residual norm 3.338653271594e-06
  4735 KSP Residual norm 3.377200032088e-06
  4736 KSP Residual norm 3.538262257498e-06
  4737 KSP Residual norm 4.180187575970e-06
  4738 KSP Residual norm 4.979104831434e-06
  4739 KSP Residual norm 5.189254157701e-06
  4740 KSP Residual norm 4.646720181478e-06
  4741 KSP Residual norm 4.069516442494e-06
  4742 KSP Residual norm 3.740268358331e-06
  4743 KSP Residual norm 3.620246546513e-06
  4744 KSP Residual norm 3.798491047346e-06
  4745 KSP Residual norm 4.297078104392e-06
  4746 KSP Residual norm 4.824745428101e-06
  4747 KSP Residual norm 4.897749121755e-06
  4748 KSP Residual norm 4.346170242500e-06
  4749 KSP Residual norm 3.875151387980e-06
  4750 KSP Residual norm 3.694255981652e-06
  4751 KSP Residual norm 3.575833468475e-06
  4752 KSP Residual norm 3.426777905916e-06
  4753 KSP Residual norm 3.401514566784e-06
  4754 KSP Residual norm 3.301125380960e-06
  4755 KSP Residual norm 2.975226002593e-06
  4756 KSP Residual norm 2.713920001261e-06
  4757 KSP Residual norm 2.732163428554e-06
  4758 KSP Residual norm 2.866192493327e-06
  4759 KSP Residual norm 2.837133478929e-06
  4760 KSP Residual norm 2.762229370665e-06
  4761 KSP Residual norm 2.709325906925e-06
  4762 KSP Residual norm 2.592704181166e-06
  4763 KSP Residual norm 2.401611584238e-06
  4764 KSP Residual norm 2.284458330486e-06
  4765 KSP Residual norm 2.067522880357e-06
  4766 KSP Residual norm 1.794173146654e-06
  4767 KSP Residual norm 1.638987433803e-06
  4768 KSP Residual norm 1.616644120241e-06
  4769 KSP Residual norm 1.765276011609e-06
  4770 KSP Residual norm 1.939186940518e-06
  4771 KSP Residual norm 2.054326582129e-06
  4772 KSP Residual norm 2.206600306076e-06
  4773 KSP Residual norm 2.216511256535e-06
  4774 KSP Residual norm 1.947687138485e-06
  4775 KSP Residual norm 1.660864978845e-06
  4776 KSP Residual norm 1.447567712612e-06
  4777 KSP Residual norm 1.342806784992e-06
  4778 KSP Residual norm 1.425754510661e-06
  4779 KSP Residual norm 1.619495185807e-06
  4780 KSP Residual norm 1.920995600812e-06
  4781 KSP Residual norm 2.227640921019e-06
  4782 KSP Residual norm 2.311592322089e-06
  4783 KSP Residual norm 2.419022845539e-06
  4784 KSP Residual norm 2.652356778770e-06
  4785 KSP Residual norm 2.967144490413e-06
  4786 KSP Residual norm 3.098277189045e-06
  4787 KSP Residual norm 3.166379282489e-06
  4788 KSP Residual norm 3.205165006833e-06
  4789 KSP Residual norm 3.005299631558e-06
  4790 KSP Residual norm 2.775364152338e-06
  4791 KSP Residual norm 2.728405120530e-06
  4792 KSP Residual norm 2.876916984430e-06
  4793 KSP Residual norm 2.979855974209e-06
  4794 KSP Residual norm 3.139757981776e-06
  4795 KSP Residual norm 3.380326600043e-06
  4796 KSP Residual norm 3.702672679125e-06
  4797 KSP Residual norm 3.747539367100e-06
  4798 KSP Residual norm 3.789335025805e-06
  4799 KSP Residual norm 4.340347431035e-06
  4800 KSP Residual norm 4.868264686609e-06
  4801 KSP Residual norm 4.762308747922e-06
  4802 KSP Residual norm 4.780595296062e-06
  4803 KSP Residual norm 5.405135265920e-06
  4804 KSP Residual norm 6.023856209637e-06
  4805 KSP Residual norm 5.676294440857e-06
  4806 KSP Residual norm 4.646489356669e-06
  4807 KSP Residual norm 3.613496919622e-06
  4808 KSP Residual norm 3.218712899497e-06
  4809 KSP Residual norm 3.635138111744e-06
  4810 KSP Residual norm 4.479517680781e-06
  4811 KSP Residual norm 5.091947045290e-06
  4812 KSP Residual norm 5.208999993187e-06
  4813 KSP Residual norm 4.668400279765e-06
  4814 KSP Residual norm 4.118793941203e-06
  4815 KSP Residual norm 4.062076557165e-06
  4816 KSP Residual norm 4.484271977201e-06
  4817 KSP Residual norm 5.621739443869e-06
  4818 KSP Residual norm 6.810404113878e-06
  4819 KSP Residual norm 6.946803138675e-06
  4820 KSP Residual norm 6.176076620899e-06
  4821 KSP Residual norm 5.699099996922e-06
  4822 KSP Residual norm 6.055108596592e-06
  4823 KSP Residual norm 6.991401831183e-06
  4824 KSP Residual norm 7.471201895190e-06
  4825 KSP Residual norm 6.548336738413e-06
  4826 KSP Residual norm 4.989613750761e-06
  4827 KSP Residual norm 3.863417462846e-06
  4828 KSP Residual norm 3.111152576912e-06
  4829 KSP Residual norm 2.612419750530e-06
  4830 KSP Residual norm 2.551531034681e-06
  4831 KSP Residual norm 2.798638196212e-06
  4832 KSP Residual norm 2.960548850026e-06
  4833 KSP Residual norm 2.921788796787e-06
  4834 KSP Residual norm 2.856582378235e-06
  4835 KSP Residual norm 2.997410597606e-06
  4836 KSP Residual norm 3.421493924306e-06
  4837 KSP Residual norm 3.879724291071e-06
  4838 KSP Residual norm 4.206758533246e-06
  4839 KSP Residual norm 4.391614738641e-06
  4840 KSP Residual norm 4.503699907786e-06
  4841 KSP Residual norm 3.984033606775e-06
  4842 KSP Residual norm 3.255453129734e-06
  4843 KSP Residual norm 2.691789121694e-06
  4844 KSP Residual norm 2.529869916316e-06
  4845 KSP Residual norm 2.518515950284e-06
  4846 KSP Residual norm 2.547826262875e-06
  4847 KSP Residual norm 2.575005713821e-06
  4848 KSP Residual norm 2.777223001965e-06
  4849 KSP Residual norm 2.983151059572e-06
  4850 KSP Residual norm 3.125125021740e-06
  4851 KSP Residual norm 2.980563465931e-06
  4852 KSP Residual norm 2.817243981615e-06
  4853 KSP Residual norm 2.929850106055e-06
  4854 KSP Residual norm 3.560071434750e-06
  4855 KSP Residual norm 4.876399936007e-06
  4856 KSP Residual norm 6.391466529659e-06
  4857 KSP Residual norm 7.200309443960e-06
  4858 KSP Residual norm 7.548833114582e-06
  4859 KSP Residual norm 7.155971000020e-06
  4860 KSP Residual norm 5.977675213753e-06
  4861 KSP Residual norm 5.146164823420e-06
  4862 KSP Residual norm 4.612369158120e-06
  4863 KSP Residual norm 4.188482375645e-06
  4864 KSP Residual norm 4.072748503590e-06
  4865 KSP Residual norm 4.405284358532e-06
  4866 KSP Residual norm 5.078307304852e-06
  4867 KSP Residual norm 5.931705439416e-06
  4868 KSP Residual norm 7.725369062149e-06
  4869 KSP Residual norm 9.325294853198e-06
  4870 KSP Residual norm 9.501574624619e-06
  4871 KSP Residual norm 8.604731387774e-06
  4872 KSP Residual norm 8.419361787674e-06
  4873 KSP Residual norm 8.980012388244e-06
  4874 KSP Residual norm 9.352931949619e-06
  4875 KSP Residual norm 8.887465800553e-06
  4876 KSP Residual norm 8.345800155569e-06
  4877 KSP Residual norm 8.350750150883e-06
  4878 KSP Residual norm 9.030199104255e-06
  4879 KSP Residual norm 9.965189094465e-06
  4880 KSP Residual norm 1.164371457342e-05
  4881 KSP Residual norm 1.263735865043e-05
  4882 KSP Residual norm 1.165467046475e-05
  4883 KSP Residual norm 9.457543792158e-06
  4884 KSP Residual norm 7.160322190847e-06
  4885 KSP Residual norm 6.332136485700e-06
  4886 KSP Residual norm 6.303715156550e-06
  4887 KSP Residual norm 7.037161653788e-06
  4888 KSP Residual norm 8.835463845288e-06
  4889 KSP Residual norm 1.054456788397e-05
  4890 KSP Residual norm 9.638764794574e-06
  4891 KSP Residual norm 7.253864680898e-06
  4892 KSP Residual norm 5.491015728626e-06
  4893 KSP Residual norm 4.510572566338e-06
  4894 KSP Residual norm 4.474795592332e-06
  4895 KSP Residual norm 5.338490002365e-06
  4896 KSP Residual norm 6.529419411095e-06
  4897 KSP Residual norm 7.008236283437e-06
  4898 KSP Residual norm 5.928560493854e-06
  4899 KSP Residual norm 4.679065249776e-06
  4900 KSP Residual norm 3.909221132438e-06
  4901 KSP Residual norm 3.552489922867e-06
  4902 KSP Residual norm 3.218240596195e-06
  4903 KSP Residual norm 3.048051253281e-06
  4904 KSP Residual norm 3.129283130238e-06
  4905 KSP Residual norm 3.631050115105e-06
  4906 KSP Residual norm 4.844259978891e-06
  4907 KSP Residual norm 6.603975724988e-06
  4908 KSP Residual norm 8.477529854999e-06
  4909 KSP Residual norm 8.928415419210e-06
  4910 KSP Residual norm 7.551853704631e-06
  4911 KSP Residual norm 5.973522173760e-06
  4912 KSP Residual norm 4.966446129656e-06
  4913 KSP Residual norm 4.289595385358e-06
  4914 KSP Residual norm 4.088756586678e-06
  4915 KSP Residual norm 4.353518740192e-06
  4916 KSP Residual norm 5.036840140768e-06
  4917 KSP Residual norm 5.600069449388e-06
  4918 KSP Residual norm 5.877277105197e-06
  4919 KSP Residual norm 6.292516962723e-06
  4920 KSP Residual norm 7.224161690643e-06
  4921 KSP Residual norm 8.453928949680e-06
  4922 KSP Residual norm 8.621060319463e-06
  4923 KSP Residual norm 7.261867530016e-06
  4924 KSP Residual norm 6.216235782566e-06
  4925 KSP Residual norm 5.835893612035e-06
  4926 KSP Residual norm 5.772699749449e-06
  4927 KSP Residual norm 6.134134078385e-06
  4928 KSP Residual norm 6.973449886435e-06
  4929 KSP Residual norm 7.514874707776e-06
  4930 KSP Residual norm 7.134120608450e-06
  4931 KSP Residual norm 7.157914024235e-06
  4932 KSP Residual norm 8.415946029380e-06
  4933 KSP Residual norm 9.456756912058e-06
  4934 KSP Residual norm 8.139480966330e-06
  4935 KSP Residual norm 6.288215010761e-06
  4936 KSP Residual norm 5.785781486311e-06
  4937 KSP Residual norm 6.718167896787e-06
  4938 KSP Residual norm 8.738489233119e-06
  4939 KSP Residual norm 1.193406596239e-05
  4940 KSP Residual norm 1.492171650905e-05
  4941 KSP Residual norm 1.488897505201e-05
  4942 KSP Residual norm 1.235072737215e-05
  4943 KSP Residual norm 9.168751883405e-06
  4944 KSP Residual norm 7.894172403725e-06
  4945 KSP Residual norm 8.691145206079e-06
  4946 KSP Residual norm 1.107398131843e-05
  4947 KSP Residual norm 1.338337006198e-05
  4948 KSP Residual norm 1.280777844831e-05
  4949 KSP Residual norm 1.067625190165e-05
  4950 KSP Residual norm 9.010288817394e-06
  4951 KSP Residual norm 8.874108801539e-06
  4952 KSP Residual norm 1.024918464827e-05
  4953 KSP Residual norm 1.362780314128e-05
  4954 KSP Residual norm 1.799165647994e-05
  4955 KSP Residual norm 1.871957505211e-05
  4956 KSP Residual norm 1.536016364199e-05
  4957 KSP Residual norm 1.164134678280e-05
  4958 KSP Residual norm 8.867152607965e-06
  4959 KSP Residual norm 7.150849026146e-06
  4960 KSP Residual norm 6.788763347845e-06
  4961 KSP Residual norm 7.666047862180e-06
  4962 KSP Residual norm 9.021011266396e-06
  4963 KSP Residual norm 1.102022417338e-05
  4964 KSP Residual norm 1.144538506363e-05
  4965 KSP Residual norm 8.211447888093e-06
  4966 KSP Residual norm 4.899355112742e-06
  4967 KSP Residual norm 3.438790404352e-06
  4968 KSP Residual norm 3.032970766247e-06
  4969 KSP Residual norm 3.179742290810e-06
  4970 KSP Residual norm 3.897029665913e-06
  4971 KSP Residual norm 4.950588738404e-06
  4972 KSP Residual norm 5.887070820936e-06
  4973 KSP Residual norm 5.641542932183e-06
  4974 KSP Residual norm 4.154254006254e-06
  4975 KSP Residual norm 3.044149900135e-06
  4976 KSP Residual norm 2.677809996279e-06
  4977 KSP Residual norm 2.732551496355e-06
  4978 KSP Residual norm 3.079826042950e-06
  4979 KSP Residual norm 3.917796141755e-06
  4980 KSP Residual norm 5.228185231160e-06
  4981 KSP Residual norm 5.970615788319e-06
  4982 KSP Residual norm 5.694607625326e-06
  4983 KSP Residual norm 4.682075549566e-06
  4984 KSP Residual norm 3.468053099142e-06
  4985 KSP Residual norm 2.824688618057e-06
  4986 KSP Residual norm 2.905797535203e-06
  4987 KSP Residual norm 3.583169323461e-06
  4988 KSP Residual norm 4.625067073184e-06
  4989 KSP Residual norm 5.387843448413e-06
  4990 KSP Residual norm 5.217286857151e-06
  4991 KSP Residual norm 4.802694825993e-06
  4992 KSP Residual norm 5.014564279131e-06
  4993 KSP Residual norm 5.129509961194e-06
  4994 KSP Residual norm 4.748480436946e-06
  4995 KSP Residual norm 4.952461806835e-06
  4996 KSP Residual norm 5.869607290622e-06
  4997 KSP Residual norm 7.390858115626e-06
  4998 KSP Residual norm 9.629378633441e-06
  4999 KSP Residual norm 1.159422889741e-05
  5000 KSP Residual norm 1.103918245739e-05
  5001 KSP Residual norm 8.113460826154e-06
  5002 KSP Residual norm 5.769684183448e-06
  5003 KSP Residual norm 4.465459942665e-06
  5004 KSP Residual norm 4.134869960992e-06
  5005 KSP Residual norm 4.510158556462e-06
  5006 KSP Residual norm 5.437779672051e-06
  5007 KSP Residual norm 6.663368262236e-06
  5008 KSP Residual norm 7.710894973869e-06
  5009 KSP Residual norm 7.526246003320e-06
  5010 KSP Residual norm 6.518820923108e-06
  5011 KSP Residual norm 5.479348712502e-06
  5012 KSP Residual norm 4.976495731943e-06
  5013 KSP Residual norm 4.717156186048e-06
  5014 KSP Residual norm 4.353470150187e-06
  5015 KSP Residual norm 3.697353729805e-06
  5016 KSP Residual norm 3.136102532853e-06
  5017 KSP Residual norm 2.928213390023e-06
  5018 KSP Residual norm 3.109316596306e-06
  5019 KSP Residual norm 3.535209195011e-06
  5020 KSP Residual norm 3.982876431802e-06
  5021 KSP Residual norm 4.066037044859e-06
  5022 KSP Residual norm 3.568848765267e-06
  5023 KSP Residual norm 3.276706364446e-06
  5024 KSP Residual norm 3.511082136006e-06
  5025 KSP Residual norm 3.890449064001e-06
  5026 KSP Residual norm 4.092649244055e-06
  5027 KSP Residual norm 3.827682909221e-06
  5028 KSP Residual norm 3.215588665982e-06
  5029 KSP Residual norm 2.786934285280e-06
  5030 KSP Residual norm 2.581325204354e-06
  5031 KSP Residual norm 2.758549405434e-06
  5032 KSP Residual norm 3.321201135465e-06
  5033 KSP Residual norm 4.463325392394e-06
  5034 KSP Residual norm 5.848537914513e-06
  5035 KSP Residual norm 6.779365561803e-06
  5036 KSP Residual norm 7.253908158929e-06
  5037 KSP Residual norm 7.245348693572e-06
  5038 KSP Residual norm 6.991476705677e-06
  5039 KSP Residual norm 6.673392851305e-06
  5040 KSP Residual norm 6.502903043145e-06
  5041 KSP Residual norm 6.054206185407e-06
  5042 KSP Residual norm 5.652495160388e-06
  5043 KSP Residual norm 5.826491811416e-06
  5044 KSP Residual norm 6.988210688674e-06
  5045 KSP Residual norm 7.841658967917e-06
  5046 KSP Residual norm 7.568405167749e-06
  5047 KSP Residual norm 7.420859651622e-06
  5048 KSP Residual norm 8.310590416574e-06
  5049 KSP Residual norm 9.895248717692e-06
  5050 KSP Residual norm 1.065252285188e-05
  5051 KSP Residual norm 9.442467824085e-06
  5052 KSP Residual norm 6.995892545410e-06
  5053 KSP Residual norm 5.605114535207e-06
  5054 KSP Residual norm 5.386586186855e-06
  5055 KSP Residual norm 5.475584768235e-06
  5056 KSP Residual norm 5.639982202183e-06
  5057 KSP Residual norm 6.334020755917e-06
  5058 KSP Residual norm 7.290974284418e-06
  5059 KSP Residual norm 7.712843822409e-06
  5060 KSP Residual norm 7.933016657078e-06
  5061 KSP Residual norm 8.815505891790e-06
  5062 KSP Residual norm 1.037240472395e-05
  5063 KSP Residual norm 1.082371785000e-05
  5064 KSP Residual norm 1.013194238412e-05
  5065 KSP Residual norm 9.676777369365e-06
  5066 KSP Residual norm 1.030048024033e-05
  5067 KSP Residual norm 1.056314605811e-05
  5068 KSP Residual norm 9.758221631567e-06
  5069 KSP Residual norm 8.779766842617e-06
  5070 KSP Residual norm 8.198975980773e-06
  5071 KSP Residual norm 7.690571485566e-06
  5072 KSP Residual norm 7.052183595688e-06
  5073 KSP Residual norm 6.555750352606e-06
  5074 KSP Residual norm 6.902660987877e-06
  5075 KSP Residual norm 8.199346484916e-06
  5076 KSP Residual norm 9.747146720780e-06
  5077 KSP Residual norm 1.121550203070e-05
  5078 KSP Residual norm 1.199731762364e-05
  5079 KSP Residual norm 1.038530974534e-05
  5080 KSP Residual norm 8.005379962562e-06
  5081 KSP Residual norm 6.547428210286e-06
  5082 KSP Residual norm 5.697079130409e-06
  5083 KSP Residual norm 5.020668735041e-06
  5084 KSP Residual norm 4.690895884031e-06
  5085 KSP Residual norm 4.553681130640e-06
  5086 KSP Residual norm 4.189605658545e-06
  5087 KSP Residual norm 3.765868818170e-06
  5088 KSP Residual norm 3.892572593241e-06
  5089 KSP Residual norm 5.028909739819e-06
  5090 KSP Residual norm 6.564763965087e-06
  5091 KSP Residual norm 6.582620915340e-06
  5092 KSP Residual norm 6.121205507721e-06
  5093 KSP Residual norm 6.196025753108e-06
  5094 KSP Residual norm 6.288598360232e-06
  5095 KSP Residual norm 6.298320393044e-06
  5096 KSP Residual norm 6.440485835464e-06
  5097 KSP Residual norm 6.265151820647e-06
  5098 KSP Residual norm 5.212115937788e-06
  5099 KSP Residual norm 4.530571405790e-06
  5100 KSP Residual norm 4.545492073676e-06
  5101 KSP Residual norm 5.078065928224e-06
  5102 KSP Residual norm 5.832244305748e-06
  5103 KSP Residual norm 6.158572741714e-06
  5104 KSP Residual norm 5.849955623442e-06
  5105 KSP Residual norm 5.472251971599e-06
  5106 KSP Residual norm 6.116985768585e-06
  5107 KSP Residual norm 7.625141357575e-06
  5108 KSP Residual norm 8.457041656584e-06
  5109 KSP Residual norm 7.566198246034e-06
  5110 KSP Residual norm 6.539373056293e-06
  5111 KSP Residual norm 6.124409022165e-06
  5112 KSP Residual norm 6.168449227270e-06
  5113 KSP Residual norm 6.143188745986e-06
  5114 KSP Residual norm 5.548608530280e-06
  5115 KSP Residual norm 4.546556440953e-06
  5116 KSP Residual norm 4.083782088424e-06
  5117 KSP Residual norm 3.960083128934e-06
  5118 KSP Residual norm 3.778898028742e-06
  5119 KSP Residual norm 3.446171195594e-06
  5120 KSP Residual norm 3.285006522825e-06
  5121 KSP Residual norm 3.617230674729e-06
  5122 KSP Residual norm 4.224563523916e-06
  5123 KSP Residual norm 4.848480383080e-06
  5124 KSP Residual norm 5.328471514985e-06
  5125 KSP Residual norm 5.841635283873e-06
  5126 KSP Residual norm 6.006966813415e-06
  5127 KSP Residual norm 6.047903869068e-06
  5128 KSP Residual norm 6.655420309169e-06
  5129 KSP Residual norm 7.490375850430e-06
  5130 KSP Residual norm 7.725182173792e-06
  5131 KSP Residual norm 6.835372701123e-06
  5132 KSP Residual norm 5.672927996960e-06
  5133 KSP Residual norm 4.707761799845e-06
  5134 KSP Residual norm 4.648403170918e-06
  5135 KSP Residual norm 5.519856986586e-06
  5136 KSP Residual norm 6.735858831513e-06
  5137 KSP Residual norm 7.702234846345e-06
  5138 KSP Residual norm 7.639691893133e-06
  5139 KSP Residual norm 7.257711249566e-06
  5140 KSP Residual norm 7.873127325778e-06
  5141 KSP Residual norm 9.717431001995e-06
  5142 KSP Residual norm 1.172031199915e-05
  5143 KSP Residual norm 1.238680126900e-05
  5144 KSP Residual norm 1.269367419071e-05
  5145 KSP Residual norm 1.416544927436e-05
  5146 KSP Residual norm 1.539832792391e-05
  5147 KSP Residual norm 1.485161114097e-05
  5148 KSP Residual norm 1.297136588694e-05
  5149 KSP Residual norm 1.189573821532e-05
  5150 KSP Residual norm 1.102158639368e-05
  5151 KSP Residual norm 1.056036924833e-05
  5152 KSP Residual norm 9.417130288301e-06
  5153 KSP Residual norm 7.493147052307e-06
  5154 KSP Residual norm 6.746297791974e-06
  5155 KSP Residual norm 7.554606661726e-06
  5156 KSP Residual norm 8.767830620654e-06
  5157 KSP Residual norm 8.823961755105e-06
  5158 KSP Residual norm 8.699489309667e-06
  5159 KSP Residual norm 9.669359737108e-06
  5160 KSP Residual norm 1.033042786227e-05
  5161 KSP Residual norm 1.009753469800e-05
  5162 KSP Residual norm 1.005430036467e-05
  5163 KSP Residual norm 9.749340579294e-06
  5164 KSP Residual norm 8.431182794856e-06
  5165 KSP Residual norm 6.691274150551e-06
  5166 KSP Residual norm 5.883360859804e-06
  5167 KSP Residual norm 6.205930693377e-06
  5168 KSP Residual norm 7.278574937625e-06
  5169 KSP Residual norm 8.226170762326e-06
  5170 KSP Residual norm 8.462716737282e-06
  5171 KSP Residual norm 9.272017691695e-06
  5172 KSP Residual norm 1.211168328934e-05
  5173 KSP Residual norm 1.505130024907e-05
  5174 KSP Residual norm 1.401866509493e-05
  5175 KSP Residual norm 1.065177276386e-05
  5176 KSP Residual norm 8.555037126333e-06
  5177 KSP Residual norm 7.852004668878e-06
  5178 KSP Residual norm 7.861151477086e-06
  5179 KSP Residual norm 8.437539604167e-06
  5180 KSP Residual norm 8.000790547168e-06
  5181 KSP Residual norm 7.337693139389e-06
  5182 KSP Residual norm 7.635424642211e-06
  5183 KSP Residual norm 8.696148831364e-06
  5184 KSP Residual norm 9.384165662391e-06
  5185 KSP Residual norm 9.319144951824e-06
  5186 KSP Residual norm 8.876564429561e-06
  5187 KSP Residual norm 8.659292761739e-06
  5188 KSP Residual norm 9.329339728702e-06
  5189 KSP Residual norm 1.087811537110e-05
  5190 KSP Residual norm 1.235427023826e-05
  5191 KSP Residual norm 1.182872048890e-05
  5192 KSP Residual norm 1.122709275608e-05
  5193 KSP Residual norm 1.200607232686e-05
  5194 KSP Residual norm 1.379343316334e-05
  5195 KSP Residual norm 1.495591994394e-05
  5196 KSP Residual norm 1.481950511353e-05
  5197 KSP Residual norm 1.426849192876e-05
  5198 KSP Residual norm 1.525642894131e-05
  5199 KSP Residual norm 1.842031320552e-05
  5200 KSP Residual norm 2.088147680253e-05
  5201 KSP Residual norm 1.963994964993e-05
  5202 KSP Residual norm 1.807501595523e-05
  5203 KSP Residual norm 1.716196245069e-05
  5204 KSP Residual norm 1.628989629117e-05
  5205 KSP Residual norm 1.623322499560e-05
  5206 KSP Residual norm 1.584812819824e-05
  5207 KSP Residual norm 1.452348256431e-05
  5208 KSP Residual norm 1.325089739661e-05
  5209 KSP Residual norm 1.220548461777e-05
  5210 KSP Residual norm 1.232059376322e-05
  5211 KSP Residual norm 1.275234238616e-05
  5212 KSP Residual norm 1.207394571244e-05
  5213 KSP Residual norm 1.162946657974e-05
  5214 KSP Residual norm 1.303835307122e-05
  5215 KSP Residual norm 1.554584798859e-05
  5216 KSP Residual norm 1.801561006151e-05
  5217 KSP Residual norm 1.896659819865e-05
  5218 KSP Residual norm 1.800946774205e-05
  5219 KSP Residual norm 1.746193164334e-05
  5220 KSP Residual norm 1.861044294687e-05
  5221 KSP Residual norm 1.887464472709e-05
  5222 KSP Residual norm 1.651312817488e-05
  5223 KSP Residual norm 1.389112595654e-05
  5224 KSP Residual norm 1.308809119504e-05
  5225 KSP Residual norm 1.357545491391e-05
  5226 KSP Residual norm 1.399150527652e-05
  5227 KSP Residual norm 1.253911172307e-05
  5228 KSP Residual norm 1.088746556343e-05
  5229 KSP Residual norm 1.150061337583e-05
  5230 KSP Residual norm 1.424066271143e-05
  5231 KSP Residual norm 1.743322968541e-05
  5232 KSP Residual norm 1.874201508677e-05
  5233 KSP Residual norm 1.826386830567e-05
  5234 KSP Residual norm 1.715889534125e-05
  5235 KSP Residual norm 1.773258909346e-05
  5236 KSP Residual norm 1.879840743439e-05
  5237 KSP Residual norm 1.952767517280e-05
  5238 KSP Residual norm 1.936323565914e-05
  5239 KSP Residual norm 1.686365983775e-05
  5240 KSP Residual norm 1.512768295192e-05
  5241 KSP Residual norm 1.604296205474e-05
  5242 KSP Residual norm 1.781036834601e-05
  5243 KSP Residual norm 1.686071031469e-05
  5244 KSP Residual norm 1.535698858318e-05
  5245 KSP Residual norm 1.438129467170e-05
  5246 KSP Residual norm 1.408751520884e-05
  5247 KSP Residual norm 1.439955825575e-05
  5248 KSP Residual norm 1.542793017451e-05
  5249 KSP Residual norm 1.631316757151e-05
  5250 KSP Residual norm 1.641818903694e-05
  5251 KSP Residual norm 1.659501574888e-05
  5252 KSP Residual norm 1.787840946378e-05
  5253 KSP Residual norm 1.851721480257e-05
  5254 KSP Residual norm 1.647814503054e-05
  5255 KSP Residual norm 1.390252172833e-05
  5256 KSP Residual norm 1.401922999706e-05
  5257 KSP Residual norm 1.552161840468e-05
  5258 KSP Residual norm 1.500311561444e-05
  5259 KSP Residual norm 1.221440231445e-05
  5260 KSP Residual norm 9.870760158073e-06
  5261 KSP Residual norm 9.415039076535e-06
  5262 KSP Residual norm 1.144499110962e-05
  5263 KSP Residual norm 1.423640171445e-05
  5264 KSP Residual norm 1.439628736300e-05
  5265 KSP Residual norm 1.383387004506e-05
  5266 KSP Residual norm 1.501675973053e-05
  5267 KSP Residual norm 1.714450575061e-05
  5268 KSP Residual norm 1.815020937663e-05
  5269 KSP Residual norm 1.607268071322e-05
  5270 KSP Residual norm 1.307822931932e-05
  5271 KSP Residual norm 1.162347835007e-05
  5272 KSP Residual norm 1.222183274596e-05
  5273 KSP Residual norm 1.302798007952e-05
  5274 KSP Residual norm 1.249208780501e-05
  5275 KSP Residual norm 1.219410033126e-05
  5276 KSP Residual norm 1.366015481101e-05
  5277 KSP Residual norm 1.668156952035e-05
  5278 KSP Residual norm 1.901897036897e-05
  5279 KSP Residual norm 1.958258115880e-05
  5280 KSP Residual norm 1.971344972876e-05
  5281 KSP Residual norm 2.196584524485e-05
  5282 KSP Residual norm 2.653950926230e-05
  5283 KSP Residual norm 3.002892132456e-05
  5284 KSP Residual norm 2.706744857327e-05
  5285 KSP Residual norm 2.345036269688e-05
  5286 KSP Residual norm 2.409680807816e-05
  5287 KSP Residual norm 2.632096241107e-05
  5288 KSP Residual norm 2.461217000940e-05
  5289 KSP Residual norm 2.323490585554e-05
  5290 KSP Residual norm 2.408795096474e-05
  5291 KSP Residual norm 2.398501489650e-05
  5292 KSP Residual norm 2.127585024156e-05
  5293 KSP Residual norm 1.973755948805e-05
  5294 KSP Residual norm 1.986590834033e-05
  5295 KSP Residual norm 2.058700096123e-05
  5296 KSP Residual norm 2.110207179006e-05
  5297 KSP Residual norm 2.074095928087e-05
  5298 KSP Residual norm 2.065225405290e-05
  5299 KSP Residual norm 2.164679055681e-05
  5300 KSP Residual norm 2.231406311089e-05
  5301 KSP Residual norm 2.187809549652e-05
  5302 KSP Residual norm 2.223774669513e-05
  5303 KSP Residual norm 2.245024794570e-05
  5304 KSP Residual norm 2.365181747614e-05
  5305 KSP Residual norm 2.599186150152e-05
  5306 KSP Residual norm 2.569490615705e-05
  5307 KSP Residual norm 2.265917121154e-05
  5308 KSP Residual norm 2.200430906084e-05
  5309 KSP Residual norm 2.248417569648e-05
  5310 KSP Residual norm 2.105729504171e-05
  5311 KSP Residual norm 1.804994868974e-05
  5312 KSP Residual norm 1.457976894569e-05
  5313 KSP Residual norm 1.250884429987e-05
  5314 KSP Residual norm 1.258421227279e-05
  5315 KSP Residual norm 1.442954099109e-05
  5316 KSP Residual norm 1.512360784407e-05
  5317 KSP Residual norm 1.290785014599e-05
  5318 KSP Residual norm 1.135555717721e-05
  5319 KSP Residual norm 1.180232954200e-05
  5320 KSP Residual norm 1.339622707811e-05
  5321 KSP Residual norm 1.352071491592e-05
  5322 KSP Residual norm 1.217398218753e-05
  5323 KSP Residual norm 1.099138044646e-05
  5324 KSP Residual norm 1.159550298081e-05
  5325 KSP Residual norm 1.317080043075e-05
  5326 KSP Residual norm 1.331755690409e-05
  5327 KSP Residual norm 1.197965064748e-05
  5328 KSP Residual norm 1.114931970007e-05
  5329 KSP Residual norm 1.079779195505e-05
  5330 KSP Residual norm 1.003193301916e-05
  5331 KSP Residual norm 8.766630643615e-06
  5332 KSP Residual norm 7.472191574213e-06
  5333 KSP Residual norm 6.141176967959e-06
  5334 KSP Residual norm 5.166553592940e-06
  5335 KSP Residual norm 5.461535799019e-06
  5336 KSP Residual norm 6.341340649007e-06
  5337 KSP Residual norm 6.019802029044e-06
  5338 KSP Residual norm 5.204084607812e-06
  5339 KSP Residual norm 4.980629218206e-06
  5340 KSP Residual norm 5.092264200404e-06
  5341 KSP Residual norm 5.150131662172e-06
  5342 KSP Residual norm 5.398309624069e-06
  5343 KSP Residual norm 5.880759054873e-06
  5344 KSP Residual norm 6.386632346182e-06
  5345 KSP Residual norm 6.806856891920e-06
  5346 KSP Residual norm 7.354823282149e-06
  5347 KSP Residual norm 7.568868156829e-06
  5348 KSP Residual norm 6.936818631693e-06
  5349 KSP Residual norm 6.369802031129e-06
  5350 KSP Residual norm 5.769136855671e-06
  5351 KSP Residual norm 5.011039465004e-06
  5352 KSP Residual norm 4.335319423599e-06
  5353 KSP Residual norm 3.844419359938e-06
  5354 KSP Residual norm 3.390508636338e-06
  5355 KSP Residual norm 3.179458559683e-06
  5356 KSP Residual norm 3.113202742255e-06
  5357 KSP Residual norm 3.040290225500e-06
  5358 KSP Residual norm 2.950528592601e-06
  5359 KSP Residual norm 3.019619020502e-06
  5360 KSP Residual norm 3.143673186037e-06
  5361 KSP Residual norm 3.269276557569e-06
  5362 KSP Residual norm 3.356248469776e-06
  5363 KSP Residual norm 3.600310368377e-06
  5364 KSP Residual norm 3.805498541574e-06
  5365 KSP Residual norm 4.095554358517e-06
  5366 KSP Residual norm 4.232018805251e-06
  5367 KSP Residual norm 4.405723514558e-06
  5368 KSP Residual norm 4.470898441287e-06
  5369 KSP Residual norm 4.574818421971e-06
  5370 KSP Residual norm 5.186806926745e-06
  5371 KSP Residual norm 5.736881498382e-06
  5372 KSP Residual norm 5.552796721800e-06
  5373 KSP Residual norm 5.548498205794e-06
  5374 KSP Residual norm 5.924411304026e-06
  5375 KSP Residual norm 5.949416006281e-06
  5376 KSP Residual norm 5.455033064685e-06
  5377 KSP Residual norm 4.992653955523e-06
  5378 KSP Residual norm 5.205434463130e-06
  5379 KSP Residual norm 5.651616992074e-06
  5380 KSP Residual norm 5.261508329334e-06
  5381 KSP Residual norm 4.398368087577e-06
  5382 KSP Residual norm 4.170460919987e-06
  5383 KSP Residual norm 4.425051117658e-06
  5384 KSP Residual norm 4.410699079509e-06
  5385 KSP Residual norm 3.906925328441e-06
  5386 KSP Residual norm 3.931178323414e-06
  5387 KSP Residual norm 4.739637765365e-06
  5388 KSP Residual norm 5.881306526868e-06
  5389 KSP Residual norm 6.432895028701e-06
  5390 KSP Residual norm 6.354554814005e-06
  5391 KSP Residual norm 6.633955648163e-06
  5392 KSP Residual norm 7.369398848998e-06
  5393 KSP Residual norm 7.773649110969e-06
  5394 KSP Residual norm 7.562943533390e-06
  5395 KSP Residual norm 7.283115738957e-06
  5396 KSP Residual norm 7.574199274886e-06
  5397 KSP Residual norm 8.606065923579e-06
  5398 KSP Residual norm 9.267867744582e-06
  5399 KSP Residual norm 8.051040672477e-06
  5400 KSP Residual norm 6.291884894095e-06
  5401 KSP Residual norm 5.947426965959e-06
  5402 KSP Residual norm 5.965490949672e-06
  5403 KSP Residual norm 5.314446054795e-06
  5404 KSP Residual norm 4.741362100572e-06
  5405 KSP Residual norm 5.073920418377e-06
  5406 KSP Residual norm 6.175108125931e-06
  5407 KSP Residual norm 6.909625261632e-06
  5408 KSP Residual norm 6.830144202480e-06
  5409 KSP Residual norm 6.850613365538e-06
  5410 KSP Residual norm 7.028557316752e-06
  5411 KSP Residual norm 6.899700480251e-06
  5412 KSP Residual norm 6.414415301855e-06
  5413 KSP Residual norm 6.157272404518e-06
  5414 KSP Residual norm 6.575130132065e-06
  5415 KSP Residual norm 6.739759095732e-06
  5416 KSP Residual norm 6.003630816430e-06
  5417 KSP Residual norm 4.887778758119e-06
  5418 KSP Residual norm 4.505276154808e-06
  5419 KSP Residual norm 4.749829166380e-06
  5420 KSP Residual norm 5.054596867370e-06
  5421 KSP Residual norm 4.822886633332e-06
  5422 KSP Residual norm 4.508693009486e-06
  5423 KSP Residual norm 4.480233898737e-06
  5424 KSP Residual norm 4.383546049897e-06
  5425 KSP Residual norm 4.217002372359e-06
  5426 KSP Residual norm 3.839299482728e-06
  5427 KSP Residual norm 3.601568628579e-06
  5428 KSP Residual norm 3.811484052474e-06
  5429 KSP Residual norm 4.130831962168e-06
  5430 KSP Residual norm 4.041655821764e-06
  5431 KSP Residual norm 3.660837963350e-06
  5432 KSP Residual norm 3.518188312194e-06
  5433 KSP Residual norm 3.558513484447e-06
  5434 KSP Residual norm 3.558792920736e-06
  5435 KSP Residual norm 3.136722315162e-06
  5436 KSP Residual norm 2.871939172431e-06
  5437 KSP Residual norm 2.980400190316e-06
  5438 KSP Residual norm 3.050197839715e-06
  5439 KSP Residual norm 2.848958913818e-06
  5440 KSP Residual norm 2.804893767689e-06
  5441 KSP Residual norm 3.101007230811e-06
  5442 KSP Residual norm 3.298011606061e-06
  5443 KSP Residual norm 3.519614516205e-06
  5444 KSP Residual norm 3.922937324800e-06
  5445 KSP Residual norm 4.104472088199e-06
  5446 KSP Residual norm 4.313871383144e-06
  5447 KSP Residual norm 4.283689253662e-06
  5448 KSP Residual norm 3.565770598566e-06
  5449 KSP Residual norm 3.019545044112e-06
  5450 KSP Residual norm 2.910694553551e-06
  5451 KSP Residual norm 2.882145235540e-06
  5452 KSP Residual norm 2.788665519059e-06
  5453 KSP Residual norm 2.677666584049e-06
  5454 KSP Residual norm 2.562591917687e-06
  5455 KSP Residual norm 2.368778067332e-06
  5456 KSP Residual norm 2.311820209788e-06
  5457 KSP Residual norm 2.553017632731e-06
  5458 KSP Residual norm 2.861173244073e-06
  5459 KSP Residual norm 3.035036050312e-06
  5460 KSP Residual norm 3.295671441835e-06
  5461 KSP Residual norm 3.966560870102e-06
  5462 KSP Residual norm 4.846038820653e-06
  5463 KSP Residual norm 5.255008993057e-06
  5464 KSP Residual norm 5.571703372525e-06
  5465 KSP Residual norm 5.815245826277e-06
  5466 KSP Residual norm 5.836891686753e-06
  5467 KSP Residual norm 6.662743981342e-06
  5468 KSP Residual norm 6.855203089823e-06
  5469 KSP Residual norm 6.362448463954e-06
  5470 KSP Residual norm 6.853417698629e-06
  5471 KSP Residual norm 8.215838502763e-06
  5472 KSP Residual norm 8.304014534722e-06
  5473 KSP Residual norm 7.131704724682e-06
  5474 KSP Residual norm 6.219898196049e-06
  5475 KSP Residual norm 5.812616173018e-06
  5476 KSP Residual norm 5.535643296512e-06
  5477 KSP Residual norm 5.641686630424e-06
  5478 KSP Residual norm 5.805216509153e-06
  5479 KSP Residual norm 6.062747358934e-06
  5480 KSP Residual norm 6.820183132139e-06
  5481 KSP Residual norm 7.350235827792e-06
  5482 KSP Residual norm 7.284057732861e-06
  5483 KSP Residual norm 7.065811376913e-06
  5484 KSP Residual norm 6.741939047962e-06
  5485 KSP Residual norm 7.002338736197e-06
  5486 KSP Residual norm 7.494533412534e-06
  5487 KSP Residual norm 7.695904858735e-06
  5488 KSP Residual norm 7.833529460142e-06
  5489 KSP Residual norm 8.578802254821e-06
  5490 KSP Residual norm 9.399250662232e-06
  5491 KSP Residual norm 1.049295756843e-05
  5492 KSP Residual norm 1.077796862400e-05
  5493 KSP Residual norm 1.009219660826e-05
  5494 KSP Residual norm 9.691802079987e-06
  5495 KSP Residual norm 9.582949292529e-06
  5496 KSP Residual norm 9.311633084079e-06
  5497 KSP Residual norm 8.745833420024e-06
  5498 KSP Residual norm 8.437873840044e-06
  5499 KSP Residual norm 8.227880394874e-06
  5500 KSP Residual norm 7.582360092270e-06
  5501 KSP Residual norm 7.069748101912e-06
  5502 KSP Residual norm 6.470585934534e-06
  5503 KSP Residual norm 5.875664271492e-06
  5504 KSP Residual norm 5.596979604300e-06
  5505 KSP Residual norm 5.491480519291e-06
  5506 KSP Residual norm 4.852646953339e-06
  5507 KSP Residual norm 3.880342022501e-06
  5508 KSP Residual norm 3.425681605682e-06
  5509 KSP Residual norm 3.422944599876e-06
  5510 KSP Residual norm 3.364888190966e-06
  5511 KSP Residual norm 2.939191801172e-06
  5512 KSP Residual norm 2.755787696764e-06
  5513 KSP Residual norm 2.971890028152e-06
  5514 KSP Residual norm 3.316198695129e-06
  5515 KSP Residual norm 3.260884358883e-06
  5516 KSP Residual norm 3.542673149487e-06
  5517 KSP Residual norm 4.196610024542e-06
  5518 KSP Residual norm 4.627562218199e-06
  5519 KSP Residual norm 4.612345028438e-06
  5520 KSP Residual norm 4.443770957171e-06
  5521 KSP Residual norm 4.380938551701e-06
  5522 KSP Residual norm 4.488535382945e-06
  5523 KSP Residual norm 4.712284498048e-06
  5524 KSP Residual norm 4.871248371661e-06
  5525 KSP Residual norm 4.726437209821e-06
  5526 KSP Residual norm 4.386096025645e-06
  5527 KSP Residual norm 4.094841007872e-06
  5528 KSP Residual norm 3.767234070384e-06
  5529 KSP Residual norm 3.648045072169e-06
  5530 KSP Residual norm 3.742156938352e-06
  5531 KSP Residual norm 4.028756284201e-06
  5532 KSP Residual norm 4.175767503667e-06
  5533 KSP Residual norm 4.409168191274e-06
  5534 KSP Residual norm 4.549924408238e-06
  5535 KSP Residual norm 4.509624886236e-06
  5536 KSP Residual norm 4.516345381255e-06
  5537 KSP Residual norm 4.624907949762e-06
  5538 KSP Residual norm 4.917901823717e-06
  5539 KSP Residual norm 5.276738004716e-06
  5540 KSP Residual norm 5.435000405822e-06
  5541 KSP Residual norm 5.852701785395e-06
  5542 KSP Residual norm 6.990750031184e-06
  5543 KSP Residual norm 8.693517933586e-06
  5544 KSP Residual norm 9.369760658684e-06
  5545 KSP Residual norm 9.091365377916e-06
  5546 KSP Residual norm 9.676056965588e-06
  5547 KSP Residual norm 1.162831783947e-05
  5548 KSP Residual norm 1.185908484572e-05
  5549 KSP Residual norm 1.101692319117e-05
  5550 KSP Residual norm 1.106300259118e-05
  5551 KSP Residual norm 1.061829230992e-05
  5552 KSP Residual norm 9.446204531968e-06
  5553 KSP Residual norm 8.217657494866e-06
  5554 KSP Residual norm 7.288849347838e-06
  5555 KSP Residual norm 6.408876538547e-06
  5556 KSP Residual norm 6.085451815969e-06
  5557 KSP Residual norm 6.484162312180e-06
  5558 KSP Residual norm 6.770883097588e-06
  5559 KSP Residual norm 6.792925646033e-06
  5560 KSP Residual norm 7.669167690081e-06
  5561 KSP Residual norm 8.945530968109e-06
  5562 KSP Residual norm 8.614026120564e-06
  5563 KSP Residual norm 7.952021595321e-06
  5564 KSP Residual norm 8.808864196321e-06
  5565 KSP Residual norm 1.108897368684e-05
  5566 KSP Residual norm 1.274380198253e-05
  5567 KSP Residual norm 1.251726858037e-05
  5568 KSP Residual norm 1.382310202679e-05
  5569 KSP Residual norm 1.782536149940e-05
  5570 KSP Residual norm 2.222905376302e-05
  5571 KSP Residual norm 2.246282468850e-05
  5572 KSP Residual norm 2.162339938983e-05
  5573 KSP Residual norm 2.071950582582e-05
  5574 KSP Residual norm 1.976450131276e-05
  5575 KSP Residual norm 1.924216283532e-05
  5576 KSP Residual norm 1.852990059726e-05
  5577 KSP Residual norm 1.591815146051e-05
  5578 KSP Residual norm 1.430446127036e-05
  5579 KSP Residual norm 1.359567948228e-05
  5580 KSP Residual norm 1.293618730115e-05
  5581 KSP Residual norm 1.343244375440e-05
  5582 KSP Residual norm 1.451686401145e-05
  5583 KSP Residual norm 1.463743451381e-05
  5584 KSP Residual norm 1.483511784571e-05
  5585 KSP Residual norm 1.549122347708e-05
  5586 KSP Residual norm 1.623796200138e-05
  5587 KSP Residual norm 1.769082340475e-05
  5588 KSP Residual norm 1.890567415499e-05
  5589 KSP Residual norm 1.859474190613e-05
  5590 KSP Residual norm 1.877462201109e-05
  5591 KSP Residual norm 2.000523147755e-05
  5592 KSP Residual norm 2.183557977029e-05
  5593 KSP Residual norm 2.191978451221e-05
  5594 KSP Residual norm 2.100070646075e-05
  5595 KSP Residual norm 2.240185493519e-05
  5596 KSP Residual norm 2.583641443670e-05
  5597 KSP Residual norm 2.882567670906e-05
  5598 KSP Residual norm 3.217132297033e-05
  5599 KSP Residual norm 3.633931039861e-05
  5600 KSP Residual norm 3.730308094759e-05
  5601 KSP Residual norm 3.055257131683e-05
  5602 KSP Residual norm 2.528066776091e-05
  5603 KSP Residual norm 2.540202678204e-05
  5604 KSP Residual norm 2.686180319422e-05
  5605 KSP Residual norm 2.354634484453e-05
  5606 KSP Residual norm 2.280406503005e-05
  5607 KSP Residual norm 2.174783123132e-05
  5608 KSP Residual norm 1.984819360122e-05
  5609 KSP Residual norm 1.978195329938e-05
  5610 KSP Residual norm 2.301921999814e-05
  5611 KSP Residual norm 2.409027614363e-05
  5612 KSP Residual norm 2.288593960908e-05
  5613 KSP Residual norm 2.207850791745e-05
  5614 KSP Residual norm 2.274204403283e-05
  5615 KSP Residual norm 2.247876000820e-05
  5616 KSP Residual norm 2.295507162696e-05
  5617 KSP Residual norm 2.320878968269e-05
  5618 KSP Residual norm 2.278502208103e-05
  5619 KSP Residual norm 2.392375194562e-05
  5620 KSP Residual norm 2.438091769438e-05
  5621 KSP Residual norm 2.162041012160e-05
  5622 KSP Residual norm 1.860746526771e-05
  5623 KSP Residual norm 1.938470088009e-05
  5624 KSP Residual norm 1.966786513250e-05
  5625 KSP Residual norm 1.711044378105e-05
  5626 KSP Residual norm 1.465659728516e-05
  5627 KSP Residual norm 1.325403260913e-05
  5628 KSP Residual norm 1.271168352537e-05
  5629 KSP Residual norm 1.159272800447e-05
  5630 KSP Residual norm 1.157809095829e-05
  5631 KSP Residual norm 1.165958179611e-05
  5632 KSP Residual norm 1.081697540804e-05
  5633 KSP Residual norm 1.088131338939e-05
  5634 KSP Residual norm 1.276452122241e-05
  5635 KSP Residual norm 1.526331334932e-05
  5636 KSP Residual norm 1.648673074780e-05
  5637 KSP Residual norm 1.554192437512e-05
  5638 KSP Residual norm 1.429637639057e-05
  5639 KSP Residual norm 1.451211727891e-05
  5640 KSP Residual norm 1.542919107416e-05
  5641 KSP Residual norm 1.587904909472e-05
  5642 KSP Residual norm 1.679889551408e-05
  5643 KSP Residual norm 1.796966854906e-05
  5644 KSP Residual norm 1.937380313007e-05
  5645 KSP Residual norm 1.868782579059e-05
  5646 KSP Residual norm 1.611698412572e-05
  5647 KSP Residual norm 1.513651859409e-05
  5648 KSP Residual norm 1.631594330603e-05
  5649 KSP Residual norm 1.662312043502e-05
  5650 KSP Residual norm 1.577007658589e-05
  5651 KSP Residual norm 1.429258386307e-05
  5652 KSP Residual norm 1.239852729962e-05
  5653 KSP Residual norm 1.149818590301e-05
  5654 KSP Residual norm 1.203759190781e-05
  5655 KSP Residual norm 1.166223800163e-05
  5656 KSP Residual norm 1.067644696576e-05
  5657 KSP Residual norm 1.167709456072e-05
  5658 KSP Residual norm 1.262413644833e-05
  5659 KSP Residual norm 1.119514853851e-05
  5660 KSP Residual norm 1.090353866791e-05
  5661 KSP Residual norm 1.292606097272e-05
  5662 KSP Residual norm 1.522265850866e-05
  5663 KSP Residual norm 1.682699556565e-05
  5664 KSP Residual norm 1.861426152386e-05
  5665 KSP Residual norm 2.146452252388e-05
  5666 KSP Residual norm 2.325557857889e-05
  5667 KSP Residual norm 2.195507348651e-05
  5668 KSP Residual norm 2.195232080741e-05
  5669 KSP Residual norm 2.553436631729e-05
  5670 KSP Residual norm 2.872147817779e-05
  5671 KSP Residual norm 2.823889361995e-05
  5672 KSP Residual norm 3.131282504082e-05
  5673 KSP Residual norm 3.656584624398e-05
  5674 KSP Residual norm 3.468831425485e-05
  5675 KSP Residual norm 3.359725448340e-05
  5676 KSP Residual norm 3.788686685775e-05
  5677 KSP Residual norm 4.077681104817e-05
  5678 KSP Residual norm 4.297939987724e-05
  5679 KSP Residual norm 4.452542660864e-05
  5680 KSP Residual norm 4.201494437652e-05
  5681 KSP Residual norm 4.499523402656e-05
  5682 KSP Residual norm 4.907649659042e-05
  5683 KSP Residual norm 4.965063196527e-05
  5684 KSP Residual norm 4.925382355341e-05
  5685 KSP Residual norm 5.444260216793e-05
  5686 KSP Residual norm 6.003934766354e-05
  5687 KSP Residual norm 5.801507984838e-05
  5688 KSP Residual norm 5.713053766418e-05
  5689 KSP Residual norm 6.049219273280e-05
  5690 KSP Residual norm 6.858110678971e-05
  5691 KSP Residual norm 7.954424524029e-05
  5692 KSP Residual norm 7.871180313959e-05
  5693 KSP Residual norm 7.335490314706e-05
  5694 KSP Residual norm 7.619457810116e-05
  5695 KSP Residual norm 7.752061580039e-05
  5696 KSP Residual norm 6.893843631676e-05
  5697 KSP Residual norm 5.936840534785e-05
  5698 KSP Residual norm 5.240926856457e-05
  5699 KSP Residual norm 5.174437745017e-05
  5700 KSP Residual norm 5.507814039568e-05
  5701 KSP Residual norm 5.362145502310e-05
  5702 KSP Residual norm 5.570774126388e-05
  5703 KSP Residual norm 6.602632868639e-05
  5704 KSP Residual norm 6.767208624985e-05
  5705 KSP Residual norm 6.261452221010e-05
  5706 KSP Residual norm 6.646518426196e-05
  5707 KSP Residual norm 7.647189913308e-05
  5708 KSP Residual norm 7.704157272977e-05
  5709 KSP Residual norm 7.107528707986e-05
  5710 KSP Residual norm 6.948803848116e-05
  5711 KSP Residual norm 8.081529790175e-05
  5712 KSP Residual norm 1.014095405237e-04
  5713 KSP Residual norm 1.081476301613e-04
  5714 KSP Residual norm 1.042940025880e-04
  5715 KSP Residual norm 1.036880210342e-04
  5716 KSP Residual norm 1.021209577493e-04
  5717 KSP Residual norm 1.002850675406e-04
  5718 KSP Residual norm 9.332248986234e-05
  5719 KSP Residual norm 7.361566497504e-05
  5720 KSP Residual norm 6.422715770513e-05
  5721 KSP Residual norm 6.915058654177e-05
  5722 KSP Residual norm 6.416960067782e-05
  5723 KSP Residual norm 5.373042668160e-05
  5724 KSP Residual norm 5.047072632927e-05
  5725 KSP Residual norm 4.778740133795e-05
  5726 KSP Residual norm 4.219161146925e-05
  5727 KSP Residual norm 4.256811949806e-05
  5728 KSP Residual norm 4.877370255517e-05
  5729 KSP Residual norm 5.098750364346e-05
  5730 KSP Residual norm 4.872494579491e-05
  5731 KSP Residual norm 4.684661658167e-05
  5732 KSP Residual norm 4.898005818936e-05
  5733 KSP Residual norm 5.431404478127e-05
  5734 KSP Residual norm 5.914049427487e-05
  5735 KSP Residual norm 6.376363132635e-05
  5736 KSP Residual norm 6.886913366330e-05
  5737 KSP Residual norm 6.868196363700e-05
  5738 KSP Residual norm 7.093686092014e-05
  5739 KSP Residual norm 6.742977748224e-05
  5740 KSP Residual norm 5.538166803462e-05
  5741 KSP Residual norm 5.419796645776e-05
  5742 KSP Residual norm 6.211945548186e-05
  5743 KSP Residual norm 6.109248894122e-05
  5744 KSP Residual norm 5.047999238871e-05
  5745 KSP Residual norm 4.611285835908e-05
  5746 KSP Residual norm 4.605103274247e-05
  5747 KSP Residual norm 4.680826782300e-05
  5748 KSP Residual norm 4.543184806948e-05
  5749 KSP Residual norm 4.288521600355e-05
  5750 KSP Residual norm 4.014917000339e-05
  5751 KSP Residual norm 3.932260316700e-05
  5752 KSP Residual norm 3.588456923275e-05
  5753 KSP Residual norm 3.196196632128e-05
  5754 KSP Residual norm 3.139416129741e-05
  5755 KSP Residual norm 3.403508684195e-05
  5756 KSP Residual norm 3.628350579050e-05
  5757 KSP Residual norm 3.836857274861e-05
  5758 KSP Residual norm 3.954386974449e-05
  5759 KSP Residual norm 4.011915555833e-05
  5760 KSP Residual norm 4.128544534608e-05
  5761 KSP Residual norm 4.439593735248e-05
  5762 KSP Residual norm 5.073916878302e-05
  5763 KSP Residual norm 5.662560320266e-05
  5764 KSP Residual norm 5.603731212473e-05
  5765 KSP Residual norm 5.533008125977e-05
  5766 KSP Residual norm 6.029697647124e-05
  5767 KSP Residual norm 6.130533399644e-05
  5768 KSP Residual norm 6.176757635929e-05
  5769 KSP Residual norm 6.175069208590e-05
  5770 KSP Residual norm 5.980765988776e-05
  5771 KSP Residual norm 5.878499444665e-05
  5772 KSP Residual norm 6.410517017736e-05
  5773 KSP Residual norm 6.402187258826e-05
  5774 KSP Residual norm 5.622645147391e-05
  5775 KSP Residual norm 5.388674481786e-05
  5776 KSP Residual norm 6.160839129385e-05
  5777 KSP Residual norm 7.149101947595e-05
  5778 KSP Residual norm 7.276262684592e-05
  5779 KSP Residual norm 6.671489237116e-05
  5780 KSP Residual norm 6.504247025748e-05
  5781 KSP Residual norm 7.006957397434e-05
  5782 KSP Residual norm 7.329011483403e-05
  5783 KSP Residual norm 7.826353525746e-05
  5784 KSP Residual norm 9.456704158856e-05
  5785 KSP Residual norm 1.092171369618e-04
  5786 KSP Residual norm 1.108722207906e-04
  5787 KSP Residual norm 1.190011317138e-04
  5788 KSP Residual norm 1.286731075942e-04
  5789 KSP Residual norm 1.240684802814e-04
  5790 KSP Residual norm 1.299914015235e-04
  5791 KSP Residual norm 1.345286967498e-04
  5792 KSP Residual norm 1.331515669063e-04
  5793 KSP Residual norm 1.391848408482e-04
  5794 KSP Residual norm 1.389994870591e-04
  5795 KSP Residual norm 1.316377668436e-04
  5796 KSP Residual norm 1.360418555561e-04
  5797 KSP Residual norm 1.434549931809e-04
  5798 KSP Residual norm 1.377260578661e-04
  5799 KSP Residual norm 1.306327978207e-04
  5800 KSP Residual norm 1.133978146600e-04
  5801 KSP Residual norm 9.364218397859e-05
  5802 KSP Residual norm 9.179247606745e-05
  5803 KSP Residual norm 9.592385039723e-05
  5804 KSP Residual norm 8.401491164108e-05
  5805 KSP Residual norm 7.765458544600e-05
  5806 KSP Residual norm 8.034330438499e-05
  5807 KSP Residual norm 7.518789904032e-05
  5808 KSP Residual norm 7.109056953595e-05
  5809 KSP Residual norm 6.638332743955e-05
  5810 KSP Residual norm 5.826636461352e-05
  5811 KSP Residual norm 5.429215649359e-05
  5812 KSP Residual norm 5.634929811268e-05
  5813 KSP Residual norm 6.148619101370e-05
  5814 KSP Residual norm 6.899444044826e-05
  5815 KSP Residual norm 7.282923000521e-05
  5816 KSP Residual norm 7.303867766647e-05
  5817 KSP Residual norm 7.733188829761e-05
  5818 KSP Residual norm 8.307647561037e-05
  5819 KSP Residual norm 7.965971236127e-05
  5820 KSP Residual norm 7.934842114619e-05
  5821 KSP Residual norm 8.209899838983e-05
  5822 KSP Residual norm 8.779306783545e-05
  5823 KSP Residual norm 9.284908590190e-05
  5824 KSP Residual norm 9.035707596758e-05
  5825 KSP Residual norm 8.497427643231e-05
  5826 KSP Residual norm 8.870949703092e-05
  5827 KSP Residual norm 8.962203641969e-05
  5828 KSP Residual norm 8.556785348387e-05
  5829 KSP Residual norm 8.707156662234e-05
  5830 KSP Residual norm 9.563497246028e-05
  5831 KSP Residual norm 1.001603792157e-04
  5832 KSP Residual norm 1.058354970032e-04
  5833 KSP Residual norm 1.020122592705e-04
  5834 KSP Residual norm 8.363758530242e-05
  5835 KSP Residual norm 7.795739977042e-05
  5836 KSP Residual norm 8.475746957849e-05
  5837 KSP Residual norm 7.746555774856e-05
  5838 KSP Residual norm 6.775976202369e-05
  5839 KSP Residual norm 6.713802694789e-05
  5840 KSP Residual norm 7.307563844167e-05
  5841 KSP Residual norm 7.119972459979e-05
  5842 KSP Residual norm 6.545254270597e-05
  5843 KSP Residual norm 6.307563127922e-05
  5844 KSP Residual norm 6.423756540491e-05
  5845 KSP Residual norm 5.995115181578e-05
  5846 KSP Residual norm 5.483045191622e-05
  5847 KSP Residual norm 5.852567918184e-05
  5848 KSP Residual norm 6.647278028454e-05
  5849 KSP Residual norm 7.028911931516e-05
  5850 KSP Residual norm 7.344523749685e-05
  5851 KSP Residual norm 7.446548518580e-05
  5852 KSP Residual norm 7.471144488338e-05
  5853 KSP Residual norm 8.373363285549e-05
  5854 KSP Residual norm 8.976656017027e-05
  5855 KSP Residual norm 7.798728475167e-05
  5856 KSP Residual norm 7.495418242486e-05
  5857 KSP Residual norm 9.070859194941e-05
  5858 KSP Residual norm 9.869230183081e-05
  5859 KSP Residual norm 8.635481019118e-05
  5860 KSP Residual norm 8.145442001528e-05
  5861 KSP Residual norm 8.539746419754e-05
  5862 KSP Residual norm 8.468993064896e-05
  5863 KSP Residual norm 7.623263543236e-05
  5864 KSP Residual norm 6.623690254470e-05
  5865 KSP Residual norm 6.297598378864e-05
  5866 KSP Residual norm 6.584547937519e-05
  5867 KSP Residual norm 6.918215431497e-05
  5868 KSP Residual norm 6.790112230965e-05
  5869 KSP Residual norm 6.472893330219e-05
  5870 KSP Residual norm 6.297316456709e-05
  5871 KSP Residual norm 6.466990087345e-05
  5872 KSP Residual norm 6.356245911866e-05
  5873 KSP Residual norm 5.566960638297e-05
  5874 KSP Residual norm 5.489411989031e-05
  5875 KSP Residual norm 6.786302618293e-05
  5876 KSP Residual norm 8.898723672657e-05
  5877 KSP Residual norm 1.046662334987e-04
  5878 KSP Residual norm 1.178311958989e-04
  5879 KSP Residual norm 1.249016558722e-04
  5880 KSP Residual norm 1.276688320097e-04
  5881 KSP Residual norm 1.325739034260e-04
  5882 KSP Residual norm 1.285071707702e-04
  5883 KSP Residual norm 1.293764487073e-04
  5884 KSP Residual norm 1.357160635366e-04
  5885 KSP Residual norm 1.217995115067e-04
  5886 KSP Residual norm 9.830532495372e-05
  5887 KSP Residual norm 8.267137011876e-05
  5888 KSP Residual norm 7.026973139745e-05
  5889 KSP Residual norm 6.452580056007e-05
  5890 KSP Residual norm 6.693542001935e-05
  5891 KSP Residual norm 6.467452058779e-05
  5892 KSP Residual norm 5.876773316360e-05
  5893 KSP Residual norm 6.256794804701e-05
  5894 KSP Residual norm 7.195749199543e-05
  5895 KSP Residual norm 7.668743317361e-05
  5896 KSP Residual norm 8.404104696612e-05
  5897 KSP Residual norm 8.982636850415e-05
  5898 KSP Residual norm 9.257872539147e-05
  5899 KSP Residual norm 9.151710165918e-05
  5900 KSP Residual norm 9.293499807731e-05
  5901 KSP Residual norm 9.811482056441e-05
  5902 KSP Residual norm 1.024843051569e-04
  5903 KSP Residual norm 9.343999355379e-05
  5904 KSP Residual norm 9.049291794660e-05
  5905 KSP Residual norm 9.780787111635e-05
  5906 KSP Residual norm 1.059508366191e-04
  5907 KSP Residual norm 1.126988190670e-04
  5908 KSP Residual norm 1.168502763320e-04
  5909 KSP Residual norm 1.058631006983e-04
  5910 KSP Residual norm 1.064516791154e-04
  5911 KSP Residual norm 1.234908099173e-04
  5912 KSP Residual norm 1.262053141692e-04
  5913 KSP Residual norm 1.031661774481e-04
  5914 KSP Residual norm 9.621588561916e-05
  5915 KSP Residual norm 9.489692242985e-05
  5916 KSP Residual norm 8.595600033991e-05
  5917 KSP Residual norm 7.207240509951e-05
  5918 KSP Residual norm 6.474146144496e-05
  5919 KSP Residual norm 6.376305361345e-05
  5920 KSP Residual norm 6.367481741882e-05
  5921 KSP Residual norm 6.344420389635e-05
  5922 KSP Residual norm 6.903360153335e-05
  5923 KSP Residual norm 6.900109282684e-05
  5924 KSP Residual norm 5.633226622044e-05
  5925 KSP Residual norm 5.203861413094e-05
  5926 KSP Residual norm 5.714220742057e-05
  5927 KSP Residual norm 5.657186479194e-05
  5928 KSP Residual norm 5.385541755184e-05
  5929 KSP Residual norm 5.532324257529e-05
  5930 KSP Residual norm 5.720913722852e-05
  5931 KSP Residual norm 5.695133225358e-05
  5932 KSP Residual norm 5.580479164771e-05
  5933 KSP Residual norm 5.493432868676e-05
  5934 KSP Residual norm 5.593406284629e-05
  5935 KSP Residual norm 6.302356173445e-05
  5936 KSP Residual norm 7.570064667564e-05
  5937 KSP Residual norm 8.576816086030e-05
  5938 KSP Residual norm 8.319890574186e-05
  5939 KSP Residual norm 6.732763896739e-05
  5940 KSP Residual norm 6.489616500681e-05
  5941 KSP Residual norm 7.135041606923e-05
  5942 KSP Residual norm 6.830405223954e-05
  5943 KSP Residual norm 5.761532078027e-05
  5944 KSP Residual norm 5.622718053728e-05
  5945 KSP Residual norm 5.101883472875e-05
  5946 KSP Residual norm 4.008305256116e-05
  5947 KSP Residual norm 3.634938787462e-05
  5948 KSP Residual norm 3.623893532702e-05
  5949 KSP Residual norm 2.946781214777e-05
  5950 KSP Residual norm 2.447952214964e-05
  5951 KSP Residual norm 2.351733396593e-05
  5952 KSP Residual norm 2.343833612171e-05
  5953 KSP Residual norm 2.271370206340e-05
  5954 KSP Residual norm 2.121613500926e-05
  5955 KSP Residual norm 1.919447557952e-05
  5956 KSP Residual norm 1.749976246413e-05
  5957 KSP Residual norm 1.580117365586e-05
  5958 KSP Residual norm 1.375424464567e-05
  5959 KSP Residual norm 1.209146880015e-05
  5960 KSP Residual norm 1.077129590390e-05
  5961 KSP Residual norm 1.000905983268e-05
  5962 KSP Residual norm 1.078203630223e-05
  5963 KSP Residual norm 1.188677774862e-05
  5964 KSP Residual norm 1.117435445555e-05
  5965 KSP Residual norm 1.117714238861e-05
  5966 KSP Residual norm 1.261972120189e-05
  5967 KSP Residual norm 1.223266462713e-05
  5968 KSP Residual norm 1.157131813930e-05
  5969 KSP Residual norm 1.222225083873e-05
  5970 KSP Residual norm 1.361994081007e-05
  5971 KSP Residual norm 1.625486334181e-05
  5972 KSP Residual norm 2.011035970780e-05
  5973 KSP Residual norm 2.047203563357e-05
  5974 KSP Residual norm 1.929428112718e-05
  5975 KSP Residual norm 1.836266924292e-05
  5976 KSP Residual norm 1.754772457829e-05
  5977 KSP Residual norm 1.871991777010e-05
  5978 KSP Residual norm 2.008547451322e-05
  5979 KSP Residual norm 1.928719405081e-05
  5980 KSP Residual norm 1.930994816398e-05
  5981 KSP Residual norm 2.222333165052e-05
  5982 KSP Residual norm 2.228829521698e-05
  5983 KSP Residual norm 2.079645222948e-05
  5984 KSP Residual norm 2.230243651587e-05
  5985 KSP Residual norm 2.363034117943e-05
  5986 KSP Residual norm 2.049160611610e-05
  5987 KSP Residual norm 1.783598976960e-05
  5988 KSP Residual norm 1.592192891959e-05
  5989 KSP Residual norm 1.326994488128e-05
  5990 KSP Residual norm 1.222755168757e-05
  5991 KSP Residual norm 1.305422019295e-05
  5992 KSP Residual norm 1.366287447021e-05
  5993 KSP Residual norm 1.245502360146e-05
  5994 KSP Residual norm 1.090667301314e-05
  5995 KSP Residual norm 1.095573106839e-05
  5996 KSP Residual norm 1.177140261272e-05
  5997 KSP Residual norm 1.144633078168e-05
  5998 KSP Residual norm 1.171583467884e-05
  5999 KSP Residual norm 1.300992972096e-05
  6000 KSP Residual norm 1.253643003247e-05
  6001 KSP Residual norm 1.261982583416e-05
  6002 KSP Residual norm 1.412796192941e-05
  6003 KSP Residual norm 1.378380777273e-05
  6004 KSP Residual norm 1.323936035625e-05
  6005 KSP Residual norm 1.437925049690e-05
  6006 KSP Residual norm 1.475915154193e-05
  6007 KSP Residual norm 1.486719633729e-05
  6008 KSP Residual norm 1.712898564869e-05
  6009 KSP Residual norm 1.794388651580e-05
  6010 KSP Residual norm 1.677613578545e-05
  6011 KSP Residual norm 1.783774693846e-05
  6012 KSP Residual norm 1.937552212011e-05
  6013 KSP Residual norm 1.630636664770e-05
  6014 KSP Residual norm 1.203072450443e-05
  6015 KSP Residual norm 1.051315266850e-05
  6016 KSP Residual norm 1.045391597948e-05
  6017 KSP Residual norm 9.505878927534e-06
  6018 KSP Residual norm 7.515713925981e-06
  6019 KSP Residual norm 6.849528398227e-06
  6020 KSP Residual norm 7.626882125460e-06
  6021 KSP Residual norm 8.965246928439e-06
  6022 KSP Residual norm 1.164015696430e-05
  6023 KSP Residual norm 1.568276073948e-05
  6024 KSP Residual norm 1.884977586545e-05
  6025 KSP Residual norm 2.125370004144e-05
  6026 KSP Residual norm 2.302208259023e-05
  6027 KSP Residual norm 2.461262298888e-05
  6028 KSP Residual norm 2.509430151314e-05
  6029 KSP Residual norm 2.404273355965e-05
  6030 KSP Residual norm 2.260517065963e-05
  6031 KSP Residual norm 2.215218737557e-05
  6032 KSP Residual norm 2.165586929092e-05
  6033 KSP Residual norm 1.904201997243e-05
  6034 KSP Residual norm 1.652157059593e-05
  6035 KSP Residual norm 1.545083552534e-05
  6036 KSP Residual norm 1.369536292644e-05
  6037 KSP Residual norm 1.177487033952e-05
  6038 KSP Residual norm 1.079295078337e-05
  6039 KSP Residual norm 1.001728310439e-05
  6040 KSP Residual norm 8.964515934753e-06
  6041 KSP Residual norm 8.264283603573e-06
  6042 KSP Residual norm 7.425923123589e-06
  6043 KSP Residual norm 6.170590287514e-06
  6044 KSP Residual norm 4.752078726923e-06
  6045 KSP Residual norm 3.658161277277e-06
  6046 KSP Residual norm 2.995395032187e-06
  6047 KSP Residual norm 2.715150704054e-06
  6048 KSP Residual norm 2.455276765537e-06
  6049 KSP Residual norm 2.347399557100e-06
  6050 KSP Residual norm 2.395500396908e-06
  6051 KSP Residual norm 2.663705358342e-06
  6052 KSP Residual norm 3.154059126358e-06
  6053 KSP Residual norm 3.158921080396e-06
  6054 KSP Residual norm 2.919528523571e-06
  6055 KSP Residual norm 3.350158617061e-06
  6056 KSP Residual norm 4.103848896061e-06
  6057 KSP Residual norm 3.851426153256e-06
  6058 KSP Residual norm 3.708543631737e-06
  6059 KSP Residual norm 4.068145614636e-06
  6060 KSP Residual norm 3.864003590417e-06
  6061 KSP Residual norm 3.601806826327e-06
  6062 KSP Residual norm 3.811777894430e-06
  6063 KSP Residual norm 3.639678919318e-06
  6064 KSP Residual norm 3.368028834060e-06
  6065 KSP Residual norm 3.732046219438e-06
  6066 KSP Residual norm 4.181593072820e-06
  6067 KSP Residual norm 3.882236217403e-06
  6068 KSP Residual norm 3.650219437644e-06
  6069 KSP Residual norm 3.589890152124e-06
  6070 KSP Residual norm 3.101744457122e-06
  6071 KSP Residual norm 2.315808469526e-06
  6072 KSP Residual norm 1.914332958941e-06
  6073 KSP Residual norm 1.922949524325e-06
  6074 KSP Residual norm 2.106086532816e-06
  6075 KSP Residual norm 1.975474421294e-06
  6076 KSP Residual norm 2.050001409721e-06
  6077 KSP Residual norm 2.615742099219e-06
  6078 KSP Residual norm 2.942360269072e-06
  6079 KSP Residual norm 2.626954717820e-06
  6080 KSP Residual norm 2.371753616575e-06
  6081 KSP Residual norm 2.260098410000e-06
  6082 KSP Residual norm 2.027621339770e-06
  6083 KSP Residual norm 1.979468525753e-06
  6084 KSP Residual norm 2.118945737429e-06
  6085 KSP Residual norm 2.077856634973e-06
  6086 KSP Residual norm 2.138160935999e-06
  6087 KSP Residual norm 2.540534594474e-06
  6088 KSP Residual norm 2.888537741658e-06
  6089 KSP Residual norm 3.050163512717e-06
  6090 KSP Residual norm 3.371443056816e-06
  6091 KSP Residual norm 3.915989100625e-06
  6092 KSP Residual norm 4.619553001790e-06
  6093 KSP Residual norm 5.272783885974e-06
  6094 KSP Residual norm 5.494039996044e-06
  6095 KSP Residual norm 5.924549292204e-06
  6096 KSP Residual norm 6.477369554878e-06
  6097 KSP Residual norm 6.841278802813e-06
  6098 KSP Residual norm 7.204216680474e-06
  6099 KSP Residual norm 7.232036392861e-06
  6100 KSP Residual norm 7.367111989628e-06
  6101 KSP Residual norm 8.528618192501e-06
  6102 KSP Residual norm 9.945914945270e-06
  6103 KSP Residual norm 1.034840402594e-05
  6104 KSP Residual norm 1.046037751746e-05
  6105 KSP Residual norm 1.021006880083e-05
  6106 KSP Residual norm 9.442280639837e-06
  6107 KSP Residual norm 8.869804848302e-06
  6108 KSP Residual norm 8.640017918616e-06
  6109 KSP Residual norm 9.116766017146e-06
  6110 KSP Residual norm 1.033439101560e-05
  6111 KSP Residual norm 9.661346546923e-06
  6112 KSP Residual norm 8.587923832160e-06
  6113 KSP Residual norm 9.095712347458e-06
  6114 KSP Residual norm 9.439618281688e-06
  6115 KSP Residual norm 8.843385064887e-06
  6116 KSP Residual norm 8.663583213299e-06
  6117 KSP Residual norm 8.578675663830e-06
  6118 KSP Residual norm 6.973282589225e-06
  6119 KSP Residual norm 5.056604287602e-06
  6120 KSP Residual norm 3.668504552844e-06
  6121 KSP Residual norm 2.821322326973e-06
  6122 KSP Residual norm 2.221793292753e-06
  6123 KSP Residual norm 1.982221390195e-06
  6124 KSP Residual norm 2.107063762549e-06
  6125 KSP Residual norm 2.392903560272e-06
  6126 KSP Residual norm 2.501184931995e-06
  6127 KSP Residual norm 2.332697236585e-06
  6128 KSP Residual norm 2.291633503538e-06
  6129 KSP Residual norm 2.636867691983e-06
  6130 KSP Residual norm 3.307155054538e-06
  6131 KSP Residual norm 3.718460419808e-06
  6132 KSP Residual norm 3.181955374404e-06
  6133 KSP Residual norm 2.672708003693e-06
  6134 KSP Residual norm 2.800497011271e-06
  6135 KSP Residual norm 2.864107488967e-06
  6136 KSP Residual norm 2.471159903414e-06
  6137 KSP Residual norm 2.265433521555e-06
  6138 KSP Residual norm 2.370594792280e-06
  6139 KSP Residual norm 2.660529802365e-06
  6140 KSP Residual norm 2.550011779831e-06
  6141 KSP Residual norm 2.270909182094e-06
  6142 KSP Residual norm 2.228171658170e-06
  6143 KSP Residual norm 2.072665241661e-06
  6144 KSP Residual norm 1.772675370133e-06
  6145 KSP Residual norm 1.634616865668e-06
  6146 KSP Residual norm 1.746068856671e-06
  6147 KSP Residual norm 1.886534439370e-06
  6148 KSP Residual norm 1.954516026958e-06
  6149 KSP Residual norm 2.008664962379e-06
  6150 KSP Residual norm 1.892225476083e-06
  6151 KSP Residual norm 1.779181971350e-06
  6152 KSP Residual norm 1.549649111191e-06
  6153 KSP Residual norm 1.309189440465e-06
  6154 KSP Residual norm 1.254473787788e-06
  6155 KSP Residual norm 1.300000186278e-06
  6156 KSP Residual norm 1.163877793019e-06
  6157 KSP Residual norm 1.025048556343e-06
  6158 KSP Residual norm 9.725747720047e-07
  6159 KSP Residual norm 8.882646534310e-07
  6160 KSP Residual norm 7.899786617629e-07
  6161 KSP Residual norm 7.098962117114e-07
  6162 KSP Residual norm 6.571438804392e-07
  6163 KSP Residual norm 6.233705437693e-07
  6164 KSP Residual norm 5.793518027939e-07
  6165 KSP Residual norm 5.017620383284e-07
  6166 KSP Residual norm 4.717545202792e-07
  6167 KSP Residual norm 5.409588054727e-07
  6168 KSP Residual norm 6.689457279101e-07
  6169 KSP Residual norm 7.068553231551e-07
  6170 KSP Residual norm 7.306878061877e-07
  6171 KSP Residual norm 8.044900764292e-07
  6172 KSP Residual norm 7.882541231289e-07
  6173 KSP Residual norm 6.381753603503e-07
  6174 KSP Residual norm 5.762064426122e-07
  6175 KSP Residual norm 6.081472533300e-07
  6176 KSP Residual norm 6.494564662187e-07
  6177 KSP Residual norm 6.376539971492e-07
  6178 KSP Residual norm 6.322647079046e-07
  6179 KSP Residual norm 6.013395049067e-07
  6180 KSP Residual norm 5.508862201265e-07
  6181 KSP Residual norm 5.525669649454e-07
  6182 KSP Residual norm 6.022831749401e-07
  6183 KSP Residual norm 5.808445015043e-07
  6184 KSP Residual norm 5.309139555604e-07
  6185 KSP Residual norm 5.450536141986e-07
  6186 KSP Residual norm 5.735104819019e-07
  6187 KSP Residual norm 6.218315760969e-07
  6188 KSP Residual norm 6.751463428041e-07
  6189 KSP Residual norm 6.788945578262e-07
  6190 KSP Residual norm 6.235551315947e-07
  6191 KSP Residual norm 5.597095584396e-07
  6192 KSP Residual norm 5.334634746193e-07
  6193 KSP Residual norm 5.074424507864e-07
  6194 KSP Residual norm 4.646078196431e-07
  6195 KSP Residual norm 4.321083281233e-07
  6196 KSP Residual norm 4.271703839390e-07
  6197 KSP Residual norm 4.133860169395e-07
  6198 KSP Residual norm 3.728355677075e-07
  6199 KSP Residual norm 3.533013662579e-07
  6200 KSP Residual norm 3.605775962320e-07
  6201 KSP Residual norm 3.676115948431e-07
  6202 KSP Residual norm 3.662721261886e-07
  6203 KSP Residual norm 3.496472803836e-07
  6204 KSP Residual norm 3.311737034080e-07
  6205 KSP Residual norm 3.168943432327e-07
  6206 KSP Residual norm 2.915249814439e-07
  6207 KSP Residual norm 2.891728659654e-07
  6208 KSP Residual norm 3.292998619762e-07
  6209 KSP Residual norm 3.602544304104e-07
  6210 KSP Residual norm 3.879586491687e-07
  6211 KSP Residual norm 4.876159692383e-07
  6212 KSP Residual norm 5.907366149398e-07
  6213 KSP Residual norm 5.718446140922e-07
  6214 KSP Residual norm 5.602727798831e-07
  6215 KSP Residual norm 5.730910805663e-07
  6216 KSP Residual norm 5.884160198151e-07
  6217 KSP Residual norm 6.345265110046e-07
  6218 KSP Residual norm 6.442966684300e-07
  6219 KSP Residual norm 5.773477175642e-07
  6220 KSP Residual norm 5.543998358024e-07
  6221 KSP Residual norm 5.968563716856e-07
  6222 KSP Residual norm 6.584070093030e-07
  6223 KSP Residual norm 7.903467297070e-07
  6224 KSP Residual norm 1.023098403601e-06
  6225 KSP Residual norm 1.172941978045e-06
  6226 KSP Residual norm 1.079032268490e-06
  6227 KSP Residual norm 9.413901883227e-07
  6228 KSP Residual norm 8.877698900315e-07
  6229 KSP Residual norm 8.839468704128e-07
  6230 KSP Residual norm 7.522229317914e-07
  6231 KSP Residual norm 6.472378292787e-07
  6232 KSP Residual norm 6.564460517430e-07
  6233 KSP Residual norm 6.505807418437e-07
  6234 KSP Residual norm 5.835276775672e-07
  6235 KSP Residual norm 5.701262909769e-07
  6236 KSP Residual norm 6.249695750825e-07
  6237 KSP Residual norm 6.239842615417e-07
  6238 KSP Residual norm 5.925788599882e-07
  6239 KSP Residual norm 5.866535984806e-07
  6240 KSP Residual norm 5.996540220879e-07
  6241 KSP Residual norm 6.549927664876e-07
  6242 KSP Residual norm 7.358669830895e-07
  6243 KSP Residual norm 7.080454652216e-07
  6244 KSP Residual norm 6.433351751416e-07
  6245 KSP Residual norm 6.399308702687e-07
  6246 KSP Residual norm 6.825307143473e-07
  6247 KSP Residual norm 7.344511881925e-07
  6248 KSP Residual norm 7.842788008254e-07
  6249 KSP Residual norm 8.608078101576e-07
  6250 KSP Residual norm 9.019566507324e-07
  6251 KSP Residual norm 8.913735864525e-07
  6252 KSP Residual norm 9.113623736156e-07
  6253 KSP Residual norm 9.130355102928e-07
  6254 KSP Residual norm 8.278906501356e-07
  6255 KSP Residual norm 8.145103778308e-07
  6256 KSP Residual norm 9.030607636329e-07
  6257 KSP Residual norm 1.010372806425e-06
  6258 KSP Residual norm 1.008382566013e-06
  6259 KSP Residual norm 9.284688392946e-07
  6260 KSP Residual norm 8.203527631787e-07
  6261 KSP Residual norm 7.197639005482e-07
  6262 KSP Residual norm 6.311405907599e-07
  6263 KSP Residual norm 6.157436203499e-07
  6264 KSP Residual norm 6.898865782815e-07
  6265 KSP Residual norm 7.417194953489e-07
  6266 KSP Residual norm 6.054022573058e-07
  6267 KSP Residual norm 4.668785423647e-07
  6268 KSP Residual norm 4.508410385323e-07
  6269 KSP Residual norm 5.143883805824e-07
  6270 KSP Residual norm 5.648076373633e-07
  6271 KSP Residual norm 5.409148297683e-07
  6272 KSP Residual norm 5.165351259597e-07
  6273 KSP Residual norm 5.026269462844e-07
  6274 KSP Residual norm 4.375611368963e-07
  6275 KSP Residual norm 4.146849745407e-07
  6276 KSP Residual norm 4.586406046337e-07
  6277 KSP Residual norm 4.817441492424e-07
  6278 KSP Residual norm 4.703949486561e-07
  6279 KSP Residual norm 4.667749440561e-07
  6280 KSP Residual norm 4.222196971916e-07
  6281 KSP Residual norm 3.746239950849e-07
  6282 KSP Residual norm 3.713933920870e-07
  6283 KSP Residual norm 3.451443225881e-07
  6284 KSP Residual norm 3.119330212513e-07
  6285 KSP Residual norm 3.488614292656e-07
  6286 KSP Residual norm 3.950470493621e-07
  6287 KSP Residual norm 3.713638264573e-07
  6288 KSP Residual norm 3.517574039356e-07
  6289 KSP Residual norm 3.733144081422e-07
  6290 KSP Residual norm 3.807975879218e-07
  6291 KSP Residual norm 4.023448976417e-07
  6292 KSP Residual norm 4.662616703048e-07
  6293 KSP Residual norm 5.209718259475e-07
  6294 KSP Residual norm 5.471513171313e-07
  6295 KSP Residual norm 5.271663865540e-07
  6296 KSP Residual norm 4.721587317034e-07
  6297 KSP Residual norm 4.497928064897e-07
  6298 KSP Residual norm 4.483047746957e-07
  6299 KSP Residual norm 4.673073053402e-07
  6300 KSP Residual norm 5.446891881007e-07
  6301 KSP Residual norm 6.418818852161e-07
  6302 KSP Residual norm 6.429118196541e-07
  6303 KSP Residual norm 5.738634053431e-07
  6304 KSP Residual norm 5.274462265722e-07
  6305 KSP Residual norm 5.477501014999e-07
  6306 KSP Residual norm 6.009321493012e-07
  6307 KSP Residual norm 5.602291527368e-07
  6308 KSP Residual norm 5.097902502607e-07
  6309 KSP Residual norm 5.227295482773e-07
  6310 KSP Residual norm 5.231921770761e-07
  6311 KSP Residual norm 5.193533448924e-07
  6312 KSP Residual norm 5.303133887726e-07
  6313 KSP Residual norm 5.538205668096e-07
  6314 KSP Residual norm 5.980964288526e-07
  6315 KSP Residual norm 5.910984694443e-07
  6316 KSP Residual norm 5.065642923694e-07
  6317 KSP Residual norm 4.577736390202e-07
  6318 KSP Residual norm 4.582705686672e-07
  6319 KSP Residual norm 4.350673266952e-07
  6320 KSP Residual norm 3.526619107630e-07
  6321 KSP Residual norm 2.931298862947e-07
  6322 KSP Residual norm 2.729729671243e-07
  6323 KSP Residual norm 2.504681920557e-07
  6324 KSP Residual norm 2.426653358934e-07
  6325 KSP Residual norm 2.640835584745e-07
  6326 KSP Residual norm 3.019080161690e-07
  6327 KSP Residual norm 3.061128156656e-07
  6328 KSP Residual norm 3.091441485783e-07
  6329 KSP Residual norm 3.352028294424e-07
  6330 KSP Residual norm 3.358706220189e-07
  6331 KSP Residual norm 3.485393523240e-07
  6332 KSP Residual norm 3.727648800641e-07
  6333 KSP Residual norm 3.759082683508e-07
  6334 KSP Residual norm 3.818279626156e-07
  6335 KSP Residual norm 4.218993941558e-07
  6336 KSP Residual norm 4.344682534579e-07
  6337 KSP Residual norm 3.656257248123e-07
  6338 KSP Residual norm 3.385624452825e-07
  6339 KSP Residual norm 3.877039070152e-07
  6340 KSP Residual norm 4.935951751207e-07
  6341 KSP Residual norm 6.569144767093e-07
  6342 KSP Residual norm 7.660848531008e-07
  6343 KSP Residual norm 7.934984653229e-07
  6344 KSP Residual norm 7.675424668406e-07
  6345 KSP Residual norm 8.377962840044e-07
  6346 KSP Residual norm 9.545422865608e-07
  6347 KSP Residual norm 1.057496088882e-06
  6348 KSP Residual norm 9.883710828163e-07
  6349 KSP Residual norm 9.107235950616e-07
  6350 KSP Residual norm 9.268906938325e-07
  6351 KSP Residual norm 1.051090392880e-06
  6352 KSP Residual norm 1.145183384474e-06
  6353 KSP Residual norm 1.058134302179e-06
  6354 KSP Residual norm 9.014728553726e-07
  6355 KSP Residual norm 8.724238298098e-07
  6356 KSP Residual norm 8.785293802982e-07
  6357 KSP Residual norm 8.761702757471e-07
  6358 KSP Residual norm 1.038441501526e-06
  6359 KSP Residual norm 1.274765200598e-06
  6360 KSP Residual norm 1.265325712153e-06
  6361 KSP Residual norm 1.128333599573e-06
  6362 KSP Residual norm 1.009829087768e-06
  6363 KSP Residual norm 9.459916949749e-07
  6364 KSP Residual norm 9.570452792994e-07
  6365 KSP Residual norm 1.016066291095e-06
  6366 KSP Residual norm 1.017760336923e-06
  6367 KSP Residual norm 9.808817971808e-07
  6368 KSP Residual norm 9.318995809997e-07
  6369 KSP Residual norm 8.742829944314e-07
  6370 KSP Residual norm 7.739606841477e-07
  6371 KSP Residual norm 6.954261149272e-07
  6372 KSP Residual norm 7.252391747903e-07
  6373 KSP Residual norm 7.356799731202e-07
  6374 KSP Residual norm 7.122346949730e-07
  6375 KSP Residual norm 8.700041933654e-07
  6376 KSP Residual norm 1.309737473034e-06
  6377 KSP Residual norm 1.662607349196e-06
  6378 KSP Residual norm 1.660696405667e-06
  6379 KSP Residual norm 1.572580005056e-06
  6380 KSP Residual norm 1.437223844487e-06
  6381 KSP Residual norm 1.235833472296e-06
  6382 KSP Residual norm 1.253437425101e-06
  6383 KSP Residual norm 1.360610622598e-06
  6384 KSP Residual norm 1.201697931476e-06
  6385 KSP Residual norm 9.286365966349e-07
  6386 KSP Residual norm 8.050433100219e-07
  6387 KSP Residual norm 8.165869035553e-07
  6388 KSP Residual norm 8.794784161120e-07
  6389 KSP Residual norm 8.958610985378e-07
  6390 KSP Residual norm 8.927986017434e-07
  6391 KSP Residual norm 8.601085910450e-07
  6392 KSP Residual norm 8.209399908810e-07
  6393 KSP Residual norm 7.650475479517e-07
  6394 KSP Residual norm 6.755650749524e-07
  6395 KSP Residual norm 6.309199963230e-07
  6396 KSP Residual norm 6.119978403458e-07
  6397 KSP Residual norm 5.463252455487e-07
  6398 KSP Residual norm 4.664170726255e-07
  6399 KSP Residual norm 4.133908923676e-07
  6400 KSP Residual norm 4.035225900687e-07
  6401 KSP Residual norm 4.150741015445e-07
  6402 KSP Residual norm 4.236628903813e-07
  6403 KSP Residual norm 4.641201780473e-07
  6404 KSP Residual norm 4.850726263279e-07
  6405 KSP Residual norm 4.317305700374e-07
  6406 KSP Residual norm 3.941400281745e-07
  6407 KSP Residual norm 3.639894440264e-07
  6408 KSP Residual norm 3.550010380782e-07
  6409 KSP Residual norm 3.782837092357e-07
  6410 KSP Residual norm 3.899330605412e-07
  6411 KSP Residual norm 3.588732395886e-07
  6412 KSP Residual norm 3.278552930119e-07
  6413 KSP Residual norm 2.950659243915e-07
  6414 KSP Residual norm 2.665135783277e-07
  6415 KSP Residual norm 2.612875782367e-07
  6416 KSP Residual norm 2.719226911927e-07
  6417 KSP Residual norm 2.738727738220e-07
  6418 KSP Residual norm 2.938431035966e-07
  6419 KSP Residual norm 3.430435262522e-07
  6420 KSP Residual norm 3.965901655360e-07
  6421 KSP Residual norm 4.427360817797e-07
  6422 KSP Residual norm 4.335946254100e-07
  6423 KSP Residual norm 4.089456189178e-07
  6424 KSP Residual norm 3.878119410296e-07
  6425 KSP Residual norm 3.461972258353e-07
  6426 KSP Residual norm 3.243312221466e-07
  6427 KSP Residual norm 3.491674965006e-07
  6428 KSP Residual norm 3.776879508520e-07
  6429 KSP Residual norm 4.524322451519e-07
  6430 KSP Residual norm 5.483594836085e-07
  6431 KSP Residual norm 5.733378424481e-07
  6432 KSP Residual norm 5.327321240402e-07
  6433 KSP Residual norm 4.782191508858e-07
  6434 KSP Residual norm 4.107190346814e-07
  6435 KSP Residual norm 3.845455050237e-07
  6436 KSP Residual norm 4.077341644874e-07
  6437 KSP Residual norm 4.402708696954e-07
  6438 KSP Residual norm 4.269029442970e-07
  6439 KSP Residual norm 4.163612319024e-07
  6440 KSP Residual norm 4.635362670375e-07
  6441 KSP Residual norm 5.408700879165e-07
  6442 KSP Residual norm 5.661962438069e-07
  6443 KSP Residual norm 5.480154694337e-07
  6444 KSP Residual norm 5.431861895114e-07
  6445 KSP Residual norm 5.023287783328e-07
  6446 KSP Residual norm 4.308621096541e-07
  6447 KSP Residual norm 3.652212931539e-07
  6448 KSP Residual norm 3.455206081438e-07
  6449 KSP Residual norm 3.899431001830e-07
  6450 KSP Residual norm 4.353716613212e-07
  6451 KSP Residual norm 4.429191743152e-07
  6452 KSP Residual norm 4.669285566468e-07
  6453 KSP Residual norm 5.032267202951e-07
  6454 KSP Residual norm 5.401002508381e-07
  6455 KSP Residual norm 5.923452132371e-07
  6456 KSP Residual norm 6.156796942614e-07
  6457 KSP Residual norm 5.023873492445e-07
  6458 KSP Residual norm 4.098589249157e-07
  6459 KSP Residual norm 4.063047300452e-07
  6460 KSP Residual norm 4.774444002876e-07
  6461 KSP Residual norm 6.027807269102e-07
  6462 KSP Residual norm 7.081376696352e-07
  6463 KSP Residual norm 6.811177988892e-07
  6464 KSP Residual norm 6.447612999089e-07
  6465 KSP Residual norm 6.758705720612e-07
  6466 KSP Residual norm 7.702373296061e-07
  6467 KSP Residual norm 9.085967717883e-07
  6468 KSP Residual norm 1.078216178031e-06
  6469 KSP Residual norm 1.282219806708e-06
  6470 KSP Residual norm 1.453948358168e-06
  6471 KSP Residual norm 1.362399350142e-06
  6472 KSP Residual norm 1.203571202395e-06
  6473 KSP Residual norm 1.258929645483e-06
  6474 KSP Residual norm 1.487083260489e-06
  6475 KSP Residual norm 1.645774021633e-06
  6476 KSP Residual norm 1.817354409772e-06
  6477 KSP Residual norm 1.914833147807e-06
  6478 KSP Residual norm 1.814116053321e-06
  6479 KSP Residual norm 1.921619699210e-06
  6480 KSP Residual norm 2.225373682415e-06
  6481 KSP Residual norm 2.284626561128e-06
  6482 KSP Residual norm 2.303082462630e-06
  6483 KSP Residual norm 2.487318750616e-06
  6484 KSP Residual norm 2.799410186991e-06
  6485 KSP Residual norm 3.082026006130e-06
  6486 KSP Residual norm 3.490225571515e-06
  6487 KSP Residual norm 3.695684083933e-06
  6488 KSP Residual norm 3.547551056691e-06
  6489 KSP Residual norm 3.288697778579e-06
  6490 KSP Residual norm 3.253980862495e-06
  6491 KSP Residual norm 3.625463830435e-06
  6492 KSP Residual norm 4.303710132026e-06
  6493 KSP Residual norm 5.276677491431e-06
  6494 KSP Residual norm 6.119632787806e-06
  6495 KSP Residual norm 5.952085434105e-06
  6496 KSP Residual norm 5.272290046261e-06
  6497 KSP Residual norm 5.252152549508e-06
  6498 KSP Residual norm 5.568805438562e-06
  6499 KSP Residual norm 5.916828534667e-06
  6500 KSP Residual norm 5.935638543313e-06
  6501 KSP Residual norm 5.679869652339e-06
  6502 KSP Residual norm 5.362173261480e-06
  6503 KSP Residual norm 5.176646890969e-06
  6504 KSP Residual norm 5.012903150866e-06
  6505 KSP Residual norm 5.452348248820e-06
  6506 KSP Residual norm 7.043846038944e-06
  6507 KSP Residual norm 8.125638665320e-06
  6508 KSP Residual norm 7.545775595277e-06
  6509 KSP Residual norm 6.736123743073e-06
  6510 KSP Residual norm 6.007392221309e-06
  6511 KSP Residual norm 4.992766628093e-06
  6512 KSP Residual norm 3.933053182416e-06
  6513 KSP Residual norm 3.371860366765e-06
  6514 KSP Residual norm 3.636531506059e-06
  6515 KSP Residual norm 4.049261808414e-06
  6516 KSP Residual norm 4.147158951520e-06
  6517 KSP Residual norm 4.377587302811e-06
  6518 KSP Residual norm 4.626976755291e-06
  6519 KSP Residual norm 4.155196693767e-06
  6520 KSP Residual norm 3.431080684784e-06
  6521 KSP Residual norm 3.069358954856e-06
  6522 KSP Residual norm 3.114707735473e-06
  6523 KSP Residual norm 3.738380157111e-06
  6524 KSP Residual norm 5.002404920306e-06
  6525 KSP Residual norm 6.456060454222e-06
  6526 KSP Residual norm 7.069232004555e-06
  6527 KSP Residual norm 6.036502593663e-06
  6528 KSP Residual norm 4.670445885839e-06
  6529 KSP Residual norm 4.213087777487e-06
  6530 KSP Residual norm 4.698086358194e-06
  6531 KSP Residual norm 6.091005397835e-06
  6532 KSP Residual norm 8.463870423912e-06
  6533 KSP Residual norm 1.164852925514e-05
  6534 KSP Residual norm 1.503976182330e-05
  6535 KSP Residual norm 1.768418226181e-05
  6536 KSP Residual norm 1.657826336905e-05
  6537 KSP Residual norm 1.297312955031e-05
  6538 KSP Residual norm 1.096611991307e-05
  6539 KSP Residual norm 1.091745835092e-05
  6540 KSP Residual norm 1.086101082767e-05
  6541 KSP Residual norm 9.979342139445e-06
  6542 KSP Residual norm 8.805349034561e-06
  6543 KSP Residual norm 8.774213426229e-06
  6544 KSP Residual norm 9.799128533711e-06
  6545 KSP Residual norm 9.942236203370e-06
  6546 KSP Residual norm 9.247492304707e-06
  6547 KSP Residual norm 8.336162402891e-06
  6548 KSP Residual norm 6.583289844006e-06
  6549 KSP Residual norm 5.370615485679e-06
  6550 KSP Residual norm 5.426101013011e-06
  6551 KSP Residual norm 6.338012993154e-06
  6552 KSP Residual norm 7.214910601911e-06
  6553 KSP Residual norm 6.882295353635e-06
  6554 KSP Residual norm 5.786641027609e-06
  6555 KSP Residual norm 5.574949475327e-06
  6556 KSP Residual norm 5.832691625224e-06
  6557 KSP Residual norm 5.378836581653e-06
  6558 KSP Residual norm 4.655270024854e-06
  6559 KSP Residual norm 4.161180032462e-06
  6560 KSP Residual norm 3.488194818668e-06
  6561 KSP Residual norm 2.855454545643e-06
  6562 KSP Residual norm 2.556251893986e-06
  6563 KSP Residual norm 2.739938520416e-06
  6564 KSP Residual norm 3.488584541423e-06
  6565 KSP Residual norm 4.272282951704e-06
  6566 KSP Residual norm 4.133694892783e-06
  6567 KSP Residual norm 3.352153587961e-06
  6568 KSP Residual norm 2.802260125366e-06
  6569 KSP Residual norm 2.380756108678e-06
  6570 KSP Residual norm 2.119745619573e-06
  6571 KSP Residual norm 2.173099026336e-06
  6572 KSP Residual norm 2.419929520031e-06
  6573 KSP Residual norm 2.683893231275e-06
  6574 KSP Residual norm 3.026100260062e-06
  6575 KSP Residual norm 3.141986656121e-06
  6576 KSP Residual norm 3.047974011258e-06
  6577 KSP Residual norm 2.835623366711e-06
  6578 KSP Residual norm 2.330604085445e-06
  6579 KSP Residual norm 1.702488309527e-06
  6580 KSP Residual norm 1.361915293592e-06
  6581 KSP Residual norm 1.329333593207e-06
  6582 KSP Residual norm 1.551935079600e-06
  6583 KSP Residual norm 1.976250999687e-06
  6584 KSP Residual norm 2.322721161211e-06
  6585 KSP Residual norm 2.239741723428e-06
  6586 KSP Residual norm 2.054609179497e-06
  6587 KSP Residual norm 2.073128435766e-06
  6588 KSP Residual norm 2.306230221339e-06
  6589 KSP Residual norm 2.643567629850e-06
  6590 KSP Residual norm 2.968773932912e-06
  6591 KSP Residual norm 2.951126612809e-06
  6592 KSP Residual norm 2.933317034566e-06
  6593 KSP Residual norm 3.146571340576e-06
  6594 KSP Residual norm 3.740933621166e-06
  6595 KSP Residual norm 4.727032623993e-06
  6596 KSP Residual norm 5.618033614885e-06
  6597 KSP Residual norm 6.085286032396e-06
  6598 KSP Residual norm 6.137086483318e-06
  6599 KSP Residual norm 5.362419496497e-06
  6600 KSP Residual norm 4.095244956105e-06
  6601 KSP Residual norm 3.615967398964e-06
  6602 KSP Residual norm 4.380404751580e-06
  6603 KSP Residual norm 6.059230428234e-06
  6604 KSP Residual norm 7.185373333013e-06
  6605 KSP Residual norm 8.320081129831e-06
  6606 KSP Residual norm 9.808972742735e-06
  6607 KSP Residual norm 1.114409918032e-05
  6608 KSP Residual norm 1.169621248075e-05
  6609 KSP Residual norm 1.238085205447e-05
  6610 KSP Residual norm 1.334922873702e-05
  6611 KSP Residual norm 1.557009789532e-05
  6612 KSP Residual norm 1.836639221466e-05
  6613 KSP Residual norm 2.117357429923e-05
  6614 KSP Residual norm 2.290953654721e-05
  6615 KSP Residual norm 2.297552309835e-05
  6616 KSP Residual norm 1.812376416333e-05
  6617 KSP Residual norm 1.306591416800e-05
  6618 KSP Residual norm 9.144831632555e-06
  6619 KSP Residual norm 5.867136223229e-06
  6620 KSP Residual norm 4.519592289942e-06
  6621 KSP Residual norm 4.773251526751e-06
  6622 KSP Residual norm 6.357201477886e-06
  6623 KSP Residual norm 9.071141108326e-06
  6624 KSP Residual norm 1.200886015081e-05
  6625 KSP Residual norm 1.335374322040e-05
  6626 KSP Residual norm 1.166972572181e-05
  6627 KSP Residual norm 9.469259405639e-06
  6628 KSP Residual norm 7.867880026589e-06
  6629 KSP Residual norm 7.148318013719e-06
  6630 KSP Residual norm 7.941631307980e-06
  6631 KSP Residual norm 1.095399848723e-05
  6632 KSP Residual norm 1.269831536566e-05
  6633 KSP Residual norm 1.166030556887e-05
  6634 KSP Residual norm 9.946358018498e-06
  6635 KSP Residual norm 8.905881699893e-06
  6636 KSP Residual norm 9.178573800420e-06
  6637 KSP Residual norm 1.101729494667e-05
  6638 KSP Residual norm 1.223260889330e-05
  6639 KSP Residual norm 1.238270795120e-05
  6640 KSP Residual norm 1.329543699464e-05
  6641 KSP Residual norm 1.427573911345e-05
  6642 KSP Residual norm 1.388470219904e-05
  6643 KSP Residual norm 1.321066339522e-05
  6644 KSP Residual norm 1.427781320863e-05
  6645 KSP Residual norm 1.678676766855e-05
  6646 KSP Residual norm 1.828711848748e-05
  6647 KSP Residual norm 1.794034891510e-05
  6648 KSP Residual norm 1.621408633770e-05
  6649 KSP Residual norm 1.267460849314e-05
  6650 KSP Residual norm 1.008607870930e-05
  6651 KSP Residual norm 9.385919454817e-06
  6652 KSP Residual norm 8.786443985421e-06
  6653 KSP Residual norm 7.587023500817e-06
  6654 KSP Residual norm 6.614216274233e-06
  6655 KSP Residual norm 5.837286796526e-06
  6656 KSP Residual norm 5.838385689975e-06
  6657 KSP Residual norm 7.033157692158e-06
  6658 KSP Residual norm 9.078611364514e-06
  6659 KSP Residual norm 1.040220968915e-05
  6660 KSP Residual norm 1.042114849271e-05
  6661 KSP Residual norm 8.851604394952e-06
  6662 KSP Residual norm 6.177059201453e-06
  6663 KSP Residual norm 4.257618992377e-06
  6664 KSP Residual norm 3.431190627451e-06
  6665 KSP Residual norm 2.996993710013e-06
  6666 KSP Residual norm 2.624505451887e-06
  6667 KSP Residual norm 2.559319804493e-06
  6668 KSP Residual norm 2.851280763754e-06
  6669 KSP Residual norm 3.097716855338e-06
  6670 KSP Residual norm 2.994036044599e-06
  6671 KSP Residual norm 2.942570790846e-06
  6672 KSP Residual norm 2.695394857269e-06
  6673 KSP Residual norm 2.330828191411e-06
  6674 KSP Residual norm 2.240425957789e-06
  6675 KSP Residual norm 2.220792693582e-06
  6676 KSP Residual norm 2.006762493251e-06
  6677 KSP Residual norm 1.737636310397e-06
  6678 KSP Residual norm 1.529860731062e-06
  6679 KSP Residual norm 1.452431511323e-06
  6680 KSP Residual norm 1.450799857764e-06
  6681 KSP Residual norm 1.423577979714e-06
  6682 KSP Residual norm 1.313425297293e-06
  6683 KSP Residual norm 1.298414357061e-06
  6684 KSP Residual norm 1.370882022878e-06
  6685 KSP Residual norm 1.338896796665e-06
  6686 KSP Residual norm 1.304140065198e-06
  6687 KSP Residual norm 1.344936581831e-06
  6688 KSP Residual norm 1.351499383490e-06
  6689 KSP Residual norm 1.349607949115e-06
  6690 KSP Residual norm 1.490656859932e-06
  6691 KSP Residual norm 1.763991880261e-06
  6692 KSP Residual norm 2.032509610570e-06
  6693 KSP Residual norm 1.822523765048e-06
  6694 KSP Residual norm 1.513191857086e-06
  6695 KSP Residual norm 1.444246887402e-06
  6696 KSP Residual norm 1.615306191272e-06
  6697 KSP Residual norm 1.666610699592e-06
  6698 KSP Residual norm 1.476347584497e-06
  6699 KSP Residual norm 1.306213776415e-06
  6700 KSP Residual norm 1.350960136403e-06
  6701 KSP Residual norm 1.517610220609e-06
  6702 KSP Residual norm 1.678378025187e-06
  6703 KSP Residual norm 1.844134600893e-06
  6704 KSP Residual norm 1.767052217614e-06
  6705 KSP Residual norm 1.415094837577e-06
  6706 KSP Residual norm 1.152284154901e-06
  6707 KSP Residual norm 1.056819277912e-06
  6708 KSP Residual norm 1.025303322665e-06
  6709 KSP Residual norm 1.046427360246e-06
  6710 KSP Residual norm 1.067144309663e-06
  6711 KSP Residual norm 1.002011102303e-06
  6712 KSP Residual norm 8.411216349052e-07
  6713 KSP Residual norm 6.211537014588e-07
  6714 KSP Residual norm 4.857100625600e-07
  6715 KSP Residual norm 4.733123203108e-07
  6716 KSP Residual norm 5.160395362539e-07
  6717 KSP Residual norm 5.840294788590e-07
  6718 KSP Residual norm 6.350169780973e-07
  6719 KSP Residual norm 6.057821727552e-07
  6720 KSP Residual norm 5.843909348521e-07
  6721 KSP Residual norm 5.870284875070e-07
  6722 KSP Residual norm 5.891865286007e-07
  6723 KSP Residual norm 6.016887955255e-07
  6724 KSP Residual norm 5.788259613774e-07
  6725 KSP Residual norm 4.703629718590e-07
  6726 KSP Residual norm 3.841806232261e-07
  6727 KSP Residual norm 3.858233112481e-07
  6728 KSP Residual norm 4.188237664181e-07
  6729 KSP Residual norm 4.254974214811e-07
  6730 KSP Residual norm 4.217723264430e-07
  6731 KSP Residual norm 4.334853544073e-07
  6732 KSP Residual norm 4.717642251073e-07
  6733 KSP Residual norm 5.204185776885e-07
  6734 KSP Residual norm 5.395769023579e-07
  6735 KSP Residual norm 5.373538349540e-07
  6736 KSP Residual norm 5.830986518148e-07
  6737 KSP Residual norm 6.524846034779e-07
  6738 KSP Residual norm 6.994354768747e-07
  6739 KSP Residual norm 7.625331162864e-07
  6740 KSP Residual norm 7.548369733101e-07
  6741 KSP Residual norm 6.765919371895e-07
  6742 KSP Residual norm 6.935519504027e-07
  6743 KSP Residual norm 8.337381465247e-07
  6744 KSP Residual norm 8.997082440405e-07
  6745 KSP Residual norm 7.657881212629e-07
  6746 KSP Residual norm 6.307120198647e-07
  6747 KSP Residual norm 5.849740003627e-07
  6748 KSP Residual norm 6.143722261097e-07
  6749 KSP Residual norm 6.257246721979e-07
  6750 KSP Residual norm 5.918744269781e-07
  6751 KSP Residual norm 5.947744685625e-07
  6752 KSP Residual norm 6.271904032836e-07
  6753 KSP Residual norm 5.614655861926e-07
  6754 KSP Residual norm 4.556843669160e-07
  6755 KSP Residual norm 4.379113005478e-07
  6756 KSP Residual norm 4.617346846598e-07
  6757 KSP Residual norm 4.584315583348e-07
  6758 KSP Residual norm 4.800651068004e-07
  6759 KSP Residual norm 5.622972047444e-07
  6760 KSP Residual norm 5.975454953659e-07
  6761 KSP Residual norm 6.153982352088e-07
  6762 KSP Residual norm 6.423895209871e-07
  6763 KSP Residual norm 6.097660070361e-07
  6764 KSP Residual norm 5.544947489951e-07
  6765 KSP Residual norm 5.340462578322e-07
  6766 KSP Residual norm 4.970999368944e-07
  6767 KSP Residual norm 4.404433530368e-07
  6768 KSP Residual norm 3.790987030243e-07
  6769 KSP Residual norm 3.269040326141e-07
  6770 KSP Residual norm 2.998573747686e-07
  6771 KSP Residual norm 2.840787499022e-07
  6772 KSP Residual norm 2.813250784708e-07
  6773 KSP Residual norm 2.842116059637e-07
  6774 KSP Residual norm 3.017198015302e-07
  6775 KSP Residual norm 3.145541463400e-07
  6776 KSP Residual norm 3.101136746635e-07
  6777 KSP Residual norm 3.393676687243e-07
  6778 KSP Residual norm 3.926551973832e-07
  6779 KSP Residual norm 3.921321961914e-07
  6780 KSP Residual norm 3.393442988392e-07
  6781 KSP Residual norm 3.151231337632e-07
  6782 KSP Residual norm 3.353308459016e-07
  6783 KSP Residual norm 3.325077905975e-07
  6784 KSP Residual norm 2.857379639833e-07
  6785 KSP Residual norm 2.492540038559e-07
  6786 KSP Residual norm 2.437626967129e-07
  6787 KSP Residual norm 2.416988058239e-07
  6788 KSP Residual norm 2.404581908445e-07
  6789 KSP Residual norm 2.439876678438e-07
  6790 KSP Residual norm 2.612133728482e-07
  6791 KSP Residual norm 2.968943601329e-07
  6792 KSP Residual norm 3.214257405215e-07
  6793 KSP Residual norm 3.369217143396e-07
  6794 KSP Residual norm 3.487393417235e-07
  6795 KSP Residual norm 3.884276033478e-07
  6796 KSP Residual norm 4.437204658280e-07
  6797 KSP Residual norm 4.564014703318e-07
  6798 KSP Residual norm 4.381130941475e-07
  6799 KSP Residual norm 4.293632526846e-07
  6800 KSP Residual norm 4.127003357639e-07
  6801 KSP Residual norm 4.543922499320e-07
  6802 KSP Residual norm 5.534901820968e-07
  6803 KSP Residual norm 5.617498079988e-07
  6804 KSP Residual norm 5.316756259514e-07
  6805 KSP Residual norm 5.586285486300e-07
  6806 KSP Residual norm 5.878574341116e-07
  6807 KSP Residual norm 6.176195699203e-07
  6808 KSP Residual norm 6.699973713749e-07
  6809 KSP Residual norm 6.834683406623e-07
  6810 KSP Residual norm 7.047100913327e-07
  6811 KSP Residual norm 7.683923729736e-07
  6812 KSP Residual norm 8.216543617353e-07
  6813 KSP Residual norm 8.929326230207e-07
  6814 KSP Residual norm 9.421865141884e-07
  6815 KSP Residual norm 8.100916229406e-07
  6816 KSP Residual norm 6.936381674114e-07
  6817 KSP Residual norm 7.108463279164e-07
  6818 KSP Residual norm 7.650673696821e-07
  6819 KSP Residual norm 7.944938532719e-07
  6820 KSP Residual norm 8.567023897731e-07
  6821 KSP Residual norm 9.177910969013e-07
  6822 KSP Residual norm 9.640965117381e-07
  6823 KSP Residual norm 1.043724766784e-06
  6824 KSP Residual norm 1.123336709193e-06
  6825 KSP Residual norm 1.070717679282e-06
  6826 KSP Residual norm 9.220585049278e-07
  6827 KSP Residual norm 8.055958295105e-07
  6828 KSP Residual norm 7.441105527280e-07
  6829 KSP Residual norm 7.581001051878e-07
  6830 KSP Residual norm 7.271303600875e-07
  6831 KSP Residual norm 6.514314794771e-07
  6832 KSP Residual norm 6.361709198155e-07
  6833 KSP Residual norm 6.603690065721e-07
  6834 KSP Residual norm 6.568973683527e-07
  6835 KSP Residual norm 6.389990764880e-07
  6836 KSP Residual norm 6.140769420995e-07
  6837 KSP Residual norm 6.126496775830e-07
  6838 KSP Residual norm 6.542619744968e-07
  6839 KSP Residual norm 6.915217125869e-07
  6840 KSP Residual norm 6.908895775180e-07
  6841 KSP Residual norm 6.834781418859e-07
  6842 KSP Residual norm 6.491098534682e-07
  6843 KSP Residual norm 6.104729611287e-07
  6844 KSP Residual norm 5.475421772278e-07
  6845 KSP Residual norm 5.094513820383e-07
  6846 KSP Residual norm 5.188992294829e-07
  6847 KSP Residual norm 5.130653354818e-07
  6848 KSP Residual norm 4.743805601088e-07
  6849 KSP Residual norm 4.072649861230e-07
  6850 KSP Residual norm 3.587735096846e-07
  6851 KSP Residual norm 3.874964143557e-07
  6852 KSP Residual norm 4.434871659896e-07
  6853 KSP Residual norm 4.391144552194e-07
  6854 KSP Residual norm 4.564405613687e-07
  6855 KSP Residual norm 5.248520066387e-07
  6856 KSP Residual norm 5.510349167838e-07
  6857 KSP Residual norm 5.649309460664e-07
  6858 KSP Residual norm 5.549868654521e-07
  6859 KSP Residual norm 4.939096866625e-07
  6860 KSP Residual norm 4.451697998912e-07
  6861 KSP Residual norm 4.197381238377e-07
  6862 KSP Residual norm 3.852029804015e-07
  6863 KSP Residual norm 3.735665303614e-07
  6864 KSP Residual norm 3.731898235927e-07
  6865 KSP Residual norm 3.681618677067e-07
  6866 KSP Residual norm 4.049666316262e-07
  6867 KSP Residual norm 4.908565354795e-07
  6868 KSP Residual norm 5.557903872167e-07
  6869 KSP Residual norm 6.149272972553e-07
  6870 KSP Residual norm 6.705359883947e-07
  6871 KSP Residual norm 6.886944879713e-07
  6872 KSP Residual norm 7.272732788909e-07
  6873 KSP Residual norm 8.354109733404e-07
  6874 KSP Residual norm 8.461638919534e-07
  6875 KSP Residual norm 6.957789206705e-07
  6876 KSP Residual norm 5.810462785831e-07
  6877 KSP Residual norm 6.121022939447e-07
  6878 KSP Residual norm 7.041961735215e-07
  6879 KSP Residual norm 7.119938234273e-07
  6880 KSP Residual norm 6.336869649012e-07
  6881 KSP Residual norm 5.823027255643e-07
  6882 KSP Residual norm 6.332105346374e-07
  6883 KSP Residual norm 7.719184493072e-07
  6884 KSP Residual norm 8.414924355228e-07
  6885 KSP Residual norm 7.937693586857e-07
  6886 KSP Residual norm 7.875945041115e-07
  6887 KSP Residual norm 7.782124993486e-07
  6888 KSP Residual norm 7.410734072886e-07
  6889 KSP Residual norm 7.343551180159e-07
  6890 KSP Residual norm 7.517788791179e-07
  6891 KSP Residual norm 7.107448425107e-07
  6892 KSP Residual norm 6.957818871198e-07
  6893 KSP Residual norm 6.609499104601e-07
  6894 KSP Residual norm 5.553024160866e-07
  6895 KSP Residual norm 4.841493854281e-07
  6896 KSP Residual norm 4.325711564758e-07
  6897 KSP Residual norm 3.688393042728e-07
  6898 KSP Residual norm 3.498375879648e-07
  6899 KSP Residual norm 3.526090815221e-07
  6900 KSP Residual norm 3.532697575106e-07
  6901 KSP Residual norm 3.405838717125e-07
  6902 KSP Residual norm 3.192031702110e-07
  6903 KSP Residual norm 2.999780640028e-07
  6904 KSP Residual norm 2.944494582545e-07
  6905 KSP Residual norm 3.109547155351e-07
  6906 KSP Residual norm 3.366456604374e-07
  6907 KSP Residual norm 3.098451728381e-07
  6908 KSP Residual norm 2.628040158125e-07
  6909 KSP Residual norm 2.404863184852e-07
  6910 KSP Residual norm 2.364380930648e-07
  6911 KSP Residual norm 2.326294013716e-07
  6912 KSP Residual norm 2.133750602761e-07
  6913 KSP Residual norm 1.785633719382e-07
  6914 KSP Residual norm 1.482640930471e-07
  6915 KSP Residual norm 1.457136832825e-07
  6916 KSP Residual norm 1.681446557917e-07
  6917 KSP Residual norm 1.895358117061e-07
  6918 KSP Residual norm 2.006024087906e-07
  6919 KSP Residual norm 2.050102425565e-07
  6920 KSP Residual norm 2.115917827221e-07
  6921 KSP Residual norm 2.341586686122e-07
  6922 KSP Residual norm 2.409380553240e-07
  6923 KSP Residual norm 2.090387148976e-07
  6924 KSP Residual norm 1.772535191023e-07
  6925 KSP Residual norm 1.635940472128e-07
  6926 KSP Residual norm 1.655646104047e-07
  6927 KSP Residual norm 1.710165196599e-07
  6928 KSP Residual norm 1.630051272625e-07
  6929 KSP Residual norm 1.514134054727e-07
  6930 KSP Residual norm 1.529866023573e-07
  6931 KSP Residual norm 1.621848351987e-07
  6932 KSP Residual norm 1.691277102554e-07
  6933 KSP Residual norm 1.680750599890e-07
  6934 KSP Residual norm 1.539977682821e-07
  6935 KSP Residual norm 1.302018127960e-07
  6936 KSP Residual norm 1.186187860436e-07
  6937 KSP Residual norm 1.237702681296e-07
  6938 KSP Residual norm 1.310276463659e-07
  6939 KSP Residual norm 1.358176541626e-07
  6940 KSP Residual norm 1.336132428635e-07
  6941 KSP Residual norm 1.353917508986e-07
  6942 KSP Residual norm 1.535669882092e-07
  6943 KSP Residual norm 1.869566718011e-07
  6944 KSP Residual norm 2.249215471818e-07
  6945 KSP Residual norm 2.371629750425e-07
  6946 KSP Residual norm 1.977586649980e-07
  6947 KSP Residual norm 1.833756991929e-07
  6948 KSP Residual norm 1.897651250677e-07
  6949 KSP Residual norm 1.695290443290e-07
  6950 KSP Residual norm 1.434150731050e-07
  6951 KSP Residual norm 1.170137016176e-07
  6952 KSP Residual norm 1.056055261459e-07
  6953 KSP Residual norm 1.098939330189e-07
  6954 KSP Residual norm 1.222557672223e-07
  6955 KSP Residual norm 1.179428559954e-07
  6956 KSP Residual norm 1.106748163215e-07
  6957 KSP Residual norm 1.203938177972e-07
  6958 KSP Residual norm 1.415083573787e-07
  6959 KSP Residual norm 1.467789134375e-07
  6960 KSP Residual norm 1.373482166777e-07
  6961 KSP Residual norm 1.332046092187e-07
  6962 KSP Residual norm 1.381139286760e-07
  6963 KSP Residual norm 1.482506753385e-07
  6964 KSP Residual norm 1.495587722966e-07
  6965 KSP Residual norm 1.316435492624e-07
  6966 KSP Residual norm 1.153549487872e-07
  6967 KSP Residual norm 1.142292361911e-07
  6968 KSP Residual norm 1.059936849884e-07
  6969 KSP Residual norm 9.083452888867e-08
  6970 KSP Residual norm 8.712012582098e-08
  6971 KSP Residual norm 8.407955470623e-08
  6972 KSP Residual norm 7.483065652687e-08
  6973 KSP Residual norm 6.636351380974e-08
  6974 KSP Residual norm 6.127718978055e-08
  6975 KSP Residual norm 6.088849759165e-08
  6976 KSP Residual norm 6.199385851259e-08
  6977 KSP Residual norm 5.992467208927e-08
  6978 KSP Residual norm 5.903363936366e-08
  6979 KSP Residual norm 6.401091334516e-08
  6980 KSP Residual norm 7.196735651336e-08
  6981 KSP Residual norm 7.094880968693e-08
  6982 KSP Residual norm 6.861296953829e-08
  6983 KSP Residual norm 7.088158982262e-08
  6984 KSP Residual norm 7.333594275249e-08
  6985 KSP Residual norm 7.553570869445e-08
  6986 KSP Residual norm 7.796998874383e-08
  6987 KSP Residual norm 7.015620199567e-08
  6988 KSP Residual norm 6.096226154075e-08
  6989 KSP Residual norm 6.176490155873e-08
  6990 KSP Residual norm 6.945638074107e-08
  6991 KSP Residual norm 7.574781261518e-08
  6992 KSP Residual norm 7.796047921170e-08
  6993 KSP Residual norm 7.808110787694e-08
  6994 KSP Residual norm 7.579717716480e-08
  6995 KSP Residual norm 7.676411540061e-08
  6996 KSP Residual norm 8.262114515763e-08
  6997 KSP Residual norm 9.177388956783e-08
  6998 KSP Residual norm 9.617462608009e-08
  6999 KSP Residual norm 8.941163153964e-08
  7000 KSP Residual norm 8.401524890944e-08
  7001 KSP Residual norm 8.513721631951e-08
  7002 KSP Residual norm 9.017096394170e-08
  7003 KSP Residual norm 9.857766880038e-08
  7004 KSP Residual norm 1.022548301836e-07
  7005 KSP Residual norm 1.029011656001e-07
  7006 KSP Residual norm 1.036875576543e-07
  7007 KSP Residual norm 1.068555232348e-07
  7008 KSP Residual norm 1.099052560653e-07
  7009 KSP Residual norm 1.123527370015e-07
  7010 KSP Residual norm 1.048210830232e-07
  7011 KSP Residual norm 9.141919649454e-08
  7012 KSP Residual norm 8.628018506195e-08
  7013 KSP Residual norm 9.393405954699e-08
  7014 KSP Residual norm 9.346318371668e-08
  7015 KSP Residual norm 8.396103424247e-08
  7016 KSP Residual norm 7.817808203003e-08
  7017 KSP Residual norm 7.267968926525e-08
  7018 KSP Residual norm 7.023729380458e-08
  7019 KSP Residual norm 7.315988860634e-08
  7020 KSP Residual norm 7.909858920963e-08
  7021 KSP Residual norm 8.158470314923e-08
  7022 KSP Residual norm 8.120008553746e-08
  7023 KSP Residual norm 8.360024845460e-08
  7024 KSP Residual norm 9.791033923165e-08
  7025 KSP Residual norm 1.221770335161e-07
  7026 KSP Residual norm 1.357195323307e-07
  7027 KSP Residual norm 1.276948800596e-07
  7028 KSP Residual norm 1.275005813735e-07
  7029 KSP Residual norm 1.496522645305e-07
  7030 KSP Residual norm 1.702158210665e-07
  7031 KSP Residual norm 1.588993181866e-07
  7032 KSP Residual norm 1.436223776002e-07
  7033 KSP Residual norm 1.335516331820e-07
  7034 KSP Residual norm 1.305230980530e-07
  7035 KSP Residual norm 1.361086771117e-07
  7036 KSP Residual norm 1.345309860839e-07
  7037 KSP Residual norm 1.296770558694e-07
  7038 KSP Residual norm 1.373873830185e-07
  7039 KSP Residual norm 1.541702564342e-07
  7040 KSP Residual norm 1.672343024808e-07
  7041 KSP Residual norm 1.704345765849e-07
  7042 KSP Residual norm 1.555432640758e-07
  7043 KSP Residual norm 1.446505145884e-07
  7044 KSP Residual norm 1.537588827766e-07
  7045 KSP Residual norm 1.636038720932e-07
  7046 KSP Residual norm 1.587427926900e-07
  7047 KSP Residual norm 1.478525284368e-07
  7048 KSP Residual norm 1.517691029199e-07
  7049 KSP Residual norm 1.631863251644e-07
  7050 KSP Residual norm 1.662339090192e-07
  7051 KSP Residual norm 1.632121257908e-07
  7052 KSP Residual norm 1.610935186985e-07
  7053 KSP Residual norm 1.591240619248e-07
  7054 KSP Residual norm 1.765923361621e-07
  7055 KSP Residual norm 1.875840478655e-07
  7056 KSP Residual norm 1.797804842108e-07
  7057 KSP Residual norm 1.829429459130e-07
  7058 KSP Residual norm 2.011340485448e-07
  7059 KSP Residual norm 2.285278784152e-07
  7060 KSP Residual norm 2.582768755843e-07
  7061 KSP Residual norm 2.704942323737e-07
  7062 KSP Residual norm 2.649893119075e-07
  7063 KSP Residual norm 2.582816750451e-07
  7064 KSP Residual norm 2.437252028868e-07
  7065 KSP Residual norm 2.229109788451e-07
  7066 KSP Residual norm 2.031149301886e-07
  7067 KSP Residual norm 2.108349851405e-07
  7068 KSP Residual norm 2.223865104080e-07
  7069 KSP Residual norm 2.134704631591e-07
  7070 KSP Residual norm 1.980489396135e-07
  7071 KSP Residual norm 1.956979793181e-07
  7072 KSP Residual norm 2.112635961163e-07
  7073 KSP Residual norm 2.271516431746e-07
  7074 KSP Residual norm 2.293998645662e-07
  7075 KSP Residual norm 2.255678941471e-07
  7076 KSP Residual norm 2.224718178276e-07
  7077 KSP Residual norm 2.202513299985e-07
  7078 KSP Residual norm 2.153554374946e-07
  7079 KSP Residual norm 1.970982318973e-07
  7080 KSP Residual norm 1.833554929085e-07
  7081 KSP Residual norm 1.914230785395e-07
  7082 KSP Residual norm 1.937345110156e-07
  7083 KSP Residual norm 1.753127310305e-07
  7084 KSP Residual norm 1.520262751991e-07
  7085 KSP Residual norm 1.460252068392e-07
  7086 KSP Residual norm 1.412619420368e-07
  7087 KSP Residual norm 1.309334763016e-07
  7088 KSP Residual norm 1.227306999678e-07
  7089 KSP Residual norm 1.203016706898e-07
  7090 KSP Residual norm 1.173312324317e-07
  7091 KSP Residual norm 1.106789169274e-07
  7092 KSP Residual norm 1.108407801762e-07
  7093 KSP Residual norm 1.170567305188e-07
  7094 KSP Residual norm 1.178183853214e-07
  7095 KSP Residual norm 1.093805315863e-07
  7096 KSP Residual norm 1.027205465504e-07
  7097 KSP Residual norm 1.109233105315e-07
  7098 KSP Residual norm 1.165326894587e-07
  7099 KSP Residual norm 1.112082573563e-07
  7100 KSP Residual norm 1.027833917460e-07
  7101 KSP Residual norm 9.753202727619e-08
  7102 KSP Residual norm 9.703911994493e-08
  7103 KSP Residual norm 9.790925514857e-08
  7104 KSP Residual norm 9.637197467685e-08
  7105 KSP Residual norm 9.511376992954e-08
  7106 KSP Residual norm 9.586555373011e-08
  7107 KSP Residual norm 9.359647777554e-08
  7108 KSP Residual norm 9.117299347872e-08
  7109 KSP Residual norm 9.500547783038e-08
  7110 KSP Residual norm 9.420707679878e-08
  7111 KSP Residual norm 8.266409344174e-08
  7112 KSP Residual norm 7.488645691674e-08
  7113 KSP Residual norm 7.098698776525e-08
  7114 KSP Residual norm 6.754446132338e-08
  7115 KSP Residual norm 6.510855153112e-08
  7116 KSP Residual norm 6.712957895384e-08
  7117 KSP Residual norm 6.566861865982e-08
  7118 KSP Residual norm 6.181502920184e-08
  7119 KSP Residual norm 6.886762710879e-08
  7120 KSP Residual norm 8.363862635951e-08
  7121 KSP Residual norm 9.215313751779e-08
  7122 KSP Residual norm 9.648378613926e-08
  7123 KSP Residual norm 9.399681994510e-08
  7124 KSP Residual norm 9.313419725666e-08
  7125 KSP Residual norm 9.685427536833e-08
  7126 KSP Residual norm 9.587960073673e-08
  7127 KSP Residual norm 8.504617156191e-08
  7128 KSP Residual norm 7.453574582655e-08
  7129 KSP Residual norm 7.091070101550e-08
  7130 KSP Residual norm 7.309833109890e-08
  7131 KSP Residual norm 7.791563551742e-08
  7132 KSP Residual norm 7.898938238778e-08
  7133 KSP Residual norm 7.082727216069e-08
  7134 KSP Residual norm 6.731472131907e-08
  7135 KSP Residual norm 6.858692392740e-08
  7136 KSP Residual norm 6.893025137245e-08
  7137 KSP Residual norm 6.781914058432e-08
  7138 KSP Residual norm 6.638046574423e-08
  7139 KSP Residual norm 6.662654937694e-08
  7140 KSP Residual norm 6.712146693464e-08
  7141 KSP Residual norm 6.357555930685e-08
  7142 KSP Residual norm 6.051361498691e-08
  7143 KSP Residual norm 5.858945091601e-08
  7144 KSP Residual norm 5.563513001168e-08
  7145 KSP Residual norm 5.318325092439e-08
  7146 KSP Residual norm 5.172624319418e-08
  7147 KSP Residual norm 5.157830769367e-08
  7148 KSP Residual norm 5.101505732286e-08
  7149 KSP Residual norm 4.657868050280e-08
  7150 KSP Residual norm 4.599594593610e-08
  7151 KSP Residual norm 4.968119952596e-08
  7152 KSP Residual norm 4.944010222136e-08
  7153 KSP Residual norm 4.797813415718e-08
  7154 KSP Residual norm 4.922439839735e-08
  7155 KSP Residual norm 4.896964941268e-08
  7156 KSP Residual norm 4.741131298000e-08
  7157 KSP Residual norm 4.880835689160e-08
  7158 KSP Residual norm 5.051359898964e-08
  7159 KSP Residual norm 5.013730154192e-08
  7160 KSP Residual norm 4.723544432392e-08
  7161 KSP Residual norm 4.207929515199e-08
  7162 KSP Residual norm 3.904373515189e-08
  7163 KSP Residual norm 3.866431120925e-08
  7164 KSP Residual norm 3.918229641765e-08
  7165 KSP Residual norm 3.962416320753e-08
  7166 KSP Residual norm 3.539511106489e-08
  7167 KSP Residual norm 3.316278375512e-08
  7168 KSP Residual norm 3.759396097196e-08
  7169 KSP Residual norm 4.195683099718e-08
  7170 KSP Residual norm 4.040094010224e-08
  7171 KSP Residual norm 3.846988435149e-08
  7172 KSP Residual norm 3.847278225971e-08
  7173 KSP Residual norm 4.263022889365e-08
  7174 KSP Residual norm 5.080396305862e-08
  7175 KSP Residual norm 5.221809997639e-08
  7176 KSP Residual norm 4.654713657878e-08
  7177 KSP Residual norm 4.418870897838e-08
  7178 KSP Residual norm 4.720652790370e-08
  7179 KSP Residual norm 4.550459344390e-08
  7180 KSP Residual norm 3.773885426493e-08
  7181 KSP Residual norm 3.154569922226e-08
  7182 KSP Residual norm 2.982774172800e-08
  7183 KSP Residual norm 3.022039741612e-08
  7184 KSP Residual norm 3.138746572474e-08
  7185 KSP Residual norm 3.125112887785e-08
  7186 KSP Residual norm 3.008820648041e-08
  7187 KSP Residual norm 3.040098108082e-08
  7188 KSP Residual norm 3.256483834220e-08
  7189 KSP Residual norm 3.620389485277e-08
  7190 KSP Residual norm 3.973826197065e-08
  7191 KSP Residual norm 4.058638616401e-08
  7192 KSP Residual norm 4.244676648091e-08
  7193 KSP Residual norm 4.737166464887e-08
  7194 KSP Residual norm 5.089035681954e-08
  7195 KSP Residual norm 4.957882566318e-08
  7196 KSP Residual norm 4.934629029121e-08
  7197 KSP Residual norm 5.415955364923e-08
  7198 KSP Residual norm 6.324254388436e-08
  7199 KSP Residual norm 6.987256807195e-08
  7200 KSP Residual norm 7.364003809136e-08
  7201 KSP Residual norm 7.537183435563e-08
  7202 KSP Residual norm 7.595704453611e-08
  7203 KSP Residual norm 8.218971910390e-08
  7204 KSP Residual norm 8.337980520790e-08
  7205 KSP Residual norm 7.750531652948e-08
  7206 KSP Residual norm 8.270853970847e-08
  7207 KSP Residual norm 8.631055861934e-08
  7208 KSP Residual norm 7.947836977351e-08
  7209 KSP Residual norm 6.766469294742e-08
  7210 KSP Residual norm 5.756691665602e-08
  7211 KSP Residual norm 4.840164668507e-08
  7212 KSP Residual norm 4.420197556324e-08
  7213 KSP Residual norm 4.101874803406e-08
  7214 KSP Residual norm 3.789038056892e-08
  7215 KSP Residual norm 3.900776325398e-08
  7216 KSP Residual norm 4.195904454366e-08
  7217 KSP Residual norm 4.192955603167e-08
  7218 KSP Residual norm 4.107417974009e-08
  7219 KSP Residual norm 3.929350671012e-08
  7220 KSP Residual norm 3.657042951107e-08
  7221 KSP Residual norm 3.766625710148e-08
  7222 KSP Residual norm 4.389487691813e-08
  7223 KSP Residual norm 4.967827997605e-08
  7224 KSP Residual norm 5.339292213320e-08
  7225 KSP Residual norm 5.715963489940e-08
  7226 KSP Residual norm 6.364203364607e-08
  7227 KSP Residual norm 6.955531970780e-08
  7228 KSP Residual norm 7.231863364659e-08
  7229 KSP Residual norm 7.371142288083e-08
  7230 KSP Residual norm 7.802137707430e-08
  7231 KSP Residual norm 8.560237628796e-08
  7232 KSP Residual norm 9.605474499130e-08
  7233 KSP Residual norm 9.888502654439e-08
  7234 KSP Residual norm 9.591488394736e-08
  7235 KSP Residual norm 1.004541705838e-07
  7236 KSP Residual norm 1.031416935636e-07
  7237 KSP Residual norm 9.608448894178e-08
  7238 KSP Residual norm 8.672183912301e-08
  7239 KSP Residual norm 8.452959896811e-08
  7240 KSP Residual norm 9.352133664228e-08
  7241 KSP Residual norm 1.035693434837e-07
  7242 KSP Residual norm 9.755993024403e-08
  7243 KSP Residual norm 9.323274216286e-08
  7244 KSP Residual norm 1.022259922304e-07
  7245 KSP Residual norm 1.156390780902e-07
  7246 KSP Residual norm 1.284854700774e-07
  7247 KSP Residual norm 1.353672794527e-07
  7248 KSP Residual norm 1.418438068534e-07
  7249 KSP Residual norm 1.528470879974e-07
  7250 KSP Residual norm 1.566151966646e-07
  7251 KSP Residual norm 1.650966536538e-07
  7252 KSP Residual norm 1.935624707177e-07
  7253 KSP Residual norm 2.135569302835e-07
  7254 KSP Residual norm 2.069946439357e-07
  7255 KSP Residual norm 2.080672721633e-07
  7256 KSP Residual norm 2.376329747756e-07
  7257 KSP Residual norm 2.750217320201e-07
  7258 KSP Residual norm 2.935013129889e-07
  7259 KSP Residual norm 3.046975383831e-07
  7260 KSP Residual norm 3.116564406197e-07
  7261 KSP Residual norm 3.161155099252e-07
  7262 KSP Residual norm 2.788830404226e-07
  7263 KSP Residual norm 2.263091834626e-07
  7264 KSP Residual norm 2.110819276117e-07
  7265 KSP Residual norm 2.184860531322e-07
  7266 KSP Residual norm 2.123127707179e-07
  7267 KSP Residual norm 2.089817664631e-07
  7268 KSP Residual norm 1.985502799856e-07
  7269 KSP Residual norm 1.951510907328e-07
  7270 KSP Residual norm 2.179052316567e-07
  7271 KSP Residual norm 2.409518664097e-07
  7272 KSP Residual norm 2.369398097534e-07
  7273 KSP Residual norm 2.368167253357e-07
  7274 KSP Residual norm 2.599636539767e-07
  7275 KSP Residual norm 2.889140136086e-07
  7276 KSP Residual norm 2.921847062945e-07
  7277 KSP Residual norm 2.887697374046e-07
  7278 KSP Residual norm 2.961514714439e-07
  7279 KSP Residual norm 2.949891173686e-07
  7280 KSP Residual norm 2.896933025296e-07
  7281 KSP Residual norm 2.901461544134e-07
  7282 KSP Residual norm 2.687765857205e-07
  7283 KSP Residual norm 2.408008687125e-07
  7284 KSP Residual norm 2.390329547974e-07
  7285 KSP Residual norm 2.510678609930e-07
  7286 KSP Residual norm 2.368966475218e-07
  7287 KSP Residual norm 2.122542807679e-07
  7288 KSP Residual norm 2.029671769330e-07
  7289 KSP Residual norm 1.961522742176e-07
  7290 KSP Residual norm 1.913443852905e-07
  7291 KSP Residual norm 2.039416180900e-07
  7292 KSP Residual norm 2.150959917544e-07
  7293 KSP Residual norm 2.219345636290e-07
  7294 KSP Residual norm 2.541533072622e-07
  7295 KSP Residual norm 3.018808921148e-07
  7296 KSP Residual norm 3.139616684865e-07
  7297 KSP Residual norm 2.962550895982e-07
  7298 KSP Residual norm 3.198068863404e-07
  7299 KSP Residual norm 3.742756194810e-07
  7300 KSP Residual norm 3.959842818393e-07
  7301 KSP Residual norm 3.964823202399e-07
  7302 KSP Residual norm 4.187061959804e-07
  7303 KSP Residual norm 4.396971781499e-07
  7304 KSP Residual norm 4.554715642577e-07
  7305 KSP Residual norm 4.822287691056e-07
  7306 KSP Residual norm 4.739427062245e-07
  7307 KSP Residual norm 4.685734909259e-07
  7308 KSP Residual norm 5.046245107242e-07
  7309 KSP Residual norm 5.114040065988e-07
  7310 KSP Residual norm 4.886034839479e-07
  7311 KSP Residual norm 4.908948908224e-07
  7312 KSP Residual norm 5.064694567661e-07
  7313 KSP Residual norm 5.271964707650e-07
  7314 KSP Residual norm 5.410219411796e-07
  7315 KSP Residual norm 5.336878375794e-07
  7316 KSP Residual norm 5.410391750970e-07
  7317 KSP Residual norm 6.157963015528e-07
  7318 KSP Residual norm 6.968998024400e-07
  7319 KSP Residual norm 7.041993953182e-07
  7320 KSP Residual norm 7.147096845297e-07
  7321 KSP Residual norm 8.001120848706e-07
  7322 KSP Residual norm 8.956876190316e-07
  7323 KSP Residual norm 9.648024666539e-07
  7324 KSP Residual norm 1.037546390916e-06
  7325 KSP Residual norm 1.160551330876e-06
  7326 KSP Residual norm 1.345903748827e-06
  7327 KSP Residual norm 1.548893195179e-06
  7328 KSP Residual norm 1.728489433297e-06
  7329 KSP Residual norm 1.928407162036e-06
  7330 KSP Residual norm 2.064523475193e-06
  7331 KSP Residual norm 2.127668034474e-06
  7332 KSP Residual norm 2.200837900367e-06
  7333 KSP Residual norm 2.342478046569e-06
  7334 KSP Residual norm 2.255502483522e-06
  7335 KSP Residual norm 2.071242807730e-06
  7336 KSP Residual norm 2.049622070359e-06
  7337 KSP Residual norm 1.891432251160e-06
  7338 KSP Residual norm 1.670979119049e-06
  7339 KSP Residual norm 1.624795912576e-06
  7340 KSP Residual norm 1.618959764401e-06
  7341 KSP Residual norm 1.496541227742e-06
  7342 KSP Residual norm 1.534664349931e-06
  7343 KSP Residual norm 1.658766214841e-06
  7344 KSP Residual norm 1.693499053434e-06
  7345 KSP Residual norm 1.770783134740e-06
  7346 KSP Residual norm 1.906003432519e-06
  7347 KSP Residual norm 1.864989918715e-06
  7348 KSP Residual norm 1.724205497069e-06
  7349 KSP Residual norm 1.585113809120e-06
  7350 KSP Residual norm 1.510430501692e-06
  7351 KSP Residual norm 1.544709111610e-06
  7352 KSP Residual norm 1.704223603156e-06
  7353 KSP Residual norm 1.797355777725e-06
  7354 KSP Residual norm 1.900166913996e-06
  7355 KSP Residual norm 1.975027210596e-06
  7356 KSP Residual norm 1.955158673940e-06
  7357 KSP Residual norm 1.836040615689e-06
  7358 KSP Residual norm 1.839221638011e-06
  7359 KSP Residual norm 1.971513329176e-06
  7360 KSP Residual norm 1.911622851630e-06
  7361 KSP Residual norm 1.890715037426e-06
  7362 KSP Residual norm 2.055261284146e-06
  7363 KSP Residual norm 2.153464847999e-06
  7364 KSP Residual norm 2.008393185291e-06
  7365 KSP Residual norm 1.897706439102e-06
  7366 KSP Residual norm 1.915211148214e-06
  7367 KSP Residual norm 2.042470700063e-06
  7368 KSP Residual norm 2.139329234885e-06
  7369 KSP Residual norm 2.180019660575e-06
  7370 KSP Residual norm 2.459675335832e-06
  7371 KSP Residual norm 2.803709806540e-06
  7372 KSP Residual norm 2.826919004970e-06
  7373 KSP Residual norm 2.807219252052e-06
  7374 KSP Residual norm 2.933592940288e-06
  7375 KSP Residual norm 2.882575790868e-06
  7376 KSP Residual norm 2.824077878684e-06
  7377 KSP Residual norm 3.056055908946e-06
  7378 KSP Residual norm 3.393614741223e-06
  7379 KSP Residual norm 3.711719625836e-06
  7380 KSP Residual norm 4.171457549568e-06
  7381 KSP Residual norm 4.315183598905e-06
  7382 KSP Residual norm 4.330420470982e-06
  7383 KSP Residual norm 4.498371230511e-06
  7384 KSP Residual norm 4.391051229443e-06
  7385 KSP Residual norm 3.950767227256e-06
  7386 KSP Residual norm 3.622979530472e-06
  7387 KSP Residual norm 3.433195136852e-06
  7388 KSP Residual norm 3.460097833917e-06
  7389 KSP Residual norm 3.404750932069e-06
  7390 KSP Residual norm 3.205631196985e-06
  7391 KSP Residual norm 3.039048015714e-06
  7392 KSP Residual norm 2.875810027938e-06
  7393 KSP Residual norm 2.756544457966e-06
  7394 KSP Residual norm 2.759596195061e-06
  7395 KSP Residual norm 2.721814333379e-06
  7396 KSP Residual norm 2.808216136613e-06
  7397 KSP Residual norm 3.079381464310e-06
  7398 KSP Residual norm 3.296628479187e-06
  7399 KSP Residual norm 3.496924708281e-06
  7400 KSP Residual norm 3.609924256297e-06
  7401 KSP Residual norm 3.611912260519e-06
  7402 KSP Residual norm 3.349943920058e-06
  7403 KSP Residual norm 3.105712990170e-06
  7404 KSP Residual norm 3.397066750256e-06
  7405 KSP Residual norm 4.403106039167e-06
  7406 KSP Residual norm 5.448131878687e-06
  7407 KSP Residual norm 5.868924270531e-06
  7408 KSP Residual norm 6.358360513096e-06
  7409 KSP Residual norm 6.546256823724e-06
  7410 KSP Residual norm 5.807578075804e-06
  7411 KSP Residual norm 4.877589321014e-06
  7412 KSP Residual norm 4.357047961191e-06
  7413 KSP Residual norm 4.625109842446e-06
  7414 KSP Residual norm 5.445790188789e-06
  7415 KSP Residual norm 5.369350612031e-06
  7416 KSP Residual norm 4.758037938977e-06
  7417 KSP Residual norm 4.947853851393e-06
  7418 KSP Residual norm 5.408830808929e-06
  7419 KSP Residual norm 5.527948257413e-06
  7420 KSP Residual norm 5.870817384348e-06
  7421 KSP Residual norm 6.634202769939e-06
  7422 KSP Residual norm 6.950684104754e-06
  7423 KSP Residual norm 7.094895956547e-06
  7424 KSP Residual norm 7.134684662989e-06
  7425 KSP Residual norm 7.058220874156e-06
  7426 KSP Residual norm 7.165775774834e-06
  7427 KSP Residual norm 7.209989257062e-06
  7428 KSP Residual norm 7.401207431631e-06
  7429 KSP Residual norm 7.491830128985e-06
  7430 KSP Residual norm 7.732961534271e-06
  7431 KSP Residual norm 7.905118596087e-06
  7432 KSP Residual norm 7.880525450629e-06
  7433 KSP Residual norm 8.077074255041e-06
  7434 KSP Residual norm 7.932670451256e-06
  7435 KSP Residual norm 7.808390286480e-06
  7436 KSP Residual norm 8.337561976437e-06
  7437 KSP Residual norm 8.346486640413e-06
  7438 KSP Residual norm 7.400818417879e-06
  7439 KSP Residual norm 6.781601708653e-06
  7440 KSP Residual norm 6.677486394509e-06
  7441 KSP Residual norm 6.543964415339e-06
  7442 KSP Residual norm 7.030968134865e-06
  7443 KSP Residual norm 6.783836032831e-06
  7444 KSP Residual norm 6.051743568940e-06
  7445 KSP Residual norm 5.632219658258e-06
  7446 KSP Residual norm 5.175084164761e-06
  7447 KSP Residual norm 4.956510470261e-06
  7448 KSP Residual norm 5.106001542929e-06
  7449 KSP Residual norm 4.884137056565e-06
  7450 KSP Residual norm 4.018563979161e-06
  7451 KSP Residual norm 3.762635094921e-06
  7452 KSP Residual norm 4.174839206176e-06
  7453 KSP Residual norm 4.601150014605e-06
  7454 KSP Residual norm 4.714770978273e-06
  7455 KSP Residual norm 5.258794056687e-06
  7456 KSP Residual norm 5.947423843634e-06
  7457 KSP Residual norm 5.886855801846e-06
  7458 KSP Residual norm 5.812182455590e-06
  7459 KSP Residual norm 6.266799958497e-06
  7460 KSP Residual norm 7.125586227852e-06
  7461 KSP Residual norm 7.725603768311e-06
  7462 KSP Residual norm 7.768847337324e-06
  7463 KSP Residual norm 6.868912963031e-06
  7464 KSP Residual norm 6.298035970097e-06
  7465 KSP Residual norm 5.986254222685e-06
  7466 KSP Residual norm 5.263279249285e-06
  7467 KSP Residual norm 4.640850270861e-06
  7468 KSP Residual norm 4.281274645449e-06
  7469 KSP Residual norm 4.378865379569e-06
  7470 KSP Residual norm 4.625254291148e-06
  7471 KSP Residual norm 4.604480313008e-06
  7472 KSP Residual norm 4.499574793283e-06
  7473 KSP Residual norm 4.754601510162e-06
  7474 KSP Residual norm 5.471345280433e-06
  7475 KSP Residual norm 5.803430465006e-06
  7476 KSP Residual norm 5.491827843799e-06
  7477 KSP Residual norm 5.568292521666e-06
  7478 KSP Residual norm 5.781627228754e-06
  7479 KSP Residual norm 6.032745873122e-06
  7480 KSP Residual norm 6.574324966192e-06
  7481 KSP Residual norm 7.520802226600e-06
  7482 KSP Residual norm 8.105384029071e-06
  7483 KSP Residual norm 8.696982662423e-06
  7484 KSP Residual norm 9.043312829595e-06
  7485 KSP Residual norm 9.153174889175e-06
  7486 KSP Residual norm 8.933332050159e-06
  7487 KSP Residual norm 9.114493043593e-06
  7488 KSP Residual norm 9.257993259567e-06
  7489 KSP Residual norm 1.010193639190e-05
  7490 KSP Residual norm 1.133217772365e-05
  7491 KSP Residual norm 1.105033167397e-05
  7492 KSP Residual norm 9.393679005325e-06
  7493 KSP Residual norm 8.461994509747e-06
  7494 KSP Residual norm 8.154267437754e-06
  7495 KSP Residual norm 8.359580049015e-06
  7496 KSP Residual norm 8.811861853892e-06
  7497 KSP Residual norm 9.206540247349e-06
  7498 KSP Residual norm 9.210921137128e-06
  7499 KSP Residual norm 9.595170861270e-06
  7500 KSP Residual norm 9.720476572278e-06
  7501 KSP Residual norm 9.057207253062e-06
  7502 KSP Residual norm 8.793348718699e-06
  7503 KSP Residual norm 8.872635795232e-06
  7504 KSP Residual norm 8.067157632592e-06
  7505 KSP Residual norm 6.910946690861e-06
  7506 KSP Residual norm 6.637232149285e-06
  7507 KSP Residual norm 7.212674730349e-06
  7508 KSP Residual norm 7.222678830237e-06
  7509 KSP Residual norm 6.801658479535e-06
  7510 KSP Residual norm 6.803026343778e-06
  7511 KSP Residual norm 6.826157559353e-06
  7512 KSP Residual norm 6.147860925154e-06
  7513 KSP Residual norm 5.649665742164e-06
  7514 KSP Residual norm 5.661394177507e-06
  7515 KSP Residual norm 6.033033496710e-06
  7516 KSP Residual norm 6.217098881835e-06
  7517 KSP Residual norm 5.790977177662e-06
  7518 KSP Residual norm 5.262555389241e-06
  7519 KSP Residual norm 5.394054256262e-06
  7520 KSP Residual norm 6.099391473298e-06
  7521 KSP Residual norm 6.017669258310e-06
  7522 KSP Residual norm 5.168489864323e-06
  7523 KSP Residual norm 4.653495379470e-06
  7524 KSP Residual norm 4.756808962319e-06
  7525 KSP Residual norm 4.710616237623e-06
  7526 KSP Residual norm 4.192384423526e-06
  7527 KSP Residual norm 3.571821185925e-06
  7528 KSP Residual norm 3.380979950370e-06
  7529 KSP Residual norm 3.394373770687e-06
  7530 KSP Residual norm 3.133394193570e-06
  7531 KSP Residual norm 2.906341574694e-06
  7532 KSP Residual norm 2.806390273384e-06
  7533 KSP Residual norm 2.576973346213e-06
  7534 KSP Residual norm 2.402896835379e-06
  7535 KSP Residual norm 2.286698857055e-06
  7536 KSP Residual norm 2.128749462796e-06
  7537 KSP Residual norm 1.849129157966e-06
  7538 KSP Residual norm 1.745649237557e-06
  7539 KSP Residual norm 1.949177086934e-06
  7540 KSP Residual norm 2.220735985337e-06
  7541 KSP Residual norm 2.491220676205e-06
  7542 KSP Residual norm 2.901861044743e-06
  7543 KSP Residual norm 2.764480884909e-06
  7544 KSP Residual norm 2.339823036839e-06
  7545 KSP Residual norm 2.117424113113e-06
  7546 KSP Residual norm 2.097804474104e-06
  7547 KSP Residual norm 2.218188692609e-06
  7548 KSP Residual norm 2.331652482351e-06
  7549 KSP Residual norm 2.281179482142e-06
  7550 KSP Residual norm 2.230880163625e-06
  7551 KSP Residual norm 2.193340962817e-06
  7552 KSP Residual norm 2.012912718695e-06
  7553 KSP Residual norm 1.797494138650e-06
  7554 KSP Residual norm 1.888851558483e-06
  7555 KSP Residual norm 2.347433938128e-06
  7556 KSP Residual norm 2.468137721919e-06
  7557 KSP Residual norm 2.384405907187e-06
  7558 KSP Residual norm 2.385175481351e-06
  7559 KSP Residual norm 2.339659926500e-06
  7560 KSP Residual norm 2.213745819020e-06
  7561 KSP Residual norm 2.038283319788e-06
  7562 KSP Residual norm 1.877067766034e-06
  7563 KSP Residual norm 1.709117716898e-06
  7564 KSP Residual norm 1.545362621855e-06
  7565 KSP Residual norm 1.370809885245e-06
  7566 KSP Residual norm 1.325113506238e-06
  7567 KSP Residual norm 1.451356910965e-06
  7568 KSP Residual norm 1.641920092931e-06
  7569 KSP Residual norm 1.789209021483e-06
  7570 KSP Residual norm 1.825554920150e-06
  7571 KSP Residual norm 1.701651428292e-06
  7572 KSP Residual norm 1.549520241332e-06
  7573 KSP Residual norm 1.478751731399e-06
  7574 KSP Residual norm 1.308030230514e-06
  7575 KSP Residual norm 1.098056663857e-06
  7576 KSP Residual norm 1.047742702407e-06
  7577 KSP Residual norm 1.077581379460e-06
  7578 KSP Residual norm 1.084524811502e-06
  7579 KSP Residual norm 1.171361395739e-06
  7580 KSP Residual norm 1.559829460255e-06
  7581 KSP Residual norm 1.888336534721e-06
  7582 KSP Residual norm 1.794949507659e-06
  7583 KSP Residual norm 1.706950736080e-06
  7584 KSP Residual norm 1.986844617867e-06
  7585 KSP Residual norm 2.333741308409e-06
  7586 KSP Residual norm 2.635723909210e-06
  7587 KSP Residual norm 2.716018453242e-06
  7588 KSP Residual norm 2.499402013645e-06
  7589 KSP Residual norm 2.563480763981e-06
  7590 KSP Residual norm 2.893051475505e-06
  7591 KSP Residual norm 2.750302539350e-06
  7592 KSP Residual norm 2.456456231021e-06
  7593 KSP Residual norm 2.258745876614e-06
  7594 KSP Residual norm 2.069890740290e-06
  7595 KSP Residual norm 1.969981072226e-06
  7596 KSP Residual norm 1.987239392270e-06
  7597 KSP Residual norm 2.046077299872e-06
  7598 KSP Residual norm 2.092767133420e-06
  7599 KSP Residual norm 1.987199894632e-06
  7600 KSP Residual norm 1.708487619018e-06
  7601 KSP Residual norm 1.528502112138e-06
  7602 KSP Residual norm 1.519839485156e-06
  7603 KSP Residual norm 1.558248795308e-06
  7604 KSP Residual norm 1.498227452433e-06
  7605 KSP Residual norm 1.350123919455e-06
  7606 KSP Residual norm 1.323829824032e-06
  7607 KSP Residual norm 1.368322777727e-06
  7608 KSP Residual norm 1.315047169960e-06
  7609 KSP Residual norm 1.226868028559e-06
  7610 KSP Residual norm 1.209345337633e-06
  7611 KSP Residual norm 1.296756002698e-06
  7612 KSP Residual norm 1.495403681433e-06
  7613 KSP Residual norm 1.543632257846e-06
  7614 KSP Residual norm 1.552141546969e-06
  7615 KSP Residual norm 1.728284505624e-06
  7616 KSP Residual norm 1.740959446910e-06
  7617 KSP Residual norm 1.427164898704e-06
  7618 KSP Residual norm 1.188343046565e-06
  7619 KSP Residual norm 1.094236234960e-06
  7620 KSP Residual norm 1.188114715187e-06
  7621 KSP Residual norm 1.311944475543e-06
  7622 KSP Residual norm 1.173316002371e-06
  7623 KSP Residual norm 9.315092629314e-07
  7624 KSP Residual norm 8.050722044022e-07
  7625 KSP Residual norm 7.758971819723e-07
  7626 KSP Residual norm 7.902972324827e-07
  7627 KSP Residual norm 7.707781085207e-07
  7628 KSP Residual norm 7.550263137422e-07
  7629 KSP Residual norm 7.903295915348e-07
  7630 KSP Residual norm 7.964973817909e-07
  7631 KSP Residual norm 7.399853560834e-07
  7632 KSP Residual norm 6.864624571673e-07
  7633 KSP Residual norm 7.173851891277e-07
  7634 KSP Residual norm 8.678556031920e-07
  7635 KSP Residual norm 1.109058101050e-06
  7636 KSP Residual norm 1.128134085893e-06
  7637 KSP Residual norm 1.003895519920e-06
  7638 KSP Residual norm 9.357897272235e-07
  7639 KSP Residual norm 9.305936242133e-07
  7640 KSP Residual norm 1.044599556472e-06
  7641 KSP Residual norm 1.267764522320e-06
  7642 KSP Residual norm 1.405290123929e-06
  7643 KSP Residual norm 1.430947834916e-06
  7644 KSP Residual norm 1.421326922048e-06
  7645 KSP Residual norm 1.255786956863e-06
  7646 KSP Residual norm 1.084774632763e-06
  7647 KSP Residual norm 1.003474902166e-06
  7648 KSP Residual norm 1.030442178222e-06
  7649 KSP Residual norm 1.115967208130e-06
  7650 KSP Residual norm 1.258699230974e-06
  7651 KSP Residual norm 1.455157355988e-06
  7652 KSP Residual norm 1.422819130257e-06
  7653 KSP Residual norm 1.256296351642e-06
  7654 KSP Residual norm 1.184008824620e-06
  7655 KSP Residual norm 1.288665846616e-06
  7656 KSP Residual norm 1.541683158251e-06
  7657 KSP Residual norm 1.621744483781e-06
  7658 KSP Residual norm 1.515973471917e-06
  7659 KSP Residual norm 1.546293219122e-06
  7660 KSP Residual norm 1.722504472439e-06
  7661 KSP Residual norm 1.895528349135e-06
  7662 KSP Residual norm 2.033657819580e-06
  7663 KSP Residual norm 1.944098905122e-06
  7664 KSP Residual norm 1.714483455032e-06
  7665 KSP Residual norm 1.639339083118e-06
  7666 KSP Residual norm 1.741623408973e-06
  7667 KSP Residual norm 1.981786428858e-06
  7668 KSP Residual norm 2.328744191905e-06
  7669 KSP Residual norm 2.812612361480e-06
  7670 KSP Residual norm 3.280118055052e-06
  7671 KSP Residual norm 3.320087437432e-06
  7672 KSP Residual norm 3.150149732969e-06
  7673 KSP Residual norm 3.053736682444e-06
  7674 KSP Residual norm 2.678521357222e-06
  7675 KSP Residual norm 2.179998337595e-06
  7676 KSP Residual norm 1.866392801572e-06
  7677 KSP Residual norm 1.827194308348e-06
  7678 KSP Residual norm 1.875664570303e-06
  7679 KSP Residual norm 1.726766288160e-06
  7680 KSP Residual norm 1.454187767829e-06
  7681 KSP Residual norm 1.372884760919e-06
  7682 KSP Residual norm 1.463078983051e-06
  7683 KSP Residual norm 1.430787554902e-06
  7684 KSP Residual norm 1.305234955272e-06
  7685 KSP Residual norm 1.315870472081e-06
  7686 KSP Residual norm 1.605222771185e-06
  7687 KSP Residual norm 2.088576810084e-06
  7688 KSP Residual norm 2.354255260154e-06
  7689 KSP Residual norm 2.038521667586e-06
  7690 KSP Residual norm 1.565043688766e-06
  7691 KSP Residual norm 1.394994089855e-06
  7692 KSP Residual norm 1.451967110031e-06
  7693 KSP Residual norm 1.471636194778e-06
  7694 KSP Residual norm 1.266189142449e-06
  7695 KSP Residual norm 1.136694354160e-06
  7696 KSP Residual norm 1.218027225686e-06
  7697 KSP Residual norm 1.462192636199e-06
  7698 KSP Residual norm 1.627371740201e-06
  7699 KSP Residual norm 1.565381118206e-06
  7700 KSP Residual norm 1.479758923915e-06
  7701 KSP Residual norm 1.461408952508e-06
  7702 KSP Residual norm 1.265609759472e-06
  7703 KSP Residual norm 9.915598891812e-07
  7704 KSP Residual norm 8.662916334648e-07
  7705 KSP Residual norm 9.059432381449e-07
  7706 KSP Residual norm 1.112807107759e-06
  7707 KSP Residual norm 1.392331327892e-06
  7708 KSP Residual norm 1.640877480017e-06
  7709 KSP Residual norm 1.759439173999e-06
  7710 KSP Residual norm 1.803277092063e-06
  7711 KSP Residual norm 1.812475848526e-06
  7712 KSP Residual norm 1.752306727511e-06
  7713 KSP Residual norm 1.748093673952e-06
  7714 KSP Residual norm 1.665086925123e-06
  7715 KSP Residual norm 1.511042176560e-06
  7716 KSP Residual norm 1.435478985287e-06
  7717 KSP Residual norm 1.400611117409e-06
  7718 KSP Residual norm 1.321510760937e-06
  7719 KSP Residual norm 1.336048870707e-06
  7720 KSP Residual norm 1.334587277990e-06
  7721 KSP Residual norm 1.359770636563e-06
  7722 KSP Residual norm 1.572246787352e-06
  7723 KSP Residual norm 1.898121724474e-06
  7724 KSP Residual norm 2.041265790273e-06
  7725 KSP Residual norm 1.988637757144e-06
  7726 KSP Residual norm 1.758225849780e-06
  7727 KSP Residual norm 1.604241350551e-06
  7728 KSP Residual norm 1.493395238764e-06
  7729 KSP Residual norm 1.278840087985e-06
  7730 KSP Residual norm 1.199994309068e-06
  7731 KSP Residual norm 1.410547879288e-06
  7732 KSP Residual norm 1.892887321646e-06
  7733 KSP Residual norm 2.382556372287e-06
  7734 KSP Residual norm 2.526191545685e-06
  7735 KSP Residual norm 2.366849552919e-06
  7736 KSP Residual norm 2.201965785733e-06
  7737 KSP Residual norm 1.949263491447e-06
  7738 KSP Residual norm 1.660818134384e-06
  7739 KSP Residual norm 1.502108494913e-06
  7740 KSP Residual norm 1.441703063890e-06
  7741 KSP Residual norm 1.543516101052e-06
  7742 KSP Residual norm 1.912139912682e-06
  7743 KSP Residual norm 2.181260820141e-06
  7744 KSP Residual norm 1.982404721499e-06
  7745 KSP Residual norm 1.788496415450e-06
  7746 KSP Residual norm 1.755905856383e-06
  7747 KSP Residual norm 1.798751962707e-06
  7748 KSP Residual norm 1.826743448290e-06
  7749 KSP Residual norm 1.794364237013e-06
  7750 KSP Residual norm 1.655274861349e-06
  7751 KSP Residual norm 1.607864966586e-06
  7752 KSP Residual norm 1.545793792005e-06
  7753 KSP Residual norm 1.383804916330e-06
  7754 KSP Residual norm 1.256160923816e-06
  7755 KSP Residual norm 1.225617055834e-06
  7756 KSP Residual norm 1.440135604763e-06
  7757 KSP Residual norm 1.822276218037e-06
  7758 KSP Residual norm 2.021691727895e-06
  7759 KSP Residual norm 1.945821107226e-06
  7760 KSP Residual norm 1.601892493006e-06
  7761 KSP Residual norm 1.320577427551e-06
  7762 KSP Residual norm 1.244750709422e-06
  7763 KSP Residual norm 1.304776354825e-06
  7764 KSP Residual norm 1.383670746135e-06
  7765 KSP Residual norm 1.330299955581e-06
  7766 KSP Residual norm 1.249706226691e-06
  7767 KSP Residual norm 1.328075503647e-06
  7768 KSP Residual norm 1.477294098990e-06
  7769 KSP Residual norm 1.433690077428e-06
  7770 KSP Residual norm 1.381042913590e-06
  7771 KSP Residual norm 1.287887954423e-06
  7772 KSP Residual norm 1.130006127816e-06
  7773 KSP Residual norm 1.011716780233e-06
  7774 KSP Residual norm 9.147596375336e-07
  7775 KSP Residual norm 7.628489774252e-07
  7776 KSP Residual norm 5.637655308019e-07
  7777 KSP Residual norm 4.169385291491e-07
  7778 KSP Residual norm 3.376188844955e-07
  7779 KSP Residual norm 3.194042227907e-07
  7780 KSP Residual norm 3.502557581226e-07
  7781 KSP Residual norm 4.271475349041e-07
  7782 KSP Residual norm 5.199353996380e-07
  7783 KSP Residual norm 6.231873012615e-07
  7784 KSP Residual norm 7.065676843507e-07
  7785 KSP Residual norm 7.020533601458e-07
  7786 KSP Residual norm 6.333922928740e-07
  7787 KSP Residual norm 6.126710697391e-07
  7788 KSP Residual norm 6.245516936564e-07
  7789 KSP Residual norm 6.125644819357e-07
  7790 KSP Residual norm 6.175451435045e-07
  7791 KSP Residual norm 6.624950033581e-07
  7792 KSP Residual norm 7.371108945590e-07
  7793 KSP Residual norm 8.388528650842e-07
  7794 KSP Residual norm 9.238375246647e-07
  7795 KSP Residual norm 8.304071987238e-07
  7796 KSP Residual norm 7.087597135093e-07
  7797 KSP Residual norm 6.153650288372e-07
  7798 KSP Residual norm 5.088104464888e-07
  7799 KSP Residual norm 4.155686689330e-07
  7800 KSP Residual norm 3.613689860961e-07
  7801 KSP Residual norm 3.303151926430e-07
  7802 KSP Residual norm 3.317027875012e-07
  7803 KSP Residual norm 3.541152444808e-07
  7804 KSP Residual norm 3.915848982899e-07
  7805 KSP Residual norm 4.392157509576e-07
  7806 KSP Residual norm 4.514871887997e-07
  7807 KSP Residual norm 4.500378393007e-07
  7808 KSP Residual norm 4.918681967471e-07
  7809 KSP Residual norm 5.988226284555e-07
  7810 KSP Residual norm 6.271943214777e-07
  7811 KSP Residual norm 5.439448444939e-07
  7812 KSP Residual norm 5.090939056623e-07
  7813 KSP Residual norm 5.607999729476e-07
  7814 KSP Residual norm 6.733954523873e-07
  7815 KSP Residual norm 8.800202184278e-07
  7816 KSP Residual norm 1.089453565854e-06
  7817 KSP Residual norm 8.759768236034e-07
  7818 KSP Residual norm 5.658411523005e-07
  7819 KSP Residual norm 4.440312990819e-07
  7820 KSP Residual norm 3.851573111640e-07
  7821 KSP Residual norm 3.128250866591e-07
  7822 KSP Residual norm 2.701549036854e-07
  7823 KSP Residual norm 2.623585589528e-07
  7824 KSP Residual norm 2.640675072228e-07
  7825 KSP Residual norm 2.766206869245e-07
  7826 KSP Residual norm 2.959579435269e-07
  7827 KSP Residual norm 3.191487734765e-07
  7828 KSP Residual norm 3.957849404071e-07
  7829 KSP Residual norm 5.915551783732e-07
  7830 KSP Residual norm 8.236966418673e-07
  7831 KSP Residual norm 8.096132648785e-07
  7832 KSP Residual norm 6.454286934911e-07
  7833 KSP Residual norm 5.516344767876e-07
  7834 KSP Residual norm 5.455079849659e-07
  7835 KSP Residual norm 5.696007548804e-07
  7836 KSP Residual norm 4.849226915416e-07
  7837 KSP Residual norm 3.900262142211e-07
  7838 KSP Residual norm 3.634726596977e-07
  7839 KSP Residual norm 3.470919882618e-07
  7840 KSP Residual norm 2.919319565751e-07
  7841 KSP Residual norm 2.332888220556e-07
  7842 KSP Residual norm 1.848391416604e-07
  7843 KSP Residual norm 1.655712646219e-07
  7844 KSP Residual norm 1.800714102656e-07
  7845 KSP Residual norm 1.975597739976e-07
  7846 KSP Residual norm 1.917655666113e-07
  7847 KSP Residual norm 1.897844147078e-07
  7848 KSP Residual norm 1.902781709051e-07
  7849 KSP Residual norm 1.732907900364e-07
  7850 KSP Residual norm 1.605368992933e-07
  7851 KSP Residual norm 1.917814237521e-07
  7852 KSP Residual norm 2.529096988932e-07
  7853 KSP Residual norm 2.975013975433e-07
  7854 KSP Residual norm 3.084666262852e-07
  7855 KSP Residual norm 3.080532270391e-07
  7856 KSP Residual norm 3.076966076176e-07
  7857 KSP Residual norm 3.401942014978e-07
  7858 KSP Residual norm 3.860996998338e-07
  7859 KSP Residual norm 3.534189697168e-07
  7860 KSP Residual norm 3.273592303477e-07
  7861 KSP Residual norm 3.371386162608e-07
  7862 KSP Residual norm 3.055434993511e-07
  7863 KSP Residual norm 2.599853444728e-07
  7864 KSP Residual norm 2.432475982379e-07
  7865 KSP Residual norm 2.381295488489e-07
  7866 KSP Residual norm 2.404107453197e-07
  7867 KSP Residual norm 2.266153684418e-07
  7868 KSP Residual norm 2.171308920114e-07
  7869 KSP Residual norm 2.446128115014e-07
  7870 KSP Residual norm 2.934260132442e-07
  7871 KSP Residual norm 3.518341924976e-07
  7872 KSP Residual norm 3.858084956032e-07
  7873 KSP Residual norm 3.862689234988e-07
  7874 KSP Residual norm 4.076547606188e-07
  7875 KSP Residual norm 4.482743976025e-07
  7876 KSP Residual norm 5.154688453269e-07
  7877 KSP Residual norm 5.487037342204e-07
  7878 KSP Residual norm 5.221342164123e-07
  7879 KSP Residual norm 4.742054797895e-07
  7880 KSP Residual norm 3.983806445520e-07
  7881 KSP Residual norm 2.961926272928e-07
  7882 KSP Residual norm 2.359776353977e-07
  7883 KSP Residual norm 2.277291789503e-07
  7884 KSP Residual norm 2.223418298875e-07
  7885 KSP Residual norm 1.893235411678e-07
  7886 KSP Residual norm 1.534105099781e-07
  7887 KSP Residual norm 1.254661639792e-07
  7888 KSP Residual norm 1.135579898410e-07
  7889 KSP Residual norm 1.312498163977e-07
  7890 KSP Residual norm 1.768469855483e-07
  7891 KSP Residual norm 1.949380402344e-07
  7892 KSP Residual norm 1.855235049881e-07
  7893 KSP Residual norm 1.825816412243e-07
  7894 KSP Residual norm 2.028823102601e-07
  7895 KSP Residual norm 2.356248695017e-07
  7896 KSP Residual norm 2.604014066294e-07
  7897 KSP Residual norm 2.704263225644e-07
  7898 KSP Residual norm 3.101537848053e-07
  7899 KSP Residual norm 3.740512218823e-07
  7900 KSP Residual norm 3.519697408755e-07
  7901 KSP Residual norm 2.538404267501e-07
  7902 KSP Residual norm 2.058518899867e-07
  7903 KSP Residual norm 1.839727959678e-07
  7904 KSP Residual norm 1.786699263491e-07
  7905 KSP Residual norm 1.734821419894e-07
  7906 KSP Residual norm 1.682588537774e-07
  7907 KSP Residual norm 1.670860584442e-07
  7908 KSP Residual norm 1.666448465470e-07
  7909 KSP Residual norm 1.688202170661e-07
  7910 KSP Residual norm 1.687753982599e-07
  7911 KSP Residual norm 1.540603074341e-07
  7912 KSP Residual norm 1.433976715364e-07
  7913 KSP Residual norm 1.441885388914e-07
  7914 KSP Residual norm 1.354919259712e-07
  7915 KSP Residual norm 1.214584483221e-07
  7916 KSP Residual norm 1.134572104274e-07
  7917 KSP Residual norm 1.154910483308e-07
  7918 KSP Residual norm 1.322883548829e-07
  7919 KSP Residual norm 1.377479981038e-07
  7920 KSP Residual norm 1.232153654558e-07
  7921 KSP Residual norm 1.162538811398e-07
  7922 KSP Residual norm 1.285562659148e-07
  7923 KSP Residual norm 1.460850487169e-07
  7924 KSP Residual norm 1.808964028303e-07
  7925 KSP Residual norm 2.164464361009e-07
  7926 KSP Residual norm 2.065840948205e-07
  7927 KSP Residual norm 1.840979636849e-07
  7928 KSP Residual norm 1.919529282356e-07
  7929 KSP Residual norm 2.315411553482e-07
  7930 KSP Residual norm 2.928671128214e-07
  7931 KSP Residual norm 3.214906371225e-07
  7932 KSP Residual norm 3.200007280974e-07
  7933 KSP Residual norm 3.097761538709e-07
  7934 KSP Residual norm 2.846148098205e-07
  7935 KSP Residual norm 2.455667408874e-07
  7936 KSP Residual norm 2.076685197628e-07
  7937 KSP Residual norm 1.970372148185e-07
  7938 KSP Residual norm 1.907694917871e-07
  7939 KSP Residual norm 1.638082937903e-07
  7940 KSP Residual norm 1.318547075624e-07
  7941 KSP Residual norm 1.139763334807e-07
  7942 KSP Residual norm 1.091558105570e-07
  7943 KSP Residual norm 1.108382419994e-07
  7944 KSP Residual norm 1.185986605639e-07
  7945 KSP Residual norm 1.231322493752e-07
  7946 KSP Residual norm 1.350694442136e-07
  7947 KSP Residual norm 1.668124241152e-07
  7948 KSP Residual norm 1.697737705990e-07
  7949 KSP Residual norm 1.481791571280e-07
  7950 KSP Residual norm 1.336122602693e-07
  7951 KSP Residual norm 1.278035161891e-07
  7952 KSP Residual norm 1.364812274164e-07
  7953 KSP Residual norm 1.682003365398e-07
  7954 KSP Residual norm 1.922424843523e-07
  7955 KSP Residual norm 1.938892763032e-07
  7956 KSP Residual norm 1.897401422072e-07
  7957 KSP Residual norm 1.818309041194e-07
  7958 KSP Residual norm 1.734056056482e-07
  7959 KSP Residual norm 1.814756398668e-07
  7960 KSP Residual norm 2.135273397600e-07
  7961 KSP Residual norm 2.333176468566e-07
  7962 KSP Residual norm 2.276991968038e-07
  7963 KSP Residual norm 2.029040313011e-07
  7964 KSP Residual norm 1.755336410683e-07
  7965 KSP Residual norm 1.791923592825e-07
  7966 KSP Residual norm 2.088339759696e-07
  7967 KSP Residual norm 2.230199098983e-07
  7968 KSP Residual norm 2.071167771478e-07
  7969 KSP Residual norm 1.875318598556e-07
  7970 KSP Residual norm 1.619419996492e-07
  7971 KSP Residual norm 1.483905675752e-07
  7972 KSP Residual norm 1.547490085129e-07
  7973 KSP Residual norm 1.609190570457e-07
  7974 KSP Residual norm 1.550612493565e-07
  7975 KSP Residual norm 1.539941746848e-07
  7976 KSP Residual norm 1.602703531411e-07
  7977 KSP Residual norm 1.511264754163e-07
  7978 KSP Residual norm 1.235449701877e-07
  7979 KSP Residual norm 9.546949724247e-08
  7980 KSP Residual norm 7.598790560702e-08
  7981 KSP Residual norm 7.647244723344e-08
  7982 KSP Residual norm 8.865460014319e-08
  7983 KSP Residual norm 9.125079128923e-08
  7984 KSP Residual norm 8.913462237708e-08
  7985 KSP Residual norm 1.023975703858e-07
  7986 KSP Residual norm 1.251663369631e-07
  7987 KSP Residual norm 1.397533666415e-07
  7988 KSP Residual norm 1.434533474053e-07
  7989 KSP Residual norm 1.461275716979e-07
  7990 KSP Residual norm 1.591826370687e-07
  7991 KSP Residual norm 1.724244877498e-07
  7992 KSP Residual norm 1.678368835412e-07
  7993 KSP Residual norm 1.455405188043e-07
  7994 KSP Residual norm 1.303234111468e-07
  7995 KSP Residual norm 1.306510863790e-07
  7996 KSP Residual norm 1.283368283856e-07
  7997 KSP Residual norm 1.204277188283e-07
  7998 KSP Residual norm 1.268576701252e-07
  7999 KSP Residual norm 1.469297128612e-07
  8000 KSP Residual norm 1.671116107791e-07
  8001 KSP Residual norm 1.753537815876e-07
  8002 KSP Residual norm 1.772431238478e-07
  8003 KSP Residual norm 1.565539391204e-07
  8004 KSP Residual norm 1.140322963539e-07
  8005 KSP Residual norm 7.811559555552e-08
  8006 KSP Residual norm 6.104447658556e-08
  8007 KSP Residual norm 6.094287522417e-08
  8008 KSP Residual norm 7.281655256732e-08
  8009 KSP Residual norm 8.587077797006e-08
  8010 KSP Residual norm 8.320379101793e-08
  8011 KSP Residual norm 7.668827992595e-08
  8012 KSP Residual norm 7.603426475381e-08
  8013 KSP Residual norm 8.683839764122e-08
  8014 KSP Residual norm 1.022330715911e-07
  8015 KSP Residual norm 1.165681124277e-07
  8016 KSP Residual norm 1.303699478073e-07
  8017 KSP Residual norm 1.454563834765e-07
  8018 KSP Residual norm 1.493475154903e-07
  8019 KSP Residual norm 1.396388561676e-07
  8020 KSP Residual norm 1.382074658829e-07
  8021 KSP Residual norm 1.390864715770e-07
  8022 KSP Residual norm 1.186968857752e-07
  8023 KSP Residual norm 9.826574517770e-08
  8024 KSP Residual norm 9.161894053450e-08
  8025 KSP Residual norm 9.710172397342e-08
  8026 KSP Residual norm 1.196314925050e-07
  8027 KSP Residual norm 1.454906301402e-07
  8028 KSP Residual norm 1.340285048430e-07
  8029 KSP Residual norm 1.139588517959e-07
  8030 KSP Residual norm 1.091091309305e-07
  8031 KSP Residual norm 1.100497165458e-07
  8032 KSP Residual norm 1.156913601001e-07
  8033 KSP Residual norm 1.158972527887e-07
  8034 KSP Residual norm 1.012568422382e-07
  8035 KSP Residual norm 8.717569410330e-08
  8036 KSP Residual norm 8.054284322170e-08
  8037 KSP Residual norm 7.359767944540e-08
  8038 KSP Residual norm 7.089659969333e-08
  8039 KSP Residual norm 7.652456475297e-08
  8040 KSP Residual norm 8.231454629192e-08
  8041 KSP Residual norm 8.379555337591e-08
  8042 KSP Residual norm 9.250916621889e-08
  8043 KSP Residual norm 1.139626887290e-07
  8044 KSP Residual norm 1.373060794601e-07
  8045 KSP Residual norm 1.417046967103e-07
  8046 KSP Residual norm 1.268522689459e-07
  8047 KSP Residual norm 1.108684525052e-07
  8048 KSP Residual norm 1.054133741146e-07
  8049 KSP Residual norm 1.124949466187e-07
  8050 KSP Residual norm 1.341757007942e-07
  8051 KSP Residual norm 1.615135499510e-07
  8052 KSP Residual norm 1.997756557535e-07
  8053 KSP Residual norm 2.036753504143e-07
  8054 KSP Residual norm 1.711877698983e-07
  8055 KSP Residual norm 1.670618866395e-07
  8056 KSP Residual norm 1.927210219069e-07
  8057 KSP Residual norm 2.201400353626e-07
  8058 KSP Residual norm 2.425169146844e-07
  8059 KSP Residual norm 2.394827120585e-07
  8060 KSP Residual norm 2.345349567835e-07
  8061 KSP Residual norm 2.472882243308e-07
  8062 KSP Residual norm 2.698750271744e-07
  8063 KSP Residual norm 2.709028252171e-07
  8064 KSP Residual norm 2.460326686723e-07
  8065 KSP Residual norm 2.160467864260e-07
  8066 KSP Residual norm 1.866177255059e-07
  8067 KSP Residual norm 1.756026331405e-07
  8068 KSP Residual norm 1.761011557913e-07
  8069 KSP Residual norm 1.667368543158e-07
  8070 KSP Residual norm 1.542804187234e-07
  8071 KSP Residual norm 1.483758101109e-07
  8072 KSP Residual norm 1.365275472760e-07
  8073 KSP Residual norm 1.160282431619e-07
  8074 KSP Residual norm 1.038107865688e-07
  8075 KSP Residual norm 1.051844319387e-07
  8076 KSP Residual norm 1.092140814882e-07
  8077 KSP Residual norm 1.212890097750e-07
  8078 KSP Residual norm 1.331292993083e-07
  8079 KSP Residual norm 1.362942419934e-07
  8080 KSP Residual norm 1.420593966625e-07
  8081 KSP Residual norm 1.552848425667e-07
  8082 KSP Residual norm 1.732088645981e-07
  8083 KSP Residual norm 1.900681814089e-07
  8084 KSP Residual norm 2.105976939310e-07
  8085 KSP Residual norm 2.307996312757e-07
  8086 KSP Residual norm 2.296348242639e-07
  8087 KSP Residual norm 2.218764084774e-07
  8088 KSP Residual norm 2.315513531708e-07
  8089 KSP Residual norm 2.654618479296e-07
  8090 KSP Residual norm 3.033057518761e-07
  8091 KSP Residual norm 3.134767579334e-07
  8092 KSP Residual norm 3.345140306933e-07
  8093 KSP Residual norm 3.558332724883e-07
  8094 KSP Residual norm 3.222785626229e-07
  8095 KSP Residual norm 2.839742900738e-07
  8096 KSP Residual norm 2.884488628695e-07
  8097 KSP Residual norm 3.141681803454e-07
  8098 KSP Residual norm 3.268323944666e-07
  8099 KSP Residual norm 3.313589995010e-07
  8100 KSP Residual norm 3.440781076779e-07
  8101 KSP Residual norm 3.878638853320e-07
  8102 KSP Residual norm 4.483814078548e-07
  8103 KSP Residual norm 4.955122521795e-07
  8104 KSP Residual norm 4.240396262148e-07
  8105 KSP Residual norm 3.567755842840e-07
  8106 KSP Residual norm 3.183332215489e-07
  8107 KSP Residual norm 2.776523250698e-07
  8108 KSP Residual norm 2.615391851424e-07
  8109 KSP Residual norm 2.533708188430e-07
  8110 KSP Residual norm 2.445258384858e-07
  8111 KSP Residual norm 2.525561435896e-07
  8112 KSP Residual norm 2.875298513083e-07
  8113 KSP Residual norm 3.318420441954e-07
  8114 KSP Residual norm 3.520479791208e-07
  8115 KSP Residual norm 3.537100577215e-07
  8116 KSP Residual norm 3.787168144664e-07
  8117 KSP Residual norm 3.989284133489e-07
  8118 KSP Residual norm 4.047857892943e-07
  8119 KSP Residual norm 3.787039293600e-07
  8120 KSP Residual norm 3.476380507194e-07
  8121 KSP Residual norm 3.473457549216e-07
  8122 KSP Residual norm 3.595491458881e-07
  8123 KSP Residual norm 3.161135371187e-07
  8124 KSP Residual norm 2.572531837543e-07
  8125 KSP Residual norm 2.518397959188e-07
  8126 KSP Residual norm 2.681978699763e-07
  8127 KSP Residual norm 2.556508712073e-07
  8128 KSP Residual norm 2.369677709949e-07
  8129 KSP Residual norm 2.187386686073e-07
  8130 KSP Residual norm 1.961445381468e-07
  8131 KSP Residual norm 1.741003596786e-07
  8132 KSP Residual norm 1.509379091122e-07
  8133 KSP Residual norm 1.402535742283e-07
  8134 KSP Residual norm 1.446935363471e-07
  8135 KSP Residual norm 1.426270809981e-07
  8136 KSP Residual norm 1.394290549272e-07
  8137 KSP Residual norm 1.482642674560e-07
  8138 KSP Residual norm 1.664610632052e-07
  8139 KSP Residual norm 1.946620990213e-07
  8140 KSP Residual norm 2.059751991649e-07
  8141 KSP Residual norm 1.854985569190e-07
  8142 KSP Residual norm 1.499449194792e-07
  8143 KSP Residual norm 1.260383314018e-07
  8144 KSP Residual norm 1.208548393115e-07
  8145 KSP Residual norm 1.197863170633e-07
  8146 KSP Residual norm 1.165889835339e-07
  8147 KSP Residual norm 1.215780667108e-07
  8148 KSP Residual norm 1.269448372734e-07
  8149 KSP Residual norm 1.294170690179e-07
  8150 KSP Residual norm 1.445149057012e-07
  8151 KSP Residual norm 1.777319392239e-07
  8152 KSP Residual norm 1.933530880859e-07
  8153 KSP Residual norm 1.920263944173e-07
  8154 KSP Residual norm 1.923992395845e-07
  8155 KSP Residual norm 1.895717394226e-07
  8156 KSP Residual norm 2.017880179412e-07
  8157 KSP Residual norm 2.077886389624e-07
  8158 KSP Residual norm 2.008259590381e-07
  8159 KSP Residual norm 2.109835535903e-07
  8160 KSP Residual norm 2.168115519092e-07
  8161 KSP Residual norm 1.987845075219e-07
  8162 KSP Residual norm 1.818674140177e-07
  8163 KSP Residual norm 1.794404144368e-07
  8164 KSP Residual norm 1.799756363352e-07
  8165 KSP Residual norm 1.574897935970e-07
  8166 KSP Residual norm 1.395808984100e-07
  8167 KSP Residual norm 1.341819021271e-07
  8168 KSP Residual norm 1.308964137536e-07
  8169 KSP Residual norm 1.381805565467e-07
  8170 KSP Residual norm 1.559639692093e-07
  8171 KSP Residual norm 1.553107986189e-07
  8172 KSP Residual norm 1.149877105812e-07
  8173 KSP Residual norm 7.601298376647e-08
  8174 KSP Residual norm 6.067059448813e-08
  8175 KSP Residual norm 6.233121800085e-08
  8176 KSP Residual norm 7.101263683727e-08
  8177 KSP Residual norm 7.586898328109e-08
  8178 KSP Residual norm 8.123264274501e-08
  8179 KSP Residual norm 9.650960285873e-08
  8180 KSP Residual norm 1.044400738220e-07
  8181 KSP Residual norm 9.760167627437e-08
  8182 KSP Residual norm 8.890408625961e-08
  8183 KSP Residual norm 7.120159679626e-08
  8184 KSP Residual norm 5.643730011864e-08
  8185 KSP Residual norm 5.380416923686e-08
  8186 KSP Residual norm 5.923414711690e-08
  8187 KSP Residual norm 6.811310711329e-08
  8188 KSP Residual norm 7.907029114505e-08
  8189 KSP Residual norm 8.779301345165e-08
  8190 KSP Residual norm 8.437311924713e-08
  8191 KSP Residual norm 7.421676267285e-08
  8192 KSP Residual norm 6.942164441429e-08
  8193 KSP Residual norm 7.621127613684e-08
  8194 KSP Residual norm 9.511735755401e-08
  8195 KSP Residual norm 1.148240988239e-07
  8196 KSP Residual norm 1.412723876400e-07
  8197 KSP Residual norm 1.586434687392e-07
  8198 KSP Residual norm 1.663285066785e-07
  8199 KSP Residual norm 1.575386237028e-07
  8200 KSP Residual norm 1.463020740937e-07
  8201 KSP Residual norm 1.440141495552e-07
  8202 KSP Residual norm 1.352373105979e-07
  8203 KSP Residual norm 1.148568626842e-07
  8204 KSP Residual norm 9.822149067879e-08
  8205 KSP Residual norm 9.694527174724e-08
  8206 KSP Residual norm 1.087085072858e-07
  8207 KSP Residual norm 1.206499061173e-07
  8208 KSP Residual norm 1.202718427106e-07
  8209 KSP Residual norm 1.056427209528e-07
  8210 KSP Residual norm 9.437572976817e-08
  8211 KSP Residual norm 8.403274396125e-08
  8212 KSP Residual norm 7.762608003983e-08
  8213 KSP Residual norm 7.758515041912e-08
  8214 KSP Residual norm 8.010721807318e-08
  8215 KSP Residual norm 8.090906665125e-08
  8216 KSP Residual norm 7.979117035351e-08
  8217 KSP Residual norm 8.265067885007e-08
  8218 KSP Residual norm 9.695677096518e-08
  8219 KSP Residual norm 1.195296040435e-07
  8220 KSP Residual norm 1.243758775694e-07
  8221 KSP Residual norm 1.179957262768e-07
  8222 KSP Residual norm 1.093729777648e-07
  8223 KSP Residual norm 9.961961876537e-08
  8224 KSP Residual norm 9.511784430671e-08
  8225 KSP Residual norm 8.777166043946e-08
  8226 KSP Residual norm 8.490926410784e-08
  8227 KSP Residual norm 9.727262199837e-08
  8228 KSP Residual norm 1.027310090408e-07
  8229 KSP Residual norm 9.737536106588e-08
  8230 KSP Residual norm 9.309925457419e-08
  8231 KSP Residual norm 8.981188245750e-08
  8232 KSP Residual norm 9.232002152399e-08
  8233 KSP Residual norm 1.078565744450e-07
  8234 KSP Residual norm 1.296724934650e-07
  8235 KSP Residual norm 1.476976944983e-07
  8236 KSP Residual norm 1.537952946545e-07
  8237 KSP Residual norm 1.319568088519e-07
  8238 KSP Residual norm 1.106302334569e-07
  8239 KSP Residual norm 1.031548994982e-07
  8240 KSP Residual norm 1.026618981486e-07
  8241 KSP Residual norm 1.042267280452e-07
  8242 KSP Residual norm 1.002284136528e-07
  8243 KSP Residual norm 9.358322106088e-08
  8244 KSP Residual norm 8.419731402061e-08
  8245 KSP Residual norm 6.989547765926e-08
  8246 KSP Residual norm 6.343702587368e-08
  8247 KSP Residual norm 6.336961062012e-08
  8248 KSP Residual norm 6.312497386673e-08
  8249 KSP Residual norm 5.762737073744e-08
  8250 KSP Residual norm 4.721550186137e-08
  8251 KSP Residual norm 4.113217813494e-08
  8252 KSP Residual norm 4.026866469743e-08
  8253 KSP Residual norm 4.266709749115e-08
  8254 KSP Residual norm 4.410197852650e-08
  8255 KSP Residual norm 4.383023694240e-08
  8256 KSP Residual norm 4.151615264390e-08
  8257 KSP Residual norm 3.340231393819e-08
  8258 KSP Residual norm 2.456194205881e-08
  8259 KSP Residual norm 1.975458161608e-08
  8260 KSP Residual norm 1.991297408068e-08
  8261 KSP Residual norm 2.434685261917e-08
  8262 KSP Residual norm 2.610083285993e-08
  8263 KSP Residual norm 2.551883123954e-08
  8264 KSP Residual norm 2.402857926867e-08
  8265 KSP Residual norm 2.006552677903e-08
  8266 KSP Residual norm 1.798741393319e-08
  8267 KSP Residual norm 1.863390123332e-08
  8268 KSP Residual norm 1.926992568396e-08
  8269 KSP Residual norm 1.870104147413e-08
  8270 KSP Residual norm 1.836691600844e-08
  8271 KSP Residual norm 1.948640221752e-08
  8272 KSP Residual norm 2.110022367758e-08
  8273 KSP Residual norm 2.138032707085e-08
  8274 KSP Residual norm 2.016778881229e-08
  8275 KSP Residual norm 1.936066762869e-08
  8276 KSP Residual norm 1.970506982458e-08
  8277 KSP Residual norm 1.966028883015e-08
  8278 KSP Residual norm 2.020927080510e-08
  8279 KSP Residual norm 2.276556968725e-08
  8280 KSP Residual norm 2.657435749998e-08
  8281 KSP Residual norm 2.956142607119e-08
  8282 KSP Residual norm 3.034349058150e-08
  8283 KSP Residual norm 3.205613116762e-08
  8284 KSP Residual norm 3.878253489280e-08
  8285 KSP Residual norm 4.440522410959e-08
  8286 KSP Residual norm 4.193078550999e-08
  8287 KSP Residual norm 3.730499531938e-08
  8288 KSP Residual norm 3.388697139884e-08
  8289 KSP Residual norm 3.331211763528e-08
  8290 KSP Residual norm 3.518153975680e-08
  8291 KSP Residual norm 3.911463099701e-08
  8292 KSP Residual norm 4.755996046227e-08
  8293 KSP Residual norm 4.998956252225e-08
  8294 KSP Residual norm 4.169998909042e-08
  8295 KSP Residual norm 3.246486200574e-08
  8296 KSP Residual norm 2.830009644268e-08
  8297 KSP Residual norm 2.802905065427e-08
  8298 KSP Residual norm 3.096063556875e-08
  8299 KSP Residual norm 3.468881469928e-08
  8300 KSP Residual norm 3.958806687273e-08
  8301 KSP Residual norm 4.237659849484e-08
  8302 KSP Residual norm 3.962901360314e-08
  8303 KSP Residual norm 3.174762806688e-08
  8304 KSP Residual norm 2.654510228998e-08
  8305 KSP Residual norm 2.442821910470e-08
  8306 KSP Residual norm 2.380910534733e-08
  8307 KSP Residual norm 2.367634107360e-08
  8308 KSP Residual norm 2.373618844011e-08
  8309 KSP Residual norm 2.504609411018e-08
  8310 KSP Residual norm 2.403606310737e-08
  8311 KSP Residual norm 2.361349723221e-08
  8312 KSP Residual norm 2.593261448389e-08
  8313 KSP Residual norm 2.635959528567e-08
  8314 KSP Residual norm 2.267503789115e-08
  8315 KSP Residual norm 2.026199083606e-08
  8316 KSP Residual norm 2.158244561341e-08
  8317 KSP Residual norm 2.399009937714e-08
  8318 KSP Residual norm 2.350534118721e-08
  8319 KSP Residual norm 2.251341348129e-08
  8320 KSP Residual norm 2.403727218036e-08
  8321 KSP Residual norm 3.017923209658e-08
  8322 KSP Residual norm 3.550911432396e-08
  8323 KSP Residual norm 3.664888792608e-08
  8324 KSP Residual norm 3.762029036968e-08
  8325 KSP Residual norm 3.945169115973e-08
  8326 KSP Residual norm 4.129361221284e-08
  8327 KSP Residual norm 4.257422290255e-08
  8328 KSP Residual norm 4.238874472628e-08
  8329 KSP Residual norm 4.411135094167e-08
  8330 KSP Residual norm 4.472287313990e-08
  8331 KSP Residual norm 4.229951763496e-08
  8332 KSP Residual norm 3.987296857135e-08
  8333 KSP Residual norm 3.944912246029e-08
  8334 KSP Residual norm 4.218273301985e-08
  8335 KSP Residual norm 4.375191512212e-08
  8336 KSP Residual norm 4.266552268868e-08
  8337 KSP Residual norm 4.142453633145e-08
  8338 KSP Residual norm 3.607133895629e-08
  8339 KSP Residual norm 3.193495604509e-08
  8340 KSP Residual norm 3.231604594279e-08
  8341 KSP Residual norm 3.447412052267e-08
  8342 KSP Residual norm 3.530910150506e-08
  8343 KSP Residual norm 3.572343898851e-08
  8344 KSP Residual norm 3.591650277812e-08
  8345 KSP Residual norm 3.472131218209e-08
  8346 KSP Residual norm 3.218174644833e-08
  8347 KSP Residual norm 2.761170384574e-08
  8348 KSP Residual norm 2.330952777237e-08
  8349 KSP Residual norm 2.033708013109e-08
  8350 KSP Residual norm 1.778056712085e-08
  8351 KSP Residual norm 1.445143221133e-08
  8352 KSP Residual norm 1.152185072821e-08
  8353 KSP Residual norm 9.406988566318e-09
  8354 KSP Residual norm 8.137696006130e-09
  8355 KSP Residual norm 7.665397480013e-09
  8356 KSP Residual norm 7.993271988101e-09
  8357 KSP Residual norm 8.650400336091e-09
  8358 KSP Residual norm 8.920178332292e-09
  8359 KSP Residual norm 8.700017091435e-09
  8360 KSP Residual norm 8.840071300215e-09
  8361 KSP Residual norm 9.465779262939e-09
  8362 KSP Residual norm 1.044034516687e-08
  8363 KSP Residual norm 1.119605029569e-08
  8364 KSP Residual norm 1.232694360878e-08
  8365 KSP Residual norm 1.372681545630e-08
  8366 KSP Residual norm 1.477438840295e-08
  8367 KSP Residual norm 1.444729448257e-08
  8368 KSP Residual norm 1.247430958940e-08
  8369 KSP Residual norm 1.132184869726e-08
  8370 KSP Residual norm 1.229739471081e-08
  8371 KSP Residual norm 1.363373172125e-08
  8372 KSP Residual norm 1.394767074689e-08
  8373 KSP Residual norm 1.434264963171e-08
  8374 KSP Residual norm 1.580114494816e-08
  8375 KSP Residual norm 1.763876616418e-08
  8376 KSP Residual norm 1.716618873389e-08
  8377 KSP Residual norm 1.639926572063e-08
  8378 KSP Residual norm 1.839225702431e-08
  8379 KSP Residual norm 2.188934161337e-08
  8380 KSP Residual norm 2.321687326199e-08
  8381 KSP Residual norm 2.206478484448e-08
  8382 KSP Residual norm 2.219570589673e-08
  8383 KSP Residual norm 2.407753536906e-08
  8384 KSP Residual norm 2.676880379990e-08
  8385 KSP Residual norm 2.754731990861e-08
  8386 KSP Residual norm 2.693970237854e-08
  8387 KSP Residual norm 2.320835698519e-08
  8388 KSP Residual norm 1.861307118737e-08
  8389 KSP Residual norm 1.654698086189e-08
  8390 KSP Residual norm 1.715183549771e-08
  8391 KSP Residual norm 1.898931366610e-08
  8392 KSP Residual norm 1.897974741648e-08
  8393 KSP Residual norm 1.810451259311e-08
  8394 KSP Residual norm 1.882063784389e-08
  8395 KSP Residual norm 2.048551534722e-08
  8396 KSP Residual norm 2.099894763288e-08
  8397 KSP Residual norm 2.124414297958e-08
  8398 KSP Residual norm 2.127293296109e-08
  8399 KSP Residual norm 1.878565997689e-08
  8400 KSP Residual norm 1.514479548060e-08
  8401 KSP Residual norm 1.360572918165e-08
  8402 KSP Residual norm 1.368400931682e-08
  8403 KSP Residual norm 1.328973572162e-08
  8404 KSP Residual norm 1.198536521624e-08
  8405 KSP Residual norm 1.190355765915e-08
  8406 KSP Residual norm 1.427664143322e-08
  8407 KSP Residual norm 1.551621970355e-08
  8408 KSP Residual norm 1.355142212447e-08
  8409 KSP Residual norm 1.175822710583e-08
  8410 KSP Residual norm 1.094808493432e-08
  8411 KSP Residual norm 1.109341843599e-08
  8412 KSP Residual norm 1.130288646501e-08
  8413 KSP Residual norm 1.112641146277e-08
  8414 KSP Residual norm 1.230854713695e-08
  8415 KSP Residual norm 1.415195764033e-08
  8416 KSP Residual norm 1.488960749268e-08
  8417 KSP Residual norm 1.487305216294e-08
  8418 KSP Residual norm 1.355237322937e-08
  8419 KSP Residual norm 1.105176061857e-08
  8420 KSP Residual norm 9.094660784816e-09
  8421 KSP Residual norm 8.690647699884e-09
  8422 KSP Residual norm 9.045488101692e-09
  8423 KSP Residual norm 9.175694713105e-09
  8424 KSP Residual norm 8.806563455271e-09
  8425 KSP Residual norm 8.429603803819e-09
  8426 KSP Residual norm 7.781537346549e-09
  8427 KSP Residual norm 7.634704735917e-09
  8428 KSP Residual norm 8.301041341438e-09
  8429 KSP Residual norm 9.080219623757e-09
  8430 KSP Residual norm 9.407473586697e-09
  8431 KSP Residual norm 9.703104311891e-09
  8432 KSP Residual norm 9.686751005158e-09
  8433 KSP Residual norm 8.650031885896e-09
  8434 KSP Residual norm 7.661911598803e-09
  8435 KSP Residual norm 7.208642038801e-09
  8436 KSP Residual norm 6.543867576988e-09
  8437 KSP Residual norm 5.562299099623e-09
  8438 KSP Residual norm 5.082116294954e-09
  8439 KSP Residual norm 5.176891810989e-09
  8440 KSP Residual norm 4.600020792388e-09
  8441 KSP Residual norm 3.309238346058e-09
  8442 KSP Residual norm 2.772899903223e-09
  8443 KSP Residual norm 3.211277016778e-09
  8444 KSP Residual norm 4.123665107737e-09
  8445 KSP Residual norm 4.884569121277e-09
  8446 KSP Residual norm 5.155925820269e-09
  8447 KSP Residual norm 4.955884245656e-09
  8448 KSP Residual norm 4.632054120753e-09
  8449 KSP Residual norm 4.773839219961e-09
  8450 KSP Residual norm 4.863446277112e-09
  8451 KSP Residual norm 4.649036937677e-09
  8452 KSP Residual norm 4.701927965135e-09
  8453 KSP Residual norm 4.838145326785e-09
  8454 KSP Residual norm 4.620895045863e-09
  8455 KSP Residual norm 4.438555814468e-09
  8456 KSP Residual norm 4.713172493984e-09
  8457 KSP Residual norm 5.114067866779e-09
  8458 KSP Residual norm 5.319442534046e-09
  8459 KSP Residual norm 5.428258771877e-09
  8460 KSP Residual norm 5.870510989293e-09
  8461 KSP Residual norm 6.226939158978e-09
  8462 KSP Residual norm 6.475616687609e-09
  8463 KSP Residual norm 7.059575186950e-09
  8464 KSP Residual norm 8.546562774206e-09
  8465 KSP Residual norm 1.097187768387e-08
  8466 KSP Residual norm 1.358928613579e-08
  8467 KSP Residual norm 1.513514855188e-08
  8468 KSP Residual norm 1.567051114533e-08
  8469 KSP Residual norm 1.516976511259e-08
  8470 KSP Residual norm 1.480890333726e-08
  8471 KSP Residual norm 1.601608950574e-08
  8472 KSP Residual norm 1.851200281858e-08
  8473 KSP Residual norm 1.875675087744e-08
  8474 KSP Residual norm 1.754703776620e-08
  8475 KSP Residual norm 1.795735102988e-08
  8476 KSP Residual norm 1.904076093650e-08
  8477 KSP Residual norm 1.892206588956e-08
  8478 KSP Residual norm 1.685818130446e-08
  8479 KSP Residual norm 1.498358954663e-08
  8480 KSP Residual norm 1.527819060121e-08
  8481 KSP Residual norm 1.631027769306e-08
  8482 KSP Residual norm 1.636461330665e-08
  8483 KSP Residual norm 1.652288424446e-08
  8484 KSP Residual norm 1.720989876561e-08
  8485 KSP Residual norm 1.633509243624e-08
  8486 KSP Residual norm 1.527548704162e-08
  8487 KSP Residual norm 1.634725339633e-08
  8488 KSP Residual norm 1.882016253273e-08
  8489 KSP Residual norm 1.884036837716e-08
  8490 KSP Residual norm 1.764590719930e-08
  8491 KSP Residual norm 1.699476453828e-08
  8492 KSP Residual norm 1.559457790853e-08
  8493 KSP Residual norm 1.447008489702e-08
  8494 KSP Residual norm 1.494168280585e-08
  8495 KSP Residual norm 1.654161101039e-08
  8496 KSP Residual norm 1.531738931568e-08
  8497 KSP Residual norm 1.295849812908e-08
  8498 KSP Residual norm 1.216503665022e-08
  8499 KSP Residual norm 1.286245412142e-08
  8500 KSP Residual norm 1.217426284241e-08
  8501 KSP Residual norm 9.713911176753e-09
  8502 KSP Residual norm 8.036724862629e-09
  8503 KSP Residual norm 7.630826177360e-09
  8504 KSP Residual norm 7.455183699549e-09
  8505 KSP Residual norm 7.211140963642e-09
  8506 KSP Residual norm 7.252201224395e-09
  8507 KSP Residual norm 7.471180708799e-09
  8508 KSP Residual norm 7.705647022067e-09
  8509 KSP Residual norm 7.686544938263e-09
  8510 KSP Residual norm 7.618336133820e-09
  8511 KSP Residual norm 7.762326564906e-09
  8512 KSP Residual norm 7.436114625215e-09
  8513 KSP Residual norm 6.709607085936e-09
  8514 KSP Residual norm 6.485611623914e-09
  8515 KSP Residual norm 6.978433717476e-09
  8516 KSP Residual norm 6.918586373201e-09
  8517 KSP Residual norm 6.109042023633e-09
  8518 KSP Residual norm 5.651557496077e-09
  8519 KSP Residual norm 5.638029748563e-09
  8520 KSP Residual norm 5.926311005288e-09
  8521 KSP Residual norm 6.866620082785e-09
  8522 KSP Residual norm 8.301611236704e-09
  8523 KSP Residual norm 8.584752844559e-09
  8524 KSP Residual norm 8.199015324435e-09
  8525 KSP Residual norm 8.303146812502e-09
  8526 KSP Residual norm 8.871372147376e-09
  8527 KSP Residual norm 8.607928285553e-09
  8528 KSP Residual norm 7.683733727360e-09
  8529 KSP Residual norm 7.341439595283e-09
  8530 KSP Residual norm 7.506714338062e-09
  8531 KSP Residual norm 7.788576640336e-09
  8532 KSP Residual norm 8.745932012631e-09
  8533 KSP Residual norm 9.535080420107e-09
  8534 KSP Residual norm 1.002029471220e-08
  8535 KSP Residual norm 1.069270476439e-08
  8536 KSP Residual norm 1.120417072149e-08
  8537 KSP Residual norm 1.140955256246e-08
  8538 KSP Residual norm 1.162681834871e-08
  8539 KSP Residual norm 1.211753042238e-08
  8540 KSP Residual norm 1.341288284159e-08
  8541 KSP Residual norm 1.306319561759e-08
  8542 KSP Residual norm 1.157977013039e-08
  8543 KSP Residual norm 1.086868648037e-08
  8544 KSP Residual norm 9.594750235659e-09
  8545 KSP Residual norm 8.087319633715e-09
  8546 KSP Residual norm 7.883300790653e-09
  8547 KSP Residual norm 8.537811733206e-09
  8548 KSP Residual norm 9.260830424347e-09
  8549 KSP Residual norm 9.705415537720e-09
  8550 KSP Residual norm 1.033281313085e-08
  8551 KSP Residual norm 1.247440812930e-08
  8552 KSP Residual norm 1.484498435278e-08
  8553 KSP Residual norm 1.567685655437e-08
  8554 KSP Residual norm 1.649800495966e-08
  8555 KSP Residual norm 1.825774714201e-08
  8556 KSP Residual norm 2.044542249042e-08
  8557 KSP Residual norm 2.278459544561e-08
  8558 KSP Residual norm 2.303148688012e-08
  8559 KSP Residual norm 2.427680741271e-08
  8560 KSP Residual norm 2.861573199464e-08
  8561 KSP Residual norm 3.124560508552e-08
  8562 KSP Residual norm 3.050624954930e-08
  8563 KSP Residual norm 2.874388465424e-08
  8564 KSP Residual norm 2.730640345194e-08
  8565 KSP Residual norm 2.471090397732e-08
  8566 KSP Residual norm 2.180885348681e-08
  8567 KSP Residual norm 2.200718282775e-08
  8568 KSP Residual norm 2.285314781889e-08
  8569 KSP Residual norm 2.008436864495e-08
  8570 KSP Residual norm 1.900603313325e-08
  8571 KSP Residual norm 2.055024876773e-08
  8572 KSP Residual norm 2.208735929378e-08
  8573 KSP Residual norm 2.110298900966e-08
  8574 KSP Residual norm 1.860572272127e-08
  8575 KSP Residual norm 1.661260446147e-08
  8576 KSP Residual norm 1.562385856847e-08
  8577 KSP Residual norm 1.439151771550e-08
  8578 KSP Residual norm 1.193375451459e-08
  8579 KSP Residual norm 9.538997414678e-09
  8580 KSP Residual norm 8.321684963984e-09
  8581 KSP Residual norm 8.142081305677e-09
  8582 KSP Residual norm 7.672049058349e-09
  8583 KSP Residual norm 6.911533540908e-09
  8584 KSP Residual norm 6.877388044757e-09
  8585 KSP Residual norm 7.512558420142e-09
  8586 KSP Residual norm 7.242145792903e-09
  8587 KSP Residual norm 6.799092440733e-09
  8588 KSP Residual norm 7.465830086631e-09
  8589 KSP Residual norm 8.284722685059e-09
  8590 KSP Residual norm 8.008444303913e-09
  8591 KSP Residual norm 7.451882862701e-09
  8592 KSP Residual norm 7.481346620614e-09
  8593 KSP Residual norm 7.404192945530e-09
  8594 KSP Residual norm 7.889657209515e-09
  8595 KSP Residual norm 8.616494943654e-09
  8596 KSP Residual norm 9.201691549956e-09
  8597 KSP Residual norm 9.435912571966e-09
  8598 KSP Residual norm 1.019696479086e-08
  8599 KSP Residual norm 1.180096396765e-08
  8600 KSP Residual norm 1.385058477350e-08
  8601 KSP Residual norm 1.559290396232e-08
  8602 KSP Residual norm 1.728400131689e-08
  8603 KSP Residual norm 1.772020157046e-08
  8604 KSP Residual norm 1.782318946155e-08
  8605 KSP Residual norm 1.869332872295e-08
  8606 KSP Residual norm 1.873666652454e-08
  8607 KSP Residual norm 1.592594818370e-08
  8608 KSP Residual norm 1.382121453864e-08
  8609 KSP Residual norm 1.416124160283e-08
  8610 KSP Residual norm 1.557538976534e-08
  8611 KSP Residual norm 1.566524755655e-08
  8612 KSP Residual norm 1.507897330649e-08
  8613 KSP Residual norm 1.751504251488e-08
  8614 KSP Residual norm 2.079400227856e-08
  8615 KSP Residual norm 2.187646914482e-08
  8616 KSP Residual norm 2.529964911724e-08
  8617 KSP Residual norm 3.047526453547e-08
  8618 KSP Residual norm 3.137998452226e-08
  8619 KSP Residual norm 2.948241044712e-08
  8620 KSP Residual norm 2.915443757825e-08
  8621 KSP Residual norm 3.255604782130e-08
  8622 KSP Residual norm 3.545845298304e-08
  8623 KSP Residual norm 3.380254678994e-08
  8624 KSP Residual norm 3.409232743236e-08
  8625 KSP Residual norm 3.464996180449e-08
  8626 KSP Residual norm 3.443724748546e-08
  8627 KSP Residual norm 3.335419366997e-08
  8628 KSP Residual norm 3.302657231993e-08
  8629 KSP Residual norm 3.188703573811e-08
  8630 KSP Residual norm 3.083389483569e-08
  8631 KSP Residual norm 3.283410887749e-08
  8632 KSP Residual norm 3.576894383964e-08
  8633 KSP Residual norm 3.934817584805e-08
  8634 KSP Residual norm 4.376046281810e-08
  8635 KSP Residual norm 4.349236128823e-08
  8636 KSP Residual norm 4.382813403687e-08
  8637 KSP Residual norm 4.816047697331e-08
  8638 KSP Residual norm 5.065565784333e-08
  8639 KSP Residual norm 4.418458753988e-08
  8640 KSP Residual norm 3.973656874844e-08
  8641 KSP Residual norm 3.963961291907e-08
  8642 KSP Residual norm 4.016773617757e-08
  8643 KSP Residual norm 3.993852853476e-08
  8644 KSP Residual norm 4.036019753768e-08
  8645 KSP Residual norm 3.933252140571e-08
  8646 KSP Residual norm 3.665079020596e-08
  8647 KSP Residual norm 3.725606638580e-08
  8648 KSP Residual norm 4.020679236599e-08
  8649 KSP Residual norm 3.979407789950e-08
  8650 KSP Residual norm 4.180650071836e-08
  8651 KSP Residual norm 4.635436141150e-08
  8652 KSP Residual norm 4.189956773501e-08
  8653 KSP Residual norm 3.256149102354e-08
  8654 KSP Residual norm 2.850344018432e-08
  8655 KSP Residual norm 2.860751672287e-08
  8656 KSP Residual norm 2.798178030186e-08
  8657 KSP Residual norm 2.654711808733e-08
  8658 KSP Residual norm 2.731966631327e-08
  8659 KSP Residual norm 2.777210436239e-08
  8660 KSP Residual norm 2.611274222448e-08
  8661 KSP Residual norm 2.537392790214e-08
  8662 KSP Residual norm 2.665224964550e-08
  8663 KSP Residual norm 2.647219468220e-08
  8664 KSP Residual norm 2.609381737749e-08
  8665 KSP Residual norm 2.581600447717e-08
  8666 KSP Residual norm 2.407948814920e-08
  8667 KSP Residual norm 2.136445756694e-08
  8668 KSP Residual norm 2.094954659488e-08
  8669 KSP Residual norm 2.187021162031e-08
  8670 KSP Residual norm 2.213914317937e-08
  8671 KSP Residual norm 2.021765159734e-08
  8672 KSP Residual norm 1.792263589912e-08
  8673 KSP Residual norm 1.737357114984e-08
  8674 KSP Residual norm 1.745060467174e-08
  8675 KSP Residual norm 1.738355919213e-08
  8676 KSP Residual norm 1.729427197379e-08
  8677 KSP Residual norm 1.662213833634e-08
  8678 KSP Residual norm 1.645058844701e-08
  8679 KSP Residual norm 1.546872940896e-08
  8680 KSP Residual norm 1.472991501051e-08
  8681 KSP Residual norm 1.527163776937e-08
  8682 KSP Residual norm 1.547684438653e-08
  8683 KSP Residual norm 1.385760425949e-08
  8684 KSP Residual norm 1.298420226947e-08
  8685 KSP Residual norm 1.400180165602e-08
  8686 KSP Residual norm 1.460933423556e-08
  8687 KSP Residual norm 1.317071505554e-08
  8688 KSP Residual norm 1.208334284832e-08
  8689 KSP Residual norm 1.212798637391e-08
  8690 KSP Residual norm 1.188796377312e-08
  8691 KSP Residual norm 1.106319062807e-08
  8692 KSP Residual norm 1.062532561091e-08
  8693 KSP Residual norm 1.028832546383e-08
  8694 KSP Residual norm 9.246136596702e-09
  8695 KSP Residual norm 8.692531438054e-09
  8696 KSP Residual norm 8.879980578229e-09
  8697 KSP Residual norm 9.494743815125e-09
  8698 KSP Residual norm 9.094265015219e-09
  8699 KSP Residual norm 7.856703802347e-09
  8700 KSP Residual norm 7.323540871151e-09
  8701 KSP Residual norm 7.414209253069e-09
  8702 KSP Residual norm 7.806869812777e-09
  8703 KSP Residual norm 7.653981130836e-09
  8704 KSP Residual norm 7.206008639479e-09
  8705 KSP Residual norm 6.659346651871e-09
  8706 KSP Residual norm 6.449514539434e-09
  8707 KSP Residual norm 6.555927801000e-09
  8708 KSP Residual norm 6.360304013846e-09
  8709 KSP Residual norm 6.324375572827e-09
  8710 KSP Residual norm 6.914167167737e-09
  8711 KSP Residual norm 7.952823918218e-09
  8712 KSP Residual norm 8.469328814199e-09
  8713 KSP Residual norm 8.763071907624e-09
  8714 KSP Residual norm 8.949458373570e-09
  8715 KSP Residual norm 9.495082472562e-09
  8716 KSP Residual norm 9.905601014247e-09
  8717 KSP Residual norm 1.039571921986e-08
  8718 KSP Residual norm 1.175348281564e-08
  8719 KSP Residual norm 1.106119462264e-08
  8720 KSP Residual norm 9.307737703967e-09
  8721 KSP Residual norm 9.087367369325e-09
  8722 KSP Residual norm 1.040000819149e-08
  8723 KSP Residual norm 1.179162353492e-08
  8724 KSP Residual norm 1.217019560195e-08
  8725 KSP Residual norm 1.262699497078e-08
  8726 KSP Residual norm 1.382244348467e-08
  8727 KSP Residual norm 1.580860338079e-08
  8728 KSP Residual norm 1.836846554705e-08
  8729 KSP Residual norm 2.053203160464e-08
  8730 KSP Residual norm 2.115929466377e-08
  8731 KSP Residual norm 2.211630616883e-08
  8732 KSP Residual norm 2.263295269215e-08
  8733 KSP Residual norm 2.154535534531e-08
  8734 KSP Residual norm 2.028926709377e-08
  8735 KSP Residual norm 2.089412413757e-08
  8736 KSP Residual norm 2.028212340696e-08
  8737 KSP Residual norm 1.784589299546e-08
  8738 KSP Residual norm 1.740652597146e-08
  8739 KSP Residual norm 1.796039620249e-08
  8740 KSP Residual norm 1.735910416941e-08
  8741 KSP Residual norm 1.618643194710e-08
  8742 KSP Residual norm 1.449071736309e-08
  8743 KSP Residual norm 1.264398904327e-08
  8744 KSP Residual norm 1.172803569934e-08
  8745 KSP Residual norm 1.131913666728e-08
  8746 KSP Residual norm 1.133352683512e-08
  8747 KSP Residual norm 1.115022910428e-08
  8748 KSP Residual norm 1.094661249087e-08
  8749 KSP Residual norm 1.083293913269e-08
  8750 KSP Residual norm 1.066106254498e-08
  8751 KSP Residual norm 1.085458217071e-08
  8752 KSP Residual norm 1.083592597992e-08
  8753 KSP Residual norm 1.016419888544e-08
  8754 KSP Residual norm 9.689007455267e-09
  8755 KSP Residual norm 9.558300151543e-09
  8756 KSP Residual norm 9.821992875716e-09
  8757 KSP Residual norm 9.446405264589e-09
  8758 KSP Residual norm 9.076794705715e-09
  8759 KSP Residual norm 9.497456280938e-09
  8760 KSP Residual norm 1.013973495648e-08
  8761 KSP Residual norm 1.008064466860e-08
  8762 KSP Residual norm 1.012639589366e-08
  8763 KSP Residual norm 9.993459040368e-09
  8764 KSP Residual norm 9.273508631326e-09
  8765 KSP Residual norm 8.746160672665e-09
  8766 KSP Residual norm 9.002756477213e-09
  8767 KSP Residual norm 9.072079308387e-09
  8768 KSP Residual norm 8.786163540242e-09
  8769 KSP Residual norm 8.646964694318e-09
  8770 KSP Residual norm 8.858270746694e-09
  8771 KSP Residual norm 8.745321967787e-09
  8772 KSP Residual norm 7.878313545491e-09
  8773 KSP Residual norm 7.585590432371e-09
  8774 KSP Residual norm 7.950125853260e-09
  8775 KSP Residual norm 8.017899729678e-09
  8776 KSP Residual norm 7.746204084037e-09
  8777 KSP Residual norm 7.292279224567e-09
  8778 KSP Residual norm 6.498375562199e-09
  8779 KSP Residual norm 5.757787944668e-09
  8780 KSP Residual norm 5.503433897550e-09
  8781 KSP Residual norm 6.063667828958e-09
  8782 KSP Residual norm 7.009680854751e-09
  8783 KSP Residual norm 6.561489552362e-09
  8784 KSP Residual norm 5.717079011731e-09
  8785 KSP Residual norm 5.580318281549e-09
  8786 KSP Residual norm 6.038423156504e-09
  8787 KSP Residual norm 6.913291760311e-09
  8788 KSP Residual norm 7.046186016661e-09
  8789 KSP Residual norm 6.159419885598e-09
  8790 KSP Residual norm 5.866342165723e-09
  8791 KSP Residual norm 6.102991302608e-09
  8792 KSP Residual norm 6.073062363822e-09
  8793 KSP Residual norm 5.533164439893e-09
  8794 KSP Residual norm 5.140272577467e-09
  8795 KSP Residual norm 5.357033839064e-09
  8796 KSP Residual norm 5.692439098078e-09
  8797 KSP Residual norm 5.839789702656e-09
  8798 KSP Residual norm 5.916184697847e-09
  8799 KSP Residual norm 5.791867615769e-09
  8800 KSP Residual norm 5.681192983387e-09
  8801 KSP Residual norm 5.973101342865e-09
  8802 KSP Residual norm 6.135487951032e-09
  8803 KSP Residual norm 5.597697412914e-09
  8804 KSP Residual norm 5.258085450915e-09
  8805 KSP Residual norm 5.554898208534e-09
  8806 KSP Residual norm 5.654155586065e-09
  8807 KSP Residual norm 5.517182412200e-09
  8808 KSP Residual norm 5.713586061302e-09
  8809 KSP Residual norm 5.859775062928e-09
  8810 KSP Residual norm 5.918359536373e-09
  8811 KSP Residual norm 5.702756789881e-09
  8812 KSP Residual norm 5.418672824538e-09
  8813 KSP Residual norm 5.347303785582e-09
  8814 KSP Residual norm 5.280945313816e-09
  8815 KSP Residual norm 5.410978173110e-09
  8816 KSP Residual norm 5.822930740078e-09
  8817 KSP Residual norm 5.966392358796e-09
  8818 KSP Residual norm 6.314315791006e-09
  8819 KSP Residual norm 6.965501127235e-09
  8820 KSP Residual norm 6.991758856234e-09
  8821 KSP Residual norm 6.655927371855e-09
  8822 KSP Residual norm 6.794408736255e-09
  8823 KSP Residual norm 7.473087551288e-09
  8824 KSP Residual norm 8.177920261847e-09
  8825 KSP Residual norm 8.551538896785e-09
  8826 KSP Residual norm 8.432074598458e-09
  8827 KSP Residual norm 8.031511086926e-09
  8828 KSP Residual norm 7.934028317848e-09
  8829 KSP Residual norm 8.577492779089e-09
  8830 KSP Residual norm 8.969926879263e-09
  8831 KSP Residual norm 8.581716278987e-09
  8832 KSP Residual norm 8.573205944971e-09
  8833 KSP Residual norm 9.398036631434e-09
  8834 KSP Residual norm 1.002929073417e-08
  8835 KSP Residual norm 1.077516154340e-08
  8836 KSP Residual norm 1.117816949849e-08
  8837 KSP Residual norm 1.040555685475e-08
  8838 KSP Residual norm 9.363946281645e-09
  8839 KSP Residual norm 9.921778812477e-09
  8840 KSP Residual norm 1.133862024228e-08
  8841 KSP Residual norm 1.093644388299e-08
  8842 KSP Residual norm 9.534443525560e-09
  8843 KSP Residual norm 8.519108670138e-09
  8844 KSP Residual norm 8.184880070581e-09
  8845 KSP Residual norm 8.361595218092e-09
  8846 KSP Residual norm 8.971525370491e-09
  8847 KSP Residual norm 9.231987952100e-09
  8848 KSP Residual norm 8.452352276354e-09
  8849 KSP Residual norm 8.468107327617e-09
  8850 KSP Residual norm 1.017437283294e-08
  8851 KSP Residual norm 1.051088926906e-08
  8852 KSP Residual norm 9.756554606238e-09
  8853 KSP Residual norm 9.533996227423e-09
  8854 KSP Residual norm 9.766062433989e-09
  8855 KSP Residual norm 1.041250961020e-08
  8856 KSP Residual norm 1.152381663496e-08
  8857 KSP Residual norm 1.198970769580e-08
  8858 KSP Residual norm 1.115582849092e-08
  8859 KSP Residual norm 9.882118916092e-09
  8860 KSP Residual norm 9.582039925273e-09
  8861 KSP Residual norm 9.101680913825e-09
  8862 KSP Residual norm 8.247802361459e-09
  8863 KSP Residual norm 8.452875464974e-09
  8864 KSP Residual norm 1.044745064400e-08
  8865 KSP Residual norm 1.125605769927e-08
  8866 KSP Residual norm 1.106538951201e-08
  8867 KSP Residual norm 1.154689637119e-08
  8868 KSP Residual norm 1.193861148112e-08
  8869 KSP Residual norm 1.153152979257e-08
  8870 KSP Residual norm 1.041884121353e-08
  8871 KSP Residual norm 9.648173257277e-09
  8872 KSP Residual norm 9.688169239763e-09
  8873 KSP Residual norm 1.042940963428e-08
  8874 KSP Residual norm 1.088038033279e-08
  8875 KSP Residual norm 1.064003815351e-08
  8876 KSP Residual norm 1.082436694473e-08
  8877 KSP Residual norm 1.177518921408e-08
  8878 KSP Residual norm 1.253389743121e-08
  8879 KSP Residual norm 1.121423883594e-08
  8880 KSP Residual norm 9.799086166815e-09
  8881 KSP Residual norm 9.179277105744e-09
  8882 KSP Residual norm 9.359438668568e-09
  8883 KSP Residual norm 1.032969833157e-08
  8884 KSP Residual norm 1.096729022376e-08
  8885 KSP Residual norm 1.021223657770e-08
  8886 KSP Residual norm 9.082057250436e-09
  8887 KSP Residual norm 7.743266209865e-09
  8888 KSP Residual norm 6.740673141900e-09
  8889 KSP Residual norm 6.711697428115e-09
  8890 KSP Residual norm 6.629451052432e-09
  8891 KSP Residual norm 5.863162925862e-09
  8892 KSP Residual norm 5.480531375678e-09
  8893 KSP Residual norm 6.110065971890e-09
  8894 KSP Residual norm 6.402535302842e-09
  8895 KSP Residual norm 5.804036946253e-09
  8896 KSP Residual norm 5.098512708575e-09
  8897 KSP Residual norm 4.763538019831e-09
  8898 KSP Residual norm 4.561609852934e-09
  8899 KSP Residual norm 4.384639575665e-09
  8900 KSP Residual norm 5.007624296738e-09
  8901 KSP Residual norm 5.740634257442e-09
  8902 KSP Residual norm 6.028725600778e-09
  8903 KSP Residual norm 6.248132801940e-09
  8904 KSP Residual norm 6.403788411869e-09
  8905 KSP Residual norm 6.378382820048e-09
  8906 KSP Residual norm 6.372740774876e-09
  8907 KSP Residual norm 6.440930686612e-09
  8908 KSP Residual norm 6.643169964271e-09
  8909 KSP Residual norm 6.641563131942e-09
  8910 KSP Residual norm 6.848258352121e-09
  8911 KSP Residual norm 7.821386722177e-09
  8912 KSP Residual norm 8.181223823149e-09
  8913 KSP Residual norm 7.839926924337e-09
  8914 KSP Residual norm 8.285173733415e-09
  8915 KSP Residual norm 8.856781828095e-09
  8916 KSP Residual norm 9.118637914033e-09
  8917 KSP Residual norm 1.013578168771e-08
  8918 KSP Residual norm 1.103431981943e-08
  8919 KSP Residual norm 1.059673390710e-08
  8920 KSP Residual norm 1.011225571390e-08
  8921 KSP Residual norm 1.086664283089e-08
  8922 KSP Residual norm 1.147634827909e-08
  8923 KSP Residual norm 1.068532421302e-08
  8924 KSP Residual norm 9.947879087919e-09
  8925 KSP Residual norm 1.000267614393e-08
  8926 KSP Residual norm 1.055792372549e-08
  8927 KSP Residual norm 1.107486089609e-08
  8928 KSP Residual norm 1.182240267290e-08
  8929 KSP Residual norm 1.140153122020e-08
  8930 KSP Residual norm 1.091067962897e-08
  8931 KSP Residual norm 1.130830113917e-08
  8932 KSP Residual norm 1.028243427294e-08
  8933 KSP Residual norm 9.209663283185e-09
  8934 KSP Residual norm 9.136746412143e-09
  8935 KSP Residual norm 8.523789238832e-09
  8936 KSP Residual norm 8.104205649795e-09
  8937 KSP Residual norm 7.988713683889e-09
  8938 KSP Residual norm 7.311343701293e-09
  8939 KSP Residual norm 6.540306800679e-09
  8940 KSP Residual norm 6.011833471426e-09
  8941 KSP Residual norm 5.868066084289e-09
  8942 KSP Residual norm 5.521734306485e-09
  8943 KSP Residual norm 5.360918894604e-09
  8944 KSP Residual norm 6.099854173915e-09
  8945 KSP Residual norm 7.090919098140e-09
  8946 KSP Residual norm 6.698010258941e-09
  8947 KSP Residual norm 5.845522007615e-09
  8948 KSP Residual norm 5.718306337455e-09
  8949 KSP Residual norm 5.973497395893e-09
  8950 KSP Residual norm 5.797927570290e-09
  8951 KSP Residual norm 5.988017705153e-09
  8952 KSP Residual norm 6.480785731029e-09
  8953 KSP Residual norm 6.802301671933e-09
  8954 KSP Residual norm 7.019232648367e-09
  8955 KSP Residual norm 7.253276941856e-09
  8956 KSP Residual norm 7.549612480376e-09
  8957 KSP Residual norm 7.427470777762e-09
  8958 KSP Residual norm 7.389045282554e-09
  8959 KSP Residual norm 8.005225156045e-09
  8960 KSP Residual norm 8.199835575176e-09
  8961 KSP Residual norm 8.071271605404e-09
  8962 KSP Residual norm 8.314880983604e-09
  8963 KSP Residual norm 9.083435578466e-09
  8964 KSP Residual norm 9.299967340116e-09
  8965 KSP Residual norm 9.109182346784e-09
  8966 KSP Residual norm 9.231350339459e-09
  8967 KSP Residual norm 1.008066239008e-08
  8968 KSP Residual norm 1.091274763214e-08
  8969 KSP Residual norm 1.208162126878e-08
  8970 KSP Residual norm 1.345275962014e-08
  8971 KSP Residual norm 1.416539684637e-08
  8972 KSP Residual norm 1.347547353335e-08
  8973 KSP Residual norm 1.316365592777e-08
  8974 KSP Residual norm 1.299808991337e-08
  8975 KSP Residual norm 1.266271321361e-08
  8976 KSP Residual norm 1.278685988373e-08
  8977 KSP Residual norm 1.388881235412e-08
  8978 KSP Residual norm 1.372720484746e-08
  8979 KSP Residual norm 1.353334491816e-08
  8980 KSP Residual norm 1.484600601560e-08
  8981 KSP Residual norm 1.536783771726e-08
  8982 KSP Residual norm 1.350046444683e-08
  8983 KSP Residual norm 1.156995920093e-08
  8984 KSP Residual norm 1.078078423739e-08
  8985 KSP Residual norm 9.942149622360e-09
  8986 KSP Residual norm 8.250437229563e-09
  8987 KSP Residual norm 7.605593820799e-09
  8988 KSP Residual norm 7.256857712935e-09
  8989 KSP Residual norm 6.285957503240e-09
  8990 KSP Residual norm 5.690995316574e-09
  8991 KSP Residual norm 5.335773462611e-09
  8992 KSP Residual norm 4.719064087211e-09
  8993 KSP Residual norm 4.218129373993e-09
  8994 KSP Residual norm 3.852715688466e-09
  8995 KSP Residual norm 3.828490914013e-09
  8996 KSP Residual norm 3.958415532292e-09
  8997 KSP Residual norm 4.297850559253e-09
  8998 KSP Residual norm 4.748851180019e-09
  8999 KSP Residual norm 4.782934563090e-09
  9000 KSP Residual norm 4.378518816260e-09
  9001 KSP Residual norm 4.490334138402e-09
  9002 KSP Residual norm 4.781086366952e-09
  9003 KSP Residual norm 4.498035035260e-09
  9004 KSP Residual norm 4.554759114966e-09
  9005 KSP Residual norm 5.145897633476e-09
  9006 KSP Residual norm 5.206359808891e-09
  9007 KSP Residual norm 4.984743865215e-09
  9008 KSP Residual norm 5.264297901333e-09
  9009 KSP Residual norm 5.622766086028e-09
  9010 KSP Residual norm 5.780116394132e-09
  9011 KSP Residual norm 6.203588933100e-09
  9012 KSP Residual norm 7.032903306156e-09
  9013 KSP Residual norm 7.794011134703e-09
  9014 KSP Residual norm 7.042066462347e-09
  9015 KSP Residual norm 6.427722753340e-09
  9016 KSP Residual norm 6.505962593421e-09
  9017 KSP Residual norm 6.587286549508e-09
  9018 KSP Residual norm 6.583076510259e-09
  9019 KSP Residual norm 6.548508954592e-09
  9020 KSP Residual norm 6.554557773928e-09
  9021 KSP Residual norm 6.950735015205e-09
  9022 KSP Residual norm 7.262834553420e-09
  9023 KSP Residual norm 6.889948234507e-09
  9024 KSP Residual norm 6.556950226374e-09
  9025 KSP Residual norm 6.447763871540e-09
  9026 KSP Residual norm 6.553934492438e-09
  9027 KSP Residual norm 6.579650002353e-09
  9028 KSP Residual norm 6.519354770507e-09
  9029 KSP Residual norm 6.841243566278e-09
  9030 KSP Residual norm 7.694556328724e-09
  9031 KSP Residual norm 8.736268066264e-09
  9032 KSP Residual norm 8.778438278900e-09
  9033 KSP Residual norm 8.495233799953e-09
  9034 KSP Residual norm 8.514962021083e-09
  9035 KSP Residual norm 9.345519722904e-09
  9036 KSP Residual norm 9.775194409644e-09
  9037 KSP Residual norm 9.733281756655e-09
  9038 KSP Residual norm 1.017412023708e-08
  9039 KSP Residual norm 9.849904881736e-09
  9040 KSP Residual norm 9.505095041147e-09
  9041 KSP Residual norm 9.579910110702e-09
  9042 KSP Residual norm 8.377045919689e-09
  9043 KSP Residual norm 7.632925810041e-09
  9044 KSP Residual norm 8.331761501494e-09
  9045 KSP Residual norm 8.325087661837e-09
  9046 KSP Residual norm 7.218093133010e-09
  9047 KSP Residual norm 6.898588776288e-09
  9048 KSP Residual norm 7.204646951647e-09
  9049 KSP Residual norm 6.797440894492e-09
  9050 KSP Residual norm 6.114197507687e-09
  9051 KSP Residual norm 5.962188598276e-09
  9052 KSP Residual norm 5.644323553419e-09
  9053 KSP Residual norm 4.957078484639e-09
  9054 KSP Residual norm 5.269087518147e-09
  9055 KSP Residual norm 6.436218479674e-09
  9056 KSP Residual norm 6.543929385769e-09
  9057 KSP Residual norm 6.112575212140e-09
  9058 KSP Residual norm 6.494831556297e-09
  9059 KSP Residual norm 6.754226202064e-09
  9060 KSP Residual norm 6.441020260725e-09
  9061 KSP Residual norm 6.079153376993e-09
  9062 KSP Residual norm 6.476512614081e-09
  9063 KSP Residual norm 6.990778460472e-09
  9064 KSP Residual norm 7.101167547708e-09
  9065 KSP Residual norm 7.080528528840e-09
  9066 KSP Residual norm 6.763004873329e-09
  9067 KSP Residual norm 6.034657353551e-09
  9068 KSP Residual norm 5.603625204797e-09
  9069 KSP Residual norm 6.027281078923e-09
  9070 KSP Residual norm 6.144682923949e-09
  9071 KSP Residual norm 5.987245941912e-09
  9072 KSP Residual norm 6.371134615856e-09
  9073 KSP Residual norm 6.556236977999e-09
  9074 KSP Residual norm 6.499932496932e-09
  9075 KSP Residual norm 6.815367190256e-09
  9076 KSP Residual norm 6.950167215938e-09
  9077 KSP Residual norm 7.250393443833e-09
  9078 KSP Residual norm 7.979593163358e-09
  9079 KSP Residual norm 8.174469391755e-09
  9080 KSP Residual norm 7.243453912754e-09
  9081 KSP Residual norm 6.127968078814e-09
  9082 KSP Residual norm 5.362990543438e-09
  9083 KSP Residual norm 5.374306185686e-09
  9084 KSP Residual norm 5.630389519460e-09
  9085 KSP Residual norm 5.104596042544e-09
  9086 KSP Residual norm 4.260562661038e-09
  9087 KSP Residual norm 3.694674735772e-09
  9088 KSP Residual norm 3.618239288912e-09
  9089 KSP Residual norm 3.441347426990e-09
  9090 KSP Residual norm 3.088685803450e-09
  9091 KSP Residual norm 2.951446136954e-09
  9092 KSP Residual norm 2.817121461993e-09
  9093 KSP Residual norm 2.343436916737e-09
  9094 KSP Residual norm 2.100553583560e-09
  9095 KSP Residual norm 2.228765075901e-09
  9096 KSP Residual norm 2.581354504647e-09
  9097 KSP Residual norm 2.865078722409e-09
  9098 KSP Residual norm 2.934849468465e-09
  9099 KSP Residual norm 2.653877590984e-09
  9100 KSP Residual norm 2.382565432111e-09
  9101 KSP Residual norm 2.323292525524e-09
  9102 KSP Residual norm 2.490134694025e-09
  9103 KSP Residual norm 2.552679696669e-09
  9104 KSP Residual norm 2.360771813905e-09
  9105 KSP Residual norm 2.186632702773e-09
  9106 KSP Residual norm 1.965470655818e-09
  9107 KSP Residual norm 1.803022376049e-09
  9108 KSP Residual norm 1.810957988708e-09
  9109 KSP Residual norm 1.983667001897e-09
  9110 KSP Residual norm 2.010042623264e-09
  9111 KSP Residual norm 1.786534481600e-09
  9112 KSP Residual norm 1.648693393965e-09
  9113 KSP Residual norm 1.594360290461e-09
  9114 KSP Residual norm 1.487856091289e-09
  9115 KSP Residual norm 1.404220348840e-09
  9116 KSP Residual norm 1.339677712361e-09
  9117 KSP Residual norm 1.221929514088e-09
  9118 KSP Residual norm 1.070016953968e-09
  9119 KSP Residual norm 9.810183659531e-10
  9120 KSP Residual norm 8.482075398213e-10
  9121 KSP Residual norm 7.471212940289e-10
  9122 KSP Residual norm 8.545157719661e-10
  9123 KSP Residual norm 1.118286491633e-09
  9124 KSP Residual norm 1.132859138892e-09
  9125 KSP Residual norm 1.088877818916e-09
  9126 KSP Residual norm 1.046702784280e-09
  9127 KSP Residual norm 9.714554365215e-10
  9128 KSP Residual norm 9.103377319977e-10
  9129 KSP Residual norm 9.268911077925e-10
  9130 KSP Residual norm 9.520055323000e-10
  9131 KSP Residual norm 1.025678215897e-09
  9132 KSP Residual norm 1.099478061775e-09
  9133 KSP Residual norm 1.154914910228e-09
  9134 KSP Residual norm 1.383770832367e-09
  9135 KSP Residual norm 1.726958260805e-09
  9136 KSP Residual norm 1.994891093759e-09
  9137 KSP Residual norm 2.026502062193e-09
  9138 KSP Residual norm 2.048590800352e-09
  9139 KSP Residual norm 2.226349026058e-09
  9140 KSP Residual norm 2.326931657849e-09
  9141 KSP Residual norm 2.245902734368e-09
  9142 KSP Residual norm 2.390890697594e-09
  9143 KSP Residual norm 2.611697552978e-09
  9144 KSP Residual norm 2.920215938974e-09
  9145 KSP Residual norm 3.257477704995e-09
  9146 KSP Residual norm 3.303606886347e-09
  9147 KSP Residual norm 3.287647011625e-09
  9148 KSP Residual norm 3.371917997931e-09
  9149 KSP Residual norm 3.461009245521e-09
  9150 KSP Residual norm 3.370989404154e-09
  9151 KSP Residual norm 3.100604909983e-09
  9152 KSP Residual norm 2.816140524451e-09
  9153 KSP Residual norm 2.538626828450e-09
  9154 KSP Residual norm 2.268399284911e-09
  9155 KSP Residual norm 2.136577220729e-09
  9156 KSP Residual norm 2.240530814013e-09
  9157 KSP Residual norm 2.284311817918e-09
  9158 KSP Residual norm 2.269589360641e-09
  9159 KSP Residual norm 2.346151724150e-09
  9160 KSP Residual norm 2.226447496905e-09
  9161 KSP Residual norm 1.967815089744e-09
  9162 KSP Residual norm 1.971012873278e-09
  9163 KSP Residual norm 2.037360393319e-09
  9164 KSP Residual norm 1.894930719186e-09
  9165 KSP Residual norm 1.749586592049e-09
  9166 KSP Residual norm 1.736587816450e-09
  9167 KSP Residual norm 1.661348397228e-09
  9168 KSP Residual norm 1.554895749154e-09
  9169 KSP Residual norm 1.542019658538e-09
  9170 KSP Residual norm 1.633095762697e-09
  9171 KSP Residual norm 1.685467876935e-09
  9172 KSP Residual norm 1.737387330953e-09
  9173 KSP Residual norm 2.038401001808e-09
  9174 KSP Residual norm 2.126492649159e-09
  9175 KSP Residual norm 2.042866639433e-09
  9176 KSP Residual norm 2.034525121408e-09
  9177 KSP Residual norm 1.846641119188e-09
  9178 KSP Residual norm 1.477907952263e-09
  9179 KSP Residual norm 1.253468339307e-09
  9180 KSP Residual norm 1.229849585367e-09
  9181 KSP Residual norm 1.289266450210e-09
  9182 KSP Residual norm 1.257995030111e-09
  9183 KSP Residual norm 1.147066358982e-09
  9184 KSP Residual norm 1.141482193748e-09
  9185 KSP Residual norm 1.144103903514e-09
  9186 KSP Residual norm 1.188107622830e-09
  9187 KSP Residual norm 1.390988440840e-09
  9188 KSP Residual norm 1.598891248735e-09
  9189 KSP Residual norm 1.668884971982e-09
  9190 KSP Residual norm 1.733422675643e-09
  9191 KSP Residual norm 1.795903930528e-09
  9192 KSP Residual norm 1.843991671217e-09
  9193 KSP Residual norm 1.617228624086e-09
  9194 KSP Residual norm 1.320076138845e-09
  9195 KSP Residual norm 1.119392127417e-09
  9196 KSP Residual norm 1.078832826890e-09
  9197 KSP Residual norm 1.202955825762e-09
  9198 KSP Residual norm 1.385727942518e-09
  9199 KSP Residual norm 1.545100689556e-09
  9200 KSP Residual norm 1.553147822993e-09
  9201 KSP Residual norm 1.407780716894e-09
  9202 KSP Residual norm 1.319202125322e-09
  9203 KSP Residual norm 1.284179473673e-09
  9204 KSP Residual norm 1.133994659329e-09
  9205 KSP Residual norm 1.043090474923e-09
  9206 KSP Residual norm 1.012998637507e-09
  9207 KSP Residual norm 9.147865915259e-10
  9208 KSP Residual norm 8.662064803857e-10
  9209 KSP Residual norm 9.640338270348e-10
  9210 KSP Residual norm 1.157010413416e-09
  9211 KSP Residual norm 1.295477554805e-09
  9212 KSP Residual norm 1.213286263685e-09
  9213 KSP Residual norm 1.166362088055e-09
  9214 KSP Residual norm 1.148536595886e-09
  9215 KSP Residual norm 1.047757066862e-09
  9216 KSP Residual norm 9.668331522612e-10
  9217 KSP Residual norm 9.782526659750e-10
  9218 KSP Residual norm 9.824584250404e-10
  9219 KSP Residual norm 9.689849685875e-10
  9220 KSP Residual norm 1.015870979449e-09
  9221 KSP Residual norm 9.916293343467e-10
  9222 KSP Residual norm 9.312685438198e-10
  9223 KSP Residual norm 9.637451218235e-10
  9224 KSP Residual norm 1.039770085774e-09
  9225 KSP Residual norm 9.426988282807e-10
  9226 KSP Residual norm 7.409694168904e-10
  9227 KSP Residual norm 6.356330396652e-10
  1 KSP Residual norm 1.849649014371e+02
    Residual norms for fieldsplit_FE_split_ solve.
    0 KSP Residual norm 1.027182122453e-05
    1 KSP Residual norm 3.135569947779e-06
    2 KSP Residual norm 2.180419532782e-06
    3 KSP Residual norm 1.528519061651e-06
    4 KSP Residual norm 1.229732258843e-06
    5 KSP Residual norm 9.829524791222e-07
    6 KSP Residual norm 8.687617524913e-07
    7 KSP Residual norm 7.696035207235e-07
    8 KSP Residual norm 6.785231901611e-07
    9 KSP Residual norm 5.756887785283e-07
   10 KSP Residual norm 5.293207094341e-07
   11 KSP Residual norm 4.866978594837e-07
   12 KSP Residual norm 4.267227044550e-07
   13 KSP Residual norm 4.241444967014e-07
   14 KSP Residual norm 3.853573900604e-07
   15 KSP Residual norm 3.584900443244e-07
   16 KSP Residual norm 3.389319354301e-07
   17 KSP Residual norm 3.208807162881e-07
   18 KSP Residual norm 3.011082111084e-07
   19 KSP Residual norm 2.861796734103e-07
   20 KSP Residual norm 2.613993785089e-07
   21 KSP Residual norm 2.510683050321e-07
   22 KSP Residual norm 2.599306815389e-07
   23 KSP Residual norm 2.339467745424e-07
   24 KSP Residual norm 2.153030888102e-07
   25 KSP Residual norm 2.150286128282e-07
   26 KSP Residual norm 2.167816703824e-07
   27 KSP Residual norm 2.059322802772e-07
   28 KSP Residual norm 2.049453923559e-07
   29 KSP Residual norm 1.932049574976e-07
   30 KSP Residual norm 1.898996913719e-07
   31 KSP Residual norm 1.872900297333e-07
   32 KSP Residual norm 1.781915323925e-07
   33 KSP Residual norm 1.751942709500e-07
   34 KSP Residual norm 1.663251505079e-07
   35 KSP Residual norm 1.553556259625e-07
   36 KSP Residual norm 1.567367881883e-07
   37 KSP Residual norm 1.532926291474e-07
   38 KSP Residual norm 1.422081410320e-07
   39 KSP Residual norm 1.436680450260e-07
   40 KSP Residual norm 1.440821625669e-07
   41 KSP Residual norm 1.340774443381e-07
   42 KSP Residual norm 1.318169190753e-07
   43 KSP Residual norm 1.257948948114e-07
   44 KSP Residual norm 1.231017575923e-07
   45 KSP Residual norm 1.215855396398e-07
   46 KSP Residual norm 1.174314784248e-07
   47 KSP Residual norm 1.182643390149e-07
   48 KSP Residual norm 1.146322844711e-07
   49 KSP Residual norm 1.095530645158e-07
   50 KSP Residual norm 1.086851045267e-07
   51 KSP Residual norm 1.129053703069e-07
   52 KSP Residual norm 1.144586281434e-07
   53 KSP Residual norm 1.088946076931e-07
   54 KSP Residual norm 1.062454716223e-07
   55 KSP Residual norm 1.080839392455e-07
   56 KSP Residual norm 1.034709791240e-07
   57 KSP Residual norm 9.990590423722e-08
   58 KSP Residual norm 1.021211873416e-07
   59 KSP Residual norm 9.717776076258e-08
   60 KSP Residual norm 9.203825395114e-08
   61 KSP Residual norm 9.266453982191e-08
   62 KSP Residual norm 8.970140008495e-08
   63 KSP Residual norm 9.164070446014e-08
   64 KSP Residual norm 9.080730275091e-08
   65 KSP Residual norm 8.884866186306e-08
   66 KSP Residual norm 8.492764404537e-08
   67 KSP Residual norm 8.110252263730e-08
   68 KSP Residual norm 7.790954181068e-08
   69 KSP Residual norm 7.973621974751e-08
   70 KSP Residual norm 8.143063857031e-08
   71 KSP Residual norm 7.739178000635e-08
   72 KSP Residual norm 7.503156097489e-08
   73 KSP Residual norm 7.547735326047e-08
   74 KSP Residual norm 7.484714618236e-08
   75 KSP Residual norm 7.748312439773e-08
   76 KSP Residual norm 7.807508092519e-08
   77 KSP Residual norm 7.572977466303e-08
   78 KSP Residual norm 7.665209770868e-08
   79 KSP Residual norm 7.431223627349e-08
   80 KSP Residual norm 7.141901261878e-08
   81 KSP Residual norm 7.196469096316e-08
   82 KSP Residual norm 7.120233758807e-08
   83 KSP Residual norm 7.029697994445e-08
   84 KSP Residual norm 6.718931484299e-08
   85 KSP Residual norm 6.809929072658e-08
   86 KSP Residual norm 6.459895170316e-08
   87 KSP Residual norm 6.393548183799e-08
   88 KSP Residual norm 6.528170282680e-08
   89 KSP Residual norm 6.455327969881e-08
   90 KSP Residual norm 6.395969408471e-08
   91 KSP Residual norm 6.047775089351e-08
   92 KSP Residual norm 6.014475855054e-08
   93 KSP Residual norm 6.083694172663e-08
   94 KSP Residual norm 5.903994958624e-08
   95 KSP Residual norm 5.915849060716e-08
   96 KSP Residual norm 5.801215315670e-08
   97 KSP Residual norm 5.553473899722e-08
   98 KSP Residual norm 5.674557082287e-08
   99 KSP Residual norm 5.783602905141e-08
  100 KSP Residual norm 5.834648896713e-08
  101 KSP Residual norm 6.101552128335e-08
  102 KSP Residual norm 5.918703686799e-08
  103 KSP Residual norm 5.595872601118e-08
  104 KSP Residual norm 5.753784803382e-08
  105 KSP Residual norm 5.502063107439e-08
  106 KSP Residual norm 5.437143512765e-08
  107 KSP Residual norm 5.289551493423e-08
  108 KSP Residual norm 5.408424858808e-08
  109 KSP Residual norm 5.251163546873e-08
  110 KSP Residual norm 5.101083421682e-08
  111 KSP Residual norm 5.105373554003e-08
  112 KSP Residual norm 5.179194383344e-08
  113 KSP Residual norm 5.221347823222e-08
  114 KSP Residual norm 4.920554168357e-08
  115 KSP Residual norm 4.968787718031e-08
  116 KSP Residual norm 4.901941039863e-08
  117 KSP Residual norm 4.729910682551e-08
  118 KSP Residual norm 4.732727932420e-08
  119 KSP Residual norm 4.788431228088e-08
  120 KSP Residual norm 4.709199891744e-08
  121 KSP Residual norm 4.633174023376e-08
  122 KSP Residual norm 4.575146306337e-08
  123 KSP Residual norm 4.675273545847e-08
  124 KSP Residual norm 4.808797552367e-08
  125 KSP Residual norm 4.683196648045e-08
  126 KSP Residual norm 4.805455052599e-08
  127 KSP Residual norm 4.782203895247e-08
  128 KSP Residual norm 4.638040072176e-08
  129 KSP Residual norm 4.406285137898e-08
  130 KSP Residual norm 4.554618434120e-08
  131 KSP Residual norm 4.412076681475e-08
  132 KSP Residual norm 4.257102684841e-08
  133 KSP Residual norm 4.360630524041e-08
  134 KSP Residual norm 4.439592322709e-08
  135 KSP Residual norm 4.371933550721e-08
  136 KSP Residual norm 4.314718814149e-08
  137 KSP Residual norm 4.203693595073e-08
  138 KSP Residual norm 4.160989517548e-08
  139 KSP Residual norm 4.100637862429e-08
  140 KSP Residual norm 4.021812214559e-08
  141 KSP Residual norm 3.841786540700e-08
  142 KSP Residual norm 3.985913676947e-08
  143 KSP Residual norm 4.049623994462e-08
  144 KSP Residual norm 3.893108342042e-08
  145 KSP Residual norm 3.868790068774e-08
  146 KSP Residual norm 3.825368674076e-08
  147 KSP Residual norm 3.990337986027e-08
  148 KSP Residual norm 4.059908155370e-08
  149 KSP Residual norm 3.941119419482e-08
  150 KSP Residual norm 3.998620761870e-08
  151 KSP Residual norm 4.002546814452e-08
  152 KSP Residual norm 3.755788414789e-08
  153 KSP Residual norm 3.742454519881e-08
  154 KSP Residual norm 3.711512103196e-08
  155 KSP Residual norm 3.684895633420e-08
  156 KSP Residual norm 3.685468343218e-08
  157 KSP Residual norm 3.681172090059e-08
  158 KSP Residual norm 3.625658052374e-08
  159 KSP Residual norm 3.614374521410e-08
  160 KSP Residual norm 3.675609152693e-08
  161 KSP Residual norm 3.576400026546e-08
  162 KSP Residual norm 3.524711834329e-08
  163 KSP Residual norm 3.439177764481e-08
  164 KSP Residual norm 3.393816437112e-08
  165 KSP Residual norm 3.337629608870e-08
  166 KSP Residual norm 3.377495388660e-08
  167 KSP Residual norm 3.474391815589e-08
  168 KSP Residual norm 3.470287882486e-08
  169 KSP Residual norm 3.410072023569e-08
  170 KSP Residual norm 3.317145997178e-08
  171 KSP Residual norm 3.289681793645e-08
  172 KSP Residual norm 3.547991630953e-08
  173 KSP Residual norm 3.581285694693e-08
  174 KSP Residual norm 3.354468381827e-08
  175 KSP Residual norm 3.330337680098e-08
  176 KSP Residual norm 3.339832234604e-08
  177 KSP Residual norm 3.273556581602e-08
  178 KSP Residual norm 3.189982581599e-08
  179 KSP Residual norm 3.118707613203e-08
  180 KSP Residual norm 3.190723390938e-08
  181 KSP Residual norm 3.301913092525e-08
  182 KSP Residual norm 3.241616565362e-08
  183 KSP Residual norm 3.088824535361e-08
  184 KSP Residual norm 3.175601876213e-08
  185 KSP Residual norm 3.185925296383e-08
  186 KSP Residual norm 3.071037294847e-08
  187 KSP Residual norm 3.045086297402e-08
  188 KSP Residual norm 2.979242520953e-08
  189 KSP Residual norm 2.894078844296e-08
  190 KSP Residual norm 3.002052268813e-08
  191 KSP Residual norm 2.981898263867e-08
  192 KSP Residual norm 2.936316221760e-08
  193 KSP Residual norm 3.021707023498e-08
  194 KSP Residual norm 3.031320787410e-08
  195 KSP Residual norm 3.044946501393e-08
  196 KSP Residual norm 3.031926106429e-08
  197 KSP Residual norm 3.221430437011e-08
  198 KSP Residual norm 3.038875346630e-08
  199 KSP Residual norm 2.987253524714e-08
  200 KSP Residual norm 2.973047891211e-08
  201 KSP Residual norm 2.847470306728e-08
  202 KSP Residual norm 2.769231503652e-08
  203 KSP Residual norm 2.933560992098e-08
  204 KSP Residual norm 2.877064307209e-08
  205 KSP Residual norm 2.916569134710e-08
  206 KSP Residual norm 2.874782000253e-08
  207 KSP Residual norm 2.877952534673e-08
  208 KSP Residual norm 2.759301348296e-08
  209 KSP Residual norm 2.702767920242e-08
  210 KSP Residual norm 2.761499970041e-08
  211 KSP Residual norm 2.713224970490e-08
  212 KSP Residual norm 2.638187630207e-08
  213 KSP Residual norm 2.588786843550e-08
  214 KSP Residual norm 2.649200860731e-08
  215 KSP Residual norm 2.677505880424e-08
  216 KSP Residual norm 2.658569524878e-08
  217 KSP Residual norm 2.690092378488e-08
  218 KSP Residual norm 2.665102352370e-08
  219 KSP Residual norm 2.720769423327e-08
  220 KSP Residual norm 2.744424052180e-08
  221 KSP Residual norm 2.672401670159e-08
  222 KSP Residual norm 2.717697366328e-08
  223 KSP Residual norm 2.756633455568e-08
  224 KSP Residual norm 2.629991517984e-08
  225 KSP Residual norm 2.613549070088e-08
  226 KSP Residual norm 2.561197918867e-08
  227 KSP Residual norm 2.530506944853e-08
  228 KSP Residual norm 2.563545980560e-08
  229 KSP Residual norm 2.582825497646e-08
  230 KSP Residual norm 2.508499061822e-08
  231 KSP Residual norm 2.536361630489e-08
  232 KSP Residual norm 2.572398586300e-08
  233 KSP Residual norm 2.424315094943e-08
  234 KSP Residual norm 2.360929803953e-08
  235 KSP Residual norm 2.456493828502e-08
  236 KSP Residual norm 2.479193950223e-08
  237 KSP Residual norm 2.367904467396e-08
  238 KSP Residual norm 2.445201181013e-08
  239 KSP Residual norm 2.372867018510e-08
  240 KSP Residual norm 2.359013173829e-08
  241 KSP Residual norm 2.456875813499e-08
  242 KSP Residual norm 2.463467535232e-08
  243 KSP Residual norm 2.373462879103e-08
  244 KSP Residual norm 2.402524293089e-08
  245 KSP Residual norm 2.427927343422e-08
  246 KSP Residual norm 2.436440506256e-08
  247 KSP Residual norm 2.423414959700e-08
  248 KSP Residual norm 2.337977647049e-08
  249 KSP Residual norm 2.307142842133e-08
  250 KSP Residual norm 2.298823072682e-08
  251 KSP Residual norm 2.305600356361e-08
  252 KSP Residual norm 2.324155041362e-08
  253 KSP Residual norm 2.298441642898e-08
  254 KSP Residual norm 2.332875861016e-08
  255 KSP Residual norm 2.399095557238e-08
  256 KSP Residual norm 2.520205815115e-08
  257 KSP Residual norm 2.565245234099e-08
  258 KSP Residual norm 2.764462107850e-08
  259 KSP Residual norm 3.040508746916e-08
  260 KSP Residual norm 3.459548723400e-08
  261 KSP Residual norm 4.129663295425e-08
  262 KSP Residual norm 5.001562019471e-08
  263 KSP Residual norm 6.192932213022e-08
  264 KSP Residual norm 7.957301695971e-08
  265 KSP Residual norm 1.004214579770e-07
  266 KSP Residual norm 1.174729609942e-07
  267 KSP Residual norm 1.246051516797e-07
  268 KSP Residual norm 1.226333849560e-07
  269 KSP Residual norm 1.041753836034e-07
  270 KSP Residual norm 8.266487400295e-08
  271 KSP Residual norm 6.459448295187e-08
  272 KSP Residual norm 4.767446738456e-08
  273 KSP Residual norm 3.635518413777e-08
  274 KSP Residual norm 3.040891301132e-08
  275 KSP Residual norm 2.999870923414e-08
  276 KSP Residual norm 3.033856829606e-08
  277 KSP Residual norm 3.033505821160e-08
  278 KSP Residual norm 2.989050704971e-08
  279 KSP Residual norm 2.538400038591e-08
  280 KSP Residual norm 2.058554366105e-08
  281 KSP Residual norm 1.542916393016e-08
  282 KSP Residual norm 1.248705137582e-08
  283 KSP Residual norm 1.069833215571e-08
  284 KSP Residual norm 9.985197354920e-09
  285 KSP Residual norm 9.842500827831e-09
  286 KSP Residual norm 9.329517439693e-09
  287 KSP Residual norm 9.274069567627e-09
  288 KSP Residual norm 8.967858460002e-09
  289 KSP Residual norm 9.183147163129e-09
  290 KSP Residual norm 9.200056208671e-09
  291 KSP Residual norm 8.732204420993e-09
  292 KSP Residual norm 7.876738027203e-09
  293 KSP Residual norm 6.840063569219e-09
  294 KSP Residual norm 6.452530492864e-09
  295 KSP Residual norm 6.389602001607e-09
  296 KSP Residual norm 6.360200975562e-09
  297 KSP Residual norm 6.297155859788e-09
  298 KSP Residual norm 5.708872790872e-09
  299 KSP Residual norm 4.841477192084e-09
  300 KSP Residual norm 4.498586927442e-09
  301 KSP Residual norm 4.442895790317e-09
  302 KSP Residual norm 4.464361027179e-09
  303 KSP Residual norm 4.194037706882e-09
  304 KSP Residual norm 3.937500911657e-09
  305 KSP Residual norm 3.781863635271e-09
  306 KSP Residual norm 3.917849883064e-09
  307 KSP Residual norm 3.803545205399e-09
  308 KSP Residual norm 3.575620156785e-09
  309 KSP Residual norm 3.219568643605e-09
  310 KSP Residual norm 3.126060864842e-09
  311 KSP Residual norm 3.313203994886e-09
  312 KSP Residual norm 3.636566666435e-09
  313 KSP Residual norm 3.964845689608e-09
  314 KSP Residual norm 3.815086572108e-09
  315 KSP Residual norm 3.398287547657e-09
  316 KSP Residual norm 3.155270497494e-09
  317 KSP Residual norm 3.120531941015e-09
  318 KSP Residual norm 3.072529914245e-09
  319 KSP Residual norm 2.875715794189e-09
  320 KSP Residual norm 2.633338659307e-09
  321 KSP Residual norm 2.486013309889e-09
  322 KSP Residual norm 2.564768273032e-09
  323 KSP Residual norm 2.549370175215e-09
  324 KSP Residual norm 2.281623714518e-09
  325 KSP Residual norm 2.050492141000e-09
  326 KSP Residual norm 1.855284575961e-09
  327 KSP Residual norm 1.780505753230e-09
  328 KSP Residual norm 1.672576359477e-09
  329 KSP Residual norm 1.591052539076e-09
  330 KSP Residual norm 1.543471457247e-09
  331 KSP Residual norm 1.592723876594e-09
  332 KSP Residual norm 1.603492920762e-09
  333 KSP Residual norm 1.574349854565e-09
  334 KSP Residual norm 1.633182713633e-09
  335 KSP Residual norm 1.723932629493e-09
  336 KSP Residual norm 1.818169620960e-09
  337 KSP Residual norm 1.710486648312e-09
  338 KSP Residual norm 1.608096129330e-09
  339 KSP Residual norm 1.587834958353e-09
  340 KSP Residual norm 1.566214069409e-09
  341 KSP Residual norm 1.492325745182e-09
  342 KSP Residual norm 1.311296843707e-09
  343 KSP Residual norm 1.201421360760e-09
  344 KSP Residual norm 1.242474044972e-09
  345 KSP Residual norm 1.303015100243e-09
  346 KSP Residual norm 1.301463807014e-09
  347 KSP Residual norm 1.295320567357e-09
  348 KSP Residual norm 1.386355882704e-09
  349 KSP Residual norm 1.489909370944e-09
  350 KSP Residual norm 1.570403083463e-09
  351 KSP Residual norm 1.618101985373e-09
  352 KSP Residual norm 1.685805874585e-09
  353 KSP Residual norm 1.747971773746e-09
  354 KSP Residual norm 1.817920635600e-09
  355 KSP Residual norm 1.838629812996e-09
  356 KSP Residual norm 1.837717242627e-09
  357 KSP Residual norm 1.922683898295e-09
  358 KSP Residual norm 1.908712791625e-09
  359 KSP Residual norm 1.849908180510e-09
  360 KSP Residual norm 1.856780413631e-09
  361 KSP Residual norm 1.842267171653e-09
  362 KSP Residual norm 1.746348805008e-09
  363 KSP Residual norm 1.749518357920e-09
  364 KSP Residual norm 1.939475822199e-09
  365 KSP Residual norm 1.990414477599e-09
  366 KSP Residual norm 1.980692673368e-09
  367 KSP Residual norm 1.886053185584e-09
  368 KSP Residual norm 1.781946469507e-09
  369 KSP Residual norm 1.774261751797e-09
  370 KSP Residual norm 1.804078271165e-09
  371 KSP Residual norm 1.745686706072e-09
  372 KSP Residual norm 1.731852936549e-09
  373 KSP Residual norm 1.754926617127e-09
  374 KSP Residual norm 1.779046260348e-09
  375 KSP Residual norm 1.745327121629e-09
  376 KSP Residual norm 1.771959236451e-09
  377 KSP Residual norm 1.827974420788e-09
  378 KSP Residual norm 1.849788084290e-09
  379 KSP Residual norm 1.941969624488e-09
  380 KSP Residual norm 2.014370599936e-09
  381 KSP Residual norm 2.030828617532e-09
  382 KSP Residual norm 1.905719257138e-09
  383 KSP Residual norm 1.863775147410e-09
  384 KSP Residual norm 1.941510721061e-09
  385 KSP Residual norm 1.974216393942e-09
  386 KSP Residual norm 1.931772303021e-09
  387 KSP Residual norm 1.899391183354e-09
  388 KSP Residual norm 1.886673499425e-09
  389 KSP Residual norm 1.878559022648e-09
  390 KSP Residual norm 1.837604105003e-09
  391 KSP Residual norm 1.740366082192e-09
  392 KSP Residual norm 1.708352566906e-09
  393 KSP Residual norm 1.787417448975e-09
  394 KSP Residual norm 1.816237088262e-09
  395 KSP Residual norm 1.691668465071e-09
  396 KSP Residual norm 1.560944830824e-09
  397 KSP Residual norm 1.515334735527e-09
  398 KSP Residual norm 1.568661395616e-09
  399 KSP Residual norm 1.548240848714e-09
  400 KSP Residual norm 1.511697795135e-09
  401 KSP Residual norm 1.487092179622e-09
  402 KSP Residual norm 1.478493260143e-09
  403 KSP Residual norm 1.538102653313e-09
  404 KSP Residual norm 1.609378381870e-09
  405 KSP Residual norm 1.664672082005e-09
  406 KSP Residual norm 1.686998752671e-09
  407 KSP Residual norm 1.595392958096e-09
  408 KSP Residual norm 1.516896889051e-09
  409 KSP Residual norm 1.511085515858e-09
  410 KSP Residual norm 1.626436837978e-09
  411 KSP Residual norm 1.606467539436e-09
  412 KSP Residual norm 1.629402219182e-09
  413 KSP Residual norm 1.721446700057e-09
  414 KSP Residual norm 1.818687216231e-09
  415 KSP Residual norm 1.805534605090e-09
  416 KSP Residual norm 1.754658310712e-09
  417 KSP Residual norm 1.773616942646e-09
  418 KSP Residual norm 1.941262952136e-09
  419 KSP Residual norm 1.968575814969e-09
  420 KSP Residual norm 1.935639538944e-09
  421 KSP Residual norm 1.953700286188e-09
  422 KSP Residual norm 2.020298940926e-09
  423 KSP Residual norm 1.999535508313e-09
  424 KSP Residual norm 2.114232391751e-09
  425 KSP Residual norm 2.020817403734e-09
  426 KSP Residual norm 1.881705180294e-09
  427 KSP Residual norm 1.882372586623e-09
  428 KSP Residual norm 1.935463919864e-09
  429 KSP Residual norm 1.949854098796e-09
  430 KSP Residual norm 1.927157285058e-09
  431 KSP Residual norm 1.920417265886e-09
  432 KSP Residual norm 2.010685319396e-09
  433 KSP Residual norm 2.078288135969e-09
  434 KSP Residual norm 2.114180100144e-09
  435 KSP Residual norm 2.012030914193e-09
  436 KSP Residual norm 1.997518451721e-09
  437 KSP Residual norm 1.956631368086e-09
  438 KSP Residual norm 1.847118497113e-09
  439 KSP Residual norm 1.730297426468e-09
  440 KSP Residual norm 1.748800420223e-09
  441 KSP Residual norm 1.828205065436e-09
  442 KSP Residual norm 1.760760033573e-09
  443 KSP Residual norm 1.724366337066e-09
  444 KSP Residual norm 1.757107798255e-09
  445 KSP Residual norm 1.831884364702e-09
  446 KSP Residual norm 1.804891154466e-09
  447 KSP Residual norm 1.716546566462e-09
  448 KSP Residual norm 1.618879910544e-09
  449 KSP Residual norm 1.579585771131e-09
  450 KSP Residual norm 1.581266394147e-09
  451 KSP Residual norm 1.553069056692e-09
  452 KSP Residual norm 1.510694874612e-09
  453 KSP Residual norm 1.450687087999e-09
  454 KSP Residual norm 1.418031117917e-09
  455 KSP Residual norm 1.381905481894e-09
  456 KSP Residual norm 1.336416913484e-09
  457 KSP Residual norm 1.291136597738e-09
  458 KSP Residual norm 1.296581485943e-09
  459 KSP Residual norm 1.304381643340e-09
  460 KSP Residual norm 1.320574612072e-09
  461 KSP Residual norm 1.395516588061e-09
  462 KSP Residual norm 1.412209599932e-09
  463 KSP Residual norm 1.400047814931e-09
  464 KSP Residual norm 1.353600507813e-09
  465 KSP Residual norm 1.416640083739e-09
  466 KSP Residual norm 1.445244139346e-09
  467 KSP Residual norm 1.433493018296e-09
  468 KSP Residual norm 1.435449995915e-09
  469 KSP Residual norm 1.429070518235e-09
  470 KSP Residual norm 1.388899906388e-09
  471 KSP Residual norm 1.395259291383e-09
  472 KSP Residual norm 1.392606153754e-09
  473 KSP Residual norm 1.396971891755e-09
  474 KSP Residual norm 1.382745441360e-09
  475 KSP Residual norm 1.408922664777e-09
  476 KSP Residual norm 1.411789277377e-09
  477 KSP Residual norm 1.361735404197e-09
  478 KSP Residual norm 1.296947723973e-09
  479 KSP Residual norm 1.240461882888e-09
  480 KSP Residual norm 1.248819724338e-09
  481 KSP Residual norm 1.322112290182e-09
  482 KSP Residual norm 1.343629557443e-09
  483 KSP Residual norm 1.324575543601e-09
  484 KSP Residual norm 1.309845665022e-09
  485 KSP Residual norm 1.314171697703e-09
  486 KSP Residual norm 1.297011033591e-09
  487 KSP Residual norm 1.286772693697e-09
  488 KSP Residual norm 1.329444773478e-09
  489 KSP Residual norm 1.335802971685e-09
  490 KSP Residual norm 1.324402725640e-09
  491 KSP Residual norm 1.394280527801e-09
  492 KSP Residual norm 1.461658436416e-09
  493 KSP Residual norm 1.495261891135e-09
  494 KSP Residual norm 1.547817326381e-09
  495 KSP Residual norm 1.532839879649e-09
  496 KSP Residual norm 1.570858598946e-09
  497 KSP Residual norm 1.641705524032e-09
  498 KSP Residual norm 1.671529718867e-09
  499 KSP Residual norm 1.772495074632e-09
  500 KSP Residual norm 1.847029248055e-09
  501 KSP Residual norm 1.766738060761e-09
  502 KSP Residual norm 1.781542344002e-09
  503 KSP Residual norm 1.735146745630e-09
  504 KSP Residual norm 1.681687631135e-09
  505 KSP Residual norm 1.727289790522e-09
  506 KSP Residual norm 1.763230239574e-09
  507 KSP Residual norm 1.795057298585e-09
  508 KSP Residual norm 1.692534511967e-09
  509 KSP Residual norm 1.532249455094e-09
  510 KSP Residual norm 1.524484968248e-09
  511 KSP Residual norm 1.614981719405e-09
  512 KSP Residual norm 1.644732322839e-09
  513 KSP Residual norm 1.648727655330e-09
  514 KSP Residual norm 1.603155602400e-09
  515 KSP Residual norm 1.610134372803e-09
  516 KSP Residual norm 1.689652383961e-09
  517 KSP Residual norm 1.652238248612e-09
  518 KSP Residual norm 1.545180754492e-09
  519 KSP Residual norm 1.595513579393e-09
  520 KSP Residual norm 1.683866217938e-09
  521 KSP Residual norm 1.763739358542e-09
  522 KSP Residual norm 1.772000950785e-09
  523 KSP Residual norm 1.847047086745e-09
  524 KSP Residual norm 1.894853851552e-09
  525 KSP Residual norm 1.988406619670e-09
  526 KSP Residual norm 1.946964922346e-09
  527 KSP Residual norm 1.854597647178e-09
  528 KSP Residual norm 1.859158597920e-09
  529 KSP Residual norm 1.873074309863e-09
  530 KSP Residual norm 1.841854149780e-09
  531 KSP Residual norm 1.820360993445e-09
  532 KSP Residual norm 1.765709064136e-09
  533 KSP Residual norm 1.743639470192e-09
  534 KSP Residual norm 1.700118978897e-09
  535 KSP Residual norm 1.686261786531e-09
  536 KSP Residual norm 1.736933884590e-09
  537 KSP Residual norm 1.714856623027e-09
  538 KSP Residual norm 1.712580333166e-09
  539 KSP Residual norm 1.772859236532e-09
  540 KSP Residual norm 1.755407084707e-09
  541 KSP Residual norm 1.768766278526e-09
  542 KSP Residual norm 1.765845696674e-09
  543 KSP Residual norm 1.775162125958e-09
  544 KSP Residual norm 1.814609910488e-09
  545 KSP Residual norm 1.880652692903e-09
  546 KSP Residual norm 1.929178971764e-09
  547 KSP Residual norm 1.934747440650e-09
  548 KSP Residual norm 1.891117997319e-09
  549 KSP Residual norm 1.915937837428e-09
  550 KSP Residual norm 1.937989831489e-09
  551 KSP Residual norm 2.001012117016e-09
  552 KSP Residual norm 2.035968118293e-09
  553 KSP Residual norm 1.945679174279e-09
  554 KSP Residual norm 1.976732083516e-09
  555 KSP Residual norm 2.116237603035e-09
  556 KSP Residual norm 2.178943630802e-09
  557 KSP Residual norm 2.172060610074e-09
  558 KSP Residual norm 2.096427640437e-09
  559 KSP Residual norm 2.008266586912e-09
  560 KSP Residual norm 2.061231834099e-09
  561 KSP Residual norm 2.205176081615e-09
  562 KSP Residual norm 2.320317704500e-09
  563 KSP Residual norm 2.354305445855e-09
  564 KSP Residual norm 2.425625924464e-09
  565 KSP Residual norm 2.428922668942e-09
  566 KSP Residual norm 2.481481736987e-09
  567 KSP Residual norm 2.558544706905e-09
  568 KSP Residual norm 2.534676686647e-09
  569 KSP Residual norm 2.575790935864e-09
  570 KSP Residual norm 2.643759551321e-09
  571 KSP Residual norm 2.636357543635e-09
  572 KSP Residual norm 2.672432286967e-09
  573 KSP Residual norm 2.712348359281e-09
  574 KSP Residual norm 2.814931661634e-09
  575 KSP Residual norm 2.795225099939e-09
  576 KSP Residual norm 2.856138873093e-09
  577 KSP Residual norm 2.896582884594e-09
  578 KSP Residual norm 2.813751269116e-09
  579 KSP Residual norm 2.838895549463e-09
  580 KSP Residual norm 3.166547856785e-09
  581 KSP Residual norm 3.467591793548e-09
  582 KSP Residual norm 3.468463407237e-09
  583 KSP Residual norm 3.455049867302e-09
  584 KSP Residual norm 3.490160079207e-09
  585 KSP Residual norm 3.679438172608e-09
  586 KSP Residual norm 3.794138702879e-09
  587 KSP Residual norm 3.916754271143e-09
  588 KSP Residual norm 3.969463178263e-09
  589 KSP Residual norm 4.049059306507e-09
  590 KSP Residual norm 4.161015123219e-09
  591 KSP Residual norm 4.314138131830e-09
  592 KSP Residual norm 4.622943377089e-09
  593 KSP Residual norm 4.760455162437e-09
  594 KSP Residual norm 4.665593699675e-09
  595 KSP Residual norm 4.701358342161e-09
  596 KSP Residual norm 4.756247348908e-09
  597 KSP Residual norm 4.529691109948e-09
  598 KSP Residual norm 4.231837687517e-09
  599 KSP Residual norm 4.108313481190e-09
  600 KSP Residual norm 4.115730756272e-09
  601 KSP Residual norm 3.938768705167e-09
  602 KSP Residual norm 3.657550920846e-09
  603 KSP Residual norm 3.418436273245e-09
  604 KSP Residual norm 3.301056252721e-09
  605 KSP Residual norm 3.307907612331e-09
  606 KSP Residual norm 3.318421058876e-09
  607 KSP Residual norm 3.334708126964e-09
  608 KSP Residual norm 3.357935341797e-09
  609 KSP Residual norm 3.382178946176e-09
  610 KSP Residual norm 3.500952993405e-09
  611 KSP Residual norm 3.621225863202e-09
  612 KSP Residual norm 3.807464983169e-09
  613 KSP Residual norm 4.042123944953e-09
  614 KSP Residual norm 4.139638937863e-09
  615 KSP Residual norm 4.237157279987e-09
  616 KSP Residual norm 4.132400549353e-09
  617 KSP Residual norm 3.891694551034e-09
  618 KSP Residual norm 3.719060748535e-09
  619 KSP Residual norm 3.769538284941e-09
  620 KSP Residual norm 3.862205365366e-09
  621 KSP Residual norm 3.687129391416e-09
  622 KSP Residual norm 3.274085792912e-09
  623 KSP Residual norm 3.004073308853e-09
  624 KSP Residual norm 2.847476307893e-09
  625 KSP Residual norm 2.862846211184e-09
  626 KSP Residual norm 2.833158068211e-09
  627 KSP Residual norm 2.892860164804e-09
  628 KSP Residual norm 2.923237474514e-09
  629 KSP Residual norm 2.878428780279e-09
  630 KSP Residual norm 2.883813062194e-09
  631 KSP Residual norm 2.915949789670e-09
  632 KSP Residual norm 2.875344149110e-09
  633 KSP Residual norm 2.929668481231e-09
  634 KSP Residual norm 2.999723144163e-09
  635 KSP Residual norm 2.967399948344e-09
  636 KSP Residual norm 2.978206024806e-09
  637 KSP Residual norm 3.065811028516e-09
  638 KSP Residual norm 3.154641432697e-09
  639 KSP Residual norm 3.174640088809e-09
  640 KSP Residual norm 3.241171659702e-09
  641 KSP Residual norm 3.513875375327e-09
  642 KSP Residual norm 3.872306217510e-09
  643 KSP Residual norm 4.360757665916e-09
  644 KSP Residual norm 4.690253449849e-09
  645 KSP Residual norm 4.762568488373e-09
  646 KSP Residual norm 4.927776012132e-09
  647 KSP Residual norm 5.232553271582e-09
  648 KSP Residual norm 5.472989166388e-09
  649 KSP Residual norm 5.656851351546e-09
  650 KSP Residual norm 5.697974630712e-09
  651 KSP Residual norm 5.785925250061e-09
  652 KSP Residual norm 5.766662930042e-09
  653 KSP Residual norm 5.592418716831e-09
  654 KSP Residual norm 5.652438840848e-09
  655 KSP Residual norm 5.720758885642e-09
  656 KSP Residual norm 5.544726700086e-09
  657 KSP Residual norm 5.429352228380e-09
  658 KSP Residual norm 5.429515264316e-09
  659 KSP Residual norm 5.489269956176e-09
  660 KSP Residual norm 5.712827764565e-09
  661 KSP Residual norm 6.087666923820e-09
  662 KSP Residual norm 6.278362274492e-09
  663 KSP Residual norm 6.301831288228e-09
  664 KSP Residual norm 5.904205849963e-09
  665 KSP Residual norm 5.779884902777e-09
  666 KSP Residual norm 6.166206300841e-09
  667 KSP Residual norm 6.628546109875e-09
  668 KSP Residual norm 7.369527158813e-09
  669 KSP Residual norm 7.834466616015e-09
  670 KSP Residual norm 7.706044513704e-09
  671 KSP Residual norm 7.189880506311e-09
  672 KSP Residual norm 6.867685071342e-09
  673 KSP Residual norm 6.998974946100e-09
  674 KSP Residual norm 7.272049542534e-09
  675 KSP Residual norm 7.413805979531e-09
  676 KSP Residual norm 7.400097954362e-09
  677 KSP Residual norm 7.463072280556e-09
  678 KSP Residual norm 7.505407311348e-09
  679 KSP Residual norm 7.519288955187e-09
  680 KSP Residual norm 7.958281843376e-09
  681 KSP Residual norm 8.503716660846e-09
  682 KSP Residual norm 8.797293228028e-09
  683 KSP Residual norm 8.302001441191e-09
  684 KSP Residual norm 7.986093430824e-09
  685 KSP Residual norm 7.954561302759e-09
  686 KSP Residual norm 8.212198244218e-09
  687 KSP Residual norm 8.201991741836e-09
  688 KSP Residual norm 7.909094237038e-09
  689 KSP Residual norm 7.905508907252e-09
  690 KSP Residual norm 7.574673743162e-09
  691 KSP Residual norm 7.048564390762e-09
  692 KSP Residual norm 6.679912990284e-09
  693 KSP Residual norm 6.559162221948e-09
  694 KSP Residual norm 6.901596439668e-09
  695 KSP Residual norm 6.784534083983e-09
  696 KSP Residual norm 6.653239702631e-09
  697 KSP Residual norm 6.990473567042e-09
  698 KSP Residual norm 7.302923907033e-09
  699 KSP Residual norm 6.911087553228e-09
  700 KSP Residual norm 6.523847038279e-09
  701 KSP Residual norm 6.577503533026e-09
  702 KSP Residual norm 6.601448221557e-09
  703 KSP Residual norm 6.478319254699e-09
  704 KSP Residual norm 6.200524824596e-09
  705 KSP Residual norm 5.978691426175e-09
  706 KSP Residual norm 6.025466334544e-09
  707 KSP Residual norm 6.460135262803e-09
  708 KSP Residual norm 6.612230713785e-09
  709 KSP Residual norm 6.513059031597e-09
  710 KSP Residual norm 6.335966030477e-09
  711 KSP Residual norm 6.245890934433e-09
  712 KSP Residual norm 5.955798653406e-09
  713 KSP Residual norm 5.855595656728e-09
  714 KSP Residual norm 6.029673220099e-09
  715 KSP Residual norm 6.081193375711e-09
  716 KSP Residual norm 6.145075528393e-09
  717 KSP Residual norm 6.420983429738e-09
  718 KSP Residual norm 6.707696634223e-09
  719 KSP Residual norm 6.919081626264e-09
  720 KSP Residual norm 6.932654590679e-09
  721 KSP Residual norm 6.674365261677e-09
  722 KSP Residual norm 6.684395882579e-09
  723 KSP Residual norm 7.031641131260e-09
  724 KSP Residual norm 7.244008138092e-09
  725 KSP Residual norm 6.985369198773e-09
  726 KSP Residual norm 6.877293912545e-09
  727 KSP Residual norm 6.656048546880e-09
  728 KSP Residual norm 6.465602711445e-09
  729 KSP Residual norm 6.124479811739e-09
  730 KSP Residual norm 5.717349545493e-09
  731 KSP Residual norm 5.837934988084e-09
  732 KSP Residual norm 5.972927388556e-09
  733 KSP Residual norm 6.227047643661e-09
  734 KSP Residual norm 6.472940051759e-09
  735 KSP Residual norm 6.500052735720e-09
  736 KSP Residual norm 6.228413412324e-09
  737 KSP Residual norm 6.203070149011e-09
  738 KSP Residual norm 6.045043224275e-09
  739 KSP Residual norm 6.217800535565e-09
  740 KSP Residual norm 6.272435645284e-09
  741 KSP Residual norm 6.093501440885e-09
  742 KSP Residual norm 5.868387675671e-09
  743 KSP Residual norm 5.941150492818e-09
  744 KSP Residual norm 6.257994600326e-09
  745 KSP Residual norm 6.559466775819e-09
  746 KSP Residual norm 6.646013125951e-09
  747 KSP Residual norm 6.603083012038e-09
  748 KSP Residual norm 6.869798917114e-09
  749 KSP Residual norm 7.035848305198e-09
  750 KSP Residual norm 6.724702795544e-09
  751 KSP Residual norm 6.643039288536e-09
  752 KSP Residual norm 6.877580654451e-09
  753 KSP Residual norm 7.372500871887e-09
  754 KSP Residual norm 7.287842891225e-09
  755 KSP Residual norm 6.854182835958e-09
  756 KSP Residual norm 6.608884099750e-09
  757 KSP Residual norm 6.543541585624e-09
  758 KSP Residual norm 6.859615233234e-09
  759 KSP Residual norm 7.577449098830e-09
  760 KSP Residual norm 7.953014484535e-09
  761 KSP Residual norm 8.026613977031e-09
  762 KSP Residual norm 7.827001819223e-09
  763 KSP Residual norm 7.545541474815e-09
  764 KSP Residual norm 7.117909723248e-09
  765 KSP Residual norm 6.653285401663e-09
  766 KSP Residual norm 6.572883257089e-09
  767 KSP Residual norm 6.748422974851e-09
  768 KSP Residual norm 7.066382058042e-09
  769 KSP Residual norm 7.559923939180e-09
  770 KSP Residual norm 8.357225213639e-09
  771 KSP Residual norm 9.015058935006e-09
  772 KSP Residual norm 9.236946944050e-09
  773 KSP Residual norm 8.704063459155e-09
  774 KSP Residual norm 8.235715120280e-09
  775 KSP Residual norm 8.163466859000e-09
  776 KSP Residual norm 7.895208198763e-09
  777 KSP Residual norm 7.569488982129e-09
  778 KSP Residual norm 7.565997464462e-09
  779 KSP Residual norm 7.453386151749e-09
  780 KSP Residual norm 7.169651648109e-09
  781 KSP Residual norm 7.143581355048e-09
  782 KSP Residual norm 7.282046900589e-09
  783 KSP Residual norm 7.157581279652e-09
  784 KSP Residual norm 7.230461011824e-09
  785 KSP Residual norm 7.878183064383e-09
  786 KSP Residual norm 8.060948501929e-09
  787 KSP Residual norm 7.912577052218e-09
  788 KSP Residual norm 7.948835121168e-09
  789 KSP Residual norm 7.674276302470e-09
  790 KSP Residual norm 7.706182467257e-09
  791 KSP Residual norm 7.388719541897e-09
  792 KSP Residual norm 7.688982310654e-09
  793 KSP Residual norm 8.020141760739e-09
  794 KSP Residual norm 8.162208765609e-09
  795 KSP Residual norm 8.034774510079e-09
  796 KSP Residual norm 7.836893773661e-09
  797 KSP Residual norm 7.547212125466e-09
  798 KSP Residual norm 7.668103085871e-09
  799 KSP Residual norm 7.623166606802e-09
  800 KSP Residual norm 7.448196207566e-09
  801 KSP Residual norm 7.091278411865e-09
  802 KSP Residual norm 6.998064038304e-09
  803 KSP Residual norm 7.160226734579e-09
  804 KSP Residual norm 7.443078968953e-09
  805 KSP Residual norm 7.369587397843e-09
  806 KSP Residual norm 7.202525538865e-09
  807 KSP Residual norm 6.962021415456e-09
  808 KSP Residual norm 6.681119302584e-09
  809 KSP Residual norm 6.785368950271e-09
  810 KSP Residual norm 6.851824936260e-09
  811 KSP Residual norm 6.565067688156e-09
  812 KSP Residual norm 6.359528559300e-09
  813 KSP Residual norm 6.202258875461e-09
  814 KSP Residual norm 6.040993476528e-09
  815 KSP Residual norm 6.048505449348e-09
  816 KSP Residual norm 6.125282224091e-09
  817 KSP Residual norm 6.190690894085e-09
  818 KSP Residual norm 6.173396419131e-09
  819 KSP Residual norm 5.797081982935e-09
  820 KSP Residual norm 5.780784627591e-09
  821 KSP Residual norm 5.908891550852e-09
  822 KSP Residual norm 6.278057324239e-09
  823 KSP Residual norm 6.129600776127e-09
  824 KSP Residual norm 5.983984436644e-09
  825 KSP Residual norm 5.706130836202e-09
  826 KSP Residual norm 5.514456245658e-09
  827 KSP Residual norm 5.443952121390e-09
  828 KSP Residual norm 5.679143660625e-09
  829 KSP Residual norm 5.607722564238e-09
  830 KSP Residual norm 5.527711112136e-09
  831 KSP Residual norm 5.540718014405e-09
  832 KSP Residual norm 5.636554453756e-09
  833 KSP Residual norm 5.602696964501e-09
  834 KSP Residual norm 5.587850079021e-09
  835 KSP Residual norm 5.601421004204e-09
  836 KSP Residual norm 5.513532911406e-09
  837 KSP Residual norm 5.464122957114e-09
  838 KSP Residual norm 5.492864528095e-09
  839 KSP Residual norm 5.728267078389e-09
  840 KSP Residual norm 5.658137947643e-09
  841 KSP Residual norm 5.382615240830e-09
  842 KSP Residual norm 5.084257134948e-09
  843 KSP Residual norm 4.800761393363e-09
  844 KSP Residual norm 4.809139612126e-09
  845 KSP Residual norm 4.863267747940e-09
  846 KSP Residual norm 4.788287281942e-09
  847 KSP Residual norm 4.805361198429e-09
  848 KSP Residual norm 4.872644208108e-09
  849 KSP Residual norm 5.004821109516e-09
  850 KSP Residual norm 5.226925462836e-09
  851 KSP Residual norm 5.408527552589e-09
  852 KSP Residual norm 5.668341959668e-09
  853 KSP Residual norm 5.825110482612e-09
  854 KSP Residual norm 5.719827720569e-09
  855 KSP Residual norm 5.647673996373e-09
  856 KSP Residual norm 5.695930630044e-09
  857 KSP Residual norm 5.786161739978e-09
  858 KSP Residual norm 5.718465017172e-09
  859 KSP Residual norm 5.474379755098e-09
  860 KSP Residual norm 5.100927461531e-09
  861 KSP Residual norm 5.182803528228e-09
  862 KSP Residual norm 5.216240079042e-09
  863 KSP Residual norm 5.183988210785e-09
  864 KSP Residual norm 5.008909032486e-09
  865 KSP Residual norm 4.826226353690e-09
  866 KSP Residual norm 4.914528211049e-09
  867 KSP Residual norm 5.231291841512e-09
  868 KSP Residual norm 5.316169185419e-09
  869 KSP Residual norm 5.400183546490e-09
  870 KSP Residual norm 5.366977587361e-09
  871 KSP Residual norm 5.341670596335e-09
  872 KSP Residual norm 5.303468774687e-09
  873 KSP Residual norm 5.366740194011e-09
  874 KSP Residual norm 5.296933732000e-09
  875 KSP Residual norm 5.288750013770e-09
  876 KSP Residual norm 5.444363031954e-09
  877 KSP Residual norm 5.784263576158e-09
  878 KSP Residual norm 5.948011993179e-09
  879 KSP Residual norm 6.115145666760e-09
  880 KSP Residual norm 6.468587599719e-09
  881 KSP Residual norm 6.923520186849e-09
  882 KSP Residual norm 6.858575958634e-09
  883 KSP Residual norm 6.530469286925e-09
  884 KSP Residual norm 6.292450555488e-09
  885 KSP Residual norm 6.613749509452e-09
  886 KSP Residual norm 7.260143027649e-09
  887 KSP Residual norm 7.724309477503e-09
  888 KSP Residual norm 7.562182819475e-09
  889 KSP Residual norm 7.258173186873e-09
  890 KSP Residual norm 7.248820531580e-09
  891 KSP Residual norm 7.057351368755e-09
  892 KSP Residual norm 6.912152860904e-09
  893 KSP Residual norm 7.151675702628e-09
  894 KSP Residual norm 7.567601172563e-09
  895 KSP Residual norm 7.974144326828e-09
  896 KSP Residual norm 7.954801860110e-09
  897 KSP Residual norm 8.106295496802e-09
  898 KSP Residual norm 8.521052347560e-09
  899 KSP Residual norm 9.062756710290e-09
  900 KSP Residual norm 8.858680189932e-09
  901 KSP Residual norm 8.275959964339e-09
  902 KSP Residual norm 7.798679446082e-09
  903 KSP Residual norm 7.735865714005e-09
  904 KSP Residual norm 7.692675569565e-09
  905 KSP Residual norm 7.877351922282e-09
  906 KSP Residual norm 7.848158383283e-09
  907 KSP Residual norm 7.412279192010e-09
  908 KSP Residual norm 7.128091487987e-09
  909 KSP Residual norm 7.143322128602e-09
  910 KSP Residual norm 7.198009345265e-09
  911 KSP Residual norm 6.993940937968e-09
  912 KSP Residual norm 6.821657925321e-09
  913 KSP Residual norm 6.517358067203e-09
  914 KSP Residual norm 5.981662338732e-09
  915 KSP Residual norm 5.688795473476e-09
  916 KSP Residual norm 5.509153758326e-09
  917 KSP Residual norm 5.677921543509e-09
  918 KSP Residual norm 5.716800765156e-09
  919 KSP Residual norm 5.638726241970e-09
  920 KSP Residual norm 5.878812403449e-09
  921 KSP Residual norm 6.114511948264e-09
  922 KSP Residual norm 6.240447909717e-09
  923 KSP Residual norm 6.251944017577e-09
  924 KSP Residual norm 6.023715038662e-09
  925 KSP Residual norm 5.693535878019e-09
  926 KSP Residual norm 5.525011521074e-09
  927 KSP Residual norm 5.681150465276e-09
  928 KSP Residual norm 5.935861345955e-09
  929 KSP Residual norm 6.159510250080e-09
  930 KSP Residual norm 6.556862156855e-09
  931 KSP Residual norm 6.934405621634e-09
  932 KSP Residual norm 7.247255478605e-09
  933 KSP Residual norm 7.405281862255e-09
  934 KSP Residual norm 7.847098478143e-09
  935 KSP Residual norm 8.233361159953e-09
  936 KSP Residual norm 8.785756248873e-09
  937 KSP Residual norm 8.968568396860e-09
  938 KSP Residual norm 8.808067495405e-09
  939 KSP Residual norm 8.643926487272e-09
  940 KSP Residual norm 9.083129511502e-09
  941 KSP Residual norm 9.679285377657e-09
  942 KSP Residual norm 9.811706021424e-09
  943 KSP Residual norm 9.667016485816e-09
  944 KSP Residual norm 9.725162049022e-09
  945 KSP Residual norm 1.068902760110e-08
  946 KSP Residual norm 1.103863427705e-08
  947 KSP Residual norm 1.017363934353e-08
  948 KSP Residual norm 9.320665616680e-09
  949 KSP Residual norm 9.051704918474e-09
  950 KSP Residual norm 9.239669744355e-09
  951 KSP Residual norm 8.957637299840e-09
  952 KSP Residual norm 8.161234593837e-09
  953 KSP Residual norm 7.564960336925e-09
  954 KSP Residual norm 7.353806885156e-09
  955 KSP Residual norm 7.367097546397e-09
  956 KSP Residual norm 7.259549067035e-09
  957 KSP Residual norm 7.325747974757e-09
  958 KSP Residual norm 7.499519634152e-09
  959 KSP Residual norm 7.437087940069e-09
  960 KSP Residual norm 7.384386309173e-09
  961 KSP Residual norm 7.496377330740e-09
  962 KSP Residual norm 7.762435909619e-09
  963 KSP Residual norm 7.908523824425e-09
  964 KSP Residual norm 7.659805582899e-09
  965 KSP Residual norm 6.832397920205e-09
  966 KSP Residual norm 6.519845374949e-09
  967 KSP Residual norm 6.574461012132e-09
  968 KSP Residual norm 6.511372659672e-09
  969 KSP Residual norm 6.583506389026e-09
  970 KSP Residual norm 6.874484606155e-09
  971 KSP Residual norm 7.012007818853e-09
  972 KSP Residual norm 7.118177107805e-09
  973 KSP Residual norm 7.256487171561e-09
  974 KSP Residual norm 7.573526048223e-09
  975 KSP Residual norm 7.974617082430e-09
  976 KSP Residual norm 7.906185386514e-09
  977 KSP Residual norm 7.823359314357e-09
  978 KSP Residual norm 7.917015528232e-09
  979 KSP Residual norm 7.898753797419e-09
  980 KSP Residual norm 7.744004531711e-09
  981 KSP Residual norm 8.030269921517e-09
  982 KSP Residual norm 8.413528651713e-09
  983 KSP Residual norm 8.887655576893e-09
  984 KSP Residual norm 8.734099877500e-09
  985 KSP Residual norm 8.613602066716e-09
  986 KSP Residual norm 8.427988446776e-09
  987 KSP Residual norm 8.513553314201e-09
  988 KSP Residual norm 8.998234130515e-09
  989 KSP Residual norm 8.915944527933e-09
  990 KSP Residual norm 8.263158719163e-09
  991 KSP Residual norm 7.701030359952e-09
  992 KSP Residual norm 7.522201936886e-09
  993 KSP Residual norm 7.127382905299e-09
  994 KSP Residual norm 6.914360075698e-09
  995 KSP Residual norm 6.958875544316e-09
  996 KSP Residual norm 6.745554185865e-09
  997 KSP Residual norm 6.497643604142e-09
  998 KSP Residual norm 6.658185439567e-09
  999 KSP Residual norm 6.797706259527e-09
  1000 KSP Residual norm 6.643547980643e-09
  1001 KSP Residual norm 6.525716501621e-09
  1002 KSP Residual norm 6.408688372054e-09
  1003 KSP Residual norm 6.212810977432e-09
  1004 KSP Residual norm 6.355261722701e-09
  1005 KSP Residual norm 6.683369639665e-09
  1006 KSP Residual norm 6.755423402063e-09
  1007 KSP Residual norm 6.817321116932e-09
  1008 KSP Residual norm 6.977177254165e-09
  1009 KSP Residual norm 7.250489956452e-09
  1010 KSP Residual norm 7.077012235869e-09
  1011 KSP Residual norm 6.554400361128e-09
  1012 KSP Residual norm 6.239676004657e-09
  1013 KSP Residual norm 6.474158239235e-09
  1014 KSP Residual norm 6.870072691977e-09
  1015 KSP Residual norm 6.864592915272e-09
  1016 KSP Residual norm 6.937825130396e-09
  1017 KSP Residual norm 6.952557781448e-09
  1018 KSP Residual norm 7.017833155262e-09
  1019 KSP Residual norm 7.291220932088e-09
  1020 KSP Residual norm 7.450728999707e-09
  1021 KSP Residual norm 7.283777585467e-09
  1022 KSP Residual norm 7.033832918743e-09
  1023 KSP Residual norm 7.196823000425e-09
  1024 KSP Residual norm 7.346160430197e-09
  1025 KSP Residual norm 7.382018006703e-09
  1026 KSP Residual norm 7.125543832461e-09
  1027 KSP Residual norm 7.237500085312e-09
  1028 KSP Residual norm 7.295483620750e-09
  1029 KSP Residual norm 7.296341550071e-09
  1030 KSP Residual norm 7.173884125813e-09
  1031 KSP Residual norm 6.939322667988e-09
  1032 KSP Residual norm 6.537141232920e-09
  1033 KSP Residual norm 6.386527226313e-09
  1034 KSP Residual norm 6.452925411362e-09
  1035 KSP Residual norm 6.198119685324e-09
  1036 KSP Residual norm 5.799844419135e-09
  1037 KSP Residual norm 5.809414044221e-09
  1038 KSP Residual norm 5.805182841062e-09
  1039 KSP Residual norm 5.889747430483e-09
  1040 KSP Residual norm 5.869962399738e-09
  1041 KSP Residual norm 5.357415686878e-09
  1042 KSP Residual norm 5.029360405793e-09
  1043 KSP Residual norm 4.948841519246e-09
  1044 KSP Residual norm 5.126733639701e-09
  1045 KSP Residual norm 5.274225737834e-09
  1046 KSP Residual norm 5.414643543120e-09
  1047 KSP Residual norm 5.354333787908e-09
  1048 KSP Residual norm 5.181061229734e-09
  1049 KSP Residual norm 5.375989535532e-09
  1050 KSP Residual norm 5.657566587982e-09
  1051 KSP Residual norm 5.248448275588e-09
  1052 KSP Residual norm 4.566160191450e-09
  1053 KSP Residual norm 4.375577774801e-09
  1054 KSP Residual norm 4.576011842869e-09
  1055 KSP Residual norm 4.915662417165e-09
  1056 KSP Residual norm 5.067861117888e-09
  1057 KSP Residual norm 5.214458113091e-09
  1058 KSP Residual norm 5.681364855361e-09
  1059 KSP Residual norm 5.856244264088e-09
  1060 KSP Residual norm 5.615827106959e-09
  1061 KSP Residual norm 5.335577355833e-09
  1062 KSP Residual norm 5.219291139339e-09
  1063 KSP Residual norm 5.001481924689e-09
  1064 KSP Residual norm 4.766345190169e-09
  1065 KSP Residual norm 4.595334671668e-09
  1066 KSP Residual norm 4.589812995159e-09
  1067 KSP Residual norm 4.861988170360e-09
  1068 KSP Residual norm 5.285857804457e-09
  1069 KSP Residual norm 5.573336093276e-09
  1070 KSP Residual norm 5.541018434628e-09
  1071 KSP Residual norm 5.534991390608e-09
  1072 KSP Residual norm 5.571698872281e-09
  1073 KSP Residual norm 5.380018423122e-09
  1074 KSP Residual norm 5.480686274751e-09
  1075 KSP Residual norm 5.844147186637e-09
  1076 KSP Residual norm 6.244775835500e-09
  1077 KSP Residual norm 6.422531855198e-09
  1078 KSP Residual norm 6.363517038435e-09
  1079 KSP Residual norm 6.327028491825e-09
  1080 KSP Residual norm 6.267223842887e-09
  1081 KSP Residual norm 6.283382477294e-09
  1082 KSP Residual norm 6.243640617307e-09
  1083 KSP Residual norm 6.151485523210e-09
  1084 KSP Residual norm 6.091475515101e-09
  1085 KSP Residual norm 6.098064843009e-09
  1086 KSP Residual norm 6.298631030314e-09
  1087 KSP Residual norm 6.404858845342e-09
  1088 KSP Residual norm 6.313176373162e-09
  1089 KSP Residual norm 6.110546614074e-09
  1090 KSP Residual norm 5.990890130531e-09
  1091 KSP Residual norm 6.132289844452e-09
  1092 KSP Residual norm 6.122679680216e-09
  1093 KSP Residual norm 5.841217190319e-09
  1094 KSP Residual norm 5.973798203640e-09
  1095 KSP Residual norm 6.331906846830e-09
  1096 KSP Residual norm 6.267233105290e-09
  1097 KSP Residual norm 6.004452007948e-09
  1098 KSP Residual norm 5.868518189995e-09
  1099 KSP Residual norm 5.998988425377e-09
  1100 KSP Residual norm 6.327160413271e-09
  1101 KSP Residual norm 6.371906224722e-09
  1102 KSP Residual norm 5.900757207841e-09
  1103 KSP Residual norm 5.510585278636e-09
  1104 KSP Residual norm 5.535611456748e-09
  1105 KSP Residual norm 5.703867445861e-09
  1106 KSP Residual norm 5.812403989081e-09
  1107 KSP Residual norm 6.260566864209e-09
  1108 KSP Residual norm 6.758791651898e-09
  1109 KSP Residual norm 7.134518657245e-09
  1110 KSP Residual norm 7.173057675491e-09
  1111 KSP Residual norm 7.246672952069e-09
  1112 KSP Residual norm 7.202316177001e-09
  1113 KSP Residual norm 6.804576953348e-09
  1114 KSP Residual norm 6.566181332967e-09
  1115 KSP Residual norm 6.652124927676e-09
  1116 KSP Residual norm 7.070295450505e-09
  1117 KSP Residual norm 7.443728026630e-09
  1118 KSP Residual norm 7.425130228737e-09
  1119 KSP Residual norm 7.052236298243e-09
  1120 KSP Residual norm 7.040314853515e-09
  1121 KSP Residual norm 7.406869377203e-09
  1122 KSP Residual norm 7.336596584712e-09
  1123 KSP Residual norm 6.839915807792e-09
  1124 KSP Residual norm 6.967748469987e-09
  1125 KSP Residual norm 7.181353827279e-09
  1126 KSP Residual norm 7.145118996033e-09
  1127 KSP Residual norm 6.848387297878e-09
  1128 KSP Residual norm 6.736283742099e-09
  1129 KSP Residual norm 6.533697196895e-09
  1130 KSP Residual norm 6.520318554180e-09
  1131 KSP Residual norm 6.757962098923e-09
  1132 KSP Residual norm 6.586499453244e-09
  1133 KSP Residual norm 6.167976960141e-09
  1134 KSP Residual norm 5.988575365919e-09
  1135 KSP Residual norm 6.085138520089e-09
  1136 KSP Residual norm 6.016534945749e-09
  1137 KSP Residual norm 6.191293510705e-09
  1138 KSP Residual norm 6.622866455767e-09
  1139 KSP Residual norm 6.630509323645e-09
  1140 KSP Residual norm 6.409833525617e-09
  1141 KSP Residual norm 6.295534129994e-09
  1142 KSP Residual norm 6.206047976266e-09
  1143 KSP Residual norm 6.219060883724e-09
  1144 KSP Residual norm 6.301985859728e-09
  1145 KSP Residual norm 6.539243445239e-09
  1146 KSP Residual norm 6.557366373887e-09
  1147 KSP Residual norm 6.535327474781e-09
  1148 KSP Residual norm 6.708995885579e-09
  1149 KSP Residual norm 7.193301098553e-09
  1150 KSP Residual norm 7.465522756484e-09
  1151 KSP Residual norm 7.378588830839e-09
  1152 KSP Residual norm 7.205740814503e-09
  1153 KSP Residual norm 7.141304336030e-09
  1154 KSP Residual norm 7.266029491326e-09
  1155 KSP Residual norm 7.457420944714e-09
  1156 KSP Residual norm 7.203911768333e-09
  1157 KSP Residual norm 7.102016305393e-09
  1158 KSP Residual norm 6.962395838658e-09
  1159 KSP Residual norm 6.883960592143e-09
  1160 KSP Residual norm 6.768301964829e-09
  1161 KSP Residual norm 6.740809348278e-09
  1162 KSP Residual norm 7.017766801025e-09
  1163 KSP Residual norm 6.859702231446e-09
  1164 KSP Residual norm 6.390321735953e-09
  1165 KSP Residual norm 5.939094327521e-09
  1166 KSP Residual norm 5.902585648094e-09
  1167 KSP Residual norm 6.254064559952e-09
  1168 KSP Residual norm 6.642458569898e-09
  1169 KSP Residual norm 6.311392943269e-09
  1170 KSP Residual norm 5.858607834117e-09
  1171 KSP Residual norm 5.370273524009e-09
  1172 KSP Residual norm 4.830991609068e-09
  1173 KSP Residual norm 4.593012148583e-09
  1174 KSP Residual norm 4.664567590757e-09
  1175 KSP Residual norm 4.830423752279e-09
  1176 KSP Residual norm 5.069882357069e-09
  1177 KSP Residual norm 5.243765559176e-09
  1178 KSP Residual norm 5.237210501583e-09
  1179 KSP Residual norm 5.319806537348e-09
  1180 KSP Residual norm 5.806306595545e-09
  1181 KSP Residual norm 6.205357832334e-09
  1182 KSP Residual norm 6.142636958698e-09
  1183 KSP Residual norm 6.115309204284e-09
  1184 KSP Residual norm 5.910952878667e-09
  1185 KSP Residual norm 5.612607861819e-09
  1186 KSP Residual norm 5.332519322139e-09
  1187 KSP Residual norm 5.494238262890e-09
  1188 KSP Residual norm 5.967681267125e-09
  1189 KSP Residual norm 6.412165183577e-09
  1190 KSP Residual norm 6.433356115566e-09
  1191 KSP Residual norm 6.082936666289e-09
  1192 KSP Residual norm 5.534608624956e-09
  1193 KSP Residual norm 5.059570131258e-09
  1194 KSP Residual norm 4.929391333560e-09
  1195 KSP Residual norm 4.930415084572e-09
  1196 KSP Residual norm 5.141994477921e-09
  1197 KSP Residual norm 5.226299317763e-09
  1198 KSP Residual norm 4.946496705404e-09
  1199 KSP Residual norm 4.650088197859e-09
  1200 KSP Residual norm 4.352259567985e-09
  1201 KSP Residual norm 4.120143379597e-09
  1202 KSP Residual norm 4.279059386121e-09
  1203 KSP Residual norm 4.567671586457e-09
  1204 KSP Residual norm 4.699298571409e-09
  1205 KSP Residual norm 4.624299946119e-09
  1206 KSP Residual norm 4.608770294521e-09
  1207 KSP Residual norm 4.881280460746e-09
  1208 KSP Residual norm 5.330401693919e-09
  1209 KSP Residual norm 5.385432775086e-09
  1210 KSP Residual norm 5.388214614690e-09
  1211 KSP Residual norm 5.351149896277e-09
  1212 KSP Residual norm 5.582075652390e-09
  1213 KSP Residual norm 5.996592344369e-09
  1214 KSP Residual norm 6.214408064240e-09
  1215 KSP Residual norm 6.200175871376e-09
  1216 KSP Residual norm 5.913835930666e-09
  1217 KSP Residual norm 5.634141218368e-09
  1218 KSP Residual norm 5.654842954419e-09
  1219 KSP Residual norm 5.665522319266e-09
  1220 KSP Residual norm 5.659720591079e-09
  1221 KSP Residual norm 5.769598812748e-09
  1222 KSP Residual norm 5.794951041275e-09
  1223 KSP Residual norm 6.160662343286e-09
  1224 KSP Residual norm 6.784284283364e-09
  1225 KSP Residual norm 7.250131995313e-09
  1226 KSP Residual norm 6.905530944923e-09
  1227 KSP Residual norm 6.327343703300e-09
  1228 KSP Residual norm 5.994703658988e-09
  1229 KSP Residual norm 5.960612848211e-09
  1230 KSP Residual norm 5.854683522494e-09
  1231 KSP Residual norm 5.283888980834e-09
  1232 KSP Residual norm 4.846806212250e-09
  1233 KSP Residual norm 4.689158987462e-09
  1234 KSP Residual norm 4.612153129971e-09
  1235 KSP Residual norm 4.486081995314e-09
  1236 KSP Residual norm 4.321890217555e-09
  1237 KSP Residual norm 4.299931629943e-09
  1238 KSP Residual norm 4.359725336312e-09
  1239 KSP Residual norm 4.360079493672e-09
  1240 KSP Residual norm 4.526052441946e-09
  1241 KSP Residual norm 4.965642352778e-09
  1242 KSP Residual norm 5.080516847525e-09
  1243 KSP Residual norm 4.498215233579e-09
  1244 KSP Residual norm 3.947183260933e-09
  1245 KSP Residual norm 3.614065402520e-09
  1246 KSP Residual norm 3.555410827381e-09
  1247 KSP Residual norm 3.676762000646e-09
  1248 KSP Residual norm 3.870078588593e-09
  1249 KSP Residual norm 4.163933781681e-09
  1250 KSP Residual norm 4.406412219699e-09
  1251 KSP Residual norm 4.599241159667e-09
  1252 KSP Residual norm 4.855642713056e-09
  1253 KSP Residual norm 5.007231578626e-09
  1254 KSP Residual norm 5.007928666428e-09
  1255 KSP Residual norm 5.213736099852e-09
  1256 KSP Residual norm 5.616982382382e-09
  1257 KSP Residual norm 5.614730284415e-09
  1258 KSP Residual norm 5.399304490788e-09
  1259 KSP Residual norm 5.382003425362e-09
  1260 KSP Residual norm 5.687888283483e-09
  1261 KSP Residual norm 5.824991233076e-09
  1262 KSP Residual norm 5.856433798492e-09
  1263 KSP Residual norm 5.631386321492e-09
  1264 KSP Residual norm 5.385578999528e-09
  1265 KSP Residual norm 5.257576755390e-09
  1266 KSP Residual norm 5.020793149592e-09
  1267 KSP Residual norm 4.906235331480e-09
  1268 KSP Residual norm 4.970895336339e-09
  1269 KSP Residual norm 4.997553668471e-09
  1270 KSP Residual norm 4.855323166727e-09
  1271 KSP Residual norm 4.821922839131e-09
  1272 KSP Residual norm 5.069687721718e-09
  1273 KSP Residual norm 5.294325975402e-09
  1274 KSP Residual norm 5.311311993649e-09
  1275 KSP Residual norm 5.317997561356e-09
  1276 KSP Residual norm 5.309721221747e-09
  1277 KSP Residual norm 5.620105797503e-09
  1278 KSP Residual norm 5.935439775168e-09
  1279 KSP Residual norm 5.998833765340e-09
  1280 KSP Residual norm 5.583404679582e-09
  1281 KSP Residual norm 5.425625266983e-09
  1282 KSP Residual norm 5.707330707086e-09
  1283 KSP Residual norm 6.031584282364e-09
  1284 KSP Residual norm 6.208485196306e-09
  1285 KSP Residual norm 5.930943101110e-09
  1286 KSP Residual norm 5.598922112699e-09
  1287 KSP Residual norm 5.455787065836e-09
  1288 KSP Residual norm 5.647832365929e-09
  1289 KSP Residual norm 5.943644239040e-09
  1290 KSP Residual norm 5.746254069827e-09
  1291 KSP Residual norm 5.469313278458e-09
  1292 KSP Residual norm 5.453617323870e-09
  1293 KSP Residual norm 5.483709114093e-09
  1294 KSP Residual norm 5.443243024556e-09
  1295 KSP Residual norm 5.274735971777e-09
  1296 KSP Residual norm 4.908737761391e-09
  1297 KSP Residual norm 4.787274963500e-09
  1298 KSP Residual norm 4.945285809020e-09
  1299 KSP Residual norm 5.091335837870e-09
  1300 KSP Residual norm 5.035912141837e-09
  1301 KSP Residual norm 5.053412721701e-09
  1302 KSP Residual norm 4.883870130753e-09
  1303 KSP Residual norm 4.556902217391e-09
  1304 KSP Residual norm 4.284552690591e-09
  1305 KSP Residual norm 4.326567573011e-09
  1306 KSP Residual norm 4.535924840015e-09
  1307 KSP Residual norm 4.844375804149e-09
  1308 KSP Residual norm 5.150956700998e-09
  1309 KSP Residual norm 5.263363526059e-09
  1310 KSP Residual norm 5.366625313142e-09
  1311 KSP Residual norm 5.513627157783e-09
  1312 KSP Residual norm 5.855262985462e-09
  1313 KSP Residual norm 6.330804485631e-09
  1314 KSP Residual norm 6.365256259406e-09
  1315 KSP Residual norm 6.190177395191e-09
  1316 KSP Residual norm 5.902414589545e-09
  1317 KSP Residual norm 5.762126876609e-09
  1318 KSP Residual norm 5.411406055006e-09
  1319 KSP Residual norm 5.111208365799e-09
  1320 KSP Residual norm 5.261067040128e-09
  1321 KSP Residual norm 5.287474930802e-09
  1322 KSP Residual norm 5.085599122668e-09
  1323 KSP Residual norm 5.083665650932e-09
  1324 KSP Residual norm 5.644383286632e-09
  1325 KSP Residual norm 6.156904323742e-09
  1326 KSP Residual norm 6.060170460270e-09
  1327 KSP Residual norm 6.000481709883e-09
  1328 KSP Residual norm 6.040621671142e-09
  1329 KSP Residual norm 6.004637505034e-09
  1330 KSP Residual norm 5.623286585342e-09
  1331 KSP Residual norm 5.298267775547e-09
  1332 KSP Residual norm 5.410136331835e-09
  1333 KSP Residual norm 5.974779175717e-09
  1334 KSP Residual norm 6.475641539617e-09
  1335 KSP Residual norm 6.868245965861e-09
  1336 KSP Residual norm 6.951227743263e-09
  1337 KSP Residual norm 7.103433831470e-09
  1338 KSP Residual norm 7.085946382509e-09
  1339 KSP Residual norm 7.400655750695e-09
  1340 KSP Residual norm 7.810180354020e-09
  1341 KSP Residual norm 8.382374392546e-09
  1342 KSP Residual norm 9.138428756890e-09
  1343 KSP Residual norm 9.789757644279e-09
  1344 KSP Residual norm 9.703147236028e-09
  1345 KSP Residual norm 9.048100224587e-09
  1346 KSP Residual norm 8.395423647786e-09
  1347 KSP Residual norm 7.625116892622e-09
  1348 KSP Residual norm 7.043054266680e-09
  1349 KSP Residual norm 6.838684120386e-09
  1350 KSP Residual norm 7.101303776111e-09
  1351 KSP Residual norm 7.210020595016e-09
  1352 KSP Residual norm 6.896418475054e-09
  1353 KSP Residual norm 6.514945509018e-09
  1354 KSP Residual norm 6.102045601718e-09
  1355 KSP Residual norm 5.972851649423e-09
  1356 KSP Residual norm 5.819162849617e-09
  1357 KSP Residual norm 5.422353326831e-09
  1358 KSP Residual norm 5.246131948395e-09
  1359 KSP Residual norm 5.232332369809e-09
  1360 KSP Residual norm 5.426837933524e-09
  1361 KSP Residual norm 5.512656806512e-09
  1362 KSP Residual norm 5.433118812931e-09
  1363 KSP Residual norm 5.013864261452e-09
  1364 KSP Residual norm 4.682205773071e-09
  1365 KSP Residual norm 4.531291442580e-09
  1366 KSP Residual norm 4.578791094112e-09
  1367 KSP Residual norm 4.906620921344e-09
  1368 KSP Residual norm 5.427132286797e-09
  1369 KSP Residual norm 5.854265639752e-09
  1370 KSP Residual norm 5.623807021231e-09
  1371 KSP Residual norm 5.242499112571e-09
  1372 KSP Residual norm 5.069759852451e-09
  1373 KSP Residual norm 5.081698629546e-09
  1374 KSP Residual norm 5.591195229187e-09
  1375 KSP Residual norm 5.913547221993e-09
  1376 KSP Residual norm 6.030696461741e-09
  1377 KSP Residual norm 6.054336420463e-09
  1378 KSP Residual norm 6.269919305163e-09
  1379 KSP Residual norm 6.393109154438e-09
  1380 KSP Residual norm 6.259991929062e-09
  1381 KSP Residual norm 6.017314653575e-09
  1382 KSP Residual norm 6.108019719040e-09
  1383 KSP Residual norm 6.309376500621e-09
  1384 KSP Residual norm 6.310777047865e-09
  1385 KSP Residual norm 6.675847423541e-09
  1386 KSP Residual norm 7.352149498320e-09
  1387 KSP Residual norm 8.250486916503e-09
  1388 KSP Residual norm 8.513052968240e-09
  1389 KSP Residual norm 8.249043482065e-09
  1390 KSP Residual norm 7.622286228721e-09
  1391 KSP Residual norm 7.747448405644e-09
  1392 KSP Residual norm 8.406074316338e-09
  1393 KSP Residual norm 9.294535267842e-09
  1394 KSP Residual norm 9.531046799137e-09
  1395 KSP Residual norm 9.496251168835e-09
  1396 KSP Residual norm 1.010589553490e-08
  1397 KSP Residual norm 1.090170851741e-08
  1398 KSP Residual norm 1.052211556223e-08
  1399 KSP Residual norm 1.021790606961e-08
  1400 KSP Residual norm 1.004286654038e-08
  1401 KSP Residual norm 1.074533324318e-08
  1402 KSP Residual norm 1.130910961436e-08
  1403 KSP Residual norm 1.090649823476e-08
  1404 KSP Residual norm 1.032580007927e-08
  1405 KSP Residual norm 9.855638426089e-09
  1406 KSP Residual norm 8.988622930243e-09
  1407 KSP Residual norm 8.242702340871e-09
  1408 KSP Residual norm 8.060879284039e-09
  1409 KSP Residual norm 7.746184075645e-09
  1410 KSP Residual norm 6.967198406970e-09
  1411 KSP Residual norm 6.448578582118e-09
  1412 KSP Residual norm 6.231104048162e-09
  1413 KSP Residual norm 6.171242946031e-09
  1414 KSP Residual norm 6.400331745132e-09
  1415 KSP Residual norm 6.967951646008e-09
  1416 KSP Residual norm 7.182359604457e-09
  1417 KSP Residual norm 7.086783585722e-09
  1418 KSP Residual norm 7.022212723172e-09
  1419 KSP Residual norm 7.310181358459e-09
  1420 KSP Residual norm 7.528464685526e-09
  1421 KSP Residual norm 7.577177499084e-09
  1422 KSP Residual norm 7.354810933642e-09
  1423 KSP Residual norm 6.959244342347e-09
  1424 KSP Residual norm 6.565494178522e-09
  1425 KSP Residual norm 6.666715261036e-09
  1426 KSP Residual norm 6.882880963642e-09
  1427 KSP Residual norm 7.165813511189e-09
  1428 KSP Residual norm 7.372403376300e-09
  1429 KSP Residual norm 7.158514503851e-09
  1430 KSP Residual norm 6.690337053705e-09
  1431 KSP Residual norm 6.756178846384e-09
  1432 KSP Residual norm 7.089250083470e-09
  1433 KSP Residual norm 7.175264719540e-09
  1434 KSP Residual norm 7.143748554355e-09
  1435 KSP Residual norm 6.859559068938e-09
  1436 KSP Residual norm 6.514087905487e-09
  1437 KSP Residual norm 6.562643222800e-09
  1438 KSP Residual norm 6.286996638589e-09
  1439 KSP Residual norm 6.062552801710e-09
  1440 KSP Residual norm 6.094373399938e-09
  1441 KSP Residual norm 5.830373295586e-09
  1442 KSP Residual norm 5.627522077750e-09
  1443 KSP Residual norm 5.435861099698e-09
  1444 KSP Residual norm 5.652393116644e-09
  1445 KSP Residual norm 6.186970893932e-09
  1446 KSP Residual norm 6.445166771951e-09
  1447 KSP Residual norm 6.445171276528e-09
  1448 KSP Residual norm 6.528443673474e-09
  1449 KSP Residual norm 6.748282868543e-09
  1450 KSP Residual norm 6.815421719872e-09
  1451 KSP Residual norm 6.663119139805e-09
  1452 KSP Residual norm 6.555604283097e-09
  1453 KSP Residual norm 6.886244609169e-09
  1454 KSP Residual norm 7.233954616481e-09
  1455 KSP Residual norm 7.206090196836e-09
  1456 KSP Residual norm 6.847925290184e-09
  1457 KSP Residual norm 6.544880897185e-09
  1458 KSP Residual norm 6.679356838442e-09
  1459 KSP Residual norm 6.848973731862e-09
  1460 KSP Residual norm 6.585010868100e-09
  1461 KSP Residual norm 6.527079366880e-09
  1462 KSP Residual norm 6.789139960888e-09
  1463 KSP Residual norm 6.865235050360e-09
  1464 KSP Residual norm 6.383461698835e-09
  1465 KSP Residual norm 5.957825132753e-09
  1466 KSP Residual norm 5.594256767203e-09
  1467 KSP Residual norm 5.050259010153e-09
  1468 KSP Residual norm 4.635201330524e-09
  1469 KSP Residual norm 4.588522577443e-09
  1470 KSP Residual norm 4.923162698408e-09
  1471 KSP Residual norm 5.275890603420e-09
  1472 KSP Residual norm 5.438420870909e-09
  1473 KSP Residual norm 5.539471465431e-09
  1474 KSP Residual norm 5.450169152634e-09
  1475 KSP Residual norm 5.764061300490e-09
  1476 KSP Residual norm 6.274072161136e-09
  1477 KSP Residual norm 6.534496745724e-09
  1478 KSP Residual norm 6.689191936490e-09
  1479 KSP Residual norm 7.222196859859e-09
  1480 KSP Residual norm 8.159134912909e-09
  1481 KSP Residual norm 9.079622355516e-09
  1482 KSP Residual norm 8.895603642795e-09
  1483 KSP Residual norm 8.478255971498e-09
  1484 KSP Residual norm 8.215665726515e-09
  1485 KSP Residual norm 8.196166810231e-09
  1486 KSP Residual norm 8.129806329385e-09
  1487 KSP Residual norm 7.712186713730e-09
  1488 KSP Residual norm 7.145726170660e-09
  1489 KSP Residual norm 6.710201723537e-09
  1490 KSP Residual norm 6.183112769537e-09
  1491 KSP Residual norm 5.890996079331e-09
  1492 KSP Residual norm 6.010850376930e-09
  1493 KSP Residual norm 6.320394181203e-09
  1494 KSP Residual norm 6.480675247649e-09
  1495 KSP Residual norm 6.468945225868e-09
  1496 KSP Residual norm 6.413151416541e-09
  1497 KSP Residual norm 6.405683049967e-09
  1498 KSP Residual norm 6.713362378397e-09
  1499 KSP Residual norm 7.362839019693e-09
  1500 KSP Residual norm 8.218546400443e-09
  1501 KSP Residual norm 9.126244371288e-09
  1502 KSP Residual norm 9.187999637682e-09
  1503 KSP Residual norm 8.994224568114e-09
  1504 KSP Residual norm 8.956791651348e-09
  1505 KSP Residual norm 9.008931250954e-09
  1506 KSP Residual norm 8.111298405204e-09
  1507 KSP Residual norm 6.857889616687e-09
  1508 KSP Residual norm 6.176286147163e-09
  1509 KSP Residual norm 6.440231115732e-09
  1510 KSP Residual norm 6.823661389405e-09
  1511 KSP Residual norm 6.992340350875e-09
  1512 KSP Residual norm 6.958305876771e-09
  1513 KSP Residual norm 6.467795789628e-09
  1514 KSP Residual norm 6.353785021005e-09
  1515 KSP Residual norm 6.340916661332e-09
  1516 KSP Residual norm 6.116061543265e-09
  1517 KSP Residual norm 5.807521585733e-09
  1518 KSP Residual norm 5.475984080710e-09
  1519 KSP Residual norm 5.654083515429e-09
  1520 KSP Residual norm 6.166066208453e-09
  1521 KSP Residual norm 6.320483108977e-09
  1522 KSP Residual norm 5.722024017225e-09
  1523 KSP Residual norm 5.188219990147e-09
  1524 KSP Residual norm 5.429086649369e-09
  1525 KSP Residual norm 6.106545681193e-09
  1526 KSP Residual norm 6.674486064947e-09
  1527 KSP Residual norm 6.910667075049e-09
  1528 KSP Residual norm 7.083576459984e-09
  1529 KSP Residual norm 7.029737335857e-09
  1530 KSP Residual norm 6.274380452945e-09
  1531 KSP Residual norm 5.679041113612e-09
  1532 KSP Residual norm 5.635687992529e-09
  1533 KSP Residual norm 5.937116614564e-09
  1534 KSP Residual norm 6.270517604186e-09
  1535 KSP Residual norm 6.244915105009e-09
  1536 KSP Residual norm 5.542777175423e-09
  1537 KSP Residual norm 5.104777082332e-09
  1538 KSP Residual norm 5.609912204567e-09
  1539 KSP Residual norm 6.794471819737e-09
  1540 KSP Residual norm 7.551266820266e-09
  1541 KSP Residual norm 7.657458970890e-09
  1542 KSP Residual norm 7.666962353838e-09
  1543 KSP Residual norm 7.524013071447e-09
  1544 KSP Residual norm 7.015237105295e-09
  1545 KSP Residual norm 6.741916666246e-09
  1546 KSP Residual norm 6.655195334126e-09
  1547 KSP Residual norm 6.749674411151e-09
  1548 KSP Residual norm 6.879670292889e-09
  1549 KSP Residual norm 7.051384388209e-09
  1550 KSP Residual norm 6.901598593430e-09
  1551 KSP Residual norm 6.799594206440e-09
  1552 KSP Residual norm 6.791120105167e-09
  1553 KSP Residual norm 6.615349086539e-09
  1554 KSP Residual norm 6.453552303435e-09
  1555 KSP Residual norm 6.197419971854e-09
  1556 KSP Residual norm 5.846764327012e-09
  1557 KSP Residual norm 5.957828177962e-09
  1558 KSP Residual norm 6.885904302613e-09
  1559 KSP Residual norm 7.918278632307e-09
  1560 KSP Residual norm 8.098796980225e-09
  1561 KSP Residual norm 7.686663728298e-09
  1562 KSP Residual norm 7.302415918739e-09
  1563 KSP Residual norm 7.108455464551e-09
  1564 KSP Residual norm 7.198431086715e-09
  1565 KSP Residual norm 7.332354765431e-09
  1566 KSP Residual norm 7.137457743318e-09
  1567 KSP Residual norm 6.843859668678e-09
  1568 KSP Residual norm 6.280092540185e-09
  1569 KSP Residual norm 5.904344627956e-09
  1570 KSP Residual norm 5.911953943207e-09
  1571 KSP Residual norm 6.395845671491e-09
  1572 KSP Residual norm 6.516540452999e-09
  1573 KSP Residual norm 6.342856496735e-09
  1574 KSP Residual norm 6.432099136908e-09
  1575 KSP Residual norm 6.990799336033e-09
  1576 KSP Residual norm 7.054507263406e-09
  1577 KSP Residual norm 6.403387625555e-09
  1578 KSP Residual norm 5.850568209413e-09
  1579 KSP Residual norm 5.731867704067e-09
  1580 KSP Residual norm 6.151642297887e-09
  1581 KSP Residual norm 6.476135359801e-09
  1582 KSP Residual norm 6.264158263459e-09
  1583 KSP Residual norm 5.789703129690e-09
  1584 KSP Residual norm 5.181119184503e-09
  1585 KSP Residual norm 4.640201574210e-09
  1586 KSP Residual norm 4.543685286328e-09
  1587 KSP Residual norm 4.886622821368e-09
  1588 KSP Residual norm 5.499371925317e-09
  1589 KSP Residual norm 5.827923288971e-09
  1590 KSP Residual norm 5.338254605360e-09
  1591 KSP Residual norm 4.615487114070e-09
  1592 KSP Residual norm 4.557857910604e-09
  1593 KSP Residual norm 5.173542884141e-09
  1594 KSP Residual norm 5.915929603126e-09
  1595 KSP Residual norm 5.912764596601e-09
  1596 KSP Residual norm 5.490354240378e-09
  1597 KSP Residual norm 5.282576243602e-09
  1598 KSP Residual norm 5.174946750847e-09
  1599 KSP Residual norm 5.194932481331e-09
  1600 KSP Residual norm 5.287455161159e-09
  1601 KSP Residual norm 5.580128563512e-09
  1602 KSP Residual norm 6.117273558801e-09
  1603 KSP Residual norm 7.071752727718e-09
  1604 KSP Residual norm 7.464901425403e-09
  1605 KSP Residual norm 7.105943174801e-09
  1606 KSP Residual norm 6.487174801206e-09
  1607 KSP Residual norm 5.797444690955e-09
  1608 KSP Residual norm 5.571365050587e-09
  1609 KSP Residual norm 5.341121800831e-09
  1610 KSP Residual norm 5.387488129072e-09
  1611 KSP Residual norm 5.949467617357e-09
  1612 KSP Residual norm 6.833874143135e-09
  1613 KSP Residual norm 7.145119281720e-09
  1614 KSP Residual norm 5.993885739091e-09
  1615 KSP Residual norm 4.942335038392e-09
  1616 KSP Residual norm 4.592638057255e-09
  1617 KSP Residual norm 4.575130760594e-09
  1618 KSP Residual norm 5.001175421143e-09
  1619 KSP Residual norm 5.479651413713e-09
  1620 KSP Residual norm 5.542987613821e-09
  1621 KSP Residual norm 5.566682970825e-09
  1622 KSP Residual norm 6.039006342030e-09
  1623 KSP Residual norm 6.688281898548e-09
  1624 KSP Residual norm 7.405214752204e-09
  1625 KSP Residual norm 8.192244573982e-09
  1626 KSP Residual norm 8.213320139816e-09
  1627 KSP Residual norm 6.719148898610e-09
  1628 KSP Residual norm 4.816441445922e-09
  1629 KSP Residual norm 3.569276385470e-09
  1630 KSP Residual norm 3.161718929418e-09
  1631 KSP Residual norm 3.384072773542e-09
  1632 KSP Residual norm 4.365942611272e-09
  1633 KSP Residual norm 5.838613372568e-09
  1634 KSP Residual norm 7.063814896833e-09
  1635 KSP Residual norm 6.754881478231e-09
  1636 KSP Residual norm 5.302993549806e-09
  1637 KSP Residual norm 4.022294698904e-09
  1638 KSP Residual norm 3.336830956381e-09
  1639 KSP Residual norm 3.382216790704e-09
  1640 KSP Residual norm 4.122846590595e-09
  1641 KSP Residual norm 5.628455678064e-09
  1642 KSP Residual norm 7.453809527574e-09
  1643 KSP Residual norm 8.585572370746e-09
  1644 KSP Residual norm 7.720245610888e-09
  1645 KSP Residual norm 5.839892756764e-09
  1646 KSP Residual norm 4.562759110000e-09
  1647 KSP Residual norm 4.035502971172e-09
  1648 KSP Residual norm 4.459746395291e-09
  1649 KSP Residual norm 6.339971680605e-09
  1650 KSP Residual norm 9.544252251435e-09
  1651 KSP Residual norm 1.277853505406e-08
  1652 KSP Residual norm 1.333674987639e-08
  1653 KSP Residual norm 1.018728090427e-08
  1654 KSP Residual norm 6.787602195166e-09
  1655 KSP Residual norm 4.634761985687e-09
  1656 KSP Residual norm 3.884765096322e-09
  1657 KSP Residual norm 4.452327817239e-09
  1658 KSP Residual norm 6.187708996720e-09
  1659 KSP Residual norm 9.188762273242e-09
  1660 KSP Residual norm 1.249234464833e-08
  1661 KSP Residual norm 1.199108676087e-08
  1662 KSP Residual norm 8.552244908845e-09
  1663 KSP Residual norm 5.350571406453e-09
  1664 KSP Residual norm 3.718955784274e-09
  1665 KSP Residual norm 3.264820096550e-09
  1666 KSP Residual norm 3.738781861703e-09
  1667 KSP Residual norm 5.868977171989e-09
  1668 KSP Residual norm 1.009716432728e-08
  1669 KSP Residual norm 1.436105605370e-08
  1670 KSP Residual norm 1.301939326527e-08
  1671 KSP Residual norm 8.547140158888e-09
  1672 KSP Residual norm 5.136000634038e-09
  1673 KSP Residual norm 3.666011695231e-09
  1674 KSP Residual norm 3.661543587382e-09
  1675 KSP Residual norm 5.172136262899e-09
  1676 KSP Residual norm 8.102397425397e-09
  1677 KSP Residual norm 1.061328652132e-08
  1678 KSP Residual norm 1.024850504659e-08
  1679 KSP Residual norm 7.497006947870e-09
  1680 KSP Residual norm 4.699527341785e-09
  1681 KSP Residual norm 3.256915648897e-09
  1682 KSP Residual norm 2.904042292936e-09
  1683 KSP Residual norm 3.406465868263e-09
  1684 KSP Residual norm 5.201344426952e-09
  1685 KSP Residual norm 8.658733429381e-09
  1686 KSP Residual norm 1.349484446793e-08
  1687 KSP Residual norm 1.480056569974e-08
  1688 KSP Residual norm 1.034265976153e-08
  1689 KSP Residual norm 5.922786724866e-09
  1690 KSP Residual norm 3.946059101282e-09
  1691 KSP Residual norm 3.478074210148e-09
  1692 KSP Residual norm 3.825656362010e-09
  1693 KSP Residual norm 5.101541505286e-09
  1694 KSP Residual norm 8.122535643963e-09
  1695 KSP Residual norm 1.310865373363e-08
  1696 KSP Residual norm 1.852190796237e-08
  1697 KSP Residual norm 1.750532575209e-08
  1698 KSP Residual norm 1.195401840458e-08
  1699 KSP Residual norm 7.469248030256e-09
  1700 KSP Residual norm 5.429595671418e-09
  1701 KSP Residual norm 5.120735893425e-09
  1702 KSP Residual norm 6.344323256916e-09
  1703 KSP Residual norm 1.005316504690e-08
  1704 KSP Residual norm 1.847642997386e-08
  1705 KSP Residual norm 3.055363250437e-08
  1706 KSP Residual norm 3.745170469893e-08
  1707 KSP Residual norm 2.894167662406e-08
  1708 KSP Residual norm 1.573341449007e-08
  1709 KSP Residual norm 8.793214737611e-09
  1710 KSP Residual norm 5.976477842103e-09
  1711 KSP Residual norm 5.542141477006e-09
  1712 KSP Residual norm 7.472309843921e-09
  1713 KSP Residual norm 1.329830601414e-08
  1714 KSP Residual norm 2.116608001002e-08
  1715 KSP Residual norm 2.352195802296e-08
  1716 KSP Residual norm 1.976217034417e-08
  1717 KSP Residual norm 1.801947342850e-08
  1718 KSP Residual norm 1.828554262245e-08
  1719 KSP Residual norm 1.760195187008e-08
  1720 KSP Residual norm 1.280354947717e-08
  1721 KSP Residual norm 8.451736364491e-09
  1722 KSP Residual norm 6.774907628386e-09
  1723 KSP Residual norm 7.218941102094e-09
  1724 KSP Residual norm 1.027905090372e-08
  1725 KSP Residual norm 1.474928042566e-08
  1726 KSP Residual norm 1.733499186888e-08
  1727 KSP Residual norm 1.788010785926e-08
  1728 KSP Residual norm 2.026175285120e-08
  1729 KSP Residual norm 2.526034973014e-08
  1730 KSP Residual norm 2.603499434422e-08
  1731 KSP Residual norm 1.923848259791e-08
  1732 KSP Residual norm 1.269150796253e-08
  1733 KSP Residual norm 1.060884812411e-08
  1734 KSP Residual norm 1.121019061563e-08
  1735 KSP Residual norm 1.170739883726e-08
  1736 KSP Residual norm 9.900160343060e-09
  1737 KSP Residual norm 7.366235694034e-09
  1738 KSP Residual norm 6.525633125056e-09
  1739 KSP Residual norm 7.892408545725e-09
  1740 KSP Residual norm 1.173096638007e-08
  1741 KSP Residual norm 1.602540287519e-08
  1742 KSP Residual norm 1.716535327318e-08
  1743 KSP Residual norm 1.598567556601e-08
  1744 KSP Residual norm 1.730297482535e-08
  1745 KSP Residual norm 2.129119221021e-08
  1746 KSP Residual norm 2.342872435743e-08
  1747 KSP Residual norm 1.777124044598e-08
  1748 KSP Residual norm 1.248784132970e-08
  1749 KSP Residual norm 9.849689081455e-09
  1750 KSP Residual norm 8.704322735055e-09
  1751 KSP Residual norm 7.815148094748e-09
  1752 KSP Residual norm 6.549680348628e-09
  1753 KSP Residual norm 5.704521062665e-09
  1754 KSP Residual norm 5.467258644598e-09
  1755 KSP Residual norm 6.364436168776e-09
  1756 KSP Residual norm 7.983867064264e-09
  1757 KSP Residual norm 8.999623138887e-09
  1758 KSP Residual norm 9.459257919283e-09
  1759 KSP Residual norm 1.133172032843e-08
  1760 KSP Residual norm 1.613675607867e-08
  1761 KSP Residual norm 2.254356723549e-08
  1762 KSP Residual norm 2.391265453795e-08
  1763 KSP Residual norm 2.057232498243e-08
  1764 KSP Residual norm 1.752588794538e-08
  1765 KSP Residual norm 1.717382880075e-08
  1766 KSP Residual norm 1.642590216359e-08
  1767 KSP Residual norm 1.256531750183e-08
  1768 KSP Residual norm 8.516038842617e-09
  1769 KSP Residual norm 7.234320500545e-09
  1770 KSP Residual norm 7.596160652642e-09
  1771 KSP Residual norm 8.904076728744e-09
  1772 KSP Residual norm 9.042841058097e-09
  1773 KSP Residual norm 8.498177420260e-09
  1774 KSP Residual norm 9.264797639594e-09
  1775 KSP Residual norm 1.218853216383e-08
  1776 KSP Residual norm 1.589969823584e-08
  1777 KSP Residual norm 1.689252909459e-08
  1778 KSP Residual norm 1.537543973601e-08
  1779 KSP Residual norm 1.573806341339e-08
  1780 KSP Residual norm 1.891512673160e-08
  1781 KSP Residual norm 2.210719254489e-08
  1782 KSP Residual norm 1.974345296844e-08
  1783 KSP Residual norm 1.638111270806e-08
  1784 KSP Residual norm 1.479827356574e-08
  1785 KSP Residual norm 1.476432877437e-08
  1786 KSP Residual norm 1.373550665203e-08
  1787 KSP Residual norm 1.061094861872e-08
  1788 KSP Residual norm 8.080373386618e-09
  1789 KSP Residual norm 7.632636997264e-09
  1790 KSP Residual norm 9.164688190743e-09
  1791 KSP Residual norm 1.067897504869e-08
  1792 KSP Residual norm 1.036983113582e-08
  1793 KSP Residual norm 1.022905298199e-08
  1794 KSP Residual norm 1.230158077891e-08
  1795 KSP Residual norm 1.608756654318e-08
  1796 KSP Residual norm 1.904297873147e-08
  1797 KSP Residual norm 1.788470456475e-08
  1798 KSP Residual norm 1.731695711901e-08
  1799 KSP Residual norm 2.030644250363e-08
  1800 KSP Residual norm 2.329210952484e-08
  1801 KSP Residual norm 2.013022304072e-08
  1802 KSP Residual norm 1.541458496493e-08
  1803 KSP Residual norm 1.322871545010e-08
  1804 KSP Residual norm 1.208525458204e-08
  1805 KSP Residual norm 1.121080615712e-08
  1806 KSP Residual norm 8.949785326725e-09
  1807 KSP Residual norm 6.569588845211e-09
  1808 KSP Residual norm 5.358179174338e-09
  1809 KSP Residual norm 5.162364029233e-09
  1810 KSP Residual norm 5.522616748915e-09
  1811 KSP Residual norm 5.458132785714e-09
  1812 KSP Residual norm 5.237020215507e-09
  1813 KSP Residual norm 5.816194788577e-09
  1814 KSP Residual norm 7.701676381278e-09
  1815 KSP Residual norm 1.116293028979e-08
  1816 KSP Residual norm 1.327857071381e-08
  1817 KSP Residual norm 1.295919675400e-08
  1818 KSP Residual norm 1.429161180964e-08
  1819 KSP Residual norm 1.859301931437e-08
  1820 KSP Residual norm 2.330822930914e-08
  1821 KSP Residual norm 2.306253036764e-08
  1822 KSP Residual norm 2.019566520997e-08
  1823 KSP Residual norm 1.997990240906e-08
  1824 KSP Residual norm 2.229829398227e-08
  1825 KSP Residual norm 2.159665340240e-08
  1826 KSP Residual norm 1.781093990726e-08
  1827 KSP Residual norm 1.508308993315e-08
  1828 KSP Residual norm 1.466340210288e-08
  1829 KSP Residual norm 1.406366536224e-08
  1830 KSP Residual norm 1.153869244684e-08
  1831 KSP Residual norm 9.168480281613e-09
  1832 KSP Residual norm 7.926855457118e-09
  1833 KSP Residual norm 7.629078007991e-09
  1834 KSP Residual norm 7.095628733395e-09
  1835 KSP Residual norm 5.816365626893e-09
  1836 KSP Residual norm 5.228358158961e-09
  1837 KSP Residual norm 5.966904006649e-09
  1838 KSP Residual norm 7.801035160832e-09
  1839 KSP Residual norm 9.025098740914e-09
  1840 KSP Residual norm 9.635038602733e-09
  1841 KSP Residual norm 1.079466311366e-08
  1842 KSP Residual norm 1.313896727167e-08
  1843 KSP Residual norm 1.618865461740e-08
  1844 KSP Residual norm 1.713577583648e-08
  1845 KSP Residual norm 1.684058929489e-08
  1846 KSP Residual norm 1.818481532415e-08
  1847 KSP Residual norm 2.016280652098e-08
  1848 KSP Residual norm 1.860839518552e-08
  1849 KSP Residual norm 1.387186213987e-08
  1850 KSP Residual norm 1.199747151286e-08
  1851 KSP Residual norm 1.220805212276e-08
  1852 KSP Residual norm 1.195497789080e-08
  1853 KSP Residual norm 9.483156084109e-09
  1854 KSP Residual norm 7.155822214847e-09
  1855 KSP Residual norm 6.440129885764e-09
  1856 KSP Residual norm 6.833104397731e-09
  1857 KSP Residual norm 6.833048263177e-09
  1858 KSP Residual norm 5.965312918960e-09
  1859 KSP Residual norm 5.754759350189e-09
  1860 KSP Residual norm 6.478501589805e-09
  1861 KSP Residual norm 6.908714291275e-09
  1862 KSP Residual norm 6.275959164779e-09
  1863 KSP Residual norm 6.234284503816e-09
  1864 KSP Residual norm 7.462466450869e-09
  1865 KSP Residual norm 1.010278392749e-08
  1866 KSP Residual norm 1.211599682211e-08
  1867 KSP Residual norm 1.203590489442e-08
  1868 KSP Residual norm 1.149924770875e-08
  1869 KSP Residual norm 1.255803267784e-08
  1870 KSP Residual norm 1.471173662658e-08
  1871 KSP Residual norm 1.489013230380e-08
  1872 KSP Residual norm 1.331860786533e-08
  1873 KSP Residual norm 1.197295717444e-08
  1874 KSP Residual norm 1.175092691038e-08
  1875 KSP Residual norm 1.065113986256e-08
  1876 KSP Residual norm 8.854186060263e-09
  1877 KSP Residual norm 8.042736995728e-09
  1878 KSP Residual norm 7.687537624914e-09
  1879 KSP Residual norm 6.979535142410e-09
  1880 KSP Residual norm 5.828717889093e-09
  1881 KSP Residual norm 5.061855541307e-09
  1882 KSP Residual norm 5.097822909601e-09
  1883 KSP Residual norm 5.635232948463e-09
  1884 KSP Residual norm 5.528839162897e-09
  1885 KSP Residual norm 5.075976285308e-09
  1886 KSP Residual norm 5.271339773256e-09
  1887 KSP Residual norm 6.466522966761e-09
  1888 KSP Residual norm 7.698424896003e-09
  1889 KSP Residual norm 7.537857878592e-09
  1890 KSP Residual norm 7.841477714487e-09
  1891 KSP Residual norm 9.802089370960e-09
  1892 KSP Residual norm 1.186683301708e-08
  1893 KSP Residual norm 1.181572401973e-08
  1894 KSP Residual norm 1.088560446859e-08
  1895 KSP Residual norm 1.074363967601e-08
  1896 KSP Residual norm 1.091873109012e-08
  1897 KSP Residual norm 1.011447702529e-08
  1898 KSP Residual norm 8.607150935035e-09
  1899 KSP Residual norm 7.809768672545e-09
  1900 KSP Residual norm 7.271647130807e-09
  1901 KSP Residual norm 6.151894558418e-09
  1902 KSP Residual norm 4.701650767176e-09
  1903 KSP Residual norm 4.001250930082e-09
  1904 KSP Residual norm 4.014342670641e-09
  1905 KSP Residual norm 4.014755518569e-09
  1906 KSP Residual norm 3.381486151607e-09
  1907 KSP Residual norm 2.860570095875e-09
  1908 KSP Residual norm 2.787194249446e-09
  1909 KSP Residual norm 2.925637573286e-09
  1910 KSP Residual norm 2.850768392710e-09
  1911 KSP Residual norm 2.629632141618e-09
  1912 KSP Residual norm 2.543488281363e-09
  1913 KSP Residual norm 2.758665203168e-09
  1914 KSP Residual norm 3.122577954135e-09
  1915 KSP Residual norm 3.300279104415e-09
  1916 KSP Residual norm 3.575903972707e-09
  1917 KSP Residual norm 4.331383168363e-09
  1918 KSP Residual norm 5.322382648184e-09
  1919 KSP Residual norm 5.989643009644e-09
  1920 KSP Residual norm 6.129501873252e-09
  1921 KSP Residual norm 6.558677929064e-09
  1922 KSP Residual norm 7.448496029930e-09
  1923 KSP Residual norm 8.309276460357e-09
  1924 KSP Residual norm 8.888394508602e-09
  1925 KSP Residual norm 9.260993804675e-09
  1926 KSP Residual norm 9.398818802763e-09
  1927 KSP Residual norm 9.167733030243e-09
  1928 KSP Residual norm 8.694452036454e-09
  1929 KSP Residual norm 8.118493730918e-09
  1930 KSP Residual norm 7.552453726393e-09
  1931 KSP Residual norm 6.690468117701e-09
  1932 KSP Residual norm 5.906787021661e-09
  1933 KSP Residual norm 5.475548056650e-09
  1934 KSP Residual norm 5.101915525627e-09
  1935 KSP Residual norm 4.372814211622e-09
  1936 KSP Residual norm 3.635411946770e-09
  1937 KSP Residual norm 3.474617295726e-09
  1938 KSP Residual norm 3.691623873856e-09
  1939 KSP Residual norm 3.769104859578e-09
  1940 KSP Residual norm 3.654357596247e-09
  1941 KSP Residual norm 3.676225696378e-09
  1942 KSP Residual norm 4.060283810478e-09
  1943 KSP Residual norm 4.794706100032e-09
  1944 KSP Residual norm 5.124706513180e-09
  1945 KSP Residual norm 4.973925947713e-09
  1946 KSP Residual norm 5.341217972474e-09
  1947 KSP Residual norm 6.724200294589e-09
  1948 KSP Residual norm 7.956478285450e-09
  1949 KSP Residual norm 8.457839054913e-09
  1950 KSP Residual norm 8.967832999552e-09
  1951 KSP Residual norm 1.079873418093e-08
  1952 KSP Residual norm 1.188594306097e-08
  1953 KSP Residual norm 1.187881125415e-08
  1954 KSP Residual norm 1.186042252355e-08
  1955 KSP Residual norm 1.215056506464e-08
  1956 KSP Residual norm 1.189277288364e-08
  1957 KSP Residual norm 1.102180231854e-08
  1958 KSP Residual norm 1.056733835946e-08
  1959 KSP Residual norm 1.070061030016e-08
  1960 KSP Residual norm 1.053021970473e-08
  1961 KSP Residual norm 9.302144668995e-09
  1962 KSP Residual norm 8.563188146430e-09
  1963 KSP Residual norm 8.636311626926e-09
  1964 KSP Residual norm 8.225365528182e-09
  1965 KSP Residual norm 6.776914402484e-09
  1966 KSP Residual norm 5.856719971272e-09
  1967 KSP Residual norm 5.674287606106e-09
  1968 KSP Residual norm 5.405078139958e-09
  1969 KSP Residual norm 4.400452615927e-09
  1970 KSP Residual norm 3.686095705298e-09
  1971 KSP Residual norm 3.423827820756e-09
  1972 KSP Residual norm 3.212476288681e-09
  1973 KSP Residual norm 2.812927100868e-09
  1974 KSP Residual norm 2.545718902593e-09
  1975 KSP Residual norm 2.685895353071e-09
  1976 KSP Residual norm 3.047570960645e-09
  1977 KSP Residual norm 3.139469952608e-09
  1978 KSP Residual norm 3.290853250926e-09
  1979 KSP Residual norm 3.797355271334e-09
  1980 KSP Residual norm 4.220123069091e-09
  1981 KSP Residual norm 4.573388248561e-09
  1982 KSP Residual norm 4.799374598505e-09
  1983 KSP Residual norm 5.168404604099e-09
  1984 KSP Residual norm 6.125216462392e-09
  1985 KSP Residual norm 7.355668791331e-09
  1986 KSP Residual norm 8.492608513183e-09
  1987 KSP Residual norm 9.785696118936e-09
  1988 KSP Residual norm 1.142568762660e-08
  1989 KSP Residual norm 1.267567918020e-08
  1990 KSP Residual norm 1.296256317284e-08
  1991 KSP Residual norm 1.278542028330e-08
  1992 KSP Residual norm 1.384185237478e-08
  1993 KSP Residual norm 1.492501923916e-08
  1994 KSP Residual norm 1.498357150428e-08
  1995 KSP Residual norm 1.459317975598e-08
  1996 KSP Residual norm 1.530320681307e-08
  1997 KSP Residual norm 1.586709210965e-08
  1998 KSP Residual norm 1.455087112376e-08
  1999 KSP Residual norm 1.210461945035e-08
  2000 KSP Residual norm 1.088544041600e-08
  2001 KSP Residual norm 1.015678590302e-08
  2002 KSP Residual norm 8.785680491739e-09
  2003 KSP Residual norm 7.162297936646e-09
  2004 KSP Residual norm 6.219081471319e-09
  2005 KSP Residual norm 6.158646998047e-09
  2006 KSP Residual norm 5.883414720073e-09
  2007 KSP Residual norm 5.058300095333e-09
  2008 KSP Residual norm 4.282198234298e-09
  2009 KSP Residual norm 4.011222031996e-09
  2010 KSP Residual norm 3.860601041274e-09
  2011 KSP Residual norm 3.343380168272e-09
  2012 KSP Residual norm 2.982887267319e-09
  2013 KSP Residual norm 3.041729383032e-09
  2014 KSP Residual norm 3.321134508816e-09
  2015 KSP Residual norm 3.554899694626e-09
  2016 KSP Residual norm 3.851531701994e-09
  2017 KSP Residual norm 4.262354490114e-09
  2018 KSP Residual norm 4.956661540559e-09
  2019 KSP Residual norm 5.407005925179e-09
  2020 KSP Residual norm 5.319152303475e-09
  2021 KSP Residual norm 5.647028584698e-09
  2022 KSP Residual norm 6.814017830980e-09
  2023 KSP Residual norm 7.988386234640e-09
  2024 KSP Residual norm 8.002221121661e-09
  2025 KSP Residual norm 8.100794945750e-09
  2026 KSP Residual norm 8.669333119823e-09
  2027 KSP Residual norm 9.139603961619e-09
  2028 KSP Residual norm 8.850704165089e-09
  2029 KSP Residual norm 9.216507414717e-09
  2030 KSP Residual norm 9.623212278569e-09
  2031 KSP Residual norm 8.980714559382e-09
  2032 KSP Residual norm 7.533323551446e-09
  2033 KSP Residual norm 6.805500572549e-09
  2034 KSP Residual norm 6.248699676593e-09
  2035 KSP Residual norm 5.832948034853e-09
  2036 KSP Residual norm 5.439983993243e-09
  2037 KSP Residual norm 5.233831436763e-09
  2038 KSP Residual norm 5.165909444091e-09
  2039 KSP Residual norm 4.871990250703e-09
  2040 KSP Residual norm 4.412149176292e-09
  2041 KSP Residual norm 3.995011545730e-09
  2042 KSP Residual norm 3.950119802286e-09
  2043 KSP Residual norm 3.736957978864e-09
  2044 KSP Residual norm 3.371533629831e-09
  2045 KSP Residual norm 3.213106028831e-09
  2046 KSP Residual norm 3.371732022504e-09
  2047 KSP Residual norm 3.570045121255e-09
  2048 KSP Residual norm 3.643938053927e-09
  2049 KSP Residual norm 3.728190288317e-09
  2050 KSP Residual norm 3.964004855891e-09
  2051 KSP Residual norm 4.420555370104e-09
  2052 KSP Residual norm 4.737581481973e-09
  2053 KSP Residual norm 5.107093954646e-09
  2054 KSP Residual norm 5.835900836343e-09
  2055 KSP Residual norm 6.209834941748e-09
  2056 KSP Residual norm 6.285170592162e-09
  2057 KSP Residual norm 6.411575279884e-09
  2058 KSP Residual norm 6.797719534515e-09
  2059 KSP Residual norm 7.195568796046e-09
  2060 KSP Residual norm 7.783525041961e-09
  2061 KSP Residual norm 8.491411039081e-09
  2062 KSP Residual norm 8.960477378264e-09
  2063 KSP Residual norm 9.874208707923e-09
  2064 KSP Residual norm 1.080702145127e-08
  2065 KSP Residual norm 1.101233769388e-08
  2066 KSP Residual norm 1.099306098986e-08
  2067 KSP Residual norm 1.124803426964e-08
  2068 KSP Residual norm 1.183694566938e-08
  2069 KSP Residual norm 1.145792372067e-08
  2070 KSP Residual norm 1.041547906245e-08
  2071 KSP Residual norm 9.871020973997e-09
  2072 KSP Residual norm 9.161857076316e-09
  2073 KSP Residual norm 8.267421448092e-09
  2074 KSP Residual norm 7.895001813094e-09
  2075 KSP Residual norm 8.030575766766e-09
  2076 KSP Residual norm 7.784006674563e-09
  2077 KSP Residual norm 6.564235338202e-09
  2078 KSP Residual norm 6.011576670459e-09
  2079 KSP Residual norm 5.871462759477e-09
  2080 KSP Residual norm 5.419567445641e-09
  2081 KSP Residual norm 4.597519438500e-09
  2082 KSP Residual norm 4.226957859381e-09
  2083 KSP Residual norm 4.415885326075e-09
  2084 KSP Residual norm 4.449295156468e-09
  2085 KSP Residual norm 4.029722722723e-09
  2086 KSP Residual norm 3.707480170466e-09
  2087 KSP Residual norm 3.834906124398e-09
  2088 KSP Residual norm 3.862734618636e-09
  2089 KSP Residual norm 3.568600227124e-09
  2090 KSP Residual norm 3.452225474400e-09
  2091 KSP Residual norm 3.989421030181e-09
  2092 KSP Residual norm 4.808559410741e-09
  2093 KSP Residual norm 5.071308160787e-09
  2094 KSP Residual norm 5.304399069072e-09
  2095 KSP Residual norm 6.232520962593e-09
  2096 KSP Residual norm 7.250939909301e-09
  2097 KSP Residual norm 7.178354715506e-09
  2098 KSP Residual norm 6.668509367606e-09
  2099 KSP Residual norm 6.920186896191e-09
  2100 KSP Residual norm 8.044591961235e-09
  2101 KSP Residual norm 8.572338116056e-09
  2102 KSP Residual norm 8.589921835449e-09
  2103 KSP Residual norm 9.603182268822e-09
  2104 KSP Residual norm 1.113859303748e-08
  2105 KSP Residual norm 1.122691963643e-08
  2106 KSP Residual norm 1.102081131919e-08
  2107 KSP Residual norm 1.131855632082e-08
  2108 KSP Residual norm 1.145658292058e-08
  2109 KSP Residual norm 1.123578497315e-08
  2110 KSP Residual norm 1.064087568512e-08
  2111 KSP Residual norm 1.052421671550e-08
  2112 KSP Residual norm 1.018539284527e-08
  2113 KSP Residual norm 9.582476339267e-09
  2114 KSP Residual norm 9.047997301229e-09
  2115 KSP Residual norm 8.149919442029e-09
  2116 KSP Residual norm 7.413352469129e-09
  2117 KSP Residual norm 6.762678437961e-09
  2118 KSP Residual norm 6.234759641656e-09
  2119 KSP Residual norm 6.021826477371e-09
  2120 KSP Residual norm 5.906263593390e-09
  2121 KSP Residual norm 5.670976330175e-09
  2122 KSP Residual norm 5.135499528580e-09
  2123 KSP Residual norm 4.651345894403e-09
  2124 KSP Residual norm 4.567896368396e-09
  2125 KSP Residual norm 4.379734816592e-09
  2126 KSP Residual norm 3.988119161519e-09
  2127 KSP Residual norm 3.645233406037e-09
  2128 KSP Residual norm 3.594578588641e-09
  2129 KSP Residual norm 3.799772163555e-09
  2130 KSP Residual norm 3.874407248191e-09
  2131 KSP Residual norm 3.899523925124e-09
  2132 KSP Residual norm 3.941871180715e-09
  2133 KSP Residual norm 4.220383101920e-09
  2134 KSP Residual norm 4.638510413027e-09
  2135 KSP Residual norm 4.921723051313e-09
  2136 KSP Residual norm 5.415365280333e-09
  2137 KSP Residual norm 6.197773697727e-09
  2138 KSP Residual norm 6.519207022254e-09
  2139 KSP Residual norm 6.524634021206e-09
  2140 KSP Residual norm 7.188245941792e-09
  2141 KSP Residual norm 9.104321152297e-09
  2142 KSP Residual norm 1.013847489269e-08
  2143 KSP Residual norm 1.013238294629e-08
  2144 KSP Residual norm 1.100532121028e-08
  2145 KSP Residual norm 1.256019105239e-08
  2146 KSP Residual norm 1.328149455892e-08
  2147 KSP Residual norm 1.376931111546e-08
  2148 KSP Residual norm 1.459563897719e-08
  2149 KSP Residual norm 1.470429193024e-08
  2150 KSP Residual norm 1.375560507137e-08
  2151 KSP Residual norm 1.267627228963e-08
  2152 KSP Residual norm 1.237541171865e-08
  2153 KSP Residual norm 1.300234164549e-08
  2154 KSP Residual norm 1.340529952548e-08
  2155 KSP Residual norm 1.289142213633e-08
  2156 KSP Residual norm 1.227270539917e-08
  2157 KSP Residual norm 1.220879997904e-08
  2158 KSP Residual norm 1.102751780957e-08
  2159 KSP Residual norm 9.346548841594e-09
  2160 KSP Residual norm 8.714478472795e-09
  2161 KSP Residual norm 8.703613006859e-09
  2162 KSP Residual norm 8.628193419787e-09
  2163 KSP Residual norm 7.849825671412e-09
  2164 KSP Residual norm 7.176800477640e-09
  2165 KSP Residual norm 6.796051542640e-09
  2166 KSP Residual norm 6.260209098082e-09
  2167 KSP Residual norm 5.933056967721e-09
  2168 KSP Residual norm 6.153632090377e-09
  2169 KSP Residual norm 6.448354297310e-09
  2170 KSP Residual norm 6.255303154254e-09
  2171 KSP Residual norm 6.092975081473e-09
  2172 KSP Residual norm 6.452634646636e-09
  2173 KSP Residual norm 6.970074186049e-09
  2174 KSP Residual norm 6.985377630371e-09
  2175 KSP Residual norm 6.938485007048e-09
  2176 KSP Residual norm 7.184606294804e-09
  2177 KSP Residual norm 7.581414708776e-09
  2178 KSP Residual norm 7.700585512259e-09
  2179 KSP Residual norm 7.782657130356e-09
  2180 KSP Residual norm 8.532754847073e-09
  2181 KSP Residual norm 9.276343146556e-09
  2182 KSP Residual norm 9.705554876659e-09
  2183 KSP Residual norm 1.036653537425e-08
  2184 KSP Residual norm 1.162089117302e-08
  2185 KSP Residual norm 1.276264634329e-08
  2186 KSP Residual norm 1.270274745815e-08
  2187 KSP Residual norm 1.330431323139e-08
  2188 KSP Residual norm 1.565994751065e-08
  2189 KSP Residual norm 1.743337151094e-08
  2190 KSP Residual norm 1.685584536665e-08
  2191 KSP Residual norm 1.685732393210e-08
  2192 KSP Residual norm 1.806024323263e-08
  2193 KSP Residual norm 1.820978501429e-08
  2194 KSP Residual norm 1.757941035548e-08
  2195 KSP Residual norm 1.737878089742e-08
  2196 KSP Residual norm 1.821200319246e-08
  2197 KSP Residual norm 1.887672839494e-08
  2198 KSP Residual norm 1.833388517475e-08
  2199 KSP Residual norm 1.755218724790e-08
  2200 KSP Residual norm 1.652514085015e-08
  2201 KSP Residual norm 1.540189602546e-08
  2202 KSP Residual norm 1.362227524045e-08
  2203 KSP Residual norm 1.250178007269e-08
  2204 KSP Residual norm 1.197898676209e-08
  2205 KSP Residual norm 1.107428842686e-08
  2206 KSP Residual norm 1.026194276605e-08
  2207 KSP Residual norm 9.421250565185e-09
  2208 KSP Residual norm 8.736419867530e-09
  2209 KSP Residual norm 7.570641010130e-09
  2210 KSP Residual norm 6.458702895554e-09
  2211 KSP Residual norm 5.977767379276e-09
  2212 KSP Residual norm 5.854562933165e-09
  2213 KSP Residual norm 5.629457453704e-09
  2214 KSP Residual norm 5.136084482492e-09
  2215 KSP Residual norm 4.941347486066e-09
  2216 KSP Residual norm 4.778514083511e-09
  2217 KSP Residual norm 4.564253784304e-09
  2218 KSP Residual norm 4.296953423563e-09
  2219 KSP Residual norm 4.183040046050e-09
  2220 KSP Residual norm 4.055234767666e-09
  2221 KSP Residual norm 4.000812566048e-09
  2222 KSP Residual norm 4.055458569808e-09
  2223 KSP Residual norm 4.176607568961e-09
  2224 KSP Residual norm 4.236486273663e-09
  2225 KSP Residual norm 4.423720668725e-09
  2226 KSP Residual norm 4.344304158398e-09
  2227 KSP Residual norm 4.266936521673e-09
  2228 KSP Residual norm 4.313535237041e-09
  2229 KSP Residual norm 4.546054737770e-09
  2230 KSP Residual norm 4.622964529090e-09
  2231 KSP Residual norm 4.804454582027e-09
  2232 KSP Residual norm 5.115850555569e-09
  2233 KSP Residual norm 5.834416680875e-09
  2234 KSP Residual norm 6.689995442789e-09
  2235 KSP Residual norm 7.098021519377e-09
  2236 KSP Residual norm 7.533528438990e-09
  2237 KSP Residual norm 8.502148216529e-09
  2238 KSP Residual norm 9.757832100791e-09
  2239 KSP Residual norm 1.035498832046e-08
  2240 KSP Residual norm 1.068832314800e-08
  2241 KSP Residual norm 1.156280626256e-08
  2242 KSP Residual norm 1.233987441610e-08
  2243 KSP Residual norm 1.271097415990e-08
  2244 KSP Residual norm 1.334160456664e-08
  2245 KSP Residual norm 1.405762190009e-08
  2246 KSP Residual norm 1.496343494878e-08
  2247 KSP Residual norm 1.581882857281e-08
  2248 KSP Residual norm 1.737848290642e-08
  2249 KSP Residual norm 1.840533082126e-08
  2250 KSP Residual norm 1.866635029912e-08
  2251 KSP Residual norm 1.898010812871e-08
  2252 KSP Residual norm 1.852337708487e-08
  2253 KSP Residual norm 1.825786239476e-08
  2254 KSP Residual norm 1.786171860744e-08
  2255 KSP Residual norm 1.701521787917e-08
  2256 KSP Residual norm 1.706541593836e-08
  2257 KSP Residual norm 1.710391270987e-08
  2258 KSP Residual norm 1.643045265157e-08
  2259 KSP Residual norm 1.514080342739e-08
  2260 KSP Residual norm 1.491368249483e-08
  2261 KSP Residual norm 1.505806019867e-08
  2262 KSP Residual norm 1.385720256023e-08
  2263 KSP Residual norm 1.284049729924e-08
  2264 KSP Residual norm 1.292276488384e-08
  2265 KSP Residual norm 1.319321029002e-08
  2266 KSP Residual norm 1.224451181118e-08
  2267 KSP Residual norm 1.065966854373e-08
  2268 KSP Residual norm 9.787363081609e-09
  2269 KSP Residual norm 9.122735711913e-09
  2270 KSP Residual norm 8.165035569607e-09
  2271 KSP Residual norm 7.237998127129e-09
  2272 KSP Residual norm 6.517751187211e-09
  2273 KSP Residual norm 6.344590541439e-09
  2274 KSP Residual norm 6.340678306741e-09
  2275 KSP Residual norm 5.715836233839e-09
  2276 KSP Residual norm 5.397662857791e-09
  2277 KSP Residual norm 5.230339854715e-09
  2278 KSP Residual norm 4.586690577107e-09
  2279 KSP Residual norm 3.964709291929e-09
  2280 KSP Residual norm 3.949355277585e-09
  2281 KSP Residual norm 4.327578375786e-09
  2282 KSP Residual norm 4.296132073917e-09
  2283 KSP Residual norm 4.106768919770e-09
  2284 KSP Residual norm 4.286676700930e-09
  2285 KSP Residual norm 4.869388691933e-09
  2286 KSP Residual norm 4.973304533827e-09
  2287 KSP Residual norm 4.584311545845e-09
  2288 KSP Residual norm 4.461168235661e-09
  2289 KSP Residual norm 4.854803468229e-09
  2290 KSP Residual norm 5.415828792883e-09
  2291 KSP Residual norm 5.920845157786e-09
  2292 KSP Residual norm 6.796133099936e-09
  2293 KSP Residual norm 7.551207915952e-09
  2294 KSP Residual norm 7.734265715194e-09
  2295 KSP Residual norm 8.006329828344e-09
  2296 KSP Residual norm 9.407041749222e-09
  2297 KSP Residual norm 1.034294380601e-08
  2298 KSP Residual norm 1.023796060750e-08
  2299 KSP Residual norm 1.086984507408e-08
  2300 KSP Residual norm 1.307877565763e-08
  2301 KSP Residual norm 1.448597116570e-08
  2302 KSP Residual norm 1.507716576250e-08
  2303 KSP Residual norm 1.683366414771e-08
  2304 KSP Residual norm 1.970119004799e-08
  2305 KSP Residual norm 2.174094043351e-08
  2306 KSP Residual norm 2.180344378516e-08
  2307 KSP Residual norm 2.136448330890e-08
  2308 KSP Residual norm 2.181920651456e-08
  2309 KSP Residual norm 2.379090777135e-08
  2310 KSP Residual norm 2.551817412914e-08
  2311 KSP Residual norm 2.674366462544e-08
  2312 KSP Residual norm 2.743131747632e-08
  2313 KSP Residual norm 2.733983139363e-08
  2314 KSP Residual norm 2.721171356242e-08
  2315 KSP Residual norm 2.749040538779e-08
  2316 KSP Residual norm 2.956209040306e-08
  2317 KSP Residual norm 3.060062594230e-08
  2318 KSP Residual norm 2.874799849491e-08
  2319 KSP Residual norm 2.665268146674e-08
  2320 KSP Residual norm 2.772857280795e-08
  2321 KSP Residual norm 2.990654125322e-08
  2322 KSP Residual norm 2.952899520359e-08
  2323 KSP Residual norm 2.792293548103e-08
  2324 KSP Residual norm 2.748598367564e-08
  2325 KSP Residual norm 2.699478973869e-08
  2326 KSP Residual norm 2.643128884756e-08
  2327 KSP Residual norm 2.511313506779e-08
  2328 KSP Residual norm 2.276669574923e-08
  2329 KSP Residual norm 2.054602062372e-08
  2330 KSP Residual norm 1.778330730040e-08
  2331 KSP Residual norm 1.621541250870e-08
  2332 KSP Residual norm 1.637764654673e-08
  2333 KSP Residual norm 1.708994064404e-08
  2334 KSP Residual norm 1.651742693394e-08
  2335 KSP Residual norm 1.500281755858e-08
  2336 KSP Residual norm 1.480045593165e-08
  2337 KSP Residual norm 1.484276302076e-08
  2338 KSP Residual norm 1.351462542533e-08
  2339 KSP Residual norm 1.191827402502e-08
  2340 KSP Residual norm 1.168662864764e-08
  2341 KSP Residual norm 1.156797835628e-08
  2342 KSP Residual norm 1.099678036576e-08
  2343 KSP Residual norm 1.041450375091e-08
  2344 KSP Residual norm 1.028811312833e-08
  2345 KSP Residual norm 1.043648171379e-08
  2346 KSP Residual norm 1.065689900500e-08
  2347 KSP Residual norm 1.061214361887e-08
  2348 KSP Residual norm 1.064871968811e-08
  2349 KSP Residual norm 1.097582498907e-08
  2350 KSP Residual norm 1.096078399204e-08
  2351 KSP Residual norm 1.088517211304e-08
  2352 KSP Residual norm 1.094875043189e-08
  2353 KSP Residual norm 1.135711333287e-08
  2354 KSP Residual norm 1.141560937711e-08
  2355 KSP Residual norm 1.180195398114e-08
  2356 KSP Residual norm 1.229408989707e-08
  2357 KSP Residual norm 1.264918363694e-08
  2358 KSP Residual norm 1.364164231703e-08
  2359 KSP Residual norm 1.391387796191e-08
  2360 KSP Residual norm 1.363171861209e-08
  2361 KSP Residual norm 1.432132433201e-08
  2362 KSP Residual norm 1.651146219121e-08
  2363 KSP Residual norm 1.739455026269e-08
  2364 KSP Residual norm 1.786970005355e-08
  2365 KSP Residual norm 1.927386266125e-08
  2366 KSP Residual norm 1.944002539024e-08
  2367 KSP Residual norm 1.825303313704e-08
  2368 KSP Residual norm 1.845942173573e-08
  2369 KSP Residual norm 2.064613582774e-08
  2370 KSP Residual norm 2.163600731320e-08
  2371 KSP Residual norm 2.066319842332e-08
  2372 KSP Residual norm 1.972281547162e-08
  2373 KSP Residual norm 2.022046954332e-08
  2374 KSP Residual norm 2.156094129891e-08
  2375 KSP Residual norm 2.134747485529e-08
  2376 KSP Residual norm 2.146466009581e-08
  2377 KSP Residual norm 2.134242298498e-08
  2378 KSP Residual norm 1.963694682345e-08
  2379 KSP Residual norm 1.788889710446e-08
  2380 KSP Residual norm 1.735742274775e-08
  2381 KSP Residual norm 1.724287054888e-08
  2382 KSP Residual norm 1.657333204418e-08
  2383 KSP Residual norm 1.601977523985e-08
  2384 KSP Residual norm 1.592980339719e-08
  2385 KSP Residual norm 1.643528353038e-08
  2386 KSP Residual norm 1.524305740226e-08
  2387 KSP Residual norm 1.281738325880e-08
  2388 KSP Residual norm 1.181102707146e-08
  2389 KSP Residual norm 1.169762846482e-08
  2390 KSP Residual norm 1.088331115373e-08
  2391 KSP Residual norm 9.926596869260e-09
  2392 KSP Residual norm 1.046136112309e-08
  2393 KSP Residual norm 1.154364345489e-08
  2394 KSP Residual norm 1.128720253874e-08
  2395 KSP Residual norm 1.049168851742e-08
  2396 KSP Residual norm 1.027055660276e-08
  2397 KSP Residual norm 9.769471007648e-09
  2398 KSP Residual norm 9.050582904842e-09
  2399 KSP Residual norm 8.767274646178e-09
  2400 KSP Residual norm 8.191786148679e-09
  2401 KSP Residual norm 7.420475335849e-09
  2402 KSP Residual norm 6.882142194668e-09
  2403 KSP Residual norm 6.682470226477e-09
  2404 KSP Residual norm 6.928923087287e-09
  2405 KSP Residual norm 7.340393361661e-09
  2406 KSP Residual norm 7.249095540000e-09
  2407 KSP Residual norm 6.733587081173e-09
  2408 KSP Residual norm 6.819910980198e-09
  2409 KSP Residual norm 6.952100736657e-09
  2410 KSP Residual norm 6.714877154834e-09
  2411 KSP Residual norm 6.345565949842e-09
  2412 KSP Residual norm 6.283651581953e-09
  2413 KSP Residual norm 6.166382733402e-09
  2414 KSP Residual norm 6.083828042828e-09
  2415 KSP Residual norm 6.426227761535e-09
  2416 KSP Residual norm 6.809718841112e-09
  2417 KSP Residual norm 7.311895519664e-09
  2418 KSP Residual norm 7.885695040613e-09
  2419 KSP Residual norm 8.293295987256e-09
  2420 KSP Residual norm 8.904912306156e-09
  2421 KSP Residual norm 9.151088014953e-09
  2422 KSP Residual norm 9.488850887938e-09
  2423 KSP Residual norm 9.949153052234e-09
  2424 KSP Residual norm 1.035318592256e-08
  2425 KSP Residual norm 1.129525959125e-08
  2426 KSP Residual norm 1.248408113736e-08
  2427 KSP Residual norm 1.272650576370e-08
  2428 KSP Residual norm 1.306691949963e-08
  2429 KSP Residual norm 1.464659469576e-08
  2430 KSP Residual norm 1.618687285881e-08
  2431 KSP Residual norm 1.634874142497e-08
  2432 KSP Residual norm 1.642309782360e-08
  2433 KSP Residual norm 1.663658078417e-08
  2434 KSP Residual norm 1.719226764242e-08
  2435 KSP Residual norm 1.667708411286e-08
  2436 KSP Residual norm 1.642638923839e-08
  2437 KSP Residual norm 1.747457374319e-08
  2438 KSP Residual norm 1.864204342869e-08
  2439 KSP Residual norm 1.929847755246e-08
  2440 KSP Residual norm 2.078650894668e-08
  2441 KSP Residual norm 2.225887764060e-08
  2442 KSP Residual norm 2.142787325635e-08
  2443 KSP Residual norm 2.045771881845e-08
  2444 KSP Residual norm 2.028908326380e-08
  2445 KSP Residual norm 2.025756936723e-08
  2446 KSP Residual norm 2.000005424982e-08
  2447 KSP Residual norm 2.015345692386e-08
  2448 KSP Residual norm 1.985966609084e-08
  2449 KSP Residual norm 1.949178423742e-08
  2450 KSP Residual norm 1.926432884163e-08
  2451 KSP Residual norm 1.904975476332e-08
  2452 KSP Residual norm 1.832013783270e-08
  2453 KSP Residual norm 1.797097355915e-08
  2454 KSP Residual norm 1.730011121490e-08
  2455 KSP Residual norm 1.538872307345e-08
  2456 KSP Residual norm 1.335901658519e-08
  2457 KSP Residual norm 1.327395760494e-08
  2458 KSP Residual norm 1.400663273338e-08
  2459 KSP Residual norm 1.284416949329e-08
  2460 KSP Residual norm 1.129660109025e-08
  2461 KSP Residual norm 1.050438029609e-08
  2462 KSP Residual norm 1.009692800540e-08
  2463 KSP Residual norm 9.121674194319e-09
  2464 KSP Residual norm 8.183286029058e-09
  2465 KSP Residual norm 8.044195697374e-09
  2466 KSP Residual norm 7.933283195800e-09
  2467 KSP Residual norm 7.750461889317e-09
  2468 KSP Residual norm 7.971090596231e-09
  2469 KSP Residual norm 8.010696023109e-09
  2470 KSP Residual norm 7.359914869366e-09
  2471 KSP Residual norm 6.860528063962e-09
  2472 KSP Residual norm 6.503824121187e-09
  2473 KSP Residual norm 6.548231468425e-09
  2474 KSP Residual norm 6.669686341449e-09
  2475 KSP Residual norm 6.323909462190e-09
  2476 KSP Residual norm 5.851288299069e-09
  2477 KSP Residual norm 5.953926704682e-09
  2478 KSP Residual norm 6.193786534656e-09
  2479 KSP Residual norm 6.382855695774e-09
  2480 KSP Residual norm 6.671346108551e-09
  2481 KSP Residual norm 7.442589185542e-09
  2482 KSP Residual norm 7.337372968494e-09
  2483 KSP Residual norm 6.445569232161e-09
  2484 KSP Residual norm 6.312266940722e-09
  2485 KSP Residual norm 7.071272824753e-09
  2486 KSP Residual norm 7.247878160167e-09
  2487 KSP Residual norm 7.541604235255e-09
  2488 KSP Residual norm 8.742718413793e-09
  2489 KSP Residual norm 9.975076976230e-09
  2490 KSP Residual norm 9.818973442672e-09
  2491 KSP Residual norm 9.588119286841e-09
  2492 KSP Residual norm 1.006198416762e-08
  2493 KSP Residual norm 1.023433506863e-08
  2494 KSP Residual norm 9.375473190107e-09
  2495 KSP Residual norm 9.406593938183e-09
  2496 KSP Residual norm 1.035641440449e-08
  2497 KSP Residual norm 1.173675682404e-08
  2498 KSP Residual norm 1.234265114038e-08
  2499 KSP Residual norm 1.218622622784e-08
  2500 KSP Residual norm 1.267436912264e-08
  2501 KSP Residual norm 1.367715131961e-08
  2502 KSP Residual norm 1.440018768183e-08
  2503 KSP Residual norm 1.508619267072e-08
  2504 KSP Residual norm 1.549639570931e-08
  2505 KSP Residual norm 1.549556075005e-08
  2506 KSP Residual norm 1.532075581523e-08
  2507 KSP Residual norm 1.488645109230e-08
  2508 KSP Residual norm 1.490285559522e-08
  2509 KSP Residual norm 1.535874586409e-08
  2510 KSP Residual norm 1.529893480935e-08
  2511 KSP Residual norm 1.477956846158e-08
  2512 KSP Residual norm 1.449415402558e-08
  2513 KSP Residual norm 1.395941129514e-08
  2514 KSP Residual norm 1.352716939284e-08
  2515 KSP Residual norm 1.339741886346e-08
  2516 KSP Residual norm 1.406782498654e-08
  2517 KSP Residual norm 1.411843736185e-08
  2518 KSP Residual norm 1.341304356648e-08
  2519 KSP Residual norm 1.250833133895e-08
  2520 KSP Residual norm 1.164073705047e-08
  2521 KSP Residual norm 1.102281414615e-08
  2522 KSP Residual norm 1.121542648851e-08
  2523 KSP Residual norm 1.120181542176e-08
  2524 KSP Residual norm 1.045407361062e-08
  2525 KSP Residual norm 9.856428805003e-09
  2526 KSP Residual norm 1.050294993783e-08
  2527 KSP Residual norm 1.057898997227e-08
  2528 KSP Residual norm 1.010643202692e-08
  2529 KSP Residual norm 9.862866919683e-09
  2530 KSP Residual norm 9.819560967018e-09
  2531 KSP Residual norm 9.347930850288e-09
  2532 KSP Residual norm 8.814108334421e-09
  2533 KSP Residual norm 8.355099459461e-09
  2534 KSP Residual norm 7.656266700119e-09
  2535 KSP Residual norm 6.844999420530e-09
  2536 KSP Residual norm 6.186101317347e-09
  2537 KSP Residual norm 5.948199628343e-09
  2538 KSP Residual norm 5.428610563762e-09
  2539 KSP Residual norm 4.982983964608e-09
  2540 KSP Residual norm 4.743777264316e-09
  2541 KSP Residual norm 4.439648638180e-09
  2542 KSP Residual norm 4.195255132473e-09
  2543 KSP Residual norm 4.065784517026e-09
  2544 KSP Residual norm 3.929976686012e-09
  2545 KSP Residual norm 3.639299967240e-09
  2546 KSP Residual norm 3.485553495785e-09
  2547 KSP Residual norm 3.446133224639e-09
  2548 KSP Residual norm 3.232074628774e-09
  2549 KSP Residual norm 3.181015483236e-09
  2550 KSP Residual norm 3.326870400750e-09
  2551 KSP Residual norm 3.226293002314e-09
  2552 KSP Residual norm 3.184635222081e-09
  2553 KSP Residual norm 3.337720238838e-09
  2554 KSP Residual norm 3.212644515614e-09
  2555 KSP Residual norm 2.696877692495e-09
  2556 KSP Residual norm 2.463682139664e-09
  2557 KSP Residual norm 2.558194255093e-09
  2558 KSP Residual norm 2.563770499815e-09
  2559 KSP Residual norm 2.431233136895e-09
  2560 KSP Residual norm 2.424757965240e-09
  2561 KSP Residual norm 2.548973524170e-09
  2562 KSP Residual norm 2.530831065549e-09
  2563 KSP Residual norm 2.360776790444e-09
  2564 KSP Residual norm 2.355650575473e-09
  2565 KSP Residual norm 2.497101659022e-09
  2566 KSP Residual norm 2.730907634833e-09
  2567 KSP Residual norm 2.775505433545e-09
  2568 KSP Residual norm 2.848580323351e-09
  2569 KSP Residual norm 2.813573068914e-09
  2570 KSP Residual norm 2.645912046140e-09
  2571 KSP Residual norm 2.683189599129e-09
  2572 KSP Residual norm 2.910642491421e-09
  2573 KSP Residual norm 3.213506736844e-09
  2574 KSP Residual norm 3.345571303534e-09
  2575 KSP Residual norm 3.487662006987e-09
  2576 KSP Residual norm 3.783578088364e-09
  2577 KSP Residual norm 4.126694757239e-09
  2578 KSP Residual norm 3.966934834228e-09
  2579 KSP Residual norm 3.938350939242e-09
  2580 KSP Residual norm 4.250763281452e-09
  2581 KSP Residual norm 4.502495779862e-09
  2582 KSP Residual norm 4.481611396450e-09
  2583 KSP Residual norm 4.516924485885e-09
  2584 KSP Residual norm 4.889234434903e-09
  2585 KSP Residual norm 5.170670476666e-09
  2586 KSP Residual norm 5.287022824447e-09
  2587 KSP Residual norm 5.472855119755e-09
  2588 KSP Residual norm 6.016180997802e-09
  2589 KSP Residual norm 6.466073329607e-09
  2590 KSP Residual norm 6.461270221363e-09
  2591 KSP Residual norm 6.973125077034e-09
  2592 KSP Residual norm 8.079750056309e-09
  2593 KSP Residual norm 8.432477647692e-09
  2594 KSP Residual norm 8.137728246274e-09
  2595 KSP Residual norm 8.638262398545e-09
  2596 KSP Residual norm 9.621070313194e-09
  2597 KSP Residual norm 1.017564474859e-08
  2598 KSP Residual norm 1.113646865170e-08
  2599 KSP Residual norm 1.210416684416e-08
  2600 KSP Residual norm 1.204361929287e-08
  2601 KSP Residual norm 1.081674699687e-08
  2602 KSP Residual norm 1.095188488372e-08
  2603 KSP Residual norm 1.179884589471e-08
  2604 KSP Residual norm 1.175099070447e-08
  2605 KSP Residual norm 1.141770008882e-08
  2606 KSP Residual norm 1.091718332799e-08
  2607 KSP Residual norm 9.470926568680e-09
  2608 KSP Residual norm 8.258630750609e-09
  2609 KSP Residual norm 7.783601965341e-09
  2610 KSP Residual norm 7.766901649221e-09
  2611 KSP Residual norm 7.693115141302e-09
  2612 KSP Residual norm 7.479212544901e-09
  2613 KSP Residual norm 7.160041634254e-09
  2614 KSP Residual norm 6.875186912935e-09
  2615 KSP Residual norm 6.676283571063e-09
  2616 KSP Residual norm 6.321536866394e-09
  2617 KSP Residual norm 5.755425502962e-09
  2618 KSP Residual norm 5.041812747416e-09
  2619 KSP Residual norm 4.803958775249e-09
  2620 KSP Residual norm 4.527691722789e-09
  2621 KSP Residual norm 3.938022685674e-09
  2622 KSP Residual norm 3.633758372931e-09
  2623 KSP Residual norm 3.738165368208e-09
  2624 KSP Residual norm 3.737226076933e-09
  2625 KSP Residual norm 3.707298492599e-09
  2626 KSP Residual norm 3.620430699791e-09
  2627 KSP Residual norm 3.386068448171e-09
  2628 KSP Residual norm 3.058281514011e-09
  2629 KSP Residual norm 3.003157638890e-09
  2630 KSP Residual norm 2.969980901234e-09
  2631 KSP Residual norm 2.940273353269e-09
  2632 KSP Residual norm 2.954900854932e-09
  2633 KSP Residual norm 2.897806303214e-09
  2634 KSP Residual norm 2.853203319843e-09
  2635 KSP Residual norm 2.831533447956e-09
  2636 KSP Residual norm 2.865348566520e-09
  2637 KSP Residual norm 2.693143836174e-09
  2638 KSP Residual norm 2.543197466684e-09
  2639 KSP Residual norm 2.605114993433e-09
  2640 KSP Residual norm 2.438432052851e-09
  2641 KSP Residual norm 2.047586379768e-09
  2642 KSP Residual norm 1.972889415337e-09
  2643 KSP Residual norm 2.033219169920e-09
  2644 KSP Residual norm 1.966769919814e-09
  2645 KSP Residual norm 1.917810564614e-09
  2646 KSP Residual norm 1.985817200822e-09
  2647 KSP Residual norm 1.949760672782e-09
  2648 KSP Residual norm 1.747593677883e-09
  2649 KSP Residual norm 1.623742393478e-09
  2650 KSP Residual norm 1.632056805693e-09
  2651 KSP Residual norm 1.633024128293e-09
  2652 KSP Residual norm 1.633658193414e-09
  2653 KSP Residual norm 1.664147180709e-09
  2654 KSP Residual norm 1.651738804611e-09
  2655 KSP Residual norm 1.595038366389e-09
  2656 KSP Residual norm 1.591886299043e-09
  2657 KSP Residual norm 1.724656738337e-09
  2658 KSP Residual norm 1.746019525312e-09
  2659 KSP Residual norm 1.670899676364e-09
  2660 KSP Residual norm 1.664490068992e-09
  2661 KSP Residual norm 1.710245233422e-09
  2662 KSP Residual norm 1.666637660573e-09
  2663 KSP Residual norm 1.641749951492e-09
  2664 KSP Residual norm 1.776495440843e-09
  2665 KSP Residual norm 1.942706172570e-09
  2666 KSP Residual norm 2.042551620639e-09
  2667 KSP Residual norm 2.064228148803e-09
  2668 KSP Residual norm 1.989940200222e-09
  2669 KSP Residual norm 2.046889113418e-09
  2670 KSP Residual norm 2.090670968148e-09
  2671 KSP Residual norm 2.096608064050e-09
  2672 KSP Residual norm 2.122985727959e-09
  2673 KSP Residual norm 2.275071665218e-09
  2674 KSP Residual norm 2.367572071053e-09
  2675 KSP Residual norm 2.453195372003e-09
  2676 KSP Residual norm 2.538209806628e-09
  2677 KSP Residual norm 2.609260859620e-09
  2678 KSP Residual norm 2.683192285067e-09
  2679 KSP Residual norm 2.943762479220e-09
  2680 KSP Residual norm 3.370405634032e-09
  2681 KSP Residual norm 3.512036945023e-09
  2682 KSP Residual norm 3.454051649847e-09
  2683 KSP Residual norm 3.708667211463e-09
  2684 KSP Residual norm 4.037301460335e-09
  2685 KSP Residual norm 4.033221032910e-09
  2686 KSP Residual norm 4.111770099676e-09
  2687 KSP Residual norm 4.433198848466e-09
  2688 KSP Residual norm 4.618878394352e-09
  2689 KSP Residual norm 4.667963732074e-09
  2690 KSP Residual norm 5.121670619576e-09
  2691 KSP Residual norm 6.055643165290e-09
  2692 KSP Residual norm 6.781998240055e-09
  2693 KSP Residual norm 6.704413128935e-09
  2694 KSP Residual norm 7.146735612908e-09
  2695 KSP Residual norm 7.809076285434e-09
  2696 KSP Residual norm 7.528292059068e-09
  2697 KSP Residual norm 7.224417949506e-09
  2698 KSP Residual norm 7.873490618361e-09
  2699 KSP Residual norm 8.190501200265e-09
  2700 KSP Residual norm 7.956062943814e-09
  2701 KSP Residual norm 8.029773409733e-09
  2702 KSP Residual norm 8.172195344241e-09
  2703 KSP Residual norm 7.316976202145e-09
  2704 KSP Residual norm 7.383627383403e-09
  2705 KSP Residual norm 8.025433562290e-09
  2706 KSP Residual norm 8.044174191405e-09
  2707 KSP Residual norm 7.319178042659e-09
  2708 KSP Residual norm 7.053531366224e-09
  2709 KSP Residual norm 7.551057668651e-09
  2710 KSP Residual norm 7.754112504251e-09
  2711 KSP Residual norm 7.051177355493e-09
  2712 KSP Residual norm 6.641770430867e-09
  2713 KSP Residual norm 7.062704584469e-09
  2714 KSP Residual norm 7.203891904612e-09
  2715 KSP Residual norm 7.004978665553e-09
  2716 KSP Residual norm 6.971547092758e-09
  2717 KSP Residual norm 7.074571122640e-09
  2718 KSP Residual norm 6.687758800246e-09
  2719 KSP Residual norm 6.030491946341e-09
  2720 KSP Residual norm 5.689079675670e-09
  2721 KSP Residual norm 5.685601729554e-09
  2722 KSP Residual norm 5.571475446101e-09
  2723 KSP Residual norm 5.458015308795e-09
  2724 KSP Residual norm 5.987585674021e-09
  2725 KSP Residual norm 6.525759775764e-09
  2726 KSP Residual norm 6.088099092887e-09
  2727 KSP Residual norm 5.165062904965e-09
  2728 KSP Residual norm 4.817167108380e-09
  2729 KSP Residual norm 4.917429258260e-09
  2730 KSP Residual norm 4.854362205433e-09
  2731 KSP Residual norm 4.788917869001e-09
  2732 KSP Residual norm 4.869046501371e-09
  2733 KSP Residual norm 4.911218160683e-09
  2734 KSP Residual norm 4.727465018014e-09
  2735 KSP Residual norm 4.508961542211e-09
  2736 KSP Residual norm 4.285587394285e-09
  2737 KSP Residual norm 4.233663917543e-09
  2738 KSP Residual norm 3.998049838763e-09
  2739 KSP Residual norm 4.094092113693e-09
  2740 KSP Residual norm 4.362354970961e-09
  2741 KSP Residual norm 4.046515936904e-09
  2742 KSP Residual norm 3.644528894172e-09
  2743 KSP Residual norm 3.400212779024e-09
  2744 KSP Residual norm 3.051614841802e-09
  2745 KSP Residual norm 2.597870368737e-09
  2746 KSP Residual norm 2.387162647797e-09
  2747 KSP Residual norm 2.470185917105e-09
  2748 KSP Residual norm 2.517048682483e-09
  2749 KSP Residual norm 2.286531072746e-09
  2750 KSP Residual norm 2.225236744650e-09
  2751 KSP Residual norm 2.481211823057e-09
  2752 KSP Residual norm 2.549869509997e-09
  2753 KSP Residual norm 2.455895955843e-09
  2754 KSP Residual norm 2.700828122162e-09
  2755 KSP Residual norm 2.796573935434e-09
  2756 KSP Residual norm 2.539217728129e-09
  2757 KSP Residual norm 2.477827386413e-09
  2758 KSP Residual norm 2.717717604447e-09
  2759 KSP Residual norm 2.634131272035e-09
  2760 KSP Residual norm 2.377625069149e-09
  2761 KSP Residual norm 2.426894982896e-09
  2762 KSP Residual norm 2.726329437074e-09
  2763 KSP Residual norm 2.952286275947e-09
  2764 KSP Residual norm 3.059023337260e-09
  2765 KSP Residual norm 3.412026777966e-09
  2766 KSP Residual norm 3.832020233261e-09
  2767 KSP Residual norm 3.882187716093e-09
  2768 KSP Residual norm 3.702401870749e-09
  2769 KSP Residual norm 3.767290470641e-09
  2770 KSP Residual norm 3.854393758332e-09
  2771 KSP Residual norm 3.803424903145e-09
  2772 KSP Residual norm 3.760490795144e-09
  2773 KSP Residual norm 3.841332849153e-09
  2774 KSP Residual norm 4.149639117958e-09
  2775 KSP Residual norm 4.451461506373e-09
  2776 KSP Residual norm 4.588461465987e-09
  2777 KSP Residual norm 4.793871863084e-09
  2778 KSP Residual norm 5.122474683701e-09
  2779 KSP Residual norm 5.371431526482e-09
  2780 KSP Residual norm 5.135808906442e-09
  2781 KSP Residual norm 5.260793911794e-09
  2782 KSP Residual norm 5.857165718928e-09
  2783 KSP Residual norm 6.381694480696e-09
  2784 KSP Residual norm 6.512497144483e-09
  2785 KSP Residual norm 6.533173277313e-09
  2786 KSP Residual norm 6.236108955963e-09
  2787 KSP Residual norm 5.923025411680e-09
  2788 KSP Residual norm 6.490975876393e-09
  2789 KSP Residual norm 7.166027410531e-09
  2790 KSP Residual norm 7.209129431455e-09
  2791 KSP Residual norm 7.051566073490e-09
  2792 KSP Residual norm 8.030358704945e-09
  2793 KSP Residual norm 9.065137803635e-09
  2794 KSP Residual norm 8.713556521944e-09
  2795 KSP Residual norm 8.484180104001e-09
  2796 KSP Residual norm 9.125206091159e-09
  2797 KSP Residual norm 9.099759915808e-09
  2798 KSP Residual norm 8.370391946821e-09
  2799 KSP Residual norm 8.475231855307e-09
  2800 KSP Residual norm 8.868159029256e-09
  2801 KSP Residual norm 9.241592810673e-09
  2802 KSP Residual norm 9.771551586297e-09
  2803 KSP Residual norm 1.067380319552e-08
  2804 KSP Residual norm 1.063704818106e-08
  2805 KSP Residual norm 9.116227620334e-09
  2806 KSP Residual norm 8.254306417035e-09
  2807 KSP Residual norm 8.773947661138e-09
  2808 KSP Residual norm 9.074387130542e-09
  2809 KSP Residual norm 8.681804154588e-09
  2810 KSP Residual norm 8.389928293070e-09
  2811 KSP Residual norm 8.158151962869e-09
  2812 KSP Residual norm 7.454687897331e-09
  2813 KSP Residual norm 6.725390281443e-09
  2814 KSP Residual norm 6.442580471280e-09
  2815 KSP Residual norm 6.594842144887e-09
  2816 KSP Residual norm 6.175468393674e-09
  2817 KSP Residual norm 5.948917296506e-09
  2818 KSP Residual norm 6.048394176460e-09
  2819 KSP Residual norm 5.771031073760e-09
  2820 KSP Residual norm 5.058013250054e-09
  2821 KSP Residual norm 5.005042538350e-09
  2822 KSP Residual norm 5.174646635816e-09
  2823 KSP Residual norm 5.297891862913e-09
  2824 KSP Residual norm 5.218582991506e-09
  2825 KSP Residual norm 5.184571403376e-09
  2826 KSP Residual norm 4.877724163497e-09
  2827 KSP Residual norm 4.376173545524e-09
  2828 KSP Residual norm 3.879420756698e-09
  2829 KSP Residual norm 3.439396018550e-09
  2830 KSP Residual norm 3.214760183503e-09
  2831 KSP Residual norm 3.260007814028e-09
  2832 KSP Residual norm 3.356921458829e-09
  2833 KSP Residual norm 3.290688450504e-09
  2834 KSP Residual norm 3.163246366208e-09
  2835 KSP Residual norm 2.955435903195e-09
  2836 KSP Residual norm 2.686316122894e-09
  2837 KSP Residual norm 2.508014674461e-09
  2838 KSP Residual norm 2.588974821038e-09
  2839 KSP Residual norm 2.550966485951e-09
  2840 KSP Residual norm 2.414762982927e-09
  2841 KSP Residual norm 2.454092884211e-09
  2842 KSP Residual norm 2.624941114781e-09
  2843 KSP Residual norm 2.543681467224e-09
  2844 KSP Residual norm 2.298222735014e-09
  2845 KSP Residual norm 2.225369846626e-09
  2846 KSP Residual norm 2.246466942198e-09
  2847 KSP Residual norm 2.102849256218e-09
  2848 KSP Residual norm 1.977287471427e-09
  2849 KSP Residual norm 1.948360601334e-09
  2850 KSP Residual norm 1.856638539318e-09
  2851 KSP Residual norm 1.762288146514e-09
  2852 KSP Residual norm 1.783254519760e-09
  2853 KSP Residual norm 1.769731460209e-09
  2854 KSP Residual norm 1.638201600958e-09
  2855 KSP Residual norm 1.640964192792e-09
  2856 KSP Residual norm 1.707268582552e-09
  2857 KSP Residual norm 1.636066496918e-09
  2858 KSP Residual norm 1.567517222222e-09
  2859 KSP Residual norm 1.553610820170e-09
  2860 KSP Residual norm 1.444711488101e-09
  2861 KSP Residual norm 1.451218386629e-09
  2862 KSP Residual norm 1.550811297135e-09
  2863 KSP Residual norm 1.559425206311e-09
  2864 KSP Residual norm 1.460071333249e-09
  2865 KSP Residual norm 1.458246533022e-09
  2866 KSP Residual norm 1.486452152424e-09
  2867 KSP Residual norm 1.323864434657e-09
  2868 KSP Residual norm 1.233595590287e-09
  2869 KSP Residual norm 1.319880348938e-09
  2870 KSP Residual norm 1.358133108944e-09
  2871 KSP Residual norm 1.229871199549e-09
  2872 KSP Residual norm 1.185891883058e-09
  2873 KSP Residual norm 1.290082776236e-09
  2874 KSP Residual norm 1.328038321947e-09
  2875 KSP Residual norm 1.317538364645e-09
  2876 KSP Residual norm 1.542014710595e-09
  2877 KSP Residual norm 1.841984536167e-09
  2878 KSP Residual norm 1.832611976675e-09
  2879 KSP Residual norm 1.716262365752e-09
  2880 KSP Residual norm 1.875582344960e-09
  2881 KSP Residual norm 1.875574764548e-09
  2882 KSP Residual norm 1.716840129990e-09
  2883 KSP Residual norm 1.712643057583e-09
  2884 KSP Residual norm 1.723655624701e-09
  2885 KSP Residual norm 1.615411584530e-09
  2886 KSP Residual norm 1.670801956517e-09
  2887 KSP Residual norm 1.936127413420e-09
  2888 KSP Residual norm 2.067951967520e-09
  2889 KSP Residual norm 2.048300456370e-09
  2890 KSP Residual norm 2.380921225057e-09
  2891 KSP Residual norm 2.939536957883e-09
  2892 KSP Residual norm 2.883724653657e-09
  2893 KSP Residual norm 2.620489080121e-09
  2894 KSP Residual norm 2.794877193591e-09
  2895 KSP Residual norm 3.063376289321e-09
  2896 KSP Residual norm 3.085815768655e-09
  2897 KSP Residual norm 3.481081390266e-09
  2898 KSP Residual norm 4.376768108428e-09
  2899 KSP Residual norm 4.534877663315e-09
  2900 KSP Residual norm 4.313685017615e-09
  2901 KSP Residual norm 4.776805577283e-09
  2902 KSP Residual norm 5.332124197875e-09
  2903 KSP Residual norm 5.283946927594e-09
  2904 KSP Residual norm 5.206005257629e-09
  2905 KSP Residual norm 5.531416350161e-09
  2906 KSP Residual norm 5.770601536643e-09
  2907 KSP Residual norm 5.625769849871e-09
  2908 KSP Residual norm 5.859016127016e-09
  2909 KSP Residual norm 6.771953315917e-09
  2910 KSP Residual norm 6.633159492461e-09
  2911 KSP Residual norm 6.342419821005e-09
  2912 KSP Residual norm 7.254879118095e-09
  2913 KSP Residual norm 8.377135113658e-09
  2914 KSP Residual norm 8.569161025211e-09
  2915 KSP Residual norm 9.312597458480e-09
  2916 KSP Residual norm 1.064500502958e-08
  2917 KSP Residual norm 9.539093393468e-09
  2918 KSP Residual norm 8.338333024324e-09
  2919 KSP Residual norm 8.587066813218e-09
  2920 KSP Residual norm 8.604327767202e-09
  2921 KSP Residual norm 7.754690685014e-09
  2922 KSP Residual norm 7.879401406835e-09
  2923 KSP Residual norm 8.525506892141e-09
  2924 KSP Residual norm 8.171632447277e-09
  2925 KSP Residual norm 7.773640417745e-09
  2926 KSP Residual norm 8.475946380531e-09
  2927 KSP Residual norm 9.508679071670e-09
  2928 KSP Residual norm 8.940031354942e-09
  2929 KSP Residual norm 7.973121653315e-09
  2930 KSP Residual norm 8.106807794805e-09
  2931 KSP Residual norm 7.751015696510e-09
  2932 KSP Residual norm 6.964268803932e-09
  2933 KSP Residual norm 7.146897865479e-09
  2934 KSP Residual norm 7.754893270261e-09
  2935 KSP Residual norm 7.446432183350e-09
  2936 KSP Residual norm 7.386712276105e-09
  2937 KSP Residual norm 8.284067578477e-09
  2938 KSP Residual norm 8.328359191638e-09
  2939 KSP Residual norm 7.377727155840e-09
  2940 KSP Residual norm 7.323373514112e-09
  2941 KSP Residual norm 7.793799213935e-09
  2942 KSP Residual norm 7.965467083386e-09
  2943 KSP Residual norm 8.213607710602e-09
  2944 KSP Residual norm 8.561815971657e-09
  2945 KSP Residual norm 7.878068525703e-09
  2946 KSP Residual norm 7.420791883455e-09
  2947 KSP Residual norm 7.863356862940e-09
  2948 KSP Residual norm 7.863276098415e-09
  2949 KSP Residual norm 7.025720508924e-09
  2950 KSP Residual norm 7.060734268418e-09
  2951 KSP Residual norm 7.491688506212e-09
  2952 KSP Residual norm 7.023666795226e-09
  2953 KSP Residual norm 6.861601581092e-09
  2954 KSP Residual norm 7.597566780992e-09
  2955 KSP Residual norm 7.691056761959e-09
  2956 KSP Residual norm 6.241066401361e-09
  2957 KSP Residual norm 5.425320168397e-09
  2958 KSP Residual norm 5.290801509322e-09
  2959 KSP Residual norm 4.941614739538e-09
  2960 KSP Residual norm 4.406386230385e-09
  2961 KSP Residual norm 4.563522198694e-09
  2962 KSP Residual norm 4.834622009435e-09
  2963 KSP Residual norm 4.264077591252e-09
  2964 KSP Residual norm 3.974265877067e-09
  2965 KSP Residual norm 4.403543971859e-09
  2966 KSP Residual norm 4.572109693925e-09
  2967 KSP Residual norm 4.209832593942e-09
  2968 KSP Residual norm 4.153200826871e-09
  2969 KSP Residual norm 4.148509905583e-09
  2970 KSP Residual norm 3.592961096984e-09
  2971 KSP Residual norm 3.193099977120e-09
  2972 KSP Residual norm 3.436900596257e-09
  2973 KSP Residual norm 3.434859820714e-09
  2974 KSP Residual norm 2.785066309851e-09
  2975 KSP Residual norm 2.507524768731e-09
  2976 KSP Residual norm 2.468199841417e-09
  2977 KSP Residual norm 2.346264531816e-09
  2978 KSP Residual norm 2.275806403748e-09
  2979 KSP Residual norm 2.399053098719e-09
  2980 KSP Residual norm 2.276114535933e-09
  2981 KSP Residual norm 1.959634703803e-09
  2982 KSP Residual norm 1.895949273734e-09
  2983 KSP Residual norm 1.865352832052e-09
  2984 KSP Residual norm 1.563795650052e-09
  2985 KSP Residual norm 1.321316532213e-09
  2986 KSP Residual norm 1.348404868013e-09
  2987 KSP Residual norm 1.499017736279e-09
  2988 KSP Residual norm 1.575753400117e-09
  2989 KSP Residual norm 1.710788127459e-09
  2990 KSP Residual norm 1.794851007666e-09
  2991 KSP Residual norm 1.644877061362e-09
  2992 KSP Residual norm 1.531454885692e-09
  2993 KSP Residual norm 1.561861640916e-09
  2994 KSP Residual norm 1.477089349020e-09
  2995 KSP Residual norm 1.373532635474e-09
  2996 KSP Residual norm 1.456041262603e-09
  2997 KSP Residual norm 1.449127861492e-09
  2998 KSP Residual norm 1.262200032375e-09
  2999 KSP Residual norm 1.164317447865e-09
  3000 KSP Residual norm 1.239948277565e-09
  3001 KSP Residual norm 1.222526005301e-09
  3002 KSP Residual norm 1.230302163924e-09
  3003 KSP Residual norm 1.373228741632e-09
  3004 KSP Residual norm 1.361535219102e-09
  3005 KSP Residual norm 1.177391542922e-09
  3006 KSP Residual norm 1.154565614024e-09
  3007 KSP Residual norm 1.303716877196e-09
  3008 KSP Residual norm 1.339522452573e-09
  3009 KSP Residual norm 1.256579854699e-09
  3010 KSP Residual norm 1.321970306015e-09
  3011 KSP Residual norm 1.537405482794e-09
  3012 KSP Residual norm 1.698741613566e-09
  3013 KSP Residual norm 1.861423793441e-09
  3014 KSP Residual norm 2.116416739772e-09
  3015 KSP Residual norm 2.243853583469e-09
  3016 KSP Residual norm 2.067642833082e-09
  3017 KSP Residual norm 1.954864562509e-09
  3018 KSP Residual norm 1.900540004228e-09
  3019 KSP Residual norm 2.008258020293e-09
  3020 KSP Residual norm 2.197543783982e-09
  3021 KSP Residual norm 2.654859755512e-09
  3022 KSP Residual norm 3.240325603636e-09
  3023 KSP Residual norm 3.459656420052e-09
  3024 KSP Residual norm 3.222389204022e-09
  3025 KSP Residual norm 3.087834144647e-09
  3026 KSP Residual norm 3.202111267821e-09
  3027 KSP Residual norm 3.314517025302e-09
  3028 KSP Residual norm 3.527196808291e-09
  3029 KSP Residual norm 3.854647521812e-09
  3030 KSP Residual norm 4.069833432228e-09
  3031 KSP Residual norm 3.797579376863e-09
  3032 KSP Residual norm 3.756568511683e-09
  3033 KSP Residual norm 4.220371445873e-09
  3034 KSP Residual norm 4.708176427459e-09
  3035 KSP Residual norm 4.945317812649e-09
  3036 KSP Residual norm 5.478547484712e-09
  3037 KSP Residual norm 6.304052270056e-09
  3038 KSP Residual norm 6.212088314622e-09
  3039 KSP Residual norm 5.574782358113e-09
  3040 KSP Residual norm 5.404259855328e-09
  3041 KSP Residual norm 5.264638183573e-09
  3042 KSP Residual norm 5.065569317258e-09
  3043 KSP Residual norm 5.476634470799e-09
  3044 KSP Residual norm 6.665331891441e-09
  3045 KSP Residual norm 7.150343226969e-09
  3046 KSP Residual norm 6.543786821056e-09
  3047 KSP Residual norm 6.575224293123e-09
  3048 KSP Residual norm 7.418459536915e-09
  3049 KSP Residual norm 7.525868476148e-09
  3050 KSP Residual norm 7.407022326650e-09
  3051 KSP Residual norm 8.706708035138e-09
  3052 KSP Residual norm 1.007171199879e-08
  3053 KSP Residual norm 1.040563158757e-08
  3054 KSP Residual norm 1.189989200710e-08
  3055 KSP Residual norm 1.403656580712e-08
  3056 KSP Residual norm 1.340357329117e-08
  3057 KSP Residual norm 1.218924437528e-08
  3058 KSP Residual norm 1.159805098760e-08
  3059 KSP Residual norm 1.089749016716e-08
  3060 KSP Residual norm 1.090186042450e-08
  3061 KSP Residual norm 1.170812688833e-08
  3062 KSP Residual norm 1.232752889129e-08
  3063 KSP Residual norm 1.187314394978e-08
  3064 KSP Residual norm 1.273939337025e-08
  3065 KSP Residual norm 1.406711256206e-08
  3066 KSP Residual norm 1.284334849219e-08
  3067 KSP Residual norm 1.184724141761e-08
  3068 KSP Residual norm 1.242920030687e-08
  3069 KSP Residual norm 1.342516168474e-08
  3070 KSP Residual norm 1.276476049647e-08
  3071 KSP Residual norm 1.283265934621e-08
  3072 KSP Residual norm 1.410385333557e-08
  3073 KSP Residual norm 1.421030635713e-08
  3074 KSP Residual norm 1.475209154677e-08
  3075 KSP Residual norm 1.559518964895e-08
  3076 KSP Residual norm 1.602050726284e-08
  3077 KSP Residual norm 1.578645683888e-08
  3078 KSP Residual norm 1.652892810577e-08
  3079 KSP Residual norm 1.731873506897e-08
  3080 KSP Residual norm 1.662545165567e-08
  3081 KSP Residual norm 1.620931807147e-08
  3082 KSP Residual norm 1.614408978898e-08
  3083 KSP Residual norm 1.548144106433e-08
  3084 KSP Residual norm 1.410795113480e-08
  3085 KSP Residual norm 1.361617814659e-08
  3086 KSP Residual norm 1.369352009898e-08
  3087 KSP Residual norm 1.344892264215e-08
  3088 KSP Residual norm 1.207989224807e-08
  3089 KSP Residual norm 1.055610165908e-08
  3090 KSP Residual norm 1.110538215000e-08
  3091 KSP Residual norm 1.298088117877e-08
  3092 KSP Residual norm 1.302948940212e-08
  3093 KSP Residual norm 1.211091835662e-08
  3094 KSP Residual norm 1.255864463435e-08
  3095 KSP Residual norm 1.314728100174e-08
  3096 KSP Residual norm 1.244011012240e-08
  3097 KSP Residual norm 1.238340792393e-08
  3098 KSP Residual norm 1.271769064545e-08
  3099 KSP Residual norm 1.219357023231e-08
  3100 KSP Residual norm 1.123626620032e-08
  3101 KSP Residual norm 1.193437827121e-08
  3102 KSP Residual norm 1.258315135802e-08
  3103 KSP Residual norm 1.229617769317e-08
  3104 KSP Residual norm 1.171454473972e-08
  3105 KSP Residual norm 1.092961840404e-08
  3106 KSP Residual norm 9.400961936808e-09
  3107 KSP Residual norm 8.398473933527e-09
  3108 KSP Residual norm 8.073021701780e-09
  3109 KSP Residual norm 7.422606183511e-09
  3110 KSP Residual norm 6.598688053983e-09
  3111 KSP Residual norm 6.077520639605e-09
  3112 KSP Residual norm 5.563492777509e-09
  3113 KSP Residual norm 5.712883851106e-09
  3114 KSP Residual norm 6.810186234463e-09
  3115 KSP Residual norm 7.918293618336e-09
  3116 KSP Residual norm 7.679418510660e-09
  3117 KSP Residual norm 6.795873755473e-09
  3118 KSP Residual norm 6.854336630074e-09
  3119 KSP Residual norm 7.027148875858e-09
  3120 KSP Residual norm 6.610531080791e-09
  3121 KSP Residual norm 6.612310218810e-09
  3122 KSP Residual norm 6.711445252418e-09
  3123 KSP Residual norm 5.886986326375e-09
  3124 KSP Residual norm 5.407965813146e-09
  3125 KSP Residual norm 5.667418719386e-09
  3126 KSP Residual norm 5.702868378387e-09
  3127 KSP Residual norm 5.475288168510e-09
  3128 KSP Residual norm 5.444311147240e-09
  3129 KSP Residual norm 5.209025034882e-09
  3130 KSP Residual norm 4.764739261775e-09
  3131 KSP Residual norm 4.632632955447e-09
  3132 KSP Residual norm 5.145605987653e-09
  3133 KSP Residual norm 5.041135631143e-09
  3134 KSP Residual norm 4.081951474773e-09
  3135 KSP Residual norm 3.627692762278e-09
  3136 KSP Residual norm 3.718177911700e-09
  3137 KSP Residual norm 3.744799480105e-09
  3138 KSP Residual norm 3.695572669460e-09
  3139 KSP Residual norm 3.972488854413e-09
  3140 KSP Residual norm 4.477639314267e-09
  3141 KSP Residual norm 4.861315216699e-09
  3142 KSP Residual norm 4.862480007791e-09
  3143 KSP Residual norm 4.294398664109e-09
  3144 KSP Residual norm 4.085632771950e-09
  3145 KSP Residual norm 4.358872461936e-09
  3146 KSP Residual norm 4.650881057237e-09
  3147 KSP Residual norm 4.654100506448e-09
  3148 KSP Residual norm 4.610817886843e-09
  3149 KSP Residual norm 4.604152233344e-09
  3150 KSP Residual norm 4.747286376013e-09
  3151 KSP Residual norm 4.856090740634e-09
  3152 KSP Residual norm 4.501567993933e-09
  3153 KSP Residual norm 3.909764657320e-09
  3154 KSP Residual norm 4.166272857820e-09
  3155 KSP Residual norm 5.107226582300e-09
  3156 KSP Residual norm 5.496526379146e-09
  3157 KSP Residual norm 5.060108390780e-09
  3158 KSP Residual norm 4.603693552068e-09
  3159 KSP Residual norm 4.423141534586e-09
  3160 KSP Residual norm 4.450086263480e-09
  3161 KSP Residual norm 4.765868255664e-09
  3162 KSP Residual norm 4.728737508027e-09
  3163 KSP Residual norm 4.225321541224e-09
  3164 KSP Residual norm 3.969670247250e-09
  3165 KSP Residual norm 4.359049255995e-09
  3166 KSP Residual norm 4.558233037824e-09
  3167 KSP Residual norm 4.313343448882e-09
  3168 KSP Residual norm 4.360678389435e-09
  3169 KSP Residual norm 4.648607092232e-09
  3170 KSP Residual norm 4.668675636775e-09
  3171 KSP Residual norm 4.948690524349e-09
  3172 KSP Residual norm 5.502370130860e-09
  3173 KSP Residual norm 5.624167600766e-09
  3174 KSP Residual norm 5.734029720277e-09
  3175 KSP Residual norm 6.354798184490e-09
  3176 KSP Residual norm 6.812857913567e-09
  3177 KSP Residual norm 6.831967731584e-09
  3178 KSP Residual norm 7.290704132342e-09
  3179 KSP Residual norm 7.298003630084e-09
  3180 KSP Residual norm 6.612265085764e-09
  3181 KSP Residual norm 6.519338901436e-09
  3182 KSP Residual norm 6.404983790976e-09
  3183 KSP Residual norm 6.359795902134e-09
  3184 KSP Residual norm 6.861813656435e-09
  3185 KSP Residual norm 7.795713316422e-09
  3186 KSP Residual norm 8.304269800623e-09
  3187 KSP Residual norm 8.907704175398e-09
  3188 KSP Residual norm 9.027928409947e-09
  3189 KSP Residual norm 7.722684766093e-09
  3190 KSP Residual norm 6.403581130323e-09
  3191 KSP Residual norm 5.955411343752e-09
  3192 KSP Residual norm 5.929991010043e-09
  3193 KSP Residual norm 5.891787892020e-09
  3194 KSP Residual norm 6.859891011974e-09
  3195 KSP Residual norm 8.986886250718e-09
  3196 KSP Residual norm 1.105195420081e-08
  3197 KSP Residual norm 1.269057641791e-08
  3198 KSP Residual norm 1.363392100764e-08
  3199 KSP Residual norm 1.301592977214e-08
  3200 KSP Residual norm 1.322105988826e-08
  3201 KSP Residual norm 1.484726971122e-08
  3202 KSP Residual norm 1.572643940722e-08
  3203 KSP Residual norm 1.568759154209e-08
  3204 KSP Residual norm 1.510737834790e-08
  3205 KSP Residual norm 1.355573402621e-08
  3206 KSP Residual norm 1.259690011737e-08
  3207 KSP Residual norm 1.318766330706e-08
  3208 KSP Residual norm 1.371488612381e-08
  3209 KSP Residual norm 1.388327712197e-08
  3210 KSP Residual norm 1.541992151500e-08
  3211 KSP Residual norm 1.840416600020e-08
  3212 KSP Residual norm 1.872128937209e-08
  3213 KSP Residual norm 1.794119065455e-08
  3214 KSP Residual norm 1.970768102999e-08
  3215 KSP Residual norm 2.328880478971e-08
  3216 KSP Residual norm 2.387532724903e-08
  3217 KSP Residual norm 2.319687198235e-08
  3218 KSP Residual norm 2.317305635572e-08
  3219 KSP Residual norm 2.199672474085e-08
  3220 KSP Residual norm 2.039507534836e-08
  3221 KSP Residual norm 1.951505705194e-08
  3222 KSP Residual norm 1.889827626342e-08
  3223 KSP Residual norm 1.689262047862e-08
  3224 KSP Residual norm 1.642409429496e-08
  3225 KSP Residual norm 1.785694234356e-08
  3226 KSP Residual norm 1.989301555152e-08
  3227 KSP Residual norm 2.063549350396e-08
  3228 KSP Residual norm 2.074923177145e-08
  3229 KSP Residual norm 1.955570386305e-08
  3230 KSP Residual norm 1.757596576290e-08
  3231 KSP Residual norm 1.780320598367e-08
  3232 KSP Residual norm 2.060389743580e-08
  3233 KSP Residual norm 2.199439410504e-08
  3234 KSP Residual norm 1.940992441617e-08
  3235 KSP Residual norm 1.497985432431e-08
  3236 KSP Residual norm 1.137578028754e-08
  3237 KSP Residual norm 9.591794383709e-09
  3238 KSP Residual norm 9.963270114348e-09
  3239 KSP Residual norm 1.297700060654e-08
  3240 KSP Residual norm 1.659306646168e-08
  3241 KSP Residual norm 1.855090668625e-08
  3242 KSP Residual norm 1.758295404025e-08
  3243 KSP Residual norm 1.402624013748e-08
  3244 KSP Residual norm 1.141735707857e-08
  3245 KSP Residual norm 1.080105145163e-08
  3246 KSP Residual norm 1.098475692728e-08
  3247 KSP Residual norm 1.201837614835e-08
  3248 KSP Residual norm 1.343465893889e-08
  3249 KSP Residual norm 1.370482802318e-08
  3250 KSP Residual norm 1.305334274353e-08
  3251 KSP Residual norm 1.300428676185e-08
  3252 KSP Residual norm 1.250321381691e-08
  3253 KSP Residual norm 1.091132868831e-08
  3254 KSP Residual norm 9.673770720204e-09
  3255 KSP Residual norm 8.559557475995e-09
  3256 KSP Residual norm 7.535639018088e-09
  3257 KSP Residual norm 7.434011933152e-09
  3258 KSP Residual norm 8.428838187541e-09
  3259 KSP Residual norm 8.874166489691e-09
  3260 KSP Residual norm 9.110673722111e-09
  3261 KSP Residual norm 9.655628995657e-09
  3262 KSP Residual norm 8.858171800408e-09
  3263 KSP Residual norm 7.583496958332e-09
  3264 KSP Residual norm 7.686864276349e-09
  3265 KSP Residual norm 8.162156249675e-09
  3266 KSP Residual norm 7.182901310783e-09
  3267 KSP Residual norm 5.694521719456e-09
  3268 KSP Residual norm 4.795371785557e-09
  3269 KSP Residual norm 4.508338780642e-09
  3270 KSP Residual norm 4.669984353910e-09
  3271 KSP Residual norm 5.056332637406e-09
  3272 KSP Residual norm 5.252464453011e-09
  3273 KSP Residual norm 4.595783529628e-09
  3274 KSP Residual norm 3.736683430581e-09
  3275 KSP Residual norm 3.102926248272e-09
  3276 KSP Residual norm 2.880059573310e-09
  3277 KSP Residual norm 3.203845172389e-09
  3278 KSP Residual norm 4.158253314906e-09
  3279 KSP Residual norm 5.247627484845e-09
  3280 KSP Residual norm 4.892056275754e-09
  3281 KSP Residual norm 4.025741432791e-09
  3282 KSP Residual norm 3.339865426301e-09
  3283 KSP Residual norm 2.963169041294e-09
  3284 KSP Residual norm 2.952512741400e-09
  3285 KSP Residual norm 3.667541702976e-09
  3286 KSP Residual norm 5.007856786367e-09
  3287 KSP Residual norm 5.390779332652e-09
  3288 KSP Residual norm 5.161106326147e-09
  3289 KSP Residual norm 4.479365045580e-09
  3290 KSP Residual norm 3.447441418488e-09
  3291 KSP Residual norm 3.006145069891e-09
  3292 KSP Residual norm 3.220482711388e-09
  3293 KSP Residual norm 3.844573265255e-09
  3294 KSP Residual norm 4.853046094149e-09
  3295 KSP Residual norm 5.888435641430e-09
  3296 KSP Residual norm 5.189350743014e-09
  3297 KSP Residual norm 3.821923786726e-09
  3298 KSP Residual norm 2.944069975844e-09
  3299 KSP Residual norm 2.494582051319e-09
  3300 KSP Residual norm 2.289549150106e-09
  3301 KSP Residual norm 2.693737324925e-09
  3302 KSP Residual norm 3.849838348754e-09
  3303 KSP Residual norm 4.835675269624e-09
  3304 KSP Residual norm 4.842406200654e-09
  3305 KSP Residual norm 4.140087834679e-09
  3306 KSP Residual norm 3.104338243174e-09
  3307 KSP Residual norm 2.280168121652e-09
  3308 KSP Residual norm 2.278600374061e-09
  3309 KSP Residual norm 3.028713403240e-09
  3310 KSP Residual norm 3.952119361701e-09
  3311 KSP Residual norm 4.563429295278e-09
  3312 KSP Residual norm 4.912516331425e-09
  3313 KSP Residual norm 4.283205127752e-09
  3314 KSP Residual norm 2.978436681738e-09
  3315 KSP Residual norm 2.235974179447e-09
  3316 KSP Residual norm 2.128837817857e-09
  3317 KSP Residual norm 2.460975418829e-09
  3318 KSP Residual norm 3.473176827566e-09
  3319 KSP Residual norm 5.327524719125e-09
  3320 KSP Residual norm 7.602820272497e-09
  3321 KSP Residual norm 8.736056237634e-09
  3322 KSP Residual norm 7.792595273450e-09
  3323 KSP Residual norm 5.341113496356e-09
  3324 KSP Residual norm 3.488015788308e-09
  3325 KSP Residual norm 2.454463916934e-09
  3326 KSP Residual norm 2.282630117337e-09
  3327 KSP Residual norm 2.813481656631e-09
  3328 KSP Residual norm 4.558997094791e-09
  3329 KSP Residual norm 7.242921443219e-09
  3330 KSP Residual norm 9.149458129878e-09
  3331 KSP Residual norm 8.914627283200e-09
  3332 KSP Residual norm 7.094245399923e-09
  3333 KSP Residual norm 5.419270550633e-09
  3334 KSP Residual norm 4.448583198149e-09
  3335 KSP Residual norm 4.236271542197e-09
  3336 KSP Residual norm 5.039249378949e-09
  3337 KSP Residual norm 7.366984118376e-09
  3338 KSP Residual norm 1.037594555909e-08
  3339 KSP Residual norm 1.162983327888e-08
  3340 KSP Residual norm 1.050870031574e-08
  3341 KSP Residual norm 7.441416017776e-09
  3342 KSP Residual norm 5.010563682115e-09
  3343 KSP Residual norm 4.413285821309e-09
  3344 KSP Residual norm 5.322154899682e-09
  3345 KSP Residual norm 7.016982336268e-09
  3346 KSP Residual norm 9.979442615695e-09
  3347 KSP Residual norm 1.474643017374e-08
  3348 KSP Residual norm 1.733890250344e-08
  3349 KSP Residual norm 1.446227057509e-08
  3350 KSP Residual norm 1.050725350013e-08
  3351 KSP Residual norm 8.239754991790e-09
  3352 KSP Residual norm 7.162606610542e-09
  3353 KSP Residual norm 7.480554202824e-09
  3354 KSP Residual norm 8.817729642449e-09
  3355 KSP Residual norm 9.784886768666e-09
  3356 KSP Residual norm 1.042163648032e-08
  3357 KSP Residual norm 1.195558535219e-08
  3358 KSP Residual norm 1.495754937394e-08
  3359 KSP Residual norm 1.848763294491e-08
  3360 KSP Residual norm 2.201414106633e-08
  3361 KSP Residual norm 2.214608803136e-08
  3362 KSP Residual norm 1.676070062554e-08
  3363 KSP Residual norm 1.149327007865e-08
  3364 KSP Residual norm 8.811553408434e-09
  3365 KSP Residual norm 8.283292405272e-09
  3366 KSP Residual norm 9.567674989402e-09
  3367 KSP Residual norm 1.238564210484e-08
  3368 KSP Residual norm 1.677732723026e-08
  3369 KSP Residual norm 1.973952324089e-08
  3370 KSP Residual norm 1.966571506297e-08
  3371 KSP Residual norm 1.896617235163e-08
  3372 KSP Residual norm 1.894264412529e-08
  3373 KSP Residual norm 1.737574021949e-08
  3374 KSP Residual norm 1.387375292483e-08
  3375 KSP Residual norm 9.964126659752e-09
  3376 KSP Residual norm 8.616881730334e-09
  3377 KSP Residual norm 9.781470363234e-09
  3378 KSP Residual norm 1.227707331458e-08
  3379 KSP Residual norm 1.313910049365e-08
  3380 KSP Residual norm 1.244759299923e-08
  3381 KSP Residual norm 1.154824615892e-08
  3382 KSP Residual norm 1.172001068772e-08
  3383 KSP Residual norm 1.403982505480e-08
  3384 KSP Residual norm 2.046507871966e-08
  3385 KSP Residual norm 2.836687901483e-08
  3386 KSP Residual norm 2.599907708862e-08
  3387 KSP Residual norm 1.854074056045e-08
  3388 KSP Residual norm 1.238517619725e-08
  3389 KSP Residual norm 8.879617534034e-09
  3390 KSP Residual norm 7.985660882134e-09
  3391 KSP Residual norm 9.315423658071e-09
  3392 KSP Residual norm 1.233130825883e-08
  3393 KSP Residual norm 1.513783762599e-08
  3394 KSP Residual norm 1.603231607686e-08
  3395 KSP Residual norm 1.598920430535e-08
  3396 KSP Residual norm 1.563997468101e-08
  3397 KSP Residual norm 1.679420713924e-08
  3398 KSP Residual norm 1.909814408703e-08
  3399 KSP Residual norm 1.915915456556e-08
  3400 KSP Residual norm 1.400561661626e-08
  3401 KSP Residual norm 9.254220043579e-09
  3402 KSP Residual norm 6.710728517274e-09
  3403 KSP Residual norm 5.844165206147e-09
  3404 KSP Residual norm 6.775210785790e-09
  3405 KSP Residual norm 8.383885863897e-09
  3406 KSP Residual norm 8.142195003197e-09
  3407 KSP Residual norm 7.429295023237e-09
  3408 KSP Residual norm 7.450045106787e-09
  3409 KSP Residual norm 8.319381837160e-09
  3410 KSP Residual norm 9.743181900403e-09
  3411 KSP Residual norm 1.034264402570e-08
  3412 KSP Residual norm 8.503383264827e-09
  3413 KSP Residual norm 6.680884299923e-09
  3414 KSP Residual norm 5.978583101887e-09
  3415 KSP Residual norm 5.396327215863e-09
  3416 KSP Residual norm 4.906741046136e-09
  3417 KSP Residual norm 5.073807402895e-09
  3418 KSP Residual norm 5.420870803317e-09
  3419 KSP Residual norm 5.771218189403e-09
  3420 KSP Residual norm 6.592935130818e-09
  3421 KSP Residual norm 8.223593132123e-09
  3422 KSP Residual norm 9.679187682916e-09
  3423 KSP Residual norm 9.162956655868e-09
  3424 KSP Residual norm 7.796048626480e-09
  3425 KSP Residual norm 6.857145822099e-09
  3426 KSP Residual norm 6.720563872184e-09
  3427 KSP Residual norm 6.037427380372e-09
  3428 KSP Residual norm 4.375346839404e-09
  3429 KSP Residual norm 3.291231325204e-09
  3430 KSP Residual norm 2.920900712586e-09
  3431 KSP Residual norm 2.951378168560e-09
  3432 KSP Residual norm 2.896509468203e-09
  3433 KSP Residual norm 2.628621810408e-09
  3434 KSP Residual norm 2.401503206811e-09
  3435 KSP Residual norm 2.530568475210e-09
  3436 KSP Residual norm 3.111733203033e-09
  3437 KSP Residual norm 3.732599896702e-09
  3438 KSP Residual norm 3.712379672726e-09
  3439 KSP Residual norm 3.715903901211e-09
  3440 KSP Residual norm 4.126600187252e-09
  3441 KSP Residual norm 4.616603692625e-09
  3442 KSP Residual norm 4.628010444851e-09
  3443 KSP Residual norm 3.615513806336e-09
  3444 KSP Residual norm 2.614434540573e-09
  3445 KSP Residual norm 2.155166720355e-09
  3446 KSP Residual norm 2.115499977160e-09
  3447 KSP Residual norm 2.228860007009e-09
  3448 KSP Residual norm 2.094895885754e-09
  3449 KSP Residual norm 1.721287915797e-09
  3450 KSP Residual norm 1.409575608678e-09
  3451 KSP Residual norm 1.332561498124e-09
  3452 KSP Residual norm 1.397428291659e-09
  3453 KSP Residual norm 1.509421119018e-09
  3454 KSP Residual norm 1.573759917446e-09
  3455 KSP Residual norm 1.601785165852e-09
  3456 KSP Residual norm 1.695432082500e-09
  3457 KSP Residual norm 2.043800520175e-09
  3458 KSP Residual norm 2.641172998665e-09
  3459 KSP Residual norm 2.935314969085e-09
  3460 KSP Residual norm 2.718901339719e-09
  3461 KSP Residual norm 2.603017000757e-09
  3462 KSP Residual norm 2.703826232617e-09
  3463 KSP Residual norm 2.518002819759e-09
  3464 KSP Residual norm 1.992587298427e-09
  3465 KSP Residual norm 1.511476163769e-09
  3466 KSP Residual norm 1.270937120814e-09
  3467 KSP Residual norm 1.225146112608e-09
  3468 KSP Residual norm 1.266371279650e-09
  3469 KSP Residual norm 1.287642511863e-09
  3470 KSP Residual norm 1.374755462896e-09
  3471 KSP Residual norm 1.511319802229e-09
  3472 KSP Residual norm 1.803117455527e-09
  3473 KSP Residual norm 2.213441955137e-09
  3474 KSP Residual norm 2.215090950986e-09
  3475 KSP Residual norm 1.853171977986e-09
  3476 KSP Residual norm 1.619802216275e-09
  3477 KSP Residual norm 1.506425003094e-09
  3478 KSP Residual norm 1.420890578758e-09
  3479 KSP Residual norm 1.338890917208e-09
  3480 KSP Residual norm 1.219600077279e-09
  3481 KSP Residual norm 9.977942922470e-10
  3482 KSP Residual norm 8.423461529404e-10
  3483 KSP Residual norm 9.014035420764e-10
  3484 KSP Residual norm 1.080199421668e-09
  3485 KSP Residual norm 1.212921777832e-09
  3486 KSP Residual norm 1.245220679264e-09
  3487 KSP Residual norm 1.412802039780e-09
  3488 KSP Residual norm 1.746093758333e-09
  3489 KSP Residual norm 2.142250818160e-09
  3490 KSP Residual norm 2.281029040563e-09
  3491 KSP Residual norm 2.027007369661e-09
  3492 KSP Residual norm 1.814600826662e-09
  3493 KSP Residual norm 1.843902150852e-09
  3494 KSP Residual norm 2.041995327305e-09
  3495 KSP Residual norm 1.961006969503e-09
  3496 KSP Residual norm 1.643166073521e-09
  3497 KSP Residual norm 1.561095553378e-09
  3498 KSP Residual norm 1.710259231828e-09
  3499 KSP Residual norm 1.857646579708e-09
  3500 KSP Residual norm 1.755617942552e-09
  3501 KSP Residual norm 1.560841148162e-09
  3502 KSP Residual norm 1.570133046983e-09
  3503 KSP Residual norm 1.864655412285e-09
  3504 KSP Residual norm 2.223247244869e-09
  3505 KSP Residual norm 2.306305379952e-09
  3506 KSP Residual norm 2.039472409439e-09
  3507 KSP Residual norm 1.808739826017e-09
  3508 KSP Residual norm 1.823828650786e-09
  3509 KSP Residual norm 1.914624790355e-09
  3510 KSP Residual norm 1.766986653823e-09
  3511 KSP Residual norm 1.532752708034e-09
  3512 KSP Residual norm 1.534680509611e-09
  3513 KSP Residual norm 1.709677101193e-09
  3514 KSP Residual norm 1.856782186056e-09
  3515 KSP Residual norm 1.657432978924e-09
  3516 KSP Residual norm 1.273121353862e-09
  3517 KSP Residual norm 1.224455718100e-09
  3518 KSP Residual norm 1.403249412630e-09
  3519 KSP Residual norm 1.624649644915e-09
  3520 KSP Residual norm 1.785241620716e-09
  3521 KSP Residual norm 1.911035235758e-09
  3522 KSP Residual norm 2.328634992011e-09
  3523 KSP Residual norm 3.296973586588e-09
  3524 KSP Residual norm 4.896969965639e-09
  3525 KSP Residual norm 5.500909302397e-09
  3526 KSP Residual norm 4.845050467002e-09
  3527 KSP Residual norm 4.397761048191e-09
  3528 KSP Residual norm 4.574699972851e-09
  3529 KSP Residual norm 4.908621211998e-09
  3530 KSP Residual norm 4.643132930641e-09
  3531 KSP Residual norm 3.614594972120e-09
  3532 KSP Residual norm 2.895717915970e-09
  3533 KSP Residual norm 2.932586395937e-09
  3534 KSP Residual norm 3.488618209129e-09
  3535 KSP Residual norm 4.099366657662e-09
  3536 KSP Residual norm 4.185695133241e-09
  3537 KSP Residual norm 4.185445437787e-09
  3538 KSP Residual norm 5.093938232234e-09
  3539 KSP Residual norm 7.531831956806e-09
  3540 KSP Residual norm 1.003060138542e-08
  3541 KSP Residual norm 9.071805650648e-09
  3542 KSP Residual norm 7.813867608053e-09
  3543 KSP Residual norm 8.660891144438e-09
  3544 KSP Residual norm 1.083239957048e-08
  3545 KSP Residual norm 1.060797959618e-08
  3546 KSP Residual norm 8.051040216406e-09
  3547 KSP Residual norm 6.483700880004e-09
  3548 KSP Residual norm 6.171761629785e-09
  3549 KSP Residual norm 6.432047785318e-09
  3550 KSP Residual norm 6.224660810513e-09
  3551 KSP Residual norm 5.525447723576e-09
  3552 KSP Residual norm 5.515604098047e-09
  3553 KSP Residual norm 6.654738665945e-09
  3554 KSP Residual norm 7.856590179732e-09
  3555 KSP Residual norm 8.306250699822e-09
  3556 KSP Residual norm 8.889530172384e-09
  3557 KSP Residual norm 1.040715392118e-08
  3558 KSP Residual norm 1.271666228128e-08
  3559 KSP Residual norm 1.482910151918e-08
  3560 KSP Residual norm 1.399640681425e-08
  3561 KSP Residual norm 1.148482692464e-08
  3562 KSP Residual norm 1.011782386133e-08
  3563 KSP Residual norm 1.033662916531e-08
  3564 KSP Residual norm 1.003734807936e-08
  3565 KSP Residual norm 8.330341997878e-09
  3566 KSP Residual norm 6.896945348191e-09
  3567 KSP Residual norm 6.236435503963e-09
  3568 KSP Residual norm 6.020297506649e-09
  3569 KSP Residual norm 5.575399864494e-09
  3570 KSP Residual norm 5.000739651273e-09
  3571 KSP Residual norm 5.229468815244e-09
  3572 KSP Residual norm 6.767901056203e-09
  3573 KSP Residual norm 8.664279885066e-09
  3574 KSP Residual norm 8.947586303432e-09
  3575 KSP Residual norm 9.028249028046e-09
  3576 KSP Residual norm 1.046710807339e-08
  3577 KSP Residual norm 1.325629425899e-08
  3578 KSP Residual norm 1.552482970550e-08
  3579 KSP Residual norm 1.541030603723e-08
  3580 KSP Residual norm 1.502321697973e-08
  3581 KSP Residual norm 1.572897171304e-08
  3582 KSP Residual norm 1.592143150348e-08
  3583 KSP Residual norm 1.463282285019e-08
  3584 KSP Residual norm 1.215857856446e-08
  3585 KSP Residual norm 1.043967230688e-08
  3586 KSP Residual norm 9.993546258971e-09
  3587 KSP Residual norm 8.901126538423e-09
  3588 KSP Residual norm 7.098600697915e-09
  3589 KSP Residual norm 5.852469115337e-09
  3590 KSP Residual norm 5.659826898317e-09
  3591 KSP Residual norm 6.105513355409e-09
  3592 KSP Residual norm 6.300337302379e-09
  3593 KSP Residual norm 5.927908222259e-09
  3594 KSP Residual norm 5.664654351998e-09
  3595 KSP Residual norm 6.318917995181e-09
  3596 KSP Residual norm 7.838197036978e-09
  3597 KSP Residual norm 8.536136733933e-09
  3598 KSP Residual norm 7.763976923173e-09
  3599 KSP Residual norm 7.985879471433e-09
  3600 KSP Residual norm 9.738862691594e-09
  3601 KSP Residual norm 1.091695508309e-08
  3602 KSP Residual norm 1.001104974036e-08
  3603 KSP Residual norm 9.233867125388e-09
  3604 KSP Residual norm 9.537585595872e-09
  3605 KSP Residual norm 9.935544775921e-09
  3606 KSP Residual norm 8.765739171866e-09
  3607 KSP Residual norm 6.351142737339e-09
  3608 KSP Residual norm 5.025162851112e-09
  3609 KSP Residual norm 4.878278010713e-09
  3610 KSP Residual norm 5.292002158799e-09
  3611 KSP Residual norm 4.990771065089e-09
  3612 KSP Residual norm 4.167520853998e-09
  3613 KSP Residual norm 3.756224737184e-09
  3614 KSP Residual norm 4.070223348321e-09
  3615 KSP Residual norm 5.097976574503e-09
  3616 KSP Residual norm 5.502139616920e-09
  3617 KSP Residual norm 4.875598963190e-09
  3618 KSP Residual norm 4.578059685077e-09
  3619 KSP Residual norm 5.059461202823e-09
  3620 KSP Residual norm 5.632415761366e-09
  3621 KSP Residual norm 5.712537216145e-09
  3622 KSP Residual norm 5.817794543408e-09
  3623 KSP Residual norm 6.245394355653e-09
  3624 KSP Residual norm 7.188889660444e-09
  3625 KSP Residual norm 7.897495504395e-09
  3626 KSP Residual norm 6.337194697730e-09
  3627 KSP Residual norm 4.975859345504e-09
  3628 KSP Residual norm 4.563651490302e-09
  3629 KSP Residual norm 4.144989088426e-09
  3630 KSP Residual norm 3.236740240349e-09
  3631 KSP Residual norm 2.703936085570e-09
  3632 KSP Residual norm 2.575225817969e-09
  3633 KSP Residual norm 2.444870236042e-09
  3634 KSP Residual norm 2.477149010409e-09
  3635 KSP Residual norm 2.586264969643e-09
  3636 KSP Residual norm 2.714795375250e-09
  3637 KSP Residual norm 3.049619731988e-09
  3638 KSP Residual norm 3.322843944377e-09
  3639 KSP Residual norm 3.013827671514e-09
  3640 KSP Residual norm 2.777575793326e-09
  3641 KSP Residual norm 3.127649029513e-09
  3642 KSP Residual norm 3.669267842667e-09
  3643 KSP Residual norm 3.808706261272e-09
  3644 KSP Residual norm 3.755146904996e-09
  3645 KSP Residual norm 3.750486986120e-09
  3646 KSP Residual norm 3.843585330706e-09
  3647 KSP Residual norm 3.811076409355e-09
  3648 KSP Residual norm 3.220294997649e-09
  3649 KSP Residual norm 2.314041764327e-09
  3650 KSP Residual norm 1.818075811897e-09
  3651 KSP Residual norm 1.677953281875e-09
  3652 KSP Residual norm 1.617488234897e-09
  3653 KSP Residual norm 1.517610583976e-09
  3654 KSP Residual norm 1.506090675990e-09
  3655 KSP Residual norm 1.504816607156e-09
  3656 KSP Residual norm 1.535251724128e-09
  3657 KSP Residual norm 1.593317822618e-09
  3658 KSP Residual norm 1.604531477442e-09
  3659 KSP Residual norm 1.686018335962e-09
  3660 KSP Residual norm 2.008847516854e-09
  3661 KSP Residual norm 2.256427498138e-09
  3662 KSP Residual norm 2.218662480385e-09
  3663 KSP Residual norm 2.349126109980e-09
  3664 KSP Residual norm 2.815456879471e-09
  3665 KSP Residual norm 3.105243592841e-09
  3666 KSP Residual norm 3.111697946625e-09
  3667 KSP Residual norm 2.986875519869e-09
  3668 KSP Residual norm 2.738098545043e-09
  3669 KSP Residual norm 2.503551675799e-09
  3670 KSP Residual norm 2.312713419424e-09
  3671 KSP Residual norm 1.964188495057e-09
  3672 KSP Residual norm 1.681739997756e-09
  3673 KSP Residual norm 1.591585888744e-09
  3674 KSP Residual norm 1.500636319990e-09
  3675 KSP Residual norm 1.308034015344e-09
  3676 KSP Residual norm 1.229565721675e-09
  3677 KSP Residual norm 1.207891801592e-09
  3678 KSP Residual norm 1.146178320427e-09
  3679 KSP Residual norm 1.202806594448e-09
  3680 KSP Residual norm 1.344935981461e-09
  3681 KSP Residual norm 1.314064474627e-09
  3682 KSP Residual norm 1.250809723212e-09
  3683 KSP Residual norm 1.342232779997e-09
  3684 KSP Residual norm 1.525539282968e-09
  3685 KSP Residual norm 1.688057331076e-09
  3686 KSP Residual norm 1.729490059005e-09
  3687 KSP Residual norm 1.577498416576e-09
  3688 KSP Residual norm 1.472874836476e-09
  3689 KSP Residual norm 1.575346556740e-09
  3690 KSP Residual norm 1.622605689175e-09
  3691 KSP Residual norm 1.535992678461e-09
  3692 KSP Residual norm 1.470848407673e-09
  3693 KSP Residual norm 1.502047000898e-09
  3694 KSP Residual norm 1.510651871516e-09
  3695 KSP Residual norm 1.398937444999e-09
  3696 KSP Residual norm 1.171234761594e-09
  3697 KSP Residual norm 9.915466067651e-10
  3698 KSP Residual norm 9.936758316105e-10
  3699 KSP Residual norm 1.032032245054e-09
  3700 KSP Residual norm 8.945241911377e-10
  3701 KSP Residual norm 7.632597830874e-10
  3702 KSP Residual norm 7.273934964478e-10
  3703 KSP Residual norm 7.200169323034e-10
  3704 KSP Residual norm 6.843857792227e-10
  3705 KSP Residual norm 6.525055860551e-10
  3706 KSP Residual norm 6.520652839039e-10
  3707 KSP Residual norm 7.185286985055e-10
  3708 KSP Residual norm 8.810604846284e-10
  3709 KSP Residual norm 9.567504870817e-10
  3710 KSP Residual norm 8.990483957396e-10
  3711 KSP Residual norm 9.344793403503e-10
  3712 KSP Residual norm 1.122997504736e-09
  3713 KSP Residual norm 1.247726837693e-09
  3714 KSP Residual norm 1.242987426230e-09
  3715 KSP Residual norm 1.206685272823e-09
  3716 KSP Residual norm 1.202928772893e-09
  3717 KSP Residual norm 1.257492782641e-09
  3718 KSP Residual norm 1.295793216627e-09
  3719 KSP Residual norm 1.254096893974e-09
  3720 KSP Residual norm 1.317976543469e-09
  3721 KSP Residual norm 1.477217056374e-09
  3722 KSP Residual norm 1.417778060759e-09
  3723 KSP Residual norm 1.279049064543e-09
  3724 KSP Residual norm 1.323701259263e-09
  3725 KSP Residual norm 1.307753080391e-09
  3726 KSP Residual norm 1.183826071489e-09
  3727 KSP Residual norm 1.078327845374e-09
  3728 KSP Residual norm 9.536633163961e-10
  3729 KSP Residual norm 8.901825635324e-10
  3730 KSP Residual norm 8.999343130855e-10
  3731 KSP Residual norm 8.890597721268e-10
  3732 KSP Residual norm 8.843304223038e-10
  3733 KSP Residual norm 1.000598872012e-09
  3734 KSP Residual norm 1.037538219714e-09
  3735 KSP Residual norm 9.754158718212e-10
  3736 KSP Residual norm 9.880149344183e-10
  3737 KSP Residual norm 1.017366680519e-09
  3738 KSP Residual norm 9.549603006671e-10
  3739 KSP Residual norm 9.258921550845e-10
  3740 KSP Residual norm 1.027346761231e-09
  3741 KSP Residual norm 1.166874318109e-09
  3742 KSP Residual norm 1.213370029486e-09
  3743 KSP Residual norm 1.184871608298e-09
  3744 KSP Residual norm 1.174473860715e-09
  3745 KSP Residual norm 1.282706697747e-09
  3746 KSP Residual norm 1.420218538661e-09
  3747 KSP Residual norm 1.213617751835e-09
  3748 KSP Residual norm 1.012616242323e-09
  3749 KSP Residual norm 1.007353910335e-09
  3750 KSP Residual norm 1.056593527376e-09
  3751 KSP Residual norm 9.580832383252e-10
  3752 KSP Residual norm 8.219281961795e-10
  3753 KSP Residual norm 7.745848997630e-10
  3754 KSP Residual norm 7.931571443373e-10
  3755 KSP Residual norm 8.467406308335e-10
  3756 KSP Residual norm 8.745814946721e-10
  3757 KSP Residual norm 8.909135899981e-10
  3758 KSP Residual norm 1.054596979550e-09
  3759 KSP Residual norm 1.438467378917e-09
  3760 KSP Residual norm 1.592665138470e-09
  3761 KSP Residual norm 1.654950136113e-09
  3762 KSP Residual norm 1.863240466378e-09
  3763 KSP Residual norm 2.196282931642e-09
  3764 KSP Residual norm 2.421102402238e-09
  3765 KSP Residual norm 2.628663441533e-09
  3766 KSP Residual norm 2.835077530258e-09
  3767 KSP Residual norm 3.175214114881e-09
  3768 KSP Residual norm 3.697360871015e-09
  3769 KSP Residual norm 3.913774246882e-09
  3770 KSP Residual norm 3.550579905576e-09
  3771 KSP Residual norm 3.304815922808e-09
  3772 KSP Residual norm 3.351194014807e-09
  3773 KSP Residual norm 3.177330698243e-09
  3774 KSP Residual norm 3.028958586793e-09
  3775 KSP Residual norm 3.006011160859e-09
  3776 KSP Residual norm 2.990140440619e-09
  3777 KSP Residual norm 2.857406980637e-09
  3778 KSP Residual norm 2.582408262295e-09
  3779 KSP Residual norm 2.337385010000e-09
  3780 KSP Residual norm 2.367977574793e-09
  3781 KSP Residual norm 2.603199274005e-09
  3782 KSP Residual norm 2.626986692675e-09
  3783 KSP Residual norm 2.507646852925e-09
  3784 KSP Residual norm 2.642769899751e-09
  3785 KSP Residual norm 3.006809518600e-09
  3786 KSP Residual norm 3.449837784267e-09
  3787 KSP Residual norm 3.967858597187e-09
  3788 KSP Residual norm 4.334255750080e-09
  3789 KSP Residual norm 4.564948892290e-09
  3790 KSP Residual norm 4.986634678652e-09
  3791 KSP Residual norm 5.282722680059e-09
  3792 KSP Residual norm 5.527223810294e-09
  3793 KSP Residual norm 6.295891355624e-09
  3794 KSP Residual norm 7.053334963000e-09
  3795 KSP Residual norm 6.909173011517e-09
  3796 KSP Residual norm 6.791535027020e-09
  3797 KSP Residual norm 6.811888049361e-09
  3798 KSP Residual norm 6.131671212365e-09
  3799 KSP Residual norm 5.152257158523e-09
  3800 KSP Residual norm 4.778158384516e-09
  3801 KSP Residual norm 4.612516711446e-09
  3802 KSP Residual norm 4.562565820156e-09
  3803 KSP Residual norm 4.617156905796e-09
  3804 KSP Residual norm 4.358636100480e-09
  3805 KSP Residual norm 3.923004546151e-09
  3806 KSP Residual norm 3.919094602564e-09
  3807 KSP Residual norm 4.137582611235e-09
  3808 KSP Residual norm 4.166762557996e-09
  3809 KSP Residual norm 4.157836207038e-09
  3810 KSP Residual norm 4.550592070789e-09
  3811 KSP Residual norm 5.318499256785e-09
  3812 KSP Residual norm 6.100259232099e-09
  3813 KSP Residual norm 6.554542794443e-09
  3814 KSP Residual norm 6.665500876471e-09
  3815 KSP Residual norm 6.966151539805e-09
  3816 KSP Residual norm 7.630082757005e-09
  3817 KSP Residual norm 7.781720204336e-09
  3818 KSP Residual norm 8.374231106959e-09
  3819 KSP Residual norm 9.886597355096e-09
  3820 KSP Residual norm 1.013796062841e-08
  3821 KSP Residual norm 9.153183359250e-09
  3822 KSP Residual norm 9.287889893112e-09
  3823 KSP Residual norm 9.002107067915e-09
  3824 KSP Residual norm 7.771162647686e-09
  3825 KSP Residual norm 6.611323733583e-09
  3826 KSP Residual norm 6.193950774151e-09
  3827 KSP Residual norm 6.006860989876e-09
  3828 KSP Residual norm 5.548811001483e-09
  3829 KSP Residual norm 4.599172770080e-09
  3830 KSP Residual norm 3.842230780770e-09
  3831 KSP Residual norm 3.622414122581e-09
  3832 KSP Residual norm 3.540520346846e-09
  3833 KSP Residual norm 3.393468599325e-09
  3834 KSP Residual norm 3.331446904417e-09
  3835 KSP Residual norm 3.514217766739e-09
  3836 KSP Residual norm 3.400366281540e-09
  3837 KSP Residual norm 3.648341368355e-09
  3838 KSP Residual norm 4.473208234460e-09
  3839 KSP Residual norm 5.249163562313e-09
  3840 KSP Residual norm 5.378339602120e-09
  3841 KSP Residual norm 5.335318247842e-09
  3842 KSP Residual norm 5.401980040816e-09
  3843 KSP Residual norm 5.490386757551e-09
  3844 KSP Residual norm 6.083459229561e-09
  3845 KSP Residual norm 6.846727677443e-09
  3846 KSP Residual norm 7.646885057928e-09
  3847 KSP Residual norm 8.071956101029e-09
  3848 KSP Residual norm 7.697960396304e-09
  3849 KSP Residual norm 6.772149457789e-09
  3850 KSP Residual norm 6.757555864440e-09
  3851 KSP Residual norm 6.974016978612e-09
  3852 KSP Residual norm 6.227274736239e-09
  3853 KSP Residual norm 5.481396616309e-09
  3854 KSP Residual norm 5.168459942046e-09
  3855 KSP Residual norm 4.953866468095e-09
  3856 KSP Residual norm 4.176294030401e-09
  3857 KSP Residual norm 3.652326452112e-09
  3858 KSP Residual norm 3.531139316008e-09
  3859 KSP Residual norm 3.543912231323e-09
  3860 KSP Residual norm 3.661827914926e-09
  3861 KSP Residual norm 3.492909356536e-09
  3862 KSP Residual norm 3.275490068445e-09
  3863 KSP Residual norm 3.590862719165e-09
  3864 KSP Residual norm 3.816489981118e-09
  3865 KSP Residual norm 3.531138746383e-09
  3866 KSP Residual norm 3.391043727578e-09
  3867 KSP Residual norm 3.676184742966e-09
  3868 KSP Residual norm 4.067098670559e-09
  3869 KSP Residual norm 4.410510232256e-09
  3870 KSP Residual norm 4.692212412907e-09
  3871 KSP Residual norm 5.069891878057e-09
  3872 KSP Residual norm 5.790013201131e-09
  3873 KSP Residual norm 6.516195442822e-09
  3874 KSP Residual norm 6.255156678025e-09
  3875 KSP Residual norm 6.063038053539e-09
  3876 KSP Residual norm 6.873342625158e-09
  3877 KSP Residual norm 6.943824440307e-09
  3878 KSP Residual norm 5.840117772191e-09
  3879 KSP Residual norm 5.144276309692e-09
  3880 KSP Residual norm 4.937580479937e-09
  3881 KSP Residual norm 4.648807688539e-09
  3882 KSP Residual norm 4.087635552319e-09
  3883 KSP Residual norm 3.443168088894e-09
  3884 KSP Residual norm 3.022006583162e-09
  3885 KSP Residual norm 2.859607370810e-09
  3886 KSP Residual norm 2.711318373182e-09
  3887 KSP Residual norm 2.405511441447e-09
  3888 KSP Residual norm 2.263807464443e-09
  3889 KSP Residual norm 2.424374509329e-09
  3890 KSP Residual norm 2.412882269713e-09
  3891 KSP Residual norm 2.287460266215e-09
  3892 KSP Residual norm 2.301876313823e-09
  3893 KSP Residual norm 2.296806627701e-09
  3894 KSP Residual norm 2.152629906513e-09
  3895 KSP Residual norm 2.190917755703e-09
  3896 KSP Residual norm 2.344507727148e-09
  3897 KSP Residual norm 2.482478128543e-09
  3898 KSP Residual norm 2.712795011790e-09
  3899 KSP Residual norm 2.919811289920e-09
  3900 KSP Residual norm 2.986213208333e-09
  3901 KSP Residual norm 3.125605230841e-09
  3902 KSP Residual norm 3.380979670104e-09
  3903 KSP Residual norm 3.283101953680e-09
  3904 KSP Residual norm 3.127916120918e-09
  3905 KSP Residual norm 3.264692015038e-09
  3906 KSP Residual norm 3.250029145900e-09
  3907 KSP Residual norm 2.946166507740e-09
  3908 KSP Residual norm 2.441775149444e-09
  3909 KSP Residual norm 2.202470467250e-09
  3910 KSP Residual norm 2.255373430765e-09
  3911 KSP Residual norm 2.353184882674e-09
  3912 KSP Residual norm 1.965759220991e-09
  3913 KSP Residual norm 1.710185402939e-09
  3914 KSP Residual norm 1.758919952194e-09
  3915 KSP Residual norm 1.795062037273e-09
  3916 KSP Residual norm 1.606618785435e-09
  3917 KSP Residual norm 1.413826151756e-09
  3918 KSP Residual norm 1.283914299032e-09
  3919 KSP Residual norm 1.232261291845e-09
  3920 KSP Residual norm 1.270161260177e-09
  3921 KSP Residual norm 1.331332352538e-09
  3922 KSP Residual norm 1.355313865150e-09
  3923 KSP Residual norm 1.448917738770e-09
  3924 KSP Residual norm 1.422362403069e-09
  3925 KSP Residual norm 1.323384522043e-09
  3926 KSP Residual norm 1.400218158388e-09
  3927 KSP Residual norm 1.656249119206e-09
  3928 KSP Residual norm 1.643725725901e-09
  3929 KSP Residual norm 1.545717747768e-09
  3930 KSP Residual norm 1.788582198740e-09
  3931 KSP Residual norm 2.181566592400e-09
  3932 KSP Residual norm 2.474210455805e-09
  3933 KSP Residual norm 2.796826555992e-09
  3934 KSP Residual norm 3.083005629464e-09
  3935 KSP Residual norm 3.066266695523e-09
  3936 KSP Residual norm 3.105401664552e-09
  3937 KSP Residual norm 3.256112899940e-09
  3938 KSP Residual norm 3.370399409679e-09
  3939 KSP Residual norm 3.834842269870e-09
  3940 KSP Residual norm 4.501186120374e-09
  3941 KSP Residual norm 4.250334618898e-09
  3942 KSP Residual norm 3.809590443123e-09
  3943 KSP Residual norm 3.756192953808e-09
  3944 KSP Residual norm 3.544461085062e-09
  3945 KSP Residual norm 3.223589182631e-09
  3946 KSP Residual norm 3.239258085287e-09
  3947 KSP Residual norm 3.360968668144e-09
  3948 KSP Residual norm 3.261628998873e-09
  3949 KSP Residual norm 3.290467660641e-09
  3950 KSP Residual norm 3.330341012352e-09
  3951 KSP Residual norm 3.239143428321e-09
  3952 KSP Residual norm 3.277741365203e-09
  3953 KSP Residual norm 3.101023282081e-09
  3954 KSP Residual norm 2.892501125850e-09
  3955 KSP Residual norm 2.856842261511e-09
  3956 KSP Residual norm 2.718427935489e-09
  3957 KSP Residual norm 2.344248405193e-09
  3958 KSP Residual norm 2.086248636909e-09
  3959 KSP Residual norm 2.184448011477e-09
  3960 KSP Residual norm 2.415925399694e-09
  3961 KSP Residual norm 2.576513553863e-09
  3962 KSP Residual norm 2.737083658035e-09
  3963 KSP Residual norm 2.965443467108e-09
  3964 KSP Residual norm 3.164083481828e-09
  3965 KSP Residual norm 3.510281077294e-09
  3966 KSP Residual norm 3.399060445216e-09
  3967 KSP Residual norm 3.331824499354e-09
  3968 KSP Residual norm 4.042252202875e-09
  3969 KSP Residual norm 4.870044093273e-09
  3970 KSP Residual norm 4.732398806993e-09
  3971 KSP Residual norm 4.662942850983e-09
  3972 KSP Residual norm 5.472474969545e-09
  3973 KSP Residual norm 5.954313908438e-09
  3974 KSP Residual norm 5.991476831585e-09
  3975 KSP Residual norm 6.001363596620e-09
  3976 KSP Residual norm 5.704183033542e-09
  3977 KSP Residual norm 5.385095024192e-09
  3978 KSP Residual norm 5.166172984365e-09
  3979 KSP Residual norm 4.943023104709e-09
  3980 KSP Residual norm 5.018177715546e-09
  3981 KSP Residual norm 5.380343119999e-09
  3982 KSP Residual norm 5.293265303117e-09
  3983 KSP Residual norm 4.729796013721e-09
  3984 KSP Residual norm 4.491842566742e-09
  3985 KSP Residual norm 4.206419801015e-09
  3986 KSP Residual norm 3.537659762079e-09
  3987 KSP Residual norm 3.053300180235e-09
  3988 KSP Residual norm 2.929047013735e-09
  3989 KSP Residual norm 3.031029702849e-09
  3990 KSP Residual norm 3.198866711459e-09
  3991 KSP Residual norm 3.376940985965e-09
  3992 KSP Residual norm 3.418156071235e-09
  3993 KSP Residual norm 3.599086389464e-09
  3994 KSP Residual norm 3.900519119845e-09
  3995 KSP Residual norm 4.034070946923e-09
  3996 KSP Residual norm 4.253185778860e-09
  3997 KSP Residual norm 4.733176776867e-09
  3998 KSP Residual norm 4.789128503963e-09
  3999 KSP Residual norm 5.016136563041e-09
  4000 KSP Residual norm 6.138581703231e-09
  4001 KSP Residual norm 7.391652942867e-09
  4002 KSP Residual norm 7.998761074459e-09
  4003 KSP Residual norm 8.679932031793e-09
  4004 KSP Residual norm 9.030328191917e-09
  4005 KSP Residual norm 9.546904892416e-09
  4006 KSP Residual norm 9.690104383683e-09
  4007 KSP Residual norm 9.483808381788e-09
  4008 KSP Residual norm 1.012588277637e-08
  4009 KSP Residual norm 1.195623866828e-08
  4010 KSP Residual norm 1.299482278386e-08
  4011 KSP Residual norm 1.146707382361e-08
  4012 KSP Residual norm 1.075923528113e-08
  4013 KSP Residual norm 1.160376593462e-08
  4014 KSP Residual norm 1.198684568405e-08
  4015 KSP Residual norm 1.135153309086e-08
  4016 KSP Residual norm 1.082837345504e-08
  4017 KSP Residual norm 1.031045035497e-08
  4018 KSP Residual norm 1.052033547756e-08
  4019 KSP Residual norm 1.121419895757e-08
  4020 KSP Residual norm 1.075574081981e-08
  4021 KSP Residual norm 9.633510824262e-09
  4022 KSP Residual norm 9.145104141050e-09
  4023 KSP Residual norm 8.862961841246e-09
  4024 KSP Residual norm 8.449292454283e-09
  4025 KSP Residual norm 8.648500752338e-09
  4026 KSP Residual norm 8.690671206694e-09
  4027 KSP Residual norm 8.056508664370e-09
  4028 KSP Residual norm 7.550167290996e-09
  4029 KSP Residual norm 7.347148765984e-09
  4030 KSP Residual norm 7.720956633865e-09
  4031 KSP Residual norm 8.762261865027e-09
  4032 KSP Residual norm 9.789504732310e-09
  4033 KSP Residual norm 1.054739089320e-08
  4034 KSP Residual norm 1.202211959112e-08
  4035 KSP Residual norm 1.330043382411e-08
  4036 KSP Residual norm 1.384409930158e-08
  4037 KSP Residual norm 1.450610028685e-08
  4038 KSP Residual norm 1.525461548139e-08
  4039 KSP Residual norm 1.617032057945e-08
  4040 KSP Residual norm 1.850654071556e-08
  4041 KSP Residual norm 2.256133336626e-08
  4042 KSP Residual norm 2.536293554944e-08
  4043 KSP Residual norm 2.655949217321e-08
  4044 KSP Residual norm 2.804175255232e-08
  4045 KSP Residual norm 2.832350176504e-08
  4046 KSP Residual norm 2.678458985868e-08
  4047 KSP Residual norm 2.592132192655e-08
  4048 KSP Residual norm 2.428932682514e-08
  4049 KSP Residual norm 2.289364976159e-08
  4050 KSP Residual norm 2.386280178571e-08
  4051 KSP Residual norm 2.559287999412e-08
  4052 KSP Residual norm 2.551019264666e-08
  4053 KSP Residual norm 2.562574769128e-08
  4054 KSP Residual norm 2.597386692494e-08
  4055 KSP Residual norm 2.249744794070e-08
  4056 KSP Residual norm 1.908553073541e-08
  4057 KSP Residual norm 1.694977829547e-08
  4058 KSP Residual norm 1.520039098624e-08
  4059 KSP Residual norm 1.419021852844e-08
  4060 KSP Residual norm 1.505391318405e-08
  4061 KSP Residual norm 1.691624430843e-08
  4062 KSP Residual norm 1.887752572332e-08
  4063 KSP Residual norm 2.089335104529e-08
  4064 KSP Residual norm 2.096062736842e-08
  4065 KSP Residual norm 2.093531483198e-08
  4066 KSP Residual norm 2.395871862416e-08
  4067 KSP Residual norm 2.764262925708e-08
  4068 KSP Residual norm 2.796000832214e-08
  4069 KSP Residual norm 2.950163871848e-08
  4070 KSP Residual norm 3.096548082627e-08
  4071 KSP Residual norm 2.737353312829e-08
  4072 KSP Residual norm 2.467622001632e-08
  4073 KSP Residual norm 2.594441514126e-08
  4074 KSP Residual norm 2.916291972136e-08
  4075 KSP Residual norm 3.509932607141e-08
  4076 KSP Residual norm 3.962877952113e-08
  4077 KSP Residual norm 3.630341801036e-08
  4078 KSP Residual norm 3.300351337923e-08
  4079 KSP Residual norm 3.323608754991e-08
  4080 KSP Residual norm 3.176039818243e-08
  4081 KSP Residual norm 2.982314458706e-08
  4082 KSP Residual norm 2.896449247494e-08
  4083 KSP Residual norm 2.793509115658e-08
  4084 KSP Residual norm 2.737195005100e-08
  4085 KSP Residual norm 2.779980127325e-08
  4086 KSP Residual norm 2.722947138431e-08
  4087 KSP Residual norm 2.612623382793e-08
  4088 KSP Residual norm 2.501790278787e-08
  4089 KSP Residual norm 2.351751942911e-08
  4090 KSP Residual norm 2.218826538225e-08
  4091 KSP Residual norm 2.130630498099e-08
  4092 KSP Residual norm 2.004207099690e-08
  4093 KSP Residual norm 1.816738300576e-08
  4094 KSP Residual norm 1.691446504243e-08
  4095 KSP Residual norm 1.668342826023e-08
  4096 KSP Residual norm 1.634621207380e-08
  4097 KSP Residual norm 1.714037481271e-08
  4098 KSP Residual norm 1.888614396702e-08
  4099 KSP Residual norm 1.863132773296e-08
  4100 KSP Residual norm 1.762413134112e-08
  4101 KSP Residual norm 1.750019528592e-08
  4102 KSP Residual norm 1.852630960347e-08
  4103 KSP Residual norm 2.062065606814e-08
  4104 KSP Residual norm 2.252875273729e-08
  4105 KSP Residual norm 2.123433448712e-08
  4106 KSP Residual norm 2.049951634218e-08
  4107 KSP Residual norm 2.329117223251e-08
  4108 KSP Residual norm 2.620288744294e-08
  4109 KSP Residual norm 2.685391666831e-08
  4110 KSP Residual norm 2.686171126390e-08
  4111 KSP Residual norm 2.870542605525e-08
  4112 KSP Residual norm 3.094716380764e-08
  4113 KSP Residual norm 3.216424756745e-08
  4114 KSP Residual norm 3.107694630275e-08
  4115 KSP Residual norm 2.957154947520e-08
  4116 KSP Residual norm 2.907453110586e-08
  4117 KSP Residual norm 2.754462213531e-08
  4118 KSP Residual norm 2.579690912899e-08
  4119 KSP Residual norm 2.635957030566e-08
  4120 KSP Residual norm 2.690930515613e-08
  4121 KSP Residual norm 2.469704710466e-08
  4122 KSP Residual norm 2.276160595317e-08
  4123 KSP Residual norm 2.239011260345e-08
  4124 KSP Residual norm 1.947472082430e-08
  4125 KSP Residual norm 1.634594843772e-08
  4126 KSP Residual norm 1.488364202351e-08
  4127 KSP Residual norm 1.438218002644e-08
  4128 KSP Residual norm 1.382772194901e-08
  4129 KSP Residual norm 1.234173421728e-08
  4130 KSP Residual norm 1.047495750096e-08
  4131 KSP Residual norm 9.085157241814e-09
  4132 KSP Residual norm 8.136981267910e-09
  4133 KSP Residual norm 7.285496427528e-09
  4134 KSP Residual norm 7.286630350205e-09
  4135 KSP Residual norm 7.946798028906e-09
  4136 KSP Residual norm 7.572693487448e-09
  4137 KSP Residual norm 7.334653980611e-09
  4138 KSP Residual norm 8.189783149138e-09
  4139 KSP Residual norm 8.691719981189e-09
  4140 KSP Residual norm 8.124376114180e-09
  4141 KSP Residual norm 8.056947204493e-09
  4142 KSP Residual norm 8.606917507653e-09
  4143 KSP Residual norm 9.058460095816e-09
  4144 KSP Residual norm 1.028394190173e-08
  4145 KSP Residual norm 1.118370605514e-08
  4146 KSP Residual norm 1.206094568346e-08
  4147 KSP Residual norm 1.396219885964e-08
  4148 KSP Residual norm 1.483429894488e-08
  4149 KSP Residual norm 1.452459617645e-08
  4150 KSP Residual norm 1.588978837067e-08
  4151 KSP Residual norm 1.768844989849e-08
  4152 KSP Residual norm 1.760452549557e-08
  4153 KSP Residual norm 1.700454262298e-08
  4154 KSP Residual norm 1.702873449272e-08
  4155 KSP Residual norm 1.625919412683e-08
  4156 KSP Residual norm 1.583500187118e-08
  4157 KSP Residual norm 1.536250272407e-08
  4158 KSP Residual norm 1.522311426297e-08
  4159 KSP Residual norm 1.558377789524e-08
  4160 KSP Residual norm 1.526581281702e-08
  4161 KSP Residual norm 1.319908355880e-08
  4162 KSP Residual norm 1.168698314210e-08
  4163 KSP Residual norm 1.107355672789e-08
  4164 KSP Residual norm 9.846608787340e-09
  4165 KSP Residual norm 8.162049245704e-09
  4166 KSP Residual norm 7.475128684377e-09
  4167 KSP Residual norm 7.661293881858e-09
  4168 KSP Residual norm 7.459525934709e-09
  4169 KSP Residual norm 6.670745519652e-09
  4170 KSP Residual norm 5.975738328781e-09
  4171 KSP Residual norm 5.318842124371e-09
  4172 KSP Residual norm 4.904736050409e-09
  4173 KSP Residual norm 4.712092107810e-09
  4174 KSP Residual norm 4.552037007123e-09
  4175 KSP Residual norm 4.446510720792e-09
  4176 KSP Residual norm 4.492990640962e-09
  4177 KSP Residual norm 4.340031148562e-09
  4178 KSP Residual norm 3.957186146268e-09
  4179 KSP Residual norm 3.843270844058e-09
  4180 KSP Residual norm 3.650804251796e-09
  4181 KSP Residual norm 3.311840002391e-09
  4182 KSP Residual norm 3.091613548750e-09
  4183 KSP Residual norm 2.924261451883e-09
  4184 KSP Residual norm 2.998860183074e-09
  4185 KSP Residual norm 3.257379147781e-09
  4186 KSP Residual norm 3.449507582137e-09
  4187 KSP Residual norm 3.681822791336e-09
  4188 KSP Residual norm 4.456311747118e-09
  4189 KSP Residual norm 5.044426395091e-09
  4190 KSP Residual norm 4.824981240267e-09
  4191 KSP Residual norm 4.884669170982e-09
  4192 KSP Residual norm 5.231543707371e-09
  4193 KSP Residual norm 4.970053567421e-09
  4194 KSP Residual norm 4.660102985186e-09
  4195 KSP Residual norm 4.943784503481e-09
  4196 KSP Residual norm 5.632527178562e-09
  4197 KSP Residual norm 6.159333909842e-09
  4198 KSP Residual norm 6.285453778351e-09
  4199 KSP Residual norm 6.446054116102e-09
  4200 KSP Residual norm 7.129726438283e-09
  4201 KSP Residual norm 7.509207436768e-09
  4202 KSP Residual norm 6.935196027170e-09
  4203 KSP Residual norm 6.599431319334e-09
  4204 KSP Residual norm 6.669173933611e-09
  4205 KSP Residual norm 6.111956360389e-09
  4206 KSP Residual norm 5.408974684279e-09
  4207 KSP Residual norm 5.421897673000e-09
  4208 KSP Residual norm 5.537024176479e-09
  4209 KSP Residual norm 4.743457554778e-09
  4210 KSP Residual norm 3.886038481710e-09
  4211 KSP Residual norm 3.486041456167e-09
  4212 KSP Residual norm 3.444291350160e-09
  4213 KSP Residual norm 3.230682605508e-09
  4214 KSP Residual norm 2.968808764869e-09
  4215 KSP Residual norm 2.718272352020e-09
  4216 KSP Residual norm 2.717145540790e-09
  4217 KSP Residual norm 2.733024094369e-09
  4218 KSP Residual norm 2.318789251138e-09
  4219 KSP Residual norm 1.954530954662e-09
  4220 KSP Residual norm 1.863062618998e-09
  4221 KSP Residual norm 1.743141338225e-09
  4222 KSP Residual norm 1.584866437917e-09
  4223 KSP Residual norm 1.528200625323e-09
  4224 KSP Residual norm 1.638050612201e-09
  4225 KSP Residual norm 1.813101976102e-09
  4226 KSP Residual norm 1.855052778576e-09
  4227 KSP Residual norm 1.874694526406e-09
  4228 KSP Residual norm 1.933001713081e-09
  4229 KSP Residual norm 1.933590237496e-09
  4230 KSP Residual norm 1.852684849220e-09
  4231 KSP Residual norm 1.794808688686e-09
  4232 KSP Residual norm 1.902146850067e-09
  4233 KSP Residual norm 2.221411289596e-09
  4234 KSP Residual norm 2.656851636003e-09
  4235 KSP Residual norm 3.032401865104e-09
  4236 KSP Residual norm 3.381271090432e-09
  4237 KSP Residual norm 3.627879707749e-09
  4238 KSP Residual norm 3.539856838872e-09
  4239 KSP Residual norm 3.634330312444e-09
  4240 KSP Residual norm 4.034810686687e-09
  4241 KSP Residual norm 4.513582389211e-09
  4242 KSP Residual norm 4.651712607100e-09
  4243 KSP Residual norm 4.395766984937e-09
  4244 KSP Residual norm 4.335803356630e-09
  4245 KSP Residual norm 4.749171512618e-09
  4246 KSP Residual norm 5.431555925950e-09
  4247 KSP Residual norm 5.718827886358e-09
  4248 KSP Residual norm 5.513411243351e-09
  4249 KSP Residual norm 5.443989217755e-09
  4250 KSP Residual norm 5.264544027474e-09
  4251 KSP Residual norm 5.016099572822e-09
  4252 KSP Residual norm 5.245565687844e-09
  4253 KSP Residual norm 5.615137487815e-09
  4254 KSP Residual norm 5.909964063308e-09
  4255 KSP Residual norm 5.718021487749e-09
  4256 KSP Residual norm 5.171547508364e-09
  4257 KSP Residual norm 4.745730365847e-09
  4258 KSP Residual norm 4.601586215582e-09
  4259 KSP Residual norm 4.482226526972e-09
  4260 KSP Residual norm 4.165847924446e-09
  4261 KSP Residual norm 3.982769321471e-09
  4262 KSP Residual norm 3.741860613841e-09
  4263 KSP Residual norm 3.376888371868e-09
  4264 KSP Residual norm 3.085969404021e-09
  4265 KSP Residual norm 3.099497896422e-09
  4266 KSP Residual norm 3.212001003247e-09
  4267 KSP Residual norm 3.002628414977e-09
  4268 KSP Residual norm 2.813528963082e-09
  4269 KSP Residual norm 2.634489823438e-09
  4270 KSP Residual norm 2.413899154472e-09
  4271 KSP Residual norm 2.443024880013e-09
  4272 KSP Residual norm 2.586223128221e-09
  4273 KSP Residual norm 2.731353001399e-09
  4274 KSP Residual norm 2.891984655130e-09
  4275 KSP Residual norm 3.033746057386e-09
  4276 KSP Residual norm 3.141960066188e-09
  4277 KSP Residual norm 3.054300320564e-09
  4278 KSP Residual norm 2.937418157421e-09
  4279 KSP Residual norm 2.719452987627e-09
  4280 KSP Residual norm 2.881251994346e-09
  4281 KSP Residual norm 3.347970414028e-09
  4282 KSP Residual norm 3.535354797926e-09
  4283 KSP Residual norm 3.417610077430e-09
  4284 KSP Residual norm 3.737110690476e-09
  4285 KSP Residual norm 4.701719482213e-09
  4286 KSP Residual norm 5.659287698474e-09
  4287 KSP Residual norm 5.706078813548e-09
  4288 KSP Residual norm 5.485752305123e-09
  4289 KSP Residual norm 5.587703646830e-09
  4290 KSP Residual norm 5.877343062071e-09
  4291 KSP Residual norm 5.900809554339e-09
  4292 KSP Residual norm 5.852848389844e-09
  4293 KSP Residual norm 6.765236661867e-09
  4294 KSP Residual norm 7.805716639767e-09
  4295 KSP Residual norm 7.943667805252e-09
  4296 KSP Residual norm 8.020819989258e-09
  4297 KSP Residual norm 8.134173165531e-09
  4298 KSP Residual norm 7.818857676861e-09
  4299 KSP Residual norm 7.375357027175e-09
  4300 KSP Residual norm 7.270318299032e-09
  4301 KSP Residual norm 7.459559362965e-09
  4302 KSP Residual norm 7.398045285850e-09
  4303 KSP Residual norm 6.785702976254e-09
  4304 KSP Residual norm 6.368121562976e-09
  4305 KSP Residual norm 6.260410644986e-09
  4306 KSP Residual norm 6.066404209616e-09
  4307 KSP Residual norm 5.420916789146e-09
  4308 KSP Residual norm 4.907630782920e-09
  4309 KSP Residual norm 4.907514085623e-09
  4310 KSP Residual norm 5.165438878515e-09
  4311 KSP Residual norm 5.179321072307e-09
  4312 KSP Residual norm 5.207561392076e-09
  4313 KSP Residual norm 5.299448255555e-09
  4314 KSP Residual norm 5.346346693285e-09
  4315 KSP Residual norm 5.216749278720e-09
  4316 KSP Residual norm 5.445059688063e-09
  4317 KSP Residual norm 5.777890646193e-09
  4318 KSP Residual norm 5.799778295627e-09
  4319 KSP Residual norm 5.471910328914e-09
  4320 KSP Residual norm 5.894159083144e-09
  4321 KSP Residual norm 6.726516622871e-09
  4322 KSP Residual norm 6.997943434322e-09
  4323 KSP Residual norm 7.002186748675e-09
  4324 KSP Residual norm 7.743685352975e-09
  4325 KSP Residual norm 9.203681043662e-09
  4326 KSP Residual norm 1.073950772096e-08
  4327 KSP Residual norm 1.123710863032e-08
  4328 KSP Residual norm 1.066033340128e-08
  4329 KSP Residual norm 1.019790983388e-08
  4330 KSP Residual norm 1.059777357551e-08
  4331 KSP Residual norm 1.056558658733e-08
  4332 KSP Residual norm 1.062520924734e-08
  4333 KSP Residual norm 1.128869046972e-08
  4334 KSP Residual norm 1.245676160904e-08
  4335 KSP Residual norm 1.284596857107e-08
  4336 KSP Residual norm 1.257009636847e-08
  4337 KSP Residual norm 1.345342783289e-08
  4338 KSP Residual norm 1.467720076671e-08
  4339 KSP Residual norm 1.473766466890e-08
  4340 KSP Residual norm 1.444039945698e-08
  4341 KSP Residual norm 1.526813382813e-08
  4342 KSP Residual norm 1.610284591133e-08
  4343 KSP Residual norm 1.572054222357e-08
  4344 KSP Residual norm 1.449874668720e-08
  4345 KSP Residual norm 1.303199757291e-08
  4346 KSP Residual norm 1.306943127101e-08
  4347 KSP Residual norm 1.463635979882e-08
  4348 KSP Residual norm 1.514037510983e-08
  4349 KSP Residual norm 1.367364350534e-08
  4350 KSP Residual norm 1.326311503293e-08
  4351 KSP Residual norm 1.382265862700e-08
  4352 KSP Residual norm 1.275336095274e-08
  4353 KSP Residual norm 1.090060101873e-08
  4354 KSP Residual norm 1.031322886619e-08
  4355 KSP Residual norm 9.637513403177e-09
  4356 KSP Residual norm 8.511479238782e-09
  4357 KSP Residual norm 7.676982152008e-09
  4358 KSP Residual norm 7.543455802657e-09
  4359 KSP Residual norm 7.745212821546e-09
  4360 KSP Residual norm 7.701607622134e-09
  4361 KSP Residual norm 7.536264377322e-09
  4362 KSP Residual norm 8.216321487838e-09
  4363 KSP Residual norm 8.942988115404e-09
  4364 KSP Residual norm 9.221724948602e-09
  4365 KSP Residual norm 9.345838316154e-09
  4366 KSP Residual norm 9.672923092334e-09
  4367 KSP Residual norm 1.004792346341e-08
  4368 KSP Residual norm 1.012360272445e-08
  4369 KSP Residual norm 9.356963292462e-09
  4370 KSP Residual norm 8.728407388702e-09
  4371 KSP Residual norm 8.592728439421e-09
  4372 KSP Residual norm 8.500617610062e-09
  4373 KSP Residual norm 8.788357452974e-09
  4374 KSP Residual norm 9.975237962618e-09
  4375 KSP Residual norm 1.170321721394e-08
  4376 KSP Residual norm 1.294928252575e-08
  4377 KSP Residual norm 1.486996616436e-08
  4378 KSP Residual norm 1.879004917031e-08
  4379 KSP Residual norm 2.369483262819e-08
  4380 KSP Residual norm 2.547815706533e-08
  4381 KSP Residual norm 2.572960842747e-08
  4382 KSP Residual norm 2.504738703577e-08
  4383 KSP Residual norm 2.414096068253e-08
  4384 KSP Residual norm 2.429378707486e-08
  4385 KSP Residual norm 2.515871370492e-08
  4386 KSP Residual norm 2.614817263368e-08
  4387 KSP Residual norm 2.582993589384e-08
  4388 KSP Residual norm 2.399701043274e-08
  4389 KSP Residual norm 2.251570113433e-08
  4390 KSP Residual norm 2.313387383880e-08
  4391 KSP Residual norm 2.302830082774e-08
  4392 KSP Residual norm 2.060495429578e-08
  4393 KSP Residual norm 1.987617078622e-08
  4394 KSP Residual norm 2.014584457462e-08
  4395 KSP Residual norm 1.921767959856e-08
  4396 KSP Residual norm 1.786962458401e-08
  4397 KSP Residual norm 1.837691393774e-08
  4398 KSP Residual norm 1.858735647288e-08
  4399 KSP Residual norm 1.774811585154e-08
  4400 KSP Residual norm 1.637791978956e-08
  4401 KSP Residual norm 1.417205799884e-08
  4402 KSP Residual norm 1.329565042525e-08
  4403 KSP Residual norm 1.361061604922e-08
  4404 KSP Residual norm 1.324875718853e-08
  4405 KSP Residual norm 1.150636799842e-08
  4406 KSP Residual norm 1.066779636820e-08
  4407 KSP Residual norm 1.005213221176e-08
  4408 KSP Residual norm 9.226708270903e-09
  4409 KSP Residual norm 8.510105202036e-09
  4410 KSP Residual norm 8.472928529278e-09
  4411 KSP Residual norm 8.529789250606e-09
  4412 KSP Residual norm 8.350403083680e-09
  4413 KSP Residual norm 7.749874929050e-09
  4414 KSP Residual norm 6.713944395903e-09
  4415 KSP Residual norm 6.110083916602e-09
  4416 KSP Residual norm 6.005297817749e-09
  4417 KSP Residual norm 5.750924992241e-09
  4418 KSP Residual norm 5.392262662601e-09
  4419 KSP Residual norm 5.583852183324e-09
  4420 KSP Residual norm 6.094412575025e-09
  4421 KSP Residual norm 6.598026601936e-09
  4422 KSP Residual norm 7.045626590495e-09
  4423 KSP Residual norm 7.382207352571e-09
  4424 KSP Residual norm 7.676866813408e-09
  4425 KSP Residual norm 7.816356815656e-09
  4426 KSP Residual norm 7.974539198641e-09
  4427 KSP Residual norm 8.331683773800e-09
  4428 KSP Residual norm 9.088757003644e-09
  4429 KSP Residual norm 8.942375396417e-09
  4430 KSP Residual norm 8.443627397115e-09
  4431 KSP Residual norm 8.623504812431e-09
  4432 KSP Residual norm 9.311227665985e-09
  4433 KSP Residual norm 9.900900216796e-09
  4434 KSP Residual norm 1.034921235909e-08
  4435 KSP Residual norm 1.070503140969e-08
  4436 KSP Residual norm 1.075426995056e-08
  4437 KSP Residual norm 1.135231363456e-08
  4438 KSP Residual norm 1.221304855777e-08
  4439 KSP Residual norm 1.355929373291e-08
  4440 KSP Residual norm 1.425322532427e-08
  4441 KSP Residual norm 1.339775040289e-08
  4442 KSP Residual norm 1.228850479973e-08
  4443 KSP Residual norm 1.254823398645e-08
  4444 KSP Residual norm 1.295451308381e-08
  4445 KSP Residual norm 1.224026505632e-08
  4446 KSP Residual norm 1.162021966628e-08
  4447 KSP Residual norm 1.163355510336e-08
  4448 KSP Residual norm 1.105638083317e-08
  4449 KSP Residual norm 1.023403779303e-08
  4450 KSP Residual norm 9.667067790283e-09
  4451 KSP Residual norm 9.590855397668e-09
  4452 KSP Residual norm 9.764728450687e-09
  4453 KSP Residual norm 9.342500122628e-09
  4454 KSP Residual norm 8.369833232295e-09
  4455 KSP Residual norm 8.012823655708e-09
  4456 KSP Residual norm 7.370505346557e-09
  4457 KSP Residual norm 6.200852618681e-09
  4458 KSP Residual norm 5.550758031790e-09
  4459 KSP Residual norm 5.645844212568e-09
  4460 KSP Residual norm 5.803222057793e-09
  4461 KSP Residual norm 5.576525562385e-09
  4462 KSP Residual norm 5.512018507493e-09
  4463 KSP Residual norm 5.599990438732e-09
  4464 KSP Residual norm 5.634363976412e-09
  4465 KSP Residual norm 5.578508349380e-09
  4466 KSP Residual norm 5.403545019877e-09
  4467 KSP Residual norm 5.581963696443e-09
  4468 KSP Residual norm 5.429837219272e-09
  4469 KSP Residual norm 4.724371673842e-09
  4470 KSP Residual norm 4.275741818411e-09
  4471 KSP Residual norm 4.117184833097e-09
  4472 KSP Residual norm 4.061274718065e-09
  4473 KSP Residual norm 3.999519684824e-09
  4474 KSP Residual norm 4.076836054810e-09
  4475 KSP Residual norm 4.149843041037e-09
  4476 KSP Residual norm 3.978307561847e-09
  4477 KSP Residual norm 3.692179653273e-09
  4478 KSP Residual norm 3.584663436887e-09
  4479 KSP Residual norm 3.563221197194e-09
  4480 KSP Residual norm 3.578350785514e-09
  4481 KSP Residual norm 3.549524919806e-09
  4482 KSP Residual norm 3.893877860437e-09
  4483 KSP Residual norm 4.273710962295e-09
  4484 KSP Residual norm 4.360180788498e-09
  4485 KSP Residual norm 4.620296307254e-09
  4486 KSP Residual norm 5.068605362933e-09
  4487 KSP Residual norm 5.144665378643e-09
  4488 KSP Residual norm 4.929813364267e-09
  4489 KSP Residual norm 4.672877012100e-09
  4490 KSP Residual norm 4.537853093509e-09
  4491 KSP Residual norm 4.959428113319e-09
  4492 KSP Residual norm 5.406926137398e-09
  4493 KSP Residual norm 5.337353646484e-09
  4494 KSP Residual norm 5.098400959075e-09
  4495 KSP Residual norm 5.167764127576e-09
  4496 KSP Residual norm 5.554008133821e-09
  4497 KSP Residual norm 5.781585684727e-09
  4498 KSP Residual norm 5.641348983860e-09
  4499 KSP Residual norm 5.679107000879e-09
  4500 KSP Residual norm 5.836242647329e-09
  4501 KSP Residual norm 6.029904152289e-09
  4502 KSP Residual norm 6.146260262992e-09
  4503 KSP Residual norm 6.292545942332e-09
  4504 KSP Residual norm 6.304079771697e-09
  4505 KSP Residual norm 6.438052195134e-09
  4506 KSP Residual norm 5.923168176896e-09
  4507 KSP Residual norm 5.593885550453e-09
  4508 KSP Residual norm 5.593585904686e-09
  4509 KSP Residual norm 5.527409825839e-09
  4510 KSP Residual norm 5.592600656993e-09
  4511 KSP Residual norm 5.778679723841e-09
  4512 KSP Residual norm 5.579350885259e-09
  4513 KSP Residual norm 4.820948400231e-09
  4514 KSP Residual norm 4.058377601432e-09
  4515 KSP Residual norm 3.856173689448e-09
  4516 KSP Residual norm 4.310398432242e-09
  4517 KSP Residual norm 4.797923329822e-09
  4518 KSP Residual norm 4.807178577905e-09
  4519 KSP Residual norm 4.725781111792e-09
  4520 KSP Residual norm 4.469949107498e-09
  4521 KSP Residual norm 3.965434357696e-09
  4522 KSP Residual norm 3.489119099765e-09
  4523 KSP Residual norm 3.292372330620e-09
  4524 KSP Residual norm 3.269512763409e-09
  4525 KSP Residual norm 3.039178880571e-09
  4526 KSP Residual norm 2.944182459164e-09
  4527 KSP Residual norm 3.318058093893e-09
  4528 KSP Residual norm 3.952038673233e-09
  4529 KSP Residual norm 4.175794248013e-09
  4530 KSP Residual norm 4.099899999796e-09
  4531 KSP Residual norm 4.257002780707e-09
  4532 KSP Residual norm 4.708080778572e-09
  4533 KSP Residual norm 4.748032588629e-09
  4534 KSP Residual norm 4.478432338986e-09
  4535 KSP Residual norm 4.563089705965e-09
  4536 KSP Residual norm 5.331753434118e-09
  4537 KSP Residual norm 6.465397132174e-09
  4538 KSP Residual norm 7.132535025954e-09
  4539 KSP Residual norm 7.329692891462e-09
  4540 KSP Residual norm 7.782169349642e-09
  4541 KSP Residual norm 7.963491956554e-09
  4542 KSP Residual norm 7.463401236906e-09
  4543 KSP Residual norm 6.836178494570e-09
  4544 KSP Residual norm 6.579792745096e-09
  4545 KSP Residual norm 6.328626826214e-09
  4546 KSP Residual norm 5.935498601518e-09
  4547 KSP Residual norm 5.827015094633e-09
  4548 KSP Residual norm 5.853409336034e-09
  4549 KSP Residual norm 5.875100594497e-09
  4550 KSP Residual norm 5.771427233238e-09
  4551 KSP Residual norm 5.868175404828e-09
  4552 KSP Residual norm 5.772535302942e-09
  4553 KSP Residual norm 5.167618612895e-09
  4554 KSP Residual norm 4.428022731934e-09
  4555 KSP Residual norm 3.904923561116e-09
  4556 KSP Residual norm 3.746972592587e-09
  4557 KSP Residual norm 3.812391993713e-09
  4558 KSP Residual norm 3.683015150848e-09
  4559 KSP Residual norm 3.499745861664e-09
  4560 KSP Residual norm 3.317222455896e-09
  4561 KSP Residual norm 3.200568725504e-09
  4562 KSP Residual norm 3.266284000413e-09
  4563 KSP Residual norm 3.538036443489e-09
  4564 KSP Residual norm 3.956845584557e-09
  4565 KSP Residual norm 4.149454382759e-09
  4566 KSP Residual norm 3.776247227187e-09
  4567 KSP Residual norm 3.348827313314e-09
  4568 KSP Residual norm 3.264810837285e-09
  4569 KSP Residual norm 3.323977004611e-09
  4570 KSP Residual norm 3.630633551004e-09
  4571 KSP Residual norm 4.091066176955e-09
  4572 KSP Residual norm 4.419450226798e-09
  4573 KSP Residual norm 4.471577034523e-09
  4574 KSP Residual norm 4.693665961920e-09
  4575 KSP Residual norm 5.273196443647e-09
  4576 KSP Residual norm 6.223293584980e-09
  4577 KSP Residual norm 7.194371646463e-09
  4578 KSP Residual norm 7.884343686008e-09
  4579 KSP Residual norm 7.928397637554e-09
  4580 KSP Residual norm 7.335596095598e-09
  4581 KSP Residual norm 7.226727521418e-09
  4582 KSP Residual norm 7.640983934240e-09
  4583 KSP Residual norm 8.131770971756e-09
  4584 KSP Residual norm 8.850593805399e-09
  4585 KSP Residual norm 9.213373643826e-09
  4586 KSP Residual norm 9.810888843997e-09
  4587 KSP Residual norm 1.064152218643e-08
  4588 KSP Residual norm 1.125917849645e-08
  4589 KSP Residual norm 1.174896379031e-08
  4590 KSP Residual norm 1.206965078081e-08
  4591 KSP Residual norm 1.208614586616e-08
  4592 KSP Residual norm 1.299647622147e-08
  4593 KSP Residual norm 1.454259945395e-08
  4594 KSP Residual norm 1.440163300519e-08
  4595 KSP Residual norm 1.355896597284e-08
  4596 KSP Residual norm 1.348090389684e-08
  4597 KSP Residual norm 1.317987150217e-08
  4598 KSP Residual norm 1.313399412472e-08
  4599 KSP Residual norm 1.406602265138e-08
  4600 KSP Residual norm 1.563055412371e-08
  4601 KSP Residual norm 1.565056842844e-08
  4602 KSP Residual norm 1.431907643321e-08
  4603 KSP Residual norm 1.292421865946e-08
  4604 KSP Residual norm 1.267001786593e-08
  4605 KSP Residual norm 1.331753125256e-08
  4606 KSP Residual norm 1.323806484535e-08
  4607 KSP Residual norm 1.242461944425e-08
  4608 KSP Residual norm 1.244938525249e-08
  4609 KSP Residual norm 1.212648492091e-08
  4610 KSP Residual norm 1.099199039113e-08
  4611 KSP Residual norm 1.043401020233e-08
  4612 KSP Residual norm 1.112749460897e-08
  4613 KSP Residual norm 1.169228678178e-08
  4614 KSP Residual norm 1.119976757439e-08
  4615 KSP Residual norm 9.812439260818e-09
  4616 KSP Residual norm 9.407128337426e-09
  4617 KSP Residual norm 1.012731065037e-08
  4618 KSP Residual norm 9.957784532997e-09
  4619 KSP Residual norm 8.554660745344e-09
  4620 KSP Residual norm 7.984730755424e-09
  4621 KSP Residual norm 7.911824637650e-09
  4622 KSP Residual norm 7.467738018371e-09
  4623 KSP Residual norm 7.401094114672e-09
  4624 KSP Residual norm 8.300238295214e-09
  4625 KSP Residual norm 9.254622331041e-09
  4626 KSP Residual norm 9.768295196698e-09
  4627 KSP Residual norm 1.000354133302e-08
  4628 KSP Residual norm 9.911918232159e-09
  4629 KSP Residual norm 9.524726183856e-09
  4630 KSP Residual norm 9.049377157010e-09
  4631 KSP Residual norm 8.566510503846e-09
  4632 KSP Residual norm 8.438043212595e-09
  4633 KSP Residual norm 8.713386361315e-09
  4634 KSP Residual norm 8.717435561180e-09
  4635 KSP Residual norm 8.395221686020e-09
  4636 KSP Residual norm 8.391192500668e-09
  4637 KSP Residual norm 8.177723154534e-09
  4638 KSP Residual norm 7.884856910439e-09
  4639 KSP Residual norm 8.751791029403e-09
  4640 KSP Residual norm 1.130944382272e-08
  4641 KSP Residual norm 1.387552113801e-08
  4642 KSP Residual norm 1.527223209850e-08
  4643 KSP Residual norm 1.627800364679e-08
  4644 KSP Residual norm 1.690272181788e-08
  4645 KSP Residual norm 1.682415508072e-08
  4646 KSP Residual norm 1.624056035877e-08
  4647 KSP Residual norm 1.541059619989e-08
  4648 KSP Residual norm 1.513394843085e-08
  4649 KSP Residual norm 1.578309331553e-08
  4650 KSP Residual norm 1.723878941045e-08
  4651 KSP Residual norm 1.908129004268e-08
  4652 KSP Residual norm 1.992434285491e-08
  4653 KSP Residual norm 2.005692059579e-08
  4654 KSP Residual norm 1.985645214815e-08
  4655 KSP Residual norm 2.102233108048e-08
  4656 KSP Residual norm 2.200196912457e-08
  4657 KSP Residual norm 2.296829523019e-08
  4658 KSP Residual norm 2.345042257052e-08
  4659 KSP Residual norm 2.285787793768e-08
  4660 KSP Residual norm 2.145601395066e-08
  4661 KSP Residual norm 1.983664711669e-08
  4662 KSP Residual norm 1.946788847880e-08
  4663 KSP Residual norm 2.099026751386e-08
  4664 KSP Residual norm 2.312241200213e-08
  4665 KSP Residual norm 2.466653512521e-08
  4666 KSP Residual norm 2.536699373022e-08
  4667 KSP Residual norm 2.484334606353e-08
  4668 KSP Residual norm 2.243544778483e-08
  4669 KSP Residual norm 1.890286329022e-08
  4670 KSP Residual norm 1.797216984915e-08
  4671 KSP Residual norm 1.926884691754e-08
  4672 KSP Residual norm 2.030959603977e-08
  4673 KSP Residual norm 2.043685124682e-08
  4674 KSP Residual norm 2.048101384626e-08
  4675 KSP Residual norm 2.158484950053e-08
  4676 KSP Residual norm 2.199582473120e-08
  4677 KSP Residual norm 2.103472998988e-08
  4678 KSP Residual norm 2.149597765021e-08
  4679 KSP Residual norm 2.293141703823e-08
  4680 KSP Residual norm 2.377618789888e-08
  4681 KSP Residual norm 2.522005360651e-08
  4682 KSP Residual norm 2.528017363569e-08
  4683 KSP Residual norm 2.264543763588e-08
  4684 KSP Residual norm 2.001167062435e-08
  4685 KSP Residual norm 1.960034733123e-08
  4686 KSP Residual norm 2.011271132987e-08
  4687 KSP Residual norm 1.991553147992e-08
  4688 KSP Residual norm 2.032520471236e-08
  4689 KSP Residual norm 2.103797214965e-08
  4690 KSP Residual norm 2.087872001534e-08
  4691 KSP Residual norm 2.222354262499e-08
  4692 KSP Residual norm 2.435560744284e-08
  4693 KSP Residual norm 2.470797337115e-08
  4694 KSP Residual norm 2.561738733446e-08
  4695 KSP Residual norm 2.960927311504e-08
  4696 KSP Residual norm 3.435621988849e-08
  4697 KSP Residual norm 3.613545705494e-08
  4698 KSP Residual norm 3.554454802162e-08
  4699 KSP Residual norm 3.501155710179e-08
  4700 KSP Residual norm 3.736528549071e-08
  4701 KSP Residual norm 4.096732674634e-08
  4702 KSP Residual norm 4.137800122019e-08
  4703 KSP Residual norm 4.271182015368e-08
  4704 KSP Residual norm 4.758737558831e-08
  4705 KSP Residual norm 5.496376912285e-08
  4706 KSP Residual norm 5.918422422082e-08
  4707 KSP Residual norm 5.803018981240e-08
  4708 KSP Residual norm 5.774158798443e-08
  4709 KSP Residual norm 5.730581838701e-08
  4710 KSP Residual norm 4.981560210110e-08
  4711 KSP Residual norm 4.296326028138e-08
  4712 KSP Residual norm 4.590214314341e-08
  4713 KSP Residual norm 5.582860602854e-08
  4714 KSP Residual norm 5.731783066456e-08
  4715 KSP Residual norm 5.473075021318e-08
  4716 KSP Residual norm 5.510097730117e-08
  4717 KSP Residual norm 5.338735720112e-08
  4718 KSP Residual norm 4.948445554735e-08
  4719 KSP Residual norm 5.070110866220e-08
  4720 KSP Residual norm 5.267720778595e-08
  4721 KSP Residual norm 4.954577041311e-08
  4722 KSP Residual norm 4.251327655883e-08
  4723 KSP Residual norm 3.752949289707e-08
  4724 KSP Residual norm 3.751706343107e-08
  4725 KSP Residual norm 3.796565389299e-08
  4726 KSP Residual norm 3.542100103321e-08
  4727 KSP Residual norm 3.265849063750e-08
  4728 KSP Residual norm 3.334157486061e-08
  4729 KSP Residual norm 3.461237448150e-08
  4730 KSP Residual norm 3.342762736315e-08
  4731 KSP Residual norm 3.283319216386e-08
  4732 KSP Residual norm 3.131778139581e-08
  4733 KSP Residual norm 2.799484005029e-08
  4734 KSP Residual norm 2.455385155547e-08
  4735 KSP Residual norm 2.318480331650e-08
  4736 KSP Residual norm 2.531433163145e-08
  4737 KSP Residual norm 2.659905422589e-08
  4738 KSP Residual norm 2.460269462742e-08
  4739 KSP Residual norm 2.207018186510e-08
  4740 KSP Residual norm 2.148754937358e-08
  4741 KSP Residual norm 2.050485358404e-08
  4742 KSP Residual norm 1.928839203929e-08
  4743 KSP Residual norm 1.989566258135e-08
  4744 KSP Residual norm 2.108809820707e-08
  4745 KSP Residual norm 2.162060936077e-08
  4746 KSP Residual norm 2.232311434411e-08
  4747 KSP Residual norm 2.309502741508e-08
  4748 KSP Residual norm 2.112635800096e-08
  4749 KSP Residual norm 1.764144993327e-08
  4750 KSP Residual norm 1.532471990940e-08
  4751 KSP Residual norm 1.534883061703e-08
  4752 KSP Residual norm 1.599513424840e-08
  4753 KSP Residual norm 1.559579321581e-08
  4754 KSP Residual norm 1.574787193525e-08
  4755 KSP Residual norm 1.668916258815e-08
  4756 KSP Residual norm 1.796671453595e-08
  4757 KSP Residual norm 1.840866192564e-08
  4758 KSP Residual norm 2.015100092714e-08
  4759 KSP Residual norm 2.301540407020e-08
  4760 KSP Residual norm 2.352201881528e-08
  4761 KSP Residual norm 2.070088872898e-08
  4762 KSP Residual norm 1.731773729206e-08
  4763 KSP Residual norm 1.602966643744e-08
  4764 KSP Residual norm 1.760237112724e-08
  4765 KSP Residual norm 2.131750529686e-08
  4766 KSP Residual norm 2.338127354619e-08
  4767 KSP Residual norm 2.267563643419e-08
  4768 KSP Residual norm 2.254188134663e-08
  4769 KSP Residual norm 2.316912058871e-08
  4770 KSP Residual norm 2.432448810286e-08
  4771 KSP Residual norm 2.691688723784e-08
  4772 KSP Residual norm 2.785590105648e-08
  4773 KSP Residual norm 2.772649291794e-08
  4774 KSP Residual norm 2.819449867580e-08
  4775 KSP Residual norm 2.824434714443e-08
  4776 KSP Residual norm 2.725330979286e-08
  4777 KSP Residual norm 2.760973101336e-08
  4778 KSP Residual norm 2.932051620582e-08
  4779 KSP Residual norm 3.038384844789e-08
  4780 KSP Residual norm 3.106119825245e-08
  4781 KSP Residual norm 3.436911547667e-08
  4782 KSP Residual norm 4.163354799929e-08
  4783 KSP Residual norm 4.603713433040e-08
  4784 KSP Residual norm 4.385744029804e-08
  4785 KSP Residual norm 4.053361358956e-08
  4786 KSP Residual norm 3.830935118003e-08
  4787 KSP Residual norm 3.825713640832e-08
  4788 KSP Residual norm 4.170247798212e-08
  4789 KSP Residual norm 4.514832352264e-08
  4790 KSP Residual norm 4.878898452952e-08
  4791 KSP Residual norm 4.881405156868e-08
  4792 KSP Residual norm 4.571897115914e-08
  4793 KSP Residual norm 3.740695275880e-08
  4794 KSP Residual norm 3.079704581811e-08
  4795 KSP Residual norm 2.809809340303e-08
  4796 KSP Residual norm 2.664867630619e-08
  4797 KSP Residual norm 2.569906274283e-08
  4798 KSP Residual norm 2.662146814451e-08
  4799 KSP Residual norm 2.821224238559e-08
  4800 KSP Residual norm 2.822152704136e-08
  4801 KSP Residual norm 2.648204771183e-08
  4802 KSP Residual norm 2.384585931635e-08
  4803 KSP Residual norm 2.112715877328e-08
  4804 KSP Residual norm 1.799728466472e-08
  4805 KSP Residual norm 1.542783482960e-08
  4806 KSP Residual norm 1.412257959635e-08
  4807 KSP Residual norm 1.475737217341e-08
  4808 KSP Residual norm 1.623938258837e-08
  4809 KSP Residual norm 1.749772496376e-08
  4810 KSP Residual norm 1.587116654716e-08
  4811 KSP Residual norm 1.264255047880e-08
  4812 KSP Residual norm 1.111888509492e-08
  4813 KSP Residual norm 1.088656798194e-08
  4814 KSP Residual norm 1.127786351296e-08
  4815 KSP Residual norm 1.108678488969e-08
  4816 KSP Residual norm 1.126902691454e-08
  4817 KSP Residual norm 1.186497775834e-08
  4818 KSP Residual norm 1.165273399847e-08
  4819 KSP Residual norm 1.119576459189e-08
  4820 KSP Residual norm 1.080585178547e-08
  4821 KSP Residual norm 1.010908106424e-08
  4822 KSP Residual norm 9.431581605174e-09
  4823 KSP Residual norm 1.006278287225e-08
  4824 KSP Residual norm 1.237956844519e-08
  4825 KSP Residual norm 1.436552315991e-08
  4826 KSP Residual norm 1.506678705748e-08
  4827 KSP Residual norm 1.474441248226e-08
  4828 KSP Residual norm 1.389914058152e-08
  4829 KSP Residual norm 1.244227551803e-08
  4830 KSP Residual norm 1.198834436868e-08
  4831 KSP Residual norm 1.310484095010e-08
  4832 KSP Residual norm 1.527173244762e-08
  4833 KSP Residual norm 1.672019630074e-08
  4834 KSP Residual norm 1.721490378932e-08
  4835 KSP Residual norm 1.724478214237e-08
  4836 KSP Residual norm 1.664378514838e-08
  4837 KSP Residual norm 1.670554081302e-08
  4838 KSP Residual norm 1.810102366011e-08
  4839 KSP Residual norm 2.070992070853e-08
  4840 KSP Residual norm 2.084588091879e-08
  4841 KSP Residual norm 1.846518223639e-08
  4842 KSP Residual norm 1.713136892600e-08
  4843 KSP Residual norm 1.727183646496e-08
  4844 KSP Residual norm 1.888224741805e-08
  4845 KSP Residual norm 2.076084166089e-08
  4846 KSP Residual norm 2.033888331407e-08
  4847 KSP Residual norm 1.666131117618e-08
  4848 KSP Residual norm 1.222990602068e-08
  4849 KSP Residual norm 9.614745602963e-09
  4850 KSP Residual norm 8.820729636134e-09
  4851 KSP Residual norm 9.496024668948e-09
  4852 KSP Residual norm 1.162359565026e-08
  4853 KSP Residual norm 1.395337063903e-08
  4854 KSP Residual norm 1.543395023871e-08
  4855 KSP Residual norm 1.697234894704e-08
  4856 KSP Residual norm 1.725366921091e-08
  4857 KSP Residual norm 1.617333682707e-08
  4858 KSP Residual norm 1.518822598988e-08
  4859 KSP Residual norm 1.449004507645e-08
  4860 KSP Residual norm 1.350731303737e-08
  4861 KSP Residual norm 1.240736596951e-08
  4862 KSP Residual norm 1.164600229163e-08
  4863 KSP Residual norm 1.149188369592e-08
  4864 KSP Residual norm 1.169780622027e-08
  4865 KSP Residual norm 1.146089153872e-08
  4866 KSP Residual norm 1.013354909887e-08
  4867 KSP Residual norm 7.756779508254e-09
  4868 KSP Residual norm 5.831225775674e-09
  4869 KSP Residual norm 5.478398771190e-09
  4870 KSP Residual norm 6.306819480271e-09
  4871 KSP Residual norm 7.333932222604e-09
  4872 KSP Residual norm 7.530781463187e-09
  4873 KSP Residual norm 7.218217312269e-09
  4874 KSP Residual norm 7.232214889971e-09
  4875 KSP Residual norm 7.302802212965e-09
  4876 KSP Residual norm 7.467797385251e-09
  4877 KSP Residual norm 7.549343859485e-09
  4878 KSP Residual norm 8.330775108373e-09
  4879 KSP Residual norm 9.160302127397e-09
  4880 KSP Residual norm 8.673269588745e-09
  4881 KSP Residual norm 7.629482665876e-09
  4882 KSP Residual norm 7.098130117016e-09
  4883 KSP Residual norm 7.680077795249e-09
  4884 KSP Residual norm 9.172277269174e-09
  4885 KSP Residual norm 1.056279333447e-08
  4886 KSP Residual norm 1.074500060177e-08
  4887 KSP Residual norm 9.960746742120e-09
  4888 KSP Residual norm 9.160063525599e-09
  4889 KSP Residual norm 8.415152576178e-09
  4890 KSP Residual norm 8.635545672044e-09
  4891 KSP Residual norm 9.312435861864e-09
  4892 KSP Residual norm 9.452476078317e-09
  4893 KSP Residual norm 9.772888171879e-09
  4894 KSP Residual norm 1.005828268570e-08
  4895 KSP Residual norm 1.007567536896e-08
  4896 KSP Residual norm 1.119778769306e-08
  4897 KSP Residual norm 1.320941829797e-08
  4898 KSP Residual norm 1.478426659633e-08
  4899 KSP Residual norm 1.619326148499e-08
  4900 KSP Residual norm 1.799211278318e-08
  4901 KSP Residual norm 1.902189221524e-08
  4902 KSP Residual norm 1.874904472085e-08
  4903 KSP Residual norm 1.571428621817e-08
  4904 KSP Residual norm 1.188808632533e-08
  4905 KSP Residual norm 9.112861206695e-09
  4906 KSP Residual norm 8.785510693330e-09
  4907 KSP Residual norm 1.036652566963e-08
  4908 KSP Residual norm 1.255446155584e-08
  4909 KSP Residual norm 1.491630099282e-08
  4910 KSP Residual norm 1.662795794254e-08
  4911 KSP Residual norm 1.641913912090e-08
  4912 KSP Residual norm 1.562516408707e-08
  4913 KSP Residual norm 1.501428479427e-08
  4914 KSP Residual norm 1.414550995303e-08
  4915 KSP Residual norm 1.290009604761e-08
  4916 KSP Residual norm 1.181571432721e-08
  4917 KSP Residual norm 1.157977522630e-08
  4918 KSP Residual norm 1.229825493817e-08
  4919 KSP Residual norm 1.251758107647e-08
  4920 KSP Residual norm 1.234461417289e-08
  4921 KSP Residual norm 1.142014850600e-08
  4922 KSP Residual norm 9.108783525908e-09
  4923 KSP Residual norm 7.385518143750e-09
  4924 KSP Residual norm 6.547490547502e-09
  4925 KSP Residual norm 6.445733302151e-09
  4926 KSP Residual norm 6.627721399506e-09
  4927 KSP Residual norm 6.581702008430e-09
  4928 KSP Residual norm 6.509018520856e-09
  4929 KSP Residual norm 5.562468472910e-09
  4930 KSP Residual norm 4.450233620632e-09
  4931 KSP Residual norm 4.101065823594e-09
  4932 KSP Residual norm 4.374306984133e-09
  4933 KSP Residual norm 4.465617833336e-09
  4934 KSP Residual norm 4.441678007321e-09
  4935 KSP Residual norm 4.045912912909e-09
  4936 KSP Residual norm 3.429384674495e-09
  4937 KSP Residual norm 3.068817653667e-09
  4938 KSP Residual norm 3.349440267742e-09
  4939 KSP Residual norm 3.996418627159e-09
  4940 KSP Residual norm 4.122748167128e-09
  4941 KSP Residual norm 3.295359386461e-09
  4942 KSP Residual norm 2.336935399635e-09
  4943 KSP Residual norm 1.865460848373e-09
  4944 KSP Residual norm 1.922806803833e-09
  4945 KSP Residual norm 2.244178942190e-09
  4946 KSP Residual norm 2.970694619915e-09
  4947 KSP Residual norm 4.299148548092e-09
  4948 KSP Residual norm 5.544189723292e-09
  4949 KSP Residual norm 5.539528944675e-09
  4950 KSP Residual norm 4.359220456487e-09
  4951 KSP Residual norm 3.171481446028e-09
  4952 KSP Residual norm 2.662849987243e-09
  4953 KSP Residual norm 2.782015079983e-09
  4954 KSP Residual norm 3.579834962474e-09
  4955 KSP Residual norm 4.837564197020e-09
  4956 KSP Residual norm 6.244282226683e-09
  4957 KSP Residual norm 7.134808492107e-09
  4958 KSP Residual norm 6.422811926555e-09
  4959 KSP Residual norm 5.118162471442e-09
  4960 KSP Residual norm 4.158518978554e-09
  4961 KSP Residual norm 3.779679949800e-09
  4962 KSP Residual norm 4.447562656411e-09
  4963 KSP Residual norm 6.820518130582e-09
  4964 KSP Residual norm 1.069437440185e-08
  4965 KSP Residual norm 1.425772909790e-08
  4966 KSP Residual norm 1.432663852981e-08
  4967 KSP Residual norm 1.135071334905e-08
  4968 KSP Residual norm 8.778983926237e-09
  4969 KSP Residual norm 7.345709657090e-09
  4970 KSP Residual norm 7.113865108685e-09
  4971 KSP Residual norm 7.517489421788e-09
  4972 KSP Residual norm 8.664510260268e-09
  4973 KSP Residual norm 1.068738813208e-08
  4974 KSP Residual norm 1.252362696137e-08
  4975 KSP Residual norm 1.287126437938e-08
  4976 KSP Residual norm 1.284679980752e-08
  4977 KSP Residual norm 1.370578197082e-08
  4978 KSP Residual norm 1.388600373684e-08
  4979 KSP Residual norm 1.210338975543e-08
  4980 KSP Residual norm 1.033220366595e-08
  4981 KSP Residual norm 9.256646046466e-09
  4982 KSP Residual norm 8.905757623719e-09
  4983 KSP Residual norm 9.648228717873e-09
  4984 KSP Residual norm 1.210547337299e-08
  4985 KSP Residual norm 1.640704748554e-08
  4986 KSP Residual norm 2.200888106662e-08
  4987 KSP Residual norm 2.569572637259e-08
  4988 KSP Residual norm 2.254532657601e-08
  4989 KSP Residual norm 1.740613530582e-08
  4990 KSP Residual norm 1.420714497249e-08
  4991 KSP Residual norm 1.400989471760e-08
  4992 KSP Residual norm 1.680004856641e-08
  4993 KSP Residual norm 2.086413240602e-08
  4994 KSP Residual norm 2.142772065225e-08
  4995 KSP Residual norm 1.929507476186e-08
  4996 KSP Residual norm 1.659369997318e-08
  4997 KSP Residual norm 1.425490368105e-08
  4998 KSP Residual norm 1.250348406266e-08
  4999 KSP Residual norm 1.193612153398e-08
  5000 KSP Residual norm 1.320239130845e-08
  5001 KSP Residual norm 1.638955127381e-08
  5002 KSP Residual norm 1.780202221191e-08
  5003 KSP Residual norm 1.585831874195e-08
  5004 KSP Residual norm 1.442006670578e-08
  5005 KSP Residual norm 1.354185998209e-08
  5006 KSP Residual norm 1.212395397269e-08
  5007 KSP Residual norm 1.260279275678e-08
  5008 KSP Residual norm 1.444314908468e-08
  5009 KSP Residual norm 1.433630390323e-08
  5010 KSP Residual norm 1.269288155003e-08
  5011 KSP Residual norm 1.146076975620e-08
  5012 KSP Residual norm 1.153821724390e-08
  5013 KSP Residual norm 1.121764201639e-08
  5014 KSP Residual norm 1.020533909900e-08
  5015 KSP Residual norm 1.049787348836e-08
  5016 KSP Residual norm 1.169658487134e-08
  5017 KSP Residual norm 1.316416544087e-08
  5018 KSP Residual norm 1.498196462253e-08
  5019 KSP Residual norm 1.535375249176e-08
  5020 KSP Residual norm 1.304361963290e-08
  5021 KSP Residual norm 9.653745677574e-09
  5022 KSP Residual norm 7.093685751387e-09
  5023 KSP Residual norm 5.875275617781e-09
  5024 KSP Residual norm 6.409674139606e-09
  5025 KSP Residual norm 8.516755292871e-09
  5026 KSP Residual norm 1.162050991216e-08
  5027 KSP Residual norm 1.547700002461e-08
  5028 KSP Residual norm 1.817392110143e-08
  5029 KSP Residual norm 1.923658279728e-08
  5030 KSP Residual norm 2.015678144366e-08
  5031 KSP Residual norm 2.239867562395e-08
  5032 KSP Residual norm 2.454507004261e-08
  5033 KSP Residual norm 2.466830078705e-08
  5034 KSP Residual norm 2.178639571084e-08
  5035 KSP Residual norm 1.752884029559e-08
  5036 KSP Residual norm 1.533330306142e-08
  5037 KSP Residual norm 1.703412357091e-08
  5038 KSP Residual norm 2.301453457961e-08
  5039 KSP Residual norm 3.383896021517e-08
  5040 KSP Residual norm 4.667546126074e-08
  5041 KSP Residual norm 4.743776097208e-08
  5042 KSP Residual norm 3.546241798944e-08
  5043 KSP Residual norm 2.661668092378e-08
  5044 KSP Residual norm 2.118767242121e-08
  5045 KSP Residual norm 2.017452541057e-08
  5046 KSP Residual norm 2.342324448713e-08
  5047 KSP Residual norm 3.186306060983e-08
  5048 KSP Residual norm 4.187445881377e-08
  5049 KSP Residual norm 4.404834500196e-08
  5050 KSP Residual norm 4.176783494062e-08
  5051 KSP Residual norm 4.327807235002e-08
  5052 KSP Residual norm 4.858598085486e-08
  5053 KSP Residual norm 5.755879591062e-08
  5054 KSP Residual norm 7.096394351257e-08
  5055 KSP Residual norm 7.153896698332e-08
  5056 KSP Residual norm 5.609646088476e-08
  5057 KSP Residual norm 4.007361196747e-08
  5058 KSP Residual norm 3.457339719149e-08
  5059 KSP Residual norm 3.420588555973e-08
  5060 KSP Residual norm 3.480078544618e-08
  5061 KSP Residual norm 3.984430873579e-08
  5062 KSP Residual norm 4.947366140697e-08
  5063 KSP Residual norm 5.933850691645e-08
  5064 KSP Residual norm 6.210855675848e-08
  5065 KSP Residual norm 6.838948855737e-08
  5066 KSP Residual norm 7.609842526292e-08
  5067 KSP Residual norm 7.705854488968e-08
  5068 KSP Residual norm 7.170952972397e-08
  5069 KSP Residual norm 6.036586461790e-08
  5070 KSP Residual norm 4.941685584211e-08
  5071 KSP Residual norm 4.579667716942e-08
  5072 KSP Residual norm 4.055067292630e-08
  5073 KSP Residual norm 3.336312231012e-08
  5074 KSP Residual norm 2.853983111673e-08
  5075 KSP Residual norm 2.704321409172e-08
  5076 KSP Residual norm 2.976551883545e-08
  5077 KSP Residual norm 3.519684239241e-08
  5078 KSP Residual norm 3.915271197418e-08
  5079 KSP Residual norm 4.063834894950e-08
  5080 KSP Residual norm 4.414751903856e-08
  5081 KSP Residual norm 5.115189675552e-08
  5082 KSP Residual norm 5.427108370732e-08
  5083 KSP Residual norm 5.255259146103e-08
  5084 KSP Residual norm 4.376465109747e-08
  5085 KSP Residual norm 3.627093036893e-08
  5086 KSP Residual norm 3.382003233561e-08
  5087 KSP Residual norm 3.100238718570e-08
  5088 KSP Residual norm 2.629669775198e-08
  5089 KSP Residual norm 2.400303568831e-08
  5090 KSP Residual norm 2.564369317749e-08
  5091 KSP Residual norm 2.858395728973e-08
  5092 KSP Residual norm 3.155578786005e-08
  5093 KSP Residual norm 3.115029883236e-08
  5094 KSP Residual norm 3.033086292063e-08
  5095 KSP Residual norm 2.999524495595e-08
  5096 KSP Residual norm 3.025279202159e-08
  5097 KSP Residual norm 3.023543255782e-08
  5098 KSP Residual norm 3.390371597983e-08
  5099 KSP Residual norm 4.213649769957e-08
  5100 KSP Residual norm 4.540779784042e-08
  5101 KSP Residual norm 4.012749310366e-08
  5102 KSP Residual norm 3.591959654820e-08
  5103 KSP Residual norm 3.307825011770e-08
  5104 KSP Residual norm 3.155700662430e-08
  5105 KSP Residual norm 3.372406185415e-08
  5106 KSP Residual norm 3.561106395454e-08
  5107 KSP Residual norm 3.196186459722e-08
  5108 KSP Residual norm 2.864642745048e-08
  5109 KSP Residual norm 3.075433200834e-08
  5110 KSP Residual norm 4.016424786053e-08
  5111 KSP Residual norm 5.735981612076e-08
  5112 KSP Residual norm 6.717125853433e-08
  5113 KSP Residual norm 6.675377276531e-08
  5114 KSP Residual norm 6.073610630430e-08
  5115 KSP Residual norm 5.341936627133e-08
  5116 KSP Residual norm 4.798732402329e-08
  5117 KSP Residual norm 4.740413626195e-08
  5118 KSP Residual norm 4.539093095482e-08
  5119 KSP Residual norm 4.449704695558e-08
  5120 KSP Residual norm 5.051419707338e-08
  5121 KSP Residual norm 6.487170435771e-08
  5122 KSP Residual norm 7.315325194322e-08
  5123 KSP Residual norm 7.050392285597e-08
  5124 KSP Residual norm 6.707601866936e-08
  5125 KSP Residual norm 6.504106930922e-08
  5126 KSP Residual norm 6.306739374666e-08
  5127 KSP Residual norm 5.813557429572e-08
  5128 KSP Residual norm 5.083581670795e-08
  5129 KSP Residual norm 4.309732123363e-08
  5130 KSP Residual norm 3.574840227741e-08
  5131 KSP Residual norm 3.044394015008e-08
  5132 KSP Residual norm 2.964737229147e-08
  5133 KSP Residual norm 3.157239422021e-08
  5134 KSP Residual norm 3.079346758429e-08
  5135 KSP Residual norm 2.872432189207e-08
  5136 KSP Residual norm 3.087574312812e-08
  5137 KSP Residual norm 3.682593556440e-08
  5138 KSP Residual norm 3.860270961689e-08
  5139 KSP Residual norm 3.208487550889e-08
  5140 KSP Residual norm 2.460511229225e-08
  5141 KSP Residual norm 2.115980086332e-08
  5142 KSP Residual norm 1.981593056871e-08
  5143 KSP Residual norm 1.768767221868e-08
  5144 KSP Residual norm 1.654395947429e-08
  5145 KSP Residual norm 1.637543189844e-08
  5146 KSP Residual norm 1.704120847862e-08
  5147 KSP Residual norm 1.991254252302e-08
  5148 KSP Residual norm 2.482591233804e-08
  5149 KSP Residual norm 2.864935672461e-08
  5150 KSP Residual norm 2.947643296294e-08
  5151 KSP Residual norm 2.705657438407e-08
  5152 KSP Residual norm 2.311379229491e-08
  5153 KSP Residual norm 2.009147992668e-08
  5154 KSP Residual norm 2.002285361090e-08
  5155 KSP Residual norm 2.033663607418e-08
  5156 KSP Residual norm 2.000806508433e-08
  5157 KSP Residual norm 1.919298530495e-08
  5158 KSP Residual norm 1.893331231195e-08
  5159 KSP Residual norm 1.994697124102e-08
  5160 KSP Residual norm 2.025064752367e-08
  5161 KSP Residual norm 1.843423505000e-08
  5162 KSP Residual norm 1.727988771247e-08
  5163 KSP Residual norm 1.928816724901e-08
  5164 KSP Residual norm 2.368469769701e-08
  5165 KSP Residual norm 2.852820226565e-08
  5166 KSP Residual norm 3.112632993780e-08
  5167 KSP Residual norm 3.264026792152e-08
  5168 KSP Residual norm 3.594119730346e-08
  5169 KSP Residual norm 4.113909968316e-08
  5170 KSP Residual norm 4.550078146693e-08
  5171 KSP Residual norm 4.905041552807e-08
  5172 KSP Residual norm 4.972253374712e-08
  5173 KSP Residual norm 4.845320194246e-08
  5174 KSP Residual norm 5.094076024480e-08
  5175 KSP Residual norm 5.667027143174e-08
  5176 KSP Residual norm 5.344219432902e-08
  5177 KSP Residual norm 4.444556102080e-08
  5178 KSP Residual norm 3.815302257821e-08
  5179 KSP Residual norm 3.477771238035e-08
  5180 KSP Residual norm 3.442569468372e-08
  5181 KSP Residual norm 3.729520586277e-08
  5182 KSP Residual norm 3.657186954468e-08
  5183 KSP Residual norm 3.327317723019e-08
  5184 KSP Residual norm 3.473118929870e-08
  5185 KSP Residual norm 4.102404415132e-08
  5186 KSP Residual norm 5.033978926796e-08
  5187 KSP Residual norm 5.260137925124e-08
  5188 KSP Residual norm 4.588945144679e-08
  5189 KSP Residual norm 3.961682638206e-08
  5190 KSP Residual norm 3.649263373234e-08
  5191 KSP Residual norm 3.352431495708e-08
  5192 KSP Residual norm 3.090321109331e-08
  5193 KSP Residual norm 3.038593633632e-08
  5194 KSP Residual norm 2.862795616464e-08
  5195 KSP Residual norm 2.712694686206e-08
  5196 KSP Residual norm 2.898652871948e-08
  5197 KSP Residual norm 3.312172447600e-08
  5198 KSP Residual norm 3.561220746246e-08
  5199 KSP Residual norm 3.436974015334e-08
  5200 KSP Residual norm 3.340514669094e-08
  5201 KSP Residual norm 3.678849440370e-08
  5202 KSP Residual norm 3.973087062860e-08
  5203 KSP Residual norm 3.678225810301e-08
  5204 KSP Residual norm 2.668639935272e-08
  5205 KSP Residual norm 1.853486472886e-08
  5206 KSP Residual norm 1.580071114004e-08
  5207 KSP Residual norm 1.686418064116e-08
  5208 KSP Residual norm 1.758813551771e-08
  5209 KSP Residual norm 1.515614074033e-08
  5210 KSP Residual norm 1.288319130983e-08
  5211 KSP Residual norm 1.317391640092e-08
  5212 KSP Residual norm 1.563337324921e-08
  5213 KSP Residual norm 1.836910623640e-08
  5214 KSP Residual norm 2.056642292708e-08
  5215 KSP Residual norm 1.925031382118e-08
  5216 KSP Residual norm 1.720975912107e-08
  5217 KSP Residual norm 1.788815852889e-08
  5218 KSP Residual norm 2.101536466453e-08
  5219 KSP Residual norm 2.161086233809e-08
  5220 KSP Residual norm 1.812037079142e-08
  5221 KSP Residual norm 1.527979160653e-08
  5222 KSP Residual norm 1.342501862572e-08
  5223 KSP Residual norm 1.259688137080e-08
  5224 KSP Residual norm 1.179364640373e-08
  5225 KSP Residual norm 1.070759367784e-08
  5226 KSP Residual norm 9.457439578089e-09
  5227 KSP Residual norm 8.486357972886e-09
  5228 KSP Residual norm 8.290822990554e-09
  5229 KSP Residual norm 9.083640801084e-09
  5230 KSP Residual norm 1.000637351468e-08
  5231 KSP Residual norm 1.002361985055e-08
  5232 KSP Residual norm 1.003527027386e-08
  5233 KSP Residual norm 1.225113043607e-08
  5234 KSP Residual norm 1.601564768659e-08
  5235 KSP Residual norm 1.736761751154e-08
  5236 KSP Residual norm 1.486255993590e-08
  5237 KSP Residual norm 1.264623323407e-08
  5238 KSP Residual norm 1.268508034831e-08
  5239 KSP Residual norm 1.250520225390e-08
  5240 KSP Residual norm 1.011529613086e-08
  5241 KSP Residual norm 8.249633152909e-09
  5242 KSP Residual norm 7.640723367700e-09
  5243 KSP Residual norm 8.185096525785e-09
  5244 KSP Residual norm 9.609117617589e-09
  5245 KSP Residual norm 1.273140701005e-08
  5246 KSP Residual norm 1.475681235338e-08
  5247 KSP Residual norm 1.425556747858e-08
  5248 KSP Residual norm 1.483417063846e-08
  5249 KSP Residual norm 1.809520173185e-08
  5250 KSP Residual norm 2.116817791637e-08
  5251 KSP Residual norm 1.985627844838e-08
  5252 KSP Residual norm 1.641719245565e-08
  5253 KSP Residual norm 1.471310814147e-08
  5254 KSP Residual norm 1.547728334189e-08
  5255 KSP Residual norm 1.593319138311e-08
  5256 KSP Residual norm 1.385382624309e-08
  5257 KSP Residual norm 1.119404791589e-08
  5258 KSP Residual norm 9.799598156439e-09
  5259 KSP Residual norm 1.029597943692e-08
  5260 KSP Residual norm 1.170230403495e-08
  5261 KSP Residual norm 1.184246092942e-08
  5262 KSP Residual norm 1.118995834206e-08
  5263 KSP Residual norm 1.209723012229e-08
  5264 KSP Residual norm 1.572976451323e-08
  5265 KSP Residual norm 2.033251134475e-08
  5266 KSP Residual norm 2.239834017548e-08
  5267 KSP Residual norm 2.383826011678e-08
  5268 KSP Residual norm 2.611021208586e-08
  5269 KSP Residual norm 3.046799874404e-08
  5270 KSP Residual norm 3.238729515163e-08
  5271 KSP Residual norm 2.703351629213e-08
  5272 KSP Residual norm 2.049389663795e-08
  5273 KSP Residual norm 1.668812317949e-08
  5274 KSP Residual norm 1.616529540939e-08
  5275 KSP Residual norm 1.514579955202e-08
  5276 KSP Residual norm 1.146275410462e-08
  5277 KSP Residual norm 8.824697577751e-09
  5278 KSP Residual norm 8.524219536924e-09
  5279 KSP Residual norm 9.477256818725e-09
  5280 KSP Residual norm 9.891137539235e-09
  5281 KSP Residual norm 9.277695621351e-09
  5282 KSP Residual norm 8.402033626064e-09
  5283 KSP Residual norm 8.385781790609e-09
  5284 KSP Residual norm 9.354022238415e-09
  5285 KSP Residual norm 1.077324267005e-08
  5286 KSP Residual norm 1.236187170584e-08
  5287 KSP Residual norm 1.394642291994e-08
  5288 KSP Residual norm 1.506244159752e-08
  5289 KSP Residual norm 1.507379796867e-08
  5290 KSP Residual norm 1.446701595202e-08
  5291 KSP Residual norm 1.295485047363e-08
  5292 KSP Residual norm 1.063944757153e-08
  5293 KSP Residual norm 8.182100034095e-09
  5294 KSP Residual norm 6.384151057184e-09
  5295 KSP Residual norm 6.005578865285e-09
  5296 KSP Residual norm 5.956673258174e-09
  5297 KSP Residual norm 5.147616207091e-09
  5298 KSP Residual norm 4.249563992660e-09
  5299 KSP Residual norm 3.653482392368e-09
  5300 KSP Residual norm 3.414677724441e-09
  5301 KSP Residual norm 3.495775209757e-09
  5302 KSP Residual norm 3.247562101001e-09
  5303 KSP Residual norm 2.790333461525e-09
  5304 KSP Residual norm 2.820342360928e-09
  5305 KSP Residual norm 3.365912072226e-09
  5306 KSP Residual norm 3.590845478438e-09
  5307 KSP Residual norm 3.732368589552e-09
  5308 KSP Residual norm 4.359455283687e-09
  5309 KSP Residual norm 5.355016091407e-09
  5310 KSP Residual norm 5.797584109377e-09
  5311 KSP Residual norm 5.095928918586e-09
  5312 KSP Residual norm 4.347574145616e-09
  5313 KSP Residual norm 4.240336244211e-09
  5314 KSP Residual norm 4.382981690610e-09
  5315 KSP Residual norm 3.916259523109e-09
  5316 KSP Residual norm 3.111055161120e-09
  5317 KSP Residual norm 2.573428969216e-09
  5318 KSP Residual norm 2.427586837119e-09
  5319 KSP Residual norm 2.629512104524e-09
  5320 KSP Residual norm 2.984688708083e-09
  5321 KSP Residual norm 3.070314844570e-09
  5322 KSP Residual norm 2.964760243063e-09
  5323 KSP Residual norm 3.321250151048e-09
  5324 KSP Residual norm 3.781034799418e-09
  5325 KSP Residual norm 3.749972407214e-09
  5326 KSP Residual norm 3.682448544110e-09
  5327 KSP Residual norm 4.018279550388e-09
  5328 KSP Residual norm 4.752849609874e-09
  5329 KSP Residual norm 5.004416912220e-09
  5330 KSP Residual norm 4.390491830602e-09
  5331 KSP Residual norm 3.885204957264e-09
  5332 KSP Residual norm 4.213007921542e-09
  5333 KSP Residual norm 4.820467902833e-09
  5334 KSP Residual norm 4.418578653671e-09
  5335 KSP Residual norm 3.564515839121e-09
  5336 KSP Residual norm 3.330067381858e-09
  5337 KSP Residual norm 3.625641042392e-09
  5338 KSP Residual norm 4.232034616018e-09
  5339 KSP Residual norm 4.141857203394e-09
  5340 KSP Residual norm 3.553180048494e-09
  5341 KSP Residual norm 3.476263188203e-09
  5342 KSP Residual norm 4.307176369541e-09
  5343 KSP Residual norm 5.332259479532e-09
  5344 KSP Residual norm 5.654245885439e-09
  5345 KSP Residual norm 5.572287615420e-09
  5346 KSP Residual norm 5.631119773992e-09
  5347 KSP Residual norm 6.377943354568e-09
  5348 KSP Residual norm 7.078274948484e-09
  5349 KSP Residual norm 6.244546244897e-09
  5350 KSP Residual norm 5.337343886572e-09
  5351 KSP Residual norm 5.055306282829e-09
  5352 KSP Residual norm 5.429366643238e-09
  5353 KSP Residual norm 5.768309355254e-09
  5354 KSP Residual norm 5.645714697861e-09
  5355 KSP Residual norm 5.312766365789e-09
  5356 KSP Residual norm 5.166523623852e-09
  5357 KSP Residual norm 5.809262700725e-09
  5358 KSP Residual norm 7.389148226883e-09
  5359 KSP Residual norm 8.442307929158e-09
  5360 KSP Residual norm 7.777782279602e-09
  5361 KSP Residual norm 6.931507684953e-09
  5362 KSP Residual norm 6.878703689288e-09
  5363 KSP Residual norm 7.186930506665e-09
  5364 KSP Residual norm 7.031153323067e-09
  5365 KSP Residual norm 6.659537111718e-09
  5366 KSP Residual norm 6.552438945355e-09
  5367 KSP Residual norm 6.254848238852e-09
  5368 KSP Residual norm 5.744820335509e-09
  5369 KSP Residual norm 5.791288067911e-09
  5370 KSP Residual norm 5.418981306944e-09
  5371 KSP Residual norm 4.594824485963e-09
  5372 KSP Residual norm 4.488692006420e-09
  5373 KSP Residual norm 4.861162386596e-09
  5374 KSP Residual norm 4.493796104688e-09
  5375 KSP Residual norm 4.276800642426e-09
  5376 KSP Residual norm 4.739573310928e-09
  5377 KSP Residual norm 5.068638550061e-09
  5378 KSP Residual norm 5.090178993738e-09
  5379 KSP Residual norm 5.199563220339e-09
  5380 KSP Residual norm 5.357313869232e-09
  5381 KSP Residual norm 5.553626258659e-09
  5382 KSP Residual norm 5.620911772695e-09
  5383 KSP Residual norm 5.159766906255e-09
  5384 KSP Residual norm 5.244434465665e-09
  5385 KSP Residual norm 5.848557469261e-09
  5386 KSP Residual norm 5.783674046793e-09
  5387 KSP Residual norm 4.475875754395e-09
  5388 KSP Residual norm 3.505881141009e-09
  5389 KSP Residual norm 3.148345082934e-09
  5390 KSP Residual norm 3.140052767082e-09
  5391 KSP Residual norm 2.797662273665e-09
  5392 KSP Residual norm 2.053696273210e-09
  5393 KSP Residual norm 1.681068186430e-09
  5394 KSP Residual norm 1.749306879109e-09
  5395 KSP Residual norm 1.882328947971e-09
  5396 KSP Residual norm 1.961876638273e-09
  5397 KSP Residual norm 2.123724920126e-09
  5398 KSP Residual norm 2.176649392262e-09
  5399 KSP Residual norm 2.303329872114e-09
  5400 KSP Residual norm 2.632300269578e-09
  5401 KSP Residual norm 2.750900546691e-09
  5402 KSP Residual norm 2.675619384512e-09
  5403 KSP Residual norm 2.919486612801e-09
  5404 KSP Residual norm 3.236854291377e-09
  5405 KSP Residual norm 3.170728042157e-09
  5406 KSP Residual norm 3.064542262822e-09
  5407 KSP Residual norm 3.072213621733e-09
  5408 KSP Residual norm 3.115991040150e-09
  5409 KSP Residual norm 2.940906854004e-09
  5410 KSP Residual norm 2.574771579917e-09
  5411 KSP Residual norm 2.394058407618e-09
  5412 KSP Residual norm 2.391180866390e-09
  5413 KSP Residual norm 2.225869718608e-09
  5414 KSP Residual norm 2.251853479309e-09
  5415 KSP Residual norm 2.445822661166e-09
  5416 KSP Residual norm 2.454786393016e-09
  5417 KSP Residual norm 2.747961023447e-09
  5418 KSP Residual norm 3.340970416372e-09
  5419 KSP Residual norm 3.703536366534e-09
  5420 KSP Residual norm 3.914892117138e-09
  5421 KSP Residual norm 4.345161827262e-09
  5422 KSP Residual norm 4.767629749741e-09
  5423 KSP Residual norm 5.040497772574e-09
  5424 KSP Residual norm 5.164075057149e-09
  5425 KSP Residual norm 5.094240251972e-09
  5426 KSP Residual norm 5.065068593267e-09
  5427 KSP Residual norm 5.623765342033e-09
  5428 KSP Residual norm 6.162100631127e-09
  5429 KSP Residual norm 5.974722336476e-09
  5430 KSP Residual norm 5.238336565323e-09
  5431 KSP Residual norm 4.984266880309e-09
  5432 KSP Residual norm 5.585447213326e-09
  5433 KSP Residual norm 6.334038803696e-09
  5434 KSP Residual norm 6.295352014384e-09
  5435 KSP Residual norm 6.227006965680e-09
  5436 KSP Residual norm 6.803133217504e-09
  5437 KSP Residual norm 7.638998936898e-09
  5438 KSP Residual norm 8.128597580473e-09
  5439 KSP Residual norm 7.730125116558e-09
  5440 KSP Residual norm 7.068133806988e-09
  5441 KSP Residual norm 6.858017473477e-09
  5442 KSP Residual norm 7.321260914968e-09
  5443 KSP Residual norm 7.332733210398e-09
  5444 KSP Residual norm 7.435705496443e-09
  5445 KSP Residual norm 8.064828369762e-09
  5446 KSP Residual norm 9.565893185868e-09
  5447 KSP Residual norm 1.034541354452e-08
  5448 KSP Residual norm 9.590598462393e-09
  5449 KSP Residual norm 8.816340289060e-09
  5450 KSP Residual norm 8.499779469801e-09
  5451 KSP Residual norm 9.046570380422e-09
  5452 KSP Residual norm 9.332070476580e-09
  5453 KSP Residual norm 8.729119829103e-09
  5454 KSP Residual norm 8.507749371153e-09
  5455 KSP Residual norm 9.354382785873e-09
  5456 KSP Residual norm 1.028016254189e-08
  5457 KSP Residual norm 9.914715904167e-09
  5458 KSP Residual norm 8.928021546735e-09
  5459 KSP Residual norm 8.871165670153e-09
  5460 KSP Residual norm 9.767890287258e-09
  5461 KSP Residual norm 9.817284326424e-09
  5462 KSP Residual norm 9.826845373987e-09
  5463 KSP Residual norm 9.430969583427e-09
  5464 KSP Residual norm 9.358237584212e-09
  5465 KSP Residual norm 1.017435885681e-08
  5466 KSP Residual norm 1.135054152660e-08
  5467 KSP Residual norm 1.089315814087e-08
  5468 KSP Residual norm 1.018803065093e-08
  5469 KSP Residual norm 1.138971066069e-08
  5470 KSP Residual norm 1.420589522448e-08
  5471 KSP Residual norm 1.458939509948e-08
  5472 KSP Residual norm 1.268384318239e-08
  5473 KSP Residual norm 1.173988664556e-08
  5474 KSP Residual norm 1.069369187998e-08
  5475 KSP Residual norm 9.520827743729e-09
  5476 KSP Residual norm 8.969588344310e-09
  5477 KSP Residual norm 8.930775474906e-09
  5478 KSP Residual norm 9.155881630595e-09
  5479 KSP Residual norm 9.066232518798e-09
  5480 KSP Residual norm 8.493827474869e-09
  5481 KSP Residual norm 7.211839855203e-09
  5482 KSP Residual norm 6.285667475568e-09
  5483 KSP Residual norm 5.882077365447e-09
  5484 KSP Residual norm 6.053635525245e-09
  5485 KSP Residual norm 5.945522294873e-09
  5486 KSP Residual norm 5.162865259241e-09
  5487 KSP Residual norm 5.118586924583e-09
  5488 KSP Residual norm 5.757943731693e-09
  5489 KSP Residual norm 6.018462252815e-09
  5490 KSP Residual norm 5.880298433806e-09
  5491 KSP Residual norm 5.917464523076e-09
  5492 KSP Residual norm 6.255456280424e-09
  5493 KSP Residual norm 7.018813858356e-09
  5494 KSP Residual norm 7.417753399832e-09
  5495 KSP Residual norm 6.901719067828e-09
  5496 KSP Residual norm 6.687732525812e-09
  5497 KSP Residual norm 7.450161183973e-09
  5498 KSP Residual norm 7.697404740340e-09
  5499 KSP Residual norm 7.151949562440e-09
  5500 KSP Residual norm 6.445657990398e-09
  5501 KSP Residual norm 6.010183819955e-09
  5502 KSP Residual norm 5.966745878790e-09
  5503 KSP Residual norm 5.881482326544e-09
  5504 KSP Residual norm 4.988414938319e-09
  5505 KSP Residual norm 4.124520600936e-09
  5506 KSP Residual norm 3.877139412178e-09
  5507 KSP Residual norm 3.876536582491e-09
  5508 KSP Residual norm 3.673786049933e-09
  5509 KSP Residual norm 3.336387891478e-09
  5510 KSP Residual norm 3.300013871202e-09
  5511 KSP Residual norm 3.591894633496e-09
  5512 KSP Residual norm 3.771410752346e-09
  5513 KSP Residual norm 3.923724529071e-09
  5514 KSP Residual norm 4.586441670445e-09
  5515 KSP Residual norm 5.016024845974e-09
  5516 KSP Residual norm 4.759019832499e-09
  5517 KSP Residual norm 5.136684610872e-09
  5518 KSP Residual norm 6.235519587485e-09
  5519 KSP Residual norm 6.634081107457e-09
  5520 KSP Residual norm 6.035546927336e-09
  5521 KSP Residual norm 6.271087794583e-09
  5522 KSP Residual norm 6.750690160849e-09
  5523 KSP Residual norm 6.706695110247e-09
  5524 KSP Residual norm 6.638881241763e-09
  5525 KSP Residual norm 6.325113175857e-09
  5526 KSP Residual norm 5.803471722733e-09
  5527 KSP Residual norm 5.771190438348e-09
  5528 KSP Residual norm 6.031731534417e-09
  5529 KSP Residual norm 6.013012406909e-09
  5530 KSP Residual norm 5.938254413672e-09
  5531 KSP Residual norm 6.733790720242e-09
  5532 KSP Residual norm 8.543132902528e-09
  5533 KSP Residual norm 9.266225786333e-09
  5534 KSP Residual norm 8.932333621643e-09
  5535 KSP Residual norm 9.342424336230e-09
  5536 KSP Residual norm 1.147456780593e-08
  5537 KSP Residual norm 1.485847655002e-08
  5538 KSP Residual norm 1.610572716282e-08
  5539 KSP Residual norm 1.669657128903e-08
  5540 KSP Residual norm 1.812196496756e-08
  5541 KSP Residual norm 2.099155993717e-08
  5542 KSP Residual norm 2.127793447970e-08
  5543 KSP Residual norm 2.011781633319e-08
  5544 KSP Residual norm 2.109445773440e-08
  5545 KSP Residual norm 2.330411711226e-08
  5546 KSP Residual norm 2.316723688848e-08
  5547 KSP Residual norm 2.136839532724e-08
  5548 KSP Residual norm 2.214809050108e-08
  5549 KSP Residual norm 2.412774017544e-08
  5550 KSP Residual norm 2.420498911693e-08
  5551 KSP Residual norm 2.234022518322e-08
  5552 KSP Residual norm 2.083387186328e-08
  5553 KSP Residual norm 2.080096682943e-08
  5554 KSP Residual norm 2.191487112178e-08
  5555 KSP Residual norm 2.303801419813e-08
  5556 KSP Residual norm 2.334319331371e-08
  5557 KSP Residual norm 2.485210730561e-08
  5558 KSP Residual norm 2.787249285305e-08
  5559 KSP Residual norm 3.185299178363e-08
  5560 KSP Residual norm 3.680262634151e-08
  5561 KSP Residual norm 3.898718822296e-08
  5562 KSP Residual norm 4.261392263539e-08
  5563 KSP Residual norm 4.872254768579e-08
  5564 KSP Residual norm 5.548824945258e-08
  5565 KSP Residual norm 5.872324210471e-08
  5566 KSP Residual norm 5.735192575544e-08
  5567 KSP Residual norm 5.211156796489e-08
  5568 KSP Residual norm 4.617614764550e-08
  5569 KSP Residual norm 3.938250407406e-08
  5570 KSP Residual norm 3.660565445409e-08
  5571 KSP Residual norm 3.597379650148e-08
  5572 KSP Residual norm 3.212215598149e-08
  5573 KSP Residual norm 3.004110415491e-08
  5574 KSP Residual norm 3.135032074160e-08
  5575 KSP Residual norm 3.172140669796e-08
  5576 KSP Residual norm 2.787048812011e-08
  5577 KSP Residual norm 2.612036552597e-08
  5578 KSP Residual norm 2.693932852706e-08
  5579 KSP Residual norm 2.820402119464e-08
  5580 KSP Residual norm 3.012982430485e-08
  5581 KSP Residual norm 3.270713757602e-08
  5582 KSP Residual norm 3.337205701952e-08
  5583 KSP Residual norm 3.496508884533e-08
  5584 KSP Residual norm 3.965545192651e-08
  5585 KSP Residual norm 4.176209474025e-08
  5586 KSP Residual norm 3.909966171697e-08
  5587 KSP Residual norm 3.837815406682e-08
  5588 KSP Residual norm 4.039239877197e-08
  5589 KSP Residual norm 3.891136143854e-08
  5590 KSP Residual norm 3.916441691126e-08
  5591 KSP Residual norm 4.153766022088e-08
  5592 KSP Residual norm 3.887766035514e-08
  5593 KSP Residual norm 3.302755884711e-08
  5594 KSP Residual norm 2.971919198533e-08
  5595 KSP Residual norm 2.864628234602e-08
  5596 KSP Residual norm 2.580760054679e-08
  5597 KSP Residual norm 2.404929008707e-08
  5598 KSP Residual norm 2.449910513666e-08
  5599 KSP Residual norm 2.321436110552e-08
  5600 KSP Residual norm 1.987905826288e-08
  5601 KSP Residual norm 1.943720364151e-08
  5602 KSP Residual norm 2.153932517945e-08
  5603 KSP Residual norm 2.146034184697e-08
  5604 KSP Residual norm 2.230019136445e-08
  5605 KSP Residual norm 2.524621550237e-08
  5606 KSP Residual norm 2.760253767765e-08
  5607 KSP Residual norm 2.847138359806e-08
  5608 KSP Residual norm 2.772981667068e-08
  5609 KSP Residual norm 2.521245172404e-08
  5610 KSP Residual norm 2.449870354785e-08
  5611 KSP Residual norm 2.682469513611e-08
  5612 KSP Residual norm 2.740541459740e-08
  5613 KSP Residual norm 2.589999032089e-08
  5614 KSP Residual norm 2.455675590031e-08
  5615 KSP Residual norm 2.329041780451e-08
  5616 KSP Residual norm 2.178485700060e-08
  5617 KSP Residual norm 2.077064459006e-08
  5618 KSP Residual norm 1.890095094995e-08
  5619 KSP Residual norm 1.703535942804e-08
  5620 KSP Residual norm 1.586457606685e-08
  5621 KSP Residual norm 1.507412097753e-08
  5622 KSP Residual norm 1.491110964296e-08
  5623 KSP Residual norm 1.504736504896e-08
  5624 KSP Residual norm 1.597859811295e-08
  5625 KSP Residual norm 1.872310216689e-08
  5626 KSP Residual norm 2.079994615551e-08
  5627 KSP Residual norm 1.970333058801e-08
  5628 KSP Residual norm 2.002603063324e-08
  5629 KSP Residual norm 2.285600263010e-08
  5630 KSP Residual norm 2.443524888109e-08
  5631 KSP Residual norm 2.718995287373e-08
  5632 KSP Residual norm 3.539178131941e-08
  5633 KSP Residual norm 4.432201291216e-08
  5634 KSP Residual norm 4.724631822443e-08
  5635 KSP Residual norm 4.844726172059e-08
  5636 KSP Residual norm 4.673145779427e-08
  5637 KSP Residual norm 4.674193185386e-08
  5638 KSP Residual norm 5.070468290648e-08
  5639 KSP Residual norm 5.351441477534e-08
  5640 KSP Residual norm 5.461767586295e-08
  5641 KSP Residual norm 5.451887222688e-08
  5642 KSP Residual norm 5.367154533557e-08
  5643 KSP Residual norm 5.636261500611e-08
  5644 KSP Residual norm 5.350177586329e-08
  5645 KSP Residual norm 4.625835696476e-08
  5646 KSP Residual norm 4.705719284550e-08
  5647 KSP Residual norm 4.886282316022e-08
  5648 KSP Residual norm 3.964387836097e-08
  5649 KSP Residual norm 3.370975258849e-08
  5650 KSP Residual norm 3.686692373523e-08
  5651 KSP Residual norm 4.291161181734e-08
  5652 KSP Residual norm 4.629409149072e-08
  5653 KSP Residual norm 4.751049211227e-08
  5654 KSP Residual norm 4.860026514681e-08
  5655 KSP Residual norm 5.331791903609e-08
  5656 KSP Residual norm 5.601682714104e-08
  5657 KSP Residual norm 5.272722404958e-08
  5658 KSP Residual norm 5.586688679224e-08
  5659 KSP Residual norm 6.723938005517e-08
  5660 KSP Residual norm 7.571913222994e-08
  5661 KSP Residual norm 7.490541476786e-08
  5662 KSP Residual norm 7.878357837021e-08
  5663 KSP Residual norm 8.790864309981e-08
  5664 KSP Residual norm 9.113778822172e-08
  5665 KSP Residual norm 8.583150294521e-08
  5666 KSP Residual norm 8.136108855064e-08
  5667 KSP Residual norm 8.233120463721e-08
  5668 KSP Residual norm 7.528723510048e-08
  5669 KSP Residual norm 6.366563210064e-08
  5670 KSP Residual norm 5.874837470335e-08
  5671 KSP Residual norm 5.431597552163e-08
  5672 KSP Residual norm 4.819563201572e-08
  5673 KSP Residual norm 4.738315303963e-08
  5674 KSP Residual norm 5.257788273270e-08
  5675 KSP Residual norm 5.279990245751e-08
  5676 KSP Residual norm 5.294166794154e-08
  5677 KSP Residual norm 5.664252658313e-08
  5678 KSP Residual norm 5.206444921232e-08
  5679 KSP Residual norm 4.792304512614e-08
  5680 KSP Residual norm 5.144030289911e-08
  5681 KSP Residual norm 5.060775284561e-08
  5682 KSP Residual norm 5.207967182338e-08
  5683 KSP Residual norm 6.055225854499e-08
  5684 KSP Residual norm 7.282313410407e-08
  5685 KSP Residual norm 8.413071583340e-08
  5686 KSP Residual norm 9.152531765068e-08
  5687 KSP Residual norm 9.477879754250e-08
  5688 KSP Residual norm 1.006128875632e-07
  5689 KSP Residual norm 1.010898096238e-07
  5690 KSP Residual norm 9.365303720768e-08
  5691 KSP Residual norm 9.309286285570e-08
  5692 KSP Residual norm 9.225324700132e-08
  5693 KSP Residual norm 8.271514500700e-08
  5694 KSP Residual norm 7.358723186206e-08
  5695 KSP Residual norm 6.494167359046e-08
  5696 KSP Residual norm 5.536674074442e-08
  5697 KSP Residual norm 4.950522947500e-08
  5698 KSP Residual norm 4.717142548697e-08
  5699 KSP Residual norm 4.221458840930e-08
  5700 KSP Residual norm 3.922209227223e-08
  5701 KSP Residual norm 4.048303049937e-08
  5702 KSP Residual norm 4.397172333271e-08
  5703 KSP Residual norm 4.359317623468e-08
  5704 KSP Residual norm 4.001127863843e-08
  5705 KSP Residual norm 3.985597044914e-08
  5706 KSP Residual norm 4.233440454446e-08
  5707 KSP Residual norm 4.466504937352e-08
  5708 KSP Residual norm 4.429060125716e-08
  5709 KSP Residual norm 4.613716216899e-08
  5710 KSP Residual norm 5.274789454310e-08
  5711 KSP Residual norm 5.703353055084e-08
  5712 KSP Residual norm 5.593959328317e-08
  5713 KSP Residual norm 5.705466655647e-08
  5714 KSP Residual norm 5.677661321640e-08
  5715 KSP Residual norm 5.404922801283e-08
  5716 KSP Residual norm 5.715669770734e-08
  5717 KSP Residual norm 6.127921801424e-08
  5718 KSP Residual norm 5.967780081763e-08
  5719 KSP Residual norm 5.323899053565e-08
  5720 KSP Residual norm 4.944186688129e-08
  5721 KSP Residual norm 4.642797513728e-08
  5722 KSP Residual norm 3.893223276039e-08
  5723 KSP Residual norm 3.199174067739e-08
  5724 KSP Residual norm 3.077940599420e-08
  5725 KSP Residual norm 3.366839790567e-08
  5726 KSP Residual norm 3.300624784741e-08
  5727 KSP Residual norm 3.091647825379e-08
  5728 KSP Residual norm 2.874090550990e-08
  5729 KSP Residual norm 2.489068229393e-08
  5730 KSP Residual norm 2.306768069770e-08
  5731 KSP Residual norm 2.436294017451e-08
  5732 KSP Residual norm 2.442663750324e-08
  5733 KSP Residual norm 2.372003424017e-08
  5734 KSP Residual norm 2.479974935550e-08
  5735 KSP Residual norm 2.676521658349e-08
  5736 KSP Residual norm 2.960853741445e-08
  5737 KSP Residual norm 3.124437445236e-08
  5738 KSP Residual norm 3.357520749142e-08
  5739 KSP Residual norm 4.003483429786e-08
  5740 KSP Residual norm 4.455042195861e-08
  5741 KSP Residual norm 4.157398487451e-08
  5742 KSP Residual norm 4.147434696137e-08
  5743 KSP Residual norm 4.746776042974e-08
  5744 KSP Residual norm 5.456934984640e-08
  5745 KSP Residual norm 5.884014158974e-08
  5746 KSP Residual norm 5.890808501872e-08
  5747 KSP Residual norm 5.449078574259e-08
  5748 KSP Residual norm 5.292630562777e-08
  5749 KSP Residual norm 4.985709322932e-08
  5750 KSP Residual norm 4.706516672267e-08
  5751 KSP Residual norm 4.766439519705e-08
  5752 KSP Residual norm 4.950733577290e-08
  5753 KSP Residual norm 4.678637797217e-08
  5754 KSP Residual norm 4.131771022137e-08
  5755 KSP Residual norm 3.597295292120e-08
  5756 KSP Residual norm 3.388196462898e-08
  5757 KSP Residual norm 3.313494414729e-08
  5758 KSP Residual norm 3.175716517903e-08
  5759 KSP Residual norm 3.052031574310e-08
  5760 KSP Residual norm 3.240460600490e-08
  5761 KSP Residual norm 3.473274891880e-08
  5762 KSP Residual norm 3.483212600354e-08
  5763 KSP Residual norm 3.558956505627e-08
  5764 KSP Residual norm 3.664029639833e-08
  5765 KSP Residual norm 3.844038827804e-08
  5766 KSP Residual norm 4.084497040166e-08
  5767 KSP Residual norm 3.766836987527e-08
  5768 KSP Residual norm 3.519655715984e-08
  5769 KSP Residual norm 4.063534875725e-08
  5770 KSP Residual norm 4.765191108157e-08
  5771 KSP Residual norm 4.782936385760e-08
  5772 KSP Residual norm 5.403902181482e-08
  5773 KSP Residual norm 5.818643702623e-08
  5774 KSP Residual norm 5.189404460853e-08
  5775 KSP Residual norm 5.103054856265e-08
  5776 KSP Residual norm 5.685251888370e-08
  5777 KSP Residual norm 5.621661882561e-08
  5778 KSP Residual norm 5.352314277389e-08
  5779 KSP Residual norm 5.376211728174e-08
  5780 KSP Residual norm 5.201824803976e-08
  5781 KSP Residual norm 4.678503248873e-08
  5782 KSP Residual norm 4.301049624167e-08
  5783 KSP Residual norm 3.857998530108e-08
  5784 KSP Residual norm 3.535176833896e-08
  5785 KSP Residual norm 3.458155927086e-08
  5786 KSP Residual norm 3.736679283351e-08
  5787 KSP Residual norm 4.090445872541e-08
  5788 KSP Residual norm 3.623148829083e-08
  5789 KSP Residual norm 2.935989936062e-08
  5790 KSP Residual norm 2.688623669509e-08
  5791 KSP Residual norm 2.338872587409e-08
  5792 KSP Residual norm 1.852915587968e-08
  5793 KSP Residual norm 1.648662220424e-08
  5794 KSP Residual norm 1.587363219678e-08
  5795 KSP Residual norm 1.532915378613e-08
  5796 KSP Residual norm 1.590968009132e-08
  5797 KSP Residual norm 1.681559660711e-08
  5798 KSP Residual norm 1.721807196553e-08
  5799 KSP Residual norm 1.863188700922e-08
  5800 KSP Residual norm 1.772203214152e-08
  5801 KSP Residual norm 1.595284376132e-08
  5802 KSP Residual norm 1.616046401886e-08
  5803 KSP Residual norm 1.808146352440e-08
  5804 KSP Residual norm 1.892865974859e-08
  5805 KSP Residual norm 1.902783691273e-08
  5806 KSP Residual norm 1.989032648195e-08
  5807 KSP Residual norm 2.102123789926e-08
  5808 KSP Residual norm 2.209121866540e-08
  5809 KSP Residual norm 2.254982800485e-08
  5810 KSP Residual norm 2.313258474437e-08
  5811 KSP Residual norm 2.581612200369e-08
  5812 KSP Residual norm 2.752323982525e-08
  5813 KSP Residual norm 2.514485359277e-08
  5814 KSP Residual norm 2.269065321902e-08
  5815 KSP Residual norm 2.135998547325e-08
  5816 KSP Residual norm 2.032274378164e-08
  5817 KSP Residual norm 1.934221578882e-08
  5818 KSP Residual norm 1.762992179274e-08
  5819 KSP Residual norm 1.631201927052e-08
  5820 KSP Residual norm 1.693077226574e-08
  5821 KSP Residual norm 1.699921318427e-08
  5822 KSP Residual norm 1.561506317076e-08
  5823 KSP Residual norm 1.539487052324e-08
  5824 KSP Residual norm 1.585745488096e-08
  5825 KSP Residual norm 1.622218989555e-08
  5826 KSP Residual norm 1.622404518393e-08
  5827 KSP Residual norm 1.527388064429e-08
  5828 KSP Residual norm 1.566218623719e-08
  5829 KSP Residual norm 1.656628072173e-08
  5830 KSP Residual norm 1.481428143463e-08
  5831 KSP Residual norm 1.358038354312e-08
  5832 KSP Residual norm 1.552817860191e-08
  5833 KSP Residual norm 1.896489426435e-08
  5834 KSP Residual norm 2.015742360109e-08
  5835 KSP Residual norm 2.135412904179e-08
  5836 KSP Residual norm 2.282637598818e-08
  5837 KSP Residual norm 2.447075053033e-08
  5838 KSP Residual norm 2.689817398861e-08
  5839 KSP Residual norm 2.884005616034e-08
  5840 KSP Residual norm 2.771649184354e-08
  5841 KSP Residual norm 2.466670222750e-08
  5842 KSP Residual norm 2.404685156236e-08
  5843 KSP Residual norm 2.633227191781e-08
  5844 KSP Residual norm 2.927161580957e-08
  5845 KSP Residual norm 3.051817865047e-08
  5846 KSP Residual norm 2.879558382870e-08
  5847 KSP Residual norm 2.846484323974e-08
  5848 KSP Residual norm 2.923170724909e-08
  5849 KSP Residual norm 2.952234902823e-08
  5850 KSP Residual norm 3.186280421965e-08
  5851 KSP Residual norm 3.302613262426e-08
  5852 KSP Residual norm 3.005668813402e-08
  5853 KSP Residual norm 3.157945371410e-08
  5854 KSP Residual norm 3.588787867689e-08
  5855 KSP Residual norm 3.412946188602e-08
  5856 KSP Residual norm 3.320629247537e-08
  5857 KSP Residual norm 3.340366889490e-08
  5858 KSP Residual norm 3.254701539974e-08
  5859 KSP Residual norm 3.244789262914e-08
  5860 KSP Residual norm 3.281573442612e-08
  5861 KSP Residual norm 3.233363644266e-08
  5862 KSP Residual norm 3.246773987535e-08
  5863 KSP Residual norm 3.055371953699e-08
  5864 KSP Residual norm 3.095554409509e-08
  5865 KSP Residual norm 3.562656762785e-08
  5866 KSP Residual norm 3.736493667298e-08
  5867 KSP Residual norm 3.393707430832e-08
  5868 KSP Residual norm 3.265206858804e-08
  5869 KSP Residual norm 3.040950142648e-08
  5870 KSP Residual norm 2.721687435818e-08
  5871 KSP Residual norm 2.683378707112e-08
  5872 KSP Residual norm 2.591301638545e-08
  5873 KSP Residual norm 2.373674591767e-08
  5874 KSP Residual norm 2.457936036754e-08
  5875 KSP Residual norm 2.634295833012e-08
  5876 KSP Residual norm 2.440797022890e-08
  5877 KSP Residual norm 2.223377749378e-08
  5878 KSP Residual norm 2.176301126012e-08
  5879 KSP Residual norm 1.970397119345e-08
  5880 KSP Residual norm 1.646534441138e-08
  5881 KSP Residual norm 1.406467831075e-08
  5882 KSP Residual norm 1.348038313322e-08
  5883 KSP Residual norm 1.404483534354e-08
  5884 KSP Residual norm 1.336211384772e-08
  5885 KSP Residual norm 1.331992184729e-08
  5886 KSP Residual norm 1.483164024070e-08
  5887 KSP Residual norm 1.422194956739e-08
  5888 KSP Residual norm 1.275547236712e-08
  5889 KSP Residual norm 1.290332807865e-08
  5890 KSP Residual norm 1.313588677336e-08
  5891 KSP Residual norm 1.186726738001e-08
  5892 KSP Residual norm 1.243162997039e-08
  5893 KSP Residual norm 1.402012635567e-08
  5894 KSP Residual norm 1.354801656375e-08
  5895 KSP Residual norm 1.308003003559e-08
  5896 KSP Residual norm 1.363945758030e-08
  5897 KSP Residual norm 1.290186535514e-08
  5898 KSP Residual norm 1.269778164537e-08
  5899 KSP Residual norm 1.325926286643e-08
  5900 KSP Residual norm 1.242521809992e-08
  5901 KSP Residual norm 1.121272945360e-08
  5902 KSP Residual norm 1.070454435813e-08
  5903 KSP Residual norm 1.024797932572e-08
  5904 KSP Residual norm 1.066504486653e-08
  5905 KSP Residual norm 1.081858001868e-08
  5906 KSP Residual norm 9.525114275304e-09
  5907 KSP Residual norm 8.810036239512e-09
  5908 KSP Residual norm 9.150124403636e-09
  5909 KSP Residual norm 8.731791657391e-09
  5910 KSP Residual norm 7.484627383632e-09
  5911 KSP Residual norm 6.027600998446e-09
  5912 KSP Residual norm 5.096028604431e-09
  5913 KSP Residual norm 4.742381062650e-09
  5914 KSP Residual norm 4.272051792203e-09
  5915 KSP Residual norm 3.922544404131e-09
  5916 KSP Residual norm 3.930225759224e-09
  5917 KSP Residual norm 3.893886602269e-09
  5918 KSP Residual norm 3.621738687027e-09
  5919 KSP Residual norm 3.407281058935e-09
  5920 KSP Residual norm 3.162966929247e-09
  5921 KSP Residual norm 3.097278195669e-09
  5922 KSP Residual norm 3.619849018096e-09
  5923 KSP Residual norm 4.030402051644e-09
  5924 KSP Residual norm 3.995320428027e-09
  5925 KSP Residual norm 3.883388468016e-09
  5926 KSP Residual norm 4.057528791695e-09
  5927 KSP Residual norm 4.122437285510e-09
  5928 KSP Residual norm 3.863876557664e-09
  5929 KSP Residual norm 3.419983414710e-09
  5930 KSP Residual norm 3.102986403806e-09
  5931 KSP Residual norm 3.195460644492e-09
  5932 KSP Residual norm 3.191190083509e-09
  5933 KSP Residual norm 2.915337234532e-09
  5934 KSP Residual norm 2.913235443711e-09
  5935 KSP Residual norm 3.226921055124e-09
  5936 KSP Residual norm 3.433108078079e-09
  5937 KSP Residual norm 3.567664707585e-09
  5938 KSP Residual norm 3.804543966619e-09
  5939 KSP Residual norm 3.897592785736e-09
  5940 KSP Residual norm 3.870750766798e-09
  5941 KSP Residual norm 3.600308993079e-09
  5942 KSP Residual norm 3.263708488569e-09
  5943 KSP Residual norm 3.073175168529e-09
  5944 KSP Residual norm 3.079858883540e-09
  5945 KSP Residual norm 3.079345925879e-09
  5946 KSP Residual norm 2.966165680211e-09
  5947 KSP Residual norm 2.820676115316e-09
  5948 KSP Residual norm 2.882584058455e-09
  5949 KSP Residual norm 3.246209067552e-09
  5950 KSP Residual norm 3.252713611405e-09
  5951 KSP Residual norm 3.009534650270e-09
  5952 KSP Residual norm 3.249549322718e-09
  5953 KSP Residual norm 3.358625983803e-09
  5954 KSP Residual norm 2.876299251941e-09
  5955 KSP Residual norm 2.941656501352e-09
  5956 KSP Residual norm 3.553386669602e-09
  5957 KSP Residual norm 3.702412733751e-09
  5958 KSP Residual norm 3.973492574675e-09
  5959 KSP Residual norm 4.929498967592e-09
  5960 KSP Residual norm 5.340033359255e-09
  5961 KSP Residual norm 5.239596817279e-09
  5962 KSP Residual norm 5.496853746315e-09
  5963 KSP Residual norm 5.585256439527e-09
  5964 KSP Residual norm 5.863909137578e-09
  5965 KSP Residual norm 5.957077491569e-09
  5966 KSP Residual norm 5.808221728001e-09
  5967 KSP Residual norm 5.589532490413e-09
  5968 KSP Residual norm 5.365430363546e-09
  5969 KSP Residual norm 5.215546493725e-09
  5970 KSP Residual norm 5.449424138904e-09
  5971 KSP Residual norm 5.511971146379e-09
  5972 KSP Residual norm 5.629324543543e-09
  5973 KSP Residual norm 5.441398073214e-09
  5974 KSP Residual norm 4.589820056398e-09
  5975 KSP Residual norm 4.134381164950e-09
  5976 KSP Residual norm 4.567986217820e-09
  5977 KSP Residual norm 4.727973123536e-09
  5978 KSP Residual norm 4.093434231705e-09
  5979 KSP Residual norm 3.947130709671e-09
  5980 KSP Residual norm 3.934809736837e-09
  5981 KSP Residual norm 3.567769743207e-09
  5982 KSP Residual norm 3.280966031334e-09
  5983 KSP Residual norm 3.501025449181e-09
  5984 KSP Residual norm 3.872891020338e-09
  5985 KSP Residual norm 4.250255910451e-09
  5986 KSP Residual norm 4.503198492871e-09
  5987 KSP Residual norm 4.482947805069e-09
  5988 KSP Residual norm 4.708546364810e-09
  5989 KSP Residual norm 5.430493063650e-09
  5990 KSP Residual norm 5.992987414875e-09
  5991 KSP Residual norm 6.621315571136e-09
  5992 KSP Residual norm 6.630560068689e-09
  5993 KSP Residual norm 6.103285643087e-09
  5994 KSP Residual norm 6.277315703186e-09
  5995 KSP Residual norm 6.723508621494e-09
  5996 KSP Residual norm 6.891389417011e-09
  5997 KSP Residual norm 7.137279211919e-09
  5998 KSP Residual norm 7.025331043085e-09
  5999 KSP Residual norm 7.278619412332e-09
  6000 KSP Residual norm 8.273612466523e-09
  6001 KSP Residual norm 9.047608991952e-09
  6002 KSP Residual norm 8.724612062836e-09
  6003 KSP Residual norm 7.883151831466e-09
  6004 KSP Residual norm 6.587703651199e-09
  6005 KSP Residual norm 5.501947508073e-09
  6006 KSP Residual norm 4.902011993415e-09
  6007 KSP Residual norm 4.564150862236e-09
  6008 KSP Residual norm 4.187352652828e-09
  6009 KSP Residual norm 3.902993654184e-09
  6010 KSP Residual norm 3.624513508135e-09
  6011 KSP Residual norm 3.138732874830e-09
  6012 KSP Residual norm 3.091461240906e-09
  6013 KSP Residual norm 2.882865174095e-09
  6014 KSP Residual norm 2.484161291479e-09
  6015 KSP Residual norm 2.413570427382e-09
  6016 KSP Residual norm 2.584409879002e-09
  6017 KSP Residual norm 2.450639779402e-09
  6018 KSP Residual norm 2.133860362854e-09
  6019 KSP Residual norm 2.053977250023e-09
  6020 KSP Residual norm 2.183797318644e-09
  6021 KSP Residual norm 2.171589150396e-09
  6022 KSP Residual norm 2.106037596595e-09
  6023 KSP Residual norm 2.384740291365e-09
  6024 KSP Residual norm 2.614852486569e-09
  6025 KSP Residual norm 2.632666986823e-09
  6026 KSP Residual norm 2.956364287423e-09
  6027 KSP Residual norm 3.496051256385e-09
  6028 KSP Residual norm 3.597714022034e-09
  6029 KSP Residual norm 3.507751220193e-09
  6030 KSP Residual norm 3.564218580868e-09
  6031 KSP Residual norm 3.417849212233e-09
  6032 KSP Residual norm 3.087887395563e-09
  6033 KSP Residual norm 3.131057078944e-09
  6034 KSP Residual norm 3.059890349461e-09
  6035 KSP Residual norm 2.815913559532e-09
  6036 KSP Residual norm 2.994575498133e-09
  6037 KSP Residual norm 3.261564599599e-09
  6038 KSP Residual norm 2.939985402942e-09
  6039 KSP Residual norm 2.572772307967e-09
  6040 KSP Residual norm 2.711814309728e-09
  6041 KSP Residual norm 2.876141614649e-09
  6042 KSP Residual norm 2.471263959136e-09
  6043 KSP Residual norm 2.150843621287e-09
  6044 KSP Residual norm 2.110771765902e-09
  6045 KSP Residual norm 1.973128080382e-09
  6046 KSP Residual norm 1.658285852779e-09
  6047 KSP Residual norm 1.478257766395e-09
  6048 KSP Residual norm 1.398461360217e-09
  6049 KSP Residual norm 1.257721415319e-09
  6050 KSP Residual norm 1.230077630566e-09
  6051 KSP Residual norm 1.366780363788e-09
  6052 KSP Residual norm 1.447661639832e-09
  6053 KSP Residual norm 1.467433637614e-09
  6054 KSP Residual norm 1.637944811330e-09
  6055 KSP Residual norm 1.637073128045e-09
  6056 KSP Residual norm 1.407615863290e-09
  6057 KSP Residual norm 1.295967981216e-09
  6058 KSP Residual norm 1.260969021591e-09
  6059 KSP Residual norm 1.193544831026e-09
  6060 KSP Residual norm 1.226326144130e-09
  6061 KSP Residual norm 1.338988504040e-09
  6062 KSP Residual norm 1.379490010129e-09
  6063 KSP Residual norm 1.305348433261e-09
  6064 KSP Residual norm 1.309951248148e-09
  6065 KSP Residual norm 1.441952613325e-09
  6066 KSP Residual norm 1.441560574500e-09
  6067 KSP Residual norm 1.370522163808e-09
  6068 KSP Residual norm 1.396785645819e-09
  6069 KSP Residual norm 1.327540706724e-09
  6070 KSP Residual norm 1.134223716186e-09
  6071 KSP Residual norm 1.019994062090e-09
  6072 KSP Residual norm 9.906695103783e-10
  6073 KSP Residual norm 8.957107405108e-10
  6074 KSP Residual norm 7.712231518853e-10
  6075 KSP Residual norm 7.180590087166e-10
  6076 KSP Residual norm 6.971859092812e-10
  6077 KSP Residual norm 6.504845748402e-10
  6078 KSP Residual norm 5.899800056985e-10
  6079 KSP Residual norm 5.263537964676e-10
  6080 KSP Residual norm 4.807841418775e-10
  6081 KSP Residual norm 4.750325054956e-10
  6082 KSP Residual norm 4.815109172544e-10
  6083 KSP Residual norm 5.229360749998e-10
  6084 KSP Residual norm 5.835856606864e-10
  6085 KSP Residual norm 5.841966786634e-10
  6086 KSP Residual norm 5.293249621404e-10
  6087 KSP Residual norm 5.179276325707e-10
  6088 KSP Residual norm 5.305128432316e-10
  6089 KSP Residual norm 5.409634169791e-10
  6090 KSP Residual norm 5.667376798817e-10
  6091 KSP Residual norm 5.959675897582e-10
  6092 KSP Residual norm 6.084385027759e-10
  6093 KSP Residual norm 6.409566008094e-10
  6094 KSP Residual norm 7.523174799242e-10
  6095 KSP Residual norm 9.165508057686e-10
  6096 KSP Residual norm 9.777751237552e-10
  6097 KSP Residual norm 1.009857263645e-09
  6098 KSP Residual norm 1.069894625240e-09
  6099 KSP Residual norm 1.037523876715e-09
  6100 KSP Residual norm 9.540853027552e-10
  6101 KSP Residual norm 1.038199777235e-09
  6102 KSP Residual norm 1.216750394909e-09
  6103 KSP Residual norm 1.339664515904e-09
  6104 KSP Residual norm 1.429808019692e-09
  6105 KSP Residual norm 1.422475584757e-09
  6106 KSP Residual norm 1.253923307797e-09
  6107 KSP Residual norm 1.160346256599e-09
  6108 KSP Residual norm 1.095092435170e-09
  6109 KSP Residual norm 1.066123491652e-09
  6110 KSP Residual norm 1.115510906723e-09
  6111 KSP Residual norm 1.124500249174e-09
  6112 KSP Residual norm 1.044469580038e-09
  6113 KSP Residual norm 9.716163592221e-10
  6114 KSP Residual norm 9.711855081516e-10
  6115 KSP Residual norm 9.445999518440e-10
  6116 KSP Residual norm 8.414672368225e-10
  6117 KSP Residual norm 7.592855436613e-10
  6118 KSP Residual norm 7.414786602700e-10
  6119 KSP Residual norm 7.706050395643e-10
  6120 KSP Residual norm 8.210346337546e-10
  6121 KSP Residual norm 8.661127475929e-10
  6122 KSP Residual norm 9.226687285164e-10
  6123 KSP Residual norm 9.151718581911e-10
  6124 KSP Residual norm 8.768534120734e-10
  6125 KSP Residual norm 8.822340695894e-10
  6126 KSP Residual norm 8.801284595006e-10
  6127 KSP Residual norm 9.205037176446e-10
  6128 KSP Residual norm 1.055337995344e-09
  6129 KSP Residual norm 1.125154773548e-09
  6130 KSP Residual norm 1.204727637066e-09
  6131 KSP Residual norm 1.261058667951e-09
  6132 KSP Residual norm 1.258718773204e-09
  6133 KSP Residual norm 1.242934921786e-09
  6134 KSP Residual norm 1.228105695423e-09
  6135 KSP Residual norm 1.278359202185e-09
  6136 KSP Residual norm 1.530124185230e-09
  6137 KSP Residual norm 1.941785222394e-09
  6138 KSP Residual norm 1.876238513400e-09
  6139 KSP Residual norm 1.726009243890e-09
  6140 KSP Residual norm 1.769993266254e-09
  6141 KSP Residual norm 1.719812529162e-09
  6142 KSP Residual norm 1.627583776111e-09
  6143 KSP Residual norm 1.715138047280e-09
  6144 KSP Residual norm 1.965100580902e-09
  6145 KSP Residual norm 2.088278876042e-09
  6146 KSP Residual norm 1.843395302318e-09
  6147 KSP Residual norm 1.754835279707e-09
  6148 KSP Residual norm 1.972849453439e-09
  6149 KSP Residual norm 1.812016212797e-09
  6150 KSP Residual norm 1.426216567062e-09
  6151 KSP Residual norm 1.321175823639e-09
  6152 KSP Residual norm 1.290100567075e-09
  6153 KSP Residual norm 1.082748146368e-09
  6154 KSP Residual norm 9.382295146216e-10
  6155 KSP Residual norm 9.764082351994e-10
  6156 KSP Residual norm 9.813166722612e-10
  6157 KSP Residual norm 8.244297960418e-10
  6158 KSP Residual norm 7.213123403286e-10
  6159 KSP Residual norm 7.633548162143e-10
  6160 KSP Residual norm 7.912410887567e-10
  6161 KSP Residual norm 8.092046161619e-10
  6162 KSP Residual norm 8.326451759415e-10
  6163 KSP Residual norm 8.438375382619e-10
  6164 KSP Residual norm 7.937358189110e-10
  6165 KSP Residual norm 7.376332168813e-10
  6166 KSP Residual norm 7.090211326279e-10
  6167 KSP Residual norm 7.715572417440e-10
  6168 KSP Residual norm 9.518302090087e-10
  6169 KSP Residual norm 1.051850190965e-09
  6170 KSP Residual norm 9.706087322195e-10
  6171 KSP Residual norm 9.559483056377e-10
  6172 KSP Residual norm 9.661835004997e-10
  6173 KSP Residual norm 8.667718298097e-10
  6174 KSP Residual norm 7.522997690931e-10
  6175 KSP Residual norm 7.278019173816e-10
  6176 KSP Residual norm 7.442018403560e-10
  6177 KSP Residual norm 7.758293404192e-10
  6178 KSP Residual norm 8.182207343272e-10
  6179 KSP Residual norm 8.174150430618e-10
  6180 KSP Residual norm 7.764645499542e-10
  6181 KSP Residual norm 6.950102409887e-10
  6182 KSP Residual norm 6.072187708247e-10
  6183 KSP Residual norm 5.623545023331e-10
  6184 KSP Residual norm 5.417003970036e-10
  6185 KSP Residual norm 4.957863648050e-10
  6186 KSP Residual norm 4.478478143951e-10
  6187 KSP Residual norm 4.472729378064e-10
  6188 KSP Residual norm 4.765792993957e-10
  6189 KSP Residual norm 4.834719144242e-10
  6190 KSP Residual norm 4.612236257706e-10
  6191 KSP Residual norm 4.133564637427e-10
  6192 KSP Residual norm 3.587137041385e-10
  6193 KSP Residual norm 2.917236412788e-10
  6194 KSP Residual norm 2.416539047235e-10
  6195 KSP Residual norm 2.163406820456e-10
  6196 KSP Residual norm 1.954512762638e-10
  6197 KSP Residual norm 1.877918407682e-10
  6198 KSP Residual norm 2.015040226482e-10
  6199 KSP Residual norm 2.113513428306e-10
  6200 KSP Residual norm 2.074538885013e-10
  6201 KSP Residual norm 2.339587315253e-10
  6202 KSP Residual norm 2.833924069414e-10
  6203 KSP Residual norm 2.701714838635e-10
  6204 KSP Residual norm 2.424744975288e-10
  6205 KSP Residual norm 2.552869279444e-10
  6206 KSP Residual norm 2.591339699979e-10
  6207 KSP Residual norm 2.392501186390e-10
  6208 KSP Residual norm 2.556631771841e-10
  6209 KSP Residual norm 2.921850353967e-10
  6210 KSP Residual norm 2.957147992054e-10
  6211 KSP Residual norm 3.133807487314e-10
  6212 KSP Residual norm 3.485972684957e-10
  6213 KSP Residual norm 3.514264720022e-10
  6214 KSP Residual norm 3.385155163660e-10
  6215 KSP Residual norm 3.574849814861e-10
  6216 KSP Residual norm 3.666372327114e-10
  6217 KSP Residual norm 3.313401297541e-10
  6218 KSP Residual norm 2.797873300889e-10
  6219 KSP Residual norm 2.490550347177e-10
  6220 KSP Residual norm 2.352702180207e-10
  6221 KSP Residual norm 2.368705151026e-10
  6222 KSP Residual norm 2.337693119992e-10
  6223 KSP Residual norm 2.220315766721e-10
  6224 KSP Residual norm 2.167788164279e-10
  6225 KSP Residual norm 2.242644816550e-10
  6226 KSP Residual norm 2.333673637625e-10
  6227 KSP Residual norm 2.263421285836e-10
  6228 KSP Residual norm 2.231179081167e-10
  6229 KSP Residual norm 2.242337779947e-10
  6230 KSP Residual norm 2.095479106598e-10
  6231 KSP Residual norm 1.927843736266e-10
  6232 KSP Residual norm 1.815759693624e-10
  6233 KSP Residual norm 1.626895202263e-10
  6234 KSP Residual norm 1.464031914533e-10
  6235 KSP Residual norm 1.406479504847e-10
  6236 KSP Residual norm 1.395819670637e-10
  6237 KSP Residual norm 1.405615196478e-10
  6238 KSP Residual norm 1.341150979370e-10
  6239 KSP Residual norm 1.229534008486e-10
  6240 KSP Residual norm 1.288967960381e-10
  6241 KSP Residual norm 1.436823952829e-10
  6242 KSP Residual norm 1.472923262999e-10
  6243 KSP Residual norm 1.450117493266e-10
  6244 KSP Residual norm 1.533282471238e-10
  6245 KSP Residual norm 1.825775139465e-10
  6246 KSP Residual norm 1.982390168984e-10
  6247 KSP Residual norm 1.822360309035e-10
  6248 KSP Residual norm 1.800088380475e-10
  6249 KSP Residual norm 2.021788691006e-10
  6250 KSP Residual norm 2.025343478524e-10
  6251 KSP Residual norm 1.864497963624e-10
  6252 KSP Residual norm 1.972406251204e-10
  6253 KSP Residual norm 2.288374788676e-10
  6254 KSP Residual norm 2.383176107803e-10
  6255 KSP Residual norm 2.541587068068e-10
  6256 KSP Residual norm 2.881014865925e-10
  6257 KSP Residual norm 3.004626436238e-10
  6258 KSP Residual norm 2.872293184840e-10
  6259 KSP Residual norm 2.566834692510e-10
  6260 KSP Residual norm 2.515171395428e-10
  6261 KSP Residual norm 2.830604881970e-10
  6262 KSP Residual norm 3.265257112164e-10
  6263 KSP Residual norm 3.159910957903e-10
  6264 KSP Residual norm 2.815434709111e-10
  6265 KSP Residual norm 2.896256852540e-10
  6266 KSP Residual norm 3.238463093672e-10
  6267 KSP Residual norm 3.281224761298e-10
  6268 KSP Residual norm 3.204524010184e-10
  6269 KSP Residual norm 3.410557383108e-10
  6270 KSP Residual norm 3.387991625434e-10
  6271 KSP Residual norm 3.075856571655e-10
  6272 KSP Residual norm 3.109727572838e-10
  6273 KSP Residual norm 3.163654673418e-10
  6274 KSP Residual norm 2.939606574436e-10
  6275 KSP Residual norm 2.852225921766e-10
  6276 KSP Residual norm 3.002546471669e-10
  6277 KSP Residual norm 3.013884827165e-10
  6278 KSP Residual norm 2.962663826877e-10
  6279 KSP Residual norm 3.231058763996e-10
  6280 KSP Residual norm 3.905623438735e-10
  6281 KSP Residual norm 4.076379640084e-10
  6282 KSP Residual norm 3.824437491362e-10
  6283 KSP Residual norm 3.897912477407e-10
  6284 KSP Residual norm 4.190534361217e-10
  6285 KSP Residual norm 4.503505758587e-10
  6286 KSP Residual norm 4.582387244468e-10
  6287 KSP Residual norm 4.558214941901e-10
  6288 KSP Residual norm 4.269638379075e-10
  6289 KSP Residual norm 4.258194229445e-10
  6290 KSP Residual norm 4.703272439840e-10
  6291 KSP Residual norm 5.098082032675e-10
  6292 KSP Residual norm 5.420034119942e-10
  6293 KSP Residual norm 5.760054392162e-10
  6294 KSP Residual norm 6.004460526476e-10
  6295 KSP Residual norm 5.812367327462e-10
  6296 KSP Residual norm 5.353855736650e-10
  6297 KSP Residual norm 5.001832361543e-10
  6298 KSP Residual norm 4.926244826373e-10
  6299 KSP Residual norm 4.650297778421e-10
  6300 KSP Residual norm 4.196714896196e-10
  6301 KSP Residual norm 4.058818421963e-10
  6302 KSP Residual norm 4.700768397871e-10
  6303 KSP Residual norm 4.924110317896e-10
  6304 KSP Residual norm 4.367754519826e-10
  6305 KSP Residual norm 4.265500723651e-10
  6306 KSP Residual norm 4.504135988059e-10
  6307 KSP Residual norm 4.458240593066e-10
  6308 KSP Residual norm 4.121214543228e-10
  6309 KSP Residual norm 3.766105876827e-10
  6310 KSP Residual norm 3.360231890837e-10
  6311 KSP Residual norm 3.017396657983e-10
  6312 KSP Residual norm 2.677521406967e-10
  6313 KSP Residual norm 2.571865825211e-10
  6314 KSP Residual norm 2.753497901649e-10
  6315 KSP Residual norm 2.764189385642e-10
  6316 KSP Residual norm 2.727474523450e-10
  6317 KSP Residual norm 2.798470473773e-10
  6318 KSP Residual norm 2.753448696369e-10
  6319 KSP Residual norm 2.679323660446e-10
  6320 KSP Residual norm 2.568638675681e-10
  6321 KSP Residual norm 2.197014293816e-10
  6322 KSP Residual norm 1.870897251100e-10
  6323 KSP Residual norm 1.743848069825e-10
  6324 KSP Residual norm 1.605645745554e-10
  6325 KSP Residual norm 1.500907760447e-10
  6326 KSP Residual norm 1.610144506994e-10
  6327 KSP Residual norm 1.696409481464e-10
  6328 KSP Residual norm 1.713855008041e-10
  6329 KSP Residual norm 1.847604893698e-10
  6330 KSP Residual norm 2.093327978241e-10
  6331 KSP Residual norm 2.179070236922e-10
  6332 KSP Residual norm 2.326397394307e-10
  6333 KSP Residual norm 2.479170661909e-10
  6334 KSP Residual norm 2.491816104608e-10
  6335 KSP Residual norm 2.557530423970e-10
  6336 KSP Residual norm 2.741468772154e-10
  6337 KSP Residual norm 2.898483418870e-10
  6338 KSP Residual norm 3.119935472738e-10
  6339 KSP Residual norm 3.173405256087e-10
  6340 KSP Residual norm 3.213690836209e-10
  6341 KSP Residual norm 3.610569911896e-10
  6342 KSP Residual norm 4.043192657301e-10
  6343 KSP Residual norm 3.897945183911e-10
  6344 KSP Residual norm 3.346846964313e-10
  6345 KSP Residual norm 2.904601764277e-10
  6346 KSP Residual norm 2.754361070914e-10
  6347 KSP Residual norm 2.644967432290e-10
  6348 KSP Residual norm 2.769539945148e-10
  6349 KSP Residual norm 3.105556917380e-10
  6350 KSP Residual norm 3.492466651845e-10
  6351 KSP Residual norm 3.389084390668e-10
  6352 KSP Residual norm 2.819463434478e-10
  6353 KSP Residual norm 2.352155435793e-10
  6354 KSP Residual norm 2.268384863729e-10
  6355 KSP Residual norm 2.308718293963e-10
  6356 KSP Residual norm 2.248163438398e-10
  6357 KSP Residual norm 1.992544136665e-10
  6358 KSP Residual norm 1.800688171609e-10
  6359 KSP Residual norm 1.731410868788e-10
  6360 KSP Residual norm 1.789306126663e-10
  6361 KSP Residual norm 1.942057118674e-10
  6362 KSP Residual norm 2.192862230693e-10
  6363 KSP Residual norm 2.530867599793e-10
  6364 KSP Residual norm 2.437307071684e-10
  6365 KSP Residual norm 2.205587886984e-10
  6366 KSP Residual norm 2.253545114318e-10
  6367 KSP Residual norm 2.457097225294e-10
  6368 KSP Residual norm 2.544127890458e-10
  6369 KSP Residual norm 2.737492705560e-10
  6370 KSP Residual norm 3.020267286924e-10
  6371 KSP Residual norm 3.167802711409e-10
  6372 KSP Residual norm 3.375404950499e-10
  6373 KSP Residual norm 3.630486238884e-10
  6374 KSP Residual norm 3.933456431989e-10
  6375 KSP Residual norm 4.128652515807e-10
  6376 KSP Residual norm 4.293376724038e-10
  6377 KSP Residual norm 4.817508985821e-10
  6378 KSP Residual norm 5.725695123185e-10
  6379 KSP Residual norm 6.860755156960e-10
  6380 KSP Residual norm 7.282407335104e-10
  6381 KSP Residual norm 6.833735458715e-10
  6382 KSP Residual norm 6.465236275899e-10
  6383 KSP Residual norm 6.079309715847e-10
  6384 KSP Residual norm 5.785636361805e-10
  6385 KSP Residual norm 5.871232418348e-10
  6386 KSP Residual norm 6.577771095019e-10
  6387 KSP Residual norm 7.426685937826e-10
  6388 KSP Residual norm 7.560635566238e-10
  6389 KSP Residual norm 6.808766948295e-10
  6390 KSP Residual norm 5.949503264164e-10
  6391 KSP Residual norm 5.952566020695e-10
  6392 KSP Residual norm 6.550098523723e-10
  6393 KSP Residual norm 7.241410218210e-10
  6394 KSP Residual norm 7.605848364720e-10
  6395 KSP Residual norm 6.748618925520e-10
  6396 KSP Residual norm 5.470121166179e-10
  6397 KSP Residual norm 4.606790119738e-10
  6398 KSP Residual norm 4.261714417924e-10
  6399 KSP Residual norm 4.436587636036e-10
  6400 KSP Residual norm 4.865112969887e-10
  6401 KSP Residual norm 4.754744923398e-10
  6402 KSP Residual norm 4.484014400693e-10
  6403 KSP Residual norm 4.744128087425e-10
  6404 KSP Residual norm 5.017251084149e-10
  6405 KSP Residual norm 5.174642628707e-10
  6406 KSP Residual norm 5.724809815916e-10
  6407 KSP Residual norm 6.364677553129e-10
  6408 KSP Residual norm 6.031011443463e-10
  6409 KSP Residual norm 5.417202460204e-10
  6410 KSP Residual norm 5.185423380994e-10
  6411 KSP Residual norm 5.250114407695e-10
  6412 KSP Residual norm 5.085543409080e-10
  6413 KSP Residual norm 5.124222783833e-10
  6414 KSP Residual norm 5.561587802150e-10
  6415 KSP Residual norm 5.963740805950e-10
  6416 KSP Residual norm 5.984293547900e-10
  6417 KSP Residual norm 6.033476562135e-10
  6418 KSP Residual norm 6.207092012846e-10
  6419 KSP Residual norm 6.323024741097e-10
  6420 KSP Residual norm 6.634040693950e-10
  6421 KSP Residual norm 7.017154912422e-10
  6422 KSP Residual norm 7.582622234446e-10
  6423 KSP Residual norm 8.035602992376e-10
  6424 KSP Residual norm 7.661197422270e-10
  6425 KSP Residual norm 6.635986112766e-10
  6426 KSP Residual norm 5.917249049254e-10
  6427 KSP Residual norm 5.531288519334e-10
  6428 KSP Residual norm 5.210300074508e-10
  6429 KSP Residual norm 4.538101004060e-10
  6430 KSP Residual norm 4.045178496337e-10
  6431 KSP Residual norm 3.940498724669e-10
  6432 KSP Residual norm 4.190712043959e-10
  6433 KSP Residual norm 4.610078580380e-10
  6434 KSP Residual norm 4.267906039007e-10
  6435 KSP Residual norm 3.269681005470e-10
  6436 KSP Residual norm 2.378093553926e-10
  6437 KSP Residual norm 1.929933709121e-10
  6438 KSP Residual norm 1.802056765507e-10
  6439 KSP Residual norm 1.805860736803e-10
  6440 KSP Residual norm 2.106644412859e-10
  6441 KSP Residual norm 2.246812384673e-10
  6442 KSP Residual norm 2.066525965362e-10
  6443 KSP Residual norm 1.818157863826e-10
  6444 KSP Residual norm 1.693902783889e-10
  6445 KSP Residual norm 1.741820113712e-10
  6446 KSP Residual norm 1.974544753032e-10
  6447 KSP Residual norm 2.375389502317e-10
  6448 KSP Residual norm 2.701102959806e-10
  6449 KSP Residual norm 3.047877367579e-10
  6450 KSP Residual norm 3.400219192936e-10
  6451 KSP Residual norm 3.404307578002e-10
  6452 KSP Residual norm 3.098401256180e-10
  6453 KSP Residual norm 2.846752339198e-10
  6454 KSP Residual norm 2.808942295429e-10
  6455 KSP Residual norm 3.104913000576e-10
  6456 KSP Residual norm 3.819986498191e-10
  6457 KSP Residual norm 4.723432304684e-10
  6458 KSP Residual norm 4.703308369125e-10
  6459 KSP Residual norm 4.270761025285e-10
  6460 KSP Residual norm 4.069680509020e-10
  6461 KSP Residual norm 3.482848298651e-10
  6462 KSP Residual norm 2.865069561315e-10
  6463 KSP Residual norm 2.848719368076e-10
  6464 KSP Residual norm 3.524077365810e-10
  6465 KSP Residual norm 4.598183147179e-10
  6466 KSP Residual norm 5.275257838962e-10
  6467 KSP Residual norm 5.381402588865e-10
  6468 KSP Residual norm 4.984872583671e-10
  6469 KSP Residual norm 4.368739085752e-10
  6470 KSP Residual norm 3.826662557108e-10
  6471 KSP Residual norm 3.765752808542e-10
  6472 KSP Residual norm 4.322947679607e-10
  6473 KSP Residual norm 4.506772985047e-10
  6474 KSP Residual norm 4.048400192512e-10
  6475 KSP Residual norm 3.762901723937e-10
  6476 KSP Residual norm 3.456788956612e-10
  6477 KSP Residual norm 2.930329537930e-10
  6478 KSP Residual norm 2.436994619607e-10
  6479 KSP Residual norm 2.166929256296e-10
  6480 KSP Residual norm 2.176824847894e-10
  6481 KSP Residual norm 2.427612983031e-10
  6482 KSP Residual norm 2.679473891524e-10
  6483 KSP Residual norm 3.192524236235e-10
  6484 KSP Residual norm 4.116640471076e-10
  6485 KSP Residual norm 4.080103150140e-10
  6486 KSP Residual norm 3.259163284976e-10
  6487 KSP Residual norm 2.842153899509e-10
  6488 KSP Residual norm 2.684223911229e-10
  6489 KSP Residual norm 2.563126825894e-10
  6490 KSP Residual norm 2.796631747537e-10
  6491 KSP Residual norm 3.243065215993e-10
  6492 KSP Residual norm 3.423239895566e-10
  6493 KSP Residual norm 3.488103428522e-10
  6494 KSP Residual norm 3.300842459012e-10
  6495 KSP Residual norm 3.240713603148e-10
  6496 KSP Residual norm 3.748708932488e-10
  6497 KSP Residual norm 4.788164382671e-10
  6498 KSP Residual norm 5.155541168561e-10
  6499 KSP Residual norm 4.755282050327e-10
  6500 KSP Residual norm 5.218048468492e-10
  6501 KSP Residual norm 6.793519256831e-10
  6502 KSP Residual norm 8.911628837045e-10
  6503 KSP Residual norm 1.011608850952e-09
  6504 KSP Residual norm 1.148770359969e-09
  6505 KSP Residual norm 1.344025089794e-09
  6506 KSP Residual norm 1.347628794633e-09
  6507 KSP Residual norm 1.239708231500e-09
  6508 KSP Residual norm 1.248436740172e-09
  6509 KSP Residual norm 1.331682474511e-09
  6510 KSP Residual norm 1.358245191015e-09
  6511 KSP Residual norm 1.344751221803e-09
  6512 KSP Residual norm 1.403572711183e-09
  6513 KSP Residual norm 1.721428756151e-09
  6514 KSP Residual norm 2.187980636782e-09
  6515 KSP Residual norm 2.395889866743e-09
  6516 KSP Residual norm 2.463653105084e-09
  6517 KSP Residual norm 2.246805874406e-09
  6518 KSP Residual norm 1.787328587150e-09
  6519 KSP Residual norm 1.563696834264e-09
  6520 KSP Residual norm 1.540331921302e-09
  6521 KSP Residual norm 1.659943252996e-09
  6522 KSP Residual norm 1.986883296707e-09
  6523 KSP Residual norm 2.301551233574e-09
  6524 KSP Residual norm 2.466650120138e-09
  6525 KSP Residual norm 2.319452517618e-09
  6526 KSP Residual norm 1.978882880874e-09
  6527 KSP Residual norm 1.742468354651e-09
  6528 KSP Residual norm 1.667649375158e-09
  6529 KSP Residual norm 1.608776287804e-09
  6530 KSP Residual norm 1.529310273765e-09
  6531 KSP Residual norm 1.497394088890e-09
  6532 KSP Residual norm 1.460383037326e-09
  6533 KSP Residual norm 1.484218728896e-09
  6534 KSP Residual norm 1.729349228423e-09
  6535 KSP Residual norm 1.982675355019e-09
  6536 KSP Residual norm 2.217430661750e-09
  6537 KSP Residual norm 2.582590219215e-09
  6538 KSP Residual norm 2.760789025930e-09
  6539 KSP Residual norm 2.819155921149e-09
  6540 KSP Residual norm 2.888536056411e-09
  6541 KSP Residual norm 2.674400073539e-09
  6542 KSP Residual norm 2.245597852661e-09
  6543 KSP Residual norm 2.078170434854e-09
  6544 KSP Residual norm 2.246113567402e-09
  6545 KSP Residual norm 2.612021289349e-09
  6546 KSP Residual norm 2.950396741392e-09
  6547 KSP Residual norm 2.664985826732e-09
  6548 KSP Residual norm 2.239550312015e-09
  6549 KSP Residual norm 2.026909988328e-09
  6550 KSP Residual norm 2.095804760795e-09
  6551 KSP Residual norm 2.457049432314e-09
  6552 KSP Residual norm 3.023046243584e-09
  6553 KSP Residual norm 3.420728901160e-09
  6554 KSP Residual norm 3.471493227182e-09
  6555 KSP Residual norm 3.404146863324e-09
  6556 KSP Residual norm 3.663283063505e-09
  6557 KSP Residual norm 4.022843999757e-09
  6558 KSP Residual norm 4.489878029133e-09
  6559 KSP Residual norm 5.440554898449e-09
  6560 KSP Residual norm 6.421947738668e-09
  6561 KSP Residual norm 6.712229769471e-09
  6562 KSP Residual norm 6.026279422836e-09
  6563 KSP Residual norm 4.886298153641e-09
  6564 KSP Residual norm 4.283833716698e-09
  6565 KSP Residual norm 4.452749073000e-09
  6566 KSP Residual norm 5.235320926129e-09
  6567 KSP Residual norm 5.870606895264e-09
  6568 KSP Residual norm 5.775381140027e-09
  6569 KSP Residual norm 6.197174653752e-09
  6570 KSP Residual norm 7.586854436747e-09
  6571 KSP Residual norm 8.528588961390e-09
  6572 KSP Residual norm 7.803346516889e-09
  6573 KSP Residual norm 5.933312324180e-09
  6574 KSP Residual norm 4.687879640052e-09
  6575 KSP Residual norm 3.870526405457e-09
  6576 KSP Residual norm 3.577002097000e-09
  6577 KSP Residual norm 3.967550802274e-09
  6578 KSP Residual norm 5.258986777645e-09
  6579 KSP Residual norm 6.551061436806e-09
  6580 KSP Residual norm 6.489290034267e-09
  6581 KSP Residual norm 5.741771570274e-09
  6582 KSP Residual norm 5.210910244808e-09
  6583 KSP Residual norm 5.015094099240e-09
  6584 KSP Residual norm 4.879126564060e-09
  6585 KSP Residual norm 4.357245603815e-09
  6586 KSP Residual norm 3.890352742026e-09
  6587 KSP Residual norm 3.720350690431e-09
  6588 KSP Residual norm 3.759121508489e-09
  6589 KSP Residual norm 4.089814488284e-09
  6590 KSP Residual norm 4.719131430882e-09
  6591 KSP Residual norm 5.568008944066e-09
  6592 KSP Residual norm 6.016325988875e-09
  6593 KSP Residual norm 5.524965143199e-09
  6594 KSP Residual norm 4.439871059433e-09
  6595 KSP Residual norm 4.013916259937e-09
  6596 KSP Residual norm 4.677630166835e-09
  6597 KSP Residual norm 6.011989019577e-09
  6598 KSP Residual norm 7.214705523408e-09
  6599 KSP Residual norm 7.412015657686e-09
  6600 KSP Residual norm 6.388216344634e-09
  6601 KSP Residual norm 5.723631458667e-09
  6602 KSP Residual norm 6.154323047313e-09
  6603 KSP Residual norm 7.794179384334e-09
  6604 KSP Residual norm 9.661310722476e-09
  6605 KSP Residual norm 1.121424379946e-08
  6606 KSP Residual norm 1.263090933027e-08
  6607 KSP Residual norm 1.363323505911e-08
  6608 KSP Residual norm 1.329374835817e-08
  6609 KSP Residual norm 1.363039383226e-08
  6610 KSP Residual norm 1.550836290477e-08
  6611 KSP Residual norm 1.590008708803e-08
  6612 KSP Residual norm 1.406088284965e-08
  6613 KSP Residual norm 1.165087361072e-08
  6614 KSP Residual norm 9.490133798845e-09
  6615 KSP Residual norm 8.821126378019e-09
  6616 KSP Residual norm 1.031112761626e-08
  6617 KSP Residual norm 1.318102355182e-08
  6618 KSP Residual norm 1.529229794917e-08
  6619 KSP Residual norm 1.599600512280e-08
  6620 KSP Residual norm 1.491240467935e-08
  6621 KSP Residual norm 1.192266413880e-08
  6622 KSP Residual norm 8.008071445255e-09
  6623 KSP Residual norm 5.898046353192e-09
  6624 KSP Residual norm 5.908269513864e-09
  6625 KSP Residual norm 7.392622300744e-09
  6626 KSP Residual norm 8.810371693225e-09
  6627 KSP Residual norm 8.852780409790e-09
  6628 KSP Residual norm 7.997281031672e-09
  6629 KSP Residual norm 7.962591993603e-09
  6630 KSP Residual norm 8.166862966071e-09
  6631 KSP Residual norm 7.475744119734e-09
  6632 KSP Residual norm 6.325371323035e-09
  6633 KSP Residual norm 5.869571791637e-09
  6634 KSP Residual norm 5.894541001207e-09
  6635 KSP Residual norm 6.055317436212e-09
  6636 KSP Residual norm 5.872978597288e-09
  6637 KSP Residual norm 5.677816023874e-09
  6638 KSP Residual norm 5.817489706461e-09
  6639 KSP Residual norm 5.695247177206e-09
  6640 KSP Residual norm 5.420719950715e-09
  6641 KSP Residual norm 5.775522841277e-09
  6642 KSP Residual norm 6.098393330035e-09
  6643 KSP Residual norm 5.749471910001e-09
  6644 KSP Residual norm 5.572039166707e-09
  6645 KSP Residual norm 5.586576422614e-09
  6646 KSP Residual norm 5.383116078703e-09
  6647 KSP Residual norm 5.639545397361e-09
  6648 KSP Residual norm 6.405485701487e-09
  6649 KSP Residual norm 7.525270062973e-09
  6650 KSP Residual norm 8.633097278371e-09
  6651 KSP Residual norm 8.863150718294e-09
  6652 KSP Residual norm 8.786241132595e-09
  6653 KSP Residual norm 9.424063732970e-09
  6654 KSP Residual norm 1.031988169205e-08
  6655 KSP Residual norm 1.139350926011e-08
  6656 KSP Residual norm 1.107548120163e-08
  6657 KSP Residual norm 1.023262186123e-08
  6658 KSP Residual norm 8.035535933135e-09
  6659 KSP Residual norm 5.153943083056e-09
  6660 KSP Residual norm 3.658505070927e-09
  6661 KSP Residual norm 3.478002624998e-09
  6662 KSP Residual norm 4.174293068048e-09
  6663 KSP Residual norm 5.334399609419e-09
  6664 KSP Residual norm 6.246140186447e-09
  6665 KSP Residual norm 6.676319555720e-09
  6666 KSP Residual norm 6.173274193301e-09
  6667 KSP Residual norm 4.637985093362e-09
  6668 KSP Residual norm 3.445899915101e-09
  6669 KSP Residual norm 3.141031147395e-09
  6670 KSP Residual norm 3.215893959917e-09
  6671 KSP Residual norm 3.247086887875e-09
  6672 KSP Residual norm 3.310977415365e-09
  6673 KSP Residual norm 3.573486609286e-09
  6674 KSP Residual norm 3.543517717311e-09
  6675 KSP Residual norm 3.014918710543e-09
  6676 KSP Residual norm 2.675986670560e-09
  6677 KSP Residual norm 2.708267374484e-09
  6678 KSP Residual norm 2.721603014777e-09
  6679 KSP Residual norm 2.333768407990e-09
  6680 KSP Residual norm 1.967486402491e-09
  6681 KSP Residual norm 1.788432988997e-09
  6682 KSP Residual norm 1.564962301050e-09
  6683 KSP Residual norm 1.344424125767e-09
  6684 KSP Residual norm 1.274721422861e-09
  6685 KSP Residual norm 1.293580164012e-09
  6686 KSP Residual norm 1.301445421268e-09
  6687 KSP Residual norm 1.248763413528e-09
  6688 KSP Residual norm 1.136771382849e-09
  6689 KSP Residual norm 1.134174313993e-09
  6690 KSP Residual norm 1.216765378574e-09
  6691 KSP Residual norm 1.198021816840e-09
  6692 KSP Residual norm 1.149802852169e-09
  6693 KSP Residual norm 1.186782639767e-09
  6694 KSP Residual norm 1.262036138120e-09
  6695 KSP Residual norm 1.285048724637e-09
  6696 KSP Residual norm 1.244359926930e-09
  6697 KSP Residual norm 1.268122388447e-09
  6698 KSP Residual norm 1.372113478002e-09
  6699 KSP Residual norm 1.460316405898e-09
  6700 KSP Residual norm 1.234788207039e-09
  6701 KSP Residual norm 1.038442205529e-09
  6702 KSP Residual norm 1.002475198995e-09
  6703 KSP Residual norm 9.789996062005e-10
  6704 KSP Residual norm 9.215037938859e-10
  6705 KSP Residual norm 9.862946833538e-10
  6706 KSP Residual norm 1.144574469155e-09
  6707 KSP Residual norm 1.326158176502e-09
  6708 KSP Residual norm 1.441128283487e-09
  6709 KSP Residual norm 1.533219331278e-09
  6710 KSP Residual norm 1.582922208288e-09
  6711 KSP Residual norm 1.483806155660e-09
  6712 KSP Residual norm 1.191497453905e-09
  6713 KSP Residual norm 1.047720736319e-09
  6714 KSP Residual norm 1.195444643356e-09
  6715 KSP Residual norm 1.480457650189e-09
  6716 KSP Residual norm 1.702134045396e-09
  6717 KSP Residual norm 1.693515580718e-09
  6718 KSP Residual norm 1.542016185545e-09
  6719 KSP Residual norm 1.378430623969e-09
  6720 KSP Residual norm 1.317913165570e-09
  6721 KSP Residual norm 1.337466184841e-09
  6722 KSP Residual norm 1.376394550666e-09
  6723 KSP Residual norm 1.317866099262e-09
  6724 KSP Residual norm 1.142831902394e-09
  6725 KSP Residual norm 1.019698600541e-09
  6726 KSP Residual norm 9.918755423397e-10
  6727 KSP Residual norm 1.095064652796e-09
  6728 KSP Residual norm 1.332602240762e-09
  6729 KSP Residual norm 1.505875301879e-09
  6730 KSP Residual norm 1.452640591614e-09
  6731 KSP Residual norm 1.267036689643e-09
  6732 KSP Residual norm 1.087261957242e-09
  6733 KSP Residual norm 9.981030972776e-10
  6734 KSP Residual norm 1.028679034830e-09
  6735 KSP Residual norm 1.228377617254e-09
  6736 KSP Residual norm 1.414617476672e-09
  6737 KSP Residual norm 1.274653929966e-09
  6738 KSP Residual norm 1.050661995309e-09
  6739 KSP Residual norm 9.513557099561e-10
  6740 KSP Residual norm 9.244325202735e-10
  6741 KSP Residual norm 8.288580797736e-10
  6742 KSP Residual norm 7.653426261965e-10
  6743 KSP Residual norm 7.500709871445e-10
  6744 KSP Residual norm 7.358653429414e-10
  6745 KSP Residual norm 7.042308544787e-10
  6746 KSP Residual norm 6.596497821137e-10
  6747 KSP Residual norm 5.891169191577e-10
  6748 KSP Residual norm 5.822955107112e-10
  6749 KSP Residual norm 6.246413425060e-10
  6750 KSP Residual norm 6.776322951171e-10
  6751 KSP Residual norm 7.385765652418e-10
  6752 KSP Residual norm 7.360861072653e-10
  6753 KSP Residual norm 6.414107254985e-10
  6754 KSP Residual norm 5.568823697080e-10
  6755 KSP Residual norm 4.740313407343e-10
  6756 KSP Residual norm 4.290153051654e-10
  6757 KSP Residual norm 4.538698025575e-10
  6758 KSP Residual norm 5.637307594738e-10
  6759 KSP Residual norm 7.530379894012e-10
  6760 KSP Residual norm 9.364526954020e-10
  6761 KSP Residual norm 9.888115923025e-10
  6762 KSP Residual norm 9.537405238699e-10
  6763 KSP Residual norm 9.968182976428e-10
  6764 KSP Residual norm 1.153514251379e-09
  6765 KSP Residual norm 1.271403342949e-09
  6766 KSP Residual norm 1.255286336932e-09
  6767 KSP Residual norm 1.341286487208e-09
  6768 KSP Residual norm 1.438035111113e-09
  6769 KSP Residual norm 1.266780821131e-09
  6770 KSP Residual norm 1.098907765336e-09
  6771 KSP Residual norm 9.860073772260e-10
  6772 KSP Residual norm 8.665133644121e-10
  6773 KSP Residual norm 8.668256471420e-10
  6774 KSP Residual norm 1.131686076490e-09
  6775 KSP Residual norm 1.427204003729e-09
  6776 KSP Residual norm 1.649206224182e-09
  6777 KSP Residual norm 1.814665710604e-09
  6778 KSP Residual norm 1.865043104375e-09
  6779 KSP Residual norm 1.742526063924e-09
  6780 KSP Residual norm 1.568604672012e-09
  6781 KSP Residual norm 1.471765011932e-09
  6782 KSP Residual norm 1.404635264886e-09
  6783 KSP Residual norm 1.367507400347e-09
  6784 KSP Residual norm 1.373105569943e-09
  6785 KSP Residual norm 1.469737044005e-09
  6786 KSP Residual norm 1.742190642927e-09
  6787 KSP Residual norm 2.024394365648e-09
  6788 KSP Residual norm 2.024796258535e-09
  6789 KSP Residual norm 2.014655683968e-09
  6790 KSP Residual norm 2.216826935791e-09
  6791 KSP Residual norm 2.220490313002e-09
  6792 KSP Residual norm 2.035552624819e-09
  6793 KSP Residual norm 1.901886035064e-09
  6794 KSP Residual norm 1.893755837638e-09
  6795 KSP Residual norm 1.916784246615e-09
  6796 KSP Residual norm 1.833321348125e-09
  6797 KSP Residual norm 1.734325229142e-09
  6798 KSP Residual norm 1.573313906055e-09
  6799 KSP Residual norm 1.251395660282e-09
  6800 KSP Residual norm 1.055411691331e-09
  6801 KSP Residual norm 1.061411753261e-09
  6802 KSP Residual norm 1.244206706469e-09
  6803 KSP Residual norm 1.449857439154e-09
  6804 KSP Residual norm 1.381414576901e-09
  6805 KSP Residual norm 1.074279081792e-09
  6806 KSP Residual norm 9.061050596284e-10
  6807 KSP Residual norm 8.828639309019e-10
  6808 KSP Residual norm 9.727880036403e-10
  6809 KSP Residual norm 1.146208460024e-09
  6810 KSP Residual norm 1.319858093909e-09
  6811 KSP Residual norm 1.223914289464e-09
  6812 KSP Residual norm 1.072845061935e-09
  6813 KSP Residual norm 9.754616312528e-10
  6814 KSP Residual norm 9.274707988584e-10
  6815 KSP Residual norm 8.861121877844e-10
  6816 KSP Residual norm 8.012584031958e-10
  6817 KSP Residual norm 7.550432189709e-10
  6818 KSP Residual norm 7.786795571308e-10
  6819 KSP Residual norm 8.206471164611e-10
  6820 KSP Residual norm 9.006156956187e-10
  6821 KSP Residual norm 1.044718041364e-09
  6822 KSP Residual norm 1.201571654795e-09
  6823 KSP Residual norm 1.384866599876e-09
  6824 KSP Residual norm 1.647284149964e-09
  6825 KSP Residual norm 1.819546054565e-09
  6826 KSP Residual norm 1.828048596638e-09
  6827 KSP Residual norm 1.648231941434e-09
  6828 KSP Residual norm 1.436421728125e-09
  6829 KSP Residual norm 1.405790622190e-09
  6830 KSP Residual norm 1.411681089188e-09
  6831 KSP Residual norm 1.270934545971e-09
  6832 KSP Residual norm 1.144593812285e-09
  6833 KSP Residual norm 1.067610450662e-09
  6834 KSP Residual norm 1.036206178449e-09
  6835 KSP Residual norm 1.180901241746e-09
  6836 KSP Residual norm 1.585244886411e-09
  6837 KSP Residual norm 2.067452595606e-09
  6838 KSP Residual norm 2.084744214581e-09
  6839 KSP Residual norm 1.755935674982e-09
  6840 KSP Residual norm 1.551585259230e-09
  6841 KSP Residual norm 1.514546892698e-09
  6842 KSP Residual norm 1.466585120469e-09
  6843 KSP Residual norm 1.240108556191e-09
  6844 KSP Residual norm 1.008842909820e-09
  6845 KSP Residual norm 9.275476986437e-10
  6846 KSP Residual norm 8.762538169827e-10
  6847 KSP Residual norm 8.680177699708e-10
  6848 KSP Residual norm 9.357353085644e-10
  6849 KSP Residual norm 1.015815535650e-09
  6850 KSP Residual norm 1.112092024327e-09
  6851 KSP Residual norm 1.130782265429e-09
  6852 KSP Residual norm 1.139446593935e-09
  6853 KSP Residual norm 1.211330433256e-09
  6854 KSP Residual norm 1.316172780462e-09
  6855 KSP Residual norm 1.293546255501e-09
  6856 KSP Residual norm 1.105026293257e-09
  6857 KSP Residual norm 8.160889061259e-10
  6858 KSP Residual norm 6.118822203858e-10
  6859 KSP Residual norm 5.432504930712e-10
  6860 KSP Residual norm 5.833435234305e-10
  6861 KSP Residual norm 5.951182954519e-10
  6862 KSP Residual norm 5.286095427287e-10
  6863 KSP Residual norm 4.678595170274e-10
  6864 KSP Residual norm 4.472174990979e-10
  6865 KSP Residual norm 4.709901684399e-10
  6866 KSP Residual norm 5.133162018208e-10
  6867 KSP Residual norm 5.423524709494e-10
  6868 KSP Residual norm 4.985922606311e-10
  6869 KSP Residual norm 4.370730034082e-10
  6870 KSP Residual norm 4.205715761094e-10
  6871 KSP Residual norm 4.549735180315e-10
  6872 KSP Residual norm 5.032134491512e-10
  6873 KSP Residual norm 5.204014811682e-10
  6874 KSP Residual norm 4.952175197828e-10
  6875 KSP Residual norm 4.109939321273e-10
  6876 KSP Residual norm 3.626591508772e-10
  6877 KSP Residual norm 3.596369030522e-10
  6878 KSP Residual norm 3.834365778097e-10
  6879 KSP Residual norm 4.191993777908e-10
  6880 KSP Residual norm 4.016112495376e-10
  6881 KSP Residual norm 3.596569970850e-10
  6882 KSP Residual norm 3.965381195627e-10
  6883 KSP Residual norm 4.832771931900e-10
  6884 KSP Residual norm 4.822306260822e-10
  6885 KSP Residual norm 4.518518438917e-10
  6886 KSP Residual norm 4.356738692225e-10
  6887 KSP Residual norm 4.275945643416e-10
  6888 KSP Residual norm 4.111862107973e-10
  6889 KSP Residual norm 3.673217682131e-10
  6890 KSP Residual norm 2.898354700426e-10
  6891 KSP Residual norm 2.608445939070e-10
  6892 KSP Residual norm 2.842607279233e-10
  6893 KSP Residual norm 3.384152451048e-10
  6894 KSP Residual norm 3.983908610737e-10
  6895 KSP Residual norm 4.192706440053e-10
  6896 KSP Residual norm 3.978994275492e-10
  6897 KSP Residual norm 3.658088806617e-10
  6898 KSP Residual norm 3.404654186631e-10
  6899 KSP Residual norm 2.906383586793e-10
  6900 KSP Residual norm 2.127962673358e-10
  6901 KSP Residual norm 1.507976490382e-10
  6902 KSP Residual norm 1.307689191667e-10
  6903 KSP Residual norm 1.366691962961e-10
  6904 KSP Residual norm 1.430541169433e-10
  6905 KSP Residual norm 1.531926143403e-10
  6906 KSP Residual norm 1.728444998741e-10
  6907 KSP Residual norm 2.020999590256e-10
  6908 KSP Residual norm 2.422547845998e-10
  6909 KSP Residual norm 2.766628999584e-10
  6910 KSP Residual norm 2.808395389371e-10
  6911 KSP Residual norm 2.447779370443e-10
  6912 KSP Residual norm 1.955617619281e-10
  6913 KSP Residual norm 1.621781823430e-10
  6914 KSP Residual norm 1.442208719555e-10
  6915 KSP Residual norm 1.293529116327e-10
  6916 KSP Residual norm 1.195731480900e-10
  6917 KSP Residual norm 1.130933240904e-10
  6918 KSP Residual norm 1.086892142717e-10
  6919 KSP Residual norm 1.088579274117e-10
  6920 KSP Residual norm 1.226378516771e-10
  6921 KSP Residual norm 1.354537586031e-10
  6922 KSP Residual norm 1.280661835705e-10
  6923 KSP Residual norm 1.158157621603e-10
  6924 KSP Residual norm 1.128689057961e-10
  6925 KSP Residual norm 1.259026116125e-10
  6926 KSP Residual norm 1.550159500855e-10
  6927 KSP Residual norm 1.709124984108e-10
  6928 KSP Residual norm 1.571447513851e-10
  6929 KSP Residual norm 1.421729230743e-10
  6930 KSP Residual norm 1.341765612678e-10
  6931 KSP Residual norm 1.391495708193e-10
  6932 KSP Residual norm 1.402892865521e-10
  6933 KSP Residual norm 1.238103802749e-10
  6934 KSP Residual norm 1.120932800918e-10
  6935 KSP Residual norm 1.194694328787e-10
  6936 KSP Residual norm 1.423886809514e-10
  6937 KSP Residual norm 1.697464312651e-10
  6938 KSP Residual norm 1.896396103745e-10
  6939 KSP Residual norm 1.895676948134e-10
  6940 KSP Residual norm 1.978519167125e-10
  6941 KSP Residual norm 2.115802038159e-10
  6942 KSP Residual norm 1.950253681897e-10
  6943 KSP Residual norm 1.832636273447e-10
  6944 KSP Residual norm 1.765129899884e-10
  6945 KSP Residual norm 1.554251261762e-10
  6946 KSP Residual norm 1.387284529801e-10
  6947 KSP Residual norm 1.368928643872e-10
  6948 KSP Residual norm 1.480856532515e-10
  6949 KSP Residual norm 1.495203726019e-10
  6950 KSP Residual norm 1.345839527133e-10
  6951 KSP Residual norm 1.370265261708e-10
  6952 KSP Residual norm 1.673014984887e-10
  6953 KSP Residual norm 1.982000514097e-10
  6954 KSP Residual norm 1.949181362237e-10
  6955 KSP Residual norm 1.787721551309e-10
  6956 KSP Residual norm 1.684502043365e-10
  6957 KSP Residual norm 1.800829936919e-10
  6958 KSP Residual norm 2.068560740665e-10
  6959 KSP Residual norm 1.987218727410e-10
  6960 KSP Residual norm 1.683268519909e-10
  6961 KSP Residual norm 1.440837774904e-10
  6962 KSP Residual norm 1.245413082518e-10
  6963 KSP Residual norm 1.116122069027e-10
  6964 KSP Residual norm 9.490089834267e-11
  2 KSP Residual norm 7.462775074989e-02
    Residual norms for fieldsplit_FE_split_ solve.
    0 KSP Residual norm 1.370782211717e-10
    1 KSP Residual norm 1.024280861285e-10
    2 KSP Residual norm 8.809415769179e-11
    3 KSP Residual norm 8.952638270118e-11
    4 KSP Residual norm 9.170144644054e-11
    5 KSP Residual norm 1.015924671212e-10
    6 KSP Residual norm 1.090354326476e-10
    7 KSP Residual norm 1.083022647467e-10
    8 KSP Residual norm 1.115250420304e-10
    9 KSP Residual norm 1.146958386652e-10
   10 KSP Residual norm 1.213468824702e-10
   11 KSP Residual norm 1.248008835517e-10
   12 KSP Residual norm 1.279282928110e-10
   13 KSP Residual norm 1.262291076395e-10
   14 KSP Residual norm 1.267310794394e-10
   15 KSP Residual norm 1.345188093647e-10
   16 KSP Residual norm 1.326440469462e-10
   17 KSP Residual norm 1.205168724598e-10
   18 KSP Residual norm 1.109518468129e-10
   19 KSP Residual norm 1.082741073597e-10
   20 KSP Residual norm 1.022304856179e-10
   21 KSP Residual norm 9.268527960155e-11
   22 KSP Residual norm 8.675437032246e-11
   23 KSP Residual norm 8.607941649840e-11
   24 KSP Residual norm 8.495173915288e-11
   25 KSP Residual norm 8.731095959945e-11
   26 KSP Residual norm 9.320113828702e-11
   27 KSP Residual norm 9.595527572231e-11
   28 KSP Residual norm 9.844853409854e-11
   29 KSP Residual norm 1.058241380014e-10
   30 KSP Residual norm 1.144602170426e-10
   31 KSP Residual norm 1.144631886591e-10
   32 KSP Residual norm 1.173182816165e-10
   33 KSP Residual norm 1.210190311017e-10
   34 KSP Residual norm 1.233616135891e-10
   35 KSP Residual norm 1.276967245169e-10
   36 KSP Residual norm 1.333969492316e-10
   37 KSP Residual norm 1.336700407046e-10
   38 KSP Residual norm 1.352284098615e-10
   39 KSP Residual norm 1.345435070010e-10
   40 KSP Residual norm 1.375670433396e-10
   41 KSP Residual norm 1.408515514924e-10
   42 KSP Residual norm 1.415067527770e-10
   43 KSP Residual norm 1.427988684151e-10
   44 KSP Residual norm 1.467385600740e-10
   45 KSP Residual norm 1.477175980117e-10
   46 KSP Residual norm 1.439405824022e-10
   47 KSP Residual norm 1.340761526111e-10
   48 KSP Residual norm 1.284776859775e-10
   49 KSP Residual norm 1.272634642818e-10
   50 KSP Residual norm 1.251645854220e-10
   51 KSP Residual norm 1.191584847788e-10
   52 KSP Residual norm 1.180693543343e-10
   53 KSP Residual norm 1.257432345004e-10
   54 KSP Residual norm 1.276786548171e-10
   55 KSP Residual norm 1.225720485378e-10
   56 KSP Residual norm 1.203380069954e-10
   57 KSP Residual norm 1.253775090002e-10
   58 KSP Residual norm 1.337194055236e-10
   59 KSP Residual norm 1.364485139739e-10
   60 KSP Residual norm 1.346369955987e-10
   61 KSP Residual norm 1.332166723746e-10
   62 KSP Residual norm 1.351690212207e-10
   63 KSP Residual norm 1.336224791293e-10
   64 KSP Residual norm 1.316183334895e-10
   65 KSP Residual norm 1.283255871955e-10
   66 KSP Residual norm 1.280107983614e-10
   67 KSP Residual norm 1.334385052474e-10
   68 KSP Residual norm 1.455686495920e-10
   69 KSP Residual norm 1.474165854733e-10
   70 KSP Residual norm 1.443911531470e-10
   71 KSP Residual norm 1.383005315067e-10
   72 KSP Residual norm 1.424509589141e-10
   73 KSP Residual norm 1.452279436447e-10
   74 KSP Residual norm 1.459641824736e-10
   75 KSP Residual norm 1.486949358196e-10
   76 KSP Residual norm 1.482577552812e-10
   77 KSP Residual norm 1.504535383313e-10
   78 KSP Residual norm 1.520308256914e-10
   79 KSP Residual norm 1.462250230483e-10
   80 KSP Residual norm 1.436731628227e-10
   81 KSP Residual norm 1.456408506250e-10
   82 KSP Residual norm 1.508742863934e-10
   83 KSP Residual norm 1.570474392129e-10
   84 KSP Residual norm 1.631604167515e-10
   85 KSP Residual norm 1.729320268404e-10
   86 KSP Residual norm 1.924365245337e-10
   87 KSP Residual norm 2.142991567629e-10
   88 KSP Residual norm 2.173638870644e-10
   89 KSP Residual norm 2.117880718435e-10
   90 KSP Residual norm 2.119706929147e-10
   91 KSP Residual norm 2.178888716512e-10
   92 KSP Residual norm 2.176340444744e-10
   93 KSP Residual norm 2.151516071092e-10
   94 KSP Residual norm 2.226646903909e-10
   95 KSP Residual norm 2.262785167746e-10
   96 KSP Residual norm 2.082083899623e-10
   97 KSP Residual norm 1.940865129763e-10
   98 KSP Residual norm 1.951383538222e-10
   99 KSP Residual norm 2.001799867116e-10
  100 KSP Residual norm 1.826998745777e-10
  101 KSP Residual norm 1.676725859187e-10
  102 KSP Residual norm 1.679116252673e-10
  103 KSP Residual norm 1.760268633782e-10
  104 KSP Residual norm 1.858781812568e-10
  105 KSP Residual norm 1.921082065578e-10
  106 KSP Residual norm 1.899607332838e-10
  107 KSP Residual norm 1.940632120325e-10
  108 KSP Residual norm 2.067570865301e-10
  109 KSP Residual norm 2.106726895208e-10
  110 KSP Residual norm 2.108004838200e-10
  111 KSP Residual norm 2.238135531736e-10
  112 KSP Residual norm 2.385934188207e-10
  113 KSP Residual norm 2.476389895293e-10
  114 KSP Residual norm 2.402959718718e-10
  115 KSP Residual norm 2.249316114863e-10
  116 KSP Residual norm 2.229416679389e-10
  117 KSP Residual norm 2.307625999260e-10
  118 KSP Residual norm 2.384735963982e-10
  119 KSP Residual norm 2.287964517971e-10
  120 KSP Residual norm 2.159229930791e-10
  121 KSP Residual norm 2.111487417633e-10
  122 KSP Residual norm 2.078675839142e-10
  123 KSP Residual norm 2.081804952191e-10
  124 KSP Residual norm 2.028084967396e-10
  125 KSP Residual norm 2.004710268426e-10
  126 KSP Residual norm 1.806870305234e-10
  127 KSP Residual norm 1.606079541305e-10
  128 KSP Residual norm 1.553349685359e-10
  129 KSP Residual norm 1.599583703164e-10
  130 KSP Residual norm 1.584549501655e-10
  131 KSP Residual norm 1.600493477242e-10
  132 KSP Residual norm 1.700704620458e-10
  133 KSP Residual norm 1.817942036827e-10
  134 KSP Residual norm 1.843583325260e-10
  135 KSP Residual norm 1.851963123539e-10
  136 KSP Residual norm 1.941311489195e-10
  137 KSP Residual norm 2.030720296350e-10
  138 KSP Residual norm 2.138447562322e-10
  139 KSP Residual norm 2.164137175361e-10
  140 KSP Residual norm 1.969482555612e-10
  141 KSP Residual norm 1.849858350896e-10
  142 KSP Residual norm 1.863610726808e-10
  143 KSP Residual norm 1.925275912987e-10
  144 KSP Residual norm 1.905834593884e-10
  145 KSP Residual norm 1.966932617883e-10
  146 KSP Residual norm 2.118177213161e-10
  147 KSP Residual norm 2.149176862885e-10
  148 KSP Residual norm 2.140618436693e-10
  149 KSP Residual norm 2.152519872613e-10
  150 KSP Residual norm 2.169156497856e-10
  151 KSP Residual norm 2.211943265641e-10
  152 KSP Residual norm 2.192940993071e-10
  153 KSP Residual norm 2.112328373672e-10
  154 KSP Residual norm 1.994325011035e-10
  155 KSP Residual norm 1.961692410338e-10
  156 KSP Residual norm 2.000446677332e-10
  157 KSP Residual norm 2.017753121297e-10
  158 KSP Residual norm 1.957197200429e-10
  159 KSP Residual norm 1.910823383668e-10
  160 KSP Residual norm 1.948932434983e-10
  161 KSP Residual norm 2.057613665037e-10
  162 KSP Residual norm 2.211722042956e-10
  163 KSP Residual norm 2.448774920590e-10
  164 KSP Residual norm 2.537300022253e-10
  165 KSP Residual norm 2.357318306264e-10
  166 KSP Residual norm 2.187091172586e-10
  167 KSP Residual norm 2.040543037176e-10
  168 KSP Residual norm 1.958575670866e-10
  169 KSP Residual norm 1.945551941975e-10
  170 KSP Residual norm 1.874393057691e-10
  171 KSP Residual norm 1.858032197341e-10
  172 KSP Residual norm 1.779295598240e-10
  173 KSP Residual norm 1.737546245916e-10
  174 KSP Residual norm 1.716663169552e-10
  175 KSP Residual norm 1.640698049013e-10
  176 KSP Residual norm 1.585278673977e-10
  177 KSP Residual norm 1.625705522370e-10
  178 KSP Residual norm 1.690410274065e-10
  179 KSP Residual norm 1.609857630911e-10
  180 KSP Residual norm 1.479484183037e-10
  181 KSP Residual norm 1.438765276419e-10
  182 KSP Residual norm 1.437253696174e-10
  183 KSP Residual norm 1.457652916028e-10
  184 KSP Residual norm 1.425451663809e-10
  185 KSP Residual norm 1.376476620658e-10
  186 KSP Residual norm 1.359029127913e-10
  187 KSP Residual norm 1.412367520538e-10
  188 KSP Residual norm 1.401843940100e-10
  189 KSP Residual norm 1.299507649264e-10
  190 KSP Residual norm 1.169634788028e-10
  191 KSP Residual norm 1.124330620856e-10
  192 KSP Residual norm 1.087739844612e-10
  193 KSP Residual norm 1.037784090813e-10
  194 KSP Residual norm 1.042404915809e-10
  195 KSP Residual norm 1.055532969214e-10
  196 KSP Residual norm 1.050814465517e-10
  197 KSP Residual norm 1.100835975196e-10
  198 KSP Residual norm 1.129168914742e-10
  199 KSP Residual norm 1.096001299019e-10
  200 KSP Residual norm 1.081552615807e-10
  201 KSP Residual norm 1.076201326032e-10
  202 KSP Residual norm 1.050595189629e-10
  203 KSP Residual norm 1.086588493934e-10
  204 KSP Residual norm 1.151470281834e-10
  205 KSP Residual norm 1.203408196405e-10
  206 KSP Residual norm 1.195789705997e-10
  207 KSP Residual norm 1.160890720372e-10
  208 KSP Residual norm 1.098967509948e-10
  209 KSP Residual norm 1.056007883989e-10
  210 KSP Residual norm 1.016288998892e-10
  211 KSP Residual norm 9.981817443041e-11
  212 KSP Residual norm 1.008770198492e-10
  213 KSP Residual norm 9.953099838669e-11
  214 KSP Residual norm 9.278286869131e-11
  215 KSP Residual norm 8.543344037330e-11
  216 KSP Residual norm 8.118759851636e-11
  217 KSP Residual norm 7.644850441865e-11
  218 KSP Residual norm 7.119653570590e-11
  219 KSP Residual norm 6.578798584845e-11
  220 KSP Residual norm 6.033004018435e-11
  221 KSP Residual norm 5.857612826322e-11
  222 KSP Residual norm 5.885803996835e-11
  223 KSP Residual norm 5.788031563802e-11
  224 KSP Residual norm 5.747781483825e-11
  225 KSP Residual norm 5.800282261246e-11
  226 KSP Residual norm 5.729498615643e-11
  227 KSP Residual norm 5.703521897442e-11
  228 KSP Residual norm 5.911364796619e-11
  229 KSP Residual norm 6.218105257491e-11
  230 KSP Residual norm 6.329160094182e-11
  231 KSP Residual norm 6.502990381022e-11
  232 KSP Residual norm 6.617662151158e-11
  233 KSP Residual norm 6.553709494720e-11
  234 KSP Residual norm 6.549108194265e-11
  235 KSP Residual norm 6.736959956683e-11
  236 KSP Residual norm 6.778885000950e-11
  237 KSP Residual norm 6.905434914429e-11
  238 KSP Residual norm 6.941177257737e-11
  239 KSP Residual norm 6.634362951098e-11
  240 KSP Residual norm 6.347627937793e-11
  241 KSP Residual norm 6.373662289251e-11
  242 KSP Residual norm 6.637973752670e-11
  243 KSP Residual norm 7.020154873095e-11
  244 KSP Residual norm 7.473837464684e-11
  245 KSP Residual norm 7.652677504169e-11
  246 KSP Residual norm 7.480994700470e-11
  247 KSP Residual norm 7.200983676419e-11
  248 KSP Residual norm 7.122097552731e-11
  249 KSP Residual norm 7.318450188452e-11
  250 KSP Residual norm 7.372651584289e-11
  251 KSP Residual norm 7.174963896698e-11
  252 KSP Residual norm 7.402034403170e-11
  253 KSP Residual norm 7.601799018494e-11
  254 KSP Residual norm 7.932790069849e-11
  255 KSP Residual norm 8.036559369947e-11
  256 KSP Residual norm 8.097733044114e-11
  257 KSP Residual norm 8.131596928036e-11
  258 KSP Residual norm 8.487134141151e-11
  259 KSP Residual norm 8.432673414151e-11
  260 KSP Residual norm 8.641315410572e-11
  261 KSP Residual norm 8.570600189544e-11
  262 KSP Residual norm 8.493207923149e-11
  263 KSP Residual norm 8.417758395909e-11
  264 KSP Residual norm 8.313217157673e-11
  265 KSP Residual norm 8.249680541616e-11
  266 KSP Residual norm 8.589071431350e-11
  267 KSP Residual norm 9.324633631003e-11
  268 KSP Residual norm 9.545117079377e-11
  269 KSP Residual norm 9.008839903066e-11
  270 KSP Residual norm 8.772845860571e-11
  271 KSP Residual norm 9.218107181305e-11
  272 KSP Residual norm 9.469442869812e-11
  273 KSP Residual norm 9.212151286481e-11
  274 KSP Residual norm 9.080889926646e-11
  275 KSP Residual norm 9.097792158798e-11
  276 KSP Residual norm 8.982856804657e-11
  277 KSP Residual norm 9.149086072101e-11
  278 KSP Residual norm 9.533832662962e-11
  279 KSP Residual norm 9.709037522266e-11
  280 KSP Residual norm 9.676839933355e-11
  281 KSP Residual norm 9.593114967158e-11
  282 KSP Residual norm 9.173370213274e-11
  283 KSP Residual norm 8.707470315126e-11
  284 KSP Residual norm 7.967812173087e-11
  285 KSP Residual norm 7.460987057520e-11
  286 KSP Residual norm 7.493734274119e-11
  287 KSP Residual norm 7.861297003712e-11
  288 KSP Residual norm 7.886006319948e-11
  289 KSP Residual norm 7.408027493244e-11
  290 KSP Residual norm 6.989202492740e-11
  291 KSP Residual norm 6.962453590656e-11
  292 KSP Residual norm 7.203315711140e-11
  293 KSP Residual norm 7.147553922817e-11
  294 KSP Residual norm 6.930069805271e-11
  295 KSP Residual norm 7.219069689586e-11
  296 KSP Residual norm 7.904494219056e-11
  297 KSP Residual norm 8.633758917157e-11
  298 KSP Residual norm 8.826926192710e-11
  299 KSP Residual norm 9.359061079782e-11
  300 KSP Residual norm 9.676640495858e-11
  301 KSP Residual norm 1.003895179952e-10
  302 KSP Residual norm 1.052961749340e-10
  303 KSP Residual norm 1.098566792687e-10
  304 KSP Residual norm 1.131066655583e-10
  305 KSP Residual norm 1.126462901128e-10
  306 KSP Residual norm 1.164446202685e-10
  307 KSP Residual norm 1.237600055850e-10
  308 KSP Residual norm 1.262984007612e-10
  309 KSP Residual norm 1.209429193689e-10
  310 KSP Residual norm 1.129162806094e-10
  311 KSP Residual norm 1.081215251179e-10
  312 KSP Residual norm 1.037112129996e-10
  313 KSP Residual norm 1.038507511790e-10
  314 KSP Residual norm 1.022585920240e-10
  315 KSP Residual norm 1.037232002363e-10
  316 KSP Residual norm 1.096019913574e-10
  317 KSP Residual norm 1.117697584112e-10
  318 KSP Residual norm 1.085742049833e-10
  319 KSP Residual norm 1.116772789910e-10
  320 KSP Residual norm 1.215335745413e-10
  321 KSP Residual norm 1.299977491068e-10
  322 KSP Residual norm 1.320200399599e-10
  323 KSP Residual norm 1.306204431776e-10
  324 KSP Residual norm 1.341199555983e-10
  325 KSP Residual norm 1.430196569389e-10
  326 KSP Residual norm 1.420217962038e-10
  327 KSP Residual norm 1.374596204533e-10
  328 KSP Residual norm 1.360981260376e-10
  329 KSP Residual norm 1.319010006072e-10
  330 KSP Residual norm 1.257548801076e-10
  331 KSP Residual norm 1.232125432291e-10
  332 KSP Residual norm 1.193480732321e-10
  333 KSP Residual norm 1.169280735538e-10
  334 KSP Residual norm 1.179654396871e-10
  335 KSP Residual norm 1.223991621312e-10
  336 KSP Residual norm 1.301578037909e-10
  337 KSP Residual norm 1.367343341005e-10
  338 KSP Residual norm 1.506216893972e-10
  339 KSP Residual norm 1.636350956967e-10
  340 KSP Residual norm 1.676831597766e-10
  341 KSP Residual norm 1.596905837717e-10
  342 KSP Residual norm 1.491096052729e-10
  343 KSP Residual norm 1.426876571613e-10
  344 KSP Residual norm 1.464460307966e-10
  345 KSP Residual norm 1.519683452860e-10
  346 KSP Residual norm 1.494018942247e-10
  347 KSP Residual norm 1.462197335329e-10
  348 KSP Residual norm 1.440145077903e-10
  349 KSP Residual norm 1.411252862876e-10
  350 KSP Residual norm 1.378855642234e-10
  351 KSP Residual norm 1.394836623807e-10
  352 KSP Residual norm 1.406921589879e-10
  353 KSP Residual norm 1.308634002462e-10
  354 KSP Residual norm 1.249431696280e-10
  355 KSP Residual norm 1.312750480769e-10
  356 KSP Residual norm 1.315878162037e-10
  357 KSP Residual norm 1.269463171173e-10
  358 KSP Residual norm 1.254232516280e-10
  359 KSP Residual norm 1.289871622715e-10
  360 KSP Residual norm 1.338467961730e-10
  361 KSP Residual norm 1.352002233898e-10
  362 KSP Residual norm 1.309099062832e-10
  363 KSP Residual norm 1.292177460147e-10
  364 KSP Residual norm 1.333204976252e-10
  365 KSP Residual norm 1.376872353931e-10
  366 KSP Residual norm 1.411472303274e-10
  367 KSP Residual norm 1.401570531848e-10
  368 KSP Residual norm 1.360468635118e-10
  369 KSP Residual norm 1.375380424409e-10
  370 KSP Residual norm 1.401212969986e-10
  371 KSP Residual norm 1.326408541078e-10
  372 KSP Residual norm 1.214519658595e-10
  373 KSP Residual norm 1.150583955129e-10
  374 KSP Residual norm 1.115844470655e-10
  375 KSP Residual norm 1.062305503542e-10
  376 KSP Residual norm 9.797964208442e-11
  377 KSP Residual norm 9.608790823163e-11
  378 KSP Residual norm 9.746546776563e-11
  379 KSP Residual norm 9.842063732815e-11
  380 KSP Residual norm 9.677981058817e-11
  381 KSP Residual norm 1.003420358087e-10
  382 KSP Residual norm 1.047654583029e-10
  383 KSP Residual norm 1.040658120500e-10
  384 KSP Residual norm 9.819264093864e-11
  385 KSP Residual norm 9.044904130672e-11
  386 KSP Residual norm 8.769804014454e-11
  387 KSP Residual norm 8.782691381774e-11
  388 KSP Residual norm 8.889264442449e-11
  389 KSP Residual norm 9.011781020588e-11
  390 KSP Residual norm 9.056370360392e-11
  391 KSP Residual norm 9.013963799066e-11
  392 KSP Residual norm 9.108096321946e-11
  393 KSP Residual norm 9.387709588279e-11
  394 KSP Residual norm 9.455709425885e-11
  395 KSP Residual norm 9.143848190643e-11
  396 KSP Residual norm 8.904516552009e-11
  397 KSP Residual norm 8.791868545759e-11
  398 KSP Residual norm 8.861452192126e-11
  399 KSP Residual norm 8.936027466983e-11
  400 KSP Residual norm 9.025502599390e-11
  401 KSP Residual norm 8.884123850125e-11
  402 KSP Residual norm 8.278342496209e-11
  403 KSP Residual norm 8.072960835880e-11
  404 KSP Residual norm 8.343209521330e-11
  405 KSP Residual norm 8.494389481873e-11
  406 KSP Residual norm 8.122455602851e-11
  407 KSP Residual norm 8.251758892002e-11
  408 KSP Residual norm 8.861369495284e-11
  409 KSP Residual norm 9.095449686780e-11
  410 KSP Residual norm 8.907494710767e-11
  411 KSP Residual norm 8.670745205835e-11
  412 KSP Residual norm 9.024053702827e-11
  413 KSP Residual norm 9.405704513442e-11
  414 KSP Residual norm 9.128912456732e-11
  415 KSP Residual norm 8.985896870899e-11
  416 KSP Residual norm 9.378544285377e-11
  417 KSP Residual norm 9.867326234355e-11
  418 KSP Residual norm 1.009237720336e-10
  419 KSP Residual norm 9.705789085782e-11
  420 KSP Residual norm 9.464615610631e-11
  421 KSP Residual norm 9.726877611052e-11
  422 KSP Residual norm 1.010513595090e-10
  423 KSP Residual norm 1.006015096923e-10
  424 KSP Residual norm 9.899501264832e-11
  425 KSP Residual norm 1.013094889359e-10
  426 KSP Residual norm 1.051013135303e-10
  427 KSP Residual norm 1.073804508653e-10
  428 KSP Residual norm 1.088021232731e-10
  429 KSP Residual norm 1.114547280784e-10
  430 KSP Residual norm 1.135506532441e-10
  431 KSP Residual norm 1.148321898402e-10
  432 KSP Residual norm 1.159096200224e-10
  433 KSP Residual norm 1.164558280000e-10
  434 KSP Residual norm 1.122352997235e-10
  435 KSP Residual norm 1.087145382814e-10
  436 KSP Residual norm 1.097894909348e-10
  437 KSP Residual norm 1.122527996191e-10
  438 KSP Residual norm 1.137491995240e-10
  439 KSP Residual norm 1.140774570496e-10
  440 KSP Residual norm 1.112589613742e-10
  441 KSP Residual norm 1.094983941213e-10
  442 KSP Residual norm 1.142562871324e-10
  443 KSP Residual norm 1.238810878572e-10
  444 KSP Residual norm 1.228791871381e-10
  445 KSP Residual norm 1.175064140499e-10
  446 KSP Residual norm 1.077466736331e-10
  447 KSP Residual norm 1.039927052253e-10
  448 KSP Residual norm 1.043533088316e-10
  449 KSP Residual norm 1.047440870394e-10
  450 KSP Residual norm 1.055522127257e-10
  451 KSP Residual norm 1.036720028434e-10
  452 KSP Residual norm 1.018155327586e-10
  453 KSP Residual norm 1.024067371058e-10
  454 KSP Residual norm 1.037494737515e-10
  455 KSP Residual norm 1.033572392592e-10
  456 KSP Residual norm 1.031045485840e-10
  457 KSP Residual norm 1.054311682262e-10
  458 KSP Residual norm 1.056995080539e-10
  459 KSP Residual norm 1.044873666824e-10
  460 KSP Residual norm 1.069091788929e-10
  461 KSP Residual norm 1.093635854489e-10
  462 KSP Residual norm 1.101887652280e-10
  463 KSP Residual norm 1.155605951432e-10
  464 KSP Residual norm 1.185883574394e-10
  465 KSP Residual norm 1.195111948651e-10
  466 KSP Residual norm 1.170226728991e-10
  467 KSP Residual norm 1.158646890160e-10
  468 KSP Residual norm 1.141738326626e-10
  469 KSP Residual norm 1.133317624204e-10
  470 KSP Residual norm 1.124826209429e-10
  471 KSP Residual norm 1.155247428899e-10
  472 KSP Residual norm 1.171227773134e-10
  473 KSP Residual norm 1.123152465461e-10
  474 KSP Residual norm 1.039973339485e-10
  475 KSP Residual norm 1.049648716183e-10
  476 KSP Residual norm 1.097148735963e-10
  477 KSP Residual norm 1.114976794603e-10
  478 KSP Residual norm 1.081918095913e-10
  479 KSP Residual norm 1.079785802457e-10
  480 KSP Residual norm 1.139522356396e-10
  481 KSP Residual norm 1.148743570563e-10
  482 KSP Residual norm 1.105669099725e-10
  483 KSP Residual norm 1.072501538178e-10
  484 KSP Residual norm 1.111845928806e-10
  485 KSP Residual norm 1.230371241072e-10
  486 KSP Residual norm 1.301767187665e-10
  487 KSP Residual norm 1.398267503430e-10
  488 KSP Residual norm 1.510580683768e-10
  489 KSP Residual norm 1.572826545860e-10
  490 KSP Residual norm 1.605159712300e-10
  491 KSP Residual norm 1.624697856367e-10
  492 KSP Residual norm 1.692094670052e-10
  493 KSP Residual norm 1.739236721802e-10
  494 KSP Residual norm 1.790000581442e-10
  495 KSP Residual norm 1.778450573647e-10
  496 KSP Residual norm 1.786454314163e-10
  497 KSP Residual norm 1.780642972262e-10
  498 KSP Residual norm 1.763582274327e-10
  499 KSP Residual norm 1.689498450926e-10
  500 KSP Residual norm 1.559343131137e-10
  501 KSP Residual norm 1.481066078777e-10
  502 KSP Residual norm 1.491899722413e-10
  503 KSP Residual norm 1.480754888971e-10
  504 KSP Residual norm 1.470274577219e-10
  505 KSP Residual norm 1.488160610072e-10
  506 KSP Residual norm 1.515779527617e-10
  507 KSP Residual norm 1.572635069659e-10
  508 KSP Residual norm 1.636582482232e-10
  509 KSP Residual norm 1.641728507805e-10
  510 KSP Residual norm 1.662097561259e-10
  511 KSP Residual norm 1.746764405987e-10
  512 KSP Residual norm 1.822360615908e-10
  513 KSP Residual norm 1.815612354338e-10
  514 KSP Residual norm 1.768132374405e-10
  515 KSP Residual norm 1.818474128730e-10
  516 KSP Residual norm 1.922637860255e-10
  517 KSP Residual norm 1.988984178281e-10
  518 KSP Residual norm 2.035266421635e-10
  519 KSP Residual norm 2.039448805526e-10
  520 KSP Residual norm 2.085091295652e-10
  521 KSP Residual norm 2.170981952231e-10
  522 KSP Residual norm 2.217800598437e-10
  523 KSP Residual norm 2.226932170255e-10
  524 KSP Residual norm 2.139060245389e-10
  525 KSP Residual norm 2.014068018946e-10
  526 KSP Residual norm 1.939654475187e-10
  527 KSP Residual norm 1.930542050393e-10
  528 KSP Residual norm 1.909651687465e-10
  529 KSP Residual norm 1.825009181196e-10
  530 KSP Residual norm 1.745936989771e-10
  531 KSP Residual norm 1.800902804406e-10
  532 KSP Residual norm 1.938026366554e-10
  533 KSP Residual norm 1.965409974991e-10
  534 KSP Residual norm 1.867434435718e-10
  535 KSP Residual norm 1.812310566456e-10
  536 KSP Residual norm 1.794267169647e-10
  537 KSP Residual norm 1.743316904438e-10
  538 KSP Residual norm 1.809021052603e-10
  539 KSP Residual norm 1.941038206959e-10
  540 KSP Residual norm 2.061227671070e-10
  541 KSP Residual norm 2.204272495965e-10
  542 KSP Residual norm 2.226107492790e-10
  543 KSP Residual norm 2.145859724464e-10
  544 KSP Residual norm 2.028559956101e-10
  545 KSP Residual norm 2.010678420953e-10
  546 KSP Residual norm 2.059400547046e-10
  547 KSP Residual norm 2.155408765763e-10
  548 KSP Residual norm 2.056221918493e-10
  549 KSP Residual norm 1.918881705640e-10
  550 KSP Residual norm 1.878014647773e-10
  551 KSP Residual norm 1.913661209845e-10
  552 KSP Residual norm 1.828508531043e-10
  553 KSP Residual norm 1.693881765474e-10
  554 KSP Residual norm 1.694584256926e-10
  555 KSP Residual norm 1.760812233836e-10
  556 KSP Residual norm 1.812192015929e-10
  557 KSP Residual norm 1.877524918190e-10
  558 KSP Residual norm 1.881720567202e-10
  559 KSP Residual norm 1.783387366241e-10
  560 KSP Residual norm 1.744480589160e-10
  561 KSP Residual norm 1.814336627861e-10
  562 KSP Residual norm 1.913469447756e-10
  563 KSP Residual norm 2.010888578609e-10
  564 KSP Residual norm 1.952870289662e-10
  565 KSP Residual norm 1.893843467257e-10
  566 KSP Residual norm 1.918549594254e-10
  567 KSP Residual norm 1.989289966291e-10
  568 KSP Residual norm 1.937183871854e-10
  569 KSP Residual norm 1.842370681866e-10
  570 KSP Residual norm 1.769928814404e-10
  571 KSP Residual norm 1.772570923404e-10
  572 KSP Residual norm 1.804216305224e-10
  573 KSP Residual norm 1.789860976695e-10
  574 KSP Residual norm 1.787037123703e-10
  575 KSP Residual norm 1.759849887693e-10
  576 KSP Residual norm 1.776969017259e-10
  577 KSP Residual norm 1.830954458633e-10
  578 KSP Residual norm 1.875910570900e-10
  579 KSP Residual norm 1.984415040785e-10
  580 KSP Residual norm 2.116606853177e-10
  581 KSP Residual norm 2.053942917391e-10
  582 KSP Residual norm 1.893566743926e-10
  583 KSP Residual norm 1.785184685867e-10
  584 KSP Residual norm 1.716183711272e-10
  585 KSP Residual norm 1.736203895607e-10
  586 KSP Residual norm 1.704484511659e-10
  587 KSP Residual norm 1.644148485745e-10
  588 KSP Residual norm 1.668583922259e-10
  589 KSP Residual norm 1.810101343623e-10
  590 KSP Residual norm 1.906796142367e-10
  591 KSP Residual norm 1.935806982046e-10
  592 KSP Residual norm 2.064014299958e-10
  593 KSP Residual norm 2.197326419846e-10
  594 KSP Residual norm 2.201830552860e-10
  595 KSP Residual norm 2.125623328059e-10
  596 KSP Residual norm 2.022460063513e-10
  597 KSP Residual norm 2.001000385744e-10
  598 KSP Residual norm 1.998768522064e-10
  599 KSP Residual norm 1.933718982975e-10
  600 KSP Residual norm 1.915740434624e-10
  601 KSP Residual norm 1.933653714604e-10
  602 KSP Residual norm 1.951435212449e-10
  603 KSP Residual norm 2.038324333315e-10
  604 KSP Residual norm 2.220329503539e-10
  605 KSP Residual norm 2.495278854397e-10
  606 KSP Residual norm 2.576209928494e-10
  607 KSP Residual norm 2.421429961141e-10
  608 KSP Residual norm 2.255355246934e-10
  609 KSP Residual norm 2.231542636799e-10
  610 KSP Residual norm 2.293456644988e-10
  611 KSP Residual norm 2.331670371593e-10
  612 KSP Residual norm 2.376547928324e-10
  613 KSP Residual norm 2.422941280715e-10
  614 KSP Residual norm 2.431381910845e-10
  615 KSP Residual norm 2.401718386582e-10
  616 KSP Residual norm 2.369321629805e-10
  617 KSP Residual norm 2.335270642779e-10
  618 KSP Residual norm 2.356230858869e-10
  619 KSP Residual norm 2.327772748258e-10
  620 KSP Residual norm 2.184154560928e-10
  621 KSP Residual norm 2.101648426423e-10
  622 KSP Residual norm 2.170030494840e-10
  623 KSP Residual norm 2.177253876233e-10
  624 KSP Residual norm 2.033105581876e-10
  625 KSP Residual norm 1.954703863351e-10
  626 KSP Residual norm 1.912352902099e-10
  627 KSP Residual norm 1.865679218894e-10
  628 KSP Residual norm 1.818188262214e-10
  629 KSP Residual norm 1.833684548112e-10
  630 KSP Residual norm 1.924942420484e-10
  631 KSP Residual norm 2.036367036511e-10
  632 KSP Residual norm 2.086889231729e-10
  633 KSP Residual norm 2.114613038145e-10
  634 KSP Residual norm 2.042754342130e-10
  635 KSP Residual norm 1.881642970141e-10
  636 KSP Residual norm 1.727757469396e-10
  637 KSP Residual norm 1.652987962858e-10
  638 KSP Residual norm 1.650230364386e-10
  639 KSP Residual norm 1.717765677817e-10
  640 KSP Residual norm 1.836789400160e-10
  641 KSP Residual norm 2.000454387967e-10
  642 KSP Residual norm 2.071921585415e-10
  643 KSP Residual norm 2.081004931713e-10
  644 KSP Residual norm 2.185069061240e-10
  645 KSP Residual norm 2.287205604048e-10
  646 KSP Residual norm 2.331019879264e-10
  647 KSP Residual norm 2.316362949551e-10
  648 KSP Residual norm 2.286823970508e-10
  649 KSP Residual norm 2.293848085066e-10
  650 KSP Residual norm 2.438784418810e-10
  651 KSP Residual norm 2.526587403875e-10
  652 KSP Residual norm 2.568420559779e-10
  653 KSP Residual norm 2.425010569264e-10
  654 KSP Residual norm 2.352198803424e-10
  655 KSP Residual norm 2.455869466605e-10
  656 KSP Residual norm 2.429215720402e-10
  657 KSP Residual norm 2.345534661051e-10
  658 KSP Residual norm 2.237167908436e-10
  659 KSP Residual norm 2.126002743319e-10
  660 KSP Residual norm 2.038458551779e-10
  661 KSP Residual norm 2.067173994015e-10
  662 KSP Residual norm 2.081124970665e-10
  663 KSP Residual norm 2.139811202812e-10
  664 KSP Residual norm 2.264061229577e-10
  665 KSP Residual norm 2.375101095671e-10
  666 KSP Residual norm 2.370122955716e-10
  667 KSP Residual norm 2.266551856449e-10
  668 KSP Residual norm 2.189360903161e-10
  669 KSP Residual norm 2.179995890352e-10
  670 KSP Residual norm 2.163092424936e-10
  671 KSP Residual norm 2.183864370351e-10
  672 KSP Residual norm 2.238014269049e-10
  673 KSP Residual norm 2.358904192887e-10
  674 KSP Residual norm 2.464595534492e-10
  675 KSP Residual norm 2.335491417182e-10
  676 KSP Residual norm 2.196323711133e-10
  677 KSP Residual norm 2.213523242846e-10
  678 KSP Residual norm 2.043120835486e-10
  679 KSP Residual norm 2.075778319304e-10
  680 KSP Residual norm 2.056906743936e-10
  681 KSP Residual norm 2.101790268865e-10
  682 KSP Residual norm 2.101145127540e-10
  683 KSP Residual norm 2.087180344450e-10
  684 KSP Residual norm 2.211517620371e-10
  685 KSP Residual norm 2.279519948783e-10
  686 KSP Residual norm 2.439915727417e-10
  687 KSP Residual norm 2.596807864920e-10
  688 KSP Residual norm 2.639790113494e-10
  689 KSP Residual norm 2.663678174672e-10
  690 KSP Residual norm 2.668064612300e-10
  691 KSP Residual norm 2.764176897416e-10
  692 KSP Residual norm 2.905522225811e-10
  693 KSP Residual norm 2.960037874305e-10
  694 KSP Residual norm 3.077213997327e-10
  695 KSP Residual norm 2.949384884034e-10
  696 KSP Residual norm 2.906327167550e-10
  697 KSP Residual norm 3.046900008151e-10
  698 KSP Residual norm 3.410358277854e-10
  699 KSP Residual norm 3.730860907175e-10
  700 KSP Residual norm 3.809336660159e-10
  701 KSP Residual norm 3.624604287047e-10
  702 KSP Residual norm 3.439749964009e-10
  703 KSP Residual norm 3.281184804047e-10
  704 KSP Residual norm 3.332878743402e-10
  705 KSP Residual norm 3.414423602397e-10
  706 KSP Residual norm 3.507964752287e-10
  707 KSP Residual norm 3.712419659917e-10
  708 KSP Residual norm 3.733357871312e-10
  709 KSP Residual norm 3.622491729105e-10
  710 KSP Residual norm 3.482167388562e-10
  711 KSP Residual norm 3.392892409711e-10
  712 KSP Residual norm 3.375639914086e-10
  713 KSP Residual norm 3.696721110919e-10
  714 KSP Residual norm 4.219383842350e-10
  715 KSP Residual norm 4.688536216617e-10
  716 KSP Residual norm 5.007353272304e-10
  717 KSP Residual norm 5.384449342297e-10
  718 KSP Residual norm 5.549011578188e-10
  719 KSP Residual norm 5.536046853695e-10
  720 KSP Residual norm 5.236485152690e-10
  721 KSP Residual norm 5.094810323967e-10
  722 KSP Residual norm 5.200268906537e-10
  723 KSP Residual norm 5.413545252793e-10
  724 KSP Residual norm 5.564693620909e-10
  725 KSP Residual norm 5.772470736711e-10
  726 KSP Residual norm 5.703687352867e-10
  727 KSP Residual norm 5.448112157796e-10
  728 KSP Residual norm 5.459180309984e-10
  729 KSP Residual norm 5.637843170989e-10
  730 KSP Residual norm 5.288179546452e-10
  731 KSP Residual norm 4.853022180494e-10
  732 KSP Residual norm 4.528402703427e-10
  733 KSP Residual norm 4.316934089981e-10
  734 KSP Residual norm 4.487153936643e-10
  735 KSP Residual norm 4.676863146105e-10
  736 KSP Residual norm 4.669185395562e-10
  737 KSP Residual norm 4.796653238233e-10
  738 KSP Residual norm 5.202958190228e-10
  739 KSP Residual norm 5.800385748514e-10
  740 KSP Residual norm 6.070581159075e-10
  741 KSP Residual norm 6.234595529537e-10
  742 KSP Residual norm 6.457826038961e-10
  743 KSP Residual norm 7.079977095355e-10
  744 KSP Residual norm 7.435357821093e-10
  745 KSP Residual norm 7.146299986801e-10
  746 KSP Residual norm 6.700412822349e-10
  747 KSP Residual norm 6.512315167885e-10
  748 KSP Residual norm 6.415254757139e-10
  749 KSP Residual norm 6.151523267880e-10
  750 KSP Residual norm 5.989118406893e-10
  751 KSP Residual norm 5.854893269656e-10
  752 KSP Residual norm 5.865341902098e-10
  753 KSP Residual norm 5.741401246338e-10
  754 KSP Residual norm 5.766190438691e-10
  755 KSP Residual norm 6.105570653010e-10
  756 KSP Residual norm 6.466463228210e-10
  757 KSP Residual norm 6.296957862106e-10
  758 KSP Residual norm 6.079600078386e-10
  759 KSP Residual norm 6.195955242589e-10
  760 KSP Residual norm 6.310398019099e-10
  761 KSP Residual norm 6.130194509493e-10
  762 KSP Residual norm 5.971752658804e-10
  763 KSP Residual norm 5.866637196686e-10
  764 KSP Residual norm 5.905912636370e-10
  765 KSP Residual norm 6.202038742986e-10
  766 KSP Residual norm 6.787100194676e-10
  767 KSP Residual norm 7.113950100922e-10
  768 KSP Residual norm 7.417949699915e-10
  769 KSP Residual norm 7.587535106951e-10
  770 KSP Residual norm 7.219782647258e-10
  771 KSP Residual norm 6.614194213521e-10
  772 KSP Residual norm 6.552952684021e-10
  773 KSP Residual norm 7.064630656962e-10
  774 KSP Residual norm 7.696705932934e-10
  775 KSP Residual norm 7.894596408595e-10
  776 KSP Residual norm 7.581219253549e-10
  777 KSP Residual norm 7.199064923237e-10
  778 KSP Residual norm 7.233021519686e-10
  779 KSP Residual norm 7.255467824559e-10
  780 KSP Residual norm 7.198755134715e-10
  781 KSP Residual norm 6.967979475498e-10
  782 KSP Residual norm 6.898243500686e-10
  783 KSP Residual norm 6.952263245737e-10
  784 KSP Residual norm 6.737457763147e-10
  785 KSP Residual norm 6.468241740127e-10
  786 KSP Residual norm 6.356857503848e-10
  787 KSP Residual norm 6.230794137109e-10
  788 KSP Residual norm 6.075857386720e-10
  789 KSP Residual norm 6.333992773390e-10
  790 KSP Residual norm 6.436249335699e-10
  791 KSP Residual norm 6.006592593413e-10
  792 KSP Residual norm 5.609887155837e-10
  793 KSP Residual norm 5.460701893927e-10
  794 KSP Residual norm 5.466387795694e-10
  795 KSP Residual norm 5.245851781888e-10
  796 KSP Residual norm 5.038967824906e-10
  797 KSP Residual norm 5.110488244116e-10
  798 KSP Residual norm 5.520342390421e-10
  799 KSP Residual norm 5.862001935001e-10
  800 KSP Residual norm 6.112081856144e-10
  801 KSP Residual norm 6.434404934191e-10
  802 KSP Residual norm 6.494527840936e-10
  803 KSP Residual norm 6.559085679793e-10
  804 KSP Residual norm 6.195347806035e-10
  805 KSP Residual norm 5.781363372952e-10
  806 KSP Residual norm 5.745697885265e-10
  807 KSP Residual norm 6.132118848257e-10
  808 KSP Residual norm 6.691546217644e-10
  809 KSP Residual norm 6.734659332666e-10
  810 KSP Residual norm 6.419195073217e-10
  811 KSP Residual norm 5.864820706635e-10
  812 KSP Residual norm 5.356310478348e-10
  813 KSP Residual norm 4.926128580964e-10
  814 KSP Residual norm 4.887564768928e-10
  815 KSP Residual norm 5.051134065194e-10
  816 KSP Residual norm 5.169022648947e-10
  817 KSP Residual norm 5.261211478534e-10
  818 KSP Residual norm 5.337550635041e-10
  819 KSP Residual norm 5.318492120777e-10
  820 KSP Residual norm 5.370820477013e-10
  821 KSP Residual norm 5.415557843983e-10
  822 KSP Residual norm 5.124846377840e-10
  823 KSP Residual norm 4.698115925146e-10
  824 KSP Residual norm 4.634140351634e-10
  825 KSP Residual norm 4.980471182710e-10
  826 KSP Residual norm 5.365674377454e-10
  827 KSP Residual norm 5.274853483100e-10
  828 KSP Residual norm 5.030326389075e-10
  829 KSP Residual norm 4.846839440079e-10
  830 KSP Residual norm 5.062069362945e-10
  831 KSP Residual norm 5.378170278237e-10
  832 KSP Residual norm 5.390812130215e-10
  833 KSP Residual norm 5.294106454447e-10
  834 KSP Residual norm 5.369020945543e-10
  835 KSP Residual norm 5.480203621406e-10
  836 KSP Residual norm 5.496370260960e-10
  837 KSP Residual norm 5.248187798370e-10
  838 KSP Residual norm 4.680871829364e-10
  839 KSP Residual norm 4.351554960438e-10
  840 KSP Residual norm 4.517457085751e-10
  841 KSP Residual norm 4.894903837526e-10
  842 KSP Residual norm 5.145747720301e-10
  843 KSP Residual norm 5.322278669627e-10
  844 KSP Residual norm 5.497680388346e-10
  845 KSP Residual norm 5.455952265822e-10
  846 KSP Residual norm 5.443095369480e-10
  847 KSP Residual norm 5.504076086696e-10
  848 KSP Residual norm 5.650793232657e-10
  849 KSP Residual norm 6.039189590649e-10
  850 KSP Residual norm 6.517088188967e-10
  851 KSP Residual norm 6.943978819316e-10
  852 KSP Residual norm 7.000419017684e-10
  853 KSP Residual norm 6.491609267055e-10
  854 KSP Residual norm 5.887657679061e-10
  855 KSP Residual norm 5.598276904567e-10
  856 KSP Residual norm 5.558752753957e-10
  857 KSP Residual norm 5.426007227076e-10
  858 KSP Residual norm 5.422251898715e-10
  859 KSP Residual norm 5.317131612180e-10
  860 KSP Residual norm 5.333062389980e-10
  861 KSP Residual norm 5.539948219391e-10
  862 KSP Residual norm 5.766572825092e-10
  863 KSP Residual norm 5.588234741305e-10
  864 KSP Residual norm 5.340018845522e-10
  865 KSP Residual norm 5.133965851998e-10
  866 KSP Residual norm 5.212229173195e-10
  867 KSP Residual norm 5.202777311207e-10
  868 KSP Residual norm 4.953825535372e-10
  869 KSP Residual norm 4.664693594801e-10
  870 KSP Residual norm 4.520155860631e-10
  871 KSP Residual norm 4.328898864573e-10
  872 KSP Residual norm 4.143775985066e-10
  873 KSP Residual norm 3.995589095060e-10
  874 KSP Residual norm 4.150352244873e-10
  875 KSP Residual norm 4.286127172925e-10
  876 KSP Residual norm 4.401296645760e-10
  877 KSP Residual norm 4.389471524053e-10
  878 KSP Residual norm 4.507336515775e-10
  879 KSP Residual norm 4.716771291256e-10
  880 KSP Residual norm 4.750881246811e-10
  881 KSP Residual norm 4.937604806469e-10
  882 KSP Residual norm 5.308729859348e-10
  883 KSP Residual norm 5.596030874562e-10
  884 KSP Residual norm 5.419538704588e-10
  885 KSP Residual norm 5.116380577576e-10
  886 KSP Residual norm 5.100411837061e-10
  887 KSP Residual norm 5.136954916304e-10
  888 KSP Residual norm 5.306415529980e-10
  889 KSP Residual norm 5.562143643389e-10
  890 KSP Residual norm 5.680597864048e-10
  891 KSP Residual norm 5.558032240071e-10
  892 KSP Residual norm 5.308725964856e-10
  893 KSP Residual norm 4.922671299915e-10
  894 KSP Residual norm 4.750722773361e-10
  895 KSP Residual norm 4.716530834926e-10
  896 KSP Residual norm 4.715429697206e-10
  897 KSP Residual norm 4.770787880106e-10
  898 KSP Residual norm 4.910169059875e-10
  899 KSP Residual norm 4.950316053815e-10
  900 KSP Residual norm 5.057671246262e-10
  901 KSP Residual norm 5.187930935719e-10
  902 KSP Residual norm 5.367652761539e-10
  903 KSP Residual norm 5.733273157387e-10
  904 KSP Residual norm 6.165699143876e-10
  905 KSP Residual norm 6.534406142013e-10
  906 KSP Residual norm 6.747733721164e-10
  907 KSP Residual norm 6.884730288643e-10
  908 KSP Residual norm 6.799991844174e-10
  909 KSP Residual norm 6.584861364922e-10
  910 KSP Residual norm 6.212351330236e-10
  911 KSP Residual norm 6.010017298295e-10
  912 KSP Residual norm 6.224121152797e-10
  913 KSP Residual norm 6.495847200552e-10
  914 KSP Residual norm 6.676052237209e-10
  915 KSP Residual norm 6.902872280847e-10
  916 KSP Residual norm 7.282544707337e-10
  917 KSP Residual norm 7.613755389096e-10
  918 KSP Residual norm 7.587551700286e-10
  919 KSP Residual norm 7.648799665555e-10
  920 KSP Residual norm 7.976559018038e-10
  921 KSP Residual norm 8.844552661071e-10
  922 KSP Residual norm 9.212573340073e-10
  923 KSP Residual norm 8.330931288257e-10
  924 KSP Residual norm 6.846769280374e-10
  925 KSP Residual norm 6.096691827333e-10
  926 KSP Residual norm 5.883429922012e-10
  927 KSP Residual norm 5.791469660230e-10
  928 KSP Residual norm 5.423228624356e-10
  929 KSP Residual norm 5.213037569586e-10
  930 KSP Residual norm 5.153642389121e-10
  931 KSP Residual norm 5.355226153632e-10
  932 KSP Residual norm 5.460843163977e-10
  933 KSP Residual norm 5.639180128626e-10
  934 KSP Residual norm 5.815237022150e-10
  935 KSP Residual norm 5.826295123147e-10
  936 KSP Residual norm 5.733978598475e-10
  937 KSP Residual norm 5.565342534135e-10
  938 KSP Residual norm 5.383603799260e-10
  939 KSP Residual norm 5.217099253861e-10
  940 KSP Residual norm 5.082194961971e-10
  941 KSP Residual norm 4.915892536656e-10
  942 KSP Residual norm 5.009220334167e-10
  943 KSP Residual norm 5.378789901038e-10
  944 KSP Residual norm 5.770886650123e-10
  945 KSP Residual norm 5.850996770602e-10
  946 KSP Residual norm 5.754041980581e-10
  947 KSP Residual norm 5.860876194141e-10
  948 KSP Residual norm 5.989489848833e-10
  949 KSP Residual norm 5.954126770656e-10
  950 KSP Residual norm 5.987889430119e-10
  951 KSP Residual norm 5.979969544187e-10
  952 KSP Residual norm 6.064645862086e-10
  953 KSP Residual norm 6.120994361376e-10
  954 KSP Residual norm 6.153306820402e-10
  955 KSP Residual norm 6.300583550256e-10
  956 KSP Residual norm 6.269213458754e-10
  957 KSP Residual norm 6.079222943604e-10
  958 KSP Residual norm 5.798121970466e-10
  959 KSP Residual norm 5.581486311722e-10
  960 KSP Residual norm 5.390408179636e-10
  961 KSP Residual norm 5.475567769388e-10
  962 KSP Residual norm 5.813670234804e-10
  963 KSP Residual norm 6.058047222206e-10
  964 KSP Residual norm 6.161861967216e-10
  965 KSP Residual norm 5.958125211842e-10
  966 KSP Residual norm 5.530137681377e-10
  967 KSP Residual norm 5.447433280026e-10
  968 KSP Residual norm 5.463469313784e-10
  969 KSP Residual norm 5.353953557889e-10
  970 KSP Residual norm 4.996266006901e-10
  971 KSP Residual norm 4.498777755624e-10
  972 KSP Residual norm 4.294140881110e-10
  973 KSP Residual norm 4.329094971861e-10
  974 KSP Residual norm 4.334356428128e-10
  975 KSP Residual norm 4.181130481390e-10
  976 KSP Residual norm 4.164840982480e-10
  977 KSP Residual norm 4.265387002252e-10
  978 KSP Residual norm 4.181379742852e-10
  979 KSP Residual norm 4.089797802319e-10
  980 KSP Residual norm 4.141032811975e-10
  981 KSP Residual norm 4.301282973720e-10
  982 KSP Residual norm 4.354042699665e-10
  983 KSP Residual norm 4.185999254546e-10
  984 KSP Residual norm 3.806601613392e-10
  985 KSP Residual norm 3.484327200485e-10
  986 KSP Residual norm 3.405848086642e-10
  987 KSP Residual norm 3.369538859992e-10
  988 KSP Residual norm 3.241564584193e-10
  989 KSP Residual norm 3.087403756511e-10
  990 KSP Residual norm 3.196517612153e-10
  991 KSP Residual norm 3.319561483120e-10
  992 KSP Residual norm 3.220990483384e-10
  993 KSP Residual norm 2.990649040859e-10
  994 KSP Residual norm 2.826147655680e-10
  995 KSP Residual norm 2.807203753680e-10
  996 KSP Residual norm 2.827366745410e-10
  997 KSP Residual norm 2.649016975505e-10
  998 KSP Residual norm 2.456412087091e-10
  999 KSP Residual norm 2.365024348027e-10
  1000 KSP Residual norm 2.350737135201e-10
  1001 KSP Residual norm 2.314619652044e-10
  1002 KSP Residual norm 2.243868500065e-10
  1003 KSP Residual norm 2.251959779604e-10
  1004 KSP Residual norm 2.281516736274e-10
  1005 KSP Residual norm 2.246202415571e-10
  1006 KSP Residual norm 2.136614334945e-10
  1007 KSP Residual norm 2.168670598797e-10
  1008 KSP Residual norm 2.300190928102e-10
  1009 KSP Residual norm 2.366984139504e-10
  1010 KSP Residual norm 2.366822958721e-10
  1011 KSP Residual norm 2.351065225949e-10
  1012 KSP Residual norm 2.425036166983e-10
  1013 KSP Residual norm 2.522463564641e-10
  1014 KSP Residual norm 2.562175678713e-10
  1015 KSP Residual norm 2.413904408114e-10
  1016 KSP Residual norm 2.344491184824e-10
  1017 KSP Residual norm 2.423150455142e-10
  1018 KSP Residual norm 2.497256711835e-10
  1019 KSP Residual norm 2.419956933276e-10
  1020 KSP Residual norm 2.385524517122e-10
  1021 KSP Residual norm 2.392111116692e-10
  1022 KSP Residual norm 2.386219416804e-10
  1023 KSP Residual norm 2.398071671630e-10
  1024 KSP Residual norm 2.327957994828e-10
  1025 KSP Residual norm 2.214112512053e-10
  1026 KSP Residual norm 2.119681445223e-10
  1027 KSP Residual norm 2.084531515800e-10
  1028 KSP Residual norm 2.075468942163e-10
  1029 KSP Residual norm 2.172778890333e-10
  1030 KSP Residual norm 2.304607637780e-10
  1031 KSP Residual norm 2.307571974843e-10
  1032 KSP Residual norm 2.270672161097e-10
  1033 KSP Residual norm 2.171332783606e-10
  1034 KSP Residual norm 2.084726701007e-10
  1035 KSP Residual norm 2.044527273295e-10
  1036 KSP Residual norm 2.039610154082e-10
  1037 KSP Residual norm 2.103251134750e-10
  1038 KSP Residual norm 2.111275095130e-10
  1039 KSP Residual norm 2.040319165422e-10
  1040 KSP Residual norm 1.815026160879e-10
  1041 KSP Residual norm 1.595170077793e-10
  1042 KSP Residual norm 1.543343906089e-10
  1043 KSP Residual norm 1.572613776785e-10
  1044 KSP Residual norm 1.588625712986e-10
  1045 KSP Residual norm 1.507427693585e-10
  1046 KSP Residual norm 1.427357673703e-10
  1047 KSP Residual norm 1.422620684647e-10
  1048 KSP Residual norm 1.467955931423e-10
  1049 KSP Residual norm 1.470377098471e-10
  1050 KSP Residual norm 1.402411794981e-10
  1051 KSP Residual norm 1.312433511091e-10
  1052 KSP Residual norm 1.211314413683e-10
  1053 KSP Residual norm 1.173887690999e-10
  1054 KSP Residual norm 1.155458216925e-10
  1055 KSP Residual norm 1.128789069219e-10
  1056 KSP Residual norm 1.084739911462e-10
  1057 KSP Residual norm 1.106094782868e-10
  1058 KSP Residual norm 1.147452985664e-10
  1059 KSP Residual norm 1.149954604269e-10
  1060 KSP Residual norm 1.193800286095e-10
  1061 KSP Residual norm 1.309023486984e-10
  1062 KSP Residual norm 1.420911020598e-10
  1063 KSP Residual norm 1.488275369637e-10
  1064 KSP Residual norm 1.446716718771e-10
  1065 KSP Residual norm 1.358881141186e-10
  1066 KSP Residual norm 1.309326531427e-10
  1067 KSP Residual norm 1.303915544725e-10
  1068 KSP Residual norm 1.232697390625e-10
  1069 KSP Residual norm 1.197024778590e-10
  1070 KSP Residual norm 1.132326897546e-10
  1071 KSP Residual norm 1.078000950676e-10
  1072 KSP Residual norm 1.119366759526e-10
  1073 KSP Residual norm 1.235712482411e-10
  1074 KSP Residual norm 1.357784939192e-10
  1075 KSP Residual norm 1.440935529404e-10
  1076 KSP Residual norm 1.471673405697e-10
  1077 KSP Residual norm 1.483366631805e-10
  1078 KSP Residual norm 1.471150335930e-10
  1079 KSP Residual norm 1.406543892592e-10
  1080 KSP Residual norm 1.340037081894e-10
  1081 KSP Residual norm 1.330062692154e-10
  1082 KSP Residual norm 1.351162630114e-10
  1083 KSP Residual norm 1.293435446636e-10
  1084 KSP Residual norm 1.177013518633e-10
  1085 KSP Residual norm 1.211017322565e-10
  1086 KSP Residual norm 1.318777753080e-10
  1087 KSP Residual norm 1.376421660394e-10
  1088 KSP Residual norm 1.347363939631e-10
  1089 KSP Residual norm 1.400588227020e-10
  1090 KSP Residual norm 1.448507844125e-10
  1091 KSP Residual norm 1.450171301749e-10
  1092 KSP Residual norm 1.359352635381e-10
  1093 KSP Residual norm 1.171919570819e-10
  1094 KSP Residual norm 1.049392967084e-10
  1095 KSP Residual norm 1.089821022460e-10
  1096 KSP Residual norm 1.185368426463e-10
  1097 KSP Residual norm 1.259915564274e-10
  1098 KSP Residual norm 1.375279809772e-10
  1099 KSP Residual norm 1.526613666737e-10
  1100 KSP Residual norm 1.565274408319e-10
  1101 KSP Residual norm 1.618324786611e-10
  1102 KSP Residual norm 1.730001357964e-10
  1103 KSP Residual norm 1.795472643169e-10
  1104 KSP Residual norm 1.813031367066e-10
  1105 KSP Residual norm 1.786546660073e-10
  1106 KSP Residual norm 1.697653039857e-10
  1107 KSP Residual norm 1.640707343660e-10
  1108 KSP Residual norm 1.615504585828e-10
  1109 KSP Residual norm 1.615096731694e-10
  1110 KSP Residual norm 1.591076231168e-10
  1111 KSP Residual norm 1.522483473249e-10
  1112 KSP Residual norm 1.465731763735e-10
  1113 KSP Residual norm 1.407913237595e-10
  1114 KSP Residual norm 1.354712014437e-10
  1115 KSP Residual norm 1.320137220037e-10
  1116 KSP Residual norm 1.313687778078e-10
  1117 KSP Residual norm 1.310971848267e-10
  1118 KSP Residual norm 1.292582460721e-10
  1119 KSP Residual norm 1.287740026063e-10
  1120 KSP Residual norm 1.300832330655e-10
  1121 KSP Residual norm 1.332045617420e-10
  1122 KSP Residual norm 1.331696634118e-10
  1123 KSP Residual norm 1.342425034096e-10
  1124 KSP Residual norm 1.387838479953e-10
  1125 KSP Residual norm 1.476424102360e-10
  1126 KSP Residual norm 1.504006860430e-10
  1127 KSP Residual norm 1.491413771797e-10
  1128 KSP Residual norm 1.505733843840e-10
  1129 KSP Residual norm 1.485491107044e-10
  1130 KSP Residual norm 1.435805257220e-10
  1131 KSP Residual norm 1.395207280188e-10
  1132 KSP Residual norm 1.311926480719e-10
  1133 KSP Residual norm 1.207266302548e-10
  1134 KSP Residual norm 1.119449237072e-10
  1135 KSP Residual norm 1.062984855452e-10
  1136 KSP Residual norm 1.068897403523e-10
  1137 KSP Residual norm 1.076414656853e-10
  1138 KSP Residual norm 1.118241265149e-10
  1139 KSP Residual norm 1.081980927745e-10
  1140 KSP Residual norm 1.019907962164e-10
  1141 KSP Residual norm 1.010209122008e-10
  1142 KSP Residual norm 1.013359420459e-10
  1143 KSP Residual norm 9.932500479177e-11
  1144 KSP Residual norm 1.003955484669e-10
  1145 KSP Residual norm 1.021893570306e-10
  1146 KSP Residual norm 9.926057322706e-11
  1147 KSP Residual norm 9.648515930229e-11
  1148 KSP Residual norm 9.569416903574e-11
  1149 KSP Residual norm 9.387155764020e-11
  1150 KSP Residual norm 9.180576887838e-11
  1151 KSP Residual norm 8.553919419715e-11
  1152 KSP Residual norm 7.851411577195e-11
  1153 KSP Residual norm 7.390482045224e-11
  1154 KSP Residual norm 7.414222446181e-11
  1155 KSP Residual norm 7.530912275082e-11
  1156 KSP Residual norm 7.673177110188e-11
  1157 KSP Residual norm 7.622477299404e-11
  1158 KSP Residual norm 7.838311761306e-11
  1159 KSP Residual norm 7.837396709383e-11
  1160 KSP Residual norm 7.634992677048e-11
  1161 KSP Residual norm 7.094509786158e-11
  1162 KSP Residual norm 6.505541987853e-11
  1163 KSP Residual norm 6.317679983339e-11
  1164 KSP Residual norm 6.341128387201e-11
  1165 KSP Residual norm 6.644580379472e-11
  1166 KSP Residual norm 7.151483215202e-11
  1167 KSP Residual norm 7.336763537086e-11
  1168 KSP Residual norm 7.504040049393e-11
  1169 KSP Residual norm 7.708207055046e-11
  1170 KSP Residual norm 7.541274845611e-11
  1171 KSP Residual norm 7.370095283574e-11
  1172 KSP Residual norm 7.580485043066e-11
  1173 KSP Residual norm 7.830355452263e-11
  1174 KSP Residual norm 8.066797742180e-11
  1175 KSP Residual norm 7.990103318601e-11
  1176 KSP Residual norm 7.663965484325e-11
  1177 KSP Residual norm 7.482882539879e-11
  1178 KSP Residual norm 7.968524832502e-11
  1179 KSP Residual norm 8.672036338053e-11
  1180 KSP Residual norm 8.883895115202e-11
  1181 KSP Residual norm 8.754218112608e-11
  1182 KSP Residual norm 8.411344146378e-11
  1183 KSP Residual norm 7.951607563253e-11
  1184 KSP Residual norm 7.594389116270e-11
  1185 KSP Residual norm 7.361251969389e-11
  1186 KSP Residual norm 7.591920100077e-11
  1187 KSP Residual norm 8.128618839562e-11
  1188 KSP Residual norm 8.450488832936e-11
  1189 KSP Residual norm 8.036441484940e-11
  1190 KSP Residual norm 7.391192244399e-11
  1191 KSP Residual norm 6.724726767951e-11
  1192 KSP Residual norm 6.272751829084e-11
  1193 KSP Residual norm 6.203026007891e-11
  1194 KSP Residual norm 6.886433780209e-11
  1195 KSP Residual norm 8.067537826361e-11
  1196 KSP Residual norm 8.622357125933e-11
  1197 KSP Residual norm 8.412820022654e-11
  1198 KSP Residual norm 8.112348323483e-11
  1199 KSP Residual norm 8.154581038652e-11
  1200 KSP Residual norm 8.706335192872e-11
  1201 KSP Residual norm 8.447054725618e-11
  1202 KSP Residual norm 7.724118069529e-11
  1203 KSP Residual norm 7.411960389970e-11
  1204 KSP Residual norm 7.543729877469e-11
  1205 KSP Residual norm 7.311925981364e-11
  1206 KSP Residual norm 6.941476000510e-11
  1207 KSP Residual norm 6.818238229188e-11
  1208 KSP Residual norm 6.818624709434e-11
  1209 KSP Residual norm 6.895336654532e-11
  1210 KSP Residual norm 6.680906918851e-11
  1211 KSP Residual norm 6.478996361213e-11
  1212 KSP Residual norm 6.275484748059e-11
  1213 KSP Residual norm 5.882549072828e-11
  1214 KSP Residual norm 5.667237302098e-11
  1215 KSP Residual norm 5.560566027770e-11
  1216 KSP Residual norm 5.677262811968e-11
  1217 KSP Residual norm 5.925752482481e-11
  1218 KSP Residual norm 6.093374373147e-11
  1219 KSP Residual norm 5.561110239316e-11
  1220 KSP Residual norm 5.004338363120e-11
  1221 KSP Residual norm 5.023474380083e-11
  1222 KSP Residual norm 5.188205042869e-11
  1223 KSP Residual norm 5.060198019439e-11
  1224 KSP Residual norm 4.747707982661e-11
  1225 KSP Residual norm 4.404904468818e-11
  1226 KSP Residual norm 4.149674942236e-11
  1227 KSP Residual norm 4.170716880284e-11
  1228 KSP Residual norm 4.336326415919e-11
  1229 KSP Residual norm 4.424919560952e-11
  1230 KSP Residual norm 4.693968400854e-11
  1231 KSP Residual norm 5.081520696434e-11
  1232 KSP Residual norm 5.593841637181e-11
  1233 KSP Residual norm 5.962831229778e-11
  1234 KSP Residual norm 6.284003277554e-11
  1235 KSP Residual norm 6.518585461858e-11
  1236 KSP Residual norm 7.253725859142e-11
  1237 KSP Residual norm 8.168930806136e-11
  1238 KSP Residual norm 8.821634436118e-11
  1239 KSP Residual norm 9.017144481000e-11
  1240 KSP Residual norm 8.364153335067e-11
  1241 KSP Residual norm 7.251020235481e-11
  1242 KSP Residual norm 6.516376464296e-11
  1243 KSP Residual norm 5.863485348560e-11
  1244 KSP Residual norm 5.533622447551e-11
  1245 KSP Residual norm 5.594684030422e-11
  1246 KSP Residual norm 5.575478407766e-11
  1247 KSP Residual norm 5.370876361827e-11
  1248 KSP Residual norm 5.088363611682e-11
  1249 KSP Residual norm 4.974082879213e-11
  1250 KSP Residual norm 4.968614173440e-11
  1251 KSP Residual norm 5.000691508005e-11
  1252 KSP Residual norm 5.188279568517e-11
  1253 KSP Residual norm 5.420189479710e-11
  1254 KSP Residual norm 5.745463020410e-11
  1255 KSP Residual norm 6.122499852708e-11
  1256 KSP Residual norm 5.869435965730e-11
  1257 KSP Residual norm 5.475717282743e-11
  1258 KSP Residual norm 5.548147909800e-11
  1259 KSP Residual norm 6.042692200772e-11
  1260 KSP Residual norm 6.073529236741e-11
  1261 KSP Residual norm 5.937409153576e-11
  1262 KSP Residual norm 5.822030769350e-11
  1263 KSP Residual norm 6.085427522775e-11
  1264 KSP Residual norm 6.499828725659e-11
  1265 KSP Residual norm 6.088528127384e-11
  1266 KSP Residual norm 5.346563602380e-11
  1267 KSP Residual norm 4.964251423195e-11
  1268 KSP Residual norm 4.813102228585e-11
  1269 KSP Residual norm 4.898451606505e-11
  1270 KSP Residual norm 5.135923313170e-11
  1271 KSP Residual norm 5.207291080755e-11
  1272 KSP Residual norm 5.528388309236e-11
  1273 KSP Residual norm 6.076704479728e-11
  1274 KSP Residual norm 6.551497089530e-11
  1275 KSP Residual norm 6.795455552311e-11
  1276 KSP Residual norm 6.562360529508e-11
  1277 KSP Residual norm 6.262558533399e-11
  1278 KSP Residual norm 5.918130092280e-11
  1279 KSP Residual norm 5.944335412715e-11
  1280 KSP Residual norm 6.372731648387e-11
  1281 KSP Residual norm 6.773464855994e-11
  1282 KSP Residual norm 6.994671750816e-11
  1283 KSP Residual norm 6.844513578006e-11
  1284 KSP Residual norm 6.434839578307e-11
  1285 KSP Residual norm 6.348697366731e-11
  1286 KSP Residual norm 6.263006197791e-11
  1287 KSP Residual norm 6.409211454301e-11
  1288 KSP Residual norm 6.723818923790e-11
  1289 KSP Residual norm 7.147719605310e-11
  1290 KSP Residual norm 7.531318784894e-11
  1291 KSP Residual norm 7.722784130899e-11
  1292 KSP Residual norm 7.816664567588e-11
  1293 KSP Residual norm 7.907723963319e-11
  1294 KSP Residual norm 7.621125387651e-11
  1295 KSP Residual norm 7.112229320293e-11
  1296 KSP Residual norm 6.709834973122e-11
  1297 KSP Residual norm 6.217948223014e-11
  1298 KSP Residual norm 6.251158409623e-11
  1299 KSP Residual norm 6.329160660033e-11
  1300 KSP Residual norm 6.122233371564e-11
  1301 KSP Residual norm 5.984253630579e-11
  1302 KSP Residual norm 5.900172232594e-11
  1303 KSP Residual norm 5.672039758740e-11
  1304 KSP Residual norm 5.574862872541e-11
  1305 KSP Residual norm 5.361354220343e-11
  1306 KSP Residual norm 5.377088040599e-11
  1307 KSP Residual norm 5.588623451823e-11
  1308 KSP Residual norm 5.747120052666e-11
  1309 KSP Residual norm 6.067295334689e-11
  1310 KSP Residual norm 6.384859635732e-11
  1311 KSP Residual norm 6.310341777068e-11
  1312 KSP Residual norm 5.830991254669e-11
  1313 KSP Residual norm 5.664240703641e-11
  1314 KSP Residual norm 5.937723401096e-11
  1315 KSP Residual norm 6.365819082483e-11
  1316 KSP Residual norm 6.373211964211e-11
  1317 KSP Residual norm 6.170333267718e-11
  1318 KSP Residual norm 5.979279405005e-11
  1319 KSP Residual norm 5.843167365927e-11
  1320 KSP Residual norm 5.672545999204e-11
  1321 KSP Residual norm 5.506594549561e-11
  1322 KSP Residual norm 5.164033773681e-11
  1323 KSP Residual norm 4.889023895512e-11
  1324 KSP Residual norm 4.925588299453e-11
  1325 KSP Residual norm 5.206318313321e-11
  1326 KSP Residual norm 5.604175265366e-11
  1327 KSP Residual norm 5.869427852544e-11
  1328 KSP Residual norm 5.558471988601e-11
  1329 KSP Residual norm 5.060340633242e-11
  1330 KSP Residual norm 4.714145744795e-11
  1331 KSP Residual norm 4.588248638026e-11
  1332 KSP Residual norm 4.647271469684e-11
  1333 KSP Residual norm 4.925900373786e-11
  1334 KSP Residual norm 5.057904596371e-11
  1335 KSP Residual norm 5.234022260567e-11
  1336 KSP Residual norm 5.325995949454e-11
  1337 KSP Residual norm 5.317434813284e-11
  1338 KSP Residual norm 5.191702846614e-11
  1339 KSP Residual norm 4.897471704247e-11
  1340 KSP Residual norm 4.813960513359e-11
  1341 KSP Residual norm 4.855388387461e-11
  1342 KSP Residual norm 4.599462972353e-11
  1343 KSP Residual norm 4.374881970369e-11
  1344 KSP Residual norm 4.156515429106e-11
  1345 KSP Residual norm 3.895489405473e-11
  1346 KSP Residual norm 3.890268026812e-11
  1347 KSP Residual norm 4.136861148277e-11
  1348 KSP Residual norm 4.480658150947e-11
  1349 KSP Residual norm 5.006162819140e-11
  1350 KSP Residual norm 4.942024962977e-11
  1351 KSP Residual norm 4.775597961287e-11
  1352 KSP Residual norm 4.648514825069e-11
  1353 KSP Residual norm 4.608697958732e-11
  1354 KSP Residual norm 4.917802547671e-11
  1355 KSP Residual norm 4.824196332672e-11
  1356 KSP Residual norm 4.680153692658e-11
  1357 KSP Residual norm 4.644762281857e-11
  1358 KSP Residual norm 4.632006199305e-11
  1359 KSP Residual norm 4.742777795788e-11
  1360 KSP Residual norm 4.837865339551e-11
  1361 KSP Residual norm 4.838156302088e-11
  1362 KSP Residual norm 4.724292198938e-11
  1363 KSP Residual norm 4.657984693394e-11
  1364 KSP Residual norm 4.364689605920e-11
  1365 KSP Residual norm 4.389591065852e-11
  1366 KSP Residual norm 4.602704010866e-11
  1367 KSP Residual norm 4.687679292430e-11
  1368 KSP Residual norm 4.622041138465e-11
  1369 KSP Residual norm 4.160480676259e-11
  1370 KSP Residual norm 3.673852490590e-11
  1371 KSP Residual norm 3.401836640249e-11
  1372 KSP Residual norm 3.430106439165e-11
  1373 KSP Residual norm 3.521297274493e-11
  1374 KSP Residual norm 3.398848156540e-11
  1375 KSP Residual norm 3.309361803380e-11
  1376 KSP Residual norm 3.349493768653e-11
  1377 KSP Residual norm 3.477463286600e-11
  1378 KSP Residual norm 3.508730728169e-11
  1379 KSP Residual norm 3.407909647317e-11
  1380 KSP Residual norm 3.140199538442e-11
  1381 KSP Residual norm 3.032291983113e-11
  1382 KSP Residual norm 2.985220889919e-11
  1383 KSP Residual norm 2.943609536448e-11
  1384 KSP Residual norm 3.023660508353e-11
  1385 KSP Residual norm 3.207694714330e-11
  1386 KSP Residual norm 3.107973980643e-11
  1387 KSP Residual norm 2.995569493004e-11
  1388 KSP Residual norm 2.994918615942e-11
  1389 KSP Residual norm 3.000370630672e-11
  1390 KSP Residual norm 2.898369471135e-11
  1391 KSP Residual norm 2.771908107131e-11
  1392 KSP Residual norm 2.911619782503e-11
  1393 KSP Residual norm 3.223861850551e-11
  1394 KSP Residual norm 3.375541451266e-11
  1395 KSP Residual norm 3.258241973401e-11
  1396 KSP Residual norm 3.189031351714e-11
  1397 KSP Residual norm 3.270424923303e-11
  1398 KSP Residual norm 3.179851172710e-11
  1399 KSP Residual norm 2.878278523803e-11
  1400 KSP Residual norm 2.832034562236e-11
  1401 KSP Residual norm 3.111959398167e-11
  1402 KSP Residual norm 3.450294410361e-11
  1403 KSP Residual norm 3.538518714304e-11
  1404 KSP Residual norm 3.211544745980e-11
  1405 KSP Residual norm 2.927393941786e-11
  1406 KSP Residual norm 2.847216185970e-11
  1407 KSP Residual norm 2.673748328135e-11
  1408 KSP Residual norm 2.421504025347e-11
  1409 KSP Residual norm 2.244606319266e-11
  1410 KSP Residual norm 2.163057581753e-11
  1411 KSP Residual norm 2.269083634779e-11
  1412 KSP Residual norm 2.520651337343e-11
  1413 KSP Residual norm 2.777649826291e-11
  1414 KSP Residual norm 2.863939481549e-11
  1415 KSP Residual norm 2.732093638839e-11
  1416 KSP Residual norm 2.728767698480e-11
  1417 KSP Residual norm 2.858027349526e-11
  1418 KSP Residual norm 2.867307570492e-11
  1419 KSP Residual norm 2.725788163399e-11
  1420 KSP Residual norm 2.606635531942e-11
  1421 KSP Residual norm 2.429601815287e-11
  1422 KSP Residual norm 2.174877744019e-11
  1423 KSP Residual norm 2.065817771683e-11
  1424 KSP Residual norm 2.159336542510e-11
  1425 KSP Residual norm 2.394758166542e-11
  1426 KSP Residual norm 2.593802033154e-11
  1427 KSP Residual norm 2.749139089143e-11
  1428 KSP Residual norm 2.806834714378e-11
  1429 KSP Residual norm 2.630380288207e-11
  1430 KSP Residual norm 2.484612708297e-11
  1431 KSP Residual norm 2.392286200592e-11
  1432 KSP Residual norm 2.403037929655e-11
  1433 KSP Residual norm 2.541950325507e-11
  1434 KSP Residual norm 2.788639621997e-11
  1435 KSP Residual norm 2.965177169216e-11
  1436 KSP Residual norm 3.041574894747e-11
  1437 KSP Residual norm 3.072785215675e-11
  1438 KSP Residual norm 3.310624061637e-11
  1439 KSP Residual norm 3.691330597709e-11
  1440 KSP Residual norm 3.712010771281e-11
  1441 KSP Residual norm 3.320808663621e-11
  1442 KSP Residual norm 2.964328803870e-11
  1443 KSP Residual norm 2.794577106536e-11
  1444 KSP Residual norm 2.854440239017e-11
  1445 KSP Residual norm 2.902941459050e-11
  1446 KSP Residual norm 2.744530268338e-11
  1447 KSP Residual norm 2.672687223569e-11
  1448 KSP Residual norm 2.801371361953e-11
  1449 KSP Residual norm 3.080483772655e-11
  1450 KSP Residual norm 3.309114705641e-11
  1451 KSP Residual norm 3.357368196619e-11
  1452 KSP Residual norm 3.303154836495e-11
  1453 KSP Residual norm 3.266008867137e-11
  1454 KSP Residual norm 3.301972640534e-11
  1455 KSP Residual norm 3.125199515467e-11
  1456 KSP Residual norm 2.979677344172e-11
  1457 KSP Residual norm 2.829202581782e-11
  1458 KSP Residual norm 2.773224969249e-11
  1459 KSP Residual norm 2.521497493726e-11
  1460 KSP Residual norm 2.282729831454e-11
  1461 KSP Residual norm 2.299547442838e-11
  1462 KSP Residual norm 2.501454377229e-11
  1463 KSP Residual norm 2.703885952792e-11
  1464 KSP Residual norm 2.797416274857e-11
  1465 KSP Residual norm 2.830179981005e-11
  1466 KSP Residual norm 3.025627164600e-11
  1467 KSP Residual norm 3.187428516745e-11
  1468 KSP Residual norm 3.078065480494e-11
  1469 KSP Residual norm 2.874915157805e-11
  1470 KSP Residual norm 2.762388703414e-11
  1471 KSP Residual norm 2.649582627983e-11
  1472 KSP Residual norm 2.704240088768e-11
  1473 KSP Residual norm 2.864315846463e-11
  1474 KSP Residual norm 2.897257884272e-11
  1475 KSP Residual norm 2.747701010956e-11
  1476 KSP Residual norm 2.666836462217e-11
  1477 KSP Residual norm 2.695829800995e-11
  1478 KSP Residual norm 3.053434935863e-11
  1479 KSP Residual norm 3.598820845699e-11
  1480 KSP Residual norm 3.765893267216e-11
  1481 KSP Residual norm 3.467521617809e-11
  1482 KSP Residual norm 3.052337971711e-11
  1483 KSP Residual norm 2.814163879082e-11
  1484 KSP Residual norm 2.772575792933e-11
  1485 KSP Residual norm 2.812504718796e-11
  1486 KSP Residual norm 2.775137737763e-11
  1487 KSP Residual norm 2.783011515919e-11
  1488 KSP Residual norm 3.002502109903e-11
  1489 KSP Residual norm 3.271777789294e-11
  1490 KSP Residual norm 3.664008296406e-11
  1491 KSP Residual norm 3.900039017270e-11
  1492 KSP Residual norm 3.638728742011e-11
  1493 KSP Residual norm 3.384389531936e-11
  1494 KSP Residual norm 3.114063530372e-11
  1495 KSP Residual norm 3.068808382847e-11
  1496 KSP Residual norm 3.444289642021e-11
  1497 KSP Residual norm 4.319965794469e-11
  1498 KSP Residual norm 5.075521002532e-11
  1499 KSP Residual norm 5.027477815867e-11
  1500 KSP Residual norm 4.493952993719e-11
  1501 KSP Residual norm 4.017880630228e-11
  1502 KSP Residual norm 3.710549316153e-11
  1503 KSP Residual norm 3.585014407402e-11
  1504 KSP Residual norm 3.692811419992e-11
  1505 KSP Residual norm 3.698431795929e-11
  1506 KSP Residual norm 3.467703478123e-11
  1507 KSP Residual norm 3.271708379039e-11
  1508 KSP Residual norm 3.133897019229e-11
  1509 KSP Residual norm 3.182786408871e-11
  1510 KSP Residual norm 3.407660285374e-11
  1511 KSP Residual norm 3.853490785694e-11
  1512 KSP Residual norm 4.368638379677e-11
  1513 KSP Residual norm 4.500511477964e-11
  1514 KSP Residual norm 4.392428749016e-11
  1515 KSP Residual norm 4.207449629175e-11
  1516 KSP Residual norm 3.787075973202e-11
  1517 KSP Residual norm 3.340000650597e-11
  1518 KSP Residual norm 3.030166034859e-11
  1519 KSP Residual norm 2.756948105011e-11
  1520 KSP Residual norm 2.496392043860e-11
  1521 KSP Residual norm 2.481008126916e-11
  1522 KSP Residual norm 2.831355831373e-11
  1523 KSP Residual norm 3.621062491559e-11
  1524 KSP Residual norm 4.695828492181e-11
  1525 KSP Residual norm 5.585391226767e-11
  1526 KSP Residual norm 5.988100223420e-11
  1527 KSP Residual norm 5.669928580340e-11
  1528 KSP Residual norm 5.119353256049e-11
  1529 KSP Residual norm 4.315188064721e-11
  1530 KSP Residual norm 3.616482128589e-11
  1531 KSP Residual norm 3.282678577329e-11
  1532 KSP Residual norm 3.161509240991e-11
  1533 KSP Residual norm 3.294008051507e-11
  1534 KSP Residual norm 3.615593372873e-11
  1535 KSP Residual norm 3.933613010667e-11
  1536 KSP Residual norm 3.994605192355e-11
  1537 KSP Residual norm 3.935046515920e-11
  1538 KSP Residual norm 3.952564541791e-11
  1539 KSP Residual norm 4.087214422067e-11
  1540 KSP Residual norm 4.284568250052e-11
  1541 KSP Residual norm 4.075779793887e-11
  1542 KSP Residual norm 3.589558446884e-11
  1543 KSP Residual norm 3.182527370981e-11
  1544 KSP Residual norm 2.930585407660e-11
  1545 KSP Residual norm 2.725557441410e-11
  1546 KSP Residual norm 2.488858603277e-11
  1547 KSP Residual norm 2.283622177416e-11
  1548 KSP Residual norm 2.253496994928e-11
  1549 KSP Residual norm 2.277359853803e-11
  1550 KSP Residual norm 2.317237489289e-11
  1551 KSP Residual norm 2.387534567051e-11
  1552 KSP Residual norm 2.460200305402e-11
  1553 KSP Residual norm 2.595059609423e-11
  1554 KSP Residual norm 2.802790157245e-11
  1555 KSP Residual norm 2.957084915308e-11
  1556 KSP Residual norm 3.141905718152e-11
  1557 KSP Residual norm 3.308939151054e-11
  1558 KSP Residual norm 3.265298233048e-11
  1559 KSP Residual norm 3.146389757611e-11
  1560 KSP Residual norm 3.155831679037e-11
  1561 KSP Residual norm 3.491764815514e-11
  1562 KSP Residual norm 3.809069285049e-11
  1563 KSP Residual norm 3.930824446404e-11
  1564 KSP Residual norm 3.747276133215e-11
  1565 KSP Residual norm 3.246307697024e-11
  1566 KSP Residual norm 2.854751960405e-11
  1567 KSP Residual norm 2.691847380379e-11
  1568 KSP Residual norm 2.712681159762e-11
  1569 KSP Residual norm 2.884262850746e-11
  1570 KSP Residual norm 3.279691580764e-11
  1571 KSP Residual norm 3.630357691665e-11
  1572 KSP Residual norm 3.945290037455e-11
  1573 KSP Residual norm 4.282388985784e-11
  1574 KSP Residual norm 4.368630280859e-11
  1575 KSP Residual norm 4.083999329904e-11
  1576 KSP Residual norm 3.753898603556e-11
  1577 KSP Residual norm 3.395497515106e-11
  1578 KSP Residual norm 2.981920923298e-11
  1579 KSP Residual norm 2.955852447007e-11
  1580 KSP Residual norm 3.412834800693e-11
  1581 KSP Residual norm 4.347404111469e-11
  1582 KSP Residual norm 5.184624968067e-11
  1583 KSP Residual norm 4.653887914245e-11
  1584 KSP Residual norm 3.499044185267e-11
  1585 KSP Residual norm 2.839030300144e-11
  1586 KSP Residual norm 2.806700484554e-11
  1587 KSP Residual norm 3.270415336715e-11
  1588 KSP Residual norm 4.080762992750e-11
  1589 KSP Residual norm 4.738497674959e-11
  1590 KSP Residual norm 4.643437058747e-11
  1591 KSP Residual norm 3.868220609496e-11
  1592 KSP Residual norm 3.414665614423e-11
  1593 KSP Residual norm 3.533824530226e-11
  1594 KSP Residual norm 3.877626134923e-11
  1595 KSP Residual norm 3.881883663426e-11
  1596 KSP Residual norm 3.369100127839e-11
  1597 KSP Residual norm 2.862743379353e-11
  1598 KSP Residual norm 2.711072883465e-11
  1599 KSP Residual norm 2.991104056452e-11
  1600 KSP Residual norm 3.815453531513e-11
  1601 KSP Residual norm 4.445839858471e-11
  1602 KSP Residual norm 4.220488864059e-11
  1603 KSP Residual norm 3.670186384085e-11
  1604 KSP Residual norm 3.428597446211e-11
  1605 KSP Residual norm 3.438934861919e-11
  1606 KSP Residual norm 3.516442529147e-11
  1607 KSP Residual norm 3.613454785533e-11
  1608 KSP Residual norm 3.837435487112e-11
  1609 KSP Residual norm 3.898085368523e-11
  1610 KSP Residual norm 3.825744659302e-11
  1611 KSP Residual norm 3.659555902035e-11
  1612 KSP Residual norm 3.280516930504e-11
  1613 KSP Residual norm 2.804445548731e-11
  1614 KSP Residual norm 2.522611289025e-11
  1615 KSP Residual norm 2.672671577127e-11
  1616 KSP Residual norm 3.107085900950e-11
  1617 KSP Residual norm 3.536169025791e-11
  1618 KSP Residual norm 4.196042641887e-11
  1619 KSP Residual norm 5.078724052572e-11
  1620 KSP Residual norm 5.340604617379e-11
  1621 KSP Residual norm 4.505452305325e-11
  1622 KSP Residual norm 3.550621552497e-11
  1623 KSP Residual norm 3.045718485390e-11
  1624 KSP Residual norm 3.115462016558e-11
  1625 KSP Residual norm 3.512956686598e-11
  1626 KSP Residual norm 4.034184914264e-11
  1627 KSP Residual norm 4.414619457890e-11
  1628 KSP Residual norm 4.111279098890e-11
  1629 KSP Residual norm 3.258370781084e-11
  1630 KSP Residual norm 2.686627278892e-11
  1631 KSP Residual norm 2.658505258504e-11
  1632 KSP Residual norm 3.245664219568e-11
  1633 KSP Residual norm 4.017130769837e-11
  1634 KSP Residual norm 4.432591891277e-11
  1635 KSP Residual norm 4.706858895655e-11
  1636 KSP Residual norm 4.836020531302e-11
  1637 KSP Residual norm 4.540688968950e-11
  1638 KSP Residual norm 4.207109431139e-11
  1639 KSP Residual norm 4.150313214986e-11
  1640 KSP Residual norm 4.131502709810e-11
  1641 KSP Residual norm 3.855983356827e-11
  1642 KSP Residual norm 2.985734288986e-11
  1643 KSP Residual norm 2.145577783988e-11
  1644 KSP Residual norm 1.872286564931e-11
  1645 KSP Residual norm 2.139014940222e-11
  1646 KSP Residual norm 2.835840706730e-11
  1647 KSP Residual norm 3.924135910021e-11
  1648 KSP Residual norm 5.144276913250e-11
  1649 KSP Residual norm 5.536070304802e-11
  1650 KSP Residual norm 4.830633315153e-11
  1651 KSP Residual norm 3.775126809654e-11
  1652 KSP Residual norm 2.791214472150e-11
  1653 KSP Residual norm 2.259655560261e-11
  1654 KSP Residual norm 2.255736694278e-11
  1655 KSP Residual norm 2.803739036615e-11
  1656 KSP Residual norm 3.813180897992e-11
  1657 KSP Residual norm 4.881271832385e-11
  1658 KSP Residual norm 4.722560642665e-11
  1659 KSP Residual norm 3.505735235567e-11
  1660 KSP Residual norm 2.461051177100e-11
  1661 KSP Residual norm 2.007860995089e-11
  1662 KSP Residual norm 2.024901373181e-11
  1663 KSP Residual norm 2.473991686929e-11
  1664 KSP Residual norm 3.364600255089e-11
  1665 KSP Residual norm 4.500327345721e-11
  1666 KSP Residual norm 4.700782746664e-11
  1667 KSP Residual norm 3.746486575550e-11
  1668 KSP Residual norm 2.361566781339e-11
  1669 KSP Residual norm 1.507023527700e-11
  1670 KSP Residual norm 1.274811563609e-11
  1671 KSP Residual norm 1.496339940879e-11
  1672 KSP Residual norm 2.176045502602e-11
  1673 KSP Residual norm 3.214339757779e-11
  1674 KSP Residual norm 3.686898219120e-11
  1675 KSP Residual norm 3.154820389403e-11
  1676 KSP Residual norm 2.415041492653e-11
  1677 KSP Residual norm 1.935630756761e-11
  1678 KSP Residual norm 1.753965388418e-11
  1679 KSP Residual norm 1.964641852536e-11
  1680 KSP Residual norm 2.686321427461e-11
  1681 KSP Residual norm 4.266527903526e-11
  1682 KSP Residual norm 6.021987310490e-11
  1683 KSP Residual norm 5.819873273258e-11
  1684 KSP Residual norm 3.920364130220e-11
  1685 KSP Residual norm 2.349727326674e-11
  1686 KSP Residual norm 1.516657162431e-11
  1687 KSP Residual norm 1.339440859578e-11
  1688 KSP Residual norm 1.807706764556e-11
  1689 KSP Residual norm 3.363536440113e-11
  1690 KSP Residual norm 6.162377039182e-11
  1691 KSP Residual norm 8.996466611310e-11
  1692 KSP Residual norm 8.645644488124e-11
  1693 KSP Residual norm 5.594241441521e-11
  1694 KSP Residual norm 3.496918386578e-11
  1695 KSP Residual norm 2.627472459740e-11
  1696 KSP Residual norm 2.599432569200e-11
  1697 KSP Residual norm 3.724913399350e-11
  1698 KSP Residual norm 6.483144055940e-11
  1699 KSP Residual norm 1.118075869119e-10
  1700 KSP Residual norm 1.586655331099e-10
  1701 KSP Residual norm 1.559009013628e-10
  1702 KSP Residual norm 9.684452744993e-11
  1703 KSP Residual norm 5.435865088920e-11
  1704 KSP Residual norm 3.680532700545e-11
  1705 KSP Residual norm 3.599508311057e-11
  1706 KSP Residual norm 5.183398549765e-11
  1707 KSP Residual norm 8.969043427494e-11
  1708 KSP Residual norm 1.295817789085e-10
  1709 KSP Residual norm 1.137013855868e-10
  1710 KSP Residual norm 6.576301467083e-11
  1711 KSP Residual norm 3.723847573454e-11
  1712 KSP Residual norm 2.706350953573e-11
  1713 KSP Residual norm 2.711020096141e-11
  1714 KSP Residual norm 3.377544703905e-11
  1715 KSP Residual norm 4.333180008162e-11
  1716 KSP Residual norm 4.461110637379e-11
  1717 KSP Residual norm 4.307497993672e-11
  1718 KSP Residual norm 4.921528950738e-11
  1719 KSP Residual norm 6.255500857736e-11
  1720 KSP Residual norm 6.585464979415e-11
  1721 KSP Residual norm 5.571965193549e-11
  1722 KSP Residual norm 4.532119216389e-11
  1723 KSP Residual norm 3.767729826496e-11
  1724 KSP Residual norm 3.376185846303e-11
  1725 KSP Residual norm 3.232789232215e-11
  1726 KSP Residual norm 3.110234690725e-11
  1727 KSP Residual norm 2.986589828327e-11
  1728 KSP Residual norm 3.037016598609e-11
  1729 KSP Residual norm 3.363073738525e-11
  1730 KSP Residual norm 4.479992602860e-11
  1731 KSP Residual norm 5.948664567830e-11
  1732 KSP Residual norm 6.936383586950e-11
  1733 KSP Residual norm 6.838459588723e-11
  1734 KSP Residual norm 6.211413432684e-11
  1735 KSP Residual norm 6.272749308915e-11
  1736 KSP Residual norm 6.773951442776e-11
  1737 KSP Residual norm 6.082588216308e-11
  1738 KSP Residual norm 4.421927208088e-11
  1739 KSP Residual norm 2.990315460770e-11
  1740 KSP Residual norm 2.365150490993e-11
  1741 KSP Residual norm 2.494387564904e-11
  1742 KSP Residual norm 3.401479761332e-11
  1743 KSP Residual norm 4.655423096847e-11
  1744 KSP Residual norm 5.136038391311e-11
  1745 KSP Residual norm 5.503272514558e-11
  1746 KSP Residual norm 7.101058823487e-11
  1747 KSP Residual norm 1.000762885889e-10
  1748 KSP Residual norm 1.189732676121e-10
  1749 KSP Residual norm 1.166621873421e-10
  1750 KSP Residual norm 1.142690385730e-10
  1751 KSP Residual norm 1.211710416190e-10
  1752 KSP Residual norm 1.179152930317e-10
  1753 KSP Residual norm 9.187785552458e-11
  1754 KSP Residual norm 6.699641828491e-11
  1755 KSP Residual norm 5.631786572253e-11
  1756 KSP Residual norm 5.560577816065e-11
  1757 KSP Residual norm 5.809043157951e-11
  1758 KSP Residual norm 5.213072564740e-11
  1759 KSP Residual norm 4.410644361859e-11
  1760 KSP Residual norm 4.512867413365e-11
  1761 KSP Residual norm 5.839645693174e-11
  1762 KSP Residual norm 8.170908547606e-11
  1763 KSP Residual norm 9.811170287370e-11
  1764 KSP Residual norm 1.032115914331e-10
  1765 KSP Residual norm 1.094448628444e-10
  1766 KSP Residual norm 1.337184242182e-10
  1767 KSP Residual norm 1.681709984990e-10
  1768 KSP Residual norm 1.692105553005e-10
  1769 KSP Residual norm 1.300398938708e-10
  1770 KSP Residual norm 9.983917051717e-11
  1771 KSP Residual norm 9.208177844164e-11
  1772 KSP Residual norm 9.299642524475e-11
  1773 KSP Residual norm 8.157379402152e-11
  1774 KSP Residual norm 5.848566077420e-11
  1775 KSP Residual norm 4.503831887317e-11
  1776 KSP Residual norm 4.341968992818e-11
  1777 KSP Residual norm 5.269820923466e-11
  1778 KSP Residual norm 6.454923119906e-11
  1779 KSP Residual norm 6.698842002430e-11
  1780 KSP Residual norm 6.903774516870e-11
  1781 KSP Residual norm 8.238263330312e-11
  1782 KSP Residual norm 1.041286837212e-10
  1783 KSP Residual norm 1.122779875998e-10
  1784 KSP Residual norm 9.630279885568e-11
  1785 KSP Residual norm 8.720426091165e-11
  1786 KSP Residual norm 9.356262561369e-11
  1787 KSP Residual norm 9.742737192669e-11
  1788 KSP Residual norm 8.387858903026e-11
  1789 KSP Residual norm 6.164097393624e-11
  1790 KSP Residual norm 5.063554535933e-11
  1791 KSP Residual norm 5.075612877868e-11
  1792 KSP Residual norm 5.234026025485e-11
  1793 KSP Residual norm 4.962657577037e-11
  1794 KSP Residual norm 4.332942543987e-11
  1795 KSP Residual norm 4.456266950221e-11
  1796 KSP Residual norm 5.433897045262e-11
  1797 KSP Residual norm 6.166950860396e-11
  1798 KSP Residual norm 5.808670693040e-11
  1799 KSP Residual norm 5.674868055482e-11
  1800 KSP Residual norm 6.645064426718e-11
  1801 KSP Residual norm 9.585295839347e-11
  1802 KSP Residual norm 1.391019482444e-10
  1803 KSP Residual norm 1.638573687544e-10
  1804 KSP Residual norm 1.764041478527e-10
  1805 KSP Residual norm 2.082193665996e-10
  1806 KSP Residual norm 2.638468322320e-10
  1807 KSP Residual norm 2.797077315284e-10
  1808 KSP Residual norm 2.205612332058e-10
  1809 KSP Residual norm 1.611740214537e-10
  1810 KSP Residual norm 1.371653681184e-10
  1811 KSP Residual norm 1.342650196247e-10
  1812 KSP Residual norm 1.244307943761e-10
  1813 KSP Residual norm 9.627299112407e-11
  1814 KSP Residual norm 6.836646352054e-11
  1815 KSP Residual norm 5.659794118851e-11
  1816 KSP Residual norm 5.598833626005e-11
  1817 KSP Residual norm 5.450863116080e-11
  1818 KSP Residual norm 4.575449672464e-11
  1819 KSP Residual norm 3.910121712738e-11
  1820 KSP Residual norm 4.201002686819e-11
  1821 KSP Residual norm 5.564772551282e-11
  1822 KSP Residual norm 6.967548378483e-11
  1823 KSP Residual norm 6.935700004202e-11
  1824 KSP Residual norm 7.029884443443e-11
  1825 KSP Residual norm 8.586880534868e-11
  1826 KSP Residual norm 1.201439185439e-10
  1827 KSP Residual norm 1.436555586520e-10
  1828 KSP Residual norm 1.334070616778e-10
  1829 KSP Residual norm 1.249784775403e-10
  1830 KSP Residual norm 1.350943254274e-10
  1831 KSP Residual norm 1.554012535051e-10
  1832 KSP Residual norm 1.418581070564e-10
  1833 KSP Residual norm 1.148504635681e-10
  1834 KSP Residual norm 1.013863617211e-10
  1835 KSP Residual norm 1.005605962819e-10
  1836 KSP Residual norm 9.587188184788e-11
  1837 KSP Residual norm 7.403186593625e-11
  1838 KSP Residual norm 5.720392939436e-11
  1839 KSP Residual norm 5.326893756025e-11
  1840 KSP Residual norm 5.683229152558e-11
  1841 KSP Residual norm 6.158025175850e-11
  1842 KSP Residual norm 5.907703940620e-11
  1843 KSP Residual norm 5.708358098481e-11
  1844 KSP Residual norm 6.314949806320e-11
  1845 KSP Residual norm 7.543793491315e-11
  1846 KSP Residual norm 8.138171034217e-11
  1847 KSP Residual norm 8.558566858840e-11
  1848 KSP Residual norm 1.021396617329e-10
  1849 KSP Residual norm 1.399082343679e-10
  1850 KSP Residual norm 1.720169796611e-10
  1851 KSP Residual norm 1.719575494536e-10
  1852 KSP Residual norm 1.819918975082e-10
  1853 KSP Residual norm 2.268386698900e-10
  1854 KSP Residual norm 2.779076825646e-10
  1855 KSP Residual norm 2.680012756453e-10
  1856 KSP Residual norm 2.251701725886e-10
  1857 KSP Residual norm 2.031711858446e-10
  1858 KSP Residual norm 2.069820003424e-10
  1859 KSP Residual norm 1.835049019101e-10
  1860 KSP Residual norm 1.420745589240e-10
  1861 KSP Residual norm 1.241201488597e-10
  1862 KSP Residual norm 1.236025394327e-10
  1863 KSP Residual norm 1.183578001551e-10
  1864 KSP Residual norm 9.231771775263e-11
  1865 KSP Residual norm 6.993237048022e-11
  1866 KSP Residual norm 6.531940008196e-11
  1867 KSP Residual norm 7.424691709638e-11
  1868 KSP Residual norm 8.174044023224e-11
  1869 KSP Residual norm 8.306160093690e-11
  1870 KSP Residual norm 8.899751858933e-11
  1871 KSP Residual norm 1.071921867869e-10
  1872 KSP Residual norm 1.296764478521e-10
  1873 KSP Residual norm 1.395024963873e-10
  1874 KSP Residual norm 1.469610784310e-10
  1875 KSP Residual norm 1.691079752839e-10
  1876 KSP Residual norm 1.970734259586e-10
  1877 KSP Residual norm 2.063061409858e-10
  1878 KSP Residual norm 1.959531000573e-10
  1879 KSP Residual norm 2.032812940376e-10
  1880 KSP Residual norm 2.328222209669e-10
  1881 KSP Residual norm 2.414616682665e-10
  1882 KSP Residual norm 2.096503821730e-10
  1883 KSP Residual norm 1.890254577129e-10
  1884 KSP Residual norm 1.824033703721e-10
  1885 KSP Residual norm 1.714173536165e-10
  1886 KSP Residual norm 1.455324140427e-10
  1887 KSP Residual norm 1.294755142389e-10
  1888 KSP Residual norm 1.245296730865e-10
  1889 KSP Residual norm 1.229687221037e-10
  1890 KSP Residual norm 1.054702775926e-10
  1891 KSP Residual norm 8.319660808855e-11
  1892 KSP Residual norm 7.285733574077e-11
  1893 KSP Residual norm 7.533674992509e-11
  1894 KSP Residual norm 7.613073266344e-11
  1895 KSP Residual norm 7.110135267061e-11
  1896 KSP Residual norm 7.201050300051e-11
  1897 KSP Residual norm 7.936507819547e-11
  1898 KSP Residual norm 8.275048609760e-11
  1899 KSP Residual norm 8.290109543377e-11
  1900 KSP Residual norm 8.834180743366e-11
  1901 KSP Residual norm 1.033493471375e-10
  1902 KSP Residual norm 1.188305820930e-10
  1903 KSP Residual norm 1.326742091115e-10
  1904 KSP Residual norm 1.396674441527e-10
  1905 KSP Residual norm 1.566418286199e-10
  1906 KSP Residual norm 1.827732608008e-10
  1907 KSP Residual norm 1.974669067479e-10
  1908 KSP Residual norm 1.938611996790e-10
  1909 KSP Residual norm 1.915562247969e-10
  1910 KSP Residual norm 1.842053303867e-10
  1911 KSP Residual norm 1.633773303297e-10
  1912 KSP Residual norm 1.452560785537e-10
  1913 KSP Residual norm 1.380318952387e-10
  1914 KSP Residual norm 1.363002069024e-10
  1915 KSP Residual norm 1.206836584703e-10
  1916 KSP Residual norm 9.974435151093e-11
  1917 KSP Residual norm 8.882801331267e-11
  1918 KSP Residual norm 8.292350786833e-11
  1919 KSP Residual norm 7.780037926348e-11
  1920 KSP Residual norm 7.407145515503e-11
  1921 KSP Residual norm 7.519067424956e-11
  1922 KSP Residual norm 8.107455076648e-11
  1923 KSP Residual norm 8.359693262964e-11
  1924 KSP Residual norm 7.887408595720e-11
  1925 KSP Residual norm 7.837516108684e-11
  1926 KSP Residual norm 9.171697252375e-11
  1927 KSP Residual norm 1.102688129402e-10
  1928 KSP Residual norm 1.176160343324e-10
  1929 KSP Residual norm 1.221261929950e-10
  1930 KSP Residual norm 1.455915938973e-10
  1931 KSP Residual norm 1.792715255549e-10
  1932 KSP Residual norm 1.898884877683e-10
  1933 KSP Residual norm 1.783373966337e-10
  1934 KSP Residual norm 1.821832691090e-10
  1935 KSP Residual norm 2.063352135026e-10
  1936 KSP Residual norm 2.222825639375e-10
  1937 KSP Residual norm 2.308025170114e-10
  1938 KSP Residual norm 2.351817038011e-10
  1939 KSP Residual norm 2.285004089208e-10
  1940 KSP Residual norm 2.048432638639e-10
  1941 KSP Residual norm 1.789156584146e-10
  1942 KSP Residual norm 1.686654993699e-10
  1943 KSP Residual norm 1.618209830643e-10
  1944 KSP Residual norm 1.450590685950e-10
  1945 KSP Residual norm 1.236932116584e-10
  1946 KSP Residual norm 1.109158508351e-10
  1947 KSP Residual norm 1.059496835659e-10
  1948 KSP Residual norm 1.037999090730e-10
  1949 KSP Residual norm 9.308779047236e-11
  1950 KSP Residual norm 8.116334665689e-11
  1951 KSP Residual norm 7.191585428170e-11
  1952 KSP Residual norm 6.588810591171e-11
  1953 KSP Residual norm 5.625006219301e-11
  1954 KSP Residual norm 4.905248307638e-11
  1955 KSP Residual norm 4.828778868116e-11
  1956 KSP Residual norm 5.672705750343e-11
  1957 KSP Residual norm 6.860083397404e-11
  1958 KSP Residual norm 7.308924598252e-11
  1959 KSP Residual norm 7.524524160838e-11
  1960 KSP Residual norm 8.633966787895e-11
  1961 KSP Residual norm 1.047479149424e-10
  1962 KSP Residual norm 1.139789025381e-10
  1963 KSP Residual norm 1.157696763288e-10
  1964 KSP Residual norm 1.300239102695e-10
  1965 KSP Residual norm 1.505530582577e-10
  1966 KSP Residual norm 1.669549427103e-10
  1967 KSP Residual norm 1.727162723745e-10
  1968 KSP Residual norm 1.833793971041e-10
  1969 KSP Residual norm 2.018894563158e-10
  1970 KSP Residual norm 2.160147223282e-10
  1971 KSP Residual norm 2.198345386089e-10
  1972 KSP Residual norm 2.189813501640e-10
  1973 KSP Residual norm 2.279090897322e-10
  1974 KSP Residual norm 2.276584245505e-10
  1975 KSP Residual norm 2.171969493039e-10
  1976 KSP Residual norm 2.113114730185e-10
  1977 KSP Residual norm 2.032912827689e-10
  1978 KSP Residual norm 1.756699673372e-10
  1979 KSP Residual norm 1.417074875890e-10
  1980 KSP Residual norm 1.315657687131e-10
  1981 KSP Residual norm 1.295456869918e-10
  1982 KSP Residual norm 1.134509726205e-10
  1983 KSP Residual norm 9.096452370523e-11
  1984 KSP Residual norm 7.695118035297e-11
  1985 KSP Residual norm 7.233319017844e-11
  1986 KSP Residual norm 6.678849183872e-11
  1987 KSP Residual norm 5.895147448799e-11
  1988 KSP Residual norm 5.307891669691e-11
  1989 KSP Residual norm 5.227623776605e-11
  1990 KSP Residual norm 5.551593346879e-11
  1991 KSP Residual norm 5.559290659743e-11
  1992 KSP Residual norm 5.491150729404e-11
  1993 KSP Residual norm 5.931771545135e-11
  1994 KSP Residual norm 7.027863320513e-11
  1995 KSP Residual norm 7.284349584872e-11
  1996 KSP Residual norm 7.255055832227e-11
  1997 KSP Residual norm 7.569347573341e-11
  1998 KSP Residual norm 8.522599457897e-11
  1999 KSP Residual norm 9.794099350455e-11
  2000 KSP Residual norm 1.090264518368e-10
  2001 KSP Residual norm 1.222210633486e-10
  2002 KSP Residual norm 1.336866469837e-10
  2003 KSP Residual norm 1.488144480910e-10
  2004 KSP Residual norm 1.651613034836e-10
  2005 KSP Residual norm 1.848777920508e-10
  2006 KSP Residual norm 2.167251724008e-10
  2007 KSP Residual norm 2.429278157763e-10
  2008 KSP Residual norm 2.543815894735e-10
  2009 KSP Residual norm 2.683818593290e-10
  2010 KSP Residual norm 2.915078352686e-10
  2011 KSP Residual norm 3.043662932702e-10
  2012 KSP Residual norm 3.084880532941e-10
  2013 KSP Residual norm 3.147027126994e-10
  2014 KSP Residual norm 3.115499246668e-10
  2015 KSP Residual norm 2.871054839937e-10
  2016 KSP Residual norm 2.650312322881e-10
  2017 KSP Residual norm 2.448722693906e-10
  2018 KSP Residual norm 2.167797523305e-10
  2019 KSP Residual norm 1.887962285832e-10
  2020 KSP Residual norm 1.637317380160e-10
  2021 KSP Residual norm 1.464218560842e-10
  2022 KSP Residual norm 1.314096150149e-10
  2023 KSP Residual norm 1.138798682243e-10
  2024 KSP Residual norm 1.026866628386e-10
  2025 KSP Residual norm 9.894343372465e-11
  2026 KSP Residual norm 1.036739297618e-10
  2027 KSP Residual norm 1.026777499986e-10
  2028 KSP Residual norm 9.579797793044e-11
  2029 KSP Residual norm 9.203657598416e-11
  2030 KSP Residual norm 1.005490308197e-10
  2031 KSP Residual norm 1.195047034194e-10
  2032 KSP Residual norm 1.370047833312e-10
  2033 KSP Residual norm 1.383078359003e-10
  2034 KSP Residual norm 1.455992384589e-10
  2035 KSP Residual norm 1.720014107699e-10
  2036 KSP Residual norm 1.971189376993e-10
  2037 KSP Residual norm 2.066768165713e-10
  2038 KSP Residual norm 2.285338454504e-10
  2039 KSP Residual norm 2.860106297261e-10
  2040 KSP Residual norm 3.502781069065e-10
  2041 KSP Residual norm 3.792965527783e-10
  2042 KSP Residual norm 4.055190871207e-10
  2043 KSP Residual norm 4.529237267325e-10
  2044 KSP Residual norm 4.758930272450e-10
  2045 KSP Residual norm 4.339312633502e-10
  2046 KSP Residual norm 4.113783731372e-10
  2047 KSP Residual norm 4.258310034508e-10
  2048 KSP Residual norm 4.172245905588e-10
  2049 KSP Residual norm 3.819415417058e-10
  2050 KSP Residual norm 3.355809192200e-10
  2051 KSP Residual norm 3.136052701437e-10
  2052 KSP Residual norm 3.103385933848e-10
  2053 KSP Residual norm 2.809161155608e-10
  2054 KSP Residual norm 2.284477350563e-10
  2055 KSP Residual norm 2.038255480305e-10
  2056 KSP Residual norm 2.039259222550e-10
  2057 KSP Residual norm 1.822560887525e-10
  2058 KSP Residual norm 1.602128574653e-10
  2059 KSP Residual norm 1.610492663859e-10
  2060 KSP Residual norm 1.623492067980e-10
  2061 KSP Residual norm 1.407130927385e-10
  2062 KSP Residual norm 1.163613966376e-10
  2063 KSP Residual norm 1.035935360281e-10
  2064 KSP Residual norm 9.917776804124e-11
  2065 KSP Residual norm 9.395269868296e-11
  2066 KSP Residual norm 9.280433125092e-11
  2067 KSP Residual norm 9.439385281818e-11
  2068 KSP Residual norm 9.619705843289e-11
  2069 KSP Residual norm 9.130026736257e-11
  2070 KSP Residual norm 8.797158306378e-11
  2071 KSP Residual norm 9.180409586536e-11
  2072 KSP Residual norm 1.040815599986e-10
  2073 KSP Residual norm 1.147104506829e-10
  2074 KSP Residual norm 1.184494011657e-10
  2075 KSP Residual norm 1.235317886114e-10
  2076 KSP Residual norm 1.419747323768e-10
  2077 KSP Residual norm 1.708297448056e-10
  2078 KSP Residual norm 1.855633410631e-10
  2079 KSP Residual norm 1.849002310169e-10
  2080 KSP Residual norm 1.920435388186e-10
  2081 KSP Residual norm 2.173952157144e-10
  2082 KSP Residual norm 2.226396729497e-10
  2083 KSP Residual norm 2.156840564653e-10
  2084 KSP Residual norm 2.140631542892e-10
  2085 KSP Residual norm 2.182642611950e-10
  2086 KSP Residual norm 2.096874291607e-10
  2087 KSP Residual norm 1.898832946013e-10
  2088 KSP Residual norm 1.810129464174e-10
  2089 KSP Residual norm 1.784759584142e-10
  2090 KSP Residual norm 1.669028061626e-10
  2091 KSP Residual norm 1.453465148264e-10
  2092 KSP Residual norm 1.320992233306e-10
  2093 KSP Residual norm 1.335668219344e-10
  2094 KSP Residual norm 1.331766050820e-10
  2095 KSP Residual norm 1.135386327476e-10
  2096 KSP Residual norm 9.982030233435e-11
  2097 KSP Residual norm 9.991809412648e-11
  2098 KSP Residual norm 1.006454093342e-10
  2099 KSP Residual norm 9.548728734724e-11
  2100 KSP Residual norm 8.700424690934e-11
  2101 KSP Residual norm 8.635180284336e-11
  2102 KSP Residual norm 9.132753533364e-11
  2103 KSP Residual norm 8.866013819529e-11
  2104 KSP Residual norm 7.810133400059e-11
  2105 KSP Residual norm 7.758472775974e-11
  2106 KSP Residual norm 8.420385421331e-11
  2107 KSP Residual norm 8.219259216674e-11
  2108 KSP Residual norm 8.004277397670e-11
  2109 KSP Residual norm 9.028722430798e-11
  2110 KSP Residual norm 1.008145586295e-10
  2111 KSP Residual norm 1.027810548114e-10
  2112 KSP Residual norm 1.077806213331e-10
  2113 KSP Residual norm 1.210004751337e-10
  2114 KSP Residual norm 1.385760197801e-10
  2115 KSP Residual norm 1.544739183311e-10
  2116 KSP Residual norm 1.561219571506e-10
  2117 KSP Residual norm 1.630509075295e-10
  2118 KSP Residual norm 1.906306268967e-10
  2119 KSP Residual norm 2.210444213755e-10
  2120 KSP Residual norm 2.346943876231e-10
  2121 KSP Residual norm 2.586014662113e-10
  2122 KSP Residual norm 2.933911383561e-10
  2123 KSP Residual norm 2.975351636786e-10
  2124 KSP Residual norm 2.972922840815e-10
  2125 KSP Residual norm 3.210992324256e-10
  2126 KSP Residual norm 3.413600628509e-10
  2127 KSP Residual norm 3.261822314442e-10
  2128 KSP Residual norm 3.122359096875e-10
  2129 KSP Residual norm 3.122783960999e-10
  2130 KSP Residual norm 3.106930144919e-10
  2131 KSP Residual norm 2.861978818888e-10
  2132 KSP Residual norm 2.543585633919e-10
  2133 KSP Residual norm 2.354930160544e-10
  2134 KSP Residual norm 2.337761728229e-10
  2135 KSP Residual norm 2.301780846776e-10
  2136 KSP Residual norm 2.051043332576e-10
  2137 KSP Residual norm 1.930328802456e-10
  2138 KSP Residual norm 1.914244625060e-10
  2139 KSP Residual norm 1.867133248933e-10
  2140 KSP Residual norm 1.737722527371e-10
  2141 KSP Residual norm 1.664834596357e-10
  2142 KSP Residual norm 1.699526348903e-10
  2143 KSP Residual norm 1.657152676381e-10
  2144 KSP Residual norm 1.581291107719e-10
  2145 KSP Residual norm 1.541609027014e-10
  2146 KSP Residual norm 1.631130581822e-10
  2147 KSP Residual norm 1.716883179138e-10
  2148 KSP Residual norm 1.759148951415e-10
  2149 KSP Residual norm 1.824679548897e-10
  2150 KSP Residual norm 1.948007607072e-10
  2151 KSP Residual norm 2.041784968468e-10
  2152 KSP Residual norm 2.240608271444e-10
  2153 KSP Residual norm 2.488840856820e-10
  2154 KSP Residual norm 2.737311786205e-10
  2155 KSP Residual norm 2.954914653271e-10
  2156 KSP Residual norm 3.143007018616e-10
  2157 KSP Residual norm 3.276300163631e-10
  2158 KSP Residual norm 3.559758190923e-10
  2159 KSP Residual norm 3.944726619021e-10
  2160 KSP Residual norm 3.981329171558e-10
  2161 KSP Residual norm 3.871500912897e-10
  2162 KSP Residual norm 3.908449560096e-10
  2163 KSP Residual norm 4.045307063583e-10
  2164 KSP Residual norm 3.967024757667e-10
  2165 KSP Residual norm 3.736716466868e-10
  2166 KSP Residual norm 3.505462125125e-10
  2167 KSP Residual norm 3.563967579342e-10
  2168 KSP Residual norm 3.373101782276e-10
  2169 KSP Residual norm 2.963070237795e-10
  2170 KSP Residual norm 2.689035293488e-10
  2171 KSP Residual norm 2.689315942289e-10
  2172 KSP Residual norm 2.660704460402e-10
  2173 KSP Residual norm 2.429375934432e-10
  2174 KSP Residual norm 2.263358766855e-10
  2175 KSP Residual norm 2.217179618254e-10
  2176 KSP Residual norm 2.138896092436e-10
  2177 KSP Residual norm 1.944626847933e-10
  2178 KSP Residual norm 1.770169096739e-10
  2179 KSP Residual norm 1.680106575919e-10
  2180 KSP Residual norm 1.607372387657e-10
  2181 KSP Residual norm 1.402798402789e-10
  2182 KSP Residual norm 1.288146935252e-10
  2183 KSP Residual norm 1.299392505235e-10
  2184 KSP Residual norm 1.218731459517e-10
  2185 KSP Residual norm 1.038040309453e-10
  2186 KSP Residual norm 9.705322938405e-11
  2187 KSP Residual norm 1.016096890036e-10
  2188 KSP Residual norm 9.825518300719e-11
  2189 KSP Residual norm 8.937069741244e-11
  2190 KSP Residual norm 8.648766581649e-11
  2191 KSP Residual norm 8.351126155862e-11
  2192 KSP Residual norm 7.474924187590e-11
  2193 KSP Residual norm 6.770423101309e-11
  2194 KSP Residual norm 6.767163026704e-11
  2195 KSP Residual norm 7.530845232610e-11
  2196 KSP Residual norm 8.055917017063e-11
  2197 KSP Residual norm 8.317101904893e-11
  2198 KSP Residual norm 8.697279910758e-11
  2199 KSP Residual norm 9.285692206865e-11
  2200 KSP Residual norm 9.740395553086e-11
  2201 KSP Residual norm 1.018754782712e-10
  2202 KSP Residual norm 1.096291599987e-10
  2203 KSP Residual norm 1.223901420078e-10
  2204 KSP Residual norm 1.267449532594e-10
  2205 KSP Residual norm 1.259707171042e-10
  2206 KSP Residual norm 1.331195020328e-10
  2207 KSP Residual norm 1.492216501630e-10
  2208 KSP Residual norm 1.527635022651e-10
  2209 KSP Residual norm 1.485398504704e-10
  2210 KSP Residual norm 1.574372137154e-10
  2211 KSP Residual norm 1.756454306567e-10
  2212 KSP Residual norm 1.786126533933e-10
  2213 KSP Residual norm 1.878415215867e-10
  2214 KSP Residual norm 2.110391239804e-10
  2215 KSP Residual norm 2.324524779983e-10
  2216 KSP Residual norm 2.356977686783e-10
  2217 KSP Residual norm 2.462168432869e-10
  2218 KSP Residual norm 2.713009449201e-10
  2219 KSP Residual norm 2.735163833974e-10
  2220 KSP Residual norm 2.611523943352e-10
  2221 KSP Residual norm 2.615651937377e-10
  2222 KSP Residual norm 2.667911046554e-10
  2223 KSP Residual norm 2.706431920824e-10
  2224 KSP Residual norm 2.756822139051e-10
  2225 KSP Residual norm 2.867192457304e-10
  2226 KSP Residual norm 2.918244187107e-10
  2227 KSP Residual norm 2.867468705694e-10
  2228 KSP Residual norm 2.665436485442e-10
  2229 KSP Residual norm 2.330319418464e-10
  2230 KSP Residual norm 2.114503277666e-10
  2231 KSP Residual norm 2.096849853863e-10
  2232 KSP Residual norm 2.066520540572e-10
  2233 KSP Residual norm 1.895970398596e-10
  2234 KSP Residual norm 1.758931729554e-10
  2235 KSP Residual norm 1.659279978155e-10
  2236 KSP Residual norm 1.486562997685e-10
  2237 KSP Residual norm 1.300372230095e-10
  2238 KSP Residual norm 1.241973805489e-10
  2239 KSP Residual norm 1.307291314495e-10
  2240 KSP Residual norm 1.344505026982e-10
  2241 KSP Residual norm 1.290694209154e-10
  2242 KSP Residual norm 1.203464342300e-10
  2243 KSP Residual norm 1.108105240480e-10
  2244 KSP Residual norm 1.014349836552e-10
  2245 KSP Residual norm 9.208955122135e-11
  2246 KSP Residual norm 8.427126685257e-11
  2247 KSP Residual norm 8.334492104759e-11
  2248 KSP Residual norm 8.899629939646e-11
  2249 KSP Residual norm 8.896845149025e-11
  2250 KSP Residual norm 8.129190458587e-11
  2251 KSP Residual norm 7.508373448121e-11
  2252 KSP Residual norm 7.304873996774e-11
  2253 KSP Residual norm 7.066829635571e-11
  2254 KSP Residual norm 6.680236434092e-11
  2255 KSP Residual norm 6.683025413622e-11
  2256 KSP Residual norm 7.090011747181e-11
  2257 KSP Residual norm 7.005075424392e-11
  2258 KSP Residual norm 6.561245931433e-11
  2259 KSP Residual norm 6.450368168419e-11
  2260 KSP Residual norm 6.557214962130e-11
  2261 KSP Residual norm 6.224610251598e-11
  2262 KSP Residual norm 6.094963079501e-11
  2263 KSP Residual norm 6.036212892653e-11
  2264 KSP Residual norm 6.038396516287e-11
  2265 KSP Residual norm 6.234647260731e-11
  2266 KSP Residual norm 6.873960815998e-11
  2267 KSP Residual norm 7.636845025300e-11
  2268 KSP Residual norm 8.195033918118e-11
  2269 KSP Residual norm 8.721677902537e-11
  2270 KSP Residual norm 9.333073210027e-11
  2271 KSP Residual norm 9.862392163768e-11
  2272 KSP Residual norm 1.048798878648e-10
  2273 KSP Residual norm 1.076425768901e-10
  2274 KSP Residual norm 1.099036098316e-10
  2275 KSP Residual norm 1.178779266547e-10
  2276 KSP Residual norm 1.256946310447e-10
  2277 KSP Residual norm 1.285687297532e-10
  2278 KSP Residual norm 1.419189611408e-10
  2279 KSP Residual norm 1.727879043610e-10
  2280 KSP Residual norm 1.952245540658e-10
  2281 KSP Residual norm 1.863186261883e-10
  2282 KSP Residual norm 1.829954529610e-10
  2283 KSP Residual norm 1.968826351800e-10
  2284 KSP Residual norm 2.108661806137e-10
  2285 KSP Residual norm 2.026921427533e-10
  2286 KSP Residual norm 2.072834428362e-10
  2287 KSP Residual norm 2.286919676782e-10
  2288 KSP Residual norm 2.384490432004e-10
  2289 KSP Residual norm 2.286022037646e-10
  2290 KSP Residual norm 2.310287296497e-10
  2291 KSP Residual norm 2.526254307259e-10
  2292 KSP Residual norm 2.733545803081e-10
  2293 KSP Residual norm 2.683329642103e-10
  2294 KSP Residual norm 2.498430049605e-10
  2295 KSP Residual norm 2.460797610497e-10
  2296 KSP Residual norm 2.397018786962e-10
  2297 KSP Residual norm 2.044028022221e-10
  2298 KSP Residual norm 1.687562986618e-10
  2299 KSP Residual norm 1.585449075899e-10
  2300 KSP Residual norm 1.585026695890e-10
  2301 KSP Residual norm 1.486731678061e-10
  2302 KSP Residual norm 1.508662006343e-10
  2303 KSP Residual norm 1.678094696439e-10
  2304 KSP Residual norm 1.794868168900e-10
  2305 KSP Residual norm 1.641459457020e-10
  2306 KSP Residual norm 1.541259104138e-10
  2307 KSP Residual norm 1.512503381706e-10
  2308 KSP Residual norm 1.409716289384e-10
  2309 KSP Residual norm 1.234692240054e-10
  2310 KSP Residual norm 1.106853373284e-10
  2311 KSP Residual norm 1.008958838863e-10
  2312 KSP Residual norm 9.153577821877e-11
  2313 KSP Residual norm 8.287864481090e-11
  2314 KSP Residual norm 7.502659240147e-11
  2315 KSP Residual norm 6.943776620384e-11
  2316 KSP Residual norm 6.406300197240e-11
  2317 KSP Residual norm 6.012260611392e-11
  2318 KSP Residual norm 5.855323861146e-11
  2319 KSP Residual norm 6.048577026317e-11
  2320 KSP Residual norm 6.107501710112e-11
  2321 KSP Residual norm 5.497086339435e-11
  2322 KSP Residual norm 4.755020157648e-11
  2323 KSP Residual norm 4.439172987450e-11
  2324 KSP Residual norm 4.402637714381e-11
  2325 KSP Residual norm 4.458360919238e-11
  2326 KSP Residual norm 4.806460091705e-11
  2327 KSP Residual norm 5.002055942832e-11
  2328 KSP Residual norm 4.889410635228e-11
  2329 KSP Residual norm 4.547611842094e-11
  2330 KSP Residual norm 4.392718140625e-11
  2331 KSP Residual norm 4.529112605626e-11
  2332 KSP Residual norm 4.646225380579e-11
  2333 KSP Residual norm 4.663544697773e-11
  2334 KSP Residual norm 5.020368130664e-11
  2335 KSP Residual norm 5.520959592618e-11
  2336 KSP Residual norm 5.876361524761e-11
  2337 KSP Residual norm 5.734870333734e-11
  2338 KSP Residual norm 5.492881440155e-11
  2339 KSP Residual norm 5.562748760637e-11
  2340 KSP Residual norm 5.982544468522e-11
  2341 KSP Residual norm 6.317231788739e-11
  2342 KSP Residual norm 6.700403168661e-11
  2343 KSP Residual norm 7.781126156878e-11
  2344 KSP Residual norm 9.014397809549e-11
  2345 KSP Residual norm 9.768087996254e-11
  2346 KSP Residual norm 9.988518851099e-11
  2347 KSP Residual norm 1.054022829386e-10
  2348 KSP Residual norm 1.066264608491e-10
  2349 KSP Residual norm 1.100231971715e-10
  2350 KSP Residual norm 1.151150154383e-10
  2351 KSP Residual norm 1.295790909111e-10
  2352 KSP Residual norm 1.479427139002e-10
  2353 KSP Residual norm 1.635584333910e-10
  2354 KSP Residual norm 1.765883948144e-10
  2355 KSP Residual norm 1.833369071770e-10
  2356 KSP Residual norm 1.791945681208e-10
  2357 KSP Residual norm 1.650143218950e-10
  2358 KSP Residual norm 1.599554547202e-10
  2359 KSP Residual norm 1.598702835078e-10
  2360 KSP Residual norm 1.572507707186e-10
  2361 KSP Residual norm 1.528490807519e-10
  2362 KSP Residual norm 1.502836665754e-10
  2363 KSP Residual norm 1.471435493140e-10
  2364 KSP Residual norm 1.555067497135e-10
  2365 KSP Residual norm 1.615339618069e-10
  2366 KSP Residual norm 1.552995480645e-10
  2367 KSP Residual norm 1.509220108105e-10
  2368 KSP Residual norm 1.570508398839e-10
  2369 KSP Residual norm 1.507379942100e-10
  2370 KSP Residual norm 1.348785416330e-10
  2371 KSP Residual norm 1.226583477580e-10
  2372 KSP Residual norm 1.234350900884e-10
  2373 KSP Residual norm 1.243480977668e-10
  2374 KSP Residual norm 1.150785591324e-10
  2375 KSP Residual norm 1.074365996010e-10
  2376 KSP Residual norm 1.087125753124e-10
  2377 KSP Residual norm 1.095320537003e-10
  2378 KSP Residual norm 9.489577081440e-11
  2379 KSP Residual norm 8.442273981455e-11
  2380 KSP Residual norm 8.236346555312e-11
  2381 KSP Residual norm 7.977056606707e-11
  2382 KSP Residual norm 7.049055659753e-11
  2383 KSP Residual norm 6.561008120567e-11
  2384 KSP Residual norm 6.617235267824e-11
  2385 KSP Residual norm 6.519195802852e-11
  2386 KSP Residual norm 6.049724471776e-11
  2387 KSP Residual norm 5.741501411826e-11
  2388 KSP Residual norm 5.690360192245e-11
  2389 KSP Residual norm 5.620160763739e-11
  2390 KSP Residual norm 5.110391910939e-11
  2391 KSP Residual norm 4.873260310287e-11
  2392 KSP Residual norm 5.346094440554e-11
  2393 KSP Residual norm 5.444908854441e-11
  2394 KSP Residual norm 4.869605676261e-11
  2395 KSP Residual norm 4.814487133963e-11
  2396 KSP Residual norm 5.013115004758e-11
  2397 KSP Residual norm 4.763495594444e-11
  2398 KSP Residual norm 4.496523472516e-11
  2399 KSP Residual norm 4.607926626287e-11
  2400 KSP Residual norm 4.767705973236e-11
  2401 KSP Residual norm 4.713311358182e-11
  2402 KSP Residual norm 4.827121081063e-11
  2403 KSP Residual norm 5.423587799687e-11
  2404 KSP Residual norm 5.822469526246e-11
  2405 KSP Residual norm 5.678957775328e-11
  2406 KSP Residual norm 5.678901971442e-11
  2407 KSP Residual norm 6.047654235700e-11
  2408 KSP Residual norm 6.093410095448e-11
  2409 KSP Residual norm 5.571741217131e-11
  2410 KSP Residual norm 5.352247060734e-11
  2411 KSP Residual norm 5.443470081772e-11
  2412 KSP Residual norm 5.736423490950e-11
  2413 KSP Residual norm 6.451088778360e-11
  2414 KSP Residual norm 7.385943714942e-11
  2415 KSP Residual norm 7.733624689963e-11
  2416 KSP Residual norm 7.902212754889e-11
  2417 KSP Residual norm 8.199277618342e-11
  2418 KSP Residual norm 8.317862802981e-11
  2419 KSP Residual norm 8.637195806732e-11
  2420 KSP Residual norm 9.508839491942e-11
  2421 KSP Residual norm 1.030441012335e-10
  2422 KSP Residual norm 1.063060670653e-10
  2423 KSP Residual norm 1.062409534710e-10
  2424 KSP Residual norm 1.079265473940e-10
  2425 KSP Residual norm 1.109429568573e-10
  2426 KSP Residual norm 1.167329412038e-10
  2427 KSP Residual norm 1.271336715819e-10
  2428 KSP Residual norm 1.317567408087e-10
  2429 KSP Residual norm 1.358436862127e-10
  2430 KSP Residual norm 1.406836948323e-10
  2431 KSP Residual norm 1.510997354977e-10
  2432 KSP Residual norm 1.708744487898e-10
  2433 KSP Residual norm 1.815913290568e-10
  2434 KSP Residual norm 1.766664855805e-10
  2435 KSP Residual norm 1.663149994630e-10
  2436 KSP Residual norm 1.660585185445e-10
  2437 KSP Residual norm 1.730002371493e-10
  2438 KSP Residual norm 1.754615577512e-10
  2439 KSP Residual norm 1.641150497490e-10
  2440 KSP Residual norm 1.582200674266e-10
  2441 KSP Residual norm 1.596055299023e-10
  2442 KSP Residual norm 1.441500743857e-10
  2443 KSP Residual norm 1.344848997642e-10
  2444 KSP Residual norm 1.388727807241e-10
  2445 KSP Residual norm 1.409190910717e-10
  2446 KSP Residual norm 1.242526205109e-10
  2447 KSP Residual norm 1.059463816423e-10
  2448 KSP Residual norm 9.912917441929e-11
  2449 KSP Residual norm 8.975577069482e-11
  2450 KSP Residual norm 7.630214910239e-11
  2451 KSP Residual norm 6.940666363100e-11
  2452 KSP Residual norm 6.787035571834e-11
  2453 KSP Residual norm 6.521350915628e-11
  2454 KSP Residual norm 6.092471142961e-11
  2455 KSP Residual norm 5.872586033531e-11
  2456 KSP Residual norm 5.751544148662e-11
  2457 KSP Residual norm 5.498838782050e-11
  2458 KSP Residual norm 5.089425159316e-11
  2459 KSP Residual norm 4.657608824059e-11
  2460 KSP Residual norm 4.350927638786e-11
  2461 KSP Residual norm 4.317109349909e-11
  2462 KSP Residual norm 4.188234333228e-11
  2463 KSP Residual norm 3.932917235981e-11
  2464 KSP Residual norm 3.776291939403e-11
  2465 KSP Residual norm 3.624746141051e-11
  2466 KSP Residual norm 3.465684715782e-11
  2467 KSP Residual norm 3.564293175324e-11
  2468 KSP Residual norm 3.694191966074e-11
  2469 KSP Residual norm 3.642041837700e-11
  2470 KSP Residual norm 3.566276159328e-11
  2471 KSP Residual norm 3.584115237200e-11
  2472 KSP Residual norm 3.718834754792e-11
  2473 KSP Residual norm 3.707367250890e-11
  2474 KSP Residual norm 3.471309140550e-11
  2475 KSP Residual norm 3.178293342347e-11
  2476 KSP Residual norm 3.213584304907e-11
  2477 KSP Residual norm 3.300900290851e-11
  2478 KSP Residual norm 3.433764709781e-11
  2479 KSP Residual norm 3.839460124533e-11
  2480 KSP Residual norm 4.711328604312e-11
  2481 KSP Residual norm 5.302465094825e-11
  2482 KSP Residual norm 5.459351161282e-11
  2483 KSP Residual norm 5.492846953401e-11
  2484 KSP Residual norm 5.896263509656e-11
  2485 KSP Residual norm 6.696702554393e-11
  2486 KSP Residual norm 7.666040156911e-11
  2487 KSP Residual norm 8.459414797285e-11
  2488 KSP Residual norm 9.033211822692e-11
  2489 KSP Residual norm 8.957024266081e-11
  2490 KSP Residual norm 8.478586845323e-11
  2491 KSP Residual norm 8.636540699604e-11
  2492 KSP Residual norm 9.561838970771e-11
  2493 KSP Residual norm 1.005762466320e-10
  2494 KSP Residual norm 1.025547639513e-10
  2495 KSP Residual norm 1.105725271912e-10
  2496 KSP Residual norm 1.257194865597e-10
  2497 KSP Residual norm 1.330229380451e-10
  2498 KSP Residual norm 1.265175578299e-10
  2499 KSP Residual norm 1.220831472158e-10
  2500 KSP Residual norm 1.235172724850e-10
  2501 KSP Residual norm 1.206732989349e-10
  2502 KSP Residual norm 1.189476356179e-10
  2503 KSP Residual norm 1.206751833771e-10
  2504 KSP Residual norm 1.207641434718e-10
  2505 KSP Residual norm 1.202520881722e-10
  2506 KSP Residual norm 1.248485636074e-10
  2507 KSP Residual norm 1.317746885834e-10
  2508 KSP Residual norm 1.272742211625e-10
  2509 KSP Residual norm 1.100786651831e-10
  2510 KSP Residual norm 1.023882981021e-10
  2511 KSP Residual norm 9.910264988489e-11
  2512 KSP Residual norm 9.763180373753e-11
  2513 KSP Residual norm 1.087741074007e-10
  2514 KSP Residual norm 1.282287087446e-10
  2515 KSP Residual norm 1.290867543517e-10
  2516 KSP Residual norm 1.145016176480e-10
  2517 KSP Residual norm 1.023200093705e-10
  2518 KSP Residual norm 9.441644031738e-11
  2519 KSP Residual norm 8.487441153069e-11
  2520 KSP Residual norm 7.973802426774e-11
  2521 KSP Residual norm 7.998558606865e-11
  2522 KSP Residual norm 7.788530126207e-11
  2523 KSP Residual norm 7.221508745819e-11
  2524 KSP Residual norm 6.761652034480e-11
  2525 KSP Residual norm 6.419216680049e-11
  2526 KSP Residual norm 6.202133779041e-11
  2527 KSP Residual norm 6.013606731827e-11
  2528 KSP Residual norm 5.798513982330e-11
  2529 KSP Residual norm 5.342747198857e-11
  2530 KSP Residual norm 4.905028982178e-11
  2531 KSP Residual norm 4.808233129657e-11
  2532 KSP Residual norm 4.934896702580e-11
  2533 KSP Residual norm 4.792407279635e-11
  2534 KSP Residual norm 4.422238339562e-11
  2535 KSP Residual norm 4.144841375059e-11
  2536 KSP Residual norm 4.442825921831e-11
  2537 KSP Residual norm 5.245180898656e-11
  2538 KSP Residual norm 5.655764847474e-11
  2539 KSP Residual norm 5.850932451106e-11
  2540 KSP Residual norm 6.087215146013e-11
  2541 KSP Residual norm 5.867803039168e-11
  2542 KSP Residual norm 5.181316895122e-11
  2543 KSP Residual norm 4.681054727332e-11
  2544 KSP Residual norm 4.794754507130e-11
  2545 KSP Residual norm 5.110304965925e-11
  2546 KSP Residual norm 5.238834238885e-11
  2547 KSP Residual norm 4.917834488831e-11
  2548 KSP Residual norm 4.665886055992e-11
  2549 KSP Residual norm 4.623505658883e-11
  2550 KSP Residual norm 4.988273795062e-11
  2551 KSP Residual norm 5.569534760476e-11
  2552 KSP Residual norm 5.935878709843e-11
  2553 KSP Residual norm 5.934490760022e-11
  2554 KSP Residual norm 6.164423650678e-11
  2555 KSP Residual norm 6.811477624227e-11
  2556 KSP Residual norm 7.751054071399e-11
  2557 KSP Residual norm 8.067618211791e-11
  2558 KSP Residual norm 8.159628951265e-11
  2559 KSP Residual norm 8.652210170827e-11
  2560 KSP Residual norm 9.159941196852e-11
  2561 KSP Residual norm 9.646290134732e-11
  2562 KSP Residual norm 9.855549239407e-11
  2563 KSP Residual norm 1.055756161297e-10
  2564 KSP Residual norm 1.159772930963e-10
  2565 KSP Residual norm 1.295069869250e-10
  2566 KSP Residual norm 1.484508987558e-10
  2567 KSP Residual norm 1.686952821331e-10
  2568 KSP Residual norm 1.786224160886e-10
  2569 KSP Residual norm 1.795002776893e-10
  2570 KSP Residual norm 1.871850344231e-10
  2571 KSP Residual norm 1.926044656943e-10
  2572 KSP Residual norm 1.895329186266e-10
  2573 KSP Residual norm 1.811685082571e-10
  2574 KSP Residual norm 1.689593808495e-10
  2575 KSP Residual norm 1.680895747670e-10
  2576 KSP Residual norm 1.734443387105e-10
  2577 KSP Residual norm 1.775646420930e-10
  2578 KSP Residual norm 1.959279248189e-10
  2579 KSP Residual norm 2.357791736647e-10
  2580 KSP Residual norm 3.020721171947e-10
  2581 KSP Residual norm 3.562992845449e-10
  2582 KSP Residual norm 3.548302562529e-10
  2583 KSP Residual norm 3.590930846421e-10
  2584 KSP Residual norm 3.646402623077e-10
  2585 KSP Residual norm 3.512284821210e-10
  2586 KSP Residual norm 3.543769172554e-10
  2587 KSP Residual norm 3.688934771167e-10
  2588 KSP Residual norm 3.666559635009e-10
  2589 KSP Residual norm 3.405576989914e-10
  2590 KSP Residual norm 3.396163974061e-10
  2591 KSP Residual norm 3.562271057121e-10
  2592 KSP Residual norm 3.544716167058e-10
  2593 KSP Residual norm 3.300122129737e-10
  2594 KSP Residual norm 3.140250916303e-10
  2595 KSP Residual norm 3.263619510241e-10
  2596 KSP Residual norm 3.652334793895e-10
  2597 KSP Residual norm 3.852867656972e-10
  2598 KSP Residual norm 3.680292373468e-10
  2599 KSP Residual norm 3.569556252489e-10
  2600 KSP Residual norm 3.408278909425e-10
  2601 KSP Residual norm 2.770747475716e-10
  2602 KSP Residual norm 2.187976742726e-10
  2603 KSP Residual norm 2.047039573634e-10
  2604 KSP Residual norm 1.994003139253e-10
  2605 KSP Residual norm 1.767896684601e-10
  2606 KSP Residual norm 1.640980260010e-10
  2607 KSP Residual norm 1.680203566240e-10
  2608 KSP Residual norm 1.689243752909e-10
  2609 KSP Residual norm 1.625011005568e-10
  2610 KSP Residual norm 1.567706871127e-10
  2611 KSP Residual norm 1.489925241491e-10
  2612 KSP Residual norm 1.335377119176e-10
  2613 KSP Residual norm 1.261349874156e-10
  2614 KSP Residual norm 1.388447344399e-10
  2615 KSP Residual norm 1.580658280228e-10
  2616 KSP Residual norm 1.610802646770e-10
  2617 KSP Residual norm 1.498291637561e-10
  2618 KSP Residual norm 1.485547292345e-10
  2619 KSP Residual norm 1.518686342353e-10
  2620 KSP Residual norm 1.501881571533e-10
  2621 KSP Residual norm 1.496790381409e-10
  2622 KSP Residual norm 1.503234034632e-10
  2623 KSP Residual norm 1.497223330107e-10
  2624 KSP Residual norm 1.510883991305e-10
  2625 KSP Residual norm 1.649849590372e-10
  2626 KSP Residual norm 1.840315351400e-10
  2627 KSP Residual norm 1.673814739933e-10
  2628 KSP Residual norm 1.368109829562e-10
  2629 KSP Residual norm 1.302384443783e-10
  2630 KSP Residual norm 1.366445164541e-10
  2631 KSP Residual norm 1.318040332276e-10
  2632 KSP Residual norm 1.279051580891e-10
  2633 KSP Residual norm 1.299769604020e-10
  2634 KSP Residual norm 1.328155185112e-10
  2635 KSP Residual norm 1.375609071911e-10
  2636 KSP Residual norm 1.588008263296e-10
  2637 KSP Residual norm 1.810078406732e-10
  2638 KSP Residual norm 1.977882099230e-10
  2639 KSP Residual norm 2.197891020341e-10
  2640 KSP Residual norm 2.410727612268e-10
  2641 KSP Residual norm 2.417572947239e-10
  2642 KSP Residual norm 2.452744148031e-10
  2643 KSP Residual norm 2.588902634833e-10
  2644 KSP Residual norm 2.723038243766e-10
  2645 KSP Residual norm 2.803523142417e-10
  2646 KSP Residual norm 2.969627004421e-10
  2647 KSP Residual norm 3.136338778948e-10
  2648 KSP Residual norm 3.320676226355e-10
  2649 KSP Residual norm 3.443285585729e-10
  2650 KSP Residual norm 3.347237303466e-10
  2651 KSP Residual norm 3.372155840079e-10
  2652 KSP Residual norm 3.719804634470e-10
  2653 KSP Residual norm 3.972016409306e-10
  2654 KSP Residual norm 3.810533768158e-10
  2655 KSP Residual norm 3.737388111414e-10
  2656 KSP Residual norm 3.914109456686e-10
  2657 KSP Residual norm 3.804713279838e-10
  2658 KSP Residual norm 3.565248556585e-10
  2659 KSP Residual norm 3.551987028844e-10
  2660 KSP Residual norm 3.755440890058e-10
  2661 KSP Residual norm 3.863739516848e-10
  2662 KSP Residual norm 3.912108676508e-10
  2663 KSP Residual norm 3.963513252839e-10
  2664 KSP Residual norm 3.997274621591e-10
  2665 KSP Residual norm 3.913657832098e-10
  2666 KSP Residual norm 4.004063814179e-10
  2667 KSP Residual norm 3.998450137889e-10
  2668 KSP Residual norm 3.399261794786e-10
  2669 KSP Residual norm 2.908464975349e-10
  2670 KSP Residual norm 2.876703334958e-10
  2671 KSP Residual norm 2.829023410521e-10
  2672 KSP Residual norm 2.530296077125e-10
  2673 KSP Residual norm 2.404197754534e-10
  2674 KSP Residual norm 2.541675313661e-10
  2675 KSP Residual norm 2.594003754784e-10
  2676 KSP Residual norm 2.482637570940e-10
  2677 KSP Residual norm 2.557166950203e-10
  2678 KSP Residual norm 3.012545001673e-10
  2679 KSP Residual norm 3.206263086224e-10
  2680 KSP Residual norm 3.035581219905e-10
  2681 KSP Residual norm 2.927200345230e-10
  2682 KSP Residual norm 2.980653223007e-10
  2683 KSP Residual norm 2.998257674591e-10
  2684 KSP Residual norm 2.719546760063e-10
  2685 KSP Residual norm 2.307806997410e-10
  2686 KSP Residual norm 1.966748949626e-10
  2687 KSP Residual norm 1.741616149224e-10
  2688 KSP Residual norm 1.543815912973e-10
  2689 KSP Residual norm 1.449637424157e-10
  2690 KSP Residual norm 1.504686373290e-10
  2691 KSP Residual norm 1.568868466377e-10
  2692 KSP Residual norm 1.531948341571e-10
  2693 KSP Residual norm 1.464998243444e-10
  2694 KSP Residual norm 1.397729534318e-10
  2695 KSP Residual norm 1.254246471131e-10
  2696 KSP Residual norm 1.148289307950e-10
  2697 KSP Residual norm 1.141021500113e-10
  2698 KSP Residual norm 1.082329439149e-10
  2699 KSP Residual norm 9.274435060555e-11
  2700 KSP Residual norm 8.971339605669e-11
  2701 KSP Residual norm 9.937094083500e-11
  2702 KSP Residual norm 9.974529709267e-11
  2703 KSP Residual norm 8.793961906419e-11
  2704 KSP Residual norm 8.457303700214e-11
  2705 KSP Residual norm 8.588173889778e-11
  2706 KSP Residual norm 8.033836401174e-11
  2707 KSP Residual norm 7.644758326775e-11
  2708 KSP Residual norm 7.770385865782e-11
  2709 KSP Residual norm 7.699212866716e-11
  2710 KSP Residual norm 6.931587621732e-11
  2711 KSP Residual norm 6.450700978620e-11
  2712 KSP Residual norm 6.999123042435e-11
  2713 KSP Residual norm 7.844740988010e-11
  2714 KSP Residual norm 7.487579437117e-11
  2715 KSP Residual norm 7.050541093724e-11
  2716 KSP Residual norm 6.862862533737e-11
  2717 KSP Residual norm 6.511622030435e-11
  2718 KSP Residual norm 6.336882344600e-11
  2719 KSP Residual norm 6.699988411513e-11
  2720 KSP Residual norm 7.052687938956e-11
  2721 KSP Residual norm 7.292347017183e-11
  2722 KSP Residual norm 7.950697211601e-11
  2723 KSP Residual norm 8.333013976557e-11
  2724 KSP Residual norm 7.831100210905e-11
  2725 KSP Residual norm 7.615807374629e-11
  2726 KSP Residual norm 8.044533317035e-11
  2727 KSP Residual norm 8.673697461589e-11
  2728 KSP Residual norm 8.961725768659e-11
  2729 KSP Residual norm 8.882582578248e-11
  2730 KSP Residual norm 8.738438053653e-11
  2731 KSP Residual norm 9.515245419945e-11
  2732 KSP Residual norm 1.136150795634e-10
  2733 KSP Residual norm 1.224052362497e-10
  2734 KSP Residual norm 1.257486426984e-10
  2735 KSP Residual norm 1.332727546660e-10
  2736 KSP Residual norm 1.408746603734e-10
  2737 KSP Residual norm 1.363725983132e-10
  2738 KSP Residual norm 1.242833549100e-10
  2739 KSP Residual norm 1.127696441597e-10
  2740 KSP Residual norm 1.026928353411e-10
  2741 KSP Residual norm 9.197681315245e-11
  2742 KSP Residual norm 9.457353479952e-11
  2743 KSP Residual norm 1.058044768705e-10
  2744 KSP Residual norm 1.025686671084e-10
  2745 KSP Residual norm 9.232891148308e-11
  2746 KSP Residual norm 9.222904710046e-11
  2747 KSP Residual norm 9.382758823938e-11
  2748 KSP Residual norm 9.266370901142e-11
  2749 KSP Residual norm 1.000855798128e-10
  2750 KSP Residual norm 1.147847606464e-10
  2751 KSP Residual norm 1.271382965803e-10
  2752 KSP Residual norm 1.400895377463e-10
  2753 KSP Residual norm 1.474502876642e-10
  2754 KSP Residual norm 1.424989806606e-10
  2755 KSP Residual norm 1.382809361402e-10
  2756 KSP Residual norm 1.379922684551e-10
  2757 KSP Residual norm 1.416947072482e-10
  2758 KSP Residual norm 1.458520569903e-10
  2759 KSP Residual norm 1.504455429371e-10
  2760 KSP Residual norm 1.488788536247e-10
  2761 KSP Residual norm 1.327345847463e-10
  2762 KSP Residual norm 1.234554964739e-10
  2763 KSP Residual norm 1.243973676093e-10
  2764 KSP Residual norm 1.229995533746e-10
  2765 KSP Residual norm 1.160884811545e-10
  2766 KSP Residual norm 1.234258201297e-10
  2767 KSP Residual norm 1.376939724850e-10
  2768 KSP Residual norm 1.461528694143e-10
  2769 KSP Residual norm 1.595014271833e-10
  2770 KSP Residual norm 1.773876280220e-10
  2771 KSP Residual norm 1.736087180434e-10
  2772 KSP Residual norm 1.620360391680e-10
  2773 KSP Residual norm 1.737192576434e-10
  2774 KSP Residual norm 1.912030924706e-10
  2775 KSP Residual norm 1.741520885187e-10
  2776 KSP Residual norm 1.505140749590e-10
  2777 KSP Residual norm 1.512178741270e-10
  2778 KSP Residual norm 1.591761698263e-10
  2779 KSP Residual norm 1.442808082135e-10
  2780 KSP Residual norm 1.437620446103e-10
  2781 KSP Residual norm 1.646068745887e-10
  2782 KSP Residual norm 1.822919243720e-10
  2783 KSP Residual norm 1.644241305869e-10
  2784 KSP Residual norm 1.450334993389e-10
  2785 KSP Residual norm 1.275630070341e-10
  2786 KSP Residual norm 1.057203959338e-10
  2787 KSP Residual norm 8.832661612782e-11
  2788 KSP Residual norm 8.663322600860e-11
  2789 KSP Residual norm 8.580088200037e-11
  2790 KSP Residual norm 7.591677040160e-11
  2791 KSP Residual norm 6.912969452594e-11
  2792 KSP Residual norm 7.641639776334e-11
  2793 KSP Residual norm 8.643252432865e-11
  2794 KSP Residual norm 8.931030063384e-11
  2795 KSP Residual norm 9.209241763996e-11
  2796 KSP Residual norm 9.061005160252e-11
  2797 KSP Residual norm 8.116282902541e-11
  2798 KSP Residual norm 6.913419348616e-11
  2799 KSP Residual norm 6.079513596297e-11
  2800 KSP Residual norm 5.592220192988e-11
  2801 KSP Residual norm 5.201870971250e-11
  2802 KSP Residual norm 5.277925756400e-11
  2803 KSP Residual norm 5.930230671833e-11
  2804 KSP Residual norm 6.410612722731e-11
  2805 KSP Residual norm 6.236451401665e-11
  2806 KSP Residual norm 5.662233128687e-11
  2807 KSP Residual norm 5.289890183490e-11
  2808 KSP Residual norm 5.090436407632e-11
  2809 KSP Residual norm 5.008807327907e-11
  2810 KSP Residual norm 4.941890934843e-11
  2811 KSP Residual norm 5.017695126338e-11
  2812 KSP Residual norm 5.044549923483e-11
  2813 KSP Residual norm 5.122023398052e-11
  2814 KSP Residual norm 5.348586433712e-11
  2815 KSP Residual norm 6.333846609935e-11
  2816 KSP Residual norm 7.681841019137e-11
  2817 KSP Residual norm 7.422696816113e-11
  2818 KSP Residual norm 6.261317178846e-11
  2819 KSP Residual norm 6.122306602876e-11
  2820 KSP Residual norm 6.508237017466e-11
  2821 KSP Residual norm 6.411561892414e-11
  2822 KSP Residual norm 6.000081192435e-11
  2823 KSP Residual norm 6.419455140445e-11
  2824 KSP Residual norm 6.683856740104e-11
  2825 KSP Residual norm 6.239902142650e-11
  2826 KSP Residual norm 5.838927276355e-11
  2827 KSP Residual norm 6.297374769097e-11
  2828 KSP Residual norm 6.997689354060e-11
  2829 KSP Residual norm 7.413935238082e-11
  2830 KSP Residual norm 8.010413536059e-11
  2831 KSP Residual norm 8.569055362059e-11
  2832 KSP Residual norm 8.085614131260e-11
  2833 KSP Residual norm 7.595593193771e-11
  2834 KSP Residual norm 8.161071586042e-11
  2835 KSP Residual norm 8.693249545344e-11
  2836 KSP Residual norm 8.133711008605e-11
  2837 KSP Residual norm 8.956980773986e-11
  2838 KSP Residual norm 1.104889846534e-10
  2839 KSP Residual norm 1.135953024730e-10
  2840 KSP Residual norm 9.934150226468e-11
  2841 KSP Residual norm 1.021410148655e-10
  2842 KSP Residual norm 1.244795989448e-10
  2843 KSP Residual norm 1.408886053405e-10
  2844 KSP Residual norm 1.471494756412e-10
  2845 KSP Residual norm 1.686075635207e-10
  2846 KSP Residual norm 1.989993690977e-10
  2847 KSP Residual norm 2.053647476809e-10
  2848 KSP Residual norm 2.012358972357e-10
  2849 KSP Residual norm 2.076965521236e-10
  2850 KSP Residual norm 2.163407181242e-10
  2851 KSP Residual norm 2.286243752289e-10
  2852 KSP Residual norm 2.636111019595e-10
  2853 KSP Residual norm 2.924816569511e-10
  2854 KSP Residual norm 2.733366782735e-10
  2855 KSP Residual norm 2.664264841346e-10
  2856 KSP Residual norm 3.250624450355e-10
  2857 KSP Residual norm 3.863137609996e-10
  2858 KSP Residual norm 3.522272644323e-10
  2859 KSP Residual norm 3.079378603273e-10
  2860 KSP Residual norm 3.044869359086e-10
  2861 KSP Residual norm 2.957089468057e-10
  2862 KSP Residual norm 2.927586504427e-10
  2863 KSP Residual norm 3.075591204124e-10
  2864 KSP Residual norm 3.093297755729e-10
  2865 KSP Residual norm 2.961328618997e-10
  2866 KSP Residual norm 3.115425809557e-10
  2867 KSP Residual norm 3.366977768627e-10
  2868 KSP Residual norm 3.370581730420e-10
  2869 KSP Residual norm 3.344545545575e-10
  2870 KSP Residual norm 3.487359258423e-10
  2871 KSP Residual norm 3.645134695704e-10
  2872 KSP Residual norm 3.669049465811e-10
  2873 KSP Residual norm 3.709342624645e-10
  2874 KSP Residual norm 3.451673144354e-10
  2875 KSP Residual norm 2.987296148283e-10
  2876 KSP Residual norm 2.876983410402e-10
  2877 KSP Residual norm 3.133126289016e-10
  2878 KSP Residual norm 3.058231471199e-10
  2879 KSP Residual norm 2.919596663525e-10
  2880 KSP Residual norm 3.184121609912e-10
  2881 KSP Residual norm 3.831276181653e-10
  2882 KSP Residual norm 3.945989898409e-10
  2883 KSP Residual norm 4.007720120790e-10
  2884 KSP Residual norm 4.433437967563e-10
  2885 KSP Residual norm 4.429921190455e-10
  2886 KSP Residual norm 3.995622207105e-10
  2887 KSP Residual norm 4.069699872912e-10
  2888 KSP Residual norm 4.524134205270e-10
  2889 KSP Residual norm 4.534607725854e-10
  2890 KSP Residual norm 4.724496379382e-10
  2891 KSP Residual norm 5.670141413287e-10
  2892 KSP Residual norm 6.081571459089e-10
  2893 KSP Residual norm 5.528512232496e-10
  2894 KSP Residual norm 5.023199494095e-10
  2895 KSP Residual norm 4.286401916995e-10
  2896 KSP Residual norm 3.468077430468e-10
  2897 KSP Residual norm 3.159937517605e-10
  2898 KSP Residual norm 3.535598826410e-10
  2899 KSP Residual norm 3.720219359788e-10
  2900 KSP Residual norm 3.106823592704e-10
  2901 KSP Residual norm 2.795887634886e-10
  2902 KSP Residual norm 2.958324289518e-10
  2903 KSP Residual norm 2.819012281393e-10
  2904 KSP Residual norm 2.703609006753e-10
  2905 KSP Residual norm 3.132423686832e-10
  2906 KSP Residual norm 3.750259473452e-10
  2907 KSP Residual norm 3.245697781487e-10
  2908 KSP Residual norm 2.844787052772e-10
  2909 KSP Residual norm 3.111649901245e-10
  2910 KSP Residual norm 3.219654773034e-10
  2911 KSP Residual norm 2.806984479859e-10
  2912 KSP Residual norm 2.548317734403e-10
  2913 KSP Residual norm 2.489661064267e-10
  2914 KSP Residual norm 2.094707676940e-10
  2915 KSP Residual norm 1.673567574308e-10
  2916 KSP Residual norm 1.568799016481e-10
  2917 KSP Residual norm 1.561146666837e-10
  2918 KSP Residual norm 1.413602759548e-10
  2919 KSP Residual norm 1.455827743572e-10
  2920 KSP Residual norm 1.662350197593e-10
  2921 KSP Residual norm 1.543764731555e-10
  2922 KSP Residual norm 1.224262741986e-10
  2923 KSP Residual norm 1.096461090648e-10
  2924 KSP Residual norm 1.111614123649e-10
  2925 KSP Residual norm 1.054671766699e-10
  2926 KSP Residual norm 1.059747020060e-10
  2927 KSP Residual norm 1.162325670389e-10
  2928 KSP Residual norm 1.118113706644e-10
  2929 KSP Residual norm 8.967047190524e-11
  2930 KSP Residual norm 8.109283692253e-11
  2931 KSP Residual norm 8.525588608580e-11
  2932 KSP Residual norm 8.170736571085e-11
  2933 KSP Residual norm 8.357596215059e-11
  2934 KSP Residual norm 9.196918167308e-11
  2935 KSP Residual norm 8.930124970252e-11
  2936 KSP Residual norm 7.534724293010e-11
  2937 KSP Residual norm 7.348576590142e-11
  2938 KSP Residual norm 7.846389202091e-11
  2939 KSP Residual norm 7.564721360210e-11
  2940 KSP Residual norm 6.945655269237e-11
  2941 KSP Residual norm 7.532278637314e-11
  2942 KSP Residual norm 8.278912828553e-11
  2943 KSP Residual norm 7.680869322829e-11
  2944 KSP Residual norm 7.325145245207e-11
  2945 KSP Residual norm 7.792590000344e-11
  2946 KSP Residual norm 7.284439452493e-11
  2947 KSP Residual norm 6.213299939558e-11
  2948 KSP Residual norm 5.826888616233e-11
  2949 KSP Residual norm 5.708149069548e-11
  2950 KSP Residual norm 5.379338404330e-11
  2951 KSP Residual norm 5.279450008556e-11
  2952 KSP Residual norm 5.205166565086e-11
  2953 KSP Residual norm 4.928073313945e-11
  2954 KSP Residual norm 4.895231466257e-11
  2955 KSP Residual norm 5.175464793394e-11
  2956 KSP Residual norm 4.778988628865e-11
  2957 KSP Residual norm 4.011322920294e-11
  2958 KSP Residual norm 4.159035668933e-11
  2959 KSP Residual norm 4.943910559722e-11
  2960 KSP Residual norm 4.819451584447e-11
  2961 KSP Residual norm 4.149331200267e-11
  2962 KSP Residual norm 4.306312544368e-11
  2963 KSP Residual norm 4.577123717922e-11
  2964 KSP Residual norm 4.208818648973e-11
  2965 KSP Residual norm 4.023903100366e-11
  2966 KSP Residual norm 4.209536168180e-11
  2967 KSP Residual norm 3.984653103433e-11
  2968 KSP Residual norm 3.500408260036e-11
  2969 KSP Residual norm 3.452553412129e-11
  2970 KSP Residual norm 3.786920468734e-11
  2971 KSP Residual norm 3.895251106948e-11
  2972 KSP Residual norm 4.055995420711e-11
  2973 KSP Residual norm 4.656080646631e-11
  2974 KSP Residual norm 4.597050777329e-11
  2975 KSP Residual norm 4.199779538364e-11
  2976 KSP Residual norm 4.593876198906e-11
  2977 KSP Residual norm 5.339149398646e-11
  2978 KSP Residual norm 4.811003973176e-11
  2979 KSP Residual norm 4.149872952656e-11
  2980 KSP Residual norm 4.222654343502e-11
  2981 KSP Residual norm 4.634228106429e-11
  2982 KSP Residual norm 4.687954987410e-11
  2983 KSP Residual norm 4.737147250984e-11
  2984 KSP Residual norm 5.064662729960e-11
  2985 KSP Residual norm 4.984903838065e-11
  2986 KSP Residual norm 4.754001567965e-11
  2987 KSP Residual norm 5.049176499555e-11
  2988 KSP Residual norm 5.120740332414e-11
  2989 KSP Residual norm 4.511741444619e-11
  2990 KSP Residual norm 4.731165752005e-11
  2991 KSP Residual norm 6.016927709597e-11
  2992 KSP Residual norm 6.613859593270e-11
  2993 KSP Residual norm 6.369621644924e-11
  2994 KSP Residual norm 7.049785786962e-11
  2995 KSP Residual norm 7.778174280848e-11
  2996 KSP Residual norm 7.373389967884e-11
  2997 KSP Residual norm 7.419902343084e-11
  2998 KSP Residual norm 8.024855664454e-11
  2999 KSP Residual norm 8.116109676494e-11
  3000 KSP Residual norm 8.472441319456e-11
  3001 KSP Residual norm 9.438220967583e-11
  3002 KSP Residual norm 9.067256184761e-11
  3003 KSP Residual norm 8.867376624264e-11
  3004 KSP Residual norm 1.043120154534e-10
  3005 KSP Residual norm 1.263925779119e-10
  3006 KSP Residual norm 1.284091647616e-10
  3007 KSP Residual norm 1.337501420266e-10
  3008 KSP Residual norm 1.483970087769e-10
  3009 KSP Residual norm 1.497242026731e-10
  3010 KSP Residual norm 1.362615155887e-10
  3011 KSP Residual norm 1.479515273854e-10
  3012 KSP Residual norm 1.806154921502e-10
  3013 KSP Residual norm 1.781317801900e-10
  3014 KSP Residual norm 1.578192929416e-10
  3015 KSP Residual norm 1.512965374372e-10
  3016 KSP Residual norm 1.472337680675e-10
  3017 KSP Residual norm 1.375823617423e-10
  3018 KSP Residual norm 1.392565856021e-10
  3019 KSP Residual norm 1.388918449602e-10
  3020 KSP Residual norm 1.245060877559e-10
  3021 KSP Residual norm 1.145256275805e-10
  3022 KSP Residual norm 1.292830907729e-10
  3023 KSP Residual norm 1.521008350815e-10
  3024 KSP Residual norm 1.521116719366e-10
  3025 KSP Residual norm 1.541964989333e-10
  3026 KSP Residual norm 1.697315594305e-10
  3027 KSP Residual norm 1.788637912313e-10
  3028 KSP Residual norm 1.976525782933e-10
  3029 KSP Residual norm 2.508091508062e-10
  3030 KSP Residual norm 3.053500222800e-10
  3031 KSP Residual norm 2.971755321277e-10
  3032 KSP Residual norm 2.812307621503e-10
  3033 KSP Residual norm 2.827143298048e-10
  3034 KSP Residual norm 2.469535401461e-10
  3035 KSP Residual norm 2.048148466590e-10
  3036 KSP Residual norm 2.131850369873e-10
  3037 KSP Residual norm 2.402244027206e-10
  3038 KSP Residual norm 2.265575690659e-10
  3039 KSP Residual norm 2.201793732626e-10
  3040 KSP Residual norm 2.542561054348e-10
  3041 KSP Residual norm 2.862016869044e-10
  3042 KSP Residual norm 2.607882591758e-10
  3043 KSP Residual norm 2.294524561694e-10
  3044 KSP Residual norm 2.125312824216e-10
  3045 KSP Residual norm 1.926241911535e-10
  3046 KSP Residual norm 1.956068644538e-10
  3047 KSP Residual norm 2.334417409363e-10
  3048 KSP Residual norm 2.779233588432e-10
  3049 KSP Residual norm 2.786276471731e-10
  3050 KSP Residual norm 2.667357007110e-10
  3051 KSP Residual norm 2.563079580266e-10
  3052 KSP Residual norm 2.354460734323e-10
  3053 KSP Residual norm 2.210460740735e-10
  3054 KSP Residual norm 2.184529220018e-10
  3055 KSP Residual norm 2.266062223824e-10
  3056 KSP Residual norm 2.296891564012e-10
  3057 KSP Residual norm 2.087029977244e-10
  3058 KSP Residual norm 1.884882431539e-10
  3059 KSP Residual norm 1.849072492994e-10
  3060 KSP Residual norm 1.933359378955e-10
  3061 KSP Residual norm 2.116624386071e-10
  3062 KSP Residual norm 2.338286383802e-10
  3063 KSP Residual norm 2.465176354056e-10
  3064 KSP Residual norm 2.365417131467e-10
  3065 KSP Residual norm 2.249229066633e-10
  3066 KSP Residual norm 2.448077727987e-10
  3067 KSP Residual norm 2.839151725092e-10
  3068 KSP Residual norm 2.766795299586e-10
  3069 KSP Residual norm 2.606315092731e-10
  3070 KSP Residual norm 2.650270457160e-10
  3071 KSP Residual norm 2.691177332525e-10
  3072 KSP Residual norm 2.616327225440e-10
  3073 KSP Residual norm 2.546012419948e-10
  3074 KSP Residual norm 2.268162557471e-10
  3075 KSP Residual norm 1.888110336794e-10
  3076 KSP Residual norm 1.657596910712e-10
  3077 KSP Residual norm 1.486168146967e-10
  3078 KSP Residual norm 1.346454796747e-10
  3079 KSP Residual norm 1.430818559260e-10
  3080 KSP Residual norm 1.647390071032e-10
  3081 KSP Residual norm 1.556128203702e-10
  3082 KSP Residual norm 1.292853797214e-10
  3083 KSP Residual norm 1.169276587706e-10
  3084 KSP Residual norm 1.150883138190e-10
  3085 KSP Residual norm 1.089736071152e-10
  3086 KSP Residual norm 1.077616032030e-10
  3087 KSP Residual norm 1.175530702237e-10
  3088 KSP Residual norm 1.221428961084e-10
  3089 KSP Residual norm 1.171599409728e-10
  3090 KSP Residual norm 1.160797278241e-10
  3091 KSP Residual norm 1.124576801714e-10
  3092 KSP Residual norm 1.056448089233e-10
  3093 KSP Residual norm 1.051531935013e-10
  3094 KSP Residual norm 1.003290598742e-10
  3095 KSP Residual norm 8.784263113800e-11
  3096 KSP Residual norm 7.886572751839e-11
  3097 KSP Residual norm 8.262692204561e-11
  3098 KSP Residual norm 8.885841735828e-11
  3099 KSP Residual norm 8.729169313802e-11
  3100 KSP Residual norm 7.949082066158e-11
  3101 KSP Residual norm 7.243742888685e-11
  3102 KSP Residual norm 6.351640386139e-11
  3103 KSP Residual norm 5.949914991173e-11
  3104 KSP Residual norm 6.844402487716e-11
  3105 KSP Residual norm 8.513589124006e-11
  3106 KSP Residual norm 9.174384498793e-11
  3107 KSP Residual norm 9.328404417081e-11
  3108 KSP Residual norm 8.297274865652e-11
  3109 KSP Residual norm 6.282663836471e-11
  3110 KSP Residual norm 5.365311875498e-11
  3111 KSP Residual norm 5.297977403727e-11
  3112 KSP Residual norm 5.063250259290e-11
  3113 KSP Residual norm 4.982913442150e-11
  3114 KSP Residual norm 5.422497867112e-11
  3115 KSP Residual norm 5.510940773171e-11
  3116 KSP Residual norm 4.918301566347e-11
  3117 KSP Residual norm 4.584589653722e-11
  3118 KSP Residual norm 4.470260866104e-11
  3119 KSP Residual norm 4.102496818577e-11
  3120 KSP Residual norm 3.728466832460e-11
  3121 KSP Residual norm 3.666512293034e-11
  3122 KSP Residual norm 3.871040493418e-11
  3123 KSP Residual norm 3.985738959604e-11
  3124 KSP Residual norm 3.971308778454e-11
  3125 KSP Residual norm 4.294684988962e-11
  3126 KSP Residual norm 4.584097034345e-11
  3127 KSP Residual norm 4.571445152909e-11
  3128 KSP Residual norm 4.587481956880e-11
  3129 KSP Residual norm 4.792398016564e-11
  3130 KSP Residual norm 5.037428353665e-11
  3131 KSP Residual norm 4.911391653513e-11
  3132 KSP Residual norm 4.509056807156e-11
  3133 KSP Residual norm 4.513740221507e-11
  3134 KSP Residual norm 4.664441273013e-11
  3135 KSP Residual norm 4.433926280757e-11
  3136 KSP Residual norm 4.182326055261e-11
  3137 KSP Residual norm 4.069076238062e-11
  3138 KSP Residual norm 4.085761016337e-11
  3139 KSP Residual norm 4.144738743686e-11
  3140 KSP Residual norm 4.809373764989e-11
  3141 KSP Residual norm 5.916625029816e-11
  3142 KSP Residual norm 5.965620833269e-11
  3143 KSP Residual norm 5.814325154515e-11
  3144 KSP Residual norm 6.853989071551e-11
  3145 KSP Residual norm 7.601685589142e-11
  3146 KSP Residual norm 6.671802165544e-11
  3147 KSP Residual norm 5.820327413471e-11
  3148 KSP Residual norm 5.594421520670e-11
  3149 KSP Residual norm 5.523458813810e-11
  3150 KSP Residual norm 6.074661818432e-11
  3151 KSP Residual norm 7.200869545119e-11
  3152 KSP Residual norm 7.454675436905e-11
  3153 KSP Residual norm 7.077785959259e-11
  3154 KSP Residual norm 7.203333736681e-11
  3155 KSP Residual norm 7.780795774508e-11
  3156 KSP Residual norm 8.635628192525e-11
  3157 KSP Residual norm 1.003216037196e-10
  3158 KSP Residual norm 1.009740359010e-10
  3159 KSP Residual norm 9.300923075687e-11
  3160 KSP Residual norm 1.054306029504e-10
  3161 KSP Residual norm 1.313965079223e-10
  3162 KSP Residual norm 1.274676220169e-10
  3163 KSP Residual norm 1.042175159654e-10
  3164 KSP Residual norm 9.544189914654e-11
  3165 KSP Residual norm 1.017976224232e-10
  3166 KSP Residual norm 1.184742228405e-10
  3167 KSP Residual norm 1.426652727774e-10
  3168 KSP Residual norm 1.519876276756e-10
  3169 KSP Residual norm 1.414399705748e-10
  3170 KSP Residual norm 1.325633763027e-10
  3171 KSP Residual norm 1.355412045541e-10
  3172 KSP Residual norm 1.417413615427e-10
  3173 KSP Residual norm 1.542832380908e-10
  3174 KSP Residual norm 1.669434289383e-10
  3175 KSP Residual norm 1.812725525160e-10
  3176 KSP Residual norm 2.103151720169e-10
  3177 KSP Residual norm 2.482950042305e-10
  3178 KSP Residual norm 2.748770554753e-10
  3179 KSP Residual norm 2.746097786508e-10
  3180 KSP Residual norm 2.397462783142e-10
  3181 KSP Residual norm 1.857138078675e-10
  3182 KSP Residual norm 1.551553637169e-10
  3183 KSP Residual norm 1.704106580391e-10
  3184 KSP Residual norm 2.228179662809e-10
  3185 KSP Residual norm 2.610008846858e-10
  3186 KSP Residual norm 2.569760997459e-10
  3187 KSP Residual norm 2.466227297936e-10
  3188 KSP Residual norm 2.318632625686e-10
  3189 KSP Residual norm 2.223784912783e-10
  3190 KSP Residual norm 2.348711244950e-10
  3191 KSP Residual norm 2.484086393324e-10
  3192 KSP Residual norm 2.250032949247e-10
  3193 KSP Residual norm 1.869438066587e-10
  3194 KSP Residual norm 1.501871274267e-10
  3195 KSP Residual norm 1.103983980661e-10
  3196 KSP Residual norm 9.052676319188e-11
  3197 KSP Residual norm 1.004510996368e-10
  3198 KSP Residual norm 1.350110613138e-10
  3199 KSP Residual norm 1.618554838079e-10
  3200 KSP Residual norm 1.794668102950e-10
  3201 KSP Residual norm 2.103194188278e-10
  3202 KSP Residual norm 2.266991759421e-10
  3203 KSP Residual norm 2.145543524745e-10
  3204 KSP Residual norm 2.162549564413e-10
  3205 KSP Residual norm 2.173455067825e-10
  3206 KSP Residual norm 1.825202927983e-10
  3207 KSP Residual norm 1.474288372031e-10
  3208 KSP Residual norm 1.323706501708e-10
  3209 KSP Residual norm 1.176077619079e-10
  3210 KSP Residual norm 1.037870761520e-10
  3211 KSP Residual norm 1.095151438899e-10
  3212 KSP Residual norm 1.315981579815e-10
  3213 KSP Residual norm 1.513174891594e-10
  3214 KSP Residual norm 1.861142187762e-10
  3215 KSP Residual norm 2.498573985392e-10
  3216 KSP Residual norm 2.753951528833e-10
  3217 KSP Residual norm 2.369600538044e-10
  3218 KSP Residual norm 1.812268470452e-10
  3219 KSP Residual norm 1.318404218297e-10
  3220 KSP Residual norm 1.085512045717e-10
  3221 KSP Residual norm 1.053002290212e-10
  3222 KSP Residual norm 1.067203619783e-10
  3223 KSP Residual norm 1.050724020343e-10
  3224 KSP Residual norm 1.167929063646e-10
  3225 KSP Residual norm 1.428581208283e-10
  3226 KSP Residual norm 1.626078855332e-10
  3227 KSP Residual norm 1.796512340171e-10
  3228 KSP Residual norm 1.915506940428e-10
  3229 KSP Residual norm 1.618555167397e-10
  3230 KSP Residual norm 1.289508129166e-10
  3231 KSP Residual norm 1.136556641398e-10
  3232 KSP Residual norm 1.035903741967e-10
  3233 KSP Residual norm 1.022234391560e-10
  3234 KSP Residual norm 1.179892718465e-10
  3235 KSP Residual norm 1.336711154933e-10
  3236 KSP Residual norm 1.217428867216e-10
  3237 KSP Residual norm 1.079429250303e-10
  3238 KSP Residual norm 9.523923351772e-11
  3239 KSP Residual norm 8.970022755045e-11
  3240 KSP Residual norm 9.821917820522e-11
  3241 KSP Residual norm 1.112150352802e-10
  3242 KSP Residual norm 1.112681054195e-10
  3243 KSP Residual norm 1.075819176977e-10
  3244 KSP Residual norm 1.018141545271e-10
  3245 KSP Residual norm 8.438393490804e-11
  3246 KSP Residual norm 6.751111666085e-11
  3247 KSP Residual norm 6.393806876166e-11
  3248 KSP Residual norm 6.705482700107e-11
  3249 KSP Residual norm 6.531062939849e-11
  3250 KSP Residual norm 5.832979179078e-11
  3251 KSP Residual norm 5.064127546472e-11
  3252 KSP Residual norm 4.492423463737e-11
  3253 KSP Residual norm 4.755823974602e-11
  3254 KSP Residual norm 5.791872890217e-11
  3255 KSP Residual norm 7.024294564646e-11
  3256 KSP Residual norm 6.550059175618e-11
  3257 KSP Residual norm 4.968424916681e-11
  3258 KSP Residual norm 3.692327893091e-11
  3259 KSP Residual norm 2.883853146583e-11
  3260 KSP Residual norm 2.571934840885e-11
  3261 KSP Residual norm 2.925462969071e-11
  3262 KSP Residual norm 3.980615267854e-11
  3263 KSP Residual norm 5.284330461985e-11
  3264 KSP Residual norm 5.636975088820e-11
  3265 KSP Residual norm 4.879615949775e-11
  3266 KSP Residual norm 4.110020642935e-11
  3267 KSP Residual norm 3.770806440637e-11
  3268 KSP Residual norm 4.039031126019e-11
  3269 KSP Residual norm 4.597081952006e-11
  3270 KSP Residual norm 5.162572610533e-11
  3271 KSP Residual norm 5.766679786297e-11
  3272 KSP Residual norm 5.942285598031e-11
  3273 KSP Residual norm 5.810007528248e-11
  3274 KSP Residual norm 5.803260733973e-11
  3275 KSP Residual norm 5.169392320556e-11
  3276 KSP Residual norm 4.005138465833e-11
  3277 KSP Residual norm 3.431545434839e-11
  3278 KSP Residual norm 3.485784406053e-11
  3279 KSP Residual norm 3.575100704778e-11
  3280 KSP Residual norm 4.113326524296e-11
  3281 KSP Residual norm 5.243424479543e-11
  3282 KSP Residual norm 6.006026934887e-11
  3283 KSP Residual norm 5.846293102654e-11
  3284 KSP Residual norm 5.869244033153e-11
  3285 KSP Residual norm 6.289406007166e-11
  3286 KSP Residual norm 6.798855082956e-11
  3287 KSP Residual norm 7.107705034424e-11
  3288 KSP Residual norm 7.110617768374e-11
  3289 KSP Residual norm 6.870567155612e-11
  3290 KSP Residual norm 6.846279164383e-11
  3291 KSP Residual norm 7.208975746138e-11
  3292 KSP Residual norm 7.682499183672e-11
  3293 KSP Residual norm 8.846440966444e-11
  3294 KSP Residual norm 1.122445315827e-10
  3295 KSP Residual norm 1.278134456487e-10
  3296 KSP Residual norm 1.094942128582e-10
  3297 KSP Residual norm 8.467383983528e-11
  3298 KSP Residual norm 7.385689774838e-11
  3299 KSP Residual norm 8.082369733595e-11
  3300 KSP Residual norm 1.065182999386e-10
  3301 KSP Residual norm 1.520861591357e-10
  3302 KSP Residual norm 2.033825468542e-10
  3303 KSP Residual norm 2.192230498169e-10
  3304 KSP Residual norm 1.887639668288e-10
  3305 KSP Residual norm 1.478064903758e-10
  3306 KSP Residual norm 1.191244009599e-10
  3307 KSP Residual norm 1.177558502157e-10
  3308 KSP Residual norm 1.386444414489e-10
  3309 KSP Residual norm 1.669552805175e-10
  3310 KSP Residual norm 1.965322007887e-10
  3311 KSP Residual norm 2.329018360254e-10
  3312 KSP Residual norm 2.289665356512e-10
  3313 KSP Residual norm 1.750070922389e-10
  3314 KSP Residual norm 1.328350562496e-10
  3315 KSP Residual norm 1.282365508702e-10
  3316 KSP Residual norm 1.506386302337e-10
  3317 KSP Residual norm 1.941071835217e-10
  3318 KSP Residual norm 2.541177831587e-10
  3319 KSP Residual norm 2.516177377778e-10
  3320 KSP Residual norm 1.750182321173e-10
  3321 KSP Residual norm 1.281395123657e-10
  3322 KSP Residual norm 1.170898267753e-10
  3323 KSP Residual norm 1.343839583065e-10
  3324 KSP Residual norm 1.884599281521e-10
  3325 KSP Residual norm 2.941834838452e-10
  3326 KSP Residual norm 4.370036244922e-10
  3327 KSP Residual norm 4.314717126356e-10
  3328 KSP Residual norm 3.280250204608e-10
  3329 KSP Residual norm 2.312443138177e-10
  3330 KSP Residual norm 1.740708047297e-10
  3331 KSP Residual norm 1.683942727067e-10
  3332 KSP Residual norm 2.055224506063e-10
  3333 KSP Residual norm 2.805148030802e-10
  3334 KSP Residual norm 3.495075744702e-10
  3335 KSP Residual norm 3.900290868124e-10
  3336 KSP Residual norm 3.661173524256e-10
  3337 KSP Residual norm 2.768793247146e-10
  3338 KSP Residual norm 2.061689825815e-10
  3339 KSP Residual norm 1.829784721707e-10
  3340 KSP Residual norm 2.001019759723e-10
  3341 KSP Residual norm 2.588805902988e-10
  3342 KSP Residual norm 3.811789485937e-10
  3343 KSP Residual norm 5.070653363899e-10
  3344 KSP Residual norm 4.839554017803e-10
  3345 KSP Residual norm 3.922609280025e-10
  3346 KSP Residual norm 2.997198861114e-10
  3347 KSP Residual norm 2.311369090448e-10
  3348 KSP Residual norm 2.099368073223e-10
  3349 KSP Residual norm 2.449462719616e-10
  3350 KSP Residual norm 3.219176469895e-10
  3351 KSP Residual norm 4.356167806774e-10
  3352 KSP Residual norm 5.536404483035e-10
  3353 KSP Residual norm 5.205754474086e-10
  3354 KSP Residual norm 3.892047643635e-10
  3355 KSP Residual norm 3.134337093148e-10
  3356 KSP Residual norm 2.966553502900e-10
  3357 KSP Residual norm 2.718737268946e-10
  3358 KSP Residual norm 2.372393233552e-10
  3359 KSP Residual norm 2.244554600371e-10
  3360 KSP Residual norm 2.227938132623e-10
  3361 KSP Residual norm 2.212822595559e-10
  3362 KSP Residual norm 2.388120811816e-10
  3363 KSP Residual norm 2.752325609251e-10
  3364 KSP Residual norm 3.067999526233e-10
  3365 KSP Residual norm 3.372021561440e-10
  3366 KSP Residual norm 3.794737876579e-10
  3367 KSP Residual norm 4.053119574349e-10
  3368 KSP Residual norm 4.052086844763e-10
  3369 KSP Residual norm 3.971790277524e-10
  3370 KSP Residual norm 3.322730105977e-10
  3371 KSP Residual norm 2.333790228663e-10
  3372 KSP Residual norm 1.736358891670e-10
  3373 KSP Residual norm 1.586793093229e-10
  3374 KSP Residual norm 1.822875447850e-10
  3375 KSP Residual norm 2.216575749924e-10
  3376 KSP Residual norm 2.613486813931e-10
  3377 KSP Residual norm 2.771698644023e-10
  3378 KSP Residual norm 2.700326689111e-10
  3379 KSP Residual norm 2.676674483288e-10
  3380 KSP Residual norm 2.586373956920e-10
  3381 KSP Residual norm 2.400924771599e-10
  3382 KSP Residual norm 2.085725274617e-10
  3383 KSP Residual norm 1.620894141114e-10
  3384 KSP Residual norm 1.142378501781e-10
  3385 KSP Residual norm 8.923093583578e-11
  3386 KSP Residual norm 8.320292485485e-11
  3387 KSP Residual norm 8.677576722453e-11
  3388 KSP Residual norm 1.050806675273e-10
  3389 KSP Residual norm 1.359306723967e-10
  3390 KSP Residual norm 1.470482454342e-10
  3391 KSP Residual norm 1.309549914668e-10
  3392 KSP Residual norm 1.303046911751e-10
  3393 KSP Residual norm 1.466899186025e-10
  3394 KSP Residual norm 1.518655875922e-10
  3395 KSP Residual norm 1.337285188591e-10
  3396 KSP Residual norm 1.142356837656e-10
  3397 KSP Residual norm 8.902797008675e-11
  3398 KSP Residual norm 7.153826763123e-11
  3399 KSP Residual norm 7.110021767952e-11
  3400 KSP Residual norm 8.219138506379e-11
  3401 KSP Residual norm 8.887039786295e-11
  3402 KSP Residual norm 9.089271742171e-11
  3403 KSP Residual norm 9.861899982067e-11
  3404 KSP Residual norm 1.141883680035e-10
  3405 KSP Residual norm 1.338574352827e-10
  3406 KSP Residual norm 1.446651528281e-10
  3407 KSP Residual norm 1.229496299193e-10
  3408 KSP Residual norm 9.603575781956e-11
  3409 KSP Residual norm 8.755270348099e-11
  3410 KSP Residual norm 8.932730219936e-11
  3411 KSP Residual norm 8.933226888376e-11
  3412 KSP Residual norm 8.891505954572e-11
  3413 KSP Residual norm 9.018877655662e-11
  3414 KSP Residual norm 8.639878128655e-11
  3415 KSP Residual norm 8.623872451571e-11
  3416 KSP Residual norm 9.965915903982e-11
  3417 KSP Residual norm 1.149592902381e-10
  3418 KSP Residual norm 1.100887933390e-10
  3419 KSP Residual norm 8.854228242143e-11
  3420 KSP Residual norm 7.568275514015e-11
  3421 KSP Residual norm 7.244575793320e-11
  3422 KSP Residual norm 6.666257885435e-11
  3423 KSP Residual norm 5.513569118787e-11
  3424 KSP Residual norm 4.725163872814e-11
  3425 KSP Residual norm 4.963910969631e-11
  3426 KSP Residual norm 5.992282230103e-11
  3427 KSP Residual norm 6.958483625407e-11
  3428 KSP Residual norm 7.315419910881e-11
  3429 KSP Residual norm 7.696004697270e-11
  3430 KSP Residual norm 8.068087614643e-11
  3431 KSP Residual norm 7.971215699061e-11
  3432 KSP Residual norm 7.689458217420e-11
  3433 KSP Residual norm 6.601501589094e-11
  3434 KSP Residual norm 4.996036275089e-11
  3435 KSP Residual norm 4.161655824275e-11
  3436 KSP Residual norm 3.907799578890e-11
  3437 KSP Residual norm 3.787426366756e-11
  3438 KSP Residual norm 3.559382951637e-11
  3439 KSP Residual norm 3.408292140737e-11
  3440 KSP Residual norm 3.254813680769e-11
  3441 KSP Residual norm 3.183047380127e-11
  3442 KSP Residual norm 3.340158978214e-11
  3443 KSP Residual norm 3.979972535906e-11
  3444 KSP Residual norm 4.814061659969e-11
  3445 KSP Residual norm 5.175884059598e-11
  3446 KSP Residual norm 4.913638598068e-11
  3447 KSP Residual norm 4.959759060046e-11
  3448 KSP Residual norm 5.731864048132e-11
  3449 KSP Residual norm 6.055034287952e-11
  3450 KSP Residual norm 4.438126942495e-11
  3451 KSP Residual norm 3.086411670345e-11
  3452 KSP Residual norm 2.536467831973e-11
  3453 KSP Residual norm 2.317586298013e-11
  3454 KSP Residual norm 2.277471923607e-11
  3455 KSP Residual norm 2.318526168517e-11
  3456 KSP Residual norm 2.210051214277e-11
  3457 KSP Residual norm 2.182186315697e-11
  3458 KSP Residual norm 2.387628311984e-11
  3459 KSP Residual norm 2.652697995126e-11
  3460 KSP Residual norm 2.580024211929e-11
  3461 KSP Residual norm 2.406008022096e-11
  3462 KSP Residual norm 2.327404523175e-11
  3463 KSP Residual norm 2.425055013962e-11
  3464 KSP Residual norm 2.785113525536e-11
  3465 KSP Residual norm 2.984465392576e-11
  3466 KSP Residual norm 2.687410867953e-11
  3467 KSP Residual norm 2.368456543414e-11
  3468 KSP Residual norm 2.368302952833e-11
  3469 KSP Residual norm 2.216782277397e-11
  3470 KSP Residual norm 1.841448173654e-11
  3471 KSP Residual norm 1.621025354172e-11
  3472 KSP Residual norm 1.464900252165e-11
  3473 KSP Residual norm 1.532834144240e-11
  3474 KSP Residual norm 1.829318142791e-11
  3475 KSP Residual norm 1.950403032118e-11
  3476 KSP Residual norm 1.668723513144e-11
  3477 KSP Residual norm 1.574182980627e-11
  3478 KSP Residual norm 1.738136698995e-11
  3479 KSP Residual norm 2.191177734002e-11
  3480 KSP Residual norm 2.478857281006e-11
  3481 KSP Residual norm 2.296960716256e-11
  3482 KSP Residual norm 1.966331189780e-11
  3483 KSP Residual norm 1.823574333396e-11
  3484 KSP Residual norm 2.008792824458e-11
  3485 KSP Residual norm 2.058501113133e-11
  3486 KSP Residual norm 1.837189447630e-11
  3487 KSP Residual norm 1.558241819578e-11
  3488 KSP Residual norm 1.482354880788e-11
  3489 KSP Residual norm 1.664940014940e-11
  3490 KSP Residual norm 2.058308638326e-11
  3491 KSP Residual norm 2.460557469264e-11
  3492 KSP Residual norm 2.682182440247e-11
  3493 KSP Residual norm 3.102360740941e-11
  3494 KSP Residual norm 3.914000054643e-11
  3495 KSP Residual norm 4.496158730816e-11
  3496 KSP Residual norm 4.437367732687e-11
  3497 KSP Residual norm 4.000194802926e-11
  3498 KSP Residual norm 3.711753076805e-11
  3499 KSP Residual norm 3.777618604059e-11
  3500 KSP Residual norm 3.713293627090e-11
  3501 KSP Residual norm 3.160740829774e-11
  3502 KSP Residual norm 2.410690943738e-11
  3503 KSP Residual norm 1.966757686369e-11
  3504 KSP Residual norm 1.825704381500e-11
  3505 KSP Residual norm 1.885678295308e-11
  3506 KSP Residual norm 1.901010155588e-11
  3507 KSP Residual norm 1.796180488368e-11
  3508 KSP Residual norm 1.699277080956e-11
  3509 KSP Residual norm 1.759894427066e-11
  3510 KSP Residual norm 2.059450482348e-11
  3511 KSP Residual norm 2.507050913528e-11
  3512 KSP Residual norm 2.972961781508e-11
  3513 KSP Residual norm 3.252252183780e-11
  3514 KSP Residual norm 3.428957722512e-11
  3515 KSP Residual norm 3.463880417866e-11
  3516 KSP Residual norm 3.427755883941e-11
  3517 KSP Residual norm 3.208725417721e-11
  3518 KSP Residual norm 2.677507126355e-11
  3519 KSP Residual norm 2.236378967435e-11
  3520 KSP Residual norm 2.207950699969e-11
  3521 KSP Residual norm 2.385802017190e-11
  3522 KSP Residual norm 2.257803780762e-11
  3523 KSP Residual norm 1.838352457592e-11
  3524 KSP Residual norm 1.626939631450e-11
  3525 KSP Residual norm 1.677127213050e-11
  3526 KSP Residual norm 2.010745780446e-11
  3527 KSP Residual norm 2.690300809964e-11
  3528 KSP Residual norm 3.156391401697e-11
  3529 KSP Residual norm 2.986449847236e-11
  3530 KSP Residual norm 2.995009123434e-11
  3531 KSP Residual norm 3.721551922166e-11
  3532 KSP Residual norm 4.578104314475e-11
  3533 KSP Residual norm 4.571453044375e-11
  3534 KSP Residual norm 3.927460641209e-11
  3535 KSP Residual norm 3.725278372518e-11
  3536 KSP Residual norm 4.183190722799e-11
  3537 KSP Residual norm 4.378715646247e-11
  3538 KSP Residual norm 3.551727326698e-11
  3539 KSP Residual norm 2.648780261804e-11
  3540 KSP Residual norm 2.448543310460e-11
  3541 KSP Residual norm 2.648229551953e-11
  3542 KSP Residual norm 2.565164787755e-11
  3543 KSP Residual norm 2.167317159623e-11
  3544 KSP Residual norm 1.868151969719e-11
  3545 KSP Residual norm 1.989740836942e-11
  3546 KSP Residual norm 2.693818975558e-11
  3547 KSP Residual norm 3.719539520925e-11
  3548 KSP Residual norm 3.725570063429e-11
  3549 KSP Residual norm 3.592235320368e-11
  3550 KSP Residual norm 4.194643814029e-11
  3551 KSP Residual norm 5.625393945049e-11
  3552 KSP Residual norm 6.848193281423e-11
  3553 KSP Residual norm 7.476361977013e-11
  3554 KSP Residual norm 7.629448804726e-11
  3555 KSP Residual norm 7.948966755251e-11
  3556 KSP Residual norm 9.469391772273e-11
  3557 KSP Residual norm 1.006377896897e-10
  3558 KSP Residual norm 8.134742644095e-11
  3559 KSP Residual norm 6.906257314974e-11
  3560 KSP Residual norm 7.255639163106e-11
  3561 KSP Residual norm 7.845615100264e-11
  3562 KSP Residual norm 6.983767645912e-11
  3563 KSP Residual norm 5.776435366861e-11
  3564 KSP Residual norm 5.020312401755e-11
  3565 KSP Residual norm 5.308236513274e-11
  3566 KSP Residual norm 6.410455100164e-11
  3567 KSP Residual norm 6.905257813414e-11
  3568 KSP Residual norm 6.425386668960e-11
  3569 KSP Residual norm 7.300585487809e-11
  3570 KSP Residual norm 1.018744260328e-10
  3571 KSP Residual norm 1.273146999105e-10
  3572 KSP Residual norm 1.306107061486e-10
  3573 KSP Residual norm 1.240554449917e-10
  3574 KSP Residual norm 1.203412278679e-10
  3575 KSP Residual norm 1.286685256576e-10
  3576 KSP Residual norm 1.310605708080e-10
  3577 KSP Residual norm 1.076431316412e-10
  3578 KSP Residual norm 9.075971022190e-11
  3579 KSP Residual norm 9.828811094089e-11
  3580 KSP Residual norm 1.062524793050e-10
  3581 KSP Residual norm 1.040610359948e-10
  3582 KSP Residual norm 1.073688421809e-10
  3583 KSP Residual norm 1.207020446715e-10
  3584 KSP Residual norm 1.293740765834e-10
  3585 KSP Residual norm 1.311118071459e-10
  3586 KSP Residual norm 1.411861875230e-10
  3587 KSP Residual norm 1.704348031847e-10
  3588 KSP Residual norm 2.119964147848e-10
  3589 KSP Residual norm 2.184565637273e-10
  3590 KSP Residual norm 2.061434712586e-10
  3591 KSP Residual norm 2.208789529637e-10
  3592 KSP Residual norm 2.569472271703e-10
  3593 KSP Residual norm 2.514591328420e-10
  3594 KSP Residual norm 2.041642910364e-10
  3595 KSP Residual norm 1.747461507741e-10
  3596 KSP Residual norm 1.647823664682e-10
  3597 KSP Residual norm 1.609055345481e-10
  3598 KSP Residual norm 1.507957560195e-10
  3599 KSP Residual norm 1.278141971873e-10
  3600 KSP Residual norm 1.068480489382e-10
  3601 KSP Residual norm 1.016852326628e-10
  3602 KSP Residual norm 1.028613589170e-10
  3603 KSP Residual norm 9.518751098156e-11
  3604 KSP Residual norm 8.367373416348e-11
  3605 KSP Residual norm 8.639865354682e-11
  3606 KSP Residual norm 1.010015214290e-10
  3607 KSP Residual norm 1.136116769874e-10
  3608 KSP Residual norm 1.161673223308e-10
  3609 KSP Residual norm 1.151582778761e-10
  3610 KSP Residual norm 1.241679983574e-10
  3611 KSP Residual norm 1.428304751257e-10
  3612 KSP Residual norm 1.510049835125e-10
  3613 KSP Residual norm 1.418430233482e-10
  3614 KSP Residual norm 1.374868059590e-10
  3615 KSP Residual norm 1.441014513217e-10
  3616 KSP Residual norm 1.302501347568e-10
  3617 KSP Residual norm 9.965452988884e-11
  3618 KSP Residual norm 8.319435600947e-11
  3619 KSP Residual norm 7.844965724595e-11
  3620 KSP Residual norm 8.073184897737e-11
  3621 KSP Residual norm 8.419652730861e-11
  3622 KSP Residual norm 8.149522832848e-11
  3623 KSP Residual norm 7.357652241908e-11
  3624 KSP Residual norm 7.425233541078e-11
  3625 KSP Residual norm 7.991312515611e-11
  3626 KSP Residual norm 7.477504734031e-11
  3627 KSP Residual norm 7.180536945570e-11
  3628 KSP Residual norm 8.189481163010e-11
  3629 KSP Residual norm 1.005844287078e-10
  3630 KSP Residual norm 1.061942429056e-10
  3631 KSP Residual norm 9.594179144092e-11
  3632 KSP Residual norm 8.372625363004e-11
  3633 KSP Residual norm 7.932342454602e-11
  3634 KSP Residual norm 8.111378002999e-11
  3635 KSP Residual norm 7.957312449991e-11
  3636 KSP Residual norm 6.627181192782e-11
  3637 KSP Residual norm 5.758185314238e-11
  3638 KSP Residual norm 5.812445371886e-11
  3639 KSP Residual norm 5.664356915330e-11
  3640 KSP Residual norm 4.965946670570e-11
  3641 KSP Residual norm 4.618439329347e-11
  3642 KSP Residual norm 4.683942558805e-11
  3643 KSP Residual norm 4.713795470647e-11
  3644 KSP Residual norm 4.714161642911e-11
  3645 KSP Residual norm 4.311925609802e-11
  3646 KSP Residual norm 3.691664744998e-11
  3647 KSP Residual norm 3.482778490986e-11
  3648 KSP Residual norm 3.630269369446e-11
  3649 KSP Residual norm 3.872588874156e-11
  3650 KSP Residual norm 3.995480920393e-11
  3651 KSP Residual norm 4.122004301925e-11
  3652 KSP Residual norm 3.979820591653e-11
  3653 KSP Residual norm 4.112604995905e-11
  3654 KSP Residual norm 4.840137256878e-11
  3655 KSP Residual norm 5.164598261273e-11
  3656 KSP Residual norm 4.511625162187e-11
  3657 KSP Residual norm 3.759183533752e-11
  3658 KSP Residual norm 3.345117403518e-11
  3659 KSP Residual norm 3.244567247183e-11
  3660 KSP Residual norm 3.269853992911e-11
  3661 KSP Residual norm 2.870709551197e-11
  3662 KSP Residual norm 2.368446495162e-11
  3663 KSP Residual norm 2.293210723648e-11
  3664 KSP Residual norm 2.335040757054e-11
  3665 KSP Residual norm 2.033271210734e-11
  3666 KSP Residual norm 1.797222792896e-11
  3667 KSP Residual norm 1.845145837970e-11
  3668 KSP Residual norm 2.019520846332e-11
  3669 KSP Residual norm 2.191520621644e-11
  3670 KSP Residual norm 2.246270564243e-11
  3671 KSP Residual norm 2.130447957007e-11
  3672 KSP Residual norm 2.171994588838e-11
  3673 KSP Residual norm 2.541871350524e-11
  3674 KSP Residual norm 2.687010561086e-11
  3675 KSP Residual norm 2.767130705552e-11
  3676 KSP Residual norm 3.284086451425e-11
  3677 KSP Residual norm 3.799530351199e-11
  3678 KSP Residual norm 3.977303234143e-11
  3679 KSP Residual norm 4.175978654735e-11
  3680 KSP Residual norm 4.138001271305e-11
  3681 KSP Residual norm 4.010153067663e-11
  3682 KSP Residual norm 3.918758454198e-11
  3683 KSP Residual norm 3.761983833732e-11
  3684 KSP Residual norm 3.366712347304e-11
  3685 KSP Residual norm 3.187252131839e-11
  3686 KSP Residual norm 3.165845836567e-11
  3687 KSP Residual norm 3.007513892687e-11
  3688 KSP Residual norm 2.593304959042e-11
  3689 KSP Residual norm 2.219391839471e-11
  3690 KSP Residual norm 1.905563064041e-11
  3691 KSP Residual norm 1.714936448801e-11
  3692 KSP Residual norm 1.664478146761e-11
  3693 KSP Residual norm 1.485382077382e-11
  3694 KSP Residual norm 1.289167610342e-11
  3695 KSP Residual norm 1.289653525823e-11
  3696 KSP Residual norm 1.371538484474e-11
  3697 KSP Residual norm 1.384954537478e-11
  3698 KSP Residual norm 1.385790386902e-11
  3699 KSP Residual norm 1.317956872006e-11
  3700 KSP Residual norm 1.208996828063e-11
  3701 KSP Residual norm 1.216113876303e-11
  3702 KSP Residual norm 1.366035785386e-11
  3703 KSP Residual norm 1.421595243618e-11
  3704 KSP Residual norm 1.376337053308e-11
  3705 KSP Residual norm 1.375753741469e-11
  3706 KSP Residual norm 1.516151617702e-11
  3707 KSP Residual norm 1.710058653890e-11
  3708 KSP Residual norm 1.782168859101e-11
  3709 KSP Residual norm 1.682970827566e-11
  3710 KSP Residual norm 1.543826047640e-11
  3711 KSP Residual norm 1.541102084599e-11
  3712 KSP Residual norm 1.504364885928e-11
  3713 KSP Residual norm 1.278433722782e-11
  3714 KSP Residual norm 1.090079022061e-11
  3715 KSP Residual norm 1.034154128675e-11
  3716 KSP Residual norm 9.968691653883e-12
  3717 KSP Residual norm 9.364287532219e-12
  3718 KSP Residual norm 8.581827940308e-12
  3719 KSP Residual norm 7.520189563279e-12
  3720 KSP Residual norm 7.298536611933e-12
  3721 KSP Residual norm 7.838645779582e-12
  3722 KSP Residual norm 7.973330533763e-12
  3723 KSP Residual norm 7.617971930490e-12
  3724 KSP Residual norm 7.709371822261e-12
  3725 KSP Residual norm 7.921660487321e-12
  3726 KSP Residual norm 7.826632319502e-12
  3727 KSP Residual norm 8.546168299266e-12
  3728 KSP Residual norm 9.669942585504e-12
  3729 KSP Residual norm 1.020377646573e-11
  3730 KSP Residual norm 1.060394611832e-11
  3731 KSP Residual norm 1.115626836337e-11
  3732 KSP Residual norm 1.034401924137e-11
  3733 KSP Residual norm 8.941442676076e-12
  3734 KSP Residual norm 8.111778884222e-12
  3735 KSP Residual norm 7.314867735474e-12
  3736 KSP Residual norm 7.065916193624e-12
  3737 KSP Residual norm 7.312212847024e-12
  3738 KSP Residual norm 7.574248136095e-12
  3739 KSP Residual norm 7.339326761645e-12
  3740 KSP Residual norm 7.111062249793e-12
  3741 KSP Residual norm 6.686457586676e-12
  3742 KSP Residual norm 5.764712409075e-12
  3743 KSP Residual norm 5.382469847078e-12
  3744 KSP Residual norm 4.982527481351e-12
  3745 KSP Residual norm 4.467402609121e-12
  3746 KSP Residual norm 4.491195969803e-12
  3747 KSP Residual norm 4.775459519086e-12
  3748 KSP Residual norm 4.882400182022e-12
  3749 KSP Residual norm 5.462956377941e-12
  3750 KSP Residual norm 6.359745255369e-12
  3751 KSP Residual norm 7.014278094362e-12
  3752 KSP Residual norm 7.634319068017e-12
  3753 KSP Residual norm 8.548180800068e-12
  3754 KSP Residual norm 8.517097288632e-12
  3755 KSP Residual norm 8.259658790553e-12
  3756 KSP Residual norm 9.152889760024e-12
  3757 KSP Residual norm 1.005558643348e-11
  3758 KSP Residual norm 1.032322286004e-11
  3759 KSP Residual norm 9.720504443234e-12
  3760 KSP Residual norm 8.297596043589e-12
  3761 KSP Residual norm 7.822017055078e-12
  3762 KSP Residual norm 7.697032113225e-12
  3763 KSP Residual norm 6.791490030114e-12
  3764 KSP Residual norm 5.942386557173e-12
  3765 KSP Residual norm 5.900249341615e-12
  3766 KSP Residual norm 5.647888230178e-12
  3767 KSP Residual norm 5.026749479117e-12
  3768 KSP Residual norm 5.217084517522e-12
  3769 KSP Residual norm 6.188035065098e-12
  3770 KSP Residual norm 6.693643412815e-12
  3771 KSP Residual norm 6.611148166963e-12
  3772 KSP Residual norm 6.085122152017e-12
  3773 KSP Residual norm 5.791050431512e-12
  3774 KSP Residual norm 6.012640776174e-12
  3775 KSP Residual norm 6.686718769643e-12
  3776 KSP Residual norm 6.887893380338e-12
  3777 KSP Residual norm 7.250744614669e-12
  3778 KSP Residual norm 8.219003144381e-12
  3779 KSP Residual norm 8.846982334777e-12
  3780 KSP Residual norm 8.883140574438e-12
  3781 KSP Residual norm 9.047157642363e-12
  3782 KSP Residual norm 8.996941353069e-12
  3783 KSP Residual norm 9.365279738745e-12
  3784 KSP Residual norm 1.015312176788e-11
  3785 KSP Residual norm 9.566329649122e-12
  3786 KSP Residual norm 8.767400558761e-12
  3787 KSP Residual norm 9.098479575690e-12
  3788 KSP Residual norm 8.996096154668e-12
  3789 KSP Residual norm 8.161338974224e-12
  3790 KSP Residual norm 7.805029485318e-12
  3791 KSP Residual norm 8.154448513357e-12
  3792 KSP Residual norm 8.220034142044e-12
  3793 KSP Residual norm 7.323383911079e-12
  3794 KSP Residual norm 6.652405962992e-12
  3795 KSP Residual norm 6.468980735354e-12
  3796 KSP Residual norm 7.006477504749e-12
  3797 KSP Residual norm 7.463201918215e-12
  3798 KSP Residual norm 6.492251789383e-12
  3799 KSP Residual norm 6.172324390659e-12
  3800 KSP Residual norm 6.853204596900e-12
  3801 KSP Residual norm 7.082347687186e-12
  3802 KSP Residual norm 6.824093061508e-12
  3803 KSP Residual norm 7.461467359836e-12
  3804 KSP Residual norm 8.838985768006e-12
  3805 KSP Residual norm 9.917804987539e-12
  3806 KSP Residual norm 1.117135323223e-11
  3807 KSP Residual norm 1.355776899362e-11
  3808 KSP Residual norm 1.679158192636e-11
  3809 KSP Residual norm 1.852974382608e-11
  3810 KSP Residual norm 1.899697545286e-11
  3811 KSP Residual norm 1.981895642261e-11
  3812 KSP Residual norm 2.085987804693e-11
  3813 KSP Residual norm 2.061291943037e-11
  3814 KSP Residual norm 1.729895759565e-11
  3815 KSP Residual norm 1.487959277245e-11
  3816 KSP Residual norm 1.565000318736e-11
  3817 KSP Residual norm 1.594451143806e-11
  3818 KSP Residual norm 1.369161384088e-11
  3819 KSP Residual norm 1.220315755012e-11
  3820 KSP Residual norm 1.228539648443e-11
  3821 KSP Residual norm 1.177986454707e-11
  3822 KSP Residual norm 1.108898964748e-11
  3823 KSP Residual norm 1.022354391172e-11
  3824 KSP Residual norm 9.969064656808e-12
  3825 KSP Residual norm 1.116041119106e-11
  3826 KSP Residual norm 1.247532765617e-11
  3827 KSP Residual norm 1.180854559556e-11
  3828 KSP Residual norm 1.158221471437e-11
  3829 KSP Residual norm 1.415954452850e-11
  3830 KSP Residual norm 1.787381094332e-11
  3831 KSP Residual norm 1.936093094724e-11
  3832 KSP Residual norm 2.026472656191e-11
  3833 KSP Residual norm 2.186710544474e-11
  3834 KSP Residual norm 2.379242354545e-11
  3835 KSP Residual norm 2.670411235574e-11
  3836 KSP Residual norm 2.956945898690e-11
  3837 KSP Residual norm 3.037240910388e-11
  3838 KSP Residual norm 3.106360495709e-11
  3839 KSP Residual norm 3.302317488468e-11
  3840 KSP Residual norm 3.011618833108e-11
  3841 KSP Residual norm 2.683239184487e-11
  3842 KSP Residual norm 2.716252372211e-11
  3843 KSP Residual norm 2.724325077449e-11
  3844 KSP Residual norm 2.614707309500e-11
  3845 KSP Residual norm 2.507740404692e-11
  3846 KSP Residual norm 2.097204973335e-11
  3847 KSP Residual norm 1.765947054803e-11
  3848 KSP Residual norm 1.636798199712e-11
  3849 KSP Residual norm 1.527603018057e-11
  3850 KSP Residual norm 1.400095344538e-11
  3851 KSP Residual norm 1.425312828211e-11
  3852 KSP Residual norm 1.433717443853e-11
  3853 KSP Residual norm 1.372162024226e-11
  3854 KSP Residual norm 1.413646008131e-11
  3855 KSP Residual norm 1.517318095629e-11
  3856 KSP Residual norm 1.543496603754e-11
  3857 KSP Residual norm 1.518793256012e-11
  3858 KSP Residual norm 1.562883295683e-11
  3859 KSP Residual norm 1.583126172226e-11
  3860 KSP Residual norm 1.641106188350e-11
  3861 KSP Residual norm 1.815660725320e-11
  3862 KSP Residual norm 2.013616999191e-11
  3863 KSP Residual norm 2.306692151250e-11
  3864 KSP Residual norm 2.611833928874e-11
  3865 KSP Residual norm 2.558534710742e-11
  3866 KSP Residual norm 2.223572873814e-11
  3867 KSP Residual norm 2.118224813771e-11
  3868 KSP Residual norm 2.097996021233e-11
  3869 KSP Residual norm 2.118891652183e-11
  3870 KSP Residual norm 2.071719158672e-11
  3871 KSP Residual norm 2.005745662121e-11
  3872 KSP Residual norm 1.937106302097e-11
  3873 KSP Residual norm 1.926951728288e-11
  3874 KSP Residual norm 1.763821681645e-11
  3875 KSP Residual norm 1.588235851249e-11
  3876 KSP Residual norm 1.523536962635e-11
  3877 KSP Residual norm 1.444208771156e-11
  3878 KSP Residual norm 1.285092256672e-11
  3879 KSP Residual norm 1.229494050237e-11
  3880 KSP Residual norm 1.223737917510e-11
  3881 KSP Residual norm 1.115146113184e-11
  3882 KSP Residual norm 1.013689021920e-11
  3883 KSP Residual norm 9.806541151080e-12
  3884 KSP Residual norm 9.905259019708e-12
  3885 KSP Residual norm 1.042576736745e-11
  3886 KSP Residual norm 1.128545140278e-11
  3887 KSP Residual norm 1.194204067757e-11
  3888 KSP Residual norm 1.355808209646e-11
  3889 KSP Residual norm 1.562528603366e-11
  3890 KSP Residual norm 1.664250444244e-11
  3891 KSP Residual norm 1.606616716334e-11
  3892 KSP Residual norm 1.700164123231e-11
  3893 KSP Residual norm 1.874075925608e-11
  3894 KSP Residual norm 1.970284513762e-11
  3895 KSP Residual norm 2.125827068339e-11
  3896 KSP Residual norm 2.202546643014e-11
  3897 KSP Residual norm 2.056956651525e-11
  3898 KSP Residual norm 1.991669936393e-11
  3899 KSP Residual norm 1.937199402495e-11
  3900 KSP Residual norm 1.755783734077e-11
  3901 KSP Residual norm 1.545396491496e-11
  3902 KSP Residual norm 1.289959091752e-11
  3903 KSP Residual norm 1.023671080712e-11
  3904 KSP Residual norm 9.307771106884e-12
  3905 KSP Residual norm 8.994063218441e-12
  3906 KSP Residual norm 7.561322035569e-12
  3907 KSP Residual norm 6.287680448530e-12
  3908 KSP Residual norm 5.804838431703e-12
  3909 KSP Residual norm 5.437289738408e-12
  3910 KSP Residual norm 5.112546727907e-12
  3911 KSP Residual norm 4.704381267769e-12
  3912 KSP Residual norm 4.335877738373e-12
  3913 KSP Residual norm 4.162380963341e-12
  3914 KSP Residual norm 4.160093426191e-12
  3915 KSP Residual norm 4.004614526500e-12
  3916 KSP Residual norm 3.874960730836e-12
  3917 KSP Residual norm 4.208403188655e-12
  3918 KSP Residual norm 4.563150815371e-12
  3919 KSP Residual norm 4.444525000091e-12
  3920 KSP Residual norm 4.438713216956e-12
  3921 KSP Residual norm 5.074240988178e-12
  3922 KSP Residual norm 5.936715532582e-12
  3923 KSP Residual norm 6.705010322443e-12
  3924 KSP Residual norm 6.833434460410e-12
  3925 KSP Residual norm 6.752869771877e-12
  3926 KSP Residual norm 7.041903157664e-12
  3927 KSP Residual norm 7.470332347600e-12
  3928 KSP Residual norm 6.420609305933e-12
  3929 KSP Residual norm 5.281791693512e-12
  3930 KSP Residual norm 5.088483216393e-12
  3931 KSP Residual norm 4.741953153135e-12
  3932 KSP Residual norm 3.748006927707e-12
  3933 KSP Residual norm 2.975302428510e-12
  3934 KSP Residual norm 2.559876609141e-12
  3935 KSP Residual norm 2.369080214867e-12
  3936 KSP Residual norm 2.303111700887e-12
  3937 KSP Residual norm 2.247625947629e-12
  3938 KSP Residual norm 2.270232120320e-12
  3939 KSP Residual norm 2.459370856192e-12
  3940 KSP Residual norm 2.410657047357e-12
  3941 KSP Residual norm 2.040868969851e-12
  3942 KSP Residual norm 1.961317730485e-12
  3943 KSP Residual norm 2.189485563422e-12
  3944 KSP Residual norm 2.113908654966e-12
  3945 KSP Residual norm 1.773820793622e-12
  3946 KSP Residual norm 1.729825784971e-12
  3947 KSP Residual norm 1.915230457881e-12
  3948 KSP Residual norm 2.121583961283e-12
  3949 KSP Residual norm 2.284106663497e-12
  3950 KSP Residual norm 2.273175354748e-12
  3951 KSP Residual norm 2.391156315291e-12
  3952 KSP Residual norm 2.782051882792e-12
  3953 KSP Residual norm 2.868326858841e-12
  3954 KSP Residual norm 2.744436218461e-12
  3955 KSP Residual norm 2.922918630504e-12
  3956 KSP Residual norm 3.134098189986e-12
  3957 KSP Residual norm 2.937613084849e-12
  3958 KSP Residual norm 2.855995509275e-12
  3959 KSP Residual norm 3.137511400185e-12
  3960 KSP Residual norm 3.234433422852e-12
  3961 KSP Residual norm 3.057070527592e-12
  3962 KSP Residual norm 2.916537392872e-12
  3963 KSP Residual norm 2.837406726834e-12
  3964 KSP Residual norm 2.897376764040e-12
  3965 KSP Residual norm 3.056470798275e-12
  3966 KSP Residual norm 3.082556705169e-12
  3967 KSP Residual norm 3.010030960494e-12
  3968 KSP Residual norm 2.798925218727e-12
  3969 KSP Residual norm 2.143874696257e-12
  3970 KSP Residual norm 1.623510664839e-12
  3971 KSP Residual norm 1.447450857531e-12
  3972 KSP Residual norm 1.367546406527e-12
  3973 KSP Residual norm 1.189200011064e-12
  3974 KSP Residual norm 1.129245822781e-12
  3975 KSP Residual norm 1.245220262555e-12
  3976 KSP Residual norm 1.415695875502e-12
  3977 KSP Residual norm 1.493792770841e-12
  3978 KSP Residual norm 1.433788754247e-12
  3979 KSP Residual norm 1.310349436151e-12
  3980 KSP Residual norm 1.311490187403e-12
  3981 KSP Residual norm 1.346403840876e-12
  3982 KSP Residual norm 1.299546813925e-12
  3983 KSP Residual norm 1.332119341782e-12
  3984 KSP Residual norm 1.595987149188e-12
  3985 KSP Residual norm 1.936004784442e-12
  3986 KSP Residual norm 2.046816721365e-12
  3987 KSP Residual norm 2.040229570084e-12
  3988 KSP Residual norm 2.128593912246e-12
  3989 KSP Residual norm 2.334378848572e-12
  3990 KSP Residual norm 2.582116501535e-12
  3991 KSP Residual norm 2.521787333521e-12
  3992 KSP Residual norm 2.372789984969e-12
  3993 KSP Residual norm 2.590548639240e-12
  3994 KSP Residual norm 2.971396155057e-12
  3995 KSP Residual norm 2.989535596592e-12
  3996 KSP Residual norm 3.117964599616e-12
  3997 KSP Residual norm 3.495803780776e-12
  3998 KSP Residual norm 3.714385030824e-12
  3999 KSP Residual norm 3.745540254322e-12
  4000 KSP Residual norm 3.632484783481e-12
  4001 KSP Residual norm 3.612104904421e-12
  4002 KSP Residual norm 3.854541552583e-12
  4003 KSP Residual norm 3.890321484221e-12
  4004 KSP Residual norm 3.437875796802e-12
  4005 KSP Residual norm 3.026395710359e-12
  4006 KSP Residual norm 2.798892246472e-12
  4007 KSP Residual norm 2.376497919053e-12
  4008 KSP Residual norm 2.066565904823e-12
  4009 KSP Residual norm 2.106971107841e-12
  4010 KSP Residual norm 2.398622873963e-12
  4011 KSP Residual norm 2.436451731668e-12
  4012 KSP Residual norm 2.501850510616e-12
  4013 KSP Residual norm 2.722734382475e-12
  4014 KSP Residual norm 3.072940678351e-12
  4015 KSP Residual norm 3.302520856483e-12
  4016 KSP Residual norm 3.403673866707e-12
  4017 KSP Residual norm 3.558456457170e-12
  4018 KSP Residual norm 4.155758181163e-12
  4019 KSP Residual norm 4.730682332391e-12
  4020 KSP Residual norm 5.072514725281e-12
  4021 KSP Residual norm 5.627588599504e-12
  4022 KSP Residual norm 6.911216953962e-12
  4023 KSP Residual norm 7.317924444762e-12
  4024 KSP Residual norm 6.940120060310e-12
  4025 KSP Residual norm 7.408537526533e-12
  4026 KSP Residual norm 8.682361569497e-12
  4027 KSP Residual norm 1.005547535525e-11
  4028 KSP Residual norm 1.095796266923e-11
  4029 KSP Residual norm 1.100123477593e-11
  4030 KSP Residual norm 1.070941014977e-11
  4031 KSP Residual norm 1.111440713300e-11
  4032 KSP Residual norm 1.026454978481e-11
  4033 KSP Residual norm 8.341420403127e-12
  4034 KSP Residual norm 7.749560789360e-12
  4035 KSP Residual norm 8.396007512512e-12
  4036 KSP Residual norm 8.332431086386e-12
  4037 KSP Residual norm 7.333191890040e-12
  4038 KSP Residual norm 6.501771657031e-12
  4039 KSP Residual norm 5.819366189390e-12
  4040 KSP Residual norm 5.487907649745e-12
  4041 KSP Residual norm 4.884158002354e-12
  4042 KSP Residual norm 4.147904412716e-12
  4043 KSP Residual norm 4.121980272279e-12
  4044 KSP Residual norm 5.104143538555e-12
  4045 KSP Residual norm 5.523539855315e-12
  4046 KSP Residual norm 4.832745307477e-12
  4047 KSP Residual norm 4.755045819265e-12
  4048 KSP Residual norm 5.501269120086e-12
  4049 KSP Residual norm 6.301510312830e-12
  4050 KSP Residual norm 6.575849352680e-12
  4051 KSP Residual norm 6.809141584285e-12
  4052 KSP Residual norm 7.378191757793e-12
  4053 KSP Residual norm 8.433216473433e-12
  4054 KSP Residual norm 9.272732269943e-12
  4055 KSP Residual norm 9.561623636455e-12
  4056 KSP Residual norm 9.637485598592e-12
  4057 KSP Residual norm 9.818230339527e-12
  4058 KSP Residual norm 9.747590562723e-12
  4059 KSP Residual norm 1.010008192877e-11
  4060 KSP Residual norm 1.081716753893e-11
  4061 KSP Residual norm 1.122605249317e-11
  4062 KSP Residual norm 1.097656412414e-11
  4063 KSP Residual norm 1.058499593201e-11
  4064 KSP Residual norm 9.695916613368e-12
  4065 KSP Residual norm 8.590016663842e-12
  4066 KSP Residual norm 7.975116833287e-12
  4067 KSP Residual norm 7.487852009165e-12
  4068 KSP Residual norm 6.804625424971e-12
  4069 KSP Residual norm 6.142024618687e-12
  4070 KSP Residual norm 5.811668237187e-12
  4071 KSP Residual norm 5.550320006565e-12
  4072 KSP Residual norm 5.447105904237e-12
  4073 KSP Residual norm 5.232979552670e-12
  4074 KSP Residual norm 4.740804185621e-12
  4075 KSP Residual norm 4.505034251757e-12
  4076 KSP Residual norm 4.645449315599e-12
  4077 KSP Residual norm 4.656942858773e-12
  4078 KSP Residual norm 4.776005408012e-12
  4079 KSP Residual norm 4.952408190675e-12
  4080 KSP Residual norm 4.849469983913e-12
  4081 KSP Residual norm 4.598758805629e-12
  4082 KSP Residual norm 4.518527775292e-12
  4083 KSP Residual norm 4.556694361654e-12
  4084 KSP Residual norm 4.897099154331e-12
  4085 KSP Residual norm 5.180884659165e-12
  4086 KSP Residual norm 4.729690524592e-12
  4087 KSP Residual norm 4.412710074368e-12
  4088 KSP Residual norm 4.840057350196e-12
  4089 KSP Residual norm 5.361427973143e-12
  4090 KSP Residual norm 4.958743031047e-12
  4091 KSP Residual norm 4.777012384117e-12
  4092 KSP Residual norm 5.012454010999e-12
  4093 KSP Residual norm 5.463119450873e-12
  4094 KSP Residual norm 5.580391517731e-12
  4095 KSP Residual norm 5.484504783757e-12
  4096 KSP Residual norm 5.392380153756e-12
  4097 KSP Residual norm 5.596264853152e-12
  4098 KSP Residual norm 5.788124201012e-12
  4099 KSP Residual norm 5.338139867049e-12
  4100 KSP Residual norm 5.028961130634e-12
  4101 KSP Residual norm 5.196737695605e-12
  4102 KSP Residual norm 4.994442094642e-12
  4103 KSP Residual norm 4.457162837789e-12
  4104 KSP Residual norm 4.336766861414e-12
  4105 KSP Residual norm 4.241261474446e-12
  4106 KSP Residual norm 3.876077306801e-12
  4107 KSP Residual norm 3.773891543988e-12
  4108 KSP Residual norm 3.692156360888e-12
  4109 KSP Residual norm 3.108566065976e-12
  4110 KSP Residual norm 2.532361956891e-12
  4111 KSP Residual norm 2.195179953933e-12
  4112 KSP Residual norm 2.005385398534e-12
  4113 KSP Residual norm 2.165441364729e-12
  4114 KSP Residual norm 2.438704615412e-12
  4115 KSP Residual norm 2.453193328565e-12
  4116 KSP Residual norm 2.334881363405e-12
  4117 KSP Residual norm 2.351486566164e-12
  4118 KSP Residual norm 2.328770035385e-12
  4119 KSP Residual norm 2.436223785387e-12
  4120 KSP Residual norm 2.547312328981e-12
  4121 KSP Residual norm 2.568589212493e-12
  4122 KSP Residual norm 2.638811597376e-12
  4123 KSP Residual norm 2.897872619967e-12
  4124 KSP Residual norm 2.967677350852e-12
  4125 KSP Residual norm 2.915304519152e-12
  4126 KSP Residual norm 2.936043479247e-12
  4127 KSP Residual norm 2.790059705419e-12
  4128 KSP Residual norm 2.761818330250e-12
  4129 KSP Residual norm 2.931944467230e-12
  4130 KSP Residual norm 2.937799573277e-12
  4131 KSP Residual norm 2.779968004098e-12
  4132 KSP Residual norm 2.676609615076e-12
  4133 KSP Residual norm 2.619587488787e-12
  4134 KSP Residual norm 2.496041327860e-12
  4135 KSP Residual norm 2.457204824607e-12
  4136 KSP Residual norm 2.372302435638e-12
  4137 KSP Residual norm 2.380355319922e-12
  4138 KSP Residual norm 2.388871559537e-12
  4139 KSP Residual norm 2.164748297247e-12
  4140 KSP Residual norm 1.965193651881e-12
  4141 KSP Residual norm 2.009668195101e-12
  4142 KSP Residual norm 2.031014528491e-12
  4143 KSP Residual norm 1.838650237450e-12
  4144 KSP Residual norm 1.778989543144e-12
  4145 KSP Residual norm 1.719174025321e-12
  4146 KSP Residual norm 1.573949523596e-12
  4147 KSP Residual norm 1.487744704197e-12
  4148 KSP Residual norm 1.376496716099e-12
  4149 KSP Residual norm 1.210332694921e-12
  4150 KSP Residual norm 1.072077690657e-12
  4151 KSP Residual norm 9.636759853239e-13
  4152 KSP Residual norm 8.978176584015e-13
  4153 KSP Residual norm 9.074329279340e-13
  4154 KSP Residual norm 8.872811574900e-13
  4155 KSP Residual norm 7.906491144898e-13
  4156 KSP Residual norm 7.315378854277e-13
  4157 KSP Residual norm 6.941250867029e-13
  4158 KSP Residual norm 6.302149790344e-13
  4159 KSP Residual norm 5.805986226317e-13
  4160 KSP Residual norm 5.632018308303e-13
  4161 KSP Residual norm 5.260536530787e-13
  4162 KSP Residual norm 4.924540196826e-13
  4163 KSP Residual norm 4.866856124941e-13
  4164 KSP Residual norm 4.887099151342e-13
  4165 KSP Residual norm 5.391058470781e-13
  4166 KSP Residual norm 6.388302926618e-13
  4167 KSP Residual norm 6.580514918767e-13
  4168 KSP Residual norm 6.189720862163e-13
  4169 KSP Residual norm 6.518164180713e-13
  4170 KSP Residual norm 7.350667052019e-13
  4171 KSP Residual norm 8.349017109924e-13
  4172 KSP Residual norm 1.040882628235e-12
  4173 KSP Residual norm 1.284975163327e-12
  4174 KSP Residual norm 1.235487216283e-12
  4175 KSP Residual norm 1.140450303584e-12
  4176 KSP Residual norm 1.190386199188e-12
  4177 KSP Residual norm 1.297961569738e-12
  4178 KSP Residual norm 1.367272768015e-12
  4179 KSP Residual norm 1.358437777270e-12
  4180 KSP Residual norm 1.290557053610e-12
  4181 KSP Residual norm 1.360958321853e-12
  4182 KSP Residual norm 1.576251872252e-12
  4183 KSP Residual norm 1.635821649585e-12
  4184 KSP Residual norm 1.646215954884e-12
  4185 KSP Residual norm 1.720408281434e-12
  4186 KSP Residual norm 1.742075741180e-12
  4187 KSP Residual norm 1.638833558464e-12
  4188 KSP Residual norm 1.484031800010e-12
  4189 KSP Residual norm 1.393569636092e-12
  4190 KSP Residual norm 1.323158504441e-12
  4191 KSP Residual norm 1.173979541907e-12
  4192 KSP Residual norm 9.787894170910e-13
  4193 KSP Residual norm 7.970031920806e-13
  4194 KSP Residual norm 7.181778595965e-13
  4195 KSP Residual norm 7.024989147695e-13
  4196 KSP Residual norm 6.427351601814e-13
  4197 KSP Residual norm 6.098973452321e-13
  4198 KSP Residual norm 6.064083593966e-13
  4199 KSP Residual norm 5.991766431913e-13
  4200 KSP Residual norm 6.006784042900e-13
  4201 KSP Residual norm 5.929587834114e-13
  4202 KSP Residual norm 5.371759240552e-13
  4203 KSP Residual norm 4.723699082384e-13
  4204 KSP Residual norm 4.288638862190e-13
  4205 KSP Residual norm 4.116287083235e-13
  4206 KSP Residual norm 4.134256928570e-13
  4207 KSP Residual norm 4.646908692584e-13
  4208 KSP Residual norm 5.095464710027e-13
  4209 KSP Residual norm 5.655967195264e-13
  4210 KSP Residual norm 6.936635437812e-13
  4211 KSP Residual norm 8.262037803297e-13
  4212 KSP Residual norm 8.956453526317e-13
  4213 KSP Residual norm 9.705251358860e-13
  4214 KSP Residual norm 1.144634524299e-12
  4215 KSP Residual norm 1.309470062725e-12
  4216 KSP Residual norm 1.449177461020e-12
  4217 KSP Residual norm 1.567531317372e-12
  4218 KSP Residual norm 1.686699890725e-12
  4219 KSP Residual norm 1.807721554767e-12
  4220 KSP Residual norm 1.799793513528e-12
  4221 KSP Residual norm 1.676280467816e-12
  4222 KSP Residual norm 1.685355331379e-12
  4223 KSP Residual norm 1.789003736006e-12
  4224 KSP Residual norm 1.784332906645e-12
  4225 KSP Residual norm 1.887626596434e-12
  4226 KSP Residual norm 2.146500546360e-12
  4227 KSP Residual norm 2.215038667803e-12
  4228 KSP Residual norm 2.153785837320e-12
  4229 KSP Residual norm 2.138556725193e-12
  4230 KSP Residual norm 2.275550157723e-12
  4231 KSP Residual norm 2.417812161464e-12
  4232 KSP Residual norm 2.271316705146e-12
  4233 KSP Residual norm 2.031607638058e-12
  4234 KSP Residual norm 1.958742891332e-12
  4235 KSP Residual norm 1.927864467265e-12
  4236 KSP Residual norm 1.777215127308e-12
  4237 KSP Residual norm 1.817461915082e-12
  4238 KSP Residual norm 2.073551018282e-12
  4239 KSP Residual norm 2.174875625718e-12
  4240 KSP Residual norm 2.105814624625e-12
  4241 KSP Residual norm 2.047828167318e-12
  4242 KSP Residual norm 1.963858691399e-12
  4243 KSP Residual norm 1.740109509462e-12
  4244 KSP Residual norm 1.487254427294e-12
  4245 KSP Residual norm 1.395755750891e-12
  4246 KSP Residual norm 1.432141907467e-12
  4247 KSP Residual norm 1.494773839748e-12
  4248 KSP Residual norm 1.437662548637e-12
  4249 KSP Residual norm 1.408847033512e-12
  4250 KSP Residual norm 1.534866474598e-12
  4251 KSP Residual norm 1.711498861688e-12
  4252 KSP Residual norm 1.812618358945e-12
  4253 KSP Residual norm 1.824841554321e-12
  4254 KSP Residual norm 1.855138135645e-12
  4255 KSP Residual norm 1.998565138501e-12
  4256 KSP Residual norm 2.096623948141e-12
  4257 KSP Residual norm 1.975852076496e-12
  4258 KSP Residual norm 1.977729046086e-12
  4259 KSP Residual norm 2.075083098594e-12
  4260 KSP Residual norm 2.203366611847e-12
  4261 KSP Residual norm 2.282851034556e-12
  4262 KSP Residual norm 2.376396254481e-12
  4263 KSP Residual norm 2.490828270152e-12
  4264 KSP Residual norm 2.555988628099e-12
  4265 KSP Residual norm 2.603667518431e-12
  4266 KSP Residual norm 2.681905264510e-12
  4267 KSP Residual norm 2.731917796090e-12
  4268 KSP Residual norm 2.608338382615e-12
  4269 KSP Residual norm 2.506097183602e-12
  4270 KSP Residual norm 2.721767136013e-12
  4271 KSP Residual norm 3.105125135282e-12
  4272 KSP Residual norm 3.331534622663e-12
  4273 KSP Residual norm 3.347810164054e-12
  4274 KSP Residual norm 3.414649573483e-12
  4275 KSP Residual norm 3.683866538803e-12
  4276 KSP Residual norm 4.082263239819e-12
  4277 KSP Residual norm 4.422367646180e-12
  4278 KSP Residual norm 4.503311971211e-12
  4279 KSP Residual norm 4.915749732951e-12
  4280 KSP Residual norm 5.462882561808e-12
  4281 KSP Residual norm 5.355392811856e-12
  4282 KSP Residual norm 4.741436033225e-12
  4283 KSP Residual norm 4.543555506834e-12
  4284 KSP Residual norm 4.567850037832e-12
  4285 KSP Residual norm 4.336364285056e-12
  4286 KSP Residual norm 4.026868223431e-12
  4287 KSP Residual norm 3.808545460471e-12
  4288 KSP Residual norm 3.560894636193e-12
  4289 KSP Residual norm 3.102325859175e-12
  4290 KSP Residual norm 2.808871035925e-12
  4291 KSP Residual norm 2.857438939100e-12
  4292 KSP Residual norm 3.164573744620e-12
  4293 KSP Residual norm 3.285275459747e-12
  4294 KSP Residual norm 3.192964301182e-12
  4295 KSP Residual norm 3.230660255289e-12
  4296 KSP Residual norm 3.334576390350e-12
  4297 KSP Residual norm 3.276173044267e-12
  4298 KSP Residual norm 3.321415637321e-12
  4299 KSP Residual norm 3.663870402715e-12
  4300 KSP Residual norm 4.263431072637e-12
  4301 KSP Residual norm 4.710042669789e-12
  4302 KSP Residual norm 4.693604195782e-12
  4303 KSP Residual norm 4.568589029363e-12
  4304 KSP Residual norm 4.597181535584e-12
  4305 KSP Residual norm 4.513971163786e-12
  4306 KSP Residual norm 4.659957415214e-12
  4307 KSP Residual norm 4.850282861480e-12
  4308 KSP Residual norm 5.593038560025e-12
  4309 KSP Residual norm 6.510824613436e-12
  4310 KSP Residual norm 7.539783538790e-12
  4311 KSP Residual norm 8.680918964755e-12
  4312 KSP Residual norm 9.257583389504e-12
  4313 KSP Residual norm 9.706421183939e-12
  4314 KSP Residual norm 1.043282264391e-11
  4315 KSP Residual norm 1.088652675137e-11
  4316 KSP Residual norm 1.121139499262e-11
  4317 KSP Residual norm 1.157179382893e-11
  4318 KSP Residual norm 1.202304132919e-11
  4319 KSP Residual norm 1.320173063631e-11
  4320 KSP Residual norm 1.572332815614e-11
  4321 KSP Residual norm 1.714603907192e-11
  4322 KSP Residual norm 1.638016555086e-11
  4323 KSP Residual norm 1.696829936866e-11
  4324 KSP Residual norm 1.782376915144e-11
  4325 KSP Residual norm 1.756613844205e-11
  4326 KSP Residual norm 1.836036726382e-11
  4327 KSP Residual norm 2.019325791376e-11
  4328 KSP Residual norm 2.173135940036e-11
  4329 KSP Residual norm 2.097774059234e-11
  4330 KSP Residual norm 1.947746899398e-11
  4331 KSP Residual norm 1.986607317386e-11
  4332 KSP Residual norm 2.161411896756e-11
  4333 KSP Residual norm 2.332733807242e-11
  4334 KSP Residual norm 2.198276476486e-11
  4335 KSP Residual norm 1.927634921429e-11
  4336 KSP Residual norm 1.852897307150e-11
  4337 KSP Residual norm 1.860544998893e-11
  4338 KSP Residual norm 1.824532804907e-11
  4339 KSP Residual norm 1.813968603854e-11
  4340 KSP Residual norm 1.841693979665e-11
  4341 KSP Residual norm 1.786262971527e-11
  4342 KSP Residual norm 1.709143954024e-11
  4343 KSP Residual norm 1.702011402086e-11
  4344 KSP Residual norm 1.808722290409e-11
  4345 KSP Residual norm 1.951906529996e-11
  4346 KSP Residual norm 1.931862003997e-11
  4347 KSP Residual norm 1.739790290573e-11
  4348 KSP Residual norm 1.593154794275e-11
  4349 KSP Residual norm 1.507336172418e-11
  4350 KSP Residual norm 1.499097226346e-11
  4351 KSP Residual norm 1.532307873312e-11
  4352 KSP Residual norm 1.517673761471e-11
  4353 KSP Residual norm 1.468877541357e-11
  4354 KSP Residual norm 1.394136992341e-11
  4355 KSP Residual norm 1.272447759331e-11
  4356 KSP Residual norm 1.257686248736e-11
  4357 KSP Residual norm 1.373327437483e-11
  4358 KSP Residual norm 1.422057025123e-11
  4359 KSP Residual norm 1.350988915595e-11
  4360 KSP Residual norm 1.320569180346e-11
  4361 KSP Residual norm 1.321124335921e-11
  4362 KSP Residual norm 1.265846099424e-11
  4363 KSP Residual norm 1.262750682713e-11
  4364 KSP Residual norm 1.248929782766e-11
  4365 KSP Residual norm 1.237844163206e-11
  4366 KSP Residual norm 1.273754968993e-11
  4367 KSP Residual norm 1.305338395799e-11
  4368 KSP Residual norm 1.383949821607e-11
  4369 KSP Residual norm 1.556322828735e-11
  4370 KSP Residual norm 1.566897911857e-11
  4371 KSP Residual norm 1.501065989491e-11
  4372 KSP Residual norm 1.610380452501e-11
  4373 KSP Residual norm 1.827597923686e-11
  4374 KSP Residual norm 1.896090505242e-11
  4375 KSP Residual norm 1.952719405350e-11
  4376 KSP Residual norm 2.219489989377e-11
  4377 KSP Residual norm 2.605892734584e-11
  4378 KSP Residual norm 2.849014051046e-11
  4379 KSP Residual norm 2.793498875739e-11
  4380 KSP Residual norm 2.556808333506e-11
  4381 KSP Residual norm 2.465028311167e-11
  4382 KSP Residual norm 2.397760932166e-11
  4383 KSP Residual norm 2.355164667807e-11
  4384 KSP Residual norm 2.364763365602e-11
  4385 KSP Residual norm 2.491635976510e-11
  4386 KSP Residual norm 2.477970974094e-11
  4387 KSP Residual norm 2.378124362338e-11
  4388 KSP Residual norm 2.249411208976e-11
  4389 KSP Residual norm 2.128478745765e-11
  4390 KSP Residual norm 1.898237568995e-11
  4391 KSP Residual norm 1.727853141974e-11
  4392 KSP Residual norm 1.686972912154e-11
  4393 KSP Residual norm 1.707985430683e-11
  4394 KSP Residual norm 1.630972699447e-11
  4395 KSP Residual norm 1.511692409126e-11
  4396 KSP Residual norm 1.461642171616e-11
  4397 KSP Residual norm 1.501351310404e-11
  4398 KSP Residual norm 1.453653198795e-11
  4399 KSP Residual norm 1.337445563587e-11
  4400 KSP Residual norm 1.193485364858e-11
  4401 KSP Residual norm 1.094047147276e-11
  4402 KSP Residual norm 1.065214091843e-11
  4403 KSP Residual norm 1.003219554056e-11
  4404 KSP Residual norm 9.293011933654e-12
  4405 KSP Residual norm 8.960027272401e-12
  4406 KSP Residual norm 8.421596272926e-12
  4407 KSP Residual norm 7.258787937917e-12
  4408 KSP Residual norm 6.136475654817e-12
  4409 KSP Residual norm 5.498110036379e-12
  4410 KSP Residual norm 5.300252463661e-12
  4411 KSP Residual norm 5.336151393489e-12
  4412 KSP Residual norm 6.084988879900e-12
  4413 KSP Residual norm 7.042208032961e-12
  4414 KSP Residual norm 7.869979367603e-12
  4415 KSP Residual norm 8.550325066756e-12
  4416 KSP Residual norm 8.603381465038e-12
  4417 KSP Residual norm 8.311101868051e-12
  4418 KSP Residual norm 7.890992295528e-12
  4419 KSP Residual norm 7.711470806370e-12
  4420 KSP Residual norm 7.721904038219e-12
  4421 KSP Residual norm 7.926788677146e-12
  4422 KSP Residual norm 8.419657559140e-12
  4423 KSP Residual norm 9.169157260452e-12
  4424 KSP Residual norm 9.465910930385e-12
  4425 KSP Residual norm 9.292922930230e-12
  4426 KSP Residual norm 9.677634201094e-12
  4427 KSP Residual norm 1.078730025710e-11
  4428 KSP Residual norm 1.190354013839e-11
  4429 KSP Residual norm 1.315319861264e-11
  4430 KSP Residual norm 1.474057087698e-11
  4431 KSP Residual norm 1.542669612650e-11
  4432 KSP Residual norm 1.589410928210e-11
  4433 KSP Residual norm 1.595295051431e-11
  4434 KSP Residual norm 1.489962558496e-11
  4435 KSP Residual norm 1.351251159620e-11
  4436 KSP Residual norm 1.285447160314e-11
  4437 KSP Residual norm 1.278627611803e-11
  4438 KSP Residual norm 1.255555379484e-11
  4439 KSP Residual norm 1.130360818266e-11
  4440 KSP Residual norm 1.046414097727e-11
  4441 KSP Residual norm 1.089998692387e-11
  4442 KSP Residual norm 1.132161766168e-11
  4443 KSP Residual norm 1.065213433185e-11
  4444 KSP Residual norm 9.923858060499e-12
  4445 KSP Residual norm 9.856363491296e-12
  4446 KSP Residual norm 9.824504893607e-12
  4447 KSP Residual norm 8.461742801694e-12
  4448 KSP Residual norm 7.377952985144e-12
  4449 KSP Residual norm 6.826119058821e-12
  4450 KSP Residual norm 6.492217457740e-12
  4451 KSP Residual norm 6.268778800284e-12
  4452 KSP Residual norm 5.751216855680e-12
  4453 KSP Residual norm 5.535364738197e-12
  4454 KSP Residual norm 5.898709223975e-12
  4455 KSP Residual norm 6.229973941040e-12
  4456 KSP Residual norm 6.068756025460e-12
  4457 KSP Residual norm 5.681128275573e-12
  4458 KSP Residual norm 5.342594609591e-12
  4459 KSP Residual norm 4.718152145356e-12
  4460 KSP Residual norm 3.860882538243e-12
  4461 KSP Residual norm 3.325263512555e-12
  4462 KSP Residual norm 2.961510314034e-12
  4463 KSP Residual norm 2.672660268807e-12
  4464 KSP Residual norm 2.516445657091e-12
  4465 KSP Residual norm 2.685154357912e-12
  4466 KSP Residual norm 2.964924795295e-12
  4467 KSP Residual norm 2.971161356099e-12
  4468 KSP Residual norm 2.905351804732e-12
  4469 KSP Residual norm 2.978282372313e-12
  4470 KSP Residual norm 3.279726509027e-12
  4471 KSP Residual norm 3.536564282113e-12
  4472 KSP Residual norm 3.716403246631e-12
  4473 KSP Residual norm 4.237460913805e-12
  4474 KSP Residual norm 4.464625523557e-12
  4475 KSP Residual norm 4.008345283160e-12
  4476 KSP Residual norm 3.659378208261e-12
  4477 KSP Residual norm 3.738555696555e-12
  4478 KSP Residual norm 3.945906703579e-12
  4479 KSP Residual norm 4.051625718802e-12
  4480 KSP Residual norm 4.181165010098e-12
  4481 KSP Residual norm 4.282143396089e-12
  4482 KSP Residual norm 4.741151464051e-12
  4483 KSP Residual norm 5.088810336468e-12
  4484 KSP Residual norm 5.071868101001e-12
  4485 KSP Residual norm 5.427191190198e-12
  4486 KSP Residual norm 6.057709346826e-12
  4487 KSP Residual norm 5.470856770235e-12
  4488 KSP Residual norm 4.475054933385e-12
  4489 KSP Residual norm 3.948394206666e-12
  4490 KSP Residual norm 3.799556147045e-12
  4491 KSP Residual norm 3.999993695381e-12
  4492 KSP Residual norm 4.417784431567e-12
  4493 KSP Residual norm 4.625446317302e-12
  4494 KSP Residual norm 4.328265250679e-12
  4495 KSP Residual norm 3.933799851482e-12
  4496 KSP Residual norm 3.626753577425e-12
  4497 KSP Residual norm 3.519903938813e-12
  4498 KSP Residual norm 3.363550542611e-12
  4499 KSP Residual norm 3.161171845465e-12
  4500 KSP Residual norm 3.214585670679e-12
  4501 KSP Residual norm 3.272599543615e-12
  4502 KSP Residual norm 3.112750371949e-12
  4503 KSP Residual norm 2.714983050967e-12
  4504 KSP Residual norm 2.493028828916e-12
  4505 KSP Residual norm 2.489616901845e-12
  4506 KSP Residual norm 2.834337477527e-12
  4507 KSP Residual norm 3.255546520883e-12
  4508 KSP Residual norm 3.611944674983e-12
  4509 KSP Residual norm 3.717569697078e-12
  4510 KSP Residual norm 3.532867649468e-12
  4511 KSP Residual norm 3.373160197025e-12
  4512 KSP Residual norm 3.320345142895e-12
  4513 KSP Residual norm 3.349291602561e-12
  4514 KSP Residual norm 3.460775369216e-12
  4515 KSP Residual norm 3.460155972860e-12
  4516 KSP Residual norm 3.152636667790e-12
  4517 KSP Residual norm 2.772757265474e-12
  4518 KSP Residual norm 2.666313390715e-12
  4519 KSP Residual norm 2.896398842765e-12
  4520 KSP Residual norm 3.145614237426e-12
  4521 KSP Residual norm 3.526758016158e-12
  4522 KSP Residual norm 3.879157164417e-12
  4523 KSP Residual norm 3.917679286649e-12
  4524 KSP Residual norm 3.725832870086e-12
  4525 KSP Residual norm 3.530423209447e-12
  4526 KSP Residual norm 3.660206615801e-12
  4527 KSP Residual norm 3.837720259203e-12
  4528 KSP Residual norm 4.082488474388e-12
  4529 KSP Residual norm 4.736783644584e-12
  4530 KSP Residual norm 5.709115252066e-12
  4531 KSP Residual norm 6.171378484480e-12
  4532 KSP Residual norm 5.890454037442e-12
  4533 KSP Residual norm 5.506296756494e-12
  4534 KSP Residual norm 5.736523005818e-12
  4535 KSP Residual norm 6.274644866718e-12
  4536 KSP Residual norm 6.726206150675e-12
  4537 KSP Residual norm 7.039135865998e-12
  4538 KSP Residual norm 7.555347659942e-12
  4539 KSP Residual norm 7.461715729300e-12
  4540 KSP Residual norm 6.812956469209e-12
  4541 KSP Residual norm 6.337560702431e-12
  4542 KSP Residual norm 6.181637549855e-12
  4543 KSP Residual norm 6.260828094515e-12
  4544 KSP Residual norm 6.097505263122e-12
  4545 KSP Residual norm 5.534911272592e-12
  4546 KSP Residual norm 5.540952651090e-12
  4547 KSP Residual norm 6.412616785043e-12
  4548 KSP Residual norm 6.980970241605e-12
  4549 KSP Residual norm 6.550171747150e-12
  4550 KSP Residual norm 6.270115378388e-12
  4551 KSP Residual norm 6.042070772535e-12
  4552 KSP Residual norm 5.500059398524e-12
  4553 KSP Residual norm 5.040932394667e-12
  4554 KSP Residual norm 5.117136719578e-12
  4555 KSP Residual norm 5.470690346210e-12
  4556 KSP Residual norm 5.698863368529e-12
  4557 KSP Residual norm 5.585454230451e-12
  4558 KSP Residual norm 5.395928584168e-12
  4559 KSP Residual norm 5.228070842600e-12
  4560 KSP Residual norm 5.201502464183e-12
  4561 KSP Residual norm 5.467917088387e-12
  4562 KSP Residual norm 6.016033631636e-12
  4563 KSP Residual norm 6.304356641702e-12
  4564 KSP Residual norm 5.865382250287e-12
  4565 KSP Residual norm 4.959210874956e-12
  4566 KSP Residual norm 4.271884443111e-12
  4567 KSP Residual norm 3.949133101333e-12
  4568 KSP Residual norm 4.166289196426e-12
  4569 KSP Residual norm 4.564036541828e-12
  4570 KSP Residual norm 4.702649401274e-12
  4571 KSP Residual norm 4.587556877837e-12
  4572 KSP Residual norm 4.303430033194e-12
  4573 KSP Residual norm 4.350642176448e-12
  4574 KSP Residual norm 5.082076505930e-12
  4575 KSP Residual norm 5.505088569960e-12
  4576 KSP Residual norm 4.988567921472e-12
  4577 KSP Residual norm 4.409505933337e-12
  4578 KSP Residual norm 4.206565465549e-12
  4579 KSP Residual norm 4.115472922427e-12
  4580 KSP Residual norm 4.227271449993e-12
  4581 KSP Residual norm 4.532324059143e-12
  4582 KSP Residual norm 5.055415836538e-12
  4583 KSP Residual norm 5.871331891541e-12
  4584 KSP Residual norm 6.806324477887e-12
  4585 KSP Residual norm 7.660741218339e-12
  4586 KSP Residual norm 8.039380877586e-12
  4587 KSP Residual norm 7.834461056744e-12
  4588 KSP Residual norm 7.450905284083e-12
  4589 KSP Residual norm 7.191761550405e-12
  4590 KSP Residual norm 7.094953884980e-12
  4591 KSP Residual norm 7.236364260058e-12
  4592 KSP Residual norm 7.189403454160e-12
  4593 KSP Residual norm 6.744248746015e-12
  4594 KSP Residual norm 6.550669786916e-12
  4595 KSP Residual norm 7.173406716310e-12
  4596 KSP Residual norm 8.154478678530e-12
  4597 KSP Residual norm 7.698662386494e-12
  4598 KSP Residual norm 6.233188323226e-12
  4599 KSP Residual norm 5.418236247466e-12
  4600 KSP Residual norm 5.387568718049e-12
  4601 KSP Residual norm 5.708011588793e-12
  4602 KSP Residual norm 6.310866767100e-12
  4603 KSP Residual norm 6.943704377872e-12
  4604 KSP Residual norm 7.521489235605e-12
  4605 KSP Residual norm 7.504685720005e-12
  4606 KSP Residual norm 7.177638685817e-12
  4607 KSP Residual norm 7.381570873954e-12
  4608 KSP Residual norm 7.979237000116e-12
  4609 KSP Residual norm 8.121942312282e-12
  4610 KSP Residual norm 7.386094106016e-12
  4611 KSP Residual norm 6.462699537675e-12
  4612 KSP Residual norm 5.576794687206e-12
  4613 KSP Residual norm 4.811626218392e-12
  4614 KSP Residual norm 4.508277157196e-12
  4615 KSP Residual norm 4.500531509828e-12
  4616 KSP Residual norm 4.599156615627e-12
  4617 KSP Residual norm 4.700844544254e-12
  4618 KSP Residual norm 4.731066357856e-12
  4619 KSP Residual norm 4.946206552900e-12
  4620 KSP Residual norm 5.372728414758e-12
  4621 KSP Residual norm 5.715908132991e-12
  4622 KSP Residual norm 5.967616279211e-12
  4623 KSP Residual norm 6.359664412376e-12
  4624 KSP Residual norm 6.664938948078e-12
  4625 KSP Residual norm 7.082324943374e-12
  4626 KSP Residual norm 8.296451903065e-12
  4627 KSP Residual norm 9.777327035694e-12
  4628 KSP Residual norm 1.006961221234e-11
  4629 KSP Residual norm 1.021557355716e-11
  4630 KSP Residual norm 1.004433854311e-11
  4631 KSP Residual norm 9.800676335584e-12
  4632 KSP Residual norm 1.033506443409e-11
  4633 KSP Residual norm 1.185175854559e-11
  4634 KSP Residual norm 1.269554508812e-11
  4635 KSP Residual norm 1.192758052150e-11
  4636 KSP Residual norm 1.063217746078e-11
  4637 KSP Residual norm 1.015920140991e-11
  4638 KSP Residual norm 1.073255679064e-11
  4639 KSP Residual norm 1.195685714053e-11
  4640 KSP Residual norm 1.295041675393e-11
  4641 KSP Residual norm 1.444079759542e-11
  4642 KSP Residual norm 1.745701887409e-11
  4643 KSP Residual norm 2.105556859293e-11
  4644 KSP Residual norm 2.172793968315e-11
  4645 KSP Residual norm 1.881212450685e-11
  4646 KSP Residual norm 1.630196355244e-11
  4647 KSP Residual norm 1.559352568027e-11
  4648 KSP Residual norm 1.429829839854e-11
  4649 KSP Residual norm 1.290083012512e-11
  4650 KSP Residual norm 1.358268496532e-11
  4651 KSP Residual norm 1.539607358102e-11
  4652 KSP Residual norm 1.417174417281e-11
  4653 KSP Residual norm 1.101131822298e-11
  4654 KSP Residual norm 8.898983856527e-12
  4655 KSP Residual norm 8.491417222645e-12
  4656 KSP Residual norm 8.674323634485e-12
  4657 KSP Residual norm 8.595498240425e-12
  4658 KSP Residual norm 8.250098349478e-12
  4659 KSP Residual norm 8.262783938633e-12
  4660 KSP Residual norm 8.498309339650e-12
  4661 KSP Residual norm 9.413153537152e-12
  4662 KSP Residual norm 1.086061737538e-11
  4663 KSP Residual norm 1.032625514051e-11
  4664 KSP Residual norm 8.963668081085e-12
  4665 KSP Residual norm 8.411297729930e-12
  4666 KSP Residual norm 8.187419896859e-12
  4667 KSP Residual norm 7.851343398847e-12
  4668 KSP Residual norm 7.706517473020e-12
  4669 KSP Residual norm 8.185541242876e-12
  4670 KSP Residual norm 8.773858726171e-12
  4671 KSP Residual norm 8.982475649870e-12
  4672 KSP Residual norm 8.551394026359e-12
  4673 KSP Residual norm 8.252729113773e-12
  4674 KSP Residual norm 8.609829953285e-12
  4675 KSP Residual norm 9.177978711003e-12
  4676 KSP Residual norm 8.754104994160e-12
  4677 KSP Residual norm 8.120036317947e-12
  4678 KSP Residual norm 8.175983026166e-12
  4679 KSP Residual norm 8.493377495447e-12
  4680 KSP Residual norm 8.866327870857e-12
  4681 KSP Residual norm 9.841449534348e-12
  4682 KSP Residual norm 1.108810403895e-11
  4683 KSP Residual norm 1.191822390686e-11
  4684 KSP Residual norm 1.236530620904e-11
  4685 KSP Residual norm 1.207590095003e-11
  4686 KSP Residual norm 1.101592104037e-11
  4687 KSP Residual norm 1.046709840251e-11
  4688 KSP Residual norm 1.055802974104e-11
  4689 KSP Residual norm 1.043374293668e-11
  4690 KSP Residual norm 1.012185489287e-11
  4691 KSP Residual norm 1.034885810600e-11
  4692 KSP Residual norm 1.178359008383e-11
  4693 KSP Residual norm 1.434671172908e-11
  4694 KSP Residual norm 1.675628333176e-11
  4695 KSP Residual norm 1.797366589557e-11
  4696 KSP Residual norm 1.815366847698e-11
  4697 KSP Residual norm 1.696625385829e-11
  4698 KSP Residual norm 1.632901949394e-11
  4699 KSP Residual norm 1.726354832203e-11
  4700 KSP Residual norm 1.893609702416e-11
  4701 KSP Residual norm 2.051892059760e-11
  4702 KSP Residual norm 2.063956469454e-11
  4703 KSP Residual norm 1.965986839390e-11
  4704 KSP Residual norm 1.816328695650e-11
  4705 KSP Residual norm 1.808038363318e-11
  4706 KSP Residual norm 1.987092228216e-11
  4707 KSP Residual norm 2.145615846570e-11
  4708 KSP Residual norm 2.050740162586e-11
  4709 KSP Residual norm 1.862007064475e-11
  4710 KSP Residual norm 1.803280033885e-11
  4711 KSP Residual norm 1.931518465701e-11
  4712 KSP Residual norm 2.171205145338e-11
  4713 KSP Residual norm 2.192347139066e-11
  4714 KSP Residual norm 1.846774002814e-11
  4715 KSP Residual norm 1.577206639506e-11
  4716 KSP Residual norm 1.431070355431e-11
  4717 KSP Residual norm 1.344026404803e-11
  4718 KSP Residual norm 1.326746770335e-11
  4719 KSP Residual norm 1.345057128103e-11
  4720 KSP Residual norm 1.203069738915e-11
  4721 KSP Residual norm 1.048837092959e-11
  4722 KSP Residual norm 1.010954959809e-11
  4723 KSP Residual norm 1.041634504813e-11
  4724 KSP Residual norm 1.082730507291e-11
  4725 KSP Residual norm 1.119631407011e-11
  4726 KSP Residual norm 1.075834599396e-11
  4727 KSP Residual norm 9.408711270743e-12
  4728 KSP Residual norm 8.824932398316e-12
  4729 KSP Residual norm 9.937830432875e-12
  4730 KSP Residual norm 1.238993234507e-11
  4731 KSP Residual norm 1.330887788740e-11
  4732 KSP Residual norm 1.184394301450e-11
  4733 KSP Residual norm 1.067538214588e-11
  4734 KSP Residual norm 1.045162151739e-11
  4735 KSP Residual norm 1.047899708575e-11
  4736 KSP Residual norm 1.041675562522e-11
  4737 KSP Residual norm 9.808209416253e-12
  4738 KSP Residual norm 9.646002890976e-12
  4739 KSP Residual norm 1.053492574712e-11
  4740 KSP Residual norm 1.208524407433e-11
  4741 KSP Residual norm 1.248932897513e-11
  4742 KSP Residual norm 1.267598776419e-11
  4743 KSP Residual norm 1.384048604244e-11
  4744 KSP Residual norm 1.385604557299e-11
  4745 KSP Residual norm 1.223423508217e-11
  4746 KSP Residual norm 1.113779128694e-11
  4747 KSP Residual norm 1.170414419102e-11
  4748 KSP Residual norm 1.451446155662e-11
  4749 KSP Residual norm 1.880211790314e-11
  4750 KSP Residual norm 2.014362685443e-11
  4751 KSP Residual norm 1.749123985572e-11
  4752 KSP Residual norm 1.422543361112e-11
  4753 KSP Residual norm 1.283401510119e-11
  4754 KSP Residual norm 1.403997928605e-11
  4755 KSP Residual norm 1.780921236354e-11
  4756 KSP Residual norm 2.047589937737e-11
  4757 KSP Residual norm 2.093911196844e-11
  4758 KSP Residual norm 2.129996071565e-11
  4759 KSP Residual norm 2.056259474967e-11
  4760 KSP Residual norm 1.939168286107e-11
  4761 KSP Residual norm 2.128032667866e-11
  4762 KSP Residual norm 2.609543115402e-11
  4763 KSP Residual norm 3.034335335761e-11
  4764 KSP Residual norm 3.173697591519e-11
  4765 KSP Residual norm 3.396616047614e-11
  4766 KSP Residual norm 3.662948112713e-11
  4767 KSP Residual norm 3.508695526962e-11
  4768 KSP Residual norm 3.102215343197e-11
  4769 KSP Residual norm 2.852274169396e-11
  4770 KSP Residual norm 2.731246915888e-11
  4771 KSP Residual norm 2.678817645367e-11
  4772 KSP Residual norm 2.588747266304e-11
  4773 KSP Residual norm 2.658482869513e-11
  4774 KSP Residual norm 2.855639113681e-11
  4775 KSP Residual norm 2.748590962730e-11
  4776 KSP Residual norm 2.382491959739e-11
  4777 KSP Residual norm 2.157501807508e-11
  4778 KSP Residual norm 2.231418214196e-11
  4779 KSP Residual norm 2.651336732086e-11
  4780 KSP Residual norm 2.900178937325e-11
  4781 KSP Residual norm 2.671059355386e-11
  4782 KSP Residual norm 2.335905118080e-11
  4783 KSP Residual norm 1.986987246025e-11
  4784 KSP Residual norm 1.772992616766e-11
  4785 KSP Residual norm 1.787960670018e-11
  4786 KSP Residual norm 1.789708557742e-11
  4787 KSP Residual norm 1.629146275550e-11
  4788 KSP Residual norm 1.650083599452e-11
  4789 KSP Residual norm 1.786004243269e-11
  4790 KSP Residual norm 1.735122595563e-11
  4791 KSP Residual norm 1.429370823342e-11
  4792 KSP Residual norm 1.168515198892e-11
  4793 KSP Residual norm 9.643375728093e-12
  4794 KSP Residual norm 8.549683983834e-12
  4795 KSP Residual norm 7.931987211215e-12
  4796 KSP Residual norm 8.066207692987e-12
  4797 KSP Residual norm 9.322869535306e-12
  4798 KSP Residual norm 1.067089680501e-11
  4799 KSP Residual norm 1.092855740926e-11
  4800 KSP Residual norm 1.025146496110e-11
  4801 KSP Residual norm 9.641315875605e-12
  4802 KSP Residual norm 8.990564325214e-12
  4803 KSP Residual norm 8.138053133236e-12
  4804 KSP Residual norm 7.997260465006e-12
  4805 KSP Residual norm 8.401812293564e-12
  4806 KSP Residual norm 8.125459308851e-12
  4807 KSP Residual norm 8.144550381611e-12
  4808 KSP Residual norm 8.436205872983e-12
  4809 KSP Residual norm 8.119208898815e-12
  4810 KSP Residual norm 7.067654731680e-12
  4811 KSP Residual norm 6.609441204809e-12
  4812 KSP Residual norm 7.258040878607e-12
  4813 KSP Residual norm 8.293291269205e-12
  4814 KSP Residual norm 8.762005561265e-12
  4815 KSP Residual norm 9.433016072475e-12
  4816 KSP Residual norm 1.101268541371e-11
  4817 KSP Residual norm 1.217209630734e-11
  4818 KSP Residual norm 1.160717861650e-11
  4819 KSP Residual norm 1.096073106840e-11
  4820 KSP Residual norm 1.102387325331e-11
  4821 KSP Residual norm 1.053735710274e-11
  4822 KSP Residual norm 1.041638896212e-11
  4823 KSP Residual norm 1.071789523708e-11
  4824 KSP Residual norm 1.085219228887e-11
  4825 KSP Residual norm 1.152477825326e-11
  4826 KSP Residual norm 1.328012397873e-11
  4827 KSP Residual norm 1.541174475805e-11
  4828 KSP Residual norm 1.779282498447e-11
  4829 KSP Residual norm 1.814441514865e-11
  4830 KSP Residual norm 1.711401675545e-11
  4831 KSP Residual norm 1.628403317988e-11
  4832 KSP Residual norm 1.425464517473e-11
  4833 KSP Residual norm 1.197787529189e-11
  4834 KSP Residual norm 1.110182904295e-11
  4835 KSP Residual norm 1.150630294373e-11
  4836 KSP Residual norm 1.311602337110e-11
  4837 KSP Residual norm 1.545426293092e-11
  4838 KSP Residual norm 1.713988193771e-11
  4839 KSP Residual norm 1.616728053326e-11
  4840 KSP Residual norm 1.445825300591e-11
  4841 KSP Residual norm 1.285385461068e-11
  4842 KSP Residual norm 1.185860497581e-11
  4843 KSP Residual norm 1.159281833783e-11
  4844 KSP Residual norm 1.152160894835e-11
  4845 KSP Residual norm 1.035927823783e-11
  4846 KSP Residual norm 8.156528465170e-12
  4847 KSP Residual norm 6.172196056574e-12
  4848 KSP Residual norm 5.049120374520e-12
  4849 KSP Residual norm 4.832068510014e-12
  4850 KSP Residual norm 5.497529062725e-12
  4851 KSP Residual norm 6.697801240399e-12
  4852 KSP Residual norm 7.903818499990e-12
  4853 KSP Residual norm 8.586650159792e-12
  4854 KSP Residual norm 8.520725490526e-12
  4855 KSP Residual norm 7.811696674260e-12
  4856 KSP Residual norm 6.822526186585e-12
  4857 KSP Residual norm 6.122277287536e-12
  4858 KSP Residual norm 6.006852570121e-12
  4859 KSP Residual norm 5.857339572564e-12
  4860 KSP Residual norm 5.197608518742e-12
  4861 KSP Residual norm 4.658913874410e-12
  4862 KSP Residual norm 4.766920372507e-12
  4863 KSP Residual norm 5.778108687216e-12
  4864 KSP Residual norm 7.557462234361e-12
  4865 KSP Residual norm 9.294102964046e-12
  4866 KSP Residual norm 9.316060800038e-12
  4867 KSP Residual norm 8.694025512986e-12
  4868 KSP Residual norm 7.627550541547e-12
  4869 KSP Residual norm 6.316597904152e-12
  4870 KSP Residual norm 5.349593547429e-12
  4871 KSP Residual norm 4.641893850650e-12
  4872 KSP Residual norm 4.223047359762e-12
  4873 KSP Residual norm 4.154842883891e-12
  4874 KSP Residual norm 4.667446739021e-12
  4875 KSP Residual norm 5.772284541539e-12
  4876 KSP Residual norm 6.522041314963e-12
  4877 KSP Residual norm 6.204002131811e-12
  4878 KSP Residual norm 5.380369149348e-12
  4879 KSP Residual norm 4.965168010305e-12
  4880 KSP Residual norm 5.143349421213e-12
  4881 KSP Residual norm 5.411730884215e-12
  4882 KSP Residual norm 5.675485775830e-12
  4883 KSP Residual norm 5.861871474799e-12
  4884 KSP Residual norm 6.451873270654e-12
  4885 KSP Residual norm 8.098552899208e-12
  4886 KSP Residual norm 9.955618586465e-12
  4887 KSP Residual norm 8.729172022580e-12
  4888 KSP Residual norm 5.977968854738e-12
  4889 KSP Residual norm 4.573038471728e-12
  4890 KSP Residual norm 4.693209980273e-12
  4891 KSP Residual norm 6.348635565815e-12
  4892 KSP Residual norm 9.128365229343e-12
  4893 KSP Residual norm 1.215066616872e-11
  4894 KSP Residual norm 1.243263951878e-11
  4895 KSP Residual norm 1.007098265013e-11
  4896 KSP Residual norm 6.990375987309e-12
  4897 KSP Residual norm 4.834316721470e-12
  4898 KSP Residual norm 3.946205997274e-12
  4899 KSP Residual norm 4.030122530025e-12
  4900 KSP Residual norm 4.933942965639e-12
  4901 KSP Residual norm 6.736305693442e-12
  4902 KSP Residual norm 8.224787480131e-12
  4903 KSP Residual norm 8.014787379513e-12
  4904 KSP Residual norm 6.924073351369e-12
  4905 KSP Residual norm 6.460348276073e-12
  4906 KSP Residual norm 6.493708996848e-12
  4907 KSP Residual norm 6.238736535374e-12
  4908 KSP Residual norm 5.553332164133e-12
  4909 KSP Residual norm 4.622901120056e-12
  4910 KSP Residual norm 3.893794998099e-12
  4911 KSP Residual norm 3.178213852006e-12
  4912 KSP Residual norm 2.579938691494e-12
  4913 KSP Residual norm 2.546170415180e-12
  4914 KSP Residual norm 3.322580961887e-12
  4915 KSP Residual norm 4.372048756355e-12
  4916 KSP Residual norm 4.498495081330e-12
  4917 KSP Residual norm 3.790374124959e-12
  4918 KSP Residual norm 3.296095716772e-12
  4919 KSP Residual norm 3.025986327543e-12
  4920 KSP Residual norm 2.942230175436e-12
  4921 KSP Residual norm 3.196296861437e-12
  4922 KSP Residual norm 3.450864950673e-12
  4923 KSP Residual norm 3.395918075624e-12
  4924 KSP Residual norm 2.853865164270e-12
  4925 KSP Residual norm 2.213003858805e-12
  4926 KSP Residual norm 1.815116721434e-12
  4927 KSP Residual norm 1.636228826521e-12
  4928 KSP Residual norm 1.645166062020e-12
  4929 KSP Residual norm 1.982567849495e-12
  4930 KSP Residual norm 2.642089608231e-12
  4931 KSP Residual norm 3.522236826372e-12
  4932 KSP Residual norm 4.370638517286e-12
  4933 KSP Residual norm 5.223417570235e-12
  4934 KSP Residual norm 6.252704758452e-12
  4935 KSP Residual norm 6.304957869600e-12
  4936 KSP Residual norm 5.329861141447e-12
  4937 KSP Residual norm 4.361544928313e-12
  4938 KSP Residual norm 3.800178014254e-12
  4939 KSP Residual norm 3.674235219780e-12
  4940 KSP Residual norm 3.829251650727e-12
  4941 KSP Residual norm 4.671949406728e-12
  4942 KSP Residual norm 6.307943697523e-12
  4943 KSP Residual norm 7.622661537012e-12
  4944 KSP Residual norm 7.907141547634e-12
  4945 KSP Residual norm 7.538648761784e-12
  4946 KSP Residual norm 7.100075847875e-12
  4947 KSP Residual norm 6.826641923909e-12
  4948 KSP Residual norm 7.456926476580e-12
  4949 KSP Residual norm 8.599291594599e-12
  4950 KSP Residual norm 8.900782807233e-12
  4951 KSP Residual norm 8.285562129459e-12
  4952 KSP Residual norm 7.712665283050e-12
  4953 KSP Residual norm 7.782455247724e-12
  4954 KSP Residual norm 8.616432928979e-12
  4955 KSP Residual norm 9.735884958254e-12
  4956 KSP Residual norm 9.078676508734e-12
  4957 KSP Residual norm 7.195086193457e-12
  4958 KSP Residual norm 5.514948214717e-12
  4959 KSP Residual norm 4.449628412853e-12
  4960 KSP Residual norm 3.903214010542e-12
  4961 KSP Residual norm 4.016351601839e-12
  4962 KSP Residual norm 4.641492860681e-12
  4963 KSP Residual norm 5.218454247470e-12
  4964 KSP Residual norm 4.992857141790e-12
  4965 KSP Residual norm 3.891308331353e-12
  4966 KSP Residual norm 2.936668024722e-12
  4967 KSP Residual norm 2.476250403264e-12
  4968 KSP Residual norm 2.561830854608e-12
  4969 KSP Residual norm 3.089239519447e-12
  4970 KSP Residual norm 3.982806307766e-12
  4971 KSP Residual norm 4.540829390456e-12
  4972 KSP Residual norm 4.179522960858e-12
  4973 KSP Residual norm 3.333512335861e-12
  4974 KSP Residual norm 2.522186352353e-12
  4975 KSP Residual norm 2.011090607646e-12
  4976 KSP Residual norm 1.835163587449e-12
  4977 KSP Residual norm 1.784056634117e-12
  4978 KSP Residual norm 1.661268075403e-12
  4979 KSP Residual norm 1.562729928729e-12
  4980 KSP Residual norm 1.551809712420e-12
  4981 KSP Residual norm 1.508478650320e-12
  4982 KSP Residual norm 1.535724842786e-12
  4983 KSP Residual norm 1.685158636575e-12
  4984 KSP Residual norm 1.927773842777e-12
  4985 KSP Residual norm 2.014045562930e-12
  4986 KSP Residual norm 1.988897435646e-12
  4987 KSP Residual norm 1.951269018622e-12
  4988 KSP Residual norm 1.746060833142e-12
  4989 KSP Residual norm 1.475543475880e-12
  4990 KSP Residual norm 1.149316236535e-12
  4991 KSP Residual norm 8.808269593741e-13
  4992 KSP Residual norm 7.762654757119e-13
  4993 KSP Residual norm 9.174295734665e-13
  4994 KSP Residual norm 1.318276463519e-12
  4995 KSP Residual norm 1.915399899229e-12
  4996 KSP Residual norm 2.515203610354e-12
  4997 KSP Residual norm 2.950900736452e-12
  4998 KSP Residual norm 3.012171764100e-12
  4999 KSP Residual norm 2.615647856943e-12
  5000 KSP Residual norm 2.376741547762e-12
  5001 KSP Residual norm 2.670017484234e-12
  5002 KSP Residual norm 3.443029543080e-12
  5003 KSP Residual norm 4.535505524500e-12
  5004 KSP Residual norm 5.435864963087e-12
  5005 KSP Residual norm 5.764025235757e-12
  5006 KSP Residual norm 5.001153657512e-12
  5007 KSP Residual norm 3.958426230740e-12
  5008 KSP Residual norm 3.299215260665e-12
  5009 KSP Residual norm 2.933458116486e-12
  5010 KSP Residual norm 2.945627316068e-12
  5011 KSP Residual norm 3.620554433854e-12
  5012 KSP Residual norm 5.265587507768e-12
  5013 KSP Residual norm 7.250353854742e-12
  5014 KSP Residual norm 7.706677328485e-12
  5015 KSP Residual norm 7.153179331880e-12
  5016 KSP Residual norm 6.779919264271e-12
  5017 KSP Residual norm 6.477956663018e-12
  5018 KSP Residual norm 6.246895597169e-12
  5019 KSP Residual norm 6.052285127208e-12
  5020 KSP Residual norm 5.747497768001e-12
  5021 KSP Residual norm 5.295060208837e-12
  5022 KSP Residual norm 5.679471168966e-12
  5023 KSP Residual norm 6.628464485607e-12
  5024 KSP Residual norm 7.595499717625e-12
  5025 KSP Residual norm 7.796270589664e-12
  5026 KSP Residual norm 7.809864583857e-12
  5027 KSP Residual norm 7.785637803330e-12
  5028 KSP Residual norm 8.085559474345e-12
  5029 KSP Residual norm 8.463470315050e-12
  5030 KSP Residual norm 7.495866059666e-12
  5031 KSP Residual norm 6.092813625487e-12
  5032 KSP Residual norm 5.215489882567e-12
  5033 KSP Residual norm 4.718919808163e-12
  5034 KSP Residual norm 4.652605574060e-12
  5035 KSP Residual norm 5.430866269390e-12
  5036 KSP Residual norm 6.269024385182e-12
  5037 KSP Residual norm 5.712582670954e-12
  5038 KSP Residual norm 5.866304317659e-12
  5039 KSP Residual norm 7.171010672447e-12
  5040 KSP Residual norm 8.630717835717e-12
  5041 KSP Residual norm 8.667415293904e-12
  5042 KSP Residual norm 7.103851835432e-12
  5043 KSP Residual norm 5.022597389599e-12
  5044 KSP Residual norm 3.626150716996e-12
  5045 KSP Residual norm 2.979784701214e-12
  5046 KSP Residual norm 3.226948875951e-12
  5047 KSP Residual norm 4.143202172347e-12
  5048 KSP Residual norm 5.042760056685e-12
  5049 KSP Residual norm 4.673684040662e-12
  5050 KSP Residual norm 3.719695552805e-12
  5051 KSP Residual norm 3.168777626937e-12
  5052 KSP Residual norm 2.875148509221e-12
  5053 KSP Residual norm 2.623294387630e-12
  5054 KSP Residual norm 2.520309633608e-12
  5055 KSP Residual norm 2.551248588685e-12
  5056 KSP Residual norm 2.770807722568e-12
  5057 KSP Residual norm 3.039161133311e-12
  5058 KSP Residual norm 3.202677963583e-12
  5059 KSP Residual norm 3.258107047385e-12
  5060 KSP Residual norm 3.475023018085e-12
  5061 KSP Residual norm 3.405977414800e-12
  5062 KSP Residual norm 3.160561072807e-12
  5063 KSP Residual norm 2.833595966846e-12
  5064 KSP Residual norm 2.451655611483e-12
  5065 KSP Residual norm 2.294236324466e-12
  5066 KSP Residual norm 2.526655323649e-12
  5067 KSP Residual norm 2.779099456475e-12
  5068 KSP Residual norm 3.030528006444e-12
  5069 KSP Residual norm 3.518839310326e-12
  5070 KSP Residual norm 4.068042799603e-12
  5071 KSP Residual norm 4.583437422417e-12
  5072 KSP Residual norm 5.239352145788e-12
  5073 KSP Residual norm 5.865542149170e-12
  5074 KSP Residual norm 6.073640108176e-12
  5075 KSP Residual norm 5.767436584434e-12
  5076 KSP Residual norm 5.144636252572e-12
  5077 KSP Residual norm 4.815701821238e-12
  5078 KSP Residual norm 5.095070531482e-12
  5079 KSP Residual norm 5.910167109382e-12
  5080 KSP Residual norm 7.210559843956e-12
  5081 KSP Residual norm 9.049114018761e-12
  5082 KSP Residual norm 1.092927403720e-11
  5083 KSP Residual norm 1.305352716560e-11
  5084 KSP Residual norm 1.442727643376e-11
  5085 KSP Residual norm 1.333539735506e-11
  5086 KSP Residual norm 1.273493823764e-11
  5087 KSP Residual norm 1.416915110236e-11
  5088 KSP Residual norm 1.600242967846e-11
  5089 KSP Residual norm 1.542236696747e-11
  5090 KSP Residual norm 1.359087259281e-11
  5091 KSP Residual norm 1.139818014743e-11
  5092 KSP Residual norm 9.811029958586e-12
  5093 KSP Residual norm 9.470171379481e-12
  5094 KSP Residual norm 9.900283064174e-12
  5095 KSP Residual norm 1.076393210753e-11
  5096 KSP Residual norm 1.205806947966e-11
  5097 KSP Residual norm 1.315929682606e-11
  5098 KSP Residual norm 1.377163497629e-11
  5099 KSP Residual norm 1.534368936316e-11
  5100 KSP Residual norm 1.730881577674e-11
  5101 KSP Residual norm 1.748350020642e-11
  5102 KSP Residual norm 1.508554358809e-11
  5103 KSP Residual norm 1.215944801548e-11
  5104 KSP Residual norm 1.066975450451e-11
  5105 KSP Residual norm 1.119357989442e-11
  5106 KSP Residual norm 1.261621605425e-11
  5107 KSP Residual norm 1.253485467066e-11
  5108 KSP Residual norm 1.271922608567e-11
  5109 KSP Residual norm 1.429569511996e-11
  5110 KSP Residual norm 1.618165005719e-11
  5111 KSP Residual norm 1.782808141838e-11
  5112 KSP Residual norm 1.898079650754e-11
  5113 KSP Residual norm 1.836721379825e-11
  5114 KSP Residual norm 1.779756376426e-11
  5115 KSP Residual norm 1.733821780578e-11
  5116 KSP Residual norm 1.746151087346e-11
  5117 KSP Residual norm 1.658327870763e-11
  5118 KSP Residual norm 1.524857515496e-11
  5119 KSP Residual norm 1.375499040244e-11
  5120 KSP Residual norm 1.326293918046e-11
  5121 KSP Residual norm 1.263184614019e-11
  5122 KSP Residual norm 1.111223998225e-11
  5123 KSP Residual norm 9.690137231123e-12
  5124 KSP Residual norm 9.785355596885e-12
  5125 KSP Residual norm 1.107099382209e-11
  5126 KSP Residual norm 1.255391932541e-11
  5127 KSP Residual norm 1.350991051568e-11
  5128 KSP Residual norm 1.463854094704e-11
  5129 KSP Residual norm 1.520438294021e-11
  5130 KSP Residual norm 1.457125873395e-11
  5131 KSP Residual norm 1.425386410197e-11
  5132 KSP Residual norm 1.584312965656e-11
  5133 KSP Residual norm 1.727907211058e-11
  5134 KSP Residual norm 1.472178077635e-11
  5135 KSP Residual norm 1.144584801987e-11
  5136 KSP Residual norm 1.015990981366e-11
  5137 KSP Residual norm 1.014184826995e-11
  5138 KSP Residual norm 1.004911333289e-11
  5139 KSP Residual norm 1.016032364438e-11
  5140 KSP Residual norm 9.236852770611e-12
  5141 KSP Residual norm 7.496401878520e-12
  5142 KSP Residual norm 6.916648420479e-12
  5143 KSP Residual norm 7.795077683598e-12
  5144 KSP Residual norm 9.253707862067e-12
  5145 KSP Residual norm 9.991879301588e-12
  5146 KSP Residual norm 1.041607901118e-11
  5147 KSP Residual norm 1.190286698193e-11
  5148 KSP Residual norm 1.374906642805e-11
  5149 KSP Residual norm 1.413298797969e-11
  5150 KSP Residual norm 1.309817235225e-11
  5151 KSP Residual norm 1.258896424291e-11
  5152 KSP Residual norm 1.277939733565e-11
  5153 KSP Residual norm 1.220465350040e-11
  5154 KSP Residual norm 1.178205863279e-11
  5155 KSP Residual norm 1.131144867847e-11
  5156 KSP Residual norm 1.097622220791e-11
  5157 KSP Residual norm 1.076970992467e-11
  5158 KSP Residual norm 1.116045919828e-11
  5159 KSP Residual norm 1.231332959387e-11
  5160 KSP Residual norm 1.425931051189e-11
  5161 KSP Residual norm 1.650665889069e-11
  5162 KSP Residual norm 1.799158075353e-11
  5163 KSP Residual norm 1.721470579305e-11
  5164 KSP Residual norm 1.517444285977e-11
  5165 KSP Residual norm 1.376778343574e-11
  5166 KSP Residual norm 1.406880009387e-11
  5167 KSP Residual norm 1.438758291399e-11
  5168 KSP Residual norm 1.369415871871e-11
  5169 KSP Residual norm 1.195606915145e-11
  5170 KSP Residual norm 1.056856896198e-11
  5171 KSP Residual norm 1.101122774990e-11
  5172 KSP Residual norm 1.314944848074e-11
  5173 KSP Residual norm 1.537357824382e-11
  5174 KSP Residual norm 1.668224620809e-11
  5175 KSP Residual norm 1.773877453808e-11
  5176 KSP Residual norm 1.846276305107e-11
  5177 KSP Residual norm 2.117767971511e-11
  5178 KSP Residual norm 2.649136526719e-11
  5179 KSP Residual norm 3.448892290166e-11
  5180 KSP Residual norm 3.963620102471e-11
  5181 KSP Residual norm 3.719600204827e-11
  5182 KSP Residual norm 3.499516929507e-11
  5183 KSP Residual norm 3.516639836872e-11
  5184 KSP Residual norm 3.479613149857e-11
  5185 KSP Residual norm 3.034967475577e-11
  5186 KSP Residual norm 2.395760066371e-11
  5187 KSP Residual norm 2.240435006689e-11
  5188 KSP Residual norm 2.562733056918e-11
  5189 KSP Residual norm 3.233203819317e-11
  5190 KSP Residual norm 3.607091389438e-11
  5191 KSP Residual norm 3.244693762497e-11
  5192 KSP Residual norm 3.106205064792e-11
  5193 KSP Residual norm 3.627014944643e-11
  5194 KSP Residual norm 4.482936931769e-11
  5195 KSP Residual norm 5.101622015491e-11
  5196 KSP Residual norm 5.159081383164e-11
  5197 KSP Residual norm 5.163585229209e-11
  5198 KSP Residual norm 5.734559264366e-11
  5199 KSP Residual norm 6.897281250318e-11
  5200 KSP Residual norm 7.151734304883e-11
  5201 KSP Residual norm 6.078510394485e-11
  5202 KSP Residual norm 5.333184351410e-11
  5203 KSP Residual norm 5.207964491519e-11
  5204 KSP Residual norm 5.152547627309e-11
  5205 KSP Residual norm 4.577269191808e-11
  5206 KSP Residual norm 4.073371927370e-11
  5207 KSP Residual norm 4.203594106114e-11
  5208 KSP Residual norm 4.601618707764e-11
  5209 KSP Residual norm 4.965284343808e-11
  5210 KSP Residual norm 5.359619357967e-11
  5211 KSP Residual norm 5.550918904485e-11
  5212 KSP Residual norm 5.172605836243e-11
  5213 KSP Residual norm 5.069626436267e-11
  5214 KSP Residual norm 5.812329376742e-11
  5215 KSP Residual norm 6.562198478921e-11
  5216 KSP Residual norm 6.194388712776e-11
  5217 KSP Residual norm 4.775219635047e-11
  5218 KSP Residual norm 3.534376936954e-11
  5219 KSP Residual norm 2.864278997591e-11
  5220 KSP Residual norm 2.695595190942e-11
  5221 KSP Residual norm 2.751794742143e-11
  5222 KSP Residual norm 2.622317547439e-11
  5223 KSP Residual norm 2.189054781817e-11
  5224 KSP Residual norm 1.803998027451e-11
  5225 KSP Residual norm 1.689983125034e-11
  5226 KSP Residual norm 1.657596909125e-11
  5227 KSP Residual norm 1.510217802600e-11
  5228 KSP Residual norm 1.361667544790e-11
  5229 KSP Residual norm 1.396466890197e-11
  5230 KSP Residual norm 1.606469929500e-11
  5231 KSP Residual norm 2.059168569761e-11
  5232 KSP Residual norm 2.424678840713e-11
  5233 KSP Residual norm 2.293308189030e-11
  5234 KSP Residual norm 2.140307643676e-11
  5235 KSP Residual norm 2.242980862915e-11
  5236 KSP Residual norm 2.500816697822e-11
  5237 KSP Residual norm 2.624572454986e-11
  5238 KSP Residual norm 2.406129680332e-11
  5239 KSP Residual norm 1.974460118952e-11
  5240 KSP Residual norm 1.881406534135e-11
  5241 KSP Residual norm 2.226203647963e-11
  5242 KSP Residual norm 2.371210779290e-11
  5243 KSP Residual norm 2.156812268998e-11
  5244 KSP Residual norm 2.321143350690e-11
  5245 KSP Residual norm 2.917661678263e-11
  5246 KSP Residual norm 3.346465501570e-11
  5247 KSP Residual norm 3.122259372121e-11
  5248 KSP Residual norm 2.688778353639e-11
  5249 KSP Residual norm 2.607531039019e-11
  5250 KSP Residual norm 2.706686313062e-11
  5251 KSP Residual norm 2.672688140460e-11
  5252 KSP Residual norm 2.568861325810e-11
  5253 KSP Residual norm 2.470453992797e-11
  5254 KSP Residual norm 2.321415245677e-11
  5255 KSP Residual norm 2.311544680159e-11
  5256 KSP Residual norm 2.607595913927e-11
  5257 KSP Residual norm 2.955130386061e-11
  5258 KSP Residual norm 2.995384714402e-11
  5259 KSP Residual norm 3.016381854237e-11
  5260 KSP Residual norm 3.103367599536e-11
  5261 KSP Residual norm 3.307388464309e-11
  5262 KSP Residual norm 3.532435461821e-11
  5263 KSP Residual norm 3.313312317926e-11
  5264 KSP Residual norm 3.057945733555e-11
  5265 KSP Residual norm 2.895140201395e-11
  5266 KSP Residual norm 2.785932000944e-11
  5267 KSP Residual norm 2.877102398968e-11
  5268 KSP Residual norm 3.281171426540e-11
  5269 KSP Residual norm 3.295290718762e-11
  5270 KSP Residual norm 3.099250282615e-11
  5271 KSP Residual norm 3.150868230177e-11
  5272 KSP Residual norm 3.540763188018e-11
  5273 KSP Residual norm 4.138148450052e-11
  5274 KSP Residual norm 4.671281401968e-11
  5275 KSP Residual norm 4.707694483194e-11
  5276 KSP Residual norm 4.632466160814e-11
  5277 KSP Residual norm 4.980757493483e-11
  5278 KSP Residual norm 5.213965586496e-11
  5279 KSP Residual norm 4.910795000236e-11
  5280 KSP Residual norm 4.328401340251e-11
  5281 KSP Residual norm 3.643260717946e-11
  5282 KSP Residual norm 3.328844964617e-11
  5283 KSP Residual norm 3.670242246005e-11
  5284 KSP Residual norm 4.194514402295e-11
  5285 KSP Residual norm 3.820112135113e-11
  5286 KSP Residual norm 3.357648126872e-11
  5287 KSP Residual norm 3.978966889095e-11
  5288 KSP Residual norm 5.397343595354e-11
  5289 KSP Residual norm 5.559260010122e-11
  5290 KSP Residual norm 4.955318286971e-11
  5291 KSP Residual norm 4.964235327076e-11
  5292 KSP Residual norm 5.425556544119e-11
  5293 KSP Residual norm 5.465675344402e-11
  5294 KSP Residual norm 5.033729101792e-11
  5295 KSP Residual norm 4.457128966413e-11
  5296 KSP Residual norm 4.042292846793e-11
  5297 KSP Residual norm 3.869087622327e-11
  5298 KSP Residual norm 3.470686551738e-11
  5299 KSP Residual norm 2.815138773690e-11
  5300 KSP Residual norm 2.406926145328e-11
  5301 KSP Residual norm 2.244859263600e-11
  5302 KSP Residual norm 2.371222375220e-11
  5303 KSP Residual norm 2.576747038746e-11
  5304 KSP Residual norm 2.897426783240e-11
  5305 KSP Residual norm 3.261916936800e-11
  5306 KSP Residual norm 3.298288529379e-11
  5307 KSP Residual norm 2.983318122278e-11
  5308 KSP Residual norm 2.865097915742e-11
  5309 KSP Residual norm 2.991660653824e-11
  5310 KSP Residual norm 3.007884422481e-11
  5311 KSP Residual norm 2.803948395660e-11
  5312 KSP Residual norm 2.646800216521e-11
  5313 KSP Residual norm 2.503799482921e-11
  5314 KSP Residual norm 2.460850680399e-11
  5315 KSP Residual norm 2.364577637134e-11
  5316 KSP Residual norm 2.097048071141e-11
  5317 KSP Residual norm 1.798058439797e-11
  5318 KSP Residual norm 1.610063184695e-11
  5319 KSP Residual norm 1.492978284174e-11
  5320 KSP Residual norm 1.413058334445e-11
  5321 KSP Residual norm 1.290589885657e-11
  5322 KSP Residual norm 1.180457001270e-11
  5323 KSP Residual norm 1.128007146840e-11
  5324 KSP Residual norm 1.202099994317e-11
  5325 KSP Residual norm 1.343129916119e-11
  5326 KSP Residual norm 1.445335862369e-11
  5327 KSP Residual norm 1.409318777141e-11
  5328 KSP Residual norm 1.343984409972e-11
  5329 KSP Residual norm 1.340832178772e-11
  5330 KSP Residual norm 1.411390877042e-11
  5331 KSP Residual norm 1.477466741838e-11
  5332 KSP Residual norm 1.354500876773e-11
  5333 KSP Residual norm 1.074612877709e-11
  5334 KSP Residual norm 8.587036619389e-12
  5335 KSP Residual norm 7.960515474483e-12
  5336 KSP Residual norm 7.874752885817e-12
  5337 KSP Residual norm 7.398059886127e-12
  5338 KSP Residual norm 6.601358560520e-12
  5339 KSP Residual norm 6.135709944485e-12
  5340 KSP Residual norm 6.473481853395e-12
  5341 KSP Residual norm 7.228592600164e-12
  5342 KSP Residual norm 7.874094710002e-12
  5343 KSP Residual norm 8.603626733140e-12
  5344 KSP Residual norm 9.530170617767e-12
  5345 KSP Residual norm 1.100001589776e-11
  5346 KSP Residual norm 1.349904254750e-11
  5347 KSP Residual norm 1.538402427904e-11
  5348 KSP Residual norm 1.506008511536e-11
  5349 KSP Residual norm 1.483934045094e-11
  5350 KSP Residual norm 1.608362116155e-11
  5351 KSP Residual norm 1.809716141392e-11
  5352 KSP Residual norm 2.020772173392e-11
  5353 KSP Residual norm 2.105044118698e-11
  5354 KSP Residual norm 1.906591614046e-11
  5355 KSP Residual norm 1.765715451594e-11
  5356 KSP Residual norm 1.850258738337e-11
  5357 KSP Residual norm 2.008790734872e-11
  5358 KSP Residual norm 1.766123807952e-11
  5359 KSP Residual norm 1.423874462258e-11
  5360 KSP Residual norm 1.360018130154e-11
  5361 KSP Residual norm 1.515454824301e-11
  5362 KSP Residual norm 1.519604236173e-11
  5363 KSP Residual norm 1.285606363857e-11
  5364 KSP Residual norm 1.221582723735e-11
  5365 KSP Residual norm 1.459647689529e-11
  5366 KSP Residual norm 1.704149243244e-11
  5367 KSP Residual norm 1.696515279880e-11
  5368 KSP Residual norm 1.674395010839e-11
  5369 KSP Residual norm 1.886583502951e-11
  5370 KSP Residual norm 2.451660548596e-11
  5371 KSP Residual norm 3.106772571867e-11
  5372 KSP Residual norm 3.180571141991e-11
  5373 KSP Residual norm 3.127384063546e-11
  5374 KSP Residual norm 3.199509160299e-11
  5375 KSP Residual norm 3.139244120777e-11
  5376 KSP Residual norm 2.632320228389e-11
  5377 KSP Residual norm 2.123561722598e-11
  5378 KSP Residual norm 1.843044483114e-11
  5379 KSP Residual norm 1.794249119264e-11
  5380 KSP Residual norm 1.788667167948e-11
  5381 KSP Residual norm 1.591700991738e-11
  5382 KSP Residual norm 1.468764867920e-11
  5383 KSP Residual norm 1.522933650195e-11
  5384 KSP Residual norm 1.638518625246e-11
  5385 KSP Residual norm 1.465970147098e-11
  5386 KSP Residual norm 1.112857794695e-11
  5387 KSP Residual norm 9.315317404182e-12
  5388 KSP Residual norm 9.326772567693e-12
  5389 KSP Residual norm 1.029214539178e-11
  5390 KSP Residual norm 1.059363007264e-11
  5391 KSP Residual norm 1.130298503889e-11
  5392 KSP Residual norm 1.325481156490e-11
  5393 KSP Residual norm 1.428637596084e-11
  5394 KSP Residual norm 1.347917755403e-11
  5395 KSP Residual norm 1.269733177386e-11
  5396 KSP Residual norm 1.186963814900e-11
  5397 KSP Residual norm 1.213677060445e-11
  5398 KSP Residual norm 1.382573846256e-11
  5399 KSP Residual norm 1.423360530884e-11
  5400 KSP Residual norm 1.210118225050e-11
  5401 KSP Residual norm 1.089226053930e-11
  5402 KSP Residual norm 1.101319544099e-11
  5403 KSP Residual norm 1.156315412254e-11
  5404 KSP Residual norm 1.122257321038e-11
  5405 KSP Residual norm 9.530089692831e-12
  5406 KSP Residual norm 7.806114902998e-12
  5407 KSP Residual norm 7.203950144184e-12
  5408 KSP Residual norm 7.413304423724e-12
  5409 KSP Residual norm 8.160282209148e-12
  5410 KSP Residual norm 9.282699219470e-12
  5411 KSP Residual norm 9.617791870059e-12
  5412 KSP Residual norm 9.358174528593e-12
  5413 KSP Residual norm 1.017776720314e-11
  5414 KSP Residual norm 1.191719446161e-11
  5415 KSP Residual norm 1.172419975584e-11
  5416 KSP Residual norm 1.049187711885e-11
  5417 KSP Residual norm 9.812594347276e-12
  5418 KSP Residual norm 9.926190160924e-12
  5419 KSP Residual norm 9.578301613333e-12
  5420 KSP Residual norm 8.542673440279e-12
  5421 KSP Residual norm 7.164333585593e-12
  5422 KSP Residual norm 6.476753814366e-12
  5423 KSP Residual norm 6.893400056395e-12
  5424 KSP Residual norm 7.121151354515e-12
  5425 KSP Residual norm 6.398375032379e-12
  5426 KSP Residual norm 5.555527321950e-12
  5427 KSP Residual norm 5.146360597222e-12
  5428 KSP Residual norm 5.402486562949e-12
  5429 KSP Residual norm 6.009660397642e-12
  5430 KSP Residual norm 5.857312257327e-12
  5431 KSP Residual norm 4.835547937453e-12
  5432 KSP Residual norm 4.276661900734e-12
  5433 KSP Residual norm 4.417990321684e-12
  5434 KSP Residual norm 4.928989287118e-12
  5435 KSP Residual norm 5.150948391793e-12
  5436 KSP Residual norm 4.753197078643e-12
  5437 KSP Residual norm 4.970181530817e-12
  5438 KSP Residual norm 5.835386973637e-12
  5439 KSP Residual norm 6.389469192916e-12
  5440 KSP Residual norm 6.605414317162e-12
  5441 KSP Residual norm 7.089388281390e-12
  5442 KSP Residual norm 7.987209953458e-12
  5443 KSP Residual norm 9.108164536296e-12
  5444 KSP Residual norm 1.050159395083e-11
  5445 KSP Residual norm 1.059094280172e-11
  5446 KSP Residual norm 9.077613292210e-12
  5447 KSP Residual norm 8.208677587707e-12
  5448 KSP Residual norm 8.207192416435e-12
  5449 KSP Residual norm 7.773362005385e-12
  5450 KSP Residual norm 6.943239754201e-12
  5451 KSP Residual norm 6.146895242273e-12
  5452 KSP Residual norm 5.477615562952e-12
  5453 KSP Residual norm 5.057195242514e-12
  5454 KSP Residual norm 5.138480432866e-12
  5455 KSP Residual norm 5.172359304340e-12
  5456 KSP Residual norm 5.317569843744e-12
  5457 KSP Residual norm 5.795613211834e-12
  5458 KSP Residual norm 7.063084726888e-12
  5459 KSP Residual norm 8.607988968644e-12
  5460 KSP Residual norm 9.185585298678e-12
  5461 KSP Residual norm 1.024418194030e-11
  5462 KSP Residual norm 1.210485321819e-11
  5463 KSP Residual norm 1.207712514917e-11
  5464 KSP Residual norm 1.183850057761e-11
  5465 KSP Residual norm 1.342713883329e-11
  5466 KSP Residual norm 1.467908085507e-11
  5467 KSP Residual norm 1.429822877368e-11
  5468 KSP Residual norm 1.343300879601e-11
  5469 KSP Residual norm 1.260346600652e-11
  5470 KSP Residual norm 1.185209565417e-11
  5471 KSP Residual norm 1.167242585746e-11
  5472 KSP Residual norm 1.195387344619e-11
  5473 KSP Residual norm 1.242235972988e-11
  5474 KSP Residual norm 1.117351173642e-11
  5475 KSP Residual norm 9.676012854783e-12
  5476 KSP Residual norm 9.096996902633e-12
  5477 KSP Residual norm 8.692391803752e-12
  5478 KSP Residual norm 8.022983750297e-12
  5479 KSP Residual norm 7.314811670998e-12
  5480 KSP Residual norm 6.621303295606e-12
  5481 KSP Residual norm 6.484803326330e-12
  5482 KSP Residual norm 7.048525559733e-12
  5483 KSP Residual norm 7.702901855617e-12
  5484 KSP Residual norm 7.206790032149e-12
  5485 KSP Residual norm 6.796633262880e-12
  5486 KSP Residual norm 7.712387262627e-12
  5487 KSP Residual norm 9.730488748942e-12
  5488 KSP Residual norm 1.042529474248e-11
  5489 KSP Residual norm 9.929568711613e-12
  5490 KSP Residual norm 1.024815995877e-11
  5491 KSP Residual norm 1.166549114584e-11
  5492 KSP Residual norm 1.210854611116e-11
  5493 KSP Residual norm 1.157403254952e-11
  5494 KSP Residual norm 1.160223681999e-11
  5495 KSP Residual norm 1.250262428085e-11
  5496 KSP Residual norm 1.302312267053e-11
  5497 KSP Residual norm 1.238596203617e-11
  5498 KSP Residual norm 1.033909755605e-11
  5499 KSP Residual norm 8.798897468260e-12
  5500 KSP Residual norm 8.835829480707e-12
  5501 KSP Residual norm 8.610273085702e-12
  5502 KSP Residual norm 7.124767022959e-12
  5503 KSP Residual norm 5.889586877039e-12
  5504 KSP Residual norm 6.016352887111e-12
  5505 KSP Residual norm 6.427926843818e-12
  5506 KSP Residual norm 6.353004121850e-12
  5507 KSP Residual norm 5.961702014386e-12
  5508 KSP Residual norm 5.572244544366e-12
  5509 KSP Residual norm 5.770233443156e-12
  5510 KSP Residual norm 6.375449959926e-12
  5511 KSP Residual norm 6.659985827730e-12
  5512 KSP Residual norm 6.609587496396e-12
  5513 KSP Residual norm 6.805204452205e-12
  5514 KSP Residual norm 6.867141738881e-12
  5515 KSP Residual norm 6.233728440556e-12
  5516 KSP Residual norm 5.677938245384e-12
  5517 KSP Residual norm 5.413145651623e-12
  5518 KSP Residual norm 5.630571534340e-12
  5519 KSP Residual norm 5.967232947870e-12
  5520 KSP Residual norm 5.917455745039e-12
  5521 KSP Residual norm 6.346756861438e-12
  5522 KSP Residual norm 7.057286572378e-12
  5523 KSP Residual norm 7.214732367034e-12
  5524 KSP Residual norm 7.439624112191e-12
  5525 KSP Residual norm 7.987661895676e-12
  5526 KSP Residual norm 8.391447385169e-12
  5527 KSP Residual norm 9.158000178287e-12
  5528 KSP Residual norm 9.924508960532e-12
  5529 KSP Residual norm 1.015857770006e-11
  5530 KSP Residual norm 1.074004662550e-11
  5531 KSP Residual norm 1.159579239177e-11
  5532 KSP Residual norm 1.122481301232e-11
  5533 KSP Residual norm 1.017824061480e-11
  5534 KSP Residual norm 9.809218424974e-12
  5535 KSP Residual norm 1.010579660232e-11
  5536 KSP Residual norm 1.059361015838e-11
  5537 KSP Residual norm 1.086764150170e-11
  5538 KSP Residual norm 1.234800115441e-11
  5539 KSP Residual norm 1.489246461477e-11
  5540 KSP Residual norm 1.519308417199e-11
  5541 KSP Residual norm 1.396694619266e-11
  5542 KSP Residual norm 1.435035664336e-11
  5543 KSP Residual norm 1.442074656565e-11
  5544 KSP Residual norm 1.227687789587e-11
  5545 KSP Residual norm 1.039735360670e-11
  5546 KSP Residual norm 9.824244281285e-12
  5547 KSP Residual norm 9.810676622436e-12
  5548 KSP Residual norm 9.286512542398e-12
  5549 KSP Residual norm 8.888380313094e-12
  5550 KSP Residual norm 8.807554668120e-12
  5551 KSP Residual norm 9.648479320880e-12
  5552 KSP Residual norm 1.032768445778e-11
  5553 KSP Residual norm 1.008481387419e-11
  5554 KSP Residual norm 1.016424204519e-11
  5555 KSP Residual norm 1.122259547765e-11
  5556 KSP Residual norm 1.189316128824e-11
  5557 KSP Residual norm 1.209898546859e-11
  5558 KSP Residual norm 1.313046807997e-11
  5559 KSP Residual norm 1.533822210499e-11
  5560 KSP Residual norm 1.872862619774e-11
  5561 KSP Residual norm 1.957616683148e-11
  5562 KSP Residual norm 1.892594697107e-11
  5563 KSP Residual norm 2.011092327579e-11
  5564 KSP Residual norm 2.149502666797e-11
  5565 KSP Residual norm 2.237795057636e-11
  5566 KSP Residual norm 2.481468631349e-11
  5567 KSP Residual norm 2.539659162738e-11
  5568 KSP Residual norm 2.450628077691e-11
  5569 KSP Residual norm 2.351965569059e-11
  5570 KSP Residual norm 2.189617612615e-11
  5571 KSP Residual norm 1.952346385018e-11
  5572 KSP Residual norm 2.016494746240e-11
  5573 KSP Residual norm 2.240459836862e-11
  5574 KSP Residual norm 2.245439359386e-11
  5575 KSP Residual norm 2.195253331909e-11
  5576 KSP Residual norm 2.242614757782e-11
  5577 KSP Residual norm 2.213716340487e-11
  5578 KSP Residual norm 2.349556255952e-11
  5579 KSP Residual norm 2.850422713540e-11
  5580 KSP Residual norm 3.303854588535e-11
  5581 KSP Residual norm 3.621154533585e-11
  5582 KSP Residual norm 3.999065823538e-11
  5583 KSP Residual norm 3.977078013051e-11
  5584 KSP Residual norm 3.669807197786e-11
  5585 KSP Residual norm 3.635416161144e-11
  5586 KSP Residual norm 4.123747838186e-11
  5587 KSP Residual norm 4.597899632726e-11
  5588 KSP Residual norm 4.340615890122e-11
  5589 KSP Residual norm 4.287827637385e-11
  5590 KSP Residual norm 4.937198760374e-11
  5591 KSP Residual norm 4.855785423357e-11
  5592 KSP Residual norm 3.709978758845e-11
  5593 KSP Residual norm 2.957822082424e-11
  5594 KSP Residual norm 2.609218010244e-11
  5595 KSP Residual norm 2.259328490265e-11
  5596 KSP Residual norm 1.965763796735e-11
  5597 KSP Residual norm 1.856369834539e-11
  5598 KSP Residual norm 1.942391529075e-11
  5599 KSP Residual norm 2.154861608985e-11
  5600 KSP Residual norm 2.374424468329e-11
  5601 KSP Residual norm 2.434339448669e-11
  5602 KSP Residual norm 2.502094502266e-11
  5603 KSP Residual norm 2.619635892519e-11
  5604 KSP Residual norm 2.731355707579e-11
  5605 KSP Residual norm 2.992192841012e-11
  5606 KSP Residual norm 3.478600266647e-11
  5607 KSP Residual norm 3.414099037596e-11
  5608 KSP Residual norm 3.113906879984e-11
  5609 KSP Residual norm 3.028969889874e-11
  5610 KSP Residual norm 3.159869810882e-11
  5611 KSP Residual norm 3.016863242224e-11
  5612 KSP Residual norm 2.853102432581e-11
  5613 KSP Residual norm 3.014264052844e-11
  5614 KSP Residual norm 3.303614026879e-11
  5615 KSP Residual norm 3.044388372803e-11
  5616 KSP Residual norm 2.626422945323e-11
  5617 KSP Residual norm 2.547853427834e-11
  5618 KSP Residual norm 2.575139445495e-11
  5619 KSP Residual norm 2.232576524035e-11
  5620 KSP Residual norm 1.827003429193e-11
  5621 KSP Residual norm 1.589397929189e-11
  5622 KSP Residual norm 1.423938233379e-11
  5623 KSP Residual norm 1.318873513523e-11
  5624 KSP Residual norm 1.318181895343e-11
  5625 KSP Residual norm 1.255081903551e-11
  5626 KSP Residual norm 1.130340395483e-11
  5627 KSP Residual norm 1.075137607446e-11
  5628 KSP Residual norm 1.057041154129e-11
  5629 KSP Residual norm 9.931293702579e-12
  5630 KSP Residual norm 8.985192718914e-12
  5631 KSP Residual norm 8.398186523772e-12
  5632 KSP Residual norm 8.933644090464e-12
  5633 KSP Residual norm 1.011279050211e-11
  5634 KSP Residual norm 1.173393290530e-11
  5635 KSP Residual norm 1.359619081274e-11
  5636 KSP Residual norm 1.545153795429e-11
  5637 KSP Residual norm 1.642524592929e-11
  5638 KSP Residual norm 1.755793154553e-11
  5639 KSP Residual norm 2.044797564840e-11
  5640 KSP Residual norm 2.484700822173e-11
  5641 KSP Residual norm 2.655340561964e-11
  5642 KSP Residual norm 2.829121611488e-11
  5643 KSP Residual norm 3.259156146349e-11
  5644 KSP Residual norm 3.606327485826e-11
  5645 KSP Residual norm 3.560568289266e-11
  5646 KSP Residual norm 3.761060611307e-11
  5647 KSP Residual norm 4.352815582403e-11
  5648 KSP Residual norm 5.353063682980e-11
  5649 KSP Residual norm 6.111845132842e-11
  5650 KSP Residual norm 6.038062861573e-11
  5651 KSP Residual norm 5.898752481490e-11
  5652 KSP Residual norm 6.522347071309e-11
  5653 KSP Residual norm 7.270413987527e-11
  5654 KSP Residual norm 6.714123027328e-11
  5655 KSP Residual norm 5.695945129323e-11
  5656 KSP Residual norm 4.866025927520e-11
  5657 KSP Residual norm 4.316327848987e-11
  5658 KSP Residual norm 4.105739476341e-11
  5659 KSP Residual norm 3.658513992281e-11
  5660 KSP Residual norm 3.587794716169e-11
  5661 KSP Residual norm 3.925707911683e-11
  5662 KSP Residual norm 4.586312803899e-11
  5663 KSP Residual norm 5.378143083475e-11
  5664 KSP Residual norm 5.418324851050e-11
  5665 KSP Residual norm 4.800839098110e-11
  5666 KSP Residual norm 4.821005432672e-11
  5667 KSP Residual norm 5.182512298826e-11
  5668 KSP Residual norm 4.811064945468e-11
  5669 KSP Residual norm 4.637349290365e-11
  5670 KSP Residual norm 4.997876964620e-11
  5671 KSP Residual norm 4.949868452906e-11
  5672 KSP Residual norm 4.370826024422e-11
  5673 KSP Residual norm 4.313800721563e-11
  5674 KSP Residual norm 4.542428277565e-11
  5675 KSP Residual norm 4.289557699782e-11
  5676 KSP Residual norm 3.896644023394e-11
  5677 KSP Residual norm 3.656489162078e-11
  5678 KSP Residual norm 3.393190531199e-11
  5679 KSP Residual norm 3.542996016483e-11
  5680 KSP Residual norm 3.851480981982e-11
  5681 KSP Residual norm 3.560364599481e-11
  5682 KSP Residual norm 3.097650730922e-11
  5683 KSP Residual norm 3.122963938428e-11
  5684 KSP Residual norm 3.880561733838e-11
  5685 KSP Residual norm 4.613100038800e-11
  5686 KSP Residual norm 4.728640105559e-11
  5687 KSP Residual norm 5.125914211218e-11
  5688 KSP Residual norm 6.218346402723e-11
  5689 KSP Residual norm 6.456549209761e-11
  5690 KSP Residual norm 5.923367346102e-11
  5691 KSP Residual norm 6.462724734893e-11
  5692 KSP Residual norm 6.865232564838e-11
  5693 KSP Residual norm 6.472334547721e-11
  5694 KSP Residual norm 6.447880492928e-11
  5695 KSP Residual norm 6.488417885693e-11
  5696 KSP Residual norm 6.255758601653e-11
  5697 KSP Residual norm 5.944574729260e-11
  5698 KSP Residual norm 5.293374468291e-11
  5699 KSP Residual norm 4.294991851597e-11
  5700 KSP Residual norm 3.689899941140e-11
  5701 KSP Residual norm 3.578131918797e-11
  5702 KSP Residual norm 3.469141599564e-11
  5703 KSP Residual norm 3.310879470648e-11
  5704 KSP Residual norm 3.417168412640e-11
  5705 KSP Residual norm 4.093848370123e-11
  5706 KSP Residual norm 5.046409858929e-11
  5707 KSP Residual norm 5.542683964662e-11
  5708 KSP Residual norm 5.909890386194e-11
  5709 KSP Residual norm 6.737348828020e-11
  5710 KSP Residual norm 7.388443503162e-11
  5711 KSP Residual norm 7.613955014665e-11
  5712 KSP Residual norm 7.806341826237e-11
  5713 KSP Residual norm 8.157831390738e-11
  5714 KSP Residual norm 8.457736671073e-11
  5715 KSP Residual norm 8.599260467969e-11
  5716 KSP Residual norm 7.828936094528e-11
  5717 KSP Residual norm 6.854499835197e-11
  5718 KSP Residual norm 6.878459637399e-11
  5719 KSP Residual norm 6.769857983918e-11
  5720 KSP Residual norm 6.024267606041e-11
  5721 KSP Residual norm 5.773292258208e-11
  5722 KSP Residual norm 5.758913749237e-11
  5723 KSP Residual norm 5.278317414136e-11
  5724 KSP Residual norm 4.869794536237e-11
  5725 KSP Residual norm 4.552170981397e-11
  5726 KSP Residual norm 4.487491673030e-11
  5727 KSP Residual norm 4.806615959698e-11
  5728 KSP Residual norm 5.234737139084e-11
  5729 KSP Residual norm 5.363295475532e-11
  5730 KSP Residual norm 5.419736839809e-11
  5731 KSP Residual norm 5.549021266325e-11
  5732 KSP Residual norm 6.396296859826e-11
  5733 KSP Residual norm 7.537143580508e-11
  5734 KSP Residual norm 8.357416465031e-11
  5735 KSP Residual norm 9.661823746778e-11
  5736 KSP Residual norm 1.174303604878e-10
  5737 KSP Residual norm 1.165633267073e-10
  5738 KSP Residual norm 1.100222014221e-10
  5739 KSP Residual norm 1.279569268042e-10
  5740 KSP Residual norm 1.383672631837e-10
  5741 KSP Residual norm 1.256840200761e-10
  5742 KSP Residual norm 1.279597953376e-10
  5743 KSP Residual norm 1.355937408620e-10
  5744 KSP Residual norm 1.300850445245e-10
  5745 KSP Residual norm 1.335925203137e-10
  5746 KSP Residual norm 1.409345632961e-10
  5747 KSP Residual norm 1.434507186744e-10
  5748 KSP Residual norm 1.354613451236e-10
  5749 KSP Residual norm 1.156082936977e-10
  5750 KSP Residual norm 1.001323250331e-10
  5751 KSP Residual norm 9.564083063013e-11
  5752 KSP Residual norm 9.521353087749e-11
  5753 KSP Residual norm 9.420194779746e-11
  5754 KSP Residual norm 9.251699808077e-11
  5755 KSP Residual norm 9.261771442548e-11
  5756 KSP Residual norm 9.916480213888e-11
  5757 KSP Residual norm 1.118228764952e-10
  5758 KSP Residual norm 1.149340334046e-10
  5759 KSP Residual norm 1.216526890013e-10
  5760 KSP Residual norm 1.452013829331e-10
  5761 KSP Residual norm 1.493113203364e-10
  5762 KSP Residual norm 1.356260273381e-10
  5763 KSP Residual norm 1.604515997576e-10
  5764 KSP Residual norm 2.031863445801e-10
  5765 KSP Residual norm 2.060254433490e-10
  5766 KSP Residual norm 1.942411873997e-10
  5767 KSP Residual norm 1.935994757589e-10
  5768 KSP Residual norm 1.881496540256e-10
  5769 KSP Residual norm 1.889755190418e-10
  5770 KSP Residual norm 1.954337928717e-10
  5771 KSP Residual norm 1.963895681667e-10
  5772 KSP Residual norm 2.195751374139e-10
  5773 KSP Residual norm 2.543635360762e-10
  5774 KSP Residual norm 2.624050825572e-10
  5775 KSP Residual norm 2.570548686124e-10
  5776 KSP Residual norm 2.574337225234e-10
  5777 KSP Residual norm 2.612126029886e-10
  5778 KSP Residual norm 2.585372503511e-10
  5779 KSP Residual norm 2.467428579512e-10
  5780 KSP Residual norm 2.293342901898e-10
  5781 KSP Residual norm 2.177866322364e-10
  5782 KSP Residual norm 1.999173116603e-10
  5783 KSP Residual norm 1.844896586790e-10
  5784 KSP Residual norm 1.841227827190e-10
  5785 KSP Residual norm 1.785740562691e-10
  5786 KSP Residual norm 1.656438303608e-10
  5787 KSP Residual norm 1.595742191893e-10
  5788 KSP Residual norm 1.509328177101e-10
  5789 KSP Residual norm 1.511043162007e-10
  5790 KSP Residual norm 1.655258694499e-10
  5791 KSP Residual norm 1.605057680389e-10
  5792 KSP Residual norm 1.432126206287e-10
  5793 KSP Residual norm 1.395361154996e-10
  5794 KSP Residual norm 1.463435452772e-10
  5795 KSP Residual norm 1.432461509420e-10
  5796 KSP Residual norm 1.361785700969e-10
  5797 KSP Residual norm 1.361006346693e-10
  5798 KSP Residual norm 1.399983943472e-10
  5799 KSP Residual norm 1.452725223508e-10
  5800 KSP Residual norm 1.442211067935e-10
  5801 KSP Residual norm 1.346628556516e-10
  5802 KSP Residual norm 1.356441924416e-10
  5803 KSP Residual norm 1.299349396197e-10
  5804 KSP Residual norm 1.113033283379e-10
  5805 KSP Residual norm 1.039366224894e-10
  5806 KSP Residual norm 1.084960630769e-10
  5807 KSP Residual norm 1.081336413826e-10
  5808 KSP Residual norm 1.030561431364e-10
  5809 KSP Residual norm 9.212207613555e-11
  5810 KSP Residual norm 8.327444190202e-11
  5811 KSP Residual norm 8.318318548337e-11
  5812 KSP Residual norm 8.613996377652e-11
  5813 KSP Residual norm 7.748248729194e-11
  5814 KSP Residual norm 7.383935918690e-11
  5815 KSP Residual norm 7.819782891562e-11
  5816 KSP Residual norm 8.169883511052e-11
  5817 KSP Residual norm 7.723758924498e-11
  5818 KSP Residual norm 7.475759197589e-11
  5819 KSP Residual norm 7.684645157648e-11
  5820 KSP Residual norm 8.219268226744e-11
  5821 KSP Residual norm 7.417878294479e-11
  5822 KSP Residual norm 6.640057309780e-11
  5823 KSP Residual norm 7.377727010312e-11
  5824 KSP Residual norm 8.856273578044e-11
  5825 KSP Residual norm 8.609443979617e-11
  5826 KSP Residual norm 8.506913818783e-11
  5827 KSP Residual norm 9.627083097049e-11
  5828 KSP Residual norm 1.007096535428e-10
  5829 KSP Residual norm 9.852594002881e-11
  5830 KSP Residual norm 1.015189302557e-10
  5831 KSP Residual norm 1.003569948251e-10
  5832 KSP Residual norm 1.018370286075e-10
  5833 KSP Residual norm 1.057034209955e-10
  5834 KSP Residual norm 1.016330717476e-10
  5835 KSP Residual norm 9.443668422471e-11
  5836 KSP Residual norm 9.037752804484e-11
  5837 KSP Residual norm 9.110894450970e-11
  5838 KSP Residual norm 9.541165287370e-11
  5839 KSP Residual norm 8.918138152508e-11
  5840 KSP Residual norm 7.634130012907e-11
  5841 KSP Residual norm 7.678527940424e-11
  5842 KSP Residual norm 8.689756028621e-11
  5843 KSP Residual norm 7.792217841204e-11
  5844 KSP Residual norm 6.791380452440e-11
  5845 KSP Residual norm 7.269258653373e-11
  5846 KSP Residual norm 8.077625651603e-11
  5847 KSP Residual norm 8.553588385418e-11
  5848 KSP Residual norm 8.390286343256e-11
  5849 KSP Residual norm 8.456223814207e-11
  5850 KSP Residual norm 1.004512177627e-10
  5851 KSP Residual norm 1.202272607853e-10
  5852 KSP Residual norm 1.213000084140e-10
  5853 KSP Residual norm 1.113221666329e-10
  5854 KSP Residual norm 9.780681784626e-11
  5855 KSP Residual norm 9.158730128583e-11
  5856 KSP Residual norm 1.003749028518e-10
  5857 KSP Residual norm 1.070610373438e-10
  5858 KSP Residual norm 1.046269894158e-10
  5859 KSP Residual norm 1.239288723376e-10
  5860 KSP Residual norm 1.547477405855e-10
  5861 KSP Residual norm 1.378143794562e-10
  5862 KSP Residual norm 1.017073226796e-10
  5863 KSP Residual norm 8.561880900112e-11
  5864 KSP Residual norm 8.533456053422e-11
  5865 KSP Residual norm 8.506281951156e-11
  5866 KSP Residual norm 7.360216662078e-11
  5867 KSP Residual norm 6.400250684363e-11
  5868 KSP Residual norm 6.424161817584e-11
  5869 KSP Residual norm 6.692885883273e-11
  5870 KSP Residual norm 6.744589834035e-11
  5871 KSP Residual norm 7.196414017098e-11
  5872 KSP Residual norm 7.690288041792e-11
  5873 KSP Residual norm 7.814729797736e-11
  5874 KSP Residual norm 7.817507959900e-11
  5875 KSP Residual norm 8.060030669745e-11
  5876 KSP Residual norm 8.513025706974e-11
  5877 KSP Residual norm 9.731240960080e-11
  5878 KSP Residual norm 1.037414966910e-10
  5879 KSP Residual norm 1.008673858655e-10
  5880 KSP Residual norm 1.090908749139e-10
  5881 KSP Residual norm 1.267070364733e-10
  5882 KSP Residual norm 1.241475047424e-10
  5883 KSP Residual norm 1.280073700169e-10
  5884 KSP Residual norm 1.489172032276e-10
  5885 KSP Residual norm 1.561390384459e-10
  5886 KSP Residual norm 1.485361753268e-10
  5887 KSP Residual norm 1.495104830699e-10
  5888 KSP Residual norm 1.504202222468e-10
  5889 KSP Residual norm 1.346720743183e-10
  5890 KSP Residual norm 1.218045943131e-10
  5891 KSP Residual norm 1.093043236346e-10
  5892 KSP Residual norm 9.477972125942e-11
  5893 KSP Residual norm 9.341793794874e-11
  5894 KSP Residual norm 1.058600854413e-10
  5895 KSP Residual norm 1.115128400226e-10
  5896 KSP Residual norm 1.041207809990e-10
  5897 KSP Residual norm 9.583970348767e-11
  5898 KSP Residual norm 9.777535096215e-11
  5899 KSP Residual norm 9.474401366706e-11
  5900 KSP Residual norm 9.087173050590e-11
  5901 KSP Residual norm 9.814759183158e-11
  5902 KSP Residual norm 1.010187887439e-10
  5903 KSP Residual norm 9.240473442485e-11
  5904 KSP Residual norm 9.906273514330e-11
  5905 KSP Residual norm 1.235739398530e-10
  5906 KSP Residual norm 1.203534874351e-10
  5907 KSP Residual norm 1.092106157425e-10
  5908 KSP Residual norm 1.207887102168e-10
  5909 KSP Residual norm 1.378268146834e-10
  5910 KSP Residual norm 1.358145069690e-10
  5911 KSP Residual norm 1.309616576167e-10
  5912 KSP Residual norm 1.349661256595e-10
  5913 KSP Residual norm 1.213429989130e-10
  5914 KSP Residual norm 9.556006585300e-11
  5915 KSP Residual norm 8.333572748946e-11
  5916 KSP Residual norm 8.093181478501e-11
  5917 KSP Residual norm 7.517408151023e-11
  5918 KSP Residual norm 6.477328330274e-11
  5919 KSP Residual norm 6.051444325039e-11
  5920 KSP Residual norm 5.928822003694e-11
  5921 KSP Residual norm 5.393272573685e-11
  5922 KSP Residual norm 5.275324709911e-11
  5923 KSP Residual norm 5.540127171928e-11
  5924 KSP Residual norm 5.099315819361e-11
  5925 KSP Residual norm 4.603188859251e-11
  5926 KSP Residual norm 4.426258066348e-11
  5927 KSP Residual norm 4.170952953323e-11
  5928 KSP Residual norm 4.161198668452e-11
  5929 KSP Residual norm 4.767327259135e-11
  5930 KSP Residual norm 5.472654339013e-11
  5931 KSP Residual norm 5.828566553660e-11
  5932 KSP Residual norm 6.461107652153e-11
  5933 KSP Residual norm 6.646430054011e-11
  5934 KSP Residual norm 6.707808932525e-11
  5935 KSP Residual norm 6.975473834227e-11
  5936 KSP Residual norm 6.477733807429e-11
  5937 KSP Residual norm 6.374916657040e-11
  5938 KSP Residual norm 7.611580566168e-11
  5939 KSP Residual norm 7.660504525112e-11
  5940 KSP Residual norm 6.781580714379e-11
  5941 KSP Residual norm 6.574410103546e-11
  5942 KSP Residual norm 6.072364872694e-11
  5943 KSP Residual norm 5.270446532914e-11
  5944 KSP Residual norm 4.994771303891e-11
  5945 KSP Residual norm 4.887491548898e-11
  5946 KSP Residual norm 4.660079555963e-11
  5947 KSP Residual norm 4.222394503038e-11
  5948 KSP Residual norm 4.143249986091e-11
  5949 KSP Residual norm 4.078249190659e-11
  5950 KSP Residual norm 3.863372359253e-11
  5951 KSP Residual norm 3.716741272742e-11
  5952 KSP Residual norm 4.015874986995e-11
  5953 KSP Residual norm 4.125877527437e-11
  5954 KSP Residual norm 3.625630583457e-11
  5955 KSP Residual norm 3.559343454009e-11
  5956 KSP Residual norm 4.031449886192e-11
  5957 KSP Residual norm 3.722192136577e-11
  5958 KSP Residual norm 3.329075975801e-11
  5959 KSP Residual norm 3.466427832161e-11
  5960 KSP Residual norm 3.663650859890e-11
  5961 KSP Residual norm 4.202150067272e-11
  5962 KSP Residual norm 5.200641059960e-11
  5963 KSP Residual norm 5.813939821609e-11
  5964 KSP Residual norm 5.714715471928e-11
  5965 KSP Residual norm 5.646893489239e-11
  5966 KSP Residual norm 5.499031474681e-11
  5967 KSP Residual norm 5.173814366849e-11
  5968 KSP Residual norm 5.429249897624e-11
  5969 KSP Residual norm 6.462715802647e-11
  5970 KSP Residual norm 7.785761818193e-11
  5971 KSP Residual norm 8.700703117530e-11
  5972 KSP Residual norm 8.993871687674e-11
  5973 KSP Residual norm 9.609659048824e-11
  5974 KSP Residual norm 1.068226511863e-10
  5975 KSP Residual norm 1.127703274380e-10
  5976 KSP Residual norm 1.193851823609e-10
  5977 KSP Residual norm 1.443660608508e-10
  5978 KSP Residual norm 1.679999300579e-10
  5979 KSP Residual norm 1.665906906259e-10
  5980 KSP Residual norm 1.603834074196e-10
  5981 KSP Residual norm 1.518458922183e-10
  5982 KSP Residual norm 1.422039734212e-10
  5983 KSP Residual norm 1.289443453085e-10
  5984 KSP Residual norm 1.053650097050e-10
  5985 KSP Residual norm 8.985168070641e-11
  5986 KSP Residual norm 8.754505438088e-11
  5987 KSP Residual norm 8.705281583706e-11
  5988 KSP Residual norm 8.727818322764e-11
  5989 KSP Residual norm 8.601023308319e-11
  5990 KSP Residual norm 7.754646282901e-11
  5991 KSP Residual norm 7.634934062486e-11
  5992 KSP Residual norm 7.646924522212e-11
  5993 KSP Residual norm 6.275081995883e-11
  5994 KSP Residual norm 5.042198120209e-11
  5995 KSP Residual norm 5.174675224079e-11
  5996 KSP Residual norm 6.192604483184e-11
  5997 KSP Residual norm 6.480544309045e-11
  5998 KSP Residual norm 6.043941633936e-11
  5999 KSP Residual norm 5.688984290809e-11
  6000 KSP Residual norm 6.153570873707e-11
  6001 KSP Residual norm 7.055374212696e-11
  6002 KSP Residual norm 7.996035899778e-11
  6003 KSP Residual norm 8.315489907540e-11
  6004 KSP Residual norm 7.809938120457e-11
  6005 KSP Residual norm 7.370801848636e-11
  6006 KSP Residual norm 7.232328876318e-11
  6007 KSP Residual norm 6.893265056490e-11
  6008 KSP Residual norm 6.215116572809e-11
  6009 KSP Residual norm 5.952797447756e-11
  6010 KSP Residual norm 5.843167301971e-11
  6011 KSP Residual norm 4.881687185081e-11
  6012 KSP Residual norm 4.309196222023e-11
  6013 KSP Residual norm 4.525902101113e-11
  6014 KSP Residual norm 4.705835977562e-11
  6015 KSP Residual norm 4.777147220703e-11
  6016 KSP Residual norm 5.205031936963e-11
  6017 KSP Residual norm 4.700818719864e-11
  6018 KSP Residual norm 3.620602021949e-11
  6019 KSP Residual norm 3.237132953078e-11
  6020 KSP Residual norm 3.055178591077e-11
  6021 KSP Residual norm 2.811245210145e-11
  6022 KSP Residual norm 2.528961926683e-11
  6023 KSP Residual norm 2.341215597173e-11
  6024 KSP Residual norm 2.115207115705e-11
  6025 KSP Residual norm 2.068847831662e-11
  6026 KSP Residual norm 2.032203732432e-11
  6027 KSP Residual norm 1.935994579464e-11
  6028 KSP Residual norm 1.746403478509e-11
  6029 KSP Residual norm 1.661646153240e-11
  6030 KSP Residual norm 1.626810951695e-11
  6031 KSP Residual norm 1.456175899872e-11
  6032 KSP Residual norm 1.238499311132e-11
  6033 KSP Residual norm 1.201875477374e-11
  6034 KSP Residual norm 1.182580076661e-11
  6035 KSP Residual norm 1.012100891493e-11
  6036 KSP Residual norm 9.133131903760e-12
  6037 KSP Residual norm 8.870422513034e-12
  6038 KSP Residual norm 8.344984715360e-12
  6039 KSP Residual norm 8.627606099311e-12
  6040 KSP Residual norm 9.307486565596e-12
  6041 KSP Residual norm 9.164096122709e-12
  6042 KSP Residual norm 8.904994947782e-12
  6043 KSP Residual norm 9.123580237034e-12
  6044 KSP Residual norm 9.270093380464e-12
  6045 KSP Residual norm 8.907549292948e-12
  6046 KSP Residual norm 8.515651720645e-12
  6047 KSP Residual norm 8.358097765138e-12
  6048 KSP Residual norm 8.867279270219e-12
  6049 KSP Residual norm 9.027176312400e-12
  6050 KSP Residual norm 8.407713257764e-12
  6051 KSP Residual norm 8.204880618109e-12
  6052 KSP Residual norm 8.297844963422e-12
  6053 KSP Residual norm 8.358495694263e-12
  6054 KSP Residual norm 9.055899779415e-12
  6055 KSP Residual norm 1.067125644897e-11
  6056 KSP Residual norm 1.179247104036e-11
  6057 KSP Residual norm 1.323546995781e-11
  6058 KSP Residual norm 1.468584329199e-11
  6059 KSP Residual norm 1.493666305568e-11
  6060 KSP Residual norm 1.425958406936e-11
  6061 KSP Residual norm 1.301153915274e-11
  6062 KSP Residual norm 1.214297419279e-11
  6063 KSP Residual norm 1.205248585571e-11
  6064 KSP Residual norm 1.117956245808e-11
  6065 KSP Residual norm 1.001031197149e-11
  6066 KSP Residual norm 1.061978302351e-11
  6067 KSP Residual norm 1.171671438435e-11
  6068 KSP Residual norm 1.094645008941e-11
  6069 KSP Residual norm 1.055300855068e-11
  6070 KSP Residual norm 9.932014465356e-12
  6071 KSP Residual norm 7.849487947874e-12
  6072 KSP Residual norm 7.237863920675e-12
  6073 KSP Residual norm 8.363893584069e-12
  6074 KSP Residual norm 8.820157634672e-12
  6075 KSP Residual norm 7.821883340973e-12
  6076 KSP Residual norm 7.398531637995e-12
  6077 KSP Residual norm 7.316354920353e-12
  6078 KSP Residual norm 6.812004232210e-12
  6079 KSP Residual norm 6.972314201247e-12
  6080 KSP Residual norm 7.920294918265e-12
  6081 KSP Residual norm 8.801369145327e-12
  6082 KSP Residual norm 8.950825652825e-12
  6083 KSP Residual norm 8.957956380879e-12
  6084 KSP Residual norm 9.343286368598e-12
  6085 KSP Residual norm 1.013201421231e-11
  6086 KSP Residual norm 1.163506274229e-11
  6087 KSP Residual norm 1.368140713205e-11
  6088 KSP Residual norm 1.393732489030e-11
  6089 KSP Residual norm 1.427054692467e-11
  6090 KSP Residual norm 1.494990610644e-11
  6091 KSP Residual norm 1.447764494045e-11
  6092 KSP Residual norm 1.422463924564e-11
  6093 KSP Residual norm 1.554601588697e-11
  6094 KSP Residual norm 1.512832738598e-11
  6095 KSP Residual norm 1.196193173304e-11
  6096 KSP Residual norm 1.011815962223e-11
  6097 KSP Residual norm 1.037988957872e-11
  6098 KSP Residual norm 1.063097926261e-11
  6099 KSP Residual norm 9.025121533150e-12
  6100 KSP Residual norm 7.807377233446e-12
  6101 KSP Residual norm 7.590657227247e-12
  6102 KSP Residual norm 7.565856827194e-12
  6103 KSP Residual norm 7.664278495335e-12
  6104 KSP Residual norm 7.858015140892e-12
  6105 KSP Residual norm 7.866027619786e-12
  6106 KSP Residual norm 7.845311582316e-12
  6107 KSP Residual norm 8.112226673436e-12
  6108 KSP Residual norm 7.996914596951e-12
  6109 KSP Residual norm 7.077237094116e-12
  6110 KSP Residual norm 6.608665602628e-12
  6111 KSP Residual norm 7.268243812588e-12
  6112 KSP Residual norm 8.691787724813e-12
  6113 KSP Residual norm 9.949927056381e-12
  6114 KSP Residual norm 1.046891548083e-11
  6115 KSP Residual norm 1.007873783824e-11
  6116 KSP Residual norm 9.319802472384e-12
  6117 KSP Residual norm 8.230892421744e-12
  6118 KSP Residual norm 7.018436917741e-12
  6119 KSP Residual norm 7.145070800058e-12
  6120 KSP Residual norm 8.268647964261e-12
  6121 KSP Residual norm 9.368909237968e-12
  6122 KSP Residual norm 1.048973177754e-11
  6123 KSP Residual norm 1.141468121149e-11
  6124 KSP Residual norm 1.087615446004e-11
  6125 KSP Residual norm 9.881721634641e-12
  6126 KSP Residual norm 9.683996051274e-12
  6127 KSP Residual norm 9.431813068795e-12
  6128 KSP Residual norm 9.292141100861e-12
  6129 KSP Residual norm 9.158965552592e-12
  6130 KSP Residual norm 8.276428489833e-12
  6131 KSP Residual norm 7.406595151324e-12
  6132 KSP Residual norm 6.499131457868e-12
  6133 KSP Residual norm 5.671565910740e-12
  6134 KSP Residual norm 5.407162563112e-12
  6135 KSP Residual norm 5.289426147416e-12
  6136 KSP Residual norm 4.959007649346e-12
  6137 KSP Residual norm 4.944594628033e-12
  6138 KSP Residual norm 5.054854738154e-12
  6139 KSP Residual norm 5.362651151330e-12
  6140 KSP Residual norm 6.425476757168e-12
  6141 KSP Residual norm 7.356937491201e-12
  6142 KSP Residual norm 6.914516904486e-12
  6143 KSP Residual norm 6.712758425577e-12
  6144 KSP Residual norm 6.417628218738e-12
  6145 KSP Residual norm 5.178819577014e-12
  6146 KSP Residual norm 4.670193997786e-12
  6147 KSP Residual norm 5.308942288506e-12
  6148 KSP Residual norm 6.318809092779e-12
  6149 KSP Residual norm 6.855865487971e-12
  6150 KSP Residual norm 7.737877038467e-12
  6151 KSP Residual norm 9.336593347318e-12
  6152 KSP Residual norm 9.381340078474e-12
  6153 KSP Residual norm 8.420831240133e-12
  6154 KSP Residual norm 7.710255212856e-12
  6155 KSP Residual norm 8.097709196618e-12
  6156 KSP Residual norm 9.024485483506e-12
  6157 KSP Residual norm 9.623181946656e-12
  6158 KSP Residual norm 9.556773848916e-12
  6159 KSP Residual norm 8.190838301943e-12
  6160 KSP Residual norm 6.681379226326e-12
  6161 KSP Residual norm 6.026475570832e-12
  6162 KSP Residual norm 5.926891189696e-12
  6163 KSP Residual norm 5.883357125780e-12
  6164 KSP Residual norm 5.600671185371e-12
  6165 KSP Residual norm 4.863587677538e-12
  6166 KSP Residual norm 4.086544640680e-12
  6167 KSP Residual norm 3.579839146206e-12
  6168 KSP Residual norm 3.165158380509e-12
  6169 KSP Residual norm 2.727991415883e-12
  6170 KSP Residual norm 2.553982049387e-12
  6171 KSP Residual norm 2.493598832989e-12
  6172 KSP Residual norm 2.143873916698e-12
  6173 KSP Residual norm 1.766446869847e-12
  6174 KSP Residual norm 1.531195948780e-12
  6175 KSP Residual norm 1.500057230144e-12
  6176 KSP Residual norm 1.711523956778e-12
  6177 KSP Residual norm 2.021899438975e-12
  6178 KSP Residual norm 2.095224967377e-12
  6179 KSP Residual norm 1.952394667114e-12
  6180 KSP Residual norm 1.843287213171e-12
  6181 KSP Residual norm 1.927074123429e-12
  6182 KSP Residual norm 2.061844787311e-12
  6183 KSP Residual norm 2.102487536545e-12
  6184 KSP Residual norm 2.110913034934e-12
  6185 KSP Residual norm 2.181746844626e-12
  6186 KSP Residual norm 2.044764459588e-12
  6187 KSP Residual norm 1.833295079031e-12
  6188 KSP Residual norm 1.728429417596e-12
  6189 KSP Residual norm 1.675857659890e-12
  6190 KSP Residual norm 1.728710098934e-12
  6191 KSP Residual norm 1.820866500974e-12
  6192 KSP Residual norm 1.799562209636e-12
  6193 KSP Residual norm 1.865313072023e-12
  6194 KSP Residual norm 2.091919303233e-12
  6195 KSP Residual norm 2.085196055514e-12
  6196 KSP Residual norm 1.911602742495e-12
  6197 KSP Residual norm 1.991891049311e-12
  6198 KSP Residual norm 2.014341909910e-12
  6199 KSP Residual norm 1.842303803951e-12
  6200 KSP Residual norm 1.784766858316e-12
  6201 KSP Residual norm 1.850213985967e-12
  6202 KSP Residual norm 1.902660457568e-12
  6203 KSP Residual norm 1.918280828462e-12
  6204 KSP Residual norm 2.075256019994e-12
  6205 KSP Residual norm 2.180153393240e-12
  6206 KSP Residual norm 2.011735542863e-12
  6207 KSP Residual norm 1.817782852107e-12
  6208 KSP Residual norm 1.802621297576e-12
  6209 KSP Residual norm 1.756182066397e-12
  6210 KSP Residual norm 1.681826917955e-12
  6211 KSP Residual norm 1.730337808959e-12
  6212 KSP Residual norm 1.938167787927e-12
  6213 KSP Residual norm 2.106872252186e-12
  6214 KSP Residual norm 2.027810660619e-12
  6215 KSP Residual norm 2.014327711251e-12
  6216 KSP Residual norm 2.251505279205e-12
  6217 KSP Residual norm 2.730209526766e-12
  6218 KSP Residual norm 3.068186089681e-12
  6219 KSP Residual norm 3.067585568432e-12
  6220 KSP Residual norm 2.942165843834e-12
  6221 KSP Residual norm 3.013851608775e-12
  6222 KSP Residual norm 3.262819100960e-12
  6223 KSP Residual norm 3.297712466264e-12
  6224 KSP Residual norm 3.277305104978e-12
  6225 KSP Residual norm 3.095325808063e-12
  6226 KSP Residual norm 2.995060338819e-12
  6227 KSP Residual norm 3.125035573952e-12
  6228 KSP Residual norm 3.271712479773e-12
  6229 KSP Residual norm 3.232111472352e-12
  6230 KSP Residual norm 3.562790170085e-12
  6231 KSP Residual norm 4.053249678612e-12
  6232 KSP Residual norm 4.184029236508e-12
  6233 KSP Residual norm 4.489313327367e-12
  6234 KSP Residual norm 5.180520004327e-12
  6235 KSP Residual norm 5.493860412508e-12
  6236 KSP Residual norm 5.211460674639e-12
  6237 KSP Residual norm 5.670669865848e-12
  6238 KSP Residual norm 6.571325540592e-12
  6239 KSP Residual norm 6.680545906921e-12
  6240 KSP Residual norm 6.617866104882e-12
  6241 KSP Residual norm 7.319968714893e-12
  6242 KSP Residual norm 7.198781060890e-12
  6243 KSP Residual norm 6.471457244881e-12
  6244 KSP Residual norm 6.900604874236e-12
  6245 KSP Residual norm 7.851974101375e-12
  6246 KSP Residual norm 7.785422791554e-12
  6247 KSP Residual norm 7.400473646111e-12
  6248 KSP Residual norm 6.966549883938e-12
  6249 KSP Residual norm 6.514984025252e-12
  6250 KSP Residual norm 5.814243427761e-12
  6251 KSP Residual norm 4.999184267309e-12
  6252 KSP Residual norm 4.558221494594e-12
  6253 KSP Residual norm 4.658655238880e-12
  6254 KSP Residual norm 4.895685496820e-12
  6255 KSP Residual norm 4.720887965718e-12
  6256 KSP Residual norm 4.649013130254e-12
  6257 KSP Residual norm 4.669778689014e-12
  6258 KSP Residual norm 4.666232942087e-12
  6259 KSP Residual norm 4.594647450559e-12
  6260 KSP Residual norm 4.240992899628e-12
  6261 KSP Residual norm 3.942221886821e-12
  6262 KSP Residual norm 3.812513113763e-12
  6263 KSP Residual norm 3.707883638356e-12
  6264 KSP Residual norm 3.371223181576e-12
  6265 KSP Residual norm 3.063157676758e-12
  6266 KSP Residual norm 2.624185594915e-12
  6267 KSP Residual norm 2.241011314784e-12
  6268 KSP Residual norm 2.018720914461e-12
  6269 KSP Residual norm 2.123934126088e-12
  6270 KSP Residual norm 2.684106729061e-12
  6271 KSP Residual norm 3.671835614509e-12
  6272 KSP Residual norm 3.554657094596e-12
  6273 KSP Residual norm 2.840277607804e-12
  6274 KSP Residual norm 2.581933305231e-12
  6275 KSP Residual norm 2.586579091349e-12
  6276 KSP Residual norm 2.503879286560e-12
  6277 KSP Residual norm 2.672603757186e-12
  6278 KSP Residual norm 3.077565464311e-12
  6279 KSP Residual norm 3.145567091956e-12
  6280 KSP Residual norm 3.115261729658e-12
  6281 KSP Residual norm 3.104606656148e-12
  6282 KSP Residual norm 2.936699857278e-12
  6283 KSP Residual norm 2.781511640020e-12
  6284 KSP Residual norm 2.557105337908e-12
  6285 KSP Residual norm 2.215311915199e-12
  6286 KSP Residual norm 2.107918059937e-12
  6287 KSP Residual norm 2.114714991963e-12
  6288 KSP Residual norm 2.008220413993e-12
  6289 KSP Residual norm 1.748020696670e-12
  6290 KSP Residual norm 1.529987445798e-12
  6291 KSP Residual norm 1.441564751622e-12
  6292 KSP Residual norm 1.284438217384e-12
  6293 KSP Residual norm 1.117144442717e-12
  6294 KSP Residual norm 9.916070704323e-13
  6295 KSP Residual norm 9.056205542244e-13
  6296 KSP Residual norm 7.809150105465e-13
  6297 KSP Residual norm 7.168072899049e-13
  6298 KSP Residual norm 7.762929198993e-13
  6299 KSP Residual norm 8.195180335768e-13
  6300 KSP Residual norm 7.834255161755e-13
  6301 KSP Residual norm 7.807438983814e-13
  6302 KSP Residual norm 7.917123178801e-13
  6303 KSP Residual norm 7.277486451241e-13
  6304 KSP Residual norm 6.151838727387e-13
  6305 KSP Residual norm 5.577869965085e-13
  6306 KSP Residual norm 5.790906428624e-13
  6307 KSP Residual norm 6.223010835772e-13
  6308 KSP Residual norm 6.309347591521e-13
  6309 KSP Residual norm 6.568806863555e-13
  6310 KSP Residual norm 7.515999655250e-13
  6311 KSP Residual norm 8.523532161536e-13
  6312 KSP Residual norm 9.053249424343e-13
  6313 KSP Residual norm 9.817148629637e-13
  6314 KSP Residual norm 1.121473061125e-12
  6315 KSP Residual norm 1.093016469358e-12
  6316 KSP Residual norm 9.097535270373e-13
  6317 KSP Residual norm 8.383120318295e-13
  6318 KSP Residual norm 9.402598006788e-13
  6319 KSP Residual norm 1.068250438640e-12
  6320 KSP Residual norm 1.159795250130e-12
  6321 KSP Residual norm 1.271584748554e-12
  6322 KSP Residual norm 1.292059809790e-12
  6323 KSP Residual norm 1.081292932737e-12
  6324 KSP Residual norm 9.762291184488e-13
  6325 KSP Residual norm 1.013449263832e-12
  6326 KSP Residual norm 1.042015380517e-12
  6327 KSP Residual norm 9.586958853510e-13
  6328 KSP Residual norm 7.594666934158e-13
  6329 KSP Residual norm 6.020557194235e-13
  6330 KSP Residual norm 5.653239520633e-13
  6331 KSP Residual norm 5.602332284611e-13
  6332 KSP Residual norm 5.234046249674e-13
  6333 KSP Residual norm 4.673555480568e-13
  6334 KSP Residual norm 4.427462804127e-13
  6335 KSP Residual norm 4.758602440865e-13
  6336 KSP Residual norm 5.428242174262e-13
  6337 KSP Residual norm 5.689572956687e-13
  6338 KSP Residual norm 5.511013968087e-13
  6339 KSP Residual norm 5.196579997918e-13
  6340 KSP Residual norm 4.744319745921e-13
  6341 KSP Residual norm 4.559328463109e-13
  6342 KSP Residual norm 4.756682233377e-13
  6343 KSP Residual norm 5.084565971691e-13
  6344 KSP Residual norm 5.548744339238e-13
  6345 KSP Residual norm 5.618392039749e-13
  6346 KSP Residual norm 4.897157572681e-13
  6347 KSP Residual norm 4.733599228276e-13
  6348 KSP Residual norm 5.358004479611e-13
  6349 KSP Residual norm 5.807672245831e-13
  6350 KSP Residual norm 6.267283463161e-13
  6351 KSP Residual norm 7.068616831703e-13
  6352 KSP Residual norm 7.125565536086e-13
  6353 KSP Residual norm 6.542396668676e-13
  6354 KSP Residual norm 6.639017377710e-13
  6355 KSP Residual norm 7.279799680717e-13
  6356 KSP Residual norm 7.955914472743e-13
  6357 KSP Residual norm 9.463652106966e-13
  6358 KSP Residual norm 1.124980304968e-12
  6359 KSP Residual norm 1.140173637744e-12
  6360 KSP Residual norm 1.192523160707e-12
  6361 KSP Residual norm 1.406926275097e-12
  6362 KSP Residual norm 1.528851459775e-12
  6363 KSP Residual norm 1.393997842856e-12
  6364 KSP Residual norm 1.096311988706e-12
  6365 KSP Residual norm 8.667405174648e-13
  6366 KSP Residual norm 7.225605491059e-13
  6367 KSP Residual norm 7.068699425585e-13
  6368 KSP Residual norm 7.622841624712e-13
  6369 KSP Residual norm 7.947744749370e-13
  6370 KSP Residual norm 6.709019339944e-13
  6371 KSP Residual norm 5.665480800689e-13
  6372 KSP Residual norm 5.789669305618e-13
  6373 KSP Residual norm 6.212472187691e-13
  6374 KSP Residual norm 6.767974725556e-13
  6375 KSP Residual norm 7.807467334895e-13
  6376 KSP Residual norm 8.100080679159e-13
  6377 KSP Residual norm 7.155650767157e-13
  6378 KSP Residual norm 6.243222327082e-13
  6379 KSP Residual norm 5.977812769521e-13
  6380 KSP Residual norm 6.700597387918e-13
  6381 KSP Residual norm 7.753564296866e-13
  6382 KSP Residual norm 8.341892750895e-13
  6383 KSP Residual norm 8.589126668977e-13
  6384 KSP Residual norm 8.882707937719e-13
  6385 KSP Residual norm 8.769363290395e-13
  6386 KSP Residual norm 8.347345346401e-13
  6387 KSP Residual norm 8.250014613191e-13
  6388 KSP Residual norm 8.588647714335e-13
  6389 KSP Residual norm 8.545911149212e-13
  6390 KSP Residual norm 8.763448697152e-13
  6391 KSP Residual norm 1.021634323004e-12
  6392 KSP Residual norm 1.394587682409e-12
  6393 KSP Residual norm 1.634491798537e-12
  6394 KSP Residual norm 1.425597165333e-12
  6395 KSP Residual norm 1.185665994278e-12
  6396 KSP Residual norm 1.046999623761e-12
  6397 KSP Residual norm 9.600698652348e-13
  6398 KSP Residual norm 9.548127101086e-13
  6399 KSP Residual norm 9.899760258211e-13
  6400 KSP Residual norm 1.086659755166e-12
  6401 KSP Residual norm 1.246289542969e-12
  6402 KSP Residual norm 1.186252539340e-12
  6403 KSP Residual norm 9.780182297002e-13
  6404 KSP Residual norm 9.463228380148e-13
  6405 KSP Residual norm 1.062570697470e-12
  6406 KSP Residual norm 9.443430454097e-13
  6407 KSP Residual norm 8.282469251560e-13
  6408 KSP Residual norm 9.860488851893e-13
  6409 KSP Residual norm 1.363816838120e-12
  6410 KSP Residual norm 1.362773207068e-12
  6411 KSP Residual norm 1.132067821407e-12
  6412 KSP Residual norm 9.989886970451e-13
  6413 KSP Residual norm 9.085876052131e-13
  6414 KSP Residual norm 8.227808018468e-13
  6415 KSP Residual norm 8.665184525798e-13
  6416 KSP Residual norm 1.033077750628e-12
  6417 KSP Residual norm 1.076161629339e-12
  6418 KSP Residual norm 9.367531933098e-13
  6419 KSP Residual norm 8.410380502892e-13
  6420 KSP Residual norm 7.738282504364e-13
  6421 KSP Residual norm 7.525560277724e-13
  6422 KSP Residual norm 8.059057394671e-13
  6423 KSP Residual norm 8.963457205953e-13
  6424 KSP Residual norm 1.008987375659e-12
  6425 KSP Residual norm 1.005752960340e-12
  6426 KSP Residual norm 9.981161831966e-13
  6427 KSP Residual norm 1.125960719128e-12
  6428 KSP Residual norm 1.363044308332e-12
  6429 KSP Residual norm 1.547849827979e-12
  6430 KSP Residual norm 1.590056441708e-12
  6431 KSP Residual norm 1.443414917110e-12
  6432 KSP Residual norm 1.206663743892e-12
  6433 KSP Residual norm 1.016125485204e-12
  6434 KSP Residual norm 9.521505304236e-13
  6435 KSP Residual norm 9.685272411580e-13
  6436 KSP Residual norm 1.047476802415e-12
  6437 KSP Residual norm 1.101205733541e-12
  6438 KSP Residual norm 1.140173464985e-12
  6439 KSP Residual norm 1.175108214282e-12
  6440 KSP Residual norm 1.175200665289e-12
  6441 KSP Residual norm 1.144406494104e-12
  6442 KSP Residual norm 1.053480276899e-12
  6443 KSP Residual norm 8.372945929723e-13
  6444 KSP Residual norm 6.877957005424e-13
  6445 KSP Residual norm 7.328422707942e-13
  6446 KSP Residual norm 9.191290004538e-13
  6447 KSP Residual norm 1.056028352808e-12
  6448 KSP Residual norm 1.113884450382e-12
  6449 KSP Residual norm 1.099985992084e-12
  6450 KSP Residual norm 1.026390137518e-12
  6451 KSP Residual norm 9.383772309035e-13
  6452 KSP Residual norm 8.254587136243e-13
  6453 KSP Residual norm 7.684109253375e-13
  6454 KSP Residual norm 7.840043811932e-13
  6455 KSP Residual norm 7.605067860639e-13
  6456 KSP Residual norm 6.375053299062e-13
  6457 KSP Residual norm 5.720584688426e-13
  6458 KSP Residual norm 5.819583740939e-13
  6459 KSP Residual norm 6.970077599502e-13
  6460 KSP Residual norm 8.146164807450e-13
  6461 KSP Residual norm 7.840968520698e-13
  6462 KSP Residual norm 7.313909076841e-13
  6463 KSP Residual norm 6.884428796987e-13
  6464 KSP Residual norm 6.133082750850e-13
  6465 KSP Residual norm 5.872898587243e-13
  6466 KSP Residual norm 7.039452047563e-13
  6467 KSP Residual norm 9.472517208189e-13
  6468 KSP Residual norm 1.103920049717e-12
  6469 KSP Residual norm 1.002253279924e-12
  6470 KSP Residual norm 9.144381228149e-13
  6471 KSP Residual norm 9.710865303757e-13
  6472 KSP Residual norm 1.038156679645e-12
  6473 KSP Residual norm 9.183425749076e-13
  6474 KSP Residual norm 7.983579890790e-13
  6475 KSP Residual norm 7.448583054290e-13
  6476 KSP Residual norm 7.280638001547e-13
  6477 KSP Residual norm 7.713638889727e-13
  6478 KSP Residual norm 8.949475625926e-13
  6479 KSP Residual norm 1.030367246282e-12
  6480 KSP Residual norm 9.641833973230e-13
  6481 KSP Residual norm 8.238596558642e-13
  6482 KSP Residual norm 8.513162407286e-13
  6483 KSP Residual norm 9.318635602426e-13
  6484 KSP Residual norm 9.027987666300e-13
  6485 KSP Residual norm 8.766379021197e-13
  6486 KSP Residual norm 8.428842142648e-13
  6487 KSP Residual norm 7.130591730843e-13
  6488 KSP Residual norm 5.600039060888e-13
  6489 KSP Residual norm 4.878621484431e-13
  6490 KSP Residual norm 4.851391550004e-13
  6491 KSP Residual norm 5.153845663974e-13
  6492 KSP Residual norm 5.505370420567e-13
  6493 KSP Residual norm 5.375826294780e-13
  6494 KSP Residual norm 5.147598298374e-13
  6495 KSP Residual norm 4.722226249848e-13
  6496 KSP Residual norm 4.182172213001e-13
  6497 KSP Residual norm 4.011326144195e-13
  6498 KSP Residual norm 4.105582673283e-13
  6499 KSP Residual norm 4.024558565460e-13
  6500 KSP Residual norm 3.674000146833e-13
  6501 KSP Residual norm 3.247280410545e-13
  6502 KSP Residual norm 3.008861435751e-13
  6503 KSP Residual norm 3.224842510274e-13
  6504 KSP Residual norm 3.622190072354e-13
  6505 KSP Residual norm 3.678724219604e-13
  6506 KSP Residual norm 3.744597313217e-13
  6507 KSP Residual norm 3.856537043005e-13
  6508 KSP Residual norm 3.356823288465e-13
  6509 KSP Residual norm 2.855075831533e-13
  6510 KSP Residual norm 2.828046257568e-13
  6511 KSP Residual norm 2.877164120038e-13
  6512 KSP Residual norm 3.003698469051e-13
  6513 KSP Residual norm 3.198786493560e-13
  6514 KSP Residual norm 3.287902163109e-13
  6515 KSP Residual norm 2.977349497977e-13
  6516 KSP Residual norm 2.526671606065e-13
  6517 KSP Residual norm 2.354020238555e-13
  6518 KSP Residual norm 2.411502884992e-13
  6519 KSP Residual norm 2.685515266370e-13
  6520 KSP Residual norm 3.261003366865e-13
  6521 KSP Residual norm 4.177763629349e-13
  6522 KSP Residual norm 4.879002525861e-13
  6523 KSP Residual norm 5.044327011168e-13
  6524 KSP Residual norm 4.927734830947e-13
  6525 KSP Residual norm 4.361576637241e-13
  6526 KSP Residual norm 4.036562642627e-13
  6527 KSP Residual norm 4.104964986397e-13
  6528 KSP Residual norm 4.360189662553e-13
  6529 KSP Residual norm 4.610660841185e-13
  6530 KSP Residual norm 5.314630782206e-13
  6531 KSP Residual norm 6.877436578038e-13
  6532 KSP Residual norm 9.142930047915e-13
  6533 KSP Residual norm 1.080826068695e-12
  6534 KSP Residual norm 1.042457200628e-12
  6535 KSP Residual norm 8.827117573815e-13
  6536 KSP Residual norm 6.595201047066e-13
  6537 KSP Residual norm 4.600406163755e-13
  6538 KSP Residual norm 3.386670368995e-13
  6539 KSP Residual norm 3.182479067427e-13
  6540 KSP Residual norm 3.807679142454e-13
  6541 KSP Residual norm 4.934242815615e-13
  6542 KSP Residual norm 6.028675161283e-13
  6543 KSP Residual norm 6.974997781850e-13
  6544 KSP Residual norm 7.359624357539e-13
  6545 KSP Residual norm 6.475720922805e-13
  6546 KSP Residual norm 5.102620020504e-13
  6547 KSP Residual norm 4.266719256571e-13
  6548 KSP Residual norm 3.422166375003e-13
  6549 KSP Residual norm 2.797064119836e-13
  6550 KSP Residual norm 2.766789598794e-13
  6551 KSP Residual norm 3.286814382996e-13
  6552 KSP Residual norm 4.162568204089e-13
  6553 KSP Residual norm 4.561556347996e-13
  6554 KSP Residual norm 4.619614689035e-13
  6555 KSP Residual norm 4.896745900075e-13
  6556 KSP Residual norm 5.495681564647e-13
  6557 KSP Residual norm 6.271703801311e-13
  6558 KSP Residual norm 7.378873395045e-13
  6559 KSP Residual norm 8.296429573313e-13
  6560 KSP Residual norm 7.696862835047e-13
  6561 KSP Residual norm 5.792630249001e-13
  6562 KSP Residual norm 4.613083715098e-13
  6563 KSP Residual norm 4.390007103729e-13
  6564 KSP Residual norm 4.482232070880e-13
  6565 KSP Residual norm 4.798351367413e-13
  6566 KSP Residual norm 5.403470179746e-13
  6567 KSP Residual norm 6.697664665234e-13
  6568 KSP Residual norm 8.835575898900e-13
  6569 KSP Residual norm 1.063937635791e-12
  6570 KSP Residual norm 1.078527041804e-12
  6571 KSP Residual norm 9.524496535539e-13
  6572 KSP Residual norm 8.842097498448e-13
  6573 KSP Residual norm 9.356392066022e-13
  6574 KSP Residual norm 9.743335169204e-13
  6575 KSP Residual norm 1.097171237261e-12
  6576 KSP Residual norm 1.452136456759e-12
  6577 KSP Residual norm 1.836411562309e-12
  6578 KSP Residual norm 1.578050690762e-12
  6579 KSP Residual norm 1.137252402985e-12
  6580 KSP Residual norm 8.379221837655e-13
  6581 KSP Residual norm 7.017385201683e-13
  6582 KSP Residual norm 7.302033682482e-13
  6583 KSP Residual norm 9.213382353717e-13
  6584 KSP Residual norm 1.164263146552e-12
  6585 KSP Residual norm 1.126290050475e-12
  6586 KSP Residual norm 1.000200867909e-12
  6587 KSP Residual norm 8.927582963779e-13
  6588 KSP Residual norm 8.174199473761e-13
  6589 KSP Residual norm 7.732828262029e-13
  6590 KSP Residual norm 7.310345391212e-13
  6591 KSP Residual norm 6.222410657803e-13
  6592 KSP Residual norm 4.737492520057e-13
  6593 KSP Residual norm 3.651477628465e-13
  6594 KSP Residual norm 3.113533210874e-13
  6595 KSP Residual norm 2.990720485877e-13
  6596 KSP Residual norm 3.378256928243e-13
  6597 KSP Residual norm 4.088597380339e-13
  6598 KSP Residual norm 4.510668270378e-13
  6599 KSP Residual norm 4.373613862822e-13
  6600 KSP Residual norm 4.093082920924e-13
  6601 KSP Residual norm 3.617110443379e-13
  6602 KSP Residual norm 2.844255958998e-13
  6603 KSP Residual norm 2.290989820966e-13
  6604 KSP Residual norm 2.076026123199e-13
  6605 KSP Residual norm 2.161045101119e-13
  6606 KSP Residual norm 2.361637693074e-13
  6607 KSP Residual norm 2.579896401181e-13
  6608 KSP Residual norm 2.743682103811e-13
  6609 KSP Residual norm 3.040949407432e-13
  6610 KSP Residual norm 3.288917527683e-13
  6611 KSP Residual norm 3.256842494228e-13
  6612 KSP Residual norm 3.037357121850e-13
  6613 KSP Residual norm 3.121659584915e-13
  6614 KSP Residual norm 4.065255411212e-13
  6615 KSP Residual norm 5.654336378386e-13
  6616 KSP Residual norm 6.900607696494e-13
  6617 KSP Residual norm 6.783973834697e-13
  6618 KSP Residual norm 5.172974731742e-13
  6619 KSP Residual norm 3.878880423231e-13
  6620 KSP Residual norm 3.586488652329e-13
  6621 KSP Residual norm 3.855970560752e-13
  6622 KSP Residual norm 4.262320183105e-13
  6623 KSP Residual norm 5.202675717976e-13
  6624 KSP Residual norm 6.295011119428e-13
  6625 KSP Residual norm 6.145666766096e-13
  6626 KSP Residual norm 6.203803498048e-13
  6627 KSP Residual norm 6.862556191082e-13
  6628 KSP Residual norm 7.651167830911e-13
  6629 KSP Residual norm 7.827133005217e-13
  6630 KSP Residual norm 7.704958444141e-13
  6631 KSP Residual norm 7.313174273393e-13
  6632 KSP Residual norm 7.040307346723e-13
  6633 KSP Residual norm 6.828907476161e-13
  6634 KSP Residual norm 6.744319019889e-13
  6635 KSP Residual norm 7.346602627366e-13
  6636 KSP Residual norm 9.187603629288e-13
  6637 KSP Residual norm 1.140706457226e-12
  6638 KSP Residual norm 1.198058829936e-12
  6639 KSP Residual norm 1.102100695344e-12
  6640 KSP Residual norm 9.365664260138e-13
  6641 KSP Residual norm 7.798411895426e-13
  6642 KSP Residual norm 7.316860534007e-13
  6643 KSP Residual norm 7.876594834112e-13
  6644 KSP Residual norm 8.822100743832e-13
  6645 KSP Residual norm 9.569760896950e-13
  6646 KSP Residual norm 9.972754753137e-13
  6647 KSP Residual norm 1.109915104315e-12
  6648 KSP Residual norm 1.267391027131e-12
  6649 KSP Residual norm 1.309623324107e-12
  6650 KSP Residual norm 1.294344866017e-12
  6651 KSP Residual norm 1.209052715194e-12
  6652 KSP Residual norm 1.108208370955e-12
  6653 KSP Residual norm 1.072686546176e-12
  6654 KSP Residual norm 1.107329690212e-12
  6655 KSP Residual norm 1.126894356092e-12
  6656 KSP Residual norm 1.042029176145e-12
  6657 KSP Residual norm 8.803391422863e-13
  6658 KSP Residual norm 8.248986017820e-13
  6659 KSP Residual norm 9.018498159244e-13
  6660 KSP Residual norm 1.072713612134e-12
  6661 KSP Residual norm 1.229907217576e-12
  6662 KSP Residual norm 1.284712127034e-12
  6663 KSP Residual norm 1.270342512862e-12
  6664 KSP Residual norm 1.229253152846e-12
  6665 KSP Residual norm 1.302788269181e-12
  6666 KSP Residual norm 1.627834245443e-12
  6667 KSP Residual norm 2.007610420521e-12
  6668 KSP Residual norm 2.059275376221e-12
  6669 KSP Residual norm 2.042349254666e-12
  6670 KSP Residual norm 2.143667995538e-12
  6671 KSP Residual norm 2.253022942359e-12
  6672 KSP Residual norm 2.346643143085e-12
  6673 KSP Residual norm 2.250493252518e-12
  6674 KSP Residual norm 1.934854033751e-12
  6675 KSP Residual norm 1.669760067203e-12
  6676 KSP Residual norm 1.586511107984e-12
  6677 KSP Residual norm 1.596071130563e-12
  6678 KSP Residual norm 1.896431639487e-12
  6679 KSP Residual norm 2.557094673539e-12
  6680 KSP Residual norm 3.635820534181e-12
  6681 KSP Residual norm 4.792115395804e-12
  6682 KSP Residual norm 5.463865751447e-12
  6683 KSP Residual norm 5.010915219993e-12
  6684 KSP Residual norm 4.000703001443e-12
  6685 KSP Residual norm 3.191506823819e-12
  6686 KSP Residual norm 2.805711906450e-12
  6687 KSP Residual norm 2.475234517921e-12
  6688 KSP Residual norm 2.425721455161e-12
  6689 KSP Residual norm 2.642491983402e-12
  6690 KSP Residual norm 2.850932201153e-12
  6691 KSP Residual norm 3.081503832868e-12
  6692 KSP Residual norm 3.397458039473e-12
  6693 KSP Residual norm 3.544049307671e-12
  6694 KSP Residual norm 3.776607961328e-12
  6695 KSP Residual norm 3.907305702869e-12
  6696 KSP Residual norm 3.483379184542e-12
  6697 KSP Residual norm 2.909427783970e-12
  6698 KSP Residual norm 2.535335182250e-12
  6699 KSP Residual norm 2.297012048417e-12
  6700 KSP Residual norm 2.184957556587e-12
  6701 KSP Residual norm 2.250290216470e-12
  6702 KSP Residual norm 2.500972610035e-12
  6703 KSP Residual norm 2.712785646125e-12
  6704 KSP Residual norm 2.530919006036e-12
  6705 KSP Residual norm 2.081793467089e-12
  6706 KSP Residual norm 1.959873501014e-12
  6707 KSP Residual norm 2.220967803355e-12
  6708 KSP Residual norm 2.641333945361e-12
  6709 KSP Residual norm 2.988694603992e-12
  6710 KSP Residual norm 3.295762703372e-12
  6711 KSP Residual norm 3.442642759726e-12
  6712 KSP Residual norm 3.597448738030e-12
  6713 KSP Residual norm 3.726038032633e-12
  6714 KSP Residual norm 3.829975672105e-12
  6715 KSP Residual norm 3.893047435795e-12
  6716 KSP Residual norm 3.697809959528e-12
  6717 KSP Residual norm 3.465977770416e-12
  6718 KSP Residual norm 3.179275571634e-12
  6719 KSP Residual norm 2.650045772893e-12
  6720 KSP Residual norm 2.433091102376e-12
  6721 KSP Residual norm 2.519663096190e-12
  6722 KSP Residual norm 3.013835119829e-12
  6723 KSP Residual norm 3.683083118870e-12
  6724 KSP Residual norm 4.087305151230e-12
  6725 KSP Residual norm 4.425327567919e-12
  6726 KSP Residual norm 5.157898365103e-12
  6727 KSP Residual norm 6.007224667260e-12
  6728 KSP Residual norm 6.614956713829e-12
  6729 KSP Residual norm 7.302102837926e-12
  6730 KSP Residual norm 7.789665323726e-12
  6731 KSP Residual norm 6.948871605606e-12
  6732 KSP Residual norm 6.563157782671e-12
  6733 KSP Residual norm 6.886027118364e-12
  6734 KSP Residual norm 6.816973511304e-12
  6735 KSP Residual norm 6.572845014578e-12
  6736 KSP Residual norm 6.366154263601e-12
  6737 KSP Residual norm 6.429508620284e-12
  6738 KSP Residual norm 7.097459241675e-12
  6739 KSP Residual norm 7.346701919450e-12
  6740 KSP Residual norm 7.490457040818e-12
  6741 KSP Residual norm 8.244431245747e-12
  6742 KSP Residual norm 8.538900652641e-12
  6743 KSP Residual norm 8.311030252970e-12
  6744 KSP Residual norm 8.315296227534e-12
  6745 KSP Residual norm 8.532891435907e-12
  6746 KSP Residual norm 8.070577559116e-12
  6747 KSP Residual norm 6.783000664127e-12
  6748 KSP Residual norm 6.120856571810e-12
  6749 KSP Residual norm 6.019677791326e-12
  6750 KSP Residual norm 5.765586191732e-12
  6751 KSP Residual norm 5.279442498847e-12
  6752 KSP Residual norm 5.092327783711e-12
  6753 KSP Residual norm 4.768228630125e-12
  6754 KSP Residual norm 4.227146082819e-12
  6755 KSP Residual norm 3.888790806712e-12
  6756 KSP Residual norm 4.192605826988e-12
  6757 KSP Residual norm 4.956659514932e-12
  6758 KSP Residual norm 5.262628057482e-12
  6759 KSP Residual norm 5.274008196949e-12
  6760 KSP Residual norm 4.995090032872e-12
  6761 KSP Residual norm 4.966339973344e-12
  6762 KSP Residual norm 5.028283076912e-12
  6763 KSP Residual norm 4.666113309143e-12
  6764 KSP Residual norm 4.000312692917e-12
  6765 KSP Residual norm 3.397105470345e-12
  6766 KSP Residual norm 3.166445759287e-12
  6767 KSP Residual norm 2.984707421220e-12
  6768 KSP Residual norm 2.618189360368e-12
  6769 KSP Residual norm 2.286663038463e-12
  6770 KSP Residual norm 2.135727644816e-12
  6771 KSP Residual norm 2.066660961143e-12
  6772 KSP Residual norm 2.252697087523e-12
  6773 KSP Residual norm 2.595520796802e-12
  6774 KSP Residual norm 2.693006405583e-12
  6775 KSP Residual norm 2.875455087755e-12
  6776 KSP Residual norm 3.476980351304e-12
  6777 KSP Residual norm 4.141638145123e-12
  6778 KSP Residual norm 4.471320664747e-12
  6779 KSP Residual norm 4.675833549447e-12
  6780 KSP Residual norm 4.512568113425e-12
  6781 KSP Residual norm 4.381923896052e-12
  6782 KSP Residual norm 4.461488673271e-12
  6783 KSP Residual norm 4.033594006620e-12
  6784 KSP Residual norm 3.507444418065e-12
  6785 KSP Residual norm 3.247448173539e-12
  6786 KSP Residual norm 2.987499785184e-12
  6787 KSP Residual norm 2.870263239097e-12
  6788 KSP Residual norm 3.110754727187e-12
  6789 KSP Residual norm 3.492882145730e-12
  6790 KSP Residual norm 3.770858558975e-12
  6791 KSP Residual norm 3.644470641028e-12
  6792 KSP Residual norm 3.474281816039e-12
  6793 KSP Residual norm 3.846291561483e-12
  6794 KSP Residual norm 4.349675279076e-12
  6795 KSP Residual norm 4.466635975265e-12
  6796 KSP Residual norm 4.288879935822e-12
  6797 KSP Residual norm 4.301271163204e-12
  6798 KSP Residual norm 4.584571307192e-12
  6799 KSP Residual norm 5.000584616832e-12
  6800 KSP Residual norm 4.882610574317e-12
  6801 KSP Residual norm 4.183410376837e-12
  6802 KSP Residual norm 3.582406754238e-12
  6803 KSP Residual norm 3.138842145634e-12
  6804 KSP Residual norm 2.926785294218e-12
  6805 KSP Residual norm 2.975677303620e-12
  6806 KSP Residual norm 2.969522916598e-12
  6807 KSP Residual norm 2.648506588978e-12
  6808 KSP Residual norm 2.279908159189e-12
  6809 KSP Residual norm 2.262444484701e-12
  6810 KSP Residual norm 2.492023204960e-12
  6811 KSP Residual norm 2.720059522904e-12
  6812 KSP Residual norm 2.842688573383e-12
  6813 KSP Residual norm 2.885646562178e-12
  6814 KSP Residual norm 2.870494081064e-12
  6815 KSP Residual norm 2.744809366888e-12
  6816 KSP Residual norm 2.638894493964e-12
  6817 KSP Residual norm 2.514559211643e-12
  6818 KSP Residual norm 2.278216729505e-12
  6819 KSP Residual norm 2.000517422179e-12
  6820 KSP Residual norm 1.918608446299e-12
  6821 KSP Residual norm 2.038083474699e-12
  6822 KSP Residual norm 1.946074090701e-12
  6823 KSP Residual norm 1.767419452285e-12
  6824 KSP Residual norm 1.763753483081e-12
  6825 KSP Residual norm 1.842595387719e-12
  6826 KSP Residual norm 1.794343878318e-12
  6827 KSP Residual norm 1.707171858242e-12
  6828 KSP Residual norm 1.705001040245e-12
  6829 KSP Residual norm 1.756531509474e-12
  6830 KSP Residual norm 1.919331131540e-12
  6831 KSP Residual norm 2.067180228684e-12
  6832 KSP Residual norm 2.033086811392e-12
  6833 KSP Residual norm 1.952445094046e-12
  6834 KSP Residual norm 1.915437061235e-12
  6835 KSP Residual norm 2.009394860665e-12
  6836 KSP Residual norm 2.127948288575e-12
  6837 KSP Residual norm 2.297454328637e-12
  6838 KSP Residual norm 2.358333456749e-12
  6839 KSP Residual norm 2.284418551198e-12
  6840 KSP Residual norm 2.416958042910e-12
  6841 KSP Residual norm 2.873774672260e-12
  6842 KSP Residual norm 3.166301284399e-12
  6843 KSP Residual norm 3.142599645332e-12
  6844 KSP Residual norm 2.906341804050e-12
  6845 KSP Residual norm 2.523073353938e-12
  6846 KSP Residual norm 2.332514882419e-12
  6847 KSP Residual norm 2.682155856643e-12
  6848 KSP Residual norm 3.387958894812e-12
  6849 KSP Residual norm 3.835468017579e-12
  6850 KSP Residual norm 4.072656400841e-12
  6851 KSP Residual norm 4.320328816913e-12
  6852 KSP Residual norm 4.572184719910e-12
  6853 KSP Residual norm 4.599859216593e-12
  6854 KSP Residual norm 4.550733493374e-12
  6855 KSP Residual norm 4.569125362196e-12
  6856 KSP Residual norm 5.205900298423e-12
  6857 KSP Residual norm 5.933544778426e-12
  6858 KSP Residual norm 6.084600128220e-12
  6859 KSP Residual norm 6.344742035839e-12
  6860 KSP Residual norm 6.726064421953e-12
  6861 KSP Residual norm 6.570584548932e-12
  6862 KSP Residual norm 6.527306885992e-12
  6863 KSP Residual norm 7.534145025894e-12
  6864 KSP Residual norm 8.278765439859e-12
  6865 KSP Residual norm 7.701415783246e-12
  6866 KSP Residual norm 6.513292061436e-12
  6867 KSP Residual norm 5.712122651076e-12
  6868 KSP Residual norm 5.254426175940e-12
  6869 KSP Residual norm 4.913615475932e-12
  6870 KSP Residual norm 4.655217368739e-12
  6871 KSP Residual norm 4.241178432908e-12
  6872 KSP Residual norm 3.843185652965e-12
  6873 KSP Residual norm 3.600928984111e-12
  6874 KSP Residual norm 3.641255064764e-12
  6875 KSP Residual norm 4.239415493699e-12
  6876 KSP Residual norm 5.286075784059e-12
  6877 KSP Residual norm 5.245108995457e-12
  6878 KSP Residual norm 5.182739174215e-12
  6879 KSP Residual norm 6.040336184419e-12
  6880 KSP Residual norm 6.407493887773e-12
  6881 KSP Residual norm 5.537446088928e-12
  6882 KSP Residual norm 4.655263947201e-12
  6883 KSP Residual norm 4.243937162935e-12
  6884 KSP Residual norm 4.193807422692e-12
  6885 KSP Residual norm 4.471323951692e-12
  6886 KSP Residual norm 4.248105257139e-12
  6887 KSP Residual norm 4.106483179768e-12
  6888 KSP Residual norm 4.174373199344e-12
  6889 KSP Residual norm 4.393914527713e-12
  6890 KSP Residual norm 4.887328023707e-12
  6891 KSP Residual norm 5.709495798651e-12
  6892 KSP Residual norm 6.038726266706e-12
  6893 KSP Residual norm 6.205798811600e-12
  6894 KSP Residual norm 6.346446397738e-12
  6895 KSP Residual norm 6.636311024786e-12
  6896 KSP Residual norm 7.422108065695e-12
  6897 KSP Residual norm 7.507655532004e-12
  6898 KSP Residual norm 7.082322399911e-12
  6899 KSP Residual norm 6.907587608139e-12
  6900 KSP Residual norm 7.097662150478e-12
  6901 KSP Residual norm 7.275953409506e-12
  6902 KSP Residual norm 8.153618258884e-12
  6903 KSP Residual norm 8.844139575425e-12
  6904 KSP Residual norm 8.307390695692e-12
  6905 KSP Residual norm 7.924809710063e-12
  6906 KSP Residual norm 8.426707708131e-12
  6907 KSP Residual norm 9.433530067087e-12
  6908 KSP Residual norm 1.023697674155e-11
  6909 KSP Residual norm 1.108350910484e-11
  6910 KSP Residual norm 1.262590407739e-11
  6911 KSP Residual norm 1.404683365935e-11
  6912 KSP Residual norm 1.433449236084e-11
  6913 KSP Residual norm 1.511918007225e-11
  6914 KSP Residual norm 1.490760062646e-11
  6915 KSP Residual norm 1.406181169382e-11
  6916 KSP Residual norm 1.369437981601e-11
  6917 KSP Residual norm 1.302727425189e-11
  6918 KSP Residual norm 1.215540945047e-11
  6919 KSP Residual norm 1.155715967507e-11
  6920 KSP Residual norm 1.146436888779e-11
  6921 KSP Residual norm 1.159608398023e-11
  6922 KSP Residual norm 1.198329818039e-11
  6923 KSP Residual norm 1.107630012964e-11
  6924 KSP Residual norm 1.002213988123e-11
  6925 KSP Residual norm 1.120885784978e-11
  6926 KSP Residual norm 1.331241705900e-11
  6927 KSP Residual norm 1.394011301280e-11
  6928 KSP Residual norm 1.385162413737e-11
  6929 KSP Residual norm 1.236194014564e-11
  6930 KSP Residual norm 1.170976843280e-11
  6931 KSP Residual norm 1.192831716472e-11
  6932 KSP Residual norm 1.094762860562e-11
  6933 KSP Residual norm 9.391710207169e-12
  6934 KSP Residual norm 9.044686804153e-12
  6935 KSP Residual norm 9.765150666316e-12
  6936 KSP Residual norm 1.053842369839e-11
  6937 KSP Residual norm 1.074524950098e-11
  6938 KSP Residual norm 9.884005904600e-12
  6939 KSP Residual norm 9.162878529825e-12
  6940 KSP Residual norm 9.672984712188e-12
  6941 KSP Residual norm 1.065461439704e-11
  6942 KSP Residual norm 1.119403746990e-11
  6943 KSP Residual norm 1.128326618488e-11
  6944 KSP Residual norm 1.089192386356e-11
  6945 KSP Residual norm 1.033026795511e-11
  6946 KSP Residual norm 1.037116488298e-11
  6947 KSP Residual norm 1.070730054145e-11
  6948 KSP Residual norm 9.721744760991e-12
  6949 KSP Residual norm 8.296659564762e-12
  6950 KSP Residual norm 7.796660191774e-12
  6951 KSP Residual norm 7.957803318852e-12
  6952 KSP Residual norm 8.174238537445e-12
  6953 KSP Residual norm 8.407697409445e-12
  6954 KSP Residual norm 9.286737324110e-12
  6955 KSP Residual norm 1.094081766513e-11
  6956 KSP Residual norm 1.179741758483e-11
  6957 KSP Residual norm 1.208412714547e-11
  6958 KSP Residual norm 1.284070538421e-11
  6959 KSP Residual norm 1.366870188158e-11
  6960 KSP Residual norm 1.347488289960e-11
  6961 KSP Residual norm 1.138255467547e-11
  6962 KSP Residual norm 9.421920058334e-12
  6963 KSP Residual norm 8.417881360899e-12
  6964 KSP Residual norm 7.922529871623e-12
  6965 KSP Residual norm 7.603592866078e-12
  6966 KSP Residual norm 7.296963747639e-12
  6967 KSP Residual norm 6.949609125989e-12
  6968 KSP Residual norm 6.602856648073e-12
  6969 KSP Residual norm 6.497717105927e-12
  6970 KSP Residual norm 6.770441161655e-12
  6971 KSP Residual norm 7.146269065070e-12
  6972 KSP Residual norm 7.184791529467e-12
  6973 KSP Residual norm 6.493264136193e-12
  6974 KSP Residual norm 5.991693535170e-12
  6975 KSP Residual norm 5.876724088225e-12
  6976 KSP Residual norm 5.886189495963e-12
  6977 KSP Residual norm 5.813119909746e-12
  6978 KSP Residual norm 5.483657482707e-12
  6979 KSP Residual norm 4.936402987922e-12
  6980 KSP Residual norm 4.759014535329e-12
  6981 KSP Residual norm 4.502716214163e-12
  6982 KSP Residual norm 3.945338822463e-12
  6983 KSP Residual norm 3.498067001642e-12
  6984 KSP Residual norm 3.038218196034e-12
  6985 KSP Residual norm 3.008863069367e-12
  6986 KSP Residual norm 3.321640059513e-12
  6987 KSP Residual norm 3.219702342180e-12
  6988 KSP Residual norm 2.597186179697e-12
  6989 KSP Residual norm 2.469317362025e-12
  6990 KSP Residual norm 2.490759644632e-12
  6991 KSP Residual norm 2.402303703581e-12
  6992 KSP Residual norm 2.350401612266e-12
  6993 KSP Residual norm 2.472453915649e-12
  6994 KSP Residual norm 2.523310846527e-12
  6995 KSP Residual norm 2.400209452250e-12
  6996 KSP Residual norm 2.184712538329e-12
  6997 KSP Residual norm 2.151650988985e-12
  6998 KSP Residual norm 2.116301852718e-12
  6999 KSP Residual norm 1.864050214750e-12
  7000 KSP Residual norm 1.535524507776e-12
  7001 KSP Residual norm 1.399027926282e-12
  7002 KSP Residual norm 1.578869154872e-12
  7003 KSP Residual norm 1.961505698592e-12
  7004 KSP Residual norm 2.097384762413e-12
  7005 KSP Residual norm 1.923746127837e-12
  7006 KSP Residual norm 1.856267501503e-12
  7007 KSP Residual norm 1.995845396381e-12
  7008 KSP Residual norm 2.174762577296e-12
  7009 KSP Residual norm 2.221582744604e-12
  7010 KSP Residual norm 2.061657069688e-12
  7011 KSP Residual norm 1.847725234425e-12
  7012 KSP Residual norm 1.747438945698e-12
  7013 KSP Residual norm 1.781454984069e-12
  7014 KSP Residual norm 1.571980382032e-12
  7015 KSP Residual norm 1.200117935589e-12
  7016 KSP Residual norm 1.039595574044e-12
  7017 KSP Residual norm 1.033852522377e-12
  7018 KSP Residual norm 1.030281702312e-12
  7019 KSP Residual norm 1.008994586326e-12
  7020 KSP Residual norm 1.010640783301e-12
  7021 KSP Residual norm 1.036421930723e-12
  7022 KSP Residual norm 1.144585794192e-12
  7023 KSP Residual norm 1.426929066878e-12
  7024 KSP Residual norm 1.678278995460e-12
  7025 KSP Residual norm 1.768945326915e-12
  7026 KSP Residual norm 1.709917772409e-12
  7027 KSP Residual norm 1.778480185091e-12
  7028 KSP Residual norm 1.920637763728e-12
  7029 KSP Residual norm 2.197831742127e-12
  7030 KSP Residual norm 2.528467908382e-12
  7031 KSP Residual norm 2.669652518637e-12
  7032 KSP Residual norm 2.892180862528e-12
  7033 KSP Residual norm 3.602717990522e-12
  7034 KSP Residual norm 4.084516269648e-12
  7035 KSP Residual norm 3.967296524216e-12
  7036 KSP Residual norm 3.922609774751e-12
  7037 KSP Residual norm 3.990432971511e-12
  7038 KSP Residual norm 4.198417693906e-12
  7039 KSP Residual norm 4.529634479549e-12
  7040 KSP Residual norm 4.934704829229e-12
  7041 KSP Residual norm 4.970322170993e-12
  7042 KSP Residual norm 4.417859119278e-12
  7043 KSP Residual norm 3.917164299486e-12
  7044 KSP Residual norm 4.216838225129e-12
  7045 KSP Residual norm 5.145672519512e-12
  7046 KSP Residual norm 5.750995221900e-12
  7047 KSP Residual norm 5.385497139837e-12
  7048 KSP Residual norm 5.083271743739e-12
  7049 KSP Residual norm 5.319335256959e-12
  7050 KSP Residual norm 5.546995999719e-12
  7051 KSP Residual norm 5.741636275815e-12
  7052 KSP Residual norm 5.530206412859e-12
  7053 KSP Residual norm 5.129743016119e-12
  7054 KSP Residual norm 5.024964805055e-12
  7055 KSP Residual norm 5.244977671427e-12
  7056 KSP Residual norm 5.470965953203e-12
  7057 KSP Residual norm 5.166643647366e-12
  7058 KSP Residual norm 4.936770430265e-12
  7059 KSP Residual norm 4.962611040529e-12
  7060 KSP Residual norm 4.775150019746e-12
  7061 KSP Residual norm 4.605760434291e-12
  7062 KSP Residual norm 4.306514413570e-12
  7063 KSP Residual norm 3.670218369758e-12
  7064 KSP Residual norm 3.480934493828e-12
  7065 KSP Residual norm 3.622483755697e-12
  7066 KSP Residual norm 3.579675625958e-12
  7067 KSP Residual norm 3.384065714145e-12
  7068 KSP Residual norm 3.215062769575e-12
  7069 KSP Residual norm 2.966372613041e-12
  7070 KSP Residual norm 2.956031889060e-12
  7071 KSP Residual norm 3.385643703128e-12
  7072 KSP Residual norm 3.305862845020e-12
  7073 KSP Residual norm 2.819272572561e-12
  7074 KSP Residual norm 2.611077864544e-12
  7075 KSP Residual norm 2.702840805890e-12
  7076 KSP Residual norm 3.083666461437e-12
  7077 KSP Residual norm 3.297923341470e-12
  7078 KSP Residual norm 3.221331203289e-12
  7079 KSP Residual norm 3.028678334177e-12
  7080 KSP Residual norm 2.969337340250e-12
  7081 KSP Residual norm 3.079592631679e-12
  7082 KSP Residual norm 3.287041564194e-12
  7083 KSP Residual norm 3.064703907962e-12
  7084 KSP Residual norm 2.616776268260e-12
  7085 KSP Residual norm 2.526594672035e-12
  7086 KSP Residual norm 2.689356777997e-12
  7087 KSP Residual norm 2.885217875396e-12
  7088 KSP Residual norm 3.156471084029e-12
  7089 KSP Residual norm 3.315769463125e-12
  7090 KSP Residual norm 3.609609036120e-12
  7091 KSP Residual norm 4.425525657020e-12
  7092 KSP Residual norm 4.973239265069e-12
  7093 KSP Residual norm 4.715671825514e-12
  7094 KSP Residual norm 4.558533520513e-12
  7095 KSP Residual norm 4.548477353336e-12
  7096 KSP Residual norm 4.573825162349e-12
  7097 KSP Residual norm 4.587228542071e-12
  7098 KSP Residual norm 4.665306391824e-12
  7099 KSP Residual norm 4.437856885798e-12
  7100 KSP Residual norm 4.224986593127e-12
  7101 KSP Residual norm 4.282120590865e-12
  7102 KSP Residual norm 4.453660972891e-12
  7103 KSP Residual norm 4.213806156487e-12
  7104 KSP Residual norm 4.109061731889e-12
  7105 KSP Residual norm 4.291431125081e-12
  7106 KSP Residual norm 4.224653242215e-12
  7107 KSP Residual norm 3.953977963458e-12
  7108 KSP Residual norm 3.676626952153e-12
  7109 KSP Residual norm 3.704729865843e-12
  7110 KSP Residual norm 4.044749675357e-12
  7111 KSP Residual norm 4.118527283785e-12
  7112 KSP Residual norm 3.421529170706e-12
  7113 KSP Residual norm 2.820881794137e-12
  7114 KSP Residual norm 2.711990123098e-12
  7115 KSP Residual norm 2.672646564011e-12
  7116 KSP Residual norm 2.542559914013e-12
  7117 KSP Residual norm 2.398801538523e-12
  7118 KSP Residual norm 2.071610189922e-12
  7119 KSP Residual norm 1.879662616197e-12
  7120 KSP Residual norm 1.934069586779e-12
  7121 KSP Residual norm 1.945671490936e-12
  7122 KSP Residual norm 1.804966170455e-12
  7123 KSP Residual norm 1.817305978052e-12
  7124 KSP Residual norm 2.016790382469e-12
  7125 KSP Residual norm 2.290706121463e-12
  7126 KSP Residual norm 2.450986844130e-12
  7127 KSP Residual norm 2.152610088285e-12
  7128 KSP Residual norm 1.673373897504e-12
  7129 KSP Residual norm 1.503455570246e-12
  7130 KSP Residual norm 1.694876628492e-12
  7131 KSP Residual norm 1.947188470809e-12
  7132 KSP Residual norm 1.863565987871e-12
  7133 KSP Residual norm 1.691018809283e-12
  7134 KSP Residual norm 1.537816988978e-12
  7135 KSP Residual norm 1.507904824438e-12
  7136 KSP Residual norm 1.575585576948e-12
  7137 KSP Residual norm 1.530242959293e-12
  7138 KSP Residual norm 1.414642176510e-12
  7139 KSP Residual norm 1.488205720504e-12
  7140 KSP Residual norm 1.622732289004e-12
  7141 KSP Residual norm 1.547661895522e-12
  7142 KSP Residual norm 1.388577795504e-12
  7143 KSP Residual norm 1.284155045709e-12
  7144 KSP Residual norm 1.313508815813e-12
  7145 KSP Residual norm 1.323675527462e-12
  7146 KSP Residual norm 1.373610630062e-12
  7147 KSP Residual norm 1.350077008553e-12
  7148 KSP Residual norm 1.405233831379e-12
  7149 KSP Residual norm 1.589700893622e-12
  7150 KSP Residual norm 1.684527820229e-12
  7151 KSP Residual norm 1.712963803902e-12
  7152 KSP Residual norm 1.724157990149e-12
  7153 KSP Residual norm 1.692485387648e-12
  7154 KSP Residual norm 1.640767115615e-12
  7155 KSP Residual norm 1.602160025028e-12
  7156 KSP Residual norm 1.485795154272e-12
  7157 KSP Residual norm 1.279038088805e-12
  7158 KSP Residual norm 1.124150787210e-12
  7159 KSP Residual norm 1.033491135376e-12
  7160 KSP Residual norm 9.832128981339e-13
  7161 KSP Residual norm 9.345687609290e-13
  7162 KSP Residual norm 8.117453604684e-13
  7163 KSP Residual norm 6.455081356350e-13
  7164 KSP Residual norm 5.306869422073e-13
  7165 KSP Residual norm 4.995064712322e-13
  7166 KSP Residual norm 4.932310799687e-13
  7167 KSP Residual norm 4.549567248007e-13
  7168 KSP Residual norm 4.252104884583e-13
  7169 KSP Residual norm 4.223619574309e-13
  7170 KSP Residual norm 4.215800723231e-13
  7171 KSP Residual norm 4.300042235788e-13
  7172 KSP Residual norm 4.175400137432e-13
  7173 KSP Residual norm 4.015507795241e-13
  7174 KSP Residual norm 4.185574762798e-13
  7175 KSP Residual norm 4.498466702574e-13
  7176 KSP Residual norm 4.242388142254e-13
  7177 KSP Residual norm 3.635558979675e-13
  7178 KSP Residual norm 3.433737997199e-13
  7179 KSP Residual norm 3.410331089387e-13
  7180 KSP Residual norm 3.122958778130e-13
  7181 KSP Residual norm 2.647850076273e-13
  7182 KSP Residual norm 2.306104135441e-13
  7183 KSP Residual norm 2.160158380962e-13
  7184 KSP Residual norm 2.145678812033e-13
  7185 KSP Residual norm 1.984858865969e-13
  7186 KSP Residual norm 1.797581096108e-13
  7187 KSP Residual norm 1.799976868019e-13
  7188 KSP Residual norm 1.840937483505e-13
  7189 KSP Residual norm 1.693814131448e-13
  7190 KSP Residual norm 1.551434785277e-13
  7191 KSP Residual norm 1.559392926667e-13
  7192 KSP Residual norm 1.743428714320e-13
  7193 KSP Residual norm 1.784957643243e-13
  7194 KSP Residual norm 1.649119263312e-13
  7195 KSP Residual norm 1.563271384366e-13
  7196 KSP Residual norm 1.503030986726e-13
  7197 KSP Residual norm 1.561945754659e-13
  7198 KSP Residual norm 1.710262381745e-13
  7199 KSP Residual norm 1.841212933044e-13
  7200 KSP Residual norm 1.773832213833e-13
  7201 KSP Residual norm 1.655035667047e-13
  7202 KSP Residual norm 1.660669733571e-13
  7203 KSP Residual norm 1.787259025283e-13
  7204 KSP Residual norm 1.945381784330e-13
  7205 KSP Residual norm 1.934800481238e-13
  7206 KSP Residual norm 1.680807178356e-13
  7207 KSP Residual norm 1.572962389503e-13
  7208 KSP Residual norm 1.651430484195e-13
  7209 KSP Residual norm 1.740795778866e-13
  7210 KSP Residual norm 1.684027527271e-13
  7211 KSP Residual norm 1.524480471969e-13
  7212 KSP Residual norm 1.396565015889e-13
  7213 KSP Residual norm 1.474570222632e-13
  7214 KSP Residual norm 1.776578127675e-13
  7215 KSP Residual norm 1.902982109606e-13
  7216 KSP Residual norm 1.852319175996e-13
  7217 KSP Residual norm 2.165500340214e-13
  7218 KSP Residual norm 2.620338241456e-13
  7219 KSP Residual norm 2.493328211354e-13
  7220 KSP Residual norm 2.072285906524e-13
  7221 KSP Residual norm 1.988913141208e-13
  7222 KSP Residual norm 2.141616564411e-13
  7223 KSP Residual norm 2.212254941886e-13
  7224 KSP Residual norm 1.869394030263e-13
  7225 KSP Residual norm 1.542384940752e-13
  7226 KSP Residual norm 1.544009121344e-13
  7227 KSP Residual norm 1.610542419612e-13
  7228 KSP Residual norm 1.484026807280e-13
  7229 KSP Residual norm 1.282754431283e-13
  7230 KSP Residual norm 1.222086131301e-13
  7231 KSP Residual norm 1.299973606511e-13
  7232 KSP Residual norm 1.247225569202e-13
  7233 KSP Residual norm 1.140236620610e-13
  7234 KSP Residual norm 1.078527678607e-13
  7235 KSP Residual norm 1.019111321444e-13
  7236 KSP Residual norm 9.310290901568e-14
  7237 KSP Residual norm 9.257312002382e-14
  7238 KSP Residual norm 9.665223132698e-14
  7239 KSP Residual norm 1.031308455639e-13
  7240 KSP Residual norm 1.137230906608e-13
  7241 KSP Residual norm 1.276253973526e-13
  7242 KSP Residual norm 1.253179555883e-13
  7243 KSP Residual norm 1.145011164345e-13
  7244 KSP Residual norm 1.123896800635e-13
  7245 KSP Residual norm 1.120559288527e-13
  7246 KSP Residual norm 1.096096535477e-13
  7247 KSP Residual norm 1.040637760995e-13
  7248 KSP Residual norm 9.599713456412e-14
  7249 KSP Residual norm 8.680985072399e-14
  7250 KSP Residual norm 8.018894383417e-14
  7251 KSP Residual norm 7.226272064244e-14
  7252 KSP Residual norm 5.896040649208e-14
  7253 KSP Residual norm 5.193258530761e-14
  7254 KSP Residual norm 5.223062218428e-14
  7255 KSP Residual norm 5.245178794763e-14
  7256 KSP Residual norm 4.595585498512e-14
  7257 KSP Residual norm 4.144261780133e-14
  7258 KSP Residual norm 3.785495859415e-14
  7259 KSP Residual norm 3.593302591830e-14
  7260 KSP Residual norm 3.997153697133e-14
  7261 KSP Residual norm 4.535529338456e-14
  7262 KSP Residual norm 4.338257631529e-14
  7263 KSP Residual norm 4.123575245139e-14
  7264 KSP Residual norm 4.415584448653e-14
  7265 KSP Residual norm 5.232057646790e-14
  7266 KSP Residual norm 6.401705339893e-14
  7267 KSP Residual norm 6.423609982907e-14
  7268 KSP Residual norm 6.110072044529e-14
  7269 KSP Residual norm 6.570638351360e-14
  7270 KSP Residual norm 6.872841880202e-14
  7271 KSP Residual norm 6.555233290253e-14
  7272 KSP Residual norm 6.263777749875e-14
  7273 KSP Residual norm 5.967126468313e-14
  7274 KSP Residual norm 5.684645281480e-14
  7275 KSP Residual norm 5.848397794758e-14
  7276 KSP Residual norm 5.827487018853e-14
  7277 KSP Residual norm 5.451577605113e-14
  7278 KSP Residual norm 5.398665001915e-14
  7279 KSP Residual norm 5.905825329091e-14
  7280 KSP Residual norm 6.581916994730e-14
  7281 KSP Residual norm 7.452601638092e-14
  7282 KSP Residual norm 8.394094102362e-14
  7283 KSP Residual norm 8.806090293657e-14
  7284 KSP Residual norm 9.220147662602e-14
  7285 KSP Residual norm 1.047565556411e-13
  7286 KSP Residual norm 1.151404733478e-13
  7287 KSP Residual norm 1.164153319315e-13
  7288 KSP Residual norm 1.157081242168e-13
  7289 KSP Residual norm 1.182325224862e-13
  7290 KSP Residual norm 1.183525688466e-13
  7291 KSP Residual norm 1.115399330124e-13
  7292 KSP Residual norm 1.005431747240e-13
  7293 KSP Residual norm 8.691161292594e-14
  7294 KSP Residual norm 7.593909515637e-14
  7295 KSP Residual norm 6.992616268158e-14
  7296 KSP Residual norm 6.409086170697e-14
  7297 KSP Residual norm 6.019016038559e-14
  7298 KSP Residual norm 6.038814818388e-14
  7299 KSP Residual norm 5.930871108725e-14
  7300 KSP Residual norm 5.336765440165e-14
  7301 KSP Residual norm 4.985299037976e-14
  7302 KSP Residual norm 4.583077037819e-14
  7303 KSP Residual norm 4.218746467174e-14
  7304 KSP Residual norm 3.937201781081e-14
  7305 KSP Residual norm 3.696856723461e-14
  7306 KSP Residual norm 3.724718301436e-14
  7307 KSP Residual norm 4.110407164512e-14
  7308 KSP Residual norm 4.537366479458e-14
  7309 KSP Residual norm 4.858008464346e-14
  7310 KSP Residual norm 5.735439828393e-14
  7311 KSP Residual norm 6.305256578234e-14
  7312 KSP Residual norm 6.804749504707e-14
  7313 KSP Residual norm 7.753568238599e-14
  7314 KSP Residual norm 8.225039801725e-14
  7315 KSP Residual norm 7.874314475546e-14
  7316 KSP Residual norm 7.537515485286e-14
  7317 KSP Residual norm 7.807347713306e-14
  7318 KSP Residual norm 8.583097576526e-14
  7319 KSP Residual norm 8.646031560070e-14
  7320 KSP Residual norm 8.217227186127e-14
  7321 KSP Residual norm 7.906046972555e-14
  7322 KSP Residual norm 7.912695461149e-14
  7323 KSP Residual norm 7.719302880100e-14
  7324 KSP Residual norm 7.216027884290e-14
  7325 KSP Residual norm 7.028922262447e-14
  7326 KSP Residual norm 6.925504575685e-14
  7327 KSP Residual norm 6.875531461662e-14
  7328 KSP Residual norm 6.676264338258e-14
  7329 KSP Residual norm 6.476908836842e-14
  7330 KSP Residual norm 6.380924812648e-14
  7331 KSP Residual norm 6.258334972281e-14
  7332 KSP Residual norm 6.360551055602e-14
  7333 KSP Residual norm 6.768577399255e-14
  7334 KSP Residual norm 7.529413994087e-14
  7335 KSP Residual norm 8.482374531993e-14
  7336 KSP Residual norm 9.748719386534e-14
  7337 KSP Residual norm 1.080654452382e-13
  7338 KSP Residual norm 1.067767601379e-13
  7339 KSP Residual norm 1.137818920854e-13
  7340 KSP Residual norm 1.363802920803e-13
  7341 KSP Residual norm 1.580068540449e-13
  7342 KSP Residual norm 1.718252272461e-13
  7343 KSP Residual norm 1.780509210480e-13
  7344 KSP Residual norm 1.966735048312e-13
  7345 KSP Residual norm 2.356262473313e-13
  7346 KSP Residual norm 2.623549879331e-13
  7347 KSP Residual norm 2.868149644783e-13
  7348 KSP Residual norm 3.144953788951e-13
  7349 KSP Residual norm 3.231052987112e-13
  7350 KSP Residual norm 3.250612686140e-13
  7351 KSP Residual norm 3.226648397164e-13
  7352 KSP Residual norm 2.860786820736e-13
  7353 KSP Residual norm 2.533381708189e-13
  7354 KSP Residual norm 2.487536508625e-13
  7355 KSP Residual norm 2.250027082847e-13
  7356 KSP Residual norm 1.989108588501e-13
  7357 KSP Residual norm 1.869651820322e-13
  7358 KSP Residual norm 1.812243831025e-13
  7359 KSP Residual norm 1.777519728726e-13
  7360 KSP Residual norm 1.721504308507e-13
  7361 KSP Residual norm 1.599887770121e-13
  7362 KSP Residual norm 1.482494679818e-13
  7363 KSP Residual norm 1.415304969898e-13
  7364 KSP Residual norm 1.411436501623e-13
  7365 KSP Residual norm 1.436736013323e-13
  7366 KSP Residual norm 1.415499522422e-13
  7367 KSP Residual norm 1.423541601522e-13
  7368 KSP Residual norm 1.502427335569e-13
  7369 KSP Residual norm 1.771026075983e-13
  7370 KSP Residual norm 2.315838018925e-13
  7371 KSP Residual norm 2.762328493793e-13
  7372 KSP Residual norm 3.087234960639e-13
  7373 KSP Residual norm 3.422233194675e-13
  7374 KSP Residual norm 3.831793720186e-13
  7375 KSP Residual norm 4.386837089904e-13
  7376 KSP Residual norm 4.636302235918e-13
  7377 KSP Residual norm 4.657412360718e-13
  7378 KSP Residual norm 4.934335911624e-13
  7379 KSP Residual norm 5.150089239700e-13
  7380 KSP Residual norm 4.798321016531e-13
  7381 KSP Residual norm 4.528505762218e-13
  7382 KSP Residual norm 4.586159709999e-13
  7383 KSP Residual norm 4.086923995500e-13
  7384 KSP Residual norm 3.623349763292e-13
  7385 KSP Residual norm 3.703557156903e-13
  7386 KSP Residual norm 3.886703716875e-13
  7387 KSP Residual norm 3.787994899294e-13
  7388 KSP Residual norm 3.621797191030e-13
  7389 KSP Residual norm 3.318294944344e-13
  7390 KSP Residual norm 3.108868805694e-13
  7391 KSP Residual norm 3.214638010837e-13
  7392 KSP Residual norm 3.392285743025e-13
  7393 KSP Residual norm 3.592730931622e-13
  7394 KSP Residual norm 3.597859374784e-13
  7395 KSP Residual norm 3.698148996909e-13
  7396 KSP Residual norm 3.560851210545e-13
  7397 KSP Residual norm 3.656910580536e-13
  7398 KSP Residual norm 4.373769317830e-13
  7399 KSP Residual norm 5.089968056150e-13
  7400 KSP Residual norm 4.890671047714e-13
  7401 KSP Residual norm 4.442049943869e-13
  7402 KSP Residual norm 4.365009156568e-13
  7403 KSP Residual norm 4.334258280601e-13
  7404 KSP Residual norm 3.937267137344e-13
  7405 KSP Residual norm 3.815888878310e-13
  7406 KSP Residual norm 4.058641561438e-13
  7407 KSP Residual norm 4.057488435734e-13
  7408 KSP Residual norm 3.575914624661e-13
  7409 KSP Residual norm 3.315124548513e-13
  7410 KSP Residual norm 3.335216105721e-13
  7411 KSP Residual norm 3.254842202101e-13
  7412 KSP Residual norm 3.081724869709e-13
  7413 KSP Residual norm 2.918625270108e-13
  7414 KSP Residual norm 2.709029524602e-13
  7415 KSP Residual norm 2.549280259433e-13
  7416 KSP Residual norm 2.398592259674e-13
  7417 KSP Residual norm 2.226624409076e-13
  7418 KSP Residual norm 2.292047019029e-13
  7419 KSP Residual norm 2.547002228306e-13
  7420 KSP Residual norm 2.583253669854e-13
  7421 KSP Residual norm 2.422895682478e-13
  7422 KSP Residual norm 2.528815516569e-13
  7423 KSP Residual norm 2.990404515076e-13
  7424 KSP Residual norm 3.261705352927e-13
  7425 KSP Residual norm 3.205806061571e-13
  7426 KSP Residual norm 2.988176104203e-13
  7427 KSP Residual norm 2.917773622559e-13
  7428 KSP Residual norm 3.054423512407e-13
  7429 KSP Residual norm 2.847320405821e-13
  7430 KSP Residual norm 2.537151078668e-13
  7431 KSP Residual norm 2.570048449654e-13
  7432 KSP Residual norm 2.756050251875e-13
  7433 KSP Residual norm 2.742588603015e-13
  7434 KSP Residual norm 2.535480275752e-13
  7435 KSP Residual norm 2.360466136851e-13
  7436 KSP Residual norm 2.415253661331e-13
  7437 KSP Residual norm 2.443639403340e-13
  7438 KSP Residual norm 2.211379000972e-13
  7439 KSP Residual norm 1.997241632692e-13
  7440 KSP Residual norm 2.010041062681e-13
  7441 KSP Residual norm 1.987552567561e-13
  7442 KSP Residual norm 1.780706041180e-13
  7443 KSP Residual norm 1.602789715274e-13
  7444 KSP Residual norm 1.561305666405e-13
  7445 KSP Residual norm 1.591868513037e-13
  7446 KSP Residual norm 1.759966285951e-13
  7447 KSP Residual norm 1.843777751829e-13
  7448 KSP Residual norm 1.820426226581e-13
  7449 KSP Residual norm 1.775002443867e-13
  7450 KSP Residual norm 1.797834384203e-13
  7451 KSP Residual norm 1.984838763802e-13
  7452 KSP Residual norm 2.122070775368e-13
  7453 KSP Residual norm 1.985992772974e-13
  7454 KSP Residual norm 1.998443800024e-13
  7455 KSP Residual norm 2.082565796200e-13
  7456 KSP Residual norm 1.841941930457e-13
  7457 KSP Residual norm 1.548493079732e-13
  7458 KSP Residual norm 1.450513762024e-13
  7459 KSP Residual norm 1.412757965796e-13
  7460 KSP Residual norm 1.403567907713e-13
  7461 KSP Residual norm 1.429002887638e-13
  7462 KSP Residual norm 1.425264166613e-13
  7463 KSP Residual norm 1.463210228447e-13
  7464 KSP Residual norm 1.524649415085e-13
  7465 KSP Residual norm 1.611450897501e-13
  7466 KSP Residual norm 1.808711953422e-13
  7467 KSP Residual norm 1.980387305396e-13
  7468 KSP Residual norm 2.145236044950e-13
  7469 KSP Residual norm 2.219383238235e-13
  7470 KSP Residual norm 2.288209966611e-13
  7471 KSP Residual norm 2.468798549875e-13
  7472 KSP Residual norm 2.531940740244e-13
  7473 KSP Residual norm 2.452531339189e-13
  7474 KSP Residual norm 2.660486084878e-13
  7475 KSP Residual norm 2.860686772226e-13
  7476 KSP Residual norm 2.813029941587e-13
  7477 KSP Residual norm 2.766231714525e-13
  7478 KSP Residual norm 2.653340423184e-13
  7479 KSP Residual norm 2.379705935850e-13
  7480 KSP Residual norm 2.294041858230e-13
  7481 KSP Residual norm 2.367729763450e-13
  7482 KSP Residual norm 2.462497355506e-13
  7483 KSP Residual norm 2.578377888792e-13
  7484 KSP Residual norm 2.621844820674e-13
  7485 KSP Residual norm 2.228233842528e-13
  7486 KSP Residual norm 1.853368516297e-13
  7487 KSP Residual norm 1.721256910097e-13
  7488 KSP Residual norm 1.682577022555e-13
  7489 KSP Residual norm 1.668108995615e-13
  7490 KSP Residual norm 1.751207183552e-13
  7491 KSP Residual norm 2.041592417258e-13
  7492 KSP Residual norm 2.245608948590e-13
  7493 KSP Residual norm 2.035063312372e-13
  7494 KSP Residual norm 1.897383106275e-13
  7495 KSP Residual norm 1.773152854770e-13
  7496 KSP Residual norm 1.775539182552e-13
  7497 KSP Residual norm 1.904499932289e-13
  7498 KSP Residual norm 1.862354493395e-13
  7499 KSP Residual norm 1.925486917868e-13
  7500 KSP Residual norm 2.296199594446e-13
  7501 KSP Residual norm 2.342312563571e-13
  7502 KSP Residual norm 2.055891955144e-13
  7503 KSP Residual norm 1.753182108102e-13
  7504 KSP Residual norm 1.506290858967e-13
  7505 KSP Residual norm 1.459453323427e-13
  7506 KSP Residual norm 1.630921883906e-13
  7507 KSP Residual norm 1.641362077969e-13
  7508 KSP Residual norm 1.529757319273e-13
  7509 KSP Residual norm 1.577329924832e-13
  7510 KSP Residual norm 1.675313304656e-13
  7511 KSP Residual norm 1.781133341752e-13
  7512 KSP Residual norm 1.800815408100e-13
  7513 KSP Residual norm 1.819565049601e-13
  7514 KSP Residual norm 1.812213086965e-13
  7515 KSP Residual norm 1.777870951633e-13
  7516 KSP Residual norm 1.680455723461e-13
  7517 KSP Residual norm 1.685796044183e-13
  7518 KSP Residual norm 1.974851486339e-13
  7519 KSP Residual norm 2.283797614143e-13
  7520 KSP Residual norm 2.315572667588e-13
  7521 KSP Residual norm 2.363712746296e-13
  7522 KSP Residual norm 2.529526958202e-13
  7523 KSP Residual norm 2.631512897072e-13
  7524 KSP Residual norm 2.632570098630e-13
  7525 KSP Residual norm 2.844737687154e-13
  7526 KSP Residual norm 3.218343083835e-13
  7527 KSP Residual norm 3.149516703547e-13
  7528 KSP Residual norm 2.908813787626e-13
  7529 KSP Residual norm 2.824554917916e-13
  7530 KSP Residual norm 2.943050745268e-13
  7531 KSP Residual norm 3.245724043979e-13
  7532 KSP Residual norm 3.471158272613e-13
  7533 KSP Residual norm 3.774907806608e-13
  7534 KSP Residual norm 4.279817223389e-13
  7535 KSP Residual norm 4.471708772205e-13
  7536 KSP Residual norm 4.212334641287e-13
  7537 KSP Residual norm 3.729169893189e-13
  7538 KSP Residual norm 3.527160229519e-13
  7539 KSP Residual norm 3.978628897016e-13
  7540 KSP Residual norm 4.187599888482e-13
  7541 KSP Residual norm 3.970258054846e-13
  7542 KSP Residual norm 4.012443122051e-13
  7543 KSP Residual norm 4.758078914336e-13
  7544 KSP Residual norm 5.848680183814e-13
  7545 KSP Residual norm 6.649087629792e-13
  7546 KSP Residual norm 7.169605672094e-13
  7547 KSP Residual norm 7.496788525859e-13
  7548 KSP Residual norm 7.398972193426e-13
  7549 KSP Residual norm 7.368341983929e-13
  7550 KSP Residual norm 6.975621710655e-13
  7551 KSP Residual norm 7.092132712935e-13
  7552 KSP Residual norm 8.229486866569e-13
  7553 KSP Residual norm 8.730168055784e-13
  7554 KSP Residual norm 8.138651540545e-13
  7555 KSP Residual norm 7.351092329276e-13
  7556 KSP Residual norm 7.108547898382e-13
  7557 KSP Residual norm 7.819787686070e-13
  7558 KSP Residual norm 8.558411089424e-13
  7559 KSP Residual norm 8.596665368614e-13
  7560 KSP Residual norm 8.697789235546e-13
  7561 KSP Residual norm 9.633236604162e-13
  7562 KSP Residual norm 9.917488879367e-13
  7563 KSP Residual norm 9.425355133933e-13
  7564 KSP Residual norm 9.928511640491e-13
  7565 KSP Residual norm 1.066408050617e-12
  7566 KSP Residual norm 1.036129826394e-12
  7567 KSP Residual norm 9.323032089209e-13
  7568 KSP Residual norm 8.931650501179e-13
  7569 KSP Residual norm 9.413940160048e-13
  7570 KSP Residual norm 1.132057244165e-12
  7571 KSP Residual norm 1.294330420294e-12
  7572 KSP Residual norm 1.176205015803e-12
  7573 KSP Residual norm 1.047828348736e-12
  7574 KSP Residual norm 9.166066480167e-13
  7575 KSP Residual norm 7.173952275169e-13
  7576 KSP Residual norm 5.832469978483e-13
  7577 KSP Residual norm 5.372010579900e-13
  7578 KSP Residual norm 5.584976258812e-13
  7579 KSP Residual norm 6.322105227295e-13
  7580 KSP Residual norm 7.088089383062e-13
  7581 KSP Residual norm 7.234123062545e-13
  7582 KSP Residual norm 6.920600782922e-13
  7583 KSP Residual norm 6.869299926558e-13
  7584 KSP Residual norm 7.147357223932e-13
  7585 KSP Residual norm 7.582910577171e-13
  7586 KSP Residual norm 7.706580526776e-13
  7587 KSP Residual norm 7.688033236089e-13
  7588 KSP Residual norm 7.482732319094e-13
  7589 KSP Residual norm 7.448456726473e-13
  7590 KSP Residual norm 7.576265558448e-13
  7591 KSP Residual norm 7.724811104206e-13
  7592 KSP Residual norm 8.538482784711e-13
  7593 KSP Residual norm 9.803355375121e-13
  7594 KSP Residual norm 1.021825028818e-12
  7595 KSP Residual norm 1.105322154626e-12
  7596 KSP Residual norm 1.194791513193e-12
  7597 KSP Residual norm 1.065598341873e-12
  7598 KSP Residual norm 8.781196764273e-13
  7599 KSP Residual norm 8.455038339434e-13
  7600 KSP Residual norm 7.989275111702e-13
  7601 KSP Residual norm 7.414268691579e-13
  7602 KSP Residual norm 6.889642855460e-13
  7603 KSP Residual norm 5.958222821302e-13
  7604 KSP Residual norm 4.926920945470e-13
  7605 KSP Residual norm 4.811692428034e-13
  7606 KSP Residual norm 4.763790988367e-13
  7607 KSP Residual norm 4.012545232230e-13
  7608 KSP Residual norm 3.393047623797e-13
  7609 KSP Residual norm 3.298002908640e-13
  7610 KSP Residual norm 3.719213762758e-13
  7611 KSP Residual norm 4.745803343887e-13
  7612 KSP Residual norm 5.638094251136e-13
  7613 KSP Residual norm 5.507232060383e-13
  7614 KSP Residual norm 4.803996737573e-13
  7615 KSP Residual norm 4.753913541833e-13
  7616 KSP Residual norm 5.019301625279e-13
  7617 KSP Residual norm 5.114945729089e-13
  7618 KSP Residual norm 5.323217639950e-13
  7619 KSP Residual norm 5.688773112219e-13
  7620 KSP Residual norm 6.166832475193e-13
  7621 KSP Residual norm 7.284999934378e-13
  7622 KSP Residual norm 8.385319669632e-13
  7623 KSP Residual norm 8.196116605667e-13
  7624 KSP Residual norm 7.980093845249e-13
  7625 KSP Residual norm 9.178503505858e-13
  7626 KSP Residual norm 1.023756999532e-12
  7627 KSP Residual norm 1.045292723855e-12
  7628 KSP Residual norm 1.097161044556e-12
  7629 KSP Residual norm 1.153591569090e-12
  7630 KSP Residual norm 1.218189671259e-12
  7631 KSP Residual norm 1.131982484043e-12
  7632 KSP Residual norm 8.809262810960e-13
  7633 KSP Residual norm 7.963463797603e-13
  7634 KSP Residual norm 8.276124793902e-13
  7635 KSP Residual norm 8.310027182937e-13
  7636 KSP Residual norm 7.589094750402e-13
  7637 KSP Residual norm 7.368234478771e-13
  7638 KSP Residual norm 8.262476591280e-13
  7639 KSP Residual norm 9.491102318632e-13
  7640 KSP Residual norm 1.029721301164e-12
  7641 KSP Residual norm 9.634517246503e-13
  7642 KSP Residual norm 9.093595496952e-13
  7643 KSP Residual norm 9.715120504248e-13
  7644 KSP Residual norm 9.888716200346e-13
  7645 KSP Residual norm 8.326242848132e-13
  7646 KSP Residual norm 7.460538864522e-13
  7647 KSP Residual norm 8.054314256617e-13
  7648 KSP Residual norm 8.012315429970e-13
  7649 KSP Residual norm 6.497574514395e-13
  7650 KSP Residual norm 5.812821706448e-13
  7651 KSP Residual norm 6.329180622732e-13
  7652 KSP Residual norm 6.672661807087e-13
  7653 KSP Residual norm 6.445743282467e-13
  7654 KSP Residual norm 5.323418751505e-13
  7655 KSP Residual norm 4.459261655378e-13
  7656 KSP Residual norm 4.777023367109e-13
  7657 KSP Residual norm 5.173568680601e-13
  7658 KSP Residual norm 4.674285652867e-13
  7659 KSP Residual norm 4.153295598925e-13
  7660 KSP Residual norm 3.981913616951e-13
  7661 KSP Residual norm 3.992422106442e-13
  7662 KSP Residual norm 4.132075174612e-13
  7663 KSP Residual norm 4.636254694342e-13
  7664 KSP Residual norm 5.219612477145e-13
  7665 KSP Residual norm 5.873852414823e-13
  7666 KSP Residual norm 6.173994836277e-13
  7667 KSP Residual norm 5.684589945229e-13
  7668 KSP Residual norm 5.376065001917e-13
  7669 KSP Residual norm 5.351656602218e-13
  7670 KSP Residual norm 5.306564957903e-13
  7671 KSP Residual norm 4.884341205658e-13
  7672 KSP Residual norm 4.334309524600e-13
  7673 KSP Residual norm 3.645129398258e-13
  7674 KSP Residual norm 3.174085436766e-13
  7675 KSP Residual norm 3.214377142368e-13
  7676 KSP Residual norm 3.421398022688e-13
  7677 KSP Residual norm 3.402091065800e-13
  7678 KSP Residual norm 3.377308105921e-13
  7679 KSP Residual norm 3.350366589929e-13
  7680 KSP Residual norm 3.176781263850e-13
  7681 KSP Residual norm 3.127766550450e-13
  7682 KSP Residual norm 3.241160670222e-13
  7683 KSP Residual norm 3.045269362551e-13
  7684 KSP Residual norm 2.618480900466e-13
  7685 KSP Residual norm 2.372560466921e-13
  7686 KSP Residual norm 2.231247809971e-13
  7687 KSP Residual norm 2.403117454388e-13
  7688 KSP Residual norm 2.911271922322e-13
  7689 KSP Residual norm 3.233842325878e-13
  7690 KSP Residual norm 3.443347269886e-13
  7691 KSP Residual norm 3.869819798594e-13
  7692 KSP Residual norm 3.887481566957e-13
  7693 KSP Residual norm 3.138967476676e-13
  7694 KSP Residual norm 2.654039287054e-13
  7695 KSP Residual norm 2.595514919557e-13
  7696 KSP Residual norm 2.783821088064e-13
  7697 KSP Residual norm 3.088027512775e-13
  7698 KSP Residual norm 3.333521067283e-13
  7699 KSP Residual norm 3.575313961218e-13
  7700 KSP Residual norm 3.983303612591e-13
  7701 KSP Residual norm 4.317759386790e-13
  7702 KSP Residual norm 4.086059100034e-13
  7703 KSP Residual norm 4.012703630968e-13
  7704 KSP Residual norm 4.310939138429e-13
  7705 KSP Residual norm 4.815475383273e-13
  7706 KSP Residual norm 5.081580356470e-13
  7707 KSP Residual norm 4.966807079939e-13
  7708 KSP Residual norm 4.725562776928e-13
  7709 KSP Residual norm 4.486568129829e-13
  7710 KSP Residual norm 4.360208818136e-13
  7711 KSP Residual norm 4.115734282025e-13
  7712 KSP Residual norm 3.623501525378e-13
  7713 KSP Residual norm 3.528672353011e-13
  7714 KSP Residual norm 3.845446425810e-13
  7715 KSP Residual norm 4.306941160469e-13
  7716 KSP Residual norm 5.089228799372e-13
  7717 KSP Residual norm 6.250453051612e-13
  7718 KSP Residual norm 6.550028522639e-13
  7719 KSP Residual norm 5.847173385523e-13
  7720 KSP Residual norm 5.265441571843e-13
  7721 KSP Residual norm 5.562219436542e-13
  7722 KSP Residual norm 6.840931919459e-13
  7723 KSP Residual norm 8.530237543342e-13
  7724 KSP Residual norm 9.844957412603e-13
  7725 KSP Residual norm 1.153822789936e-12
  7726 KSP Residual norm 1.356410197937e-12
  7727 KSP Residual norm 1.395161473798e-12
  7728 KSP Residual norm 1.314084971494e-12
  7729 KSP Residual norm 1.448378954124e-12
  7730 KSP Residual norm 1.757314482134e-12
  7731 KSP Residual norm 2.073894402390e-12
  7732 KSP Residual norm 2.290424996899e-12
  7733 KSP Residual norm 2.170201507433e-12
  7734 KSP Residual norm 1.730422202439e-12
  7735 KSP Residual norm 1.510596032556e-12
  7736 KSP Residual norm 1.451280757527e-12
  7737 KSP Residual norm 1.270618378272e-12
  7738 KSP Residual norm 1.015547234305e-12
  7739 KSP Residual norm 8.434531100169e-13
  7740 KSP Residual norm 8.555732657493e-13
  7741 KSP Residual norm 1.075835904867e-12
  7742 KSP Residual norm 1.407817694623e-12
  7743 KSP Residual norm 1.608776786179e-12
  7744 KSP Residual norm 1.580720206908e-12
  7745 KSP Residual norm 1.525628988359e-12
  7746 KSP Residual norm 1.576082524000e-12
  7747 KSP Residual norm 1.620159910695e-12
  7748 KSP Residual norm 1.673691566840e-12
  7749 KSP Residual norm 1.928327077023e-12
  7750 KSP Residual norm 2.183879229528e-12
  7751 KSP Residual norm 2.332558605763e-12
  7752 KSP Residual norm 2.293511075151e-12
  7753 KSP Residual norm 2.066870042879e-12
  7754 KSP Residual norm 2.036684375943e-12
  7755 KSP Residual norm 2.191179619555e-12
  7756 KSP Residual norm 2.266760194661e-12
  7757 KSP Residual norm 2.438193210121e-12
  7758 KSP Residual norm 2.637417692438e-12
  7759 KSP Residual norm 2.556994033109e-12
  7760 KSP Residual norm 2.393235828751e-12
  7761 KSP Residual norm 2.236661925217e-12
  7762 KSP Residual norm 2.043347292547e-12
  7763 KSP Residual norm 1.972641340067e-12
  7764 KSP Residual norm 2.121231789974e-12
  7765 KSP Residual norm 2.225365175710e-12
  7766 KSP Residual norm 2.336593354441e-12
  7767 KSP Residual norm 2.579076751912e-12
  7768 KSP Residual norm 2.754017683251e-12
  7769 KSP Residual norm 2.739160645893e-12
  7770 KSP Residual norm 2.947995752649e-12
  7771 KSP Residual norm 3.575120726244e-12
  7772 KSP Residual norm 3.762251930777e-12
  7773 KSP Residual norm 2.977381123545e-12
  7774 KSP Residual norm 2.405293401829e-12
  7775 KSP Residual norm 2.393154955084e-12
  7776 KSP Residual norm 2.496210347138e-12
  7777 KSP Residual norm 2.871972327628e-12
  7778 KSP Residual norm 3.356668557516e-12
  7779 KSP Residual norm 3.463161085549e-12
  7780 KSP Residual norm 3.364189718610e-12
  7781 KSP Residual norm 3.632572585331e-12
  7782 KSP Residual norm 4.127824451400e-12
  7783 KSP Residual norm 4.515259435082e-12
  7784 KSP Residual norm 4.846534188837e-12
  7785 KSP Residual norm 4.825011797118e-12
  7786 KSP Residual norm 4.391717279684e-12
  7787 KSP Residual norm 4.381721937401e-12
  7788 KSP Residual norm 4.729638804602e-12
  7789 KSP Residual norm 4.955897303374e-12
  7790 KSP Residual norm 5.293790349207e-12
  7791 KSP Residual norm 5.617896799041e-12
  7792 KSP Residual norm 5.588562168915e-12
  7793 KSP Residual norm 5.295793901439e-12
  7794 KSP Residual norm 4.532212947523e-12
  7795 KSP Residual norm 3.982264153903e-12
  7796 KSP Residual norm 4.075475283841e-12
  7797 KSP Residual norm 4.607718746484e-12
  7798 KSP Residual norm 4.979721304956e-12
  7799 KSP Residual norm 4.874622119983e-12
  7800 KSP Residual norm 4.967788193091e-12
  7801 KSP Residual norm 4.947258241718e-12
  7802 KSP Residual norm 4.881870257782e-12
  7803 KSP Residual norm 5.004884036076e-12
  7804 KSP Residual norm 5.482963866741e-12
  7805 KSP Residual norm 6.518193777735e-12
  7806 KSP Residual norm 8.754908067927e-12
  7807 KSP Residual norm 1.038402512838e-11
  7808 KSP Residual norm 9.029468060963e-12
  7809 KSP Residual norm 7.505241458090e-12
  7810 KSP Residual norm 7.337767327736e-12
  7811 KSP Residual norm 8.408390653967e-12
  7812 KSP Residual norm 1.093615628013e-11
  7813 KSP Residual norm 1.254251198960e-11
  7814 KSP Residual norm 1.117373944616e-11
  7815 KSP Residual norm 1.003638698477e-11
  7816 KSP Residual norm 9.309377925520e-12
  7817 KSP Residual norm 7.460770940601e-12
  7818 KSP Residual norm 6.377641380694e-12
  7819 KSP Residual norm 6.906334784951e-12
  7820 KSP Residual norm 8.009428240380e-12
  7821 KSP Residual norm 8.833421756135e-12
  7822 KSP Residual norm 8.936861652442e-12
  7823 KSP Residual norm 8.485990550786e-12
  7824 KSP Residual norm 8.329296944992e-12
  7825 KSP Residual norm 8.036892358296e-12
  7826 KSP Residual norm 7.299585157135e-12
  7827 KSP Residual norm 6.967378519347e-12
  7828 KSP Residual norm 7.554657544609e-12
  7829 KSP Residual norm 8.542823806256e-12
  7830 KSP Residual norm 9.007431225929e-12
  7831 KSP Residual norm 9.036966316882e-12
  7832 KSP Residual norm 9.268034278139e-12
  7833 KSP Residual norm 1.017483282473e-11
  7834 KSP Residual norm 1.246552131499e-11
  7835 KSP Residual norm 1.525684406523e-11
  7836 KSP Residual norm 1.564681798325e-11
  7837 KSP Residual norm 1.472287086748e-11
  7838 KSP Residual norm 1.522429641847e-11
  7839 KSP Residual norm 1.514006351533e-11
  7840 KSP Residual norm 1.224668119737e-11
  7841 KSP Residual norm 1.012877121990e-11
  7842 KSP Residual norm 1.005505954997e-11
  7843 KSP Residual norm 1.064342048533e-11
  7844 KSP Residual norm 1.006785278964e-11
  7845 KSP Residual norm 7.777808292507e-12
  7846 KSP Residual norm 6.234101186632e-12
  7847 KSP Residual norm 6.627007025227e-12
  7848 KSP Residual norm 8.862331782728e-12
  7849 KSP Residual norm 1.036050820472e-11
  7850 KSP Residual norm 9.678630161381e-12
  7851 KSP Residual norm 9.188327812782e-12
  7852 KSP Residual norm 9.809906469246e-12
  7853 KSP Residual norm 1.247002865207e-11
  7854 KSP Residual norm 1.765426445461e-11
  7855 KSP Residual norm 1.989035560985e-11
  7856 KSP Residual norm 1.675934977281e-11
  7857 KSP Residual norm 1.412596795407e-11
  7858 KSP Residual norm 1.318706967744e-11
  7859 KSP Residual norm 1.238692067343e-11
  7860 KSP Residual norm 1.182679588462e-11
  7861 KSP Residual norm 1.164780604591e-11
  7862 KSP Residual norm 1.060499081414e-11
  7863 KSP Residual norm 9.239919262693e-12
  7864 KSP Residual norm 8.807027276712e-12
  7865 KSP Residual norm 8.709204375696e-12
  7866 KSP Residual norm 8.434311470714e-12
  7867 KSP Residual norm 8.332532658072e-12
  7868 KSP Residual norm 7.916973908033e-12
  7869 KSP Residual norm 6.793044665684e-12
  7870 KSP Residual norm 6.079911034527e-12
  7871 KSP Residual norm 6.012013727332e-12
  7872 KSP Residual norm 6.089025467139e-12
  7873 KSP Residual norm 6.350385597151e-12
  7874 KSP Residual norm 6.199734118070e-12
  7875 KSP Residual norm 5.490865491278e-12
  7876 KSP Residual norm 5.148150806266e-12
  7877 KSP Residual norm 5.097358245933e-12
  7878 KSP Residual norm 5.121673124665e-12
  7879 KSP Residual norm 5.404286356277e-12
  7880 KSP Residual norm 5.890044724071e-12
  7881 KSP Residual norm 6.193397462807e-12
  7882 KSP Residual norm 6.163494589869e-12
  7883 KSP Residual norm 6.026094906149e-12
  7884 KSP Residual norm 5.519611060887e-12
  7885 KSP Residual norm 5.618958209326e-12
  7886 KSP Residual norm 6.540138891911e-12
  7887 KSP Residual norm 8.256611419756e-12
  7888 KSP Residual norm 9.714784881590e-12
  7889 KSP Residual norm 1.086978141669e-11
  7890 KSP Residual norm 1.112873379923e-11
  7891 KSP Residual norm 1.113720767031e-11
  7892 KSP Residual norm 1.204767631789e-11
  7893 KSP Residual norm 1.289200065017e-11
  7894 KSP Residual norm 1.320860382600e-11
  7895 KSP Residual norm 1.399824161279e-11
  7896 KSP Residual norm 1.469115783586e-11
  7897 KSP Residual norm 1.473593370287e-11
  7898 KSP Residual norm 1.393380094868e-11
  7899 KSP Residual norm 1.178410124308e-11
  7900 KSP Residual norm 8.910304061811e-12
  7901 KSP Residual norm 6.566265192993e-12
  7902 KSP Residual norm 5.586076066953e-12
  7903 KSP Residual norm 5.276727400867e-12
  7904 KSP Residual norm 5.117531607468e-12
  7905 KSP Residual norm 5.220524597794e-12
  7906 KSP Residual norm 5.342721926399e-12
  7907 KSP Residual norm 5.076932876238e-12
  7908 KSP Residual norm 5.304519670976e-12
  7909 KSP Residual norm 6.739179724009e-12
  7910 KSP Residual norm 7.325666906258e-12
  7911 KSP Residual norm 6.733763235157e-12
  7912 KSP Residual norm 6.657494039131e-12
  7913 KSP Residual norm 6.803225766968e-12
  7914 KSP Residual norm 6.643826895528e-12
  7915 KSP Residual norm 6.564552798759e-12
  7916 KSP Residual norm 7.341693900262e-12
  7917 KSP Residual norm 9.713852310020e-12
  7918 KSP Residual norm 1.186757678574e-11
  7919 KSP Residual norm 1.163176560036e-11
  7920 KSP Residual norm 1.135847783916e-11
  7921 KSP Residual norm 1.182153154053e-11
  7922 KSP Residual norm 1.126861489410e-11
  7923 KSP Residual norm 9.543896413281e-12
  7924 KSP Residual norm 7.843549213881e-12
  7925 KSP Residual norm 7.040592964766e-12
  7926 KSP Residual norm 7.677508166157e-12
  7927 KSP Residual norm 9.262357755254e-12
  7928 KSP Residual norm 1.195801258592e-11
  7929 KSP Residual norm 1.416725878977e-11
  7930 KSP Residual norm 1.306563770972e-11
  7931 KSP Residual norm 1.027706381659e-11
  7932 KSP Residual norm 8.040850887065e-12
  7933 KSP Residual norm 7.124505083435e-12
  7934 KSP Residual norm 7.410006059268e-12
  7935 KSP Residual norm 7.620910127014e-12
  7936 KSP Residual norm 7.849336006518e-12
  7937 KSP Residual norm 7.884924764024e-12
  7938 KSP Residual norm 6.495987930448e-12
  7939 KSP Residual norm 5.254171522024e-12
  7940 KSP Residual norm 4.916030986793e-12
  7941 KSP Residual norm 4.674730383977e-12
  7942 KSP Residual norm 4.177317722290e-12
  7943 KSP Residual norm 4.229636276450e-12
  7944 KSP Residual norm 4.447064106992e-12
  7945 KSP Residual norm 4.016284558496e-12
  7946 KSP Residual norm 3.399004555068e-12
  7947 KSP Residual norm 2.925716132915e-12
  7948 KSP Residual norm 2.681352377550e-12
  7949 KSP Residual norm 2.683251070188e-12
  7950 KSP Residual norm 2.896518606237e-12
  7951 KSP Residual norm 3.272749598375e-12
  7952 KSP Residual norm 3.626322637737e-12
  7953 KSP Residual norm 3.705552281445e-12
  7954 KSP Residual norm 4.009978920900e-12
  7955 KSP Residual norm 4.275209277911e-12
  7956 KSP Residual norm 3.940153698469e-12
  7957 KSP Residual norm 3.512922288189e-12
  7958 KSP Residual norm 3.310515827727e-12
  7959 KSP Residual norm 3.190213328370e-12
  7960 KSP Residual norm 3.064971593588e-12
  7961 KSP Residual norm 2.670529527490e-12
  7962 KSP Residual norm 2.374143926570e-12
  7963 KSP Residual norm 2.009678946199e-12
  7964 KSP Residual norm 1.622270523389e-12
  7965 KSP Residual norm 1.584229899985e-12
  7966 KSP Residual norm 1.716394211949e-12
  7967 KSP Residual norm 1.741954487196e-12
  7968 KSP Residual norm 1.755621534254e-12
  7969 KSP Residual norm 1.641362180726e-12
  7970 KSP Residual norm 1.509475214078e-12
  7971 KSP Residual norm 1.530487471655e-12
  7972 KSP Residual norm 1.674880207701e-12
  7973 KSP Residual norm 1.605266966311e-12
  7974 KSP Residual norm 1.345697942925e-12
  7975 KSP Residual norm 1.202589103502e-12
  7976 KSP Residual norm 1.099934917259e-12
  7977 KSP Residual norm 1.013188675224e-12
  7978 KSP Residual norm 9.343601955511e-13
  7979 KSP Residual norm 8.782463162755e-13
  7980 KSP Residual norm 8.605804962555e-13
  7981 KSP Residual norm 9.138108728857e-13
  7982 KSP Residual norm 9.777551890931e-13
  7983 KSP Residual norm 9.913794283619e-13
  7984 KSP Residual norm 1.014333466342e-12
  7985 KSP Residual norm 1.175022705198e-12
  7986 KSP Residual norm 1.401401319099e-12
  7987 KSP Residual norm 1.372645097225e-12
  7988 KSP Residual norm 1.323898065715e-12
  7989 KSP Residual norm 1.327322381726e-12
  7990 KSP Residual norm 1.253296314880e-12
  7991 KSP Residual norm 1.201725219056e-12
  7992 KSP Residual norm 1.122152981521e-12
  7993 KSP Residual norm 9.710536694927e-13
  7994 KSP Residual norm 9.215264443346e-13
  7995 KSP Residual norm 1.017896246923e-12
  7996 KSP Residual norm 1.257096323213e-12
  7997 KSP Residual norm 1.614134870187e-12
  7998 KSP Residual norm 1.855627493639e-12
  7999 KSP Residual norm 1.885458576993e-12
  8000 KSP Residual norm 2.139884322483e-12
  8001 KSP Residual norm 2.673016233258e-12
  8002 KSP Residual norm 2.983559220282e-12
  8003 KSP Residual norm 2.677070281132e-12
  8004 KSP Residual norm 1.822829859337e-12
  8005 KSP Residual norm 1.197124215835e-12
  8006 KSP Residual norm 9.752456159362e-13
  8007 KSP Residual norm 9.785369839400e-13
  8008 KSP Residual norm 1.113543967478e-12
  8009 KSP Residual norm 1.379898427374e-12
  8010 KSP Residual norm 1.634414421448e-12
  8011 KSP Residual norm 1.623444412048e-12
  8012 KSP Residual norm 1.268321271938e-12
  8013 KSP Residual norm 9.884295495442e-13
  8014 KSP Residual norm 9.309741894614e-13
  8015 KSP Residual norm 1.021804451680e-12
  8016 KSP Residual norm 1.262822718401e-12
  8017 KSP Residual norm 1.574048205884e-12
  8018 KSP Residual norm 1.759808816820e-12
  8019 KSP Residual norm 1.728531582622e-12
  8020 KSP Residual norm 1.780519534887e-12
  8021 KSP Residual norm 1.898972481400e-12
  8022 KSP Residual norm 1.889596667160e-12
  8023 KSP Residual norm 1.797026856460e-12
  8024 KSP Residual norm 1.608584819567e-12
  8025 KSP Residual norm 1.392816312184e-12
  8026 KSP Residual norm 1.318097428555e-12
  8027 KSP Residual norm 1.493552271679e-12
  8028 KSP Residual norm 1.803144730093e-12
  8029 KSP Residual norm 1.719955954569e-12
  8030 KSP Residual norm 1.475874723916e-12
  8031 KSP Residual norm 1.485049834374e-12
  8032 KSP Residual norm 1.612817844913e-12
  8033 KSP Residual norm 1.714087320936e-12
  8034 KSP Residual norm 1.568841981556e-12
  8035 KSP Residual norm 1.222833893556e-12
  8036 KSP Residual norm 1.020196364219e-12
  8037 KSP Residual norm 9.090304340421e-13
  8038 KSP Residual norm 8.194728285695e-13
  8039 KSP Residual norm 8.584096839161e-13
  8040 KSP Residual norm 1.002057423967e-12
  8041 KSP Residual norm 1.151958784094e-12
  8042 KSP Residual norm 1.053552251337e-12
  8043 KSP Residual norm 8.212272939747e-13
  8044 KSP Residual norm 6.923011369716e-13
  8045 KSP Residual norm 6.623208436709e-13
  8046 KSP Residual norm 5.569838144050e-13
  8047 KSP Residual norm 4.309526519913e-13
  8048 KSP Residual norm 4.038468888546e-13
  8049 KSP Residual norm 5.070270089244e-13
  8050 KSP Residual norm 6.723204128354e-13
  8051 KSP Residual norm 7.788304937448e-13
  8052 KSP Residual norm 8.111631043041e-13
  8053 KSP Residual norm 8.051158087207e-13
  8054 KSP Residual norm 7.340388919981e-13
  8055 KSP Residual norm 7.064015725695e-13
  8056 KSP Residual norm 7.933919697917e-13
  8057 KSP Residual norm 9.269044646518e-13
  8058 KSP Residual norm 1.036611383084e-12
  8059 KSP Residual norm 1.054537972585e-12
  8060 KSP Residual norm 9.248785347597e-13
  8061 KSP Residual norm 7.923800206360e-13
  8062 KSP Residual norm 7.723190159987e-13
  8063 KSP Residual norm 8.107652482237e-13
  8064 KSP Residual norm 7.993830323043e-13
  8065 KSP Residual norm 7.778097324870e-13
  8066 KSP Residual norm 7.787876941700e-13
  8067 KSP Residual norm 7.562126097712e-13
  8068 KSP Residual norm 7.381813070490e-13
  8069 KSP Residual norm 7.817379515344e-13
  8070 KSP Residual norm 7.574031303734e-13
  8071 KSP Residual norm 6.876131628293e-13
  8072 KSP Residual norm 6.484457046057e-13
  8073 KSP Residual norm 5.696931276987e-13
  8074 KSP Residual norm 5.104650707221e-13
  8075 KSP Residual norm 5.127984757632e-13
  8076 KSP Residual norm 5.588403353175e-13
  8077 KSP Residual norm 6.575025731760e-13
  8078 KSP Residual norm 7.453324460147e-13
  8079 KSP Residual norm 7.272748818496e-13
  8080 KSP Residual norm 6.902171712185e-13
  8081 KSP Residual norm 7.066495940395e-13
  8082 KSP Residual norm 7.341095052674e-13
  8083 KSP Residual norm 7.163685016603e-13
  8084 KSP Residual norm 6.883194278414e-13
  8085 KSP Residual norm 6.539457141140e-13
  8086 KSP Residual norm 6.639254231574e-13
  8087 KSP Residual norm 8.065304741115e-13
  8088 KSP Residual norm 1.044826950451e-12
  8089 KSP Residual norm 1.115620344863e-12
  8090 KSP Residual norm 1.038200614357e-12
  8091 KSP Residual norm 9.315098829633e-13
  8092 KSP Residual norm 8.754865886870e-13
  8093 KSP Residual norm 9.174340859188e-13
  8094 KSP Residual norm 1.073574194195e-12
  8095 KSP Residual norm 1.149977755839e-12
  8096 KSP Residual norm 1.151902659205e-12
  8097 KSP Residual norm 1.172319197797e-12
  8098 KSP Residual norm 1.225078270794e-12
  8099 KSP Residual norm 1.214177679110e-12
  8100 KSP Residual norm 1.150445829929e-12
  8101 KSP Residual norm 1.019631922200e-12
  8102 KSP Residual norm 8.312827010001e-13
  8103 KSP Residual norm 7.323322680565e-13
  8104 KSP Residual norm 7.572581345187e-13
  8105 KSP Residual norm 8.420066653727e-13
  8106 KSP Residual norm 9.313352164136e-13
  8107 KSP Residual norm 9.948774464440e-13
  8108 KSP Residual norm 9.790715846550e-13
  8109 KSP Residual norm 9.650043337563e-13
  8110 KSP Residual norm 1.070139922112e-12
  8111 KSP Residual norm 1.322517107858e-12
  8112 KSP Residual norm 1.480877874165e-12
  8113 KSP Residual norm 1.351890309275e-12
  8114 KSP Residual norm 1.220509523321e-12
  8115 KSP Residual norm 1.278567255544e-12
  8116 KSP Residual norm 1.447414903135e-12
  8117 KSP Residual norm 1.512467927993e-12
  8118 KSP Residual norm 1.642682460113e-12
  8119 KSP Residual norm 1.983707443032e-12
  8120 KSP Residual norm 2.326995850640e-12
  8121 KSP Residual norm 2.367967143096e-12
  8122 KSP Residual norm 2.339888470975e-12
  8123 KSP Residual norm 2.184205706366e-12
  8124 KSP Residual norm 1.917557257164e-12
  8125 KSP Residual norm 1.761664849400e-12
  8126 KSP Residual norm 1.572285837606e-12
  8127 KSP Residual norm 1.344709360689e-12
  8128 KSP Residual norm 1.315576153885e-12
  8129 KSP Residual norm 1.473564994016e-12
  8130 KSP Residual norm 1.559920455129e-12
  8131 KSP Residual norm 1.487102004701e-12
  8132 KSP Residual norm 1.609397047292e-12
  8133 KSP Residual norm 1.725551521641e-12
  8134 KSP Residual norm 1.680261315686e-12
  8135 KSP Residual norm 1.538745486822e-12
  8136 KSP Residual norm 1.434978433902e-12
  8137 KSP Residual norm 1.308049131431e-12
  8138 KSP Residual norm 1.217837377282e-12
  8139 KSP Residual norm 1.156082119591e-12
  8140 KSP Residual norm 1.151107178413e-12
  8141 KSP Residual norm 1.399939768660e-12
  8142 KSP Residual norm 1.839031600816e-12
  8143 KSP Residual norm 2.200809871839e-12
  8144 KSP Residual norm 2.387934265025e-12
  8145 KSP Residual norm 2.500847179119e-12
  8146 KSP Residual norm 2.442127961902e-12
  8147 KSP Residual norm 2.043933442923e-12
  8148 KSP Residual norm 1.695152254268e-12
  8149 KSP Residual norm 1.819506845898e-12
  8150 KSP Residual norm 2.518866712064e-12
  8151 KSP Residual norm 3.137372190680e-12
  8152 KSP Residual norm 3.101096862650e-12
  8153 KSP Residual norm 2.750105725947e-12
  8154 KSP Residual norm 2.618890149176e-12
  8155 KSP Residual norm 2.508969770101e-12
  8156 KSP Residual norm 2.467436884668e-12
  8157 KSP Residual norm 2.398156110246e-12
  8158 KSP Residual norm 2.243317638736e-12
  8159 KSP Residual norm 1.830892938751e-12
  8160 KSP Residual norm 1.398579258754e-12
  8161 KSP Residual norm 1.100084786758e-12
  8162 KSP Residual norm 9.134058518838e-13
  8163 KSP Residual norm 8.336424683903e-13
  8164 KSP Residual norm 8.190970957541e-13
  8165 KSP Residual norm 7.277540400607e-13
  8166 KSP Residual norm 6.999769390226e-13
  8167 KSP Residual norm 8.347416688425e-13
  8168 KSP Residual norm 1.201759870785e-12
  8169 KSP Residual norm 1.561329304463e-12
  8170 KSP Residual norm 1.614479453641e-12
  8171 KSP Residual norm 1.417896489359e-12
  8172 KSP Residual norm 1.152615456896e-12
  8173 KSP Residual norm 1.002346137129e-12
  8174 KSP Residual norm 9.861980167485e-13
  8175 KSP Residual norm 1.057163774224e-12
  8176 KSP Residual norm 1.258556480418e-12
  8177 KSP Residual norm 1.485661878687e-12
  8178 KSP Residual norm 1.590746004774e-12
  8179 KSP Residual norm 1.600979395383e-12
  8180 KSP Residual norm 1.479894841916e-12
  8181 KSP Residual norm 1.388200792382e-12
  8182 KSP Residual norm 1.394344749611e-12
  8183 KSP Residual norm 1.498108566389e-12
  8184 KSP Residual norm 1.757769752881e-12
  8185 KSP Residual norm 1.965337433307e-12
  8186 KSP Residual norm 2.247915825659e-12
  8187 KSP Residual norm 2.573939345220e-12
  8188 KSP Residual norm 2.603330186089e-12
  8189 KSP Residual norm 2.382818646396e-12
  8190 KSP Residual norm 2.140081728047e-12
  8191 KSP Residual norm 1.952611657219e-12
  8192 KSP Residual norm 1.894423805840e-12
  8193 KSP Residual norm 2.032502087180e-12
  8194 KSP Residual norm 2.164484238183e-12
  8195 KSP Residual norm 2.265511172813e-12
  8196 KSP Residual norm 2.386590667632e-12
  8197 KSP Residual norm 2.329994687168e-12
  8198 KSP Residual norm 2.309505448967e-12
  8199 KSP Residual norm 2.628059422235e-12
  8200 KSP Residual norm 2.988191469977e-12
  8201 KSP Residual norm 3.132221078510e-12
  8202 KSP Residual norm 2.756194794646e-12
  8203 KSP Residual norm 2.389600266342e-12
  8204 KSP Residual norm 2.137667035895e-12
  8205 KSP Residual norm 1.982397326790e-12
  8206 KSP Residual norm 1.982099737187e-12
  8207 KSP Residual norm 2.069831111011e-12
  8208 KSP Residual norm 1.959566378868e-12
  8209 KSP Residual norm 1.772085785483e-12
  8210 KSP Residual norm 1.542249079172e-12
  8211 KSP Residual norm 1.195562738267e-12
  8212 KSP Residual norm 1.034971216429e-12
  8213 KSP Residual norm 1.041684689984e-12
  8214 KSP Residual norm 1.117117581337e-12
  8215 KSP Residual norm 1.393121856906e-12
  8216 KSP Residual norm 1.641205915398e-12
  8217 KSP Residual norm 1.636923621079e-12
  8218 KSP Residual norm 1.533612857387e-12
  8219 KSP Residual norm 1.351348190075e-12
  8220 KSP Residual norm 1.195533391113e-12
  8221 KSP Residual norm 1.187885063644e-12
  8222 KSP Residual norm 1.266844419467e-12
  8223 KSP Residual norm 1.291137797956e-12
  8224 KSP Residual norm 1.377255263845e-12
  8225 KSP Residual norm 1.504056531048e-12
  8226 KSP Residual norm 1.592985999570e-12
  8227 KSP Residual norm 1.689024060472e-12
  8228 KSP Residual norm 1.721068522516e-12
  8229 KSP Residual norm 1.685105249767e-12
  8230 KSP Residual norm 1.653551274955e-12
  8231 KSP Residual norm 1.511328225197e-12
  8232 KSP Residual norm 1.236504033510e-12
  8233 KSP Residual norm 1.132945627086e-12
  8234 KSP Residual norm 1.293862582760e-12
  8235 KSP Residual norm 1.686000462282e-12
  8236 KSP Residual norm 2.224628072001e-12
  8237 KSP Residual norm 2.834533806054e-12
  8238 KSP Residual norm 3.199721239496e-12
  8239 KSP Residual norm 2.836800906916e-12
  8240 KSP Residual norm 2.389252694137e-12
  8241 KSP Residual norm 2.134628174016e-12
  8242 KSP Residual norm 1.834326576456e-12
  8243 KSP Residual norm 1.446339945710e-12
  8244 KSP Residual norm 1.140321990337e-12
  8245 KSP Residual norm 9.120866784871e-13
  8246 KSP Residual norm 7.942115879252e-13
  8247 KSP Residual norm 6.854572604145e-13
  8248 KSP Residual norm 5.749483812424e-13
  8249 KSP Residual norm 5.171656441685e-13
  8250 KSP Residual norm 5.027694121846e-13
  8251 KSP Residual norm 5.060452668351e-13
  8252 KSP Residual norm 5.337368357915e-13
  8253 KSP Residual norm 5.330211583895e-13
  8254 KSP Residual norm 4.518090526819e-13
  8255 KSP Residual norm 4.044333979336e-13
  8256 KSP Residual norm 4.393737964531e-13
  8257 KSP Residual norm 4.759895104176e-13
  8258 KSP Residual norm 4.587174501314e-13
  8259 KSP Residual norm 4.622509815619e-13
  8260 KSP Residual norm 5.422119805480e-13
  8261 KSP Residual norm 5.832620941009e-13
  8262 KSP Residual norm 5.077923890157e-13
  8263 KSP Residual norm 4.541075776876e-13
  8264 KSP Residual norm 4.630699529990e-13
  8265 KSP Residual norm 4.655272609549e-13
  8266 KSP Residual norm 4.607606252990e-13
  8267 KSP Residual norm 4.510032310869e-13
  8268 KSP Residual norm 4.475861572721e-13
  8269 KSP Residual norm 4.940501311665e-13
  8270 KSP Residual norm 5.711529598786e-13
  8271 KSP Residual norm 6.354844739706e-13
  8272 KSP Residual norm 6.648693609686e-13
  8273 KSP Residual norm 6.481003966630e-13
  8274 KSP Residual norm 5.555032756193e-13
  8275 KSP Residual norm 4.236819845889e-13
  8276 KSP Residual norm 3.394759670186e-13
  8277 KSP Residual norm 3.223995704607e-13
  8278 KSP Residual norm 3.126136972214e-13
  8279 KSP Residual norm 2.975270147178e-13
  8280 KSP Residual norm 2.891212621576e-13
  8281 KSP Residual norm 2.659339566703e-13
  8282 KSP Residual norm 2.393509607355e-13
  8283 KSP Residual norm 2.452091069469e-13
  8284 KSP Residual norm 2.812993023144e-13
  8285 KSP Residual norm 3.019938662643e-13
  8286 KSP Residual norm 3.151242685805e-13
  8287 KSP Residual norm 3.242607137484e-13
  8288 KSP Residual norm 3.056077913966e-13
  8289 KSP Residual norm 2.702738585250e-13
  8290 KSP Residual norm 2.316167684755e-13
  8291 KSP Residual norm 2.138971634700e-13
  8292 KSP Residual norm 2.311150074740e-13
  8293 KSP Residual norm 2.645523559141e-13
  8294 KSP Residual norm 2.997874712429e-13
  8295 KSP Residual norm 3.355843954387e-13
  8296 KSP Residual norm 3.740673010708e-13
  8297 KSP Residual norm 4.506391313262e-13
  8298 KSP Residual norm 5.264852459291e-13
  8299 KSP Residual norm 5.715946486913e-13
  8300 KSP Residual norm 6.512522269081e-13
  8301 KSP Residual norm 7.735164021159e-13
  8302 KSP Residual norm 7.804423445484e-13
  8303 KSP Residual norm 7.813830319672e-13
  8304 KSP Residual norm 8.873941741712e-13
  8305 KSP Residual norm 9.974409390370e-13
  8306 KSP Residual norm 1.055539553251e-12
  8307 KSP Residual norm 1.054537752517e-12
  8308 KSP Residual norm 1.032723865680e-12
  8309 KSP Residual norm 9.648069998665e-13
  8310 KSP Residual norm 8.559696918552e-13
  8311 KSP Residual norm 7.290193909546e-13
  8312 KSP Residual norm 5.950304431214e-13
  8313 KSP Residual norm 4.903383952342e-13
  8314 KSP Residual norm 4.654276559851e-13
  8315 KSP Residual norm 4.465587261480e-13
  8316 KSP Residual norm 4.415151525440e-13
  8317 KSP Residual norm 5.009685069177e-13
  8318 KSP Residual norm 6.155175422901e-13
  8319 KSP Residual norm 6.952799845996e-13
  8320 KSP Residual norm 6.236963999911e-13
  8321 KSP Residual norm 5.122203505722e-13
  8322 KSP Residual norm 4.341113310152e-13
  8323 KSP Residual norm 3.926896861018e-13
  8324 KSP Residual norm 3.596875313506e-13
  8325 KSP Residual norm 3.255875715250e-13
  8326 KSP Residual norm 3.101995463737e-13
  8327 KSP Residual norm 2.998340879713e-13
  8328 KSP Residual norm 2.671456691312e-13
  8329 KSP Residual norm 2.664925839220e-13
  8330 KSP Residual norm 3.040851663283e-13
  8331 KSP Residual norm 3.308877194804e-13
  8332 KSP Residual norm 3.424110377370e-13
  8333 KSP Residual norm 3.665467574051e-13
  8334 KSP Residual norm 3.955552087098e-13
  8335 KSP Residual norm 4.057969558244e-13
  8336 KSP Residual norm 3.840657174897e-13
  8337 KSP Residual norm 3.499084013917e-13
  8338 KSP Residual norm 3.309909719138e-13
  8339 KSP Residual norm 3.210015703765e-13
  8340 KSP Residual norm 3.157687381608e-13
  8341 KSP Residual norm 3.454224369747e-13
  8342 KSP Residual norm 3.738856455304e-13
  8343 KSP Residual norm 3.450309675304e-13
  8344 KSP Residual norm 3.223687680617e-13
  8345 KSP Residual norm 3.300095890291e-13
  8346 KSP Residual norm 3.465294930966e-13
  8347 KSP Residual norm 2.895022577537e-13
  8348 KSP Residual norm 2.037331316814e-13
  8349 KSP Residual norm 1.818053916577e-13
  8350 KSP Residual norm 1.960614682504e-13
  8351 KSP Residual norm 2.011334243858e-13
  8352 KSP Residual norm 1.948658713393e-13
  8353 KSP Residual norm 2.033774074032e-13
  8354 KSP Residual norm 2.192417301265e-13
  8355 KSP Residual norm 2.270960009964e-13
  8356 KSP Residual norm 2.302527608768e-13
  8357 KSP Residual norm 2.270616321346e-13
  8358 KSP Residual norm 2.131533812293e-13
  8359 KSP Residual norm 1.900315563741e-13
  8360 KSP Residual norm 1.942349552406e-13
  8361 KSP Residual norm 2.000119683424e-13
  8362 KSP Residual norm 1.907666035574e-13
  8363 KSP Residual norm 1.903994718762e-13
  8364 KSP Residual norm 1.772726314509e-13
  8365 KSP Residual norm 1.556371211117e-13
  8366 KSP Residual norm 1.528082863521e-13
  8367 KSP Residual norm 1.556075031018e-13
  8368 KSP Residual norm 1.384660601584e-13
  8369 KSP Residual norm 1.282052275832e-13
  8370 KSP Residual norm 1.322827468811e-13
  8371 KSP Residual norm 1.501475063106e-13
  8372 KSP Residual norm 1.671171953725e-13
  8373 KSP Residual norm 1.836399696109e-13
  8374 KSP Residual norm 1.922056817122e-13
  8375 KSP Residual norm 1.951382318169e-13
  8376 KSP Residual norm 1.867108164064e-13
  8377 KSP Residual norm 1.788188218203e-13
  8378 KSP Residual norm 1.792835454917e-13
  8379 KSP Residual norm 1.735013773520e-13
  8380 KSP Residual norm 1.775927004240e-13
  8381 KSP Residual norm 1.873438347067e-13
  8382 KSP Residual norm 1.950715563534e-13
  8383 KSP Residual norm 1.985548936050e-13
  8384 KSP Residual norm 1.932490177351e-13
  8385 KSP Residual norm 1.813686508648e-13
  8386 KSP Residual norm 1.764057626472e-13
  8387 KSP Residual norm 1.796394189888e-13
  8388 KSP Residual norm 1.877601612329e-13
  8389 KSP Residual norm 2.004648172069e-13
  8390 KSP Residual norm 2.132535888838e-13
  8391 KSP Residual norm 2.496329459044e-13
  8392 KSP Residual norm 2.946350506472e-13
  8393 KSP Residual norm 2.784442299417e-13
  8394 KSP Residual norm 2.573511040097e-13
  8395 KSP Residual norm 2.679713572541e-13
  8396 KSP Residual norm 2.657276068198e-13
  8397 KSP Residual norm 2.472969012217e-13
  8398 KSP Residual norm 2.146554861508e-13
  8399 KSP Residual norm 2.146956058580e-13
  8400 KSP Residual norm 2.445528075885e-13
  8401 KSP Residual norm 2.807214692594e-13
  8402 KSP Residual norm 2.902610227885e-13
  8403 KSP Residual norm 2.813612478459e-13
  8404 KSP Residual norm 2.860432277957e-13
  8405 KSP Residual norm 2.988213638997e-13
  8406 KSP Residual norm 3.129331460619e-13
  8407 KSP Residual norm 3.277691586118e-13
  8408 KSP Residual norm 3.407127580826e-13
  8409 KSP Residual norm 3.306655322212e-13
  8410 KSP Residual norm 2.728874127963e-13
  8411 KSP Residual norm 2.296420947113e-13
  8412 KSP Residual norm 2.173358805628e-13
  8413 KSP Residual norm 2.219782143548e-13
  8414 KSP Residual norm 2.218250373334e-13
  8415 KSP Residual norm 2.343565510491e-13
  8416 KSP Residual norm 2.700921579876e-13
  8417 KSP Residual norm 2.773238802448e-13
  8418 KSP Residual norm 2.691752501575e-13
  8419 KSP Residual norm 3.006501993058e-13
  8420 KSP Residual norm 3.556388342331e-13
  8421 KSP Residual norm 3.383152843170e-13
  8422 KSP Residual norm 3.076790615748e-13
  8423 KSP Residual norm 3.044366661059e-13
  8424 KSP Residual norm 2.756361778237e-13
  8425 KSP Residual norm 2.389033839092e-13
  8426 KSP Residual norm 2.218955391264e-13
  8427 KSP Residual norm 2.009783871767e-13
  8428 KSP Residual norm 1.672730551314e-13
  8429 KSP Residual norm 1.346088958959e-13
  8430 KSP Residual norm 1.183423281115e-13
  8431 KSP Residual norm 1.180449843232e-13
  8432 KSP Residual norm 1.267195177292e-13
  8433 KSP Residual norm 1.357801668150e-13
  8434 KSP Residual norm 1.431477689929e-13
  8435 KSP Residual norm 1.488773470594e-13
  8436 KSP Residual norm 1.557667436247e-13
  8437 KSP Residual norm 1.508720303563e-13
  8438 KSP Residual norm 1.349190712024e-13
  8439 KSP Residual norm 1.248977885361e-13
  8440 KSP Residual norm 1.273876372666e-13
  8441 KSP Residual norm 1.417274852468e-13
  8442 KSP Residual norm 1.469841945165e-13
  8443 KSP Residual norm 1.388222326761e-13
  8444 KSP Residual norm 1.202070080158e-13
  8445 KSP Residual norm 1.013114538943e-13
  8446 KSP Residual norm 8.950530423180e-14
  8447 KSP Residual norm 8.211625544193e-14
  8448 KSP Residual norm 7.934484802376e-14
  8449 KSP Residual norm 8.131190810159e-14
  8450 KSP Residual norm 8.059038010516e-14
  8451 KSP Residual norm 7.615315399224e-14
  8452 KSP Residual norm 8.161655005164e-14
  8453 KSP Residual norm 1.019702647576e-13
  8454 KSP Residual norm 1.196330905040e-13
  8455 KSP Residual norm 1.268762961525e-13
  8456 KSP Residual norm 1.246590080257e-13
  8457 KSP Residual norm 1.184480985419e-13
  8458 KSP Residual norm 1.090749305961e-13
  8459 KSP Residual norm 1.017654249623e-13
  8460 KSP Residual norm 1.076838500501e-13
  8461 KSP Residual norm 1.140911949995e-13
  8462 KSP Residual norm 1.042025556842e-13
  8463 KSP Residual norm 9.596354759382e-14
  8464 KSP Residual norm 9.963015233215e-14
  8465 KSP Residual norm 1.143839773312e-13
  8466 KSP Residual norm 1.231466483912e-13
  8467 KSP Residual norm 1.326512745683e-13
  8468 KSP Residual norm 1.560871848672e-13
  8469 KSP Residual norm 1.840497317850e-13
  8470 KSP Residual norm 2.061674137667e-13
  8471 KSP Residual norm 2.270657261907e-13
  8472 KSP Residual norm 2.762312561425e-13
  8473 KSP Residual norm 3.170217065494e-13
  8474 KSP Residual norm 3.419797080772e-13
  8475 KSP Residual norm 3.563274532794e-13
  8476 KSP Residual norm 3.680405460044e-13
  8477 KSP Residual norm 3.866743161952e-13
  8478 KSP Residual norm 3.735269525353e-13
  8479 KSP Residual norm 3.420680168814e-13
  8480 KSP Residual norm 3.332142457882e-13
  8481 KSP Residual norm 3.363593024330e-13
  8482 KSP Residual norm 3.498926112925e-13
  8483 KSP Residual norm 3.443397408087e-13
  8484 KSP Residual norm 3.346421092902e-13
  8485 KSP Residual norm 3.561770539033e-13
  8486 KSP Residual norm 3.819308611528e-13
  8487 KSP Residual norm 3.883194669158e-13
  8488 KSP Residual norm 4.065492681318e-13
  8489 KSP Residual norm 4.398594286480e-13
  8490 KSP Residual norm 4.518278562267e-13
  8491 KSP Residual norm 4.478425079308e-13
  8492 KSP Residual norm 4.695681719070e-13
  8493 KSP Residual norm 4.730865254946e-13
  8494 KSP Residual norm 4.250238104376e-13
  8495 KSP Residual norm 3.726722327838e-13
  8496 KSP Residual norm 3.546559878957e-13
  8497 KSP Residual norm 3.644870053439e-13
  8498 KSP Residual norm 3.482513708472e-13
  8499 KSP Residual norm 3.185485627429e-13
  8500 KSP Residual norm 3.125198312261e-13
  8501 KSP Residual norm 3.271221464307e-13
  8502 KSP Residual norm 3.290250078092e-13
  8503 KSP Residual norm 3.401866309664e-13
  8504 KSP Residual norm 3.838159984717e-13
  8505 KSP Residual norm 4.625047512261e-13
  8506 KSP Residual norm 4.565284830056e-13
  8507 KSP Residual norm 4.012131675105e-13
  8508 KSP Residual norm 4.128404480680e-13
  8509 KSP Residual norm 4.489041098766e-13
  8510 KSP Residual norm 4.231769952800e-13
  8511 KSP Residual norm 3.571035931853e-13
  8512 KSP Residual norm 3.205834838831e-13
  8513 KSP Residual norm 3.337867866494e-13
  8514 KSP Residual norm 3.548556536463e-13
  8515 KSP Residual norm 3.241773910396e-13
  8516 KSP Residual norm 2.950700574042e-13
  8517 KSP Residual norm 2.992010017558e-13
  8518 KSP Residual norm 3.068676913260e-13
  8519 KSP Residual norm 2.990993999671e-13
  8520 KSP Residual norm 2.958900157212e-13
  8521 KSP Residual norm 2.900841550226e-13
  8522 KSP Residual norm 2.677745316329e-13
  8523 KSP Residual norm 2.507247580348e-13
  8524 KSP Residual norm 2.538130320529e-13
  8525 KSP Residual norm 2.668841285740e-13
  8526 KSP Residual norm 2.431797321909e-13
  8527 KSP Residual norm 1.907190802272e-13
  8528 KSP Residual norm 1.635043152448e-13
  8529 KSP Residual norm 1.399058448554e-13
  8530 KSP Residual norm 1.165452232380e-13
  8531 KSP Residual norm 1.000788702929e-13
  8532 KSP Residual norm 9.339283202514e-14
  8533 KSP Residual norm 7.990730600194e-14
  8534 KSP Residual norm 6.492896622078e-14
  8535 KSP Residual norm 5.265444932396e-14
  8536 KSP Residual norm 4.793626058357e-14
  8537 KSP Residual norm 5.104386446335e-14
  8538 KSP Residual norm 5.546570399796e-14
  8539 KSP Residual norm 6.082810888450e-14
  8540 KSP Residual norm 7.027090485407e-14
  8541 KSP Residual norm 7.840082420585e-14
  8542 KSP Residual norm 8.540245120069e-14
  8543 KSP Residual norm 9.531584230949e-14
  8544 KSP Residual norm 1.036499891032e-13
  8545 KSP Residual norm 1.216415025774e-13
  8546 KSP Residual norm 1.428557015622e-13
  8547 KSP Residual norm 1.524756071051e-13
  8548 KSP Residual norm 1.562081036931e-13
  8549 KSP Residual norm 1.438908867589e-13
  8550 KSP Residual norm 1.248159937456e-13
  8551 KSP Residual norm 1.124555115609e-13
  8552 KSP Residual norm 1.076088136741e-13
  8553 KSP Residual norm 1.093169079845e-13
  8554 KSP Residual norm 1.237274147995e-13
  8555 KSP Residual norm 1.323041363020e-13
  8556 KSP Residual norm 1.332526005054e-13
  8557 KSP Residual norm 1.285115200543e-13
  8558 KSP Residual norm 1.358179404127e-13
  8559 KSP Residual norm 1.600312923102e-13
  8560 KSP Residual norm 1.820452284648e-13
  8561 KSP Residual norm 1.885836551875e-13
  8562 KSP Residual norm 2.044018756656e-13
  8563 KSP Residual norm 2.296485994941e-13
  8564 KSP Residual norm 2.238629035808e-13
  8565 KSP Residual norm 2.104952302935e-13
  8566 KSP Residual norm 1.875605877986e-13
  8567 KSP Residual norm 1.565332459613e-13
  8568 KSP Residual norm 1.441141565715e-13
  8569 KSP Residual norm 1.600276170039e-13
  8570 KSP Residual norm 1.795853550367e-13
  8571 KSP Residual norm 1.656892294009e-13
  8572 KSP Residual norm 1.399597564490e-13
  8573 KSP Residual norm 1.340190700339e-13
  8574 KSP Residual norm 1.400259553597e-13
  8575 KSP Residual norm 1.441243934368e-13
  8576 KSP Residual norm 1.436694245980e-13
  8577 KSP Residual norm 1.445441364226e-13
  8578 KSP Residual norm 1.446230720373e-13
  8579 KSP Residual norm 1.406874357620e-13
  8580 KSP Residual norm 1.406940045337e-13
  8581 KSP Residual norm 1.351802943770e-13
  8582 KSP Residual norm 1.182051549321e-13
  8583 KSP Residual norm 9.490533262949e-14
  8584 KSP Residual norm 8.760102841546e-14
  8585 KSP Residual norm 9.387450960201e-14
  8586 KSP Residual norm 1.012503902179e-13
  8587 KSP Residual norm 1.011575165831e-13
  8588 KSP Residual norm 8.484272185587e-14
  8589 KSP Residual norm 7.876273869965e-14
  8590 KSP Residual norm 9.114296793682e-14
  8591 KSP Residual norm 1.018388808177e-13
  8592 KSP Residual norm 9.547097044588e-14
  8593 KSP Residual norm 9.066068009183e-14
  8594 KSP Residual norm 9.996631442325e-14
  8595 KSP Residual norm 1.263578230878e-13
  8596 KSP Residual norm 1.417828034686e-13
  8597 KSP Residual norm 1.239188938073e-13
  8598 KSP Residual norm 1.038926748905e-13
  8599 KSP Residual norm 9.617256935683e-14
  8600 KSP Residual norm 8.907331146121e-14
  8601 KSP Residual norm 7.993871507715e-14
  8602 KSP Residual norm 7.531715888566e-14
  8603 KSP Residual norm 7.046139598548e-14
  8604 KSP Residual norm 6.416937851521e-14
  8605 KSP Residual norm 6.546029562239e-14
  8606 KSP Residual norm 7.469596314592e-14
  8607 KSP Residual norm 7.871379566721e-14
  8608 KSP Residual norm 7.306264421987e-14
  8609 KSP Residual norm 7.148305850669e-14
  8610 KSP Residual norm 7.508714352060e-14
  8611 KSP Residual norm 7.222328174457e-14
  8612 KSP Residual norm 6.345451591733e-14
  8613 KSP Residual norm 5.999260414904e-14
  8614 KSP Residual norm 6.157860270190e-14
  8615 KSP Residual norm 6.118946578782e-14
  8616 KSP Residual norm 5.560174485684e-14
  8617 KSP Residual norm 4.913556977464e-14
  8618 KSP Residual norm 4.699445555206e-14
  8619 KSP Residual norm 4.622291618863e-14
  8620 KSP Residual norm 4.685621138786e-14
  8621 KSP Residual norm 5.062017130644e-14
  8622 KSP Residual norm 5.034271911502e-14
  8623 KSP Residual norm 4.264454745684e-14
  8624 KSP Residual norm 3.680455223204e-14
  8625 KSP Residual norm 3.442926207987e-14
  8626 KSP Residual norm 3.523532462009e-14
  8627 KSP Residual norm 3.862504520275e-14
  8628 KSP Residual norm 3.861149607326e-14
  8629 KSP Residual norm 3.424867472188e-14
  8630 KSP Residual norm 3.193892357215e-14
  8631 KSP Residual norm 3.373034156009e-14
  8632 KSP Residual norm 3.662907252206e-14
  8633 KSP Residual norm 4.028224400079e-14
  8634 KSP Residual norm 4.327011857151e-14
  8635 KSP Residual norm 4.346908012663e-14
  8636 KSP Residual norm 4.451346079016e-14
  8637 KSP Residual norm 5.197100169204e-14
  8638 KSP Residual norm 6.542891077464e-14
  8639 KSP Residual norm 7.259991216566e-14
  8640 KSP Residual norm 7.604349606867e-14
  8641 KSP Residual norm 8.231662580420e-14
  8642 KSP Residual norm 8.804973267362e-14
  8643 KSP Residual norm 9.817998922852e-14
  8644 KSP Residual norm 1.047188920530e-13
  8645 KSP Residual norm 9.910059797992e-14
  8646 KSP Residual norm 9.892643146612e-14
  8647 KSP Residual norm 1.127014828315e-13
  8648 KSP Residual norm 1.208617116659e-13
  8649 KSP Residual norm 1.124213111310e-13
  8650 KSP Residual norm 1.021637348050e-13
  8651 KSP Residual norm 1.019379051815e-13
  8652 KSP Residual norm 1.024674940320e-13
  8653 KSP Residual norm 9.409010939044e-14
  8654 KSP Residual norm 8.731978373156e-14
  8655 KSP Residual norm 8.283059013558e-14
  8656 KSP Residual norm 7.344130489835e-14
  8657 KSP Residual norm 6.738169114549e-14
  8658 KSP Residual norm 7.115885343313e-14
  8659 KSP Residual norm 7.496571499094e-14
  8660 KSP Residual norm 7.712464829599e-14
  8661 KSP Residual norm 8.332897404540e-14
  8662 KSP Residual norm 8.739608065157e-14
  8663 KSP Residual norm 8.451267777934e-14
  8664 KSP Residual norm 8.203679503749e-14
  8665 KSP Residual norm 7.753699500762e-14
  8666 KSP Residual norm 7.146579495247e-14
  8667 KSP Residual norm 6.591030904723e-14
  8668 KSP Residual norm 6.201459877928e-14
  8669 KSP Residual norm 5.714344046839e-14
  8670 KSP Residual norm 5.538909724892e-14
  8671 KSP Residual norm 5.768302158340e-14
  8672 KSP Residual norm 5.843472110890e-14
  8673 KSP Residual norm 5.167936763068e-14
  8674 KSP Residual norm 4.546894501676e-14
  8675 KSP Residual norm 3.925125054481e-14
  8676 KSP Residual norm 3.409686080720e-14
  8677 KSP Residual norm 3.202680921189e-14
  8678 KSP Residual norm 3.012396253861e-14
  8679 KSP Residual norm 2.727748422958e-14
  8680 KSP Residual norm 2.434424661559e-14
  8681 KSP Residual norm 1.987638795779e-14
  8682 KSP Residual norm 1.718466449319e-14
  8683 KSP Residual norm 1.665717707003e-14
  8684 KSP Residual norm 1.430452593341e-14
  8685 KSP Residual norm 1.180072540018e-14
  8686 KSP Residual norm 1.084700575984e-14
  8687 KSP Residual norm 1.074124999293e-14
  8688 KSP Residual norm 1.024097118710e-14
  8689 KSP Residual norm 1.048741843336e-14
  8690 KSP Residual norm 1.155336843376e-14
  8691 KSP Residual norm 1.238949795935e-14
  8692 KSP Residual norm 1.173666777919e-14
  8693 KSP Residual norm 1.031443474719e-14
  8694 KSP Residual norm 1.073539529220e-14
  8695 KSP Residual norm 1.248031363200e-14
  8696 KSP Residual norm 1.278463355503e-14
  8697 KSP Residual norm 1.157327944716e-14
  8698 KSP Residual norm 1.080665085104e-14
  8699 KSP Residual norm 1.171996486813e-14
  8700 KSP Residual norm 1.345951575753e-14
  8701 KSP Residual norm 1.317802443636e-14
  8702 KSP Residual norm 1.165961273497e-14
  8703 KSP Residual norm 1.096820651287e-14
  8704 KSP Residual norm 1.131510800034e-14
  8705 KSP Residual norm 1.188587410254e-14
  8706 KSP Residual norm 1.187678464291e-14
  8707 KSP Residual norm 1.187679074295e-14
  8708 KSP Residual norm 1.208709807280e-14
  8709 KSP Residual norm 1.232913423542e-14
  8710 KSP Residual norm 1.443746341201e-14
  8711 KSP Residual norm 1.762957700338e-14
  8712 KSP Residual norm 1.819269772111e-14
  8713 KSP Residual norm 1.774275229551e-14
  8714 KSP Residual norm 1.862056024630e-14
  8715 KSP Residual norm 1.877968721430e-14
  8716 KSP Residual norm 1.921920762896e-14
  8717 KSP Residual norm 2.136114136039e-14
  8718 KSP Residual norm 2.218158455400e-14
  8719 KSP Residual norm 1.859455253929e-14
  8720 KSP Residual norm 1.754400506810e-14
  8721 KSP Residual norm 2.013118578087e-14
  8722 KSP Residual norm 2.165777540089e-14
  8723 KSP Residual norm 2.020956840178e-14
  8724 KSP Residual norm 1.878198346002e-14
  8725 KSP Residual norm 1.962434993947e-14
  8726 KSP Residual norm 1.934782853350e-14
  8727 KSP Residual norm 1.889784837639e-14
  8728 KSP Residual norm 1.937085417932e-14
  8729 KSP Residual norm 1.890586454918e-14
  8730 KSP Residual norm 1.680331544343e-14
  8731 KSP Residual norm 1.575829612372e-14
  8732 KSP Residual norm 1.624604132569e-14
  8733 KSP Residual norm 1.560739543694e-14
  8734 KSP Residual norm 1.444074106656e-14
  8735 KSP Residual norm 1.465278257090e-14
  8736 KSP Residual norm 1.540168121107e-14
  8737 KSP Residual norm 1.580668297260e-14
  8738 KSP Residual norm 1.517482744787e-14
  8739 KSP Residual norm 1.386739174802e-14
  8740 KSP Residual norm 1.331680514651e-14
  8741 KSP Residual norm 1.256538465282e-14
  8742 KSP Residual norm 1.118591383838e-14
  8743 KSP Residual norm 1.033085367057e-14
  8744 KSP Residual norm 1.043761596261e-14
  8745 KSP Residual norm 1.115946363289e-14
  8746 KSP Residual norm 1.125495560131e-14
  8747 KSP Residual norm 1.033512871241e-14
  8748 KSP Residual norm 1.002153151274e-14
  8749 KSP Residual norm 9.879064490278e-15
  8750 KSP Residual norm 9.053892684873e-15
  8751 KSP Residual norm 8.610835303500e-15
  8752 KSP Residual norm 8.704490350748e-15
  8753 KSP Residual norm 9.196900533833e-15
  8754 KSP Residual norm 1.018894347341e-14
  8755 KSP Residual norm 1.146294196113e-14
  8756 KSP Residual norm 1.288384924388e-14
  8757 KSP Residual norm 1.345408994646e-14
  8758 KSP Residual norm 1.304143052223e-14
  8759 KSP Residual norm 1.314860871431e-14
  8760 KSP Residual norm 1.496998720285e-14
  8761 KSP Residual norm 1.709119429479e-14
  8762 KSP Residual norm 1.795052786616e-14
  8763 KSP Residual norm 1.773489252126e-14
  8764 KSP Residual norm 1.654202482200e-14
  8765 KSP Residual norm 1.543822696459e-14
  8766 KSP Residual norm 1.486958094919e-14
  8767 KSP Residual norm 1.498048009560e-14
  8768 KSP Residual norm 1.487028654002e-14
  8769 KSP Residual norm 1.406630044857e-14
  8770 KSP Residual norm 1.370735514548e-14
  8771 KSP Residual norm 1.441103709090e-14
  8772 KSP Residual norm 1.533425175784e-14
  8773 KSP Residual norm 1.677915571019e-14
  8774 KSP Residual norm 1.993155113187e-14
  8775 KSP Residual norm 2.170375330715e-14
  8776 KSP Residual norm 2.246279236036e-14
  8777 KSP Residual norm 2.347671212867e-14
  8778 KSP Residual norm 2.277654373645e-14
  8779 KSP Residual norm 2.106399246114e-14
  8780 KSP Residual norm 2.096814844731e-14
  8781 KSP Residual norm 2.049385839792e-14
  8782 KSP Residual norm 1.922329473649e-14
  8783 KSP Residual norm 1.700886243592e-14
  8784 KSP Residual norm 1.664025819024e-14
  8785 KSP Residual norm 1.751872309889e-14
  8786 KSP Residual norm 1.835945772053e-14
  8787 KSP Residual norm 1.949913445228e-14
  8788 KSP Residual norm 1.996625080217e-14
  8789 KSP Residual norm 1.817150755202e-14
  8790 KSP Residual norm 1.641854498494e-14
  8791 KSP Residual norm 1.549381477432e-14
  8792 KSP Residual norm 1.514243528331e-14
  8793 KSP Residual norm 1.529299176116e-14
  8794 KSP Residual norm 1.566842493208e-14
  8795 KSP Residual norm 1.568647391629e-14
  8796 KSP Residual norm 1.494723376969e-14
  8797 KSP Residual norm 1.498803523162e-14
  8798 KSP Residual norm 1.457902670898e-14
  8799 KSP Residual norm 1.294181016884e-14
  8800 KSP Residual norm 1.175511496910e-14
  8801 KSP Residual norm 1.154778839303e-14
  8802 KSP Residual norm 1.106536804309e-14
  8803 KSP Residual norm 1.003965037799e-14
  8804 KSP Residual norm 9.987668774659e-15
  8805 KSP Residual norm 1.057946500537e-14
  8806 KSP Residual norm 1.002222444324e-14
  8807 KSP Residual norm 9.623630828757e-15
  8808 KSP Residual norm 9.604605164527e-15
  8809 KSP Residual norm 9.178977024342e-15
  8810 KSP Residual norm 8.348084108334e-15
  8811 KSP Residual norm 8.179063654940e-15
  8812 KSP Residual norm 8.973260312549e-15
  8813 KSP Residual norm 8.703065094894e-15
  8814 KSP Residual norm 7.242523503854e-15
  8815 KSP Residual norm 6.772760753434e-15
  8816 KSP Residual norm 7.016907167108e-15
  8817 KSP Residual norm 7.252161166635e-15
  8818 KSP Residual norm 7.463683648768e-15
  8819 KSP Residual norm 7.498714403759e-15
  8820 KSP Residual norm 7.698537521435e-15
  8821 KSP Residual norm 8.213535115422e-15
  8822 KSP Residual norm 9.059527406983e-15
  8823 KSP Residual norm 9.640454855390e-15
  8824 KSP Residual norm 9.757479821798e-15
  8825 KSP Residual norm 1.026126776132e-14
  8826 KSP Residual norm 1.036726609718e-14
  8827 KSP Residual norm 9.741517662450e-15
  8828 KSP Residual norm 9.379205026806e-15
  8829 KSP Residual norm 1.037064089200e-14
  8830 KSP Residual norm 1.131064386495e-14
  8831 KSP Residual norm 1.135933346408e-14
  8832 KSP Residual norm 1.099244123038e-14
  8833 KSP Residual norm 1.112298227967e-14
  8834 KSP Residual norm 1.121364450892e-14
  8835 KSP Residual norm 1.139829165979e-14
  8836 KSP Residual norm 1.169793391332e-14
  8837 KSP Residual norm 1.217132007593e-14
  8838 KSP Residual norm 1.223414342704e-14
  8839 KSP Residual norm 1.258441318921e-14
  8840 KSP Residual norm 1.323877123723e-14
  8841 KSP Residual norm 1.238418863507e-14
  8842 KSP Residual norm 1.065435689660e-14
  8843 KSP Residual norm 9.881081031366e-15
  8844 KSP Residual norm 1.024852262342e-14
  8845 KSP Residual norm 1.094989227899e-14
  8846 KSP Residual norm 1.245888556657e-14
  8847 KSP Residual norm 1.350037595501e-14
  8848 KSP Residual norm 1.268852794129e-14
  8849 KSP Residual norm 1.207361231109e-14
  8850 KSP Residual norm 1.202048643532e-14
  8851 KSP Residual norm 1.226860055066e-14
  8852 KSP Residual norm 1.348736045677e-14
  8853 KSP Residual norm 1.511157637832e-14
  8854 KSP Residual norm 1.687810779425e-14
  8855 KSP Residual norm 1.927901028133e-14
  8856 KSP Residual norm 2.065271654792e-14
  8857 KSP Residual norm 1.794856147899e-14
  8858 KSP Residual norm 1.440987660868e-14
  8859 KSP Residual norm 1.276158968853e-14
  8860 KSP Residual norm 1.375092796871e-14
  8861 KSP Residual norm 1.525866366352e-14
  8862 KSP Residual norm 1.599326827412e-14
  8863 KSP Residual norm 1.610744724426e-14
  8864 KSP Residual norm 1.536287380873e-14
  8865 KSP Residual norm 1.469392464952e-14
  8866 KSP Residual norm 1.445534071351e-14
  8867 KSP Residual norm 1.436634173723e-14
  8868 KSP Residual norm 1.460923031049e-14
  8869 KSP Residual norm 1.419028858542e-14
  8870 KSP Residual norm 1.271112104762e-14
  8871 KSP Residual norm 1.210272826236e-14
  8872 KSP Residual norm 1.279156054071e-14
  8873 KSP Residual norm 1.312402512524e-14
  8874 KSP Residual norm 1.277007349662e-14
  8875 KSP Residual norm 1.186399922799e-14
  8876 KSP Residual norm 1.178869955505e-14
  8877 KSP Residual norm 1.268822347283e-14
  8878 KSP Residual norm 1.306614121278e-14
  8879 KSP Residual norm 1.234436505561e-14
  8880 KSP Residual norm 1.226474062278e-14
  8881 KSP Residual norm 1.274249868150e-14
  8882 KSP Residual norm 1.285071498186e-14
  8883 KSP Residual norm 1.206928049289e-14
  8884 KSP Residual norm 1.091491078995e-14
  8885 KSP Residual norm 1.096668142721e-14
  8886 KSP Residual norm 1.068746539458e-14
  8887 KSP Residual norm 9.523687549370e-15
  8888 KSP Residual norm 9.247326697468e-15
  8889 KSP Residual norm 9.315941869623e-15
  8890 KSP Residual norm 7.952570878562e-15
  8891 KSP Residual norm 7.035984444996e-15
  8892 KSP Residual norm 7.251641147823e-15
  8893 KSP Residual norm 7.695983612195e-15
  8894 KSP Residual norm 7.000988406685e-15
  8895 KSP Residual norm 6.055835978860e-15
  8896 KSP Residual norm 6.297276122771e-15
  8897 KSP Residual norm 7.234659542297e-15
  8898 KSP Residual norm 7.172537973014e-15
  8899 KSP Residual norm 6.405434091962e-15
  8900 KSP Residual norm 6.250291359564e-15
  8901 KSP Residual norm 5.750225127069e-15
  8902 KSP Residual norm 5.284662380638e-15
  8903 KSP Residual norm 5.261609882521e-15
  8904 KSP Residual norm 5.696115691171e-15
  8905 KSP Residual norm 6.320460084061e-15
  8906 KSP Residual norm 6.884268215719e-15
  8907 KSP Residual norm 7.149209246252e-15
  8908 KSP Residual norm 7.114554065318e-15
  8909 KSP Residual norm 6.727903511753e-15
  8910 KSP Residual norm 7.573724141107e-15
  8911 KSP Residual norm 9.010537046846e-15
  8912 KSP Residual norm 8.385283632852e-15
  8913 KSP Residual norm 7.520416004430e-15
  8914 KSP Residual norm 7.960049664770e-15
  8915 KSP Residual norm 8.224844817960e-15
  8916 KSP Residual norm 7.623232044115e-15
  8917 KSP Residual norm 6.919478459129e-15
  8918 KSP Residual norm 7.407511461985e-15
  8919 KSP Residual norm 9.330339280863e-15
  8920 KSP Residual norm 1.078368860718e-14
  8921 KSP Residual norm 9.747358216959e-15
  8922 KSP Residual norm 8.742521545317e-15
  8923 KSP Residual norm 8.511576740553e-15
  8924 KSP Residual norm 8.623508010105e-15
  8925 KSP Residual norm 9.433690895103e-15
  8926 KSP Residual norm 9.818833375390e-15
  8927 KSP Residual norm 9.201673946696e-15
  8928 KSP Residual norm 9.598143661961e-15
  8929 KSP Residual norm 1.176379488067e-14
  8930 KSP Residual norm 1.461274234568e-14
  8931 KSP Residual norm 1.653579579934e-14
  8932 KSP Residual norm 1.726319292678e-14
  8933 KSP Residual norm 1.870952211470e-14
  8934 KSP Residual norm 1.974419151246e-14
  8935 KSP Residual norm 1.955741886984e-14
  8936 KSP Residual norm 2.046747032718e-14
  8937 KSP Residual norm 2.111863372193e-14
  8938 KSP Residual norm 1.973036776111e-14
  8939 KSP Residual norm 2.059281667903e-14
  8940 KSP Residual norm 2.249590635709e-14
  8941 KSP Residual norm 2.172468393985e-14
  8942 KSP Residual norm 1.896209442106e-14
  8943 KSP Residual norm 1.765859548911e-14
  8944 KSP Residual norm 1.957374972482e-14
  8945 KSP Residual norm 2.097392755704e-14
  8946 KSP Residual norm 1.866119447746e-14
  8947 KSP Residual norm 1.756509148359e-14
  8948 KSP Residual norm 1.768796917415e-14
  8949 KSP Residual norm 1.820464295976e-14
  8950 KSP Residual norm 1.805093321840e-14
  8951 KSP Residual norm 1.669096910997e-14
  8952 KSP Residual norm 1.411472566716e-14
  8953 KSP Residual norm 1.304670457303e-14
  8954 KSP Residual norm 1.456473150874e-14
  8955 KSP Residual norm 1.651236721887e-14
  8956 KSP Residual norm 1.706104882254e-14
  8957 KSP Residual norm 1.686843029418e-14
  8958 KSP Residual norm 1.641811831399e-14
  8959 KSP Residual norm 1.691051342056e-14
  8960 KSP Residual norm 1.752345970383e-14
  8961 KSP Residual norm 1.836755618696e-14
  8962 KSP Residual norm 1.685636613914e-14
  8963 KSP Residual norm 1.562909309529e-14
  8964 KSP Residual norm 1.699092125143e-14
  8965 KSP Residual norm 1.749848952793e-14
  8966 KSP Residual norm 1.622379457013e-14
  8967 KSP Residual norm 1.512175700354e-14
  8968 KSP Residual norm 1.432231421952e-14
  8969 KSP Residual norm 1.495803721460e-14
  8970 KSP Residual norm 1.560733825782e-14
  8971 KSP Residual norm 1.470415609682e-14
  8972 KSP Residual norm 1.608568830670e-14
  8973 KSP Residual norm 1.972246578404e-14
  8974 KSP Residual norm 1.940715219800e-14
  8975 KSP Residual norm 1.890238444260e-14
  8976 KSP Residual norm 2.184350860414e-14
  8977 KSP Residual norm 2.495288701931e-14
  8978 KSP Residual norm 2.584611051453e-14
  8979 KSP Residual norm 2.631889186258e-14
  8980 KSP Residual norm 2.887818621735e-14
  8981 KSP Residual norm 3.031781266390e-14
  8982 KSP Residual norm 3.099501634965e-14
  8983 KSP Residual norm 3.337193565137e-14
  8984 KSP Residual norm 3.604888670668e-14
  8985 KSP Residual norm 3.422700664338e-14
  8986 KSP Residual norm 3.169611554186e-14
  8987 KSP Residual norm 3.249986401150e-14
  8988 KSP Residual norm 3.337388498119e-14
  8989 KSP Residual norm 3.155772394763e-14
  8990 KSP Residual norm 3.110333506560e-14
  8991 KSP Residual norm 2.986413089251e-14
  8992 KSP Residual norm 2.819675561971e-14
  8993 KSP Residual norm 2.835108541859e-14
  8994 KSP Residual norm 2.765734465347e-14
  8995 KSP Residual norm 2.474814988021e-14
  8996 KSP Residual norm 2.421404945453e-14
  8997 KSP Residual norm 2.825044061797e-14
  8998 KSP Residual norm 3.162010715682e-14
  8999 KSP Residual norm 2.991389376550e-14
  9000 KSP Residual norm 2.790937429058e-14
  9001 KSP Residual norm 2.758770041169e-14
  9002 KSP Residual norm 2.733546317060e-14
  9003 KSP Residual norm 2.697166561733e-14
  9004 KSP Residual norm 2.770373043105e-14
  9005 KSP Residual norm 2.669473798794e-14
  9006 KSP Residual norm 2.580110323446e-14
  9007 KSP Residual norm 2.619909425318e-14
  9008 KSP Residual norm 2.362024016404e-14
  9009 KSP Residual norm 2.084082140914e-14
  9010 KSP Residual norm 2.081073341714e-14
  9011 KSP Residual norm 2.189275046618e-14
  9012 KSP Residual norm 2.301954646717e-14
  9013 KSP Residual norm 2.335721662552e-14
  9014 KSP Residual norm 2.435375698914e-14
  9015 KSP Residual norm 2.397367370062e-14
  9016 KSP Residual norm 1.940577445610e-14
  9017 KSP Residual norm 1.604111462853e-14
  9018 KSP Residual norm 1.585958908101e-14
  9019 KSP Residual norm 1.485206789485e-14
  9020 KSP Residual norm 1.408127289502e-14
  9021 KSP Residual norm 1.447662039715e-14
  9022 KSP Residual norm 1.464301870951e-14
  9023 KSP Residual norm 1.528565685550e-14
  9024 KSP Residual norm 1.718835359540e-14
  9025 KSP Residual norm 1.726963002001e-14
  9026 KSP Residual norm 1.605533501647e-14
  9027 KSP Residual norm 1.562186088963e-14
  9028 KSP Residual norm 1.594901880003e-14
  9029 KSP Residual norm 1.648985738136e-14
  9030 KSP Residual norm 1.689194371157e-14
  9031 KSP Residual norm 1.642938479848e-14
  9032 KSP Residual norm 1.496966823412e-14
  9033 KSP Residual norm 1.406602301415e-14
  9034 KSP Residual norm 1.699475747468e-14
  9035 KSP Residual norm 2.214253669930e-14
  9036 KSP Residual norm 2.250991094688e-14
  9037 KSP Residual norm 2.090216990873e-14
  9038 KSP Residual norm 2.129473081338e-14
  9039 KSP Residual norm 2.074779888403e-14
  9040 KSP Residual norm 2.035233897199e-14
  9041 KSP Residual norm 2.190691680588e-14
  9042 KSP Residual norm 2.458512304794e-14
  9043 KSP Residual norm 2.553511960597e-14
  9044 KSP Residual norm 2.556805736793e-14
  9045 KSP Residual norm 2.556132450190e-14
  9046 KSP Residual norm 2.609892300526e-14
  9047 KSP Residual norm 2.686735347674e-14
  9048 KSP Residual norm 3.062068057759e-14
  9049 KSP Residual norm 3.714287928313e-14
  9050 KSP Residual norm 3.244144252901e-14
  9051 KSP Residual norm 2.988574511825e-14
  9052 KSP Residual norm 3.261444744494e-14
  9053 KSP Residual norm 3.072401316275e-14
  9054 KSP Residual norm 2.842795510307e-14
  9055 KSP Residual norm 2.901684730075e-14
  9056 KSP Residual norm 2.960755938724e-14
  9057 KSP Residual norm 2.822473125595e-14
  9058 KSP Residual norm 2.657957948117e-14
  9059 KSP Residual norm 2.641505588529e-14
  9060 KSP Residual norm 2.551827271115e-14
  9061 KSP Residual norm 2.508189675249e-14
  9062 KSP Residual norm 2.847389072290e-14
  9063 KSP Residual norm 2.980177503820e-14
  9064 KSP Residual norm 2.859435769666e-14
  9065 KSP Residual norm 2.838810177800e-14
  9066 KSP Residual norm 2.558367466202e-14
  9067 KSP Residual norm 2.079442300253e-14
  9068 KSP Residual norm 1.747365396742e-14
  9069 KSP Residual norm 1.555703372582e-14
  9070 KSP Residual norm 1.488009968560e-14
  9071 KSP Residual norm 1.591812273997e-14
  9072 KSP Residual norm 1.935283826421e-14
  9073 KSP Residual norm 2.476368447326e-14
  9074 KSP Residual norm 2.753915532880e-14
  9075 KSP Residual norm 2.886273878870e-14
  9076 KSP Residual norm 3.146221075189e-14
  9077 KSP Residual norm 3.649104733418e-14
  9078 KSP Residual norm 4.122381977352e-14
  9079 KSP Residual norm 4.674835105953e-14
  9080 KSP Residual norm 4.797235780612e-14
  9081 KSP Residual norm 4.482029327996e-14
  9082 KSP Residual norm 4.295373190427e-14
  9083 KSP Residual norm 4.707831028348e-14
  9084 KSP Residual norm 4.850152590168e-14
  9085 KSP Residual norm 4.833778798741e-14
  9086 KSP Residual norm 5.286350455295e-14
  9087 KSP Residual norm 5.497131544752e-14
  9088 KSP Residual norm 4.920180036102e-14
  9089 KSP Residual norm 4.467218058711e-14
  9090 KSP Residual norm 4.433426365228e-14
  9091 KSP Residual norm 4.344062692086e-14
  9092 KSP Residual norm 3.999178928395e-14
  9093 KSP Residual norm 3.684631706162e-14
  9094 KSP Residual norm 3.685894431913e-14
  9095 KSP Residual norm 3.735851584260e-14
  9096 KSP Residual norm 3.529244404479e-14
  9097 KSP Residual norm 2.995081079752e-14
  9098 KSP Residual norm 2.709008670932e-14
  9099 KSP Residual norm 2.818760955285e-14
  9100 KSP Residual norm 3.006552211564e-14
  9101 KSP Residual norm 3.167253650890e-14
  9102 KSP Residual norm 3.410953005694e-14
  9103 KSP Residual norm 3.513131299874e-14
  9104 KSP Residual norm 3.251118195865e-14
  9105 KSP Residual norm 3.176371801433e-14
  9106 KSP Residual norm 3.146676133950e-14
  9107 KSP Residual norm 2.918589321127e-14
  9108 KSP Residual norm 2.744164462872e-14
  9109 KSP Residual norm 2.569106006511e-14
  9110 KSP Residual norm 2.199208274094e-14
  9111 KSP Residual norm 2.041029952702e-14
  9112 KSP Residual norm 2.141585663651e-14
  9113 KSP Residual norm 2.041415974760e-14
  9114 KSP Residual norm 1.674049769935e-14
  9115 KSP Residual norm 1.468328851750e-14
  9116 KSP Residual norm 1.482691280602e-14
  9117 KSP Residual norm 1.381029273695e-14
  9118 KSP Residual norm 1.245313185533e-14
  9119 KSP Residual norm 1.368500948985e-14
  9120 KSP Residual norm 1.585221259816e-14
  9121 KSP Residual norm 1.547417221770e-14
  9122 KSP Residual norm 1.426151909889e-14
  9123 KSP Residual norm 1.537889273253e-14
  9124 KSP Residual norm 1.682305681553e-14
  9125 KSP Residual norm 1.621638493318e-14
  9126 KSP Residual norm 1.590524338620e-14
  9127 KSP Residual norm 1.665983243967e-14
  9128 KSP Residual norm 1.703691825908e-14
  9129 KSP Residual norm 1.791998077936e-14
  9130 KSP Residual norm 1.919904179678e-14
  9131 KSP Residual norm 1.848156517240e-14
  9132 KSP Residual norm 1.640358708024e-14
  9133 KSP Residual norm 1.522187623252e-14
  9134 KSP Residual norm 1.474313206749e-14
  9135 KSP Residual norm 1.388154432692e-14
  9136 KSP Residual norm 1.250687425702e-14
  9137 KSP Residual norm 1.099224317057e-14
  9138 KSP Residual norm 1.002650652787e-14
  9139 KSP Residual norm 9.826049051255e-15
  9140 KSP Residual norm 1.070088531298e-14
  9141 KSP Residual norm 1.173089906026e-14
  9142 KSP Residual norm 1.146829286258e-14
  9143 KSP Residual norm 1.039461000358e-14
  9144 KSP Residual norm 9.692603247354e-15
  9145 KSP Residual norm 9.574539119198e-15
  9146 KSP Residual norm 9.648678192672e-15
  9147 KSP Residual norm 9.932575189238e-15
  9148 KSP Residual norm 1.060530261667e-14
  9149 KSP Residual norm 1.176791188983e-14
  9150 KSP Residual norm 1.287784315386e-14
  9151 KSP Residual norm 1.290976145607e-14
  9152 KSP Residual norm 1.333395631183e-14
  9153 KSP Residual norm 1.298414114579e-14
  9154 KSP Residual norm 1.198336383732e-14
  9155 KSP Residual norm 1.207402048986e-14
  9156 KSP Residual norm 1.200828413916e-14
  9157 KSP Residual norm 1.070755788239e-14
  9158 KSP Residual norm 9.488127030292e-15
  9159 KSP Residual norm 9.111340395373e-15
  9160 KSP Residual norm 1.003427645318e-14
  9161 KSP Residual norm 1.092576661592e-14
  9162 KSP Residual norm 1.116362534981e-14
  9163 KSP Residual norm 1.136277123437e-14
  9164 KSP Residual norm 1.070234967248e-14
  9165 KSP Residual norm 9.414286209489e-15
  9166 KSP Residual norm 9.631035784247e-15
  9167 KSP Residual norm 1.042780656958e-14
  9168 KSP Residual norm 9.402011974727e-15
  9169 KSP Residual norm 8.737090706628e-15
  9170 KSP Residual norm 9.008898568264e-15
  9171 KSP Residual norm 8.840942359011e-15
  9172 KSP Residual norm 8.041660576649e-15
  9173 KSP Residual norm 7.576075368878e-15
  9174 KSP Residual norm 8.233120887949e-15
  9175 KSP Residual norm 9.147104210363e-15
  9176 KSP Residual norm 9.296264354106e-15
  9177 KSP Residual norm 8.303171561636e-15
  9178 KSP Residual norm 7.429452435568e-15
  9179 KSP Residual norm 7.075806974472e-15
  9180 KSP Residual norm 7.196274996196e-15
  9181 KSP Residual norm 7.587936655192e-15
  9182 KSP Residual norm 7.642439011473e-15
  9183 KSP Residual norm 7.748025350579e-15
  9184 KSP Residual norm 7.308392772232e-15
  9185 KSP Residual norm 6.690661423926e-15
  9186 KSP Residual norm 6.985758204799e-15
  9187 KSP Residual norm 7.853148695577e-15
  9188 KSP Residual norm 8.321947504989e-15
  9189 KSP Residual norm 8.481750637914e-15
  9190 KSP Residual norm 8.442815520063e-15
  9191 KSP Residual norm 8.762575493196e-15
  9192 KSP Residual norm 8.860001713959e-15
  9193 KSP Residual norm 8.823972676293e-15
  9194 KSP Residual norm 8.953485662489e-15
  9195 KSP Residual norm 8.956904691112e-15
  9196 KSP Residual norm 8.755709650688e-15
  9197 KSP Residual norm 8.456855447792e-15
  9198 KSP Residual norm 8.025838514180e-15
  9199 KSP Residual norm 8.436859520175e-15
  9200 KSP Residual norm 9.662073545465e-15
  9201 KSP Residual norm 1.010995341077e-14
  9202 KSP Residual norm 1.036473079521e-14
  9203 KSP Residual norm 1.085357450650e-14
  9204 KSP Residual norm 1.128587907408e-14
  9205 KSP Residual norm 1.219676744220e-14
  9206 KSP Residual norm 1.232748730930e-14
  9207 KSP Residual norm 1.116674511441e-14
  9208 KSP Residual norm 1.110599756682e-14
  9209 KSP Residual norm 1.212785252882e-14
  9210 KSP Residual norm 1.334271816050e-14
  9211 KSP Residual norm 1.310895905220e-14
  9212 KSP Residual norm 1.284409200849e-14
  9213 KSP Residual norm 1.479260812639e-14
  9214 KSP Residual norm 1.612835470600e-14
  9215 KSP Residual norm 1.531213493541e-14
  9216 KSP Residual norm 1.587925962076e-14
  9217 KSP Residual norm 1.664244097840e-14
  9218 KSP Residual norm 1.568387231177e-14
  9219 KSP Residual norm 1.585020901221e-14
  9220 KSP Residual norm 1.817576387880e-14
  9221 KSP Residual norm 1.930950232843e-14
  9222 KSP Residual norm 1.908890428552e-14
  9223 KSP Residual norm 1.838840156265e-14
  9224 KSP Residual norm 1.727969132184e-14
  9225 KSP Residual norm 1.604343819332e-14
  9226 KSP Residual norm 1.502938197736e-14
  9227 KSP Residual norm 1.501069094124e-14
  9228 KSP Residual norm 1.508267702412e-14
  9229 KSP Residual norm 1.380868858610e-14
  9230 KSP Residual norm 1.194122881044e-14
  9231 KSP Residual norm 9.697318830659e-15
  9232 KSP Residual norm 7.956261436143e-15
  9233 KSP Residual norm 7.181112906066e-15
  9234 KSP Residual norm 6.646189007872e-15
  9235 KSP Residual norm 6.164703554689e-15
  9236 KSP Residual norm 5.749769792037e-15
  9237 KSP Residual norm 5.439301076373e-15
  9238 KSP Residual norm 4.905301298865e-15
  9239 KSP Residual norm 4.498767596433e-15
  9240 KSP Residual norm 4.150029782386e-15
  9241 KSP Residual norm 3.759020714171e-15
  9242 KSP Residual norm 4.024717814437e-15
  9243 KSP Residual norm 4.540688225080e-15
  9244 KSP Residual norm 4.815711851291e-15
  9245 KSP Residual norm 4.851345107199e-15
  9246 KSP Residual norm 4.824949481016e-15
  9247 KSP Residual norm 4.291523609310e-15
  9248 KSP Residual norm 3.774057032606e-15
  9249 KSP Residual norm 3.823016631081e-15
  9250 KSP Residual norm 4.339072800663e-15
  9251 KSP Residual norm 4.275158111314e-15
  9252 KSP Residual norm 3.961837473205e-15
  9253 KSP Residual norm 3.836138464604e-15
  9254 KSP Residual norm 3.784722460005e-15
  9255 KSP Residual norm 3.411223019952e-15
  9256 KSP Residual norm 2.991952667593e-15
  9257 KSP Residual norm 2.738904410644e-15
  9258 KSP Residual norm 2.531742666309e-15
  9259 KSP Residual norm 2.667527805970e-15
  9260 KSP Residual norm 2.892797566513e-15
  9261 KSP Residual norm 2.659602008808e-15
  9262 KSP Residual norm 2.498732315075e-15
  9263 KSP Residual norm 2.678558934355e-15
  9264 KSP Residual norm 2.798150118860e-15
  9265 KSP Residual norm 2.754133427213e-15
  9266 KSP Residual norm 2.866800460238e-15
  9267 KSP Residual norm 3.386645589945e-15
  9268 KSP Residual norm 4.505681691060e-15
  9269 KSP Residual norm 5.685520563306e-15
  9270 KSP Residual norm 6.546617694284e-15
  9271 KSP Residual norm 6.727377549918e-15
  9272 KSP Residual norm 6.780230159595e-15
  9273 KSP Residual norm 7.608845894131e-15
  9274 KSP Residual norm 8.034192807295e-15
  9275 KSP Residual norm 6.927346833155e-15
  9276 KSP Residual norm 6.256926873401e-15
  9277 KSP Residual norm 6.097451819555e-15
  9278 KSP Residual norm 5.702929616655e-15
  9279 KSP Residual norm 4.850560824207e-15
  9280 KSP Residual norm 4.320008177558e-15
  9281 KSP Residual norm 4.292423202500e-15
  9282 KSP Residual norm 4.560619115856e-15
  9283 KSP Residual norm 4.578470888297e-15
  9284 KSP Residual norm 4.104728302685e-15
  9285 KSP Residual norm 3.694990390643e-15
  9286 KSP Residual norm 3.667272930671e-15
  9287 KSP Residual norm 4.133102156304e-15
  9288 KSP Residual norm 4.831207220009e-15
  9289 KSP Residual norm 5.118727505834e-15
  9290 KSP Residual norm 4.956211601906e-15
  9291 KSP Residual norm 4.373262262468e-15
  9292 KSP Residual norm 3.942507517194e-15
  9293 KSP Residual norm 4.266329523068e-15
  9294 KSP Residual norm 4.583313596032e-15
  9295 KSP Residual norm 4.620580515393e-15
  9296 KSP Residual norm 4.440135739395e-15
  9297 KSP Residual norm 3.953372395305e-15
  9298 KSP Residual norm 3.928297130420e-15
  9299 KSP Residual norm 4.615832020086e-15
  9300 KSP Residual norm 5.012487447065e-15
  9301 KSP Residual norm 4.415552098678e-15
  9302 KSP Residual norm 4.175672646589e-15
  9303 KSP Residual norm 4.634801659910e-15
  9304 KSP Residual norm 4.826727148862e-15
  9305 KSP Residual norm 4.670505690115e-15
  9306 KSP Residual norm 4.976120201915e-15
  9307 KSP Residual norm 5.643258175217e-15
  9308 KSP Residual norm 5.782585587664e-15
  9309 KSP Residual norm 5.277085203613e-15
  9310 KSP Residual norm 5.372754034031e-15
  9311 KSP Residual norm 5.683540113337e-15
  9312 KSP Residual norm 5.935417856865e-15
  9313 KSP Residual norm 6.778883902737e-15
  9314 KSP Residual norm 7.352511041029e-15
  9315 KSP Residual norm 7.023774329350e-15
  9316 KSP Residual norm 7.033227455306e-15
  9317 KSP Residual norm 8.240253049080e-15
  9318 KSP Residual norm 9.579702059610e-15
  9319 KSP Residual norm 9.783197471875e-15
  9320 KSP Residual norm 1.017048546594e-14
  9321 KSP Residual norm 1.067111214849e-14
  9322 KSP Residual norm 9.051507749121e-15
  9323 KSP Residual norm 7.257339962734e-15
  9324 KSP Residual norm 6.476919993810e-15
  9325 KSP Residual norm 6.273585577315e-15
  9326 KSP Residual norm 5.996433467446e-15
  9327 KSP Residual norm 5.598551090688e-15
  9328 KSP Residual norm 5.274000479849e-15
  9329 KSP Residual norm 5.405237315381e-15
  9330 KSP Residual norm 5.562755656629e-15
  9331 KSP Residual norm 5.169209145677e-15
  9332 KSP Residual norm 4.020484530917e-15
  9333 KSP Residual norm 3.072491242952e-15
  9334 KSP Residual norm 2.701492726092e-15
  9335 KSP Residual norm 2.523437810801e-15
  9336 KSP Residual norm 2.254036010295e-15
  9337 KSP Residual norm 2.083474106549e-15
  9338 KSP Residual norm 2.284223245844e-15
  9339 KSP Residual norm 2.968961542976e-15
  9340 KSP Residual norm 3.816882185534e-15
  9341 KSP Residual norm 4.422432095500e-15
  9342 KSP Residual norm 4.015585887103e-15
  9343 KSP Residual norm 3.729822740431e-15
  9344 KSP Residual norm 3.773624481319e-15
  9345 KSP Residual norm 3.565607962606e-15
  9346 KSP Residual norm 3.636584688026e-15
  9347 KSP Residual norm 4.599220162259e-15
  9348 KSP Residual norm 6.343880823929e-15
  9349 KSP Residual norm 7.427256855945e-15
  9350 KSP Residual norm 6.949301136188e-15
  9351 KSP Residual norm 6.537950992119e-15
  9352 KSP Residual norm 6.535442229061e-15
  9353 KSP Residual norm 6.535928572811e-15
  9354 KSP Residual norm 6.841432435220e-15
  9355 KSP Residual norm 6.920516747553e-15
  9356 KSP Residual norm 6.210851190673e-15
  9357 KSP Residual norm 5.596805012535e-15
  9358 KSP Residual norm 5.285696165821e-15
  9359 KSP Residual norm 4.537075188035e-15
  9360 KSP Residual norm 3.829795786015e-15
  9361 KSP Residual norm 3.892639061230e-15
  9362 KSP Residual norm 4.217753444146e-15
  9363 KSP Residual norm 4.141273012190e-15
  9364 KSP Residual norm 4.344146665933e-15
  9365 KSP Residual norm 5.426382716396e-15
  9366 KSP Residual norm 7.070009409216e-15
  9367 KSP Residual norm 8.258356113262e-15
  9368 KSP Residual norm 8.343133239166e-15
  9369 KSP Residual norm 7.184856711875e-15
  9370 KSP Residual norm 5.927947992869e-15
  9371 KSP Residual norm 5.794138596608e-15
  9372 KSP Residual norm 6.204234792181e-15
  9373 KSP Residual norm 6.086624595408e-15
  9374 KSP Residual norm 6.041251917018e-15
  9375 KSP Residual norm 6.184545030143e-15
  9376 KSP Residual norm 5.381881932556e-15
  9377 KSP Residual norm 4.624335308162e-15
  9378 KSP Residual norm 4.608374030844e-15
  9379 KSP Residual norm 4.683555690121e-15
  9380 KSP Residual norm 4.325274469553e-15
  9381 KSP Residual norm 4.051423949426e-15
  9382 KSP Residual norm 3.966628221781e-15
  9383 KSP Residual norm 3.821614145293e-15
  9384 KSP Residual norm 3.412218000237e-15
  9385 KSP Residual norm 3.042866090395e-15
  9386 KSP Residual norm 2.598407307620e-15
  9387 KSP Residual norm 2.428677272833e-15
  9388 KSP Residual norm 2.665805839101e-15
  9389 KSP Residual norm 2.887329257590e-15
  9390 KSP Residual norm 2.810487912914e-15
  9391 KSP Residual norm 2.872604043281e-15
  9392 KSP Residual norm 3.258462231653e-15
  9393 KSP Residual norm 3.464523929580e-15
  9394 KSP Residual norm 3.477114082596e-15
  9395 KSP Residual norm 3.301689995227e-15
  9396 KSP Residual norm 2.935536245869e-15
  9397 KSP Residual norm 2.815172961856e-15
  9398 KSP Residual norm 2.952424510427e-15
  9399 KSP Residual norm 2.891376838884e-15
  9400 KSP Residual norm 2.874560325878e-15
  9401 KSP Residual norm 3.181173291875e-15
  9402 KSP Residual norm 3.473289597162e-15
  9403 KSP Residual norm 3.435544229353e-15
  9404 KSP Residual norm 3.250031573428e-15
  9405 KSP Residual norm 2.947420673821e-15
  9406 KSP Residual norm 2.698221073014e-15
  9407 KSP Residual norm 2.761758417515e-15
  9408 KSP Residual norm 3.107285739791e-15
  9409 KSP Residual norm 3.242450260512e-15
  9410 KSP Residual norm 2.835452207108e-15
  9411 KSP Residual norm 2.725229525769e-15
  9412 KSP Residual norm 2.999659951835e-15
  9413 KSP Residual norm 3.313086391514e-15
  9414 KSP Residual norm 3.412628779280e-15
  9415 KSP Residual norm 3.298460931724e-15
  9416 KSP Residual norm 3.504251126746e-15
  9417 KSP Residual norm 4.113389991233e-15
  9418 KSP Residual norm 4.684097247310e-15
  9419 KSP Residual norm 5.340611767575e-15
  9420 KSP Residual norm 5.528828542720e-15
  9421 KSP Residual norm 5.289784054583e-15
  9422 KSP Residual norm 5.429881082465e-15
  9423 KSP Residual norm 5.123190827200e-15
  9424 KSP Residual norm 4.648981763593e-15
  9425 KSP Residual norm 4.599540553773e-15
  9426 KSP Residual norm 5.045822739977e-15
  9427 KSP Residual norm 5.615436896525e-15
  9428 KSP Residual norm 5.401328506369e-15
  9429 KSP Residual norm 5.013789897722e-15
  9430 KSP Residual norm 5.212374508155e-15
  9431 KSP Residual norm 5.539280225525e-15
  9432 KSP Residual norm 5.861276415591e-15
  9433 KSP Residual norm 5.927535248764e-15
  9434 KSP Residual norm 6.094461453616e-15
  9435 KSP Residual norm 6.432453643655e-15
  9436 KSP Residual norm 6.577149234847e-15
  9437 KSP Residual norm 6.139211944649e-15
  9438 KSP Residual norm 5.624503984129e-15
  9439 KSP Residual norm 5.186142526477e-15
  9440 KSP Residual norm 5.342347471701e-15
  9441 KSP Residual norm 6.160515923416e-15
  9442 KSP Residual norm 6.442266581885e-15
  9443 KSP Residual norm 5.700610207676e-15
  9444 KSP Residual norm 4.998833225428e-15
  9445 KSP Residual norm 4.818082390822e-15
  9446 KSP Residual norm 5.224432767968e-15
  9447 KSP Residual norm 5.701363226785e-15
  9448 KSP Residual norm 5.829861749495e-15
  9449 KSP Residual norm 5.975384690231e-15
  9450 KSP Residual norm 5.790037362985e-15
  9451 KSP Residual norm 5.401432228377e-15
  9452 KSP Residual norm 5.298904407184e-15
  9453 KSP Residual norm 5.462202059568e-15
  9454 KSP Residual norm 5.553505369169e-15
  9455 KSP Residual norm 5.356570179269e-15
  9456 KSP Residual norm 5.192547895170e-15
  9457 KSP Residual norm 5.117701871839e-15
  9458 KSP Residual norm 5.391242782896e-15
  9459 KSP Residual norm 5.859874365962e-15
  9460 KSP Residual norm 6.238241606020e-15
  9461 KSP Residual norm 6.815147817997e-15
  9462 KSP Residual norm 7.429067744481e-15
  9463 KSP Residual norm 6.843679843867e-15
  9464 KSP Residual norm 5.706600222302e-15
  9465 KSP Residual norm 5.323346966792e-15
  9466 KSP Residual norm 5.652342475115e-15
  9467 KSP Residual norm 6.571747815066e-15
  9468 KSP Residual norm 7.162647618738e-15
  9469 KSP Residual norm 7.280177154589e-15
  9470 KSP Residual norm 7.465523254279e-15
  9471 KSP Residual norm 7.391928076386e-15
  9472 KSP Residual norm 6.853717416991e-15
  9473 KSP Residual norm 7.004398308309e-15
  9474 KSP Residual norm 8.367016310898e-15
  9475 KSP Residual norm 1.077917293783e-14
  9476 KSP Residual norm 1.238879214507e-14
  9477 KSP Residual norm 1.278339700700e-14
  9478 KSP Residual norm 1.262766796661e-14
  9479 KSP Residual norm 1.199376308310e-14
  9480 KSP Residual norm 1.099912828807e-14
  9481 KSP Residual norm 1.064226699286e-14
  9482 KSP Residual norm 1.121970625467e-14
  9483 KSP Residual norm 1.204791553451e-14
  9484 KSP Residual norm 1.289007318565e-14
  9485 KSP Residual norm 1.348512220343e-14
  9486 KSP Residual norm 1.281259550366e-14
  9487 KSP Residual norm 1.108446307686e-14
  9488 KSP Residual norm 1.110466677621e-14
  9489 KSP Residual norm 1.259904105420e-14
  9490 KSP Residual norm 1.300508290565e-14
  9491 KSP Residual norm 1.284155607738e-14
  9492 KSP Residual norm 1.302649221525e-14
  9493 KSP Residual norm 1.267328360459e-14
  9494 KSP Residual norm 1.158891283398e-14
  9495 KSP Residual norm 1.144916302415e-14
  9496 KSP Residual norm 1.198792031339e-14
  9497 KSP Residual norm 1.171087883064e-14
  9498 KSP Residual norm 1.162774118158e-14
  9499 KSP Residual norm 1.191506955211e-14
  9500 KSP Residual norm 1.260471360130e-14
  9501 KSP Residual norm 1.384489559443e-14
  9502 KSP Residual norm 1.602845064113e-14
  9503 KSP Residual norm 1.656411148524e-14
  9504 KSP Residual norm 1.450948165696e-14
  9505 KSP Residual norm 1.273576977428e-14
  9506 KSP Residual norm 1.146352641729e-14
  9507 KSP Residual norm 9.694883209962e-15
  9508 KSP Residual norm 9.920906643356e-15
  9509 KSP Residual norm 1.151017413016e-14
  9510 KSP Residual norm 1.134193899613e-14
  9511 KSP Residual norm 9.095923536439e-15
  9512 KSP Residual norm 7.692353038209e-15
  9513 KSP Residual norm 7.338127664650e-15
  9514 KSP Residual norm 7.157550473650e-15
  9515 KSP Residual norm 7.069409735135e-15
  9516 KSP Residual norm 6.899057770678e-15
  9517 KSP Residual norm 6.314944196615e-15
  9518 KSP Residual norm 5.597123312520e-15
  9519 KSP Residual norm 5.088391788599e-15
  9520 KSP Residual norm 5.459350955952e-15
  9521 KSP Residual norm 5.851061056375e-15
  9522 KSP Residual norm 6.314638008870e-15
  9523 KSP Residual norm 7.087487190274e-15
  9524 KSP Residual norm 7.453901122470e-15
  9525 KSP Residual norm 7.564568608633e-15
  9526 KSP Residual norm 7.588635222121e-15
  9527 KSP Residual norm 8.101367014585e-15
  9528 KSP Residual norm 8.379831153973e-15
  9529 KSP Residual norm 8.436373553752e-15
  9530 KSP Residual norm 8.410827741007e-15
  9531 KSP Residual norm 8.254941567261e-15
  9532 KSP Residual norm 7.869633293819e-15
  9533 KSP Residual norm 7.357025716922e-15
  9534 KSP Residual norm 6.625838223723e-15
  9535 KSP Residual norm 5.190383406704e-15
  9536 KSP Residual norm 4.471977567772e-15
  9537 KSP Residual norm 4.513505169152e-15
  9538 KSP Residual norm 4.528567693562e-15
  9539 KSP Residual norm 4.556358245389e-15
  9540 KSP Residual norm 4.706018153538e-15
  9541 KSP Residual norm 4.685527140507e-15
  9542 KSP Residual norm 4.519803093931e-15
  9543 KSP Residual norm 3.978093751583e-15
  9544 KSP Residual norm 3.598207305460e-15
  9545 KSP Residual norm 3.570426886893e-15
  9546 KSP Residual norm 3.699987757989e-15
  9547 KSP Residual norm 3.848249594558e-15
  9548 KSP Residual norm 4.031728150645e-15
  9549 KSP Residual norm 3.814091787717e-15
  9550 KSP Residual norm 3.176014359424e-15
  9551 KSP Residual norm 2.646392634344e-15
  9552 KSP Residual norm 2.555185228114e-15
  9553 KSP Residual norm 2.680290311956e-15
  9554 KSP Residual norm 2.790000732818e-15
  9555 KSP Residual norm 2.864679007364e-15
  9556 KSP Residual norm 3.082030513089e-15
  9557 KSP Residual norm 3.359513114761e-15
  9558 KSP Residual norm 3.345548371493e-15
  9559 KSP Residual norm 2.932733533164e-15
  9560 KSP Residual norm 2.439387077592e-15
  9561 KSP Residual norm 2.125121401864e-15
  9562 KSP Residual norm 2.091257379569e-15
  9563 KSP Residual norm 2.273408167429e-15
  9564 KSP Residual norm 2.443968727645e-15
  9565 KSP Residual norm 2.412180047832e-15
  9566 KSP Residual norm 2.434514540146e-15
  9567 KSP Residual norm 2.539242314509e-15
  9568 KSP Residual norm 2.535329264580e-15
  9569 KSP Residual norm 2.479050492618e-15
  9570 KSP Residual norm 2.419681336614e-15
  9571 KSP Residual norm 2.302608339316e-15
  9572 KSP Residual norm 1.938508221947e-15
  9573 KSP Residual norm 1.541476556155e-15
  9574 KSP Residual norm 1.176917049061e-15
  3 KSP Residual norm 2.680497175260e-04
KSP Object: 1 MPI processes
  type: cg
  maximum iterations=1000
  tolerances:  relative=1e-06, absolute=1e-50, divergence=10000.
  left preconditioning
  using nonzero initial guess
  using PRECONDITIONED norm type for convergence test
PC Object: 1 MPI processes
  type: fieldsplit
    FieldSplit with Schur preconditioner, factorization FULL
    Preconditioner for the Schur complement formed from A11
    Split info:
    Split number 0 Defined by IS
    Split number 1 Defined by IS
    KSP solver for A00 block
      KSP Object:      (fieldsplit_RB_split_)       1 MPI processes
        type: preonly
        maximum iterations=10000, initial guess is zero
        tolerances:  relative=1e-05, absolute=1e-50, divergence=10000.
        using NONE norm type for convergence test
      PC Object:      (fieldsplit_RB_split_)       1 MPI processes
        type: cholesky
          Cholesky: out-of-place factorization
          tolerance for zero pivot 2.22045e-14
          matrix ordering: natural
          factor fill ratio given 0., needed 0.
            Factored matrix follows:
              Mat Object:               1 MPI processes
                type: seqaij
                rows=324, cols=324
                package used to perform factorization: mumps
                total: nonzeros=3042, allocated nonzeros=3042
                total number of mallocs used during MatSetValues calls =0
                  MUMPS run parameters:
                    SYM (matrix type):                   2
                    PAR (host participation):            1
                    ICNTL(1) (output for error):         6
                    ICNTL(2) (output of diagnostic msg): 0
                    ICNTL(3) (output for global info):   0
                    ICNTL(4) (level of printing):        0
                    ICNTL(5) (input mat struct):         0
                    ICNTL(6) (matrix prescaling):        7
                    ICNTL(7) (sequentia matrix ordering):7
                    ICNTL(8) (scalling strategy):        77
                    ICNTL(10) (max num of refinements):  0
                    ICNTL(11) (error analysis):          0
                    ICNTL(12) (efficiency control):                         0
                    ICNTL(13) (efficiency control):                         0
                    ICNTL(14) (percentage of estimated workspace increase): 20
                    ICNTL(18) (input mat struct):                           0
                    ICNTL(19) (Shur complement info):                       0
                    ICNTL(20) (rhs sparse pattern):                         0
                    ICNTL(21) (solution struct):                            0
                    ICNTL(22) (in-core/out-of-core facility):               0
                    ICNTL(23) (max size of memory can be allocated locally):0
                    ICNTL(24) (detection of null pivot rows):               0
                    ICNTL(25) (computation of a null space basis):          0
                    ICNTL(26) (Schur options for rhs or solution):          0
                    ICNTL(27) (experimental parameter):                     -24
                    ICNTL(28) (use parallel or sequential ordering):        1
                    ICNTL(29) (parallel ordering):                          0
                    ICNTL(30) (user-specified set of entries in inv(A)):    0
                    ICNTL(31) (factors is discarded in the solve phase):    0
                    ICNTL(33) (compute determinant):                        0
                    CNTL(1) (relative pivoting threshold):      0.01
                    CNTL(2) (stopping criterion of refinement): 1.49012e-08
                    CNTL(3) (absolute pivoting threshold):      0.
                    CNTL(4) (value of static pivoting):         -1.
                    CNTL(5) (fixation for null pivots):         0.
                    RINFO(1) (local estimated flops for the elimination after analysis):
                      [0] 29394.
                    RINFO(2) (local estimated flops for the assembly after factorization):
                      [0]  1092.
                    RINFO(3) (local estimated flops for the elimination after factorization):
                      [0]  29394.
                    INFO(15) (estimated size of (in MB) MUMPS internal data for running numerical factorization):
                    [0] 1
                    INFO(16) (size of (in MB) MUMPS internal data used during numerical factorization):
                      [0] 1
                    INFO(23) (num of pivots eliminated on this processor after factorization):
                      [0] 324
                    RINFOG(1) (global estimated flops for the elimination after analysis): 29394.
                    RINFOG(2) (global estimated flops for the assembly after factorization): 1092.
                    RINFOG(3) (global estimated flops for the elimination after factorization): 29394.
                    (RINFOG(12) RINFOG(13))*2^INFOG(34) (determinant): (0.,0.)*(2^0)
                    INFOG(3) (estimated real workspace for factors on all processors after analysis): 3888
                    INFOG(4) (estimated integer workspace for factors on all processors after analysis): 2067
                    INFOG(5) (estimated maximum front size in the complete tree): 12
                    INFOG(6) (number of nodes in the complete tree): 53
                    INFOG(7) (ordering option effectively use after analysis): 2
                    INFOG(8) (structural symmetry in percent of the permuted matrix after analysis): 100
                    INFOG(9) (total real/complex workspace to store the matrix factors after factorization): 3888
                    INFOG(10) (total integer space store the matrix factors after factorization): 2067
                    INFOG(11) (order of largest frontal matrix after factorization): 12
                    INFOG(12) (number of off-diagonal pivots): 0
                    INFOG(13) (number of delayed pivots after factorization): 0
                    INFOG(14) (number of memory compress after factorization): 0
                    INFOG(15) (number of steps of iterative refinement after solution): 0
                    INFOG(16) (estimated size (in MB) of all MUMPS internal data for factorization after analysis: value on the most memory consuming processor): 1
                    INFOG(17) (estimated size of all MUMPS internal data for factorization after analysis: sum over all processors): 1
                    INFOG(18) (size of all MUMPS internal data allocated during factorization: value on the most memory consuming processor): 1
                    INFOG(19) (size of all MUMPS internal data allocated during factorization: sum over all processors): 1
                    INFOG(20) (estimated number of entries in the factors): 3042
                    INFOG(21) (size in MB of memory effectively used during factorization - value on the most memory consuming processor): 1
                    INFOG(22) (size in MB of memory effectively used during factorization - sum over all processors): 1
                    INFOG(23) (after analysis: value of ICNTL(6) effectively used): 5
                    INFOG(24) (after analysis: value of ICNTL(12) effectively used): 1
                    INFOG(25) (after factorization: number of pivots modified by static pivoting): 0
                    INFOG(28) (after factorization: number of null pivots encountered): 0
                    INFOG(29) (after factorization: effective number of entries in the factors (sum over all processors)): 3042
                    INFOG(30, 31) (after solution: size in Mbytes of memory used during solution phase): 0, 0
                    INFOG(32) (after analysis: type of analysis done): 1
                    INFOG(33) (value used for ICNTL(8)): -2
                    INFOG(34) (exponent of the determinant if determinant is requested): 0
        linear system matrix = precond matrix:
        Mat Object:        (fieldsplit_RB_split_)         1 MPI processes
          type: seqaij
          rows=324, cols=324
          total: nonzeros=5760, allocated nonzeros=5760
            using I-node routines: found 108 nodes, limit used is 5
    KSP solver for S = A11 - A10 inv(A00) A01
      KSP Object:      (fieldsplit_FE_split_)       1 MPI processes
        type: cg
      PC Object:      (fieldsplit_FE_split_)       1 MPI processes
        type: bjacobi
          block Jacobi: number of blocks = 1
          Local solve is same for all blocks, in the following KSP and PC objects:
          KSP Object:          (fieldsplit_FE_split_sub_)           1 MPI processes
            type: preonly
          PC Object:          (fieldsplit_FE_split_sub_)           1 MPI processes
            type: ilu
              ILU: out-of-place factorization
              0 levels of fill
              factor fill ratio given 1., needed 1.
                    type: seqaij
                    rows=28476, cols=28476
                    package used to perform factorization: petsc
                    total: nonzeros=1017054, allocated nonzeros=1017054
                      using I-node routines: found 9492 nodes, limit used is 5
            Mat Object:            (fieldsplit_FE_split_)             1 MPI processes
              type: seqaij
        linear system matrix followed by preconditioner matrix:
          type: schurcomplement
            Schur complement A11 - A10 inv(A00) A01
            A11
                type: seqaij
            A10
                type: seqaij
                rows=28476, cols=324
                total: nonzeros=936, allocated nonzeros=936
                  using I-node routines: found 5717 nodes, limit used is 5
            KSP of A00
                type: preonly
                type: cholesky
                        type: seqaij
                        rows=324, cols=324
                              [0] 29394.
                              [0]  1092.
                              [0]  29394.
                            [0] 1
                              [0] 1
                              [0] 324
                  type: seqaij
                  rows=324, cols=324
            A01
                type: seqaij
                rows=324, cols=28476
                  using I-node routines: found 67 nodes, limit used is 5
          type: seqaij
  Mat Object:  ()   1 MPI processes
    type: seqaij
    rows=28800, cols=28800
    total: nonzeros=1024686, allocated nonzeros=1024794
      using I-node routines: found 9600 nodes, limit used is 5
---------------------------------------------- PETSc Performance Summary: ----------------------------------------------
/home/dknez/akselos-dev/scrbe/build/bin/fe_solver-opt_real on a arch-linux2-c-opt named david-Lenovo with 1 processor, by dknez Wed Jan 11 20:39:53 2017
Using Petsc Release Version 3.7.3, unknown
                         Max       Max/Min        Avg      Total
Time (sec):           1.040e+02      1.00000   1.040e+02
Objects:              1.990e+02      1.00000   1.990e+02
Flops:                1.634e+11      1.00000   1.634e+11  1.634e+11
Flops/sec:            1.571e+09      1.00000   1.571e+09  1.571e+09
MPI Messages:         0.000e+00      0.00000   0.000e+00  0.000e+00
MPI Message Lengths:  0.000e+00      0.00000   0.000e+00  0.000e+00
MPI Reductions:       0.000e+00      0.00000
Flop counting convention: 1 flop = 1 real number operation of type (multiply/divide/add/subtract)
                            e.g., VecAXPY() for real vectors of length N --> 2N flops
                            and VecAXPY() for complex vectors of length N --> 8N flops
Summary of Stages:   ----- Time ------  ----- Flops -----  --- Messages ---  -- Message Lengths --  -- Reductions --
                        Avg     %Total     Avg     %Total   counts   %Total     Avg         %Total   counts   %Total
 0:      Main Stage: 1.0396e+02 100.0%  1.6336e+11 100.0%  0.000e+00   0.0%  0.000e+00        0.0%  0.000e+00   0.0%
See the 'Profiling' chapter of the users' manual for details on interpreting output.
Phase summary info:
   Count: number of times phase was executed
   Time and Flops: Max - maximum over all processors
                   Ratio - ratio of maximum to minimum over all processors
   Mess: number of messages sent
   Avg. len: average message length (bytes)
   Reduct: number of global reductions
   Global: entire computation
   Stage: stages of a computation. Set stages with PetscLogStagePush() and PetscLogStagePop().
      %T - percent time in this phase         %F - percent flops in this phase
      %M - percent messages in this phase     %L - percent message lengths in this phase
      %R - percent reductions in this phase
   Total Mflop/s: 10e-6 * (sum of flops over all processors)/(max time over all processors)
Event                Count      Time (sec)     Flops                             --- Global ---  --- Stage ---   Total
                   Max Ratio  Max     Ratio   Max  Ratio  Mess   Avg len Reduct  %T %F %M %L %R  %T %F %M %L %R Mflop/s
--- Event Stage 0: Main Stage
VecDot                42 1.0 2.1935e-05 1.0 8.53e+03 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0   389
VecTDot            74012 1.0 1.7883e+00 1.0 4.22e+09 1.0 0.0e+00 0.0e+00 0.0e+00  2  3  0  0  0   2  3  0  0  0  2357
VecNorm            37020 1.0 9.6073e-01 1.0 2.11e+09 1.0 0.0e+00 0.0e+00 0.0e+00  1  1  0  0  0   1  1  0  0  0  2195
VecScale           37008 1.0 3.7900e-01 1.0 1.05e+09 1.0 0.0e+00 0.0e+00 0.0e+00  0  1  0  0  0   0  1  0  0  0  2781
VecCopy            37034 1.0 3.5509e-02 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecSet             74137 1.0 3.1407e-01 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecAXPY            74029 1.0 1.8788e+00 1.0 4.22e+09 1.0 0.0e+00 0.0e+00 0.0e+00  2  3  0  0  0   2  3  0  0  0  2244
VecAYPX            37001 1.0 1.3694e+00 1.0 2.11e+09 1.0 0.0e+00 0.0e+00 0.0e+00  1  1  0  0  0   1  1  0  0  0  1539
VecAssemblyBegin      68 1.0 2.1172e-04 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecAssemblyEnd        68 1.0 3.8862e-05 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecScatterBegin       48 1.0 6.0940e-04 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatMult            37017 1.0 4.6933e+01 1.0 7.65e+10 1.0 0.0e+00 0.0e+00 0.0e+00 45 47  0  0  0  45 47  0  0  0  1629
MatMultAdd         37015 1.0 3.8572e+01 1.0 7.53e+10 1.0 0.0e+00 0.0e+00 0.0e+00 37 46  0  0  0  37 46  0  0  0  1951
MatSolve           74021 1.0 5.0074e+01 1.0 7.42e+10 1.0 0.0e+00 0.0e+00 0.0e+00 48 45  0  0  0  48 45  0  0  0  1482
MatLUFactorNum         1 1.0 1.7191e-02 1.0 2.44e+07 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0  1422
MatCholFctrSym         1 1.0 8.8000e-04 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatCholFctrNum         1 1.0 3.5787e-04 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatILUFactorSym        1 1.0 3.7310e-03 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatAssemblyBegin      29 1.0 1.9073e-06 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatAssemblyEnd        29 1.0 9.9218e-03 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatGetRow          58026 1.0 2.8136e-03 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatGetRowIJ            2 1.0 0.0000e+00 0.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatGetSubMatrice       6 1.0 1.5302e-02 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatGetOrdering         2 1.0 2.9898e-04 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatZeroEntries         6 1.0 2.9335e-03 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatView                7 1.0 2.6632e-02 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
KSPSetUp               4 1.0 9.7990e-05 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
KSPSolve               1 1.0 1.0089e+02 1.0 1.63e+11 1.0 0.0e+00 0.0e+00 0.0e+00 97100  0  0  0  97100  0  0  0  1619
PCSetUp                4 1.0 3.8233e-02 1.0 2.44e+07 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0   639
PCSetUpOnBlocks        5 1.0 2.1231e-02 1.0 2.44e+07 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0  1151
PCApply                5 1.0 1.0088e+02 1.0 1.63e+11 1.0 0.0e+00 0.0e+00 0.0e+00 97100  0  0  0  97100  0  0  0  1619
KSPSolve_FS_0          5 1.0 8.0919e-04 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
KSPSolve_FS_Schu       5 1.0 1.0088e+02 1.0 1.63e+11 1.0 0.0e+00 0.0e+00 0.0e+00 97100  0  0  0  97100  0  0  0  1619
KSPSolve_FS_Low        5 1.0 2.1861e-03 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
Memory usage is given in bytes:
Object Type          Creations   Destructions     Memory  Descendants' Mem.
Reports information only for process 0.
              Vector    91             91      9693912     0.
      Vector Scatter    24             24        15936     0.
           Index Set    51             51       537888     0.
   IS L to G Mapping     3              3       240408     0.
              Matrix    13             13     64097868     0.
       Krylov Solver     6              6         7888     0.
      Preconditioner     6              6         6288     0.
              Viewer     1              0            0     0.
    Distributed Mesh     1              1         4624     0.
Star Forest Bipartite Graph     2              2         1616     0.
     Discrete System     1              1          872     0.
Average time to get PetscTime(): 0.
#PETSc Option Table entries:
-fieldsplit_FE_split_ksp_monitor
-JSON_INIT /home/dknez/akselos-dev/data/instance/workers/fe-0d134a805c21419dacaad5fc4256078d/json_init.json
-JSON_INPUT /home/dknez/akselos-dev/data/instance/workers/fe-0d134a805c21419dacaad5fc4256078d/json_input.json
-ksp_monitor
-ksp_view
-log_view
#End of PETSc Option Table entries
Compiled without FORTRAN kernels
Compiled with full precision matrices (default)
sizeof(short) 2 sizeof(int) 4 sizeof(long) 8 sizeof(void*) 8 sizeof(PetscScalar) 8 sizeof(PetscInt) 4
Configure options: --with-shared-libraries=1 --with-debugging=0 --download-suitesparse --download-blacs --download-ptscotch=yes --with-blas-lapack-dir=/opt/intel/system_studio_2015.2.050/mkl --CXXFLAGS=-Wl,--no-as-needed --download-scalapack --download-mumps --download-metis --prefix=/home/dknez/software/libmesh_install/opt_real/petsc --download-hypre --download-ml
Libraries compiled on Wed Sep 21 17:38:52 2016 on david-Lenovo
Machine characteristics: Linux-4.4.0-38-generic-x86_64-with-Ubuntu-16.04-xenial
Using PETSc directory: /home/dknez/software/petsc-src
Using PETSc arch: arch-linux2-c-opt
Using C compiler: mpicc  -fPIC  -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -fvisibility=hidden -g -O  ${COPTFLAGS} ${CFLAGS}
Using Fortran compiler: mpif90  -fPIC -Wall -ffree-line-length-0 -Wno-unused-dummy-argument -g -O   ${FOPTFLAGS} ${FFLAGS}
Using include paths: -I/home/dknez/software/petsc-src/arch-linux2-c-opt/include -I/home/dknez/software/petsc-src/include -I/home/dknez/software/petsc-src/include -I/home/dknez/software/petsc-src/arch-linux2-c-opt/include -I/home/dknez/software/libmesh_install/opt_real/petsc/include -I/usr/lib/openmpi/include/openmpi/opal/mca/event/libevent2021/libevent -I/usr/lib/openmpi/include/openmpi/opal/mca/event/libevent2021/libevent/include -I/usr/lib/openmpi/include -I/usr/lib/openmpi/include/openmpi
Using C linker: mpicc
Using Fortran linker: mpif90
Using libraries: -Wl,-rpath,/home/dknez/software/petsc-src/arch-linux2-c-opt/lib -L/home/dknez/software/petsc-src/arch-linux2-c-opt/lib -lpetsc -Wl,-rpath,/home/dknez/software/libmesh_install/opt_real/petsc/lib -L/home/dknez/software/libmesh_install/opt_real/petsc/lib -lcmumps -ldmumps -lsmumps -lzmumps -lmumps_common -lpord -lmetis -lHYPRE -Wl,-rpath,/usr/lib/openmpi/lib -L/usr/lib/openmpi/lib -Wl,-rpath,/usr/lib/gcc/x86_64-linux-gnu/5 -L/usr/lib/gcc/x86_64-linux-gnu/5 -Wl,-rpath,/usr/lib/x86_64-linux-gnu -L/usr/lib/x86_64-linux-gnu -Wl,-rpath,/lib/x86_64-linux-gnu -L/lib/x86_64-linux-gnu -lmpi_cxx -lstdc++ -lscalapack -lml -lmpi_cxx -lstdc++ -lumfpack -lklu -lcholmod -lbtf -lccolamd -lcolamd -lcamd -lamd -lsuitesparseconfig -Wl,-rpath,/opt/intel/system_studio_2015.2.050/mkl/lib/intel64 -L/opt/intel/system_studio_2015.2.050/mkl/lib/intel64 -lmkl_intel_lp64 -lmkl_sequential -lmkl_core -lpthread -lm -lhwloc -lptesmumps -lptscotch -lptscotcherr -lscotch -lscotcherr -lX11 -lm -lmpi_usempif08 -lmpi_usempi_ignore_tkr -lmpi_mpifh -lgfortran -lm -lgfortran -lm -lquadmath -lm -lmpi_cxx -lstdc++ -lrt -lm -lpthread -lz -Wl,-rpath,/usr/lib/openmpi/lib -L/usr/lib/openmpi/lib -Wl,-rpath,/usr/lib/gcc/x86_64-linux-gnu/5 -L/usr/lib/gcc/x86_64-linux-gnu/5 -Wl,-rpath,/usr/lib/x86_64-linux-gnu -L/usr/lib/x86_64-linux-gnu -Wl,-rpath,/lib/x86_64-linux-gnu -L/lib/x86_64-linux-gnu -Wl,-rpath,/usr/lib/x86_64-linux-gnu -L/usr/lib/x86_64-linux-gnu -ldl -Wl,-rpath,/usr/lib/openmpi/lib -lmpi -lgcc_s -lpthread -ldl
    Residual norms for fieldsplit_FE_split_ solve.
    0 KSP Residual norm 3.488000613428e+03
    1 KSP Residual norm 1.913340289348e+01
    2 KSP Residual norm 3.047725579058e+00
    3 KSP Residual norm 3.529039571593e+01
    4 KSP Residual norm 8.262625546196e+00
    5 KSP Residual norm 7.990055719857e-02
    6 KSP Residual norm 2.526767904945e+02
    7 KSP Residual norm 2.056036001808e+02
    8 KSP Residual norm 1.435294157910e-03
  0 KSP Residual norm 5.406453059409e+04
    0 KSP Residual norm 1.425561332687e-03
    1 KSP Residual norm 1.126199428914e-03
    2 KSP Residual norm 3.541272181089e-04
    3 KSP Residual norm 7.057045636795e-03
    4 KSP Residual norm 4.941909117571e+00
    5 KSP Residual norm 1.892567169990e-03
    6 KSP Residual norm 1.767149982341e-04
    7 KSP Residual norm 2.376234803480e-05
    8 KSP Residual norm 1.478680549262e-08
    9 KSP Residual norm 2.286631816570e-03
   10 KSP Residual norm 3.133892392939e-05
   11 KSP Residual norm 1.386605538133e-05
   12 KSP Residual norm 3.440599766764e-05
   13 KSP Residual norm 3.707164789996e-10
  1 KSP Residual norm 7.914512561765e+01
    0 KSP Residual norm 4.504468374410e-05
    1 KSP Residual norm 2.471894787785e-07
    2 KSP Residual norm 4.826148705457e-08
    3 KSP Residual norm 4.642653751093e-07
    4 KSP Residual norm 9.602100964786e-08
    5 KSP Residual norm 1.082771472305e-09
    6 KSP Residual norm 3.367681326448e-06
    7 KSP Residual norm 2.574877773283e-06
    8 KSP Residual norm 1.714795084862e-11
  2 KSP Residual norm 6.982879146138e-04
  type: cg
  type: fieldsplit
    Split info:
        type: preonly
        type: cholesky
                type: seqaij
                rows=324, cols=324
                      [0] 29394.
                      [0]  1092.
                      [0]  29394.
                    [0] 1
                      [0] 1
                      [0] 324
          type: seqaij
          rows=324, cols=324
        type: cg
        type: cholesky
          factor fill ratio given 5., needed 23.5462
                type: seqsbaij
                total: nonzeros=12309111, allocated nonzeros=12309111
                    block size is 1
            A11
                type: seqaij
            A10
                type: seqaij
            KSP of A00
                type: preonly
                type: cholesky
                        type: seqaij
                        rows=324, cols=324
                              [0] 29394.
                              [0]  1092.
                              [0]  29394.
                            [0] 1
                              [0] 1
                              [0] 324
                  type: seqaij
                  rows=324, cols=324
            A01
                type: seqaij
          type: seqaij
    type: seqaij
/home/dknez/akselos-dev/scrbe/build/bin/fe_solver-opt_real on a arch-linux2-c-opt named david-Lenovo with 1 processor, by dknez Wed Jan 11 20:42:58 2017
Time (sec):           1.861e+01      1.00000   1.861e+01
Objects:              1.950e+02      1.00000   1.950e+02
Flops:                2.112e+09      1.00000   2.112e+09  2.112e+09
Flops/sec:            1.134e+08      1.00000   1.134e+08  1.134e+08
 0:      Main Stage: 1.8614e+01 100.0%  2.1118e+09 100.0%  0.000e+00   0.0%  0.000e+00        0.0%  0.000e+00   0.0%
Phase summary info:
VecTDot               78 1.0 1.4541e-03 1.0 4.44e+06 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0  3057
VecNorm               52 1.0 1.1883e-03 1.0 2.96e+06 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0  2494
VecScale              41 1.0 4.0245e-04 1.0 1.17e+06 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0  2901
VecCopy               64 1.0 2.5177e-04 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecSet               160 1.0 4.2248e-04 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecAXPY               94 1.0 1.8404e-03 1.0 4.48e+06 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0  2435
VecAYPX               35 1.0 1.1680e-03 1.0 1.97e+06 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0  1683
VecAssemblyBegin      68 1.0 1.9956e-04 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecAssemblyEnd        68 1.0 2.7418e-05 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecScatterBegin       44 1.0 3.8147e-04 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatMult               48 1.0 4.4571e-02 1.0 8.25e+07 1.0 0.0e+00 0.0e+00 0.0e+00  0  4  0  0  0   0  4  0  0  0  1852
MatMultAdd            49 1.0 3.3489e-02 1.0 7.53e+07 1.0 0.0e+00 0.0e+00 0.0e+00  0  4  0  0  0   0  4  0  0  0  2249
MatSolve              86 1.0 9.5013e-01 1.0 2.02e+09 1.0 0.0e+00 0.0e+00 0.0e+00  5 95  0  0  0   5 95  0  0  0  2121
MatCholFctrSym         2 1.0 1.0396e+01 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 56  0  0  0  0  56  0  0  0  0     0
MatCholFctrNum         2 1.0 4.0893e+00 1.0 2.85e+04 1.0 0.0e+00 0.0e+00 0.0e+00 22  0  0  0  0  22  0  0  0  0     0
MatAssemblyBegin      29 1.0 4.0531e-06 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatAssemblyEnd        29 1.0 1.0732e-02 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatGetRow          58026 1.0 3.2039e-03 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatGetRowIJ            2 1.0 9.5367e-07 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatGetSubMatrice       6 1.0 1.7126e-02 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatGetOrdering         2 1.0 3.0589e-04 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatZeroEntries         6 1.0 3.0849e-03 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatView                6 1.0 2.4055e-02 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
KSPSetUp               3 1.0 1.0300e-04 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
KSPSolve               1 1.0 1.5489e+01 1.0 2.11e+09 1.0 0.0e+00 0.0e+00 0.0e+00 83100  0  0  0  83100  0  0  0   136
PCSetUp                3 1.0 1.4508e+01 1.0 2.85e+04 1.0 0.0e+00 0.0e+00 0.0e+00 78  0  0  0  0  78  0  0  0  0     0
PCApply                4 1.0 1.5486e+01 1.0 2.10e+09 1.0 0.0e+00 0.0e+00 0.0e+00 83100  0  0  0  83100  0  0  0   136
KSPSolve_FS_0          4 1.0 6.0940e-04 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
KSPSolve_FS_Schu       4 1.0 1.5483e+01 1.0 2.10e+09 1.0 0.0e+00 0.0e+00 0.0e+00 83100  0  0  0  83100  0  0  0   136
KSPSolve_FS_Low        4 1.0 2.0130e-03 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
              Vector    89             89      9690840     0.
              Matrix    13             13    199146960     0.
       Krylov Solver     5              5         6720     0.
      Preconditioner     5              5         5360     0.
              Viewer     1              0            0     0.
-ksp_monitor
-ksp_view
-log_view
