[petsc-users] Using PCFIELDSPLIT with -pc_fieldsplit_type schur
David Knezevic david.knezevic at akselos.com
Wed Jan 11 18:32:30 CST 2017
On Wed, Jan 11, 2017 at 5:52 PM, Dave May <dave.mayhem23 at gmail.com> wrote:
> so I gather that I'll have to look into a user-defined approximation to S.
> Where does the 2x2 block system come from?
> Maybe someone on the list knows the right approximation to use for S.
The model is 3D linear elasticity using a finite element discretization. I
applied substructuring to part of the system to "condense" it, and that
results in the small A00 block. The A11 block is just standard 3D
elasticity; no substructuring was applied there. There are constraints to
connect the degrees of freedom on the interface of the substructured and
non-substructured regions.
If anyone has suggestions for a good way to precondition this type of
system, I'd be most appreciative!
David
>>   0 KSP Residual norm 5.405528187695e+04
>>   1 KSP Residual norm 2.187814910803e+02
>>   2 KSP Residual norm 1.019051577515e-01
>>   3 KSP Residual norm 4.370464012859e-04
>> KSP Object: 1 MPI processes
>>   type: cg
>>   maximum iterations=1000
>>   tolerances:  relative=1e-06, absolute=1e-50, divergence=10000.
>>   left preconditioning
>>   using nonzero initial guess
>>   using PRECONDITIONED norm type for convergence test
>> PC Object: 1 MPI processes
>>   type: fieldsplit
>>     FieldSplit with Schur preconditioner, factorization FULL
>>     Preconditioner for the Schur complement formed from Sp, an assembled
>> approximation to S, which uses (lumped, if requested) A00's diagonal's
>> inverse
>>     Split info:
>>     Split number 0 Defined by IS
>>     Split number 1 Defined by IS
>>     KSP solver for A00 block
>>       KSP Object:      (fieldsplit_RB_split_)       1 MPI processes
>>         type: preonly
>>         maximum iterations=10000, initial guess is zero
>>         tolerances:  relative=1e-05, absolute=1e-50, divergence=10000.
>>         using NONE norm type for convergence test
>>       PC Object:      (fieldsplit_RB_split_)       1 MPI processes
>>         type: cholesky
>>           Cholesky: out-of-place factorization
>>           tolerance for zero pivot 2.22045e-14
>>           matrix ordering: natural
>>           factor fill ratio given 0., needed 0.
>>             Factored matrix follows:
>>               Mat Object:               1 MPI processes
>>                 type: seqaij
>>                 rows=324, cols=324
>>                 package used to perform factorization: mumps
>>                 total: nonzeros=3042, allocated nonzeros=3042
>>                 total number of mallocs used during MatSetValues calls =0
>>                   MUMPS run parameters:
>>                     SYM (matrix type):                   2
>>                     PAR (host participation):            1
>>                     ICNTL(1) (output for error):         6
>>                     ICNTL(2) (output of diagnostic msg): 0
>>                     ICNTL(3) (output for global info):   0
>>                     ICNTL(4) (level of printing):        0
>>                     ICNTL(5) (input mat struct):         0
>>                     ICNTL(6) (matrix prescaling):        7
>>                     ICNTL(7) (sequentia matrix ordering):7
>>                     ICNTL(8) (scalling strategy):        77
>>                     ICNTL(10) (max num of refinements):  0
>>                     ICNTL(11) (error analysis):          0
>>                     ICNTL(12) (efficiency control):
>>   0
>>                     ICNTL(13) (efficiency control):
>>   0
>>                     ICNTL(14) (percentage of estimated workspace
>> increase): 20
>>                     ICNTL(18) (input mat struct):
>>   0
>>                     ICNTL(19) (Shur complement info):
>>   0
>>                     ICNTL(20) (rhs sparse pattern):
>>   0
>>                     ICNTL(21) (solution struct):
>>    0
>>                     ICNTL(22) (in-core/out-of-core facility):
>>   0
>>                     ICNTL(23) (max size of memory can be allocated
>> locally):0
>>                     ICNTL(24) (detection of null pivot rows):
>>   0
>>                     ICNTL(25) (computation of a null space basis):
>>    0
>>                     ICNTL(26) (Schur options for rhs or solution):
>>    0
>>                     ICNTL(27) (experimental parameter):
>>   -24
>>                     ICNTL(28) (use parallel or sequential ordering):
>>    1
>>                     ICNTL(29) (parallel ordering):
>>    0
>>                     ICNTL(30) (user-specified set of entries in inv(A)):
>>    0
>>                     ICNTL(31) (factors is discarded in the solve phase):
>>    0
>>                     ICNTL(33) (compute determinant):
>>    0
>>                     CNTL(1) (relative pivoting threshold):      0.01
>>                     CNTL(2) (stopping criterion of refinement):
>> 1.49012e-08
>>                     CNTL(3) (absolute pivoting threshold):      0.
>>                     CNTL(4) (value of static pivoting):         -1.
>>                     CNTL(5) (fixation for null pivots):         0.
>>                     RINFO(1) (local estimated flops for the elimination
>> after analysis):
>>                       [0] 29394.
>>                     RINFO(2) (local estimated flops for the assembly
>> after factorization):
>>                       [0]  1092.
>>                     RINFO(3) (local estimated flops for the elimination
>>                       [0]  29394.
>>                     INFO(15) (estimated size of (in MB) MUMPS internal
>> data for running numerical factorization):
>>                     [0] 1
>>                     INFO(16) (size of (in MB) MUMPS internal data used
>> during numerical factorization):
>>                       [0] 1
>>                     INFO(23) (num of pivots eliminated on this processor
>>                       [0] 324
>>                     RINFOG(1) (global estimated flops for the elimination
>> after analysis): 29394.
>>                     RINFOG(2) (global estimated flops for the assembly
>> after factorization): 1092.
>>                     RINFOG(3) (global estimated flops for the elimination
>> after factorization): 29394.
>>                     (RINFOG(12) RINFOG(13))*2^INFOG(34) (determinant):
>> (0.,0.)*(2^0)
>>                     INFOG(3) (estimated real workspace for factors on all
>> processors after analysis): 3888
>>                     INFOG(4) (estimated integer workspace for factors on
>> all processors after analysis): 2067
>>                     INFOG(5) (estimated maximum front size in the
>> complete tree): 12
>>                     INFOG(6) (number of nodes in the complete tree): 53
>>                     INFOG(7) (ordering option effectively use after
>> analysis): 2
>>                     INFOG(8) (structural symmetry in percent of the
>> permuted matrix after analysis): 100
>>                     INFOG(9) (total real/complex workspace to store the
>> matrix factors after factorization): 3888
>>                     INFOG(10) (total integer space store the matrix
>> factors after factorization): 2067
>>                     INFOG(11) (order of largest frontal matrix after
>> factorization): 12
>>                     INFOG(12) (number of off-diagonal pivots): 0
>>                     INFOG(13) (number of delayed pivots after
>> factorization): 0
>>                     INFOG(14) (number of memory compress after
>> factorization): 0
>>                     INFOG(15) (number of steps of iterative refinement
>> after solution): 0
>>                     INFOG(16) (estimated size (in MB) of all MUMPS
>> internal data for factorization after analysis: value on the most memory
>> consuming processor): 1
>>                     INFOG(17) (estimated size of all MUMPS internal data
>> for factorization after analysis: sum over all processors): 1
>>                     INFOG(18) (size of all MUMPS internal data allocated
>> during factorization: value on the most memory consuming processor): 1
>>                     INFOG(19) (size of all MUMPS internal data allocated
>> during factorization: sum over all processors): 1
>>                     INFOG(20) (estimated number of entries in the
>> factors): 3042
>>                     INFOG(21) (size in MB of memory effectively used
>> during factorization - value on the most memory consuming processor): 1
>>                     INFOG(22) (size in MB of memory effectively used
>> during factorization - sum over all processors): 1
>>                     INFOG(23) (after analysis: value of ICNTL(6)
>> effectively used): 5
>>                     INFOG(24) (after analysis: value of ICNTL(12)
>> effectively used): 1
>>                     INFOG(25) (after factorization: number of pivots
>> modified by static pivoting): 0
>>                     INFOG(28) (after factorization: number of null pivots
>> encountered): 0
>>                     INFOG(29) (after factorization: effective number of
>> entries in the factors (sum over all processors)): 3042
>>                     INFOG(30, 31) (after solution: size in Mbytes of
>> memory used during solution phase): 0, 0
>>                     INFOG(32) (after analysis: type of analysis done): 1
>>                     INFOG(33) (value used for ICNTL(8)): -2
>>                     INFOG(34) (exponent of the determinant if determinant
>> is requested): 0
>>         linear system matrix = precond matrix:
>>         Mat Object:        (fieldsplit_RB_split_)         1 MPI processes
>>           type: seqaij
>>           rows=324, cols=324
>>           total: nonzeros=5760, allocated nonzeros=5760
>>             using I-node routines: found 108 nodes, limit used is 5
>>     KSP solver for S = A11 - A10 inv(A00) A01
>>       KSP Object:      (fieldsplit_FE_split_)       1 MPI processes
>>         type: cg
>>       PC Object:      (fieldsplit_FE_split_)       1 MPI processes
>>         type: bjacobi
>>           block Jacobi: number of blocks = 1
>>           Local solve is same for all blocks, in the following KSP and PC
>> objects:
>>           KSP Object:          (fieldsplit_FE_split_sub_)           1 MPI
>> processes
>>             type: preonly
>>           PC Object:          (fieldsplit_FE_split_sub_)           1 MPI
>> processes
>>             type: ilu
>>               ILU: out-of-place factorization
>>               0 levels of fill
>>               factor fill ratio given 1., needed 1.
>>                     type: seqaij
>>                     rows=28476, cols=28476
>>                     package used to perform factorization: petsc
>>                     total: nonzeros=1037052, allocated nonzeros=1037052
>> calls =0
>>                       using I-node routines: found 9489 nodes, limit used
>> is 5
>>               type: seqaij
>>                 using I-node routines: found 9489 nodes, limit used is 5
>>         linear system matrix followed by preconditioner matrix:
>>         Mat Object:        (fieldsplit_FE_split_)         1 MPI processes
>>           type: schurcomplement
>>             Schur complement A11 - A10 inv(A00) A01
>>             A11
>>   1 MPI processes
>>                 type: seqaij
>>                 total: nonzeros=1017054, allocated nonzeros=1017054
>>                   using I-node routines: found 9492 nodes, limit used is 5
>>             A10
>>                 type: seqaij
>>                 rows=28476, cols=324
>>                 total: nonzeros=936, allocated nonzeros=936
>>                   using I-node routines: found 5717 nodes, limit used is 5
>>             KSP of A00
>>   1 MPI processes
>>                 type: preonly
>> divergence=10000.
>>   1 MPI processes
>>                 type: cholesky
>>                         type: seqaij
>>                         rows=324, cols=324
>> calls =0
>>           0
>>           0
>> increase): 20
>>           0
>>           0
>>           0
>>            0
>>           0
>> allocated locally):0
>>           0
>> basis):          0
>> solution):          0
>>           -24
>> ordering):        1
>>            0
>> inv(A)):    0
>> phase):    0
>>            0
>>  0.01
>> 1.49012e-08
>>  0.
>> -1.
>> 0.
>> elimination after analysis):
>>                               [0] 29394.
>> assembly after factorization):
>>                               [0]  1092.
>> elimination after factorization):
>>                               [0]  29394.
>> internal data for running numerical factorization):
>>                             [0] 1
>> used during numerical factorization):
>>                               [0] 1
>> processor after factorization):
>>                               [0] 324
>> elimination after analysis): 29394.
>> assembly after factorization): 1092.
>> elimination after factorization): 29394.
>> (determinant): (0.,0.)*(2^0)
>> factors on all processors after analysis): 3888
>> factors on all processors after analysis): 2067
>> complete tree): 12
>> tree): 53
>> after analysis): 2
>> the permuted matrix after analysis): 100
>> store the matrix factors after factorization): 3888
>> matrix factors after factorization): 2067
>> after factorization): 12
>> factorization): 0
>> factorization): 0
>> refinement after solution): 0
>> MUMPS internal data for factorization after analysis: value on the most
>> internal data for factorization after analysis: sum over all processors): 1
>> allocated during factorization: value on the most memory consuming
>> processor): 1
>> allocated during factorization: sum over all processors): 1
>> factors): 3042
>> used during factorization - value on the most memory consuming processor):
>> 1
>> used during factorization - sum over all processors): 1
>> pivots modified by static pivoting): 0
>> null pivots encountered): 0
>> number of entries in the factors (sum over all processors)): 3042
>> of memory used during solution phase): 0, 0
>> done): 1
>> determinant is requested): 0
>>         1 MPI processes
>>                   type: seqaij
>>                   rows=324, cols=324
>> =0
>> 5
>>             A01
>>                 type: seqaij
>>                 rows=324, cols=28476
>>                   using I-node routines: found 67 nodes, limit used is 5
>>           type: seqaij
>>   Mat Object:  ()   1 MPI processes
>>     type: seqaij
>>     rows=28800, cols=28800
>>     total: nonzeros=1024686, allocated nonzeros=1024794
>>       using I-node routines: found 9600 nodes, limit used is 5
>> ---------------------------------------------- PETSc Performance
>> Summary: ----------------------------------------------
>> /home/dknez/akselos-dev/scrbe/build/bin/fe_solver-opt_real on a
>> arch-linux2-c-opt named david-Lenovo with 1 processor, by dknez Wed Jan 11
>> 17:22:10 2017
>> Using Petsc Release Version 3.7.3, unknown
>>                          Max       Max/Min        Avg      Total
>> Time (sec):           9.638e+01      1.00000   9.638e+01
>> Objects:              2.030e+02      1.00000   2.030e+02
>> Flops:                1.732e+11      1.00000   1.732e+11  1.732e+11
>> Flops/sec:            1.797e+09      1.00000   1.797e+09  1.797e+09
>> MPI Messages:         0.000e+00      0.00000   0.000e+00  0.000e+00
>> MPI Message Lengths:  0.000e+00      0.00000   0.000e+00  0.000e+00
>> MPI Reductions:       0.000e+00      0.00000
>> Flop counting convention: 1 flop = 1 real number operation of type
>> (multiply/divide/add/subtract)
>>                             e.g., VecAXPY() for real vectors of length N
>> --> 2N flops
>>                             and VecAXPY() for complex vectors of length N
>> --> 8N flops
>> Summary of Stages:   ----- Time ------  ----- Flops -----  --- Messages
>> ---  -- Message Lengths --  -- Reductions --
>>                         Avg     %Total     Avg     %Total   counts
>> %Total     Avg         %Total   counts   %Total
>>  0:      Main Stage: 9.6379e+01 100.0%  1.7318e+11 100.0%  0.000e+00
>> 0.0%  0.000e+00        0.0%  0.000e+00   0.0%
>> See the 'Profiling' chapter of the users' manual for details on
>> interpreting output.
>> Phase summary info:
>>    Count: number of times phase was executed
>>    Time and Flops: Max - maximum over all processors
>>                    Ratio - ratio of maximum to minimum over all processors
>>    Mess: number of messages sent
>>    Avg. len: average message length (bytes)
>>    Reduct: number of global reductions
>>    Global: entire computation
>>    Stage: stages of a computation. Set stages with PetscLogStagePush()
>> and PetscLogStagePop().
>>       %T - percent time in this phase         %F - percent flops in this
>> phase
>>       %M - percent messages in this phase     %L - percent message
>> lengths in this phase
>>       %R - percent reductions in this phase
>>    Total Mflop/s: 10e-6 * (sum of flops over all processors)/(max time
>> Event                Count      Time (sec)     Flops
>>         --- Global ---  --- Stage ---   Total
>>                    Max Ratio  Max     Ratio   Max  Ratio  Mess   Avg len
>> Reduct  %T %F %M %L %R  %T %F %M %L %R Mflop/s
>> --- Event Stage 0: Main Stage
>> VecDot                42 1.0 2.2411e-05 1.0 8.53e+03 1.0 0.0e+00 0.0e+00
>> 0.0e+00  0  0  0  0  0   0  0  0  0  0   380
>> VecTDot            77761 1.0 1.4294e+00 1.0 4.43e+09 1.0 0.0e+00 0.0e+00
>> 0.0e+00  1  3  0  0  0   1  3  0  0  0  3098
>> VecNorm            38894 1.0 9.1002e-01 1.0 2.22e+09 1.0 0.0e+00 0.0e+00
>> 0.0e+00  1  1  0  0  0   1  1  0  0  0  2434
>> VecScale           38882 1.0 3.7314e-01 1.0 1.11e+09 1.0 0.0e+00 0.0e+00
>> 0.0e+00  0  1  0  0  0   0  1  0  0  0  2967
>> VecCopy            38908 1.0 2.1655e-02 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
>> 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
>> VecSet             77887 1.0 3.2034e-01 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
>> VecAXPY            77777 1.0 1.8382e+00 1.0 4.43e+09 1.0 0.0e+00 0.0e+00
>> 0.0e+00  2  3  0  0  0   2  3  0  0  0  2409
>> VecAYPX            38875 1.0 1.2884e+00 1.0 2.21e+09 1.0 0.0e+00 0.0e+00
>> 0.0e+00  1  1  0  0  0   1  1  0  0  0  1718
>> VecAssemblyBegin      68 1.0 1.9407e-04 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
>> VecAssemblyEnd        68 1.0 2.6941e-05 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
>> VecScatterBegin       48 1.0 4.6349e-04 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
>> MatMult            38891 1.0 4.3045e+01 1.0 8.03e+10 1.0 0.0e+00 0.0e+00
>> 0.0e+00 45 46  0  0  0  45 46  0  0  0  1866
>> MatMultAdd         38889 1.0 3.5360e+01 1.0 7.91e+10 1.0 0.0e+00 0.0e+00
>> 0.0e+00 37 46  0  0  0  37 46  0  0  0  2236
>> MatSolve           77769 1.0 4.8780e+01 1.0 7.95e+10 1.0 0.0e+00 0.0e+00
>> 0.0e+00 51 46  0  0  0  51 46  0  0  0  1631
>> MatLUFactorNum         1 1.0 1.9575e-02 1.0 2.49e+07 1.0 0.0e+00 0.0e+00
>> 0.0e+00  0  0  0  0  0   0  0  0  0  0  1274
>> MatCholFctrSym         1 1.0 9.4891e-04 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
>> MatCholFctrNum         1 1.0 3.7885e-04 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
>> MatILUFactorSym        1 1.0 4.1780e-03 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
>> MatConvert             1 1.0 3.0041e-05 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
>> MatScale               2 1.0 2.7180e-05 1.0 2.53e+04 1.0 0.0e+00 0.0e+00
>> 0.0e+00  0  0  0  0  0   0  0  0  0  0   930
>> MatAssemblyBegin      32 1.0 4.0531e-06 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
>> MatAssemblyEnd        32 1.0 1.2032e-02 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
>> MatGetRow         114978 1.0 5.9254e-03 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
>> MatGetRowIJ            2 1.0 2.1458e-06 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
>> MatGetSubMatrice       6 1.0 1.5707e-02 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
>> MatGetOrdering         2 1.0 3.2425e-04 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
>> MatZeroEntries         6 1.0 3.0580e-03 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
>> MatView                7 1.0 3.5119e-03 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
>> MatAXPY                1 1.0 1.9384e-02 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
>> MatMatMult             1 1.0 2.7120e-03 1.0 3.16e+05 1.0 0.0e+00 0.0e+00
>> 0.0e+00  0  0  0  0  0   0  0  0  0  0   117
>> MatMatMultSym          1 1.0 1.8010e-03 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
>> MatMatMultNum          1 1.0 6.1703e-04 1.0 3.16e+05 1.0 0.0e+00 0.0e+00
>> 0.0e+00  0  0  0  0  0   0  0  0  0  0   513
>> KSPSetUp               4 1.0 9.8944e-05 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
>> KSPSolve               1 1.0 9.3380e+01 1.0 1.73e+11 1.0 0.0e+00 0.0e+00
>> 0.0e+00 97100  0  0  0  97100  0  0  0  1855
>> PCSetUp                4 1.0 6.6326e-02 1.0 2.53e+07 1.0 0.0e+00 0.0e+00
>> 0.0e+00  0  0  0  0  0   0  0  0  0  0   381
>> PCSetUpOnBlocks        5 1.0 2.4082e-02 1.0 2.49e+07 1.0 0.0e+00 0.0e+00
>> 0.0e+00  0  0  0  0  0   0  0  0  0  0  1036
>> PCApply                5 1.0 9.3376e+01 1.0 1.73e+11 1.0 0.0e+00 0.0e+00
>> KSPSolve_FS_0          5 1.0 7.0214e-04 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
>> KSPSolve_FS_Schu       5 1.0 9.3372e+01 1.0 1.73e+11 1.0 0.0e+00 0.0e+00
>> KSPSolve_FS_Low        5 1.0 2.1377e-03 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
>> Memory usage is given in bytes:
>> Object Type          Creations   Destructions     Memory  Descendants'
>> Mem.
>> Reports information only for process 0.
>>               Vector    92             92      9698040     0.
>>       Vector Scatter    24             24        15936     0.
>>            Index Set    51             51       537876     0.
>>    IS L to G Mapping     3              3       240408     0.
>>               Matrix    16             16     77377776     0.
>>        Krylov Solver     6              6         7888     0.
>>       Preconditioner     6              6         6288     0.
>>               Viewer     1              0            0     0.
>>     Distributed Mesh     1              1         4624     0.
>> Star Forest Bipartite Graph     2              2         1616     0.
>>      Discrete System     1              1          872     0.
>> Average time to get PetscTime(): 0.
>> #PETSc Option Table entries:
>> -ksp_monitor
>> -ksp_view
>> -log_view
>> #End of PETSc Option Table entries
>> Compiled without FORTRAN kernels
>> Compiled with full precision matrices (default)
>> sizeof(short) 2 sizeof(int) 4 sizeof(long) 8 sizeof(void*) 8
>> sizeof(PetscScalar) 8 sizeof(PetscInt) 4
>> Configure options: --with-shared-libraries=1 --with-debugging=0
>> --download-suitesparse --download-blacs --download-ptscotch=yes
>> --with-blas-lapack-dir=/opt/intel/system_studio_2015.2.050/mkl
>> --CXXFLAGS=-Wl,--no-as-needed --download-scalapack --download-mumps
>> --download-metis --prefix=/home/dknez/software/libmesh_install/opt_real/petsc
>> --download-hypre --download-ml
>> Libraries compiled on Wed Sep 21 17:38:52 2016 on david-Lenovo
>> Machine characteristics: Linux-4.4.0-38-generic-x86_64-
>> with-Ubuntu-16.04-xenial
>> Using PETSc directory: /home/dknez/software/petsc-src
>> Using PETSc arch: arch-linux2-c-opt
>> Using C compiler: mpicc  -fPIC  -Wall -Wwrite-strings
>> -Wno-strict-aliasing -Wno-unknown-pragmas -fvisibility=hidden -g -O
>>  ${COPTFLAGS} ${CFLAGS}
>> Using Fortran compiler: mpif90  -fPIC -Wall -ffree-line-length-0
>> -Wno-unused-dummy-argument -g -O   ${FOPTFLAGS} ${FFLAGS}
>> Using include paths: -I/home/dknez/software/petsc-src/arch-linux2-c-opt/include
>> -I/home/dknez/software/petsc-src/include -I/home/dknez/software/petsc-src/include
>> -I/home/dknez/software/libmesh_install/opt_real/petsc/include
>> -I/usr/lib/openmpi/include/openmpi/opal/mca/event/libevent2021/libevent
>> -I/usr/lib/openmpi/include/openmpi/opal/mca/event/libevent2021/libevent/include
>> -I/usr/lib/openmpi/include -I/usr/lib/openmpi/include/openmpi
>> Using C linker: mpicc
>> Using Fortran linker: mpif90
>> Using libraries: -Wl,-rpath,/home/dknez/softwar
>> e/petsc-src/arch-linux2-c-opt/lib -L/home/dknez/software/petsc-src/arch-linux2-c-opt/lib
>> -lpetsc -Wl,-rpath,/home/dknez/software/libmesh_install/opt_real/petsc/lib
>> -L/home/dknez/software/libmesh_install/opt_real/petsc/lib -lcmumps
>> -ldmumps -lsmumps -lzmumps -lmumps_common -lpord -lmetis -lHYPRE
>> -Wl,-rpath,/usr/lib/openmpi/lib -L/usr/lib/openmpi/lib
>> -Wl,-rpath,/usr/lib/gcc/x86_64-linux-gnu/5 -L/usr/lib/gcc/x86_64-linux-gnu/5
>> -Wl,-rpath,/usr/lib/x86_64-linux-gnu -L/usr/lib/x86_64-linux-gnu
>> -Wl,-rpath,/lib/x86_64-linux-gnu -L/lib/x86_64-linux-gnu -lmpi_cxx
>> -lstdc++ -lscalapack -lml -lmpi_cxx -lstdc++ -lumfpack -lklu -lcholmod
>> -lbtf -lccolamd -lcolamd -lcamd -lamd -lsuitesparseconfig
>> -Wl,-rpath,/opt/intel/system_studio_2015.2.050/mkl/lib/intel64
>> -L/opt/intel/system_studio_2015.2.050/mkl/lib/intel64 -lmkl_intel_lp64
>> -lmkl_sequential -lmkl_core -lpthread -lm -lhwloc -lptesmumps -lptscotch
>> -lptscotcherr -lscotch -lscotcherr -lX11 -lm -lmpi_usempif08
>> -lmpi_usempi_ignore_tkr -lmpi_mpifh -lgfortran -lm -lgfortran -lm
>> -lquadmath -lm -lmpi_cxx -lstdc++ -lrt -lm -lpthread -lz
>> -Wl,-rpath,/usr/lib/x86_64-linux-gnu -L/usr/lib/x86_64-linux-gnu -ldl
>> -Wl,-rpath,/usr/lib/openmpi/lib -lmpi -lgcc_s -lpthread -ldl
>> On Wed, Jan 11, 2017 at 4:49 PM, Dave May <dave.mayhem23 at gmail.com>
>> wrote:
>>> It looks like the Schur solve is requiring a huge number of iterates to
>>> converge (based on the instances of MatMult).
>>> This is killing the performance.
>>> Are you sure that A11 is a good approximation to S? You might consider
>>> trying the selfp option
>>> http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/
>>> PC/PCFieldSplitSetSchurPre.html#PCFieldSplitSetSchurPre
>>> Note that the best approx to S is likely both problem and discretisation
>>> dependent so if selfp is also terrible, you might want to consider coding
>>> up your own approx to S for your specific system.
>>> Thanks,
>>>   Dave
>>> On Wed, 11 Jan 2017 at 22:34, David Knezevic <david.knezevic at akselos.com>
>>> wrote:
>>> I have a definite block 2x2 system and I figured it'd be good to apply
>>> the PCFIELDSPLIT functionality with Schur complement, as described in
>>> Section 4.5 of the manual.
>>> The A00 block of my matrix is very small so I figured I'd specify a
>>> direct solver (i.e. MUMPS) for that block.
>>> So I did the following:
>>> - PCFieldSplitSetIS to specify the indices of the two splits
>>> - PCFieldSplitGetSubKSP to get the two KSP objects, and to set the
>>> solver and PC types for each (MUMPS for A00, ILU+CG for A11)
>>> - I set -pc_fieldsplit_schur_fact_type full
>>> Below I have pasted the output of "-ksp_view -ksp_monitor -log_view" for
>>> a test case. It seems to converge well, but I'm concerned about the speed
>>> (about 90 seconds, vs. about 1 second if I use a direct solver for the
>>> entire system). I just wanted to check if I'm setting this up in a good way?
>>> Many thanks,
>>> David
>>>   0 KSP Residual norm 5.405774214400e+04
>>>   1 KSP Residual norm 1.849649014371e+02
>>>   2 KSP Residual norm 7.462775074989e-02
>>>   3 KSP Residual norm 2.680497175260e-04
>>>   type: cg
>>>   type: fieldsplit
>>>     Preconditioner for the Schur complement formed from A11
>>>     Split info:
>>>         type: preonly
>>>         type: cholesky
>>>                 type: seqaij
>>>                 rows=324, cols=324
>>>     0
>>>     0
>>> increase): 20
>>>     0
>>>     0
>>>     0
>>>    0
>>>     0
>>> locally):0
>>>     0
>>>    0
>>>    0
>>>     -24
>>>    1
>>>    0
>>>    0
>>>    0
>>>    0
>>> 1.49012e-08
>>> after analysis):
>>>                       [0] 29394.
>>>                       [0]  1092.
>>>                       [0]  29394.
>>>                     [0] 1
>>>                       [0] 1
>>>                       [0] 324
>>> (0.,0.)*(2^0)
>>> complete tree): 12
>>> analysis): 2
>>> factorization): 12
>>> factorization): 0
>>> factorization): 0
>>> after solution): 0
>>> factors): 3042
>>>           type: seqaij
>>>           rows=324, cols=324
>>>         type: cg
>>>         type: bjacobi
>>> PC objects:
>>> MPI processes
>>>             type: preonly
>>> divergence=10000.
>>> processes
>>>             type: ilu
>>>               0 levels of fill
>>>                     type: seqaij
>>> calls =0
>>> used is 5
>>> MPI processes
>>>               type: seqaij
>>>             A11
>>>     1 MPI processes
>>>                 type: seqaij
>>> 5
>>>             A10
>>>                 type: seqaij
>>> 5
>>>             KSP of A00
>>>     1 MPI processes
>>>                 type: preonly
>>> divergence=10000.
>>>   1 MPI processes
>>>                 type: cholesky
>>>                         type: seqaij
>>>                         rows=324, cols=324
>>> calls =0
>>>             0
>>>             0
>>> increase): 20
>>>             0
>>>             0
>>>             0
>>>            0
>>>             0
>>>             0
>>> basis):          0
>>> solution):          0
>>>             -24
>>> ordering):        1
>>>            0
>>> inv(A)):    0
>>> phase):    0
>>>            0
>>>  0.01
>>> 1.49012e-08
>>>  0.
>>> -1.
>>> 0.
>>>                               [0] 29394.
>>>                               [0]  1092.
>>>                               [0]  29394.
>>>                             [0] 1
>>> data used during numerical factorization):
>>>                               [0] 1
>>>                               [0] 324
>>> the complete tree): 12
>>> tree): 53
>>> after analysis): 2
>>> factorization): 0
>>> factorization): 0
>>> processor): 1
>>> the factors): 3042
>>> 1
>>> ICNTL(12) effectively used): 1
>>> Mbytes of memory used during solution phase): 0, 0
>>> done): 1
>>>           1 MPI processes
>>>                   type: seqaij
>>>                   rows=324, cols=324
>>> =0
>>> is 5
>>>             A01
>>>                 type: seqaij
>>>           type: seqaij
>>>     type: seqaij
>>> 16:16:47 2017
>>> Time (sec):           9.179e+01      1.00000   9.179e+01
>>> Objects:              1.990e+02      1.00000   1.990e+02
>>> Flops:                1.634e+11      1.00000   1.634e+11  1.634e+11
>>> Flops/sec:            1.780e+09      1.00000   1.780e+09  1.780e+09
>>> --> 2N flops
>>> N --> 8N flops
>>>  0:      Main Stage: 9.1787e+01 100.0%  1.6336e+11 100.0%  0.000e+00
>>> Phase summary info:
>>> processors
>>> phase
>>> VecDot                42 1.0 2.4080e-05 1.0 8.53e+03 1.0 0.0e+00 0.0e+00
>>> 0.0e+00  0  0  0  0  0   0  0  0  0  0   354
>>> VecTDot            74012 1.0 1.2440e+00 1.0 4.22e+09 1.0 0.0e+00 0.0e+00
>>> 0.0e+00  1  3  0  0  0   1  3  0  0  0  3388
>>> VecNorm            37020 1.0 8.3580e-01 1.0 2.11e+09 1.0 0.0e+00 0.0e+00
>>> 0.0e+00  1  1  0  0  0   1  1  0  0  0  2523
>>> VecScale           37008 1.0 3.5800e-01 1.0 1.05e+09 1.0 0.0e+00 0.0e+00
>>> 0.0e+00  0  1  0  0  0   0  1  0  0  0  2944
>>> VecCopy            37034 1.0 2.5754e-02 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
>>> VecSet             74137 1.0 3.0537e-01 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
>>> VecAXPY            74029 1.0 1.7233e+00 1.0 4.22e+09 1.0 0.0e+00 0.0e+00
>>> 0.0e+00  2  3  0  0  0   2  3  0  0  0  2446
>>> VecAYPX            37001 1.0 1.2214e+00 1.0 2.11e+09 1.0 0.0e+00 0.0e+00
>>> 0.0e+00  1  1  0  0  0   1  1  0  0  0  1725
>>> VecAssemblyBegin      68 1.0 2.0432e-04 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
>>> VecAssemblyEnd        68 1.0 2.5988e-05 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
>>> VecScatterBegin       48 1.0 4.6921e-04 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
>>> MatMult            37017 1.0 4.1269e+01 1.0 7.65e+10 1.0 0.0e+00 0.0e+00
>>> 0.0e+00 45 47  0  0  0  45 47  0  0  0  1853
>>> MatMultAdd         37015 1.0 3.3638e+01 1.0 7.53e+10 1.0 0.0e+00 0.0e+00
>>> 0.0e+00 37 46  0  0  0  37 46  0  0  0  2238
>>> MatSolve           74021 1.0 4.6602e+01 1.0 7.42e+10 1.0 0.0e+00 0.0e+00
>>> 0.0e+00 51 45  0  0  0  51 45  0  0  0  1593
>>> MatLUFactorNum         1 1.0 1.7209e-02 1.0 2.44e+07 1.0 0.0e+00 0.0e+00
>>> 0.0e+00  0  0  0  0  0   0  0  0  0  0  1420
>>> MatCholFctrSym         1 1.0 8.8310e-04 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
>>> MatCholFctrNum         1 1.0 3.6907e-04 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
>>> MatILUFactorSym        1 1.0 3.7372e-03 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
>>> MatAssemblyBegin      29 1.0 2.1458e-06 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
>>> MatAssemblyEnd        29 1.0 9.9473e-03 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
>>> MatGetRow          58026 1.0 2.8155e-03 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
>>> MatGetRowIJ            2 1.0 0.0000e+00 0.0 0.00e+00 0.0 0.0e+00 0.0e+00
>>> MatGetSubMatrice       6 1.0 1.5399e-02 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
>>> MatGetOrdering         2 1.0 3.0112e-04 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
>>> MatZeroEntries         6 1.0 2.9490e-03 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
>>> MatView                7 1.0 3.4356e-03 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
>>> KSPSetUp               4 1.0 9.4891e-05 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
>>> KSPSolve               1 1.0 8.8793e+01 1.0 1.63e+11 1.0 0.0e+00 0.0e+00
>>> 0.0e+00 97100  0  0  0  97100  0  0  0  1840
>>> PCSetUp                4 1.0 3.8375e-02 1.0 2.44e+07 1.0 0.0e+00 0.0e+00
>>> 0.0e+00  0  0  0  0  0   0  0  0  0  0   637
>>> PCSetUpOnBlocks        5 1.0 2.1250e-02 1.0 2.44e+07 1.0 0.0e+00 0.0e+00
>>> 0.0e+00  0  0  0  0  0   0  0  0  0  0  1150
>>> PCApply                5 1.0 8.8789e+01 1.0 1.63e+11 1.0 0.0e+00 0.0e+00
>>> KSPSolve_FS_0          5 1.0 7.5364e-04 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
>>> KSPSolve_FS_Schu       5 1.0 8.8785e+01 1.0 1.63e+11 1.0 0.0e+00 0.0e+00
>>> KSPSolve_FS_Low        5 1.0 2.1019e-03 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
>>> Mem.
>>>               Vector    91             91      9693912     0.
>>>            Index Set    51             51       537888     0.
>>>               Matrix    13             13     64097868     0.
>>>               Viewer     1              0            0     0.
>>> -ksp_monitor
>>> -ksp_view
>>> -log_view
>>> -L/usr/lib/gcc/x86_64-linux-gnu/5 -Wl,-rpath,/usr/lib/x86_64-linux-gnu
>>> -L/usr/lib/x86_64-linux-gnu -Wl,-rpath,/lib/x86_64-linux-gnu
>>> -L/lib/x86_64-linux-gnu -lmpi_cxx -lstdc++ -lscalapack -lml -lmpi_cxx
>>> -lstdc++ -lumfpack -lklu -lcholmod -lbtf -lccolamd -lcolamd -lcamd -lamd
>>> -lsuitesparseconfig -Wl,-rpath,/opt/intel/system_s
>>> tudio_2015.2.050/mkl/lib/intel64 -L/opt/intel/system_studio_2015.2.050/mkl/lib/intel64
>>> -lmkl_intel_lp64 -lmkl_sequential -lmkl_core -lpthread -lm -lhwloc
>>> -lptesmumps -lptscotch -lptscotcherr -lscotch -lscotcherr -lX11 -lm
>>> -lmpi_usempif08 -lmpi_usempi_ignore_tkr -lmpi_mpifh -lgfortran -lm
>>> -lgfortran -lm -lquadmath -lm -lmpi_cxx -lstdc++ -lrt -lm -lpthread -lz
>>> -L/lib/x86_64-linux-gnu -Wl,-rpath,/usr/lib/x86_64-linux-gnu
>>> -L/usr/lib/x86_64-linux-gnu -ldl -Wl,-rpath,/usr/lib/openmpi/lib -lmpi
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20170111/cf233480/attachment-0001.html>
