[petsc-users] -log_view hangs unexpectedly // how to optimize my kspsolve
Manuel Valera mvalera at mail.sdsu.edu
Sat Jan 7 18:17:45 CST 2017
I was able to find the bug, it was the outer loop bound in the same fashion
than before, my -log_view is this :
---------------------------------------------- PETSc Performance Summary:
./ucmsMR on a arch-linux2-c-debug named ocean with 2 processors, by valera
Sat Jan  7 16:11:51 2017
Using Petsc Release Version 3.7.4, unknown
                         Max       Max/Min        Avg      Total
Time (sec):           2.074e+01      1.00000   2.074e+01
Objects:              9.300e+01      1.00000   9.300e+01
Flops:                8.662e+09      1.00000   8.662e+09  1.732e+10
Flops/sec:            4.177e+08      1.00000   4.177e+08  8.354e+08
Memory:               1.027e+08      1.03217              2.021e+08
MPI Messages:         5.535e+02      1.00000   5.535e+02  1.107e+03
MPI Message Lengths:  2.533e+07      1.00000   4.576e+04  5.066e+07
MPI Reductions:       1.903e+04      1.00000
Flop counting convention: 1 flop = 1 real number operation of type
(multiply/divide/add/subtract)
                            e.g., VecAXPY() for real vectors of length N
--> 2N flops
                            and VecAXPY() for complex vectors of length N
--> 8N flops
Summary of Stages:   ----- Time ------  ----- Flops -----  --- Messages
---  -- Message Lengths --  -- Reductions --
                        Avg     %Total     Avg     %Total   counts   %Total
 0:      Main Stage: 2.0739e+01 100.0%  1.7325e+10 100.0%  1.107e+03
100.0%  4.576e+04      100.0%  1.903e+04 100.0%
See the 'Profiling' chapter of the users' manual for details on
interpreting output.
Phase summary info:
   Count: number of times phase was executed
   Time and Flops: Max - maximum over all processors
                   Ratio - ratio of maximum to minimum over all processors
   Mess: number of messages sent
   Avg. len: average message length (bytes)
   Reduct: number of global reductions
   Global: entire computation
   Stage: stages of a computation. Set stages with PetscLogStagePush() and
PetscLogStagePop().
      %T - percent time in this phase         %F - percent flops in this
phase
      %M - percent messages in this phase     %L - percent message lengths
in this phase
      %R - percent reductions in this phase
   Total Mflop/s: 10e-6 * (sum of flops over all processors)/(max time over
all processors)
      #                          WARNING!!!                    #
      #   This code was compiled with a debugging option,      #
      #   To get timing results run ./configure                #
      #   using --with-debugging=no, the performance will      #
      #   be generally two or three times faster.              #
Event                Count      Time (sec)     Flops
      --- Global ---  --- Stage ---   Total
                   Max Ratio  Max     Ratio   Max  Ratio  Mess   Avg len
Reduct  %T %F %M %L %R  %T %F %M %L %R Mflop/s
--- Event Stage 0: Main Stage
VecDotNorm2          545 1.0 4.4925e-01 1.6 2.18e+08 1.0 0.0e+00 0.0e+00
1.1e+03  2  3  0  0  6   2  3  0  0  6   971
VecMDot              525 1.0 1.7089e+00 1.7 1.48e+09 1.0 0.0e+00 0.0e+00
1.0e+03  7 17  0  0  6   7 17  0  0  6  1735
VecNorm              420 1.0 7.6857e-02 1.0 8.40e+07 1.0 0.0e+00 0.0e+00
8.4e+02  0  1  0  0  4   0  1  0  0  4  2186
VecScale            1090 1.0 2.5113e-01 1.1 1.09e+08 1.0 0.0e+00 0.0e+00
0.0e+00  1  1  0  0  0   1  1  0  0  0   868
VecSet               555 1.0 7.3570e-02 1.2 0.00e+00 0.0 0.0e+00 0.0e+00
0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecAXPY             1090 1.0 2.7621e-01 1.1 2.18e+08 1.0 0.0e+00 0.0e+00
0.0e+00  1  3  0  0  0   1  3  0  0  0  1579
VecAYPX                5 1.0 3.6647e-03 2.1 5.00e+05 1.0 0.0e+00 0.0e+00
0.0e+00  0  0  0  0  0   0  0  0  0  0   273
VecMAXPY            1050 1.0 2.3646e+00 1.1 2.97e+09 1.0 0.0e+00 0.0e+00
0.0e+00 11 34  0  0  0  11 34  0  0  0  2508
VecAssemblyBegin      12 1.7 2.4388e-03 2.2 0.00e+00 0.0 0.0e+00 0.0e+00
2.8e+01  0  0  0  0  0   0  0  0  0  0     0
VecAssemblyEnd        12 1.7 1.0085e-04 2.0 0.00e+00 0.0 0.0e+00 0.0e+00
VecScatterBegin      560 1.0 2.3770e+0071.3 0.00e+00 0.0 1.1e+03 2.7e+04
1.0e+01  6  0 99 59  0   6  0 99 59  0     0
VecScatterEnd        550 1.0 3.7769e-02 1.8 0.00e+00 0.0 0.0e+00 0.0e+00
MatMult              550 1.0 3.7412e+00 1.1 1.80e+09 1.0 1.1e+03 2.0e+04
0.0e+00 17 21 99 43  0  17 21 99 43  0   962
MatSolve             545 1.0 3.6138e+00 1.1 1.77e+09 1.0 0.0e+00 0.0e+00
0.0e+00 17 20  0  0  0  17 20  0  0  0   980
MatLUFactorNum         1 1.0 1.2530e-01 1.5 1.27e+07 1.0 0.0e+00 0.0e+00
0.0e+00  1  0  0  0  0   1  0  0  0  0   203
MatILUFactorSym        1 1.0 2.0162e-02 1.8 0.00e+00 0.0 0.0e+00 0.0e+00
MatConvert             1 1.0 3.3683e-02 1.1 0.00e+00 0.0 0.0e+00 0.0e+00
MatAssemblyBegin       1 1.0 9.5172e-02359.3 0.00e+00 0.0 0.0e+00 0.0e+00
4.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatAssemblyEnd         1 1.0 2.6907e-02 1.0 0.00e+00 0.0 4.0e+00 5.0e+03
2.3e+01  0  0  0  0  0   0  0  0  0  0     0
MatGetRowIJ            3 1.0 1.2398e-05 1.2 0.00e+00 0.0 0.0e+00 0.0e+00
MatGetOrdering         1 1.0 4.4249e-02 2.5 0.00e+00 0.0 0.0e+00 0.0e+00
MatLoad                1 1.0 3.8892e-01 1.0 0.00e+00 0.0 7.0e+00 3.0e+06
3.8e+01  2  0  1 41  0   2  0  1 41  0     0
KSPSetUp               2 1.0 2.2634e-02 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
5.0e+00  0  0  0  0  0   0  0  0  0  0     0
KSPSolve               5 1.0 1.2218e+01 1.0 8.66e+09 1.0 1.1e+03 2.0e+04
1.9e+04 59100 99 43 99  59100 99 43 99  1418
PCSetUp                3 1.0 1.7993e+00 1.0 1.27e+07 1.0 0.0e+00 0.0e+00
1.0e+01  8  0  0  0  0   8  0  0  0  0    14
PCSetUpOnBlocks        5 1.0 1.9013e-01 1.7 1.27e+07 1.0 0.0e+00 0.0e+00
0.0e+00  1  0  0  0  0   1  0  0  0  0   134
PCApply              546 1.0 3.8320e+00 1.1 1.77e+09 1.0 0.0e+00 0.0e+00
1.0e+00 18 20  0  0  0  18 20  0  0  0   925
Memory usage is given in bytes:
Object Type          Creations   Destructions     Memory  Descendants' Mem.
Reports information only for process 0.
              Vector    72              6      5609648     0.
      Vector Scatter     3              2         1312     0.
              Matrix     4              0            0     0.
              Viewer     2              0            0     0.
           Index Set     7              4        13104     0.
       Krylov Solver     2              0            0     0.
      Preconditioner     3              1         1384     0.
Average time to get PetscTime(): 7.15256e-08
Average time for MPI_Barrier(): 1.82629e-05
Average time for zero size MPI_Send(): 9.89437e-06
#PETSc Option Table entries:
-log_view
-matload_block_size 1
-pc_hypre_boomeramg_nodal_coarsen 1
-pc_hypre_boomeramg_vec_interp_variant 1
#End of PETSc Option Table entries
Compiled without FORTRAN kernels
Compiled with full precision matrices (default)
sizeof(short) 2 sizeof(int) 4 sizeof(long) 8 sizeof(void*) 8
sizeof(PetscScalar) 8 sizeof(PetscInt) 4
Configure options: --with-cc=gcc --with-cxx=g++ --with-fc=gfortran
--download-fblaslapack --download-mpich --download-hdf5 --download-netcdf
--download-hypre --download-metis --download-parmetis --download-trillinos
Libraries compiled on Fri Dec  9 12:45:19 2016 on ocean
Machine characteristics:
Linux-3.10.0-327.13.1.el7.x86_64-x86_64-with-centos-7.2.1511-Core
Using PETSc directory: /home/valera/petsc
Using PETSc arch: arch-linux2-c-debug
Using C compiler: /home/valera/petsc/arch-linux2-c-debug/bin/mpicc    -Wall
-Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas
-fvisibility=hidden -g3  ${COPTFLAGS} ${CFLAGS}
Using Fortran compiler: /home/valera/petsc/arch-linux2-c-debug/bin/mpif90
  -Wall -ffree-line-length-0 -Wno-unused-dummy-argument -g  ${FOPTFLAGS}
${FFLAGS}
Using include paths: -I/home/valera/petsc/arch-linux2-c-debug/include
-I/home/valera/petsc/include -I/home/valera/petsc/include
Using C linker: /home/valera/petsc/arch-linux2-c-debug/bin/mpicc
Using Fortran linker: /home/valera/petsc/arch-linux2-c-debug/bin/mpif90
Using libraries: -Wl,-rpath,/home/valera/petsc/arch-linux2-c-debug/lib
-L/home/valera/petsc/arch-linux2-c-debug/lib -lpetsc
-L/home/valera/petsc/arch-linux2-c-debug/lib -lparmetis -lmetis -lHYPRE
-Wl,-rpath,/usr/lib/gcc/x86_64-redhat-linux/4.8.5
-L/usr/lib/gcc/x86_64-redhat-linux/4.8.5 -lmpicxx -lstdc++ -lflapack
-lfblas -lnetcdf -lhdf5hl_fortran -lhdf5_fortran -lhdf5_hl -lhdf5 -lpthread
-lm -lmpifort -lgfortran -lm -lgfortran -lm -lquadmath -lm -lmpicxx
-lstdc++ -Wl,-rpath,/home/valera/petsc/arch-linux2-c-debug/lib
-L/usr/lib/gcc/x86_64-redhat-linux/4.8.5 -ldl
-Wl,-rpath,/home/valera/petsc/arch-linux2-c-debug/lib -lmpi -lgcc_s -ldl
WARNING! There are options you set that were not used!
WARNING! could be spelling mistake, etc!
Option left: name:-pc_hypre_boomeramg_nodal_coarsen value: 1
Option left: name:-pc_hypre_boomeramg_vec_interp_variant value: 1
[valera at ocean serGCCOM]$
Any suggestions are very much appreciated,
Thanks
On Sat, Jan 7, 2017 at 3:39 PM, Matthew Knepley <knepley at gmail.com> wrote:
> On Sat, Jan 7, 2017 at 5:33 PM, Manuel Valera <mvalera at mail.sdsu.edu>
> wrote:
>> Thanks Barry and Matt,
>> I was able to detect a bug that i just solved, as suggested the loop
>> parameters weren't updated as it should, now it does and the program still
>> freezes but now in the beginning of the loop... ?
> You have called a collective function from only one process. Stepping
> through on both processes in your run will find this easily.
>   Thanks,
>      Matt
>> Im attaching screen so you have an idea. Im thinking about it...
>> Thanks
>> On Sat, Jan 7, 2017 at 3:21 PM, Matthew Knepley <knepley at gmail.com>
>> wrote:
>>> On Sat, Jan 7, 2017 at 4:59 PM, Manuel Valera <mvalera at mail.sdsu.edu>
>>> wrote:
>>>> I would have to think and code a MWE for this problem before sending it
>>>> since the model is much bigger than the petsc solver. Attached here is a
>>>> screenshot of the debugger as barry taught me, is that the stack trace you
>>>> need ?
>>>> the ucmsMain.f90:522 that shows is the call (from all processes) to the
>>>> routine that updates the rhs vector (from root) and scatters it (from all
>>>> processes).
>>> Yes, so one process is here and the other has moved on, so there is a
>>> mismatch in calls.
>>> You could do what Barry suggests, but I think it would be better to just
>>> step through your main routine once (its slow going), and
>>> see where the divergence happens.
>>>    Matt
>>>> This routine is itself inside a double loop that occurs in all
>>>> processes but the only call from all processes to the solver is this one,
>>>> the rest of the loop which involves correcting for velocities, pressure and
>>>> temperature, all happens in root node.
>>>> Sorry for the convoluted program design, this is the first beta version
>>>> of the model working on parallel and was the best i could come with, i
>>>> suppose it makes more sense in serial,
>>>> Thanks
>>>> On Sat, Jan 7, 2017 at 2:24 PM, Matthew Knepley <knepley at gmail.com>
>>>> wrote:
>>>>> On Sat, Jan 7, 2017 at 4:20 PM, Manuel Valera <mvalera at mail.sdsu.edu>
>>>>> wrote:
>>>>>> Thank you Matthew,
>>>>>> On Sat, Jan 7, 2017 at 1:49 PM, Matthew Knepley <knepley at gmail.com>
>>>>>> wrote:
>>>>>>> On Sat, Jan 7, 2017 at 3:32 PM, Manuel Valera <mvalera at mail.sdsu.edu
>>>>>>> > wrote:
>>>>>>>> Hi Devs, hope you are having a great weekend,
>>>>>>>> I could finally parallelize my linear solver and implement it into
>>>>>>>> the rest of the code in a way that only the linear system is solved in
>>>>>>>> parallel, great news for my team, but there is a catch and is that i don't
>>>>>>>> see any speedup in the linear system, i don't know if its the MPI in the
>>>>>>>> cluster we are using, but im not sure on how to debug it,
>>>>>>> We need to see -log_view output for any performance question.
>>>>>>>> On the other hand and because of this issue i was trying to do
>>>>>>>> -log_summary or -log_view and i noticed the program in this context hangs
>>>>>>>> when is time of producing the log, if i debug this for 2 cores, process 0
>>>>>>>> exits normally but process 1 hangs in the vectorscatterbegin() with
>>>>>>>> scatter_reverse way back in the code,
>>>>>>> You are calling a collective routine from only 1 process.
>>>>>>   Matt
>>>>>> I am pretty confident this is not the case,
>>>>> This is still the simplest explanation. Can you send the stack trace
>>>>> for the 2 process run?
>>>>>> the callings to vecscattercreatetozero and vecscatterbegin are made
>>>>>> in all processes, the program goes thru all of the iterations on the linear
>>>>>> solver, writes output correctly and even closes all the petsc objects
>>>>>> without complaining, the freeze occurs at the very end when the log is to
>>>>>> be produced.
>>>>> If you can send us a code to run, we can likely find the error.
>>>>>   Thanks,
>>>>>      Matt
>>>>>> Thanks,
>>>>>> Manuel
>>>>>>>> and even after destroying all associated objects and calling
>>>>>>>> petscfinalize(), so im really clueless on why is this, as it only happens
>>>>>>>> for -log_* or -ksp_view options.
>>>>>>>> my -ksp_view shows this:
>>>>>>>>  KSP Object: 2 MPI processes
>>>>>>>>   type: gcr
>>>>>>>>     GCR: restart = 30
>>>>>>>>     GCR: restarts performed = 20
>>>>>>>>   maximum iterations=10000, initial guess is zero
>>>>>>>>   tolerances:  relative=1e-14, absolute=1e-50, divergence=10000.
>>>>>>>>   right preconditioning
>>>>>>>>   using UNPRECONDITIONED norm type for convergence test
>>>>>>>> PC Object: 2 MPI processes
>>>>>>>>   type: bjacobi
>>>>>>>>     block Jacobi: number of blocks = 2
>>>>>>>>     Local solve is same for all blocks, in the following KSP and PC
>>>>>>>> objects:
>>>>>>>>   KSP Object:  (sub_)   1 MPI processes
>>>>>>>>     type: preonly
>>>>>>>>     tolerances:  relative=1e-05, absolute=1e-50, divergence=10000.
>>>>>>>>     left preconditioning
>>>>>>>>     using NONE norm type for convergence test
>>>>>>>>   PC Object:  (sub_)   1 MPI processes
>>>>>>>>     type: ilu
>>>>>>>>       ILU: out-of-place factorization
>>>>>>>>       0 levels of fill
>>>>>>>>       tolerance for zero pivot 2.22045e-14
>>>>>>>>       matrix ordering: natural
>>>>>>>>       factor fill ratio given 1., needed 1.
>>>>>>>>         Factored matrix follows:
>>>>>>>>           Mat Object:           1 MPI processes
>>>>>>>>             type: seqaij
>>>>>>>>             rows=100000, cols=100000
>>>>>>>>             package used to perform factorization: petsc
>>>>>>>>             total: nonzeros=1675180, allocated nonzeros=1675180
>>>>>>>>             total number of mallocs used during MatSetValues calls
>>>>>>>> =0
>>>>>>>>               not using I-node routines
>>>>>>>>     linear system matrix = precond matrix:
>>>>>>>>       type: seqaij
>>>>>>>>       total number of mallocs used during MatSetValues calls =0
>>>>>>>>   Mat Object:   2 MPI processes
>>>>>>>>     type: mpiaij
>>>>>>>>     rows=200000, cols=200000
>>>>>>>>     total: nonzeros=3373340, allocated nonzeros=3373340
>>>>>>>>       not using I-node (on process 0) routines
>>>>>>>> And i configured my PC object as:
>>>>>>>>    call PCSetType(mg,PCHYPRE,ierr)
>>>>>>>>    call PCHYPRESetType(mg,'boomeramg',ierr)
>>>>>>>>     call PetscOptionsSetValue(PETSC_NULL_OBJECT,
>>>>>>>> 'pc_hypre_boomeramg_nodal_coarsen','1',ierr)
>>>>>>>> 'pc_hypre_boomeramg_vec_interp_variant','1',ierr)
>>>>>>>> What are your thoughts ?
>>>>>>>> Thanks,
>>>>>>>> Manuel
>>>>>>>> On Fri, Jan 6, 2017 at 1:58 PM, Manuel Valera <
>>>>>>>> mvalera at mail.sdsu.edu> wrote:
>>>>>>>>> Awesome, that did it, thanks once again.
>>>>>>>>> On Fri, Jan 6, 2017 at 1:53 PM, Barry Smith <bsmith at mcs.anl.gov>
>>>>>>>>> wrote:
>>>>>>>>>>    Take the scatter out of the if () since everyone does it and
>>>>>>>>>> get rid of the VecView().
>>>>>>>>>>    Does this work? If not where is it hanging?
>>>>>>>>>> > On Jan 6, 2017, at 3:29 PM, Manuel Valera <
>>>>>>>>>> > Thanks Dave,
>>>>>>>>>> > I think is interesting it never gave an error on this, after
>>>>>>>>>> adding the vecassembly calls it still shows the same behavior, without
>>>>>>>>>> complaining, i did:
>>>>>>>>>> > if(rankl==0)then
>>>>>>>>>> >      call VecSetValues(bp0,nbdp,ind,Rhs,INSERT_VALUES,ierr)
>>>>>>>>>> >      call VecAssemblyBegin(bp0,ierr) ; call
>>>>>>>>>> VecAssemblyEnd(bp0,ierr);
>>>>>>>>>> >      CHKERRQ(ierr)
>>>>>>>>>> endif
>>>>>>>>>> >      call VecScatterBegin(ctr,bp0,bp2,IN
>>>>>>>>>> SERT_VALUES,SCATTER_REVERSE,ierr)
>>>>>>>>>> >      call VecScatterEnd(ctr,bp0,bp2,INSE
>>>>>>>>>> >      print*,"done! "
>>>>>>>>>> >      CHKERRQ(ierr)
>>>>>>>>>> >        CHKERRQ(ierr)
>>>>>>>>>> > Thanks.
>>>>>>>>>> > On Fri, Jan 6, 2017 at 12:44 PM, Dave May <
>>>>>>>>>> dave.mayhem23 at gmail.com> wrote:
>>>>>>>>>> > On 6 January 2017 at 20:24, Manuel Valera <
>>>>>>>>>> > Great help Barry, i totally had overlooked that option (it is
>>>>>>>>>> explicit in the vecscatterbegin call help page but not in
>>>>>>>>>> vecscattercreatetozero, as i read later)
>>>>>>>>>> > So i used that and it works partially, it scatters te values
>>>>>>>>>> assigned in root but not the rest, if i call vecscatterbegin from outside
>>>>>>>>>> root it hangs, the code currently look as this:
>>>>>>>>>> >   call VecScatterCreateToZero(bp2,ctr,bp0,ierr); CHKERRQ(ierr)
>>>>>>>>>> >   call PetscObjectSetName(bp0, 'bp0:',ierr)
>>>>>>>>>> > if(rankl==0)then
>>>>>>>>>> >      call VecView(bp0,PETSC_VIEWER_STDOUT_WORLD,ierr)
>>>>>>>>>> > You need to call
>>>>>>>>>> >   VecAssemblyBegin(bp0);
>>>>>>>>>> >   VecAssemblyEnd(bp0);
>>>>>>>>>> > after your last call to VecSetValues() before you can do any
>>>>>>>>>> operations with bp0.
>>>>>>>>>> > With your current code, the call to VecView should produce an
>>>>>>>>>> error if you used the error checking macro CHKERRQ(ierr) (as should
>>>>>>>>>> VecScatter{Begin,End}
>>>>>>>>>> > Thanks,
>>>>>>>>>> >   Dave
>>>>>>>>>> >      print*,"done! "
>>>>>>>>>> >      CHKERRQ(ierr)
>>>>>>>>>> > endif
>>>>>>>>>> >    ! call VecScatterBegin(ctr,bp0,bp2,IN
>>>>>>>>>> >    !  call VecScatterEnd(ctr,bp0,bp2,INSE
>>>>>>>>>> >   call VecView(bp2,PETSC_VIEWER_STDOUT_WORLD,ierr)
>>>>>>>>>> >   call PetscBarrier(PETSC_NULL_OBJECT,ierr)
>>>>>>>>>> >   call exit()
>>>>>>>>>> > And the output is: (with bp the right answer)
>>>>>>>>>> > Vec Object:bp: 2 MPI processes
>>>>>>>>>> >   type: mpi
>>>>>>>>>> > Process [0]
>>>>>>>>>> > 1.
>>>>>>>>>> > 2.
>>>>>>>>>> > Process [1]
>>>>>>>>>> > 4.
>>>>>>>>>> > 3.
>>>>>>>>>> > Vec Object:bp2: 2 MPI processes  (before scatter)
>>>>>>>>>> >   type: mpi
>>>>>>>>>> > Process [0]
>>>>>>>>>> > 0.
>>>>>>>>>> > 0.
>>>>>>>>>> > Process [1]
>>>>>>>>>> > 0.
>>>>>>>>>> > 0.
>>>>>>>>>> > Vec Object:bp0: 1 MPI processes
>>>>>>>>>> >   type: seq
>>>>>>>>>> > 1.
>>>>>>>>>> > 2.
>>>>>>>>>> > 4.
>>>>>>>>>> > 3.
>>>>>>>>>> >  done!
>>>>>>>>>> > Vec Object:bp2: 2 MPI processes  (after scatter)
>>>>>>>>>> >   type: mpi
>>>>>>>>>> > Process [0]
>>>>>>>>>> > 1.
>>>>>>>>>> > 2.
>>>>>>>>>> > Process [1]
>>>>>>>>>> > 0.
>>>>>>>>>> > 0.
>>>>>>>>>> > Thanks inmensely for your help,
>>>>>>>>>> > Manuel
>>>>>>>>>> > On Thu, Jan 5, 2017 at 4:39 PM, Barry Smith <bsmith at mcs.anl.gov>
>>>>>>>>>> wrote:
>>>>>>>>>> > > On Jan 5, 2017, at 6:21 PM, Manuel Valera <
>>>>>>>>>> > > Hello Devs is me again,
>>>>>>>>>> > > I'm trying to distribute a vector to all called processes,
>>>>>>>>>> the vector would be originally in root as a sequential vector and i would
>>>>>>>>>> like to scatter it, what would the best call to do this ?
>>>>>>>>>> > > I already know how to gather a distributed vector to root
>>>>>>>>>> with VecScatterCreateToZero, this would be the inverse operation,
>>>>>>>>>> >    Use the same VecScatter object but with SCATTER_REVERSE, not
>>>>>>>>>> you need to reverse the two vector arguments as well.
>>>>>>>>>> > > i'm currently trying with VecScatterCreate() and as of now im
>>>>>>>>>> doing the following:
>>>>>>>>>> > > if(rank==0)then
>>>>>>>>>> > >      call VecCreate(PETSC_COMM_SELF,bp0,ierr); CHKERRQ(ierr)
>>>>>>>>>> !if i use WORLD
>>>>>>>>>> !freezes in SetSizes
>>>>>>>>>> > >      call VecSetSizes(bp0,PETSC_DECIDE,nbdp,ierr);
>>>>>>>>>> CHKERRQ(ierr)
>>>>>>>>>> > >      call VecSetType(bp0,VECSEQ,ierr)
>>>>>>>>>> > >      call VecSetFromOptions(bp0,ierr); CHKERRQ(ierr)
>>>>>>>>>> > >      !call VecSet(bp0,5.0D0,ierr); CHKERRQ(ierr)
>>>>>>>>>> VecAssemblyEnd(bp0,ierr) !rhs
>>>>>>>>>> > >      do i=0,nbdp-1,1
>>>>>>>>>> > >         ind(i+1) = i
>>>>>>>>>> > >      enddo
>>>>>>>>>> > >      call ISCreateGeneral(PETSC_COMM_SEL
>>>>>>>>>> F,nbdp,ind,PETSC_COPY_VALUES,locis,ierr)
>>>>>>>>>> > >     !call VecScatterCreate(bp0,PETSC_NULL_OBJECT,bp2,is,ctr,ierr)
>>>>>>>>>> !if i use SELF
>>>>>>>>>>      !freezes here.
>>>>>>>>>> > >      call VecScatterCreate(bp0,locis,bp2
>>>>>>>>>> ,PETSC_NULL_OBJECT,ctr,ierr)
>>>>>>>>>> > > endif
>>>>>>>>>> > > bp2 being the receptor MPI vector to scatter to
>>>>>>>>>> > > But it freezes in VecScatterCreate when trying to use more
>>>>>>>>>> than one processor, what would be a better approach ?
>>>>>>>>>> > > Thanks once again,
>>>>>>>>>> > > Manuel
>>>>>>>>>> > > On Wed, Jan 4, 2017 at 3:30 PM, Manuel Valera <
>>>>>>>>>> > > Thanks i had no idea how to debug and read those logs, that
>>>>>>>>>> solved this issue at least (i was sending a message from root to everyone
>>>>>>>>>> else, but trying to catch from everyone else including root)
>>>>>>>>>> > > Until next time, many thanks,
>>>>>>>>>> > > Manuel
>>>>>>>>>> > > On Wed, Jan 4, 2017 at 3:23 PM, Matthew Knepley <
>>>>>>>>>> > > On Wed, Jan 4, 2017 at 5:21 PM, Manuel Valera <
>>>>>>>>>> > > I did a PetscBarrier just before calling the vicariate
>>>>>>>>>> routine and im pretty sure im calling it from every processor, code looks
>>>>>>>>>> like this:
>>>>>>>>>> > > From the gdb trace.
>>>>>>>>>> > >   Proc 0: Is in some MPI routine you call yourself, line 113
>>>>>>>>>> > >   Proc 1: Is in VecCreate(), line 130
>>>>>>>>>> > > You need to fix your communication code.
>>>>>>>>>> > >    Matt
>>>>>>>>>> > > print*,'entering POInit from',rank
>>>>>>>>>> > > !call exit()
>>>>>>>>>> > > call PetscObjsInit()
>>>>>>>>>> > > And output gives:
>>>>>>>>>> > >  entering POInit from           0
>>>>>>>>>> > >  entering POInit from           1
>>>>>>>>>> > >  entering POInit from           2
>>>>>>>>>> > >  entering POInit from           3
>>>>>>>>>> > > Still hangs in the same way,
>>>>>>>>>> > > Thanks,
>>>>>>>>>> > > Manuel
>>>>>>>>>> > > On Wed, Jan 4, 2017 at 2:55 PM, Manuel Valera <
>>>>>>>>>> > > Thanks for the answers !
>>>>>>>>>> > > heres the screenshot of what i got from bt in gdb (great hint
>>>>>>>>>> in how to debug in petsc, didn't know that)
>>>>>>>>>> > > I don't really know what to look at here,
>>>>>>>>>> > > Thanks,
>>>>>>>>>> > > Manuel
>>>>>>>>>> > > On Wed, Jan 4, 2017 at 2:39 PM, Dave May <
>>>>>>>>>> > > Are you certain ALL ranks in PETSC_COMM_WORLD call these
>>>>>>>>>> function(s). These functions cannot be inside if statements like
>>>>>>>>>> > > if (rank == 0){
>>>>>>>>>> > >   VecCreateMPI(...)
>>>>>>>>>> > > On Wed, 4 Jan 2017 at 23:34, Manuel Valera <
>>>>>>>>>> > > Thanks Dave for the quick answer, appreciate it,
>>>>>>>>>> > > I just tried that and it didn't make a difference, any other
>>>>>>>>>> suggestions ?
>>>>>>>>>> > > Thanks,
>>>>>>>>>> > > Manuel
>>>>>>>>>> > > On Wed, Jan 4, 2017 at 2:29 PM, Dave May <
>>>>>>>>>> > > You need to swap the order of your function calls.
>>>>>>>>>> > > Call VecSetSizes() before VecSetType()
>>>>>>>>>> > > Thanks,
>>>>>>>>>> > >   Dave
>>>>>>>>>> > > On Wed, 4 Jan 2017 at 23:21, Manuel Valera <
>>>>>>>>>> > > Hello all, happy new year,
>>>>>>>>>> > > I'm working on parallelizing my code, it worked and provided
>>>>>>>>>> some results when i just called more than one processor, but created
>>>>>>>>>> artifacts because i didn't need one image of the whole program in each
>>>>>>>>>> processor, conflicting with each other.
>>>>>>>>>> > > Since the pressure solver is the main part i need in parallel
>>>>>>>>>> im chosing mpi to run everything in root processor until its time to solve
>>>>>>>>>> for pressure, at this point im trying to create a distributed vector using
>>>>>>>>>> either
>>>>>>>>>> > >      call VecCreateMPI(PETSC_COMM_WORLD,
>>>>>>>>>> PETSC_DECIDE,nbdp,xp,ierr)
>>>>>>>>>> > > or
>>>>>>>>>> > >      call VecCreate(PETSC_COMM_WORLD,xp,ierr); CHKERRQ(ierr)
>>>>>>>>>> > >      call VecSetType(xp,VECMPI,ierr)
>>>>>>>>>> > >      call VecSetSizes(xp,PETSC_DECIDE,nbdp,ierr);
>>>>>>>>>> CHKERRQ(ierr)
>>>>>>>>>> > > In both cases program hangs at this point, something it never
>>>>>>>>>> happened on the naive way i described before. I've made sure the global
>>>>>>>>>> size, nbdp, is the same in every processor. What can be wrong?
>>>>>>>>>> > > Thanks for your kind help,
>>>>>>>>>> > > Manuel.
>>>>>>>>>> > > What most experimenters take for granted before they begin
>>>>>>>>>> their experiments is infinitely more interesting than any results to which
>>>>>>>>>> their experiments lead.
>>>>>>>>>> > > -- Norbert Wiener
>>>>>>> What most experimenters take for granted before they begin their
>>>>>>> experiments is infinitely more interesting than any results to which their
>>>>>>> experiments lead.
>>>>>>> -- Norbert Wiener
>>>>> experiments lead.
>>>>> -- Norbert Wiener
>>> experiments lead.
>>> -- Norbert Wiener
> experiments lead.
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20170107/e7049d5c/attachment-0001.html>
