[petsc-users] -log_view hangs unexpectedly // how to optimize my kspsolve
Sat Jan 7 17:39:39 CST 2017
On Sat, Jan 7, 2017 at 5:33 PM, Manuel Valera <mvalera at mail.sdsu.edu> wrote:
> Thanks Barry and Matt,
> I was able to detect a bug that i just solved, as suggested the loop
> parameters weren't updated as it should, now it does and the program still
> freezes but now in the beginning of the loop... ?
You have called a collective function from only one process. Stepping
through on both processes in your run will find this easily.
     Matt
> Im attaching screen so you have an idea. Im thinking about it...
> Thanks
> On Sat, Jan 7, 2017 at 3:21 PM, Matthew Knepley <knepley at gmail.com> wrote:
>> On Sat, Jan 7, 2017 at 4:59 PM, Manuel Valera <mvalera at mail.sdsu.edu>
>> wrote:
>>> I would have to think and code a MWE for this problem before sending it
>>> since the model is much bigger than the petsc solver. Attached here is a
>>> screenshot of the debugger as barry taught me, is that the stack trace you
>>> need ?
>>> the ucmsMain.f90:522 that shows is the call (from all processes) to the
>>> routine that updates the rhs vector (from root) and scatters it (from all
>>> processes).
>> Yes, so one process is here and the other has moved on, so there is a
>> mismatch in calls.
>> You could do what Barry suggests, but I think it would be better to just
>> step through your main routine once (its slow going), and
>> see where the divergence happens.
>>    Matt
>>> This routine is itself inside a double loop that occurs in all processes
>>> but the only call from all processes to the solver is this one, the rest of
>>> the loop which involves correcting for velocities, pressure and
>>> temperature, all happens in root node.
>>> Sorry for the convoluted program design, this is the first beta version
>>> of the model working on parallel and was the best i could come with, i
>>> suppose it makes more sense in serial,
>>> Thanks
>>> On Sat, Jan 7, 2017 at 2:24 PM, Matthew Knepley <knepley at gmail.com>
>>> wrote:
>>>> On Sat, Jan 7, 2017 at 4:20 PM, Manuel Valera <mvalera at mail.sdsu.edu>
>>>> wrote:
>>>>> Thank you Matthew,
>>>>> On Sat, Jan 7, 2017 at 1:49 PM, Matthew Knepley <knepley at gmail.com>
>>>>> wrote:
>>>>>> On Sat, Jan 7, 2017 at 3:32 PM, Manuel Valera <mvalera at mail.sdsu.edu>
>>>>>> wrote:
>>>>>>> Hi Devs, hope you are having a great weekend,
>>>>>>> I could finally parallelize my linear solver and implement it into
>>>>>>> the rest of the code in a way that only the linear system is solved in
>>>>>>> parallel, great news for my team, but there is a catch and is that i don't
>>>>>>> see any speedup in the linear system, i don't know if its the MPI in the
>>>>>>> cluster we are using, but im not sure on how to debug it,
>>>>>> We need to see -log_view output for any performance question.
>>>>>>> On the other hand and because of this issue i was trying to do
>>>>>>> -log_summary or -log_view and i noticed the program in this context hangs
>>>>>>> when is time of producing the log, if i debug this for 2 cores, process 0
>>>>>>> exits normally but process 1 hangs in the vectorscatterbegin() with
>>>>>>> scatter_reverse way back in the code,
>>>>>> You are calling a collective routine from only 1 process.
>>>>>   Matt
>>>>> I am pretty confident this is not the case,
>>>> This is still the simplest explanation. Can you send the stack trace
>>>> for the 2 process run?
>>>>> the callings to vecscattercreatetozero and vecscatterbegin are made in
>>>>> all processes, the program goes thru all of the iterations on the linear
>>>>> solver, writes output correctly and even closes all the petsc objects
>>>>> without complaining, the freeze occurs at the very end when the log is to
>>>>> be produced.
>>>> If you can send us a code to run, we can likely find the error.
>>>>   Thanks,
>>>>      Matt
>>>>> Thanks,
>>>>> Manuel
>>>>>>> and even after destroying all associated objects and calling
>>>>>>> petscfinalize(), so im really clueless on why is this, as it only happens
>>>>>>> for -log_* or -ksp_view options.
>>>>>>> my -ksp_view shows this:
>>>>>>>  KSP Object: 2 MPI processes
>>>>>>>   type: gcr
>>>>>>>     GCR: restart = 30
>>>>>>>     GCR: restarts performed = 20
>>>>>>>   maximum iterations=10000, initial guess is zero
>>>>>>>   tolerances:  relative=1e-14, absolute=1e-50, divergence=10000.
>>>>>>>   right preconditioning
>>>>>>>   using UNPRECONDITIONED norm type for convergence test
>>>>>>> PC Object: 2 MPI processes
>>>>>>>   type: bjacobi
>>>>>>>     block Jacobi: number of blocks = 2
>>>>>>>     Local solve is same for all blocks, in the following KSP and PC
>>>>>>> objects:
>>>>>>>   KSP Object:  (sub_)   1 MPI processes
>>>>>>>     type: preonly
>>>>>>>     tolerances:  relative=1e-05, absolute=1e-50, divergence=10000.
>>>>>>>     left preconditioning
>>>>>>>     using NONE norm type for convergence test
>>>>>>>   PC Object:  (sub_)   1 MPI processes
>>>>>>>     type: ilu
>>>>>>>       ILU: out-of-place factorization
>>>>>>>       0 levels of fill
>>>>>>>       tolerance for zero pivot 2.22045e-14
>>>>>>>       matrix ordering: natural
>>>>>>>       factor fill ratio given 1., needed 1.
>>>>>>>         Factored matrix follows:
>>>>>>>           Mat Object:           1 MPI processes
>>>>>>>             type: seqaij
>>>>>>>             rows=100000, cols=100000
>>>>>>>             package used to perform factorization: petsc
>>>>>>>             total: nonzeros=1675180, allocated nonzeros=1675180
>>>>>>>             total number of mallocs used during MatSetValues calls =0
>>>>>>>               not using I-node routines
>>>>>>>     linear system matrix = precond matrix:
>>>>>>>       type: seqaij
>>>>>>>   Mat Object:   2 MPI processes
>>>>>>>     type: mpiaij
>>>>>>>     rows=200000, cols=200000
>>>>>>>     total: nonzeros=3373340, allocated nonzeros=3373340
>>>>>>>       not using I-node (on process 0) routines
>>>>>>> And i configured my PC object as:
>>>>>>>    call PCSetType(mg,PCHYPRE,ierr)
>>>>>>>    call PCHYPRESetType(mg,'boomeramg',ierr)
>>>>>>>     call PetscOptionsSetValue(PETSC_NULL_OBJECT,
>>>>>>> 'pc_hypre_boomeramg_nodal_coarsen','1',ierr)
>>>>>>> 'pc_hypre_boomeramg_vec_interp_variant','1',ierr)
>>>>>>> What are your thoughts ?
>>>>>>> Thanks,
>>>>>>> Manuel
>>>>>>> On Fri, Jan 6, 2017 at 1:58 PM, Manuel Valera <mvalera at mail.sdsu.edu
>>>>>>> > wrote:
>>>>>>>> Awesome, that did it, thanks once again.
>>>>>>>> On Fri, Jan 6, 2017 at 1:53 PM, Barry Smith <bsmith at mcs.anl.gov>
>>>>>>>> wrote:
>>>>>>>>>    Take the scatter out of the if () since everyone does it and
>>>>>>>>> get rid of the VecView().
>>>>>>>>>    Does this work? If not where is it hanging?
>>>>>>>>> > On Jan 6, 2017, at 3:29 PM, Manuel Valera <mvalera at mail.sdsu.edu>
>>>>>>>>> wrote:
>>>>>>>>> > Thanks Dave,
>>>>>>>>> > I think is interesting it never gave an error on this, after
>>>>>>>>> adding the vecassembly calls it still shows the same behavior, without
>>>>>>>>> complaining, i did:
>>>>>>>>> > if(rankl==0)then
>>>>>>>>> >      call VecSetValues(bp0,nbdp,ind,Rhs,INSERT_VALUES,ierr)
>>>>>>>>> >      call VecAssemblyBegin(bp0,ierr) ; call
>>>>>>>>> VecAssemblyEnd(bp0,ierr);
>>>>>>>>> >      CHKERRQ(ierr)
>>>>>>>>> endif
>>>>>>>>> >      call VecScatterBegin(ctr,bp0,bp2,IN
>>>>>>>>> SERT_VALUES,SCATTER_REVERSE,ierr)
>>>>>>>>> >      call VecScatterEnd(ctr,bp0,bp2,INSE
>>>>>>>>> >      print*,"done! "
>>>>>>>>> >      CHKERRQ(ierr)
>>>>>>>>> >        CHKERRQ(ierr)
>>>>>>>>> > Thanks.
>>>>>>>>> > On Fri, Jan 6, 2017 at 12:44 PM, Dave May <
>>>>>>>>> dave.mayhem23 at gmail.com> wrote:
>>>>>>>>> > On 6 January 2017 at 20:24, Manuel Valera <mvalera at mail.sdsu.edu>
>>>>>>>>> wrote:
>>>>>>>>> > Great help Barry, i totally had overlooked that option (it is
>>>>>>>>> explicit in the vecscatterbegin call help page but not in
>>>>>>>>> vecscattercreatetozero, as i read later)
>>>>>>>>> > So i used that and it works partially, it scatters te values
>>>>>>>>> assigned in root but not the rest, if i call vecscatterbegin from outside
>>>>>>>>> root it hangs, the code currently look as this:
>>>>>>>>> >   call VecScatterCreateToZero(bp2,ctr,bp0,ierr); CHKERRQ(ierr)
>>>>>>>>> >   call PetscObjectSetName(bp0, 'bp0:',ierr)
>>>>>>>>> > if(rankl==0)then
>>>>>>>>> >      call VecView(bp0,PETSC_VIEWER_STDOUT_WORLD,ierr)
>>>>>>>>> > You need to call
>>>>>>>>> >   VecAssemblyBegin(bp0);
>>>>>>>>> >   VecAssemblyEnd(bp0);
>>>>>>>>> > after your last call to VecSetValues() before you can do any
>>>>>>>>> operations with bp0.
>>>>>>>>> > With your current code, the call to VecView should produce an
>>>>>>>>> error if you used the error checking macro CHKERRQ(ierr) (as should
>>>>>>>>> VecScatter{Begin,End}
>>>>>>>>> > Thanks,
>>>>>>>>> >   Dave
>>>>>>>>> >      print*,"done! "
>>>>>>>>> >      CHKERRQ(ierr)
>>>>>>>>> > endif
>>>>>>>>> >    ! call VecScatterBegin(ctr,bp0,bp2,IN
>>>>>>>>> >    !  call VecScatterEnd(ctr,bp0,bp2,INSE
>>>>>>>>> >   call VecView(bp2,PETSC_VIEWER_STDOUT_WORLD,ierr)
>>>>>>>>> >   call PetscBarrier(PETSC_NULL_OBJECT,ierr)
>>>>>>>>> >   call exit()
>>>>>>>>> > And the output is: (with bp the right answer)
>>>>>>>>> > Vec Object:bp: 2 MPI processes
>>>>>>>>> >   type: mpi
>>>>>>>>> > Process [0]
>>>>>>>>> > 1.
>>>>>>>>> > 2.
>>>>>>>>> > Process [1]
>>>>>>>>> > 4.
>>>>>>>>> > 3.
>>>>>>>>> > Vec Object:bp2: 2 MPI processes  (before scatter)
>>>>>>>>> >   type: mpi
>>>>>>>>> > Process [0]
>>>>>>>>> > 0.
>>>>>>>>> > 0.
>>>>>>>>> > Process [1]
>>>>>>>>> > 0.
>>>>>>>>> > 0.
>>>>>>>>> > Vec Object:bp0: 1 MPI processes
>>>>>>>>> >   type: seq
>>>>>>>>> > 1.
>>>>>>>>> > 2.
>>>>>>>>> > 4.
>>>>>>>>> > 3.
>>>>>>>>> >  done!
>>>>>>>>> > Vec Object:bp2: 2 MPI processes  (after scatter)
>>>>>>>>> >   type: mpi
>>>>>>>>> > Process [0]
>>>>>>>>> > 1.
>>>>>>>>> > 2.
>>>>>>>>> > Process [1]
>>>>>>>>> > 0.
>>>>>>>>> > 0.
>>>>>>>>> > Thanks inmensely for your help,
>>>>>>>>> > Manuel
>>>>>>>>> > On Thu, Jan 5, 2017 at 4:39 PM, Barry Smith <bsmith at mcs.anl.gov>
>>>>>>>>> wrote:
>>>>>>>>> > > On Jan 5, 2017, at 6:21 PM, Manuel Valera <
>>>>>>>>> > > Hello Devs is me again,
>>>>>>>>> > > I'm trying to distribute a vector to all called processes, the
>>>>>>>>> vector would be originally in root as a sequential vector and i would like
>>>>>>>>> to scatter it, what would the best call to do this ?
>>>>>>>>> > > I already know how to gather a distributed vector to root with
>>>>>>>>> VecScatterCreateToZero, this would be the inverse operation,
>>>>>>>>> >    Use the same VecScatter object but with SCATTER_REVERSE, not
>>>>>>>>> you need to reverse the two vector arguments as well.
>>>>>>>>> > > i'm currently trying with VecScatterCreate() and as of now im
>>>>>>>>> doing the following:
>>>>>>>>> > > if(rank==0)then
>>>>>>>>> > >      call VecCreate(PETSC_COMM_SELF,bp0,ierr); CHKERRQ(ierr)
>>>>>>>>> !if i use WORLD
>>>>>>>>> !freezes in SetSizes
>>>>>>>>> > >      call VecSetSizes(bp0,PETSC_DECIDE,nbdp,ierr);
>>>>>>>>> CHKERRQ(ierr)
>>>>>>>>> > >      call VecSetType(bp0,VECSEQ,ierr)
>>>>>>>>> > >      call VecSetFromOptions(bp0,ierr); CHKERRQ(ierr)
>>>>>>>>> > >      !call VecSet(bp0,5.0D0,ierr); CHKERRQ(ierr)
>>>>>>>>> VecAssemblyEnd(bp0,ierr) !rhs
>>>>>>>>> > >      do i=0,nbdp-1,1
>>>>>>>>> > >         ind(i+1) = i
>>>>>>>>> > >      enddo
>>>>>>>>> > >      call ISCreateGeneral(PETSC_COMM_SEL
>>>>>>>>> F,nbdp,ind,PETSC_COPY_VALUES,locis,ierr)
>>>>>>>>> > >     !call VecScatterCreate(bp0,PETSC_NULL_OBJECT,bp2,is,ctr,ierr)
>>>>>>>>> !if i use SELF
>>>>>>>>>    !freezes here.
>>>>>>>>> > >      call VecScatterCreate(bp0,locis,bp2
>>>>>>>>> ,PETSC_NULL_OBJECT,ctr,ierr)
>>>>>>>>> > > endif
>>>>>>>>> > > bp2 being the receptor MPI vector to scatter to
>>>>>>>>> > > But it freezes in VecScatterCreate when trying to use more
>>>>>>>>> than one processor, what would be a better approach ?
>>>>>>>>> > > Thanks once again,
>>>>>>>>> > > Manuel
>>>>>>>>> > > On Wed, Jan 4, 2017 at 3:30 PM, Manuel Valera <
>>>>>>>>> > > Thanks i had no idea how to debug and read those logs, that
>>>>>>>>> solved this issue at least (i was sending a message from root to everyone
>>>>>>>>> else, but trying to catch from everyone else including root)
>>>>>>>>> > > Until next time, many thanks,
>>>>>>>>> > > Manuel
>>>>>>>>> > > On Wed, Jan 4, 2017 at 3:23 PM, Matthew Knepley <
>>>>>>>>> > > On Wed, Jan 4, 2017 at 5:21 PM, Manuel Valera <
>>>>>>>>> > > I did a PetscBarrier just before calling the vicariate routine
>>>>>>>>> and im pretty sure im calling it from every processor, code looks like this:
>>>>>>>>> > > From the gdb trace.
>>>>>>>>> > >   Proc 0: Is in some MPI routine you call yourself, line 113
>>>>>>>>> > >   Proc 1: Is in VecCreate(), line 130
>>>>>>>>> > > You need to fix your communication code.
>>>>>>>>> > >    Matt
>>>>>>>>> > > print*,'entering POInit from',rank
>>>>>>>>> > > !call exit()
>>>>>>>>> > > call PetscObjsInit()
>>>>>>>>> > > And output gives:
>>>>>>>>> > >  entering POInit from           0
>>>>>>>>> > >  entering POInit from           1
>>>>>>>>> > >  entering POInit from           2
>>>>>>>>> > >  entering POInit from           3
>>>>>>>>> > > Still hangs in the same way,
>>>>>>>>> > > Thanks,
>>>>>>>>> > > Manuel
>>>>>>>>> > > On Wed, Jan 4, 2017 at 2:55 PM, Manuel Valera <
>>>>>>>>> > > Thanks for the answers !
>>>>>>>>> > > heres the screenshot of what i got from bt in gdb (great hint
>>>>>>>>> in how to debug in petsc, didn't know that)
>>>>>>>>> > > I don't really know what to look at here,
>>>>>>>>> > > Thanks,
>>>>>>>>> > > Manuel
>>>>>>>>> > > On Wed, Jan 4, 2017 at 2:39 PM, Dave May <
>>>>>>>>> > > Are you certain ALL ranks in PETSC_COMM_WORLD call these
>>>>>>>>> function(s). These functions cannot be inside if statements like
>>>>>>>>> > > if (rank == 0){
>>>>>>>>> > >   VecCreateMPI(...)
>>>>>>>>> > > On Wed, 4 Jan 2017 at 23:34, Manuel Valera <
>>>>>>>>> > > Thanks Dave for the quick answer, appreciate it,
>>>>>>>>> > > I just tried that and it didn't make a difference, any other
>>>>>>>>> suggestions ?
>>>>>>>>> > > Thanks,
>>>>>>>>> > > Manuel
>>>>>>>>> > > On Wed, Jan 4, 2017 at 2:29 PM, Dave May <
>>>>>>>>> > > You need to swap the order of your function calls.
>>>>>>>>> > > Call VecSetSizes() before VecSetType()
>>>>>>>>> > > Thanks,
>>>>>>>>> > >   Dave
>>>>>>>>> > > On Wed, 4 Jan 2017 at 23:21, Manuel Valera <
>>>>>>>>> > > Hello all, happy new year,
>>>>>>>>> > > I'm working on parallelizing my code, it worked and provided
>>>>>>>>> some results when i just called more than one processor, but created
>>>>>>>>> artifacts because i didn't need one image of the whole program in each
>>>>>>>>> processor, conflicting with each other.
>>>>>>>>> > > Since the pressure solver is the main part i need in parallel
>>>>>>>>> im chosing mpi to run everything in root processor until its time to solve
>>>>>>>>> for pressure, at this point im trying to create a distributed vector using
>>>>>>>>> either
>>>>>>>>> > >      call VecCreateMPI(PETSC_COMM_WORLD,
>>>>>>>>> PETSC_DECIDE,nbdp,xp,ierr)
>>>>>>>>> > > or
>>>>>>>>> > >      call VecCreate(PETSC_COMM_WORLD,xp,ierr); CHKERRQ(ierr)
>>>>>>>>> > >      call VecSetType(xp,VECMPI,ierr)
>>>>>>>>> > >      call VecSetSizes(xp,PETSC_DECIDE,nbdp,ierr);
>>>>>>>>> CHKERRQ(ierr)
>>>>>>>>> > > In both cases program hangs at this point, something it never
>>>>>>>>> happened on the naive way i described before. I've made sure the global
>>>>>>>>> size, nbdp, is the same in every processor. What can be wrong?
>>>>>>>>> > > Thanks for your kind help,
>>>>>>>>> > > Manuel.
>>>>>>>>> > > What most experimenters take for granted before they begin
>>>>>>>>> their experiments is infinitely more interesting than any results to which
>>>>>>>>> their experiments lead.
>>>>>>>>> > > -- Norbert Wiener
>>>>>> What most experimenters take for granted before they begin their
>>>>>> experiments is infinitely more interesting than any results to which their
>>>>>> experiments lead.
>>>>>> -- Norbert Wiener
>>>> experiments lead.
>>>> -- Norbert Wiener
>> experiments lead.
>> -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20170107/fb9d3de5/attachment-0001.html>
