[petsc-users] -log_view hangs unexpectedly // how to optimize my kspsolve
Jed Brown jed at jedbrown.org
Sat Jan 7 18:34:52 CST 2017
Manuel Valera <mvalera at mail.sdsu.edu> writes:
> I was able to find the bug, it was the outer loop bound in the same fashion
> than before, my -log_view is this :
>       #                          WARNING!!!                    #
>       #   This code was compiled with a debugging option,      #
>       #   To get timing results run ./configure                #
>       #   using --with-debugging=no, the performance will      #
>       #   be generally two or three times faster.              #
The above isn't a joke.
> VecMDot              525 1.0 1.7089e+00 1.7 1.48e+09 1.0 0.0e+00 0.0e+00
> 1.0e+03  7 17  0  0  6   7 17  0  0  6  1735
> VecMAXPY            1050 1.0 2.3646e+00 1.1 2.97e+09 1.0 0.0e+00 0.0e+00
> 0.0e+00 11 34  0  0  0  11 34  0  0  0  2508
You are spending about a third of the solve time doing vector work.
What is your reason for using GCR?
> KSPSolve               5 1.0 1.2218e+01 1.0 8.66e+09 1.0 1.1e+03 2.0e+04
> 1.9e+04 59100 99 43 99  59100 99 43 99  1418
> PCSetUp                3 1.0 1.7993e+00 1.0 1.27e+07 1.0 0.0e+00 0.0e+00
> 1.0e+01  8  0  0  0  0   8  0  0  0  0    14
> PCSetUpOnBlocks        5 1.0 1.9013e-01 1.7 1.27e+07 1.0 0.0e+00 0.0e+00
> 0.0e+00  1  0  0  0  0   1  0  0  0  0   134
> PCApply              546 1.0 3.8320e+00 1.1 1.77e+09 1.0 0.0e+00 0.0e+00
> 1.0e+00 18 20  0  0  0  18 20  0  0  0   925
To make a big improvement, you'll need a better preconditioner.  What
kind of problem is this?
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20170107/a1a84730/attachment.pgp>
