[petsc-users] -log_view hangs unexpectedly // how to optimize my kspsolve
Manuel Valera mvalera at mail.sdsu.edu
Sat Jan 7 17:33:48 CST 2017
Thanks Barry and Matt,
I was able to detect a bug that i just solved, as suggested the loop
parameters weren't updated as it should, now it does and the program still
freezes but now in the beginning of the loop... ?
Im attaching screen so you have an idea. Im thinking about it...
Thanks
On Sat, Jan 7, 2017 at 3:21 PM, Matthew Knepley <knepley at gmail.com> wrote:
> On Sat, Jan 7, 2017 at 4:59 PM, Manuel Valera <mvalera at mail.sdsu.edu>
> wrote:
>> I would have to think and code a MWE for this problem before sending it
>> since the model is much bigger than the petsc solver. Attached here is a
>> screenshot of the debugger as barry taught me, is that the stack trace you
>> need ?
>> the ucmsMain.f90:522 that shows is the call (from all processes) to the
>> routine that updates the rhs vector (from root) and scatters it (from all
>> processes).
> Yes, so one process is here and the other has moved on, so there is a
> mismatch in calls.
> You could do what Barry suggests, but I think it would be better to just
> step through your main routine once (its slow going), and
> see where the divergence happens.
>    Matt
>> This routine is itself inside a double loop that occurs in all processes
>> but the only call from all processes to the solver is this one, the rest of
>> the loop which involves correcting for velocities, pressure and
>> temperature, all happens in root node.
>> Sorry for the convoluted program design, this is the first beta version
>> of the model working on parallel and was the best i could come with, i
>> suppose it makes more sense in serial,
>> Thanks
>> On Sat, Jan 7, 2017 at 2:24 PM, Matthew Knepley <knepley at gmail.com>
>> wrote:
>>> On Sat, Jan 7, 2017 at 4:20 PM, Manuel Valera <mvalera at mail.sdsu.edu>
>>> wrote:
>>>> Thank you Matthew,
>>>> On Sat, Jan 7, 2017 at 1:49 PM, Matthew Knepley <knepley at gmail.com>
>>>> wrote:
>>>>> On Sat, Jan 7, 2017 at 3:32 PM, Manuel Valera <mvalera at mail.sdsu.edu>
>>>>> wrote:
>>>>>> Hi Devs, hope you are having a great weekend,
>>>>>> I could finally parallelize my linear solver and implement it into
>>>>>> the rest of the code in a way that only the linear system is solved in
>>>>>> parallel, great news for my team, but there is a catch and is that i don't
>>>>>> see any speedup in the linear system, i don't know if its the MPI in the
>>>>>> cluster we are using, but im not sure on how to debug it,
>>>>> We need to see -log_view output for any performance question.
>>>>>> On the other hand and because of this issue i was trying to do
>>>>>> -log_summary or -log_view and i noticed the program in this context hangs
>>>>>> when is time of producing the log, if i debug this for 2 cores, process 0
>>>>>> exits normally but process 1 hangs in the vectorscatterbegin() with
>>>>>> scatter_reverse way back in the code,
>>>>> You are calling a collective routine from only 1 process.
>>>>   Matt
>>>> I am pretty confident this is not the case,
>>> This is still the simplest explanation. Can you send the stack trace for
>>> the 2 process run?
>>>> the callings to vecscattercreatetozero and vecscatterbegin are made in
>>>> all processes, the program goes thru all of the iterations on the linear
>>>> solver, writes output correctly and even closes all the petsc objects
>>>> without complaining, the freeze occurs at the very end when the log is to
>>>> be produced.
>>> If you can send us a code to run, we can likely find the error.
>>>   Thanks,
>>>      Matt
>>>> Thanks,
>>>> Manuel
>>>>>> and even after destroying all associated objects and calling
>>>>>> petscfinalize(), so im really clueless on why is this, as it only happens
>>>>>> for -log_* or -ksp_view options.
>>>>>> my -ksp_view shows this:
>>>>>>  KSP Object: 2 MPI processes
>>>>>>   type: gcr
>>>>>>     GCR: restart = 30
>>>>>>     GCR: restarts performed = 20
>>>>>>   maximum iterations=10000, initial guess is zero
>>>>>>   tolerances:  relative=1e-14, absolute=1e-50, divergence=10000.
>>>>>>   right preconditioning
>>>>>>   using UNPRECONDITIONED norm type for convergence test
>>>>>> PC Object: 2 MPI processes
>>>>>>   type: bjacobi
>>>>>>     block Jacobi: number of blocks = 2
>>>>>>     Local solve is same for all blocks, in the following KSP and PC
>>>>>> objects:
>>>>>>   KSP Object:  (sub_)   1 MPI processes
>>>>>>     type: preonly
>>>>>>     tolerances:  relative=1e-05, absolute=1e-50, divergence=10000.
>>>>>>     left preconditioning
>>>>>>     using NONE norm type for convergence test
>>>>>>   PC Object:  (sub_)   1 MPI processes
>>>>>>     type: ilu
>>>>>>       ILU: out-of-place factorization
>>>>>>       0 levels of fill
>>>>>>       tolerance for zero pivot 2.22045e-14
>>>>>>       matrix ordering: natural
>>>>>>       factor fill ratio given 1., needed 1.
>>>>>>         Factored matrix follows:
>>>>>>           Mat Object:           1 MPI processes
>>>>>>             type: seqaij
>>>>>>             rows=100000, cols=100000
>>>>>>             package used to perform factorization: petsc
>>>>>>             total: nonzeros=1675180, allocated nonzeros=1675180
>>>>>>             total number of mallocs used during MatSetValues calls =0
>>>>>>               not using I-node routines
>>>>>>     linear system matrix = precond matrix:
>>>>>>       type: seqaij
>>>>>>   Mat Object:   2 MPI processes
>>>>>>     type: mpiaij
>>>>>>     rows=200000, cols=200000
>>>>>>     total: nonzeros=3373340, allocated nonzeros=3373340
>>>>>>       not using I-node (on process 0) routines
>>>>>> And i configured my PC object as:
>>>>>>    call PCSetType(mg,PCHYPRE,ierr)
>>>>>>    call PCHYPRESetType(mg,'boomeramg',ierr)
>>>>>>     call PetscOptionsSetValue(PETSC_NULL_OBJECT,'pc_hypre_boomeramg_n
>>>>>> odal_coarsen','1',ierr)
>>>>>>     call PetscOptionsSetValue(PETSC_NULL_OBJECT,'pc_hypre_boomeramg_v
>>>>>> ec_interp_variant','1',ierr)
>>>>>> What are your thoughts ?
>>>>>> Thanks,
>>>>>> Manuel
>>>>>> On Fri, Jan 6, 2017 at 1:58 PM, Manuel Valera <mvalera at mail.sdsu.edu>
>>>>>> wrote:
>>>>>>> Awesome, that did it, thanks once again.
>>>>>>> On Fri, Jan 6, 2017 at 1:53 PM, Barry Smith <bsmith at mcs.anl.gov>
>>>>>>> wrote:
>>>>>>>>    Take the scatter out of the if () since everyone does it and get
>>>>>>>> rid of the VecView().
>>>>>>>>    Does this work? If not where is it hanging?
>>>>>>>> > On Jan 6, 2017, at 3:29 PM, Manuel Valera <mvalera at mail.sdsu.edu>
>>>>>>>> wrote:
>>>>>>>> > Thanks Dave,
>>>>>>>> > I think is interesting it never gave an error on this, after
>>>>>>>> adding the vecassembly calls it still shows the same behavior, without
>>>>>>>> complaining, i did:
>>>>>>>> > if(rankl==0)then
>>>>>>>> >      call VecSetValues(bp0,nbdp,ind,Rhs,INSERT_VALUES,ierr)
>>>>>>>> >      call VecAssemblyBegin(bp0,ierr) ; call
>>>>>>>> VecAssemblyEnd(bp0,ierr);
>>>>>>>> >      CHKERRQ(ierr)
>>>>>>>> endif
>>>>>>>> >      call VecScatterBegin(ctr,bp0,bp2,IN
>>>>>>>> SERT_VALUES,SCATTER_REVERSE,ierr)
>>>>>>>> >      call VecScatterEnd(ctr,bp0,bp2,INSE
>>>>>>>> >      print*,"done! "
>>>>>>>> >      CHKERRQ(ierr)
>>>>>>>> >        CHKERRQ(ierr)
>>>>>>>> > Thanks.
>>>>>>>> > On Fri, Jan 6, 2017 at 12:44 PM, Dave May <
>>>>>>>> dave.mayhem23 at gmail.com> wrote:
>>>>>>>> > On 6 January 2017 at 20:24, Manuel Valera <mvalera at mail.sdsu.edu>
>>>>>>>> wrote:
>>>>>>>> > Great help Barry, i totally had overlooked that option (it is
>>>>>>>> explicit in the vecscatterbegin call help page but not in
>>>>>>>> vecscattercreatetozero, as i read later)
>>>>>>>> > So i used that and it works partially, it scatters te values
>>>>>>>> assigned in root but not the rest, if i call vecscatterbegin from outside
>>>>>>>> root it hangs, the code currently look as this:
>>>>>>>> >   call VecScatterCreateToZero(bp2,ctr,bp0,ierr); CHKERRQ(ierr)
>>>>>>>> >   call PetscObjectSetName(bp0, 'bp0:',ierr)
>>>>>>>> > if(rankl==0)then
>>>>>>>> >      call VecView(bp0,PETSC_VIEWER_STDOUT_WORLD,ierr)
>>>>>>>> > You need to call
>>>>>>>> >   VecAssemblyBegin(bp0);
>>>>>>>> >   VecAssemblyEnd(bp0);
>>>>>>>> > after your last call to VecSetValues() before you can do any
>>>>>>>> operations with bp0.
>>>>>>>> > With your current code, the call to VecView should produce an
>>>>>>>> error if you used the error checking macro CHKERRQ(ierr) (as should
>>>>>>>> VecScatter{Begin,End}
>>>>>>>> > Thanks,
>>>>>>>> >   Dave
>>>>>>>> >      print*,"done! "
>>>>>>>> >      CHKERRQ(ierr)
>>>>>>>> > endif
>>>>>>>> >    ! call VecScatterBegin(ctr,bp0,bp2,IN
>>>>>>>> >    !  call VecScatterEnd(ctr,bp0,bp2,INSE
>>>>>>>> >   call VecView(bp2,PETSC_VIEWER_STDOUT_WORLD,ierr)
>>>>>>>> >   call PetscBarrier(PETSC_NULL_OBJECT,ierr)
>>>>>>>> >   call exit()
>>>>>>>> > And the output is: (with bp the right answer)
>>>>>>>> > Vec Object:bp: 2 MPI processes
>>>>>>>> >   type: mpi
>>>>>>>> > Process [0]
>>>>>>>> > 1.
>>>>>>>> > 2.
>>>>>>>> > Process [1]
>>>>>>>> > 4.
>>>>>>>> > 3.
>>>>>>>> > Vec Object:bp2: 2 MPI processes  (before scatter)
>>>>>>>> >   type: mpi
>>>>>>>> > Process [0]
>>>>>>>> > 0.
>>>>>>>> > 0.
>>>>>>>> > Process [1]
>>>>>>>> > 0.
>>>>>>>> > 0.
>>>>>>>> > Vec Object:bp0: 1 MPI processes
>>>>>>>> >   type: seq
>>>>>>>> > 1.
>>>>>>>> > 2.
>>>>>>>> > 4.
>>>>>>>> > 3.
>>>>>>>> >  done!
>>>>>>>> > Vec Object:bp2: 2 MPI processes  (after scatter)
>>>>>>>> >   type: mpi
>>>>>>>> > Process [0]
>>>>>>>> > 1.
>>>>>>>> > 2.
>>>>>>>> > Process [1]
>>>>>>>> > 0.
>>>>>>>> > 0.
>>>>>>>> > Thanks inmensely for your help,
>>>>>>>> > Manuel
>>>>>>>> > On Thu, Jan 5, 2017 at 4:39 PM, Barry Smith <bsmith at mcs.anl.gov>
>>>>>>>> wrote:
>>>>>>>> > > On Jan 5, 2017, at 6:21 PM, Manuel Valera <
>>>>>>>> mvalera at mail.sdsu.edu> wrote:
>>>>>>>> > > Hello Devs is me again,
>>>>>>>> > > I'm trying to distribute a vector to all called processes, the
>>>>>>>> vector would be originally in root as a sequential vector and i would like
>>>>>>>> to scatter it, what would the best call to do this ?
>>>>>>>> > > I already know how to gather a distributed vector to root with
>>>>>>>> VecScatterCreateToZero, this would be the inverse operation,
>>>>>>>> >    Use the same VecScatter object but with SCATTER_REVERSE, not
>>>>>>>> you need to reverse the two vector arguments as well.
>>>>>>>> > > i'm currently trying with VecScatterCreate() and as of now im
>>>>>>>> doing the following:
>>>>>>>> > > if(rank==0)then
>>>>>>>> > >      call VecCreate(PETSC_COMM_SELF,bp0,ierr); CHKERRQ(ierr)
>>>>>>>> !if i use WORLD
>>>>>>>> !freezes in SetSizes
>>>>>>>> > >      call VecSetSizes(bp0,PETSC_DECIDE,nbdp,ierr);
>>>>>>>> CHKERRQ(ierr)
>>>>>>>> > >      call VecSetType(bp0,VECSEQ,ierr)
>>>>>>>> > >      call VecSetFromOptions(bp0,ierr); CHKERRQ(ierr)
>>>>>>>> > >      !call VecSet(bp0,5.0D0,ierr); CHKERRQ(ierr)
>>>>>>>> VecAssemblyEnd(bp0,ierr) !rhs
>>>>>>>> > >      do i=0,nbdp-1,1
>>>>>>>> > >         ind(i+1) = i
>>>>>>>> > >      enddo
>>>>>>>> > >      call ISCreateGeneral(PETSC_COMM_SEL
>>>>>>>> F,nbdp,ind,PETSC_COPY_VALUES,locis,ierr)
>>>>>>>> > >     !call VecScatterCreate(bp0,PETSC_NULL_OBJECT,bp2,is,ctr,ierr)
>>>>>>>> !if i use SELF
>>>>>>>>    !freezes here.
>>>>>>>> > >      call VecScatterCreate(bp0,locis,bp2
>>>>>>>> ,PETSC_NULL_OBJECT,ctr,ierr)
>>>>>>>> > > endif
>>>>>>>> > > bp2 being the receptor MPI vector to scatter to
>>>>>>>> > > But it freezes in VecScatterCreate when trying to use more than
>>>>>>>> one processor, what would be a better approach ?
>>>>>>>> > > Thanks once again,
>>>>>>>> > > Manuel
>>>>>>>> > > On Wed, Jan 4, 2017 at 3:30 PM, Manuel Valera <
>>>>>>>> > > Thanks i had no idea how to debug and read those logs, that
>>>>>>>> solved this issue at least (i was sending a message from root to everyone
>>>>>>>> else, but trying to catch from everyone else including root)
>>>>>>>> > > Until next time, many thanks,
>>>>>>>> > > Manuel
>>>>>>>> > > On Wed, Jan 4, 2017 at 3:23 PM, Matthew Knepley <
>>>>>>>> > > On Wed, Jan 4, 2017 at 5:21 PM, Manuel Valera <
>>>>>>>> > > I did a PetscBarrier just before calling the vicariate routine
>>>>>>>> and im pretty sure im calling it from every processor, code looks like this:
>>>>>>>> > > From the gdb trace.
>>>>>>>> > >   Proc 0: Is in some MPI routine you call yourself, line 113
>>>>>>>> > >   Proc 1: Is in VecCreate(), line 130
>>>>>>>> > > You need to fix your communication code.
>>>>>>>> > >    Matt
>>>>>>>> > > print*,'entering POInit from',rank
>>>>>>>> > > !call exit()
>>>>>>>> > > call PetscObjsInit()
>>>>>>>> > > And output gives:
>>>>>>>> > >  entering POInit from           0
>>>>>>>> > >  entering POInit from           1
>>>>>>>> > >  entering POInit from           2
>>>>>>>> > >  entering POInit from           3
>>>>>>>> > > Still hangs in the same way,
>>>>>>>> > > Thanks,
>>>>>>>> > > Manuel
>>>>>>>> > > On Wed, Jan 4, 2017 at 2:55 PM, Manuel Valera <
>>>>>>>> > > Thanks for the answers !
>>>>>>>> > > heres the screenshot of what i got from bt in gdb (great hint
>>>>>>>> in how to debug in petsc, didn't know that)
>>>>>>>> > > I don't really know what to look at here,
>>>>>>>> > > Thanks,
>>>>>>>> > > Manuel
>>>>>>>> > > On Wed, Jan 4, 2017 at 2:39 PM, Dave May <
>>>>>>>> > > Are you certain ALL ranks in PETSC_COMM_WORLD call these
>>>>>>>> function(s). These functions cannot be inside if statements like
>>>>>>>> > > if (rank == 0){
>>>>>>>> > >   VecCreateMPI(...)
>>>>>>>> > > On Wed, 4 Jan 2017 at 23:34, Manuel Valera <
>>>>>>>> > > Thanks Dave for the quick answer, appreciate it,
>>>>>>>> > > I just tried that and it didn't make a difference, any other
>>>>>>>> suggestions ?
>>>>>>>> > > Thanks,
>>>>>>>> > > Manuel
>>>>>>>> > > On Wed, Jan 4, 2017 at 2:29 PM, Dave May <
>>>>>>>> > > You need to swap the order of your function calls.
>>>>>>>> > > Call VecSetSizes() before VecSetType()
>>>>>>>> > > Thanks,
>>>>>>>> > >   Dave
>>>>>>>> > > On Wed, 4 Jan 2017 at 23:21, Manuel Valera <
>>>>>>>> > > Hello all, happy new year,
>>>>>>>> > > I'm working on parallelizing my code, it worked and provided
>>>>>>>> some results when i just called more than one processor, but created
>>>>>>>> artifacts because i didn't need one image of the whole program in each
>>>>>>>> processor, conflicting with each other.
>>>>>>>> > > Since the pressure solver is the main part i need in parallel
>>>>>>>> im chosing mpi to run everything in root processor until its time to solve
>>>>>>>> for pressure, at this point im trying to create a distributed vector using
>>>>>>>> either
>>>>>>>> > >      call VecCreateMPI(PETSC_COMM_WORLD,
>>>>>>>> PETSC_DECIDE,nbdp,xp,ierr)
>>>>>>>> > > or
>>>>>>>> > >      call VecCreate(PETSC_COMM_WORLD,xp,ierr); CHKERRQ(ierr)
>>>>>>>> > >      call VecSetType(xp,VECMPI,ierr)
>>>>>>>> > >      call VecSetSizes(xp,PETSC_DECIDE,nbdp,ierr); CHKERRQ(ierr)
>>>>>>>> > > In both cases program hangs at this point, something it never
>>>>>>>> happened on the naive way i described before. I've made sure the global
>>>>>>>> size, nbdp, is the same in every processor. What can be wrong?
>>>>>>>> > > Thanks for your kind help,
>>>>>>>> > > Manuel.
>>>>>>>> > > What most experimenters take for granted before they begin
>>>>>>>> their experiments is infinitely more interesting than any results to which
>>>>>>>> their experiments lead.
>>>>>>>> > > -- Norbert Wiener
>>>>> What most experimenters take for granted before they begin their
>>>>> experiments is infinitely more interesting than any results to which their
>>>>> experiments lead.
>>>>> -- Norbert Wiener
>>> experiments lead.
>>> -- Norbert Wiener
> experiments lead.
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20170107/ed68a385/attachment-0001.html>
Name: Screen Shot 2017-01-07 at 3.30.48 PM.png
Type: image/png
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20170107/ed68a385/attachment-0001.png>
