[petsc-users] Use previous solution when encountering "DIVERGED_LINE_SEARCH"
Wed Nov 30 20:35:57 CST 2016
On Wed, Nov 30, 2016 at 8:27 PM, Justin Chang <jychang48 at gmail.com> wrote:
> Hi all,
> I am running some transient simulations using SNESVINEWTONRSLS. At
> certain timesteps, I get a "DIVERGED_LINE_SEARCH" which essentially
> "resets" my solution to zero and messes everything up. I notice that this
> happens when the SNES Function norm no longer decreases, and if I were to
> manually terminate the solver right before the final iteration I get the
> answer I want.
Yes, its possible, however isn't that a dangerous way to terminate?
Couldn't you terminate on stagnation?
     Matt
> Is there a way to "detect" this error and use the solution from the
> previous non-failing iteration? Setting a fixed maximum iteration doesn't
> seem reasonble because every time level will require different numbers of
> iterations to converge.
> Thanks,
> Justin
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20161130/8a2c4e4e/attachment.html>
