[petsc-users] Use previous solution when encountering "DIVERGED_LINE_SEARCH"
Justin Chang jychang48 at gmail.com
Wed Nov 30 20:38:56 CST 2016
By manually terminating I meant setting -snes_max_it to 5 if I know
occurs after 6 iterations. In a transient simulation I cannot do this
On Wed, Nov 30, 2016 at 8:35 PM, Matthew Knepley <knepley at gmail.com> wrote:
> On Wed, Nov 30, 2016 at 8:27 PM, Justin Chang <jychang48 at gmail.com> wrote:
>> Hi all,
>> I am running some transient simulations using SNESVINEWTONRSLS. At
>> certain timesteps, I get a "DIVERGED_LINE_SEARCH" which essentially
>> "resets" my solution to zero and messes everything up. I notice that this
>> happens when the SNES Function norm no longer decreases, and if I were to
>> manually terminate the solver right before the final iteration I get the
>> answer I want.
> Yes, its possible, however isn't that a dangerous way to terminate?
> Couldn't you terminate on stagnation?
>   Thanks,
>      Matt
>> Is there a way to "detect" this error and use the solution from the
>> previous non-failing iteration? Setting a fixed maximum iteration doesn't
>> seem reasonble because every time level will require different numbers of
>> iterations to converge.
>> Thanks,
>> Justin
> experiments lead.
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20161130/ae0730e6/attachment.html>
