[petsc-users] Strange GAMG performance for mixed FE formulation
Wed Mar 2 19:48:20 CST 2016
On Wed, Mar 2, 2016 at 7:15 PM, Justin Chang <jychang48 at gmail.com> wrote:
> Barry,
> Attached are the log_summary output for each preconditioner.
MatPtAP takes all the time. It looks like there is no coarsening at all at
the first level. Mark, can you see what is going on here?
   Matt
> Thanks,
> Justin
> On Wednesday, March 2, 2016, Barry Smith <bsmith at mcs.anl.gov> wrote:
>>   Justin,
>>    Do you have the -log_summary output for these runs?
>> Barry
>> > On Mar 2, 2016, at 4:28 PM, Justin Chang <jychang48 at gmail.com> wrote:
>> > Dear all,
>> > Using the firedrake project, I am solving this simple mixed poisson
>> problem:
>> > mesh = UnitCubeMesh(40,40,40)
>> > V = FunctionSpace(mesh,"RT",1)
>> > Q = FunctionSpace(mesh,"DG",0)
>> > W = V*Q
>> > v, p = TrialFunctions(W)
>> > w, q = TestFunctions(W)
>> > f = Function(Q)
>> f.interpolate(Expression("12*pi*pi*sin(pi*x[0]*2)*sin(pi*x[1]*2)*sin(2*pi*x[2])"))
>> > a = dot(v,w)*dx - p*div(w)*dx + div(v)*q*dx
>> > L = f*q*dx
>> > u = Function(W)
>> > solve(a==L,u,solver_parameters={...})
>> > This problem has 1161600 degrees of freedom. The solver_parameters are:
>> > -ksp_type gmres
>> > -pc_type fieldsplit
>> > -pc_fieldsplit_type schur
>> > -pc_fieldsplit_schur_fact_type: upper
>> > -pc_fieldsplit_schur_precondition selfp
>> > -fieldsplit_0_ksp_type preonly
>> > -fieldsplit_0_pc_type bjacobi
>> > -fieldsplit_1_ksp_type preonly
>> > -fieldsplit_1_pc_type hypre/ml/gamg
>> > for the last option, I compared the wall-clock timings for hypre,
>> ml,and gamg. Here are the strong-scaling results (across 64 cores, 8 cores
>> per Intel Xeon E5-2670 node) for hypre, ml, and gamg:
>> > hypre:
>> > 1 core: 47.5 s, 12 solver iters
>> > 2 cores: 34.1 s, 15 solver iters
>> > 4 cores: 21.5 s, 15 solver iters
>> > 8 cores: 16.6 s, 15 solver iters
>> > 16 cores: 10.2 s, 15 solver iters
>> > 24 cores: 7.66 s, 15 solver iters
>> > 32 cores: 6.31 s, 15 solver iters
>> > 40 cores: 5.68 s, 15 solver iters
>> > 48 cores: 5.36 s, 16 solver iters
>> > 56 cores: 5.12 s, 16 solver iters
>> > 64 cores: 4.99 s, 16 solver iters
>> > ml:
>> > 1 core: 4.44 s, 14 solver iters
>> > 2 cores: 2.85 s, 16 solver iters
>> > 4 cores: 1.6 s, 17 solver iters
>> > 8 cores: 0.966 s, 17 solver iters
>> > 16 cores: 0.585 s, 18 solver iters
>> > 24 cores: 0.440 s, 18 solver iters
>> > 32 cores: 0.375 s, 18 solver iters
>> > 40 cores: 0.332 s, 18 solver iters
>> > 48 cores: 0.307 s, 17 solver iters
>> > 56 cores: 0.290 s, 18 solver iters
>> > 64 cores: 0.281 s, 18 solver items
>> > gamg:
>> > 1 core: 613 s, 12 solver iters
>> > 2 cores: 204 s, 15 solver iters
>> > 4 cores: 77.1 s, 15 solver iters
>> > 8 cores: 38.1 s, 15 solver iters
>> > 16 cores: 15.9 s, 16 solver iters
>> > 24 cores: 9.24 s, 16 solver iters
>> > 32 cores: 5.92 s, 16 solver iters
>> > 40 cores: 4.72 s, 16 solver iters
>> > 48 cores: 3.89 s, 16 solver iters
>> > 56 cores: 3.65 s, 16 solver iters
>> > 64 cores: 3.46 s, 16 solver iters
>> > The performance difference between ML and HYPRE makes sense to me, but
>> what I am really confused about is GAMG. It seems GAMG is really slow on a
>> single core but something internally is causing it to speed up
>> super-linearly as I increase the number of MPI processes. Shouldn't ML and
>> GAMG have the same performance? I am not sure what log outputs to give you
>> guys, but for starters, below is -ksp_view for the single core case with
>> GAMG
>> > KSP Object:(solver_) 1 MPI processes
>> >   type: gmres
>> >     GMRES: restart=30, using Classical (unmodified) Gram-Schmidt
>> Orthogonalization with no iterative refinement
>> >     GMRES: happy breakdown tolerance 1e-30
>> >   maximum iterations=10000, initial guess is zero
>> >   tolerances:  relative=1e-07, absolute=1e-50, divergence=10000.
>> >   left preconditioning
>> >   using PRECONDITIONED norm type for convergence test
>> > PC Object:(solver_) 1 MPI processes
>> >   type: fieldsplit
>> >     FieldSplit with Schur preconditioner, factorization UPPER
>> >     Preconditioner for the Schur complement formed from Sp, an
>> assembled approximation to S, which uses (lumped, if requested) A00's
>> diagonal's inverse
>> >     Split info:
>> >     Split number 0 Defined by IS
>> >     Split number 1 Defined by IS
>> >     KSP solver for A00 block
>> >       KSP Object:      (solver_fieldsplit_0_)       1 MPI processes
>> >         type: preonly
>> >         tolerances:  relative=1e-05, absolute=1e-50, divergence=10000.
>> >         using NONE norm type for convergence test
>> >       PC Object:      (solver_fieldsplit_0_)       1 MPI processes
>> >         type: bjacobi
>> >           block Jacobi: number of blocks = 1
>> >           Local solve is same for all blocks, in the following KSP and
>> PC objects:
>> >           KSP Object:          (solver_fieldsplit_0_sub_)           1
>> MPI processes
>> >             type: preonly
>> divergence=10000.
>> >           PC Object:          (solver_fieldsplit_0_sub_)           1
>> MPI processes
>> >             type: ilu
>> >               ILU: out-of-place factorization
>> >               0 levels of fill
>> >               tolerance for zero pivot 2.22045e-14
>> >               matrix ordering: natural
>> >               factor fill ratio given 1., needed 1.
>> >                 Factored matrix follows:
>> >                   Mat Object:                   1 MPI processes
>> >                     type: seqaij
>> >                     rows=777600, cols=777600
>> >                     package used to perform factorization: petsc
>> >                     total: nonzeros=5385600, allocated nonzeros=5385600
>> >                     total number of mallocs used during MatSetValues
>> calls =0
>> >                       not using I-node routines
>> >             linear system matrix = precond matrix:
>> >             Mat Object:            (solver_fieldsplit_0_)             1
>> MPI processes
>> >               type: seqaij
>> >               total number of mallocs used during MatSetValues calls =0
>> >         Mat Object:        (solver_fieldsplit_0_)         1 MPI
>> processes
>> >           type: seqaij
>> >     KSP solver for S = A11 - A10 inv(A00) A01
>> >       KSP Object:      (solver_fieldsplit_1_)       1 MPI processes
>> >         type: preonly
>> >       PC Object:      (solver_fieldsplit_1_)       1 MPI processes
>> >         type: gamg
>> >           MG: type is MULTIPLICATIVE, levels=5 cycles=v
>> >             Cycles per PCApply=1
>> >             Using Galerkin computed coarse grid matrices
>> >             GAMG specific options
>> >               Threshold for dropping small values from graph 0.
>> >               AGG specific options
>> >                 Symmetric graph false
>> >         Coarse grid solver -- level -------------------------------
>> >           KSP Object:          (solver_fieldsplit_1_mg_coarse_)
>>    1 MPI processes
>> >             type: preonly
>> >             maximum iterations=1, initial guess is zero
>> divergence=10000.
>> >           PC Object:          (solver_fieldsplit_1_mg_coarse_)
>>  1 MPI processes
>> >             type: bjacobi
>> and PC objects:
>> >               KSP Object:
>> (solver_fieldsplit_1_mg_coarse_sub_)               1 MPI processes
>> >                 type: preonly
>> divergence=10000.
>> >               PC Object:
>> >                 type: lu
>> >                   using diagonal shift on blocks to prevent zero pivot
>> [INBLOCKS]
>> >                   matrix ordering: nd
>> >                   factor fill ratio given 5., needed 1.
>> >                         type: seqaij
>> >                         rows=9, cols=9
>> >                         total: nonzeros=81, allocated nonzeros=81
>> >                           using I-node routines: found 2 nodes, limit
>> used is 5
>> >                   type: seqaij
>> >                   rows=9, cols=9
>> calls =0
>> >                     using I-node routines: found 2 nodes, limit used is
>> 5
>> >               type: seqaij
>> >               rows=9, cols=9
>> >                 using I-node routines: found 2 nodes, limit used is 5
>> >         Down solver (pre-smoother) on level 1
>> >           KSP Object:          (solver_fieldsplit_1_mg_levels_1_)
>>      1 MPI processes
>> >             type: chebyshev
>> >               Chebyshev: eigenvalue estimates:  min = 0.0999525, max =
>> 1.09948
>> >               Chebyshev: eigenvalues estimated using gmres with
>> translations  [0. 0.1; 0. 1.1]
>> >               KSP Object:
>> (solver_fieldsplit_1_mg_levels_1_esteig_)               1 MPI processes
>> >                 type: gmres
>> Gram-Schmidt Orthogonalization with no iterative refinement
>> >                 maximum iterations=10, initial guess is zero
>> >                 tolerances:  relative=1e-12, absolute=1e-50,
>> divergence=10000.
>> >             maximum iterations=2
>> divergence=10000.
>> >             using nonzero initial guess
>> >           PC Object:          (solver_fieldsplit_1_mg_levels_1_)
>>    1 MPI processes
>> >             type: sor
>> >               SOR: type = local_symmetric, iterations = 1, local
>> iterations = 1, omega = 1.
>> >               type: seqaij
>> >               rows=207, cols=207
>> >               total: nonzeros=42849, allocated nonzeros=42849
>> >                 using I-node routines: found 42 nodes, limit used is 5
>> >         Up solver (post-smoother) same as down solver (pre-smoother)
>> >         Down solver (pre-smoother) on level 2
>> >           KSP Object:          (solver_fieldsplit_1_mg_levels_2_)
>>      1 MPI processes
>> >             type: chebyshev
>> >               Chebyshev: eigenvalue estimates:  min = 0.0996628, max =
>> 1.09629
>> >               KSP Object:
>> (solver_fieldsplit_1_mg_levels_2_esteig_)               1 MPI processes
>> >                 type: gmres
>> divergence=10000.
>> divergence=10000.
>> >           PC Object:          (solver_fieldsplit_1_mg_levels_2_)
>>    1 MPI processes
>> >             type: sor
>> >               type: seqaij
>> >               rows=5373, cols=5373
>> >               total: nonzeros=28852043, allocated nonzeros=28852043
>> >                 using I-node routines: found 1481 nodes, limit used is 5
>> >         Down solver (pre-smoother) on level 3
>> >           KSP Object:          (solver_fieldsplit_1_mg_levels_3_)
>>      1 MPI processes
>> >             type: chebyshev
>> >               Chebyshev: eigenvalue estimates:  min = 0.0994294, max =
>> 1.09372
>> >               KSP Object:
>> (solver_fieldsplit_1_mg_levels_3_esteig_)               1 MPI processes
>> >                 type: gmres
>> divergence=10000.
>> divergence=10000.
>> >           PC Object:          (solver_fieldsplit_1_mg_levels_3_)
>>    1 MPI processes
>> >             type: sor
>> >               type: seqaij
>> >               rows=52147, cols=52147
>> >               total: nonzeros=38604909, allocated nonzeros=38604909
>> >               total number of mallocs used during MatSetValues calls =2
>> >         Down solver (pre-smoother) on level 4
>> >           KSP Object:          (solver_fieldsplit_1_mg_levels_4_)
>>      1 MPI processes
>> >             type: chebyshev
>> >               Chebyshev: eigenvalue estimates:  min = 0.158979, max =
>> 1.74876
>> >               KSP Object:
>> (solver_fieldsplit_1_mg_levels_4_esteig_)               1 MPI processes
>> >                 type: gmres
>> divergence=10000.
>> divergence=10000.
>> >           PC Object:          (solver_fieldsplit_1_mg_levels_4_)
>>    1 MPI processes
>> >             type: sor
>> >             linear system matrix followed by preconditioner matrix:
>> >             Mat Object:            (solver_fieldsplit_1_)             1
>> MPI processes
>> >               type: schurcomplement
>> >               rows=384000, cols=384000
>> >                 Schur complement A11 - A10 inv(A00) A01
>> >                 A11
>>                  1 MPI processes
>> >                     type: seqaij
>> >                     total: nonzeros=384000, allocated nonzeros=384000
>> calls =0
>> >                 A10
>> >                     type: seqaij
>> >                     rows=384000, cols=777600
>> >                     total: nonzeros=1919999, allocated nonzeros=1919999
>> calls =0
>> >                 KSP of A00
>>                  1 MPI processes
>> >                     type: preonly
>> divergence=10000.
>>                1 MPI processes
>> >                     type: bjacobi
>> following KSP and PC objects:
>> >                       KSP Object:
>> (solver_fieldsplit_0_sub_)                       1 MPI processes
>> >                         type: preonly
>> divergence=10000.
>> >                       PC Object:
>> >                         type: ilu
>> >                           0 levels of fill
>> >                               Mat Object:
>>  1 MPI processes
>> >                                 type: seqaij
>> petsc
>> nonzeros=5385600
>> >                         Mat Object:
>> >                           type: seqaij
>> nonzeros=5385600
>> >                     Mat Object:
>> >                       type: seqaij
>> nonzeros=5385600
>> calls =0
>> >                 A01
>> >                     type: seqaij
>> >                     rows=777600, cols=384000
>> calls =0
>> >               type: seqaij
>> >               total: nonzeros=3416452, allocated nonzeros=3416452
>> >         Mat Object:        (solver_fieldsplit_1_)         1 MPI
>> processes
>> >             A11
>>      1 MPI processes
>> >                 type: seqaij
>> =0
>> >             A10
>> >                 type: seqaij
>> =0
>> >             KSP of A00
>>      1 MPI processes
>> >                 type: preonly
>> divergence=10000.
>>    1 MPI processes
>> >                 type: bjacobi
>> KSP and PC objects:
>> >                   KSP Object:
>> >                     type: preonly
>> divergence=10000.
>> >                   PC Object:
>> >                     type: ilu
>> >                       0 levels of fill
>> >                           Mat Object:                           1 MPI
>> processes
>> >                             type: seqaij
>> nonzeros=5385600
>> >                     Mat Object:
>> >                       type: seqaij
>> nonzeros=5385600
>> calls =0
>>            1 MPI processes
>> >                   type: seqaij
>> calls =0
>> >             A01
>> >                 type: seqaij
>> =0
>> >           type: seqaij
>> >     type: nest
>> >     rows=1161600, cols=1161600
>> >       Matrix object:
>> >         type=nest, rows=2, cols=2
>> >         MatNest structure:
>> >         (0,0) : prefix="solver_fieldsplit_0_", type=seqaij,
>> >         (0,1) : type=seqaij, rows=777600, cols=384000
>> >         (1,0) : type=seqaij, rows=384000, cols=777600
>> >         (1,1) : prefix="solver_fieldsplit_1_", type=seqaij,
>> > Any insight as to what's happening? Btw this firedrake/petsc-mapdes is
>> from way back in october 2015 (yes much has changed since but
>> reinstalling/updating firedrake and petsc on LANL's firewall HPC machines
>> is a big pain in the ass).
>> > Thanks,
>> > Justin
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20160302/a17429c9/attachment-0001.html>
