[petsc-users] Strange GAMG performance for mixed FE formulation
Lawrence Mitchell lawrence.mitchell at imperial.ac.uk
Thu Mar 3 03:36:01 CST 2016
On 02/03/16 22:28, Justin Chang wrote:
>         Down solver (pre-smoother) on level 3
>           KSP Object:          (solver_fieldsplit_1_mg_levels_3_)
>             linear system matrix = precond matrix:
>             Mat Object:             1 MPI processes
>               type: seqaij
>               rows=52147, cols=52147
>               total: nonzeros=38604909, allocated nonzeros=38604909
>               total number of mallocs used during MatSetValues calls =2
>                 not using I-node routines
>         Down solver (pre-smoother) on level 4
>           KSP Object:          (solver_fieldsplit_1_mg_levels_4_)
>             linear system matrix followed by preconditioner matrix:
>             Mat Object:            (solver_fieldsplit_1_)
>               type: seqaij
>               rows=384000, cols=384000
>               total: nonzeros=3416452, allocated nonzeros=3416452
This looks pretty suspicious to me.  The original matrix on the finest
level has 3.8e5 rows and ~3.4e6 nonzeros.  The next level up, the
coarsening produces 5.2e4 rows, but 38e6 nonzeros.
FWIW, although Justin's PETSc is from Oct 2015, I get the same
behaviour with:
ad5697c (Master as of 1st March).
If I compare with the coarse operators that ML produces on the same
problem:
The original matrix has, again:
          type: seqaij
          total number of mallocs used during MatSetValues calls=0
While the next finest level has:
              type: seqaij
              rows=65258, cols=65258
              total: nonzeros=1318400, allocated nonzeros=1318400
So we have 6.5e4 rows and 1.3e6 nonzeros, which seems more plausible.
Cheers,
Lawrence
Desc: OpenPGP digital signature
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20160303/f597c2ca/attachment.pgp>
