[petsc-users] Strange GAMG performance for mixed FE formulation
Justin Chang jychang48 at gmail.com
Wed Mar 2 19:15:48 CST 2016
Barry,
Attached are the log_summary output for each preconditioner.
Justin
On Wednesday, March 2, 2016, Barry Smith <bsmith at mcs.anl.gov> wrote:
>   Justin,
>    Do you have the -log_summary output for these runs?
> Barry
> > On Mar 2, 2016, at 4:28 PM, Justin Chang <jychang48 at gmail.com> wrote:
> > Dear all,
> > Using the firedrake project, I am solving this simple mixed poisson
> problem:
> > mesh = UnitCubeMesh(40,40,40)
> > V = FunctionSpace(mesh,"RT",1)
> > Q = FunctionSpace(mesh,"DG",0)
> > W = V*Q
> > v, p = TrialFunctions(W)
> > w, q = TestFunctions(W)
> > f = Function(Q)
> f.interpolate(Expression("12*pi*pi*sin(pi*x[0]*2)*sin(pi*x[1]*2)*sin(2*pi*x[2])"))
> > a = dot(v,w)*dx - p*div(w)*dx + div(v)*q*dx
> > L = f*q*dx
> > u = Function(W)
> > solve(a==L,u,solver_parameters={...})
> > This problem has 1161600 degrees of freedom. The solver_parameters are:
> > -ksp_type gmres
> > -pc_type fieldsplit
> > -pc_fieldsplit_type schur
> > -pc_fieldsplit_schur_fact_type: upper
> > -pc_fieldsplit_schur_precondition selfp
> > -fieldsplit_0_ksp_type preonly
> > -fieldsplit_0_pc_type bjacobi
> > -fieldsplit_1_ksp_type preonly
> > -fieldsplit_1_pc_type hypre/ml/gamg
> > for the last option, I compared the wall-clock timings for hypre, ml,and
> gamg. Here are the strong-scaling results (across 64 cores, 8 cores per
> Intel Xeon E5-2670 node) for hypre, ml, and gamg:
> > hypre:
> > 1 core: 47.5 s, 12 solver iters
> > 2 cores: 34.1 s, 15 solver iters
> > 4 cores: 21.5 s, 15 solver iters
> > 8 cores: 16.6 s, 15 solver iters
> > 16 cores: 10.2 s, 15 solver iters
> > 24 cores: 7.66 s, 15 solver iters
> > 32 cores: 6.31 s, 15 solver iters
> > 40 cores: 5.68 s, 15 solver iters
> > 48 cores: 5.36 s, 16 solver iters
> > 56 cores: 5.12 s, 16 solver iters
> > 64 cores: 4.99 s, 16 solver iters
> > ml:
> > 1 core: 4.44 s, 14 solver iters
> > 2 cores: 2.85 s, 16 solver iters
> > 4 cores: 1.6 s, 17 solver iters
> > 8 cores: 0.966 s, 17 solver iters
> > 16 cores: 0.585 s, 18 solver iters
> > 24 cores: 0.440 s, 18 solver iters
> > 32 cores: 0.375 s, 18 solver iters
> > 40 cores: 0.332 s, 18 solver iters
> > 48 cores: 0.307 s, 17 solver iters
> > 56 cores: 0.290 s, 18 solver iters
> > 64 cores: 0.281 s, 18 solver items
> > gamg:
> > 1 core: 613 s, 12 solver iters
> > 2 cores: 204 s, 15 solver iters
> > 4 cores: 77.1 s, 15 solver iters
> > 8 cores: 38.1 s, 15 solver iters
> > 16 cores: 15.9 s, 16 solver iters
> > 24 cores: 9.24 s, 16 solver iters
> > 32 cores: 5.92 s, 16 solver iters
> > 40 cores: 4.72 s, 16 solver iters
> > 48 cores: 3.89 s, 16 solver iters
> > 56 cores: 3.65 s, 16 solver iters
> > 64 cores: 3.46 s, 16 solver iters
> > The performance difference between ML and HYPRE makes sense to me, but
> what I am really confused about is GAMG. It seems GAMG is really slow on a
> single core but something internally is causing it to speed up
> super-linearly as I increase the number of MPI processes. Shouldn't ML and
> GAMG have the same performance? I am not sure what log outputs to give you
> guys, but for starters, below is -ksp_view for the single core case with
> GAMG
> > KSP Object:(solver_) 1 MPI processes
> >   type: gmres
> >     GMRES: restart=30, using Classical (unmodified) Gram-Schmidt
> Orthogonalization with no iterative refinement
> >     GMRES: happy breakdown tolerance 1e-30
> >   maximum iterations=10000, initial guess is zero
> >   tolerances:  relative=1e-07, absolute=1e-50, divergence=10000.
> >   left preconditioning
> >   using PRECONDITIONED norm type for convergence test
> > PC Object:(solver_) 1 MPI processes
> >   type: fieldsplit
> >     FieldSplit with Schur preconditioner, factorization UPPER
> >     Preconditioner for the Schur complement formed from Sp, an assembled
> approximation to S, which uses (lumped, if requested) A00's diagonal's
> inverse
> >     Split info:
> >     Split number 0 Defined by IS
> >     Split number 1 Defined by IS
> >     KSP solver for A00 block
> >       KSP Object:      (solver_fieldsplit_0_)       1 MPI processes
> >         type: preonly
> >         tolerances:  relative=1e-05, absolute=1e-50, divergence=10000.
> >         using NONE norm type for convergence test
> >       PC Object:      (solver_fieldsplit_0_)       1 MPI processes
> >         type: bjacobi
> >           block Jacobi: number of blocks = 1
> >           Local solve is same for all blocks, in the following KSP and
> PC objects:
> >           KSP Object:          (solver_fieldsplit_0_sub_)           1
> MPI processes
> >             type: preonly
> divergence=10000.
> >           PC Object:          (solver_fieldsplit_0_sub_)           1 MPI
> processes
> >             type: ilu
> >               ILU: out-of-place factorization
> >               0 levels of fill
> >               tolerance for zero pivot 2.22045e-14
> >               matrix ordering: natural
> >               factor fill ratio given 1., needed 1.
> >                 Factored matrix follows:
> >                   Mat Object:                   1 MPI processes
> >                     type: seqaij
> >                     rows=777600, cols=777600
> >                     package used to perform factorization: petsc
> >                     total: nonzeros=5385600, allocated nonzeros=5385600
> >                     total number of mallocs used during MatSetValues
> calls =0
> >                       not using I-node routines
> >             linear system matrix = precond matrix:
> >             Mat Object:            (solver_fieldsplit_0_)             1
> MPI processes
> >               type: seqaij
> >               total number of mallocs used during MatSetValues calls =0
> >         Mat Object:        (solver_fieldsplit_0_)         1 MPI processes
> >           type: seqaij
> >     KSP solver for S = A11 - A10 inv(A00) A01
> >       KSP Object:      (solver_fieldsplit_1_)       1 MPI processes
> >         type: preonly
> >       PC Object:      (solver_fieldsplit_1_)       1 MPI processes
> >         type: gamg
> >           MG: type is MULTIPLICATIVE, levels=5 cycles=v
> >             Cycles per PCApply=1
> >             Using Galerkin computed coarse grid matrices
> >             GAMG specific options
> >               Threshold for dropping small values from graph 0.
> >               AGG specific options
> >                 Symmetric graph false
> >         Coarse grid solver -- level -------------------------------
> >           KSP Object:          (solver_fieldsplit_1_mg_coarse_)
>  1 MPI processes
> >             type: preonly
> >             maximum iterations=1, initial guess is zero
> divergence=10000.
> >           PC Object:          (solver_fieldsplit_1_mg_coarse_)
>  1 MPI processes
> >             type: bjacobi
> and PC objects:
> >               KSP Object:
> (solver_fieldsplit_1_mg_coarse_sub_)               1 MPI processes
> >                 type: preonly
> divergence=10000.
> >               PC Object:
> >                 type: lu
> >                   using diagonal shift on blocks to prevent zero pivot
> [INBLOCKS]
> >                   matrix ordering: nd
> >                   factor fill ratio given 5., needed 1.
> >                         type: seqaij
> >                         rows=9, cols=9
> >                         total: nonzeros=81, allocated nonzeros=81
> calls =0
> >                           using I-node routines: found 2 nodes, limit
> used is 5
> >                   type: seqaij
> >                   rows=9, cols=9
> =0
> >                     using I-node routines: found 2 nodes, limit used is 5
> >               type: seqaij
> >               rows=9, cols=9
> >         Down solver (pre-smoother) on level 1
> >           KSP Object:          (solver_fieldsplit_1_mg_levels_1_)
>    1 MPI processes
> >             type: chebyshev
> >               Chebyshev: eigenvalue estimates:  min = 0.0999525, max =
> 1.09948
> >               Chebyshev: eigenvalues estimated using gmres with
> translations  [0. 0.1; 0. 1.1]
> >               KSP Object:
> (solver_fieldsplit_1_mg_levels_1_esteig_)               1 MPI processes
> >                 type: gmres
> Gram-Schmidt Orthogonalization with no iterative refinement
> >                 maximum iterations=10, initial guess is zero
> >                 tolerances:  relative=1e-12, absolute=1e-50,
> divergence=10000.
> >             maximum iterations=2
> divergence=10000.
> >             using nonzero initial guess
> >           PC Object:          (solver_fieldsplit_1_mg_levels_1_)
>    1 MPI processes
> >             type: sor
> >               SOR: type = local_symmetric, iterations = 1, local
> iterations = 1, omega = 1.
> >               type: seqaij
> >               rows=207, cols=207
> >               total: nonzeros=42849, allocated nonzeros=42849
> >                 using I-node routines: found 42 nodes, limit used is 5
> >         Up solver (post-smoother) same as down solver (pre-smoother)
> >         Down solver (pre-smoother) on level 2
> >           KSP Object:          (solver_fieldsplit_1_mg_levels_2_)
>    1 MPI processes
> >             type: chebyshev
> >               Chebyshev: eigenvalue estimates:  min = 0.0996628, max =
> 1.09629
> >               KSP Object:
> (solver_fieldsplit_1_mg_levels_2_esteig_)               1 MPI processes
> >                 type: gmres
> divergence=10000.
> divergence=10000.
> >           PC Object:          (solver_fieldsplit_1_mg_levels_2_)
>    1 MPI processes
> >             type: sor
> >               type: seqaij
> >               rows=5373, cols=5373
> >               total: nonzeros=28852043, allocated nonzeros=28852043
> >                 using I-node routines: found 1481 nodes, limit used is 5
> >         Down solver (pre-smoother) on level 3
> >           KSP Object:          (solver_fieldsplit_1_mg_levels_3_)
>    1 MPI processes
> >             type: chebyshev
> >               Chebyshev: eigenvalue estimates:  min = 0.0994294, max =
> 1.09372
> >               KSP Object:
> (solver_fieldsplit_1_mg_levels_3_esteig_)               1 MPI processes
> >                 type: gmres
> divergence=10000.
> divergence=10000.
> >           PC Object:          (solver_fieldsplit_1_mg_levels_3_)
>    1 MPI processes
> >             type: sor
> >               type: seqaij
> >               rows=52147, cols=52147
> >               total: nonzeros=38604909, allocated nonzeros=38604909
> >               total number of mallocs used during MatSetValues calls =2
> >         Down solver (pre-smoother) on level 4
> >           KSP Object:          (solver_fieldsplit_1_mg_levels_4_)
>    1 MPI processes
> >             type: chebyshev
> >               Chebyshev: eigenvalue estimates:  min = 0.158979, max =
> 1.74876
> >               KSP Object:
> (solver_fieldsplit_1_mg_levels_4_esteig_)               1 MPI processes
> >                 type: gmres
> divergence=10000.
> divergence=10000.
> >           PC Object:          (solver_fieldsplit_1_mg_levels_4_)
>    1 MPI processes
> >             type: sor
> >             linear system matrix followed by preconditioner matrix:
> >             Mat Object:            (solver_fieldsplit_1_)             1
> MPI processes
> >               type: schurcomplement
> >               rows=384000, cols=384000
> >                 Schur complement A11 - A10 inv(A00) A01
> >                 A11
>                1 MPI processes
> >                     type: seqaij
> >                     total: nonzeros=384000, allocated nonzeros=384000
> calls =0
> >                 A10
> >                     type: seqaij
> >                     rows=384000, cols=777600
> >                     total: nonzeros=1919999, allocated nonzeros=1919999
> calls =0
> >                 KSP of A00
>                1 MPI processes
> >                     type: preonly
> divergence=10000.
>                1 MPI processes
> >                     type: bjacobi
> following KSP and PC objects:
> >                       KSP Object:
> (solver_fieldsplit_0_sub_)                       1 MPI processes
> >                         type: preonly
> divergence=10000.
> >                       PC Object:
> >                         type: ilu
> >                           0 levels of fill
> >                               Mat Object:
>  1 MPI processes
> >                                 type: seqaij
> petsc
> nonzeros=5385600
> >                         Mat Object:
> >                           type: seqaij
> nonzeros=5385600
> >                     Mat Object:
> >                       type: seqaij
> calls =0
> >                 A01
> >                     type: seqaij
> >                     rows=777600, cols=384000
> calls =0
> >               type: seqaij
> >               total: nonzeros=3416452, allocated nonzeros=3416452
> >         Mat Object:        (solver_fieldsplit_1_)         1 MPI processes
> >             A11
>    1 MPI processes
> >                 type: seqaij
> >             A10
> >                 type: seqaij
> >             KSP of A00
>    1 MPI processes
> >                 type: preonly
> divergence=10000.
>    1 MPI processes
> >                 type: bjacobi
> KSP and PC objects:
> >                   KSP Object:
> >                     type: preonly
> divergence=10000.
> >                   PC Object:
> >                     type: ilu
> >                       0 levels of fill
> >                           Mat Object:                           1 MPI
> processes
> >                             type: seqaij
> nonzeros=5385600
> >                     Mat Object:
> >                       type: seqaij
> calls =0
>          1 MPI processes
> >                   type: seqaij
> =0
> >             A01
> >                 type: seqaij
> >           type: seqaij
> >     type: nest
> >     rows=1161600, cols=1161600
> >       Matrix object:
> >         type=nest, rows=2, cols=2
> >         MatNest structure:
> >         (0,0) : prefix="solver_fieldsplit_0_", type=seqaij, rows=777600,
> cols=777600
> >         (0,1) : type=seqaij, rows=777600, cols=384000
> >         (1,0) : type=seqaij, rows=384000, cols=777600
> >         (1,1) : prefix="solver_fieldsplit_1_", type=seqaij, rows=384000,
> cols=384000
> > Any insight as to what's happening? Btw this firedrake/petsc-mapdes is
> from way back in october 2015 (yes much has changed since but
> reinstalling/updating firedrake and petsc on LANL's firewall HPC machines
> is a big pain in the ass).
> > Thanks,
> > Justin
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20160302/cb4af408/attachment-0001.html>
 gamg 40 1
Discretization: RT
MPI processes 1: solving...
((1161600, 1161600), (1161600, 1161600))
	Solver time: 6.176223e+02
	Solver iterations: 12
***             WIDEN YOUR WINDOW TO 120 CHARACTERS.  Use 'enscript -r -fCourier9' to print this document            ***
---------------------------------------------- PETSc Performance Summary: ----------------------------------------------
Darcy_FE.py on a arch-linux2-c-opt named wf153.localdomain with 1 processor, by jychang48 Wed Mar  2 17:54:07 2016
Using Petsc Development GIT revision: v3.6.3-1924-ge972cd5  GIT Date: 2016-01-01 10:01:13 -0600
                         Max       Max/Min        Avg      Total
Time (sec):           6.314e+02      1.00000   6.314e+02
Objects:              4.870e+02      1.00000   4.870e+02
Flops:                2.621e+11      1.00000   2.621e+11  2.621e+11
Flops/sec:            4.151e+08      1.00000   4.151e+08  4.151e+08
MPI Messages:         0.000e+00      0.00000   0.000e+00  0.000e+00
MPI Message Lengths:  0.000e+00      0.00000   0.000e+00  0.000e+00
MPI Reductions:       0.000e+00      0.00000
Flop counting convention: 1 flop = 1 real number operation of type (multiply/divide/add/subtract)
                            e.g., VecAXPY() for real vectors of length N --> 2N flops
                            and VecAXPY() for complex vectors of length N --> 8N flops
Summary of Stages:   ----- Time ------  ----- Flops -----  --- Messages ---  -- Message Lengths --  -- Reductions --
                        Avg     %Total     Avg     %Total   counts   %Total     Avg         %Total   counts   %Total
 0:      Main Stage: 1.3802e+01   2.2%  0.0000e+00   0.0%  0.000e+00   0.0%  0.000e+00        0.0%  0.000e+00   0.0%
 1:             FEM: 6.1762e+02  97.8%  2.6212e+11 100.0%  0.000e+00   0.0%  0.000e+00        0.0%  0.000e+00   0.0%
See the 'Profiling' chapter of the users' manual for details on interpreting output.
Phase summary info:
   Count: number of times phase was executed
   Time and Flops: Max - maximum over all processors
                   Ratio - ratio of maximum to minimum over all processors
   Mess: number of messages sent
   Avg. len: average message length (bytes)
   Reduct: number of global reductions
   Global: entire computation
   Stage: stages of a computation. Set stages with PetscLogStagePush() and PetscLogStagePop().
      %T - percent time in this phase         %F - percent flops in this phase
      %M - percent messages in this phase     %L - percent message lengths in this phase
      %R - percent reductions in this phase
   Total Mflop/s: 10e-6 * (sum of flops over all processors)/(max time over all processors)
Event                Count      Time (sec)     Flops                             --- Global ---  --- Stage ---   Total
                   Max Ratio  Max     Ratio   Max  Ratio  Mess   Avg len Reduct  %T %F %M %L %R  %T %F %M %L %R Mflop/s
--- Event Stage 0: Main Stage
VecSet                 8 1.0 1.5719e-02 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecScatterBegin        2 1.0 2.5649e-03 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
DMPlexInterp           1 1.0 2.0957e+00 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0  15  0  0  0  0     0
DMPlexStratify         4 1.0 5.1086e-01 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   4  0  0  0  0     0
SFSetGraph             7 1.0 2.6373e-02 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
--- Event Stage 1: FEM
VecMDot               90 1.0 9.1943e-02 1.0 2.78e+08 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0  3028
VecNorm               99 1.0 2.5040e-02 1.0 4.96e+07 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0  1982
VecScale             187 1.0 4.3765e-02 1.0 6.37e+07 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0  1456
VecCopy               61 1.0 1.4966e-02 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecSet               585 1.0 3.6946e-01 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecAXPY                9 1.0 2.4149e-03 1.0 4.09e+06 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0  1694
VecAYPX              416 1.0 5.2025e-02 1.0 5.74e+07 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0  1104
VecAXPBYCZ           208 1.0 3.7029e-02 1.0 1.15e+08 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0  3102
VecMAXPY              99 1.0 1.0790e-01 1.0 3.24e+08 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0  3002
VecPointwiseMult      44 1.0 7.9148e-03 1.0 4.86e+06 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0   614
VecScatterBegin       58 1.0 6.4158e-02 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecSetRandom           4 1.0 1.7824e-02 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecNormalize          99 1.0 4.0050e-02 1.0 7.45e+07 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0  1859
MatMult              415 1.0 1.0716e+01 1.0 1.50e+10 1.0 0.0e+00 0.0e+00 0.0e+00  2  6  0  0  0   2  6  0  0  0  1398
MatMultAdd           175 1.0 6.3934e-01 1.0 8.98e+08 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0  1404
MatMultTranspose      52 1.0 4.7943e-01 1.0 6.09e+08 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0  1271
MatSolve             101 1.0 9.7955e-01 1.0 8.79e+08 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0   898
MatSOR               354 1.0 8.2436e+00 1.0 1.26e+10 1.0 0.0e+00 0.0e+00 0.0e+00  1  5  0  0  0   1  5  0  0  0  1531
MatLUFactorSym         1 1.0 1.5020e-05 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatLUFactorNum         2 1.0 6.5916e-02 1.0 1.81e+07 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0   275
MatILUFactorSym        1 1.0 5.1070e-02 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatConvert             5 1.0 5.2860e-01 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatScale              14 1.0 2.0680e-01 1.0 1.94e+08 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0   938
MatResidual           52 1.0 1.2122e+00 1.0 1.84e+09 1.0 0.0e+00 0.0e+00 0.0e+00  0  1  0  0  0   0  1  0  0  0  1521
MatAssemblyBegin      41 1.0 3.8147e-05 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatAssemblyEnd        41 1.0 2.9745e-01 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatGetRow        2093181 1.0 1.3037e+00 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatGetRowIJ            2 1.0 1.0967e-05 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatGetSubMatrix        4 1.0 4.8364e-02 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatGetOrdering         2 1.0 5.2271e-03 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatCoarsen             4 1.0 2.7666e-02 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatAXPY                5 1.0 1.6762e+00 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatMatMult             5 1.0 2.0927e+00 1.0 1.79e+08 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0    85
MatMatMultSym          5 1.0 1.5816e+00 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatMatMultNum          5 1.0 5.1102e-01 1.0 1.79e+08 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0   349
MatPtAP                4 1.0 5.8895e+02 1.0 2.31e+11 1.0 0.0e+00 0.0e+00 0.0e+00 93 88  0  0  0  95 88  0  0  0   392
MatPtAPSymbolic        4 1.0 3.6005e+02 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 57  0  0  0  0  58  0  0  0  0     0
MatPtAPNumeric         4 1.0 2.2890e+02 1.0 2.31e+11 1.0 0.0e+00 0.0e+00 0.0e+00 36 88  0  0  0  37 88  0  0  0  1010
MatTrnMatMult          1 1.0 1.8922e-01 1.0 1.89e+07 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0   100
MatTrnMatMultSym       1 1.0 1.3319e-01 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatTrnMatMultNum       1 1.0 5.6026e-02 1.0 1.89e+07 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0   337
MatGetSymTrans         5 1.0 2.6924e-01 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
PCGAMGGraph_AGG        4 1.0 2.3435e+00 1.0 1.42e+08 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0    61
PCGAMGCoarse_AGG       4 1.0 2.7229e-01 1.0 1.89e+07 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0    69
PCGAMGProl_AGG         4 1.0 7.6182e-02 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
PCGAMGPOpt_AGG         4 1.0 3.7438e+00 1.0 1.75e+09 1.0 0.0e+00 0.0e+00 0.0e+00  1  1  0  0  0   1  1  0  0  0   468
GAMG: createProl       4 1.0 6.4585e+00 1.0 1.91e+09 1.0 0.0e+00 0.0e+00 0.0e+00  1  1  0  0  0   1  1  0  0  0   296
  Graph                8 1.0 2.3078e+00 1.0 1.42e+08 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0    61
  MIS/Agg              4 1.0 2.7763e-02 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
  SA: col data         4 1.0 9.4485e-04 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
  SA: frmProl0         4 1.0 7.2291e-02 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
  SA: smooth           4 1.0 3.7438e+00 1.0 1.75e+09 1.0 0.0e+00 0.0e+00 0.0e+00  1  1  0  0  0   1  1  0  0  0   468
GAMG: partLevel        4 1.0 5.8895e+02 1.0 2.31e+11 1.0 0.0e+00 0.0e+00 0.0e+00 93 88  0  0  0  95 88  0  0  0   392
PCSetUp                5 1.0 5.9682e+02 1.0 2.33e+11 1.0 0.0e+00 0.0e+00 0.0e+00 95 89  0  0  0  97 89  0  0  0   390
PCSetUpOnBlocks      101 1.0 1.2241e-01 1.0 1.81e+07 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0   148
PCApply               13 1.0 6.1450e+02 1.0 2.61e+11 1.0 0.0e+00 0.0e+00 0.0e+00 97 99  0  0  0  99 99  0  0  0   424
KSPGMRESOrthog        90 1.0 1.8531e-01 1.0 5.57e+08 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0  3004
KSPSetUp              18 1.0 3.1746e-02 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
KSPSolve               1 1.0 6.1623e+02 1.0 2.61e+11 1.0 0.0e+00 0.0e+00 0.0e+00 98100  0  0  0 100100  0  0  0   424
Memory usage is given in bytes:
Object Type          Creations   Destructions     Memory  Descendants' Mem.
Reports information only for process 0.
           Container     6              3         1728     0.
              Viewer     1              0            0     0.
         PetscRandom     0              1          646     0.
           Index Set    22             25     38642096     0.
             Section    26              8         5376     0.
              Vector    13            119    258907968     0.
      Vector Scatter     2              6         3984     0.
              Matrix     0             12    136713716     0.
      Preconditioner     0             11        11092     0.
       Krylov Solver     0             15       151752     0.
    Distributed Mesh    10              4        19256     0.
    GraphPartitioner     4              3         1836     0.
Star Forest Bipartite Graph    23             12         9696     0.
     Discrete System    10              4         3456     0.
         PetscRandom     1              0            0     0.
           Index Set    28             18        14128     0.
   IS L to G Mapping     4              0            0     0.
              Vector   254            139     93471128     0.
      Vector Scatter     6              0            0     0.
              Matrix    33             16   1768633272     0.
      Matrix Coarsen     4              4         2544     0.
      Preconditioner    20              9         8536     0.
       Krylov Solver    20              5       122312     0.
Average time to get PetscTime(): 5.96046e-07
#PETSc Option Table entries:
-log_summary
-solver_fieldsplit_0_ksp_type preonly
-solver_fieldsplit_0_pc_type bjacobi
-solver_fieldsplit_1_ksp_type preonly
-solver_fieldsplit_1_pc_type gamg
-solver_ksp_rtol 1e-7
-solver_ksp_type gmres
-solver_pc_fieldsplit_schur_fact_type upper
-solver_pc_fieldsplit_schur_precondition selfp
-solver_pc_fieldsplit_type schur
-solver_pc_type fieldsplit
#End of PETSc Option Table entries
Compiled without FORTRAN kernels
Compiled with full precision matrices (default)
sizeof(short) 2 sizeof(int) 4 sizeof(long) 8 sizeof(void*) 8 sizeof(PetscScalar) 8 sizeof(PetscInt) 4
Configure options: --download-chaco=/users/jychang48/externalpackages/Chaco-2.2-p2.tar.gz --download-ctetgen=/users/jychang48/externalpackages/ctetgen-0.4.tar.gz --download-exodusii=/users/jychang48/externalpackages/exodus-5.24.tar.bz2 --download-fblaslapack=/users/jychang48/externalpackages/fblaslapack-3.4.2.tar.gz --download-hdf5=/users/jychang48/externalpackages/hdf5-1.8.12.tar.gz --download-hypre=/users/jychang48/externalpackages/hypre-2.10.0b-p1.tar.gz --download-metis=/users/jychang48/externalpackages/metis-5.1.0-p1.tar.gz --download-ml=/users/jychang48/externalpackages/ml-6.2-p3.tar.gz --download-mumps=/users/jychang48/externalpackages/MUMPS_5.0.1-p1.tar.gz --download-netcdf=/users/jychang48/externalpackages/netcdf-4.3.2.tar.gz --download-parmetis=/users/jychang48/externalpackages/parmetis-4.0.3-p2.tar.gz --download-scalapack=/users/jychang48/externalpackages/scalapack-2.0.2.tgz --download-superlu_dist --download-triangle=/users/jychang48/externalpackages/Triangle.tar.gz --with-cc=mpicc --with-cxx=mpicxx --with-debugging=0 --with-fc=mpif90 --with-papi=/usr/projects/hpcsoft/toss2/common/papi/5.4.1 --with-shared-libraries COPTFLAGS=-O3 CXXOPTFLAGS=-O3 FOPTFLAGS=-O3 PETSC_ARCH=arch-linux2-c-opt
Libraries compiled on Fri Jan  1 21:44:06 2016 on wf-fe2.lanl.gov
Machine characteristics: Linux-2.6.32-573.8.1.2chaos.ch5.4.x86_64-x86_64-with-redhat-6.7-Santiago
Using PETSc directory: /users/jychang48/petsc
Using PETSc arch: arch-linux2-c-opt
Using C compiler: mpicc  -fPIC  -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -O3  ${COPTFLAGS} ${CFLAGS}
Using Fortran compiler: mpif90  -fPIC -Wall -Wno-unused-variable -ffree-line-length-0 -Wno-unused-dummy-argument -O3   ${FOPTFLAGS} ${FFLAGS}
Using include paths: -I/users/jychang48/petsc/arch-linux2-c-opt/include -I/users/jychang48/petsc/include -I/users/jychang48/petsc/include -I/users/jychang48/petsc/arch-linux2-c-opt/include -I/usr/projects/hpcsoft/toss2.2/wolf/openmpi/1.6.5-gcc-4.8/include/openmpi/opal/mca/hwloc/hwloc132/hwloc/include -I/usr/projects/hpcsoft/toss2.2/wolf/openmpi/1.6.5-gcc-4.8/include -I/usr/projects/hpcsoft/toss2.2/wolf/openmpi/1.6.5-gcc-4.8/include/openmpi
Using C linker: mpicc
Using Fortran linker: mpif90
Using libraries: -Wl,-rpath,/users/jychang48/petsc/arch-linux2-c-opt/lib -L/users/jychang48/petsc/arch-linux2-c-opt/lib -lpetsc -Wl,-rpath,/users/jychang48/petsc/arch-linux2-c-opt/lib -L/users/jychang48/petsc/arch-linux2-c-opt/lib -lcmumps -ldmumps -lsmumps -lzmumps -lmumps_common -lpord -lscalapack -lsuperlu_dist_4.2 -lHYPRE -Wl,-rpath,/usr/projects/hpcsoft/toss2.2/wolf/openmpi/1.6.5-gcc-4.8/lib -L/usr/projects/hpcsoft/toss2.2/wolf/openmpi/1.6.5-gcc-4.8/lib -Wl,-rpath,/turquoise/usr/projects/hpcsoft/toss2/common/gcc/4.8.2/lib/gcc/x86_64-unknown-linux-gnu/4.8.2 -L/turquoise/usr/projects/hpcsoft/toss2/common/gcc/4.8.2/lib/gcc/x86_64-unknown-linux-gnu/4.8.2 -Wl,-rpath,/turquoise/usr/projects/hpcsoft/toss2/common/gcc/4.8.2/lib/gcc -L/turquoise/usr/projects/hpcsoft/toss2/common/gcc/4.8.2/lib/gcc -Wl,-rpath,/turquoise/usr/projects/hpcsoft/toss2/common/gcc/4.8.2/lib64 -L/turquoise/usr/projects/hpcsoft/toss2/common/gcc/4.8.2/lib64 -Wl,-rpath,/turquoise/usr/projects/hpcsoft/toss2/common/gcc/4.8.2/lib -L/turquoise/usr/projects/hpcsoft/toss2/common/gcc/4.8.2/lib -lmpi_cxx -lstdc++ -lml -lmpi_cxx -lstdc++ -lflapack -lfblas -lparmetis -lmetis -lchaco -lexoIIv2for -lexodus -lnetcdf -lhdf5hl_fortran -lhdf5_fortran -lhdf5_hl -lhdf5 -ltriangle -lX11 -lhwloc -lctetgen -lssl -lcrypto -lmpi_f90 -lmpi_f77 -lgfortran -lm -lgfortran -lm -lgfortran -lm -lgfortran -lm -lgfortran -lm -lquadmath -lm -lmpi_cxx -lstdc++ -Wl,-rpath,/usr/projects/hpcsoft/toss2.2/wolf/openmpi/1.6.5-gcc-4.8/lib -L/usr/projects/hpcsoft/toss2.2/wolf/openmpi/1.6.5-gcc-4.8/lib -Wl,-rpath,/turquoise/usr/projects/hpcsoft/toss2/common/gcc/4.8.2/lib/gcc/x86_64-unknown-linux-gnu/4.8.2 -L/turquoise/usr/projects/hpcsoft/toss2/common/gcc/4.8.2/lib/gcc/x86_64-unknown-linux-gnu/4.8.2 -Wl,-rpath,/turquoise/usr/projects/hpcsoft/toss2/common/gcc/4.8.2/lib/gcc -L/turquoise/usr/projects/hpcsoft/toss2/common/gcc/4.8.2/lib/gcc -Wl,-rpath,/turquoise/usr/projects/hpcsoft/toss2/common/gcc/4.8.2/lib64 -L/turquoise/usr/projects/hpcsoft/toss2/common/gcc/4.8.2/lib64 -Wl,-rpath,/turquoise/usr/projects/hpcsoft/toss2/common/gcc/4.8.2/lib -L/turquoise/usr/projects/hpcsoft/toss2/common/gcc/4.8.2/lib -ldl -lmpi -losmcomp -lrdmacm -libverbs -lsctp -lrt -lnsl -lutil -lpsm_infinipath -lpmi -lnuma -lgcc_s -lpthread -ldl
 gamg 40 1
Discretization: RT
MPI processes 2: solving...
((579051, 1161600), (579051, 1161600))
	Solver time: 2.062817e+02
	Solver iterations: 15
Darcy_FE.py on a arch-linux2-c-opt named wf153.localdomain with 2 processors, by jychang48 Wed Mar  2 17:57:49 2016
Time (sec):           2.205e+02      1.00001   2.205e+02
Objects:              9.470e+02      1.01719   9.390e+02
Flops:                1.113e+11      1.14917   1.041e+11  2.082e+11
Flops/sec:            5.049e+08      1.14915   4.722e+08  9.444e+08
MPI Messages:         1.065e+03      1.06928   1.030e+03  2.061e+03
MPI Message Lengths:  6.096e+08      1.34148   5.163e+05  1.064e+09
MPI Reductions:       1.005e+03      1.00000
 0:      Main Stage: 1.4211e+01   6.4%  0.0000e+00   0.0%  5.020e+02  24.4%  3.027e+05       58.6%  1.250e+02  12.4%
 1:             FEM: 2.0628e+02  93.6%  2.0822e+11 100.0%  1.559e+03  75.6%  2.135e+05       41.4%  8.790e+02  87.5%
Phase summary info:
BuildTwoSided         44 1.0 8.1745e-01 9.9 0.00e+00 0.0 1.2e+02 4.0e+00 4.4e+01  0  0  6  0  4   3  0 24  0 35     0
VecScatterBegin        2 1.0 1.5371e-03 1.4 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecScatterEnd          2 1.0 3.0994e-06 1.4 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
Mesh Partition         2 1.0 1.6335e+00 1.1 0.00e+00 0.0 9.2e+01 5.5e+05 2.1e+01  1  0  4  5  2  11  0 18  8 17     0
Mesh Migration         2 1.0 1.6901e+00 1.0 0.00e+00 0.0 3.7e+02 1.4e+06 5.4e+01  1  0 18 49  5  12  0 75 83 43     0
DMPlexInterp           1 1.0 2.0401e+0041740.2 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   7  0  0  0  0     0
DMPlexDistribute       1 1.0 2.1610e+00 1.1 0.00e+00 0.0 1.7e+02 1.9e+06 2.5e+01  1  0  8 30  2  15  0 33 50 20     0
DMPlexDistCones        2 1.0 3.6283e-01 1.0 0.00e+00 0.0 5.4e+01 3.2e+06 4.0e+00  0  0  3 16  0   3  0 11 28  3     0
DMPlexDistLabels       2 1.0 8.6425e-01 1.0 0.00e+00 0.0 2.4e+02 1.2e+06 2.2e+01  0  0 12 28  2   6  0 48 47 18     0
DMPlexDistribOL        1 1.0 1.1811e+00 1.0 0.00e+00 0.0 3.1e+02 9.6e+05 5.0e+01  1  0 15 28  5   8  0 61 48 40     0
DMPlexDistField        3 1.0 4.4417e-02 1.1 0.00e+00 0.0 6.2e+01 3.5e+05 1.2e+01  0  0  3  2  1   0  0 12  3 10     0
DMPlexDistData         2 1.0 8.4055e-0126.5 0.00e+00 0.0 5.4e+01 4.0e+05 6.0e+00  0  0  3  2  1   3  0 11  3  5     0
DMPlexStratify         6 1.5 7.7436e-01 2.9 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   4  0  0  0  0     0
SFSetGraph            51 1.0 4.1998e-01 1.1 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   3  0  0  0  0     0
SFBcastBegin          95 1.0 9.1913e-01 3.3 0.00e+00 0.0 4.8e+02 1.2e+06 4.1e+01  0  0 23 56  4   4  0 96 96 33     0
SFBcastEnd            95 1.0 3.4255e-01 2.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   2  0  0  0  0     0
SFReduceBegin          4 1.0 3.0928e-03 1.2 0.00e+00 0.0 1.1e+01 1.3e+06 3.0e+00  0  0  1  1  0   0  0  2  2  2     0
SFReduceEnd            4 1.0 5.1863e-03 1.4 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
SFFetchOpBegin         1 1.0 3.0994e-05 6.2 0.00e+00 0.0 1.0e+00 4.2e+04 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
SFFetchOpEnd           1 1.0 5.9104e-04 3.8 0.00e+00 0.0 1.0e+00 4.2e+04 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
BuildTwoSided         17 1.0 3.1600e-03 6.4 0.00e+00 0.0 1.0e+01 4.0e+00 1.7e+01  0  0  0  0  2   0  0  1  0  2     0
BuildTwoSidedF        12 1.0 1.7691e-04 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 1.2e+01  0  0  0  0  1   0  0  0  0  1     0
VecMDot               95 1.0 7.7544e-02 1.2 1.88e+08 1.0 0.0e+00 0.0e+00 9.5e+01  0  0  0  0  9   0  0  0  0 11  4849
VecNorm              104 1.0 1.8694e-02 1.1 2.84e+07 1.0 0.0e+00 0.0e+00 1.0e+02  0  0  0  0 10   0  0  0  0 12  3028
VecScale             210 1.0 2.2894e-02 1.0 3.77e+07 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0  3289
VecCopy               73 1.0 7.2665e-03 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecSet               563 1.0 1.2248e-01 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecAXPY                9 1.0 1.0741e-03 1.0 2.05e+06 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0  3808
VecAYPX              512 1.0 3.0463e-02 1.0 3.54e+07 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0  2321
VecAXPBYCZ           256 1.0 2.1654e-02 1.0 7.08e+07 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0  6529
VecMAXPY             104 1.0 6.4986e-02 1.0 2.15e+08 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0  6594
VecAssemblyBegin      13 1.0 2.4629e-04 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 1.2e+01  0  0  0  0  1   0  0  0  0  1     0
VecAssemblyEnd        13 1.0 2.4557e-05 1.2 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecPointwiseMult      44 1.0 3.5381e-03 1.0 2.43e+06 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0  1374
VecScatterBegin      936 1.0 4.1796e-02 1.0 0.00e+00 0.0 1.3e+03 2.4e+04 0.0e+00  0  0 61  3  0   0  0 81  7  0     0
VecScatterEnd        936 1.0 4.6248e-01 3.7 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecSetRandom           4 1.0 8.8727e-03 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecNormalize         104 1.0 2.7498e-02 1.0 4.26e+07 1.0 0.0e+00 0.0e+00 1.0e+02  0  0  0  0 10   0  0  0  0 12  3088
MatMult              495 1.0 6.5382e+00 1.0 9.15e+09 1.0 1.0e+03 2.8e+04 1.2e+02  3  9 49  3 12   3  9 64  6 14  2794
MatMultAdd           214 1.0 3.9983e-01 1.1 5.66e+08 1.1 1.7e+02 1.6e+04 0.0e+00  0  1  8  0  0   0  1 11  1  0  2751
MatMultTranspose      64 1.0 2.8789e-01 1.1 3.88e+08 1.1 1.1e+02 5.9e+03 0.0e+00  0  0  5  0  0   0  0  7  0  0  2580
MatSolve             122 1.2 6.5441e-01 1.0 5.30e+08 1.0 0.0e+00 0.0e+00 0.0e+00  0  1  0  0  0   0  1  0  0  0  1612
MatSOR               428 1.0 4.2707e+00 1.0 6.26e+09 1.0 0.0e+00 0.0e+00 0.0e+00  2  6  0  0  0   2  6  0  0  0  2925
MatLUFactorSym         1 1.0 1.5974e-05 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatLUFactorNum         2 1.0 3.4417e-02 1.0 9.09e+06 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0   525
MatILUFactorSym        1 1.0 2.5373e-02 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatConvert             5 1.0 2.6755e-01 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatScale              14 1.0 1.0400e-01 1.0 9.99e+07 1.0 8.0e+00 2.8e+04 0.0e+00  0  0  0  0  0   0  0  1  0  0  1903
MatResidual           64 1.0 7.6395e-01 1.0 1.17e+09 1.0 1.3e+02 2.8e+04 0.0e+00  0  1  6  0  0   0  1  8  1  0  3061
MatAssemblyBegin      89 1.0 1.1247e+0138.9 0.00e+00 0.0 3.9e+01 5.9e+06 5.4e+01  3  0  2 22  5   3  0  3 52  6     0
MatAssemblyEnd        89 1.0 1.0761e+00 1.0 0.00e+00 0.0 8.0e+01 4.3e+03 2.0e+02  0  0  4  0 20   1  0  5  0 23     0
MatGetRow        1047432 1.0 1.0699e+00 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   1  0  0  0  0     0
MatGetRowIJ            2 2.0 8.1062e-06 4.2 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatGetSubMatrix        6 1.0 2.5043e-01 1.0 0.00e+00 0.0 7.0e+00 1.0e+02 4.0e+01  0  0  0  0  4   0  0  0  0  5     0
MatGetOrdering         2 2.0 2.4710e-03 1.7 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatCoarsen             4 1.0 1.5470e-02 1.1 0.00e+00 0.0 4.8e+01 8.1e+03 1.2e+01  0  0  2  0  1   0  0  3  0  1     0
MatZeroEntries         4 1.0 1.3583e-01 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatAXPY                5 1.0 1.2150e+00 1.0 0.00e+00 0.0 4.0e+00 6.7e+03 2.0e+01  1  0  0  0  2   1  0  0  0  2     0
MatMatMult             5 1.0 7.4322e+00 1.0 7.81e+07 1.0 5.6e+01 1.5e+04 8.0e+01  3  0  3  0  8   4  0  4  0  9    21
MatMatMultSym          5 1.0 7.1974e+00 1.0 0.00e+00 0.0 4.7e+01 1.3e+04 7.0e+01  3  0  2  0  7   3  0  3  0  8     0
MatMatMultNum          5 1.0 2.3470e-01 1.0 7.81e+07 1.0 9.0e+00 3.1e+04 1.0e+01  0  0  0  0  1   0  0  1  0  1   665
MatPtAP                4 1.0 1.8275e+02 1.0 9.39e+10 1.2 8.8e+01 4.3e+06 6.8e+01 83 83  4 36  7  89 83  6 86  8   949
MatPtAPSymbolic        4 1.0 1.1582e+02 1.0 0.00e+00 0.0 4.8e+01 3.1e+06 2.8e+01 53  0  2 14  3  56  0  3 34  3     0
MatPtAPNumeric         4 1.0 6.6931e+01 1.0 9.39e+10 1.2 4.0e+01 5.8e+06 4.0e+01 30 83  2 22  4  32 83  3 52  5  2592
MatTrnMatMult          1 1.0 2.4068e-01 1.0 9.46e+06 1.0 1.2e+01 4.3e+04 1.9e+01  0  0  1  0  2   0  0  1  0  2    79
MatTrnMatMultSym       1 1.0 1.5422e-01 1.0 0.00e+00 0.0 1.0e+01 2.4e+04 1.7e+01  0  0  0  0  2   0  0  1  0  2     0
MatTrnMatMultNum       1 1.0 8.6440e-02 1.0 9.46e+06 1.0 2.0e+00 1.4e+05 2.0e+00  0  0  0  0  0   0  0  0  0  0   219
MatGetLocalMat        16 1.0 1.1441e-01 1.1 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatGetBrAoCol         14 1.0 7.4965e-02 1.0 0.00e+00 0.0 6.0e+01 1.5e+06 0.0e+00  0  0  3  9  0   0  0  4 21  0     0
PCGAMGGraph_AGG        4 1.0 1.5076e+00 1.0 7.32e+07 1.0 2.4e+01 1.1e+04 4.8e+01  1  0  1  0  5   1  0  2  0  5    97
PCGAMGCoarse_AGG       4 1.0 2.9894e-01 1.0 9.46e+06 1.0 7.0e+01 2.0e+04 3.9e+01  0  0  3  0  4   0  0  4  0  4    63
PCGAMGProl_AGG         4 1.0 5.3907e-02 1.0 0.00e+00 0.0 4.1e+01 8.8e+03 8.0e+01  0  0  2  0  8   0  0  3  0  9     0
PCGAMGPOpt_AGG         4 1.0 8.3099e+00 1.0 8.88e+08 1.0 1.3e+02 2.3e+04 1.9e+02  4  1  6  0 19   4  1  8  1 21   214
GAMG: createProl       4 1.0 1.0182e+01 1.0 9.71e+08 1.0 2.6e+02 1.9e+04 3.6e+02  5  1 13  0 35   5  1 17  1 40   191
  Graph                8 1.0 1.4890e+00 1.0 7.32e+07 1.0 2.4e+01 1.1e+04 4.8e+01  1  0  1  0  5   1  0  2  0  5    98
  MIS/Agg              4 1.0 1.5540e-02 1.0 0.00e+00 0.0 4.8e+01 8.1e+03 1.2e+01  0  0  2  0  1   0  0  3  0  1     0
  SA: col data         4 1.0 1.1244e-02 1.0 0.00e+00 0.0 1.6e+01 1.9e+04 2.4e+01  0  0  1  0  2   0  0  1  0  3     0
  SA: frmProl0         4 1.0 3.9084e-02 1.0 0.00e+00 0.0 2.5e+01 2.0e+03 4.0e+01  0  0  1  0  4   0  0  2  0  5     0
  SA: smooth           4 1.0 8.3098e+00 1.0 8.88e+08 1.0 1.3e+02 2.3e+04 1.9e+02  4  1  6  0 19   4  1  8  1 21   214
GAMG: partLevel        4 1.0 1.8298e+02 1.0 9.39e+10 1.2 9.8e+01 3.9e+06 1.2e+02 83 83  5 36 12  89 83  6 86 14   948
  repartition          1 1.0 2.5988e-05 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 6.0e+00  0  0  0  0  1   0  0  0  0  1     0
  Invert-Sort          1 1.0 1.8120e-05 1.1 0.00e+00 0.0 0.0e+00 0.0e+00 4.0e+00  0  0  0  0  0   0  0  0  0  0     0
  Move A               1 1.0 2.2859e-01 1.0 0.00e+00 0.0 5.0e+00 1.3e+02 1.8e+01  0  0  0  0  2   0  0  0  0  2     0
  Move P               1 1.0 1.9908e-04 1.0 0.00e+00 0.0 2.0e+00 2.2e+01 1.8e+01  0  0  0  0  2   0  0  0  0  2     0
PCSetUp                5 1.0 1.9420e+02 1.0 9.49e+10 1.2 3.8e+02 1.0e+06 5.6e+02 88 84 18 37 56  94 84 24 89 64   903
PCSetUpOnBlocks      122 1.0 6.2164e-02 1.0 9.09e+06 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0   291
PCApply               16 1.0 2.0400e+02 1.0 1.10e+11 1.2 1.4e+03 2.8e+05 5.9e+02 93 99 70 38 58  99 99 93 93 67  1012
KSPGMRESOrthog        95 1.0 1.3511e-01 1.1 3.77e+08 1.0 0.0e+00 0.0e+00 9.5e+01  0  0  0  0  9   0  0  0  0 11  5566
KSPSetUp              18 1.0 1.5130e-02 1.2 0.00e+00 0.0 0.0e+00 0.0e+00 8.0e+00  0  0  0  0  1   0  0  0  0  1     0
KSPSolve               1 1.0 2.0527e+02 1.0 1.11e+11 1.1 1.5e+03 2.8e+05 8.0e+02 93100 74 40 80 100100 98 96 91  1010
SFSetGraph             4 1.0 1.7595e-04 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
SFBcastBegin          17 1.0 3.2637e-03 5.2 0.00e+00 0.0 5.4e+01 1.2e+04 5.0e+00  0  0  3  0  0   0  0  3  0  1     0
SFBcastEnd            17 1.0 8.5759e-04 2.1 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
              Viewer     1              0            0     0.
           Index Set    79             84     49128340     0.
   IS L to G Mapping     3              3     23945692     0.
             Section    70             53        35616     0.
              Vector    15            141    180695472     0.
      Vector Scatter     2             15     13913664     0.
              Matrix     0             59    790177488     0.
      Preconditioner     0             11        11020     0.
    Distributed Mesh    14              8        38248     0.
    GraphPartitioner     6              5         3060     0.
Star Forest Bipartite Graph    74             63        53256     0.
     Discrete System    14              8         6912     0.
           Index Set    88             76       217792     0.
              Vector   346            208     53912024     0.
      Vector Scatter    37             18        19768     0.
              Matrix   137             65   1266465532     0.
      Preconditioner    21             10         8944     0.
       Krylov Solver    21              6       123480     0.
Star Forest Bipartite Graph     4              4         3456     0.
Average time to get PetscTime(): 8.10623e-07
Average time for MPI_Barrier(): 8.10623e-07
Average time for zero size MPI_Send(): 2.98023e-06
-log_summary
 gamg 40 1
Discretization: RT
MPI processes 4: solving...
((288348, 1161600), (288348, 1161600))
	Solver time: 7.881676e+01
Darcy_FE.py on a arch-linux2-c-opt named wf153.localdomain with 4 processors, by jychang48 Wed Mar  2 17:59:23 2016
Time (sec):           9.180e+01      1.00003   9.180e+01
Objects:              9.550e+02      1.02358   9.390e+02
Flops:                3.967e+10      1.06829   3.820e+10  1.528e+11
Flops/sec:            4.321e+08      1.06831   4.161e+08  1.664e+09
MPI Messages:         2.896e+03      1.22894   2.581e+03  1.032e+04
MPI Message Lengths:  6.146e+08      1.57029   1.801e+05  1.860e+09
MPI Reductions:       1.010e+03      1.00000
 0:      Main Stage: 1.2979e+01  14.1%  0.0000e+00   0.0%  1.654e+03  16.0%  6.288e+04       34.9%  1.250e+02  12.4%
 1:             FEM: 7.8817e+01  85.9%  1.5278e+11 100.0%  8.671e+03  84.0%  1.173e+05       65.1%  8.840e+02  87.5%
Phase summary info:
BuildTwoSided         44 1.0 9.2481e-0116.9 0.00e+00 0.0 3.9e+02 4.0e+00 4.4e+01  1  0  4  0  4   5  0 24  0 35     0
VecScatterBegin        2 1.0 6.7115e-04 1.5 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecScatterEnd          2 1.0 5.2452e-06 1.8 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
Mesh Partition         2 1.0 1.7374e+00 1.1 0.00e+00 0.0 3.8e+02 1.4e+05 2.1e+01  2  0  4  3  2  13  0 23  8 17     0
Mesh Migration         2 1.0 1.0188e+00 1.0 0.00e+00 0.0 1.1e+03 4.7e+05 5.4e+01  1  0 11 29  5   8  0 69 83 43     0
DMPlexInterp           1 1.0 2.0553e+0052887.5 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  1  0  0  0  0   4  0  0  0  0     0
DMPlexDistribute       1 1.0 2.0098e+00 1.1 0.00e+00 0.0 3.9e+02 8.1e+05 2.5e+01  2  0  4 17  2  15  0 23 49 20     0
DMPlexDistCones        2 1.0 2.3204e-01 1.0 0.00e+00 0.0 1.6e+02 1.1e+06 4.0e+00  0  0  2 10  0   2  0 10 28  3     0
DMPlexDistLabels       2 1.0 5.4382e-01 1.0 0.00e+00 0.0 7.2e+02 4.2e+05 2.2e+01  1  0  7 16  2   4  0 44 47 18     0
DMPlexDistribOL        1 1.0 7.6249e-01 1.0 0.00e+00 0.0 1.2e+03 2.8e+05 5.0e+01  1  0 11 17  5   6  0 70 49 40     0
DMPlexDistField        3 1.0 2.7687e-02 1.2 0.00e+00 0.0 2.0e+02 1.1e+05 1.2e+01  0  0  2  1  1   0  0 12  4 10     0
DMPlexDistData         2 1.0 9.2141e-0140.2 0.00e+00 0.0 2.2e+02 1.0e+05 6.0e+00  1  0  2  1  1   5  0 14  4  5     0
DMPlexStratify         6 1.5 6.4549e-01 4.8 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   2  0  0  0  0     0
SFSetGraph            51 1.0 2.4213e-01 1.1 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   2  0  0  0  0     0
SFBcastBegin          95 1.0 9.8293e-01 4.6 0.00e+00 0.0 1.6e+03 4.0e+05 4.1e+01  1  0 15 34  4   6  0 95 96 33     0
SFBcastEnd            95 1.0 3.0583e-01 2.6 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   2  0  0  0  0     0
SFReduceBegin          4 1.0 2.8150e-03 2.0 0.00e+00 0.0 4.9e+01 2.9e+05 3.0e+00  0  0  0  1  0   0  0  3  2  2     0
SFReduceEnd            4 1.0 6.0437e-03 2.6 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
SFFetchOpBegin         1 1.0 3.9101e-05 7.8 0.00e+00 0.0 5.0e+00 1.7e+04 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
SFFetchOpEnd           1 1.0 2.9993e-04 2.9 0.00e+00 0.0 5.0e+00 1.7e+04 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
BuildTwoSided         17 1.0 3.0973e-03 3.2 0.00e+00 0.0 5.4e+01 4.0e+00 1.7e+01  0  0  1  0  2   0  0  1  0  2     0
BuildTwoSidedF        12 1.0 3.7432e-04 2.9 0.00e+00 0.0 0.0e+00 0.0e+00 1.2e+01  0  0  0  0  1   0  0  0  0  1     0
VecMDot               95 1.0 6.2907e-02 1.6 9.45e+07 1.0 0.0e+00 0.0e+00 9.5e+01  0  0  0  0  9   0  0  0  0 11  5977
VecNorm              104 1.0 1.1690e-02 1.3 1.42e+07 1.0 0.0e+00 0.0e+00 1.0e+02  0  0  0  0 10   0  0  0  0 12  4843
VecScale             210 1.0 1.1790e-02 1.0 1.89e+07 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0  6387
VecCopy               73 1.0 2.9068e-03 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecSet               563 1.0 6.0357e-02 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecAXPY                9 1.0 6.0582e-04 1.0 1.03e+06 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0  6752
VecAYPX              512 1.0 1.6990e-02 1.0 1.77e+07 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0  4161
VecAXPBYCZ           256 1.0 1.2354e-02 1.0 3.54e+07 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0 11446
VecMAXPY             104 1.0 3.6181e-02 1.0 1.08e+08 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0 11844
VecAssemblyBegin      13 1.0 4.4584e-04 2.1 0.00e+00 0.0 0.0e+00 0.0e+00 1.2e+01  0  0  0  0  1   0  0  0  0  1     0
VecAssemblyEnd        13 1.0 2.8133e-05 1.1 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecPointwiseMult      44 1.0 1.8675e-03 1.0 1.22e+06 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0  2603
VecScatterBegin      936 1.0 2.9592e-02 1.1 0.00e+00 0.0 7.1e+03 1.2e+04 0.0e+00  0  0 69  5  0   0  0 82  7  0     0
VecScatterEnd        936 1.0 2.7927e-01 4.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecSetRandom           4 1.0 4.5090e-03 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecNormalize         104 1.0 1.6539e-02 1.2 2.13e+07 1.0 0.0e+00 0.0e+00 1.0e+02  0  0  0  0 10   0  0  0  0 12  5135
MatMult              495 1.0 3.3400e+00 1.0 4.53e+09 1.0 5.7e+03 1.4e+04 1.2e+02  4 12 55  4 12   4 12 66  7 14  5284
MatMultAdd           214 1.0 1.9689e-01 1.0 2.56e+08 1.0 8.9e+02 6.8e+03 0.0e+00  0  1  9  0  0   0  1 10  1  0  5084
MatMultTranspose      64 1.0 1.5643e-01 1.3 1.67e+08 1.1 5.9e+02 3.0e+03 0.0e+00  0  0  6  0  0   0  0  7  0  0  4115
MatSolve             122 1.2 3.5537e-01 1.1 2.65e+08 1.0 0.0e+00 0.0e+00 0.0e+00  0  1  0  0  0   0  1  0  0  0  2957
MatSOR               428 1.0 2.0880e+00 1.1 2.71e+09 1.1 0.0e+00 0.0e+00 0.0e+00  2  7  0  0  0   3  7  0  0  0  4989
MatLUFactorSym         1 1.0 3.5048e-05 2.9 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatLUFactorNum         2 1.0 1.8154e-02 1.0 4.57e+06 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0   995
MatILUFactorSym        1 1.0 1.2837e-02 1.4 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatConvert             5 1.0 1.3118e-01 1.1 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatScale              14 1.0 5.5241e-02 1.0 4.79e+07 1.0 4.6e+01 1.4e+04 0.0e+00  0  0  0  0  0   0  0  1  0  0  3375
MatResidual           64 1.0 3.8316e-01 1.0 5.79e+08 1.0 7.4e+02 1.4e+04 0.0e+00  0  1  7  1  0   0  1  8  1  0  5882
MatAssemblyBegin      89 1.0 2.4723e+00 7.3 0.00e+00 0.0 2.1e+02 3.2e+06 5.4e+01  2  0  2 36  5   2  0  2 56  6     0
MatAssemblyEnd        89 1.0 1.3361e+00 1.0 0.00e+00 0.0 4.3e+02 1.8e+03 2.0e+02  1  0  4  0 20   2  0  5  0 23     0
MatGetRow         524034 1.0 1.0427e+00 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  1  0  0  0  0   1  0  0  0  0     0
MatGetSubMatrix        6 1.0 1.0785e-02 1.0 0.00e+00 0.0 2.1e+01 4.8e+01 4.0e+01  0  0  0  0  4   0  0  0  0  5     0
MatGetOrdering         2 2.0 1.2300e-03 1.8 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatCoarsen             4 1.0 8.7881e-03 1.1 0.00e+00 0.0 3.2e+02 3.0e+03 1.7e+01  0  0  3  0  2   0  0  4  0  2     0
MatZeroEntries         4 1.0 7.0884e-02 1.1 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatAXPY                5 1.0 1.2048e+00 1.0 0.00e+00 0.0 2.0e+01 2.7e+03 2.0e+01  1  0  0  0  2   2  0  0  0  2     0
MatMatMult             5 1.0 2.5813e+00 1.0 3.86e+07 1.0 3.2e+02 7.3e+03 8.0e+01  3  0  3  0  8   3  0  4  0  9    58
MatMatMultSym          5 1.0 2.4731e+00 1.0 0.00e+00 0.0 2.6e+02 5.9e+03 7.0e+01  3  0  3  0  7   3  0  3  0  8     0
MatMatMultNum          5 1.0 1.0818e-01 1.0 3.86e+07 1.0 5.1e+01 1.5e+04 1.0e+01  0  0  0  0  1   0  0  1  0  1  1394
MatPtAP                4 1.0 6.7203e+01 1.0 3.18e+10 1.1 5.1e+02 2.1e+06 6.8e+01 73 79  5 59  7  85 79  6 90  8  1799
MatPtAPSymbolic        4 1.0 4.1790e+01 1.0 0.00e+00 0.0 2.8e+02 1.5e+06 2.8e+01 46  0  3 22  3  53  0  3 34  3     0
MatPtAPNumeric         4 1.0 2.5414e+01 1.0 3.18e+10 1.1 2.3e+02 2.9e+06 4.0e+01 28 79  2 36  4  32 79  3 56  5  4756
MatTrnMatMult          1 1.0 1.3047e-01 1.0 4.76e+06 1.0 6.0e+01 1.7e+04 1.9e+01  0  0  1  0  2   0  0  1  0  2   146
MatTrnMatMultSym       1 1.0 8.3536e-02 1.0 0.00e+00 0.0 5.0e+01 9.7e+03 1.7e+01  0  0  0  0  2   0  0  1  0  2     0
MatTrnMatMultNum       1 1.0 4.6928e-02 1.0 4.76e+06 1.0 1.0e+01 5.4e+04 2.0e+00  0  0  0  0  0   0  0  0  0  0   405
MatGetLocalMat        16 1.0 5.5166e-02 1.2 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatGetBrAoCol         14 1.0 1.3093e-01 1.2 0.00e+00 0.0 3.4e+02 7.3e+05 0.0e+00  0  0  3 13  0   0  0  4 21  0     0
PCGAMGGraph_AGG        4 1.0 1.1715e+00 1.0 3.62e+07 1.0 1.3e+02 5.5e+03 4.8e+01  1  0  1  0  5   1  0  2  0  5   120
PCGAMGCoarse_AGG       4 1.0 1.6066e-01 1.0 4.76e+06 1.0 4.3e+02 6.9e+03 4.4e+01  0  0  4  0  4   0  0  5  0  5   118
PCGAMGProl_AGG         4 1.0 2.7573e-02 1.0 0.00e+00 0.0 2.1e+02 3.5e+03 8.0e+01  0  0  2  0  8   0  0  2  0  9     0
PCGAMGPOpt_AGG         4 1.0 3.2287e+00 1.0 4.39e+08 1.0 7.4e+02 1.1e+04 1.9e+02  4  1  7  0 19   4  1  8  1 21   530
GAMG: createProl       4 1.0 4.5962e+00 1.0 4.80e+08 1.0 1.5e+03 8.4e+03 3.6e+02  5  1 15  1 36   6  1 17  1 41   407
  Graph                8 1.0 1.1613e+00 1.0 3.62e+07 1.0 1.3e+02 5.5e+03 4.8e+01  1  0  1  0  5   1  0  2  0  5   121
  MIS/Agg              4 1.0 8.8501e-03 1.1 0.00e+00 0.0 3.2e+02 3.0e+03 1.7e+01  0  0  3  0  2   0  0  4  0  2     0
  SA: col data         4 1.0 5.9159e-03 1.0 0.00e+00 0.0 8.8e+01 7.3e+03 2.4e+01  0  0  1  0  2   0  0  1  0  3     0
  SA: frmProl0         4 1.0 2.0285e-02 1.0 0.00e+00 0.0 1.2e+02 8.0e+02 4.0e+01  0  0  1  0  4   0  0  1  0  5     0
  SA: smooth           4 1.0 3.2287e+00 1.0 4.39e+08 1.0 7.4e+02 1.1e+04 1.9e+02  4  1  7  0 19   4  1  8  1 21   530
GAMG: partLevel        4 1.0 6.7203e+01 1.0 3.18e+10 1.1 5.4e+02 2.0e+06 1.2e+02 73 79  5 59 12  85 79  6 90 14  1799
  repartition          1 1.0 5.2929e-05 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 6.0e+00  0  0  0  0  1   0  0  0  0  1     0
  Invert-Sort          1 1.0 4.6968e-05 1.1 0.00e+00 0.0 0.0e+00 0.0e+00 4.0e+00  0  0  0  0  0   0  0  0  0  0     0
  Move A               1 1.0 2.0814e-04 1.0 0.00e+00 0.0 1.5e+01 6.0e+01 1.8e+01  0  0  0  0  2   0  0  0  0  2     0
  Move P               1 1.0 1.8096e-04 1.0 0.00e+00 0.0 6.0e+00 2.0e+01 1.8e+01  0  0  0  0  2   0  0  0  0  2     0
PCSetUp                5 1.0 7.2710e+01 1.0 3.22e+10 1.1 2.1e+03 5.2e+05 5.7e+02 79 80 21 60 56  92 80 25 92 64  1689
PCSetUpOnBlocks      122 1.0 3.2053e-02 1.1 4.57e+06 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0   563
PCApply               16 1.0 7.7192e+01 1.0 3.92e+10 1.1 8.2e+03 1.4e+05 5.9e+02 84 99 79 63 59  98 99 94 97 67  1955
KSPGMRESOrthog        95 1.0 9.5074e-02 1.3 1.89e+08 1.0 0.0e+00 0.0e+00 9.5e+01  0  0  0  0  9   0  0  0  0 11  7910
KSPSetUp              18 1.0 6.6414e-03 2.0 0.00e+00 0.0 0.0e+00 0.0e+00 8.0e+00  0  0  0  0  1   0  0  0  0  1     0
KSPSolve               1 1.0 7.8229e+01 1.0 3.94e+10 1.1 8.6e+03 1.4e+05 8.0e+02 85 99 83 64 80  99 99 99 98 91  1941
SFSetGraph             4 1.0 2.3985e-04 1.4 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
SFBcastBegin          22 1.0 3.1741e-03 2.8 0.00e+00 0.0 3.5e+02 4.2e+03 5.0e+00  0  0  3  0  0   0  0  4  0  1     0
SFBcastEnd            22 1.0 3.9601e-04 1.3 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
              Viewer     1              0            0     0.
           Index Set    87             92     35927140     0.
   IS L to G Mapping     3              3     18881016     0.
              Vector    15            141     92771016     0.
      Vector Scatter     2             15      6936792     0.
              Matrix     0             59    361266968     0.
           Index Set    88             76       260344     0.
              Vector   346            208     27367352     0.
      Vector Scatter    37             18        19744     0.
              Matrix   137             65    608134404     0.
Average time for MPI_Barrier(): 1.57356e-06
Average time for zero size MPI_Send(): 1.96695e-06
-log_summary
 gamg 40 1
Discretization: RT
MPI processes 8: solving...
((143102, 1161600), (143102, 1161600))
	Solver time: 4.012547e+01
Darcy_FE.py on a arch-linux2-c-opt named wf153.localdomain with 8 processors, by jychang48 Wed Mar  2 18:00:17 2016
Time (sec):           5.307e+01      1.00010   5.307e+01
Objects:              1.002e+03      1.03512   9.730e+02
Flops:                1.814e+10      1.32210   1.527e+10  1.221e+11
Flops/sec:            3.418e+08      1.32197   2.877e+08  2.301e+09
MPI Messages:         5.818e+03      1.51879   4.441e+03  3.553e+04
MPI Message Lengths:  5.914e+08      2.04577   8.271e+04  2.938e+09
MPI Reductions:       1.063e+03      1.00000
 0:      Main Stage: 1.2942e+01  24.4%  0.0000e+00   0.0%  5.296e+03  14.9%  1.912e+04       23.1%  1.250e+02  11.8%
 1:             FEM: 4.0126e+01  75.6%  1.2213e+11 100.0%  3.023e+04  85.1%  6.359e+04       76.9%  9.370e+02  88.1%
Phase summary info:
BuildTwoSided         44 1.0 9.8084e-0133.7 0.00e+00 0.0 1.2e+03 4.0e+00 4.4e+01  2  0  3  0  4   6  0 23  0 35     0
VecScatterBegin        2 1.0 3.1185e-04 1.4 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecScatterEnd          2 1.0 3.8147e-06 2.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
Mesh Partition         2 1.0 1.8528e+00 1.1 0.00e+00 0.0 1.4e+03 4.1e+04 2.1e+01  3  0  4  2  2  14  0 26  8 17     0
Mesh Migration         2 1.0 6.9385e-01 1.0 0.00e+00 0.0 3.4e+03 1.6e+05 5.4e+01  1  0 10 19  5   5  0 65 82 43     0
DMPlexInterp           1 1.0 2.1209e+0058911.1 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   2  0  0  0  0     0
DMPlexDistribute       1 1.0 2.0432e+00 1.1 0.00e+00 0.0 1.0e+03 3.2e+05 2.5e+01  4  0  3 11  2  16  0 19 47 20     0
DMPlexDistCones        2 1.0 1.6185e-01 1.0 0.00e+00 0.0 4.9e+02 3.8e+05 4.0e+00  0  0  1  6  0   1  0  9 27  3     0
DMPlexDistLabels       2 1.0 3.9578e-01 1.0 0.00e+00 0.0 2.1e+03 1.5e+05 2.2e+01  1  0  6 11  2   3  0 40 47 18     0
DMPlexDistribOL        1 1.0 5.2214e-01 1.0 0.00e+00 0.0 3.9e+03 8.8e+04 5.0e+01  1  0 11 12  5   4  0 73 50 40     0
DMPlexDistField        3 1.0 2.2155e-02 1.2 0.00e+00 0.0 6.4e+02 3.8e+04 1.2e+01  0  0  2  1  1   0  0 12  4 10     0
DMPlexDistData         2 1.0 9.7258e-0152.8 0.00e+00 0.0 8.5e+02 3.0e+04 6.0e+00  2  0  2  1  1   6  0 16  4  5     0
DMPlexStratify         6 1.5 6.0035e-01 8.6 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   1  0  0  0  0     0
SFSetGraph            51 1.0 1.4183e-01 1.1 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   1  0  0  0  0     0
SFBcastBegin          95 1.0 1.0219e+00 6.0 0.00e+00 0.0 5.0e+03 1.3e+05 4.1e+01  2  0 14 22  4   7  0 95 96 33     0
SFBcastEnd            95 1.0 3.0369e-01 2.9 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  1  0  0  0  0   2  0  0  0  0     0
SFReduceBegin          4 1.0 3.5670e-03 3.6 0.00e+00 0.0 1.8e+02 8.2e+04 3.0e+00  0  0  1  0  0   0  0  3  2  2     0
SFReduceEnd            4 1.0 6.7761e-03 2.9 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
SFFetchOpBegin         1 1.0 6.9857e-0511.3 0.00e+00 0.0 1.9e+01 7.0e+03 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
SFFetchOpEnd           1 1.0 2.3389e-04 2.6 0.00e+00 0.0 1.9e+01 7.0e+03 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
BuildTwoSided         17 1.0 2.7728e-03 6.0 0.00e+00 0.0 1.7e+02 4.0e+00 1.7e+01  0  0  0  0  2   0  0  1  0  2     0
BuildTwoSidedF        12 1.0 4.5395e-04 1.6 0.00e+00 0.0 0.0e+00 0.0e+00 1.2e+01  0  0  0  0  1   0  0  0  0  1     0
VecMDot               95 1.0 4.5413e-02 1.8 4.73e+07 1.0 0.0e+00 0.0e+00 9.5e+01  0  0  0  0  9   0  0  0  0 10  8279
VecNorm              104 1.0 7.2548e-03 1.2 7.12e+06 1.0 0.0e+00 0.0e+00 1.0e+02  0  0  0  0 10   0  0  0  0 11  7803
VecScale             210 1.0 6.3441e-03 1.0 9.46e+06 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0 11871
VecCopy               73 1.0 1.6530e-03 1.1 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecSet               566 1.0 1.8410e-02 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecAXPY                9 1.0 3.9196e-04 1.2 5.14e+05 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0 10436
VecAYPX              512 1.0 1.1320e-02 1.2 8.85e+06 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0  6245
VecAXPBYCZ           256 1.0 7.8399e-03 1.1 1.77e+07 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0 18034
VecMAXPY             104 1.0 2.3948e-02 1.1 5.39e+07 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0 17894
VecAssemblyBegin      14 1.0 5.6481e-04 1.4 0.00e+00 0.0 0.0e+00 0.0e+00 1.2e+01  0  0  0  0  1   0  0  0  0  1     0
VecAssemblyEnd        14 1.0 5.9128e-05 1.2 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecPointwiseMult      44 1.0 1.1752e-03 1.1 6.09e+05 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0  4136
VecScatterBegin      937 1.0 2.5381e-02 1.1 0.00e+00 0.0 2.5e+04 6.9e+03 0.0e+00  0  0 70  6  0   0  0 82  8  0     0
VecScatterEnd        937 1.0 1.5833e-01 6.3 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecSetRandom           4 1.0 2.2795e-03 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecNormalize         104 1.0 1.0659e-02 1.1 1.07e+07 1.0 0.0e+00 0.0e+00 1.0e+02  0  0  0  0 10   0  0  0  0 11  7967
MatMult              495 1.0 1.7763e+00 1.0 2.19e+09 1.1 2.0e+04 7.9e+03 1.2e+02  3 14 57  5 12   4 14 67  7 13  9571
MatMultAdd           214 1.0 1.1394e-01 1.1 1.18e+08 1.1 3.1e+03 3.3e+03 0.0e+00  0  1  9  0  0   0  1 10  0  0  8065
MatMultTranspose      64 1.0 7.4735e-02 1.3 7.34e+07 1.1 2.0e+03 1.8e+03 0.0e+00  0  0  6  0  0   0  0  7  0  0  7514
MatSolve             122 1.2 1.9528e-01 1.1 1.33e+08 1.0 0.0e+00 0.0e+00 0.0e+00  0  1  0  0  0   0  1  0  0  0  5355
MatSOR               428 1.0 1.1337e+00 1.0 1.18e+09 1.1 0.0e+00 0.0e+00 0.0e+00  2  8  0  0  0   3  8  0  0  0  8134
MatLUFactorSym         1 1.0 2.3842e-05 2.7 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatLUFactorNum         2 1.0 9.0170e-03 1.0 2.31e+06 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0  2003
MatILUFactorSym        1 1.0 3.6991e-03 1.1 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatConvert             5 1.0 7.0534e-02 1.1 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatScale              14 1.0 3.9479e-02 1.0 2.27e+07 1.1 1.6e+02 8.1e+03 0.0e+00  0  0  0  0  0   0  0  1  0  0  4452
MatResidual           64 1.0 2.0590e-01 1.0 2.80e+08 1.1 2.6e+03 8.1e+03 0.0e+00  0  2  7  1  0   1  2  9  1  0 10516
MatAssemblyBegin      93 1.0 3.5671e+0011.2 0.00e+00 0.0 7.3e+02 1.7e+06 5.8e+01  4  0  2 43  5   6  0  2 56  6     0
MatAssemblyEnd        93 1.0 1.8181e+00 1.0 0.00e+00 0.0 1.6e+03 9.3e+02 2.2e+02  3  0  4  0 20   4  0  5  0 23     0
MatGetRow         262026 1.0 1.0316e+00 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  2  0  0  0  0   3  0  0  0  0     0
MatGetRowIJ            2 2.0 1.0014e-05 5.2 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatGetSubMatrix        8 1.0 1.3851e-02 1.0 0.00e+00 0.0 1.4e+02 3.6e+03 7.4e+01  0  0  0  0  7   0  0  0  0  8     0
MatGetOrdering         2 2.0 3.9101e-04 1.1 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatCoarsen             4 1.0 6.0310e-03 1.1 0.00e+00 0.0 9.5e+02 1.8e+03 1.7e+01  0  0  3  0  2   0  0  3  0  2     0
MatZeroEntries         4 1.0 3.4907e-02 1.1 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatAXPY                5 1.0 1.2078e+00 1.0 0.00e+00 0.0 7.6e+01 1.1e+03 2.0e+01  2  0  0  0  2   3  0  0  0  2     0
MatMatMult             5 1.0 1.0170e+00 1.0 1.87e+07 1.1 1.1e+03 4.1e+03 8.0e+01  2  0  3  0  8   3  0  4  0  9   143
MatMatMultSym          5 1.0 9.6113e-01 1.0 0.00e+00 0.0 9.4e+02 3.3e+03 7.0e+01  2  0  3  0  7   2  0  3  0  7     0
MatMatMultNum          5 1.0 5.5820e-02 1.0 1.87e+07 1.1 1.8e+02 8.2e+03 1.0e+01  0  0  1  0  1   0  0  1  0  1  2602
MatPtAP                4 1.0 3.3189e+01 1.0 1.43e+10 1.4 1.8e+03 1.1e+06 6.8e+01 63 75  5 70  6  83 75  6 91  7  2778
MatPtAPSymbolic        4 1.0 1.9334e+01 1.0 0.00e+00 0.0 9.7e+02 8.1e+05 2.8e+01 36  0  3 27  3  48  0  3 35  3     0
MatPtAPNumeric         4 1.0 1.3856e+01 1.0 1.43e+10 1.4 8.5e+02 1.5e+06 4.0e+01 26 75  2 43  4  35 75  3 56  4  6653
MatTrnMatMult          1 1.0 7.2624e-02 1.0 2.41e+06 1.0 2.3e+02 7.1e+03 1.9e+01  0  0  1  0  2   0  0  1  0  2   263
MatTrnMatMultSym       1 1.0 4.6745e-02 1.0 0.00e+00 0.0 1.9e+02 4.1e+03 1.7e+01  0  0  1  0  2   0  0  1  0  2     0
MatTrnMatMultNum       1 1.0 2.5871e-02 1.0 2.41e+06 1.0 3.8e+01 2.3e+04 2.0e+00  0  0  0  0  0   0  0  0  0  0   737
MatGetLocalMat        16 1.0 2.7739e-02 1.4 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatGetBrAoCol         14 1.0 1.5730e-01 1.1 0.00e+00 0.0 1.2e+03 4.0e+05 0.0e+00  0  0  3 16  0   0  0  4 21  0     0
PCGAMGGraph_AGG        4 1.0 1.0277e+00 1.0 1.75e+07 1.1 4.2e+02 3.5e+03 4.8e+01  2  0  1  0  5   3  0  1  0  5   132
PCGAMGCoarse_AGG       4 1.0 9.0071e-02 1.0 2.41e+06 1.0 1.4e+03 3.6e+03 4.4e+01  0  0  4  0  4   0  0  5  0  5   212
PCGAMGProl_AGG         4 1.0 1.5908e-02 1.0 0.00e+00 0.0 6.6e+02 1.8e+03 8.0e+01  0  0  2  0  8   0  0  2  0  9     0
PCGAMGPOpt_AGG         4 1.0 1.5742e+00 1.0 2.12e+08 1.1 2.6e+03 6.6e+03 1.9e+02  3  1  7  1 18   4  1  9  1 20  1045
GAMG: createProl       4 1.0 2.7134e+00 1.0 2.32e+08 1.1 5.0e+03 4.9e+03 3.6e+02  5  1 14  1 34   7  1 17  1 38   663
  Graph                8 1.0 1.0201e+00 1.0 1.75e+07 1.1 4.2e+02 3.5e+03 4.8e+01  2  0  1  0  5   3  0  1  0  5   133
  MIS/Agg              4 1.0 6.1002e-03 1.1 0.00e+00 0.0 9.5e+02 1.8e+03 1.7e+01  0  0  3  0  2   0  0  3  0  2     0
  SA: col data         4 1.0 3.9160e-03 1.0 0.00e+00 0.0 2.6e+02 3.9e+03 2.4e+01  0  0  1  0  2   0  0  1  0  3     0
  SA: frmProl0         4 1.0 1.1169e-02 1.0 0.00e+00 0.0 4.0e+02 3.9e+02 4.0e+01  0  0  1  0  4   0  0  1  0  4     0
  SA: smooth           4 1.0 1.5742e+00 1.0 2.12e+08 1.1 2.6e+03 6.6e+03 1.9e+02  3  1  7  1 18   4  1  9  1 20  1045
GAMG: partLevel        4 1.0 3.3198e+01 1.0 1.43e+10 1.4 2.0e+03 1.0e+06 1.7e+02 63 75  6 70 16  83 75  7 91 19  2777
  repartition          2 1.0 1.0920e-04 1.1 0.00e+00 0.0 0.0e+00 0.0e+00 1.2e+01  0  0  0  0  1   0  0  0  0  1     0
  Invert-Sort          2 1.0 1.3280e-04 1.1 0.00e+00 0.0 0.0e+00 0.0e+00 8.0e+00  0  0  0  0  1   0  0  0  0  1     0
  Move A               2 1.0 1.1239e-03 1.0 0.00e+00 0.0 7.4e+01 6.6e+03 3.6e+01  0  0  0  0  3   0  0  0  0  4     0
  Move P               2 1.0 7.6461e-03 1.0 0.00e+00 0.0 6.2e+01 9.9e+01 3.6e+01  0  0  0  0  3   0  0  0  0  4     0
PCSetUp                5 1.0 3.6754e+01 1.0 1.45e+10 1.4 7.3e+03 2.9e+05 6.2e+02 69 77 21 71 58  92 77 24 92 66  2558
PCSetUpOnBlocks      122 1.0 1.3308e-02 1.0 2.31e+06 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0  1357
PCApply               16 1.0 3.8816e+01 1.0 1.79e+10 1.3 2.8e+04 7.8e+04 6.4e+02 73 98 80 76 61  97 98 94 98 69  3097
KSPGMRESOrthog        95 1.0 6.7224e-02 1.5 9.47e+07 1.0 0.0e+00 0.0e+00 9.5e+01  0  1  0  0  9   0  1  0  0 10 11186
KSPSetUp              18 1.0 3.2098e-03 1.9 0.00e+00 0.0 0.0e+00 0.0e+00 8.0e+00  0  0  0  0  1   0  0  0  0  1     0
KSPSolve               1 1.0 3.9741e+01 1.0 1.80e+10 1.3 3.0e+04 7.5e+04 8.6e+02 75 99 84 76 81  99 99 99 99 92  3049
SFSetGraph             4 1.0 2.6512e-04 1.7 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
SFBcastBegin          22 1.0 2.9793e-03 3.8 0.00e+00 0.0 1.1e+03 2.4e+03 5.0e+00  0  0  3  0  0   0  0  4  0  1     0
SFBcastEnd            22 1.0 7.0238e-04 2.4 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
              Viewer     1              0            0     0.
           Index Set   103            110     29169724     0.
   IS L to G Mapping     3              3     16320748     0.
              Vector    15            141     48823152     0.
      Vector Scatter     2             15      3450888     0.
              Matrix     0             52    170292328     0.
           Index Set   102             88       277596     0.
              Vector   352            214     14068176     0.
      Vector Scatter    40             21        23168     0.
              Matrix   145             80    299175352     0.
Average time for MPI_Barrier(): 3.24249e-06
Average time for zero size MPI_Send(): 1.49012e-06
-log_summary
 gamg 40 1
Discretization: RT
MPI processes 16: solving...
((70996, 1161600), (70996, 1161600))
	Solver time: 1.734145e+01
	Solver iterations: 16
Darcy_FE.py on a arch-linux2-c-opt named wf153.localdomain with 16 processors, by jychang48 Wed Mar  2 18:00:52 2016
Time (sec):           3.188e+01      1.00047   3.187e+01
Objects:              1.028e+03      1.05761   9.805e+02
Flops:                6.348e+09      1.50259   5.466e+09  8.746e+10
Flops/sec:            1.991e+08      1.50208   1.715e+08  2.744e+09
MPI Messages:         9.623e+03      1.72687   7.338e+03  1.174e+05
MPI Message Lengths:  3.833e+08      2.99434   2.872e+04  3.371e+09
MPI Reductions:       1.076e+03      1.00000
 0:      Main Stage: 1.4530e+01  45.6%  0.0000e+00   0.0%  1.470e+04  12.5%  6.199e+03       21.6%  1.250e+02  11.6%
 1:             FEM: 1.7342e+01  54.4%  8.7456e+10 100.0%  1.027e+05  87.5%  2.252e+04       78.4%  9.500e+02  88.3%
Phase summary info:
BuildTwoSided         44 1.0 1.1578e+00 8.9 0.00e+00 0.0 3.5e+03 4.0e+00 4.4e+01  3  0  3  0  4   7  0 24  0 35     0
VecScatterBegin        2 1.0 8.3208e-05 1.9 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecScatterEnd          2 1.0 5.0068e-06 2.6 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
Mesh Partition         2 1.0 1.9160e+00 1.1 0.00e+00 0.0 4.4e+03 1.4e+04 2.1e+01  6  0  4  2  2  13  0 30  9 17     0
Mesh Migration         2 1.0 5.1724e-01 1.0 0.00e+00 0.0 8.9e+03 6.6e+04 5.4e+01  2  0  8 18  5   4  0 61 81 43     0
DMPlexInterp           1 1.0 2.1073e+0058535.3 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   1  0  0  0  0     0
DMPlexDistribute       1 1.0 2.1091e+00 1.1 0.00e+00 0.0 2.9e+03 1.1e+05 2.5e+01  7  0  2 10  2  14  0 20 44 20     0
DMPlexDistCones        2 1.0 1.2136e-01 1.1 0.00e+00 0.0 1.3e+03 1.5e+05 4.0e+00  0  0  1  6  0   1  0  9 27  3     0
DMPlexDistLabels       2 1.0 3.1182e-01 1.0 0.00e+00 0.0 5.5e+03 6.1e+04 2.2e+01  1  0  5 10  2   2  0 38 46 18     0
DMPlexDistribOL        1 1.0 3.4499e-01 1.0 0.00e+00 0.0 1.1e+04 3.5e+04 5.0e+01  1  0  9 11  5   2  0 72 52 40     0
DMPlexDistField        3 1.0 3.0422e-02 1.9 0.00e+00 0.0 1.7e+03 1.5e+04 1.2e+01  0  0  1  1  1   0  0 12  4 10     0
DMPlexDistData         2 1.0 9.8079e-0161.7 0.00e+00 0.0 2.9e+03 9.6e+03 6.0e+00  3  0  3  1  1   6  0 20  4  5     0
DMPlexStratify         6 1.5 5.6268e-0115.8 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
SFSetGraph            51 1.0 8.5973e-02 1.3 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   1  0  0  0  0     0
SFBcastBegin          95 1.0 1.1731e+00 3.9 0.00e+00 0.0 1.4e+04 5.0e+04 4.1e+01  3  0 12 21  4   7  0 95 97 33     0
SFBcastEnd            95 1.0 2.9754e-01 5.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  1  0  0  0  0   2  0  0  0  0     0
SFReduceBegin          4 1.0 7.7155e-0312.1 0.00e+00 0.0 5.0e+02 3.0e+04 3.0e+00  0  0  0  0  0   0  0  3  2  2     0
SFReduceEnd            4 1.0 8.9478e-03 4.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
SFFetchOpBegin         1 1.0 4.9114e-0517.2 0.00e+00 0.0 5.4e+01 3.9e+03 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
SFFetchOpEnd           1 1.0 1.9598e-04 3.1 0.00e+00 0.0 5.4e+01 3.9e+03 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
BuildTwoSided         17 1.0 3.8493e-03 8.3 0.00e+00 0.0 4.7e+02 4.0e+00 1.7e+01  0  0  0  0  2   0  0  0  0  2     0
BuildTwoSidedF        12 1.0 3.8695e-04 1.4 0.00e+00 0.0 0.0e+00 0.0e+00 1.2e+01  0  0  0  0  1   0  0  0  0  1     0
VecMDot               96 1.0 4.4748e-02 3.3 2.61e+07 1.0 0.0e+00 0.0e+00 9.6e+01  0  0  0  0  9   0  0  0  0 10  9234
VecNorm              105 1.0 6.0410e-03 1.4 3.73e+06 1.0 0.0e+00 0.0e+00 1.0e+02  0  0  0  0 10   0  0  0  0 11  9757
VecScale             217 1.0 3.4852e-03 1.1 4.99e+06 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0 22716
VecCopy               77 1.0 9.4819e-04 1.1 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecSet               596 1.0 9.9552e-03 1.1 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecAXPY                9 1.0 1.9503e-04 1.1 2.58e+05 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0 20979
VecAYPX              544 1.0 5.8689e-03 1.2 4.72e+06 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0 12804
VecAXPBYCZ           272 1.0 3.8891e-03 1.2 9.44e+06 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0 38645
VecMAXPY             105 1.0 1.0443e-02 1.1 2.96e+07 1.0 0.0e+00 0.0e+00 0.0e+00  0  1  0  0  0   0  1  0  0  0 44820
VecAssemblyBegin      14 1.0 4.9472e-04 1.3 0.00e+00 0.0 0.0e+00 0.0e+00 1.2e+01  0  0  0  0  1   0  0  0  0  1     0
VecAssemblyEnd        14 1.0 6.8665e-05 1.5 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecPointwiseMult      44 1.0 5.2500e-04 1.2 3.05e+05 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0  9262
VecScatterBegin      988 1.0 2.9767e-02 1.3 0.00e+00 0.0 8.6e+04 3.5e+03 0.0e+00  0  0 73  9  0   0  0 84 11  0     0
VecScatterEnd        988 1.0 2.4255e-01 8.9 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   1  0  0  0  0     0
VecSetRandom           4 1.0 1.1868e-03 1.1 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecNormalize         105 1.0 8.3659e-03 1.3 5.59e+06 1.0 0.0e+00 0.0e+00 1.0e+02  0  0  0  0 10   0  0  0  0 11 10569
MatMult              521 1.0 9.2801e-01 1.1 1.15e+09 1.3 7.1e+04 3.9e+03 1.3e+02  3 19 61  8 12   5 19 70 11 14 17559
MatMultAdd           227 1.0 8.0478e-02 1.5 5.58e+07 1.1 9.7e+03 1.8e+03 0.0e+00  0  1  8  1  0   0  1  9  1  0 10703
MatMultTranspose      68 1.0 4.1057e-02 1.5 3.17e+07 1.2 6.3e+03 9.3e+02 0.0e+00  0  1  5  0  0   0  1  6  0  0 11713
MatSolve             129 1.2 1.0344e-01 1.1 7.01e+07 1.1 0.0e+00 0.0e+00 0.0e+00  0  1  0  0  0   1  1  0  0  0 10602
MatSOR               452 1.0 5.2970e-01 1.1 5.58e+08 1.1 0.0e+00 0.0e+00 0.0e+00  2 10  0  0  0   3 10  0  0  0 15905
MatLUFactorSym         1 1.0 3.1948e-05 3.6 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatLUFactorNum         2 1.0 4.5488e-03 1.1 1.17e+06 1.1 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0  3964
MatILUFactorSym        1 1.0 1.7991e-03 1.1 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatConvert             5 1.0 3.1865e-02 1.7 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatScale              14 1.0 1.8671e-02 1.2 1.09e+07 1.3 5.5e+02 4.0e+03 0.0e+00  0  0  0  0  0   0  0  1  0  0  8353
MatResidual           68 1.0 1.1264e-01 1.1 1.48e+08 1.3 9.4e+03 4.0e+03 0.0e+00  0  2  8  1  0   1  2  9  1  0 18463
MatAssemblyBegin      93 1.0 1.7310e+00 6.5 0.00e+00 0.0 2.3e+03 5.8e+05 5.8e+01  3  0  2 40  5   5  0  2 51  6     0
MatAssemblyEnd        93 1.0 1.6349e+00 1.3 0.00e+00 0.0 4.9e+03 4.9e+02 2.2e+02  5  0  4  0 20   9  0  5  0 23     0
MatGetRow         131316 1.0 5.1258e-01 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  2  0  0  0  0   3  0  0  0  0     0
MatGetRowIJ            2 2.0 9.0599e-06 4.8 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatGetSubMatrix        8 1.0 8.2927e-03 1.0 0.00e+00 0.0 2.4e+02 2.6e+03 7.4e+01  0  0  0  0  7   0  0  0  0  8     0
MatGetOrdering         2 2.0 2.1505e-04 1.2 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatCoarsen             4 1.0 5.2981e-03 1.6 0.00e+00 0.0 2.9e+03 9.7e+02 2.0e+01  0  0  2  0  2   0  0  3  0  2     0
MatZeroEntries         4 1.0 1.5755e-02 3.1 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatAXPY                5 1.0 6.0479e-01 1.0 0.00e+00 0.0 2.2e+02 6.2e+02 2.0e+01  2  0  0  0  2   3  0  0  0  2     0
MatMatMult             5 1.0 3.3290e-01 1.0 9.34e+06 1.3 3.7e+03 2.0e+03 8.0e+01  1  0  3  0  7   2  0  4  0  8   397
MatMatMultSym          5 1.0 3.0637e-01 1.0 0.00e+00 0.0 3.1e+03 1.6e+03 7.0e+01  1  0  3  0  7   2  0  3  0  7     0
MatMatMultNum          5 1.0 2.6513e-02 1.0 9.34e+06 1.3 6.0e+02 4.1e+03 1.0e+01  0  0  1  0  1   0  0  1  0  1  4987
MatPtAP                4 1.0 1.3960e+01 1.0 4.49e+09 1.7 6.4e+03 3.6e+05 6.8e+01 44 67  5 68  6  80 67  6 87  7  4228
MatPtAPSymbolic        4 1.0 8.5832e+00 1.0 0.00e+00 0.0 3.3e+03 2.9e+05 2.8e+01 27  0  3 28  3  49  0  3 36  3     0
MatPtAPNumeric         4 1.0 5.3769e+00 1.0 4.49e+09 1.7 3.0e+03 4.4e+05 4.0e+01 17 67  3 40  4  31 67  3 51  4 10978
MatTrnMatMult          1 1.0 3.8761e-02 1.0 1.22e+06 1.0 6.5e+02 4.0e+03 1.9e+01  0  0  1  0  2   0  0  1  0  2   495
MatTrnMatMultSym       1 1.0 2.4785e-02 1.0 0.00e+00 0.0 5.4e+02 2.3e+03 1.7e+01  0  0  0  0  2   0  0  1  0  2     0
MatTrnMatMultNum       1 1.0 1.3965e-02 1.0 1.22e+06 1.0 1.1e+02 1.3e+04 2.0e+00  0  0  0  0  0   0  0  0  0  0  1374
MatGetLocalMat        16 1.0 1.1930e-02 1.3 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatGetBrAoCol         14 1.0 9.5529e-02 1.3 0.00e+00 0.0 4.1e+03 1.5e+05 0.0e+00  0  0  3 19  0   1  0  4 24  0     0
PCGAMGGraph_AGG        4 1.0 5.0889e-01 1.0 8.72e+06 1.3 1.3e+03 1.9e+03 4.8e+01  2  0  1  0  4   3  0  1  0  5   240
PCGAMGCoarse_AGG       4 1.0 5.0001e-02 1.0 1.22e+06 1.0 4.1e+03 1.9e+03 4.7e+01  0  0  3  0  4   0  0  4  0  5   384
PCGAMGProl_AGG         4 1.0 1.1742e-02 1.0 0.00e+00 0.0 1.8e+03 1.0e+03 8.0e+01  0  0  2  0  7   0  0  2  0  8     0
PCGAMGPOpt_AGG         4 1.0 6.1055e-01 1.0 1.05e+08 1.3 8.8e+03 3.2e+03 1.9e+02  2  2  8  1 17   4  2  9  1 20  2450
GAMG: createProl       4 1.0 1.1821e+00 1.0 1.15e+08 1.3 1.6e+04 2.5e+03 3.6e+02  4  2 14  1 34   7  2 16  2 38  1385
  Graph                8 1.0 5.0667e-01 1.0 8.72e+06 1.3 1.3e+03 1.9e+03 4.8e+01  2  0  1  0  4   3  0  1  0  5   241
  MIS/Agg              4 1.0 5.3558e-03 1.6 0.00e+00 0.0 2.9e+03 9.7e+02 2.0e+01  0  0  2  0  2   0  0  3  0  2     0
  SA: col data         4 1.0 2.2843e-03 1.0 0.00e+00 0.0 7.2e+02 2.3e+03 2.4e+01  0  0  1  0  2   0  0  1  0  3     0
  SA: frmProl0         4 1.0 8.7664e-03 1.0 0.00e+00 0.0 1.1e+03 2.3e+02 4.0e+01  0  0  1  0  4   0  0  1  0  4     0
  SA: smooth           4 1.0 6.1054e-01 1.0 1.05e+08 1.3 8.8e+03 3.2e+03 1.9e+02  2  2  8  1 17   4  2  9  1 20  2450
GAMG: partLevel        4 1.0 1.3967e+01 1.0 4.49e+09 1.7 6.6e+03 3.5e+05 1.7e+02 44 67  6 68 16  81 67  6 87 18  4226
  repartition          2 1.0 2.9707e-04 1.2 0.00e+00 0.0 0.0e+00 0.0e+00 1.2e+01  0  0  0  0  1   0  0  0  0  1     0
  Invert-Sort          2 1.0 1.8883e-04 1.2 0.00e+00 0.0 0.0e+00 0.0e+00 8.0e+00  0  0  0  0  1   0  0  0  0  1     0
  Move A               2 1.0 1.3578e-03 1.0 0.00e+00 0.0 1.1e+02 5.3e+03 3.6e+01  0  0  0  0  3   0  0  0  0  4     0
  Move P               2 1.0 4.5681e-03 1.0 0.00e+00 0.0 1.3e+02 1.1e+02 3.6e+01  0  0  0  0  3   0  0  0  0  4     0
PCSetUp                5 1.0 1.5573e+01 1.0 4.60e+09 1.7 2.3e+04 1.0e+05 6.2e+02 49 69 20 70 58  90 69 23 89 65  3898
PCSetUpOnBlocks      129 1.0 6.7956e-03 1.1 1.17e+06 1.1 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0  2654
PCApply               17 1.0 1.6612e+01 1.0 6.21e+09 1.5 9.8e+04 2.7e+04 6.5e+02 52 98 83 77 60  96 98 95 98 68  5138
KSPGMRESOrthog        96 1.0 5.4426e-02 2.4 5.23e+07 1.0 0.0e+00 0.0e+00 9.6e+01  0  1  0  0  9   0  1  0  0 10 15184
KSPSetUp              18 1.0 1.6465e-03 1.9 0.00e+00 0.0 0.0e+00 0.0e+00 8.0e+00  0  0  0  0  1   0  0  0  0  1     0
KSPSolve               1 1.0 1.7078e+01 1.0 6.28e+09 1.5 1.0e+05 2.6e+04 8.7e+02 54 99 87 78 81  98 99 99 99 92  5059
SFSetGraph             4 1.0 2.7418e-04 2.7 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
SFBcastBegin          25 1.0 4.1673e-03 4.9 0.00e+00 0.0 3.2e+03 1.3e+03 5.0e+00  0  0  3  0  0   0  0  3  0  1     0
SFBcastEnd            25 1.0 6.3801e-04 2.7 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
              Viewer     1              0            0     0.
           Index Set   125            132     25606724     0.
   IS L to G Mapping     3              3     15014432     0.
              Vector    15            141     26937184     0.
      Vector Scatter     2             15      1720344     0.
              Matrix     0             52     71903496     0.
           Index Set   102             88       239952     0.
              Vector   356            218      7355832     0.
      Vector Scatter    40             21        23096     0.
              Matrix   145             80    132079708     0.
Average time for MPI_Barrier(): 5.38826e-06
Average time for zero size MPI_Send(): 1.68383e-06
-log_summary
 gamg 40 1
Discretization: RT
MPI processes 24: solving...
((47407, 1161600), (47407, 1161600))
	Solver time: 1.005248e+01
Darcy_FE.py on a arch-linux2-c-opt named wf153.localdomain with 24 processors, by jychang48 Wed Mar  2 18:01:20 2016
Time (sec):           2.430e+01      1.00050   2.430e+01
Objects:              1.042e+03      1.07202   9.828e+02
Flops:                3.581e+09      1.56180   2.922e+09  7.012e+10
Flops/sec:            1.474e+08      1.56148   1.202e+08  2.886e+09
MPI Messages:         1.260e+04      1.77245   9.542e+03  2.290e+05
MPI Message Lengths:  3.024e+08      3.27966   1.567e+04  3.589e+09
 0:      Main Stage: 1.4244e+01  58.6%  0.0000e+00   0.0%  2.618e+04  11.4%  3.318e+03       21.2%  1.250e+02  11.6%
 1:             FEM: 1.0052e+01  41.4%  7.0118e+10 100.0%  2.028e+05  88.6%  1.235e+04       78.8%  9.500e+02  88.3%
Phase summary info:
BuildTwoSided         44 1.0 1.1165e+00 9.7 0.00e+00 0.0 6.2e+03 4.0e+00 4.4e+01  4  0  3  0  4   7  0 24  0 35     0
VecScatterBegin        2 1.0 6.1035e-05 2.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecScatterEnd          2 1.0 1.0014e-0510.5 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
Mesh Partition         2 1.0 1.9826e+00 1.1 0.00e+00 0.0 8.7e+03 7.7e+03 2.1e+01  8  0  4  2  2  14  0 33  9 17     0
Mesh Migration         2 1.0 4.5927e-01 1.0 0.00e+00 0.0 1.5e+04 4.0e+04 5.4e+01  2  0  7 17  5   3  0 58 81 43     0
DMPlexInterp           1 1.0 2.1183e+0057320.8 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   1  0  0  0  0     0
DMPlexDistribute       1 1.0 2.1988e+00 1.1 0.00e+00 0.0 5.7e+03 5.7e+04 2.5e+01  9  0  2  9  2  15  0 22 43 20     0
DMPlexDistCones        2 1.0 1.0621e-01 1.1 0.00e+00 0.0 2.2e+03 9.3e+04 4.0e+00  0  0  1  6  0   1  0  8 27  3     0
DMPlexDistLabels       2 1.0 2.8685e-01 1.0 0.00e+00 0.0 9.3e+03 3.7e+04 2.2e+01  1  0  4 10  2   2  0 35 46 18     0
DMPlexDistribOL        1 1.0 2.6254e-01 1.0 0.00e+00 0.0 1.8e+04 2.2e+04 5.0e+01  1  0  8 11  5   2  0 70 53 40     0
DMPlexDistField        3 1.0 2.6364e-02 1.8 0.00e+00 0.0 3.0e+03 9.4e+03 1.2e+01  0  0  1  1  1   0  0 11  4 10     0
DMPlexDistData         2 1.0 9.9430e-0127.9 0.00e+00 0.0 6.0e+03 5.0e+03 6.0e+00  4  0  3  1  1   6  0 23  4  5     0
DMPlexStratify         6 1.5 5.5264e-0122.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
SFSetGraph            51 1.0 6.1109e-02 1.3 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
SFBcastBegin          95 1.0 1.1261e+00 4.0 0.00e+00 0.0 2.5e+04 2.9e+04 4.1e+01  4  0 11 20  4   7  0 96 97 33     0
SFBcastEnd            95 1.0 2.9690e-01 5.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  1  0  0  0  0   2  0  0  0  0     0
SFReduceBegin          4 1.0 7.7369e-0312.0 0.00e+00 0.0 8.7e+02 1.8e+04 3.0e+00  0  0  0  0  0   0  0  3  2  2     0
SFReduceEnd            4 1.0 8.3060e-03 4.6 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
SFFetchOpBegin         1 1.0 4.6968e-0521.9 0.00e+00 0.0 9.4e+01 2.8e+03 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
SFFetchOpEnd           1 1.0 1.3208e-04 3.2 0.00e+00 0.0 9.4e+01 2.8e+03 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
BuildTwoSided         17 1.0 3.1033e-03 5.2 0.00e+00 0.0 8.3e+02 4.0e+00 1.7e+01  0  0  0  0  2   0  0  0  0  2     0
BuildTwoSidedF        12 1.0 4.2391e-04 1.4 0.00e+00 0.0 0.0e+00 0.0e+00 1.2e+01  0  0  0  0  1   0  0  0  0  1     0
VecMDot               96 1.0 3.3720e-02 3.3 1.75e+07 1.0 0.0e+00 0.0e+00 9.6e+01  0  1  0  0  9   0  1  0  0 10 12253
VecNorm              105 1.0 4.9245e-03 1.4 2.49e+06 1.0 0.0e+00 0.0e+00 1.0e+02  0  0  0  0 10   0  0  0  0 11 11969
VecScale             217 1.0 2.3873e-03 1.1 3.33e+06 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0 33163
VecCopy               77 1.0 7.2002e-04 1.1 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecSet               596 1.0 6.5861e-03 1.1 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecAXPY                9 1.0 1.4710e-04 1.2 1.73e+05 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0 27810
VecAYPX              544 1.0 3.7701e-03 1.1 3.16e+06 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0 19928
VecAXPBYCZ           272 1.0 2.6333e-03 1.2 6.31e+06 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0 57063
VecMAXPY             105 1.0 5.9943e-03 1.2 1.98e+07 1.0 0.0e+00 0.0e+00 0.0e+00  0  1  0  0  0   0  1  0  0  0 78080
VecAssemblyBegin      14 1.0 5.3096e-04 1.2 0.00e+00 0.0 0.0e+00 0.0e+00 1.2e+01  0  0  0  0  1   0  0  0  0  1     0
VecAssemblyEnd        14 1.0 6.6996e-05 1.6 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecPointwiseMult      44 1.0 3.2210e-04 1.2 2.04e+05 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0 15093
VecScatterBegin      988 1.0 3.2264e-02 1.4 0.00e+00 0.0 1.7e+05 2.3e+03 0.0e+00  0  0 74 11  0   0  0 84 14  0     0
VecScatterEnd        988 1.0 1.3531e-01 5.7 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   1  0  0  0  0     0
VecSetRandom           4 1.0 8.0204e-04 1.1 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecNormalize         105 1.0 6.9528e-03 1.2 3.74e+06 1.0 0.0e+00 0.0e+00 1.0e+02  0  0  0  0 10   0  0  0  0 11 12716
MatMult              521 1.0 6.0050e-01 1.1 7.20e+08 1.3 1.4e+05 2.6e+03 1.3e+02  2 22 63 10 12   6 22 71 13 14 25122
MatMultAdd           227 1.0 6.2568e-02 1.7 3.48e+07 1.1 1.7e+04 1.2e+03 0.0e+00  0  1  8  1  0   1  1  9  1  0 12729
MatMultTranspose      68 1.0 3.3125e-02 2.0 1.88e+07 1.2 1.1e+04 6.3e+02 0.0e+00  0  1  5  0  0   0  1  6  0  0 12559
MatSolve             129 1.2 7.0106e-02 1.1 4.68e+07 1.1 0.0e+00 0.0e+00 0.0e+00  0  2  0  0  0   1  2  0  0  0 15570
MatSOR               452 1.0 3.2208e-01 1.1 3.43e+08 1.2 0.0e+00 0.0e+00 0.0e+00  1 11  0  0  0   3 11  0  0  0 23760
MatLUFactorSym         1 1.0 2.0027e-05 2.2 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatLUFactorNum         2 1.0 2.9938e-03 1.1 7.77e+05 1.1 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0  6005
MatILUFactorSym        1 1.0 1.2600e-03 1.1 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatConvert             5 1.0 2.0496e-02 2.6 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatScale              14 1.0 1.1414e-02 1.3 6.76e+06 1.2 1.1e+03 2.6e+03 0.0e+00  0  0  0  0  0   0  0  1  0  0 12464
MatResidual           68 1.0 7.3167e-02 1.1 9.23e+07 1.3 1.9e+04 2.6e+03 0.0e+00  0  3  8  1  0   1  3  9  2  0 26129
MatAssemblyBegin      93 1.0 1.0436e+00 7.0 0.00e+00 0.0 4.5e+03 3.0e+05 5.8e+01  3  0  2 38  5   6  0  2 48  6     0
MatAssemblyEnd        93 1.0 1.0572e+00 1.1 0.00e+00 0.0 9.3e+03 3.2e+02 2.2e+02  4  0  4  0 20  10  0  5  0 23     0
MatGetRow          87698 1.0 3.4188e-01 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  1  0  0  0  0   3  0  0  0  0     0
MatGetRowIJ            2 2.0 7.8678e-06 8.2 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatGetSubMatrix        8 1.0 6.2807e-03 1.0 0.00e+00 0.0 3.4e+02 1.7e+03 7.4e+01  0  0  0  0  7   0  0  0  0  8     0
MatGetOrdering         2 2.0 1.7095e-04 1.3 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatCoarsen             4 1.0 3.9628e-03 1.5 0.00e+00 0.0 5.1e+03 7.0e+02 2.0e+01  0  0  2  0  2   0  0  2  0  2     0
MatZeroEntries         4 1.0 1.0336e-02 4.2 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatAXPY                5 1.0 4.0474e-01 1.0 0.00e+00 0.0 3.7e+02 4.4e+02 2.0e+01  2  0  0  0  2   4  0  0  0  2     0
MatMatMult             5 1.0 1.8609e-01 1.0 5.84e+06 1.3 7.5e+03 1.3e+03 8.0e+01  1  0  3  0  7   2  0  4  0  8   657
MatMatMultSym          5 1.0 1.6933e-01 1.0 0.00e+00 0.0 6.3e+03 1.1e+03 7.0e+01  1  0  3  0  7   2  0  3  0  7     0
MatMatMultNum          5 1.0 1.6730e-02 1.0 5.84e+06 1.3 1.2e+03 2.6e+03 1.0e+01  0  0  1  0  1   0  0  1  0  1  7314
MatPtAP                4 1.0 7.8254e+00 1.0 2.42e+09 1.9 1.3e+04 1.8e+05 6.8e+01 32 62  6 67  6  78 62  6 84  7  5593
MatPtAPSymbolic        4 1.0 4.7722e+00 1.0 0.00e+00 0.0 6.8e+03 1.5e+05 2.8e+01 20  0  3 29  3  47  0  3 37  3     0
MatPtAPNumeric         4 1.0 3.0532e+00 1.0 2.42e+09 1.9 6.4e+03 2.1e+05 4.0e+01 13 62  3 38  4  30 62  3 48  4 14334
MatTrnMatMult          1 1.0 2.6716e-02 1.0 8.18e+05 1.0 1.1e+03 2.8e+03 1.9e+01  0  0  0  0  2   0  0  1  0  2   721
MatTrnMatMultSym       1 1.0 1.7252e-02 1.0 0.00e+00 0.0 9.4e+02 1.6e+03 1.7e+01  0  0  0  0  2   0  0  0  0  2     0
MatTrnMatMultNum       1 1.0 9.4512e-03 1.0 8.18e+05 1.0 1.9e+02 8.9e+03 2.0e+00  0  0  0  0  0   0  0  0  0  0  2039
MatGetLocalMat        16 1.0 7.0903e-03 1.2 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatGetBrAoCol         14 1.0 8.4786e-02 1.2 0.00e+00 0.0 8.2e+03 8.7e+04 0.0e+00  0  0  4 20  0   1  0  4 25  0     0
PCGAMGGraph_AGG        4 1.0 3.3958e-01 1.0 5.43e+06 1.3 2.4e+03 1.4e+03 4.8e+01  1  0  1  0  4   3  0  1  0  5   331
PCGAMGCoarse_AGG       4 1.0 3.4880e-02 1.0 8.18e+05 1.0 7.1e+03 1.4e+03 4.7e+01  0  0  3  0  4   0  0  4  0  5   552
PCGAMGProl_AGG         4 1.0 1.0176e-02 1.0 0.00e+00 0.0 3.0e+03 7.7e+02 8.0e+01  0  0  1  0  7   0  0  2  0  8     0
PCGAMGPOpt_AGG         4 1.0 3.7025e-01 1.0 6.59e+07 1.3 1.8e+04 2.1e+03 1.9e+02  2  2  8  1 17   4  2  9  1 20  3737
GAMG: createProl       4 1.0 7.5580e-01 1.0 7.22e+07 1.3 3.1e+04 1.7e+03 3.6e+02  3  2 13  1 34   8  2 15  2 38  2005
  Graph                8 1.0 3.3810e-01 1.0 5.43e+06 1.3 2.4e+03 1.4e+03 4.8e+01  1  0  1  0  4   3  0  1  0  5   333
  MIS/Agg              4 1.0 4.0288e-03 1.5 0.00e+00 0.0 5.1e+03 7.0e+02 2.0e+01  0  0  2  0  2   0  0  2  0  2     0
  SA: col data         4 1.0 1.8752e-03 1.0 0.00e+00 0.0 1.3e+03 1.6e+03 2.4e+01  0  0  1  0  2   0  0  1  0  3     0
  SA: frmProl0         4 1.0 7.7009e-03 1.0 0.00e+00 0.0 1.8e+03 1.7e+02 4.0e+01  0  0  1  0  4   0  0  1  0  4     0
  SA: smooth           4 1.0 3.7022e-01 1.0 6.59e+07 1.3 1.8e+04 2.1e+03 1.9e+02  2  2  8  1 17   4  2  9  1 20  3737
GAMG: partLevel        4 1.0 7.8308e+00 1.0 2.42e+09 1.9 1.4e+04 1.8e+05 1.7e+02 32 62  6 67 16  78 62  7 85 18  5589
  repartition          2 1.0 2.1386e-04 1.1 0.00e+00 0.0 0.0e+00 0.0e+00 1.2e+01  0  0  0  0  1   0  0  0  0  1     0
  Invert-Sort          2 1.0 2.1815e-04 1.1 0.00e+00 0.0 0.0e+00 0.0e+00 8.0e+00  0  0  0  0  1   0  0  0  0  1     0
  Move A               2 1.0 1.4272e-03 1.0 0.00e+00 0.0 1.5e+02 3.7e+03 3.6e+01  0  0  0  0  3   0  0  0  0  4     0
  Move P               2 1.0 3.1939e-03 1.0 0.00e+00 0.0 1.9e+02 1.1e+02 3.6e+01  0  0  0  0  3   0  0  0  0  4     0
PCSetUp                5 1.0 8.8722e+00 1.0 2.49e+09 1.9 4.5e+04 5.4e+04 6.2e+02 37 65 20 68 58  88 65 22 87 65  5107
PCSetUpOnBlocks      129 1.0 4.6492e-03 1.1 7.77e+05 1.1 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0  3867
PCApply               17 1.0 9.5174e+00 1.0 3.49e+09 1.6 1.9e+05 1.4e+04 6.5e+02 39 97 85 78 60  95 97 96 98 68  7139
KSPGMRESOrthog        96 1.0 3.9721e-02 2.6 3.50e+07 1.0 0.0e+00 0.0e+00 9.6e+01  0  1  0  0  9   0  1  0  0 10 20804
KSPSetUp              18 1.0 1.1928e-03 1.8 0.00e+00 0.0 0.0e+00 0.0e+00 8.0e+00  0  0  0  0  1   0  0  0  0  1     0
KSPSolve               1 1.0 9.8317e+00 1.0 3.53e+09 1.6 2.0e+05 1.4e+04 8.7e+02 40 98 88 78 81  98 98 99 99 92  7018
SFSetGraph             4 1.0 2.1601e-04 2.6 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
SFBcastBegin          25 1.0 3.2976e-03 3.6 0.00e+00 0.0 5.6e+03 9.2e+02 5.0e+00  0  0  2  0  0   0  0  3  0  1     0
SFBcastEnd            25 1.0 1.0622e-03 4.1 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
--- Event Stage 0: Main Stage
              Viewer     1              0            0     0.
           Index Set   139            146     24070156     0.
   IS L to G Mapping     3              3     14448024     0.
              Vector    15            141     19734088     0.
      Vector Scatter     2             15      1154208     0.
              Matrix     0             52     42870916     0.
--- Event Stage 1: FEM
           Index Set   102             88       195904     0.
              Vector   356            218      5052384     0.
      Vector Scatter    40             21        23080     0.
              Matrix   145             80     79765836     0.
Average time for MPI_Barrier(): 1.71661e-05
Average time for zero size MPI_Send(): 1.41064e-06
-log_summary
 gamg 40 1
Discretization: RT
MPI processes 32: solving...
((35155, 1161600), (35155, 1161600))
	Solver time: 6.467208e+00
***             WIDEN YOUR WINDOW TO 120 CHARACTERS.  Use 'enscript -r -fCourier9' to print this document            ***
---------------------------------------------- PETSc Performance Summary: ----------------------------------------------
Darcy_FE.py on a arch-linux2-c-opt named wf153.localdomain with 32 processors, by jychang48 Wed Mar  2 18:01:44 2016
Using Petsc Development GIT revision: v3.6.3-1924-ge972cd5  GIT Date: 2016-01-01 10:01:13 -0600
                         Max       Max/Min        Avg      Total
Time (sec):           2.074e+01      1.00048   2.074e+01
Objects:              1.068e+03      1.09877   9.844e+02
Flops:                2.198e+09      1.49553   1.837e+09  5.879e+10
Flops/sec:            1.060e+08      1.49497   8.860e+07  2.835e+09
MPI Messages:         1.553e+04      1.84528   1.145e+04  3.664e+05
MPI Message Lengths:  2.863e+08      4.24531   9.989e+03  3.660e+09
MPI Reductions:       1.078e+03      1.00000
Flop counting convention: 1 flop = 1 real number operation of type (multiply/divide/add/subtract)
                            e.g., VecAXPY() for real vectors of length N --> 2N flops
                            and VecAXPY() for complex vectors of length N --> 8N flops
Summary of Stages:   ----- Time ------  ----- Flops -----  --- Messages ---  -- Message Lengths --  -- Reductions --
                        Avg     %Total     Avg     %Total   counts   %Total     Avg         %Total   counts   %Total
 0:      Main Stage: 1.4269e+01  68.8%  0.0000e+00   0.0%  3.925e+04  10.7%  2.153e+03       21.5%  1.250e+02  11.6%
 1:             FEM: 6.4673e+00  31.2%  5.8792e+10 100.0%  3.271e+05  89.3%  7.837e+03       78.5%  9.520e+02  88.3%
See the 'Profiling' chapter of the users' manual for details on interpreting output.
Phase summary info:
   Count: number of times phase was executed
   Time and Flops: Max - maximum over all processors
                   Ratio - ratio of maximum to minimum over all processors
   Mess: number of messages sent
   Avg. len: average message length (bytes)
   Reduct: number of global reductions
   Global: entire computation
   Stage: stages of a computation. Set stages with PetscLogStagePush() and PetscLogStagePop().
      %T - percent time in this phase         %F - percent flops in this phase
      %M - percent messages in this phase     %L - percent message lengths in this phase
      %R - percent reductions in this phase
   Total Mflop/s: 10e-6 * (sum of flops over all processors)/(max time over all processors)
Event                Count      Time (sec)     Flops                             --- Global ---  --- Stage ---   Total
                   Max Ratio  Max     Ratio   Max  Ratio  Mess   Avg len Reduct  %T %F %M %L %R  %T %F %M %L %R Mflop/s
BuildTwoSided         44 1.0 1.1607e+0012.7 0.00e+00 0.0 9.3e+03 4.0e+00 4.4e+01  5  0  3  0  4   7  0 24  0 35     0
VecScatterBegin        2 1.0 4.7922e-05 2.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecScatterEnd          2 1.0 6.9141e-06 3.6 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
Mesh Partition         2 1.0 2.0361e+00 1.1 0.00e+00 0.0 1.4e+04 5.1e+03 2.1e+01 10  0  4  2  2  14  0 36  9 17     0
Mesh Migration         2 1.0 4.3835e-01 1.0 0.00e+00 0.0 2.2e+04 2.9e+04 5.4e+01  2  0  6 17  5   3  0 56 80 43     0
DMPlexInterp           1 1.0 2.1146e+0064271.4 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
DMPlexDistribute       1 1.0 2.2676e+00 1.1 0.00e+00 0.0 9.4e+03 3.5e+04 2.5e+01 11  0  3  9  2  16  0 24 41 20     0
DMPlexDistCones        2 1.0 1.0199e-01 1.1 0.00e+00 0.0 3.2e+03 6.6e+04 4.0e+00  0  0  1  6  0   1  0  8 27  3     0
DMPlexDistLabels       2 1.0 2.7904e-01 1.0 0.00e+00 0.0 1.3e+04 2.7e+04 2.2e+01  1  0  4 10  2   2  0 34 45 18     0
DMPlexDistribOL        1 1.0 2.2615e-01 1.0 0.00e+00 0.0 2.7e+04 1.6e+04 5.0e+01  1  0  7 12  5   2  0 68 54 40     0
DMPlexDistField        3 1.0 3.1294e-02 2.0 0.00e+00 0.0 4.3e+03 6.8e+03 1.2e+01  0  0  1  1  1   0  0 11  4 10     0
DMPlexDistData         2 1.0 9.9918e-0173.6 0.00e+00 0.0 1.0e+04 3.2e+03 6.0e+00  5  0  3  1  1   7  0 26  4  5     0
DMPlexStratify         6 1.5 5.4843e-0129.4 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
SFSetGraph            51 1.0 5.1525e-02 1.5 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
SFBcastBegin          95 1.0 1.1663e+00 4.4 0.00e+00 0.0 3.8e+04 2.0e+04 4.1e+01  5  0 10 21  4   7  0 96 97 33     0
SFBcastEnd            95 1.0 3.0130e-01 6.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  1  0  0  0  0   2  0  0  0  0     0
SFReduceBegin          4 1.0 8.7683e-0318.0 0.00e+00 0.0 1.3e+03 1.3e+04 3.0e+00  0  0  0  0  0   0  0  3  2  2     0
SFReduceEnd            4 1.0 8.8024e-03 5.7 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
SFFetchOpBegin         1 1.0 3.8862e-0512.5 0.00e+00 0.0 1.4e+02 2.2e+03 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
SFFetchOpEnd           1 1.0 1.3995e-04 3.2 0.00e+00 0.0 1.4e+02 2.2e+03 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
BuildTwoSided         17 1.0 1.9822e-03 2.9 0.00e+00 0.0 1.2e+03 4.0e+00 1.7e+01  0  0  0  0  2   0  0  0  0  2     0
BuildTwoSidedF        12 1.0 4.4608e-04 1.5 0.00e+00 0.0 0.0e+00 0.0e+00 1.2e+01  0  0  0  0  1   0  0  0  0  1     0
VecMDot               96 1.0 3.1041e-02 3.4 1.32e+07 1.0 0.0e+00 0.0e+00 9.6e+01  0  1  0  0  9   0  1  0  0 10 13312
VecNorm              105 1.0 5.3015e-03 1.5 1.87e+06 1.0 0.0e+00 0.0e+00 1.0e+02  0  0  0  0 10   0  0  0  0 11 11119
VecScale             217 1.0 1.9186e-03 1.1 2.50e+06 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0 41267
VecCopy               77 1.0 5.4383e-04 1.1 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecSet               596 1.0 4.6587e-03 1.1 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecAXPY                9 1.0 1.0824e-04 1.2 1.30e+05 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0 37802
VecAYPX              544 1.0 3.0854e-03 1.2 2.37e+06 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0 24362
VecAXPBYCZ           272 1.0 1.8950e-03 1.2 4.74e+06 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0 79333
VecMAXPY             105 1.0 4.1659e-03 1.2 1.49e+07 1.0 0.0e+00 0.0e+00 0.0e+00  0  1  0  0  0   0  1  0  0  0 112362
VecAssemblyBegin      14 1.0 5.6028e-04 1.3 0.00e+00 0.0 0.0e+00 0.0e+00 1.2e+01  0  0  0  0  1   0  0  0  0  1     0
VecAssemblyEnd        14 1.0 6.9141e-05 1.6 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecPointwiseMult      44 1.0 2.4009e-04 1.2 1.53e+05 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0 20258
VecScatterBegin      988 1.0 3.2709e-02 1.6 0.00e+00 0.0 2.8e+05 1.7e+03 0.0e+00  0  0 75 13  0   0  0 84 16  0     0
VecScatterEnd        988 1.0 1.0493e-01 3.8 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   1  0  0  0  0     0
VecSetRandom           4 1.0 5.8675e-04 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecNormalize         105 1.0 7.1294e-03 1.3 2.81e+06 1.0 0.0e+00 0.0e+00 1.0e+02  0  0  0  0 10   0  0  0  0 11 12403
MatMult              521 1.0 4.4204e-01 1.1 5.11e+08 1.3 2.4e+05 1.9e+03 1.3e+02  2 24 65 12 12   6 24 72 15 14 32017
MatMultAdd           227 1.0 5.3586e-02 1.9 2.44e+07 1.1 2.6e+04 9.6e+02 0.0e+00  0  1  7  1  0   1  1  8  1  0 14062
MatMultTranspose      68 1.0 2.3165e-02 1.9 1.23e+07 1.1 1.7e+04 4.9e+02 0.0e+00  0  1  5  0  0   0  1  5  0  0 16104
MatSolve             129 1.2 5.2656e-02 1.2 3.51e+07 1.1 0.0e+00 0.0e+00 0.0e+00  0  2  0  0  0   1  2  0  0  0 20642
MatSOR               452 1.0 2.2063e-01 1.1 2.33e+08 1.2 0.0e+00 0.0e+00 0.0e+00  1 12  0  0  0   3 12  0  0  0 32021
MatLUFactorSym         1 1.0 3.3855e-05 3.8 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatLUFactorNum         2 1.0 2.1760e-03 1.1 5.87e+05 1.1 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0  8254
MatILUFactorSym        1 1.0 9.6488e-04 1.2 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatConvert             5 1.0 1.2136e-02 2.1 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatScale              14 1.0 9.3570e-03 1.7 4.72e+06 1.3 1.8e+03 1.9e+03 0.0e+00  0  0  1  0  0   0  0  1  0  0 14120
MatResidual           68 1.0 5.2496e-02 1.2 6.51e+07 1.3 3.1e+04 1.9e+03 0.0e+00  0  3  9  2  0   1  3 10  2  0 33952
MatAssemblyBegin      93 1.0 5.5953e-01 4.5 0.00e+00 0.0 7.1e+03 1.8e+05 5.8e+01  2  0  2 36  5   5  0  2 45  6     0
MatAssemblyEnd        93 1.0 8.5411e-01 1.1 0.00e+00 0.0 1.5e+04 2.4e+02 2.2e+02  4  0  4  0 20  13  0  5  0 23     0
MatGetRow          65844 1.0 2.5644e-01 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  1  0  0  0  0   4  0  0  0  0     0
MatGetRowIJ            2 2.0 8.1062e-06 8.5 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatGetSubMatrix        8 1.0 5.0519e-03 1.0 0.00e+00 0.0 4.5e+02 1.2e+03 7.4e+01  0  0  0  0  7   0  0  0  0  8     0
MatGetOrdering         2 2.0 1.4186e-04 1.5 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatCoarsen             4 1.0 3.4940e-03 1.5 0.00e+00 0.0 8.3e+03 5.3e+02 2.2e+01  0  0  2  0  2   0  0  3  0  2     0
MatZeroEntries         4 1.0 7.4160e-03 4.2 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatAXPY                5 1.0 3.0466e-01 1.0 0.00e+00 0.0 5.4e+02 3.6e+02 2.0e+01  1  0  0  0  2   5  0  0  0  2     0
MatMatMult             5 1.0 1.1690e-01 1.0 4.14e+06 1.3 1.2e+04 9.7e+02 8.0e+01  1  0  3  0  7   2  0  4  0  8   982
MatMatMultSym          5 1.0 1.0482e-01 1.0 0.00e+00 0.0 1.0e+04 7.8e+02 7.0e+01  1  0  3  0  6   2  0  3  0  7     0
MatMatMultNum          5 1.0 1.2022e-02 1.0 4.14e+06 1.3 2.0e+03 1.9e+03 1.0e+01  0  0  1  0  1   0  0  1  0  1  9545
MatPtAP                4 1.0 4.8059e+00 1.0 1.35e+09 1.8 2.2e+04 1.1e+05 6.8e+01 23 58  6 64  6  74 58  7 82  7  7077
MatPtAPSymbolic        4 1.0 2.8555e+00 1.0 0.00e+00 0.0 1.1e+04 9.4e+04 2.8e+01 14  0  3 29  3  44  0  3 37  3     0
MatPtAPNumeric         4 1.0 1.9504e+00 1.0 1.35e+09 1.8 1.1e+04 1.2e+05 4.0e+01  9 58  3 36  4  30 58  3 45  4 17438
MatTrnMatMult          1 1.0 2.0930e-02 1.0 6.19e+05 1.1 1.6e+03 2.3e+03 1.9e+01  0  0  0  0  2   0  0  0  0  2   924
MatTrnMatMultSym       1 1.0 1.3424e-02 1.0 0.00e+00 0.0 1.4e+03 1.3e+03 1.7e+01  0  0  0  0  2   0  0  0  0  2     0
MatTrnMatMultNum       1 1.0 7.4990e-03 1.0 6.19e+05 1.1 2.7e+02 7.2e+03 2.0e+00  0  0  0  0  0   0  0  0  0  0  2579
MatGetLocalMat        16 1.0 4.7717e-03 1.1 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatGetBrAoCol         14 1.0 6.7384e-02 1.3 0.00e+00 0.0 1.3e+04 5.4e+04 0.0e+00  0  0  4 20  0   1  0  4 26  0     0
PCGAMGGraph_AGG        4 1.0 2.5093e-01 1.0 3.83e+06 1.3 3.7e+03 1.0e+03 4.8e+01  1  0  1  0  4   4  0  1  0  5   418
PCGAMGCoarse_AGG       4 1.0 2.7763e-02 1.0 6.19e+05 1.1 1.1e+04 1.0e+03 4.9e+01  0  0  3  0  5   0  0  3  0  5   697
PCGAMGProl_AGG         4 1.0 8.3046e-03 1.0 0.00e+00 0.0 4.4e+03 6.2e+02 8.0e+01  0  0  1  0  7   0  0  1  0  8     0
PCGAMGPOpt_AGG         4 1.0 2.5502e-01 1.0 4.67e+07 1.3 3.0e+04 1.5e+03 1.9e+02  1  2  8  1 17   4  2  9  2 20  5087
GAMG: createProl       4 1.0 5.4260e-01 1.0 5.11e+07 1.3 4.9e+04 1.3e+03 3.6e+02  3  2 13  2 34   8  2 15  2 38  2620
  Graph                8 1.0 2.4971e-01 1.0 3.83e+06 1.3 3.7e+03 1.0e+03 4.8e+01  1  0  1  0  4   4  0  1  0  5   420
  MIS/Agg              4 1.0 3.5570e-03 1.4 0.00e+00 0.0 8.3e+03 5.3e+02 2.2e+01  0  0  2  0  2   0  0  3  0  2     0
  SA: col data         4 1.0 1.6532e-03 1.1 0.00e+00 0.0 1.9e+03 1.3e+03 2.4e+01  0  0  1  0  2   0  0  1  0  3     0
  SA: frmProl0         4 1.0 6.1510e-03 1.0 0.00e+00 0.0 2.5e+03 1.4e+02 4.0e+01  0  0  1  0  4   0  0  1  0  4     0
  SA: smooth           4 1.0 2.5500e-01 1.0 4.67e+07 1.3 3.0e+04 1.5e+03 1.9e+02  1  2  8  1 17   4  2  9  2 20  5087
GAMG: partLevel        4 1.0 4.8109e+00 1.0 1.35e+09 1.8 2.2e+04 1.1e+05 1.7e+02 23 58  6 64 16  74 58  7 82 18  7070
  repartition          2 1.0 2.5296e-04 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 1.2e+01  0  0  0  0  1   0  0  0  0  1     0
  Invert-Sort          2 1.0 3.9124e-04 1.1 0.00e+00 0.0 0.0e+00 0.0e+00 8.0e+00  0  0  0  0  1   0  0  0  0  1     0
  Move A               2 1.0 1.4398e-03 1.0 0.00e+00 0.0 1.9e+02 2.6e+03 3.6e+01  0  0  0  0  3   0  0  0  0  4     0
  Move P               2 1.0 2.5690e-03 1.0 0.00e+00 0.0 2.5e+02 9.6e+01 3.6e+01  0  0  0  0  3   0  0  0  0  4     0
PCSetUp                5 1.0 5.5706e+00 1.0 1.41e+09 1.8 7.3e+04 3.3e+04 6.2e+02 27 60 20 66 58  86 60 22 85 66  6367
PCSetUpOnBlocks      129 1.0 3.5369e-03 1.1 5.87e+05 1.1 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0  5078
PCApply               17 1.0 6.0198e+00 1.0 2.13e+09 1.5 3.1e+05 9.0e+03 6.5e+02 29 96 86 77 60  93 96 96 98 68  9397
KSPGMRESOrthog        96 1.0 3.5287e-02 2.7 2.63e+07 1.0 0.0e+00 0.0e+00 9.6e+01  0  1  0  0  9   0  1  0  0 10 23420
KSPSetUp              18 1.0 1.0297e-03 1.5 0.00e+00 0.0 0.0e+00 0.0e+00 8.0e+00  0  0  0  0  1   0  0  0  0  1     0
KSPSolve               1 1.0 6.2599e+00 1.0 2.16e+09 1.5 3.2e+05 8.8e+03 8.7e+02 30 98 89 78 81  97 98 99 99 92  9205
SFSetGraph             4 1.0 2.0409e-04 2.6 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
SFBcastBegin          27 1.0 2.2466e-03 2.6 0.00e+00 0.0 9.1e+03 6.9e+02 5.0e+00  0  0  2  0  0   0  0  3  0  1     0
SFBcastEnd            27 1.0 5.7459e-04 2.8 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
Memory usage is given in bytes:
Object Type          Creations   Destructions     Memory  Descendants' Mem.
Reports information only for process 0.
           Container     6              3         1728     0.
              Viewer     1              0            0     0.
         PetscRandom     0              1          646     0.
           Index Set   165            172     23657268     0.
   IS L to G Mapping     3              3     14326164     0.
              Vector    15            141     16031216     0.
      Vector Scatter     2             15       860160     0.
              Matrix     0             52     30817568     0.
       Krylov Solver     0             15       151752     0.
         PetscRandom     1              0            0     0.
           Index Set   102             88       197036     0.
   IS L to G Mapping     4              0            0     0.
              Vector   356            218      3951520     0.
      Vector Scatter    40             21        23048     0.
              Matrix   145             80     57676072     0.
      Matrix Coarsen     4              4         2544     0.
Average time to get PetscTime(): 6.19888e-07
Average time for MPI_Barrier(): 6.96182e-06
Average time for zero size MPI_Send(): 1.65403e-06
#PETSc Option Table entries:
-log_summary
-solver_fieldsplit_0_ksp_type preonly
-solver_fieldsplit_0_pc_type bjacobi
-solver_fieldsplit_1_ksp_type preonly
-solver_fieldsplit_1_pc_type gamg
-solver_ksp_rtol 1e-7
-solver_ksp_type gmres
-solver_pc_fieldsplit_schur_fact_type upper
-solver_pc_fieldsplit_schur_precondition selfp
-solver_pc_fieldsplit_type schur
-solver_pc_type fieldsplit
#End of PETSc Option Table entries
Compiled without FORTRAN kernels
Compiled with full precision matrices (default)
sizeof(short) 2 sizeof(int) 4 sizeof(long) 8 sizeof(void*) 8 sizeof(PetscScalar) 8 sizeof(PetscInt) 4
Configure options: --download-chaco=/users/jychang48/externalpackages/Chaco-2.2-p2.tar.gz --download-ctetgen=/users/jychang48/externalpackages/ctetgen-0.4.tar.gz --download-exodusii=/users/jychang48/externalpackages/exodus-5.24.tar.bz2 --download-fblaslapack=/users/jychang48/externalpackages/fblaslapack-3.4.2.tar.gz --download-hdf5=/users/jychang48/externalpackages/hdf5-1.8.12.tar.gz --download-hypre=/users/jychang48/externalpackages/hypre-2.10.0b-p1.tar.gz --download-metis=/users/jychang48/externalpackages/metis-5.1.0-p1.tar.gz --download-ml=/users/jychang48/externalpackages/ml-6.2-p3.tar.gz --download-mumps=/users/jychang48/externalpackages/MUMPS_5.0.1-p1.tar.gz --download-netcdf=/users/jychang48/externalpackages/netcdf-4.3.2.tar.gz --download-parmetis=/users/jychang48/externalpackages/parmetis-4.0.3-p2.tar.gz --download-scalapack=/users/jychang48/externalpackages/scalapack-2.0.2.tgz --download-superlu_dist --download-triangle=/users/jychang48/externalpackages/Triangle.tar.gz --with-cc=mpicc --with-cxx=mpicxx --with-debugging=0 --with-fc=mpif90 --with-papi=/usr/projects/hpcsoft/toss2/common/papi/5.4.1 --with-shared-libraries COPTFLAGS=-O3 CXXOPTFLAGS=-O3 FOPTFLAGS=-O3 PETSC_ARCH=arch-linux2-c-opt
Libraries compiled on Fri Jan  1 21:44:06 2016 on wf-fe2.lanl.gov
Machine characteristics: Linux-2.6.32-573.8.1.2chaos.ch5.4.x86_64-x86_64-with-redhat-6.7-Santiago
Using PETSc directory: /users/jychang48/petsc
Using PETSc arch: arch-linux2-c-opt
Using C compiler: mpicc  -fPIC  -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -O3  ${COPTFLAGS} ${CFLAGS}
Using Fortran compiler: mpif90  -fPIC -Wall -Wno-unused-variable -ffree-line-length-0 -Wno-unused-dummy-argument -O3   ${FOPTFLAGS} ${FFLAGS}
Using include paths: -I/users/jychang48/petsc/arch-linux2-c-opt/include -I/users/jychang48/petsc/include -I/users/jychang48/petsc/include -I/users/jychang48/petsc/arch-linux2-c-opt/include -I/usr/projects/hpcsoft/toss2.2/wolf/openmpi/1.6.5-gcc-4.8/include/openmpi/opal/mca/hwloc/hwloc132/hwloc/include -I/usr/projects/hpcsoft/toss2.2/wolf/openmpi/1.6.5-gcc-4.8/include -I/usr/projects/hpcsoft/toss2.2/wolf/openmpi/1.6.5-gcc-4.8/include/openmpi
Using C linker: mpicc
Using Fortran linker: mpif90
Using libraries: -Wl,-rpath,/users/jychang48/petsc/arch-linux2-c-opt/lib -L/users/jychang48/petsc/arch-linux2-c-opt/lib -lpetsc -Wl,-rpath,/users/jychang48/petsc/arch-linux2-c-opt/lib -L/users/jychang48/petsc/arch-linux2-c-opt/lib -lcmumps -ldmumps -lsmumps -lzmumps -lmumps_common -lpord -lscalapack -lsuperlu_dist_4.2 -lHYPRE -Wl,-rpath,/usr/projects/hpcsoft/toss2.2/wolf/openmpi/1.6.5-gcc-4.8/lib -L/usr/projects/hpcsoft/toss2.2/wolf/openmpi/1.6.5-gcc-4.8/lib -Wl,-rpath,/turquoise/usr/projects/hpcsoft/toss2/common/gcc/4.8.2/lib/gcc/x86_64-unknown-linux-gnu/4.8.2 -L/turquoise/usr/projects/hpcsoft/toss2/common/gcc/4.8.2/lib/gcc/x86_64-unknown-linux-gnu/4.8.2 -Wl,-rpath,/turquoise/usr/projects/hpcsoft/toss2/common/gcc/4.8.2/lib/gcc -L/turquoise/usr/projects/hpcsoft/toss2/common/gcc/4.8.2/lib/gcc -Wl,-rpath,/turquoise/usr/projects/hpcsoft/toss2/common/gcc/4.8.2/lib64 -L/turquoise/usr/projects/hpcsoft/toss2/common/gcc/4.8.2/lib64 -Wl,-rpath,/turquoise/usr/projects/hpcsoft/toss2/common/gcc/4.8.2/lib -L/turquoise/usr/projects/hpcsoft/toss2/common/gcc/4.8.2/lib -lmpi_cxx -lstdc++ -lml -lmpi_cxx -lstdc++ -lflapack -lfblas -lparmetis -lmetis -lchaco -lexoIIv2for -lexodus -lnetcdf -lhdf5hl_fortran -lhdf5_fortran -lhdf5_hl -lhdf5 -ltriangle -lX11 -lhwloc -lctetgen -lssl -lcrypto -lmpi_f90 -lmpi_f77 -lgfortran -lm -lgfortran -lm -lgfortran -lm -lgfortran -lm -lgfortran -lm -lquadmath -lm -lmpi_cxx -lstdc++ -Wl,-rpath,/usr/projects/hpcsoft/toss2.2/wolf/openmpi/1.6.5-gcc-4.8/lib -L/usr/projects/hpcsoft/toss2.2/wolf/openmpi/1.6.5-gcc-4.8/lib -Wl,-rpath,/turquoise/usr/projects/hpcsoft/toss2/common/gcc/4.8.2/lib/gcc/x86_64-unknown-linux-gnu/4.8.2 -L/turquoise/usr/projects/hpcsoft/toss2/common/gcc/4.8.2/lib/gcc/x86_64-unknown-linux-gnu/4.8.2 -Wl,-rpath,/turquoise/usr/projects/hpcsoft/toss2/common/gcc/4.8.2/lib/gcc -L/turquoise/usr/projects/hpcsoft/toss2/common/gcc/4.8.2/lib/gcc -Wl,-rpath,/turquoise/usr/projects/hpcsoft/toss2/common/gcc/4.8.2/lib64 -L/turquoise/usr/projects/hpcsoft/toss2/common/gcc/4.8.2/lib64 -Wl,-rpath,/turquoise/usr/projects/hpcsoft/toss2/common/gcc/4.8.2/lib -L/turquoise/usr/projects/hpcsoft/toss2/common/gcc/4.8.2/lib -ldl -lmpi -losmcomp -lrdmacm -libverbs -lsctp -lrt -lnsl -lutil -lpsm_infinipath -lpmi -lnuma -lgcc_s -lpthread -ldl
 gamg 40 1
Discretization: RT
MPI processes 40: solving...
((27890, 1161600), (27890, 1161600))
	Solver time: 5.067154e+00
Darcy_FE.py on a arch-linux2-c-opt named wf153.localdomain with 40 processors, by jychang48 Wed Mar  2 18:02:07 2016
Time (sec):           1.954e+01      1.00033   1.953e+01
Objects:              1.090e+03      1.12371   9.856e+02
Flops:                1.585e+09      1.51148   1.325e+09  5.299e+10
Flops/sec:            8.113e+07      1.51121   6.782e+07  2.713e+09
MPI Messages:         1.975e+04      2.40864   1.332e+04  5.330e+05
MPI Message Lengths:  2.951e+08      6.39097   7.450e+03  3.971e+09
MPI Reductions:       1.077e+03      1.00000
 0:      Main Stage: 1.4467e+01  74.1%  0.0000e+00   0.0%  5.371e+04  10.1%  1.521e+03       20.4%  1.250e+02  11.6%
 1:             FEM: 5.0672e+00  25.9%  5.2989e+10 100.0%  4.793e+05  89.9%  5.929e+03       79.6%  9.510e+02  88.3%
Phase summary info:
BuildTwoSided         44 1.0 1.1854e+0014.3 0.00e+00 0.0 1.3e+04 4.0e+00 4.4e+01  6  0  2  0  4   7  0 24  0 35     0
VecScatterBegin        2 1.0 2.8849e-05 1.4 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecScatterEnd          2 1.0 8.1062e-06 3.4 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
Mesh Partition         2 1.0 2.1183e+00 1.1 0.00e+00 0.0 2.0e+04 3.6e+03 2.1e+01 11  0  4  2  2  15  0 38  9 17     0
Mesh Migration         2 1.0 4.1828e-01 1.0 0.00e+00 0.0 2.9e+04 2.2e+04 5.4e+01  2  0  5 16  5   3  0 54 80 43     0
DMPlexInterp           1 1.0 2.1106e+0061906.1 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
DMPlexDistribute       1 1.0 2.3542e+00 1.1 0.00e+00 0.0 1.4e+04 2.3e+04 2.5e+01 12  0  3  8  2  16  0 26 40 20     0
DMPlexDistCones        2 1.0 9.7619e-02 1.2 0.00e+00 0.0 4.3e+03 5.1e+04 4.0e+00  0  0  1  5  0   1  0  8 27  3     0
DMPlexDistLabels       2 1.0 2.6993e-01 1.0 0.00e+00 0.0 1.7e+04 2.1e+04 2.2e+01  1  0  3  9  2   2  0 32 45 18     0
DMPlexDistribOL        1 1.0 2.0237e-01 1.0 0.00e+00 0.0 3.6e+04 1.2e+04 5.0e+01  1  0  7 11  5   1  0 66 55 40     0
DMPlexDistField        3 1.0 2.9826e-02 2.2 0.00e+00 0.0 5.7e+03 5.2e+03 1.2e+01  0  0  1  1  1   0  0 11  4 10     0
DMPlexDistData         2 1.0 1.0467e+0079.2 0.00e+00 0.0 1.5e+04 2.2e+03 6.0e+00  5  0  3  1  1   7  0 28  4  5     0
DMPlexStratify         6 1.5 5.4628e-0136.1 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
SFSetGraph            51 1.0 4.2505e-02 1.6 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
SFBcastBegin          95 1.0 1.1899e+00 4.6 0.00e+00 0.0 5.1e+04 1.5e+04 4.1e+01  6  0 10 20  4   8  0 96 97 33     0
SFBcastEnd            95 1.0 3.0756e-01 6.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  1  0  0  0  0   2  0  0  0  0     0
SFReduceBegin          4 1.0 8.8451e-0319.5 0.00e+00 0.0 1.7e+03 9.4e+03 3.0e+00  0  0  0  0  0   0  0  3  2  2     0
SFReduceEnd            4 1.0 9.1884e-03 7.2 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
SFFetchOpBegin         1 1.0 4.7207e-0524.8 0.00e+00 0.0 1.9e+02 1.8e+03 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
SFFetchOpEnd           1 1.0 1.4687e-04 3.1 0.00e+00 0.0 1.9e+02 1.8e+03 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
BuildTwoSided         17 1.0 2.3334e-03 3.5 0.00e+00 0.0 1.7e+03 4.0e+00 1.7e+01  0  0  0  0  2   0  0  0  0  2     0
BuildTwoSidedF        12 1.0 4.2319e-04 1.5 0.00e+00 0.0 0.0e+00 0.0e+00 1.2e+01  0  0  0  0  1   0  0  0  0  1     0
VecMDot               96 1.0 2.6845e-02 3.8 1.05e+07 1.1 0.0e+00 0.0e+00 9.6e+01  0  1  0  0  9   0  1  0  0 10 15392
VecNorm              105 1.0 4.4451e-03 1.5 1.50e+06 1.1 0.0e+00 0.0e+00 1.0e+02  0  0  0  0 10   0  0  0  0 11 13260
VecScale             217 1.0 1.6758e-03 1.2 2.01e+06 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0 47243
VecCopy               77 1.0 5.0402e-04 1.2 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecSet               596 1.0 3.8776e-03 1.2 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecAXPY                9 1.0 9.5606e-05 1.2 1.04e+05 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0 42794
VecAYPX              544 1.0 2.5859e-03 1.2 1.90e+06 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0 29060
VecAXPBYCZ           272 1.0 1.5566e-03 1.2 3.80e+06 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0 96549
VecMAXPY             105 1.0 3.2706e-03 1.2 1.19e+07 1.1 0.0e+00 0.0e+00 0.0e+00  0  1  0  0  0   0  1  0  0  0 143109
VecAssemblyBegin      14 1.0 5.3811e-04 1.3 0.00e+00 0.0 0.0e+00 0.0e+00 1.2e+01  0  0  0  0  1   0  0  0  0  1     0
VecAssemblyEnd        14 1.0 5.7459e-05 1.4 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecPointwiseMult      44 1.0 2.1434e-04 1.3 1.23e+05 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0 22685
VecScatterBegin      988 1.0 3.5461e-02 2.1 0.00e+00 0.0 4.0e+05 1.3e+03 0.0e+00  0  0 76 14  0   1  0 84 17  0     0
VecScatterEnd        988 1.0 1.2415e-01 5.3 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   2  0  0  0  0     0
VecSetRandom           4 1.0 5.0902e-04 1.1 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecNormalize         105 1.0 6.2478e-03 1.3 2.25e+06 1.1 0.0e+00 0.0e+00 1.0e+02  0  0  0  0 10   0  0  0  0 11 14152
MatMult              521 1.0 3.6698e-01 1.2 4.16e+08 1.4 3.5e+05 1.5e+03 1.3e+02  2 26 66 13 12   7 26 73 16 14 36848
MatMultAdd           227 1.0 5.2911e-02 2.1 1.89e+07 1.1 3.5e+04 7.9e+02 0.0e+00  0  1  7  1  0   1  1  7  1  0 13698
MatMultTranspose      68 1.0 2.4873e-02 2.5 9.31e+06 1.1 2.4e+04 4.0e+02 0.0e+00  0  1  4  0  0   0  1  5  0  0 13844
MatSolve             129 1.2 4.1506e-02 1.2 2.81e+07 1.1 0.0e+00 0.0e+00 0.0e+00  0  2  0  0  0   1  2  0  0  0 26104
MatSOR               452 1.0 1.6256e-01 1.2 1.78e+08 1.3 0.0e+00 0.0e+00 0.0e+00  1 12  0  0  0   3 12  0  0  0 40040
MatLUFactorSym         1 1.0 4.1962e-05 4.8 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatLUFactorNum         2 1.0 1.7710e-03 1.1 4.73e+05 1.1 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0 10116
MatILUFactorSym        1 1.0 8.9598e-04 1.3 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatConvert             5 1.0 1.1864e-02 3.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatScale              14 1.0 6.0964e-03 1.6 3.80e+06 1.4 2.8e+03 1.5e+03 0.0e+00  0  0  1  0  0   0  0  1  0  0 20551
MatResidual           68 1.0 4.3995e-02 1.2 5.31e+07 1.5 4.7e+04 1.5e+03 0.0e+00  0  3  9  2  0   1  3 10  2  0 38524
MatAssemblyBegin      93 1.0 4.5627e-01 4.6 0.00e+00 0.0 1.0e+04 1.4e+05 5.8e+01  1  0  2 35  5   5  0  2 44  6     0
MatAssemblyEnd        93 1.0 7.9526e-01 1.1 0.00e+00 0.0 2.1e+04 1.9e+02 2.2e+02  4  0  4  0 20  15  0  4  0 23     0
MatGetRow          52698 1.0 2.0620e-01 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  1  0  0  0  0   4  0  0  0  0     0
MatGetRowIJ            2 2.0 1.0014e-05 8.4 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatGetSubMatrix        8 1.0 5.0244e-03 1.0 0.00e+00 0.0 5.5e+02 1.1e+03 7.4e+01  0  0  0  0  7   0  0  0  0  8     0
MatGetOrdering         2 2.0 1.1802e-04 1.5 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatCoarsen             4 1.0 3.3238e-03 1.3 0.00e+00 0.0 1.1e+04 4.3e+02 2.1e+01  0  0  2  0  2   0  0  2  0  2     0
MatZeroEntries         4 1.0 5.5079e-03 4.2 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatAXPY                5 1.0 2.4477e-01 1.0 0.00e+00 0.0 7.2e+02 3.0e+02 2.0e+01  1  0  0  0  2   5  0  0  0  2     0
MatMatMult             5 1.0 8.6163e-02 1.0 3.37e+06 1.4 1.8e+04 7.6e+02 8.0e+01  0  0  3  0  7   2  0  4  0  8  1272
MatMatMultSym          5 1.0 7.6432e-02 1.0 0.00e+00 0.0 1.5e+04 6.2e+02 7.0e+01  0  0  3  0  6   2  0  3  0  7     0
MatMatMultNum          5 1.0 9.7311e-03 1.0 3.37e+06 1.4 2.9e+03 1.5e+03 1.0e+01  0  0  1  0  1   0  0  1  0  1 11263
MatPtAP                4 1.0 3.7207e+00 1.0 9.62e+08 1.9 3.3e+04 7.8e+04 6.8e+01 19 56  6 65  6  73 56  7 81  7  7908
MatPtAPSymbolic        4 1.0 2.1426e+00 1.0 0.00e+00 0.0 1.7e+04 7.0e+04 2.8e+01 11  0  3 29  3  42  0  3 37  3     0
MatPtAPNumeric         4 1.0 1.5781e+00 1.0 9.62e+08 1.9 1.6e+04 8.6e+04 4.0e+01  8 56  3 35  4  31 56  3 44  4 18646
MatTrnMatMult          1 1.0 1.6947e-02 1.0 4.99e+05 1.1 2.2e+03 1.9e+03 1.9e+01  0  0  0  0  2   0  0  0  0  2  1144
MatTrnMatMultSym       1 1.0 1.1003e-02 1.0 0.00e+00 0.0 1.8e+03 1.1e+03 1.7e+01  0  0  0  0  2   0  0  0  0  2     0
MatTrnMatMultNum       1 1.0 5.9371e-03 1.0 4.99e+05 1.1 3.6e+02 6.0e+03 2.0e+00  0  0  0  0  0   0  0  0  0  0  3266
MatGetLocalMat        16 1.0 3.9840e-03 1.2 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatGetBrAoCol         14 1.0 6.5035e-02 1.3 0.00e+00 0.0 2.0e+04 4.1e+04 0.0e+00  0  0  4 21  0   1  0  4 26  0     0
PCGAMGGraph_AGG        4 1.0 2.0390e-01 1.0 3.12e+06 1.5 5.3e+03 8.4e+02 4.8e+01  1  0  1  0  4   4  0  1  0  5   489
PCGAMGCoarse_AGG       4 1.0 2.3103e-02 1.0 4.99e+05 1.1 1.5e+04 8.4e+02 4.8e+01  0  0  3  0  4   0  0  3  0  5   839
PCGAMGProl_AGG         4 1.0 8.3230e-03 1.0 0.00e+00 0.0 5.9e+03 5.2e+02 8.0e+01  0  0  1  0  7   0  0  1  0  8     0
PCGAMGPOpt_AGG         4 1.0 1.9880e-01 1.0 3.80e+07 1.4 4.4e+04 1.2e+03 1.9e+02  1  2  8  1 17   4  2  9  2 20  6232
GAMG: createProl       4 1.0 4.3470e-01 1.0 4.16e+07 1.4 7.0e+04 1.0e+03 3.6e+02  2  3 13  2 34   9  3 15  2 38  3124
  Graph                8 1.0 2.0300e-01 1.0 3.12e+06 1.5 5.3e+03 8.4e+02 4.8e+01  1  0  1  0  4   4  0  1  0  5   491
  MIS/Agg              4 1.0 3.3939e-03 1.3 0.00e+00 0.0 1.1e+04 4.3e+02 2.1e+01  0  0  2  0  2   0  0  2  0  2     0
  SA: col data         4 1.0 1.5466e-03 1.1 0.00e+00 0.0 2.5e+03 1.0e+03 2.4e+01  0  0  0  0  2   0  0  1  0  3     0
  SA: frmProl0         4 1.0 6.2592e-03 1.0 0.00e+00 0.0 3.4e+03 1.2e+02 4.0e+01  0  0  1  0  4   0  0  1  0  4     0
  SA: smooth           4 1.0 1.9878e-01 1.0 3.80e+07 1.4 4.4e+04 1.2e+03 1.9e+02  1  2  8  1 17   4  2  9  2 20  6233
GAMG: partLevel        4 1.0 3.7256e+00 1.0 9.62e+08 1.9 3.4e+04 7.7e+04 1.7e+02 19 56  6 65 16  74 56  7 81 18  7898
  repartition          2 1.0 2.9397e-04 1.1 0.00e+00 0.0 0.0e+00 0.0e+00 1.2e+01  0  0  0  0  1   0  0  0  0  1     0
  Invert-Sort          2 1.0 3.0017e-04 1.2 0.00e+00 0.0 0.0e+00 0.0e+00 8.0e+00  0  0  0  0  1   0  0  0  0  1     0
  Move A               2 1.0 1.5130e-03 1.0 0.00e+00 0.0 2.3e+02 2.4e+03 3.6e+01  0  0  0  0  3   0  0  0  0  4     0
  Move P               2 1.0 2.5032e-03 1.0 0.00e+00 0.0 3.2e+02 1.0e+02 3.6e+01  0  0  0  0  3   0  0  0  0  4     0
PCSetUp                5 1.0 4.3353e+00 1.0 1.00e+09 1.9 1.1e+05 2.5e+04 6.2e+02 22 58 20 67 58  86 58 22 84 66  7108
PCSetUpOnBlocks      129 1.0 3.0313e-03 1.2 4.73e+05 1.1 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0  5910
PCApply               17 1.0 4.6916e+00 1.0 1.52e+09 1.5 4.6e+05 6.7e+03 6.5e+02 24 96 87 78 60  93 96 97 98 68 10812
KSPGMRESOrthog        96 1.0 3.0260e-02 2.9 2.11e+07 1.1 0.0e+00 0.0e+00 9.6e+01  0  2  0  0  9   0  2  0  0 10 27310
KSPSetUp              18 1.0 8.6641e-04 1.5 0.00e+00 0.0 0.0e+00 0.0e+00 8.0e+00  0  0  0  0  1   0  0  0  0  1     0
KSPSolve               1 1.0 4.8847e+00 1.0 1.55e+09 1.5 4.8e+05 6.6e+03 8.7e+02 25 98 89 79 81  96 98 99 99 92 10601
SFSetGraph             4 1.0 2.2912e-04 3.5 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
SFBcastBegin          26 1.0 2.7394e-03 2.6 0.00e+00 0.0 1.2e+04 5.6e+02 5.0e+00  0  0  2  0  0   0  0  3  0  1     0
SFBcastEnd            26 1.0 1.0862e-03 3.4 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
              Viewer     1              0            0     0.
           Index Set   187            194     23336772     0.
   IS L to G Mapping     3              3     14094724     0.
             Section    70             53        35616     0.
              Vector    15            141     13835680     0.
      Vector Scatter     2             15       685800     0.
              Matrix     0             52     22699316     0.
      Preconditioner     0             11        11020     0.
    Distributed Mesh    14              8        38248     0.
    GraphPartitioner     6              5         3060     0.
Star Forest Bipartite Graph    74             63        53256     0.
     Discrete System    14              8         6912     0.
           Index Set   102             88       198216     0.
              Vector   356            218      3282272     0.
      Vector Scatter    40             21        23032     0.
              Matrix   145             80     42315724     0.
      Preconditioner    21             10         8944     0.
       Krylov Solver    21              6       123480     0.
Star Forest Bipartite Graph     4              4         3456     0.
Average time to get PetscTime(): 5.96046e-07
Average time for MPI_Barrier(): 9.58443e-06
Average time for zero size MPI_Send(): 1.40071e-06
-log_summary
 gamg 40 1
Discretization: RT
MPI processes 48: solving...
((23365, 1161600), (23365, 1161600))
	Solver time: 4.216640e+00
Darcy_FE.py on a arch-linux2-c-opt named wf153.localdomain with 48 processors, by jychang48 Wed Mar  2 18:02:30 2016
Time (sec):           1.886e+01      1.00032   1.886e+01
Objects:              1.098e+03      1.13196   9.852e+02
Flops:                1.310e+09      1.70226   1.017e+09  4.881e+10
Flops/sec:            6.945e+07      1.70193   5.392e+07  2.588e+09
MPI Messages:         2.029e+04      2.24362   1.474e+04  7.073e+05
MPI Message Lengths:  2.606e+08      6.46661   5.856e+03  4.142e+09
 0:      Main Stage: 1.4641e+01  77.6%  0.0000e+00   0.0%  6.669e+04   9.4%  1.171e+03       20.0%  1.250e+02  11.6%
 1:             FEM: 4.2166e+00  22.4%  4.8807e+10 100.0%  6.406e+05  90.6%  4.686e+03       80.0%  9.520e+02  88.3%
Phase summary info:
BuildTwoSided         44 1.0 1.1856e+0013.6 0.00e+00 0.0 1.6e+04 4.0e+00 4.4e+01  6  0  2  0  4   7  0 24  0 35     0
VecScatterBegin        2 1.0 2.2173e-05 1.3 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecScatterEnd          2 1.0 8.1062e-06 4.2 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
Mesh Partition         2 1.0 2.1368e+00 1.1 0.00e+00 0.0 2.7e+04 2.8e+03 2.1e+01 11  0  4  2  2  15  0 40  9 17     0
Mesh Migration         2 1.0 4.0564e-01 1.0 0.00e+00 0.0 3.4e+04 1.9e+04 5.4e+01  2  0  5 16  5   3  0 51 80 43     0
DMPlexInterp           1 1.0 2.1086e+0061847.5 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
DMPlexDistribute       1 1.0 2.3904e+00 1.1 0.00e+00 0.0 1.9e+04 1.7e+04 2.5e+01 13  0  3  8  2  16  0 29 40 20     0
DMPlexDistCones        2 1.0 9.4622e-02 1.2 0.00e+00 0.0 5.1e+03 4.3e+04 4.0e+00  0  0  1  5  0   1  0  8 26  3     0
DMPlexDistLabels       2 1.0 2.6377e-01 1.0 0.00e+00 0.0 2.1e+04 1.8e+04 2.2e+01  1  0  3  9  2   2  0 31 45 18     0
DMPlexDistribOL        1 1.0 1.7173e-01 1.1 0.00e+00 0.0 4.2e+04 1.1e+04 5.0e+01  1  0  6 11  5   1  0 64 55 40     0
DMPlexDistField        3 1.0 2.9037e-02 2.1 0.00e+00 0.0 6.8e+03 4.5e+03 1.2e+01  0  0  1  1  1   0  0 10  4 10     0
DMPlexDistData         2 1.0 1.0405e+0065.1 0.00e+00 0.0 2.1e+04 1.7e+03 6.0e+00  5  0  3  1  1   7  0 31  4  5     0
DMPlexStratify         6 1.5 5.4211e-0141.9 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
SFSetGraph            51 1.0 3.6311e-02 1.6 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
SFBcastBegin          95 1.0 1.1934e+00 4.4 0.00e+00 0.0 6.4e+04 1.3e+04 4.1e+01  6  0  9 19  4   8  0 96 97 33     0
SFBcastEnd            95 1.0 2.9515e-01 6.5 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  1  0  0  0  0   2  0  0  0  0     0
SFReduceBegin          4 1.0 9.3102e-0322.9 0.00e+00 0.0 2.0e+03 8.2e+03 3.0e+00  0  0  0  0  0   0  0  3  2  2     0
SFReduceEnd            4 1.0 9.3510e-03 7.5 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
SFFetchOpBegin         1 1.0 4.2915e-0520.0 0.00e+00 0.0 2.2e+02 1.7e+03 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
SFFetchOpEnd           1 1.0 1.1206e-04 2.2 0.00e+00 0.0 2.2e+02 1.7e+03 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
BuildTwoSided         17 1.0 2.1787e-03 3.6 0.00e+00 0.0 2.0e+03 4.0e+00 1.7e+01  0  0  0  0  2   0  0  0  0  2     0
BuildTwoSidedF        12 1.0 5.0044e-04 1.5 0.00e+00 0.0 0.0e+00 0.0e+00 1.2e+01  0  0  0  0  1   0  0  0  0  1     0
VecMDot               96 1.0 2.5555e-02 3.9 8.80e+06 1.1 0.0e+00 0.0e+00 9.6e+01  0  1  0  0  9   0  1  0  0 10 16169
VecNorm              105 1.0 4.3268e-03 1.5 1.25e+06 1.0 0.0e+00 0.0e+00 1.0e+02  0  0  0  0 10   0  0  0  0 11 13624
VecScale             217 1.0 1.4749e-03 1.2 1.67e+06 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0 53683
VecCopy               77 1.0 5.0020e-04 1.5 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecSet               596 1.0 3.2456e-03 1.2 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecAXPY                9 1.0 9.8467e-05 1.5 8.69e+04 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0 41556
VecAYPX              544 1.0 2.2662e-03 1.3 1.58e+06 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0 33170
VecAXPBYCZ           272 1.0 1.3177e-03 1.3 3.16e+06 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0 114089
VecMAXPY             105 1.0 2.5764e-03 1.1 9.97e+06 1.1 0.0e+00 0.0e+00 0.0e+00  0  1  0  0  0   0  1  0  0  0 181688
VecAssemblyBegin      14 1.0 6.0821e-04 1.4 0.00e+00 0.0 0.0e+00 0.0e+00 1.2e+01  0  0  0  0  1   0  0  0  0  1     0
VecAssemblyEnd        14 1.0 6.1989e-05 1.4 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecPointwiseMult      44 1.0 2.0766e-04 1.5 1.02e+05 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0 23422
VecScatterBegin      988 1.0 3.0665e-02 1.9 0.00e+00 0.0 5.4e+05 1.1e+03 0.0e+00  0  0 77 15  0   1  0 85 18  0     0
VecScatterEnd        988 1.0 1.0807e-01 4.4 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   2  0  0  0  0     0
VecSetRandom           4 1.0 4.1986e-04 1.1 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecNormalize         105 1.0 5.9941e-03 1.4 1.88e+06 1.0 0.0e+00 0.0e+00 1.0e+02  0  0  0  0 10   0  0  0  0 11 14752
MatMult              521 1.0 2.9442e-01 1.2 3.40e+08 1.5 4.7e+05 1.2e+03 1.3e+02  1 27 67 14 12   7 27 74 17 14 44430
MatMultAdd           227 1.0 4.8976e-02 2.3 1.57e+07 1.1 4.4e+04 6.9e+02 0.0e+00  0  1  6  1  0   1  1  7  1  0 14413
MatMultTranspose      68 1.0 2.0373e-02 2.3 7.53e+06 1.2 3.0e+04 3.5e+02 0.0e+00  0  1  4  0  0   0  1  5  0  0 15974
MatSolve             129 1.2 3.4987e-02 1.2 2.34e+07 1.1 0.0e+00 0.0e+00 0.0e+00  0  2  0  0  0   1  2  0  0  0 30892
MatSOR               452 1.0 1.1530e-01 1.2 1.39e+08 1.2 0.0e+00 0.0e+00 0.0e+00  1 13  0  0  0   3 13  0  0  0 53183
MatLUFactorSym         1 1.0 3.8862e-05 4.9 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatLUFactorNum         2 1.0 1.4689e-03 1.1 3.97e+05 1.1 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0 12180
MatILUFactorSym        1 1.0 6.6495e-04 1.1 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatConvert             5 1.0 9.6900e-03 2.9 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatScale              14 1.0 5.3563e-03 1.9 3.09e+06 1.5 3.7e+03 1.2e+03 0.0e+00  0  0  1  0  0   0  0  1  0  0 22511
MatResidual           68 1.0 3.6604e-02 1.3 4.32e+07 1.6 6.4e+04 1.2e+03 0.0e+00  0  3  9  2  0   1  3 10  2  0 44632
MatAssemblyBegin      93 1.0 4.2010e-01 4.6 0.00e+00 0.0 1.4e+04 1.1e+05 5.8e+01  1  0  2 35  5   6  0  2 43  6     0
MatAssemblyEnd        93 1.0 5.8031e-01 1.2 0.00e+00 0.0 2.8e+04 1.6e+02 2.2e+02  3  0  4  0 20  13  0  4  0 23     0
MatGetRow          43909 1.0 1.7181e-01 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  1  0  0  0  0   4  0  0  0  0     0
MatGetRowIJ            2 2.0 1.0252e-0510.8 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatGetSubMatrix        8 1.0 4.6279e-03 1.0 0.00e+00 0.0 6.6e+02 8.8e+02 7.4e+01  0  0  0  0  7   0  0  0  0  8     0
MatGetOrdering         2 2.0 1.0300e-04 1.6 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatCoarsen             4 1.0 2.2120e-03 1.1 0.00e+00 0.0 1.4e+04 3.8e+02 2.2e+01  0  0  2  0  2   0  0  2  0  2     0
MatZeroEntries         4 1.0 4.2212e-03 4.2 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatAXPY                5 1.0 2.0452e-01 1.0 0.00e+00 0.0 8.6e+02 2.7e+02 2.0e+01  1  0  0  0  2   5  0  0  0  2     0
MatMatMult             5 1.0 7.1930e-02 1.0 2.75e+06 1.5 2.4e+04 6.3e+02 8.0e+01  0  0  3  0  7   2  0  4  0  8  1474
MatMatMultSym          5 1.0 6.3674e-02 1.0 0.00e+00 0.0 2.0e+04 5.1e+02 7.0e+01  0  0  3  0  6   2  0  3  0  7     0
MatMatMultNum          5 1.0 8.2068e-03 1.0 2.75e+06 1.5 4.0e+03 1.2e+03 1.0e+01  0  0  1  0  1   0  0  1  0  1 12916
MatPtAP                4 1.0 3.0910e+00 1.0 7.76e+08 2.2 4.5e+04 5.9e+04 6.8e+01 16 53  6 64  6  73 53  7 80  7  8436
MatPtAPSymbolic        4 1.0 1.8711e+00 1.0 0.00e+00 0.0 2.2e+04 5.4e+04 2.8e+01 10  0  3 29  3  44  0  4 37  3     0
MatPtAPNumeric         4 1.0 1.2206e+00 1.0 7.76e+08 2.2 2.2e+04 6.4e+04 4.0e+01  6 53  3 35  4  29 53  3 43  4 21364
MatTrnMatMult          1 1.0 1.4337e-02 1.0 4.16e+05 1.1 2.6e+03 1.7e+03 1.9e+01  0  0  0  0  2   0  0  0  0  2  1355
MatTrnMatMultSym       1 1.0 9.2320e-03 1.0 0.00e+00 0.0 2.2e+03 9.6e+02 1.7e+01  0  0  0  0  2   0  0  0  0  2     0
MatTrnMatMultNum       1 1.0 5.0960e-03 1.0 4.16e+05 1.1 4.3e+02 5.3e+03 2.0e+00  0  0  0  0  0   0  0  0  0  0  3813
MatGetLocalMat        16 1.0 3.2232e-03 1.2 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatGetBrAoCol         14 1.0 5.9111e-02 1.3 0.00e+00 0.0 2.7e+04 3.2e+04 0.0e+00  0  0  4 21  0   1  0  4 26  0     0
PCGAMGGraph_AGG        4 1.0 1.6926e-01 1.0 2.54e+06 1.6 6.8e+03 7.3e+02 4.8e+01  1  0  1  0  4   4  0  1  0  5   568
PCGAMGCoarse_AGG       4 1.0 1.9103e-02 1.0 4.16e+05 1.1 1.9e+04 7.3e+02 4.9e+01  0  0  3  0  5   0  0  3  0  5  1017
PCGAMGProl_AGG         4 1.0 6.7439e-03 1.0 0.00e+00 0.0 7.1e+03 4.7e+02 8.0e+01  0  0  1  0  7   0  0  1  0  8     0
PCGAMGPOpt_AGG         4 1.0 1.6605e-01 1.0 3.10e+07 1.5 6.0e+04 9.7e+02 1.9e+02  1  2  8  1 17   4  2  9  2 20  7216
GAMG: createProl       4 1.0 3.6235e-01 1.0 3.39e+07 1.5 9.3e+04 8.7e+02 3.6e+02  2  3 13  2 34   9  3 14  2 38  3626
  Graph                8 1.0 1.6913e-01 1.0 2.54e+06 1.6 6.8e+03 7.3e+02 4.8e+01  1  0  1  0  4   4  0  1  0  5   568
  MIS/Agg              4 1.0 2.2740e-03 1.0 0.00e+00 0.0 1.4e+04 3.8e+02 2.2e+01  0  0  2  0  2   0  0  2  0  2     0
  SA: col data         4 1.0 1.4884e-03 1.1 0.00e+00 0.0 3.1e+03 9.4e+02 2.4e+01  0  0  0  0  2   0  0  0  0  3     0
  SA: frmProl0         4 1.0 4.6790e-03 1.0 0.00e+00 0.0 4.0e+03 1.1e+02 4.0e+01  0  0  1  0  4   0  0  1  0  4     0
  SA: smooth           4 1.0 1.6603e-01 1.0 3.10e+07 1.5 6.0e+04 9.7e+02 1.9e+02  1  2  8  1 17   4  2  9  2 20  7217
GAMG: partLevel        4 1.0 3.0959e+00 1.0 7.76e+08 2.2 4.6e+04 5.8e+04 1.7e+02 16 53  6 64 16  73 53  7 80 18  8423
  repartition          2 1.0 3.0708e-04 1.1 0.00e+00 0.0 0.0e+00 0.0e+00 1.2e+01  0  0  0  0  1   0  0  0  0  1     0
  Invert-Sort          2 1.0 3.5977e-04 1.2 0.00e+00 0.0 0.0e+00 0.0e+00 8.0e+00  0  0  0  0  1   0  0  0  0  1     0
  Move A               2 1.0 1.6382e-03 1.0 0.00e+00 0.0 2.7e+02 2.0e+03 3.6e+01  0  0  0  0  3   0  0  0  0  4     0
  Move P               2 1.0 2.2459e-03 1.0 0.00e+00 0.0 3.8e+02 9.8e+01 3.6e+01  0  0  0  0  3   0  0  0  0  4     0
PCSetUp                5 1.0 3.6055e+00 1.0 8.07e+08 2.2 1.4e+05 1.9e+04 6.2e+02 19 56 20 66 58  86 56 22 83 66  7606
PCSetUpOnBlocks      129 1.0 2.4600e-03 1.1 3.97e+05 1.1 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0  7273
PCApply               17 1.0 3.8817e+00 1.0 1.26e+09 1.7 6.2e+05 5.3e+03 6.5e+02 21 95 88 79 60  92 95 97 98 68 11983
KSPGMRESOrthog        96 1.0 2.8517e-02 3.0 1.76e+07 1.1 0.0e+00 0.0e+00 9.6e+01  0  2  0  0  9   0  2  0  0 10 28981
KSPSetUp              18 1.0 7.9155e-04 1.5 0.00e+00 0.0 0.0e+00 0.0e+00 8.0e+00  0  0  0  0  1   0  0  0  0  1     0
KSPSolve               1 1.0 4.0445e+00 1.0 1.28e+09 1.7 6.4e+05 5.2e+03 8.7e+02 21 97 90 79 81  96 97 99 99 92 11761
SFSetGraph             4 1.0 1.7500e-04 3.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
SFBcastBegin          27 1.0 2.1336e-03 2.8 0.00e+00 0.0 1.6e+04 4.9e+02 5.0e+00  0  0  2  0  0   0  0  2  0  1     0
SFBcastEnd            27 1.0 8.4925e-04 5.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
              Viewer     1              0            0     0.
           Index Set   195            202     22897792     0.
   IS L to G Mapping     3              3     14076928     0.
              Vector    15            141     12429688     0.
      Vector Scatter     2             15       577200     0.
              Matrix     0             52     18299000     0.
           Index Set   102             88       174544     0.
              Vector   356            218      2791528     0.
      Vector Scatter    40             21        23056     0.
              Matrix   145             80     34632808     0.
Average time for MPI_Barrier(): 1.12057e-05
Average time for zero size MPI_Send(): 1.39574e-06
-log_summary
 gamg 40 1
Discretization: RT
MPI processes 56: solving...
((20104, 1161600), (20104, 1161600))
	Solver time: 3.855059e+00
Darcy_FE.py on a arch-linux2-c-opt named wf153.localdomain with 56 processors, by jychang48 Wed Mar  2 18:02:52 2016
Time (sec):           1.866e+01      1.00021   1.866e+01
Objects:              1.116e+03      1.14815   9.859e+02
Flops:                1.055e+09      1.76655   8.275e+08  4.634e+10
Flops/sec:            5.653e+07      1.76628   4.435e+07  2.484e+09
MPI Messages:         2.255e+04      2.17874   1.655e+04  9.265e+05
MPI Message Lengths:  2.460e+08      7.31784   4.913e+03  4.552e+09
 0:      Main Stage: 1.4803e+01  79.3%  0.0000e+00   0.0%  8.318e+04   9.0%  9.156e+02       18.6%  1.250e+02  11.6%
 1:             FEM: 3.8551e+00  20.7%  4.6342e+10 100.0%  8.434e+05  91.0%  3.997e+03       81.4%  9.520e+02  88.3%
Phase summary info:
BuildTwoSided         44 1.0 1.2211e+0012.6 0.00e+00 0.0 2.0e+04 4.0e+00 4.4e+01  6  0  2  0  4   8  0 24  0 35     0
VecScatterBegin        2 1.0 2.0027e-05 1.3 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
Mesh Partition         2 1.0 2.1955e+00 1.1 0.00e+00 0.0 3.5e+04 2.2e+03 2.1e+01 12  0  4  2  2  15  0 42  9 17     0
Mesh Migration         2 1.0 4.0020e-01 1.0 0.00e+00 0.0 4.1e+04 1.6e+04 5.4e+01  2  0  4 15  5   3  0 50 79 43     0
DMPlexInterp           1 1.0 2.1409e+0065070.9 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
DMPlexDistribute       1 1.0 2.4610e+00 1.1 0.00e+00 0.0 2.6e+04 1.3e+04 2.5e+01 13  0  3  7  2  17  0 31 39 20     0
DMPlexDistCones        2 1.0 9.4115e-02 1.2 0.00e+00 0.0 6.2e+03 3.6e+04 4.0e+00  0  0  1  5  0   1  0  7 26  3     0
DMPlexDistLabels       2 1.0 2.6018e-01 1.0 0.00e+00 0.0 2.5e+04 1.5e+04 2.2e+01  1  0  3  8  2   2  0 30 45 18     0
DMPlexDistribOL        1 1.0 1.5694e-01 1.1 0.00e+00 0.0 5.1e+04 9.2e+03 5.0e+01  1  0  6 10  5   1  0 62 56 40     0
DMPlexDistField        3 1.0 3.1035e-02 2.2 0.00e+00 0.0 8.3e+03 3.8e+03 1.2e+01  0  0  1  1  1   0  0 10  4 10     0
DMPlexDistData         2 1.0 1.0645e+0052.3 0.00e+00 0.0 2.8e+04 1.3e+03 6.0e+00  5  0  3  1  1   7  0 33  4  5     0
DMPlexStratify         6 1.5 5.4196e-0150.8 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
SFSetGraph            51 1.0 3.2694e-02 1.7 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
SFBcastBegin          95 1.0 1.2282e+00 4.1 0.00e+00 0.0 8.0e+04 1.0e+04 4.1e+01  6  0  9 18  4   8  0 96 97 33     0
SFBcastEnd            95 1.0 2.9801e-01 9.1 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  1  0  0  0  0   2  0  0  0  0     0
SFReduceBegin          4 1.0 9.2599e-0323.0 0.00e+00 0.0 2.5e+03 6.8e+03 3.0e+00  0  0  0  0  0   0  0  3  2  2     0
SFReduceEnd            4 1.0 1.0490e-02 8.6 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
SFFetchOpBegin         1 1.0 3.5048e-0518.4 0.00e+00 0.0 2.7e+02 1.5e+03 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
SFFetchOpEnd           1 1.0 1.1206e-04 2.5 0.00e+00 0.0 2.7e+02 1.5e+03 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
BuildTwoSided         17 1.0 2.0077e-03 3.6 0.00e+00 0.0 2.5e+03 4.0e+00 1.7e+01  0  0  0  0  2   0  0  0  0  2     0
BuildTwoSidedF        12 1.0 4.8900e-04 1.4 0.00e+00 0.0 0.0e+00 0.0e+00 1.2e+01  0  0  0  0  1   0  0  0  0  1     0
VecMDot               96 1.0 2.3549e-02 3.5 7.55e+06 1.0 0.0e+00 0.0e+00 9.6e+01  0  1  0  0  9   0  1  0  0 10 17546
VecNorm              105 1.0 4.9648e-03 1.4 1.08e+06 1.0 0.0e+00 0.0e+00 1.0e+02  0  0  0  0 10   0  0  0  0 11 11873
VecScale             217 1.0 1.3340e-03 1.2 1.43e+06 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0 59353
VecCopy               77 1.0 3.8218e-04 1.3 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecSet               596 1.0 2.8689e-03 1.2 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecAXPY                9 1.0 8.3923e-05 1.4 7.45e+04 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0 48756
VecAYPX              544 1.0 1.7948e-03 1.2 1.36e+06 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0 41879
VecAXPBYCZ           272 1.0 1.0500e-03 1.2 2.71e+06 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0 143173
VecMAXPY             105 1.0 2.2776e-03 1.1 8.55e+06 1.0 0.0e+00 0.0e+00 0.0e+00  0  1  0  0  0   0  1  0  0  0 205516
VecAssemblyBegin      14 1.0 5.9843e-04 1.3 0.00e+00 0.0 0.0e+00 0.0e+00 1.2e+01  0  0  0  0  1   0  0  0  0  1     0
VecAssemblyEnd        14 1.0 6.9380e-05 1.8 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecPointwiseMult      44 1.0 1.8048e-04 1.4 8.77e+04 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0 26948
VecScatterBegin      988 1.0 3.1637e-02 2.2 0.00e+00 0.0 7.2e+05 9.4e+02 0.0e+00  0  0 77 15  0   1  0 85 18  0     0
VecScatterEnd        988 1.0 8.6891e-02 3.9 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   1  0  0  0  0     0
VecSetRandom           4 1.0 3.6597e-04 1.1 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecNormalize         105 1.0 6.5765e-03 1.3 1.61e+06 1.0 0.0e+00 0.0e+00 1.0e+02  0  0  0  0 10   0  0  0  0 11 13445
MatMult              521 1.0 2.4558e-01 1.2 2.74e+08 1.5 6.3e+05 1.0e+03 1.3e+02  1 27 68 14 12   6 27 75 17 14 51699
MatMultAdd           227 1.0 3.8159e-02 2.0 1.29e+07 1.1 5.5e+04 5.9e+02 0.0e+00  0  1  6  1  0   1  1  7  1  0 18085
MatMultTranspose      68 1.0 1.6905e-02 2.4 6.06e+06 1.2 3.8e+04 3.0e+02 0.0e+00  0  1  4  0  0   0  1  5  0  0 18319
MatSolve             129 1.2 2.8386e-02 1.1 2.01e+07 1.1 0.0e+00 0.0e+00 0.0e+00  0  2  0  0  0   1  2  0  0  0 37974
MatSOR               452 1.0 8.4327e-02 1.2 1.13e+08 1.2 0.0e+00 0.0e+00 0.0e+00  0 12  0  0  0   2 12  0  0  0 67671
MatLUFactorSym         1 1.0 4.3869e-05 5.6 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatLUFactorNum         2 1.0 1.2627e-03 1.1 3.40e+05 1.1 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0 14138
MatILUFactorSym        1 1.0 7.9203e-04 1.6 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatConvert             5 1.0 6.6226e-03 2.4 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatScale              14 1.0 4.1234e-03 1.9 2.47e+06 1.4 5.0e+03 1.0e+03 0.0e+00  0  0  1  0  0   0  0  1  0  0 28256
MatResidual           68 1.0 2.7525e-02 1.1 3.46e+07 1.5 8.5e+04 1.0e+03 0.0e+00  0  3  9  2  0   1  3 10  2  0 57417
MatAssemblyBegin      93 1.0 4.3088e-01 3.8 0.00e+00 0.0 1.8e+04 9.0e+04 5.8e+01  2  0  2 35  5   7  0  2 43  6     0
MatAssemblyEnd        93 1.0 6.9626e-01 1.4 0.00e+00 0.0 3.6e+04 1.4e+02 2.2e+02  4  0  4  0 20  17  0  4  0 23     0
MatGetRow          37645 1.0 1.4686e-01 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  1  0  0  0  0   4  0  0  0  0     0
MatGetRowIJ            2 2.0 5.9605e-06 6.2 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatGetSubMatrix        8 1.0 4.5202e-03 1.0 0.00e+00 0.0 7.6e+02 8.8e+02 7.4e+01  0  0  0  0  7   0  0  0  0  8     0
MatGetOrdering         2 2.0 9.2030e-05 1.6 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatCoarsen             4 1.0 2.1741e-03 1.1 0.00e+00 0.0 1.7e+04 3.4e+02 2.2e+01  0  0  2  0  2   0  0  2  0  2     0
MatZeroEntries         4 1.0 3.0334e-03 2.5 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatAXPY                5 1.0 1.7570e-01 1.0 0.00e+00 0.0 1.0e+03 2.4e+02 2.0e+01  1  0  0  0  2   5  0  0  0  2     0
MatMatMult             5 1.0 6.3858e-02 1.0 2.21e+06 1.5 3.2e+04 5.3e+02 8.0e+01  0  0  3  0  7   2  0  4  0  8  1611
MatMatMultSym          5 1.0 5.6910e-02 1.0 0.00e+00 0.0 2.7e+04 4.3e+02 7.0e+01  0  0  3  0  6   1  0  3  0  7     0
MatMatMultNum          5 1.0 6.9041e-03 1.0 2.21e+06 1.5 5.2e+03 1.1e+03 1.0e+01  0  0  1  0  1   0  0  1  0  1 14898
MatPtAP                4 1.0 2.8888e+00 1.0 6.50e+08 2.6 6.0e+04 5.0e+04 6.8e+01 15 53  6 65  6  75 53  7 80  7  8455
MatPtAPSymbolic        4 1.0 1.6264e+00 1.0 0.00e+00 0.0 3.0e+04 4.6e+04 2.8e+01  9  0  3 30  3  42  0  4 37  3     0
MatPtAPNumeric         4 1.0 1.2635e+00 1.0 6.50e+08 2.6 3.0e+04 5.4e+04 4.0e+01  7 53  3 35  4  33 53  4 43  4 19331
MatTrnMatMult          1 1.0 1.2778e-02 1.0 3.58e+05 1.1 3.2e+03 1.5e+03 1.9e+01  0  0  0  0  2   0  0  0  0  2  1524
MatTrnMatMultSym       1 1.0 8.3380e-03 1.0 0.00e+00 0.0 2.6e+03 8.5e+02 1.7e+01  0  0  0  0  2   0  0  0  0  2     0
MatTrnMatMultNum       1 1.0 4.4389e-03 1.0 3.58e+05 1.1 5.2e+02 4.8e+03 2.0e+00  0  0  0  0  0   0  0  0  0  0  4388
MatGetLocalMat        16 1.0 2.8000e-03 1.2 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatGetBrAoCol         14 1.0 5.8958e-02 1.3 0.00e+00 0.0 3.6e+04 2.7e+04 0.0e+00  0  0  4 21  0   1  0  4 26  0     0
PCGAMGGraph_AGG        4 1.0 1.4344e-01 1.0 2.04e+06 1.5 8.7e+03 6.3e+02 4.8e+01  1  0  1  0  4   4  0  1  0  5   648
PCGAMGCoarse_AGG       4 1.0 1.7099e-02 1.0 3.58e+05 1.1 2.3e+04 6.5e+02 4.9e+01  0  0  2  0  5   0  0  3  0  5  1139
PCGAMGProl_AGG         4 1.0 6.5010e-03 1.0 0.00e+00 0.0 8.7e+03 4.1e+02 8.0e+01  0  0  1  0  7   0  0  1  0  8     0
PCGAMGPOpt_AGG         4 1.0 1.4499e-01 1.0 2.49e+07 1.5 8.0e+04 8.2e+02 1.9e+02  1  3  9  1 17   4  3  9  2 20  8020
GAMG: createProl       4 1.0 3.1266e-01 1.0 2.73e+07 1.5 1.2e+05 7.5e+02 3.6e+02  2  3 13  2 34   8  3 14  2 38  4079
  Graph                8 1.0 1.4329e-01 1.0 2.04e+06 1.5 8.7e+03 6.3e+02 4.8e+01  1  0  1  0  4   4  0  1  0  5   649
  MIS/Agg              4 1.0 2.2221e-03 1.0 0.00e+00 0.0 1.7e+04 3.4e+02 2.2e+01  0  0  2  0  2   0  0  2  0  2     0
  SA: col data         4 1.0 1.4677e-03 1.1 0.00e+00 0.0 3.8e+03 8.2e+02 2.4e+01  0  0  0  0  2   0  0  0  0  3     0
  SA: frmProl0         4 1.0 4.5345e-03 1.0 0.00e+00 0.0 4.9e+03 9.5e+01 4.0e+01  0  0  1  0  4   0  0  1  0  4     0
  SA: smooth           4 1.0 1.4497e-01 1.0 2.49e+07 1.5 8.0e+04 8.2e+02 1.9e+02  1  3  9  1 17   4  3  9  2 20  8021
GAMG: partLevel        4 1.0 2.8946e+00 1.0 6.50e+08 2.6 6.1e+04 4.9e+04 1.7e+02 16 53  7 65 16  75 53  7 80 18  8438
  repartition          2 1.0 3.2711e-04 1.1 0.00e+00 0.0 0.0e+00 0.0e+00 1.2e+01  0  0  0  0  1   0  0  0  0  1     0
  Invert-Sort          2 1.0 4.0507e-04 1.2 0.00e+00 0.0 0.0e+00 0.0e+00 8.0e+00  0  0  0  0  1   0  0  0  0  1     0
  Move A               2 1.0 2.5859e-03 1.5 0.00e+00 0.0 3.1e+02 2.0e+03 3.6e+01  0  0  0  0  3   0  0  0  0  4     0
  Move P               2 1.0 2.9900e-03 1.4 0.00e+00 0.0 4.5e+02 1.0e+02 3.6e+01  0  0  0  0  3   0  0  0  0  4     0
PCSetUp                5 1.0 3.3360e+00 1.0 6.75e+08 2.5 1.8e+05 1.7e+04 6.2e+02 18 56 20 68 58  87 56 22 83 66  7714
PCSetUpOnBlocks      129 1.0 2.3839e-03 1.2 3.40e+05 1.1 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0  7488
PCApply               17 1.0 3.5413e+00 1.0 1.01e+09 1.8 8.2e+05 4.5e+03 6.5e+02 19 95 88 80 60  92 95 97 99 68 12428
KSPGMRESOrthog        96 1.0 2.6282e-02 2.8 1.51e+07 1.0 0.0e+00 0.0e+00 9.6e+01  0  2  0  0  9   0  2  0  0 10 31445
KSPSetUp              18 1.0 7.0262e-04 1.4 0.00e+00 0.0 0.0e+00 0.0e+00 8.0e+00  0  0  0  0  1   0  0  0  0  1     0
KSPSolve               1 1.0 3.6885e+00 1.0 1.03e+09 1.8 8.4e+05 4.4e+03 8.7e+02 20 97 91 81 81  96 97 99 99 92 12218
SFSetGraph             4 1.0 1.6308e-04 3.3 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
SFBcastBegin          27 1.0 2.0990e-03 2.8 0.00e+00 0.0 1.9e+04 4.4e+02 5.0e+00  0  0  2  0  0   0  0  2  0  1     0
SFBcastEnd            27 1.0 7.8893e-04 3.8 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
              Viewer     1              0            0     0.
           Index Set   213            220     22661528     0.
   IS L to G Mapping     3              3     12801292     0.
              Vector    15            141     11422112     0.
      Vector Scatter     2             15       498936     0.
              Matrix     0             52     15514332     0.
           Index Set   102             88       158676     0.
              Vector   356            218      2450960     0.
      Vector Scatter    40             21        23040     0.
              Matrix   145             80     29369344     0.
Average time for MPI_Barrier(): 9.44138e-06
Average time for zero size MPI_Send(): 1.28576e-06
-log_summary
 gamg 40 1
Discretization: RT
MPI processes 64: solving...
((17544, 1161600), (17544, 1161600))
	Solver time: 3.773817e+00
	Solver iterations: 16
Darcy_FE.py on a arch-linux2-c-opt named wf153.localdomain with 64 processors, by jychang48 Wed Mar  2 18:03:15 2016
Time (sec):           1.874e+01      1.00026   1.873e+01
Objects:              1.130e+03      1.16495   9.868e+02
Flops:                9.997e+08      2.24666   6.960e+08  4.454e+10
Flops/sec:            5.336e+07      2.24622   3.715e+07  2.378e+09
MPI Messages:         2.500e+04      2.38812   1.814e+04  1.161e+06
MPI Message Lengths:  2.334e+08      8.33714   4.205e+03  4.883e+09
MPI Reductions:       1.081e+03      1.00000
 0:      Main Stage: 1.4959e+01  79.9%  0.0000e+00   0.0%  1.007e+05   8.7%  7.457e+02       17.7%  1.250e+02  11.6%
 1:             FEM: 3.7738e+00  20.1%  4.4543e+10 100.0%  1.061e+06  91.3%  3.459e+03       82.3%  9.550e+02  88.3%
Phase summary info:
BuildTwoSided         44 1.0 1.2383e+0012.0 0.00e+00 0.0 2.4e+04 4.0e+00 4.4e+01  6  0  2  0  4   8  0 24  0 35     0
VecScatterBegin        2 1.0 1.9073e-05 1.5 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecScatterEnd          2 1.0 7.1526e-06 3.8 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
Mesh Partition         2 1.0 2.2405e+00 1.1 0.00e+00 0.0 4.4e+04 1.8e+03 2.1e+01 12  0  4  2  2  15  0 44  9 17     0
Mesh Migration         2 1.0 3.9701e-01 1.0 0.00e+00 0.0 4.9e+04 1.4e+04 5.4e+01  2  0  4 14  5   3  0 48 79 43     0
DMPlexInterp           1 1.0 2.1140e+0062441.5 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
DMPlexDistribute       1 1.0 2.5115e+00 1.1 0.00e+00 0.0 3.3e+04 1.0e+04 2.5e+01 13  0  3  7  2  17  0 33 38 20     0
DMPlexDistCones        2 1.0 9.2092e-02 1.2 0.00e+00 0.0 7.2e+03 3.1e+04 4.0e+00  0  0  1  5  0   1  0  7 26  3     0
DMPlexDistLabels       2 1.0 2.6102e-01 1.0 0.00e+00 0.0 2.9e+04 1.3e+04 2.2e+01  1  0  3  8  2   2  0 29 45 18     0
DMPlexDistribOL        1 1.0 1.4294e-01 1.1 0.00e+00 0.0 6.1e+04 8.0e+03 5.0e+01  1  0  5 10  5   1  0 60 56 40     0
DMPlexDistField        3 1.0 3.2045e-02 2.3 0.00e+00 0.0 9.7e+03 3.4e+03 1.2e+01  0  0  1  1  1   0  0 10  4 10     0
DMPlexDistData         2 1.0 1.0870e+0055.1 0.00e+00 0.0 3.5e+04 1.0e+03 6.0e+00  6  0  3  1  1   7  0 35  4  5     0
DMPlexStratify         6 1.5 5.4254e-0157.1 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
SFSetGraph            51 1.0 2.8019e-02 1.6 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
SFBcastBegin          95 1.0 1.2455e+00 4.0 0.00e+00 0.0 9.7e+04 8.7e+03 4.1e+01  6  0  8 17  4   8  0 96 97 33     0
SFBcastEnd            95 1.0 3.0168e-0110.2 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  1  0  0  0  0   2  0  0  0  0     0
SFReduceBegin          4 1.0 9.6369e-0322.3 0.00e+00 0.0 2.9e+03 5.8e+03 3.0e+00  0  0  0  0  0   0  0  3  2  2     0
SFReduceEnd            4 1.0 9.7442e-03 8.4 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
SFFetchOpBegin         1 1.0 3.6001e-0516.8 0.00e+00 0.0 3.2e+02 1.3e+03 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
SFFetchOpEnd           1 1.0 1.6093e-04 4.6 0.00e+00 0.0 3.2e+02 1.3e+03 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
BuildTwoSided         17 1.0 2.0092e-03 4.2 0.00e+00 0.0 2.9e+03 4.0e+00 1.7e+01  0  0  0  0  2   0  0  0  0  2     0
BuildTwoSidedF        12 1.0 4.2796e-04 1.4 0.00e+00 0.0 0.0e+00 0.0e+00 1.2e+01  0  0  0  0  1   0  0  0  0  1     0
VecMDot               96 1.0 2.3543e-02 5.1 6.61e+06 1.1 0.0e+00 0.0e+00 9.6e+01  0  1  0  0  9   0  1  0  0 10 17550
VecNorm              105 1.0 1.2387e-02 5.0 9.42e+05 1.0 0.0e+00 0.0e+00 1.0e+02  0  0  0  0 10   0  0  0  0 11  4759
VecScale             217 1.0 1.4968e-03 1.4 1.26e+06 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0 52895
VecCopy               77 1.0 3.4785e-04 1.4 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecSet               596 1.0 2.5966e-03 1.2 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecAXPY                9 1.0 7.5102e-05 1.4 6.53e+04 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0 54480
VecAYPX              544 1.0 1.8840e-03 1.5 1.19e+06 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0 39891
VecAXPBYCZ           272 1.0 1.1594e-03 1.5 2.37e+06 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0 129640
VecMAXPY             105 1.0 1.9822e-03 1.1 7.49e+06 1.1 0.0e+00 0.0e+00 0.0e+00  0  1  0  0  0   0  1  0  0  0 236134
VecAssemblyBegin      14 1.0 5.4741e-04 1.3 0.00e+00 0.0 0.0e+00 0.0e+00 1.2e+01  0  0  0  0  1   0  0  0  0  1     0
VecAssemblyEnd        14 1.0 7.1526e-05 1.6 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecPointwiseMult      44 1.0 1.6665e-04 1.5 7.68e+04 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0 29180
VecScatterBegin      988 1.0 3.0876e-02 2.5 0.00e+00 0.0 9.0e+05 8.2e+02 0.0e+00  0  0 78 15  0   1  0 85 18  0     0
VecScatterEnd        988 1.0 9.7675e-02 4.1 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   2  0  0  0  0     0
VecSetRandom           4 1.0 3.1018e-04 1.1 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecNormalize         105 1.0 1.3980e-02 3.5 1.41e+06 1.0 0.0e+00 0.0e+00 1.0e+02  0  0  0  0 10   0  0  0  0 11  6325
MatMult              521 1.0 2.2436e-01 1.2 2.57e+08 1.8 7.9e+05 8.8e+02 1.3e+02  1 28 68 14 12   5 28 75 17 14 55789
MatMultAdd           227 1.0 3.2643e-02 1.8 1.14e+07 1.2 6.5e+04 5.4e+02 0.0e+00  0  2  6  1  0   1  2  6  1  0 20795
MatMultTranspose      68 1.0 1.7001e-02 2.5 5.40e+06 1.4 4.6e+04 2.7e+02 0.0e+00  0  1  4  0  0   0  1  4  0  0 17550
MatSolve             129 1.2 2.5924e-02 1.2 1.76e+07 1.1 0.0e+00 0.0e+00 0.0e+00  0  2  0  0  0   1  2  0  0  0 41475
MatSOR               452 1.0 7.1886e-02 1.3 9.34e+07 1.3 0.0e+00 0.0e+00 0.0e+00  0 12  0  0  0   2 12  0  0  0 74824
MatLUFactorSym         1 1.0 3.0994e-05 3.9 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatLUFactorNum         2 1.0 1.1089e-03 1.1 2.96e+05 1.1 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0 16070
MatILUFactorSym        1 1.0 7.7200e-04 1.8 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatConvert             5 1.0 6.6314e-03 2.8 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatScale              14 1.0 4.2133e-03 2.7 2.33e+06 1.7 6.3e+03 8.7e+02 0.0e+00  0  0  1  0  0   0  0  1  0  0 27151
MatResidual           68 1.0 2.6713e-02 1.2 3.27e+07 1.9 1.1e+05 8.7e+02 0.0e+00  0  3  9  2  0   1  3 10  2  0 58240
MatAssemblyBegin      93 1.0 4.7054e-01 4.1 0.00e+00 0.0 2.2e+04 7.8e+04 5.8e+01  2  0  2 36  5   9  0  2 44  6     0
MatAssemblyEnd        93 1.0 8.0991e-01 1.2 0.00e+00 0.0 4.6e+04 1.2e+02 2.2e+02  4  0  4  0 20  21  0  4  0 23     0
MatGetRow          32943 1.0 1.2840e-01 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  1  0  0  0  0   3  0  0  0  0     0
MatGetRowIJ            2 2.0 6.9141e-06 7.2 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatGetSubMatrix        8 1.0 4.1435e-03 1.0 0.00e+00 0.0 8.6e+02 6.5e+02 7.4e+01  0  0  0  0  7   0  0  0  0  8     0
MatGetOrdering         2 2.0 8.7023e-05 1.7 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatCoarsen             4 1.0 2.1451e-03 1.0 0.00e+00 0.0 2.2e+04 2.9e+02 2.5e+01  0  0  2  0  2   0  0  2  0  3     0
MatZeroEntries         4 1.0 2.5702e-03 3.7 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatAXPY                5 1.0 1.5406e-01 1.0 0.00e+00 0.0 1.2e+03 2.2e+02 2.0e+01  1  0  0  0  2   4  0  0  0  2     0
MatMatMult             5 1.0 5.2665e-02 1.0 2.08e+06 1.8 4.0e+04 4.6e+02 8.0e+01  0  0  3  0  7   1  0  4  0  8  1926
MatMatMultSym          5 1.0 4.6258e-02 1.0 0.00e+00 0.0 3.4e+04 3.7e+02 7.0e+01  0  0  3  0  6   1  0  3  0  7     0
MatMatMultNum          5 1.0 6.3677e-03 1.0 2.08e+06 1.8 6.6e+03 9.2e+02 1.0e+01  0  0  1  0  1   0  0  1  0  1 15926
MatPtAP                4 1.0 2.8912e+00 1.0 6.30e+08 3.8 7.6e+04 4.2e+04 6.8e+01 15 52  7 66  6  77 52  7 80  7  7999
MatPtAPSymbolic        4 1.0 1.5281e+00 1.0 0.00e+00 0.0 3.8e+04 3.9e+04 2.8e+01  8  0  3 30  3  40  0  4 36  3     0
MatPtAPNumeric         4 1.0 1.3641e+00 1.0 6.30e+08 3.8 3.8e+04 4.6e+04 4.0e+01  7 52  3 36  4  36 52  4 44  4 16954
MatTrnMatMult          1 1.0 1.1292e-02 1.0 3.14e+05 1.1 3.7e+03 1.4e+03 1.9e+01  0  0  0  0  2   0  0  0  0  2  1728
MatTrnMatMultSym       1 1.0 7.5750e-03 1.0 0.00e+00 0.0 3.1e+03 7.8e+02 1.7e+01  0  0  0  0  2   0  0  0  0  2     0
MatTrnMatMultNum       1 1.0 3.7148e-03 1.0 3.14e+05 1.1 6.1e+02 4.3e+03 2.0e+00  0  0  0  0  0   0  0  0  0  0  5254
MatGetLocalMat        16 1.0 2.3561e-03 1.1 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatGetBrAoCol         14 1.0 5.9310e-02 1.7 0.00e+00 0.0 4.5e+04 2.3e+04 0.0e+00  0  0  4 21  0   1  0  4 26  0     0
PCGAMGGraph_AGG        4 1.0 1.2765e-01 1.0 1.93e+06 1.9 1.1e+04 5.6e+02 4.8e+01  1  0  1  0  4   3  0  1  0  5   717
PCGAMGCoarse_AGG       4 1.0 1.5398e-02 1.0 3.14e+05 1.1 2.9e+04 5.6e+02 5.2e+01  0  0  3  0  5   0  0  3  0  5  1268
PCGAMGProl_AGG         4 1.0 6.5541e-03 1.0 0.00e+00 0.0 1.0e+04 3.8e+02 8.0e+01  0  0  1  0  7   0  0  1  0  8     0
PCGAMGPOpt_AGG         4 1.0 1.2338e-01 1.0 2.34e+07 1.8 1.0e+05 7.1e+02 1.9e+02  1  3  9  1 17   3  3 10  2 20  9290
GAMG: createProl       4 1.0 2.7354e-01 1.0 2.57e+07 1.8 1.5e+05 6.5e+02 3.7e+02  1  3 13  2 34   7  3 14  2 39  4596
  Graph                8 1.0 1.2751e-01 1.0 1.93e+06 1.9 1.1e+04 5.6e+02 4.8e+01  1  0  1  0  4   3  0  1  0  5   718
  MIS/Agg              4 1.0 2.1992e-03 1.0 0.00e+00 0.0 2.2e+04 2.9e+02 2.5e+01  0  0  2  0  2   0  0  2  0  3     0
  SA: col data         4 1.0 1.3566e-03 1.1 0.00e+00 0.0 4.5e+03 7.5e+02 2.4e+01  0  0  0  0  2   0  0  0  0  3     0
  SA: frmProl0         4 1.0 4.7398e-03 1.0 0.00e+00 0.0 5.6e+03 8.8e+01 4.0e+01  0  0  0  0  4   0  0  1  0  4     0
  SA: smooth           4 1.0 1.2335e-01 1.0 2.34e+07 1.8 1.0e+05 7.1e+02 1.9e+02  1  3  9  1 17   3  3 10  2 20  9292
GAMG: partLevel        4 1.0 2.8968e+00 1.0 6.30e+08 3.8 7.8e+04 4.1e+04 1.7e+02 15 52  7 66 16  77 52  7 80 18  7984
  repartition          2 1.0 3.7479e-04 1.1 0.00e+00 0.0 0.0e+00 0.0e+00 1.2e+01  0  0  0  0  1   0  0  0  0  1     0
  Invert-Sort          2 1.0 4.2200e-04 1.2 0.00e+00 0.0 0.0e+00 0.0e+00 8.0e+00  0  0  0  0  1   0  0  0  0  1     0
  Move A               2 1.0 2.3668e-03 1.5 0.00e+00 0.0 3.5e+02 1.4e+03 3.6e+01  0  0  0  0  3   0  0  0  0  4     0
  Move P               2 1.0 2.7559e-03 1.4 0.00e+00 0.0 5.1e+02 9.7e+01 3.6e+01  0  0  0  0  3   0  0  0  0  4     0
PCSetUp                5 1.0 3.2839e+00 1.0 6.53e+08 3.6 2.3e+05 1.4e+04 6.3e+02 18 55 20 68 58  87 55 22 83 66  7435
PCSetUpOnBlocks      129 1.0 2.1794e-03 1.3 2.96e+05 1.1 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0  8177
PCApply               17 1.0 3.4818e+00 1.0 9.60e+08 2.3 1.0e+06 3.8e+03 6.5e+02 19 95 89 81 60  92 95 97 99 68 12115
KSPGMRESOrthog        96 1.0 2.5954e-02 3.6 1.32e+07 1.1 0.0e+00 0.0e+00 9.6e+01  0  2  0  0  9   0  2  0  0 10 31841
KSPSetUp              18 1.0 7.0524e-04 1.4 0.00e+00 0.0 0.0e+00 0.0e+00 8.0e+00  0  0  0  0  1   0  0  0  0  1     0
KSPSolve               1 1.0 3.6077e+00 1.0 9.76e+08 2.3 1.1e+06 3.8e+03 8.8e+02 19 97 91 82 81  96 97100 99 92 11984
SFSetGraph             4 1.0 1.5688e-04 3.4 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
SFBcastBegin          30 1.0 2.1074e-03 2.9 0.00e+00 0.0 2.4e+04 3.8e+02 5.0e+00  0  0  2  0  0   0  0  2  0  1     0
SFBcastEnd            30 1.0 1.0002e-03 5.8 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
              Viewer     1              0            0     0.
           Index Set   227            234     22508856     0.
   IS L to G Mapping     3              3     12541056     0.
              Vector    15            141     10638768     0.
      Vector Scatter     2             15       437496     0.
              Matrix     0             52     12578516     0.
           Index Set   102             88       152948     0.
              Vector   356            218      2199448     0.
              Matrix   145             80     23656560     0.
Average time for MPI_Barrier(): 8.63075e-06
Average time for zero size MPI_Send(): 1.65775e-06
-log_summary
 hypre 40 1
Discretization: RT
MPI processes 1: solving...
((1161600, 1161600), (1161600, 1161600))
	Solver time: 4.842733e+01
	Solver iterations: 12
Darcy_FE.py on a arch-linux2-c-opt named wf153.localdomain with 1 processor, by jychang48 Wed Mar  2 17:34:27 2016
Time (sec):           6.507e+01      1.00000   6.507e+01
Objects:              2.470e+02      1.00000   2.470e+02
Flops:                1.711e+09      1.00000   1.711e+09  1.711e+09
Flops/sec:            2.630e+07      1.00000   2.630e+07  2.630e+07
MPI Messages:         0.000e+00      0.00000   0.000e+00  0.000e+00
MPI Message Lengths:  0.000e+00      0.00000   0.000e+00  0.000e+00
MPI Reductions:       0.000e+00      0.00000
 0:      Main Stage: 1.6646e+01  25.6%  0.0000e+00   0.0%  0.000e+00   0.0%  0.000e+00        0.0%  0.000e+00   0.0%
 1:             FEM: 4.8427e+01  74.4%  1.7111e+09 100.0%  0.000e+00   0.0%  0.000e+00        0.0%  0.000e+00   0.0%
Phase summary info:
VecSet                 8 1.0 1.5751e-02 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecScatterBegin        2 1.0 3.6759e-03 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
DMPlexInterp           1 1.0 2.1008e+00 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  3  0  0  0  0  13  0  0  0  0     0
DMPlexStratify         4 1.0 5.1098e-01 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  1  0  0  0  0   3  0  0  0  0     0
SFSetGraph             7 1.0 2.6133e-02 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecMDot               12 1.0 6.1646e-02 1.0 1.81e+08 1.0 0.0e+00 0.0e+00 0.0e+00  0 11  0  0  0   0 11  0  0  0  2939
VecNorm               13 1.0 1.5800e-02 1.0 3.02e+07 1.0 0.0e+00 0.0e+00 0.0e+00  0  2  0  0  0   0  2  0  0  0  1911
VecScale              26 1.0 1.6351e-02 1.0 2.52e+07 1.0 0.0e+00 0.0e+00 0.0e+00  0  1  0  0  0   0  1  0  0  0  1542
VecCopy                1 1.0 2.6531e-03 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecSet               104 1.0 1.5827e-01 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecAXPY                1 1.0 1.4691e-03 1.0 2.32e+06 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0  1581
VecMAXPY              13 1.0 7.4229e-02 1.0 2.09e+08 1.0 0.0e+00 0.0e+00 0.0e+00  0 12  0  0  0   0 12  0  0  0  2817
VecScatterBegin       58 1.0 6.3398e-02 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecNormalize          13 1.0 2.4897e-02 1.0 4.53e+07 1.0 0.0e+00 0.0e+00 0.0e+00  0  3  0  0  0   0  3  0  0  0  1820
MatMult               25 1.0 2.4851e-01 1.0 2.70e+08 1.0 0.0e+00 0.0e+00 0.0e+00  0 16  0  0  0   1 16  0  0  0  1088
MatMultAdd            48 1.0 1.8471e-01 1.0 2.31e+08 1.0 0.0e+00 0.0e+00 0.0e+00  0 13  0  0  0   0 13  0  0  0  1249
MatSolve              13 1.0 1.4378e-01 1.0 1.30e+08 1.0 0.0e+00 0.0e+00 0.0e+00  0  8  0  0  0   0  8  0  0  0   904
MatLUFactorNum         1 1.0 6.5479e-02 1.0 1.81e+07 1.0 0.0e+00 0.0e+00 0.0e+00  0  1  0  0  0   0  1  0  0  0   276
MatILUFactorSym        1 1.0 4.7690e-02 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatConvert             2 1.0 4.4951e-02 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatScale               2 1.0 8.9600e-03 1.0 5.34e+06 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0   596
MatAssemblyBegin      10 1.0 4.7684e-06 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatAssemblyEnd        10 1.0 9.9671e-02 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatGetRow         768000 1.0 4.7885e-01 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  1  0  0  0  0   1  0  0  0  0     0
MatGetRowIJ            2 1.0 2.8610e-06 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatGetSubMatrix        4 1.0 4.8168e-02 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatGetOrdering         1 1.0 2.9769e-03 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatAXPY                1 1.0 1.0544e+00 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  2  0  0  0  0   2  0  0  0  0     0
MatMatMult             1 1.0 1.2049e-01 1.0 1.33e+07 1.0 0.0e+00 0.0e+00 0.0e+00  0  1  0  0  0   0  1  0  0  0   111
MatMatMultSym          1 1.0 8.2528e-02 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatMatMultNum          1 1.0 3.7939e-02 1.0 1.33e+07 1.0 0.0e+00 0.0e+00 0.0e+00  0  1  0  0  0   0  1  0  0  0   351
PCSetUp                4 1.0 2.7671e+01 1.0 3.68e+07 1.0 0.0e+00 0.0e+00 0.0e+00 43  2  0  0  0  57  2  0  0  0     1
PCSetUpOnBlocks       13 1.0 1.1621e-01 1.0 1.81e+07 1.0 0.0e+00 0.0e+00 0.0e+00  0  1  0  0  0   0  1  0  0  0   156
PCApply               13 1.0 4.5220e+01 1.0 1.98e+08 1.0 0.0e+00 0.0e+00 0.0e+00 69 12  0  0  0  93 12  0  0  0     4
KSPGMRESOrthog        12 1.0 1.2641e-01 1.0 3.62e+08 1.0 0.0e+00 0.0e+00 0.0e+00  0 21  0  0  0   0 21  0  0  0  2867
KSPSetUp               4 1.0 2.3469e-02 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
KSPSolve               1 1.0 4.6958e+01 1.0 8.85e+08 1.0 0.0e+00 0.0e+00 0.0e+00 72 52  0  0  0  97 52  0  0  0    19
--- Event Stage 0: Main Stage
              Viewer     1              0            0     0.
           Index Set    22             22     38639672     0.
             Section    26              8         5376     0.
              Vector    13             31    178264920     0.
      Vector Scatter     2              6         3984     0.
              Matrix     0              3    124219284     0.
      Preconditioner     0              5         5176     0.
       Krylov Solver     0              5        23264     0.
    Distributed Mesh    10              4        19256     0.
    GraphPartitioner     4              3         1836     0.
Star Forest Bipartite Graph    23             12         9696     0.
     Discrete System    10              4         3456     0.
--- Event Stage 1: FEM
           Index Set    19             12         9408     0.
              Vector    79             52     21737472     0.
      Vector Scatter     6              0            0     0.
              Matrix    10              2     37023836     0.
      Preconditioner     6              1         1016     0.
       Krylov Solver     6              1         1352     0.
-log_summary
-solver_fieldsplit_1_pc_type hypre
 hypre 40 1
Discretization: RT
MPI processes 2: solving...
((579051, 1161600), (579051, 1161600))
	Solver time: 3.476467e+01
	Solver iterations: 15
***             WIDEN YOUR WINDOW TO 120 CHARACTERS.  Use 'enscript -r -fCourier9' to print this document            ***
---------------------------------------------- PETSc Performance Summary: ----------------------------------------------
Darcy_FE.py on a arch-linux2-c-opt named wf153.localdomain with 2 processors, by jychang48 Wed Mar  2 17:35:18 2016
Using Petsc Development GIT revision: v3.6.3-1924-ge972cd5  GIT Date: 2016-01-01 10:01:13 -0600
                         Max       Max/Min        Avg      Total
Time (sec):           4.903e+01      1.00022   4.903e+01
Objects:              4.840e+02      1.02979   4.770e+02
Flops:                1.033e+09      1.00377   1.031e+09  2.063e+09
Flops/sec:            2.108e+07      1.00400   2.104e+07  4.207e+07
MPI Messages:         3.485e+02      1.24687   3.140e+02  6.280e+02
MPI Message Lengths:  4.050e+08      1.62105   1.043e+06  6.549e+08
MPI Reductions:       4.220e+02      1.00000
Flop counting convention: 1 flop = 1 real number operation of type (multiply/divide/add/subtract)
                            e.g., VecAXPY() for real vectors of length N --> 2N flops
                            and VecAXPY() for complex vectors of length N --> 8N flops
Summary of Stages:   ----- Time ------  ----- Flops -----  --- Messages ---  -- Message Lengths --  -- Reductions --
                        Avg     %Total     Avg     %Total   counts   %Total     Avg         %Total   counts   %Total
 0:      Main Stage: 1.4264e+01  29.1%  0.0000e+00   0.0%  5.020e+02  79.9%  9.935e+05       95.3%  1.250e+02  29.6%
 1:             FEM: 3.4765e+01  70.9%  2.0627e+09 100.0%  1.260e+02  20.1%  4.932e+04        4.7%  2.960e+02  70.1%
See the 'Profiling' chapter of the users' manual for details on interpreting output.
Phase summary info:
   Count: number of times phase was executed
   Time and Flops: Max - maximum over all processors
                   Ratio - ratio of maximum to minimum over all processors
   Mess: number of messages sent
   Avg. len: average message length (bytes)
   Reduct: number of global reductions
   Global: entire computation
   Stage: stages of a computation. Set stages with PetscLogStagePush() and PetscLogStagePop().
      %T - percent time in this phase         %F - percent flops in this phase
      %M - percent messages in this phase     %L - percent message lengths in this phase
      %R - percent reductions in this phase
   Total Mflop/s: 10e-6 * (sum of flops over all processors)/(max time over all processors)
Event                Count      Time (sec)     Flops                             --- Global ---  --- Stage ---   Total
                   Max Ratio  Max     Ratio   Max  Ratio  Mess   Avg len Reduct  %T %F %M %L %R  %T %F %M %L %R Mflop/s
BuildTwoSided         44 1.0 8.3311e-01 9.6 0.00e+00 0.0 1.2e+02 4.0e+00 4.4e+01  1  0 19  0 10   3  0 24  0 35     0
VecScatterBegin        2 1.0 1.6110e-03 1.5 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecScatterEnd          2 1.0 1.9073e-06 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
Mesh Partition         2 1.0 1.6245e+00 1.1 0.00e+00 0.0 9.2e+01 5.5e+05 2.1e+01  3  0 15  8  5  11  0 18  8 17     0
Mesh Migration         2 1.0 1.7902e+00 1.0 0.00e+00 0.0 3.7e+02 1.4e+06 5.4e+01  4  0 60 79 13  13  0 75 83 43     0
DMPlexInterp           1 1.0 2.0429e+0045337.1 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  2  0  0  0  0   7  0  0  0  0     0
DMPlexDistribute       1 1.0 2.2455e+00 1.1 0.00e+00 0.0 1.7e+02 1.9e+06 2.5e+01  4  0 26 48  6  15  0 33 50 20     0
DMPlexDistCones        2 1.0 3.6353e-01 1.0 0.00e+00 0.0 5.4e+01 3.2e+06 4.0e+00  1  0  9 27  1   3  0 11 28  3     0
DMPlexDistLabels       2 1.0 9.6565e-01 1.0 0.00e+00 0.0 2.4e+02 1.2e+06 2.2e+01  2  0 38 45  5   7  0 48 47 18     0
DMPlexDistribOL        1 1.0 1.1889e+00 1.0 0.00e+00 0.0 3.1e+02 9.6e+05 5.0e+01  2  0 49 45 12   8  0 61 48 40     0
DMPlexDistField        3 1.0 4.3184e-02 1.1 0.00e+00 0.0 6.2e+01 3.5e+05 1.2e+01  0  0 10  3  3   0  0 12  3 10     0
DMPlexDistData         2 1.0 8.3491e-0126.1 0.00e+00 0.0 5.4e+01 4.0e+05 6.0e+00  1  0  9  3  1   3  0 11  3  5     0
DMPlexStratify         6 1.5 7.6915e-01 2.9 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  1  0  0  0  0   4  0  0  0  0     0
SFSetGraph            51 1.0 4.2324e-01 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  1  0  0  0  0   3  0  0  0  0     0
SFBcastBegin          95 1.0 9.3474e-01 3.1 0.00e+00 0.0 4.8e+02 1.2e+06 4.1e+01  1  0 77 92 10   4  0 96 96 33     0
SFBcastEnd            95 1.0 4.0109e-01 2.3 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  1  0  0  0  0   2  0  0  0  0     0
SFReduceBegin          4 1.0 3.5613e-03 1.4 0.00e+00 0.0 1.1e+01 1.3e+06 3.0e+00  0  0  2  2  1   0  0  2  2  2     0
SFReduceEnd            4 1.0 5.1992e-03 1.2 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
SFFetchOpBegin         1 1.0 3.0994e-05 6.2 0.00e+00 0.0 1.0e+00 4.2e+04 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
SFFetchOpEnd           1 1.0 9.9111e-04 6.3 0.00e+00 0.0 1.0e+00 4.2e+04 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
BuildTwoSided          1 1.0 1.8351e-03108.4 0.00e+00 0.0 2.0e+00 4.0e+00 1.0e+00  0  0  0  0  0   0  0  2  0  0     0
VecMDot               15 1.0 4.5149e-02 1.0 1.40e+08 1.0 0.0e+00 0.0e+00 1.5e+01  0 14  0  0  4   0 14  0  0  5  6175
VecNorm               16 1.0 1.0752e-02 1.2 1.86e+07 1.0 0.0e+00 0.0e+00 1.6e+01  0  2  0  0  4   0  2  0  0  5  3457
VecScale              32 1.0 9.4597e-03 1.0 1.56e+07 1.0 0.0e+00 0.0e+00 0.0e+00  0  2  0  0  0   0  2  0  0  0  3280
VecCopy                1 1.0 1.1580e-03 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecSet               104 1.0 3.4921e-02 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecAXPY                1 1.0 6.0606e-04 1.0 1.17e+06 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0  3833
VecMAXPY              16 1.0 5.1952e-02 1.0 1.57e+08 1.0 0.0e+00 0.0e+00 0.0e+00  0 15  0  0  0   0 15  0  0  0  6037
VecScatterBegin      146 1.0 3.5844e-02 1.0 0.00e+00 0.0 7.6e+01 3.4e+04 0.0e+00  0  0 12  0  0   0  0 60  8  0     0
VecScatterEnd        146 1.0 2.1336e-03 1.2 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecNormalize          16 1.0 1.6374e-02 1.1 2.80e+07 1.0 0.0e+00 0.0e+00 1.6e+01  0  3  0  0  4   0  3  0  0  5  3405
MatMult               31 1.0 1.5530e-01 1.0 1.69e+08 1.0 7.6e+01 3.4e+04 1.2e+02  0 16 12  0 28   0 16 60  8 41  2172
MatMultAdd            60 1.0 1.1559e-01 1.0 1.45e+08 1.0 6.0e+01 3.6e+04 0.0e+00  0 14 10  0  0   0 14 48  7  0  2494
MatSolve              16 1.0 9.8875e-02 1.0 8.00e+07 1.0 0.0e+00 0.0e+00 0.0e+00  0  8  0  0  0   0  8  0  0  0  1611
MatLUFactorNum         1 1.0 3.3598e-02 1.0 9.09e+06 1.0 0.0e+00 0.0e+00 0.0e+00  0  1  0  0  0   0  1  0  0  0   538
MatILUFactorSym        1 1.0 2.3966e-02 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatConvert             2 1.0 2.4728e-02 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatScale               2 1.0 3.5920e-03 1.0 2.67e+06 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0  1485
MatAssemblyBegin      12 1.0 5.8002e-0312.5 0.00e+00 0.0 0.0e+00 0.0e+00 6.0e+00  0  0  0  0  1   0  0  0  0  2     0
MatAssemblyEnd        12 1.0 9.0917e-02 1.0 0.00e+00 0.0 1.6e+01 7.8e+03 4.8e+01  0  0  3  0 11   0  0 13  0 16     0
MatGetRow         384000 1.0 3.7148e-01 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  1  0  0  0  0   1  0  0  0  0     0
MatGetRowIJ            3 1.0 3.0994e-06 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatGetSubMatrix        4 1.0 2.1708e-02 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 6.0e+00  0  0  0  0  1   0  0  0  0  2     0
MatGetOrdering         1 1.0 1.4248e-03 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatAXPY                1 1.0 7.6908e-01 1.0 0.00e+00 0.0 4.0e+00 6.7e+03 1.2e+01  2  0  1  0  3   2  0  3  0  4     0
MatMatMult             1 1.0 1.4067e-01 1.0 4.95e+06 1.0 8.0e+00 2.2e+04 1.6e+01  0  0  1  0  4   0  0  6  1  5    70
MatMatMultSym          1 1.0 1.2321e-01 1.0 0.00e+00 0.0 7.0e+00 1.8e+04 1.4e+01  0  0  1  0  3   0  0  6  0  5     0
MatMatMultNum          1 1.0 1.7438e-02 1.0 4.95e+06 1.0 1.0e+00 5.5e+04 2.0e+00  0  0  0  0  0   0  0  1  0  1   568
MatGetLocalMat         2 1.0 2.2079e-02 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatGetBrAoCol          2 1.0 1.1523e-03 1.5 0.00e+00 0.0 4.0e+00 3.8e+04 0.0e+00  0  0  1  0  0   0  0  3  0  0     0
PCSetUp                4 1.0 2.2106e+01 1.0 1.67e+07 1.0 2.0e+01 4.7e+05 6.6e+01 45  2  3  1 16  64  2 16 31 22     2
PCSetUpOnBlocks       16 1.0 5.9039e-02 1.0 9.09e+06 1.0 0.0e+00 0.0e+00 0.0e+00  0  1  0  0  0   0  1  0  0  0   306
PCApply               16 1.0 3.2480e+01 1.0 1.20e+08 1.0 1.6e+01 2.7e+04 4.0e+00 66 12  3  0  1  93 12 13  1  1     7
KSPGMRESOrthog        15 1.0 9.1311e-02 1.0 2.80e+08 1.0 0.0e+00 0.0e+00 1.5e+01  0 27  0  0  4   0 27  0  0  5  6106
KSPSetUp               4 1.0 9.7001e-03 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
KSPSolve               1 1.0 3.3756e+01 1.0 5.98e+08 1.0 9.6e+01 1.3e+05 2.2e+02 69 58 15  2 51  97 58 76 39 73    35
SFBcastBegin           1 1.0 1.8959e-0324.3 0.00e+00 0.0 6.0e+00 4.1e+04 1.0e+00  0  0  1  0  0   0  0  5  1  0     0
SFBcastEnd             1 1.0 3.1090e-04 4.4 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
              Viewer     1              0            0     0.
           Index Set    79             79     49124340     0.
   IS L to G Mapping     3              3     23945692     0.
              Vector    15             45    140251432     0.
      Vector Scatter     2              7     13904896     0.
              Matrix     0              5     64871960     0.
           Index Set    31             24        73104     0.
              Vector   114             72     10946608     0.
      Vector Scatter    13              2         2192     0.
              Matrix    26              8     52067772     0.
      Preconditioner     6              1          896     0.
Average time for MPI_Barrier(): 1.62125e-06
Average time for zero size MPI_Send(): 2.5034e-06
-log_summary
 hypre 40 1
Discretization: RT
MPI processes 4: solving...
((288348, 1161600), (288348, 1161600))
	Solver time: 2.221880e+01
Darcy_FE.py on a arch-linux2-c-opt named wf153.localdomain with 4 processors, by jychang48 Wed Mar  2 17:35:54 2016
Time (sec):           3.523e+01      1.00003   3.523e+01
Objects:              4.920e+02      1.04237   4.775e+02
Flops:                5.295e+08      1.00702   5.270e+08  2.108e+09
Flops/sec:            1.503e+07      1.00704   1.496e+07  5.983e+07
MPI Messages:         7.315e+02      1.64938   5.530e+02  2.212e+03
MPI Message Lengths:  2.891e+08      2.21291   3.089e+05  6.833e+08
 0:      Main Stage: 1.3011e+01  36.9%  0.0000e+00   0.0%  1.654e+03  74.8%  2.935e+05       95.0%  1.250e+02  29.6%
 1:             FEM: 2.2219e+01  63.1%  2.1080e+09 100.0%  5.580e+02  25.2%  1.541e+04        5.0%  2.960e+02  70.1%
Phase summary info:
BuildTwoSided         44 1.0 9.3237e-0117.3 0.00e+00 0.0 3.9e+02 4.0e+00 4.4e+01  2  0 18  0 10   5  0 24  0 35     0
VecScatterBegin        2 1.0 7.1883e-04 1.5 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecScatterEnd          2 1.0 5.0068e-06 1.8 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
Mesh Partition         2 1.0 1.7474e+00 1.1 0.00e+00 0.0 3.8e+02 1.4e+05 2.1e+01  5  0 17  8  5  13  0 23  8 17     0
Mesh Migration         2 1.0 1.0405e+00 1.0 0.00e+00 0.0 1.1e+03 4.7e+05 5.4e+01  3  0 51 79 13   8  0 69 83 43     0
DMPlexInterp           1 1.0 2.0642e+0053115.7 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  1  0  0  0  0   4  0  0  0  0     0
DMPlexDistribute       1 1.0 2.0381e+00 1.1 0.00e+00 0.0 3.9e+02 8.1e+05 2.5e+01  6  0 18 46  6  15  0 23 49 20     0
DMPlexDistCones        2 1.0 2.3054e-01 1.0 0.00e+00 0.0 1.6e+02 1.1e+06 4.0e+00  1  0  7 26  1   2  0 10 28  3     0
DMPlexDistLabels       2 1.0 5.6307e-01 1.0 0.00e+00 0.0 7.2e+02 4.2e+05 2.2e+01  2  0 33 45  5   4  0 44 47 18     0
DMPlexDistribOL        1 1.0 7.6747e-01 1.0 0.00e+00 0.0 1.2e+03 2.8e+05 5.0e+01  2  0 52 46 12   6  0 70 49 40     0
DMPlexDistField        3 1.0 2.9449e-02 1.0 0.00e+00 0.0 2.0e+02 1.1e+05 1.2e+01  0  0  9  3  3   0  0 12  4 10     0
DMPlexDistData         2 1.0 9.2793e-0140.7 0.00e+00 0.0 2.2e+02 1.0e+05 6.0e+00  2  0 10  3  1   5  0 14  4  5     0
DMPlexStratify         6 1.5 6.5141e-01 4.8 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  1  0  0  0  0   2  0  0  0  0     0
SFSetGraph            51 1.0 2.4321e-01 1.1 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  1  0  0  0  0   2  0  0  0  0     0
SFBcastBegin          95 1.0 9.8964e-01 4.5 0.00e+00 0.0 1.6e+03 4.0e+05 4.1e+01  2  0 71 92 10   6  0 95 96 33     0
SFBcastEnd            95 1.0 3.2814e-01 2.7 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  1  0  0  0  0   2  0  0  0  0     0
SFReduceBegin          4 1.0 2.9824e-03 2.1 0.00e+00 0.0 4.9e+01 2.9e+05 3.0e+00  0  0  2  2  1   0  0  3  2  2     0
SFReduceEnd            4 1.0 6.0050e-03 2.1 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
SFFetchOpBegin         1 1.0 3.6001e-05 9.4 0.00e+00 0.0 5.0e+00 1.7e+04 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
SFFetchOpEnd           1 1.0 4.2892e-04 2.8 0.00e+00 0.0 5.0e+00 1.7e+04 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
BuildTwoSided          1 1.0 1.8361e-0391.7 0.00e+00 0.0 1.0e+01 4.0e+00 1.0e+00  0  0  0  0  0   0  0  2  0  0     0
VecMDot               15 1.0 3.0009e-02 1.2 7.01e+07 1.0 0.0e+00 0.0e+00 1.5e+01  0 13  0  0  4   0 13  0  0  5  9290
VecNorm               16 1.0 6.5994e-03 1.3 9.35e+06 1.0 0.0e+00 0.0e+00 1.6e+01  0  2  0  0  4   0  2  0  0  5  5632
VecScale              32 1.0 4.8001e-03 1.0 7.81e+06 1.0 0.0e+00 0.0e+00 0.0e+00  0  1  0  0  0   0  1  0  0  0  6464
VecCopy                1 1.0 5.7697e-04 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecSet               104 1.0 1.5269e-02 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecAXPY                1 1.0 3.2783e-04 1.0 5.84e+05 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0  7087
VecMAXPY              16 1.0 2.9337e-02 1.0 7.89e+07 1.0 0.0e+00 0.0e+00 0.0e+00  0 15  0  0  0   0 15  0  0  0 10691
VecScatterBegin      146 1.0 1.7044e-02 1.1 0.00e+00 0.0 3.8e+02 1.4e+04 0.0e+00  0  0 17  1  0   0  0 68 15  0     0
VecScatterEnd        146 1.0 1.6215e-03 1.4 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecNormalize          16 1.0 9.4516e-03 1.2 1.40e+07 1.0 0.0e+00 0.0e+00 1.6e+01  0  3  0  0  4   0  3  0  0  5  5899
MatMult               31 1.0 8.5318e-02 1.0 8.48e+07 1.0 3.8e+02 1.4e+04 1.2e+02  0 16 17  1 28   0 16 68 15 41  3953
MatMultAdd            60 1.0 6.3984e-02 1.0 7.25e+07 1.0 3.0e+02 1.4e+04 0.0e+00  0 14 14  1  0   0 14 54 13  0  4506
MatSolve              16 1.0 5.3797e-02 1.1 4.00e+07 1.0 0.0e+00 0.0e+00 0.0e+00  0  8  0  0  0   0  8  0  0  0  2948
MatLUFactorNum         1 1.0 1.7410e-02 1.0 4.57e+06 1.0 0.0e+00 0.0e+00 0.0e+00  0  1  0  0  0   0  1  0  0  0  1037
MatILUFactorSym        1 1.0 6.5880e-03 1.1 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatConvert             2 1.0 1.2823e-02 1.3 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatScale               2 1.0 1.9329e-03 1.1 1.34e+06 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0  2758
MatAssemblyBegin      12 1.0 1.0853e-0230.3 0.00e+00 0.0 0.0e+00 0.0e+00 6.0e+00  0  0  0  0  1   0  0  0  0  2     0
MatAssemblyEnd        12 1.0 4.9526e-02 1.0 0.00e+00 0.0 8.0e+01 3.1e+03 4.8e+01  0  0  4  0 11   0  0 14  1 16     0
MatGetRow         192000 1.0 3.7644e-01 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  1  0  0  0  0   2  0  0  0  0     0
MatGetRowIJ            3 1.0 5.0068e-06 1.8 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatGetSubMatrix        4 1.0 1.0573e-02 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 6.0e+00  0  0  0  0  1   0  0  0  0  2     0
MatGetOrdering         1 1.0 6.9499e-04 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatAXPY                1 1.0 7.6509e-01 1.0 0.00e+00 0.0 2.0e+01 2.7e+03 1.2e+01  2  0  1  0  3   3  0  4  0  4     0
MatMatMult             1 1.0 7.6802e-02 1.0 2.48e+06 1.0 4.0e+01 8.9e+03 1.6e+01  0  0  2  0  4   0  0  7  1  5   129
MatMatMultSym          1 1.0 6.7404e-02 1.1 0.00e+00 0.0 3.5e+01 7.0e+03 1.4e+01  0  0  2  0  3   0  0  6  1  5     0
MatMatMultNum          1 1.0 9.4151e-03 1.0 2.48e+06 1.0 5.0e+00 2.2e+04 2.0e+00  0  0  0  0  0   0  0  1  0  1  1051
MatGetLocalMat         2 1.0 1.1554e-02 1.2 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatGetBrAoCol          2 1.0 4.0152e-03 5.9 0.00e+00 0.0 2.0e+01 1.5e+04 0.0e+00  0  0  1  0  0   0  0  4  1  0     0
PCSetUp                4 1.0 1.6053e+01 1.0 8.38e+06 1.0 7.6e+01 1.3e+05 6.6e+01 46  2  3  1 16  72  2 14 28 22     2
PCSetUpOnBlocks       16 1.0 2.4721e-02 1.0 4.57e+06 1.0 0.0e+00 0.0e+00 0.0e+00  0  1  0  0  0   0  1  0  0  0   730
PCApply               16 1.0 2.0598e+01 1.0 6.00e+07 1.0 8.0e+01 1.1e+04 4.0e+00 58 11  4  0  1  93 11 14  3  1    12
KSPGMRESOrthog        15 1.0 5.6051e-02 1.1 1.40e+08 1.0 0.0e+00 0.0e+00 1.5e+01  0 26  0  0  4   0 26  0  0  5  9947
KSPSetUp               4 1.0 5.0209e-03 3.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
KSPSolve               1 1.0 2.1633e+01 1.0 3.00e+08 1.0 4.6e+02 3.3e+04 2.2e+02 61 57 21  2 51  97 57 82 44 73    55
SFBcastBegin           1 1.0 1.9069e-0318.0 0.00e+00 0.0 3.0e+01 1.7e+04 1.0e+00  0  0  1  0  0   0  0  5  1  0     0
SFBcastEnd             1 1.0 2.2197e-04 2.6 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
Memory usage is given in bytes:
Object Type          Creations   Destructions     Memory  Descendants' Mem.
Reports information only for process 0.
           Container     6              3         1728     0.
              Viewer     1              0            0     0.
           Index Set    87             87     35923148     0.
   IS L to G Mapping     3              3     18881016     0.
              Vector    15             45     72396112     0.
      Vector Scatter     2              7      6928024     0.
              Matrix     0              5     32297372     0.
           Index Set    31             24        76832     0.
   IS L to G Mapping     4              0            0     0.
              Vector   114             72      5529184     0.
              Matrix    26              8     26014168     0.
Average time for MPI_Barrier(): 1.38283e-06
Average time for zero size MPI_Send(): 1.72853e-06
#PETSc Option Table entries:
-log_summary
-solver_fieldsplit_0_ksp_type preonly
-solver_fieldsplit_0_pc_type bjacobi
-solver_fieldsplit_1_ksp_type preonly
-solver_ksp_rtol 1e-7
-solver_ksp_type gmres
-solver_pc_fieldsplit_schur_fact_type upper
-solver_pc_fieldsplit_schur_precondition selfp
-solver_pc_fieldsplit_type schur
-solver_pc_type fieldsplit
#End of PETSc Option Table entries
Compiled without FORTRAN kernels
Compiled with full precision matrices (default)
sizeof(short) 2 sizeof(int) 4 sizeof(long) 8 sizeof(void*) 8 sizeof(PetscScalar) 8 sizeof(PetscInt) 4
Configure options: --download-chaco=/users/jychang48/externalpackages/Chaco-2.2-p2.tar.gz --download-ctetgen=/users/jychang48/externalpackages/ctetgen-0.4.tar.gz --download-exodusii=/users/jychang48/externalpackages/exodus-5.24.tar.bz2 --download-fblaslapack=/users/jychang48/externalpackages/fblaslapack-3.4.2.tar.gz --download-hdf5=/users/jychang48/externalpackages/hdf5-1.8.12.tar.gz --download-hypre=/users/jychang48/externalpackages/hypre-2.10.0b-p1.tar.gz --download-metis=/users/jychang48/externalpackages/metis-5.1.0-p1.tar.gz --download-ml=/users/jychang48/externalpackages/ml-6.2-p3.tar.gz --download-mumps=/users/jychang48/externalpackages/MUMPS_5.0.1-p1.tar.gz --download-netcdf=/users/jychang48/externalpackages/netcdf-4.3.2.tar.gz --download-parmetis=/users/jychang48/externalpackages/parmetis-4.0.3-p2.tar.gz --download-scalapack=/users/jychang48/externalpackages/scalapack-2.0.2.tgz --download-superlu_dist --download-triangle=/users/jychang48/externalpackages/Triangle.tar.gz --with-cc=mpicc --with-cxx=mpicxx --with-debugging=0 --with-fc=mpif90 --with-papi=/usr/projects/hpcsoft/toss2/common/papi/5.4.1 --with-shared-libraries COPTFLAGS=-O3 CXXOPTFLAGS=-O3 FOPTFLAGS=-O3 PETSC_ARCH=arch-linux2-c-opt
Libraries compiled on Fri Jan  1 21:44:06 2016 on wf-fe2.lanl.gov
Machine characteristics: Linux-2.6.32-573.8.1.2chaos.ch5.4.x86_64-x86_64-with-redhat-6.7-Santiago
Using PETSc directory: /users/jychang48/petsc
Using PETSc arch: arch-linux2-c-opt
Using C compiler: mpicc  -fPIC  -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -O3  ${COPTFLAGS} ${CFLAGS}
Using Fortran compiler: mpif90  -fPIC -Wall -Wno-unused-variable -ffree-line-length-0 -Wno-unused-dummy-argument -O3   ${FOPTFLAGS} ${FFLAGS}
Using include paths: -I/users/jychang48/petsc/arch-linux2-c-opt/include -I/users/jychang48/petsc/include -I/users/jychang48/petsc/include -I/users/jychang48/petsc/arch-linux2-c-opt/include -I/usr/projects/hpcsoft/toss2.2/wolf/openmpi/1.6.5-gcc-4.8/include/openmpi/opal/mca/hwloc/hwloc132/hwloc/include -I/usr/projects/hpcsoft/toss2.2/wolf/openmpi/1.6.5-gcc-4.8/include -I/usr/projects/hpcsoft/toss2.2/wolf/openmpi/1.6.5-gcc-4.8/include/openmpi
Using C linker: mpicc
Using Fortran linker: mpif90
Using libraries: -Wl,-rpath,/users/jychang48/petsc/arch-linux2-c-opt/lib -L/users/jychang48/petsc/arch-linux2-c-opt/lib -lpetsc -Wl,-rpath,/users/jychang48/petsc/arch-linux2-c-opt/lib -L/users/jychang48/petsc/arch-linux2-c-opt/lib -lcmumps -ldmumps -lsmumps -lzmumps -lmumps_common -lpord -lscalapack -lsuperlu_dist_4.2 -lHYPRE -Wl,-rpath,/usr/projects/hpcsoft/toss2.2/wolf/openmpi/1.6.5-gcc-4.8/lib -L/usr/projects/hpcsoft/toss2.2/wolf/openmpi/1.6.5-gcc-4.8/lib -Wl,-rpath,/turquoise/usr/projects/hpcsoft/toss2/common/gcc/4.8.2/lib/gcc/x86_64-unknown-linux-gnu/4.8.2 -L/turquoise/usr/projects/hpcsoft/toss2/common/gcc/4.8.2/lib/gcc/x86_64-unknown-linux-gnu/4.8.2 -Wl,-rpath,/turquoise/usr/projects/hpcsoft/toss2/common/gcc/4.8.2/lib/gcc -L/turquoise/usr/projects/hpcsoft/toss2/common/gcc/4.8.2/lib/gcc -Wl,-rpath,/turquoise/usr/projects/hpcsoft/toss2/common/gcc/4.8.2/lib64 -L/turquoise/usr/projects/hpcsoft/toss2/common/gcc/4.8.2/lib64 -Wl,-rpath,/turquoise/usr/projects/hpcsoft/toss2/common/gcc/4.8.2/lib -L/turquoise/usr/projects/hpcsoft/toss2/common/gcc/4.8.2/lib -lmpi_cxx -lstdc++ -lml -lmpi_cxx -lstdc++ -lflapack -lfblas -lparmetis -lmetis -lchaco -lexoIIv2for -lexodus -lnetcdf -lhdf5hl_fortran -lhdf5_fortran -lhdf5_hl -lhdf5 -ltriangle -lX11 -lhwloc -lctetgen -lssl -lcrypto -lmpi_f90 -lmpi_f77 -lgfortran -lm -lgfortran -lm -lgfortran -lm -lgfortran -lm -lgfortran -lm -lquadmath -lm -lmpi_cxx -lstdc++ -Wl,-rpath,/usr/projects/hpcsoft/toss2.2/wolf/openmpi/1.6.5-gcc-4.8/lib -L/usr/projects/hpcsoft/toss2.2/wolf/openmpi/1.6.5-gcc-4.8/lib -Wl,-rpath,/turquoise/usr/projects/hpcsoft/toss2/common/gcc/4.8.2/lib/gcc/x86_64-unknown-linux-gnu/4.8.2 -L/turquoise/usr/projects/hpcsoft/toss2/common/gcc/4.8.2/lib/gcc/x86_64-unknown-linux-gnu/4.8.2 -Wl,-rpath,/turquoise/usr/projects/hpcsoft/toss2/common/gcc/4.8.2/lib/gcc -L/turquoise/usr/projects/hpcsoft/toss2/common/gcc/4.8.2/lib/gcc -Wl,-rpath,/turquoise/usr/projects/hpcsoft/toss2/common/gcc/4.8.2/lib64 -L/turquoise/usr/projects/hpcsoft/toss2/common/gcc/4.8.2/lib64 -Wl,-rpath,/turquoise/usr/projects/hpcsoft/toss2/common/gcc/4.8.2/lib -L/turquoise/usr/projects/hpcsoft/toss2/common/gcc/4.8.2/lib -ldl -lmpi -losmcomp -lrdmacm -libverbs -lsctp -lrt -lnsl -lutil -lpsm_infinipath -lpmi -lnuma -lgcc_s -lpthread -ldl
 hypre 40 1
Discretization: RT
MPI processes 8: solving...
((143102, 1161600), (143102, 1161600))
	Solver time: 1.735006e+01
Darcy_FE.py on a arch-linux2-c-opt named wf153.localdomain with 8 processors, by jychang48 Wed Mar  2 17:36:26 2016
Time (sec):           3.019e+01      1.00018   3.019e+01
Objects:              5.080e+02      1.06723   4.808e+02
Flops:                2.751e+08      1.02555   2.702e+08  2.162e+09
Flops/sec:            9.112e+06      1.02543   8.951e+06  7.161e+07
MPI Messages:         1.488e+03      1.92936   9.162e+02  7.330e+03
MPI Message Lengths:  2.303e+08      3.35599   9.783e+04  7.171e+08
 0:      Main Stage: 1.2840e+01  42.5%  0.0000e+00   0.0%  5.296e+03  72.3%  9.268e+04       94.7%  1.250e+02  29.6%
 1:             FEM: 1.7350e+01  57.5%  2.1619e+09 100.0%  2.034e+03  27.7%  5.144e+03        5.3%  2.960e+02  70.1%
Phase summary info:
BuildTwoSided         44 1.0 9.9128e-0138.8 0.00e+00 0.0 1.2e+03 4.0e+00 4.4e+01  3  0 17  0 10   7  0 23  0 35     0
VecScatterBegin        2 1.0 2.8896e-04 1.3 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecScatterEnd          2 1.0 4.2915e-06 1.5 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
Mesh Partition         2 1.0 1.8551e+00 1.1 0.00e+00 0.0 1.4e+03 4.1e+04 2.1e+01  6  0 19  8  5  14  0 26  8 17     0
Mesh Migration         2 1.0 6.9572e-01 1.0 0.00e+00 0.0 3.4e+03 1.6e+05 5.4e+01  2  0 47 78 13   5  0 65 82 43     0
DMPlexInterp           1 1.0 2.1258e+0061070.6 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  1  0  0  0  0   2  0  0  0  0     0
DMPlexDistribute       1 1.0 2.0482e+00 1.1 0.00e+00 0.0 1.0e+03 3.2e+05 2.5e+01  7  0 14 44  6  16  0 19 47 20     0
DMPlexDistCones        2 1.0 1.6333e-01 1.0 0.00e+00 0.0 4.9e+02 3.8e+05 4.0e+00  1  0  7 26  1   1  0  9 27  3     0
DMPlexDistLabels       2 1.0 3.9636e-01 1.0 0.00e+00 0.0 2.1e+03 1.5e+05 2.2e+01  1  0 29 44  5   3  0 40 47 18     0
DMPlexDistribOL        1 1.0 5.2188e-01 1.0 0.00e+00 0.0 3.9e+03 8.8e+04 5.0e+01  2  0 53 47 12   4  0 73 50 40     0
DMPlexDistField        3 1.0 2.2661e-02 1.2 0.00e+00 0.0 6.4e+02 3.8e+04 1.2e+01  0  0  9  3  3   0  0 12  4 10     0
DMPlexDistData         2 1.0 9.7732e-0152.9 0.00e+00 0.0 8.5e+02 3.0e+04 6.0e+00  3  0 12  4  1   6  0 16  4  5     0
DMPlexStratify         6 1.5 6.0215e-01 8.6 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   1  0  0  0  0     0
SFSetGraph            51 1.0 1.4261e-01 1.1 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   1  0  0  0  0     0
SFBcastBegin          95 1.0 1.0311e+00 6.1 0.00e+00 0.0 5.0e+03 1.3e+05 4.1e+01  3  0 69 91 10   7  0 95 96 33     0
SFBcastEnd            95 1.0 3.0112e-01 2.9 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  1  0  0  0  0   2  0  0  0  0     0
SFReduceBegin          4 1.0 3.5210e-03 3.5 0.00e+00 0.0 1.8e+02 8.2e+04 3.0e+00  0  0  2  2  1   0  0  3  2  2     0
SFReduceEnd            4 1.0 6.8002e-03 3.1 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
SFFetchOpBegin         1 1.0 6.3896e-0510.7 0.00e+00 0.0 1.9e+01 7.0e+03 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
SFFetchOpEnd           1 1.0 2.3389e-04 2.4 0.00e+00 0.0 1.9e+01 7.0e+03 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
BuildTwoSided          1 1.0 1.9801e-0368.1 0.00e+00 0.0 3.8e+01 4.0e+00 1.0e+00  0  0  1  0  0   0  0  2  0  0     0
VecMDot               15 1.0 2.0872e-02 1.2 3.52e+07 1.0 0.0e+00 0.0e+00 1.5e+01  0 13  0  0  4   0 13  0  0  5 13357
VecNorm               16 1.0 4.1130e-03 1.4 4.69e+06 1.0 0.0e+00 0.0e+00 1.6e+01  0  2  0  0  4   0  2  0  0  5  9038
VecScale              32 1.0 2.5165e-03 1.1 3.92e+06 1.0 0.0e+00 0.0e+00 0.0e+00  0  1  0  0  0   0  1  0  0  0 12329
VecCopy                1 1.0 3.9196e-04 1.1 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecSet               104 1.0 5.7840e-03 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecAXPY                1 1.0 2.0885e-04 1.1 2.93e+05 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0 11124
VecMAXPY              16 1.0 2.0167e-02 1.1 3.95e+07 1.0 0.0e+00 0.0e+00 0.0e+00  0 15  0  0  0   0 15  0  0  0 15552
VecScatterBegin      146 1.0 9.3625e-03 1.1 0.00e+00 0.0 1.4e+03 5.6e+03 0.0e+00  0  0 20  1  0   0  0 71 22  0     0
VecScatterEnd        146 1.0 1.7571e-03 1.8 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecNormalize          16 1.0 5.5876e-03 1.2 7.03e+06 1.0 0.0e+00 0.0e+00 1.6e+01  0  3  0  0  4   0  3  0  0  5  9979
MatMult               31 1.0 5.3636e-02 1.0 4.25e+07 1.0 1.4e+03 5.6e+03 1.2e+02  0 16 20  1 28   0 16 71 22 41  6288
MatMultAdd            60 1.0 4.1250e-02 1.0 3.64e+07 1.0 1.1e+03 6.0e+03 0.0e+00  0 13 16  1  0   0 13 56 18  0  6989
MatSolve              16 1.0 2.9535e-02 1.1 2.00e+07 1.0 0.0e+00 0.0e+00 0.0e+00  0  7  0  0  0   0  7  0  0  0  5344
MatLUFactorNum         1 1.0 9.0630e-03 1.0 2.31e+06 1.0 0.0e+00 0.0e+00 0.0e+00  0  1  0  0  0   0  1  0  0  0  1993
MatILUFactorSym        1 1.0 3.5720e-03 1.1 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatConvert             2 1.0 7.2582e-03 1.3 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatScale               2 1.0 1.1430e-03 1.1 6.70e+05 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0  4666
MatAssemblyBegin      12 1.0 1.4740e-0230.9 0.00e+00 0.0 0.0e+00 0.0e+00 6.0e+00  0  0  0  0  1   0  0  0  0  2     0
MatAssemblyEnd        12 1.0 2.9862e-02 1.1 0.00e+00 0.0 3.0e+02 1.3e+03 4.8e+01  0  0  4  0 11   0  0 15  1 16     0
MatGetRow          96000 1.0 3.8036e-01 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  1  0  0  0  0   2  0  0  0  0     0
MatGetRowIJ            3 1.0 7.3910e-06 2.4 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatGetSubMatrix        4 1.0 5.1844e-03 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 6.0e+00  0  0  0  0  1   0  0  0  0  2     0
MatGetOrdering         1 1.0 3.9101e-04 1.1 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatAXPY                1 1.0 7.6591e-01 1.0 0.00e+00 0.0 7.6e+01 1.1e+03 1.2e+01  3  0  1  0  3   4  0  4  0  4     0
MatMatMult             1 1.0 4.1730e-02 1.0 1.24e+06 1.0 1.5e+02 3.7e+03 1.6e+01  0  0  2  0  4   0  0  7  1  5   237
MatMatMultSym          1 1.0 3.6349e-02 1.1 0.00e+00 0.0 1.3e+02 2.9e+03 1.4e+01  0  0  2  0  3   0  0  7  1  5     0
MatMatMultNum          1 1.0 5.3639e-03 1.0 1.24e+06 1.0 1.9e+01 9.1e+03 2.0e+00  0  0  0  0  0   0  0  1  0  1  1846
MatGetLocalMat         2 1.0 6.2211e-03 1.3 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatGetBrAoCol          2 1.0 2.3620e-03 3.6 0.00e+00 0.0 7.6e+01 6.3e+03 0.0e+00  0  0  1  0  0   0  0  4  1  0     0
PCSetUp                4 1.0 1.3550e+01 1.0 4.22e+06 1.0 2.6e+02 3.8e+04 6.6e+01 45  2  4  1 16  78  2 13 26 22     2
PCSetUpOnBlocks       16 1.0 1.3087e-02 1.1 2.31e+06 1.0 0.0e+00 0.0e+00 0.0e+00  0  1  0  0  0   0  1  0  0  0  1380
PCApply               16 1.0 1.6049e+01 1.0 3.01e+07 1.0 3.0e+02 4.5e+03 4.0e+00 53 11  4  0  1  92 11 15  4  1    15
KSPGMRESOrthog        15 1.0 3.8775e-02 1.1 7.03e+07 1.0 0.0e+00 0.0e+00 1.5e+01  0 26  0  0  4   0 26  0  0  5 14380
KSPSetUp               4 1.0 2.0099e-03 3.3 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
KSPSolve               1 1.0 1.6968e+01 1.0 1.50e+08 1.0 1.7e+03 1.1e+04 2.2e+02 56 55 23  3 51  98 55 84 48 73    70
SFBcastBegin           1 1.0 2.1381e-0310.9 0.00e+00 0.0 1.1e+02 7.1e+03 1.0e+00  0  0  2  0  0   0  0  6  2  0     0
SFBcastEnd             1 1.0 1.9217e-04 4.3 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
              Viewer     1              0            0     0.
           Index Set   103            103     29164164     0.
   IS L to G Mapping     3              3     16320748     0.
             Section    70             53        35616     0.
              Vector    15             45     38486192     0.
      Vector Scatter     2              7      3442120     0.
              Matrix     0              5     16044008     0.
    Distributed Mesh    14              8        38248     0.
    GraphPartitioner     6              5         3060     0.
Star Forest Bipartite Graph    74             63        53256     0.
     Discrete System    14              8         6912     0.
           Index Set    31             24        72488     0.
              Vector   114             72      2819096     0.
              Matrix    26              8     12996772     0.
Average time to get PetscTime(): 5.96046e-07
Average time for MPI_Barrier(): 2.57492e-06
Average time for zero size MPI_Send(): 1.63913e-06
-log_summary
 hypre 40 1
Discretization: RT
MPI processes 16: solving...
((70996, 1161600), (70996, 1161600))
	Solver time: 1.058687e+01
Darcy_FE.py on a arch-linux2-c-opt named wf153.localdomain with 16 processors, by jychang48 Wed Mar  2 17:36:54 2016
Time (sec):           2.499e+01      1.00048   2.498e+01
Objects:              5.300e+02      1.11345   4.844e+02
Flops:                1.457e+08      1.07257   1.405e+08  2.248e+09
Flops/sec:            5.832e+06      1.07236   5.625e+06  8.999e+07
MPI Messages:         2.200e+03      2.65801   1.275e+03  2.041e+04
MPI Message Lengths:  2.006e+08      5.65486   3.779e+04  7.712e+08
 0:      Main Stage: 1.4394e+01  57.6%  0.0000e+00   0.0%  1.470e+04  72.0%  3.566e+04       94.4%  1.250e+02  29.6%
 1:             FEM: 1.0587e+01  42.4%  2.2481e+09 100.0%  5.706e+03  28.0%  2.128e+03        5.6%  2.960e+02  70.1%
Phase summary info:
BuildTwoSided         44 1.0 1.1248e+0011.8 0.00e+00 0.0 3.5e+03 4.0e+00 4.4e+01  4  0 17  0 10   7  0 24  0 35     0
VecScatterBegin        2 1.0 9.4891e-05 2.1 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecScatterEnd          2 1.0 5.0068e-06 2.6 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
Mesh Partition         2 1.0 1.9227e+00 1.1 0.00e+00 0.0 4.4e+03 1.4e+04 2.1e+01  8  0 22  8  5  13  0 30  9 17     0
Mesh Migration         2 1.0 5.1665e-01 1.0 0.00e+00 0.0 8.9e+03 6.6e+04 5.4e+01  2  0 44 77 13   4  0 61 81 43     0
DMPlexInterp           1 1.0 2.1289e+0057607.7 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  1  0  0  0  0   1  0  0  0  0     0
DMPlexDistribute       1 1.0 2.1160e+00 1.1 0.00e+00 0.0 2.9e+03 1.1e+05 2.5e+01  8  0 14 42  6  15  0 20 44 20     0
DMPlexDistCones        2 1.0 1.2104e-01 1.1 0.00e+00 0.0 1.3e+03 1.5e+05 4.0e+00  0  0  6 26  1   1  0  9 27  3     0
DMPlexDistLabels       2 1.0 3.1131e-01 1.0 0.00e+00 0.0 5.5e+03 6.1e+04 2.2e+01  1  0 27 43  5   2  0 38 46 18     0
DMPlexDistribOL        1 1.0 3.4250e-01 1.0 0.00e+00 0.0 1.1e+04 3.5e+04 5.0e+01  1  0 52 49 12   2  0 72 52 40     0
DMPlexDistField        3 1.0 2.6409e-02 1.7 0.00e+00 0.0 1.7e+03 1.5e+04 1.2e+01  0  0  8  3  3   0  0 12  4 10     0
DMPlexDistData         2 1.0 9.8067e-0166.0 0.00e+00 0.0 2.9e+03 9.6e+03 6.0e+00  4  0 14  4  1   6  0 20  4  5     0
DMPlexStratify         6 1.5 5.7033e-0116.1 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
SFSetGraph            51 1.0 8.5479e-02 1.3 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   1  0  0  0  0     0
SFBcastBegin          95 1.0 1.1410e+00 4.2 0.00e+00 0.0 1.4e+04 5.0e+04 4.1e+01  4  0 69 91 10   7  0 95 97 33     0
SFBcastEnd            95 1.0 2.9869e-01 5.5 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  1  0  0  0  0   2  0  0  0  0     0
SFReduceBegin          4 1.0 7.5610e-0311.6 0.00e+00 0.0 5.0e+02 3.0e+04 3.0e+00  0  0  2  2  1   0  0  3  2  2     0
SFReduceEnd            4 1.0 8.0378e-03 3.7 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
SFFetchOpBegin         1 1.0 4.8876e-0517.1 0.00e+00 0.0 5.4e+01 3.9e+03 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
SFFetchOpEnd           1 1.0 2.0194e-04 2.8 0.00e+00 0.0 5.4e+01 3.9e+03 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
BuildTwoSided          1 1.0 1.9481e-0357.1 0.00e+00 0.0 1.1e+02 4.0e+00 1.0e+00  0  0  1  0  0   0  0  2  0  0     0
VecMDot               15 1.0 1.0908e-02 1.3 1.77e+07 1.0 0.0e+00 0.0e+00 1.5e+01  0 12  0  0  4   0 12  0  0  5 25557
VecNorm               16 1.0 2.3785e-03 1.4 2.36e+06 1.0 0.0e+00 0.0e+00 1.6e+01  0  2  0  0  4   0  2  0  0  5 15628
VecScale              32 1.0 1.2298e-03 1.1 1.97e+06 1.0 0.0e+00 0.0e+00 0.0e+00  0  1  0  0  0   0  1  0  0  0 25230
VecCopy                1 1.0 2.2292e-04 1.9 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecSet               104 1.0 2.8174e-03 1.1 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecAXPY                1 1.0 1.0705e-04 1.2 1.47e+05 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0 21702
VecMAXPY              16 1.0 7.5836e-03 1.1 1.99e+07 1.0 0.0e+00 0.0e+00 0.0e+00  0 14  0  0  0   0 14  0  0  0 41357
VecScatterBegin      146 1.0 5.2605e-03 1.2 0.00e+00 0.0 4.1e+03 3.1e+03 0.0e+00  0  0 20  2  0   0  0 72 30  0     0
VecScatterEnd        146 1.0 1.6868e-03 2.5 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecNormalize          16 1.0 3.2125e-03 1.3 3.53e+06 1.0 0.0e+00 0.0e+00 1.6e+01  0  2  0  0  4   0  2  0  0  5 17356
MatMult               31 1.0 2.9088e-02 1.1 2.15e+07 1.0 4.1e+03 3.1e+03 1.2e+02  0 15 20  2 28   0 15 72 30 41 11595
MatMultAdd            60 1.0 2.0502e-02 1.1 1.84e+07 1.0 3.2e+03 3.3e+03 0.0e+00  0 13 16  1  0   0 13 57 25  0 14061
MatSolve              16 1.0 1.4782e-02 1.2 1.00e+07 1.1 0.0e+00 0.0e+00 0.0e+00  0  7  0  0  0   0  7  0  0  0 10598
MatLUFactorNum         1 1.0 4.4949e-03 1.1 1.17e+06 1.1 0.0e+00 0.0e+00 0.0e+00  0  1  0  0  0   0  1  0  0  0  4012
MatILUFactorSym        1 1.0 1.7769e-03 1.1 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatConvert             2 1.0 3.6948e-03 1.2 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatScale               2 1.0 1.8299e-03 4.0 3.37e+05 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0  2915
MatAssemblyBegin      12 1.0 6.6197e-0314.5 0.00e+00 0.0 0.0e+00 0.0e+00 6.0e+00  0  0  0  0  1   0  0  0  0  2     0
MatAssemblyEnd        12 1.0 1.8342e-02 1.2 0.00e+00 0.0 8.6e+02 7.2e+02 4.8e+01  0  0  4  0 11   0  0 15  1 16     0
MatGetRow          48000 1.0 1.9010e-01 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  1  0  0  0  0   2  0  0  0  0     0
MatGetRowIJ            3 1.0 7.3910e-06 1.9 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatGetSubMatrix        4 1.0 2.5330e-03 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 6.0e+00  0  0  0  0  1   0  0  0  0  2     0
MatGetOrdering         1 1.0 1.8501e-04 1.1 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatAXPY                1 1.0 3.8416e-01 1.0 0.00e+00 0.0 2.2e+02 6.2e+02 1.2e+01  2  0  1  0  3   4  0  4  0  4     0
MatMatMult             1 1.0 2.2542e-02 1.0 6.22e+05 1.0 4.3e+02 2.1e+03 1.6e+01  0  0  2  0  4   0  0  8  2  5   439
MatMatMultSym          1 1.0 1.9671e-02 1.0 0.00e+00 0.0 3.8e+02 1.6e+03 1.4e+01  0  0  2  0  3   0  0  7  1  5     0
MatMatMultNum          1 1.0 2.8560e-03 1.0 6.22e+05 1.0 5.4e+01 5.1e+03 2.0e+00  0  0  0  0  0   0  0  1  1  1  3467
MatGetLocalMat         2 1.0 3.1629e-03 1.4 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatGetBrAoCol          2 1.0 1.3680e-03 3.8 0.00e+00 0.0 2.2e+02 3.5e+03 0.0e+00  0  0  1  0  0   0  0  4  2  0     0
PCSetUp                4 1.0 8.6555e+00 1.0 2.13e+06 1.0 7.1e+02 1.4e+04 6.6e+01 35  1  3  1 16  82  1 12 24 22     4
PCSetUpOnBlocks       16 1.0 6.4955e-03 1.1 1.17e+06 1.1 0.0e+00 0.0e+00 0.0e+00  0  1  0  0  0   0  1  0  0  0  2776
PCApply               16 1.0 9.8637e+00 1.0 1.51e+07 1.1 8.6e+02 2.5e+03 4.0e+00 39 11  4  0  1  93 11 15  5  1    24
KSPGMRESOrthog        15 1.0 1.7411e-02 1.1 3.53e+07 1.0 0.0e+00 0.0e+00 1.5e+01  0 25  0  0  4   0 25  0  0  5 32024
KSPSetUp               4 1.0 1.0309e-03 3.6 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
KSPSolve               1 1.0 1.0327e+01 1.0 7.56e+07 1.0 4.8e+03 4.8e+03 2.2e+02 41 53 24  3 51  98 53 84 53 73   115
SFBcastBegin           1 1.0 2.0330e-0312.4 0.00e+00 0.0 3.3e+02 3.9e+03 1.0e+00  0  0  2  0  0   0  0  6  3  0     0
SFBcastEnd             1 1.0 6.5589e-0418.7 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
              Viewer     1              0            0     0.
           Index Set   125            125     25601172     0.
   IS L to G Mapping     3              3     15014432     0.
              Vector    15             45     21647864     0.
      Vector Scatter     2              7      1711576     0.
              Matrix     0              5      7939056     0.
           Index Set    31             24        62680     0.
              Vector   114             72      1468496     0.
              Matrix    26              8      6483848     0.
Average time for MPI_Barrier(): 5.19753e-06
Average time for zero size MPI_Send(): 1.74344e-06
-log_summary
 hypre 40 1
Discretization: RT
MPI processes 24: solving...
((47407, 1161600), (47407, 1161600))
	Solver time: 7.910459e+00
Darcy_FE.py on a arch-linux2-c-opt named wf153.localdomain with 24 processors, by jychang48 Wed Mar  2 17:37:20 2016
Time (sec):           2.242e+01      1.00049   2.241e+01
Objects:              5.440e+02      1.14286   4.867e+02
Flops:                1.007e+08      1.09540   9.605e+07  2.305e+09
Flops/sec:            4.496e+06      1.09573   4.286e+06  1.029e+08
MPI Messages:         2.382e+03      2.69553   1.502e+03  3.605e+04
MPI Message Lengths:  1.887e+08      7.68458   2.238e+04  8.069e+08
 0:      Main Stage: 1.4502e+01  64.7%  0.0000e+00   0.0%  2.618e+04  72.6%  2.108e+04       94.2%  1.250e+02  29.6%
 1:             FEM: 7.9106e+00  35.3%  2.3052e+09 100.0%  9.866e+03  27.4%  1.304e+03        5.8%  2.960e+02  70.1%
Phase summary info:
BuildTwoSided         44 1.0 1.1278e+00 9.6 0.00e+00 0.0 6.2e+03 4.0e+00 4.4e+01  5  0 17  0 10   7  0 24  0 35     0
VecScatterBegin        2 1.0 5.1975e-05 1.7 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecScatterEnd          2 1.0 6.1989e-06 3.2 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
Mesh Partition         2 1.0 1.9991e+00 1.1 0.00e+00 0.0 8.7e+03 7.7e+03 2.1e+01  9  0 24  8  5  14  0 33  9 17     0
Mesh Migration         2 1.0 4.5798e-01 1.0 0.00e+00 0.0 1.5e+04 4.0e+04 5.4e+01  2  0 42 76 13   3  0 58 81 43     0
DMPlexInterp           1 1.0 2.1214e+0062660.5 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   1  0  0  0  0     0
DMPlexDistribute       1 1.0 2.2150e+00 1.1 0.00e+00 0.0 5.7e+03 5.7e+04 2.5e+01 10  0 16 40  6  15  0 22 43 20     0
DMPlexDistCones        2 1.0 1.0382e-01 1.1 0.00e+00 0.0 2.2e+03 9.3e+04 4.0e+00  0  0  6 25  1   1  0  8 27  3     0
DMPlexDistLabels       2 1.0 2.8698e-01 1.0 0.00e+00 0.0 9.3e+03 3.7e+04 2.2e+01  1  0 26 43  5   2  0 35 46 18     0
DMPlexDistribOL        1 1.0 2.6150e-01 1.0 0.00e+00 0.0 1.8e+04 2.2e+04 5.0e+01  1  0 51 50 12   2  0 70 53 40     0
DMPlexDistField        3 1.0 2.8048e-02 1.9 0.00e+00 0.0 3.0e+03 9.4e+03 1.2e+01  0  0  8  3  3   0  0 11  4 10     0
DMPlexDistData         2 1.0 1.0004e+0029.4 0.00e+00 0.0 6.0e+03 5.0e+03 6.0e+00  4  0 17  4  1   6  0 23  4  5     0
DMPlexStratify         6 1.5 5.5870e-0122.2 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
SFSetGraph            51 1.0 6.0882e-02 1.3 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
SFBcastBegin          95 1.0 1.1378e+00 4.0 0.00e+00 0.0 2.5e+04 2.9e+04 4.1e+01  5  0 69 91 10   7  0 96 97 33     0
SFBcastEnd            95 1.0 2.9645e-01 5.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  1  0  0  0  0   2  0  0  0  0     0
SFReduceBegin          4 1.0 7.4639e-0312.3 0.00e+00 0.0 8.7e+02 1.8e+04 3.0e+00  0  0  2  2  1   0  0  3  2  2     0
SFReduceEnd            4 1.0 8.2810e-03 4.8 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
SFFetchOpBegin         1 1.0 5.1975e-0527.2 0.00e+00 0.0 9.4e+01 2.8e+03 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
SFFetchOpEnd           1 1.0 1.4901e-04 3.2 0.00e+00 0.0 9.4e+01 2.8e+03 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
BuildTwoSided          1 1.0 1.2400e-0322.1 0.00e+00 0.0 1.9e+02 4.0e+00 1.0e+00  0  0  1  0  0   0  0  2  0  0     0
VecMDot               15 1.0 7.2665e-03 1.2 1.18e+07 1.0 0.0e+00 0.0e+00 1.5e+01  0 12  0  0  4   0 12  0  0  5 38365
VecNorm               16 1.0 1.5225e-03 1.3 1.58e+06 1.0 0.0e+00 0.0e+00 1.6e+01  0  2  0  0  4   0  2  0  0  5 24414
VecScale              32 1.0 8.1635e-04 1.1 1.32e+06 1.1 0.0e+00 0.0e+00 0.0e+00  0  1  0  0  0   0  1  0  0  0 38007
VecCopy                1 1.0 1.5211e-04 1.9 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecSet               104 1.0 1.9157e-03 1.1 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecAXPY                1 1.0 9.1076e-05 1.5 9.87e+04 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0 25508
VecMAXPY              16 1.0 4.0472e-03 1.1 1.33e+07 1.0 0.0e+00 0.0e+00 0.0e+00  0 14  0  0  0   0 14  0  0  0 77494
VecScatterBegin      146 1.0 3.9029e-03 1.3 0.00e+00 0.0 7.1e+03 2.2e+03 0.0e+00  0  0 20  2  0   0  0 72 34  0     0
VecScatterEnd        146 1.0 1.7533e-03 3.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecNormalize          16 1.0 2.1329e-03 1.2 2.37e+06 1.0 0.0e+00 0.0e+00 1.6e+01  0  2  0  0  4   0  2  0  0  5 26141
MatMult               31 1.0 2.0300e-02 1.1 1.43e+07 1.0 7.1e+03 2.2e+03 1.2e+02  0 15 20  2 28   0 15 72 34 41 16614
MatMultAdd            60 1.0 1.4215e-02 1.1 1.22e+07 1.0 5.6e+03 2.3e+03 0.0e+00  0 13 16  2  0   0 13 57 28  0 20280
MatSolve              16 1.0 1.0126e-02 1.1 6.68e+06 1.1 0.0e+00 0.0e+00 0.0e+00  0  7  0  0  0   0  7  0  0  0 15400
MatLUFactorNum         1 1.0 2.9531e-03 1.1 7.77e+05 1.1 0.0e+00 0.0e+00 0.0e+00  0  1  0  0  0   0  1  0  0  0  6088
MatILUFactorSym        1 1.0 1.2059e-03 1.1 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatConvert             2 1.0 2.4192e-03 1.3 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatScale               2 1.0 2.8942e-0310.6 2.25e+05 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0  1842
MatAssemblyBegin      12 1.0 3.4149e-0312.4 0.00e+00 0.0 0.0e+00 0.0e+00 6.0e+00  0  0  0  0  1   0  0  0  0  2     0
MatAssemblyEnd        12 1.0 1.3027e-02 1.2 0.00e+00 0.0 1.5e+03 5.2e+02 4.8e+01  0  0  4  0 11   0  0 15  2 16     0
MatGetRow          32000 1.0 1.2811e-01 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  1  0  0  0  0   2  0  0  0  0     0
MatGetRowIJ            3 1.0 9.0599e-06 2.4 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatGetSubMatrix        4 1.0 1.8091e-03 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 6.0e+00  0  0  0  0  1   0  0  0  0  2     0
MatGetOrdering         1 1.0 1.3399e-04 1.1 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatAXPY                1 1.0 2.5847e-01 1.0 0.00e+00 0.0 3.7e+02 4.4e+02 1.2e+01  1  0  1  0  3   3  0  4  0  4     0
MatMatMult             1 1.0 1.5638e-02 1.0 4.15e+05 1.0 7.4e+02 1.5e+03 1.6e+01  0  0  2  0  4   0  0  8  2  5   633
MatMatMultSym          1 1.0 1.3800e-02 1.0 0.00e+00 0.0 6.5e+02 1.2e+03 1.4e+01  0  0  2  0  3   0  0  7  2  5     0
MatMatMultNum          1 1.0 1.8721e-03 1.0 4.15e+05 1.0 9.3e+01 3.6e+03 2.0e+00  0  0  0  0  0   0  0  1  1  1  5287
MatGetLocalMat         2 1.0 2.0990e-03 1.4 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatGetBrAoCol          2 1.0 8.5115e-04 3.2 0.00e+00 0.0 3.7e+02 2.5e+03 0.0e+00  0  0  1  0  0   0  0  4  2  0     0
PCSetUp                4 1.0 6.6768e+00 1.0 1.42e+06 1.1 1.2e+03 8.7e+03 6.6e+01 30  1  3  1 16  84  1 12 22 22     5
PCSetUpOnBlocks       16 1.0 4.3478e-03 1.1 7.77e+05 1.1 0.0e+00 0.0e+00 0.0e+00  0  1  0  0  0   0  1  0  0  0  4135
PCApply               16 1.0 7.3809e+00 1.0 1.01e+07 1.1 1.5e+03 1.8e+03 4.0e+00 33 10  4  0  1  93 10 15  6  1    32
KSPGMRESOrthog        15 1.0 1.0740e-02 1.2 2.37e+07 1.0 0.0e+00 0.0e+00 1.5e+01  0 24  0  0  4   0 24  0  0  5 51917
KSPSetUp               4 1.0 7.2980e-04 4.1 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
KSPSolve               1 1.0 7.6940e+00 1.0 5.05e+07 1.0 8.3e+03 3.2e+03 2.2e+02 34 52 23  3 51  97 52 85 56 73   155
SFBcastBegin           1 1.0 1.3211e-03 7.3 0.00e+00 0.0 5.8e+02 2.8e+03 1.0e+00  0  0  2  0  0   0  0  6  3  0     0
SFBcastEnd             1 1.0 4.4298e-0422.1 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
              Viewer     1              0            0     0.
           Index Set   139            139     24064612     0.
   IS L to G Mapping     3              3     14448024     0.
              Vector    15             45     16129832     0.
      Vector Scatter     2              7      1145440     0.
              Matrix     0              5      5296216     0.
           Index Set    31             24        48256     0.
              Vector   114             72      1020040     0.
              Matrix    26              8      4329832     0.
Average time for MPI_Barrier(): 9.01222e-06
Average time for zero size MPI_Send(): 1.41064e-06
-log_summary
 hypre 40 1
Discretization: RT
MPI processes 32: solving...
((35155, 1161600), (35155, 1161600))
	Solver time: 6.555492e+00
Darcy_FE.py on a arch-linux2-c-opt named wf153.localdomain with 32 processors, by jychang48 Wed Mar  2 17:37:44 2016
Time (sec):           2.096e+01      1.00042   2.095e+01
Objects:              5.700e+02      1.19748   4.884e+02
Flops:                7.783e+07      1.11880   7.364e+07  2.357e+09
Flops/sec:            3.714e+06      1.11873   3.514e+06  1.125e+08
MPI Messages:         3.398e+03      3.61735   1.672e+03  5.349e+04
MPI Message Lengths:  1.852e+08      9.83329   1.568e+04  8.389e+08
 0:      Main Stage: 1.4399e+01  68.7%  0.0000e+00   0.0%  3.925e+04  73.4%  1.474e+04       94.0%  1.250e+02  29.6%
 1:             FEM: 6.5554e+00  31.3%  2.3565e+09 100.0%  1.424e+04  26.6%  9.392e+02        6.0%  2.960e+02  70.1%
Phase summary info:
BuildTwoSided         44 1.0 1.1524e+0013.3 0.00e+00 0.0 9.3e+03 4.0e+00 4.4e+01  5  0 17  0 10   7  0 24  0 35     0
VecScatterBegin        2 1.0 4.9114e-05 2.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecScatterEnd          2 1.0 1.0014e-05 5.2 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
Mesh Partition         2 1.0 2.0450e+00 1.1 0.00e+00 0.0 1.4e+04 5.1e+03 2.1e+01 10  0 26  8  5  14  0 36  9 17     0
Mesh Migration         2 1.0 4.3641e-01 1.0 0.00e+00 0.0 2.2e+04 2.9e+04 5.4e+01  2  0 41 75 13   3  0 56 80 43     0
DMPlexInterp           1 1.0 2.1204e+0066370.9 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
DMPlexDistribute       1 1.0 2.2712e+00 1.1 0.00e+00 0.0 9.4e+03 3.5e+04 2.5e+01 11  0 18 39  6  16  0 24 41 20     0
DMPlexDistCones        2 1.0 1.0140e-01 1.2 0.00e+00 0.0 3.2e+03 6.6e+04 4.0e+00  0  0  6 25  1   1  0  8 27  3     0
DMPlexDistLabels       2 1.0 2.7727e-01 1.0 0.00e+00 0.0 1.3e+04 2.7e+04 2.2e+01  1  0 25 43  5   2  0 34 45 18     0
DMPlexDistribOL        1 1.0 2.2697e-01 1.0 0.00e+00 0.0 2.7e+04 1.6e+04 5.0e+01  1  0 50 51 12   2  0 68 54 40     0
DMPlexDistField        3 1.0 2.7891e-02 2.0 0.00e+00 0.0 4.3e+03 6.8e+03 1.2e+01  0  0  8  3  3   0  0 11  4 10     0
DMPlexDistData         2 1.0 9.9838e-0173.6 0.00e+00 0.0 1.0e+04 3.2e+03 6.0e+00  4  0 19  4  1   7  0 26  4  5     0
DMPlexStratify         6 1.5 5.4583e-0129.3 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
SFSetGraph            51 1.0 5.1974e-02 1.5 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
SFBcastBegin          95 1.0 1.1583e+00 4.5 0.00e+00 0.0 3.8e+04 2.0e+04 4.1e+01  5  0 70 91 10   7  0 96 97 33     0
SFBcastEnd            95 1.0 3.0140e-01 5.5 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  1  0  0  0  0   2  0  0  0  0     0
SFReduceBegin          4 1.0 8.4107e-0318.3 0.00e+00 0.0 1.3e+03 1.3e+04 3.0e+00  0  0  2  2  1   0  0  3  2  2     0
SFReduceEnd            4 1.0 8.6839e-03 5.7 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
SFFetchOpBegin         1 1.0 4.0054e-0512.9 0.00e+00 0.0 1.4e+02 2.2e+03 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
SFFetchOpEnd           1 1.0 1.4400e-04 2.1 0.00e+00 0.0 1.4e+02 2.2e+03 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
BuildTwoSided          1 1.0 1.5190e-0325.4 0.00e+00 0.0 2.9e+02 4.0e+00 1.0e+00  0  0  1  0  0   0  0  2  0  0     0
VecMDot               15 1.0 7.0019e-03 1.3 8.90e+06 1.1 0.0e+00 0.0e+00 1.5e+01  0 12  0  0  4   0 12  0  0  5 39815
VecNorm               16 1.0 1.7715e-03 1.5 1.19e+06 1.1 0.0e+00 0.0e+00 1.6e+01  0  2  0  0  4   0  2  0  0  5 20983
VecScale              32 1.0 6.4635e-04 1.2 9.95e+05 1.1 0.0e+00 0.0e+00 0.0e+00  0  1  0  0  0   0  1  0  0  0 48004
VecCopy                1 1.0 1.8501e-04 1.9 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecSet               104 1.0 1.4009e-03 1.1 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecAXPY                1 1.0 7.7963e-05 1.6 7.42e+04 1.1 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0 29799
VecMAXPY              16 1.0 2.8646e-03 1.2 1.00e+07 1.1 0.0e+00 0.0e+00 0.0e+00  0 13  0  0  0   0 13  0  0  0 109485
VecScatterBegin      146 1.0 3.1700e-03 1.3 0.00e+00 0.0 1.0e+04 1.8e+03 0.0e+00  0  0 19  2  0   0  0 72 37  0     0
VecScatterEnd        146 1.0 1.4212e-03 2.8 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecNormalize          16 1.0 2.2540e-03 1.3 1.78e+06 1.1 0.0e+00 0.0e+00 1.6e+01  0  2  0  0  4   0  2  0  0  5 24737
MatMult               31 1.0 1.6098e-02 1.1 1.08e+07 1.1 1.0e+04 1.8e+03 1.2e+02  0 14 19  2 28   0 14 72 37 41 20950
MatMultAdd            60 1.0 1.1012e-02 1.2 9.23e+06 1.1 8.1e+03 1.9e+03 0.0e+00  0 12 15  2  0   0 12 57 31  0 26178
MatSolve              16 1.0 7.5953e-03 1.2 5.01e+06 1.1 0.0e+00 0.0e+00 0.0e+00  0  7  0  0  0   0  7  0  0  0 20444
MatLUFactorNum         1 1.0 2.1951e-03 1.1 5.87e+05 1.1 0.0e+00 0.0e+00 0.0e+00  0  1  0  0  0   0  1  0  0  0  8182
MatILUFactorSym        1 1.0 9.3198e-04 1.2 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatConvert             2 1.0 1.9350e-03 1.3 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatScale               2 1.0 1.6952e-03 8.8 1.69e+05 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0  3146
MatAssemblyBegin      12 1.0 4.2899e-0319.1 0.00e+00 0.0 0.0e+00 0.0e+00 6.0e+00  0  0  0  0  1   0  0  0  0  2     0
MatAssemblyEnd        12 1.0 1.1258e-02 1.2 0.00e+00 0.0 2.2e+03 4.2e+02 4.8e+01  0  0  4  0 11   0  0 15  2 16     0
MatGetRow          24000 1.0 9.5220e-02 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   1  0  0  0  0     0
MatGetRowIJ            3 1.0 9.0599e-06 3.2 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatGetSubMatrix        4 1.0 1.2531e-03 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 6.0e+00  0  0  0  0  1   0  0  0  0  2     0
MatGetOrdering         1 1.0 1.2612e-04 1.3 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatAXPY                1 1.0 1.9306e-01 1.0 0.00e+00 0.0 5.4e+02 3.6e+02 1.2e+01  1  0  1  0  3   3  0  4  0  4     0
MatMatMult             1 1.0 1.2406e-02 1.0 3.11e+05 1.0 1.1e+03 1.2e+03 1.6e+01  0  0  2  0  4   0  0  8  3  5   798
MatMatMultSym          1 1.0 1.1072e-02 1.0 0.00e+00 0.0 9.4e+02 9.4e+02 1.4e+01  0  0  2  0  3   0  0  7  2  5     0
MatMatMultNum          1 1.0 1.3359e-03 1.0 3.11e+05 1.0 1.4e+02 2.9e+03 2.0e+00  0  0  0  0  0   0  0  1  1  1  7412
MatGetLocalMat         2 1.0 1.5900e-03 1.5 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatGetBrAoCol          2 1.0 7.4410e-04 2.9 0.00e+00 0.0 5.4e+02 2.0e+03 0.0e+00  0  0  1  0  0   0  0  4  2  0     0
PCSetUp                4 1.0 5.6156e+00 1.0 1.07e+06 1.1 1.7e+03 6.2e+03 6.6e+01 27  1  3  1 16  86  1 12 21 22     6
PCSetUpOnBlocks       16 1.0 3.2737e-03 1.1 5.87e+05 1.1 0.0e+00 0.0e+00 0.0e+00  0  1  0  0  0   0  1  0  0  0  5486
PCApply               16 1.0 6.1178e+00 1.0 7.57e+06 1.1 2.2e+03 1.4e+03 4.0e+00 29 10  4  0  1  93 10 15  6  1    38
KSPGMRESOrthog        15 1.0 9.2309e-03 1.2 1.78e+07 1.1 0.0e+00 0.0e+00 1.5e+01  0 24  0  0  4   0 24  0  0  5 60402
KSPSetUp               4 1.0 5.3430e-04 3.3 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
KSPSolve               1 1.0 6.3550e+00 1.0 3.80e+07 1.1 1.2e+04 2.4e+03 2.2e+02 30 50 23  3 51  97 50 85 58 73   187
SFBcastBegin           1 1.0 1.6100e-03 9.0 0.00e+00 0.0 8.6e+02 2.2e+03 1.0e+00  0  0  2  0  0   0  0  6  4  0     0
SFBcastEnd             1 1.0 2.7430e-03162.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
              Viewer     1              0            0     0.
           Index Set   165            165     23651716     0.
   IS L to G Mapping     3              3     14326164     0.
              Vector    15             45     13270832     0.
      Vector Scatter     2              7       851392     0.
              Matrix     0              5      3930504     0.
           Index Set    31             24        50224     0.
              Vector   114             72       792920     0.
              Matrix    26              8      3242072     0.
Average time for MPI_Barrier(): 7.58171e-06
Average time for zero size MPI_Send(): 1.68383e-06
-log_summary
 hypre 40 1
Discretization: RT
MPI processes 40: solving...
((27890, 1161600), (27890, 1161600))
	Solver time: 5.808753e+00
Darcy_FE.py on a arch-linux2-c-opt named wf153.localdomain with 40 processors, by jychang48 Wed Mar  2 17:38:08 2016
Time (sec):           2.025e+01      1.00036   2.025e+01
Objects:              5.920e+02      1.24895   4.896e+02
Flops:                6.409e+07      1.14442   5.989e+07  2.396e+09
Flops/sec:            3.165e+06      1.14437   2.958e+06  1.183e+08
MPI Messages:         4.088e+03      4.83560   1.815e+03  7.260e+04
MPI Message Lengths:  1.828e+08     12.01197   1.189e+04  8.633e+08
 0:      Main Stage: 1.4441e+01  71.3%  0.0000e+00   0.0%  5.371e+04  74.0%  1.117e+04       93.9%  1.250e+02  29.6%
 1:             FEM: 5.8089e+00  28.7%  2.3956e+09 100.0%  1.888e+04  26.0%  7.254e+02        6.1%  2.960e+02  70.1%
Phase summary info:
BuildTwoSided         44 1.0 1.1936e+0013.3 0.00e+00 0.0 1.3e+04 4.0e+00 4.4e+01  5  0 18  0 10   8  0 24  0 35     0
VecScatterBegin        2 1.0 3.5048e-05 1.8 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecScatterEnd          2 1.0 8.1062e-06 4.2 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
Mesh Partition         2 1.0 2.1145e+00 1.1 0.00e+00 0.0 2.0e+04 3.6e+03 2.1e+01 10  0 28  9  5  15  0 38  9 17     0
Mesh Migration         2 1.0 4.1762e-01 1.0 0.00e+00 0.0 2.9e+04 2.2e+04 5.4e+01  2  0 40 75 13   3  0 54 80 43     0
DMPlexInterp           1 1.0 2.1110e+0060232.7 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
DMPlexDistribute       1 1.0 2.3499e+00 1.1 0.00e+00 0.0 1.4e+04 2.3e+04 2.5e+01 12  0 19 38  6  16  0 26 40 20     0
DMPlexDistCones        2 1.0 9.5561e-02 1.2 0.00e+00 0.0 4.3e+03 5.1e+04 4.0e+00  0  0  6 25  1   1  0  8 27  3     0
DMPlexDistLabels       2 1.0 2.6967e-01 1.0 0.00e+00 0.0 1.7e+04 2.1e+04 2.2e+01  1  0 24 42  5   2  0 32 45 18     0
DMPlexDistribOL        1 1.0 2.0232e-01 1.0 0.00e+00 0.0 3.6e+04 1.2e+04 5.0e+01  1  0 49 51 12   1  0 66 55 40     0
DMPlexDistField        3 1.0 3.1459e-02 2.2 0.00e+00 0.0 5.7e+03 5.2e+03 1.2e+01  0  0  8  3  3   0  0 11  4 10     0
DMPlexDistData         2 1.0 1.0449e+0078.5 0.00e+00 0.0 1.5e+04 2.2e+03 6.0e+00  5  0 21  4  1   7  0 28  4  5     0
DMPlexStratify         6 1.5 5.4727e-0136.1 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
SFSetGraph            51 1.0 4.2525e-02 1.6 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
SFBcastBegin          95 1.0 1.1982e+00 4.5 0.00e+00 0.0 5.1e+04 1.5e+04 4.1e+01  5  0 71 91 10   8  0 96 97 33     0
SFBcastEnd            95 1.0 3.0828e-01 6.1 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  1  0  0  0  0   2  0  0  0  0     0
SFReduceBegin          4 1.0 8.9126e-0319.8 0.00e+00 0.0 1.7e+03 9.4e+03 3.0e+00  0  0  2  2  1   0  0  3  2  2     0
SFReduceEnd            4 1.0 9.0048e-03 6.6 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
SFFetchOpBegin         1 1.0 4.0054e-0514.0 0.00e+00 0.0 1.9e+02 1.8e+03 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
SFFetchOpEnd           1 1.0 1.1182e-04 2.3 0.00e+00 0.0 1.9e+02 1.8e+03 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
BuildTwoSided          1 1.0 1.0710e-0319.5 0.00e+00 0.0 3.8e+02 4.0e+00 1.0e+00  0  0  1  0  0   0  0  2  0  0     0
VecMDot               15 1.0 4.8821e-03 1.3 7.14e+06 1.1 0.0e+00 0.0e+00 1.5e+01  0 12  0  0  4   0 12  0  0  5 57102
VecNorm               16 1.0 1.3859e-03 1.6 9.52e+05 1.1 0.0e+00 0.0e+00 1.6e+01  0  2  0  0  4   0  2  0  0  5 26820
VecScale              32 1.0 5.1856e-04 1.2 7.98e+05 1.1 0.0e+00 0.0e+00 0.0e+00  0  1  0  0  0   0  1  0  0  0 59833
VecCopy                1 1.0 9.8944e-05 1.9 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecSet               104 1.0 1.1306e-03 1.1 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecAXPY                1 1.0 5.8174e-05 1.6 5.95e+04 1.1 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0 39935
VecMAXPY              16 1.0 2.0962e-03 1.2 8.03e+06 1.1 0.0e+00 0.0e+00 0.0e+00  0 13  0  0  0   0 13  0  0  0 149621
VecScatterBegin      146 1.0 2.9225e-03 1.6 0.00e+00 0.0 1.4e+04 1.5e+03 0.0e+00  0  0 19  2  0   0  0 72 39  0     0
VecScatterEnd        146 1.0 1.6057e-03 3.6 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecNormalize          16 1.0 1.7741e-03 1.4 1.43e+06 1.1 0.0e+00 0.0e+00 1.6e+01  0  2  0  0  4   0  2  0  0  5 31429
MatMult               31 1.0 1.4111e-02 1.2 8.66e+06 1.1 1.4e+04 1.5e+03 1.2e+02  0 14 19  2 28   0 14 72 39 41 23901
MatMultAdd            60 1.0 9.0714e-03 1.2 7.40e+06 1.1 1.1e+04 1.6e+03 0.0e+00  0 12 15  2  0   0 12 57 32  0 31779
MatSolve              16 1.0 6.0453e-03 1.2 4.01e+06 1.1 0.0e+00 0.0e+00 0.0e+00  0  6  0  0  0   0  6  0  0  0 25604
MatLUFactorNum         1 1.0 1.7362e-03 1.1 4.73e+05 1.1 0.0e+00 0.0e+00 0.0e+00  0  1  0  0  0   0  1  0  0  0 10319
MatILUFactorSym        1 1.0 7.0596e-04 1.2 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatConvert             2 1.0 1.5569e-03 1.2 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatScale               2 1.0 1.7138e-0311.6 1.35e+05 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0  3112
MatAssemblyBegin      12 1.0 4.5278e-0321.5 0.00e+00 0.0 0.0e+00 0.0e+00 6.0e+00  0  0  0  0  1   0  0  0  0  2     0
MatAssemblyEnd        12 1.0 9.7792e-03 1.2 0.00e+00 0.0 2.9e+03 3.5e+02 4.8e+01  0  0  4  0 11   0  0 15  2 16     0
MatGetRow          19200 1.0 7.6635e-02 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   1  0  0  0  0     0
MatGetRowIJ            3 1.0 9.5367e-06 3.3 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatGetSubMatrix        4 1.0 1.1559e-03 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 6.0e+00  0  0  0  0  1   0  0  0  0  2     0
MatGetOrdering         1 1.0 8.6069e-05 1.2 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatAXPY                1 1.0 1.5613e-01 1.0 0.00e+00 0.0 7.2e+02 3.0e+02 1.2e+01  1  0  1  0  3   3  0  4  0  4     0
MatMatMult             1 1.0 1.0730e-02 1.0 2.49e+05 1.0 1.4e+03 9.9e+02 1.6e+01  0  0  2  0  4   0  0  8  3  5   923
MatMatMultSym          1 1.0 9.6390e-03 1.0 0.00e+00 0.0 1.3e+03 7.8e+02 1.4e+01  0  0  2  0  3   0  0  7  2  5     0
MatMatMultNum          1 1.0 1.0788e-03 1.1 2.49e+05 1.0 1.8e+02 2.4e+03 2.0e+00  0  0  0  0  0   0  0  1  1  1  9176
MatGetLocalMat         2 1.0 1.2472e-03 1.5 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatGetBrAoCol          2 1.0 6.6495e-04 3.2 0.00e+00 0.0 7.2e+02 1.7e+03 0.0e+00  0  0  1  0  0   0  0  4  2  0     0
PCSetUp                4 1.0 5.0245e+00 1.0 8.56e+05 1.1 2.3e+03 4.7e+03 6.6e+01 25  1  3  1 16  86  1 12 21 22     7
PCSetUpOnBlocks       16 1.0 2.5797e-03 1.1 4.73e+05 1.1 0.0e+00 0.0e+00 0.0e+00  0  1  0  0  0   0  1  0  0  0  6945
PCApply               16 1.0 5.4329e+00 1.0 6.07e+06 1.1 2.9e+03 1.2e+03 4.0e+00 27 10  4  0  1  94 10 15  6  1    43
KSPGMRESOrthog        15 1.0 6.5861e-03 1.2 1.43e+07 1.1 0.0e+00 0.0e+00 1.5e+01  0 23  0  0  4   0 23  0  0  5 84658
KSPSetUp               4 1.0 4.7898e-04 3.7 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
KSPSolve               1 1.0 5.6257e+00 1.0 3.05e+07 1.1 1.6e+04 2.0e+03 2.2e+02 28 50 22  4 51  97 50 85 60 73   211
SFBcastBegin           1 1.0 1.1621e-03 6.0 0.00e+00 0.0 1.2e+03 1.8e+03 1.0e+00  0  0  2  0  0   0  0  6  4  0     0
SFBcastEnd             1 1.0 6.1488e-0436.3 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
              Viewer     1              0            0     0.
           Index Set   187            187     23331236     0.
   IS L to G Mapping     3              3     14094724     0.
              Vector    15             45     11572992     0.
      Vector Scatter     2              7       677032     0.
              Matrix     0              5      3124972     0.
           Index Set    31             24        48720     0.
              Vector   114             72       656808     0.
              Matrix    26              8      2592528     0.
Average time to get PetscTime(): 6.91414e-07
Average time for MPI_Barrier(): 9.63211e-06
Average time for zero size MPI_Send(): 1.42455e-06
-log_summary
 hypre 40 1
Discretization: RT
MPI processes 48: solving...
((23365, 1161600), (23365, 1161600))
	Solver time: 5.547698e+00
	Solver iterations: 16
Darcy_FE.py on a arch-linux2-c-opt named wf153.localdomain with 48 processors, by jychang48 Wed Mar  2 17:38:33 2016
Time (sec):           2.058e+01      1.00033   2.058e+01
Objects:              6.040e+02      1.26360   4.931e+02
Flops:                5.665e+07      1.15192   5.290e+07  2.539e+09
Flops/sec:            2.753e+06      1.15212   2.571e+06  1.234e+08
MPI Messages:         3.949e+03      4.19214   1.888e+03  9.063e+04
MPI Message Lengths:  1.799e+08     13.98669   9.756e+03  8.842e+08
MPI Reductions:       4.320e+02      1.00000
 0:      Main Stage: 1.5032e+01  73.0%  0.0000e+00   0.0%  6.669e+04  73.6%  9.138e+03       93.7%  1.250e+02  28.9%
 1:             FEM: 5.5477e+00  27.0%  2.5394e+09 100.0%  2.394e+04  26.4%  6.183e+02        6.3%  3.060e+02  70.8%
Phase summary info:
BuildTwoSided         44 1.0 1.3304e+0082.7 0.00e+00 0.0 1.6e+04 4.0e+00 4.4e+01  6  0 18  0 10   8  0 24  0 35     0
VecScatterBegin        2 1.0 2.3127e-05 1.4 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecScatterEnd          2 1.0 8.8215e-06 3.1 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
Mesh Partition         2 1.0 2.1502e+00 1.1 0.00e+00 0.0 2.7e+04 2.8e+03 2.1e+01 10  0 30  9  5  14  0 40  9 17     0
Mesh Migration         2 1.0 4.0710e-01 1.0 0.00e+00 0.0 3.4e+04 1.9e+04 5.4e+01  2  0 38 75 12   3  0 51 80 43     0
DMPlexInterp           1 1.0 2.1277e+0062846.1 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
DMPlexDistribute       1 1.0 2.4059e+00 1.1 0.00e+00 0.0 1.9e+04 1.7e+04 2.5e+01 12  0 21 37  6  16  0 29 40 20     0
DMPlexDistCones        2 1.0 9.4815e-02 1.2 0.00e+00 0.0 5.1e+03 4.3e+04 4.0e+00  0  0  6 25  1   1  0  8 26  3     0
DMPlexDistLabels       2 1.0 2.6481e-01 1.0 0.00e+00 0.0 2.1e+04 1.8e+04 2.2e+01  1  0 23 42  5   2  0 31 45 18     0
DMPlexDistribOL        1 1.0 1.7179e-01 1.1 0.00e+00 0.0 4.2e+04 1.1e+04 5.0e+01  1  0 47 52 12   1  0 64 55 40     0
DMPlexDistField        3 1.0 3.1440e-02 2.3 0.00e+00 0.0 6.8e+03 4.5e+03 1.2e+01  0  0  8  3  3   0  0 10  4 10     0
DMPlexDistData         2 1.0 1.0401e+0067.8 0.00e+00 0.0 2.1e+04 1.7e+03 6.0e+00  5  0 23  4  1   7  0 31  4  5     0
DMPlexStratify         6 1.5 5.3913e-0141.6 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
SFSetGraph            51 1.0 3.6406e-02 1.6 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
SFBcastBegin          95 1.0 1.3376e+00 6.7 0.00e+00 0.0 6.4e+04 1.3e+04 4.1e+01  6  0 71 91  9   8  0 96 97 33     0
SFBcastEnd            95 1.0 3.0287e-01 6.2 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  1  0  0  0  0   2  0  0  0  0     0
SFReduceBegin          4 1.0 9.4006e-0323.4 0.00e+00 0.0 2.0e+03 8.2e+03 3.0e+00  0  0  2  2  1   0  0  3  2  2     0
SFReduceEnd            4 1.0 9.3119e-03 7.4 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
SFFetchOpBegin         1 1.0 3.3855e-0515.8 0.00e+00 0.0 2.2e+02 1.7e+03 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
SFFetchOpEnd           1 1.0 1.2398e-04 2.5 0.00e+00 0.0 2.2e+02 1.7e+03 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
BuildTwoSided          1 1.0 1.3649e-0317.7 0.00e+00 0.0 4.6e+02 4.0e+00 1.0e+00  0  0  1  0  0   0  0  2  0  0     0
VecMDot               16 1.0 4.8552e-03 1.3 6.76e+06 1.1 0.0e+00 0.0e+00 1.6e+01  0 12  0  0  4   0 12  0  0  5 65075
VecNorm               17 1.0 1.2991e-03 1.5 8.45e+05 1.1 0.0e+00 0.0e+00 1.7e+01  0  2  0  0  4   0  2  0  0  6 30400
VecScale              34 1.0 4.4942e-04 1.2 7.09e+05 1.1 0.0e+00 0.0e+00 0.0e+00  0  1  0  0  0   0  1  0  0  0 73353
VecCopy                1 1.0 1.1802e-04 1.9 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecSet               110 1.0 9.8443e-04 1.2 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecAXPY                1 1.0 7.2956e-05 2.3 4.97e+04 1.1 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0 31844
VecMAXPY              17 1.0 1.9226e-03 1.2 7.56e+06 1.1 0.0e+00 0.0e+00 0.0e+00  0 14  0  0  0   0 14  0  0  0 183671
VecScatterBegin      155 1.0 2.6774e-03 1.6 0.00e+00 0.0 1.8e+04 1.3e+03 0.0e+00  0  0 19  3  0   0  0 74 42  0     0
VecScatterEnd        155 1.0 1.3506e-03 3.4 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecNormalize          17 1.0 1.6842e-03 1.3 1.27e+06 1.1 0.0e+00 0.0e+00 1.7e+01  0  2  0  0  4   0  2  0  0  6 35175
MatMult               33 1.0 1.3046e-02 1.2 7.76e+06 1.1 1.8e+04 1.3e+03 1.3e+02  0 14 19  3 30   0 14 74 42 42 27561
MatMultAdd            64 1.0 8.1303e-03 1.2 6.63e+06 1.1 1.4e+04 1.4e+03 0.0e+00  0 12 15  2  0   0 12 58 35  0 37821
MatSolve              17 1.0 5.3048e-03 1.1 3.55e+06 1.1 0.0e+00 0.0e+00 0.0e+00  0  6  0  0  0   0  6  0  0  0 30925
MatLUFactorNum         1 1.0 1.4539e-03 1.1 3.97e+05 1.1 0.0e+00 0.0e+00 0.0e+00  0  1  0  0  0   0  1  0  0  0 12306
MatILUFactorSym        1 1.0 5.9080e-04 1.1 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatConvert             2 1.0 1.2629e-03 1.3 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatScale               2 1.0 1.9281e-0315.4 1.13e+05 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0  2766
MatAssemblyBegin      12 1.0 3.2587e-0318.4 0.00e+00 0.0 0.0e+00 0.0e+00 6.0e+00  0  0  0  0  1   0  0  0  0  2     0
MatAssemblyEnd        12 1.0 8.6644e-03 1.2 0.00e+00 0.0 3.5e+03 3.1e+02 4.8e+01  0  0  4  0 11   0  0 15  2 16     0
MatGetRow          16000 1.0 6.3950e-02 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   1  0  0  0  0     0
MatGetRowIJ            3 1.0 1.0729e-05 3.5 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatGetSubMatrix        4 1.0 9.5296e-04 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 6.0e+00  0  0  0  0  1   0  0  0  0  2     0
MatGetOrdering         1 1.0 7.7963e-05 1.2 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatAXPY                1 1.0 1.3025e-01 1.0 0.00e+00 0.0 8.6e+02 2.7e+02 1.2e+01  1  0  1  0  3   2  0  4  0  4     0
MatMatMult             1 1.0 9.7330e-03 1.0 2.08e+05 1.0 1.7e+03 8.9e+02 1.6e+01  0  0  2  0  4   0  0  7  3  5  1017
MatMatMultSym          1 1.0 8.7850e-03 1.0 0.00e+00 0.0 1.5e+03 7.0e+02 1.4e+01  0  0  2  0  3   0  0  6  2  5     0
MatMatMultNum          1 1.0 9.3794e-04 1.0 2.08e+05 1.0 2.2e+02 2.2e+03 2.0e+00  0  0  0  0  0   0  0  1  1  1 10554
MatGetLocalMat         2 1.0 1.0867e-03 1.5 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatGetBrAoCol          2 1.0 6.5875e-04 3.9 0.00e+00 0.0 8.6e+02 1.5e+03 0.0e+00  0  0  1  0  0   0  0  4  2  0     0
PCSetUp                4 1.0 4.8043e+00 1.0 7.17e+05 1.1 2.8e+03 4.0e+03 6.6e+01 23  1  3  1 15  87  1 12 20 22     7
PCSetUpOnBlocks       17 1.0 2.2023e-03 1.1 3.97e+05 1.1 0.0e+00 0.0e+00 0.0e+00  0  1  0  0  0   0  1  0  0  0  8124
PCApply               17 1.0 5.2019e+00 1.0 5.36e+06 1.1 3.7e+03 1.1e+03 4.0e+00 25 10  4  0  1  94 10 15  7  1    48
KSPGMRESOrthog        16 1.0 6.3984e-03 1.2 1.35e+07 1.1 0.0e+00 0.0e+00 1.6e+01  0 25  0  0  4   0 25  0  0  5 98759
KSPSetUp               4 1.0 3.8409e-04 3.3 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
KSPSolve               1 1.0 5.3660e+00 1.0 2.80e+07 1.1 2.0e+04 1.7e+03 2.3e+02 26 51 23  4 53  97 51 85 62 74   242
SFBcastBegin           1 1.0 1.4529e-03 8.4 0.00e+00 0.0 1.4e+03 1.7e+03 1.0e+00  0  0  2  0  0   0  0  6  4  0     0
SFBcastEnd             1 1.0 7.1597e-0450.9 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
--- Event Stage 0: Main Stage
              Viewer     1              0            0     0.
           Index Set   195            195     22892240     0.
   IS L to G Mapping     3              3     14076928     0.
              Vector    15             45     10511976     0.
      Vector Scatter     2              7       568432     0.
              Matrix     0              5      2614408     0.
      Preconditioner     0              5         5176     0.
       Krylov Solver     0              5        23264     0.
--- Event Stage 1: FEM
           Index Set    31             24        42440     0.
              Vector   118             76       575296     0.
              Matrix    26              8      2166428     0.
       Krylov Solver     6              1         1352     0.
Average time for MPI_Barrier(): 8.96454e-06
Average time for zero size MPI_Send(): 1.35601e-06
-log_summary
-solver_fieldsplit_1_pc_type hypre
 hypre 40 1
Discretization: RT
MPI processes 56: solving...
((20104, 1161600), (20104, 1161600))
	Solver time: 5.245087e+00
***             WIDEN YOUR WINDOW TO 120 CHARACTERS.  Use 'enscript -r -fCourier9' to print this document            ***
---------------------------------------------- PETSc Performance Summary: ----------------------------------------------
Darcy_FE.py on a arch-linux2-c-opt named wf153.localdomain with 56 processors, by jychang48 Wed Mar  2 17:38:56 2016
Using Petsc Development GIT revision: v3.6.3-1924-ge972cd5  GIT Date: 2016-01-01 10:01:13 -0600
                         Max       Max/Min        Avg      Total
Time (sec):           1.992e+01      1.00032   1.991e+01
Objects:              6.220e+02      1.29583   4.939e+02
Flops:                4.935e+07      1.17708   4.599e+07  2.575e+09
Flops/sec:            2.478e+06      1.17720   2.310e+06  1.293e+08
MPI Messages:         4.414e+03      3.94944   2.001e+03  1.120e+05
MPI Message Lengths:  1.783e+08     16.37358   8.092e+03  9.066e+08
Flop counting convention: 1 flop = 1 real number operation of type (multiply/divide/add/subtract)
                            e.g., VecAXPY() for real vectors of length N --> 2N flops
                            and VecAXPY() for complex vectors of length N --> 8N flops
Summary of Stages:   ----- Time ------  ----- Flops -----  --- Messages ---  -- Message Lengths --  -- Reductions --
                        Avg     %Total     Avg     %Total   counts   %Total     Avg         %Total   counts   %Total
 0:      Main Stage: 1.4666e+01  73.7%  0.0000e+00   0.0%  8.318e+04  74.3%  7.573e+03       93.6%  1.250e+02  28.9%
 1:             FEM: 5.2451e+00  26.3%  2.5753e+09 100.0%  2.884e+04  25.7%  5.196e+02        6.4%  3.060e+02  70.8%
See the 'Profiling' chapter of the users' manual for details on interpreting output.
Phase summary info:
   Count: number of times phase was executed
   Time and Flops: Max - maximum over all processors
                   Ratio - ratio of maximum to minimum over all processors
   Mess: number of messages sent
   Avg. len: average message length (bytes)
   Reduct: number of global reductions
   Global: entire computation
   Stage: stages of a computation. Set stages with PetscLogStagePush() and PetscLogStagePop().
      %T - percent time in this phase         %F - percent flops in this phase
      %M - percent messages in this phase     %L - percent message lengths in this phase
      %R - percent reductions in this phase
   Total Mflop/s: 10e-6 * (sum of flops over all processors)/(max time over all processors)
Event                Count      Time (sec)     Flops                             --- Global ---  --- Stage ---   Total
                   Max Ratio  Max     Ratio   Max  Ratio  Mess   Avg len Reduct  %T %F %M %L %R  %T %F %M %L %R Mflop/s
BuildTwoSided         44 1.0 1.2130e+0012.1 0.00e+00 0.0 2.0e+04 4.0e+00 4.4e+01  6  0 18  0 10   8  0 24  0 35     0
VecScatterBegin        2 1.0 2.5034e-05 1.7 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
Mesh Partition         2 1.0 2.1797e+00 1.1 0.00e+00 0.0 3.5e+04 2.2e+03 2.1e+01 11  0 31  9  5  15  0 42  9 17     0
Mesh Migration         2 1.0 3.9948e-01 1.0 0.00e+00 0.0 4.1e+04 1.6e+04 5.4e+01  2  0 37 74 12   3  0 50 79 43     0
DMPlexInterp           1 1.0 2.1081e+0065986.7 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
DMPlexDistribute       1 1.0 2.4434e+00 1.1 0.00e+00 0.0 2.6e+04 1.3e+04 2.5e+01 12  0 23 36  6  17  0 31 39 20     0
DMPlexDistCones        2 1.0 9.4779e-02 1.2 0.00e+00 0.0 6.2e+03 3.6e+04 4.0e+00  0  0  5 25  1   1  0  7 26  3     0
DMPlexDistLabels       2 1.0 2.6069e-01 1.0 0.00e+00 0.0 2.5e+04 1.5e+04 2.2e+01  1  0 22 42  5   2  0 30 45 18     0
DMPlexDistribOL        1 1.0 1.5735e-01 1.1 0.00e+00 0.0 5.1e+04 9.2e+03 5.0e+01  1  0 46 52 12   1  0 62 56 40     0
DMPlexDistField        3 1.0 3.0454e-02 2.4 0.00e+00 0.0 8.3e+03 3.8e+03 1.2e+01  0  0  7  3  3   0  0 10  4 10     0
DMPlexDistData         2 1.0 1.0585e+0051.5 0.00e+00 0.0 2.8e+04 1.3e+03 6.0e+00  5  0 25  4  1   7  0 33  4  5     0
DMPlexStratify         6 1.5 5.3799e-0149.7 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
SFSetGraph            51 1.0 3.2726e-02 1.7 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
SFBcastBegin          95 1.0 1.2201e+00 4.0 0.00e+00 0.0 8.0e+04 1.0e+04 4.1e+01  6  0 71 91  9   8  0 96 97 33     0
SFBcastEnd            95 1.0 2.9608e-01 8.5 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  1  0  0  0  0   2  0  0  0  0     0
SFReduceBegin          4 1.0 9.1550e-0324.3 0.00e+00 0.0 2.5e+03 6.8e+03 3.0e+00  0  0  2  2  1   0  0  3  2  2     0
SFReduceEnd            4 1.0 1.0157e-02 8.1 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
SFFetchOpBegin         1 1.0 3.2902e-0517.2 0.00e+00 0.0 2.7e+02 1.5e+03 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
SFFetchOpEnd           1 1.0 1.2207e-04 2.7 0.00e+00 0.0 2.7e+02 1.5e+03 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
BuildTwoSided          1 1.0 1.4939e-0332.5 0.00e+00 0.0 5.6e+02 4.0e+00 1.0e+00  0  0  0  0  0   0  0  2  0  0     0
VecMDot               16 1.0 4.8904e-03 1.5 5.80e+06 1.1 0.0e+00 0.0e+00 1.6e+01  0 12  0  0  4   0 12  0  0  5 64605
VecNorm               17 1.0 1.1060e-03 1.5 7.25e+05 1.1 0.0e+00 0.0e+00 1.7e+01  0  2  0  0  4   0  2  0  0  6 35708
VecScale              34 1.0 4.6110e-04 1.4 6.08e+05 1.1 0.0e+00 0.0e+00 0.0e+00  0  1  0  0  0   0  1  0  0  0 71495
VecCopy                1 1.0 7.5102e-05 2.4 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecSet               110 1.0 8.4519e-04 1.2 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecAXPY                1 1.0 4.8161e-05 1.8 4.26e+04 1.1 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0 48239
VecMAXPY              17 1.0 1.5872e-03 1.2 6.48e+06 1.1 0.0e+00 0.0e+00 0.0e+00  0 14  0  0  0   0 14  0  0  0 222491
VecScatterBegin      155 1.0 2.4736e-03 1.6 0.00e+00 0.0 2.1e+04 1.2e+03 0.0e+00  0  0 19  3  0   0  0 74 43  0     0
VecScatterEnd        155 1.0 1.1752e-03 2.6 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecNormalize          17 1.0 1.4255e-03 1.4 1.09e+06 1.1 0.0e+00 0.0e+00 1.7e+01  0  2  0  0  4   0  2  0  0  6 41558
MatMult               33 1.0 1.2118e-02 1.2 6.64e+06 1.1 2.1e+04 1.2e+03 1.3e+02  0 14 19  3 30   0 14 74 43 42 29670
MatMultAdd            64 1.0 7.1990e-03 1.3 5.67e+06 1.1 1.7e+04 1.3e+03 0.0e+00  0 12 15  2  0   0 12 58 36  0 42713
MatSolve              17 1.0 4.6377e-03 1.1 3.05e+06 1.1 0.0e+00 0.0e+00 0.0e+00  0  6  0  0  0   0  6  0  0  0 35279
MatLUFactorNum         1 1.0 1.2581e-03 1.1 3.40e+05 1.1 0.0e+00 0.0e+00 0.0e+00  0  1  0  0  0   0  1  0  0  0 14188
MatILUFactorSym        1 1.0 5.0306e-04 1.2 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatConvert             2 1.0 1.0850e-03 1.4 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatScale               2 1.0 1.8859e-0317.4 9.68e+04 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0  2827
MatAssemblyBegin      12 1.0 3.0339e-0318.7 0.00e+00 0.0 0.0e+00 0.0e+00 6.0e+00  0  0  0  0  1   0  0  0  0  2     0
MatAssemblyEnd        12 1.0 8.4910e-03 1.4 0.00e+00 0.0 4.2e+03 2.8e+02 4.8e+01  0  0  4  0 11   0  0 15  2 16     0
MatGetRow          13716 1.0 5.4852e-02 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   1  0  0  0  0     0
MatGetRowIJ            3 1.0 9.2983e-06 3.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatGetSubMatrix        4 1.0 8.1325e-04 1.1 0.00e+00 0.0 0.0e+00 0.0e+00 6.0e+00  0  0  0  0  1   0  0  0  0  2     0
MatGetOrdering         1 1.0 6.8188e-05 1.2 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatAXPY                1 1.0 1.1231e-01 1.0 0.00e+00 0.0 1.0e+03 2.4e+02 1.2e+01  1  0  1  0  3   2  0  4  0  4     0
MatMatMult             1 1.0 8.4488e-03 1.0 1.78e+05 1.0 2.1e+03 8.0e+02 1.6e+01  0  0  2  0  4   0  0  7  3  5  1171
MatMatMultSym          1 1.0 7.6680e-03 1.1 0.00e+00 0.0 1.8e+03 6.3e+02 1.4e+01  0  0  2  0  3   0  0  6  2  5     0
MatMatMultNum          1 1.0 7.8893e-04 1.0 1.78e+05 1.0 2.6e+02 2.0e+03 2.0e+00  0  0  0  0  0   0  0  1  1  1 12545
MatGetLocalMat         2 1.0 9.2196e-04 1.4 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatGetBrAoCol          2 1.0 5.2214e-04 3.5 0.00e+00 0.0 1.0e+03 1.4e+03 0.0e+00  0  0  1  0  0   0  0  4  2  0     0
PCSetUp                4 1.0 4.5953e+00 1.0 6.15e+05 1.1 3.4e+03 3.3e+03 6.6e+01 23  1  3  1 15  88  1 12 19 22     7
PCSetUpOnBlocks       17 1.0 1.9102e-03 1.1 3.40e+05 1.1 0.0e+00 0.0e+00 0.0e+00  0  1  0  0  0   0  1  0  0  0  9345
PCApply               17 1.0 4.9382e+00 1.0 4.60e+06 1.1 4.4e+03 9.4e+02 4.0e+00 25 10  4  0  1  94 10 15  7  1    50
KSPGMRESOrthog        16 1.0 6.3207e-03 1.3 1.16e+07 1.1 0.0e+00 0.0e+00 1.6e+01  0 25  0  0  4   0 25  0  0  5 99973
KSPSetUp               4 1.0 3.2091e-04 3.2 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
KSPSolve               1 1.0 5.0805e+00 1.0 2.39e+07 1.1 2.5e+04 1.5e+03 2.3e+02 26 50 22  4 53  97 50 85 63 74   256
SFBcastBegin           1 1.0 1.5471e-0310.0 0.00e+00 0.0 1.7e+03 1.5e+03 1.0e+00  0  0  1  0  0   0  0  6  4  0     0
SFBcastEnd             1 1.0 6.0892e-0451.1 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
              Viewer     1              0            0     0.
           Index Set   213            213     22655968     0.
   IS L to G Mapping     3              3     12801292     0.
              Vector    15             45      9747824     0.
      Vector Scatter     2              7       490168     0.
              Matrix     0              5      2241752     0.
           Index Set    31             24        38312     0.
              Vector   118             76       511680     0.
      Vector Scatter    13              2         2192     0.
              Matrix    26              8      1858040     0.
      Preconditioner     6              1          896     0.
Average time for MPI_Barrier(): 1.07765e-05
Average time for zero size MPI_Send(): 1.37516e-06
-log_summary
 hypre 40 1
Discretization: RT
MPI processes 64: solving...
((17544, 1161600), (17544, 1161600))
	Solver time: 5.107411e+00
Darcy_FE.py on a arch-linux2-c-opt named wf153.localdomain with 64 processors, by jychang48 Wed Mar  2 17:39:20 2016
Time (sec):           1.985e+01      1.00035   1.984e+01
Objects:              6.360e+02      1.33054   4.947e+02
Flops:                4.357e+07      1.18779   4.072e+07  2.606e+09
Flops/sec:            2.196e+06      1.18785   2.052e+06  1.314e+08
MPI Messages:         4.678e+03      4.58129   2.100e+03  1.344e+05
MPI Message Lengths:  1.774e+08     18.56783   6.891e+03  9.262e+08
 0:      Main Stage: 1.4735e+01  74.3%  0.0000e+00   0.0%  1.007e+05  74.9%  6.442e+03       93.5%  1.250e+02  28.9%
 1:             FEM: 5.1075e+00  25.7%  2.6063e+09 100.0%  3.371e+04  25.1%  4.482e+02        6.5%  3.060e+02  70.8%
Phase summary info:
BuildTwoSided         44 1.0 1.2411e+0012.0 0.00e+00 0.0 2.4e+04 4.0e+00 4.4e+01  6  0 18  0 10   8  0 24  0 35     0
VecScatterBegin        2 1.0 5.1975e-05 4.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
Mesh Partition         2 1.0 2.2346e+00 1.1 0.00e+00 0.0 4.4e+04 1.8e+03 2.1e+01 11  0 33  9  5  15  0 44  9 17     0
Mesh Migration         2 1.0 3.9620e-01 1.0 0.00e+00 0.0 4.9e+04 1.4e+04 5.4e+01  2  0 36 74 12   3  0 48 79 43     0
DMPlexInterp           1 1.0 2.1139e+0058718.7 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
DMPlexDistribute       1 1.0 2.5038e+00 1.1 0.00e+00 0.0 3.3e+04 1.0e+04 2.5e+01 13  0 25 36  6  17  0 33 38 20     0
DMPlexDistCones        2 1.0 9.2579e-02 1.2 0.00e+00 0.0 7.2e+03 3.1e+04 4.0e+00  0  0  5 25  1   1  0  7 26  3     0
DMPlexDistLabels       2 1.0 2.5964e-01 1.0 0.00e+00 0.0 2.9e+04 1.3e+04 2.2e+01  1  0 22 42  5   2  0 29 45 18     0
DMPlexDistribOL        1 1.0 1.4357e-01 1.1 0.00e+00 0.0 6.1e+04 8.0e+03 5.0e+01  1  0 45 52 12   1  0 60 56 40     0
DMPlexDistField        3 1.0 3.1811e-02 2.4 0.00e+00 0.0 9.7e+03 3.4e+03 1.2e+01  0  0  7  4  3   0  0 10  4 10     0
DMPlexDistData         2 1.0 1.0804e+0051.6 0.00e+00 0.0 3.5e+04 1.0e+03 6.0e+00  5  0 26  4  1   7  0 35  4  5     0
DMPlexStratify         6 1.5 5.3848e-0156.5 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
SFSetGraph            51 1.0 2.8280e-02 1.7 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
SFBcastBegin          95 1.0 1.2476e+00 4.0 0.00e+00 0.0 9.7e+04 8.7e+03 4.1e+01  6  0 72 91  9   8  0 96 97 33     0
SFBcastEnd            95 1.0 3.0134e-0110.3 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  1  0  0  0  0   2  0  0  0  0     0
SFReduceBegin          4 1.0 9.5589e-0322.9 0.00e+00 0.0 2.9e+03 5.8e+03 3.0e+00  0  0  2  2  1   0  0  3  2  2     0
SFReduceEnd            4 1.0 9.6300e-03 8.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
SFFetchOpBegin         1 1.0 3.2902e-0515.3 0.00e+00 0.0 3.2e+02 1.3e+03 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
SFFetchOpEnd           1 1.0 1.2994e-04 3.1 0.00e+00 0.0 3.2e+02 1.3e+03 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
BuildTwoSided          1 1.0 1.2991e-0318.9 0.00e+00 0.0 6.5e+02 4.0e+00 1.0e+00  0  0  0  0  0   0  0  2  0  0     0
VecMDot               16 1.0 5.5118e-03 1.9 5.08e+06 1.1 0.0e+00 0.0e+00 1.6e+01  0 12  0  0  4   0 12  0  0  5 57322
VecNorm               17 1.0 1.2081e-03 1.3 6.35e+05 1.1 0.0e+00 0.0e+00 1.7e+01  0  2  0  0  4   0  2  0  0  6 32692
VecScale              34 1.0 3.6025e-04 1.2 5.33e+05 1.1 0.0e+00 0.0e+00 0.0e+00  0  1  0  0  0   0  1  0  0  0 91510
VecCopy                1 1.0 5.5075e-05 1.6 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecSet               110 1.0 7.6127e-04 1.2 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecAXPY                1 1.0 4.4823e-05 1.8 3.73e+04 1.1 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0 51831
VecMAXPY              17 1.0 1.3549e-03 1.1 5.68e+06 1.1 0.0e+00 0.0e+00 0.0e+00  0 14  0  0  0   0 14  0  0  0 260623
VecScatterBegin      155 1.0 2.3611e-03 1.6 0.00e+00 0.0 2.5e+04 1.1e+03 0.0e+00  0  0 18  3  0   0  0 74 45  0     0
VecScatterEnd        155 1.0 1.4179e-03 3.1 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecNormalize          17 1.0 1.5237e-03 1.3 9.52e+05 1.1 0.0e+00 0.0e+00 1.7e+01  0  2  0  0  4   0  2  0  0  6 38879
MatMult               33 1.0 1.1678e-02 1.2 5.80e+06 1.1 2.5e+04 1.1e+03 1.3e+02  0 14 18  3 30   0 14 74 45 42 30787
MatMultAdd            64 1.0 6.7151e-03 1.3 4.96e+06 1.1 2.0e+04 1.1e+03 0.0e+00  0 12 15  2  0   0 12 58 37  0 45791
MatSolve              17 1.0 4.0982e-03 1.1 2.67e+06 1.1 0.0e+00 0.0e+00 0.0e+00  0  6  0  0  0   0  6  0  0  0 39822
MatLUFactorNum         1 1.0 1.1230e-03 1.1 2.96e+05 1.1 0.0e+00 0.0e+00 0.0e+00  0  1  0  0  0   0  1  0  0  0 15869
MatILUFactorSym        1 1.0 4.8018e-04 1.2 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatConvert             2 1.0 9.8610e-04 1.4 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatScale               2 1.0 2.9418e-0330.9 8.46e+04 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0  1812
MatAssemblyBegin      12 1.0 2.3770e-0314.8 0.00e+00 0.0 0.0e+00 0.0e+00 6.0e+00  0  0  0  0  1   0  0  0  0  2     0
MatAssemblyEnd        12 1.0 7.4003e-03 1.4 0.00e+00 0.0 4.9e+03 2.5e+02 4.8e+01  0  0  4  0 11   0  0 15  2 16     0
MatGetRow          12000 1.0 4.7642e-02 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   1  0  0  0  0     0
MatGetRowIJ            3 1.0 1.1206e-05 3.9 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatGetSubMatrix        4 1.0 6.6686e-04 1.1 0.00e+00 0.0 0.0e+00 0.0e+00 6.0e+00  0  0  0  0  1   0  0  0  0  2     0
MatGetOrdering         1 1.0 6.3181e-05 1.2 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatAXPY                1 1.0 9.9198e-02 1.0 0.00e+00 0.0 1.2e+03 2.2e+02 1.2e+01  0  0  1  0  3   2  0  4  0  4     0
MatMatMult             1 1.0 7.7269e-03 1.0 1.56e+05 1.0 2.4e+03 7.3e+02 1.6e+01  0  0  2  0  4   0  0  7  3  5  1281
MatMatMultSym          1 1.0 7.0100e-03 1.0 0.00e+00 0.0 2.1e+03 5.8e+02 1.4e+01  0  0  2  0  3   0  0  6  2  5     0
MatMatMultNum          1 1.0 7.3886e-04 1.1 1.56e+05 1.0 3.1e+02 1.8e+03 2.0e+00  0  0  0  0  0   0  0  1  1  1 13397
MatGetLocalMat         2 1.0 8.2898e-04 1.4 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatGetBrAoCol          2 1.0 4.1103e-04 2.6 0.00e+00 0.0 1.2e+03 1.2e+03 0.0e+00  0  0  1  0  0   0  0  4  3  0     0
PCSetUp                4 1.0 4.4948e+00 1.0 5.36e+05 1.1 3.9e+03 2.9e+03 6.6e+01 23  1  3  1 15  88  1 12 19 22     7
PCSetUpOnBlocks       17 1.0 1.6925e-03 1.1 2.96e+05 1.1 0.0e+00 0.0e+00 0.0e+00  0  1  0  0  0   0  1  0  0  0 10529
PCApply               17 1.0 4.8126e+00 1.0 4.02e+06 1.1 5.2e+03 8.5e+02 4.0e+00 24  9  4  0  1  94  9 15  7  1    51
KSPGMRESOrthog        16 1.0 6.7701e-03 1.6 1.02e+07 1.1 0.0e+00 0.0e+00 1.6e+01  0 24  0  0  4   0 24  0  0  5 93337
KSPSetUp               4 1.0 2.9278e-04 3.2 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
KSPSolve               1 1.0 4.9404e+00 1.0 2.09e+07 1.1 2.9e+04 1.3e+03 2.3e+02 25 50 21  4 53  97 50 85 64 74   263
SFBcastBegin           1 1.0 1.3502e-03 8.5 0.00e+00 0.0 2.0e+03 1.4e+03 1.0e+00  0  0  1  0  0   0  0  6  4  0     0
SFBcastEnd             1 1.0 6.3281e-03530.8 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
Memory usage is given in bytes:
Object Type          Creations   Destructions     Memory  Descendants' Mem.
Reports information only for process 0.
           Container     6              3         1728     0.
              Viewer     1              0            0     0.
           Index Set   227            227     22503312     0.
   IS L to G Mapping     3              3     12541056     0.
              Vector    15             45      9148440     0.
      Vector Scatter     2              7       428728     0.
              Matrix     0              5      1962204     0.
           Index Set    31             24        36680     0.
   IS L to G Mapping     4              0            0     0.
              Vector   118             76       463200     0.
              Matrix    26              8      1629940     0.
Average time to get PetscTime(): 6.19888e-07
Average time for MPI_Barrier(): 1.2207e-05
Average time for zero size MPI_Send(): 1.64285e-06
#PETSc Option Table entries:
-log_summary
-solver_fieldsplit_0_ksp_type preonly
-solver_fieldsplit_0_pc_type bjacobi
-solver_fieldsplit_1_ksp_type preonly
-solver_ksp_rtol 1e-7
-solver_ksp_type gmres
-solver_pc_fieldsplit_schur_fact_type upper
-solver_pc_fieldsplit_schur_precondition selfp
-solver_pc_fieldsplit_type schur
-solver_pc_type fieldsplit
#End of PETSc Option Table entries
Compiled without FORTRAN kernels
Compiled with full precision matrices (default)
sizeof(short) 2 sizeof(int) 4 sizeof(long) 8 sizeof(void*) 8 sizeof(PetscScalar) 8 sizeof(PetscInt) 4
Configure options: --download-chaco=/users/jychang48/externalpackages/Chaco-2.2-p2.tar.gz --download-ctetgen=/users/jychang48/externalpackages/ctetgen-0.4.tar.gz --download-exodusii=/users/jychang48/externalpackages/exodus-5.24.tar.bz2 --download-fblaslapack=/users/jychang48/externalpackages/fblaslapack-3.4.2.tar.gz --download-hdf5=/users/jychang48/externalpackages/hdf5-1.8.12.tar.gz --download-hypre=/users/jychang48/externalpackages/hypre-2.10.0b-p1.tar.gz --download-metis=/users/jychang48/externalpackages/metis-5.1.0-p1.tar.gz --download-ml=/users/jychang48/externalpackages/ml-6.2-p3.tar.gz --download-mumps=/users/jychang48/externalpackages/MUMPS_5.0.1-p1.tar.gz --download-netcdf=/users/jychang48/externalpackages/netcdf-4.3.2.tar.gz --download-parmetis=/users/jychang48/externalpackages/parmetis-4.0.3-p2.tar.gz --download-scalapack=/users/jychang48/externalpackages/scalapack-2.0.2.tgz --download-superlu_dist --download-triangle=/users/jychang48/externalpackages/Triangle.tar.gz --with-cc=mpicc --with-cxx=mpicxx --with-debugging=0 --with-fc=mpif90 --with-papi=/usr/projects/hpcsoft/toss2/common/papi/5.4.1 --with-shared-libraries COPTFLAGS=-O3 CXXOPTFLAGS=-O3 FOPTFLAGS=-O3 PETSC_ARCH=arch-linux2-c-opt
Libraries compiled on Fri Jan  1 21:44:06 2016 on wf-fe2.lanl.gov
Machine characteristics: Linux-2.6.32-573.8.1.2chaos.ch5.4.x86_64-x86_64-with-redhat-6.7-Santiago
Using PETSc directory: /users/jychang48/petsc
Using PETSc arch: arch-linux2-c-opt
Using C compiler: mpicc  -fPIC  -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -O3  ${COPTFLAGS} ${CFLAGS}
Using Fortran compiler: mpif90  -fPIC -Wall -Wno-unused-variable -ffree-line-length-0 -Wno-unused-dummy-argument -O3   ${FOPTFLAGS} ${FFLAGS}
Using include paths: -I/users/jychang48/petsc/arch-linux2-c-opt/include -I/users/jychang48/petsc/include -I/users/jychang48/petsc/include -I/users/jychang48/petsc/arch-linux2-c-opt/include -I/usr/projects/hpcsoft/toss2.2/wolf/openmpi/1.6.5-gcc-4.8/include/openmpi/opal/mca/hwloc/hwloc132/hwloc/include -I/usr/projects/hpcsoft/toss2.2/wolf/openmpi/1.6.5-gcc-4.8/include -I/usr/projects/hpcsoft/toss2.2/wolf/openmpi/1.6.5-gcc-4.8/include/openmpi
Using C linker: mpicc
Using Fortran linker: mpif90
Using libraries: -Wl,-rpath,/users/jychang48/petsc/arch-linux2-c-opt/lib -L/users/jychang48/petsc/arch-linux2-c-opt/lib -lpetsc -Wl,-rpath,/users/jychang48/petsc/arch-linux2-c-opt/lib -L/users/jychang48/petsc/arch-linux2-c-opt/lib -lcmumps -ldmumps -lsmumps -lzmumps -lmumps_common -lpord -lscalapack -lsuperlu_dist_4.2 -lHYPRE -Wl,-rpath,/usr/projects/hpcsoft/toss2.2/wolf/openmpi/1.6.5-gcc-4.8/lib -L/usr/projects/hpcsoft/toss2.2/wolf/openmpi/1.6.5-gcc-4.8/lib -Wl,-rpath,/turquoise/usr/projects/hpcsoft/toss2/common/gcc/4.8.2/lib/gcc/x86_64-unknown-linux-gnu/4.8.2 -L/turquoise/usr/projects/hpcsoft/toss2/common/gcc/4.8.2/lib/gcc/x86_64-unknown-linux-gnu/4.8.2 -Wl,-rpath,/turquoise/usr/projects/hpcsoft/toss2/common/gcc/4.8.2/lib/gcc -L/turquoise/usr/projects/hpcsoft/toss2/common/gcc/4.8.2/lib/gcc -Wl,-rpath,/turquoise/usr/projects/hpcsoft/toss2/common/gcc/4.8.2/lib64 -L/turquoise/usr/projects/hpcsoft/toss2/common/gcc/4.8.2/lib64 -Wl,-rpath,/turquoise/usr/projects/hpcsoft/toss2/common/gcc/4.8.2/lib -L/turquoise/usr/projects/hpcsoft/toss2/common/gcc/4.8.2/lib -lmpi_cxx -lstdc++ -lml -lmpi_cxx -lstdc++ -lflapack -lfblas -lparmetis -lmetis -lchaco -lexoIIv2for -lexodus -lnetcdf -lhdf5hl_fortran -lhdf5_fortran -lhdf5_hl -lhdf5 -ltriangle -lX11 -lhwloc -lctetgen -lssl -lcrypto -lmpi_f90 -lmpi_f77 -lgfortran -lm -lgfortran -lm -lgfortran -lm -lgfortran -lm -lgfortran -lm -lquadmath -lm -lmpi_cxx -lstdc++ -Wl,-rpath,/usr/projects/hpcsoft/toss2.2/wolf/openmpi/1.6.5-gcc-4.8/lib -L/usr/projects/hpcsoft/toss2.2/wolf/openmpi/1.6.5-gcc-4.8/lib -Wl,-rpath,/turquoise/usr/projects/hpcsoft/toss2/common/gcc/4.8.2/lib/gcc/x86_64-unknown-linux-gnu/4.8.2 -L/turquoise/usr/projects/hpcsoft/toss2/common/gcc/4.8.2/lib/gcc/x86_64-unknown-linux-gnu/4.8.2 -Wl,-rpath,/turquoise/usr/projects/hpcsoft/toss2/common/gcc/4.8.2/lib/gcc -L/turquoise/usr/projects/hpcsoft/toss2/common/gcc/4.8.2/lib/gcc -Wl,-rpath,/turquoise/usr/projects/hpcsoft/toss2/common/gcc/4.8.2/lib64 -L/turquoise/usr/projects/hpcsoft/toss2/common/gcc/4.8.2/lib64 -Wl,-rpath,/turquoise/usr/projects/hpcsoft/toss2/common/gcc/4.8.2/lib -L/turquoise/usr/projects/hpcsoft/toss2/common/gcc/4.8.2/lib -ldl -lmpi -losmcomp -lrdmacm -libverbs -lsctp -lrt -lnsl -lutil -lpsm_infinipath -lpmi -lnuma -lgcc_s -lpthread -ldl
 ml 40 1
Discretization: RT
MPI processes 1: solving...
((1161600, 1161600), (1161600, 1161600))
	Solver time: 5.434000e+00
	Solver iterations: 14
Darcy_FE.py on a arch-linux2-c-opt named wf153.localdomain with 1 processor, by jychang48 Wed Mar  2 17:40:07 2016
Time (sec):           1.920e+01      1.00000   1.920e+01
Objects:              3.260e+02      1.00000   3.260e+02
Flops:                3.005e+09      1.00000   3.005e+09  3.005e+09
Flops/sec:            1.565e+08      1.00000   1.565e+08  1.565e+08
MPI Messages:         0.000e+00      0.00000   0.000e+00  0.000e+00
MPI Message Lengths:  0.000e+00      0.00000   0.000e+00  0.000e+00
MPI Reductions:       0.000e+00      0.00000
 0:      Main Stage: 1.3767e+01  71.7%  0.0000e+00   0.0%  0.000e+00   0.0%  0.000e+00        0.0%  0.000e+00   0.0%
 1:             FEM: 5.4340e+00  28.3%  3.0049e+09 100.0%  0.000e+00   0.0%  0.000e+00        0.0%  0.000e+00   0.0%
Phase summary info:
VecSet                 8 1.0 1.6064e-02 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecScatterBegin        2 1.0 3.6058e-03 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
DMPlexInterp           1 1.0 2.0997e+00 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 11  0  0  0  0  15  0  0  0  0     0
DMPlexStratify         4 1.0 5.1062e-01 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  3  0  0  0  0   4  0  0  0  0     0
SFSetGraph             7 1.0 2.6127e-02 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecMDot               14 1.0 8.3214e-02 1.0 2.44e+08 1.0 0.0e+00 0.0e+00 0.0e+00  0  8  0  0  0   2  8  0  0  0  2931
VecNorm               15 1.0 1.8275e-02 1.0 3.48e+07 1.0 0.0e+00 0.0e+00 0.0e+00  0  1  0  0  0   0  1  0  0  0  1907
VecScale              30 1.0 1.8777e-02 1.0 2.91e+07 1.0 0.0e+00 0.0e+00 0.0e+00  0  1  0  0  0   0  1  0  0  0  1549
VecCopy                1 1.0 2.6550e-03 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecSet               231 1.0 2.2175e-01 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  1  0  0  0  0   4  0  0  0  0     0
VecAXPY                1 1.0 1.4780e-03 1.0 2.32e+06 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0  1572
VecAYPX               75 1.0 7.5226e-03 1.0 6.78e+06 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0   901
VecMAXPY              15 1.0 9.9054e-02 1.0 2.76e+08 1.0 0.0e+00 0.0e+00 0.0e+00  1  9  0  0  0   2  9  0  0  0  2791
VecScatterBegin       66 1.0 7.1086e-02 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   1  0  0  0  0     0
VecNormalize          15 1.0 2.8637e-02 1.0 5.23e+07 1.0 0.0e+00 0.0e+00 0.0e+00  0  2  0  0  0   1  2  0  0  0  1825
MatMult              189 1.0 4.6065e-01 1.0 5.58e+08 1.0 0.0e+00 0.0e+00 0.0e+00  2 19  0  0  0   8 19  0  0  0  1212
MatMultAdd           131 1.0 2.5532e-01 1.0 3.10e+08 1.0 0.0e+00 0.0e+00 0.0e+00  1 10  0  0  0   5 10  0  0  0  1215
MatSolve              30 1.0 1.6508e-01 1.0 1.50e+08 1.0 0.0e+00 0.0e+00 0.0e+00  1  5  0  0  0   3  5  0  0  0   908
MatSOR               150 1.0 7.3408e-01 1.0 8.00e+08 1.0 0.0e+00 0.0e+00 0.0e+00  4 27  0  0  0  14 27  0  0  0  1089
MatLUFactorSym         1 1.0 1.0014e-05 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatLUFactorNum         2 1.0 6.5596e-02 1.0 1.81e+07 1.0 0.0e+00 0.0e+00 0.0e+00  0  1  0  0  0   1  1  0  0  0   276
MatILUFactorSym        1 1.0 4.8129e-02 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   1  0  0  0  0     0
MatConvert             1 1.0 1.8516e-02 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatScale               2 1.0 7.8988e-03 1.0 5.34e+06 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0   676
MatResidual           75 1.0 1.0117e-01 1.0 1.45e+08 1.0 0.0e+00 0.0e+00 0.0e+00  1  5  0  0  0   2  5  0  0  0  1436
MatAssemblyBegin      25 1.0 1.6451e-05 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatAssemblyEnd        25 1.0 1.1168e-01 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  1  0  0  0  0   2  0  0  0  0     0
MatGetRow         768000 1.0 4.7904e-01 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  2  0  0  0  0   9  0  0  0  0     0
MatGetRowIJ            2 1.0 5.0068e-06 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatGetSubMatrix        4 1.0 4.8298e-02 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   1  0  0  0  0     0
MatGetOrdering         2 1.0 3.0270e-03 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatAXPY                1 1.0 1.0552e+00 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  5  0  0  0  0  19  0  0  0  0     0
MatMatMult             1 1.0 1.2038e-01 1.0 1.33e+07 1.0 0.0e+00 0.0e+00 0.0e+00  1  0  0  0  0   2  0  0  0  0   111
MatMatMultSym          1 1.0 8.1955e-02 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   2  0  0  0  0     0
MatMatMultNum          1 1.0 3.8406e-02 1.0 1.33e+07 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   1  0  0  0  0   347
PCSetUp                4 1.0 2.2227e+00 1.0 1.01e+08 1.0 0.0e+00 0.0e+00 0.0e+00 12  3  0  0  0  41  3  0  0  0    46
PCSetUpOnBlocks       15 1.0 1.1679e-01 1.0 1.81e+07 1.0 0.0e+00 0.0e+00 0.0e+00  1  1  0  0  0   2  1  0  0  0   155
PCApply               15 1.0 2.1770e+00 1.0 1.32e+09 1.0 0.0e+00 0.0e+00 0.0e+00 11 44  0  0  0  40 44  0  0  0   605
KSPGMRESOrthog        14 1.0 1.7076e-01 1.0 4.88e+08 1.0 0.0e+00 0.0e+00 0.0e+00  1 16  0  0  0   3 16  0  0  0  2857
KSPSetUp              10 1.0 2.5997e-02 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
KSPSolve               1 1.0 4.0425e+00 1.0 2.18e+09 1.0 0.0e+00 0.0e+00 0.0e+00 21 73  0  0  0  74 73  0  0  0   539
              Viewer     1              0            0     0.
           Index Set    22             25     38642032     0.
             Section    26              8         5376     0.
              Vector    13             68    289326248     0.
      Vector Scatter     2              6         3984     0.
              Matrix     0             19    155400352     0.
      Preconditioner     0             11        11008     0.
       Krylov Solver     0             11        30976     0.
    Distributed Mesh    10              4        19256     0.
    GraphPartitioner     4              3         1836     0.
Star Forest Bipartite Graph    23             12         9696     0.
     Discrete System    10              4         3456     0.
           Index Set    22             12         9408     0.
              Vector   127             63     19225304     0.
      Vector Scatter     6              0            0     0.
              Matrix    26              2     37023836     0.
      Preconditioner    12              1         1016     0.
       Krylov Solver    12              1         1352     0.
-log_summary
-solver_fieldsplit_1_pc_type ml
 ml 40 1
Discretization: RT
MPI processes 2: solving...
((579051, 1161600), (579051, 1161600))
	Solver time: 3.572446e+00
Darcy_FE.py on a arch-linux2-c-opt named wf153.localdomain with 2 processors, by jychang48 Wed Mar  2 17:40:26 2016
Time (sec):           1.773e+01      1.00036   1.773e+01
Objects:              7.890e+02      1.01806   7.820e+02
Flops:                1.659e+09      1.00160   1.658e+09  3.315e+09
Flops/sec:            9.356e+07      1.00124   9.350e+07  1.870e+08
MPI Messages:         7.360e+02      1.10345   7.015e+02  1.403e+03
MPI Message Lengths:  4.089e+08      1.61162   4.723e+05  6.626e+08
MPI Reductions:       6.180e+02      1.00000
 0:      Main Stage: 1.4155e+01  79.8%  0.0000e+00   0.0%  5.020e+02  35.8%  4.447e+05       94.2%  1.250e+02  20.2%
 1:             FEM: 3.5725e+00  20.2%  3.3150e+09 100.0%  9.010e+02  64.2%  2.757e+04        5.8%  4.920e+02  79.6%
Phase summary info:
BuildTwoSided         44 1.0 8.3753e-0110.1 0.00e+00 0.0 1.2e+02 4.0e+00 4.4e+01  3  0  8  0  7   3  0 24  0 35     0
VecScatterBegin        2 1.0 1.5290e-03 1.5 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecScatterEnd          2 1.0 3.0994e-06 1.1 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
Mesh Partition         2 1.0 1.6361e+00 1.1 0.00e+00 0.0 9.2e+01 5.5e+05 2.1e+01  9  0  7  8  3  11  0 18  8 17     0
Mesh Migration         2 1.0 1.7862e+00 1.0 0.00e+00 0.0 3.7e+02 1.4e+06 5.4e+01 10  0 27 78  9  13  0 75 83 43     0
DMPlexInterp           1 1.0 2.0356e+0049929.3 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  6  0  0  0  0   7  0  0  0  0     0
DMPlexDistribute       1 1.0 2.2571e+00 1.1 0.00e+00 0.0 1.7e+02 1.9e+06 2.5e+01 12  0 12 47  4  15  0 33 50 20     0
DMPlexDistCones        2 1.0 3.6382e-01 1.0 0.00e+00 0.0 5.4e+01 3.2e+06 4.0e+00  2  0  4 26  1   3  0 11 28  3     0
DMPlexDistLabels       2 1.0 9.6086e-01 1.0 0.00e+00 0.0 2.4e+02 1.2e+06 2.2e+01  5  0 17 44  4   7  0 48 47 18     0
DMPlexDistribOL        1 1.0 1.1848e+00 1.0 0.00e+00 0.0 3.1e+02 9.6e+05 5.0e+01  7  0 22 45  8   8  0 61 48 40     0
DMPlexDistField        3 1.0 4.3099e-02 1.1 0.00e+00 0.0 6.2e+01 3.5e+05 1.2e+01  0  0  4  3  2   0  0 12  3 10     0
DMPlexDistData         2 1.0 8.3743e-0126.3 0.00e+00 0.0 5.4e+01 4.0e+05 6.0e+00  2  0  4  3  1   3  0 11  3  5     0
DMPlexStratify         6 1.5 7.6924e-01 2.9 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  3  0  0  0  0   4  0  0  0  0     0
SFSetGraph            51 1.0 4.1922e-01 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  2  0  0  0  0   3  0  0  0  0     0
SFBcastBegin          95 1.0 9.3978e-01 3.2 0.00e+00 0.0 4.8e+02 1.2e+06 4.1e+01  3  0 34 91  7   4  0 96 96 33     0
SFBcastEnd            95 1.0 4.0925e-01 2.3 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  2  0  0  0  0   2  0  0  0  0     0
SFReduceBegin          4 1.0 3.2341e-03 1.3 0.00e+00 0.0 1.1e+01 1.3e+06 3.0e+00  0  0  1  2  0   0  0  2  2  2     0
SFReduceEnd            4 1.0 5.1863e-03 1.2 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
SFFetchOpBegin         1 1.0 3.0994e-05 7.6 0.00e+00 0.0 1.0e+00 4.2e+04 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
SFFetchOpEnd           1 1.0 4.2391e-04 2.8 0.00e+00 0.0 1.0e+00 4.2e+04 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
BuildTwoSided          1 1.0 1.8229e-03121.4 0.00e+00 0.0 2.0e+00 4.0e+00 1.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecMDot               16 1.0 5.0983e-02 1.0 1.58e+08 1.0 0.0e+00 0.0e+00 1.6e+01  0 10  0  0  3   1 10  0  0  3  6197
VecNorm               17 1.0 1.0093e-02 1.0 1.98e+07 1.0 0.0e+00 0.0e+00 1.7e+01  0  1  0  0  3   0  1  0  0  3  3913
VecScale             289 1.0 1.0229e-02 1.0 1.69e+07 1.0 0.0e+00 0.0e+00 0.0e+00  0  1  0  0  0   0  1  0  0  0  3286
VecCopy                1 1.0 1.1420e-03 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecSet               238 1.0 3.8023e-02 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   1  0  0  0  0     0
VecAXPY               86 1.0 4.3805e-03 1.0 8.83e+06 1.0 0.0e+00 0.0e+00 0.0e+00  0  1  0  0  0   0  1  0  0  0  4027
VecAYPX               85 1.0 3.9430e-03 1.0 3.83e+06 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0  1942
VecMAXPY              17 1.0 5.8177e-02 1.0 1.77e+08 1.0 0.0e+00 0.0e+00 0.0e+00  0 11  0  0  0   2 11  0  0  0  6070
VecScatterBegin      541 1.0 3.9975e-02 1.0 0.00e+00 0.0 8.2e+02 1.3e+04 0.0e+00  0  0 58  2  0   1  0 91 27  0     0
VecScatterEnd        541 1.0 1.5631e-02 2.1 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecNormalize          17 1.0 1.6049e-02 1.0 2.97e+07 1.0 0.0e+00 0.0e+00 1.7e+01  0  2  0  0  3   0  2  0  0  3  3691
MatMult              213 1.0 2.6564e-01 1.0 2.90e+08 1.0 2.5e+02 1.8e+04 1.3e+02  1 17 18  1 21   7 17 28 12 26  2183
MatMultAdd           149 1.0 1.5978e-01 1.0 1.62e+08 1.0 6.4e+01 3.6e+04 0.0e+00  1 10  5  0  0   4 10  7  6  0  2020
MatSolve              34 1.0 1.0493e-01 1.0 8.50e+07 1.0 0.0e+00 0.0e+00 0.0e+00  1  5  0  0  0   3  5  0  0  0  1612
MatSOR               170 1.0 4.4878e-01 1.0 4.49e+08 1.0 5.1e+02 1.0e+04 0.0e+00  3 27 36  1  0  13 27 57 13  0  1996
MatLUFactorSym         1 1.0 1.0967e-05 1.1 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatLUFactorNum         2 1.0 3.4249e-02 1.0 9.09e+06 1.0 0.0e+00 0.0e+00 0.0e+00  0  1  0  0  0   1  1  0  0  0   527
MatILUFactorSym        1 1.0 2.4367e-02 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   1  0  0  0  0     0
MatConvert             2 1.0 1.0835e-02 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatScale               2 1.0 3.6101e-03 1.0 2.67e+06 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0  1477
MatResidual           85 1.0 5.9523e-02 1.0 8.19e+07 1.0 1.7e+02 1.0e+04 0.0e+00  0  5 12  0  0   2  5 19  4  0  2746
MatAssemblyBegin      19 1.0 1.9948e-03 1.5 0.00e+00 0.0 0.0e+00 0.0e+00 1.6e+01  0  0  0  0  3   0  0  0  0  3     0
MatAssemblyEnd        19 1.0 1.0086e-01 1.0 0.00e+00 0.0 3.6e+01 4.1e+03 8.8e+01  1  0  3  0 14   3  0  4  0 18     0
MatGetRow         384000 1.0 3.7113e-01 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  2  0  0  0  0  10  0  0  0  0     0
MatGetRowIJ            2 1.0 5.9605e-06 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatGetSubMatrice       1 1.0 1.2000e-03 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 4.0e+00  0  0  0  0  1   0  0  0  0  1     0
MatGetSubMatrix        4 1.0 2.1678e-02 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 6.0e+00  0  0  0  0  1   1  0  0  0  1     0
MatGetOrdering         2 1.0 1.4310e-03 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatAXPY                1 1.0 7.6797e-01 1.0 0.00e+00 0.0 4.0e+00 6.7e+03 1.2e+01  4  0  0  0  2  21  0  0  0  2     0
MatMatMult             1 1.0 1.4012e-01 1.0 4.95e+06 1.0 8.0e+00 2.2e+04 1.6e+01  1  0  1  0  3   4  0  1  0  3    71
MatMatMultSym          1 1.0 1.2285e-01 1.0 0.00e+00 0.0 7.0e+00 1.8e+04 1.4e+01  1  0  0  0  2   3  0  1  0  3     0
MatMatMultNum          1 1.0 1.7299e-02 1.0 4.95e+06 1.0 1.0e+00 5.5e+04 2.0e+00  0  0  0  0  0   0  0  0  0  0   572
MatRedundantMat        1 1.0 1.2240e-03 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 4.0e+00  0  0  0  0  1   0  0  0  0  1     0
MatGetLocalMat         2 1.0 2.2047e-02 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   1  0  0  0  0     0
MatGetBrAoCol          2 1.0 1.2829e-03 2.9 0.00e+00 0.0 4.0e+00 3.8e+04 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
PCSetUp                4 1.0 1.4806e+00 1.0 4.89e+07 1.0 7.6e+01 1.3e+05 2.5e+02  8  3  5  2 41  41  3  8 26 51    66
PCSetUpOnBlocks       17 1.0 6.0061e-02 1.0 9.09e+06 1.0 0.0e+00 0.0e+00 0.0e+00  0  1  0  0  0   2  1  0  0  0   301
PCApply               17 1.0 1.2664e+00 1.0 6.96e+08 1.0 7.9e+02 1.0e+04 1.9e+02  7 42 56  1 31  35 42 87 21 39  1099
KSPGMRESOrthog        16 1.0 1.0304e-01 1.0 3.17e+08 1.0 0.0e+00 0.0e+00 1.6e+01  1 19  0  0  3   3 19  0  0  3  6133
KSPSetUp              11 1.0 9.7177e-03 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 1.0e+01  0  0  0  0  2   0  0  0  0  2     0
KSPSolve               1 1.0 2.5623e+00 1.0 1.22e+09 1.0 8.7e+02 2.3e+04 4.1e+02 14 74 62  3 67  72 74 97 51 84   954
SFBcastBegin           1 1.0 1.8821e-0324.7 0.00e+00 0.0 6.0e+00 4.1e+04 1.0e+00  0  0  0  0  0   0  0  1  1  0     0
SFBcastEnd             1 1.0 7.5102e-05 1.1 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
              Viewer     1              0            0     0.
           Index Set    79             84     49128276     0.
   IS L to G Mapping     3              3     23945692     0.
             Section    70             53        35616     0.
              Vector    15             96    153254352     0.
      Vector Scatter     2             14     13912584     0.
              Matrix     0             34     80629960     0.
      Preconditioner     0             12        11944     0.
       Krylov Solver     0             12        32144     0.
    Distributed Mesh    14              8        38248     0.
    GraphPartitioner     6              5         3060     0.
Star Forest Bipartite Graph    74             63        53256     0.
     Discrete System    14              8         6912     0.
           Index Set    52             40        97704     0.
              Vector   348            255     71197824     0.
      Vector Scatter    20              2         2192     0.
              Matrix    55              8     52067772     0.
      Preconditioner    13              1          896     0.
       Krylov Solver    13              1         1352     0.
Average time to get PetscTime(): 5.96046e-07
Average time for MPI_Barrier(): 1.00136e-06
Average time for zero size MPI_Send(): 2.5034e-06
-log_summary
 ml 40 1
Discretization: RT
MPI processes 4: solving...
((288348, 1161600), (288348, 1161600))
	Solver time: 2.355974e+00
	Solver iterations: 17
Darcy_FE.py on a arch-linux2-c-opt named wf153.localdomain with 4 processors, by jychang48 Wed Mar  2 17:40:43 2016
Time (sec):           1.540e+01      1.00012   1.540e+01
Objects:              7.540e+02      1.02725   7.395e+02
Flops:                8.911e+08      1.00740   8.865e+08  3.546e+09
Flops/sec:            5.788e+07      1.00742   5.759e+07  2.303e+08
MPI Messages:         1.734e+03      1.43406   1.438e+03  5.750e+03
MPI Message Lengths:  2.936e+08      2.18390   1.217e+05  7.001e+08
MPI Reductions:       5.940e+02      1.00000
 0:      Main Stage: 1.3039e+01  84.7%  0.0000e+00   0.0%  1.654e+03  28.8%  1.129e+05       92.7%  1.250e+02  21.0%
 1:             FEM: 2.3563e+00  15.3%  3.5462e+09 100.0%  4.096e+03  71.2%  8.839e+03        7.3%  4.680e+02  78.8%
Phase summary info:
BuildTwoSided         44 1.0 9.1547e-0122.2 0.00e+00 0.0 3.9e+02 4.0e+00 4.4e+01  4  0  7  0  7   5  0 24  0 35     0
VecScatterBegin        2 1.0 6.8903e-04 1.6 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecScatterEnd          2 1.0 4.0531e-06 1.4 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
Mesh Partition         2 1.0 1.7451e+00 1.1 0.00e+00 0.0 3.8e+02 1.4e+05 2.1e+01 11  0  7  8  4  13  0 23  8 17     0
Mesh Migration         2 1.0 1.0095e+00 1.0 0.00e+00 0.0 1.1e+03 4.7e+05 5.4e+01  7  0 20 77  9   8  0 69 83 43     0
DMPlexInterp           1 1.0 2.0528e+0051557.5 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  3  0  0  0  0   4  0  0  0  0     0
DMPlexDistribute       1 1.0 2.0368e+00 1.1 0.00e+00 0.0 3.9e+02 8.1e+05 2.5e+01 13  0  7 45  4  15  0 23 49 20     0
DMPlexDistCones        2 1.0 2.3249e-01 1.0 0.00e+00 0.0 1.6e+02 1.1e+06 4.0e+00  2  0  3 26  1   2  0 10 28  3     0
DMPlexDistLabels       2 1.0 5.3011e-01 1.0 0.00e+00 0.0 7.2e+02 4.2e+05 2.2e+01  3  0 13 43  4   4  0 44 47 18     0
DMPlexDistribOL        1 1.0 7.3405e-01 1.0 0.00e+00 0.0 1.2e+03 2.8e+05 5.0e+01  5  0 20 45  8   6  0 70 49 40     0
DMPlexDistField        3 1.0 2.9428e-02 1.1 0.00e+00 0.0 2.0e+02 1.1e+05 1.2e+01  0  0  4  3  2   0  0 12  4 10     0
DMPlexDistData         2 1.0 9.2139e-0141.2 0.00e+00 0.0 2.2e+02 1.0e+05 6.0e+00  4  0  4  3  1   5  0 14  4  5     0
DMPlexStratify         6 1.5 6.4224e-01 4.7 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  2  0  0  0  0   2  0  0  0  0     0
SFSetGraph            51 1.0 2.3842e-01 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  2  0  0  0  0   2  0  0  0  0     0
SFBcastBegin          95 1.0 9.6980e-01 4.8 0.00e+00 0.0 1.6e+03 4.0e+05 4.1e+01  5  0 27 89  7   6  0 95 96 33     0
SFBcastEnd            95 1.0 3.1558e-01 3.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  2  0  0  0  0   2  0  0  0  0     0
SFReduceBegin          4 1.0 2.9893e-03 2.1 0.00e+00 0.0 4.9e+01 2.9e+05 3.0e+00  0  0  1  2  1   0  0  3  2  2     0
SFReduceEnd            4 1.0 6.0470e-03 2.2 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
SFFetchOpBegin         1 1.0 3.6955e-0512.9 0.00e+00 0.0 5.0e+00 1.7e+04 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
SFFetchOpEnd           1 1.0 3.9387e-04 2.3 0.00e+00 0.0 5.0e+00 1.7e+04 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
BuildTwoSided          1 1.0 1.7231e-0396.4 0.00e+00 0.0 1.0e+01 4.0e+00 1.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecMDot               17 1.0 3.9099e-02 1.2 8.94e+07 1.0 0.0e+00 0.0e+00 1.7e+01  0 10  0  0  3   1 10  0  0  4  9091
VecNorm               18 1.0 8.1410e-03 1.3 1.05e+07 1.0 0.0e+00 0.0e+00 1.8e+01  0  1  0  0  3   0  1  0  0  4  5137
VecScale             252 1.0 5.7852e-03 1.0 9.11e+06 1.0 0.0e+00 0.0e+00 0.0e+00  0  1  0  0  0   0  1  0  0  0  6272
VecCopy                1 1.0 6.0797e-04 1.1 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecSet               232 1.0 1.7792e-02 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   1  0  0  0  0     0
VecAXPY               73 1.0 2.5489e-03 1.0 4.64e+06 1.0 0.0e+00 0.0e+00 0.0e+00  0  1  0  0  0   0  1  0  0  0  7271
VecAYPX               72 1.0 2.3601e-03 1.1 2.03e+06 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0  3434
VecMAXPY              18 1.0 3.7059e-02 1.0 9.93e+07 1.0 0.0e+00 0.0e+00 0.0e+00  0 11  0  0  0   2 11  0  0  0 10657
VecScatterBegin      500 1.0 2.3368e-02 1.0 0.00e+00 0.0 3.8e+03 5.8e+03 0.0e+00  0  0 66  3  0   1  0 93 43  0     0
VecScatterEnd        500 1.0 8.3990e-03 1.8 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecNormalize          18 1.0 1.1338e-02 1.2 1.58e+07 1.0 0.0e+00 0.0e+00 1.8e+01  0  2  0  0  3   0  2  0  0  4  5532
MatMult              189 1.0 1.5278e-01 1.0 1.54e+08 1.0 1.2e+03 8.0e+03 1.4e+02  1 17 21  1 23   6 17 29 19 29  4009
MatMultAdd           140 1.0 9.3157e-02 1.0 8.62e+07 1.0 3.4e+02 1.4e+04 0.0e+00  1 10  6  1  0   4 10  8 10  0  3681
MatSolve              36 1.0 5.9907e-02 1.1 4.50e+07 1.0 0.0e+00 0.0e+00 0.0e+00  0  5  0  0  0   2  5  0  0  0  2978
MatSOR               144 1.0 2.5068e-01 1.0 2.40e+08 1.0 2.3e+03 4.9e+03 0.0e+00  2 27 39  2  0  11 27 55 22  0  3799
MatLUFactorSym         1 1.0 1.3113e-05 1.2 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatLUFactorNum         2 1.0 1.8109e-02 1.0 4.57e+06 1.0 0.0e+00 0.0e+00 0.0e+00  0  1  0  0  0   1  1  0  0  0   997
MatILUFactorSym        1 1.0 1.3030e-02 1.2 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   1  0  0  0  0     0
MatConvert             2 1.0 5.7888e-03 2.2 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatScale               2 1.0 2.0142e-03 1.1 1.34e+06 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0  2647
MatResidual           72 1.0 3.2858e-02 1.0 4.39e+07 1.0 7.6e+02 4.9e+03 0.0e+00  0  5 13  1  0   1  5 18  7  0  5307
MatAssemblyBegin      18 1.0 1.1560e-02 9.3 0.00e+00 0.0 0.0e+00 0.0e+00 1.4e+01  0  0  0  0  2   0  0  0  0  3     0
MatAssemblyEnd        18 1.0 5.6518e-02 1.1 0.00e+00 0.0 1.7e+02 1.8e+03 8.0e+01  0  0  3  0 13   2  0  4  1 17     0
MatGetRow         192000 1.0 3.7683e-01 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  2  0  0  0  0  16  0  0  0  0     0
MatGetRowIJ            2 1.0 5.9605e-06 1.2 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatGetSubMatrice       1 1.0 6.4135e-05 1.1 0.00e+00 0.0 0.0e+00 0.0e+00 4.0e+00  0  0  0  0  1   0  0  0  0  1     0
MatGetSubMatrix        4 1.0 1.0420e-02 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 6.0e+00  0  0  0  0  1   0  0  0  0  1     0
MatGetOrdering         2 1.0 7.2408e-04 1.1 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatAXPY                1 1.0 7.6580e-01 1.0 0.00e+00 0.0 2.0e+01 2.7e+03 1.2e+01  5  0  0  0  2  32  0  0  0  3     0
MatMatMult             1 1.0 7.8246e-02 1.0 2.48e+06 1.0 4.0e+01 8.9e+03 1.6e+01  0  0  1  0  3   3  0  1  1  3   126
MatMatMultSym          1 1.0 6.8802e-02 1.1 0.00e+00 0.0 3.5e+01 7.0e+03 1.4e+01  0  0  1  0  2   3  0  1  0  3     0
MatMatMultNum          1 1.0 9.4202e-03 1.0 2.48e+06 1.0 5.0e+00 2.2e+04 2.0e+00  0  0  0  0  0   0  0  0  0  0  1050
MatRedundantMat        1 1.0 8.8930e-05 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 4.0e+00  0  0  0  0  1   0  0  0  0  1     0
MatGetLocalMat         2 1.0 1.1519e-02 1.2 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatGetBrAoCol          2 1.0 4.1471e-03 5.9 0.00e+00 0.0 2.0e+01 1.5e+04 0.0e+00  0  0  0  0  0   0  0  0  1  0     0
PCSetUp                4 1.0 1.1437e+00 1.0 2.45e+07 1.0 3.2e+02 3.4e+04 2.2e+02  7  3  6  2 37  48  3  8 22 47    85
PCSetUpOnBlocks       18 1.0 3.1880e-02 1.1 4.57e+06 1.0 0.0e+00 0.0e+00 0.0e+00  0  1  0  0  0   1  1  0  0  0   566
PCApply               18 1.0 6.9520e-01 1.0 3.70e+08 1.0 3.6e+03 4.8e+03 1.6e+02  4 42 62  2 26  29 42 87 33 33  2119
KSPGMRESOrthog        17 1.0 7.2115e-02 1.1 1.79e+08 1.0 0.0e+00 0.0e+00 1.7e+01  0 20  0  0  3   3 20  0  0  4  9858
KSPSetUp              10 1.0 5.5130e-03 2.6 0.00e+00 0.0 0.0e+00 0.0e+00 8.0e+00  0  0  0  0  1   0  0  0  0  2     0
KSPSolve               1 1.0 1.7607e+00 1.0 6.60e+08 1.0 4.0e+03 7.9e+03 3.9e+02 11 74 69  5 65  75 74 98 62 83  1494
SFBcastBegin           1 1.0 1.7951e-0317.1 0.00e+00 0.0 3.0e+01 1.7e+04 1.0e+00  0  0  1  0  0   0  0  1  1  0     0
SFBcastEnd             1 1.0 1.2398e-04 1.4 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
              Viewer     1              0            0     0.
           Index Set    87             92     35927100     0.
   IS L to G Mapping     3              3     18881016     0.
              Vector    15             87     78953080     0.
      Vector Scatter     2             13      6934616     0.
              Matrix     0             29     40306524     0.
      Preconditioner     0             11        10960     0.
       Krylov Solver     0             11        30856     0.
           Index Set    50             38       100832     0.
              Vector   315            231     37564192     0.
      Vector Scatter    19              2         2192     0.
              Matrix    50              8     26014168     0.
      Preconditioner    12              1          896     0.
Average time for MPI_Barrier(): 1.19209e-06
Average time for zero size MPI_Send(): 1.54972e-06
-log_summary
 ml 40 1
Discretization: RT
MPI processes 8: solving...
((143102, 1161600), (143102, 1161600))
	Solver time: 1.725371e+00
Darcy_FE.py on a arch-linux2-c-opt named wf153.localdomain with 8 processors, by jychang48 Wed Mar  2 17:40:59 2016
Time (sec):           1.389e+01      1.00022   1.389e+01
Objects:              7.700e+02      1.04336   7.428e+02
Flops:                4.567e+08      1.01904   4.507e+08  3.605e+09
Flops/sec:            3.287e+07      1.01910   3.244e+07  2.595e+08
MPI Messages:         3.824e+03      1.59612   2.718e+03  2.174e+04
MPI Message Lengths:  2.346e+08      3.28110   3.422e+04  7.441e+08
 0:      Main Stage: 1.2167e+01  87.6%  0.0000e+00   0.0%  5.296e+03  24.4%  3.124e+04       91.3%  1.250e+02  21.0%
 1:             FEM: 1.7258e+00  12.4%  3.6052e+09 100.0%  1.645e+04  75.6%  2.978e+03        8.7%  4.680e+02  78.8%
Phase summary info:
BuildTwoSided         44 1.0 9.9127e-0135.3 0.00e+00 0.0 1.2e+03 4.0e+00 4.4e+01  6  0  6  0  7   7  0 23  0 35     0
VecScatterBegin        2 1.0 2.7800e-04 1.5 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecScatterEnd          2 1.0 3.3379e-06 1.4 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
Mesh Partition         2 1.0 1.8539e+00 1.1 0.00e+00 0.0 1.4e+03 4.1e+04 2.1e+01 13  0  6  8  4  15  0 26  8 17     0
Mesh Migration         2 1.0 6.9888e-01 1.0 0.00e+00 0.0 3.4e+03 1.6e+05 5.4e+01  5  0 16 75  9   6  0 65 82 43     0
DMPlexInterp           1 1.0 2.1155e+0064296.2 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  2  0  0  0  0   2  0  0  0  0     0
DMPlexDistribute       1 1.0 2.0479e+00 1.1 0.00e+00 0.0 1.0e+03 3.2e+05 2.5e+01 15  0  5 43  4  17  0 19 47 20     0
DMPlexDistCones        2 1.0 1.6353e-01 1.0 0.00e+00 0.0 4.9e+02 3.8e+05 4.0e+00  1  0  2 25  1   1  0  9 27  3     0
DMPlexDistLabels       2 1.0 3.9835e-01 1.0 0.00e+00 0.0 2.1e+03 1.5e+05 2.2e+01  3  0 10 42  4   3  0 40 47 18     0
DMPlexDistribOL        1 1.0 5.2452e-01 1.0 0.00e+00 0.0 3.9e+03 8.8e+04 5.0e+01  4  0 18 46  8   4  0 73 50 40     0
DMPlexDistField        3 1.0 2.3566e-02 1.3 0.00e+00 0.0 6.4e+02 3.8e+04 1.2e+01  0  0  3  3  2   0  0 12  4 10     0
DMPlexDistData         2 1.0 9.7306e-0152.6 0.00e+00 0.0 8.5e+02 3.0e+04 6.0e+00  6  0  4  3  1   7  0 16  4  5     0
DMPlexStratify         6 1.5 5.9495e-01 8.5 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  1  0  0  0  0   1  0  0  0  0     0
SFSetGraph            51 1.0 1.4286e-01 1.1 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  1  0  0  0  0   1  0  0  0  0     0
SFBcastBegin          95 1.0 1.0315e+00 6.1 0.00e+00 0.0 5.0e+03 1.3e+05 4.1e+01  6  0 23 88  7   7  0 95 96 33     0
SFBcastEnd            95 1.0 2.9712e-01 2.8 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  2  0  0  0  0   2  0  0  0  0     0
SFReduceBegin          4 1.0 3.7477e-03 3.8 0.00e+00 0.0 1.8e+02 8.2e+04 3.0e+00  0  0  1  2  1   0  0  3  2  2     0
SFReduceEnd            4 1.0 6.8834e-03 2.7 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
SFFetchOpBegin         1 1.0 6.5088e-0513.0 0.00e+00 0.0 1.9e+01 7.0e+03 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
SFFetchOpEnd           1 1.0 2.9087e-04 2.9 0.00e+00 0.0 1.9e+01 7.0e+03 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
BuildTwoSided          1 1.0 1.9469e-0377.8 0.00e+00 0.0 3.8e+01 4.0e+00 1.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecMDot               17 1.0 2.6954e-02 1.1 4.48e+07 1.0 0.0e+00 0.0e+00 1.7e+01  0 10  0  0  3   1 10  0  0  4 13187
VecNorm               18 1.0 1.0048e-02 2.8 5.27e+06 1.0 0.0e+00 0.0e+00 1.8e+01  0  1  0  0  3   0  1  0  0  4  4162
VecScale             252 1.0 3.3975e-03 1.1 4.70e+06 1.0 0.0e+00 0.0e+00 0.0e+00  0  1  0  0  0   0  1  0  0  0 10932
VecCopy                1 1.0 3.8004e-04 1.1 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecSet               232 1.0 6.7997e-03 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecAXPY               73 1.0 1.5988e-03 1.1 2.33e+06 1.0 0.0e+00 0.0e+00 0.0e+00  0  1  0  0  0   0  1  0  0  0 11593
VecAYPX               72 1.0 1.4379e-03 1.1 1.02e+06 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0  5638
VecMAXPY              18 1.0 2.6705e-02 1.1 4.98e+07 1.0 0.0e+00 0.0e+00 0.0e+00  0 11  0  0  0   1 11  0  0  0 14789
VecScatterBegin      500 1.0 1.6459e-02 1.1 0.00e+00 0.0 1.5e+04 2.3e+03 0.0e+00  0  0 71  5  0   1  0 93 54  0     0
VecScatterEnd        500 1.0 8.3652e-03 1.7 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecNormalize          18 1.0 1.1821e-02 2.2 7.91e+06 1.0 0.0e+00 0.0e+00 1.8e+01  0  2  0  0  3   0  2  0  0  4  5307
MatMult              189 1.0 1.0047e-01 1.1 7.71e+07 1.0 4.7e+03 3.2e+03 1.4e+02  1 17 22  2 23   6 17 29 23 29  6111
MatMultAdd           140 1.0 5.8617e-02 1.0 4.32e+07 1.0 1.3e+03 6.0e+03 0.0e+00  0 10  6  1  0   3 10  8 12  0  5850
MatSolve              36 1.0 3.2941e-02 1.1 2.25e+07 1.0 0.0e+00 0.0e+00 0.0e+00  0  5  0  0  0   2  5  0  0  0  5391
MatSOR               144 1.0 1.4923e-01 1.0 1.20e+08 1.0 9.2e+03 1.9e+03 0.0e+00  1 27 42  2  0   9 27 56 28  0  6406
MatLUFactorSym         1 1.0 1.4782e-05 1.5 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatLUFactorNum         2 1.0 9.5110e-03 1.1 2.31e+06 1.0 0.0e+00 0.0e+00 0.0e+00  0  1  0  0  0   1  1  0  0  0  1900
MatILUFactorSym        1 1.0 6.8221e-03 2.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatConvert             2 1.0 3.1312e-03 2.2 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatScale               2 1.0 1.1721e-03 1.1 6.70e+05 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0  4550
MatResidual           72 1.0 1.9800e-02 1.0 2.22e+07 1.0 3.1e+03 1.9e+03 0.0e+00  0  5 14  1  0   1  5 19  9  0  8879
MatAssemblyBegin      18 1.0 1.0952e-0212.5 0.00e+00 0.0 0.0e+00 0.0e+00 1.4e+01  0  0  0  0  2   0  0  0  0  3     0
MatAssemblyEnd        18 1.0 3.2517e-02 1.1 0.00e+00 0.0 6.8e+02 7.0e+02 8.0e+01  0  0  3  0 13   2  0  4  1 17     0
MatGetRow          96000 1.0 3.8074e-01 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  3  0  0  0  0  22  0  0  0  0     0
MatGetRowIJ            2 1.0 9.0599e-06 1.9 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatGetSubMatrice       1 1.0 1.1802e-04 1.2 0.00e+00 0.0 0.0e+00 0.0e+00 4.0e+00  0  0  0  0  1   0  0  0  0  1     0
MatGetSubMatrix        4 1.0 5.2059e-03 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 6.0e+00  0  0  0  0  1   0  0  0  0  1     0
MatGetOrdering         2 1.0 3.7909e-04 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatAXPY                1 1.0 7.6783e-01 1.0 0.00e+00 0.0 7.6e+01 1.1e+03 1.2e+01  6  0  0  0  2  44  0  0  0  3     0
MatMatMult             1 1.0 4.1842e-02 1.0 1.24e+06 1.0 1.5e+02 3.7e+03 1.6e+01  0  0  1  0  3   2  0  1  1  3   237
MatMatMultSym          1 1.0 3.6508e-02 1.1 0.00e+00 0.0 1.3e+02 2.9e+03 1.4e+01  0  0  1  0  2   2  0  1  1  3     0
MatMatMultNum          1 1.0 5.3141e-03 1.0 1.24e+06 1.0 1.9e+01 9.1e+03 2.0e+00  0  0  0  0  0   0  0  0  0  0  1863
MatRedundantMat        1 1.0 1.4997e-04 1.2 0.00e+00 0.0 0.0e+00 0.0e+00 4.0e+00  0  0  0  0  1   0  0  0  0  1     0
MatGetLocalMat         2 1.0 6.3159e-03 1.3 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatGetBrAoCol          2 1.0 2.3229e-03 3.7 0.00e+00 0.0 7.6e+01 6.3e+03 0.0e+00  0  0  0  0  0   0  0  0  1  0     0
PCSetUp                4 1.0 9.7671e-01 1.0 1.23e+07 1.0 1.2e+03 9.8e+03 2.2e+02  7  3  6  2 37  57  3  8 19 47   100
PCSetUpOnBlocks       18 1.0 1.6695e-02 1.3 2.31e+06 1.0 0.0e+00 0.0e+00 0.0e+00  0  1  0  0  0   1  1  0  0  0  1082
PCApply               18 1.0 4.0179e-01 1.0 1.86e+08 1.0 1.5e+04 1.9e+03 1.6e+02  3 41 67  4 26  23 41 89 42 33  3677
KSPGMRESOrthog        17 1.0 5.0506e-02 1.1 8.96e+07 1.0 0.0e+00 0.0e+00 1.7e+01  0 20  0  0  3   3 20  0  0  4 14075
KSPSetUp              10 1.0 2.3572e-03 2.5 0.00e+00 0.0 0.0e+00 0.0e+00 8.0e+00  0  0  0  0  1   0  0  0  0  2     0
KSPSolve               1 1.0 1.3470e+00 1.0 3.31e+08 1.0 1.6e+04 2.8e+03 3.9e+02 10 73 74  6 65  78 73 98 70 83  1956
SFBcastBegin           1 1.0 2.0890e-0312.0 0.00e+00 0.0 1.1e+02 7.1e+03 1.0e+00  0  0  1  0  0   0  0  1  1  0     0
SFBcastEnd             1 1.0 1.4305e-04 2.8 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
              Viewer     1              0            0     0.
           Index Set   103            108     29168148     0.
   IS L to G Mapping     3              3     16320748     0.
              Vector    15             87     41816936     0.
      Vector Scatter     2             13      3448712     0.
              Matrix     0             29     20176708     0.
           Index Set    50             38        96316     0.
              Vector   315            231     18936288     0.
              Matrix    50              8     12996772     0.
Average time for MPI_Barrier(): 2.00272e-06
Average time for zero size MPI_Send(): 1.63913e-06
-log_summary
 ml 40 1
Discretization: RT
MPI processes 16: solving...
((70996, 1161600), (70996, 1161600))
	Solver time: 9.724491e-01
	Solver iterations: 18
Darcy_FE.py on a arch-linux2-c-opt named wf153.localdomain with 16 processors, by jychang48 Wed Mar  2 17:41:17 2016
Time (sec):           1.549e+01      1.00008   1.549e+01
Objects:              8.040e+02      1.07200   7.584e+02
Flops:                2.486e+08      1.05022   2.426e+08  3.882e+09
Flops/sec:            1.605e+07      1.05015   1.567e+07  2.507e+08
MPI Messages:         6.216e+03      1.99327   4.443e+03  7.109e+04
MPI Message Lengths:  2.044e+08      5.47991   1.150e+04  8.175e+08
MPI Reductions:       6.040e+02      1.00000
 0:      Main Stage: 1.4514e+01  93.7%  0.0000e+00   0.0%  1.470e+04  20.7%  1.024e+04       89.0%  1.250e+02  20.7%
 1:             FEM: 9.7263e-01   6.3%  3.8821e+09 100.0%  5.639e+04  79.3%  1.263e+03       11.0%  4.780e+02  79.1%
Phase summary info:
BuildTwoSided         44 1.0 1.1980e+00 7.6 0.00e+00 0.0 3.5e+03 4.0e+00 4.4e+01  6  0  5  0  7   7  0 24  0 35     0
VecScatterBegin        2 1.0 8.1062e-05 1.8 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecScatterEnd          2 1.0 5.0068e-06 1.8 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
Mesh Partition         2 1.0 1.9332e+00 1.1 0.00e+00 0.0 4.4e+03 1.4e+04 2.1e+01 12  0  6  8  3  13  0 30  9 17     0
Mesh Migration         2 1.0 5.2375e-01 1.0 0.00e+00 0.0 8.9e+03 6.6e+04 5.4e+01  3  0 13 72  9   4  0 61 81 43     0
DMPlexInterp           1 1.0 2.1157e+0055461.3 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  1  0  0  0  0   1  0  0  0  0     0
DMPlexDistribute       1 1.0 2.1336e+00 1.1 0.00e+00 0.0 2.9e+03 1.1e+05 2.5e+01 14  0  4 39  4  15  0 20 44 20     0
DMPlexDistCones        2 1.0 1.2215e-01 1.0 0.00e+00 0.0 1.3e+03 1.5e+05 4.0e+00  1  0  2 24  1   1  0  9 27  3     0
DMPlexDistLabels       2 1.0 3.1635e-01 1.0 0.00e+00 0.0 5.5e+03 6.1e+04 2.2e+01  2  0  8 41  4   2  0 38 46 18     0
DMPlexDistribOL        1 1.0 3.4299e-01 1.0 0.00e+00 0.0 1.1e+04 3.5e+04 5.0e+01  2  0 15 46  8   2  0 72 52 40     0
DMPlexDistField        3 1.0 2.6731e-02 1.7 0.00e+00 0.0 1.7e+03 1.5e+04 1.2e+01  0  0  2  3  2   0  0 12  4 10     0
DMPlexDistData         2 1.0 9.9244e-0167.5 0.00e+00 0.0 2.9e+03 9.6e+03 6.0e+00  6  0  4  3  1   6  0 20  4  5     0
DMPlexStratify         6 1.5 5.6545e-0115.9 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
SFSetGraph            51 1.0 8.5791e-02 1.3 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   1  0  0  0  0     0
SFBcastBegin          95 1.0 1.2138e+00 3.6 0.00e+00 0.0 1.4e+04 5.0e+04 4.1e+01  7  0 20 86  7   7  0 95 97 33     0
SFBcastEnd            95 1.0 3.0706e-01 5.6 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  2  0  0  0  0   2  0  0  0  0     0
SFReduceBegin          4 1.0 7.5688e-0311.7 0.00e+00 0.0 5.0e+02 3.0e+04 3.0e+00  0  0  1  2  0   0  0  3  2  2     0
SFReduceEnd            4 1.0 8.1227e-03 3.4 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
SFFetchOpBegin         1 1.0 5.1022e-0526.8 0.00e+00 0.0 5.4e+01 3.9e+03 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
SFFetchOpEnd           1 1.0 2.3007e-04 2.4 0.00e+00 0.0 5.4e+01 3.9e+03 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
BuildTwoSided          1 1.0 1.2939e-0336.9 0.00e+00 0.0 1.1e+02 4.0e+00 1.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecMDot               18 1.0 1.5401e-02 1.3 2.52e+07 1.0 0.0e+00 0.0e+00 1.8e+01  0 10  0  0  3   1 10  0  0  4 25795
VecNorm               19 1.0 4.7302e-03 2.3 2.80e+06 1.0 0.0e+00 0.0e+00 1.9e+01  0  1  0  0  3   0  1  0  0  4  9332
VecScale             266 1.0 2.0359e-03 1.1 2.62e+06 1.1 0.0e+00 0.0e+00 0.0e+00  0  1  0  0  0   0  1  0  0  0 19960
VecCopy                1 1.0 2.0003e-04 1.1 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecSet               244 1.0 3.7987e-03 1.1 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecAXPY               77 1.0 9.3222e-04 1.1 1.22e+06 1.0 0.0e+00 0.0e+00 0.0e+00  0  1  0  0  0   0  1  0  0  0 20859
VecAYPX               76 1.0 6.7663e-04 1.2 5.38e+05 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0 12652
VecMAXPY              19 1.0 1.0955e-02 1.1 2.78e+07 1.0 0.0e+00 0.0e+00 0.0e+00  0 11  0  0  0   1 11  0  0  0 40080
VecScatterBegin      527 1.0 1.1807e-02 1.3 0.00e+00 0.0 5.3e+04 1.1e+03 0.0e+00  0  0 74  7  0   1  0 94 66  0     0
VecScatterEnd        527 1.0 1.1447e-02 2.1 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   1  0  0  0  0     0
VecNormalize          19 1.0 5.7294e-03 1.9 4.20e+06 1.0 0.0e+00 0.0e+00 1.9e+01  0  2  0  0  3   0  2  0  0  4 11556
MatMult              199 1.0 5.5462e-02 1.1 4.11e+07 1.0 1.5e+04 1.7e+03 1.4e+02  0 17 22  3 24   5 17 27 28 30 11672
MatMultAdd           148 1.0 3.2288e-02 1.1 2.31e+07 1.0 3.9e+03 3.3e+03 0.0e+00  0  9  5  2  0   3  9  7 14  0 11244
MatSolve              38 1.0 1.7801e-02 1.2 1.19e+07 1.1 0.0e+00 0.0e+00 0.0e+00  0  5  0  0  0   2  5  0  0  0 10460
MatSOR               152 1.0 7.6650e-02 1.0 6.41e+07 1.0 3.2e+04 9.6e+02 0.0e+00  0 26 44  4  0   8 26 56 34  0 13202
MatLUFactorSym         1 1.0 2.9087e-05 1.8 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatLUFactorNum         2 1.0 4.6940e-03 1.1 1.17e+06 1.1 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0  3851
MatILUFactorSym        1 1.0 3.3820e-03 2.1 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatConvert             2 1.0 1.5450e-03 2.2 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatScale               2 1.0 2.5489e-03 5.7 3.37e+05 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0  2093
MatResidual           76 1.0 1.2002e-02 1.2 1.20e+07 1.0 1.1e+04 9.6e+02 0.0e+00  0  5 15  1  0   1  5 19 11  0 15609
MatAssemblyBegin      18 1.0 6.2559e-0314.2 0.00e+00 0.0 0.0e+00 0.0e+00 1.4e+01  0  0  0  0  2   0  0  0  0  3     0
MatAssemblyEnd        18 1.0 2.1353e-02 1.2 0.00e+00 0.0 2.2e+03 3.4e+02 8.0e+01  0  0  3  0 13   2  0  4  1 17     0
MatGetRow          48000 1.0 1.9073e-01 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  1  0  0  0  0  19  0  0  0  0     0
MatGetRowIJ            2 1.0 4.4990e-04117.9 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatGetSubMatrice       1 1.0 1.5783e-04 1.3 0.00e+00 0.0 0.0e+00 0.0e+00 4.0e+00  0  0  0  0  1   0  0  0  0  1     0
MatGetSubMatrix        4 1.0 2.5711e-03 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 6.0e+00  0  0  0  0  1   0  0  0  0  1     0
MatGetOrdering         2 1.0 6.6710e-04 3.2 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatAXPY                1 1.0 3.8572e-01 1.0 0.00e+00 0.0 2.2e+02 6.2e+02 1.2e+01  2  0  0  0  2  40  0  0  0  3     0
MatMatMult             1 1.0 2.2668e-02 1.0 6.22e+05 1.0 4.3e+02 2.1e+03 1.6e+01  0  0  1  0  3   2  0  1  1  3   437
MatMatMultSym          1 1.0 1.9739e-02 1.1 0.00e+00 0.0 3.8e+02 1.6e+03 1.4e+01  0  0  1  0  2   2  0  1  1  3     0
MatMatMultNum          1 1.0 2.9190e-03 1.0 6.22e+05 1.0 5.4e+01 5.1e+03 2.0e+00  0  0  0  0  0   0  0  0  0  0  3392
MatRedundantMat        1 1.0 1.8787e-04 1.1 0.00e+00 0.0 0.0e+00 0.0e+00 4.0e+00  0  0  0  0  1   0  0  0  0  1     0
MatGetLocalMat         2 1.0 3.1598e-03 1.3 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatGetBrAoCol          2 1.0 1.4391e-03 3.9 0.00e+00 0.0 2.2e+02 3.5e+03 0.0e+00  0  0  0  0  0   0  0  0  1  0     0
PCSetUp                4 1.0 5.0388e-01 1.0 6.18e+06 1.0 3.9e+03 3.5e+03 2.2e+02  3  3  6  2 36  52  3  7 15 46   194
PCSetUpOnBlocks       19 1.0 8.1487e-03 1.3 1.17e+06 1.1 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   1  0  0  0  0  2213
PCApply               19 1.0 2.2397e-01 1.0 9.86e+07 1.0 5.1e+04 9.1e+02 1.6e+02  1 40 72  6 26  23 40 90 52 33  6956
KSPGMRESOrthog        18 1.0 2.4910e-02 1.2 5.04e+07 1.0 0.0e+00 0.0e+00 1.8e+01  0 20  0  0  3   2 20  0  0  4 31896
KSPSetUp              10 1.0 1.2152e-03 2.3 0.00e+00 0.0 0.0e+00 0.0e+00 8.0e+00  0  0  0  0  1   0  0  0  0  2     0
KSPSolve               1 1.0 7.0285e-01 1.0 1.79e+08 1.0 5.6e+04 1.3e+03 4.0e+02  5 73 78  9 66  72 73 98 77 83  4018
SFBcastBegin           1 1.0 1.3649e-03 8.3 0.00e+00 0.0 3.3e+02 3.9e+03 1.0e+00  0  0  0  0  0   0  0  1  1  0     0
SFBcastEnd             1 1.0 6.1879e-03167.4 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
              Viewer     1              0            0     0.
           Index Set   125            130     25605220     0.
   IS L to G Mapping     3              3     15014432     0.
              Vector    15             87     23370536     0.
      Vector Scatter     2             13      1718168     0.
              Matrix     0             29     10124824     0.
           Index Set    50             38        84652     0.
              Vector   327            243     10154536     0.
              Matrix    50              8      6483848     0.
Average time for MPI_Barrier(): 5.00679e-06
Average time for zero size MPI_Send(): 1.80304e-06
-log_summary
 ml 40 1
Discretization: RT
MPI processes 24: solving...
((47407, 1161600), (47407, 1161600))
	Solver time: 7.069969e-01
Darcy_FE.py on a arch-linux2-c-opt named wf153.localdomain with 24 processors, by jychang48 Wed Mar  2 17:41:35 2016
Time (sec):           1.503e+01      1.00014   1.503e+01
Objects:              8.180e+02      1.09067   7.607e+02
Flops:                1.700e+08      1.06571   1.644e+08  3.945e+09
Flops/sec:            1.131e+07      1.06582   1.094e+07  2.625e+08
MPI Messages:         8.270e+03      2.25324   5.616e+03  1.348e+05
MPI Message Lengths:  1.913e+08      7.34285   6.417e+03  8.650e+08
 0:      Main Stage: 1.4322e+01  95.3%  0.0000e+00   0.0%  2.618e+04  19.4%  5.638e+03       87.8%  1.250e+02  20.7%
 1:             FEM: 7.0697e-01   4.7%  3.9447e+09 100.0%  1.086e+05  80.6%  7.798e+02       12.2%  4.780e+02  79.1%
Phase summary info:
BuildTwoSided         44 1.0 1.1264e+00 9.5 0.00e+00 0.0 6.2e+03 4.0e+00 4.4e+01  7  0  5  0  7   7  0 24  0 35     0
VecScatterBegin        2 1.0 5.2214e-05 1.7 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecScatterEnd          2 1.0 1.8835e-05 9.9 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
Mesh Partition         2 1.0 1.9900e+00 1.1 0.00e+00 0.0 8.7e+03 7.7e+03 2.1e+01 13  0  6  8  3  14  0 33  9 17     0
Mesh Migration         2 1.0 4.5752e-01 1.0 0.00e+00 0.0 1.5e+04 4.0e+04 5.4e+01  3  0 11 71  9   3  0 58 81 43     0
DMPlexInterp           1 1.0 2.1216e+0058932.7 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  1  0  0  0  0   1  0  0  0  0     0
DMPlexDistribute       1 1.0 2.2043e+00 1.1 0.00e+00 0.0 5.7e+03 5.7e+04 2.5e+01 15  0  4 37  4  15  0 22 43 20     0
DMPlexDistCones        2 1.0 1.0450e-01 1.1 0.00e+00 0.0 2.2e+03 9.3e+04 4.0e+00  1  0  2 24  1   1  0  8 27  3     0
DMPlexDistLabels       2 1.0 2.8710e-01 1.0 0.00e+00 0.0 9.3e+03 3.7e+04 2.2e+01  2  0  7 40  4   2  0 35 46 18     0
DMPlexDistribOL        1 1.0 2.6298e-01 1.0 0.00e+00 0.0 1.8e+04 2.2e+04 5.0e+01  2  0 14 47  8   2  0 70 53 40     0
DMPlexDistField        3 1.0 2.8758e-02 2.1 0.00e+00 0.0 3.0e+03 9.4e+03 1.2e+01  0  0  2  3  2   0  0 11  4 10     0
DMPlexDistData         2 1.0 9.9861e-0127.8 0.00e+00 0.0 6.0e+03 5.0e+03 6.0e+00  6  0  4  3  1   6  0 23  4  5     0
DMPlexStratify         6 1.5 5.6285e-0122.3 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
SFSetGraph            51 1.0 6.0824e-02 1.3 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
SFBcastBegin          95 1.0 1.1366e+00 4.0 0.00e+00 0.0 2.5e+04 2.9e+04 4.1e+01  7  0 19 85  7   7  0 96 97 33     0
SFBcastEnd            95 1.0 3.0235e-01 5.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  2  0  0  0  0   2  0  0  0  0     0
SFReduceBegin          4 1.0 7.5159e-0313.3 0.00e+00 0.0 8.7e+02 1.8e+04 3.0e+00  0  0  1  2  0   0  0  3  2  2     0
SFReduceEnd            4 1.0 8.3404e-03 4.7 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
SFFetchOpBegin         1 1.0 4.4107e-0523.1 0.00e+00 0.0 9.4e+01 2.8e+03 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
SFFetchOpEnd           1 1.0 1.7095e-04 3.6 0.00e+00 0.0 9.4e+01 2.8e+03 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
BuildTwoSided          1 1.0 1.7259e-0328.3 0.00e+00 0.0 1.9e+02 4.0e+00 1.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecMDot               18 1.0 1.1039e-02 1.3 1.69e+07 1.0 0.0e+00 0.0e+00 1.8e+01  0 10  0  0  3   1 10  0  0  4 35989
VecNorm               19 1.0 3.1846e-03 2.2 1.88e+06 1.0 0.0e+00 0.0e+00 1.9e+01  0  1  0  0  3   0  1  0  0  4 13861
VecScale             266 1.0 1.4791e-03 1.1 1.81e+06 1.1 0.0e+00 0.0e+00 0.0e+00  0  1  0  0  0   0  1  0  0  0 28126
VecCopy                1 1.0 1.4901e-04 1.2 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecSet               244 1.0 2.5969e-03 1.1 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecAXPY               77 1.0 6.2633e-04 1.1 8.16e+05 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0 31062
VecAYPX               76 1.0 4.6229e-04 1.2 3.59e+05 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0 18529
VecMAXPY              19 1.0 6.4399e-03 1.1 1.87e+07 1.0 0.0e+00 0.0e+00 0.0e+00  0 11  0  0  0   1 11  0  0  0 68182
VecScatterBegin      527 1.0 1.0387e-02 1.5 0.00e+00 0.0 1.0e+05 7.2e+02 0.0e+00  0  0 76  9  0   1  0 94 70  0     0
VecScatterEnd        527 1.0 1.1114e-02 1.7 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   1  0  0  0  0     0
VecNormalize          19 1.0 3.8595e-03 1.8 2.81e+06 1.0 0.0e+00 0.0e+00 1.9e+01  0  2  0  0  3   0  2  0  0  4 17155
MatMult              199 1.0 3.9954e-02 1.1 2.74e+07 1.0 2.9e+04 1.1e+03 1.4e+02  0 16 21  4 24   5 16 26 30 30 16239
MatMultAdd           148 1.0 2.3000e-02 1.1 1.54e+07 1.0 6.8e+03 2.3e+03 0.0e+00  0  9  5  2  0   3  9  6 15  0 15786
MatSolve              38 1.0 1.2058e-02 1.1 7.95e+06 1.1 0.0e+00 0.0e+00 0.0e+00  0  5  0  0  0   2  5  0  0  0 15399
MatSOR               152 1.0 5.3896e-02 1.0 4.33e+07 1.0 6.0e+04 6.3e+02 0.0e+00  0 26 45  4  0   7 26 56 36  0 18843
MatLUFactorSym         1 1.0 3.1948e-05 1.6 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatLUFactorNum         2 1.0 3.0081e-03 1.1 7.86e+05 1.1 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0  6048
MatILUFactorSym        1 1.0 2.2931e-03 2.1 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatConvert             2 1.0 1.0121e-03 1.8 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatScale               2 1.0 2.3041e-03 8.9 2.25e+05 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0  2314
MatResidual           76 1.0 8.7066e-03 1.2 8.11e+06 1.1 2.0e+04 6.3e+02 0.0e+00  0  5 15  1  0   1  5 19 12  0 21688
MatAssemblyBegin      18 1.0 4.5638e-03 9.1 0.00e+00 0.0 0.0e+00 0.0e+00 1.4e+01  0  0  0  0  2   0  0  0  0  3     0
MatAssemblyEnd        18 1.0 1.5963e-02 1.2 0.00e+00 0.0 4.3e+03 2.2e+02 8.0e+01  0  0  3  0 13   2  0  4  1 17     0
MatGetRow          32000 1.0 1.2688e-01 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  1  0  0  0  0  18  0  0  0  0     0
MatGetRowIJ            2 1.0 5.6219e-04112.3 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatGetSubMatrice       1 1.0 1.5306e-04 1.2 0.00e+00 0.0 0.0e+00 0.0e+00 4.0e+00  0  0  0  0  1   0  0  0  0  1     0
MatGetSubMatrix        4 1.0 1.8289e-03 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 6.0e+00  0  0  0  0  1   0  0  0  0  1     0
MatGetOrdering         2 1.0 7.2408e-04 5.3 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatAXPY                1 1.0 2.5769e-01 1.0 0.00e+00 0.0 3.7e+02 4.4e+02 1.2e+01  2  0  0  0  2  36  0  0  0  3     0
MatMatMult             1 1.0 1.5805e-02 1.0 4.15e+05 1.0 7.4e+02 1.5e+03 1.6e+01  0  0  1  0  3   2  0  1  1  3   626
MatMatMultSym          1 1.0 1.3917e-02 1.0 0.00e+00 0.0 6.5e+02 1.2e+03 1.4e+01  0  0  0  0  2   2  0  1  1  3     0
MatMatMultNum          1 1.0 1.8940e-03 1.0 4.15e+05 1.0 9.3e+01 3.6e+03 2.0e+00  0  0  0  0  0   0  0  0  0  0  5226
MatRedundantMat        1 1.0 1.8001e-04 1.2 0.00e+00 0.0 0.0e+00 0.0e+00 4.0e+00  0  0  0  0  1   0  0  0  0  1     0
MatGetLocalMat         2 1.0 2.1231e-03 1.2 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatGetBrAoCol          2 1.0 8.0800e-04 3.2 0.00e+00 0.0 3.7e+02 2.5e+03 0.0e+00  0  0  0  0  0   0  0  0  1  0     0
PCSetUp                4 1.0 3.4841e-01 1.0 4.13e+06 1.0 7.5e+03 2.0e+03 2.2e+02  2  2  6  2 36  49  2  7 14 46   281
PCSetUpOnBlocks       19 1.0 5.4433e-03 1.4 7.77e+05 1.1 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   1  0  0  0  0  3303
PCApply               19 1.0 1.6812e-01 1.0 6.60e+07 1.0 9.9e+04 5.9e+02 1.6e+02  1 40 74  7 26  24 40 91 55 33  9296
KSPGMRESOrthog        18 1.0 1.6622e-02 1.2 3.38e+07 1.0 0.0e+00 0.0e+00 1.8e+01  0 20  0  0  3   2 20  0  0  4 47800
KSPSetUp              10 1.0 8.8477e-04 2.2 0.00e+00 0.0 0.0e+00 0.0e+00 8.0e+00  0  0  0  0  1   0  0  0  0  2     0
KSPSolve               1 1.0 4.9091e-01 1.0 1.19e+08 1.0 1.1e+05 7.9e+02 4.0e+02  3 72 79 10 66  69 72 99 80 83  5762
SFBcastBegin           1 1.0 1.8461e-0310.3 0.00e+00 0.0 5.8e+02 2.8e+03 1.0e+00  0  0  0  0  0   0  0  1  2  0     0
SFBcastEnd             1 1.0 6.1107e-0451.3 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
--- Event Stage 0: Main Stage
              Viewer     1              0            0     0.
           Index Set   139            144     24068724     0.
   IS L to G Mapping     3              3     14448024     0.
              Vector    15             87     17303640     0.
      Vector Scatter     2             13      1152032     0.
              Matrix     0             29      6806588     0.
--- Event Stage 1: FEM
           Index Set    50             38        67128     0.
              Vector   327            243      6910640     0.
              Matrix    50              8      4329832     0.
Average time for MPI_Barrier(): 9.82285e-06
Average time for zero size MPI_Send(): 1.37091e-06
-log_summary
 ml 40 1
Discretization: RT
MPI processes 32: solving...
((35155, 1161600), (35155, 1161600))
	Solver time: 5.819740e-01
***             WIDEN YOUR WINDOW TO 120 CHARACTERS.  Use 'enscript -r -fCourier9' to print this document            ***
---------------------------------------------- PETSc Performance Summary: ----------------------------------------------
Darcy_FE.py on a arch-linux2-c-opt named wf153.localdomain with 32 processors, by jychang48 Wed Mar  2 17:41:54 2016
Using Petsc Development GIT revision: v3.6.3-1924-ge972cd5  GIT Date: 2016-01-01 10:01:13 -0600
                         Max       Max/Min        Avg      Total
Time (sec):           1.505e+01      1.00013   1.505e+01
Objects:              8.440e+02      1.12533   7.624e+02
Flops:                1.300e+08      1.08171   1.250e+08  3.999e+09
Flops/sec:            8.641e+06      1.08171   8.307e+06  2.658e+08
MPI Messages:         1.004e+04      2.37869   6.666e+03  2.133e+05
MPI Message Lengths:  1.880e+08      9.33983   4.255e+03  9.076e+08
Flop counting convention: 1 flop = 1 real number operation of type (multiply/divide/add/subtract)
                            e.g., VecAXPY() for real vectors of length N --> 2N flops
                            and VecAXPY() for complex vectors of length N --> 8N flops
Summary of Stages:   ----- Time ------  ----- Flops -----  --- Messages ---  -- Message Lengths --  -- Reductions --
                        Avg     %Total     Avg     %Total   counts   %Total     Avg         %Total   counts   %Total
 0:      Main Stage: 1.4463e+01  96.1%  0.0000e+00   0.0%  3.925e+04  18.4%  3.698e+03       86.9%  1.250e+02  20.7%
 1:             FEM: 5.8202e-01   3.9%  3.9993e+09 100.0%  1.740e+05  81.6%  5.576e+02       13.1%  4.780e+02  79.1%
See the 'Profiling' chapter of the users' manual for details on interpreting output.
Phase summary info:
   Count: number of times phase was executed
   Time and Flops: Max - maximum over all processors
                   Ratio - ratio of maximum to minimum over all processors
   Mess: number of messages sent
   Avg. len: average message length (bytes)
   Reduct: number of global reductions
   Global: entire computation
   Stage: stages of a computation. Set stages with PetscLogStagePush() and PetscLogStagePop().
      %T - percent time in this phase         %F - percent flops in this phase
      %M - percent messages in this phase     %L - percent message lengths in this phase
      %R - percent reductions in this phase
   Total Mflop/s: 10e-6 * (sum of flops over all processors)/(max time over all processors)
Event                Count      Time (sec)     Flops                             --- Global ---  --- Stage ---   Total
                   Max Ratio  Max     Ratio   Max  Ratio  Mess   Avg len Reduct  %T %F %M %L %R  %T %F %M %L %R Mflop/s
BuildTwoSided         44 1.0 1.1604e+0012.6 0.00e+00 0.0 9.3e+03 4.0e+00 4.4e+01  7  0  4  0  7   7  0 24  0 35     0
VecScatterBegin        2 1.0 3.6001e-05 1.5 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecScatterEnd          2 1.0 1.6928e-0517.8 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
Mesh Partition         2 1.0 2.0413e+00 1.1 0.00e+00 0.0 1.4e+04 5.1e+03 2.1e+01 14  0  7  8  3  14  0 36  9 17     0
Mesh Migration         2 1.0 4.3615e-01 1.0 0.00e+00 0.0 2.2e+04 2.9e+04 5.4e+01  3  0 10 70  9   3  0 56 80 43     0
DMPlexInterp           1 1.0 2.1172e+0064348.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
DMPlexDistribute       1 1.0 2.2697e+00 1.1 0.00e+00 0.0 9.4e+03 3.5e+04 2.5e+01 15  0  4 36  4  16  0 24 41 20     0
DMPlexDistCones        2 1.0 1.0138e-01 1.1 0.00e+00 0.0 3.2e+03 6.6e+04 4.0e+00  1  0  2 23  1   1  0  8 27  3     0
DMPlexDistLabels       2 1.0 2.7745e-01 1.0 0.00e+00 0.0 1.3e+04 2.7e+04 2.2e+01  2  0  6 39  4   2  0 34 45 18     0
DMPlexDistribOL        1 1.0 2.2781e-01 1.0 0.00e+00 0.0 2.7e+04 1.6e+04 5.0e+01  1  0 13 47  8   2  0 68 54 40     0
DMPlexDistField        3 1.0 3.1382e-02 2.1 0.00e+00 0.0 4.3e+03 6.8e+03 1.2e+01  0  0  2  3  2   0  0 11  4 10     0
DMPlexDistData         2 1.0 1.0031e+0069.7 0.00e+00 0.0 1.0e+04 3.2e+03 6.0e+00  6  0  5  4  1   7  0 26  4  5     0
DMPlexStratify         6 1.5 5.4998e-0129.5 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
SFSetGraph            51 1.0 5.1585e-02 1.5 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
SFBcastBegin          95 1.0 1.1656e+00 4.3 0.00e+00 0.0 3.8e+04 2.0e+04 4.1e+01  7  0 18 84  7   7  0 96 97 33     0
SFBcastEnd            95 1.0 2.9936e-01 6.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  2  0  0  0  0   2  0  0  0  0     0
SFReduceBegin          4 1.0 8.7662e-0318.1 0.00e+00 0.0 1.3e+03 1.3e+04 3.0e+00  0  0  1  2  0   0  0  3  2  2     0
SFReduceEnd            4 1.0 8.8432e-03 5.9 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
SFFetchOpBegin         1 1.0 4.0054e-0518.7 0.00e+00 0.0 1.4e+02 2.2e+03 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
SFFetchOpEnd           1 1.0 1.4091e-04 2.2 0.00e+00 0.0 1.4e+02 2.2e+03 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
BuildTwoSided          1 1.0 1.3969e-0331.2 0.00e+00 0.0 2.9e+02 4.0e+00 1.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecMDot               18 1.0 8.9464e-03 1.4 1.27e+07 1.1 0.0e+00 0.0e+00 1.8e+01  0 10  0  0  3   1 10  0  0  4 44405
VecNorm               19 1.0 3.4175e-03 2.4 1.41e+06 1.1 0.0e+00 0.0e+00 1.9e+01  0  1  0  0  3   0  1  0  0  4 12916
VecScale             266 1.0 1.2009e-03 1.2 1.39e+06 1.1 0.0e+00 0.0e+00 0.0e+00  0  1  0  0  0   0  1  0  0  0 35370
VecCopy                1 1.0 1.2088e-04 1.2 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecSet               244 1.0 2.0475e-03 1.1 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecAXPY               77 1.0 4.8566e-04 1.2 6.13e+05 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0 40100
VecAYPX               76 1.0 3.9840e-04 1.4 2.70e+05 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0 21526
VecMAXPY              19 1.0 4.6327e-03 1.4 1.40e+07 1.1 0.0e+00 0.0e+00 0.0e+00  0 11  0  0  0   1 11  0  0  0 94779
VecScatterBegin      527 1.0 9.9692e-03 1.6 0.00e+00 0.0 1.6e+05 5.3e+02 0.0e+00  0  0 76 10  0   1  0 94 73  0     0
VecScatterEnd        527 1.0 1.0046e-02 1.6 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   1  0  0  0  0     0
VecNormalize          19 1.0 3.9191e-03 2.0 2.11e+06 1.1 0.0e+00 0.0e+00 1.9e+01  0  2  0  0  3   0  2  0  0  4 16894
MatMult              199 1.0 3.2215e-02 1.1 2.07e+07 1.0 4.5e+04 8.3e+02 1.4e+02  0 16 21  4 24   5 16 26 31 30 20169
MatMultAdd           148 1.0 1.8383e-02 1.1 1.16e+07 1.1 9.8e+03 1.9e+03 0.0e+00  0  9  5  2  0   3  9  6 16  0 19751
MatSolve              38 1.0 9.1224e-03 1.2 5.99e+06 1.1 0.0e+00 0.0e+00 0.0e+00  0  5  0  0  0   1  5  0  0  0 20347
MatSOR               152 1.0 4.2917e-02 1.0 3.26e+07 1.1 9.7e+04 4.7e+02 0.0e+00  0 25 45  5  0   7 25 55 38  0 23694
MatLUFactorSym         1 1.0 4.6015e-05 1.6 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatLUFactorNum         2 1.0 2.2459e-03 1.1 6.08e+05 1.1 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0  8301
MatILUFactorSym        1 1.0 1.7860e-03 2.3 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatConvert             2 1.0 8.0991e-04 2.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatScale               2 1.0 1.7459e-03 8.5 1.69e+05 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0  3055
MatResidual           76 1.0 7.5746e-03 1.2 6.14e+06 1.1 3.2e+04 4.7e+02 0.0e+00  0  5 15  2  0   1  5 18 13  0 25052
MatAssemblyBegin      18 1.0 3.6287e-0310.2 0.00e+00 0.0 0.0e+00 0.0e+00 1.4e+01  0  0  0  0  2   0  0  0  0  3     0
MatAssemblyEnd        18 1.0 1.3054e-02 1.2 0.00e+00 0.0 7.0e+03 1.6e+02 8.0e+01  0  0  3  0 13   2  0  4  1 17     0
MatGetRow          24000 1.0 9.4720e-02 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  1  0  0  0  0  16  0  0  0  0     0
MatGetRowIJ            2 1.0 5.1618e-04108.2 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatGetSubMatrice       1 1.0 1.8001e-04 1.2 0.00e+00 0.0 0.0e+00 0.0e+00 4.0e+00  0  0  0  0  1   0  0  0  0  1     0
MatGetSubMatrix        4 1.0 1.2710e-03 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 6.0e+00  0  0  0  0  1   0  0  0  0  1     0
MatGetOrdering         2 1.0 6.5613e-04 5.9 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatAXPY                1 1.0 1.9316e-01 1.0 0.00e+00 0.0 5.4e+02 3.6e+02 1.2e+01  1  0  0  0  2  33  0  0  0  3     0
MatMatMult             1 1.0 1.2574e-02 1.0 3.11e+05 1.0 1.1e+03 1.2e+03 1.6e+01  0  0  1  0  3   2  0  1  1  3   787
MatMatMultSym          1 1.0 1.1223e-02 1.0 0.00e+00 0.0 9.4e+02 9.4e+02 1.4e+01  0  0  0  0  2   2  0  1  1  3     0
MatMatMultNum          1 1.0 1.3480e-03 1.0 3.11e+05 1.0 1.4e+02 2.9e+03 2.0e+00  0  0  0  0  0   0  0  0  0  0  7345
MatRedundantMat        1 1.0 2.0981e-04 1.2 0.00e+00 0.0 0.0e+00 0.0e+00 4.0e+00  0  0  0  0  1   0  0  0  0  1     0
MatGetLocalMat         2 1.0 1.5619e-03 1.4 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatGetBrAoCol          2 1.0 7.3791e-04 2.4 0.00e+00 0.0 5.4e+02 2.0e+03 0.0e+00  0  0  0  0  0   0  0  0  1  0     0
PCSetUp                4 1.0 2.6482e-01 1.0 3.11e+06 1.0 1.2e+04 1.3e+03 2.2e+02  2  2  6  2 36  45  2  7 13 46   371
PCSetUpOnBlocks       19 1.0 4.1590e-03 1.4 5.87e+05 1.1 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   1  0  0  0  0  4318
PCApply               19 1.0 1.3506e-01 1.0 4.98e+07 1.0 1.6e+05 4.3e+02 1.6e+02  1 39 75  8 26  23 39 92 58 33 11590
KSPGMRESOrthog        18 1.0 1.2306e-02 1.3 2.54e+07 1.1 0.0e+00 0.0e+00 1.8e+01  0 20  0  0  3   2 20  0  0  4 64564
KSPSetUp              10 1.0 7.0786e-04 2.2 0.00e+00 0.0 0.0e+00 0.0e+00 8.0e+00  0  0  0  0  1   0  0  0  0  2     0
KSPSolve               1 1.0 3.7938e-01 1.0 9.02e+07 1.0 1.7e+05 5.7e+02 4.0e+02  3 71 81 11 66  65 71 99 82 83  7463
SFBcastBegin           1 1.0 1.4801e-03 9.9 0.00e+00 0.0 8.6e+02 2.2e+03 1.0e+00  0  0  0  0  0   0  0  0  2  0     0
SFBcastEnd             1 1.0 4.5705e-0426.6 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
              Viewer     1              0            0     0.
           Index Set   165            170     23655892     0.
   IS L to G Mapping     3              3     14326164     0.
              Vector    15             87     14178840     0.
      Vector Scatter     2             13       857984     0.
              Matrix     0             29      5131328     0.
           Index Set    50             38        69996     0.
              Vector   327            243      5282368     0.
              Matrix    50              8      3242072     0.
Average time for MPI_Barrier(): 9.01222e-06
Average time for zero size MPI_Send(): 1.65403e-06
-log_summary
 ml 40 1
Discretization: RT
MPI processes 40: solving...
((27890, 1161600), (27890, 1161600))
	Solver time: 5.010350e-01
Darcy_FE.py on a arch-linux2-c-opt named wf153.localdomain with 40 processors, by jychang48 Wed Mar  2 17:42:13 2016
Time (sec):           1.486e+01      1.00013   1.486e+01
Objects:              8.660e+02      1.15775   7.635e+02
Flops:                1.061e+08      1.10163   1.011e+08  4.043e+09
Flops/sec:            7.138e+06      1.10159   6.800e+06  2.720e+08
MPI Messages:         1.235e+04      2.82415   7.572e+03  3.029e+05
MPI Message Lengths:  1.855e+08     11.36833   3.104e+03  9.402e+08
 0:      Main Stage: 1.4362e+01  96.6%  0.0000e+00   0.0%  5.371e+04  17.7%  2.676e+03       86.2%  1.250e+02  20.7%
 1:             FEM: 5.0110e-01   3.4%  4.0430e+09 100.0%  2.492e+05  82.3%  4.278e+02       13.8%  4.780e+02  79.1%
Phase summary info:
BuildTwoSided         44 1.0 1.2159e+0011.9 0.00e+00 0.0 1.3e+04 4.0e+00 4.4e+01  7  0  4  0  7   8  0 24  0 35     0
VecScatterBegin        2 1.0 3.5763e-05 1.8 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecScatterEnd          2 1.0 7.8678e-06 2.8 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
Mesh Partition         2 1.0 2.1240e+00 1.1 0.00e+00 0.0 2.0e+04 3.6e+03 2.1e+01 14  0  7  8  3  15  0 38  9 17     0
Mesh Migration         2 1.0 4.1766e-01 1.0 0.00e+00 0.0 2.9e+04 2.2e+04 5.4e+01  3  0 10 69  9   3  0 54 80 43     0
DMPlexInterp           1 1.0 2.1100e+0061887.8 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
DMPlexDistribute       1 1.0 2.3591e+00 1.1 0.00e+00 0.0 1.4e+04 2.3e+04 2.5e+01 16  0  5 35  4  16  0 26 40 20     0
DMPlexDistCones        2 1.0 9.5764e-02 1.1 0.00e+00 0.0 4.3e+03 5.1e+04 4.0e+00  1  0  1 23  1   1  0  8 27  3     0
DMPlexDistLabels       2 1.0 2.6905e-01 1.0 0.00e+00 0.0 1.7e+04 2.1e+04 2.2e+01  2  0  6 39  4   2  0 32 45 18     0
DMPlexDistribOL        1 1.0 2.0288e-01 1.0 0.00e+00 0.0 3.6e+04 1.2e+04 5.0e+01  1  0 12 47  8   1  0 66 55 40     0
DMPlexDistField        3 1.0 2.9222e-02 2.1 0.00e+00 0.0 5.7e+03 5.2e+03 1.2e+01  0  0  2  3  2   0  0 11  4 10     0
DMPlexDistData         2 1.0 1.0574e+0077.8 0.00e+00 0.0 1.5e+04 2.2e+03 6.0e+00  7  0  5  4  1   7  0 28  4  5     0
DMPlexStratify         6 1.5 5.4311e-0135.7 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
SFSetGraph            51 1.0 4.2634e-02 1.6 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
SFBcastBegin          95 1.0 1.2205e+00 4.4 0.00e+00 0.0 5.1e+04 1.5e+04 4.1e+01  8  0 17 83  7   8  0 96 97 33     0
SFBcastEnd            95 1.0 3.0737e-01 6.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  2  0  0  0  0   2  0  0  0  0     0
SFReduceBegin          4 1.0 9.1023e-0319.9 0.00e+00 0.0 1.7e+03 9.4e+03 3.0e+00  0  0  1  2  0   0  0  3  2  2     0
SFReduceEnd            4 1.0 9.7229e-03 7.6 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
SFFetchOpBegin         1 1.0 4.1008e-0521.5 0.00e+00 0.0 1.9e+02 1.8e+03 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
SFFetchOpEnd           1 1.0 1.1396e-04 2.1 0.00e+00 0.0 1.9e+02 1.8e+03 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
BuildTwoSided          1 1.0 1.7800e-0332.3 0.00e+00 0.0 3.8e+02 4.0e+00 1.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecMDot               18 1.0 7.3071e-03 1.4 1.02e+07 1.1 0.0e+00 0.0e+00 1.8e+01  0 10  0  0  3   1 10  0  0  4 54367
VecNorm               19 1.0 1.8599e-03 1.8 1.13e+06 1.1 0.0e+00 0.0e+00 1.9e+01  0  1  0  0  3   0  1  0  0  4 23733
VecScale             266 1.0 1.0359e-03 1.2 1.14e+06 1.1 0.0e+00 0.0e+00 0.0e+00  0  1  0  0  0   0  1  0  0  0 41655
VecCopy                1 1.0 1.0204e-04 1.3 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecSet               244 1.0 1.7505e-03 1.2 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecAXPY               77 1.0 4.1318e-04 1.3 4.91e+05 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0 47153
VecAYPX               76 1.0 3.1829e-04 1.3 2.16e+05 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0 26956
VecMAXPY              19 1.0 2.7597e-03 1.2 1.12e+07 1.1 0.0e+00 0.0e+00 0.0e+00  0 11  0  0  0   0 11  0  0  0 159106
VecScatterBegin      527 1.0 9.4907e-03 1.8 0.00e+00 0.0 2.3e+05 4.2e+02 0.0e+00  0  0 77 10  0   1  0 94 75  0     0
VecScatterEnd        527 1.0 1.1055e-02 1.7 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   2  0  0  0  0     0
VecNormalize          19 1.0 2.2883e-03 1.5 1.70e+06 1.1 0.0e+00 0.0e+00 1.9e+01  0  2  0  0  3   0  2  0  0  4 28934
MatMult              199 1.0 2.8809e-02 1.1 1.66e+07 1.0 6.2e+04 6.6e+02 1.4e+02  0 16 21  4 24   6 16 25 32 30 22581
MatMultAdd           148 1.0 1.5773e-02 1.2 9.31e+06 1.1 1.3e+04 1.6e+03 0.0e+00  0  9  4  2  0   3  9  5 16  0 23019
MatSolve              38 1.0 7.4098e-03 1.1 4.82e+06 1.1 0.0e+00 0.0e+00 0.0e+00  0  5  0  0  0   1  5  0  0  0 25130
MatSOR               152 1.0 3.6705e-02 1.0 2.62e+07 1.1 1.4e+05 3.7e+02 0.0e+00  0 25 45  5  0   7 25 55 39  0 27750
MatLUFactorSym         1 1.0 5.2929e-05 1.4 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatLUFactorNum         2 1.0 1.8580e-03 1.1 5.15e+05 1.1 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0 10544
MatILUFactorSym        1 1.0 1.2209e-03 1.9 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatConvert             2 1.0 6.3920e-04 1.5 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatScale               2 1.0 2.2421e-0315.3 1.35e+05 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0  2378
MatResidual           76 1.0 6.9928e-03 1.2 4.96e+06 1.1 4.6e+04 3.7e+02 0.0e+00  0  5 15  2  0   1  5 18 13  0 27255
MatAssemblyBegin      18 1.0 3.5076e-0310.1 0.00e+00 0.0 0.0e+00 0.0e+00 1.4e+01  0  0  0  0  2   0  0  0  0  3     0
MatAssemblyEnd        18 1.0 1.1627e-02 1.2 0.00e+00 0.0 1.0e+04 1.2e+02 8.0e+01  0  0  3  0 13   2  0  4  1 17     0
MatGetRow          19200 1.0 7.6632e-02 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  1  0  0  0  0  15  0  0  0  0     0
MatGetRowIJ            2 1.0 5.0902e-04101.7 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatGetSubMatrice       1 1.0 2.1482e-04 1.1 0.00e+00 0.0 0.0e+00 0.0e+00 4.0e+00  0  0  0  0  1   0  0  0  0  1     0
MatGetSubMatrix        4 1.0 1.1673e-03 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 6.0e+00  0  0  0  0  1   0  0  0  0  1     0
MatGetOrdering         2 1.0 6.2823e-04 6.3 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatAXPY                1 1.0 1.5566e-01 1.0 0.00e+00 0.0 7.2e+02 3.0e+02 1.2e+01  1  0  0  0  2  31  0  0  0  3     0
MatMatMult             1 1.0 1.0531e-02 1.0 2.49e+05 1.0 1.4e+03 9.9e+02 1.6e+01  0  0  0  0  3   2  0  1  1  3   940
MatMatMultSym          1 1.0 9.4621e-03 1.0 0.00e+00 0.0 1.3e+03 7.8e+02 1.4e+01  0  0  0  0  2   2  0  1  1  3     0
MatMatMultNum          1 1.0 1.0662e-03 1.0 2.49e+05 1.0 1.8e+02 2.4e+03 2.0e+00  0  0  0  0  0   0  0  0  0  0  9284
MatRedundantMat        1 1.0 2.4199e-04 1.1 0.00e+00 0.0 0.0e+00 0.0e+00 4.0e+00  0  0  0  0  1   0  0  0  0  1     0
MatGetLocalMat         2 1.0 1.2550e-03 1.4 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatGetBrAoCol          2 1.0 5.9271e-04 2.9 0.00e+00 0.0 7.2e+02 1.7e+03 0.0e+00  0  0  0  0  0   0  0  0  1  0     0
PCSetUp                4 1.0 2.1873e-01 1.0 2.52e+06 1.0 1.7e+04 9.5e+02 2.2e+02  1  2  6  2 36  44  2  7 13 46   454
PCSetUpOnBlocks       19 1.0 3.0646e-03 1.3 4.73e+05 1.1 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   1  0  0  0  0  5846
PCApply               19 1.0 1.1932e-01 1.0 4.00e+07 1.0 2.3e+05 3.3e+02 1.6e+02  1 39 76  8 26  24 39 93 59 33 13154
KSPGMRESOrthog        18 1.0 9.8231e-03 1.3 2.03e+07 1.1 0.0e+00 0.0e+00 1.8e+01  0 20  0  0  3   2 20  0  0  4 80884
KSPSetUp              10 1.0 6.3419e-04 1.9 0.00e+00 0.0 0.0e+00 0.0e+00 8.0e+00  0  0  0  0  1   0  0  0  0  2     0
KSPSolve               1 1.0 3.1758e-01 1.0 7.21e+07 1.0 2.5e+05 4.4e+02 4.0e+02  2 70 81 12 66  63 70 99 84 83  8928
SFBcastBegin           1 1.0 1.8940e-0310.1 0.00e+00 0.0 1.2e+03 1.8e+03 1.0e+00  0  0  0  0  0   0  0  0  2  0     0
SFBcastEnd             1 1.0 6.5684e-0443.7 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
Memory usage is given in bytes:
Object Type          Creations   Destructions     Memory  Descendants' Mem.
Reports information only for process 0.
           Container     6              3         1728     0.
              Viewer     1              0            0     0.
           Index Set   187            192     23335476     0.
   IS L to G Mapping     3              3     14094724     0.
              Vector    15             87     12319944     0.
      Vector Scatter     2             13       683624     0.
              Matrix     0             29      4148000     0.
           Index Set    50             38        68468     0.
   IS L to G Mapping     4              0            0     0.
              Vector   327            243      4309184     0.
              Matrix    50              8      2592528     0.
Average time for zero size MPI_Send(): 1.40071e-06
#PETSc Option Table entries:
-log_summary
-solver_fieldsplit_0_ksp_type preonly
-solver_fieldsplit_0_pc_type bjacobi
-solver_fieldsplit_1_ksp_type preonly
-solver_ksp_rtol 1e-7
-solver_ksp_type gmres
-solver_pc_fieldsplit_schur_fact_type upper
-solver_pc_fieldsplit_schur_precondition selfp
-solver_pc_fieldsplit_type schur
-solver_pc_type fieldsplit
#End of PETSc Option Table entries
Compiled without FORTRAN kernels
Compiled with full precision matrices (default)
sizeof(short) 2 sizeof(int) 4 sizeof(long) 8 sizeof(void*) 8 sizeof(PetscScalar) 8 sizeof(PetscInt) 4
Configure options: --download-chaco=/users/jychang48/externalpackages/Chaco-2.2-p2.tar.gz --download-ctetgen=/users/jychang48/externalpackages/ctetgen-0.4.tar.gz --download-exodusii=/users/jychang48/externalpackages/exodus-5.24.tar.bz2 --download-fblaslapack=/users/jychang48/externalpackages/fblaslapack-3.4.2.tar.gz --download-hdf5=/users/jychang48/externalpackages/hdf5-1.8.12.tar.gz --download-hypre=/users/jychang48/externalpackages/hypre-2.10.0b-p1.tar.gz --download-metis=/users/jychang48/externalpackages/metis-5.1.0-p1.tar.gz --download-ml=/users/jychang48/externalpackages/ml-6.2-p3.tar.gz --download-mumps=/users/jychang48/externalpackages/MUMPS_5.0.1-p1.tar.gz --download-netcdf=/users/jychang48/externalpackages/netcdf-4.3.2.tar.gz --download-parmetis=/users/jychang48/externalpackages/parmetis-4.0.3-p2.tar.gz --download-scalapack=/users/jychang48/externalpackages/scalapack-2.0.2.tgz --download-superlu_dist --download-triangle=/users/jychang48/externalpackages/Triangle.tar.gz --with-cc=mpicc --with-cxx=mpicxx --with-debugging=0 --with-fc=mpif90 --with-papi=/usr/projects/hpcsoft/toss2/common/papi/5.4.1 --with-shared-libraries COPTFLAGS=-O3 CXXOPTFLAGS=-O3 FOPTFLAGS=-O3 PETSC_ARCH=arch-linux2-c-opt
Libraries compiled on Fri Jan  1 21:44:06 2016 on wf-fe2.lanl.gov
Machine characteristics: Linux-2.6.32-573.8.1.2chaos.ch5.4.x86_64-x86_64-with-redhat-6.7-Santiago
Using PETSc directory: /users/jychang48/petsc
Using PETSc arch: arch-linux2-c-opt
Using C compiler: mpicc  -fPIC  -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -O3  ${COPTFLAGS} ${CFLAGS}
Using Fortran compiler: mpif90  -fPIC -Wall -Wno-unused-variable -ffree-line-length-0 -Wno-unused-dummy-argument -O3   ${FOPTFLAGS} ${FFLAGS}
Using include paths: -I/users/jychang48/petsc/arch-linux2-c-opt/include -I/users/jychang48/petsc/include -I/users/jychang48/petsc/include -I/users/jychang48/petsc/arch-linux2-c-opt/include -I/usr/projects/hpcsoft/toss2.2/wolf/openmpi/1.6.5-gcc-4.8/include/openmpi/opal/mca/hwloc/hwloc132/hwloc/include -I/usr/projects/hpcsoft/toss2.2/wolf/openmpi/1.6.5-gcc-4.8/include -I/usr/projects/hpcsoft/toss2.2/wolf/openmpi/1.6.5-gcc-4.8/include/openmpi
Using C linker: mpicc
Using Fortran linker: mpif90
Using libraries: -Wl,-rpath,/users/jychang48/petsc/arch-linux2-c-opt/lib -L/users/jychang48/petsc/arch-linux2-c-opt/lib -lpetsc -Wl,-rpath,/users/jychang48/petsc/arch-linux2-c-opt/lib -L/users/jychang48/petsc/arch-linux2-c-opt/lib -lcmumps -ldmumps -lsmumps -lzmumps -lmumps_common -lpord -lscalapack -lsuperlu_dist_4.2 -lHYPRE -Wl,-rpath,/usr/projects/hpcsoft/toss2.2/wolf/openmpi/1.6.5-gcc-4.8/lib -L/usr/projects/hpcsoft/toss2.2/wolf/openmpi/1.6.5-gcc-4.8/lib -Wl,-rpath,/turquoise/usr/projects/hpcsoft/toss2/common/gcc/4.8.2/lib/gcc/x86_64-unknown-linux-gnu/4.8.2 -L/turquoise/usr/projects/hpcsoft/toss2/common/gcc/4.8.2/lib/gcc/x86_64-unknown-linux-gnu/4.8.2 -Wl,-rpath,/turquoise/usr/projects/hpcsoft/toss2/common/gcc/4.8.2/lib/gcc -L/turquoise/usr/projects/hpcsoft/toss2/common/gcc/4.8.2/lib/gcc -Wl,-rpath,/turquoise/usr/projects/hpcsoft/toss2/common/gcc/4.8.2/lib64 -L/turquoise/usr/projects/hpcsoft/toss2/common/gcc/4.8.2/lib64 -Wl,-rpath,/turquoise/usr/projects/hpcsoft/toss2/common/gcc/4.8.2/lib -L/turquoise/usr/projects/hpcsoft/toss2/common/gcc/4.8.2/lib -lmpi_cxx -lstdc++ -lml -lmpi_cxx -lstdc++ -lflapack -lfblas -lparmetis -lmetis -lchaco -lexoIIv2for -lexodus -lnetcdf -lhdf5hl_fortran -lhdf5_fortran -lhdf5_hl -lhdf5 -ltriangle -lX11 -lhwloc -lctetgen -lssl -lcrypto -lmpi_f90 -lmpi_f77 -lgfortran -lm -lgfortran -lm -lgfortran -lm -lgfortran -lm -lgfortran -lm -lquadmath -lm -lmpi_cxx -lstdc++ -Wl,-rpath,/usr/projects/hpcsoft/toss2.2/wolf/openmpi/1.6.5-gcc-4.8/lib -L/usr/projects/hpcsoft/toss2.2/wolf/openmpi/1.6.5-gcc-4.8/lib -Wl,-rpath,/turquoise/usr/projects/hpcsoft/toss2/common/gcc/4.8.2/lib/gcc/x86_64-unknown-linux-gnu/4.8.2 -L/turquoise/usr/projects/hpcsoft/toss2/common/gcc/4.8.2/lib/gcc/x86_64-unknown-linux-gnu/4.8.2 -Wl,-rpath,/turquoise/usr/projects/hpcsoft/toss2/common/gcc/4.8.2/lib/gcc -L/turquoise/usr/projects/hpcsoft/toss2/common/gcc/4.8.2/lib/gcc -Wl,-rpath,/turquoise/usr/projects/hpcsoft/toss2/common/gcc/4.8.2/lib64 -L/turquoise/usr/projects/hpcsoft/toss2/common/gcc/4.8.2/lib64 -Wl,-rpath,/turquoise/usr/projects/hpcsoft/toss2/common/gcc/4.8.2/lib -L/turquoise/usr/projects/hpcsoft/toss2/common/gcc/4.8.2/lib -ldl -lmpi -losmcomp -lrdmacm -libverbs -lsctp -lrt -lnsl -lutil -lpsm_infinipath -lpmi -lnuma -lgcc_s -lpthread -ldl
 ml 40 1
Discretization: RT
MPI processes 48: solving...
((23365, 1161600), (23365, 1161600))
	Solver time: 4.549189e-01
Darcy_FE.py on a arch-linux2-c-opt named wf153.localdomain with 48 processors, by jychang48 Wed Mar  2 17:42:31 2016
Time (sec):           1.494e+01      1.00013   1.494e+01
Objects:              8.740e+02      1.16845   7.631e+02
Flops:                8.941e+07      1.11020   8.501e+07  4.081e+09
Flops/sec:            5.986e+06      1.11026   5.692e+06  2.732e+08
MPI Messages:         1.241e+04      2.76359   8.136e+03  3.905e+05
MPI Message Lengths:  1.820e+08     13.08995   2.475e+03  9.666e+08
 0:      Main Stage: 1.4481e+01  97.0%  0.0000e+00   0.0%  6.669e+04  17.1%  2.121e+03       85.7%  1.250e+02  20.7%
 1:             FEM: 4.5505e-01   3.0%  4.0806e+09 100.0%  3.239e+05  82.9%  3.544e+02       14.3%  4.780e+02  79.1%
Phase summary info:
BuildTwoSided         44 1.0 1.2041e+0013.4 0.00e+00 0.0 1.6e+04 4.0e+00 4.4e+01  7  0  4  0  7   8  0 24  0 35     0
VecScatterBegin        2 1.0 3.1948e-05 1.9 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecScatterEnd          2 1.0 9.0599e-06 4.8 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
Mesh Partition         2 1.0 2.1464e+00 1.1 0.00e+00 0.0 2.7e+04 2.8e+03 2.1e+01 14  0  7  8  3  15  0 40  9 17     0
Mesh Migration         2 1.0 4.0869e-01 1.0 0.00e+00 0.0 3.4e+04 1.9e+04 5.4e+01  3  0  9 68  9   3  0 51 80 43     0
DMPlexInterp           1 1.0 2.1102e+0064135.7 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
DMPlexDistribute       1 1.0 2.4017e+00 1.1 0.00e+00 0.0 1.9e+04 1.7e+04 2.5e+01 16  0  5 34  4  17  0 29 40 20     0
DMPlexDistCones        2 1.0 9.4518e-02 1.2 0.00e+00 0.0 5.1e+03 4.3e+04 4.0e+00  1  0  1 23  1   1  0  8 26  3     0
DMPlexDistLabels       2 1.0 2.6648e-01 1.0 0.00e+00 0.0 2.1e+04 1.8e+04 2.2e+01  2  0  5 39  4   2  0 31 45 18     0
DMPlexDistribOL        1 1.0 1.7164e-01 1.1 0.00e+00 0.0 4.2e+04 1.1e+04 5.0e+01  1  0 11 47  8   1  0 64 55 40     0
DMPlexDistField        3 1.0 2.8804e-02 2.2 0.00e+00 0.0 6.8e+03 4.5e+03 1.2e+01  0  0  2  3  2   0  0 10  4 10     0
DMPlexDistData         2 1.0 1.0458e+0067.3 0.00e+00 0.0 2.1e+04 1.7e+03 6.0e+00  7  0  5  4  1   7  0 31  4  5     0
DMPlexStratify         6 1.5 5.3865e-0141.3 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
SFSetGraph            51 1.0 3.6523e-02 1.6 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
SFBcastBegin          95 1.0 1.2136e+00 4.5 0.00e+00 0.0 6.4e+04 1.3e+04 4.1e+01  8  0 16 83  7   8  0 96 97 33     0
SFBcastEnd            95 1.0 3.0116e-01 6.1 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  2  0  0  0  0   2  0  0  0  0     0
SFReduceBegin          4 1.0 9.5670e-0323.0 0.00e+00 0.0 2.0e+03 8.2e+03 3.0e+00  0  0  1  2  0   0  0  3  2  2     0
SFReduceEnd            4 1.0 9.3460e-03 7.4 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
SFFetchOpBegin         1 1.0 3.5048e-0518.4 0.00e+00 0.0 2.2e+02 1.7e+03 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
SFFetchOpEnd           1 1.0 1.1182e-04 2.5 0.00e+00 0.0 2.2e+02 1.7e+03 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
BuildTwoSided          1 1.0 3.1829e-0358.8 0.00e+00 0.0 4.6e+02 4.0e+00 1.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecMDot               18 1.0 6.1665e-03 1.5 8.50e+06 1.1 0.0e+00 0.0e+00 1.8e+01  0 10  0  0  3   1 10  0  0  4 64423
VecNorm               19 1.0 1.2932e-03 1.5 9.45e+05 1.1 0.0e+00 0.0e+00 1.9e+01  0  1  0  0  3   0  1  0  0  4 34133
VecScale             266 1.0 9.3555e-04 1.2 9.80e+05 1.2 0.0e+00 0.0e+00 0.0e+00  0  1  0  0  0   0  1  0  0  0 46730
VecCopy                1 1.0 7.7009e-05 1.2 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecSet               244 1.0 1.3967e-03 1.1 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecAXPY               77 1.0 3.7766e-04 1.4 4.09e+05 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0 51622
VecAYPX               76 1.0 3.3188e-04 1.6 1.80e+05 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0 25871
VecMAXPY              19 1.0 2.2688e-03 1.2 9.40e+06 1.1 0.0e+00 0.0e+00 0.0e+00  0 11  0  0  0   0 11  0  0  0 193532
VecScatterBegin      527 1.0 9.3722e-03 1.9 0.00e+00 0.0 3.0e+05 3.5e+02 0.0e+00  0  0 78 11  0   2  0 94 76  0     0
VecScatterEnd        527 1.0 1.1200e-02 1.8 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   2  0  0  0  0     0
VecNormalize          19 1.0 1.7309e-03 1.3 1.42e+06 1.1 0.0e+00 0.0e+00 1.9e+01  0  2  0  0  3   0  2  0  0  4 38252
MatMult              199 1.0 2.5053e-02 1.1 1.40e+07 1.1 7.9e+04 5.7e+02 1.4e+02  0 16 20  5 24   5 16 24 32 30 25999
MatMultAdd           148 1.0 1.3936e-02 1.2 7.82e+06 1.1 1.6e+04 1.4e+03 0.0e+00  0  9  4  2  0   3  9  5 16  0 26055
MatSolve              38 1.0 6.1853e-03 1.1 4.06e+06 1.1 0.0e+00 0.0e+00 0.0e+00  0  5  0  0  0   1  5  0  0  0 30315
MatSOR               152 1.0 3.2173e-02 1.1 2.18e+07 1.1 1.8e+05 3.1e+02 0.0e+00  0 25 45  6  0   7 25 54 40  0 31732
MatLUFactorSym         1 1.0 6.9857e-05 1.5 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatLUFactorNum         2 1.0 1.5531e-03 1.1 4.69e+05 1.1 0.0e+00 0.0e+00 0.0e+00  0  1  0  0  0   0  1  0  0  0 13764
MatILUFactorSym        1 1.0 6.4588e-04 1.1 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatConvert             2 1.0 5.5194e-04 1.7 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatScale               2 1.0 1.5218e-0312.3 1.13e+05 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0  3504
MatResidual           76 1.0 6.3055e-03 1.2 4.14e+06 1.1 5.9e+04 3.1e+02 0.0e+00  0  5 15  2  0   1  5 18 13  0 30359
MatAssemblyBegin      18 1.0 3.1672e-03 7.4 0.00e+00 0.0 0.0e+00 0.0e+00 1.4e+01  0  0  0  0  2   0  0  0  0  3     0
MatAssemblyEnd        18 1.0 1.0310e-02 1.2 0.00e+00 0.0 1.3e+04 1.0e+02 8.0e+01  0  0  3  0 13   2  0  4  1 17     0
MatGetRow          16000 1.0 6.3519e-02 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0  14  0  0  0  0     0
MatGetRowIJ            2 1.0 4.5180e-0475.8 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatGetSubMatrice       1 1.0 2.7895e-04 1.2 0.00e+00 0.0 0.0e+00 0.0e+00 4.0e+00  0  0  0  0  1   0  0  0  0  1     0
MatGetSubMatrix        4 1.0 9.4771e-04 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 6.0e+00  0  0  0  0  1   0  0  0  0  1     0
MatGetOrdering         2 1.0 5.5814e-04 6.3 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatAXPY                1 1.0 1.2936e-01 1.0 0.00e+00 0.0 8.6e+02 2.7e+02 1.2e+01  1  0  0  0  2  28  0  0  0  3     0
MatMatMult             1 1.0 9.1429e-03 1.0 2.08e+05 1.0 1.7e+03 8.9e+02 1.6e+01  0  0  0  0  3   2  0  1  1  3  1083
MatMatMultSym          1 1.0 8.2440e-03 1.0 0.00e+00 0.0 1.5e+03 7.0e+02 1.4e+01  0  0  0  0  2   2  0  0  1  3     0
MatMatMultNum          1 1.0 8.9502e-04 1.0 2.08e+05 1.0 2.2e+02 2.2e+03 2.0e+00  0  0  0  0  0   0  0  0  0  0 11060
MatRedundantMat        1 1.0 3.0804e-04 1.2 0.00e+00 0.0 0.0e+00 0.0e+00 4.0e+00  0  0  0  0  1   0  0  0  0  1     0
MatGetLocalMat         2 1.0 1.0741e-03 1.5 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatGetBrAoCol          2 1.0 5.8627e-04 3.3 0.00e+00 0.0 8.6e+02 1.5e+03 0.0e+00  0  0  0  0  0   0  0  0  1  0     0
PCSetUp                4 1.0 1.8617e-01 1.0 2.14e+06 1.0 2.3e+04 7.5e+02 2.2e+02  1  2  6  2 36  41  2  7 12 46   543
PCSetUpOnBlocks       19 1.0 2.2240e-03 1.1 3.97e+05 1.1 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0  8045
PCApply               19 1.0 1.0738e-01 1.0 3.36e+07 1.0 3.0e+05 2.8e+02 1.6e+02  1 39 77  9 26  23 39 93 61 33 14674
KSPGMRESOrthog        18 1.0 8.1601e-03 1.3 1.70e+07 1.1 0.0e+00 0.0e+00 1.8e+01  0 19  0  0  3   2 19  0  0  4 97367
KSPSetUp              10 1.0 5.8508e-04 1.8 0.00e+00 0.0 0.0e+00 0.0e+00 8.0e+00  0  0  0  0  1   0  0  0  0  2     0
KSPSolve               1 1.0 2.7342e-01 1.0 6.07e+07 1.0 3.2e+05 3.6e+02 4.0e+02  2 70 82 12 66  60 70 99 84 83 10394
SFBcastBegin           1 1.0 3.2558e-0320.1 0.00e+00 0.0 1.4e+03 1.7e+03 1.0e+00  0  0  0  0  0   0  0  0  2  0     0
SFBcastEnd             1 1.0 2.1031e-03163.4 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
              Viewer     1              0            0     0.
           Index Set   195            200     22896544     0.
   IS L to G Mapping     3              3     14076928     0.
              Vector    15             87     11144984     0.
      Vector Scatter     2             13       575024     0.
              Matrix     0             29      3506540     0.
           Index Set    50             38        60332     0.
              Vector   327            243      3661024     0.
              Matrix    50              8      2166428     0.
       Krylov Solver    12              1         1352     0.
Average time for MPI_Barrier(): 9.63211e-06
Average time for zero size MPI_Send(): 1.35601e-06
-log_summary
-solver_fieldsplit_1_pc_type ml
 ml 40 1
Discretization: RT
MPI processes 56: solving...
((20104, 1161600), (20104, 1161600))
	Solver time: 4.187219e-01
Darcy_FE.py on a arch-linux2-c-opt named wf153.localdomain with 56 processors, by jychang48 Wed Mar  2 17:42:50 2016
Time (sec):           1.527e+01      1.00017   1.527e+01
Objects:              8.920e+02      1.18933   7.639e+02
Flops:                7.757e+07      1.12535   7.363e+07  4.123e+09
Flops/sec:            5.079e+06      1.12536   4.821e+06  2.700e+08
MPI Messages:         1.388e+04      2.76367   8.987e+03  5.033e+05
MPI Message Lengths:  1.801e+08     15.41287   1.981e+03  9.969e+08
 0:      Main Stage: 1.4853e+01  97.3%  0.0000e+00   0.0%  8.318e+04  16.5%  1.686e+03       85.1%  1.250e+02  20.7%
 1:             FEM: 4.1873e-01   2.7%  4.1231e+09 100.0%  4.201e+05  83.5%  2.951e+02       14.9%  4.780e+02  79.1%
Phase summary info:
BuildTwoSided         44 1.0 1.2200e+0012.6 0.00e+00 0.0 2.0e+04 4.0e+00 4.4e+01  7  0  4  0  7   8  0 24  0 35     0
VecScatterBegin        2 1.0 2.7418e-05 1.9 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
Mesh Partition         2 1.0 2.1967e+00 1.1 0.00e+00 0.0 3.5e+04 2.2e+03 2.1e+01 14  0  7  8  3  15  0 42  9 17     0
Mesh Migration         2 1.0 4.0311e-01 1.0 0.00e+00 0.0 4.1e+04 1.6e+04 5.4e+01  3  0  8 68  9   3  0 50 79 43     0
DMPlexInterp           1 1.0 2.1118e+0061941.1 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
DMPlexDistribute       1 1.0 2.4639e+00 1.1 0.00e+00 0.0 2.6e+04 1.3e+04 2.5e+01 16  0  5 33  4  17  0 31 39 20     0
DMPlexDistCones        2 1.0 9.4431e-02 1.2 0.00e+00 0.0 6.2e+03 3.6e+04 4.0e+00  1  0  1 22  1   1  0  7 26  3     0
DMPlexDistLabels       2 1.0 2.6321e-01 1.0 0.00e+00 0.0 2.5e+04 1.5e+04 2.2e+01  2  0  5 38  4   2  0 30 45 18     0
DMPlexDistribOL        1 1.0 1.5705e-01 1.1 0.00e+00 0.0 5.1e+04 9.2e+03 5.0e+01  1  0 10 47  8   1  0 62 56 40     0
DMPlexDistField        3 1.0 3.1058e-02 2.4 0.00e+00 0.0 8.3e+03 3.8e+03 1.2e+01  0  0  2  3  2   0  0 10  4 10     0
DMPlexDistData         2 1.0 1.0646e+0054.2 0.00e+00 0.0 2.8e+04 1.3e+03 6.0e+00  7  0  6  4  1   7  0 33  4  5     0
DMPlexStratify         6 1.5 5.4248e-0150.3 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
SFSetGraph            51 1.0 3.2736e-02 1.7 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
SFBcastBegin          95 1.0 1.2264e+00 4.1 0.00e+00 0.0 8.0e+04 1.0e+04 4.1e+01  8  0 16 82  7   8  0 96 97 33     0
SFBcastEnd            95 1.0 2.9831e-01 9.7 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  2  0  0  0  0   2  0  0  0  0     0
SFReduceBegin          4 1.0 9.1031e-0324.5 0.00e+00 0.0 2.5e+03 6.8e+03 3.0e+00  0  0  0  2  0   0  0  3  2  2     0
SFReduceEnd            4 1.0 9.3877e-03 7.3 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
SFFetchOpBegin         1 1.0 3.6001e-0518.9 0.00e+00 0.0 2.7e+02 1.5e+03 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
SFFetchOpEnd           1 1.0 1.2803e-04 3.4 0.00e+00 0.0 2.7e+02 1.5e+03 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
BuildTwoSided          1 1.0 1.4439e-0329.0 0.00e+00 0.0 5.6e+02 4.0e+00 1.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecMDot               18 1.0 6.0709e-03 1.5 7.29e+06 1.1 0.0e+00 0.0e+00 1.8e+01  0 10  0  0  3   1 10  0  0  4 65437
VecNorm               19 1.0 1.3041e-03 1.4 8.10e+05 1.1 0.0e+00 0.0e+00 1.9e+01  0  1  0  0  3   0  1  0  0  4 33846
VecScale             266 1.0 8.6451e-04 1.2 8.50e+05 1.2 0.0e+00 0.0e+00 0.0e+00  0  1  0  0  0   0  1  0  0  0 51332
VecCopy                1 1.0 7.3910e-05 1.4 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecSet               244 1.0 1.2527e-03 1.2 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecAXPY               77 1.0 3.4428e-04 1.5 3.51e+05 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0 56644
VecAYPX               76 1.0 2.8181e-04 1.5 1.54e+05 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0 30478
VecMAXPY              19 1.0 1.9228e-03 1.2 8.05e+06 1.1 0.0e+00 0.0e+00 0.0e+00  0 11  0  0  0   0 11  0  0  0 228352
VecScatterBegin      527 1.0 9.7260e-03 2.0 0.00e+00 0.0 3.9e+05 2.9e+02 0.0e+00  0  0 78 12  0   2  0 94 78  0     0
VecScatterEnd        527 1.0 1.1311e-02 1.6 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   2  0  0  0  0     0
VecNormalize          19 1.0 1.6813e-03 1.3 1.21e+06 1.1 0.0e+00 0.0e+00 1.9e+01  0  2  0  0  3   0  2  0  0  4 39380
MatMult              199 1.0 2.4066e-02 1.1 1.19e+07 1.1 1.0e+05 4.8e+02 1.4e+02  0 16 20  5 24   6 16 24 33 30 27088
MatMultAdd           148 1.0 1.2908e-02 1.2 6.69e+06 1.1 1.9e+04 1.3e+03 0.0e+00  0  9  4  2  0   3  9  5 16  0 28129
MatSolve              38 1.0 5.4102e-03 1.1 3.52e+06 1.1 0.0e+00 0.0e+00 0.0e+00  0  5  0  0  0   1  5  0  0  0 35022
MatSOR               152 1.0 3.0248e-02 1.1 1.88e+07 1.1 2.3e+05 2.6e+02 0.0e+00  0 25 45  6  0   7 25 54 41  0 33772
MatLUFactorSym         1 1.0 1.0395e-04 1.6 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatLUFactorNum         2 1.0 1.3649e-03 1.1 4.56e+05 1.1 0.0e+00 0.0e+00 0.0e+00  0  1  0  0  0   0  1  0  0  0 17818
MatILUFactorSym        1 1.0 5.8317e-04 1.2 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatConvert             2 1.0 5.0116e-04 2.1 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatScale               2 1.0 2.1529e-0319.4 9.68e+04 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0  2476
MatResidual           76 1.0 6.1171e-03 1.2 3.58e+06 1.1 7.6e+04 2.6e+02 0.0e+00  0  5 15  2  0   1  5 18 14  0 31389
MatAssemblyBegin      18 1.0 3.7098e-03 7.8 0.00e+00 0.0 0.0e+00 0.0e+00 1.4e+01  0  0  0  0  2   1  0  0  0  3     0
MatAssemblyEnd        18 1.0 1.0228e-02 1.2 0.00e+00 0.0 1.7e+04 8.6e+01 8.0e+01  0  0  3  0 13   2  0  4  1 17     0
MatGetRow          13716 1.0 5.4721e-02 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0  13  0  0  0  0     0
MatGetRowIJ            2 1.0 5.5599e-0493.3 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatGetSubMatrice       1 1.0 3.1495e-04 1.3 0.00e+00 0.0 0.0e+00 0.0e+00 4.0e+00  0  0  0  0  1   0  0  0  0  1     0
MatGetSubMatrix        4 1.0 8.2636e-04 1.1 0.00e+00 0.0 0.0e+00 0.0e+00 6.0e+00  0  0  0  0  1   0  0  0  0  1     0
MatGetOrdering         2 1.0 6.3801e-04 8.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatAXPY                1 1.0 1.1296e-01 1.0 0.00e+00 0.0 1.0e+03 2.4e+02 1.2e+01  1  0  0  0  2  27  0  0  0  3     0
MatMatMult             1 1.0 8.5900e-03 1.0 1.78e+05 1.0 2.1e+03 8.0e+02 1.6e+01  0  0  0  0  3   2  0  0  1  3  1152
MatMatMultSym          1 1.0 7.7760e-03 1.0 0.00e+00 0.0 1.8e+03 6.3e+02 1.4e+01  0  0  0  0  2   2  0  0  1  3     0
MatMatMultNum          1 1.0 8.0490e-04 1.0 1.78e+05 1.0 2.6e+02 2.0e+03 2.0e+00  0  0  0  0  0   0  0  0  0  0 12296
MatRedundantMat        1 1.0 3.4714e-04 1.2 0.00e+00 0.0 0.0e+00 0.0e+00 4.0e+00  0  0  0  0  1   0  0  0  0  1     0
MatGetLocalMat         2 1.0 9.2196e-04 1.4 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatGetBrAoCol          2 1.0 4.9806e-04 2.9 0.00e+00 0.0 1.0e+03 1.4e+03 0.0e+00  0  0  0  0  0   0  0  0  1  0     0
PCSetUp                4 1.0 1.6844e-01 1.0 1.89e+06 1.0 2.9e+04 6.0e+02 2.2e+02  1  3  6  2 36  40  3  7 12 46   617
PCSetUpOnBlocks       19 1.0 1.9562e-03 1.1 3.40e+05 1.1 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0  9125
PCApply               19 1.0 1.0325e-01 1.0 2.89e+07 1.0 3.9e+05 2.3e+02 1.6e+02  1 38 78  9 26  24 38 94 62 33 15320
KSPGMRESOrthog        18 1.0 7.8821e-03 1.3 1.46e+07 1.1 0.0e+00 0.0e+00 1.8e+01  0 19  0  0  3   2 19  0  0  4 100801
KSPSetUp              10 1.0 5.4169e-04 1.9 0.00e+00 0.0 0.0e+00 0.0e+00 8.0e+00  0  0  0  0  1   0  0  0  0  2     0
KSPSolve               1 1.0 2.5057e-01 1.0 5.19e+07 1.0 4.2e+05 3.0e+02 4.0e+02  2 69 83 13 66  60 69 99 85 83 11366
SFBcastBegin           1 1.0 1.5159e-03 8.7 0.00e+00 0.0 1.7e+03 1.5e+03 1.0e+00  0  0  0  0  0   0  0  0  2  0     0
SFBcastEnd             1 1.0 4.6587e-0431.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
              Viewer     1              0            0     0.
           Index Set   213            218     22660336     0.
   IS L to G Mapping     3              3     12801292     0.
             Section    70             53        35616     0.
              Vector    15             87     10301560     0.
      Vector Scatter     2             13       496760     0.
              Matrix     0             29      3056328     0.
    Distributed Mesh    14              8        38248     0.
    GraphPartitioner     6              5         3060     0.
Star Forest Bipartite Graph    74             63        53256     0.
     Discrete System    14              8         6912     0.
           Index Set    50             38        55528     0.
              Vector   327            243      3202296     0.
              Matrix    50              8      1858040     0.
Average time to get PetscTime(): 6.19888e-07
Average time for MPI_Barrier(): 9.39369e-06
Average time for zero size MPI_Send(): 1.51566e-06
-log_summary
 ml 40 1
Discretization: RT
MPI processes 64: solving...
((17544, 1161600), (17544, 1161600))
	Solver time: 3.889170e-01
Darcy_FE.py on a arch-linux2-c-opt named wf153.localdomain with 64 processors, by jychang48 Wed Mar  2 17:43:09 2016
Time (sec):           1.513e+01      1.00019   1.513e+01
Objects:              9.060e+02      1.21123   7.647e+02
Flops:                6.855e+07      1.13507   6.507e+07  4.164e+09
Flops/sec:            4.532e+06      1.13513   4.302e+06  2.753e+08
MPI Messages:         1.488e+04      2.83578   9.700e+03  6.208e+05
MPI Message Lengths:  1.790e+08     17.44347   1.649e+03  1.024e+09
 0:      Main Stage: 1.4737e+01  97.4%  0.0000e+00   0.0%  1.007e+05  16.2%  1.395e+03       84.6%  1.250e+02  20.7%
 1:             FEM: 3.8892e-01   2.6%  4.1645e+09 100.0%  5.201e+05  83.8%  2.538e+02       15.4%  4.780e+02  79.1%
Phase summary info:
BuildTwoSided         44 1.0 1.2409e+0012.9 0.00e+00 0.0 2.4e+04 4.0e+00 4.4e+01  8  0  4  0  7   8  0 24  0 35     0
VecScatterBegin        2 1.0 1.8835e-05 1.5 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecScatterEnd          2 1.0 1.0729e-05 5.6 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
Mesh Partition         2 1.0 2.2316e+00 1.1 0.00e+00 0.0 4.4e+04 1.8e+03 2.1e+01 15  0  7  8  3  15  0 44  9 17     0
Mesh Migration         2 1.0 3.9511e-01 1.0 0.00e+00 0.0 4.9e+04 1.4e+04 5.4e+01  3  0  8 67  9   3  0 48 79 43     0
DMPlexInterp           1 1.0 2.1213e+0062219.4 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
DMPlexDistribute       1 1.0 2.5055e+00 1.1 0.00e+00 0.0 3.3e+04 1.0e+04 2.5e+01 17  0  5 32  4  17  0 33 38 20     0
DMPlexDistCones        2 1.0 9.2890e-02 1.2 0.00e+00 0.0 7.2e+03 3.1e+04 4.0e+00  1  0  1 22  1   1  0  7 26  3     0
DMPlexDistLabels       2 1.0 2.5924e-01 1.0 0.00e+00 0.0 2.9e+04 1.3e+04 2.2e+01  2  0  5 38  4   2  0 29 45 18     0
DMPlexDistribOL        1 1.0 1.4374e-01 1.1 0.00e+00 0.0 6.1e+04 8.0e+03 5.0e+01  1  0 10 47  8   1  0 60 56 40     0
DMPlexDistField        3 1.0 3.1577e-02 2.4 0.00e+00 0.0 9.7e+03 3.4e+03 1.2e+01  0  0  2  3  2   0  0 10  4 10     0
DMPlexDistData         2 1.0 1.0807e+0052.5 0.00e+00 0.0 3.5e+04 1.0e+03 6.0e+00  7  0  6  4  1   7  0 35  4  5     0
DMPlexStratify         6 1.5 5.4088e-0157.1 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
SFSetGraph            51 1.0 2.7965e-02 1.6 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
SFBcastBegin          95 1.0 1.2455e+00 4.1 0.00e+00 0.0 9.7e+04 8.7e+03 4.1e+01  8  0 16 82  7   8  0 96 97 33     0
SFBcastEnd            95 1.0 3.0530e-0110.2 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  2  0  0  0  0   2  0  0  0  0     0
SFReduceBegin          4 1.0 9.7501e-0323.5 0.00e+00 0.0 2.9e+03 5.8e+03 3.0e+00  0  0  0  2  0   0  0  3  2  2     0
SFReduceEnd            4 1.0 1.0731e-02 8.4 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
SFFetchOpBegin         1 1.0 3.3140e-0517.4 0.00e+00 0.0 3.2e+02 1.3e+03 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
SFFetchOpEnd           1 1.0 1.0800e-04 2.5 0.00e+00 0.0 3.2e+02 1.3e+03 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
BuildTwoSided          1 1.0 1.4801e-0327.5 0.00e+00 0.0 6.5e+02 4.0e+00 1.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecMDot               18 1.0 5.7650e-03 1.6 6.39e+06 1.1 0.0e+00 0.0e+00 1.8e+01  0 10  0  0  3   1 10  0  0  4 68909
VecNorm               19 1.0 1.2131e-03 1.4 7.10e+05 1.1 0.0e+00 0.0e+00 1.9e+01  0  1  0  0  3   0  1  0  0  4 36388
VecScale             266 1.0 8.2517e-04 1.3 7.55e+05 1.2 0.0e+00 0.0e+00 0.0e+00  0  1  0  0  0   0  1  0  0  0 54483
VecCopy                1 1.0 6.3181e-05 1.5 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecSet               244 1.0 1.0672e-03 1.2 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecAXPY               77 1.0 3.1257e-04 1.5 3.08e+05 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0 62425
VecAYPX               76 1.0 2.6488e-04 1.5 1.35e+05 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0 32446
VecMAXPY              19 1.0 1.6687e-03 1.1 7.06e+06 1.1 0.0e+00 0.0e+00 0.0e+00  0 11  0  0  0   0 11  0  0  0 263131
VecScatterBegin      527 1.0 9.8925e-03 2.1 0.00e+00 0.0 4.9e+05 2.5e+02 0.0e+00  0  0 78 12  0   2  0 93 79  0     0
VecScatterEnd        527 1.0 1.3103e-02 1.8 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   2  0  0  0  0     0
VecNormalize          19 1.0 1.5395e-03 1.3 1.06e+06 1.1 0.0e+00 0.0e+00 1.9e+01  0  2  0  0  3   0  2  0  0  4 43009
MatMult              199 1.0 2.2541e-02 1.1 1.04e+07 1.0 1.2e+05 4.3e+02 1.4e+02  0 16 20  5 24   6 16 23 33 30 28955
MatMultAdd           148 1.0 1.1942e-02 1.2 5.84e+06 1.1 2.2e+04 1.1e+03 0.0e+00  0  9  4  2  0   3  9  4 16  0 30407
MatSolve              38 1.0 4.7653e-03 1.1 3.14e+06 1.1 0.0e+00 0.0e+00 0.0e+00  0  5  0  0  0   1  5  0  0  0 40351
MatSOR               152 1.0 2.8343e-02 1.1 1.65e+07 1.1 2.8e+05 2.3e+02 0.0e+00  0 25 45  6  0   7 25 54 41  0 36104
MatLUFactorSym         1 1.0 1.1396e-04 1.5 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatLUFactorNum         2 1.0 1.2221e-03 1.1 4.69e+05 1.1 0.0e+00 0.0e+00 0.0e+00  0  1  0  0  0   0  1  0  0  0 23627
MatILUFactorSym        1 1.0 5.0211e-04 1.1 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatConvert             2 1.0 4.3702e-04 1.9 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatScale               2 1.0 1.7388e-0318.5 8.46e+04 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0  3066
MatResidual           76 1.0 6.0871e-03 1.2 3.14e+06 1.1 9.4e+04 2.3e+02 0.0e+00  0  5 15  2  0   1  5 18 14  0 31668
MatAssemblyBegin      18 1.0 3.1993e-03 6.1 0.00e+00 0.0 0.0e+00 0.0e+00 1.4e+01  0  0  0  0  2   1  0  0  0  3     0
MatAssemblyEnd        18 1.0 8.8515e-03 1.2 0.00e+00 0.0 2.2e+04 7.4e+01 8.0e+01  0  0  3  0 13   2  0  4  1 17     0
MatGetRow          12000 1.0 4.8211e-02 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0  12  0  0  0  0     0
MatGetRowIJ            2 1.0 5.0211e-0484.2 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatGetSubMatrice       1 1.0 4.3511e-04 1.6 0.00e+00 0.0 0.0e+00 0.0e+00 4.0e+00  0  0  0  0  1   0  0  0  0  1     0
MatGetSubMatrix        4 1.0 7.3576e-04 1.1 0.00e+00 0.0 0.0e+00 0.0e+00 6.0e+00  0  0  0  0  1   0  0  0  0  1     0
MatGetOrdering         2 1.0 5.8365e-04 7.7 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatAXPY                1 1.0 9.8725e-02 1.0 0.00e+00 0.0 1.2e+03 2.2e+02 1.2e+01  1  0  0  0  2  25  0  0  0  3     0
MatMatMult             1 1.0 7.8750e-03 1.0 1.56e+05 1.0 2.4e+03 7.3e+02 1.6e+01  0  0  0  0  3   2  0  0  1  3  1257
MatMatMultSym          1 1.0 7.1521e-03 1.0 0.00e+00 0.0 2.1e+03 5.8e+02 1.4e+01  0  0  0  0  2   2  0  0  1  3     0
MatMatMultNum          1 1.0 7.3504e-04 1.1 1.56e+05 1.0 3.1e+02 1.8e+03 2.0e+00  0  0  0  0  0   0  0  0  0  0 13467
MatRedundantMat        1 1.0 4.6396e-04 1.5 0.00e+00 0.0 0.0e+00 0.0e+00 4.0e+00  0  0  0  0  1   0  0  0  0  1     0
MatGetLocalMat         2 1.0 8.2898e-04 1.5 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatGetBrAoCol          2 1.0 4.4298e-04 2.5 0.00e+00 0.0 1.2e+03 1.2e+03 0.0e+00  0  0  0  0  0   0  0  0  1  0     0
PCSetUp                4 1.0 1.4942e-01 1.0 1.72e+06 1.0 3.6e+04 5.0e+02 2.2e+02  1  3  6  2 36  38  3  7 12 46   726
PCSetUpOnBlocks       19 1.0 1.7056e-03 1.1 2.96e+05 1.1 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0 10448
PCApply               19 1.0 9.6567e-02 1.0 2.55e+07 1.1 4.9e+05 2.0e+02 1.6e+02  1 38 79 10 26  25 38 94 63 33 16484
KSPGMRESOrthog        18 1.0 7.3059e-03 1.5 1.28e+07 1.1 0.0e+00 0.0e+00 1.8e+01  0 19  0  0  3   2 19  0  0  4 108752
KSPSetUp              10 1.0 4.7541e-04 1.7 0.00e+00 0.0 0.0e+00 0.0e+00 8.0e+00  0  0  0  0  1   0  0  0  0  2     0
KSPSolve               1 1.0 2.2602e-01 1.0 4.55e+07 1.0 5.2e+05 2.6e+02 4.0e+02  1 69 83 13 66  58 69 99 86 83 12644
SFBcastBegin           1 1.0 1.5361e-0312.2 0.00e+00 0.0 2.0e+03 1.4e+03 1.0e+00  0  0  0  0  0   0  0  0  2  0     0
SFBcastEnd             1 1.0 8.6808e-0472.8 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
              Viewer     1              0            0     0.
           Index Set   227            232     22507744     0.
   IS L to G Mapping     3              3     12541056     0.
              Vector    15             87      9643080     0.
      Vector Scatter     2             13       435320     0.
              Matrix     0             29      2741220     0.
      Preconditioner     0             11        10960     0.
       Krylov Solver     0             11        30856     0.
           Index Set    50             38        53548     0.
              Vector   327            243      2852408     0.
      Vector Scatter    19              2         2192     0.
              Matrix    50              8      1629940     0.
      Preconditioner    12              1          896     0.
Average time to get PetscTime(): 5.96046e-07
Average time for MPI_Barrier(): 9.20296e-06
-log_summary
