[petsc-users] Optimization methods in PETSc/TAO
Fri Jan 22 16:42:20 CST 2016
On Fri, Jan 22, 2016 at 4:27 PM, Justin Chang <jychang48 at gmail.com> wrote:
> Hi all,
> Consider the following problem:
> minimize  1/2<c,Kc> - <c,f>
> subject to  c >= 0                     (P1)
> To solve (P1) using TAO, I recall that there were two recommended solvers
> to use: TRON and BLMVM
> I recently got reviews for this paper of mine that uses BLMVM and got
> hammered for this, as I quote, "convenient yet inadequate choice" of
> solver.
If they did not back this up with a citation it is just empty snobbery, not
surprising from some quarters.
> It was suggested that I use either semi smooth Newton methods or
> projected Newton methods for the optimization problem. My question is, are
> these methodologies/solvers available currently within PETSc/TAO?
You can Google TRON and BLMVM and they come up on the NEOS pages. BLMVM is
a gradient descent method, but
TRON is a Newton method, so trying it may silence the doubters.
  Matt
> 1) I see that we have SNESVINEWTONSSLS, and I tried this over half a year
> ago but it didn't seem to work. I believe I was told by one of the PETSc
> developers (Matt?) that this was not the one to use?
> 2) Is TRON a type of projected Newton method? I know it's an active-set
> Newton trust region, but is this a well-accepted high performing
> optimization method to use?
> I was also referred to ROL: https://trilinos.org/packages/rol but I am
> guessing this isn't accessible/downloadable from petsc at the moment?
> Thanks,
> Justin
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20160122/c3564678/attachment.html>
