[petsc-users] Optimization methods in PETSc/TAO
Justin Chang jychang48 at gmail.com
Fri Jan 22 16:27:00 CST 2016
Hi all,
Consider the following problem:
minimize  1/2<c,Kc> - <c,f>
subject to  c >= 0                     (P1)
To solve (P1) using TAO, I recall that there were two recommended solvers
to use: TRON and BLMVM
I recently got reviews for this paper of mine that uses BLMVM and got
hammered for this, as I quote, "convenient yet inadequate choice" of
solver.
It was suggested that I use either semi smooth Newton methods or projected
Newton methods for the optimization problem. My question is, are these
methodologies/solvers available currently within PETSc/TAO?
1) I see that we have SNESVINEWTONSSLS, and I tried this over half a year
ago but it didn't seem to work. I believe I was told by one of the PETSc
developers (Matt?) that this was not the one to use?
2) Is TRON a type of projected Newton method? I know it's an active-set
Newton trust region, but is this a well-accepted high performing
optimization method to use?
I was also referred to ROL: https://trilinos.org/packages/rol but I am
guessing this isn't accessible/downloadable from petsc at the moment?
Justin
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20160122/ae1c5f8f/attachment.html>
