[petsc-users] Why use MATMPIBAIJ?
Fri Jan 22 09:32:52 CST 2016
On Fri, Jan 22, 2016 at 9:27 AM, Mark Adams <mfadams at lbl.gov> wrote:
>> I said the Hypre setup cost is not scalable,
> I'd be a little careful here.  Scaling for the matrix triple product is
> hard and hypre does put effort into scaling. I don't have any data
> however.  Do you?
I used it for PyLith and saw this. I did not think any AMG had scalable
setup time.
   Matt
> but it can be amortized over the iterations. You can quantify this
>> just by looking at the PCSetUp time as your increase the number of
>> processes. I don't think they have a good
>> model for the memory usage, and if they do, I do not know what it is.
>> However, generally Hypre takes more
>> memory than the agglomeration MG like ML or GAMG.
> agglomerations methods tend to have lower "grid complexity", that is
> smaller coarse grids, than classic AMG like in hypre. THis is more of a
> constant complexity and not a scaling issue though.  You can address this
> with parameters to some extent. But for elasticity, you want to at least
> try, if not start with, GAMG or ML.
>>   Thanks,
>>     Matt
>>> Giang
>>> On Mon, Jan 18, 2016 at 5:25 PM, Jed Brown <jed at jedbrown.org> wrote:
>>>> Hoang Giang Bui <hgbk2008 at gmail.com> writes:
>>>> > Why P2/P2 is not for co-located discretization?
>>>> Matt typed "P2/P2" when me meant "P2/P1".
>> experiments lead.
>> -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20160122/b3d03570/attachment.html>
