[petsc-users] Why use MATMPIBAIJ?
Mark Adams mfadams at lbl.gov
Fri Jan 22 09:27:53 CST 2016
> I said the Hypre setup cost is not scalable,
I'd be a little careful here.  Scaling for the matrix triple product is
hard and hypre does put effort into scaling. I don't have any data
however.  Do you?
> but it can be amortized over the iterations. You can quantify this
> just by looking at the PCSetUp time as your increase the number of
> processes. I don't think they have a good
> model for the memory usage, and if they do, I do not know what it is.
> However, generally Hypre takes more
> memory than the agglomeration MG like ML or GAMG.
agglomerations methods tend to have lower "grid complexity", that is
smaller coarse grids, than classic AMG like in hypre. THis is more of a
constant complexity and not a scaling issue though.  You can address this
with parameters to some extent. But for elasticity, you want to at least
try, if not start with, GAMG or ML.
>   Thanks,
>     Matt
>> Giang
>> On Mon, Jan 18, 2016 at 5:25 PM, Jed Brown <jed at jedbrown.org> wrote:
>>> Hoang Giang Bui <hgbk2008 at gmail.com> writes:
>>> > Why P2/P2 is not for co-located discretization?
>>> Matt typed "P2/P2" when me meant "P2/P1".
> experiments lead.
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20160122/4db0fbb7/attachment.html>
