[petsc-users] Why use MATMPIBAIJ?
Hoang Giang Bui hgbk2008 at gmail.com
Tue Jan 26 11:41:08 CST 2016
Clear enough. Thank you :-)
Giang
On Tue, Jan 26, 2016 at 3:01 PM, Mark Adams <mfadams at lbl.gov> wrote:
> On Tue, Jan 26, 2016 at 3:58 AM, Hoang Giang Bui <hgbk2008 at gmail.com>
> wrote:
>> Hi
>> I assert this line to the hypre.c to see what block size it set to
>> /* special case for BoomerAMG */
>>   if (jac->setup == HYPRE_BoomerAMGSetup) {
>>     ierr = MatGetBlockSize(pc->pmat,&bs);CHKERRQ(ierr);
>>     // check block size passed to HYPRE
>>     PetscPrintf(PetscObjectComm((PetscObject)pc),"the block size passed
>> to HYPRE is %d\n",bs);
>>     if (bs > 1)
>> PetscStackCallStandard(HYPRE_BoomerAMGSetNumFunctions,(jac->hsolver,bs));
>> It shows that the passing block size is 1. So my hypothesis is correct.
>> In the manual of MatSetBlockSize (
>> http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/Mat/MatSetBlockSize.html),
>> it has to be called before MatSetUp. Hence I guess the matrix passed to
>> HYPRE is created before I set the block size. Given that, I set the block
>> size after the call to PCFieldSplitSetIS
>>         ierr = PCFieldSplitSetIS(pc, "u", IS_u); CHKERRQ(ierr);
>>         ierr = PCFieldSplitSetIS(pc, "p", IS_p); CHKERRQ(ierr);
>>             Set block size for sub-matrix,
>>         ierr = PCFieldSplitGetSubKSP(pc, &nsplits, &sub_ksp);
>> CHKERRQ(ierr);
>>         ksp_U = sub_ksp[0];
>>         ierr = KSPGetOperators(ksp_U, &A_U, &P_U); CHKERRQ(ierr);
>>         ierr = MatSetBlockSize(A_U, 3); CHKERRQ(ierr);
>>         ierr = MatSetBlockSize(P_U, 3); CHKERRQ(ierr);
>> I guess the sub-matrices is created at PCFieldSplitSetIS. If that's
>> correct then it's not possible to set the block size this way.
> You set the block size in the ISs that you give to FieldSplit. FieldSplit
> will give it to the matrices.
>> Giang
>> On Mon, Jan 25, 2016 at 7:43 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>>> > On Jan 25, 2016, at 11:13 AM, Hoang Giang Bui <hgbk2008 at gmail.com>
>>> wrote:
>>> > OK, let's come back to my problem. I got your point about the
>>> interaction between components in one block. In my case, the interaction is
>>> strong.
>>> > As you said, I try this:
>>> >         ierr = KSPSetFromOptions(ksp); CHKERRQ(ierr);
>>> CHKERRQ(ierr);
>>> >         ksp_U = sub_ksp[0];
>>> >         ierr = PetscFree(sub_ksp); CHKERRQ(ierr);
>>> > But it seems doesn't work. The output from -ksp_view shows that matrix
>>> passed to Hypre still has bs=1
>>>    Hmm, this is strange. MatSetBlockSize() should have either set the
>>> block size to 3 or generated an error.  Can you run in the debugger on one
>>> process and put a break point in MatSetBlockSize() and see what it is
>>> setting the block size to. Then in PCSetUp_hypre() you can see what it is
>>> passing to hypre as the block size and maybe figure out how it becomes 1.
>>>   Barry
>>> > KSP Object:    (fieldsplit_u_)     8 MPI processes
>>> >       type: preonly
>>> >       maximum iterations=10000, initial guess is zero
>>> >       tolerances:  relative=1e-05, absolute=1e-50, divergence=10000
>>> >       left preconditioning
>>> >       using NONE norm type for convergence test
>>> >     PC Object:    (fieldsplit_u_)     8 MPI processes
>>> >       type: hypre
>>> >         HYPRE BoomerAMG preconditioning
>>> >         HYPRE BoomerAMG: Cycle type V
>>> >         HYPRE BoomerAMG: Maximum number of levels 25
>>> >         HYPRE BoomerAMG: Maximum number of iterations PER hypre call 1
>>> >         HYPRE BoomerAMG: Convergence tolerance PER hypre call 0
>>> >         HYPRE BoomerAMG: Threshold for strong coupling 0.25
>>> >         HYPRE BoomerAMG: Interpolation truncation factor 0
>>> >         HYPRE BoomerAMG: Interpolation: max elements per row 0
>>> >         HYPRE BoomerAMG: Number of levels of aggressive coarsening 0
>>> >         HYPRE BoomerAMG: Number of paths for aggressive coarsening 1
>>> >         HYPRE BoomerAMG: Maximum row sums 0.9
>>> >         HYPRE BoomerAMG: Sweeps down         1
>>> >         HYPRE BoomerAMG: Sweeps up           1
>>> >         HYPRE BoomerAMG: Sweeps on coarse    1
>>> >         HYPRE BoomerAMG: Relax down          symmetric-SOR/Jacobi
>>> >         HYPRE BoomerAMG: Relax up            symmetric-SOR/Jacobi
>>> >         HYPRE BoomerAMG: Relax on coarse     Gaussian-elimination
>>> >         HYPRE BoomerAMG: Relax weight  (all)      1
>>> >         HYPRE BoomerAMG: Outer relax weight (all) 1
>>> >         HYPRE BoomerAMG: Using CF-relaxation
>>> >         HYPRE BoomerAMG: Measure type        local
>>> >         HYPRE BoomerAMG: Coarsen type        PMIS
>>> >         HYPRE BoomerAMG: Interpolation type  classical
>>> >       linear system matrix = precond matrix:
>>> >       Mat Object:      (fieldsplit_u_)       8 MPI processes
>>> >         type: mpiaij
>>> >         rows=792333, cols=792333
>>> >         total: nonzeros=1.39004e+08, allocated nonzeros=1.39004e+08
>>> >         total number of mallocs used during MatSetValues calls =0
>>> >           using I-node (on process 0) routines: found 30057 nodes,
>>> limit used is 5
>>> > In other test, I can see the block size bs=3 in the section of Mat
>>> Object
>>> > Regardless the setup cost of Hypre AMG, I saw it gives quite a radical
>>> performance, providing that the material parameters does not vary strongly,
>>> and the geometry is regular enough.
>>> > Giang
>>> > On Fri, Jan 22, 2016 at 2:57 PM, Matthew Knepley <knepley at gmail.com>
>>> wrote:
>>> > On Fri, Jan 22, 2016 at 7:27 AM, Hoang Giang Bui <hgbk2008 at gmail.com>
>>> wrote:
>>> > DO you mean the option pc_fieldsplit_block_size? In this thread:
>>> > http://petsc-users.mcs.anl.narkive.com/qSHIOFhh/fieldsplit-error
>>> > No. "Block Size" is confusing on PETSc since it is used to do several
>>> things. Here block size
>>> > is being used to split the matrix. You do not need this since you are
>>> prescribing your splits. The
>>> > matrix block size is used two ways:
>>> >   1) To indicate that matrix values come in logically dense blocks
>>> >   2) To change the storage to match this logical arrangement
>>> > After everything works, we can just indicate to the submatrix which is
>>> extracted that it has a
>>> > certain block size. However, for the Laplacian I expect it not to
>>> matter.
>>> > It assumes you have a constant number of fields at each grid point, am
>>> I right? However, my field split is not constant, like
>>> > [u1_x   u1_y    u1_z    p_1    u2_x    u2_y    u2_z    u3_x    u3_y
>>> u3_z    p_3    u4_x    u4_y    u4_z]
>>> > Subsequently the fieldsplit is
>>> > [u1_x   u1_y    u1_z    u2_x    u2_y    u2_z    u3_x    u3_y    u3_z
>>>  u4_x    u4_y    u4_z]
>>> > [p_1    p_3]
>>> > Then what is the option to set block size 3 for split 0?
>>> > Sorry, I search several forum threads but cannot figure out the
>>> options as you said.
>>> > You can still do that. It can be done with options once the
>>> decomposition is working. Its true that these solvers
>>> > work better with the block size set. However, if its the P2 Laplacian
>>> it does not really matter since its uncoupled.
>>> > Yes, I agree it's uncoupled with the other field, but the crucial
>>> factor defining the quality of the block preconditioner is the approximate
>>> inversion of individual block. I would merely try block Jacobi first,
>>> because it's quite simple. Nevertheless, fieldsplit implements other nice
>>> things, like Schur complement, etc.
>>> > I think concepts are getting confused here. I was talking about the
>>> interaction of components in one block (the P2 block). You
>>> > are talking about interaction between blocks.
>>> >   Thanks,
>>> >      Matt
>>> > Giang
>>> > On Fri, Jan 22, 2016 at 11:15 AM, Matthew Knepley <knepley at gmail.com>
>>> wrote:
>>> > On Fri, Jan 22, 2016 at 3:40 AM, Hoang Giang Bui <hgbk2008 at gmail.com>
>>> wrote:
>>> > Hi Matt
>>> > I would rather like to set the block size for block P2 too. Why?
>>> > Because in one of my test (for problem involves only [u_x u_y u_z]),
>>> the gmres + Hypre AMG converges in 50 steps with block size 3, whereby it
>>> increases to 140 if block size is 1 (see attached files).
>>> > This gives me the impression that AMG will give better inversion for
>>> "P2" block if I can set its block size to 3. Of course it's still an
>>> hypothesis but worth to try.
>>> > Another question: In one of the Petsc presentation, you said the Hypre
>>> AMG does not scale well, because set up cost amortize the iterations. How
>>> is it quantified? and what is the memory overhead?
>>> > I said the Hypre setup cost is not scalable, but it can be amortized
>>> over the iterations. You can quantify this
>>> > just by looking at the PCSetUp time as your increase the number of
>>> processes. I don't think they have a good
>>> > model for the memory usage, and if they do, I do not know what it is.
>>> However, generally Hypre takes more
>>> > memory than the agglomeration MG like ML or GAMG.
>>> >   Thanks,
>>> >     Matt
>>> > Giang
>>> > On Mon, Jan 18, 2016 at 5:25 PM, Jed Brown <jed at jedbrown.org> wrote:
>>> > Hoang Giang Bui <hgbk2008 at gmail.com> writes:
>>> > > Why P2/P2 is not for co-located discretization?
>>> > Matt typed "P2/P2" when me meant "P2/P1".
>>> > What most experimenters take for granted before they begin their
>>> experiments is infinitely more interesting than any results to which their
>>> experiments lead.
>>> > -- Norbert Wiener
>>> experiments lead.
>>> > -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20160126/90fd1d9c/attachment-0001.html>
