[petsc-users] 3.5 -> 3.6 Change in MatOrdering Behavior
Paul T. Bauman ptbauman at gmail.com
Thu Jan 21 11:59:55 CST 2016
On Thu, Jan 21, 2016 at 12:51 PM, Hong <hzhang at mcs.anl.gov> wrote:
> Paul:
> It might be caused by our changes in default shift strategy.
> We previously used '-pc_factor_shift_type NONZERO' for ilu, then changed
> to '-pc_factor_shift_type NONE'.
> For your test, I get
> ./ex10 -f0 test.mat -rhs 0 -pc_type asm -pc_asm_overlap 12 -sub_pc_type
> ilu -sub_pc_factor_mat_ordering_type 1wd -sub_pc_factor_levels 4
> -ksp_converged_reason -sub_pc_factor_shift_type NONZERO
Ah! That was the change. Confirmed, adding -sub_pc_factor_shift_type
nonzero gets our test passing again with those options. Mystery solved.
Thank you very much.
Best,
Paul
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20160121/babef95b/attachment.html>
