[petsc-users] HPCToolKit/HPCViewer on OS X
Bhalla, Amneet Pal S amneetb at live.unc.edu
Thu Jan 14 01:26:57 CST 2016
On Jan 13, 2016, at 9:17 PM, Griffith, Boyce Eugene <boyceg at email.unc.edu<mailto:boyceg at email.unc.edu>> wrote:
I see one hot spot:
Here is with opt build
***             WIDEN YOUR WINDOW TO 120 CHARACTERS.  Use 'enscript -r -fCourier9' to print this document            ***
---------------------------------------------- PETSc Performance Summary: ----------------------------------------------
./main2d on a linux-opt named aorta with 1 processor, by amneetb Thu Jan 14 02:24:43 2016
Using Petsc Development GIT revision: v3.6.3-3098-ga3ecda2  GIT Date: 2016-01-13 21:30:26 -0600
                         Max       Max/Min        Avg      Total
Time (sec):           1.018e+00      1.00000   1.018e+00
Objects:              2.935e+03      1.00000   2.935e+03
Flops:                4.957e+08      1.00000   4.957e+08  4.957e+08
Flops/sec:            4.868e+08      1.00000   4.868e+08  4.868e+08
MPI Messages:         0.000e+00      0.00000   0.000e+00  0.000e+00
MPI Message Lengths:  0.000e+00      0.00000   0.000e+00  0.000e+00
MPI Reductions:       0.000e+00      0.00000
Flop counting convention: 1 flop = 1 real number operation of type (multiply/divide/add/subtract)
                            e.g., VecAXPY() for real vectors of length N --> 2N flops
                            and VecAXPY() for complex vectors of length N --> 8N flops
Summary of Stages:   ----- Time ------  ----- Flops -----  --- Messages ---  -- Message Lengths --  -- Reductions --
                        Avg     %Total     Avg     %Total   counts   %Total     Avg         %Total   counts   %Total
 0:      Main Stage: 1.0183e+00 100.0%  4.9570e+08 100.0%  0.000e+00   0.0%  0.000e+00        0.0%  0.000e+00   0.0%
See the 'Profiling' chapter of the users' manual for details on interpreting output.
Phase summary info:
   Count: number of times phase was executed
   Time and Flops: Max - maximum over all processors
                   Ratio - ratio of maximum to minimum over all processors
   Mess: number of messages sent
   Avg. len: average message length (bytes)
   Reduct: number of global reductions
   Global: entire computation
   Stage: stages of a computation. Set stages with PetscLogStagePush() and PetscLogStagePop().
      %T - percent time in this phase         %F - percent flops in this phase
      %M - percent messages in this phase     %L - percent message lengths in this phase
      %R - percent reductions in this phase
   Total Mflop/s: 10e-6 * (sum of flops over all processors)/(max time over all processors)
Event                Count      Time (sec)     Flops                             --- Global ---  --- Stage ---   Total
                   Max Ratio  Max     Ratio   Max  Ratio  Mess   Avg len Reduct  %T %F %M %L %R  %T %F %M %L %R Mflop/s
--- Event Stage 0: Main Stage
VecDot                 4 1.0 2.9564e-05 1.0 3.31e+04 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0  1120
VecDotNorm2          272 1.0 1.4565e-03 1.0 4.25e+06 1.0 0.0e+00 0.0e+00 0.0e+00  0  1  0  0  0   0  1  0  0  0  2920
VecMDot              624 1.0 8.4300e-03 1.0 5.29e+06 1.0 0.0e+00 0.0e+00 0.0e+00  1  1  0  0  0   1  1  0  0  0   627
VecNorm              565 1.0 3.8033e-03 1.0 4.38e+06 1.0 0.0e+00 0.0e+00 0.0e+00  0  1  0  0  0   0  1  0  0  0  1151
VecScale              86 1.0 5.5480e-04 1.0 1.55e+05 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0   279
VecCopy               28 1.0 5.2261e-04 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecSet             14567 1.0 1.2443e-02 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  1  0  0  0  0   1  0  0  0  0     0
VecAXPY              903 1.0 4.2996e-03 1.0 6.66e+06 1.0 0.0e+00 0.0e+00 0.0e+00  0  1  0  0  0   0  1  0  0  0  1550
VecAYPX              225 1.0 1.2550e-03 1.0 8.55e+05 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0   681
VecAXPBYCZ            42 1.0 1.7118e-04 1.0 3.45e+05 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0  2014
VecWAXPY              70 1.0 1.9503e-04 1.0 2.98e+05 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0  1528
VecMAXPY             641 1.0 1.1136e-02 1.0 5.29e+06 1.0 0.0e+00 0.0e+00 0.0e+00  1  1  0  0  0   1  1  0  0  0   475
VecSwap              135 1.0 4.5896e-04 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecAssemblyBegin     745 1.0 4.9477e-03 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecAssemblyEnd       745 1.0 9.2411e-04 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecScatterBegin    40831 1.0 3.4502e-02 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  3  0  0  0  0   3  0  0  0  0     0
BuildTwoSidedF       738 1.0 2.6712e-03 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatMult              513 1.0 9.1235e-02 1.0 7.75e+07 1.0 0.0e+00 0.0e+00 0.0e+00  9 16  0  0  0   9 16  0  0  0   849
MatSolve           13568 1.0 2.3605e-01 1.0 3.45e+08 1.0 0.0e+00 0.0e+00 0.0e+00 23 70  0  0  0  23 70  0  0  0  1460
MatLUFactorSym        84 1.0 3.7430e-02 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  4  0  0  0  0   4  0  0  0  0     0
MatLUFactorNum        85 1.0 3.9623e-02 1.0 4.19e+07 1.0 0.0e+00 0.0e+00 0.0e+00  4  8  0  0  0   4  8  0  0  0  1058
MatILUFactorSym        1 1.0 3.3617e-05 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatScale               4 1.0 2.5511e-04 1.0 2.51e+05 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0   984
MatAssemblyBegin     108 1.0 6.3658e-05 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatAssemblyEnd       108 1.0 2.9490e-03 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatGetRow          33120 1.0 2.0157e-02 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  2  0  0  0  0   2  0  0  0  0     0
MatGetRowIJ           85 1.0 1.2145e-03 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatGetSubMatrice       4 1.0 8.4379e-03 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  1  0  0  0  0   1  0  0  0  0     0
MatGetOrdering        85 1.0 7.7887e-03 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  1  0  0  0  0   1  0  0  0  0     0
MatAXPY                4 1.0 4.9596e-02 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  5  0  0  0  0   5  0  0  0  0     0
MatPtAP                4 1.0 4.4426e-02 1.0 4.99e+06 1.0 0.0e+00 0.0e+00 0.0e+00  4  1  0  0  0   4  1  0  0  0   112
MatPtAPSymbolic        4 1.0 2.7664e-02 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  3  0  0  0  0   3  0  0  0  0     0
MatPtAPNumeric         4 1.0 1.6732e-02 1.0 4.99e+06 1.0 0.0e+00 0.0e+00 0.0e+00  2  1  0  0  0   2  1  0  0  0   298
MatGetSymTrans         4 1.0 3.6621e-04 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
KSPGMRESOrthog        16 1.0 9.7778e-03 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  1  0  0  0  0   1  0  0  0  0     0
KSPSetUp              90 1.0 5.7650e-04 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
KSPSolve               1 1.0 7.8831e-01 1.0 4.90e+08 1.0 0.0e+00 0.0e+00 0.0e+00 77 99  0  0  0  77 99  0  0  0   622
PCSetUp               90 1.0 9.9725e-02 1.0 4.19e+07 1.0 0.0e+00 0.0e+00 0.0e+00 10  8  0  0  0  10  8  0  0  0   420
PCSetUpOnBlocks      112 1.0 8.7547e-02 1.0 4.19e+07 1.0 0.0e+00 0.0e+00 0.0e+00  9  8  0  0  0   9  8  0  0  0   479
PCApply               16 1.0 7.1952e-01 1.0 4.89e+08 1.0 0.0e+00 0.0e+00 0.0e+00 71 99  0  0  0  71 99  0  0  0   680
SNESSolve              1 1.0 7.9225e-01 1.0 4.90e+08 1.0 0.0e+00 0.0e+00 0.0e+00 78 99  0  0  0  78 99  0  0  0   619
SNESFunctionEval       2 1.0 3.2940e-03 1.0 4.68e+04 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0    14
SNESJacobianEval       1 1.0 4.7255e-04 1.0 4.26e+03 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     9
Memory usage is given in bytes:
Object Type          Creations   Destructions     Memory  Descendants' Mem.
Reports information only for process 0.
              Vector   971            839     15573352     0.
      Vector Scatter   290            289       189584     0.
           Index Set  1171            823       951928     0.
   IS L to G Mapping   110            109      2156656     0.
   Application Order     6              6        99952     0.
             MatMFFD     1              1          776     0.
              Matrix   189            189     24083332     0.
   Matrix Null Space     4              4         2432     0.
       Krylov Solver    90             90       122720     0.
     DMKSP interface     1              1          648     0.
      Preconditioner    90             90        89872     0.
                SNES     1              1         1328     0.
      SNESLineSearch     1              1          984     0.
              DMSNES     1              1          664     0.
    Distributed Mesh     2              2         9168     0.
Star Forest Bipartite Graph     4              4         3168     0.
     Discrete System     2              2         1712     0.
              Viewer     1              0            0     0.
Average time to get PetscTime(): 9.53674e-07
#PETSc Option Table entries:
-ib_ksp_converged_reason
-ib_ksp_monitor_true_residual
-ib_snes_type ksponly
-log_summary
-stokes_ib_pc_level_0_sub_pc_factor_nonzeros_along_diagonal
-stokes_ib_pc_level_0_sub_pc_type ilu
-stokes_ib_pc_level_ksp_richardson_self_scale
-stokes_ib_pc_level_ksp_type richardson
-stokes_ib_pc_level_pc_asm_local_type additive
-stokes_ib_pc_level_sub_pc_factor_nonzeros_along_diagonal
-stokes_ib_pc_level_sub_pc_type lu
#End of PETSc Option Table entries
Compiled without FORTRAN kernels
Compiled with full precision matrices (default)
sizeof(short) 2 sizeof(int) 4 sizeof(long) 8 sizeof(void*) 8 sizeof(PetscScalar) 8 sizeof(PetscInt) 4
Configure options: --CC=mpicc --CXX=mpicxx --FC=mpif90 --with-default-arch=0 --PETSC_ARCH=linux-opt --with-debugging=0 --with-c++-support=1 --with-hypre=1 --download-hypre=1 --with-hdf5=yes --COPTFLAGS=-O3 --CXXOPTFLAGS=-O3 --FOPTFLAGS=-O3
Libraries compiled on Thu Jan 14 01:29:56 2016 on aorta
Machine characteristics: Linux-3.13.0-63-generic-x86_64-with-Ubuntu-14.04-trusty
Using PETSc directory: /not_backed_up/amneetb/softwares/PETSc-BitBucket/PETSc
Using PETSc arch: linux-opt
Using C compiler: mpicc  -fPIC  -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -Qunused-arguments -O3  ${COPTFLAGS} ${CFLAGS}
Using Fortran compiler: mpif90  -fPIC -Wall -Wno-unused-variable -ffree-line-length-0 -Wno-unused-dummy-argument -O3   ${FOPTFLAGS} ${FFLAGS}
Using include paths: -I/not_backed_up/amneetb/softwares/PETSc-BitBucket/PETSc/linux-opt/include -I/not_backed_up/amneetb/softwares/PETSc-BitBucket/PETSc/include -I/not_backed_up/amneetb/softwares/PETSc-BitBucket/PETSc/include -I/not_backed_up/amneetb/softwares/PETSc-BitBucket/PETSc/linux-opt/include -I/not_backed_up/softwares/MPICH/include
Using C linker: mpicc
Using Fortran linker: mpif90
Using libraries: -Wl,-rpath,/not_backed_up/amneetb/softwares/PETSc-BitBucket/PETSc/linux-opt/lib -L/not_backed_up/amneetb/softwares/PETSc-BitBucket/PETSc/linux-opt/lib -lpetsc -Wl,-rpath,/not_backed_up/amneetb/softwares/PETSc-BitBucket/PETSc/linux-opt/lib -L/not_backed_up/amneetb/softwares/PETSc-BitBucket/PETSc/linux-opt/lib -lHYPRE -Wl,-rpath,/not_backed_up/softwares/MPICH/lib -L/not_backed_up/softwares/MPICH/lib -Wl,-rpath,/usr/lib/gcc/x86_64-linux-gnu/4.8 -L/usr/lib/gcc/x86_64-linux-gnu/4.8 -Wl,-rpath,/usr/lib/x86_64-linux-gnu -L/usr/lib/x86_64-linux-gnu -Wl,-rpath,/lib/x86_64-linux-gnu -L/lib/x86_64-linux-gnu -lmpicxx -lstdc++ -llapack -lblas -lpthread -lhdf5hl_fortran -lhdf5_fortran -lhdf5_hl -lhdf5 -lX11 -lm -lmpifort -lgfortran -lm -lgfortran -lm -lquadmath -lm -lmpicxx -lstdc++ -Wl,-rpath,/not_backed_up/softwares/MPICH/lib -L/not_backed_up/softwares/MPICH/lib -Wl,-rpath,/usr/lib/gcc/x86_64-linux-gnu/4.8 -L/usr/lib/gcc/x86_64-linux-gnu/4.8 -Wl,-rpath,/usr/lib/x86_64-linux-gnu -L/usr/lib/x86_64-linux-gnu -Wl,-rpath,/lib/x86_64-linux-gnu -L/lib/x86_64-linux-gnu -Wl,-rpath,/usr/lib/x86_64-linux-gnu -L/usr/lib/x86_64-linux-gnu -ldl -Wl,-rpath,/not_backed_up/softwares/MPICH/lib -lmpi -lgcc_s -ldl
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20160114/fc05cbee/attachment-0001.html>
