[petsc-users] HPCToolKit/HPCViewer on OS X
Bhalla, Amneet Pal S amneetb at live.unc.edu
Thu Jan 14 00:19:42 CST 2016
Thanks! That worked for me.
On Jan 13, 2016, at 10:05 PM, Justin Chang <jychang48 at gmail.com<mailto:jychang48 at gmail.com>> wrote:
HPCToolkit for MacOSX doesn't require any installation.
Just go to:
http://hpctoolkit.org/download/hpcviewer/
and download this file:
hpctraceviewer-5.4.2-r20160111-macosx.cocoa.x86_64.zip
Important note: be sure to unzip the file via the terminal, not with Finder. It may screw up the GUI. On my MacOSX I had to "Download Linked File As..."
Then you can drag the corresponding hpctraceviewer.app into your Applications directory. Now you *should* be good to go.
Justin
On Wed, Jan 13, 2016 at 10:17 PM, Griffith, Boyce Eugene <boyceg at email.unc.edu<mailto:boyceg at email.unc.edu>> wrote:
I see one hot spot:
On Jan 14, 2016, at 12:12 AM, Bhalla, Amneet Pal S <amneetb at live.unc.edu<mailto:amneetb at live.unc.edu>> wrote:
      #                          WARNING!!!                    #
      #   This code was compiled with a debugging option,      #
      #   To get timing results run ./configure                #
      #   using --with-debugging=no, the performance will      #
      #   be generally two or three times faster.              #
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20160114/755df188/attachment.html>
