[petsc-users] HPCToolKit/HPCViewer on OS X
Justin Chang jychang48 at gmail.com
Thu Jan 14 00:05:59 CST 2016
HPCToolkit for MacOSX doesn't require any installation.
Just go to:
http://hpctoolkit.org/download/hpcviewer/
and download this file:
hpctraceviewer-5.4.2-r20160111-macosx.cocoa.x86_64.zip
Important note: be sure to unzip the file via the terminal, not with
Finder. It may screw up the GUI. On my MacOSX I had to "Download Linked
File As..."
Then you can drag the corresponding hpctraceviewer.app into your
Applications directory. Now you *should* be good to go.
Justin
On Wed, Jan 13, 2016 at 10:17 PM, Griffith, Boyce Eugene <
boyceg at email.unc.edu> wrote:
> I see one hot spot:
> On Jan 14, 2016, at 12:12 AM, Bhalla, Amneet Pal S <amneetb at live.unc.edu>
> wrote:
>       #                          WARNING!!!                    #
>       #   This code was compiled with a debugging option,      #
>       #   To get timing results run ./configure                #
>       #   using --with-debugging=no, the performance will      #
>       #   be generally two or three times faster.              #
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20160113/f4a42e41/attachment-0001.html>
