[petsc-users] PETSC_i
Jin, Shuangshuang Shuangshuang.Jin at pnnl.gov
Mon Jan 11 13:26:16 CST 2016
I didn't see anything wrong with my PETSC_DIR and PETSC_ARCH.
Please see my setup below:
setenv PETSC_DIR /pic/projects/software_new/petsc-3.6.0
setenv PETSC_ARCH linux-openmpi-gnu-cxx-complex-opt
Shuangshuang
-----Original Message-----
Sent: Monday, January 11, 2016 11:18 AM
To: Jin, Shuangshuang; petsc-users at mcs.anl.gov
Subject: Re: [petsc-users] PETSC_i
"Jin, Shuangshuang" <Shuangshuang.Jin at pnnl.gov> writes:
> Hi, I have the following codes (The version of Petsc installed on my machine has PetscScalar set to be complex number):
Looks like you're trying to compile with a different PETSc.  Check PETSC_DIR and PETSC_ARCH.
