[petsc-users] PETSC_i
Jed Brown jed at jedbrown.org
Mon Jan 11 13:18:26 CST 2016
"Jin, Shuangshuang" <Shuangshuang.Jin at pnnl.gov> writes:
> Hi, I have the following codes (The version of Petsc installed on my machine has PetscScalar set to be complex number):
Looks like you're trying to compile with a different PETSc.  Check PETSC_DIR and PETSC_ARCH.
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20160111/6de601be/attachment.pgp>
