[petsc-users] PETSC_i
Mon Jan 11 13:48:29 CST 2016
Are you sure its a complex build? Please send us configure.log or
make.log for this build.
Also send us test.log for this build.
Satish
On Mon, 11 Jan 2016, Jin, Shuangshuang wrote:
> I didn't see anything wrong with my PETSC_DIR and PETSC_ARCH.
> Please see my setup below:
> setenv PETSC_DIR /pic/projects/software_new/petsc-3.6.0
> setenv PETSC_ARCH linux-openmpi-gnu-cxx-complex-opt
> Thanks,
> Shuangshuang
> -----Original Message-----
> From: Jed Brown [mailto:jed at jedbrown.org]
> Sent: Monday, January 11, 2016 11:18 AM
> To: Jin, Shuangshuang; petsc-users at mcs.anl.gov
> Subject: Re: [petsc-users] PETSC_i
> "Jin, Shuangshuang" <Shuangshuang.Jin at pnnl.gov> writes:
> > Hi, I have the following codes (The version of Petsc installed on my machine has PetscScalar set to be complex number):
> Looks like you're trying to compile with a different PETSc.  Check PETSC_DIR and PETSC_ARCH.
