[petsc-users] Extracting CSR format from matrices for CUDA
Fri Feb 12 15:01:08 CST 2016
On Fri, Feb 12, 2016 at 12:24 PM, Jed Brown <jed at jedbrown.org> wrote:
> Dave May <dave.mayhem23 at gmail.com> writes:
> >> If so is there an example/source code showing this extraction?
> > Not that I know of.
> > But there isn't much to it, the description on these webpages should be
> > sufficient.
> See also the CUSP and ViennaCL matrix classes, which can run on CUDA.
> But also note that it stands a good chance of not solving your problem
> any faster, unless you have a very special problem.
<yuen>GPU!</yuen>
  Matt
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20160212/541a13de/attachment.html>
