[petsc-users] Extracting CSR format from matrices for CUDA
Boyce Griffith griffith at cims.nyu.edu
Fri Feb 12 15:06:48 CST 2016
> On Feb 12, 2016, at 4:01 PM, Matthew Knepley <knepley at gmail.com> wrote:
> On Fri, Feb 12, 2016 at 12:24 PM, Jed Brown <jed at jedbrown.org <mailto:jed at jedbrown.org>> wrote:
> Dave May <dave.mayhem23 at gmail.com <mailto:dave.mayhem23 at gmail.com>> writes:
> >> If so is there an example/source code showing this extraction?
> > Not that I know of.
> > But there isn't much to it, the description on these webpages should be
> > sufficient.
> See also the CUSP and ViennaCL matrix classes, which can run on CUDA.
> But also note that it stands a good chance of not solving your problem
> any faster, unless you have a very special problem.
> <yuen>GPU!</yuen>
I think I've convinced Amneet to try out some other things before/instead of heading down this route.
-- Boyce
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20160212/a87e5f4b/attachment.html>
