[petsc-users] Extracting CSR format from matrices for CUDA
Jed Brown jed at jedbrown.org
Fri Feb 12 12:24:32 CST 2016
Dave May <dave.mayhem23 at gmail.com> writes:
>> If so is there an example/source code showing this extraction?
> Not that I know of.
> But there isn't much to it, the description on these webpages should be
> sufficient.
See also the CUSP and ViennaCL matrix classes, which can run on CUDA.
But also note that it stands a good chance of not solving your problem
any faster, unless you have a very special problem.
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20160212/f009859f/attachment.pgp>
