[petsc-users] DIVERGED_PCSETUP_FAILED
Thu Feb 11 08:50:10 CST 2016
On Thu, Feb 11, 2016 at 12:30 AM, Dave May <dave.mayhem23 at gmail.com> wrote:
> On 11 February 2016 at 07:05, Michele Rosso <mrosso at uci.edu> wrote:
>> I tried setting -mat_superlu_dist_replacetinypivot true: it does help to
>> advance the run past the previous "critical"  point but eventually it stops
>> later with the same error.
>> I forgot to mention my system is singular: I remove the constant null
>> space but I am not sure if the coarse solver needs to be explicity informed
>> of this.
> Right - are you using pure Newmann boundary conditions?
> To make the solution unique, are you
> (a) imposing a single Dichletet boundary condition on your field
> by explicitly modifying the matrix
> (b) imposing a a condition like
>   \int \phi dV = 0
> via something like -ksp_constant_null_space
> If you removed removed the null space by modifying the matrix explicitly
> (a), the sparse direct solver
> should go through. If you use (b), then this method cannot be used to help
> the direct solver.
> If this is the intended target problem size (16x16), gather the matrix and
> using petsc Cholesky or Umfpack.
> Cholesky is more stable than LU and can usually deal with a single zero
> eigenvaue without resorting to tricks. Umfpack will solve the problem
> easily as it uses clever re-ordering. If you have access to MKL-Pardiso,
> that will also work great.
An easy fix is just to use -pc_type svd on the coarse grid.
  Matt
> Thanks,
>   Dave
>> Michele
>> On Wed, 2016-02-10 at 22:15 -0600, Barry Smith wrote:
>>    You can try the option
>> if you are luck it get you past the zero pivot but still give an adequate preconditioner.
>>   Barry
>> > On Feb 10, 2016, at 9:49 PM, Michele Rosso <mrosso at uci.edu> wrote:> > Hong,> > here if the output of grep -info:> >         using diagonal shift on blocks to prevent zero pivot [INBLOCKS]>                   Replace tiny pivots FALSE>         tolerance for zero pivot 2.22045e-14> > It seems it is not replacing small pivots: could this be the problem?> I will also try Barry's suggestion to diagnose the problem.> > Thanks,> Michele> > > On Wed, 2016-02-10 at 21:22 -0600, Barry Smith wrote:>> > On Feb 10, 2016, at 9:00 PM, Hong <hzhang at mcs.anl.gov> wrote:>> > >> > Michele :>> > Superlu_dist LU is used for coarse grid PC, which likely produces a zero-pivot.>> > Run your code with '-info |grep pivot' to  verify.>> >> >>   Michele>> >>    You can also run with -ksp_error_if_not_converged in or not in the debugger and it will stop immediately when the problem is detected and hopefully provide additional useful  information about what has happened.>> >>   Barry>> >> >> > >> > Hong>> > >> > Hi Matt,>> > >> > the ksp_view output was an attachment to my previous email.>> > Here it is:>> > >> > KSP Object: 1 MPI processes>> >   type: cg>> >   maximum iterations=10000>> >   tolerances:  relative=1e-08, absolute=1e-50, divergence=10000.>> >   left preconditioning>> >   using nonzero initial guess>> >   using UNPRECONDITIONED norm type for convergence test>> > PC Object: 1 MPI processes>> >   type: mg>> >     MG: type is MULTIPLICATIVE, levels=4 cycles=v>> >       Cycles per PCApply=1>> >       Using Galerkin computed coarse grid matrices>> >   Coarse grid solver -- level ------------------------------->> >     KSP Object:    (mg_coarse_)     1 MPI processes>> >       type: preonly>> >       maximum iterations=1, initial guess is zero>> >       tolerances:  relative=1e-05, absolute=1e-50, divergence=10000.>> >       left preconditioning>> >       using NONE norm type for convergence test>> >     PC Object:    (mg_coarse_)     1 MPI processes>> >       type: lu>> >         LU: out-of-place factorization>> >         tolerance for zero pivot 2.22045e-14>> >         using diagonal shift on blocks to prevent zero pivot [INBLOCKS]>> >         matrix ordering: nd>> >         factor fill ratio given 0., needed 0.>> >           Factored matrix follows:>> >             Mat Object:             1 MPI processes>> >               type: seqaij>> >               rows=16, cols=16>> >               package used to perform factorization: superlu_dist>> >               total: nonzeros=0, allocated nonzeros=0>> >               total number of mallocs used during MatSetValues calls =0>> >                 SuperLU_DIST run parameters:>> >                   Process grid nprow 1 x npcol 1 >> >                   Equilibrate matrix TRUE >> >                   Matrix input mode 0 >> >                   Replace tiny pivots FALSE >> >                   Use iterative refinement FALSE >> >                   Processors in row 1 col partition 1 >> >                   Row permutation LargeDiag >> >                   Column permutation METIS_AT_PLUS_A>> >                   Parallel symbolic factorization FALSE >> >                   Repeated factorization SamePattern>> >       linear system matrix = precond matrix:>> >       Mat Object:       1 MPI processes>> >         type: seqaij>> >         rows=16, cols=16>> >         total: nonzeros=72, allocated nonzeros=72>> >         total number of mallocs used during MatSetValues calls =0>> >           not using I-node routines>> >   Down solver (pre-smoother) on level 1 ------------------------------->> >     KSP Object:    (mg_levels_1_)     1 MPI processes>> >       type: richardson>> >         Richardson: damping factor=1.>> >       maximum iterations=2>> >       tolerances:  relative=1e-05, absolute=1e-50, divergence=10000.>> >       left preconditioning>> >       using nonzero initial guess>> >       using NONE norm type for convergence test>> >     PC Object:    (mg_levels_1_)     1 MPI processes>> >       type: sor>> >         SOR: type = local_symmetric, iterations = 1, local iterations = 1, omega = 1.>> >       linear system matrix = precond matrix:>> >       Mat Object:       1 MPI processes>> >         type: seqaij>> >         rows=64, cols=64>> >         total: nonzeros=304, allocated nonzeros=304>> >         total number of mallocs used during MatSetValues calls =0>> >           not using I-node routines>> >   Up solver (post-smoother) same as down solver (pre-smoother)>> >   Down solver (pre-smoother) on level 2 ------------------------------->> >     KSP Object:    (mg_levels_2_)     1 MPI processes>> >       type: richardson>> >         Richardson: damping factor=1.>> >       maximum iterations=2>> >       tolerances:  relative=1e-05, absolute=1e-50, divergence=10000.>> >       left preconditioning>> >       using nonzero initial guess>> >       using NONE norm type for convergence test>> >     PC Object:    (mg_levels_2_)     1 MPI processes>> >       type: sor>> >         SOR: type = local_symmetric, iterations = 1, local iterations = 1, omega = 1.>> >       linear system matrix = precond matrix:>> >       Mat Object:       1 MPI processes>> >         type: seqaij>> >         rows=256, cols=256>> >         total: nonzeros=1248, allocated nonzeros=1248>> >         total number of mallocs used during MatSetValues calls =0>> >           not using I-node routines>> >   Up solver (post-smoother) same as down solver (pre-smoother)>> >   Down solver (pre-smoother) on level 3 ------------------------------->> >     KSP Object:    (mg_levels_3_)     1 MPI processes>> >       type: richardson>> >         Richardson: damping factor=1.>> >       maximum iterations=2>> >       tolerances:  relative=1e-05, absolute=1e-50, divergence=10000.>> >       left preconditioning>> >       using nonzero initial guess>> >       using NONE norm type for convergence test>> >     PC Object:    (mg_levels_3_)     1 MPI processes>> >       type: sor>> >         SOR: type = local_symmetric, iterations = 1, local iterations = 1, omega = 1.>> >       linear system matrix = precond matrix:>> >       Mat Object:       1 MPI processes>> >         type: seqaij>> >         rows=1024, cols=1024>> >         total: nonzeros=5056, allocated nonzeros=5056>> >         total number of mallocs used during MatSetValues calls =0>> >           has attached null space>> >           not using I-node routines>> >   Up solver (post-smoother) same as down solver (pre-smoother)>> >   linear system matrix = precond matrix:>> >   Mat Object:   1 MPI processes>> >     type: seqaij>> >     rows=1024, cols=1024>> >     total: nonzeros=5056, allocated nonzeros=5056>> >     total number of mallocs used during MatSetValues calls =0>> >       has attached null space>> >       not using I-node routines>> > >> > >> > Michele>> > >> > >> > >> > >> > On Wed, 2016-02-10 at 19:37 -0600, Matthew Knepley wrote:>> >> On Wed, Feb 10, 2016 at 7:33 PM, Michele Rosso <mrosso at uci.edu> wrote:>> >> Hi,>> >> >> >> I encountered the following error while solving a symmetric positive defined system:>> >> >> >> Linear solve did not converge due to DIVERGED_PCSETUP_FAILED iterations 0>> >>                PCSETUP_FAILED due to SUBPC_ERROR >> >> >> >> This error appears only if I use the  optimized version of both petsc and my code ( compiler: gfortran, flags: -O3 ).>> >> It is weird since I am solving  a time-dependent problem and everything, i.e. results and convergence rate, are as expected until the above error shows up. If I run both petsc and my code in debug mode, everything goes smooth till the end of the simulation.>> >> However, if I reduce the ksp_rtol, even the debug run fails, after running as expected for a while, because of a KSP_DIVERGED_INDEFINITE_PC . >> >> The options I am using are:>> >> >> >> -ksp_type        cg>> >> -ksp_norm_type   unpreconditioned>> >> -ksp_rtol        1e-8>> >> -ksp_lag_norm>> >> -ksp_initial_guess_nonzero  yes>> >> -pc_type mg>> >> -pc_mg_galerkin>> >> -pc_mg_levels 4>> >> -mg_levels_ksp_type richardson>> >> -mg_coarse_ksp_constant_null_space>> >> -mg_coarse_pc_type lu>> >> -mg_coarse_pc_factor_mat_solver_package superlu_dist>> >> -options_left>> >> >> >> I attached a copy of ksp_view. I am currently using petsc-master (last updated yesterday).>> >> I would appreciate any suggestion on this matter.>> >> >> >> >> >> >> >> I suspect you have a nonlinear PC. Can you send the output of -ksp_view?>> >> >> >> >> >>    Matt>> >>  >> >> Thanks,>> >> Michele>> >> >> >> >> >> >> >> >> >> >> >> >> >> >> >> >> >> >> >> >> >> >> >> >> >> -->> >> What most experimenters take for granted before they begin their experiments is infinitely more interesting than any results to which their experiments lead.>> >> -- Norbert Wiener>> > >> > >> >> >> >
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20160211/056e2cfc/attachment.html>
