[petsc-users] DIVERGED_PCSETUP_FAILED
Michele Rosso mrosso at uci.edu
Thu Feb 11 13:17:50 CST 2016
I am using periodic along x and Neumann along y. I remove the nullspace
via -ksp_constant_null_space.
Matt's suggestion worked; I will also give a try to umfpack and cholesky.
Michele
On 02/11/2016 06:50 AM, Matthew Knepley wrote:
> On Thu, Feb 11, 2016 at 12:30 AM, Dave May <dave.mayhem23 at gmail.com
> <mailto:dave.mayhem23 at gmail.com>> wrote:
>     On 11 February 2016 at 07:05, Michele Rosso <mrosso at uci.edu
>     <mailto:mrosso at uci.edu>> wrote:
>         I tried setting -mat_superlu_dist_replacetinypivot true: it
>         does help to advance the run past the previous "critical"
>         point but eventually it stops later with the same error.
>         I forgot to mention my system is singular: I remove the
>         constant null space but I am not sure if the coarse solver
>         needs to be explicity informed of this.
>     Right - are you using pure Newmann boundary conditions?
>     To make the solution unique, are you
>     (a) imposing a single Dichletet boundary condition on your field
>     by explicitly modifying the matrix
>     (b) imposing a a condition like
>       \int \phi dV = 0
>     via something like -ksp_constant_null_space
>     If you removed removed the null space by modifying the matrix
>     explicitly (a), the sparse direct solver
>     should go through. If you use (b), then this method cannot be used
>     to help the direct solver.
>     If this is the intended target problem size (16x16), gather the
>     matrix and using petsc Cholesky or Umfpack.
>     Cholesky is more stable than LU and can usually deal with a single
>     zero eigenvaue without resorting to tricks. Umfpack will solve the
>     problem easily as it uses clever re-ordering. If you have access
>     to MKL-Pardiso, that will also work great.
> An easy fix is just to use -pc_type svd on the coarse grid.
>   Matt
>     Thanks,
>       Dave
>         Michele
>         On Wed, 2016-02-10 at 22:15 -0600, Barry Smith wrote:
>>             You can try the option
>>         if you are luck it get you past the zero pivot but still give an adequate preconditioner.
>>            Barry
>>         > On Feb 10, 2016, at 9:49 PM, Michele Rosso <mrosso at uci.edu
>>         > Hong,
>>         > here if the output of grep -info:
>>         > using diagonal shift on blocks to prevent zero pivot [INBLOCKS]
>>         > Replace tiny pivots FALSE
>>         > tolerance for zero pivot 2.22045e-14
>>         > It seems it is not replacing small pivots: could this be
>>         the problem?
>>         > I will also try Barry's suggestion to diagnose the problem.
>>         > Thanks,
>>         > Michele
>>         > On Wed, 2016-02-10 at 21:22 -0600, Barry Smith wrote:
>>         >> > On Feb 10, 2016, at 9:00 PM, Hong <hzhang at mcs.anl.gov
>>         <mailto:hzhang at mcs.anl.gov>> wrote:
>>         >> > Michele :
>>         >> > Superlu_dist LU is used for coarse grid PC, which likely
>>         produces a zero-pivot.
>>         >> > Run your code with '-info |grep pivot' to verify.
>>         >> Michele
>>         >> You can also run with -ksp_error_if_not_converged in or
>>         not in the debugger and it will stop immediately when the
>>         problem is detected and hopefully provide additional useful
>>         information about what has happened.
>>         >> Barry
>>         >> > Hong
>>         >> > Hi Matt,
>>         >> > the ksp_view output was an attachment to my previous email.
>>         >> > Here it is:
>>         >> > KSP Object: 1 MPI processes
>>         >> > type: cg
>>         >> > maximum iterations=10000
>>         >> > tolerances: relative=1e-08, absolute=1e-50,
>>         divergence=10000.
>>         >> > left preconditioning
>>         >> > using nonzero initial guess
>>         >> > using UNPRECONDITIONED norm type for convergence test
>>         >> > PC Object: 1 MPI processes
>>         >> > type: mg
>>         >> > MG: type is MULTIPLICATIVE, levels=4 cycles=v
>>         >> > Cycles per PCApply=1
>>         >> > Using Galerkin computed coarse grid matrices
>>         >> > Coarse grid solver -- level -------------------------------
>>         >> > KSP Object: (mg_coarse_) 1 MPI processes
>>         >> > type: preonly
>>         >> > maximum iterations=1, initial guess is zero
>>         >> > tolerances: relative=1e-05, absolute=1e-50,
>>         divergence=10000.
>>         >> > using NONE norm type for convergence test
>>         >> > PC Object: (mg_coarse_) 1 MPI processes
>>         >> > type: lu
>>         >> > LU: out-of-place factorization
>>         [INBLOCKS]
>>         >> > matrix ordering: nd
>>         >> > factor fill ratio given 0., needed 0.
>>         >> > Factored matrix follows:
>>         >> > Mat Object: 1 MPI processes
>>         >> > type: seqaij
>>         >> > rows=16, cols=16
>>         >> > package used to perform factorization: superlu_dist
>>         >> > total: nonzeros=0, allocated nonzeros=0
>>         >> > total number of mallocs used during MatSetValues calls =0
>>         >> > SuperLU_DIST run parameters:
>>         >> > Process grid nprow 1 x npcol 1
>>         >> > Equilibrate matrix TRUE
>>         >> > Matrix input mode 0
>>         >> > Use iterative refinement FALSE
>>         >> > Processors in row 1 col partition 1
>>         >> > Row permutation LargeDiag
>>         >> > Column permutation METIS_AT_PLUS_A
>>         >> > Parallel symbolic factorization FALSE
>>         >> > Repeated factorization SamePattern
>>         >> > linear system matrix = precond matrix:
>>         >> > type: seqaij
>>         >> > rows=16, cols=16
>>         >> > total: nonzeros=72, allocated nonzeros=72
>>         >> > not using I-node routines
>>         >> > Down solver (pre-smoother) on level 1
>>         >> > KSP Object: (mg_levels_1_) 1 MPI processes
>>         >> > type: richardson
>>         >> > Richardson: damping factor=1.
>>         >> > maximum iterations=2
>>         divergence=10000.
>>         >> > PC Object: (mg_levels_1_) 1 MPI processes
>>         >> > type: sor
>>         >> > SOR: type = local_symmetric, iterations = 1, local
>>         iterations = 1, omega = 1.
>>         >> > type: seqaij
>>         >> > rows=64, cols=64
>>         >> > total: nonzeros=304, allocated nonzeros=304
>>         >> > Up solver (post-smoother) same as down solver (pre-smoother)
>>         >> > Down solver (pre-smoother) on level 2
>>         >> > KSP Object: (mg_levels_2_) 1 MPI processes
>>         >> > type: richardson
>>         divergence=10000.
>>         >> > PC Object: (mg_levels_2_) 1 MPI processes
>>         >> > type: sor
>>         >> > type: seqaij
>>         >> > rows=256, cols=256
>>         >> > total: nonzeros=1248, allocated nonzeros=1248
>>         >> > Down solver (pre-smoother) on level 3
>>         >> > KSP Object: (mg_levels_3_) 1 MPI processes
>>         >> > type: richardson
>>         divergence=10000.
>>         >> > PC Object: (mg_levels_3_) 1 MPI processes
>>         >> > type: sor
>>         >> > type: seqaij
>>         >> > rows=1024, cols=1024
>>         >> > total: nonzeros=5056, allocated nonzeros=5056
>>         >> > has attached null space
>>         >> > type: seqaij
>>         >> > Michele
>>         >> > On Wed, 2016-02-10 at 19:37 -0600, Matthew Knepley wrote:
>>         >> >> On Wed, Feb 10, 2016 at 7:33 PM, Michele Rosso
>>         <mrosso at uci.edu <mailto:mrosso at uci.edu>> wrote:
>>         >> >> Hi,
>>         >> >> I encountered the following error while solving a
>>         symmetric positive defined system:
>>         >> >> Linear solve did not converge due to
>>         DIVERGED_PCSETUP_FAILED iterations 0
>>         >> >> PCSETUP_FAILED due to SUBPC_ERROR
>>         >> >> This error appears only if I use the optimized version
>>         of both petsc and my code ( compiler: gfortran, flags: -O3 ).
>>         >> >> It is weird since I am solving a time-dependent problem
>>         and everything, i.e. results and convergence rate, are as
>>         expected until the above error shows up. If I run both petsc
>>         and my code in debug mode, everything goes smooth till the
>>         end of the simulation.
>>         >> >> However, if I reduce the ksp_rtol, even the debug run
>>         fails, after running as expected for a while, because of a
>>         KSP_DIVERGED_INDEFINITE_PC .
>>         >> >> The options I am using are:
>>         >> >> -ksp_type cg
>>         >> >> -ksp_norm_type unpreconditioned
>>         >> >> -ksp_rtol 1e-8
>>         >> >> -ksp_lag_norm
>>         >> >> -ksp_initial_guess_nonzero yes
>>         >> >> -pc_type mg
>>         >> >> -pc_mg_galerkin
>>         >> >> -pc_mg_levels 4
>>         >> >> -mg_levels_ksp_type richardson
>>         >> >> -mg_coarse_ksp_constant_null_space
>>         >> >> -mg_coarse_pc_type lu
>>         >> >> -mg_coarse_pc_factor_mat_solver_package superlu_dist
>>         >> >> -options_left
>>         >> >> I attached a copy of ksp_view. I am currently using
>>         petsc-master (last updated yesterday).
>>         >> >> I would appreciate any suggestion on this matter.
>>         >> >> I suspect you have a nonlinear PC. Can you send the
>>         output of -ksp_view?
>>         >> >> Matt
>>         >> >> Thanks,
>>         >> >> Michele
>>         >> >> What most experimenters take for granted before they
>>         begin their experiments is infinitely more interesting than
>>         any results to which their experiments lead.
>>         >> >> -- Norbert Wiener
> experiments is infinitely more interesting than any results to which
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20160211/dee36778/attachment-0001.html>
