[petsc-users] DIVERGED_PCSETUP_FAILED
Wed Feb 10 21:22:33 CST 2016
> On Feb 10, 2016, at 9:00 PM, Hong <hzhang at mcs.anl.gov> wrote:
> Michele :
> Superlu_dist LU is used for coarse grid PC, which likely produces a zero-pivot.
> Run your code with '-info |grep pivot' to  verify.
  Michele
   You can also run with -ksp_error_if_not_converged in or not in the debugger and it will stop immediately when the problem is detected and hopefully provide additional useful  information about what has happened.
  Barry
> Hong
> Hi Matt,
> the ksp_view output was an attachment to my previous email.
> Here it is:
> KSP Object: 1 MPI processes
>   type: cg
>   maximum iterations=10000
>   tolerances:  relative=1e-08, absolute=1e-50, divergence=10000.
>   left preconditioning
>   using nonzero initial guess
>   using UNPRECONDITIONED norm type for convergence test
> PC Object: 1 MPI processes
>   type: mg
>     MG: type is MULTIPLICATIVE, levels=4 cycles=v
>       Cycles per PCApply=1
>       Using Galerkin computed coarse grid matrices
>   Coarse grid solver -- level -------------------------------
>     KSP Object:    (mg_coarse_)     1 MPI processes
>       type: preonly
>       maximum iterations=1, initial guess is zero
>       tolerances:  relative=1e-05, absolute=1e-50, divergence=10000.
>       using NONE norm type for convergence test
>     PC Object:    (mg_coarse_)     1 MPI processes
>       type: lu
>         LU: out-of-place factorization
>         tolerance for zero pivot 2.22045e-14
>         using diagonal shift on blocks to prevent zero pivot [INBLOCKS]
>         matrix ordering: nd
>         factor fill ratio given 0., needed 0.
>           Factored matrix follows:
>             Mat Object:             1 MPI processes
>               type: seqaij
>               rows=16, cols=16
>               package used to perform factorization: superlu_dist
>               total: nonzeros=0, allocated nonzeros=0
>               total number of mallocs used during MatSetValues calls =0
>                 SuperLU_DIST run parameters:
>                   Process grid nprow 1 x npcol 1
>                   Equilibrate matrix TRUE
>                   Matrix input mode 0
>                   Replace tiny pivots FALSE
>                   Use iterative refinement FALSE
>                   Processors in row 1 col partition 1
>                   Row permutation LargeDiag
>                   Column permutation METIS_AT_PLUS_A
>                   Parallel symbolic factorization FALSE
>                   Repeated factorization SamePattern
>       linear system matrix = precond matrix:
>         type: seqaij
>         rows=16, cols=16
>         total: nonzeros=72, allocated nonzeros=72
>           not using I-node routines
>   Down solver (pre-smoother) on level 1 -------------------------------
>     KSP Object:    (mg_levels_1_)     1 MPI processes
>       type: richardson
>         Richardson: damping factor=1.
>       maximum iterations=2
>     PC Object:    (mg_levels_1_)     1 MPI processes
>       type: sor
>         SOR: type = local_symmetric, iterations = 1, local iterations = 1, omega = 1.
>         type: seqaij
>         rows=64, cols=64
>         total: nonzeros=304, allocated nonzeros=304
>   Up solver (post-smoother) same as down solver (pre-smoother)
>   Down solver (pre-smoother) on level 2 -------------------------------
>     KSP Object:    (mg_levels_2_)     1 MPI processes
>       type: richardson
>     PC Object:    (mg_levels_2_)     1 MPI processes
>       type: sor
>         type: seqaij
>         rows=256, cols=256
>         total: nonzeros=1248, allocated nonzeros=1248
>   Down solver (pre-smoother) on level 3 -------------------------------
>     KSP Object:    (mg_levels_3_)     1 MPI processes
>       type: richardson
>     PC Object:    (mg_levels_3_)     1 MPI processes
>       type: sor
>         type: seqaij
>         rows=1024, cols=1024
>         total: nonzeros=5056, allocated nonzeros=5056
>           has attached null space
>     type: seqaij
> Michele
> On Wed, 2016-02-10 at 19:37 -0600, Matthew Knepley wrote:
>> On Wed, Feb 10, 2016 at 7:33 PM, Michele Rosso <mrosso at uci.edu> wrote:
>> Hi,
>> I encountered the following error while solving a symmetric positive defined system:
>> Linear solve did not converge due to DIVERGED_PCSETUP_FAILED iterations 0
>>                PCSETUP_FAILED due to SUBPC_ERROR
>> This error appears only if I use the  optimized version of both petsc and my code ( compiler: gfortran, flags: -O3 ).
>> It is weird since I am solving  a time-dependent problem and everything, i.e. results and convergence rate, are as expected until the above error shows up. If I run both petsc and my code in debug mode, everything goes smooth till the end of the simulation.
>> However, if I reduce the ksp_rtol, even the debug run fails, after running as expected for a while, because of a KSP_DIVERGED_INDEFINITE_PC .
>> The options I am using are:
>> -ksp_type        cg
>> -ksp_norm_type   unpreconditioned
>> -ksp_rtol        1e-8
>> -ksp_lag_norm
>> -ksp_initial_guess_nonzero  yes
>> -pc_type mg
>> -pc_mg_galerkin
>> -pc_mg_levels 4
>> -mg_levels_ksp_type richardson
>> -mg_coarse_ksp_constant_null_space
>> -mg_coarse_pc_type lu
>> -mg_coarse_pc_factor_mat_solver_package superlu_dist
>> -options_left
>> I attached a copy of ksp_view. I am currently using petsc-master (last updated yesterday).
>> I would appreciate any suggestion on this matter.
>> I suspect you have a nonlinear PC. Can you send the output of -ksp_view?
>>    Matt
>> Thanks,
>> Michele
>> What most experimenters take for granted before they begin their experiments is infinitely more interesting than any results to which their experiments lead.
>> -- Norbert Wiener
