[petsc-users] DIVERGED_PCSETUP_FAILED
Hong hzhang at mcs.anl.gov
Wed Feb 10 21:00:20 CST 2016
Michele :
Superlu_dist LU is used for coarse grid PC, which likely produces a
zero-pivot.
Run your code with '-info |grep pivot' to  verify.
Hong
Hi Matt,
> the ksp_view output was an attachment to my previous email.
> Here it is:
> KSP Object: 1 MPI processes
>   type: cg
>   maximum iterations=10000
>   tolerances:  relative=1e-08, absolute=1e-50, divergence=10000.
>   left preconditioning
>   using nonzero initial guess
>   using UNPRECONDITIONED norm type for convergence test
> PC Object: 1 MPI processes
>   type: mg
>     MG: type is MULTIPLICATIVE, levels=4 cycles=v
>       Cycles per PCApply=1
>       Using Galerkin computed coarse grid matrices
>   Coarse grid solver -- level -------------------------------
>     KSP Object:    (mg_coarse_)     1 MPI processes
>       type: preonly
>       maximum iterations=1, initial guess is zero
>       tolerances:  relative=1e-05, absolute=1e-50, divergence=10000.
>       using NONE norm type for convergence test
>     PC Object:    (mg_coarse_)     1 MPI processes
>       type: lu
>         LU: out-of-place factorization
>         tolerance for zero pivot 2.22045e-14
>         using diagonal shift on blocks to prevent zero pivot [INBLOCKS]
>         matrix ordering: nd
>         factor fill ratio given 0., needed 0.
>           Factored matrix follows:
>             Mat Object:             1 MPI processes
>               type: seqaij
>               rows=16, cols=16
>               package used to perform factorization: superlu_dist
>               total: nonzeros=0, allocated nonzeros=0
>               total number of mallocs used during MatSetValues calls =0
>                 SuperLU_DIST run parameters:
>                   Process grid nprow 1 x npcol 1
>                   Equilibrate matrix TRUE
>                   Matrix input mode 0
>                   Replace tiny pivots FALSE
>                   Use iterative refinement FALSE
>                   Processors in row 1 col partition 1
>                   Row permutation LargeDiag
>                   Column permutation METIS_AT_PLUS_A
>                   Parallel symbolic factorization FALSE
>                   Repeated factorization SamePattern
>       linear system matrix = precond matrix:
>         type: seqaij
>         rows=16, cols=16
>         total: nonzeros=72, allocated nonzeros=72
>           not using I-node routines
>   Down solver (pre-smoother) on level 1 -------------------------------
>     KSP Object:    (mg_levels_1_)     1 MPI processes
>       type: richardson
>         Richardson: damping factor=1.
>       maximum iterations=2
>     PC Object:    (mg_levels_1_)     1 MPI processes
>       type: sor
>         SOR: type = local_symmetric, iterations = 1, local iterations = 1,
> omega = 1.
>         type: seqaij
>         rows=64, cols=64
>         total: nonzeros=304, allocated nonzeros=304
>   Up solver (post-smoother) same as down solver (pre-smoother)
>   Down solver (pre-smoother) on level 2 -------------------------------
>     KSP Object:    (mg_levels_2_)     1 MPI processes
>       type: richardson
>     PC Object:    (mg_levels_2_)     1 MPI processes
>       type: sor
> omega = 1.
>         type: seqaij
>         rows=256, cols=256
>         total: nonzeros=1248, allocated nonzeros=1248
>   Down solver (pre-smoother) on level 3 -------------------------------
>     KSP Object:    (mg_levels_3_)     1 MPI processes
>       type: richardson
>     PC Object:    (mg_levels_3_)     1 MPI processes
>       type: sor
> omega = 1.
>         type: seqaij
>         rows=1024, cols=1024
>         total: nonzeros=5056, allocated nonzeros=5056
>           has attached null space
>     type: seqaij
> Michele
> On Wed, 2016-02-10 at 19:37 -0600, Matthew Knepley wrote:
> On Wed, Feb 10, 2016 at 7:33 PM, Michele Rosso <mrosso at uci.edu> wrote:
> Hi,
> I encountered the following error while solving a symmetric positive
> defined system:
> Linear solve did not converge due to DIVERGED_PCSETUP_FAILED iterations 0
>                PCSETUP_FAILED due to SUBPC_ERROR
> This error appears only if I use the  optimized version of both petsc and
> my code ( compiler: gfortran, flags: -O3 ).
> It is weird since I am solving  a time-dependent problem and everything,
> i.e. results and convergence rate, are as expected until the above error
> shows up. If I run both petsc and my code in debug mode, everything goes
> smooth till the end of the simulation.
> However, if I reduce the ksp_rtol, even the debug run fails, after running
> as expected for a while, because of a KSP_DIVERGED_INDEFINITE_PC .
> The options I am using are:
> -ksp_type        cg
> -ksp_norm_type   unpreconditioned
> -ksp_rtol        1e-8
> -ksp_lag_norm
> -ksp_initial_guess_nonzero  yes
> -pc_type mg
> -pc_mg_galerkin
> -pc_mg_levels 4
> -mg_levels_ksp_type richardson
> -mg_coarse_ksp_constant_null_space
> -mg_coarse_pc_type lu
> -mg_coarse_pc_factor_mat_solver_package superlu_dist
> -options_left
> I attached a copy of ksp_view. I am currently using petsc-master (last
> updated yesterday).
> I would appreciate any suggestion on this matter.
> I suspect you have a nonlinear PC. Can you send the output of -ksp_view?
>    Matt
> Thanks,
> Michele
> experiments lead.
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20160210/87d99f4d/attachment-0001.html>
