[petsc-users] DIVERGED_PCSETUP_FAILED
Michele Rosso mrosso at uci.edu
Wed Feb 10 21:49:00 CST 2016
Hong,
here if the output of grep -info:
        using diagonal shift on blocks to prevent zero pivot [INBLOCKS]
                  Replace tiny pivots FALSE
        tolerance for zero pivot 2.22045e-14
It seems it is not replacing small pivots: could this be the problem?
I will also try Barry's suggestion to diagnose the problem.
Michele
On Wed, 2016-02-10 at 21:22 -0600, Barry Smith wrote:
> > On Feb 10, 2016, at 9:00 PM, Hong <hzhang at mcs.anl.gov> wrote:
> > Michele :
> > Superlu_dist LU is used for coarse grid PC, which likely produces a zero-pivot.
> > Run your code with '-info |grep pivot' to  verify.
>   Michele
>    You can also run with -ksp_error_if_not_converged in or not in the debugger and it will stop immediately when the problem is detected and hopefully provide additional useful  information about what has happened.
>   Barry
> > Hong
> > Hi Matt,
> > the ksp_view output was an attachment to my previous email.
> > Here it is:
> > KSP Object: 1 MPI processes
> >   type: cg
> >   maximum iterations=10000
> >   tolerances:  relative=1e-08, absolute=1e-50, divergence=10000.
> >   left preconditioning
> >   using nonzero initial guess
> >   using UNPRECONDITIONED norm type for convergence test
> > PC Object: 1 MPI processes
> >   type: mg
> >     MG: type is MULTIPLICATIVE, levels=4 cycles=v
> >       Cycles per PCApply=1
> >       Using Galerkin computed coarse grid matrices
> >   Coarse grid solver -- level -------------------------------
> >     KSP Object:    (mg_coarse_)     1 MPI processes
> >       type: preonly
> >       maximum iterations=1, initial guess is zero
> >       tolerances:  relative=1e-05, absolute=1e-50, divergence=10000.
> >       using NONE norm type for convergence test
> >     PC Object:    (mg_coarse_)     1 MPI processes
> >       type: lu
> >         LU: out-of-place factorization
> >         matrix ordering: nd
> >         factor fill ratio given 0., needed 0.
> >           Factored matrix follows:
> >             Mat Object:             1 MPI processes
> >               type: seqaij
> >               rows=16, cols=16
> >               package used to perform factorization: superlu_dist
> >               total: nonzeros=0, allocated nonzeros=0
> >               total number of mallocs used during MatSetValues calls =0
> >                 SuperLU_DIST run parameters:
> >                   Process grid nprow 1 x npcol 1
> >                   Equilibrate matrix TRUE
> >                   Matrix input mode 0
> >                   Use iterative refinement FALSE
> >                   Processors in row 1 col partition 1
> >                   Row permutation LargeDiag
> >                   Column permutation METIS_AT_PLUS_A
> >                   Parallel symbolic factorization FALSE
> >                   Repeated factorization SamePattern
> >       linear system matrix = precond matrix:
> >         type: seqaij
> >         rows=16, cols=16
> >         total: nonzeros=72, allocated nonzeros=72
> >           not using I-node routines
> >   Down solver (pre-smoother) on level 1 -------------------------------
> >     KSP Object:    (mg_levels_1_)     1 MPI processes
> >       type: richardson
> >         Richardson: damping factor=1.
> >       maximum iterations=2
> >     PC Object:    (mg_levels_1_)     1 MPI processes
> >       type: sor
> >         SOR: type = local_symmetric, iterations = 1, local iterations = 1, omega = 1.
> >         type: seqaij
> >         rows=64, cols=64
> >         total: nonzeros=304, allocated nonzeros=304
> >   Up solver (post-smoother) same as down solver (pre-smoother)
> >   Down solver (pre-smoother) on level 2 -------------------------------
> >     KSP Object:    (mg_levels_2_)     1 MPI processes
> >       type: richardson
> >     PC Object:    (mg_levels_2_)     1 MPI processes
> >       type: sor
> >         type: seqaij
> >         rows=256, cols=256
> >         total: nonzeros=1248, allocated nonzeros=1248
> >   Down solver (pre-smoother) on level 3 -------------------------------
> >     KSP Object:    (mg_levels_3_)     1 MPI processes
> >       type: richardson
> >     PC Object:    (mg_levels_3_)     1 MPI processes
> >       type: sor
> >         type: seqaij
> >         rows=1024, cols=1024
> >         total: nonzeros=5056, allocated nonzeros=5056
> >           has attached null space
> >     type: seqaij
> > Michele
> > On Wed, 2016-02-10 at 19:37 -0600, Matthew Knepley wrote:
> >> On Wed, Feb 10, 2016 at 7:33 PM, Michele Rosso <mrosso at uci.edu> wrote:
> >> Hi,
> >> I encountered the following error while solving a symmetric positive defined system:
> >> Linear solve did not converge due to DIVERGED_PCSETUP_FAILED iterations 0
> >>                PCSETUP_FAILED due to SUBPC_ERROR
> >> This error appears only if I use the  optimized version of both petsc and my code ( compiler: gfortran, flags: -O3 ).
> >> It is weird since I am solving  a time-dependent problem and everything, i.e. results and convergence rate, are as expected until the above error shows up. If I run both petsc and my code in debug mode, everything goes smooth till the end of the simulation.
> >> However, if I reduce the ksp_rtol, even the debug run fails, after running as expected for a while, because of a KSP_DIVERGED_INDEFINITE_PC .
> >> The options I am using are:
> >> -ksp_type        cg
> >> -ksp_norm_type   unpreconditioned
> >> -ksp_rtol        1e-8
> >> -ksp_lag_norm
> >> -ksp_initial_guess_nonzero  yes
> >> -pc_type mg
> >> -pc_mg_galerkin
> >> -pc_mg_levels 4
> >> -mg_levels_ksp_type richardson
> >> -mg_coarse_ksp_constant_null_space
> >> -mg_coarse_pc_type lu
> >> -mg_coarse_pc_factor_mat_solver_package superlu_dist
> >> -options_left
> >> I attached a copy of ksp_view. I am currently using petsc-master (last updated yesterday).
> >> I would appreciate any suggestion on this matter.
> >> I suspect you have a nonlinear PC. Can you send the output of -ksp_view?
> >>    Matt
> >> Thanks,
> >> Michele
> >> What most experimenters take for granted before they begin their experiments is infinitely more interesting than any results to which their experiments lead.
> >> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20160210/c8b5ad9e/attachment-0001.html>
