[petsc-users] DIVERGED_PCSETUP_FAILED
Michele Rosso mrosso at uci.edu
Wed Feb 10 20:21:31 CST 2016
Hi Matt,
the ksp_view output was an attachment to my previous email.
Here it is:
KSP Object: 1 MPI processes
  type: cg
  maximum iterations=10000
  tolerances:  relative=1e-08, absolute=1e-50, divergence=10000.
  left preconditioning
  using nonzero initial guess
  using UNPRECONDITIONED norm type for convergence test
PC Object: 1 MPI processes
  type: mg
    MG: type is MULTIPLICATIVE, levels=4 cycles=v
      Cycles per PCApply=1
      Using Galerkin computed coarse grid matrices
  Coarse grid solver -- level -------------------------------
    KSP Object:    (mg_coarse_)     1 MPI processes
      type: preonly
      maximum iterations=1, initial guess is zero
      tolerances:  relative=1e-05, absolute=1e-50, divergence=10000.
      using NONE norm type for convergence test
    PC Object:    (mg_coarse_)     1 MPI processes
      type: lu
        LU: out-of-place factorization
        tolerance for zero pivot 2.22045e-14
        using diagonal shift on blocks to prevent zero pivot [INBLOCKS]
        matrix ordering: nd
        factor fill ratio given 0., needed 0.
          Factored matrix follows:
            Mat Object:             1 MPI processes
              type: seqaij
              rows=16, cols=16
              package used to perform factorization: superlu_dist
              total: nonzeros=0, allocated nonzeros=0
              total number of mallocs used during MatSetValues calls =0
                SuperLU_DIST run parameters:
                  Process grid nprow 1 x npcol 1
                  Equilibrate matrix TRUE
                  Matrix input mode 0
                  Replace tiny pivots FALSE
                  Use iterative refinement FALSE
                  Processors in row 1 col partition 1
                  Row permutation LargeDiag
                  Column permutation METIS_AT_PLUS_A
                  Parallel symbolic factorization FALSE
                  Repeated factorization SamePattern
      linear system matrix = precond matrix:
        type: seqaij
        rows=16, cols=16
        total: nonzeros=72, allocated nonzeros=72
          not using I-node routines
  Down solver (pre-smoother) on level 1 -------------------------------
    KSP Object:    (mg_levels_1_)     1 MPI processes
      type: richardson
        Richardson: damping factor=1.
      maximum iterations=2
    PC Object:    (mg_levels_1_)     1 MPI processes
      type: sor
        SOR: type = local_symmetric, iterations = 1, local iterations =
1, omega = 1.
        type: seqaij
        rows=64, cols=64
        total: nonzeros=304, allocated nonzeros=304
  Up solver (post-smoother) same as down solver (pre-smoother)
  Down solver (pre-smoother) on level 2 -------------------------------
    KSP Object:    (mg_levels_2_)     1 MPI processes
      type: richardson
    PC Object:    (mg_levels_2_)     1 MPI processes
      type: sor
1, omega = 1.
        type: seqaij
        rows=256, cols=256
        total: nonzeros=1248, allocated nonzeros=1248
  Down solver (pre-smoother) on level 3 -------------------------------
    KSP Object:    (mg_levels_3_)     1 MPI processes
      type: richardson
    PC Object:    (mg_levels_3_)     1 MPI processes
      type: sor
1, omega = 1.
        type: seqaij
        rows=1024, cols=1024
        total: nonzeros=5056, allocated nonzeros=5056
          has attached null space
    type: seqaij
Michele
On Wed, 2016-02-10 at 19:37 -0600, Matthew Knepley wrote:
> On Wed, Feb 10, 2016 at 7:33 PM, Michele Rosso <mrosso at uci.edu> wrote:
>         Hi,
>         I encountered the following error while solving a symmetric
>         positive defined system:
>         Linear solve did not converge due to DIVERGED_PCSETUP_FAILED
>         iterations 0
>                        PCSETUP_FAILED due to SUBPC_ERROR
>         This error appears only if I use the  optimized version of
>         both petsc and my code ( compiler: gfortran, flags: -O3 ).
>         It is weird since I am solving  a time-dependent problem and
>         everything, i.e. results and convergence rate, are as expected
>         until the above error shows up. If I run both petsc and my
>         code in debug mode, everything goes smooth till the end of the
>         simulation.
>         However, if I reduce the ksp_rtol, even the debug run fails,
>         after running as expected for a while, because of a
>         KSP_DIVERGED_INDEFINITE_PC .
>         The options I am using are:
>         -ksp_type        cg
>         -ksp_norm_type   unpreconditioned
>         -ksp_rtol        1e-8
>         -ksp_lag_norm
>         -ksp_initial_guess_nonzero  yes
>         -pc_type mg
>         -pc_mg_galerkin
>         -pc_mg_levels 4
>         -mg_levels_ksp_type richardson
>         -mg_coarse_ksp_constant_null_space
>         -mg_coarse_pc_type lu
>         -mg_coarse_pc_factor_mat_solver_package superlu_dist
>         -options_left
>         I attached a copy of ksp_view. I am currently using
>         petsc-master (last updated yesterday).
>         I would appreciate any suggestion on this matter.
> I suspect you have a nonlinear PC. Can you send the output of
> -ksp_view?
>    Matt
>         Thanks,
>         Michele
> experiments is infinitely more interesting than any results to which
> their experiments lead.
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20160210/9e973151/attachment-0001.html>
