[petsc-users] Diagnosing Poisson Solver Behavior
K. N. Ramachandran knram06 at gmail.com
Thu Oct 15 12:10:01 CDT 2015
Hello Matt,
On Thu, Oct 15, 2015 at 12:18 PM, Matthew Knepley <knepley at gmail.com> wrote:
> The bad design decision is using a storage format designed for high speed
> MatMult() to use for data interchange. You should be
> using the API for value insertion rather than some storage format.
Ok, noted. Instead of using CreateMatSeqAIJWithArrays, I have also tried
setting up the Mat passed into the ComputeMatrix function, using
MatSetValue where the cols and values are referred to values in the CSR
format, but I still get the same error. It looks like the Mat is not
preallocated properly in the DM, even when I use DMDACreate3d.
Could you suggest what I can do to resolve this?
K.N.Ramachandran
Ph: 814-441-4279
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20151015/f7312e00/attachment.html>
