[petsc-users] Diagnosing Poisson Solver Behavior
Thu Oct 15 12:12:45 CDT 2015
On Thu, Oct 15, 2015 at 12:10 PM, K. N. Ramachandran <knram06 at gmail.com>
wrote:
> Hello Matt,
> On Thu, Oct 15, 2015 at 12:18 PM, Matthew Knepley <knepley at gmail.com>
> wrote:
>> The bad design decision is using a storage format designed for high speed
>> MatMult() to use for data interchange. You should be
>> using the API for value insertion rather than some storage format.
> Ok, noted. Instead of using CreateMatSeqAIJWithArrays, I have also tried
> setting up the Mat passed into the ComputeMatrix function, using
> MatSetValue where the cols and values are referred to values in the CSR
> format, but I still get the same error. It looks like the Mat is not
> preallocated properly in the DM, even when I use DMDACreate3d.
Another explanation is that the matrix is preallocated correctly, but you
are mapping the row and columns indices differently than the
DM. This what I was refering to when I said that getting the parallel
partition correct would be challenging.
  Matt
> Could you suggest what I can do to resolve this?
> Thanks,
> K.N.Ramachandran
> Ph: 814-441-4279
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20151015/6ce30452/attachment.html>
