[petsc-users] Diagnosing Poisson Solver Behavior
Thu Oct 15 11:18:44 CDT 2015
On Thu, Oct 15, 2015 at 11:15 AM, K. N. Ramachandran <knram06 at gmail.com>
wrote:
> Hello Matt,
> On Thu, Oct 15, 2015 at 11:46 AM, Matthew Knepley <knepley at gmail.com>
> wrote:
>> This seems like the hardest way to do this. We have running examples,
>> that scale well, and produce exactly the matrix
>> you are using. In addition, they create the matrix in parallel, so the
>> whole thing is scalable.
>> In order to do it the way you want, you would need to match the
>> partitioning, which is hard.
> Yes, I understand. I am trying to keep the solver module separate from the
> problem physics (like boundary conditions), i.e. my code has knowledge of
> the physics and I generate the matrix in sparse format. I then hand it over
> to some Solver module (say, PETSc) which can efficiently solve this.
> Examples like snes/ex5.c, ksp/ex45.c, etc. use knowledge of the boundary
> conditions to fill up the matrix and the RHS and this makes sense, if the
> entire code is written using PETSc's native data structures. But from a
> modularity point of view, if my problem needs a different partitioning
> based on the physics, I feel like my code should generate the relevant
> matrices on each rank and send it to PETSc.
> I am trying to simulate the movement of charged particles in a domain, and
> these particles become collimated along a particular direction. So one way
> to partition might be 1D slabs perpendicular to the collimated direction,
> so each rank can calculate the field and move the particles on each
> timestep. Of course communication across the slabs would be inevitable. But
> this way, the partitioning is based on the physics of the problem and the
> solver module just efficiently solves the system without having to know the
> boundary conditions, which makes sense to me overall.
> Hope this description helps.
The bad design decision is using a storage format designed for high speed
MatMult() to use for data interchange. You should be
using the API for value insertion rather than some storage format.
  Matt
> Thanking You,
> K.N.Ramachandran
> Ph: 814-441-4279
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20151015/74b19894/attachment.html>
