[petsc-users] Moving from KSPSetNullSpace to MatSetNullSpace
Gil Forsyth gforsyth at gwu.edu
Thu Oct 1 15:21:24 CDT 2015
I ran for one timestep against 3.5.4 with
#+BEGIN_SRC
petibm-3.5.4/bin/petibm2d -directory examples/2d/lidDrivenCavity/Re100
-poisson_pc_type gamg -poisson_pc_gamg_type agg
-poisson_pc_gamg_agg_nsmooths 1 -poisson_ksp_view
-poisson_ksp_monitor_true_residual -poisson_ksp_converged_reason -info >
kspview_3.5.4.log
#+END_SRC
and then against 25a145a with the same inputs.  I notice that the poisson
multigrid solve in 25a145a is using GMRES again while 3.5.4 is using
preonly.
Logs from both runs are attached.
On Thu, Oct 1, 2015 at 3:52 PM, Mark Adams <mfadams at lbl.gov> wrote:
> Can you please send a good log also, with the ksp_view.
> Mark
> On Wed, Sep 30, 2015 at 3:11 PM, Gil Forsyth <gforsyth at gwu.edu> wrote:
>> Using PETSc master branch solved the problem in serial, but I'm still
>> seeing the same KSP_DIVERGED_INDEFINITE_PC error when I run with MPI.  This
>> runs to completion when I don't use GAMG.  Log is attached for the
>> following run.
>> $PETSC_DIR/$PETSC_ARCH/bin/mpirun -n 2
>> $PETIBM_DIR/petibm-git/bin/petibm2d -directory . -poisson_pc_type gamg
>> -poisson_pc_gamg_type agg -poisson_pc_gamg_agg_nsmooths 1 -poisson_ksp_view
>> Thanks again,
>> Gil Forsyth
>> On Tue, Sep 29, 2015 at 1:12 PM, Gil Forsyth <gforsyth at gwu.edu> wrote:
>>> Ah, got it.  I'll checkout the master branch and see if the behavior
>>> persists.
>>> Many thanks,
>>> Gil
>>> On Tue, Sep 29, 2015 at 1:10 PM, Matthew Knepley <knepley at gmail.com>
>>> wrote:
>>>> On Tue, Sep 29, 2015 at 12:08 PM, Gil Forsyth <gforsyth at gwu.edu> wrote:
>>>>> PETSc is version 3.6.1 -- I just included a log from 3.5.4 to show
>>>>> that the behavior seems to have changed between versions.  The only
>>>>> difference in our code between 3.5.4 and 3.6.1 is the change from
>>>>> KSPSetNullSpace to MatSetNullSpace.
>>>> Mark made some GAMG changes which were later reversed because they had
>>>> unintended consequences like this.
>>>> I think what Barry means is, "you should get the behavior you expect
>>>> using the master branch from PETSc development"
>>>>   Thanks,
>>>>      Matt
>>>>> On Tue, Sep 29, 2015 at 1:04 PM, Barry Smith <bsmith at mcs.anl.gov>
>>>>> wrote:
>>>>>>   Update your PETSc
>>>>>> > On Sep 29, 2015, at 12:00 PM, Gil Forsyth <gforsyth at gwu.edu> wrote:
>>>>>> > Hi Barry,
>>>>>> > We aren't explicitly setting GMRES anywhere in the code and I'm not
>>>>>> sure why it's being used.  Running our 3.5.4 code using KSPSetNullSpace
>>>>>> works with:
>>>>>> > $PETIBM_DIR/petibm3.5/bin/petibm2d -directory . -poisson_pc_type
>>>>>> gamg -poisson_pc_gamg_type agg -poisson_pc_gamg_agg_nsmooths 1
>>>>>> -poisson_ksp_view -poisson_ksp_monitor_true_residual
>>>>>> -poisson_ksp_converged_reason > kspview3.5.4
>>>>>> > and shows that the coarse grid solver is of type:preonly
>>>>>> > running the newer version that uses MatSetNullSpace in its stead
>>>>>> and adding in -poisson_mg_coarse_ksp_type preonly
>>>>>> > $PETIBM_DIR/petibm3.6/bin/petibm2d -directory . -poisson_pc_type
>>>>>> -poisson_mg_coarse_ksp_type preonly -poisson_ksp_view
>>>>>> -poisson_ksp_monitor_true_residual -poisson_ksp_converged_reason >
>>>>>> kspview3.6.1
>>>>>> > still shows
>>>>>> > KSP Object:(poisson_) 1 MPI processes
>>>>>> >   type: cg
>>>>>> >   maximum iterations=10000
>>>>>> >   tolerances:  relative=1e-05, absolute=1e-50, divergence=10000
>>>>>> >   left preconditioning
>>>>>> >   using nonzero initial guess
>>>>>> >   using PRECONDITIONED norm type for convergence test
>>>>>> > PC Object:(poisson_) 1 MPI processes
>>>>>> >   type: gamg
>>>>>> >     MG: type is MULTIPLICATIVE, levels=3 cycles=v
>>>>>> >       Cycles per PCApply=1
>>>>>> >       Using Galerkin computed coarse grid matrices
>>>>>> >       GAMG specific options
>>>>>> >         Threshold for dropping small values from graph 0
>>>>>> >         AGG specific options
>>>>>> >           Symmetric graph false
>>>>>> >   Coarse grid solver -- level -------------------------------
>>>>>> >     KSP Object:    (poisson_mg_coarse_)     1 MPI processes
>>>>>> >       type: gmres
>>>>>> >         GMRES: restart=30, using Classical (unmodified)
>>>>>> Gram-Schmidt Orthogonalization with no iterative refinement
>>>>>> >         GMRES: happy breakdown tolerance 1e-30
>>>>>> >       maximum iterations=1, initial guess is zero
>>>>>> >       using NONE norm type for convergence test
>>>>>> > both logs are attached.
>>>>>> > On Tue, Sep 29, 2015 at 12:37 PM, Barry Smith <bsmith at mcs.anl.gov>
>>>>>> wrote:
>>>>>> >    This can't work. You can't use a GMRES inside a CG.   Try
>>>>>> changing to -poisson_mg_coarse_ksp_type preonly
>>>>>> >   type: cg
>>>>>> >       type: gmres
>>>>>> > > On Sep 29, 2015, at 10:53 AM, Gil Forsyth <gforsyth at gwu.edu>
>>>>>> wrote:
>>>>>> > > On Tue, Sep 29, 2015 at 11:42 AM, Matthew Knepley <
>>>>>> knepley at gmail.com> wrote:
>>>>>> > > On Tue, Sep 29, 2015 at 10:28 AM, Gil Forsyth <gforsyth at gwu.edu>
>>>>>> wrote:
>>>>>> > > Hi all,
>>>>>> > > I've been having some trouble with what should be a relatively
>>>>>> simple update to an immersed boundary CFD solver from PETSc 3.5.4 to 3.6.1
>>>>>> > > I'm getting indefinite PC errors for a simple lid-driven cavity
>>>>>> test problem, 32x32 at Re 100
>>>>>> > > Under PETSc 3.5.4 using KSPSetNullSpace we used the following to
>>>>>> set the null space.  This is for a 2D Poisson system with no immersed
>>>>>> boundary and so the null space is the constant vector.
>>>>>> > >   MatNullSpace nsp;
>>>>>> > >   ierr = MatNullSpaceCreate(PETSC_COMM_WORLD, PETSC_TRUE, 0,
>>>>>> NULL, &nsp); CHKERRQ(ierr);
>>>>>> > >   ierr = KSPSetNullSpace(ksp2, nsp); CHKERRQ(ierr);
>>>>>> > >   ierr = MatNullSpaceDestroy(&nsp); CHKERRQ(ierr);
>>>>>> > > Clearly this has to happen in the reverse order, since ksp2 would
>>>>>> not be created yet.
>>>>>> > > For questions about solvers, we HAVE to see the complete output
>>>>>> of -ksp_view so we
>>>>>> > > know what we are dealing with. Its also nice to have
>>>>>> -ksp_monitor_true_residual -ksp_converged_reason
>>>>>> > >   Matt
>>>>>> > > Yes -- sorry, those are both in inline files and are called in
>>>>>> the reverse order that I wrote them out.
>>>>>> > > I've attached the output of
>>>>>> gamg -poisson_pc_gamg_type agg -poisson_gamg_agg_nsmooths 1
>>>>>> -poisson_ksp_converged_reason > kspview.log
>>>>>> > > And then setup the KSP with
>>>>>> > >   ierr = KSPCreate(PETSC_COMM_WORLD, &ksp2); CHKERRQ(ierr);
>>>>>> > >   ierr = KSPSetOptionsPrefix(ksp2, "poisson_"); CHKERRQ(ierr);
>>>>>> > >   ierr = KSPSetOperators(ksp2, QTBNQ, QTBNQ); CHKERRQ(ierr);
>>>>>> > >   ierr = KSPSetInitialGuessNonzero(ksp2, PETSC_TRUE);
>>>>>> CHKERRQ(ierr);
>>>>>> > >   ierr = KSPSetType(ksp2, KSPCG); CHKERRQ(ierr);
>>>>>> > >   ierr = KSPSetReusePreconditioner(ksp2, PETSC_TRUE);
>>>>>> CHKERRQ(ierr);
>>>>>> > >   ierr = KSPSetFromOptions(ksp2); CHKERRQ(ierr);
>>>>>> > > The matrix QTBNQ does not change, only the rhs of the system is
>>>>>> updated.
>>>>>> > > We run this with `-pc_type gamg -pc_gamg_type agg
>>>>>> -pc_gamg_agg_nsmooths 1` and everything seems to work as expected.
>>>>>> > > Under PETSc 3.6.1, we change only the KSPSetNullSpace line, to
>>>>>> > >   ierr = MatSetNullSpace(QTBNQ, nsp); CHKERRQ(ierr);
>>>>>> > > and the same code diverges after 1 timestep and returns a -8
>>>>>> > > This is weird, especially because if we change nsmooths to 2, it
>>>>>> runs for 264 timesteps and the returns the same error.  But we have
>>>>>> explicitly set KSPSetReusePreconditioner so it should be using the same PC,
>>>>>> right?
>>>>>> > > Change nsmooths to 3 and it again diverges after 1 timestep.
>>>>>> > > Change nsmooths to 4 and it runs to completion.
>>>>>> > > It seems like either gamg's behavior has changed, or that
>>>>>> KSPSetNullSpace was doing something implicitly that we now need to do
>>>>>> explicitly in addition to MatSetNullSpace?
>>>>>> > > Thanks,
>>>>>> > > Gil Forsyth
>>>>>> > > What most experimenters take for granted before they begin their
>>>>>> experiments is infinitely more interesting than any results to which their
>>>>>> experiments lead.
>>>>>> > > -- Norbert Wiener
>>>>>> > > <kspview.log>
>>>>>> > <kspview3.5.4><kspview3.6.1>
>>>> experiments lead.
>>>> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20151001/69ce2e07/attachment-0001.html>
Type: text/x-log
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20151001/69ce2e07/attachment-0002.bin>
Type: text/x-log
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20151001/69ce2e07/attachment-0003.bin>
