[petsc-users] Moving from KSPSetNullSpace to MatSetNullSpace
Gil Forsyth gforsyth at gwu.edu
Thu Oct 1 15:27:23 CDT 2015
Hi Mark,
I just noticed that in the previous commit 7743f89, it's also using GMRES
in the multigrid solve but doesn't complain until the 2nd timestep, so my
bisection criteria is off, since I was giving commits a PASS if they made
it through the one timestep without complaining about the indefinite PC. I
think I'm still close to the problem commit, but it's probably a little bit
before 25a145a.  Apologies for the goose chase.
Gil Forsyth
On Thu, Oct 1, 2015 at 4:21 PM, Gil Forsyth <gforsyth at gwu.edu> wrote:
> I ran for one timestep against 3.5.4 with
> #+BEGIN_SRC
> petibm-3.5.4/bin/petibm2d -directory examples/2d/lidDrivenCavity/Re100
> -poisson_pc_type gamg -poisson_pc_gamg_type agg
> -poisson_pc_gamg_agg_nsmooths 1 -poisson_ksp_view
> -poisson_ksp_monitor_true_residual -poisson_ksp_converged_reason -info >
> kspview_3.5.4.log
> #+END_SRC
> and then against 25a145a with the same inputs.  I notice that the poisson
> multigrid solve in 25a145a is using GMRES again while 3.5.4 is using
> preonly.
> Logs from both runs are attached.
> On Thu, Oct 1, 2015 at 3:52 PM, Mark Adams <mfadams at lbl.gov> wrote:
>> Can you please send a good log also, with the ksp_view.
>> Mark
>> On Wed, Sep 30, 2015 at 3:11 PM, Gil Forsyth <gforsyth at gwu.edu> wrote:
>>> Using PETSc master branch solved the problem in serial, but I'm still
>>> seeing the same KSP_DIVERGED_INDEFINITE_PC error when I run with MPI.  This
>>> runs to completion when I don't use GAMG.  Log is attached for the
>>> following run.
>>> $PETSC_DIR/$PETSC_ARCH/bin/mpirun -n 2
>>> $PETIBM_DIR/petibm-git/bin/petibm2d -directory . -poisson_pc_type gamg
>>> -poisson_pc_gamg_type agg -poisson_pc_gamg_agg_nsmooths 1 -poisson_ksp_view
>>> Thanks again,
>>> Gil Forsyth
>>> On Tue, Sep 29, 2015 at 1:12 PM, Gil Forsyth <gforsyth at gwu.edu> wrote:
>>>> Ah, got it.  I'll checkout the master branch and see if the behavior
>>>> persists.
>>>> Many thanks,
>>>> Gil
>>>> On Tue, Sep 29, 2015 at 1:10 PM, Matthew Knepley <knepley at gmail.com>
>>>> wrote:
>>>>> On Tue, Sep 29, 2015 at 12:08 PM, Gil Forsyth <gforsyth at gwu.edu>
>>>>> wrote:
>>>>>> PETSc is version 3.6.1 -- I just included a log from 3.5.4 to show
>>>>>> that the behavior seems to have changed between versions.  The only
>>>>>> difference in our code between 3.5.4 and 3.6.1 is the change from
>>>>>> KSPSetNullSpace to MatSetNullSpace.
>>>>> Mark made some GAMG changes which were later reversed because they had
>>>>> unintended consequences like this.
>>>>> I think what Barry means is, "you should get the behavior you expect
>>>>> using the master branch from PETSc development"
>>>>>   Thanks,
>>>>>      Matt
>>>>>> On Tue, Sep 29, 2015 at 1:04 PM, Barry Smith <bsmith at mcs.anl.gov>
>>>>>> wrote:
>>>>>>>   Update your PETSc
>>>>>>> > On Sep 29, 2015, at 12:00 PM, Gil Forsyth <gforsyth at gwu.edu>
>>>>>>> wrote:
>>>>>>> > Hi Barry,
>>>>>>> > We aren't explicitly setting GMRES anywhere in the code and I'm
>>>>>>> not sure why it's being used.  Running our 3.5.4 code using KSPSetNullSpace
>>>>>>> works with:
>>>>>>> > $PETIBM_DIR/petibm3.5/bin/petibm2d -directory . -poisson_pc_type
>>>>>>> gamg -poisson_pc_gamg_type agg -poisson_pc_gamg_agg_nsmooths 1
>>>>>>> -poisson_ksp_view -poisson_ksp_monitor_true_residual
>>>>>>> -poisson_ksp_converged_reason > kspview3.5.4
>>>>>>> > and shows that the coarse grid solver is of type:preonly
>>>>>>> > running the newer version that uses MatSetNullSpace in its stead
>>>>>>> and adding in -poisson_mg_coarse_ksp_type preonly
>>>>>>> > $PETIBM_DIR/petibm3.6/bin/petibm2d -directory . -poisson_pc_type
>>>>>>> -poisson_mg_coarse_ksp_type preonly -poisson_ksp_view
>>>>>>> -poisson_ksp_monitor_true_residual -poisson_ksp_converged_reason >
>>>>>>> kspview3.6.1
>>>>>>> > still shows
>>>>>>> > KSP Object:(poisson_) 1 MPI processes
>>>>>>> >   type: cg
>>>>>>> >   maximum iterations=10000
>>>>>>> >   tolerances:  relative=1e-05, absolute=1e-50, divergence=10000
>>>>>>> >   left preconditioning
>>>>>>> >   using nonzero initial guess
>>>>>>> >   using PRECONDITIONED norm type for convergence test
>>>>>>> > PC Object:(poisson_) 1 MPI processes
>>>>>>> >   type: gamg
>>>>>>> >     MG: type is MULTIPLICATIVE, levels=3 cycles=v
>>>>>>> >       Cycles per PCApply=1
>>>>>>> >       Using Galerkin computed coarse grid matrices
>>>>>>> >       GAMG specific options
>>>>>>> >         Threshold for dropping small values from graph 0
>>>>>>> >         AGG specific options
>>>>>>> >           Symmetric graph false
>>>>>>> >   Coarse grid solver -- level -------------------------------
>>>>>>> >     KSP Object:    (poisson_mg_coarse_)     1 MPI processes
>>>>>>> >       type: gmres
>>>>>>> >         GMRES: restart=30, using Classical (unmodified)
>>>>>>> Gram-Schmidt Orthogonalization with no iterative refinement
>>>>>>> >         GMRES: happy breakdown tolerance 1e-30
>>>>>>> >       maximum iterations=1, initial guess is zero
>>>>>>> >       using NONE norm type for convergence test
>>>>>>> > both logs are attached.
>>>>>>> > On Tue, Sep 29, 2015 at 12:37 PM, Barry Smith <bsmith at mcs.anl.gov>
>>>>>>> wrote:
>>>>>>> >    This can't work. You can't use a GMRES inside a CG.   Try
>>>>>>> changing to -poisson_mg_coarse_ksp_type preonly
>>>>>>> >   type: cg
>>>>>>> >       type: gmres
>>>>>>> > > On Sep 29, 2015, at 10:53 AM, Gil Forsyth <gforsyth at gwu.edu>
>>>>>>> wrote:
>>>>>>> > > On Tue, Sep 29, 2015 at 11:42 AM, Matthew Knepley <
>>>>>>> knepley at gmail.com> wrote:
>>>>>>> > > On Tue, Sep 29, 2015 at 10:28 AM, Gil Forsyth <gforsyth at gwu.edu>
>>>>>>> wrote:
>>>>>>> > > Hi all,
>>>>>>> > > I've been having some trouble with what should be a relatively
>>>>>>> simple update to an immersed boundary CFD solver from PETSc 3.5.4 to 3.6.1
>>>>>>> > > I'm getting indefinite PC errors for a simple lid-driven cavity
>>>>>>> test problem, 32x32 at Re 100
>>>>>>> > > Under PETSc 3.5.4 using KSPSetNullSpace we used the following to
>>>>>>> set the null space.  This is for a 2D Poisson system with no immersed
>>>>>>> boundary and so the null space is the constant vector.
>>>>>>> > >   MatNullSpace nsp;
>>>>>>> > >   ierr = MatNullSpaceCreate(PETSC_COMM_WORLD, PETSC_TRUE, 0,
>>>>>>> NULL, &nsp); CHKERRQ(ierr);
>>>>>>> > >   ierr = KSPSetNullSpace(ksp2, nsp); CHKERRQ(ierr);
>>>>>>> > >   ierr = MatNullSpaceDestroy(&nsp); CHKERRQ(ierr);
>>>>>>> > > Clearly this has to happen in the reverse order, since ksp2
>>>>>>> would not be created yet.
>>>>>>> > > For questions about solvers, we HAVE to see the complete output
>>>>>>> of -ksp_view so we
>>>>>>> > > know what we are dealing with. Its also nice to have
>>>>>>> -ksp_monitor_true_residual -ksp_converged_reason
>>>>>>> > >   Matt
>>>>>>> > > Yes -- sorry, those are both in inline files and are called in
>>>>>>> the reverse order that I wrote them out.
>>>>>>> > > I've attached the output of
>>>>>>> gamg -poisson_pc_gamg_type agg -poisson_gamg_agg_nsmooths 1
>>>>>>> -poisson_ksp_converged_reason > kspview.log
>>>>>>> > > And then setup the KSP with
>>>>>>> > >   ierr = KSPCreate(PETSC_COMM_WORLD, &ksp2); CHKERRQ(ierr);
>>>>>>> > >   ierr = KSPSetOptionsPrefix(ksp2, "poisson_"); CHKERRQ(ierr);
>>>>>>> > >   ierr = KSPSetOperators(ksp2, QTBNQ, QTBNQ); CHKERRQ(ierr);
>>>>>>> > >   ierr = KSPSetInitialGuessNonzero(ksp2, PETSC_TRUE);
>>>>>>> CHKERRQ(ierr);
>>>>>>> > >   ierr = KSPSetType(ksp2, KSPCG); CHKERRQ(ierr);
>>>>>>> > >   ierr = KSPSetReusePreconditioner(ksp2, PETSC_TRUE);
>>>>>>> CHKERRQ(ierr);
>>>>>>> > >   ierr = KSPSetFromOptions(ksp2); CHKERRQ(ierr);
>>>>>>> > > The matrix QTBNQ does not change, only the rhs of the system is
>>>>>>> updated.
>>>>>>> > > We run this with `-pc_type gamg -pc_gamg_type agg
>>>>>>> -pc_gamg_agg_nsmooths 1` and everything seems to work as expected.
>>>>>>> > > Under PETSc 3.6.1, we change only the KSPSetNullSpace line, to
>>>>>>> > >   ierr = MatSetNullSpace(QTBNQ, nsp); CHKERRQ(ierr);
>>>>>>> > > and the same code diverges after 1 timestep and returns a -8
>>>>>>> > > This is weird, especially because if we change nsmooths to 2, it
>>>>>>> runs for 264 timesteps and the returns the same error.  But we have
>>>>>>> explicitly set KSPSetReusePreconditioner so it should be using the same PC,
>>>>>>> right?
>>>>>>> > > Change nsmooths to 3 and it again diverges after 1 timestep.
>>>>>>> > > Change nsmooths to 4 and it runs to completion.
>>>>>>> > > It seems like either gamg's behavior has changed, or that
>>>>>>> KSPSetNullSpace was doing something implicitly that we now need to do
>>>>>>> explicitly in addition to MatSetNullSpace?
>>>>>>> > > Thanks,
>>>>>>> > > Gil Forsyth
>>>>>>> > > What most experimenters take for granted before they begin their
>>>>>>> experiments is infinitely more interesting than any results to which their
>>>>>>> experiments lead.
>>>>>>> > > -- Norbert Wiener
>>>>>>> > > <kspview.log>
>>>>>>> > <kspview3.5.4><kspview3.6.1>
>>>>> experiments lead.
>>>>> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20151001/a74c9263/attachment.html>
