[petsc-users] PETSC error: Caught signal number 8 FPE
Mon Nov 30 08:08:03 CST 2015
On Mon, Nov 30, 2015 at 7:59 AM, Soumya Mukherjee <soumyamechanics at gmail.com
> wrote:
> It is a PETSc error. And I just wanted to know if runs without an error in
> your machine.
This is not a PETSc error, as such. PETSc installs a signal handler so that
we can try and get more
information about signals. However, it is likely that you have a Floating
Point Exception, like a divide
by zero, in your user code.
     Matt
> On Nov 30, 2015 4:34 AM, "Jose E. Roman" <jroman at dsic.upv.es> wrote:
> > I am not going to run your code. We are not a free debugging service.
> You have to debug the code yourself, and let us know only if the issue is
> related to the SLEPc library. Start adding error checking code with the
> CHKERRQ macro to all PETSc/SLEPc calls. This will catch most errors. It no
> errors are detected, then run with a debugger such as gdb or valgrind to
> determine the exact point where the program fails.
> > Jose
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20151130/9d2004eb/attachment.html>
