[petsc-users] PETSC error: Caught signal number 8 FPE
Soumya Mukherjee soumyamechanics at gmail.com
Mon Nov 30 14:43:35 CST 2015
Thanks for the reply.
The error message shows
[0]PETSC ERROR: Invalid argument
[0]PETSC ERROR: Scalar value must be same on all processes, argument # 3
[0]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html for
trouble shooting.
[0]PETSC ERROR: Petsc Release Version 3.6.1, Jul, 22, 2015
[0]PETSC ERROR: ./main on a arch-linux2-cxx-debug named
soumya-OptiPlex-9010 by soumya Mon Nov 30 12:30:28 2015
[0]PETSC ERROR: Configure options --with-cc=gcc --with-fc=gfortran
--with-cxx=g++ --with-clanguage=cxx --download-fblaslapack --download-mpich
--with-scalar-type=complex
[0]PETSC ERROR: #1016 BVScaleColumn() line 380 in
/home/soumya/slepc-3.6.0/src/sys/classes/bv/interface/bvops.c
[0]PETSC ERROR: #1017 EPSBasicArnoldi() line 65 in
/home/soumya/slepc-3.6.0/src/eps/impls/krylov/epskrylov.c
[0]PETSC ERROR: #1018 EPSSolve_KrylovSchur_Default() line 201 in
/home/soumya/slepc-3.6.0/src/eps/impls/krylov/krylovschur/krylovschur.c
[0]PETSC ERROR: #1019 EPSSolve() line 101 in
/home/soumya/slepc-3.6.0/src/eps/interface/epssolve.c
[0]PETSC ERROR: --------------------- Error Message
[0]PETSC ERROR: Object is in wrong state
[0]PETSC ERROR: Must call EPSSolve() first: Parameter #1
trouble shooting.
[0]PETSC ERROR: #1020 EPSGetConverged() line 236 in
trouble shooting.
[0]PETSC ERROR: #1021 EPSGetEigenpair() line 378 in
trouble shooting.
[0]PETSC ERROR: #1022 EPSGetEigenpair() line 378 in
On Mon, Nov 30, 2015 at 9:08 AM, Matthew Knepley <knepley at gmail.com> wrote:
> On Mon, Nov 30, 2015 at 7:59 AM, Soumya Mukherjee <
> soumyamechanics at gmail.com> wrote:
>> It is a PETSc error. And I just wanted to know if runs without an error
>> in your machine.
> This is not a PETSc error, as such. PETSc installs a signal handler so
> that we can try and get more
> information about signals. However, it is likely that you have a Floating
> Point Exception, like a divide
> by zero, in your user code.
>   Thanks,
>      Matt
>> On Nov 30, 2015 4:34 AM, "Jose E. Roman" <jroman at dsic.upv.es> wrote:
>> > I am not going to run your code. We are not a free debugging service.
>> You have to debug the code yourself, and let us know only if the issue is
>> related to the SLEPc library. Start adding error checking code with the
>> CHKERRQ macro to all PETSc/SLEPc calls. This will catch most errors. It no
>> errors are detected, then run with a debugger such as gdb or valgrind to
>> determine the exact point where the program fails.
>> > Jose
> experiments lead.
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20151130/3817e03c/attachment.html>
