[petsc-users] problem compiling
Randall Mackie rlmackie862 at gmail.com
Thu Nov 26 12:22:18 CST 2015
Thanks Satish,
Turns out it was a local system problem that has now been resolved.
Randy M.
> On Nov 26, 2015, at 9:40 AM, Satish Balay <balay at mcs.anl.gov> wrote:
> Its always best to send logs so that we know whats hapenning. To be
> sure - you can try a clean build.
> Satish
> On Thu, 26 Nov 2015, Randall Mackie wrote:
>> I was trying to recompile PETSc using superlu_dist on a linux system, and I had configure download the necessary packages, and the configure went fine.
>> Compilation bombed out with the error message:
>> /usr/bin/ld cannot find -ldat
>> this came immediately after the ztaulinesearch compile in the make.log.
>> I thought before I mailed off the make.log to petsc-maint I would see if anyone knew the issue here.
>> Thanks,
>> Randy M.
