[petsc-users] problem compiling
Thu Nov 26 11:40:27 CST 2015
Its always best to send logs so that we know whats hapenning. To be
sure - you can try a clean build.
Satish
On Thu, 26 Nov 2015, Randall Mackie wrote:
> I was trying to recompile PETSc using superlu_dist on a linux system, and I had configure download the necessary packages, and the configure went fine.
> Compilation bombed out with the error message:
> /usr/bin/ld cannot find -ldat
> this came immediately after the ztaulinesearch compile in the make.log.
> I thought before I mailed off the make.log to petsc-maint I would see if anyone knew the issue here.
> Thanks,
> Randy M.
