[petsc-users] question about MPI_Bcast and 64-bit-indices
Randall Mackie rlmackie862 at gmail.com
Fri Nov 27 12:00:18 CST 2015
If my program is compiled using 64-bit-indices, and I have an integer variable defined as PetscInt, what is the right way to broadcast that using MPI_Bcast?
I currently have:
call MPI_Bcast(n, 1, MPI_INTEGER, …
which is the right way to do it for regular integers, but what do I use in place of MPI_INTEGER when Petsc is compiled with 64-bit-indices.
Randy M.
