[petsc-users] problem compiling
Randall Mackie rlmackie862 at gmail.com
Thu Nov 26 11:01:04 CST 2015
I was trying to recompile PETSc using superlu_dist on a linux system, and I had configure download the necessary packages, and the configure went fine.
Compilation bombed out with the error message:
/usr/bin/ld cannot find -ldat
this came immediately after the ztaulinesearch compile in the make.log.
I thought before I mailed off the make.log to petsc-maint I would see if anyone knew the issue here.
Randy M.
