[petsc-users] GAMG and zero pivots follow up
Fri Nov 13 13:48:50 CST 2015
On Fri, Nov 13, 2015 at 12:28 PM, Jed Brown <jed at jedbrown.org> wrote:
> Matthew Knepley <knepley at gmail.com> writes:
> > Something very strange is happening here. CG should converge
> monotonically,
> > but above it does not. What could be happening?
> Are you use -ksp_norm_type natural?  CG is not monotone in other norms.
Yikes! I did not check that. Why do we have PRECONDITIONED as the default
for CG?
   Matt
Also, if boundary conditions are enforced using a nonsymmetric
> formulation (for example), then you can get lack of monotonicity with CG
> that may not be catastrophic.
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20151113/3ad0c28d/attachment.html>
