[petsc-users] GAMG and zero pivots follow up
Jed Brown jed at jedbrown.org
Fri Nov 13 12:28:59 CST 2015
Matthew Knepley <knepley at gmail.com> writes:
> Something very strange is happening here. CG should converge monotonically,
> but above it does not. What could be happening?
Are you use -ksp_norm_type natural?  CG is not monotone in other norms.
Also, if boundary conditions are enforced using a nonsymmetric
formulation (for example), then you can get lack of monotonicity with CG
that may not be catastrophic.
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20151113/3e76c9be/attachment.pgp>
