[petsc-users] MUMPS with symmetric matrices
Jed Brown jed at jedbrown.org
Wed Nov 4 15:16:35 CST 2015
Gianluca Meneghello <gianmail at gmail.com> writes:
> That is correct... I will try with -pc_type cholesky and use
> MatTransposeMatMult.
> Using cholesky I do not need to specify mumps as a solver, am I right?
Of course you do.
> A is a linearization of the Navier Stokes equation.
Of the differential operator, its inverse, or a map from some parameters
to observations?
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20151104/0076b596/attachment.pgp>
